13-WLAN
04-HH3C-DOT11-CFG-MIB
本章节下载: 04-HH3C-DOT11-CFG-MIB  (522.89 KB)
HH3C-DOT11-CFG-MIB
功能介绍
MIB文件名
根节点
全局节点详细描述
hh3cDot11GlobalCountryCode
hh3cDot11StaKeepALiveTimerIntvl
hh3cDot11StaIdleTimerIntvl
hh3cDot11BroadcastProbeReply
hh3cDot11APScanMode
hh3cDot11ACCtrlTunnelSecSupport
hh3cDot11ACDataTunnelSecSupport
hh3cDot11ACAutoAPSupport
hh3cDot11AutoAPName
hh3cDot11PersistentName
hh3cDot11IntfTrapThreshold
hh3cDot11MonitorInterval
hh3cDot11SampleInterval
hh3cDot11ChnlSwitChkInterval
hh3cDot11APUserUplimit
hh3cDot11APL2IsolateEnable
hh3cDot11APBSSIDSupportNum
hh3cDot11APLastUpdateStatTime
hh3cDot11APDoSProtectEnable
hh3cDot11MaxAPPerIf
hh3cDot11SampleTimeStamp
hh3cDot11UplinkTrackId
hh3cDot11RtCollectSwitch
hh3cDot11RglCollectIntvl
hh3cDot11RtCollectIntvl
hh3cDot11AllAPCpuUsageThreshold
hh3cDot11AllAPMemUsageThreshold
hh3cDot11AdjIntfTrapThreshold
hh3cDot11AllAPMonitorMode
hh3cDot11GlobalApFmwUpdState
hh3cDot11ACNasIDCM
hh3cDot11ACRole
hh3cDot11GlobalLocalACState
hh3cDot11CentralACIPAddress
hh3cDot11CentralACIPv6Address
hh3cDot11iMcIP
hh3cDot11iMcPort
hh3cDot11APProvisionSave
hh3cDot11ApRenameCurrentName
hh3cDot11ApRenameNewName
hh3cDot11ACDescription
hh3cDot11BackupACAdrssIP
hh3cDot11BackupACAdrssIPv6
hh3cDot11PreConflictTemplateNum
hh3cDot11CurrConflictTemplateNum
hh3cDot11ConflictCipherIdx
hh3cDot11ConfigureAPID
hh3cDot11ConfigureRadioID
hh3cDot11ConfigureAPMacAddress
hh3cDot11PreConflictTemplateSSID
hh3cDot11CurrConflictTemplateSSID
表节点详细描述
hh3cDot11ServicePolicyTable
hh3cDot11ServicePolicyExtTable
hh3cDot11RadioPolicyExtTable
hh3cDot11SrvPortSecurityTable
hh3cDot11SrvPolicyExtendTable
hh3cDot11SrvL2AuthenTable
hh3cDot11IPLearningTable
hh3cDot11APTemplateTable
hh3cDot11RadioToConfigTable
hh3cDot11APServiceSetTable
hh3cDot11APSysInfoSetTable
hh3cDot11APLimitTable
hh3cDot11APIfSetTable
hh3cDot11RadioConfigTable
hh3cDot11APServiceVlanTable
hh3cDot11RadioSSIDCfgTable
hh3cDot11APSerialIDTable
hh3cDot11APSTVlanTable
hh3cDot11RadioIntfConfigTable
hh3cDot11RadioIntfBindTable
hh3cDot11WlanEssIfTable
hh3cDot11WlanBssIfTable
hh3cDot11WLANEthernetIfTable
hh3cDot11PortSecurityTable
hh3cDot11nRadioCfgTable
hh3cDot11nRadioCfg2Table
hh3cDot11LocalACTemplateTable
hh3cDot11RemoteCfgIFTable
告警信息
hh3cDot11CfgCipherChange
hh3cDot11CfgPSKChange
hh3cDot11SSIDWepIDConflictTrap
HH3C-DOT11-CFG-MIB
功能介绍
HH3C-DOT11-CFG-MIB用来实现无线配置相关信息的功能。
MIB文件名
hh3c-dot11-cfg.mib
根节点
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11CFG(4)
全局节点详细描述
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11GlobalCountryCode (1.3.6.1.4.1.25506.2.75.4.1.1)
read-write
OCTET STRING
OCTET STRING(1..3)
表示无线网络的国家码
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11StaKeepALiveTimerIntvl (1.3.6.1.4.1.25506.2.75.4.1.2)
read-write
Unsigned32
同MIB标准取值
表示AP和终端间保活报文发送的时间间隔。默认值为0:保活功能关闭
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11StaIdleTimerIntvl (1.3.6.1.4.1.25506.2.75.4.1.3)
read-write
INTEGER
normal(0), reboot(1)
表示AP和终端(省电或唤醒)之间链路空闲的时间间隔
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11BroadcastProbeReply (1.3.6.1.4.1.25506.2.75.4.1.4)
read-write
TruthValue
true(1),
false(2)
表示AP是否开启回复广播探测报文功能。
true:开启
false:关闭
实现与MIB文件定义一致
hh3cDot11APScanMode
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11APScanMode (1.3.6.1.4.1.25506.2.75.4.1.5)
read-write
INTEGER
active(1),
passive(2)
表示AP扫描模式。
默认值为passive(2)
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11ACCtrlTunnelSecSupport (1.3.6.1.4.1.25506.2.75.4.1.6)
read-write
Hh3cDot11TunnelSecSchemType
INTEGER{
cleartxt(1),
dtls(2),
ipsec(3)
表示CAPWAP控制隧道支持的加密模式
