16-安全命令参考
13-攻击检测与防范命令
本章节下载: 13-攻击检测与防范命令  (1013.84 KB)
13-攻击检测与防范命令
1 攻击检测与防范
1.1 攻击检测与防范配置命令
1.1.1 ack-flood action
1.1.2 ack-flood detect
1.1.3 ack-flood detect non-specific
1.1.4 ack-flood threshold
1.1.5 ack-flood source-threshold
1.1.6 attack-defense apply policy
1.1.7 attack-defense local apply policy
1.1.8 attack-defense login block-timeout
1.1.9 attack-defense login enable
1.1.10 attack-defense login max-attempt
1.1.11 attack-defense login reauthentication-delay
1.1.12 attack-defense policy
1.1.13 attack-defense signature log non-aggregate
1.1.14 attack-defense tcp fragment enable
1.1.15 attack-defense top-attack-statistics enable
1.1.16 blacklist global enable
1.1.17 display attack-defense flood statistics ip
1.1.18 display attack-defense flood statistics ipv6
1.1.19 display attack-defense http-slow-attack statistics ip
1.1.20 display attack-defense http-slow-attack statistics ipv6
1.1.21 display attack-defense policy
1.1.22 display attack-defense policy ip
1.1.23 display attack-defense policy ipv6
1.1.24 display attack-defense scan attacker ip
1.1.25 display attack-defense scan attacker ipv6
1.1.26 display attack-defense statistics interface
1.1.27 display attack-defense statistics local
1.1.28 display attack-defense top-attack-statistics
1.1.29 dns-flood action
1.1.30 dns-flood detect
1.1.31 dns-flood detect non-specific
1.1.32 dns-flood port
1.1.33 dns-flood threshold
1.1.34 dns-flood source-threshold
1.1.35 dns-reply-flood action
1.1.36 dns-reply-flood detect
1.1.37 dns-reply-flood detect non-specific
1.1.38 dns-reply-flood port
1.1.39 dns-reply-flood threshold
1.1.40 dns-reply-flood source-threshold
1.1.41 exempt acl
1.1.42 fin-flood action
1.1.43 fin-flood detect
1.1.44 fin-flood detect non-specific
1.1.45 fin-flood threshold
1.1.46 fin-flood source-threshold
1.1.47 http-flood action
1.1.48 http-flood detect
1.1.49 http-flood detect non-specific
1.1.50 http-flood port
1.1.51 http-flood threshold
1.1.52 http-flood source-threshold
1.1.53 http-slow-attack action
1.1.54 http-slow-attack detect
1.1.55 http-slow-attack detect non-specific
1.1.56 http-slow-attack period
1.1.57 http-slow-attack port
1.1.58 http-slow-attack threshold
1.1.59 https-flood action
1.1.60 https-flood detect
1.1.61 https-flood detect non-specific
1.1.62 https-flood port
1.1.63 https-flood threshold
1.1.64 https-flood source-threshold
1.1.65 icmp-flood action
1.1.66 icmp-flood detect ip
1.1.67 icmp-flood detect non-specific
1.1.68 icmp-flood threshold
1.1.69 icmp-flood source-threshold
1.1.70 icmpv6-flood action
1.1.71 icmpv6-flood detect ipv6
1.1.72 icmpv6-flood detect non-specific
1.1.73 icmpv6-flood threshold
1.1.74 icmpv6-flood source-threshold
1.1.75 reset attack-defense policy flood
1.1.76 reset attack-defense statistics interface
1.1.77 reset attack-defense statistics local
1.1.78 reset attack-defense top-attack-statistics
1.1.79 rst-flood action
1.1.80 rst-flood detect
1.1.81 rst-flood detect non-specific
1.1.82 rst-flood threshold
1.1.83 rst-flood source-threshold
1.1.84 scan detect
1.1.85 signature { large-icmp | large-icmpv6 } max-length
1.1.86 signature detect
1.1.87 signature level action
1.1.88 signature level detect
1.1.89 sip-flood action
1.1.90 sip-flood detect
1.1.91 sip-flood detect non-specific
1.1.92 sip-flood port
1.1.93 sip-flood threshold
1.1.94 sip-flood source-threshold
1.1.95 syn-ack-flood action
1.1.96 syn-ack-flood detect
1.1.97 syn-ack-flood detect non-specific
1.1.98 syn-ack-flood threshold
1.1.99 syn-ack-flood source-threshold
1.1.100 syn-flood action
1.1.101 syn-flood detect
1.1.102 syn-flood detect non-specific
1.1.103 syn-flood threshold
1.1.104 syn-flood source-threshold
1.1.105 threshold-learn apply
1.1.106 threshold-learn auto-apply enable
1.1.107 threshold-learn duration
1.1.108 threshold-learn enable
1.1.109 threshold-learn interval
1.1.110 threshold-learn mode
1.1.111 threshold-learn tolerance-value
1.1.112 udp-flood action
1.1.113 udp-flood detect
1.1.114 udp-flood detect non-specific
1.1.115 udp-flood threshold
1.1.116 udp-flood source-threshold
1 攻击检测与防范
1.1  攻击检测与防范配置命令
ack-flood action命令用来配置ACK flood攻击防范的全局处理行为。
undo ack-flood action命令用来恢复缺省情况。
ack-flood action { drop | logging } *
不对检测到的ACK flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文。对于基于源IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃源自攻击者的后续所有ACK报文;对于基于目的IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃向被攻击者发送的后续所有ACK报文。
logging:表示输出告警日志,即设备检测到攻击发生时,生成告警信息,生成的告警信息将被发送到日志系统。
输出告警日志功能开启后,设备生成的告警日志信息不会输出到控制台和监视终端,可通过执行display logbuffer命令进行查看。有关display logbuffer命令的详细介绍,请参见“设备管理命令参考”中的“信息中心”。
# 在攻击防范策略atk-policy-1中配置ACK flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname] attack-defense policy atk-policy-1
[Sysname-attack-defense-policy-atk-policy-1] ack-flood action drop
·     ack-flood detect
·     ack-flood detect non-specific
·     ack-flood source-threshold
·     ack-flood threshold
ack-flood detect命令用来开启对指定IP地址的ACK flood攻击防范检测,并配置ACK flood攻击防范的触发阈值和对ACK flood攻击的处理行为。
undo ack-flood detect命令用来关闭对指定IP地址的ACK flood攻击防范检测。
ack-flood detect { ip ipv4-address | ipv6 ipv6-address } [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo ack-flood detect { ip ipv4-address | ipv6 ipv6-address }
未对任何指定IP地址开启ACK flood攻击防范检测。
攻击防范策略视图
ip ipv4-address:指定要保护的IPv4地址。该IPv4地址不能为255.255.255.255或0.0.0.0。
ipv6 ipv6-address:指定要保护的IPv6地址。该IPv6地址不能为组播地址或::。
threshold threshold-value:指定ACK flood攻击防范基于目的IP统计的触发阈值。其中,threshold-value为向指定IP地址每秒发送的ACK报文数目,取值范围为1~1000000。
action:设置对ACK flood攻击的处理行为。若未指定本参数,则表示采用ACK flood攻击防范的全局处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有ACK报文都会被丢弃。
none:表示不采取任何动作。
使能ACK flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送ACK报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了ACK flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置ACK flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的ACK flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的ACK报文数持续达到或超过2000时,启动ACK flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] ack-flood detect ip 192.168.1.2 threshold 2000
·     ack-flood action
ack-flood detect non-specific命令用来对所有非受保护IP地址开启ACK flood攻击防范检测。
undo ack-flood detect non-specific命令用来关闭对所有非受保护IP地址的ACK flood攻击防范检测。
未对任何非受保护IP地址开启ACK flood攻击防范检测。
攻击防范策略视图
对所有未配置具体攻击防范策略的IP地址开启ACK flood攻击防范检测后,设备将采用全局的阈值设置(由ack-flood threshold或ack-flood source-threshold命令设置)和处理行为(由ack-flood action命令配置)对这些IP地址进行保护或防御。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启ACK flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] ack-flood detect non-specific
·     ack-flood action
·     ack-flood detect
ack-flood threshold命令用来配置ACK flood攻击防范基于目的IP统计的全局触发阈值。
undo ack-flood threshold命令用来恢复缺省情况。
ack-flood threshold threshold-value
ACK flood攻击防范基于目的IP统计的全局触发阈值为40000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的ACK报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于目的IP地址的ACK flood攻击防范。
使能ACK flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送ACK报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了ACK flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置ACK flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的ACK报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置ACK flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的ACK报文数持续达到或超过100时,启动ACK flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] ack-flood threshold 100
·     ack-flood action
·     ack-flood detect
ack-flood source-threshold命令用来配置ACK flood攻击防范基于源IP统计的全局触发阈值。
undo ack-flood source-threshold命令用来恢复缺省情况。
ack-flood source-threshold threshold-value
ACK flood攻击防范基于源IP统计的全局触发阈值为40000。
攻击防范策略视图
threshold-value:指定每秒接收到从某IP地址发出的ACK报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于源IP统计的ACK flood攻击防范。
使能ACK flood攻击防范后,设备处于攻击检测状态,当它监测到某IP地址发送的ACK报文的速率持续达到或超过了该触发阈值时,即认为该IP地址发起了ACK flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到该IP地址发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中配置ACK flood攻击防范基于源IP统计的全局触发阈值为100,即当设备监测到某IP地址每秒发送的ACK报文数持续达到或超过100时,启动ACK flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] ack-flood source-threshold 100
·     ack-flood action
·     ack-flood detect
attack-defense apply policy命令用来在接口上应用攻击防范策略。
undo attack-defense apply policy命令用来恢复缺省情况。
attack-defense apply policy policy-name
接口上未应用任何攻击防范策略。
policy-name:攻击防范策略名称,为1~31个字符的字符串,不区分大小写。合法取值包括大写字母、小写字母、数字、特殊字符“_”和“-”。
一个接口上只能应用一个攻击防范策略(可多次配置,最后一次配置的有效),但一个攻击防范策略可应用到多个接口上。
# 将攻击防范策略atk-policy-1应用到接口Vlan-interface100上。
[Sysname-Vlan-interface100] attack-defense apply policy atk-policy-1
·     attack-defense policy
·     display attack-defense policy
attack-defense local apply policy命令用来在本机应用安全攻击防范策略。
undo attack-defense local apply policy命令用来恢复缺省情况。
attack-defense local apply policy policy-name
本机未应用任何攻击防范策略。
通过在本机应用攻击防范策略,使已配置的攻击防范策略对目的地址为本机的报文生效。
可以通过在本机上应用攻击防范策略提高对目的地址为本机的攻击报文的处理效率。
本机只能应用一个攻击防范策略(可多次配置,最后一次配置的有效),但一个攻击防范策略除了可以应用到本机外,还可应用到多个接口上。
当同时在接口和本机应用攻击防范策略时,目的地址是本机的报文到达设备后,将会被根据应用在接口上的策略和应用在本机的策略先后检测两次。
# 在本机应用攻击防范策略atk-policy-1。
[Sysname] attack-defense local apply policy atk-policy-1
attack-defense login block-timeout命令用来配置Login用户登录失败后阻断时长。
undo attack-defense login block-timeout命令用来恢复缺省情况。
attack-defense login block-timeout minutes
Login用户登录失败后默认阻断时长为60分钟。
minutes:设备管理用户登录失败后阻断时长,取值范围为1~2880,单位为分钟。
Login用户登录失败后,若用户的IP地址被加入黑名单,则设备将会丢弃来自该IP地址的报文,使得该用户不能在指定的阻断时长内进行登录操作。
# 配置Login用户登录失败后阻断时长为5分钟。
[Sysname] attack-defense login block-timeout 5
·     attack-defense login enable
·     blacklist global enable
attack-defense login enable命令用来开启Login用户攻击防范功能。
undo attack-defense login enable命令用来关闭Login用户攻击防范功能。
Login用户攻击防范功能处于关闭状态。
开启Login用户攻击防范功能后,如果用户登录设备连续失败的次数达到指定次数,则此用户IP将被加入黑名单,并在指定时间内不能进行登录。
将Login用户加入黑名单进行阻断的功能必须在全局黑名单过滤功能处于开启状态时才能生效。
# 开启Login用户攻击防范功能。
[Sysname] attack-defense login enable
attack-defense login max-attempt命令用来配置Login用户登录失败的最大次数。
undo attack-defense login max-attempt命令用来恢复缺省情况。
attack-defense login max-attempt max-attempt
Login用户登录失败的最大次数为3次。
max-attempt:用户登录连续失败的最大次数,取值为1~60。
Login用户攻击防范功能处于开启状态时,如果用户登录设备连续失败的次数达到指定次数,则此用户IP地址将被加入黑名单,在全局黑名单功能开启的情况下,来自该IP地址的用户报文将被阻断指定的时长。
若用户成功登录或设备重启,用户登录失败次数会重新从零计数。
# 配置Login用户登录失败的最大次数为5次。
[Sysname] attack-defense login max-attempt 5
attack-defense login reauthentication-delay命令用来配置Login用户登录失败后重新进行认证的等待时长。
undo attack-defense login reauthentication-delay命令用来恢复缺省情况。
attack-defense login reauthentication-delay seconds
Login用户登录失败后重新进行认证不需要等待。
seconds:设备管理用户登录失败后重新进行认证的等待时长,取值范围为4~60,单位为秒。
Login用户登录失败后,若设备上配置了重新进行认证的等待时长,则系统将会延迟一定的时长之后再允许用户进行认证,可以避免设备受到字典式攻击。
Login用户延迟认证功能与Login用户攻击防范功能无关,只要配置了延迟认证等待时间,即可生效。
# 配置Login用户登录失败后重新进行认证的等待时长为5秒钟。
[Sysname] attack-defense login reauthentication-delay 5
attack-defense policy命令用来创建一个攻击防范策略,并进入攻击防范策略视图。如果指定的攻击防范策略已经存在,则直接进入攻击防范策略视图。
undo attack-defense policy命令用来删除指定的攻击防范策略。
attack-defense policy policy-name
undo attack-defense policy policy-name
不存在任何攻击防范策略。
攻击防范的缺省触发阈值对于现网环境而言可能过小,这会导致用户上网慢或者网页打不开等情况,请根据实际网络环境配置合理的触发阈值。
# 创建攻击防范策略atk-policy-1,并进入攻击防范策略视图。
·     attack-defense apply policy
attack-defense signature log non-aggregate命令用来指定对单包攻击防范日志非聚合输出。
undo attack-defense signature log non-aggregate命令用来恢复缺省情况。
单包攻击防范的日志信息经系统聚合后再输出。
对日志进行聚合输出是指,在一定时间内,对在本机或同一个接口上检测到的相同攻击类型、相同攻击防范动作、相同的源/目的地址的单包攻击的所有日志聚合成一条日志输出。通常不建议开启单包攻击防范的日志非聚合输出功能,因为在单包攻击较为频繁的情况下,它会导致大量日志信息输出,占用控制台的显示资源。
# 开启对单包攻击防范日志的非聚合输出功能。
[Sysname] attack-defense signature log non-aggregate
·     signature detect
attack-defense tcp fragment enable命令用来开启TCP分片攻击防范功能。
undo attack-defense tcp fragment enable命令用来关闭TCP分片攻击防范功能。
TCP分片攻击防范功能处于开启状态。
设备的包过滤功能一般是通过判断TCP首个分片中的五元组(源IP地址、源端口号、目的IP地址、目的端口号、传输层协议号)信息来决定后续TCP分片是否允许通过。RFC 1858对TCP分片报文进行了规定,认为TCP分片报文中,首片报文中TCP报文长度小于20字节,或后续分片报文中分片偏移量等于8字节的报文为TCP分片攻击报文。这类报文可以成功绕过上述包过滤功能,对设备造成攻击。为防止这类攻击,可以在设备上开启TCP分片攻击防范功能,对TCP分片攻击报文进行丢弃。
如果设备上开启了TCP分片攻击防范功能,并应用了单包攻击防范策略,则TCP分片攻击防范功能会先于单包攻击防范策略检测并处理入方向的TCP报文。
# 开启TCP分片攻击防范功能。
[Sysname] attack-defense tcp fragment enable
attack-defense top-attack-statistics enable命令用来开启攻击排名的Top统计功能。
undo attack-defense top-attack-statistics enable命令用来关闭攻击排名的Top统计功能。
攻击排名的Top统计功能处于关闭状态。
可以通过display attack-defense top-attack-statistics命令查看攻击数目的Top排名统计信息。
# 开启攻击排名的Top统计功能。
[Sysname] attack-defense top-attack-statistics enable
·     display attack-defense top-attack-statistics
blacklist global enable命令用来开启全局黑名单过滤功能。
undo blacklist global enable命令用来关闭全局黑名单过滤功能。
全局黑名单过滤功能处于关闭状态。
使能全局黑名单过滤功能表示开启所有接口上的黑名单过滤功能。
# 开启全局黑名单过滤功能。
[Sysname] blacklist global enable
·     blacklist enable
·     blacklist ip
display attack-defense flood statistics ip命令用来显示IPv4 flood攻击防范统计信息。
display attack-defense { ack-flood | dns-flood | dns-reply-flood | fin-flood | flood | http-flood | https-flood | icmp-flood | rst-flood | sip-flood | syn-ack-flood | syn-flood | udp-flood } statistics ip [ ip-address ] [ interface interface-type interface-number | local ] [ count ]
ack-flood:显示ACK flood攻击防范统计信息。
dns-flood:显示DNS flood攻击防范统计信息。
dns-reply-flood:显示DNS reply flood攻击防范统计信息。
fin-flood:显示FIN flood攻击防范统计信息。
flood:显示所有类型的IPv4 flood攻击防范统计信息。
http-flood:显示HTTP flood攻击防范统计信息。
https-flood:显示HTTPS flood攻击防范统计信息。
icmp-flood:显示ICMP flood攻击防范统计信息。
rst-flood:显示RST flood攻击防范统计信息。
sip-flood:显示SIP flood攻击防范统计信息。
syn-ack-flood:显示SYN-ACK flood攻击防范统计信息。
syn-flood:显示SYN flood攻击防范统计信息。
udp-flood:显示UDP flood攻击防范统计信息。
ip-address:显示指定目的IPv4地址的flood攻击防范统计信息。若未指定本参数,则显示所有目的IPv4地址的flood攻击防范统计信息。
interface interface-type interface-number:显示指定接口的flood攻击防范统计信息,interface-type interface-number表示接口类型和接口编号。
local:显示本机上进行检测的flood攻击防范统计信息。
count:显示受到flood攻击的IPv4地址数目。
由于flood攻击不关心源IP地址,因此本命令显示的是对指定目的IPv4地址的攻击防范统计信息。
若未指定interface和local参数,则显示所有接口以及本机上的flood攻击防范统计信息。
# 显示所有类型的IPv4 flood攻击防范统计信息。
<Sysname> display attack-defense flood statistics ip
Dest IP         VPN         Detected on  Detect type   State    PPS    Dropped
201.55.7.45     --          GE1/0/1      SYN-ACK-FLOOD Normal   1000   111111111
192.168.11.5    --          GE1/0/2      ACK-FLOOD     Normal   1000   222222222
Src IP          VPN         Detected on  Detect type   State    PPS    Dropped
201.55.7.44     --          Local        DNS-FLOOD     Normal   1000   111111111
192.168.11.4    --          Local        ACK-FLOOD     Normal   1000   22222222
192.168.8.41    --          Local        SIP-FLOOD     Normal   1000   125623489
# 显示所有类型的flood攻击检测的IPv4地址数目。
<Sysname> display attack-defense flood statistics ip count
Totally 2 flood destination entries.
Totally 3 flood source entries.
表1-1 display attack-defense flood statistics ip命令显示信息描述表
Dest IP
被检测的目的IPv4地址
Src IP
被检测的源IPv4地址
VPN
(暂不支持)目的IPv4地址所属的MPLS L3VPN实例名称,属于公网时显示为“--”
Detected on
进行攻击检测的位置,包括接口和本机(Local)
Detect type
检测的flood攻击类型,包括:
·     ACK flood
·     DNS flood
·     DNS reply flood
·     FIN flood
·     ICMP flood
·     ICMPv6 flood
·     SYN flood
·     SYN-ACK flood
·     UDP flood
·     RST flood
·     HTTP flood
·     SIP flood
·     HTTPS flood
接口或本机是否处于攻击状态,可包括以下取值:
·     Attacked:受攻击状态
·     Normal:正常状态(当前并未受到攻击)
PPS
指定的目的IPv4地址收到flood攻击报文的速率(单位为报文每秒)
Dropped
接口或本机丢弃的flood攻击报文数目
被检测的IPv4目的地址表项数目
Totally 2 flood source entries
被检测的IPv4源地址表项数目
display attack-defense flood statistics ipv6命令用来显示IPv6 flood攻击防范统计信息。
display attack-defense { ack-flood | dns-flood | dns-reply-flood | fin-flood | flood | http-flood | https-flood | icmpv6-flood | rst-flood | sip-flood | syn-ack-flood | syn-flood | udp-flood } statistics ipv6 [ ipv6-address ] [ interface interface-type interface-number | local ] [ count ]
ack-flood:显示指定ACK flood类型统计信息。
dns-flood:显示指定DNS flood类型统计信息。
fin-flood:显示指定FIN flood类型统计信息。
flood:显示所有类型的IPv6 flood攻击防范统计信息。
https-flood:显示HTTP flood攻击防范统计信息。
icmpv6-flood:显示指定ICMPv6 flood类型统计信息。
rst-flood:显示指定RST flood类型统计信息。
sip-flood:显示指定SIP flood类型统计信息。
syn-flood:显示指定SYN flood类型统计信息。
udp-flood:显示指定UDP flood类型统计信息。
ipv6-address:显示指定目的IPv6地址的flood攻击防范统计信息。若未指定本参数,则显示所有目的IPv6地址的flood攻击防范统计信息。
count:显示受到flood攻击的IPv6地址数目。
由于flood攻击不关心源IP地址,因此本命令显示的是对指定目的IPv6地址的攻击防范统计信息。
# 显示所有类型的IPv6 flood攻击防范统计信息。
<Sysname> display attack-defense flood statistics ipv6
Dest IPv6       VPN         Detected on  Detect type   State    PPS    Dropped
1::2            --          GE1/0/1      DNS-FLOOD     Normal   1000   111111111
1::3            --          GE1/0/2      SYN-ACK-FLOOD Normal   1000   222222222
Src IPv6        VPN         Detected on  Detect type   State    PPS    Dropped
1::4            --          Local        ACK-FLOOD     Normal   1000   111111111
1::5            --          Local        SYN-FLOOD     Normal   1000   22222222
17::14          --          Local        SIP-FLOOD     Normal   1000   264549789
# 显示所有类型的flood攻击检测的IPv6地址数目。
<Sysname> display attack-defense flood statistics ipv6 count
表1-2 display attack-defense flood statistics ipv6命令显示信息描述表
Dest IPv6
被检测的目的IPv6地址
Src IPv6
被检测的源IPv6地址
VPN
(暂不支持)目的IPv6地址所属的MPLS L3VPN实例名称,属于公网时显示为“--”
Detected on
Detect type
检测的flood攻击类型,包括:
·     ACK flood
·     DNS flood
·     DNS reply flood
·     FIN flood
·     ICMPv6 flood
·     SYN flood
·     SYN-ACK flood
·     UDP flood
·     RST flood
·     HTTP flood
·     SIP flood
·     HTTPS flood
·     Attacked:受攻击状态
PPS
指定的目的IPv6地址收到报文的速率(单位为报文每秒)
Dropped
接口或本机丢弃的flood攻击报文数目
Totally 4 flood destination entries
被检测的IPv6目的地址表项数目
被检测的IPv6源地址表项数目
display attack-defense http-slow-attack statistics ip命令用来显示IPv4慢速攻击防范统计信息。
display attack-defense http-slow-attack statistics ip [ ip-address ] [ interface { interface-type interface-number | interface-name } | local ] [ count ]
ip-address:显示指定目的IPv4地址的慢速攻击防范统计信息。若未指定本参数,则显示指定接口或本机上的所有慢速攻击防范统计信息。
interface { interface-type interface-number | interface-name }:显示指定接口的慢速攻击防范统计信息,interface-type表示接口类型,interface-number接口编号,interface-name表示接口名称。
local:显示本机上进行检测的慢速攻击防范统计信息。
count:显示受到慢速攻击的IPv4地址的数目。
若未指定interface和local参数,则显示所有接口以及本机上的慢速攻击防范统计信息。
# 显示IPv4 慢速攻击防范统计信息。
<Sysname> display attack-defense http-slow-attack statistics ip
IP address       VPN              Detected on           State
192.168.11.4     asd              Local                 Normal
201.55.7.44      --               GE1/0/2               Normal
# 显示受到慢速攻击的IPv4地址的数目。
<Sysname> display attack-defense http-slow-attack statistics ip count
Totally 2 HTTP slow attack entries.
表1-3 display attack-defense http-slow-attack statistics ip命令显示信息描述表
IP address
被检测的目的IPv4地址
Detected on
·     Attacked:受攻击状态
Totally 2 http slow attack entries
被检测的IPv4源地址表项数目
display attack-defense http-slow-attack statistics ipv6命令用来显示IPv6慢速攻击防范统计信息。
display attack-defense http-slow-attack statistics ipv6 [ ipv6-address ] [ interface { interface-type interface-number | interface-name } | local ] [ count ]
ipv6-address:显示指定目的IPv6地址的慢速攻击防范统计信息。若未指定本参数,则显示指定接口或本机上的所有慢速攻击防范统计信息。
count:显示受到慢速攻击的IPv6地址的数目。
# 显示慢速攻击防范统计信息。
<Sysname> display attack-defense http-slow-attack statistics ipv6
IPv6 address     VPN              Detected on           State
1::5             asd              Local                 Normal
17::14           --               GE1/0/2               Normal
# 显示受到慢速攻击的IPv6地址的数目。
<Sysname> display attack-defense http-slow-attack statistics ipv6 count
Totally 5 HTTP slow attack entries.
表1-4 display attack-defense http-slow-attack statistics ipv6命令显示信息描述表
IPv6 address
被检测的目的IPv6地址
Detected on
·     Attacked:受攻击状态
被检测的IPv6源地址表项数目
display attack-defense policy用来显示攻击防范策略的配置信息。
display attack-defense policy [ policy-name ]
policy-name:攻击防范策略名称,为1~31个字符的字符串,包括英文大/小写字母、数字、下划线和连字符,不区分大小写。若未指定本参数,则表示显示所有攻击防范策略的摘要信息。
本命令显示的内容主要包括各类型攻击防范的使能情况、对攻击报文的处理方式和相关的阈值参数。
# 显示指定攻击防范策略abc的配置信息。
<Sysname> display attack-defense policy abc
          Attack-defense Policy Information
Policy name                        : abc
Applied list                       : Local
                                     GE1/0/1
                                     Vlan1
Exempt IPv4 ACL:                  : Not configured
Exempt IPv6 ACL:                  : vip
  Actions: CV-Client verify  BS-Block source  L-Logging  D-Drop  N-None
Signature attack defense configuration:
Signature name                     Defense      Level             Actions
Fragment                           Enabled      Info              L
Impossible                         Enabled      Info              L
Teardrop                           Disabled     Info              L
Tiny fragment                      Disabled     Info              L
IP option abnormal                 Disabled     Info              L
Smurf                              Disabled     Info              N
Traceroute                         Disabled     Medium            L,D
Ping of death                      Disabled     Low               L
Large ICMP                         Disabled     Medium            L,D
  Max length                       4000 bytes
Large ICMPv6                       Disabled     Low               L
TCP invalid flags                  Disabled     medium            L,D
TCP null flag                      Disabled     Low               L
TCP all flags                      Enabled      Info              L
TCP SYN-FIN flags                  Disabled     Info              L
TCP FIN only flag                  Enabled      Info              L
TCP Land                           Disabled     Info              L
Winnuke                            Disabled     Info              L
UDP Bomb                           Disabled     Info              L
UDP Snork                          Disabled     Info              L
UDP Fraggle                        Enabled      Info              L
IP option record route             Disabled     Info              L
IP option internet timestamp       Enabled      Info              L
IP option security                 Disabled     Info              L
IP option loose source routing     Enabled      Info              L
IP option stream ID                Disabled     Info              L
IP option strict source routing    Disabled     Info              L
IP option route alert              Disabled     Info              L
ICMP echo request                  Disabled     Info              L
ICMP echo reply                    Disabled     Info              L
ICMP source quench                 Disabled     Info              L
ICMP destination unreachable       Enabled      Info              L
ICMP redirect                      Enabled      Info              L
ICMP time exceeded                 Enabled      Info              L
ICMP parameter problem             Disabled     Info              L
ICMP timestamp request             Disabled     Info              L
ICMP timestamp reply               Disabled     Info              L
ICMP information request           Disabled     Info              L
ICMP information reply             Disabled     Medium            L,D
ICMP address mask request          Disabled     Medium            L,D
ICMP address mask reply            Disabled     Medium            L,D
ICMPv6 echo request                Enabled      Medium            L,D
ICMPv6 echo reply                  Disabled     Medium            L,D
ICMPv6 group membership query      Disabled     Medium            L,D
ICMPv6 group membership report     Disabled     Medium            L,D
ICMPv6 group membership reduction  Disabled     Medium            L,D
ICMPv6 destination unreachable     Enabled      Medium            L,D
ICMPv6 time exceeded               Enabled      Medium            L,D
ICMPv6 parameter problem           Disabled     Medium            L,D
ICMPv6 packet too big              Disabled     Medium            L,D
IPv6 extension header abnormal     Disabled     Info              L
IPv6 extension header exceeded     Disabled     Info              L
  Limit                            7
Scan attack defense configuration:
  Preset defense:
  Defense: Disabled
  User-defined defense:
    Port scan defense: Enabled
    Port scan defense threshold: 5000 packets
    IP sweep defense: Enabled
    IP sweep defense threshold: 8000 packets
    Period: 100s
    Actions: L
Flood type  Global dest/src thres(pps)  Global actions Service ports  Non-specific
DNS flood         1000/1000             -              53             Disabled
DNS reply flood   1000/1000             -              -              Disabled
HTTP flood        1000/1000             80             -              Disabled
SIP flood         1000/1000             50             -              Enabled
HTTPS flood       1000/1000             -              443            Disabled
SYN flood         1000/1000             -              -              Disabled
ACK flood         1000/1000             -              -              Disabled
SYN-ACK flood     1000/1000             -              -              Disabled
RST flood         1000/1000             -              -              Disabled
FIN flood         1000/1000             -              -              Disabled
UDP flood         1000/1000             -              -              Disabled
ICMP flood        1000/1000             -              -              Disabled
ICMPv6 flood      1000/1000             -              -              Enabled
Flood attack defense for protected IP addresses:
 Address                 VPN instance Flood type    Thres(pps)  Actions Ports
 1::1                    --           FIN-FLOOD     10          L,D     -
 192.168.1.1             --           SYN-ACK-FLOOD 10          -       -
 1::1                    --           FIN-FLOOD     -           L       -
HTTP slow attack defense configuration:
  Non-specific: Enabled
  Global threshold:
    Alert-number: 1200000
    Content-length: 100000000
    Payload-length: 1000
    Packet-number: 1000
  Global period: 1200 seconds
  Global action: L, BS (1000)
  Ports: 80, 8000 to 8001
Threshold: AN-Alert number, CL-Content length, PL-Payload length, PN-Packet number
HTTP slow attack defense configuration for protected IP addresses:
Address          VPN instance  Threshold (AN/CL/PL/PN)      Period  Actions  Ports
1111:2222:3333:4 abcdefghigkl 1200000,100000000,1000,1000  1000    L,BS(10) 80
444::8888        mnopqrstuvwx
                 yz
表1-5 display attack-defense policy命令显示信息描述表
Policy name
攻击防范策略名称
Applied list
攻击防范策略应用的对象列表,包括接口名称和本机(Local)
Exempt IPv4 ACL
IPv4例外列表
Exempt IPv6 ACL
IPv6例外列表
Actions
攻击防范的处理行为,包括以下取值:
·     (暂不支持)CV:启用客户端验证
·     (暂不支持)BS:添加黑名单(老化时间,单位为分钟)
·     L:输出告警日志
·     D:丢弃报文
·     N:不采用任何处理行为
单包攻击防范配置信息
Signature name
单包的类型
Defense
攻击防范的开启状态,包括以下取值:
·     Enabled:开启
·     Disabled:关闭
Level
单包攻击的级别,包括以下取值:
·     Info: 提示级别
·     low:低级别
·     medium:中级别
·     high:高级别(目前暂无实例)
Actions
单包攻击防范的处理行为,包括以下取值:
·     L:输出告警日志
·     D:丢弃报文
·     N:不采用任何处理行为
IP选项record route攻击
IP option security
IP选项security攻击
IP option stream ID
IP选项stream identifier攻击
IP选项 internet timestamp攻击
IP选项loose source routing攻击
IP选项strict source routing攻击
IP option abnormal
IP选项异常攻击
IP选项route alert攻击
Fragment
IP分片异常攻击
IP impossible
IP impossible攻击
Tiny fragment
IP tiny fragment攻击
Teardrop
IP teardrop攻击,又称IP overlapping fragments
Large ICMP
Large ICMP攻击
Max length
ICMP报文所允许的最大长度
Smurf
Smurf攻击
Traceroute
Traceroute攻击
Ping of death
Ping of death攻击
ICMP echo request
ICMP echo request攻击
ICMP echo reply
ICMP echo reply攻击
ICMP source quench
ICMP source quench攻击
ICMP redirect
ICMP redirect攻击
ICMP parameter problem攻击
ICMP timestamp request攻击
ICMP timestamp reply攻击
ICMP information request攻击
ICMP information reply攻击
ICMP address mask request攻击
ICMP address mask reply攻击
ICMP destination  unreachable攻击
ICMP time exceeded
ICMP time exceeded攻击
Large ICMPv6
Large ICMPv6攻击
ICMPv6 echo request
ICMPv6 echo request攻击
ICMPv6 echo reply
ICMPv6 echo reply攻击
ICMPv6 group membership query攻击
ICMPv6 group membership report攻击
ICMPv6 group membership reduction攻击
ICMPv6 destination unreachable攻击
ICMPv6 time exceeded攻击
ICMPv6 parameter problem攻击
ICMPv6 packet too big攻击
IPv6扩展头异常攻击
Limit
IPv6扩展头数目上限
Winnuke
Winnuke攻击
TCP Land
Land攻击
TCP NULL flag
TCP NULL flag攻击
TCP invalid flags
TCP invalid flags攻击
TCP all flags
TCP所有标志位均被置位攻击,又称圣诞树攻击
TCP SYN-FIN flags
TCP SYN和FIN被同时置位攻击
TCP FIN only flag
TCP 只有FIN被置位的攻击
Fraggle
Fraggle攻击,又称UDP chargen DoS attack
UDP Bomb
UDP Bomb攻击
Snork
Snork攻击
扫描攻击防范配置信息
Preset defense
预定义扫描攻击防范配置信息
Defense
扫描攻击防范的开启状态
Level
扫描攻击的级别,包括以下取值:
·     low:低级别
·     medium:中级别
·     high:高级别
用户自定义扫描攻击防范配置信息
Port scan defense
端口扫描攻击防范状态:
·     Enabled:开启
·     Disabled:关闭
端口扫描防范检测阈值
IP sweep defense
IP地址扫描攻击防范状态:
·     Enabled:开启
·     Disabled:关闭
IP地址扫描防范检测阈值
Period
扫描攻击防范检测周期
Actions
扫描攻击防范的处理行为,包括以下取值:
·     D:丢弃报文
·     L:输出告警日志
Flood attack defense configuration
flood攻击防范配置信息
Flood type
flood攻击类型,包括以下取值:
·     ACK flood
·     DNS flood
·     DNS reply flood
·     FIN flood
·     ICMP flood
·     ICMPv6 flood
·     SYN flood
·     SYN-ACK flood
·     UDP flood
·     RST flood
·     HTTP flood
·     SIP flood
·     HTTPS flood
flood攻击防范基于目的地址检测和源地址检测的全局触发阈值,单位为每秒报文数,默认值为1000pps
Global actions
flood攻击防范的全局处理行为,包括以下取值:
·     D:丢弃报文
·     L:输出告警日志,
·     (暂不支持)CV:启用客户端验证
·     -:未配置
Service ports
flood攻击防范的全局检测端口号。该字段只对DNS flood攻击防范和HTTP flood攻击防范生效,对于其它flood攻击防范,显示为“-”
Non-specific
对非受保护IP地址开启SYN flood攻击防范检测的状态
对受保护IP地址的flood攻击防范配置
Address
指定的IP地址
VPN instance
(暂不支持)所属的VPN实例名称,未配置时显示为空
Thres(pps)
攻击防范检测的触发阈值,单位为报文每秒,未配置时显示为“1000”
Actions
对指定IP地址采用的攻击防范处理行为,包括 取值:
·     (暂不支持)CV:启用客户端验证
·     (暂不支持)BS:添加黑名单
·     L:输出告警日志
·     D:丢弃报文
·     N:不采用任何处理行为
Ports
flood攻击防范的检测端口号。该字段只对DNS flood攻击防范和HTTP flood攻击防范生效,对于其他攻击防范,显示为“-”
慢速攻击防范非保护IP配置信息
Non-specific
对非受保护IP地址开启慢速攻击防范检测的状态:
·     Enabled:开启
·     Disabled:关闭
Global threshold
对非受保护IP地址配置的阈值。包括:
Alert-number:触发慢速攻击检查的HTTP并发连接数,未配置时显示为“5000”。
Content-length:Content-Length字段阈值,未配置时显示为“10000”。
Payload-length:报文实际载荷阈值,未配置时显示为“50”。
Packet-number:异常报文的防范阈值,未配置时显示为“10”。
Global period
慢速攻击防范非受保护IP地址的检测周期
Global action
慢速攻击防范非受保护IP地址的处理动作,包括以下取值:
·     L:输出告警日志
Ports
慢速攻击防范非受保护IP地址的检测端口。未配置时显示为“80”
对受保护IP地址的慢速攻击防范配置
Address
慢速攻击防范指定的IP地址
VPN instance
(暂不支持)慢速攻击防范指定的VPN实例名称,未配置时显示为空
对受保护IP地址配置的阈值,其中AN-Alert number,CL-Content length,PL-Payload length,PN-Packet number。
四项阈值均未配置时,显示为非受保护IP的对应阈值。如部分配置四项阈值,则其余未配置的阈值显示为非受保护IP对应该阈值的缺省值。
Period
慢速攻击防范受保护IP地址的检测周期。未配置时,显示为非受保护IP的检测周期。
Actions
慢速攻击防范受保护IP地址采用的处理动作,包括以下取值:
·     BS:添加黑名单(老化时间,单位为分钟)
·     L:输出告警日志
未配置时,显示为非受保护IP的处理动作。
Ports
慢速攻击防范受保护IP的检测端口。未配置时显示为非受保护IP的检测端口。
# 显示所有攻击防范策略的概要配置信息。
           Attack-defense Policy Brief Information
Policy Name                        Applied list
Atk-policy-1                       GigabitEthernet1/0/1
                                   GigabitEthernet1/0/2
P123                               GigabitEthernet1/0/2
p1                                 Local
p12                                Local
表1-6 display attack-defense policy命令显示信息描述表
Policy Name
攻击防范策略名称
Applied list
display attack-defense policy ip命令用来显示flood攻击防范的IPv4类型的受保护IP表项。
display attack-defense policy policy-name { ack-flood | dns-flood | dns-reply-flood | fin-flood | flood | http-flood | https-flood | icmp-flood | rst-flood | sip-flood | syn-ack-flood | syn-flood | udp-flood } ip [ ip-address ] [ count ]
ack-flood:显示ACK flood攻击防范受保护IP表项。
dns-flood:显示DNS flood攻击防范受保护IP表项。
dns-reply-flood:显示DNS reply flood攻击防范受保护IP表项。
fin-flood:显示FIN flood攻击防范受保护IP表项。
flood:显示所有类型的flood攻击防范受保护IP表项。
http-flood:显示HTTP flood攻击防范受保护IP表项。
https-flood:显示HTTPS flood攻击防范受保护IP表项。
icmp-flood:显示ICMP flood攻击防范受保护IP表项。
rst-flood:显示RST flood攻击防范受保护IP表项。
sip-flood:显示SIP flood攻击防范受保护IP表项。
syn-ack-flood:显示SYN-ACK flood攻击防范受保护IP表项。
syn-flood:显示SYN flood攻击防范受保护IP表项。
udp-flood:显示UDP flood攻击防范受保护IP表项。
ip ip-address:显示指定IPv4地址的受保护IP表项。若未指定ip-address参数,则表示显示所有IPv4类型的受保护IP表项。
count:显示符合指定条件的flood受保护IP表项的数目。
# 显示指定攻击防范策略abc中所有flood攻击防范的IPv4类型受保护IP表项的信息。
<Sysname> display attack-defense policy abc flood ip
IP address      VPN instance     Type Rate threshold(PPS) Dropped
123.123.123.123 --               SYN-ACK-FLOOD 100                 4294967295
201.55.7.45     --               ICMP-FLOOD    100                 10
192.168.11.5    --               DNS-FLOOD 23                  100
10.168.200.5    --               SIP-FLOOD     100                 102556
# 显示指定攻击防范策略abc中所有flood攻击防范的IPv4类型受保护IP表项的个数。
<Sysname> display attack-defense policy abc flood ip count
Totally 3 flood protected IP addresses.
表1-7 display attack-defense flood ip命令显示信息描述表
IPv4类型受保护IP表项数目
IP address
受保护的IPv4地址
VPN instance
(暂不支持)受保护的IPv4地址所属的MPLS L3VPN实例名称,未指定时显示为空
flood攻击类型
Rate threshold(PPS)
配置的flood攻击防范触发阈值(单位为报文每秒),未配置时显示“1000”
Dropped
检测到flood攻击后的丢包数,若只输出日志该项显示为0
display attack-defense policy ipv6命令用来显示flood攻击防范的IPv6类型的受保护IP表项。
display attack-defense policy policy-name { ack-flood | dns-flood | dns-reply-flood | fin-flood | flood | http-flood | https-flood | icmpv6-flood | rst-flood | sip-flood | syn-ack-flood | syn-flood | udp-flood } ipv6 [ ipv6-address ] [ count ]
icmpv6-flood:显示ICMPv6 flood攻击防范受保护IP表项。
ipv6 ipv6-address:显示指定IPv6地址的受保护IP表项。若未指定ipv6-address参数,则表示所有IPv6类型的受保护IP表项。
# 显示指定攻击防范策略abc中所有flood攻击防范的IPv6类型受保护IP表项。
<Sysname> display attack-defense policy abc flood ipv6
IPv6 address    VPN instance     Type Rate threshold(PPS) Dropped
2013::127f      --               SYN-ACK-FLOOD 100                 4294967295
2::5            --               ACK-FLOOD 100                 10
1::5            --               ACK-FLOOD 100                 23
10::15          --               SIP-FLOOD     100                 1002
# 显示指定攻击防范策略abc中所有flood攻击防范的IPv6类型受保护IP表项的个数。
<Sysname> display attack-defense policy abc flood ipv6 count
表1-8 display flood ipv6命令显示信息描述表
IPv6类型受保护IP表项数目
IPv6 address
受保护的IPv6地址
VPN instance
(暂不支持)受保护的IPv6地址所属的MPLS L3VPN实例名称,未指定时显示为空
flood攻击类型
Rate threshold(PPS)
Dropped
display attack-defense scan attacker ip命令用来显示扫描攻击者的IPv4地址表项。
display attack-defense scan attacker ip [ interface interface-type interface-number | local ] [ count ]
interface interface-type interface-number:显示指定接口上检测到的扫描攻击者的IPv4地址表项,interface-type interface-number表示接口类型和接口编号。
local:显示本机检测到的扫描攻击者IPv4地址表项。
count:显示受到扫描攻击的IPv4地址数目。
若未指定任何参数,则表示显示所有扫描攻击者的IPv4地址表项。
# 显示所有扫描攻击者的IPv4地址表项。
<Sysname> display attack-defense scan attacker ip
IP addr(DslitePeer) VPN instance     Protocol      Detected on  Duration(min)
192.168.31.2(--)    --               TCP           GE1/0/2      1284
2.2.2.3(--)         --               UDP           GE1/0/2      23
192.68.11.2(--)     --               TCP           Local        782
2.2.2.1(--)         --               UDP           Local        23
# 显示所有扫描攻击者的IPv4地址表项的个数。
<Sysname> display attack-defense scan attacker ip count
Totally 3 attackers.
表1-9 display attack-defense scan attacker ip命令显示信息描述表
Totally 3 attackers
扫描攻击者的数目
IP addr(DslitePeer)
发起攻击的IPv4地址,DS-Lite组网DslitePeer显示为DS-Lite隧道源IPv6地址,否则显示“--”
VPN instance
(暂不支持)所属的MPLS L3VPN实例名称,属于公网时显示为空
Protocol
协议名称
Detected on
进行攻击检测的位置,包括接口或本机(Local)
Duration(min)
检测到攻击持续的时间,单位为分钟
·     scan detect
display attack-defense scan attacker ipv6命令用来显示扫描攻击者的IPv6地址表项。
display attack-defense scan attacker ipv6 [ interface interface-type interface-number | local ] [ count ]
interface interface-type interface-number:显示指定接口的扫描攻击者的IPv6地址表项,interface-type interface-number表示接口类型和接口编号。
local:显示本机检测到的扫描攻击者IPv6地址表项。
count:显示受到扫描攻击的IPv6地址数目。
若未指定任何参数,则表示显示所有扫描攻击者的IPv6地址表项。
# 显示扫描攻击者的IPv6地址表项。
<Sysname> display attack-defense scan attacker ipv6
IPv6 address       VPN instance     Protocol Detected on      Duration(min)
2013::2            --               TCP          GE1/0/1          1234
1230::22           --               UDP          GE1/0/2          10
1002::20           --               TCP          Local            782
1230::1            --               UDP          Local            10
# 显示扫描攻击者的IPv6地址表项的个数。
<Sysname> display attack-defense scan attacker ipv6 count
表1-10 display attack-defense scan attacker ipv6命令显示信息描述表
Totally 3 attackers
攻击者的数目
IPv6 address
发起攻击的IPv6地址
VPN instance
Protocol
协议名称
Detected on
Duration(min)
检测到攻击持续的时间,单位为分钟
·     scan detect
display attack-defense statistics interface命令用来显示接口上的攻击防范统计信息。
display attack-defense statistics interface interface-type interface-number
interface-type interface-number:表示指定接口的接口类型和接口编号。
# 显示接口GigabitEthernet1/0/1上的攻击防范统计信息。
<Sysname> display attack-defense statistics interface gigabitethernet 1/0/1
Attack policy name: abc
Scan attack defense statistics:
 AttackType                          AttackTimes Dropped
 Port scan                           2           23
 IP sweep                            3           33
 Distribute port scan                1           10
Flood attack defense statistics:
 SYN flood                           1           0
 ACK flood                           1           0
 SYN-ACK flood                       3           5000
 RST flood                           2           0
 FIN flood                           2           0
 UDP flood                           1           0
 ICMP flood                          1           0
 ICMPv6 flood                        1           0
 DNS flood                           1           0
 DNS reply flood                     1           0
 HTTP flood                          1           0
 SIP flood                           1           1000
 HTTPS flood                         1           0
HTTP slow attack defense statistics:
HTTP slow attack                    1
Signature attack defense statistics:
 IP option record route              1           100
 IP option security                  2           0
 IP option stream ID                 3           0
 IP option internet timestamp        4           1
 IP option loose source routing      5           0
 IP option strict source routing     6           0
 IP option route alert               3           0
 Fragment                            1           0
 Impossible                          1           1
 Teardrop                            1           1
 Tiny fragment                       1           0
 IP options abnormal                 3           0
 Smurf                               1           0
 Ping of death                       1           0
 Traceroute                          1           0
 Large ICMP                          1           0
 TCP NULL flag                       1           0
 TCP all flags                       1           0
 TCP SYN-FIN flags                   1           0
 TCP FIN only flag                   1           0
 TCP invalid flag                    1           0
 TCP Land                            1           0
 Winnuke                             1           0
 UDP Bomb                            1           0
 Snork                               1           0
 Fraggle                             1           0
 Large ICMPv6                        1           0
 ICMP echo request                   1           0
 ICMP echo reply                     1           0
 ICMP source quench                  1           0
 ICMP destination unreachable        1           0
 ICMP redirect                       2           0
 ICMP time exceeded                  3           0
 ICMP parameter problem              4           0
 ICMP timestamp request              5           0
 ICMP timestamp reply                6           0
 ICMP information request            7           0
 ICMP information reply              4           0
 ICMP address mask request           2           0
 ICMP address mask reply             1           0
 ICMPv6 echo request                 1           1
 ICMPv6 echo reply                   1           1
 ICMPv6 group membership query       1           0
 ICMPv6 group membership report      1           0
 ICMPv6 group membership reduction   1           0
 ICMPv6 destination unreachable      1           0
 ICMPv6 time exceeded                1           0
 ICMPv6 parameter problem            1           0
 ICMPv6 packet too big               1           0
 IPv6 extension header abnormal      1           0
 IPv6 extension header exceeded      1           0
表1-11 display attack-defense statistics interface 命令显示信息描述表
AttackType
攻击类型
AttackTimes
受到攻击的次数
Dropped
丢弃报文的数目
SYN flood
SYN flood攻击,当AttackTimes为0时,该列不显示
ACK flood
ACK flood攻击,当AttackTimes为0时,该列不显示
SYN-ACK flood
SYN-ACK flood攻击,当AttackTimes为0时,该列不显示
RST flood
RST flood攻击,当AttackTimes为0时,该列不显示
FIN flood
FIN flood攻击,当AttackTimes为0时,该列不显示
UDP flood
UDP flood 攻击,当AttackTimes为0时,该列不显示
ICMP flood
ICMP flood攻击,当AttackTimes为0时,该列不显示
ICMPv6 flood
ICMPv6 flood攻击,当AttackTimes为0时,该列不显示
DNS flood
DNS flood攻击,当AttackTimes为0时,该列不显示
DNS reply flood
DNS reply flood攻击,当AttackTimes为0时,该列不显示
HTTP flood
HTTP flood攻击,当AttackTimes为0时,该列不显示
HTTP slow attack
HTTP slow attack攻击,当AttackTimes为0时,显示为No HTTP slow attack detected
HTTPS flood
HTTPS flood攻击,当AttackTimes为0时,该列不显示
SIP flood
SIP flood攻击,当AttackTimes为0时,该列不显示
Port scan
端口扫描攻击,当AttackTimes 为0时,该列不显示
IP Sweep
IP扫描攻击,当AttackTimes 为0时,该列不显示
分布式端口扫描攻击,当AttackTimes为0时,该列不显示
IP选项record route攻击,当AttackTimes为0时,该列不显示
IP option security
IP选项security攻击,当AttackTimes 为0时,该列不显示
IP option stream ID
IP选项stream identifier攻击,当AttackTimes 为0时,该列不显示
IP选项 internet timestamp攻击,当AttackTimes为0时,该列不显示
IP选项loose source routing攻击,当AttackTimes为0时,该列不显示
IP选项strict source routing攻击,当AttackTimes为0时,该列不显示
Fragment
IP分片异常攻击,当AttackTimes为0时,该列不显示
Impossible
IP impossible攻击,当AttackTimes为0时,该列不显示
Teardrop
IP teardrop攻击,又称IP overlapping fragments,当AttackTimes为0时,该列不显示
Tiny fragment
IP tiny fragment攻击
IP option abnormal
IP选项异常攻击,当AttackTimes为0时,该列不显示
Smurf
Smurf攻击,当AttackTimes为0时,该列不显示
Ping of death
Ping of death攻击,当AttackTimes为0时,该列不显示
Traceroute
Traceroute攻击,当AttackTimes为0时,该列不显示
Large ICMP
Large ICMP攻击,当AttackTimes为0时,该列不显示
TCP NULL flag
TCP NULL flag攻击,当AttackTimes为0时,该列不显示
TCP all flags
TCP所有标志位均被置位攻击,又称圣诞树攻击,当AttackTimes为0时,该列不显示
TCP SYN-FIN flags
TCP SYN和FIN被同时置位攻击,当AttackTimes为0时,该列不显示
TCP FIN only flag
TCP 只有FIN被置位的攻击,当AttackTimes为0时,该列不显示
TCP invalid flag
TCP 非法标志位攻击,当AttackTimes 为0时,该列不显示
TCP Land
TCP Land攻击,当AttackTimes为0时,该列不显示
Winnuke
Winnuke攻击,当AttackTimes为0时,该列不显示
UDP Bomb
UDP Bomb攻击,当AttackTimes为0时,该列不显示
Snork
UDP snork攻击,当AttackTimes为0时,该列不显示
Fraggle
Fraggle攻击,又称UDP chargen DoS attack,当AttackTimes为0时,该列不显示
Large ICMPv6
Large ICMPv6攻击,当AttackTimes为0时,该列不显示
ICMP echo request
ICMP echo request攻击,当AttackTimes为0时,该列不显示
ICMP echo reply
ICMP echo reply攻击,当AttackTimes为0时,该列不显示
ICMP source quench
ICMP source quench攻击,当AttackTimes为0时,该列不显示
ICMP destination unreachable攻击,当AttackTimes为0时,该列不显示
ICMP redirect
ICMP redirect攻击,当AttackTimes为0时,该列不显示
ICMP time exceeded
ICMP time exceeded攻击,当AttackTimes为0时,该列不显示
ICMP parameter problem攻击,当AttackTimes 为0时,该列不显示
ICMP timestamp request攻击,当AttackTimes为0时,该列不显示
ICMP timestamp reply攻击,当AttackTimes为0时,该列不显示
ICMP information request攻击,当AttackTimes为0时,该列不显示
ICMP information reply攻击,当AttackTimes为0时,该列不显示
ICMP address mask request攻击,当AttackTimes为0时,该列不显示
ICMP address mask reply攻击,当AttackTimes为0时,该列不显示
ICMPv6 echo request
ICMPv6 echo request攻击,当AttackTimes 为0时,该列不显示
ICMPv6 echo reply
ICMPv6 echo reply攻击,当AttackTimes为0时,该列不显示
ICMPv6 group membership query攻击,当AttackTimes为0时,该列不显示
ICMPv6 group membership report攻击,当AttackTimes为0时,该列不显示
ICMPv6 group membership reduction攻击,当AttackTimes为0时,该列不显示
ICMPv6 destination unreachable攻击,当AttackTimes为0时,该列不显示
ICMPv6 time exceeded攻击,当AttackTimes为0时,该列不显示
ICMPv6 parameter problem攻击,当AttackTimes为0时,该列不显示
ICMPv6 packet too big攻击,当AttackTimes为0时,该列不显示
IPv6扩展头异常攻击,当AttackTimes为0时,该列不显示
IPv6扩展头数目超限攻击,当AttackTimes为0时,该列不显示
·     reset attack-defense statistics interface
display attack-defense statistics local命令用来显示本机攻击防范的统计信息。
# 显示本机攻击防范统计信息。
<Sysname> display attack-defense statistics local
Attack defense policy name: abc
 Port scan                           2           23
 IP sweep                            3           33
 SYN flood                           1           0
 ACK flood                           1           0
 RST flood                           2           0
 FIN flood                           2           0
 UDP flood                           1           0
 ICMP flood                          1           0
 ICMPv6 flood                        1           0
 DNS flood                           1           0
 DNS reply flood                     1           0
 HTTP flood                          1           0
 SIP flood                           1           1000
 HTTPS flood                         1           0
HTTP slow attack                    1
 Fragment                            1           0
 Impossible                          1           1
 Teardrop                            1           1
 Tiny fragment                       1           0
 Smurf                               1           0
 Ping of death                       1           0
 Traceroute                          1           0
 Large ICMP                          1           0
 TCP NULL flag                       1           0
 TCP all flags                       1           0
 TCP Land                            1           0
 Winnuke                             1           0
 UDP Bomb                            1           0
 Snork                               1           0
 Fraggle                             1           0
 Large ICMPv6                        1           0
 ICMP echo reply                     1           0
 ICMP redirect                       2           0
表1-12 display attack-defense statistics local命令显示信息描述表
AttackType
攻击类型
AttackTimes
受到攻击的次数
Dropped
丢弃报文的数目
Port scan
IP Sweep
IP扫描攻击,当AttackTimes为0时,该列不显示
SYN flood
SYN flood攻击,当AttackTimes 为0时,该列不显示
ACK flood
ACK flood攻击,当AttackTimes 为0时,该列不显示
SYN-ACK flood
RST flood
FIN flood
UDP flood
ICMP flood
ICMPv6 flood
DNS flood
DNS reply flood
HTTP flood
HTTP slow attack
HTTPS flood
SIP flood
IP option security
IP选项security攻击,当AttackTimes为0时,该列不显示
IP option stream ID
IP选项stream identifier攻击,当AttackTimes为0时,该列不显示
Fragment
Impossible
Teardrop
Tiny fragment
IP tiny fragment攻击
IP option abnormal
Smurf
Ping of death
Traceroute
Large ICMP
TCP NULL flag
TCP all flags
TCP SYN-FIN flags
TCP FIN only flag
TCP只有FIN被置位的攻击,当AttackTimes为0时,该列不显示
TCP invalid flag
TCP非法标志位攻击,当AttackTimes为0时,该列不显示
TCP Land
Winnuke
UDP Bomb
Snork
Snork攻击,当AttackTimes为0时,该列不显示
Fraggle
Large ICMPv6
ICMP echo request
ICMP echo request攻击,当AttackTimes 为0时,该列不显示
ICMP echo reply
ICMP source quench
ICMP redirect
ICMP time exceeded
ICMP parameter problem攻击,当AttackTimes为0时,该列不显示
ICMPv6 echo request
ICMPv6 echo reply
ICMPv6 group membership query攻击,当AttackTimes 为0时,该列不显示
·     reset attack-defense statistics local
display attack-defense top-attack-statistics命令用来显示Top10的攻击排名统计信息。
display attack-defense top-attack-statistics { last-1-hour | last-24-hours | last-30-days } [ by-attacker | by-type | by-victim ]
last-1-hour:显示最近1小时的统计信息。
last-24-hours:显示最近24小时的统计信息。
last-30-days:显示最近30天的统计信息。
by-attacker:显示基于攻击者IP地址的Top10排名统计信息。
by-type:显示基于攻击类型的统计信息。
by-victim:显示基于被攻击者IP地址的Top10排名统计信息。
若未指定[ by-attacker | by-type | by-victim ]参数,则同时显示基于攻击者IP地址、被攻击者IP地址和攻击类型的统计信息。
# 显示最近1小时的Top10排名统计信息
<Sysname> display attack-defense top-attack-statistics last-1-hour
Top attackers:
No.     VPN instance   Attacker IP         Attacks
1                      200.200.200.55 21
2                      200.200.200.21 16
3                      200.200.200.133 12
4                      200.200.200.19      10
5                      200.200.200.4       8
6                      200.200.200.155 8
7                      200.200.200.93 5
8                      200.200.200.67      3
9                      200.200.200.70 1
10                     200.200.200.23      1
Top victims:
No.     VPN instance   Victim IP            Attacks
1       --             201.200.200.12       21
2       --             201.200.200.32       16
3       --             201.200.200.14       12
4       --             201.200.200.251      12
5       --             201.200.200.10       7
6       --             201.200.200.77       6
7       --             201.200.200.96       2
8       --             201.200.200.22       2
9       --             201.200.200.154      2
10      --             201.200.200.18       1
Top attack types:
Attack type       Attacks
Scan              155
Syn               155
表1-13 display attack-defense top-attack-statistics命令显示信息描述表
Top attackers
No.
Top10排名
VPN instance
(暂不支持)所属的VPN实例名称,属于公网时显示为空
Attacker IP
攻击者的IP地址
Attacks
攻击次数
Top victims
Victim IP
被攻击者的IP地址
Top attack types
基于攻击类型的统计信息
Attack type
攻击类型
·     attack-defense top-attack-statistics enable
dns-flood action命令用来配置对DNS flood攻击防范的全局处理行为。
undo dns-flood action命令用来恢复缺省情况。
dns-flood action { drop | logging } *
不对检测到的DNS flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文。对于基于源IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃源自攻击者的后续所有DNS报文;对于基于目的IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃向被攻击者发送的后续所有DNS报文。
# 在攻击防范策略atk-policy-1中配置对DNS flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood action drop
·     dns-flood detect
·     dns-flood detect non-specific
·     dns-flood port
·     dns-flood source-threshold
·     dns-flood threshold
dns-flood detect命令用来开启对指定IP地址的攻击防范检测,并配置DNS flood攻击防范检测的触发阈值和对DNS flood攻击的处理行为。
undo dns-flood detect命令用来关闭对指定IP地址的DNS flood攻击防范检测。
dns-flood detect { ip ipv4-address | ipv6 ipv6-address } [ port port-list ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo dns-flood detect { ip ipv4-address | ipv6 ipv6-address }
未对任何指定IP地址配置DNS flood攻击防范检测。
攻击防范策略视图
port port-list:指定开启DNS flood攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-24>。&<1-24>表示前面的参数最多可以输入24次。end-port-number必须大于或等于start-port-number。若未指定本参数,则表示使用全局配置的检测端口列表。
threshold threshold-value:指定DNS flood攻击防范基于目的IP统计的触发阈值。其中,threshold-value为向指定IP地址每秒发送的DNS报文数目,取值范围为1~1000000。
action:设置对DNS flood攻击的处理行为。若未指定本参数,则表示采用DNS flood攻击防范的全局处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有DNS报文都会被丢弃。
none:表示不采取任何动作。
使能DNS flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送DNS报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了DNS flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置DNS flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的DNS flood攻击防范检测,并指定检测端口为53、触发阈值为2000。当设备监测到向该IP地址的53端口每秒发送的DNS报文数持续达到或超过2000时,启动DNS flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood detect ip 192.168.1.2 port 53 threshold 2000
·     dns-flood action
·     dns-flood port
dns-flood detect non-specific命令用来对所有非受保护IP地址开启DNS flood攻击防范检测。
undo dns-flood detect non-specific命令用来关闭对所有非受保护IP地址的DNS flood攻击防范检测。
未对任何非受保护IP地址开启DNS flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启DNS flood攻击防范检测后,设备将采用全局的阈值设置(由dns-flood threshold或dns-flood source-threshold命令设置)和处理行为(由dns-flood action命令配置)对这些IP地址进行保护或防御。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启DNS flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood detect non-specific
·     dns-flood action
·     dns-flood detect
·     dns-flood port
dns-flood port命令用来配置DNS flood攻击防范的全局检测端口号。
undo dns-flood port命令用来恢复缺省情况。
dns-flood port port-list
undo dns-flood port
DNS flood攻击防范的全局检测端口号为53。
攻击防范策略视图
port-list:指定开启DNS flood攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-32>。&<1-32>表示前面的参数最多可以输入32次。end-port-number必须大于或等于start-port-number。
设备只对指定检测端口上收到的报文进行DNS flood攻击检测。
对于所有非受保护IP地址,或未指定检测端口的受保护IP地址,设备采用全局的检测端口进行DNS flood攻击检测。对于所有指定检测端口的受保护IP地址,设备针对为每个受保护IP地址指定的端口进行DNS flood攻击检测。
# 在攻击防范策略atk-policy-1中配置DNS flood攻击防范的全局检测端口为53与61000,当设备检测到访问53端口或61000端口的DNS flood攻击时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood port 53 61000
·     dns-flood action
·     dns-flood detect
dns-flood threshold命令用来配置DNS flood攻击防范基于目的IP统计的全局触发阈值。
undo dns-flood threshold命令用来恢复缺省情况。
dns-flood threshold threshold-value
DNS flood攻击防范基于目的IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的DNS报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于目的IP地址的DNS flood攻击防范。
使能DNS flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送DNS报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了DNS flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置DNS flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(DNS服务器)的DNS报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置DNS flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的DNS报文数持续达到或超过100时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood threshold 100
·     dns-flood action
·     dns-flood detect ip
·     dns-flood port
dns-flood source-threshold命令用来配置DNS flood攻击防范基于源IP统计的全局触发阈值。
undo dns-flood source-threshold命令用来恢复缺省情况。
dns-flood source-threshold threshold-value
DNS flood攻击防范基于源IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定每秒接收到从某IP地址发出的DNS报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于源IP统计的DNS flood攻击防范。
使能DNS flood攻击防范后,设备处于攻击检测状态,当它监测到某IP地址发送DNS报文的速率持续达到或超过了该触发阈值时,即认为该IP地址发起了DNS flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到该IP地址发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中配置DNS flood攻击防范基于源IP统计的全局触发阈值为100,即当设备监测到某IP地址每秒发送的DNS报文数持续达到或超过100时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood source-threshold 100
·     dns-flood action
·     dns-flood port
dns-reply-flood action命令用来配置对DNS reply flood攻击防范的全局处理行为。
undo dns-reply-flood action命令用来恢复缺省情况。
dns-reply-flood action { drop | logging } *
不对检测到的DNS reply flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文。对于基于源IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃源自攻击者的后续所有DNS reply报文;对于基于目的IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃向被攻击者发送的后续所有DNS reply报文。
# 在攻击防范策略atk-policy-1中配置对DNS reply flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] dns-reply-flood action drop
·     dns-reply-flood detect
·     dns-reply-flood detect non-specific
·     dns-reply-flood source-threshold
·     dns-reply-flood threshold
dns-reply-flood detect命令用来开启对指定IP地址的攻击防范检测,并配置DNS reply flood攻击防范检测的触发阈值和对DNS reply flood攻击的处理行为。
undo dns-reply-flood detect命令用来关闭对指定IP地址的DNS reply flood攻击防范检测。
dns-reply-flood detect { ip ipv4-address | ipv6 ipv6-address } [ port port-list ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo dns-reply-flood detect { ip ipv4-address | ipv6 ipv6-address }
未对任何指定IP地址配置DNS reply flood攻击防范检测。
攻击防范策略视图
port port-list:指定开启DNS reply flood攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-24>。&<1-24>表示前面的参数最多可以输入24次。end-port-number必须大于或等于start-port-number。若未指定本参数,则表示使用全局配置的检测端口列表。
threshold threshold-value:指定DNS flood攻击防范基于目的IP统计的触发阈值。其中,threshold-value为向指定IP地址每秒发送的DNS reply报文数目,取值范围为1~1000000,缺省为1000。
action:设置对DNS reply flood攻击的处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有DNS reply报文都会被丢弃。
none:表示不采取任何动作。
每个攻击防范策略下可以同时对多个IP地址配置DNS reply flood攻击防范检测。
开启DNS reply flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送DNS reply报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了DNS reply flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该IP地址发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的DNS reply flood攻击防范检测,并指定检测端口为53、触发阈值为2000。当设备监测到向该IP地址的53端口每秒发送的DNS reply报文数持续达到或超过2000时,启动DNS reply flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] dns-reply-flood detect ip 192.168.1.2 port 53 threshold 2000
·     dns-reply-flood action
·     dns-reply-flood port
dns-reply-flood detect non-specific命令用来对所有非受保护IP地址开启DNS reply flood攻击防范检测。
undo dns-reply-flood detect non-specific命令用来关闭对所有非受保护IP地址的DNS reply flood攻击防范检测。
未对任何非受保护IP地址开启DNS reply-flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启DNS reply flood攻击防范检测后,设备将采用全局的阈值设置(由dns-reply-flood threshold或dns-reply-flood source-threshold命令设置)和处理行为(由dns-reply-flood action命令配置)对这些IP地址进行保护或防御。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启DNS reply-flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] dns-reply-flood detect non-specific
dns-reply-flood port命令用来配置DNS reply flood攻击防范的全局检测端口号。
undo dns-reply-flood port命令用来恢复缺省情况。
dns-reply-flood port port-list
DNS reply-flood攻击防范的全局检测端口号为53。
攻击防范策略视图
port-list:指定开启DNS reply flood攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-32>。&<1-32>表示前面的参数最多可以输入32次。end-port-number必须大于或等于start-port-number。
设备只对指定检测端口上收到的报文进行DNS reply flood攻击检测。
对于所有非受保护IP地址,或未指定检测端口的受保护IP地址,设备采用全局的检测端口进行DNS reply flood攻击检测。对于所有指定检测端口的受保护IP地址,设备针对为每个受保护IP地址指定的端口进行DNS reply flood攻击检测。
# 在攻击防范策略atk-policy-1中配置DNS reply flood攻击防范的全局检测端口为53与61000,当设备检测到访问53端口或61000端口的DNS flood攻击时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] dns-reply-flood port 53 61000
dns-reply-flood threshold命令用来配置DNS reply flood攻击防范基于目的IP统计的全局触发阈值。
undo dns-reply-flood threshold命令用来恢复缺省情况。
dns-reply-flood threshold threshold-value
DNS reply flood攻击防范基于目的IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的DNS reply报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于目的IP地址的DNS reply flood攻击防范。
开启DNS reply flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送DNS reply 报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了DNS reply flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。
对于未专门配置DNS reply flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(DNS客户端)的DNS reply报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置DNS reply flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的DNS reply报文数持续达到或超过100时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] dns-reply-flood threshold 100
·     dns-reply-flood detect ip
dns-reply-flood source-threshold命令用来配置DNS reply flood攻击防范基于源IP统计的全局触发阈值。
undo dns-reply-flood source-threshold命令用来恢复缺省情况。
dns-reply-flood source-threshold threshold-value
DNS reply flood攻击防范基于源IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定每秒接收到从某IP地址发出的DNS reply报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于源IP统计的DNS reply flood攻击防范。
开启DNS reply flood攻击防范后,设备处于攻击检测状态,当它监测到某IP地址发送DNSreply 报文的速率持续达到或超过了该触发阈值时,即认为该IP地址发起了DNS reply flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到该IP地址发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中配置DNS reply flood攻击防范基于源IP统计的全局触发阈值为100,即当设备监测到某IP地址每秒发送的DNS reply报文数持续达到或超过100时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] dns-reply-flood source-threshold 100
1.1.41  exempt acl
exempt acl命令用来配置攻击防范例外列表。
undo exempt acl命令用来恢复缺省情况。
exempt acl [ ipv6 ] { acl-number | name acl-name }
undo exempt acl [ ipv6 ]
未配置攻击防范例外列表。
攻击防范策略视图
ipv6:指定IPv6 ACL。如果未指定本参数,则表示IPv4 ACL。
acl-number:表示ACL的编号,取值范围及其代表的ACL类型如下:
·     2000~2999:表示基本ACL。
·     3000~3999:表示高级ACL。
name acl-name:指定ACL的名称。acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。
通过配置例外列表,使用ACL过滤不需要进行攻击防范检测的主机报文。当本机或接口上收到的报文与攻击防范例外列表引用的ACL中的permit规则匹配时,设备不对其进行攻击防范检测。该配置用于过滤某些被信任的安全主机发送的报文,可以有效的减小误报率,并提高服务器处理效率。
例外列表引用的ACL的permit规则中仅源地址、目的地址、源端口、目的端口、协议号和非首片分片标记参数用于匹配报文。
如果配置的攻击防范例外列表中引用的ACL不存在,或引用的ACL中未定义任何规则,例外列表不会生效。
# 在攻击防范策略atk-policy-1中配置例外列表ACL 2001,过滤来自主机1.1.1.1的报文,不对其进行攻击防范检测。
[Sysname] acl basic 2001
[attack-defense-policy-atk-policy-1] exempt acl 2001
fin-flood action命令用来配置对FIN flood攻击防范的全局处理行为。
undo fin-flood action命令用来恢复缺省情况。
fin-flood action { drop | logging } *
不对检测到的FIN flood攻击采取任何处理行为。
攻击防范策略视图
drop:表示丢弃攻击报文。对于基于源IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃源自攻击者的后续所有FIN报文;对于基于目的IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃向被攻击者发送的后续所有FIN报文。
#在攻击防范策略atk-policy-1配置对FIN flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] fin-flood action drop
·     fin-flood detect
·     fin-flood detect non-specific
·     fin-flood source-threshold
·     fin-flood threshold
fin-flood detect命令用来开启对指定IP地址的FIN flood攻击防范检测,并配置FIN flood攻击防范检测的触发阈值和对FIN flood攻击的处理行为。
undo fin-flood detect命令用来关闭对指定IP地址的FIN flood攻击防范检测。
fin-flood detect { ip ipv4-address | ipv6 ipv6-address } [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo fin-flood detect { ip ipv4-address | ipv6 ipv6-address }
未对任何指定IP地址配置FIN flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定FIN flood攻击防范基于目的IP统计的触发阈值。其中,threshold-value为向指定IP地址每秒发送的FIN报文数目,取值范围为1~1000000。
action:设置对FIN flood攻击的处理行为。若未指定本参数,则表示采用FIN flood攻击防范的全局处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有FIN报文都会被丢弃。
none:表示不采取任何动作。
使能FIN flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送FIN报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了FIN flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置FIN flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的FIN flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的FIN报文数持续达到或超过2000时,启动FIN flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] fin-flood detect ip 192.168.1.2 threshold 2000
·     fin-flood action
fin-flood detect non-specific命令用来对所有非受保护IP地址开启FIN flood攻击防范检测。
undo fin-flood detect non-specific命令用来关闭对所有非受保护IP地址的FIN flood攻击防范检测。
未对任何非受保护IP地址开启FIN flood攻击防范检测。
攻击防范策略视图
无
对所有非受保护IP地址开启FIN flood攻击防范检测后,设备将采用全局的阈值设置(由fin-flood threshold或fin-flood source-threshold命令设置)和处理行为(由fin-flood action命令配置)对这些IP地址进行保护或防御。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启FIN flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] fin-flood detect non-specific
·     fin-flood action
·     fin-flood detect
fin-flood threshold命令用来配置FIN flood攻击防范基于目的IP统计的全局触发阈值。
undo fin-flood threshold命令用来恢复缺省情况。
fin-flood threshold threshold-value
FIN flood攻击防范基于目的IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的FIN报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于目的IP地址的FIN flood攻击防范。
使能FIN flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送FIN报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了FIN flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置FIN flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的FIN报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置FIN flood攻击防范检测的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的FIN报文数持续达到或超过100时,启动FIN flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] fin-flood threshold 100
·     fin-flood action
·     fin-flood detect
fin-flood source-threshold命令用来配置FIN flood攻击防范基于源IP统计的全局触发阈值。
undo fin-flood source-threshold命令用来恢复缺省情况。
fin-flood source-threshold threshold-value
FIN flood攻击防范基于源IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定每秒接收到从某IP地址发出的FIN报文数目,取值范围为0~1000000,取值范围为0~1000000,当设置为0时,表示关闭基于源IP统计的FIN flood攻击防范。
使能FIN flood攻击防范后,设备处于攻击检测状态,当它监测到某IP地址发送FIN报文的速率持续达到或超过了该触发阈值时,即认为该IP地址发起了FIN flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到该IP地址发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中配置FIN flood攻击防范检测基于源IP统计的全局触发阈值为100,即当设备监测到某IP地址每秒发送的FIN报文数持续达到或超过100时,启动FIN flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] fin-flood source-threshold 100
·     fin-flood action
·     fin-flood detect
http-flood action命令用来配置对HTTP flood攻击防范的全局处理行为。
undo http-flood action命令用来恢复缺省情况。
http-flood action { drop | logging } *
不对检测到的HTTP flood攻击采取任何处理行为。
攻击防范策略视图
drop:表示丢弃攻击报文。对于基于源IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃源自攻击者的后续所有HTTP报文;对于基于目的IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃向被攻击者发送的后续所有HTTP报文。
# 在攻击防范策略atk-policy-1中配置对HTTP flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] http-flood action drop
·     http-flood detect non-specific
·     http-flood detect
·     http-flood source-threshold
·     http-flood threshold
http-flood detect命令用来开启对指定IP地址的HTTP flood攻击防范检测,并配置HTTP flood攻击防范的触发阈值和对HTTP flood攻击的处理行为。
undo http-flood detect命令用来关闭对指定IP地址的HTTP flood攻击防范检测。
http-flood detect { ip ipv4-address | ipv6 ipv6-address } [ port port-list ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo http-flood detect { ip ipv4-address | ipv6 ipv6-address }
未对任何指定IP地址配置HTTP flood攻击防范检测。
攻击防范策略视图
port port-list:指定开启HTTP flood攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-24>。&<1-24>表示前面的参数最多可以输入24次。end-port-number必须大于或等于start-port-number。若未指定本参数,则表示使用全局配置的检测端口列表。
threshold threshold-value:指定HTTP flood攻击防范基于目的IP统计的触发阈值。其中,threshold-value为向指定IP地址每秒发送的HTTP报文数目,取值范围为1~1000000。
action:设置对HTTP flood攻击的处理行为。若未指定本参数,则表示采用HTTP flood攻击防范的全局处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有HTTP报文都会被丢弃。
none:表示不采取任何动作。
使能HTTP flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送HTTP报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了HTTP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置HTTP flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的HTTP flood攻击防范检测,并指定检测端口为80与8080、触发阈值为2000。当设备监测到向该IP地址的80或8080端口每秒发送的HTTP报文数持续达到或超过2000时,启动HTTP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] http-flood detect ip 192.168.1.2 port 80 8080 threshold 2000
·     http-flood action
·     http-flood port
http-flood detect non-specific命令用来对所有非受保护IPv4地址开启HTTP flood攻击防范检测。
undo http-flood detect non-specific命令用来关闭对所有非受保护IPv4地址的HTTP flood攻击防范检测。
未对任何非受保护IP地址开启HTTP flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启HTTP flood攻击防范检测后,设备将采用全局的阈值设置(由http-flood threshold或http-flood source-threshold命令设置)和处理行为(由http-flood action命令配置)对这些IP地址进行保护或防御。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启HTTP flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] http-flood detect non-specific
·     http-flood action
·     http-flood detect
http-flood port命令用来配置HTTP flood攻击防范的全局检测端口号。
undo http-flood port命令用来恢复缺省情况。
http-flood port port-list
HTTP flood攻击防范的全局检测端口号为80。
攻击防范策略视图
port-list:指定开启HTTP flood攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-32>。&<1-32>表示前面的参数最多可以输入32次。end-port-number必须大于或等于start-port-number。
设备只对指定检测端口上收到的报文进行HTTP flood攻击检测。
对于所有非受保护IP地址,或未指定检测端口的受保护IP地址,设备采用全局的检测端口进行HTTP flood攻击检测。对于所有指定检测端口的受保护IP地址,设备针对为每个受保护IP地址指定的端口进行HTTP flood攻击检测。
# 在攻击防范策略atk-policy-1中配置DNS flood攻击防范的全局检测端口为80与8080,当设备检测到访问80端口或8080端口的HTTP flood攻击时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] http-flood port 80 8080
·     http-flood action
·     http-flood detect
http-flood threshold命令用来配置HTTP flood攻击防范基于目的IP统计的全局触发阈值。
undo http-flood threshold命令用来恢复缺省情况。
http-flood threshold threshold-value
HTTP flood攻击防范基于目的IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的HTTP报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于目的IP地址的HTTP flood攻击防范。
使能HTTP flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送HTTP报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了HTTP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置HTTP flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器)的HTTP报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置HTTP flood攻击防范的全局触发阈值为100, 即当设备监测到向某IP地址每秒发送的HTTP报文数持续达到或超过100时,启动HTTP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] http-flood threshold 100
·     http-flood action
·     http-flood detect
·     http-flood port
http-flood source-threshold命令用来配置HTTP flood攻击防范基于源IP统计的全局触发阈值。
undo http-flood source-threshold命令用来恢复缺省情况。
http-flood source-threshold threshold-value
HTTP flood攻击防范基于源IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定每秒接收到从某IP地址发出的HTTP报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于源IP统计的HTTP flood攻击防范。
使能HTTP flood攻击防范后,设备处于攻击检测状态,当它监测到某IP地址发送HTTP报文的速率持续达到或超过了该触发阈值时,即认为该IP地址发起了HTTP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到该IP地址发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中配置HTTP flood攻击防范基于源IP统计的全局触发阈值为100, 即当设备监测到某IP地址每秒发送的HTTP报文数持续达到或超过100时,启动HTTP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] http-flood source-threshold 100
·     http-flood action
·     http-flood detect
·     http-flood port
http-slow-attack action命令用来配置HTTP慢速攻击防范的全局处理行为。
undo http-slow-attack action命令用来恢复缺省情况。
http-slow-attack action logging
不对检测到的HTTP慢速攻击采取任何措施。
攻击防范策略视图
# 在攻击防范策略atk-policy-1中配置HTTP慢速攻击防范的全局处理行为为输出告警日志和阻断并丢弃来自该IP地址的后续报文。
[Sysname-attack-defense-policy-atk-policy-1] http-slow-attack action logging
·     http-slow-attack detect
·     http-slow-attack detect non-specific
·     http-slow-attack period
·     http-slow-attack port
·     http-slow-attack threshold
http-slow-attack detect命令用来开启对指定IP地址的HTTP慢速攻击防范检测,并配置HTTP慢速攻击防范检测的检测端口号、触发阈值、检测周期和对HTTP慢速攻击的处理行为。
undo http-slow-attack detect命令用来关闭对指定IP地址的HTTP慢速攻击防范检测。
http-slow-attack detect { ip ipv4-address | ipv6 ipv6-address } [ port { start-port-number [ to end-port-number ] } &<1-16> ] [ threshold { alert-number alert-number | content-length content-length | payload-length payload-length | packet-number packet-number }* ] [ period period ] [ action logging ]
undo http-slow-attack detect { ip ipv4-address | ipv6 ipv6-address }
未对任何指定IP地址开启HTTP慢速攻击防范检测。
攻击防范策略视图
port port-list:指定开启慢速攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-16>。&<1-16>表示前面的参数最多可以输入16次。end-port-number必须大于或等于start-port-number。若未指定本参数,则表示使用全局配置的检测端口列表。
threshold:指定HTTP慢速攻击防范的阈值。若未指定本参数,则表示采用慢速攻击防范的全局阈值。
alert-number alert-number:指定触发慢速攻击检测的HTTP并发连接数,取值范围为1~1200000,缺省为5000。
content-length content-length:指定HTTP报文Content-Length字段的阈值,取值范围为100~100000000,缺省为10000。
payload-length payload-length:指定HTTP报文实际载荷的阈值,取值范围为1~1000,缺省为50。
packet-number packet-number:指定异常报文的防范阈值,取值范围为1~1000,缺省为10。
period period:攻击检测周期,取值范围为1~1200,单位为秒。若未指定本参数,则表示采用慢速攻击防范的全局检测周期。
action:设置对HTTP慢速攻击的处理行为。若未指定本参数,则表示采用慢速攻击防范的全局处理行为。
若指定threshold关键字,而未指定alert-number、content-length、payload-length、packet-number参数中的一个或多个,未指定的参数采用缺省值,而不采用全局阈值。
# 在攻击防范策略atk-policy-1中开启对IP地址1.1.1.1的HTTP慢速攻击检测,并指定检测端口为80和8080,指定HTTP慢速攻击检测的触发阈值为3000,HTTP报文首部Content-Length字段大于10000且负载长度小于20时,则认为该报文异常。当异常报文个数超过10后,将该源IP地址加入告警日志。
[Sysname-attack-defense-policy-atk-policy-1] http-slow-attack detect ip 1.1.1.1 port 80 8080 threshold alert-number 3000 content-length 10000 payload-length 20 packet-number 10  action logging
·     http-slow-attack action
1.1.55  http-slow-attack detect non-specific
http-slow-attack detect non-specific命令用来对所有非受保护IP地址开启HTTP慢速攻击防范检测。
undo http-slow-attack detect non-specific命令用来关闭对所有非受保护IP地址的HTTP慢速攻击防范检测。
未对任何非受保护IP地址开启HTTP慢速攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启HTTP慢速攻击防范检测后,设备将采用全局的阈值设置(由http-slow-attack threshold命令配置)、周期设置(由http-slow-attack period命令配置)、端口设置(由http-slow-attack port命令配置)和处理行为(由http-slow-attack action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启HTTP慢速攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] http-slow-attack detect non-specific
1.1.56  http-slow-attack period
http-slow-attack period命令用来配置HTTP慢速攻击防范的检测周期。
undo http-slow-attack period命令用来恢复缺省情况。
http-slow-attack period period
HTTP慢速攻击检测周期为60秒。
攻击防范策略视图
period period:攻击检测周期,取值范围为1~1200,缺省值为60,单位为秒。
# 在攻击防范策略atk-policy-1中配置HTTP慢速攻击检测周期为10秒。
[Sysname-attack-defense-policy-atk-policy-1] http-slow-attack period 10
1.1.57  http-slow-attack port
http-slow-attack port命令用来配置慢速攻击防范的全局检测端口号。
undo http-slow-attack port命令用来恢复缺省情况。
http-slow-attack port port-list &<1-32>
慢速攻击防范的全局检测端口号为80。
攻击防范策略视图
port-list:指定开启慢速攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-32>。&<1-32>表示前面的参数最多可以输入32次。end-port-number必须大于或等于start-port-number。
设备只对指定检测端口的报文进行慢速攻击检测。
对于所有非受保护IP地址,或未指定检测端口的受保护IP地址,设备采用全局的检测端口进行慢速攻击检测。对于所有指定检测端口的受保护IP地址,设备针对为每个受保护IP地址指定的端口进行慢速攻击检测。
一般情况下,建议尽量使用缺省端口号80作为慢速攻击防范的全局检测端口号。如果需要通过本命令指定非缺省端口作为慢速攻击防范的全局检测端口号,需确保配置的端口号为HTTP协议的通信端口号。否则会给设备带来大量无效的HTTP慢速攻击检测,耗费大量系统资源。
# 在攻击防范策略atk-policy-1中配置慢速攻击防范的全局检测端口为80与8000,设备统计目的端口为80或8000的并发连接数,超过阈值后启动慢速攻击报文检测。
[Sysname] attack-defense policy atk-policy-1
[Sysname-attack-defense-policy-atk-policy-1] http-slow-attack port 80 8000
1.1.58  http-slow-attack threshold
http-slow-attack threshold命令用来配置HTTP慢速攻击防范的全局触发阈值。
undo http-slow-attack threshold命令用来恢复缺省情况。
http-slow-attack threshold [ alert-number alert-number | content-length content-length | payload-length payload-length | packet-number packet-number ]*
当HTTP报文连接数超过5000时,触发HTTP慢速攻击检测功能。当HTTP报文首部Content-Length字段的值大于10000,并且HTTP报文负载长度小于50时,则认为设备受到了HTTP慢速攻击。当检测周期内,异常报文个数超过10个,则执行相应的HTTP慢速攻击防范处理行为。
攻击防范策略视图
alert-number alert-number:指定触发慢速攻击检查的HTTP每秒并发连接数,取值范围为1~1200000,缺省为5000。
payload-length payload-length:指定报文实际载荷的阈值,取值范围为1~1000,缺省为50。
当设备的HTTP并发连接数超过HTTP慢速攻击检测的触发阈值时,触发HTTP慢速攻击检测功能。之后,若设备收到的HTTP报文首部Content-Length字段的值大于content-length,并且HTTP报文负载长度小于payload-length,则认为设备受到了HTTP慢速攻击。当设备收到报文的数目超过配置的异常报文防范阈值,则执行相应的HTTP慢速攻击防范处理行为。
阈值参数可选配,如未配置,则默认为缺省值。
多次命令行配置以最后一次为准。
# 在攻击防范策略atk-policy-1中配置HTTP慢速攻击检测,配置HTTP慢速攻击检测的触发阈值为3000,HTTP报文首部Content-Length字段的阈值为10000,HTTP报文实际载荷阈值为20,异常报文的防范阈值为10。
[Sysname-attack-defense-policy-atk-policy-1] http-slow-attack  threshold alert-number 3000 content-length 10000 payload-length 20 packet-number 10
1.1.59  https-flood action
https-flood action命令用来配置对HTTPS flood攻击防范的全局处理行为。
undo https-flood action命令用来恢复缺省情况。
https-flood action { client-verify | drop | logging } *
不对检测到的HTTPS flood攻击采取任何处理行为。
攻击防范策略视图
client-verify:表示自动将受到攻击的IP地址添加到HTTPS客户端验证的受保护IP列表中。若客户端验证功能已使能,则对客户端与受保护IP地址之间的连接进行代理。本参数对基于源IP统计的泛洪攻击不生效。
drop:表示丢弃攻击报文。对于基于源IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃源自攻击者的后续所有HTTPS报文;对于基于目的IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃向被攻击者发送的后续所有HTTPS报文。
logging:表示输出告警日志,即设备检测到攻击发生时,生成告警信息,生成的告警信息将被发送到日志系统。
本命令中client-verify参数的使用需要和HTTPS客户端验证功能配合。开启了HTTPS客户端验证的接口或安全域检测到HTTPS flood攻击时,若本命令中指定了client-verify参数,则设备会将受攻击的IP地址动态添加到相应客户端验证的受保护IP列表中,并对与这些IP地址建立的连接进行代理。若接口或安全域上未开启相应的代理功能,则不会对任何连接进行代理。
输出告警日志功能开启后,设备生成的告警日志信息不会输出到控制台和监视终端,可通过执行display logbuffer命令进行查看。有关display logbuffer命令的详细介绍,请参见“设备管理命令参考”中的“信息中心”。
# 在攻击防范策略atk-policy-1中配置对HTTPS flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] https-flood action drop
·     client-verify https enable
·     https-flood detect non-specific
·     https-flood source-threshold
·     https-flood threshold
1.1.60  https-flood detect
https-flood detect命令用来开启对指定IP地址的HTTPS flood攻击防范检测,并配置HTTPS flood攻击防范的触发阈值和对HTTPS flood攻击的处理行为。
undo https-flood detect命令用来关闭对指定IP地址的HTTPS flood攻击防范检测。
https-flood detect { ip ipv4-address | ipv6 ipv6-address } [ port port-list ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo https-flood detect { ip ipv4-address | ipv6 ipv6-address }
未对任何指定IP地址配置HTTPS flood攻击防范检测。
攻击防范策略视图
ip ipv4-address:指定要保护的IPv4地址。该IPv4地址不能为255.255.255.255或0.0.0.0。
ipv6 ipv6-address:指定要保护的IPv6地址。该IPv6地址不能为组播地址或::。
port port-list:指定开启HTTPS flood攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-24>。&<1-24>表示前面的参数最多可以输入24次。end-port-number必须大于或等于start-port-number。若未指定本参数,则表示使用全局配置的检测端口列表。
threshold threshold-value:指定HTTPS flood攻击防范基于目的IP统计的触发阈值。其中,threshold-value为向指定IP地址每秒发送的HTTPS报文数目,取值范围为1~1000000。
action:设置对HTTPS flood攻击的处理行为。若未指定本参数,则表示采用HTTPS flood攻击防范的全局处理行为。
client-verify:表示自动将受到攻击的IP地址添加到HTTP客户端验证的受保护IP列表中。若客户端验证功能已使能,则对客户端与受保护IP地址之间的连接进行代理。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有HTTPS报文都会被丢弃。
none:表示不采取任何动作。
使能HTTPS flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送HTTPS报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了HTTPS flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置HTTPS flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的HTTPS flood攻击防范检测,并指定检测端口为443、触发阈值为2000。当设备监测到向该IP地址的443端口每秒发送的HTTP报文数持续达到或超过2000时,启动HTTPS flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] https-flood detect ip 192.168.1.2 port 443 threshold 2000
·     https-flood action
·     https-flood port
1.1.61  https-flood detect non-specific
https-flood detect non-specific命令用来对所有非受保护IPv4地址开启HTTPS flood攻击防范检测。
undo https-flood detect non-specific命令用来关闭对所有非受保护IPv4地址的HTTPS flood攻击防范检测。
未对任何非受保护IP地址开启HTTPS flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启HTTPS flood攻击防范检测后,设备将采用全局的阈值设置(由https-flood threshold或https-flood source-threshold命令设置)和处理行为(由https-flood action命令配置)对这些IP地址进行保护或防御。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启HTTPS flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] https-flood detect non-specific
1.1.62  https-flood port
https-flood port命令用来配置HTTPS flood攻击防范的全局检测端口号。
undo https-flood port命令用来恢复缺省情况。
https-flood port port-list
HTTPS flood攻击防范的全局检测端口号为443。
攻击防范策略视图
port-list:指定开启HTTPS flood攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-32>。&<1-32>表示前面的参数最多可以输入32次。end-port-number必须大于或等于start-port-number。
设备只对指定检测端口上收到的报文进行HTTPS flood攻击检测。
对于所有非受保护IP地址,或未指定检测端口的受保护IP地址,设备采用全局的检测端口进行HTTPS flood攻击检测。对于所有指定检测端口的受保护IP地址,设备针对为每个受保护IP地址指定的端口进行HTTPS flood攻击检测。
# 在攻击防范策略atk-policy-1中配置HTTPS flood攻击防范的全局检测端口为443,当设备检测到访问443端口的HTTPS flood攻击时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] https-flood port 443
1.1.63  https-flood threshold
https-flood threshold命令用来配置HTTPS flood攻击防范基于目的IP统计的全局触发阈值。
undo https-flood threshold命令用来恢复缺省情况。
https-flood threshold threshold-value
HTTPS flood攻击防范基于目的IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的HTTPS报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于目的IP地址的HTTPS flood攻击防范。
使能HTTPS flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送HTTPS报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了HTTPS flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置HTTPS flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTPS服务器)的HTTPS报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置HTTPS flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的HTTPS报文数持续达到或超过100时,启动HTTPS flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] https-flood threshold 100
·     https-flood port
1.1.64  https-flood source-threshold
https-flood source-threshold命令用来配置HTTPS flood攻击防范基于源IP统计的全局触发阈值。
undo https-flood source-threshold命令用来恢复缺省情况。
https-flood source-threshold threshold-value
HTTPS flood攻击防范基于源IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定每秒接收到从某IP地址发出的HTTPS报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于源IP统计的HTTPS flood攻击防范。
使能HTTPS flood攻击防范后,设备处于攻击检测状态,当它监测到某IP地址发送HTTPS报文的速率持续达到或超过了该触发阈值时,即认为该IP地址发起了HTTPS flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到该IP地址发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中配置HTTPS flood攻击防范基于源IP统计的全局触发阈值为100,即当设备监测到某IP地址每秒发送的HTTPS报文数持续达到或超过100时,启动HTTPS flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] https-flood source-threshold 100
·     https-flood port
1.1.65  icmp-flood action
icmp-flood action命令用来配置对ICMP flood攻击防范的全局处理行为。
undo icmp-flood action命令用来恢复缺省情况。
icmp-flood action { drop | logging } *
不对检测到的ICMP flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文。对于基于源IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃源自攻击者的后续所有ICMP报文;对于基于目的IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃向被攻击者发送的后续所有ICMP报文。
# 在攻击防范策略atk-policy-1中配置对ICMP flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood action drop
·     icmp-flood detect non-specific
·     icmp-flood detect ip
·     icmp-flood source-threshold
·     icmp-flood threshold
1.1.66  icmp-flood detect ip
icmp-flood detect ip命令用来开启对指定IP地址的ICMP flood攻击防范检测,并配置ICMP flood攻击防范检测的触发阈值和对ICMP flood攻击的处理行为。
undo icmp-flood detect ip命令用来关闭对指定IP地址的ICMP flood攻击防范检测。
icmp-flood detect ip ip-address [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo icmp-flood detect ip ip-address
未对任何指定IP地址配置ICMP flood 攻击防范触发阈值。
攻击防范策略视图
ip ip-address:指定要保护的IP地址。该IP地址不能为255.255.255.255或0.0.0.0。
threshold threshold-value:指定ICMP flood攻击防范基于目的IP统计的触发阈值。其中,threshold-value为向指定IP地址每秒发送的ICMP报文数目,取值范围为1~1000000。
action:设置对ICMP flood攻击的处理行为。若未指定本参数,则表示采用ICMP flood攻击防范的全局处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有ICMP报文都会被丢弃。
none:表示不采取任何动作。
使能ICMP flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送ICMP报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了ICMP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置ICMP flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的ICMP flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的ICMP报文数持续达到或超过2000时,启动ICMP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood detect ip 192.168.1.2 threshold 2000
·     icmp-flood action
1.1.67  icmp-flood detect non-specific
icmp-flood detect non-specific命令用来对所有非受保护IPv4地址开启ICMP flood攻击防范检测。
undo icmp-flood detect non-specific命令用来关闭对所有非受保护IPv4地址的ICMP flood攻击防范检测。
未对任何非受保护IPv4地址开启ICMP flood攻击防范检测。
攻击防范策略视图
对任何非受保护IPv4地址开启ICMP flood攻击防范检测后,设备将采用全局的阈值设置(由icmp-flood threshold或icmp-flood source-threshold命令设置)和处理行为(由icmp-flood action命令配置)对这些IP地址进行保护或防御。
# 在攻击防范策略atk-policy-1中,对所有非受保护IPv4地址开启ICMP flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood detect non-specific
·     icmp-flood action
1.1.68  icmp-flood threshold
icmp-flood threshold命令用来配置ICMP flood攻击防范基于目的IP统计的全局触发阈值。
undo icmp-flood threshold命令用来恢复缺省情况。
icmp-flood threshold threshold-value
ICMP flood攻击防范基于目的IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的ICMP报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于目的IP地址的ICMP flood攻击防范。
使能ICMP flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送ICMP报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了ICMP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置ICMP flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的ICMP报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置ICMP flood攻击防范检测的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的ICMP报文数持续达到或超过100时,启动ICMP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood threshold 100
·     icmp-flood action
·     icmp-flood detect
1.1.69  icmp-flood source-threshold
icmp-flood source-threshold命令用来配置ICMP flood攻击防范基于源IP统计的全局触发阈值。
undo icmp-flood source-threshold命令用来恢复缺省情况。
icmp-flood source-threshold threshold-value
ICMP flood攻击防范基于源IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定每秒接收到从某IP地址发出的ICMP报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于源IP统计的ICMP flood攻击防范。
使能ICMP flood攻击防范后,设备处于攻击检测状态,当它监测到某IP地址发送ICMP报文的速率持续达到或超过了该触发阈值时,即认为该IP地址发起了ICMP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该IP发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中配置ICMP flood攻击防范检测基于源IP统计的全局触发阈值为100,即当设备监测到某IP地址每秒发送的ICMP报文数持续达到或超过100时,启动ICMP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood source-threshold 100
·     icmp-flood action
·     icmp-flood detect
1.1.70  icmpv6-flood action
icmpv6-flood action命令用来配置对ICMPv6 flood攻击防范的全局处理行为。
undo icmpv6-flood action命令用来恢复缺省情况。
icmpv6-flood action { drop | logging } *
不对检测到的ICMPv6 flood攻击采取任何防范措施。
攻击防范策略视图
drop:表示丢弃攻击报文。对于基于源IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃源自攻击者的后续所有ICMPv6报文;对于基于目的IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃向被攻击者发送的后续所有ICMPv6报文。
# 在攻击防范策略atk-policy-1中配置对ICMPv6 flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood action drop
·     icmpv6-flood detect ipv6
·     icmpv6-flood detect non-specific
·     icmpv6-flood source-threshold
·     icmpv6-flood threshold
1.1.71  icmpv6-flood detect ipv6
icmpv6-flood detect ipv6命令用来开启对指定IPv6地址的ICMPv6 flood攻击防范检测,并配置ICMPv6 flood攻击防范检测的触发阈值和对ICMPv6 flood攻击的处理行为。
undo icmpv6-flood detect ipv6命令用来关闭对指定IPv6地址的ICMPv6 flood攻击防范检测。
icmpv6-flood detect ipv6 ipv6-address [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo icmpv6-flood detect ipv6 ipv6-address
未对任何指定IPv6地址配置ICMPv6 flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定ICMPv6 flood攻击防范基于目的IP统计的触发阈值。其中,threshold-value为向指定IP地址每秒发送的ICMPv6报文数目,取值范围为1~1000000。
action:设置对ICMPv6 flood攻击的处理行为。若未指定本参数,则表示采用ICMPv6 flood攻击防范的全局处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有ICMPv6报文都会被丢弃。
none:表示不采取任何动作。
使能ICMPv6 flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送ICMPv6报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了ICMPv6 flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IPv6地址配置ICMPv6 flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址2012::12的ICMPv6 flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的ICMP报文数持续达到或超过2000时,启动ICMPv6 flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood detect ipv6 2012::12 threshold 2000
·     icmpv6-flood action
1.1.72  icmpv6-flood detect non-specific
icmpv6-flood detect non-specific命令用来对所有非受保护IPv6地址开启ICMPv6 flood攻击防范检测。
undo icmpv6-flood detect non-specific命令用来关闭对所有非受保护IPv6地址的ICMPv6 flood攻击防范检测。
未对任何非受保护IPv6地址开启ICMPv6 flood攻击防范检测。
攻击防范策略视图
对所有非受保护IPv6地址开启ICMPv6 flood攻击防范检测后,设备将采用全局的阈值设置(由icmpv6-flood threshold或icmpv6-flood source-threshold命令设置)和处理行为(由icmpv6-flood action命令配置)对这些IP地址进行保护或防御。
# 在攻击防范策略atk-policy-1中,对所有非受保护IPv6地址开启ICMPv6 flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood detect non-specific
1.1.73  icmpv6-flood threshold
icmpv6-flood threshold命令用来配置ICMPv6 flood攻击防范基于目的IP统计的全局触发阈值。
undo icmpv6-flood threshold命令用来恢复缺省情况。
icmpv6-flood threshold threshold-value
ICMPv6 flood攻击防范基于目的IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定向某IPv6地址每秒发送的ICMPv6报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于目的IP地址的ICMPv6 flood攻击防范。
使能ICMPv6 flood攻击防范后,设备处于攻击检测状态,当它监测到向某IPv6地址发送ICMPv6报文的速率持续达到或超过了该触发阈值时,即认为该IPv6地址受到了ICMPv6 flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置ICMPv6 flood攻击防范检测的IPv6地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的ICMPv6报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置ICMPv6 flood攻击防范检测的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的ICMPv6报文数持续达到或超过100时,启动ICMPv6 flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood threshold 100
1.1.74  icmpv6-flood source-threshold
icmpv6-flood source-threshold命令用来配置ICMPv6 flood攻击防范基于源IP统计的全局触发阈值。
undo icmpv6-flood source-source-threshold命令用来恢复缺省情况。
icmpv6-flood source-threshold threshold-value
undo icmpv6-flood source-threshold
ICMPv6 flood攻击防范基于源IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定每秒接收到从某IP地址发出的ICMPv6报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于源IP统计的ICMPv6 flood攻击防范。
使能ICMPv6 flood攻击防范后,设备处于攻击检测状态,当它监测到某IP地址发送ICMPv6报文的速率持续达到或超过了该触发阈值时,即认为该IP地址发起了ICMPv6 flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到该IP地址发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中配置ICMPv6 flood攻击防范检测基于源IP统计的全局触发阈值为100,即当设备监测到某IP地址每秒发送的ICMPv6报文数持续达到或超过100时,启动ICMPv6 flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood source-threshold 100
1.1.75  reset attack-defense policy flood
reset attack-defense policy flood命令用来清除flood攻击防范受保护IP表项的统计信息。
reset attack-defense policy policy-name flood protected { ip | ipv6 } statistics
policy-name:攻击防范策略名称,为1~31个字符的字符串,不区分大小写。合法取值包括大写字母、小写字母、数字、特殊字符“_”和“-”。
ip:指定IPv4类型的flood受保护IP表项。
ipv6:指定IPv6类型的flood受保护IP表项。
statistics:清除指定类型的flood受保护IP表项的统计信息。
# 清除攻击防范策略abc中所有IPv4类型的flood保护IP表项的统计信息
<Sysname> reset attack-defense policy abc flood protected ip statistics
# 清除攻击防范策略abc中所有IPv6类型的flood保护IP表项的统计信息
<Sysname> reset attack-defense policy abc flood protected ipv6 statistics
·     display attack-defense policy ip
·     display attack-defense policy ipv6
1.1.76  reset attack-defense statistics interface
reset attack-defense statistics interface命令用来清除接口上的攻击防范统计信息。
reset attack-defense statistics interface interface-type interface-number
# 清除接口Vlan-interface100上的攻击防范的统计信息。
<Sysname> reset attack-defense statistics interface vlan-interface 100
1.1.77  reset attack-defense statistics local
reset attack-defense statistics local命令用来清除本机攻击防范的统计信息。
# 清除本机上所有攻击防范的统计信息。
<Sysname> reset attack-defense statistics local
·     display attack-defense statistics local
1.1.78  reset attack-defense top-attack-statistics
reset attack-defense top-attack-statistics命令用来清除Top10的攻击排名统计信息。
# 清除Top10的攻击排名统计信息。
<Sysname> reset attack-defense top-attack-statistics
·     display attack-defense top-attack-statistics
1.1.79  rst-flood action
rst-flood action命令用来配置对RST flood攻击防范的全局处理行为。
undo rst-flood action命令用来恢复缺省情况。
rst-flood action { drop | logging } *
不对检测到的RST flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文。对于基于源IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃源自攻击者的后续所有RST报文;对于基于目的IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃向被攻击者发送的后续所有RST报文。
# 在攻击防范策略atk-policy-1中配置对RST flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] rst-flood action drop
·     rst-flood detect
·     rst-flood detect non-specific
·     rst-flood source-threshold
·     rst-flood threshold
1.1.80  rst-flood detect
rst-flood detect命令用来开启对指定IP地址的RST flood攻击防范检测,并配置RST flood攻击防范的触发阈值和对RST flood攻击的处理行为。
undo rst-flood命令用来关闭对指定IP地址的RST flood攻击防范检测。
rst-flood detect { ip ipv4-address | ipv6 ipv6-address } [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo rst-flood detect { ip ipv4-address | ipv6 ipv6-address }
未对任何指定IP地址配置RST flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定RST flood攻击防范基于目的IP统计的触发阈值。其中,threshold-value为向指定IP地址每秒发送的RST报文数目,取值范围为1~1000000。
action:设置对RST flood攻击的处理行为。若未指定本参数,则表示采用RST flood攻击防范的全局处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有RST报文都会被丢弃。
none:表示不采取任何动作。
使能RST flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送RST报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了RST flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置RST flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的RST flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的RST报文数持续达到或超过2000时,启动RST flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] rst-flood detect ip 192.168.1.2 threshold 2000
·     rst-flood action
1.1.81  rst-flood detect non-specific
rst-flood detect non-specific命令用来对所有非受保护IP地址开启RST flood攻击防范检测。
undo rst-flood detect non-specific命令用来关闭对所有非受保护IP地址的RST flood攻击防范检测。
未对任何非受保护IP地址开启RST flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启RST flood攻击防范检测后,设备将采用全局的阈值设置(由rst-flood threshold或rst-flood source-threshold命令设置)和处理行为(由rst-flood action命令配置)对这些IP地址进行保护或防御。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启RST flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] rst-flood detect non-specific
·     rst-flood action
·     rst-flood detect
1.1.82  rst-flood threshold
rst-flood threshold命令用来配置RST flood攻击防范基于目的IP统计的全局触发阈值。
undo rst-flood threshold命令用来恢复缺省情况。
rst-flood threshold threshold-value
RST flood攻击防范基于目的IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的RST报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于目的IP地址的RST flood攻击防范。
使能RST flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送RST报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了RST flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置RST flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的RST报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置RST flood攻击防范检测的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的RST报文数持续达到或超过100时,启动RST flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] rst-flood threshold 100
·     rst-flood action
·     rst-flood detect
1.1.83  rst-flood source-threshold
rst-flood source-threshold命令用来配置RST flood攻击防范基于源IP统计的全局触发阈值。
undo rst-flood source-threshold命令用来恢复缺省情况。
rst-flood source-threshold threshold-value
RST flood攻击防范基于源IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定每秒接收到从某IP地址发出的RST报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于源IP统计的RST flood攻击防范。
使能RST flood攻击防范后,设备处于攻击检测状态,当它监测到某IP地址发出RST报文的速率持续达到或超过了该触发阈值时,即认为该IP地址发起了RST flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中配置RST flood攻击防范检测的基于源IP统计的全局触发阈值为100,即当设备监测到某IP地址每秒发送的RST报文数持续达到或超过100时,启动RST flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] rst-flood source-threshold 100
·     rst-flood action
·     rst-flood detect
1.1.84  scan detect
scan detect命令用来配置开启指定级别的扫描攻击防范。
undo scan detect命令用来关闭指定级别的扫描攻击防范。
scan detect level { { high | low | medium } | user-defined { port-scan-threshold threshold-value | ip-sweep-threshold threshold-value } * [ period period-value ] } action { drop | logging } *
undo scan detect
扫描攻击防范处于关闭状态。
攻击防范策略视图
level:指定攻击防范的检测级别。
high:表示高防范级别,该级别能检测出大部分的扫描攻击,但对活跃主机误报率较高,即将可提供服务的主机的报文错误判断为攻击报文的概率比较高。该级别的扫描攻击检测周期为10秒,针对端口扫描的防范阈值为5000 packets,针对地址扫描的防范阈值为5000 packets。
low:表示低防范级别,该级别提供基本的扫描攻击检测,有很低的误报率,但对于一些扫描攻击类型不能检出。该级别的扫描攻击检测周期为10秒,针对端口扫描的防范阈值为100000 packets,针对地址扫描的防范阈值为100000 packets。
medium:表示中防范级别,该级别有适中的攻击检出率与误报率,通常能够检测出Filtered Scan等攻击。该级别的扫描攻击检测周期为10秒,针对端口扫描的防范阈值为40000 packets,针对地址扫描的防范阈值为40000 packets。
user-defined:表示用户自定义防范规则,用户可根据网络实际情况和需求指定端口扫描、地址扫描的防范阈值和检测周期。
port-scan-threshold threshold-value:指定端口扫描攻击防范的触发阈值。其中,threshold-value为源IP地址每个检测周期内发送的目的端口不同的报文数目,取值范围为1~1000000000。
ip-sweep-threshold threshold-value:指定地址扫描攻击防范的触发阈值。其中,threshold-value为源IP地址每个检测周期内发往不同目的IP地址的报文数目,取值范围为1~1000000000。
period period-value:表示检测周期,period-value的取值范围为1~1000000000,单位为秒,缺省值为10。
action:设置对扫描攻击的处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,由该攻击者发送的报文都将被丢弃。
logging:表示输出告警日志,即设备检测到攻击发生时,生成记录告警信息,生成的告警信息将被发送到日志系统。
# 在攻击防范策略atk-policy-1中配置扫描攻击的检测级别为低级别,处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] scan detect level low action drop
1.1.85  signature { large-icmp | large-icmpv6 } max-length
signature { large-icmp | large-icmpv6 } max-length命令用来配置启动Large ICMP攻击防范的ICMP报文长度的最大值。
undo signature { large-icmp | large-icmpv6 } max-length命令用来恢复缺省情况。
signature { large-icmp | large-icmpv6 } max-length length
启动Large ICMP攻击防范的ICMP报文和ICMPv6报文长度的最大值均为4000字节。
攻击防范策略视图
large-icmp:表示超大ICMP报文攻击防范。
large-icmpv6:表示超大ICMPv6报文攻击防范。
length:表示ICMP报文长度的最大值,ICMP报文取值范围为28~65534,ICMPv6报文取值范围为48~65534,单位为字节。
# 在攻击防范策略atk-policy-1中配置启动Large ICMP攻击防范的ICMP报文长度的最大值为50000字节。
[Sysname-attack-defense-policy-atk-policy-1] signature large-icmp max-length 50000
·     signature detect
1.1.86  signature detect
signature detect命令用来开启指定类型单包攻击报文的特征检测,并设置攻击防范的处理行为。
undo signature detect命令用来关闭对指定类型的单包攻击报文的特征检测。
signature detect { fraggle | fragment | impossible | land | large-icmp | large-icmpv6 | smurf | snork | tcp-all-flags | tcp-fin-only | tcp-invalid-flags | tcp-null-flag | tcp-syn-fin | tiny-fragment | traceroute | udp-bomb | winnuke } [ action { { drop | logging } * | none } ]
undo signature detect { fraggle | fragment | impossible | land | large-icmp | large-icmpv6 | smurf | snork | tcp-all-flags | tcp-fin-only | tcp-invalid-flags | tcp-null-flag | tcp-syn-fin | tiny-fragment | traceroute | udp-bomb | winnuke }
signature detect { ip-option-abnormal | ping-of-death | teardrop } action { drop | logging } *
undo signature detect { ip-option-abnormal | ping-of-death | teardrop }
signature detect icmp-type { icmp-type-value | address-mask-reply | address-mask-request | destination-unreachable | echo-reply | echo-request | information-reply | information-request | parameter-problem | redirect | source-quench | time-exceeded | timestamp-reply | timestamp-request } [ action { { drop | logging } * | none } ]
undo signature detect icmp-type { icmp-type-value | address-mask-reply | address-mask-request | destination-unreachable | echo-reply | echo-request | information-reply | information-request | parameter-problem | redirect | source-quench | time-exceeded | timestamp-reply | timestamp-request }
signature detect icmpv6-type { icmpv6-type-value | destination-unreachable | echo-reply | echo-request | group-query | group-reduction | group-report | packet-too-big | parameter-problem | time-exceeded } [ action { { drop | logging } * | none } ]
undo signature detect icmpv6-type { icmpv6-type-value | destination-unreachable | echo-reply | echo-request | group-query | group-reduction | group-report | packet-too-big | parameter-problem | time-exceeded }
signature detect ip-option { option-code | internet-timestamp | loose-source-routing | record-route | route-alert | security | stream-id | strict-source-routing } [ action { { drop | logging } * | none } ]
undo signature detect ip-option { option-code | internet-timestamp | loose-source-routing | record-route | route-alert | security | stream-id | strict-source-routing }
signature detect ipv6-ext-header ext-header-value [ action { { drop | logging } * | none } ]
undo signature detect ipv6-ext-header next-header-value
signature detect ipv6-ext-header-abnormal [ action { { drop | logging } * | none } ]
undo signature detect ipv6-ext-header-abnormal
signature detect ipv6-ext-header-exceed [ limit limit-value ] [ action { { drop | logging } * | none } ]
undo signature detect ipv6-ext-header-exceed
所有类型的单包攻击报文的特征检测均处于关闭状态。
攻击防范策略视图
fraggle:表示Fraggle类型的报文攻击。
fragment:表示IP分片报文攻击。
icmp-type:表示ICMP类型的报文攻击。可以指定报文的类型值,或者指定报文的类型关键字。
·     icmp-type-value:表示ICMP报文类型的数值,取值范围为0~255。
·     address-mask-reply:表示ICMP address mask reply类型的报文攻击。
·     address-mask-request:表示ICMP address mask request类型的报文攻击。
·     destination-unreachable:表示ICMP destination unreachable类型的报文攻击。
·     echo-reply:表示ICMP echo reply类型的报文攻击。
·     echo-request:表示ICMP echo request类型的报文攻击。
·     information-reply:表示ICMP information reply类型的报文攻击。
·     information-request:表示ICMP information request类型的报文攻击。
·     parameter-problem:表示ICMP para problem类型的报文攻击。
·     redirect:表示ICMP redirect类型的报文攻击。
·     source-quench:表示ICMP source quench类型的报文攻击。
·     time-exceeded:表示ICMP time exceeded类型的报文攻击。
·     timestamp-reply:表示ICMP timestamp reply类型的报文攻击。
·     timestamp-request:表示ICMP timestamp request类型的报文攻击。
icmpv6-type:表示ICMPv6类型的报文攻击。可以指定报文的类型值,或者指定报文的类型关键字。
·     icmpv6-type-value:表示ICMPv6报文类型的数值,取值范围为0~255。
·     destination-unreachable:表示ICMPv6 destination unreachable类型的报文攻击。
·     echo-reply:表示ICMPv6 echo reply类型的报文攻击。
·     echo-request:表示ICMPv6 echo request类型的报文攻击。
·     group-query:表示ICMPv6 group query类型的报文攻击。
·     group-reduction:表示ICMPv6 group reduction类型的报文攻击。
·     group-report:表示ICMPv6 group report类型的报文攻击。
·     packet-too-big:表示ICMPv6 packet too big类型的报文攻击。
·     parameter-problem:表示ICMPv6 para problem类型的报文攻击。
·     time-exceeded:表示ICMPv6 time exceeded类型的报文攻击。
impossible:表示IP不可信报文的攻击。
ip-option:表示IP选项类型的报文攻击。可以指定IP选项代码值,或者指定IP选项关键字。
·     option-code:表示IP选项代码值,取值范围为1~255。
·     internet-timestamp:表示IP选项timestamp类型的报文攻击。
·     loose-source-routing:表示IP选项loose source route类型的报文攻击。
·     record-route:表示IP选项record packet route类型的报文攻击。
·     route-alert:表示IP选项route alert类型的报文攻击。
·     security:表示IP选项security类型的报文攻击。
·     stream-id:表示IP选项stream identifier类型的报文攻击。
·     strict-source-routing:表示IP选项strict source route类型的报文攻击。
ip-option-abnormal:表示IP选项异常类型的报文攻击。
ipv6-ext-header ext-header-value:表示IPv6扩展头参数值,取值范围在0~255。
ipv6-ext-header-abnormal:表示IPv6扩展头异常攻击。
ipv6-ext-header-exceed:表示IPv6扩展头数目超限攻击。
land:表示Land类型的报文攻击。
large-icmp:表示超大ICMP报文的攻击。
large-icmpv6:表示超大ICMPv6报文的攻击。
limit limit-value:指定IPv6扩展头数目上限,取值范围为0~7,缺省值为7。超过limit-value个扩展头数目的IPv6报文将被视为IPv6扩展头数目超限攻击报文。
ping-of-death:表示Ping-of-death类型的报文攻击。
smurf:表示Smurf类型的报文攻击。
snork:表示UDP Snork attack类型的报文攻击。
tcp-all-flags:表示TCP所有标志位均置位的报文攻击。
tcp-fin-only:表示TCP仅FIN标志被置位的报文攻击。
tcp-invalid-flags:表示TCP 标志位非法的报文攻击。
tcp-null-flag:表示TCP 标志位为零的报文攻击。
tcp-syn-fin:表示TCP SYN和FIN标志位被同时置位的报文攻击。
teardrop:表示teardrop类型的报文攻击。
tiny-fragment:表示IP分片报文的攻击。
traceroute:表示Trace route类型的报文攻击。
udp-bomb:表示UDP Bomb attack类型的报文攻击。
winnuke:表示WinNuke类型的报文攻击。
action:对指定报文攻击所采取的攻击防范处理行为。若未指定本参数,则采用该攻击报文所属的攻击防范级别所对应的默认处理行为。
·     drop:设置单包攻击的处理行为为丢弃报文。
·     logging:设置单包攻击的处理行为为发送日志。
·     none:不采取任何动作。
可以通过多次执行本命令开启多种类型的单包攻击报文的特征检测。
若通过数值指定了报文类型,则当指定的数值为标准的报文类型值时,在显示信息中将会显示该数值对应的报文类型字符串,否则显示为数值。
针对IPv6扩展头异常攻击和IPv6扩展头数目超限攻击的检测仅对IPv6报文头部位于ESP扩展头前的部分进行,不检测位于ESP扩展头之后的部分。
# 在攻击防范策略atk-policy-1中开启对IP分片攻击报文的特征检测,并指定攻击防范处理行为为为丢弃报文。
[Sysname-attack-defense-policy-atk-policy-1] signature detect fragment action drop
·     signature level action
1.1.87  signature level action
signature level action命令用来配置指定级别单包攻击的处理行为。
undo signature level action命令用来恢复缺省情况。
signature level { high | info | low | medium } action { { drop | logging } * | none }
undo signature level { high | info | low | medium } action
对提示级别和低级别的单包攻击的处理行为是发送日志;对中级别的单包攻击的处理行为是发送日志并丢包;对高级别的单包攻击的处理行为是发送日志并丢包。
攻击防范策略视图
high:表示高级别的单包攻击,暂无实例。
info:表示提示级别的单包攻击,例如Large ICMP。
low:表示低级别的单包攻击,例如Traceroute。
medium:表示中级别的单包攻击,例如Winnuke。
none:不采取任何动作。
系统根据单包攻击结果的严重程度由低到高将其划分为四个攻击级别:提示、低级、中级、高级。开启某一个级别的单包攻击报文的特征检测,相当于批量开启了属于该级别的所有类型的单包攻击报文的特征检测。
若同时通过signature detect命令开启了具体类型的单包攻击报文的特征检测,则以signature detect命令配置的参数为准。
# 在攻击防范策略atk-policy-1中配置对提示级别的单包攻击的处理行为是丢弃后续报文。
[Sysname] attack-defense policy 1
[Sysname-attack-defense-policy-1] signature level info action drop
·     signature detect
·     signature level detect
1.1.88  signature level detect
signature level detect命令用来开启指定级别单包攻击报文的特征检测。
undo signature level detect命令用来关闭对指定级别的单包攻击报文的特征检测。
signature level { high | info | low | medium } detect
undo signature level { high | info | low | medium } detect
未开启任何级别的单包攻击报文的特征检测。
攻击防范策略视图
info:表示提示级别的单包攻击,例如Large ICMP报文攻击。
low:表示低级别的单包攻击,例如Traceroute报文攻击。
medium:表示中级别的单包攻击,例如Winnuke报文攻击。
系统根据单包攻击结果的严重程度将其划分为四个级别:提示、低级、中级、高级。开启某一个级别的单包攻击报文的特征检测,相当于批量开启了属于该级别的所有单包攻击报文的特征检测。针对某一级别的单包攻击的处理行为由signature level action命令指定。若通过signature detect命令开启了具体的单包攻击报文的特征检测,则对该类攻击报文的处理行为以signature detect命令配置的参数为准。
可通过display attack-defense policy命令查看各类型单包攻击所属的级别。
# 在攻击防范策略atk-policy-1中开启提示级别的单包攻击报文的特征检测。
[Sysname-attack-defense-policy-1] signature level info detect
·     signature detect
1.1.89  sip-flood action
sip-flood action命令用来配置SIP flood攻击防范的全局处理行为。
undo sip-flood action命令用来恢复缺省情况。
sip-flood action { drop | logging } *
不对检测到的SIP flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文。对于基于源IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃源自攻击者的后续所有SIP报文;对于基于目的IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃向被攻击者发送的后续所有SIP报文。
# 在攻击防范策略atk-policy-1中配置SIP flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] sip-flood action drop
·     sip-flood detect
·     sip-flood detect non-specific
·     sip-flood port
·     sip-flood source-threshold
·     sip-flood threshold
1.1.90  sip-flood detect
sip-flood detect命令用来开启对指定IP地址的SIP flood攻击防范检测,并配置SIP flood攻击防范检测的触发阈值和对SIP flood攻击的处理行为。
undo sip-flood detect命令用来关闭对指定IP地址的SIP flood攻击防范检测。
sip-flood detect { ip ipv4-address | ipv6 ipv6-address } [ port port-list ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo sip-flood detect { ip ipv4-address | ipv6 ipv6-address }
未对任何指定IP地址开启SIP flood攻击防范检测。
攻击防范策略视图
port port-list:指定开启SIP flood攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-32>。&<1-32>表示前面的参数最多可以输入32次。end-port-number必须大于或等于start-port-number。若未指定本参数,则表示使用全局配置的检测端口列表。
threshold threshold-value:指定SIP flood攻击防范基于目的IP统计的触发阈值。其中,threshold-value为向指定IP地址每秒发送的SIP报文数目,取值范围为1~1000000,缺省为1000。
action:设置对SIP flood攻击的处理行为。若未指定本参数,则表示采用SIP flood攻击防范的全局处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有SIP报文都会被丢弃。
none:表示不采取任何动作。
开启SIP flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送SIP报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了SIP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置SIP flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的SIP flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的SIP报文数持续达到或超过2000时,启动SIP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] sip-flood detect ip 192.168.1.2 threshold 2000
·     sip-flood action
·     sip-flood port
1.1.91  sip-flood detect non-specific
sip-flood detect non-specific命令用来对所有非受保护IP地址开启SIP flood攻击防范检测。
undo sip-flood detect non-specific命令用来关闭对所有非受保护IP地址的SIP flood攻击防范检测。
未对任何非受保护IP地址开启SIP flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启SIP flood攻击防范检测后,设备将采用全局的阈值设置(由sip-flood threshold或sip-flood source-threshold命令设置)、端口设置(由sip-flood port命令设置)和处理行为(由sip-flood action命令配置)对这些IP地址进行保护或防御。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启SIP flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] sip-flood detect non-specific
·     sip-flood action
·     sip-flood detect
·     sip-flood port
1.1.92  sip-flood port
sip-flood port命令用来配置SIP flood攻击防范的全局检测端口号。
undo sip-flood port命令用来恢复缺省情况。
sip-flood port port-list
undo sip-flood port
SIP flood攻击防范的全局检测端口号为5060。
攻击防范策略视图
设备只对指定检测端口上收到的报文进行SIP flood攻击检测。
对于所有非受保护IP地址,或未指定检测端口的受保护IP地址,设备采用全局的检测端口进行SIP flood攻击检测。对于所有指定检测端口的受保护IP地址,设备针对为每个受保护IP地址指定的端口进行SIP flood攻击检测。
# 在攻击防范策略atk-policy-1中配置SIP flood攻击防范的全局检测端口为5060与65530,当设备检测到访问5060端口或65530端口的SIP flood攻击时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] sip-flood port 5060 65530
·     sip-flood action
·     sip-flood detect
1.1.93  sip-flood threshold
sip-flood threshold命令用来配置SIP flood攻击防范基于目的IP统计的全局触发阈值。
undo sip-flood threshold命令用来恢复缺省情况。
sip-flood threshold threshold-value
SIP flood攻击防范基于目的IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的SIP报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于目的IP地址的SIP flood攻击防范。开启SIP flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送SIP报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了SIP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。
对于未专门配置SIP flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象的SIP报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置SIP flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的SIP报文数持续达到或超过100时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] sip-flood threshold 100
·     sip-flood action
·     sip-flood detect
·     sip-flood port
1.1.94  sip-flood source-threshold
sip-flood source-threshold命令用来配置SIP flood攻击防范基于源IP统计的全局触发阈值。
undo sip-flood source-threshold命令用来恢复缺省情况。
sip-flood source-threshold threshold-value
SIP flood攻击防范基于源IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定某IP地址每秒发送的SIP报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于源IP统计的SIP flood攻击防范。
开启SIP flood攻击防范后,设备处于攻击检测状态,当它监测到某IP地址发送SIP报文的速率持续达到或超过了该触发阈值时,即认为该IP地址发起了SIP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到该IP地址发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中配置SIP flood攻击防范基于源IP统计的全局触发阈值为100,即当设备监测到某IP地址每秒发送的SIP报文数持续达到或超过100时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] sip-flood source-threshold 100
·     sip-flood action
·     sip-flood detect
·     sip-flood port
1.1.95  syn-ack-flood action
syn-ack-flood action命令用来配置对SYN-ACK flood攻击防范的全局处理行为。
undo syn-ack-flood action命令用来恢复缺省情况。
syn-ack-flood action { drop | logging }*
不对检测到的 SYN-ACK flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文。对于基于源IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃源自攻击者的后续所有SYN-ACK报文;对于基于目的IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃向被攻击者发送的后续所有SYN-ACK报文。
# 在攻击防范策略atk-policy-1中配置对SYN-ACK flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood action drop
·     syn-ack-flood detect
·     syn-ack-flood detect non-specific
·     syn-ack-flood source-threshold
·     syn-ack-flood threshold
1.1.96  syn-ack-flood detect
syn-ack-flood detect命令用来对指定IP地址的SYN-ACK flood攻击防范检测,并配置SYN-ACK flood攻击防范检测触发阈值和防范行为。
undo syn-ack-flood detect命令用来关闭对指定IP地址的SYN-ACK flood攻击防范检测。
syn-ack-flood detect { ip ipv4-address | ipv6 ipv6-address } [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo syn-ack-flood detect { ip ipv4-address | ipv6 ipv6-address }
未对任何指定IP地址配置SYN-ACK flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定SYN-ACK flood攻击防范基于目的IP统计的触发阈值。其中,threshold-value为向指定IP地址每秒发送的SYN-ACK报文数目,取值范围为1~1000000。
action:设置对SYN-ACK flood攻击的处理行为。若未指定本参数,则表示采用SYN-ACK flood攻击防范的全局处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有SYN-ACK报文都会被丢弃。
none:表示不采取任何动作。
使能SYN-ACK flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送SYN-ACK报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了SYN-ACK flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置SYN-ACK flood攻击防范检测。
# 开启对IP地址192.168.1.2的SYN-ACK flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的SYN-ACK报文数持续达到或超过2000时,启动SYN-ACK攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood detect ip 192.168.1.2 threshold 2000
·     syn-ack-flood action
1.1.97  syn-ack-flood detect non-specific
syn-ack-flood detect non-specific命令用来对所有非受保护IP地址开启SYN-ACK flood攻击防范检测。
undo syn-ack-flood detect non-specific命令用来关闭对所有非受保护IP地址的SYN-ACK flood攻击防范检测。
未对任何非受保护IP地址开启SYN-ACK flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启SYN-ACK flood攻击防范检测后,设备将采用全局的阈值设置(由syn-ack-flood threshold或syn-ack-flood source-threshold命令设置)和处理行为(由syn-ack-flood action命令配置)对这些IP地址进行保护或防御。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启UDP flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood detect non-specific
·     syn-ack flood action
1.1.98  syn-ack-flood threshold
syn-ack-flood threshold命令用来配置SYN-ACK flood攻击防范基于目的IP统计的全局触发阈值。
undo syn-ack-flood threshold命令用来恢复缺省情况。
syn-ack-flood threshold threshold-value
SYN-ACK flood攻击防范基于目的IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的SYN-ACK报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于目的IP地址的SYN-ACK flood攻击防范。
使能SYN-ACK flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送SYN-ACK报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了SYN-ACK flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置SYN-ACK flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的SYN-ACK报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置SYN-ACK flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的SYN-ACK报文数持续达到或超过100时,启动SYN-ACK flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood threshold 100
1.1.99  syn-ack-flood source-threshold
syn-ack-flood source-threshold命令用来配置SYN-ACK flood攻击防范基于源IP统计的全局触发阈值。
undo syn-ack-flood source-threshold命令用来恢复缺省情况。
syn-ack-flood source-threshold threshold-value
SYN-ACK flood攻击防范基于源IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定每秒接收到从某IP地址发出的SYN-ACK报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于源IP统计的SYN-ACK flood攻击防范。
使能SYN-ACK flood攻击防范后,设备处于攻击检测状态,当它监测到某IP地址发出的SYN-ACK报文的速率持续达到或超过了该触发阈值时,即认为该IP地址发起了SYN-ACK flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到该IP地址发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中配置SYN-ACK flood攻击防范基于源IP统计的全局触发阈值为100,即当设备监测到某IP地址每秒发送的SYN-ACK报文数持续达到或超过100时,启动SYN-ACK flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood source-threshold 100
1.1.100  syn-flood action
syn-flood action命令用来配置对SYN flood攻击防范的全局处理行为。
undo syn-flood action命令用来恢复缺省情况。
syn-flood action { drop | logging } *
不对检测到的SYN flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文。对于基于源IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃源自攻击者的后续所有SYN报文;对于基于目的IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃向被攻击者发送的后续所有SYN报文。
# 在攻击防范策略atk-policy-1中配置对SYN flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] syn-flood action drop
·     syn-flood detect non-specific
·     syn-flood detect
·     syn-flood source-threshold
·     syn-flood threshold
1.1.101  syn-flood detect
syn-flood detect命令用来开启对指定IP地址的SYN flood攻击防范检测,并配置SYN flood攻击防范检测的触发阈值和对SYN flood攻击的处理行为。
undo syn-flood detect命令用来关闭对指定IP地址的SYN flood攻击防范检测。
syn-flood detect { ip ipv4-address | ipv6 ipv6-address } [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo syn-flood detect { ip ipv4-address | ipv6 ipv6-address }
未对任何指定IP地址配置SYN flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定SYN flood攻击防范基于目的IP统计的触发阈值。其中,threshold-value为向指定IP地址每秒发送的SYN报文数目,取值范围为1~1000000。
action:设置对SYN flood攻击的处理行为。若未指定本参数,则表示采用SYN flood攻击防范的全局处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有SYN报文都会被丢弃。
none:表示不采取任何动作。
使能SYN flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送SYN报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了SYN flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置SYN flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的SYN flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的SYN报文数持续达到或超过2000时,启动SYN flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] syn-flood detect ip 192.168.1.2 threshold 2000
·     syn-flood action
1.1.102  syn-flood detect non-specific
syn-flood detect non-specific命令用来对所有非受保护IP地址开启SYN flood攻击防范检测。
undo syn-flood detect non-specific命令用来关闭对所有非受保护IP地址的SYN flood攻击防范检测。
未对任何非受保护IP地址开启SYN flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启SYN flood攻击防范检测后,设备将采用全局的阈值设置(由syn-flood threshold或syn-flood source-threshold命令设置)和处理行为(由syn-flood action命令配置)对这些IP地址进行保护或防御。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启SYN flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] syn-flood detect non-specific
·     syn-flood action
·     syn-flood detect
1.1.103  syn-flood threshold
syn-flood threshold命令用来配置SYN flood攻击防范基于目的IP统计的全局触发阈值。
undo syn-flood threshold命令用来恢复缺省情况。
syn-flood threshold threshold-value
SYN flood攻击防范基于目的IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的SYN报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于目的IP地址的SYN flood攻击防范。
使能SYN flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送SYN报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了SYN flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置SYN flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的SYN报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置SYN flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的SYN报文数持续达到或超过100时,启动SYN flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] syn-flood threshold 100
·     syn-flood action
·     syn-flood detect
1.1.104  syn-flood source-threshold
syn-flood source-threshold命令用来配置SYN flood攻击防范基于源IP统计的全局触发阈值。
undo syn-flood source-threshold命令用来恢复缺省情况。
syn-flood source-threshold threshold-value
SYN flood攻击防范基于源IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定每秒接收到从某IP地址发出的SYN报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于源IP地址的SYN flood攻击防范。
使能SYN flood攻击防范后,设备处于攻击检测状态,当它监测到某IP地址发出的SYN报文的速率持续达到或超过了该触发阈值时,即认为该IP地址发起了SYN flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到该IP地址发出报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中配置SYN flood攻击防范基于源IP统计的全局触发阈值为100,即当设备监测到某IP地址每秒发送的SYN报文数持续达到或超过100时,启动SYN flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] syn-flood source-threshold 100
·     syn-flood action
·     syn-flood detect
1.1.105  threshold-learn apply
threshold-learn apply命令用来立即应用最近一次的阈值学习结果。
攻击防范策略视图
在开启阈值学习功能但没有开启阈值学习结果自动应用功能的攻击防范策略中,可以通过执行该命令将最近一次的阈值学习结果作为泛洪攻击防范的阈值。多次执行本命令,最后一次执行的命令生效。在阈值学习结果自动应用功能开启时,此命令不生效。
该功能仅对非受保护IP地址也开启攻击防范检测的泛洪攻击类型生效。
# 在攻击防范策略atk-policy-1中立即应用阈值学习功能上次的学习结果。
[Sysname-attack-defense-policy-atk-policy-1] threshold-learn apply
·     threshold-learn enable
1.1.106  threshold-learn auto-apply enable
threshold-learn auto-apply enable命令用来开启阈值学习结果自动应用功能。
undo threshold-learn auto-apply enable命令用来关闭阈值学习结果自动应用功能。
阈值学习结果自动应用功能处于关闭状态。
攻击防范策略视图
只有在启用阈值学习功能的攻击防范策略中才可以应用阈值学习结果自动应用功能,且该功能仅对非受保护IP地址也开启攻击防范检测的泛洪攻击类型生效。启用该功能后,系统会在每次完成阈值学习后根据阈值学习结果重新设置泛洪攻击阈值,即泛洪攻击阈值为学习值×(1+学习容忍度)。其中,学习值是设备在学习时长内实际网络流量的峰值,学习容忍度则将学习值进行放大,从而避免在正常的峰值流量时造成合法流量的丢包。
通过执行threshold-learn enable命令可以启用阈值学习功能;通过执行threshold-learn tolerance-value命令可以配置阈值学习功能的学习容忍度。
# 在攻击防范策略atk-policy-1中开启阈值学习结果自动应用功能。
[Sysname-attack-defense-policy-atk-policy-1] threshold-learn auto-apply enable
·     threshold-learn tolerance-value
1.1.107  threshold-learn duration
threshold-learn duration命令用来配置阈值学习时长。
undo threshold-learn duration命令用来恢复缺省情况。
threshold-learn duration duration
流量阈值学习时长为1440分钟。
攻击防范策略视图
duration:阈值学习时长,取值范围为1~1200000,单位为分钟。
在应用已启用了阈值学习功能的攻击防范策略时,系统会自动开始进行阈值学习。建议学习时长设置大于1440分钟(24小时),以确保设备学习到一整天的流量。如果在学习过程中修改了该值,则会重新开始学习。
# 在攻击防范策略atk-policy-1中配置流量阈值学习时长为2880分钟(48小时)。
[Sysname-attack-defense-policy-atk-policy-1] threshold-learn duration 2880
·     threshold-learn loop
1.1.108  threshold-learn enable
threshold-learn enable命令用来开启泛洪攻击阈值学习功能。
undo threshold-learn enable命令用来关闭泛洪攻击阈值学习功能。
泛洪攻击阈值学习功能处于关闭状态。
攻击防范策略视图
阈值是触发系统执行防范动作的条件,阈值的设置是否合理将直接影响攻击防范的效果。如果阈值设置过低,则可能造成正常流量被丢弃;而阈值设置过高,则可能在发生攻击时系统不能及时启动防范功能。因此,在配置泛洪攻击防范时,为了合理设置阈值,建议启用阈值学习功能。
# 在攻击防范策略atk-policy-1中开启流量阈值学习功能。
[Sysname-attack-defense-policy-atk-policy-1] threshold-learn enable
·     threshold-learn auto-apply enable
·     threshold-learn duration
1.1.109  threshold-learn interval
threshold-learn interval命令用来配置阈值学习功能的学习间隔。
undo threshold-learn interval命令用来恢复缺省情况。
threshold-learn interval interval
阈值学习功能的学习间隔为1440分钟。
攻击防范策略视图
interval:阈值学习功能的学习间隔,取值范围为1~1200000,单位为分钟。
若攻击防范策略中启用了阈值学习功能且学习模式为周期学习,则在应用该策略时,系统会根据学习间隔周期性地进行阈值学习。其中,学习间隔是指定从上次学习的结束时间到下次学习开始时间的间隔时间。通过执行threshold-learn enable命令可以启用阈值学习功能;通过执行threshold-learn mode periodic命令可以配置阈值学习为周期学习模式。
# 在攻击防范策略atk-policy-1中配置流量阈值学习周期间隔为120分钟。
[Sysname-attack-defense-policy-atk-policy-1] threshold-learn interval 120
·     threshold-learn mode
1.1.110  threshold-learn mode
threshold-learn mode命令用来配置阈值学习功能的学习模式。
undo threshold-learn mode命令用来恢复缺省情况。
threshold-learn mode { once | periodic }
阈值学习功能的学习模式为单次学习。
攻击防范策略视图
once:学习模式为单次学习。
periodic:学习模式为周期学习。
阈值学习有单次学习和周期学习两种学习模式:
·     单次学习:只进行一次阈值学习。学习时长通过threshold-learnduration命令进行配置。对于网络流量模型比较稳定的场景可以使用该模式。
·     周期学习:按配置的学习间隔进行周期性的学习。其中,每个周期中的学习时长通过threshold-learn duration命令进行配置,学习间隔通过threshold-learn interval命令进行配置。对于网络流量模型易变化的场景可以使用该模式。
# 在攻击防范策略atk-policy-1中配置流量阈值学习模式为周期学习。
[Sysname-attack-defense-policy-atk-policy-1] threshold-learn mode periodic
·     threshold-learn interval
1.1.111  threshold-learn tolerance-value
threshold-learn tolerance-value命令用来配置阈值学习功能的学习容忍度。
undo threshold-learn tolerance-value命令用来恢复缺省情况。
threshold-learn tolerance-value tolerance-value
阈值学习功能的学习容忍度为50%。
攻击防范策略视图
tolerance-value:学习容忍度,取值范围为0~4000,单位为百分比。
由于网络中的流量是时刻变化的,因此将某个学习时长内学习所得的统计值作为防范阈值后,若网络流量突然增大,可能会造成正常流量被丢弃。系统提供一个阈值容忍机制,它允许系统在将学习结果应用之前将阈值扩大指定的范围,然后再应用到网路中。扩大后的阈值为学习值×(1+学习容忍度)。
容忍度机制可以使阈值学习功能更好的应对网络流量的波动。只有当阈值学习结果自动应用功能处于开启状态时,配置学习容忍度才生效。
# 在攻击防范策略atk-policy-1中开启自动应用,设置容忍度为100。
[Sysname-attack-defense-policy-atk-policy-1] threshold-learn tolerance-value 100
1.1.112  udp-flood action
udp-flood action命令用来配置对UDP flood攻击防范的全局处理行为。
undo udp-flood action命令用来恢复缺省情况。
udp-flood action { drop | logging } *
不对检测到的UDP flood攻击进行任何处理。
攻击防范策略视图
drop:表示丢弃攻击报文。对于基于源IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃源自攻击者的后续所有UDP报文;对于基于目的IP统计的泛洪攻击,设备检测到攻击发生后,将丢弃向被攻击者发送的后续所有UDP报文。
# 在攻击防范策略atk-policy-1中配置对UDP flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] udp-flood action drop
·     udp-flood detect
·     udp-flood detect non-specific
·     udp-flood source-threshold
·     udp-flood threshold
1.1.113  udp-flood detect
udp-flood detect命令用来开启对指定IP地址的UDP flood攻击防范检测,并配置UDP flood攻击防范检测的触发阈值和对UDP flood攻击的处理行为。
undo udp-flood detect命令用来关闭对指定IP地址的UDP flood攻击防范检测。
udp-flood detect { ip ipv4-address | ipv6 ipv6-address } [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo udp-flood detect { ip ipv4-address | ipv6 ipv6-address }
未对任何指定IP地址配置UDP flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定UDP flood攻击防范基于目的IP统计的触发阈值。其中,threshold-value为向指定IP地址每秒发送的UDP报文数目,取值范围为1~1000000,则表示采用UDP flood攻击防范的全局处理行为。
action:设置对UDP flood攻击的处理行为。若未指定本参数,则表示采用UDP flood攻击防范的全局处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有UDP报文都会被丢弃。
none:表示不采取任何动作。
使能UDP flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送UDP报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了UDP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置UDP flood攻击防范参数。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的UDP flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的UDP报文数持续达到或超过2000时,启动UDP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] udp-flood detect ip 192.168.1.2 threshold 2000
·     udp-flood action
1.1.114  udp-flood detect non-specific
udp-flood detect non-specific命令用来对所有非受保护IP地址开启UDP flood攻击防范检测。
undo udp-flood detect non-specific命令用来关闭对所有非受保护IP地址的UDP flood攻击防范检测。
未对任何非受保护IP地址开启UDP flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启UDP flood攻击防范检测后,设备将采用全局的阈值设置(由udp-flood threshold或udp-flood source-threshold命令设置)和处理行为(由udp-flood action命令配置)对这些IP地址进行保护或防御。
[Sysname-attack-defense-policy-atk-policy-1] udp-flood detect non-specific
·     udp-flood action
·     udp-flood detect
1.1.115  udp-flood threshold
udp-flood threshold命令用来配置UDP flood攻击防范基于目的IP统计的全局触发阈值。
undo udp-flood threshold命令用来恢复缺省情况。
udp-flood threshold threshold-value
UDP flood攻击防范基于目的IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的UDP报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于目的IP地址的UDP flood攻击防范。
使能UDP flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送UDP报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了UDP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置UDP flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的UDP报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置UDP flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的UDP报文数持续达到或超过100时,启动UDP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] udp-flood threshold 100
·     udp-flood action
·     udp-flood detect
1.1.116  udp-flood source-threshold
udp-flood source-threshold命令用来配置UDP flood攻击防范基于源IP统计的全局触发阈值。
undo udp-flood source-threshold命令用来恢复缺省情况。
udp-flood source-threshold threshold-value
UDP flood攻击防范基于源IP统计的全局触发阈值为10000。
攻击防范策略视图
threshold-value:指定每秒接收到从某IP地址发出的UDP报文数目,取值范围为0~1000000,当设置为0时,表示关闭基于源IP统计的UDP flood攻击防范。
使能UDP flood攻击防范后,设备处于攻击检测状态,当它监测到某IP地址发送UDP报文的速率持续达到或超过了该触发阈值时,即认为该IP地址发起了UDP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到该IP发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中配置UDP flood攻击防范基于源IP统计的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的UDP报文数持续达到或超过100时,启动UDP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] udp-flood source-threshold 100
·     udp-flood action
·     udp-flood detect