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
(1.3.6.1.4.1.25506.2.75.4.1.7)
read-write
INTEGER{
cleartxt(1),
dtls(2),
ipsec(3)
表示CAPWAP数据隧道支持的加密模式,默认模式为cleartxt。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11ACAutoAPSupport (1.3.6.1.4.1.25506.2.75.4.1.8)
read-write
TruthValue
true(1),
false(2)
表示是否开启自动AP上线功能。
true:开启
false:关闭
实现与MIB文件定义一致
hh3cDot11AutoAPName
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11AutoAPName (1.3.6.1.4.1.25506.2.75.4.1.9)
read-write
OCTET STRING
OCTET STRING(0..127)
表示需要固化的自动AP名称。此节点不支持读操作。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11PersistentName (1.3.6.1.4.1.25506.2.75.4.1.10)
read-write
OCTET STRING
表示需要固化的自动AP的新名称。此节点不支持读操作。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11IntfTrapThreshold (1.3.6.1.4.1.25506.2.75.4.1.11)
read-write
Integer32
同MIB标准取值
表示干扰告警的阈值,如果设备的信号强度超过此阈值,将会发送相关告警。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11MonitorInterval (1.3.6.1.4.1.25506.2.75.4.1.12)
read-write
Unsigned32
Unsigned32(0 | 5..15)
表示监测时间间隔,单位为分钟。默认值为0,表示监测功能将更改为实时模式。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11SampleInterval (1.3.6.1.4.1.25506.2.75.4.1.13)
read-write
Unsigned32
Unsigned32(0 | 10..300)
表示射频统计信息采样时间间隔,单位为秒。默认值为0,表示采用功能关闭。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11ChnlSwitChkInterval (1.3.6.1.4.1.25506.2.75.4.1.14)
read-write
Unsigned32
Unsigned32(8..180)
表示信道切换的检测时间间隔,单位为分钟。默认值为8。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11APUserUplimit (1.3.6.1.4.1.25506.2.75.4.1.15)
read-write
Unsigned32
Unsigned32(0..65535)
表示可以访问此AP的用户上限。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11APL2IsolateEnable (1.3.6.1.4.1.25506.2.75.4.1.16)
read-write
TruthValue
true(1),
false(2)
表示二层隔离是否使能。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11APBSSIDSupportNum (1.3.6.1.4.1.25506.2.75.4.1.17)
read-only
Integer32
同MIB标准取值
表示当前AP支持的BSSID最大数。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11APLastUpdateStatTime (1.3.6.1.4.1.25506.2.75.4.1.18)
read-only
DateAndTime
同MIB标准取值
表示最近一个统计信息更新的日期和时间。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11APDoSProtectEnable (1.3.6.1.4.1.25506.2.75.4.1.19)
read-write
TruthValue
true(1),
false(2)
表示是否使能DOS保护功能。
实现与MIB文件定义一致
hh3cDot11MaxAPPerIf
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11MaxAPPerIf (1.3.6.1.4.1.25506.2.75.4.1.20)
read-write
Unsigned32
表示可连接到AC接口的最大AP数。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11SampleTimeStamp (1.3.6.1.4.1.25506.2.75.4.1.21)
read-only
DateAndTime
同MIB标准取值
表示当次采样周期的开始时间。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11UplinkTrackId (1.3.6.1.4.1.25506.2.75.4.1.22)
read-write
Unsigned32
同MIB标准取值
表示AP的track id。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11RtCollectSwitch (1.3.6.1.4.1.25506.2.75.4.1.23)
read-write
TruthValue
true(1),
false(2)
表示打开或关闭AC和AP间的实时统计功能。如果此值为true,hh3cDot11RtCollectIntvl将生效,否则hh3cDot11RglCollectIntvl生效。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11RglCollectIntvl (1.3.6.1.4.1.25506.2.75.4.1.24)
read-write
Integer32
同MIB标准取值
表示周期性收集统计信息的时间间隔。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11RtCollectIntvl (1.3.6.1.4.1.25506.2.75.4.1.25)
read-write
Integer32
同MIB标准取值
表示实时收集统计信息的时间间隔。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
(1.3.6.1.4.1.25506.2.75.4.1.26)
read-write
Integer32
Integer32(0..100)
表示AP的CPU使用阈值。
不支持
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
(1.3.6.1.4.1.25506.2.75.4.1.27)
read-write
Integer32
Integer32(0..100)
表示AP的内存使用阈值。
不支持
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11AdjIntfTrapThreshold (1.3.6.1.4.1.25506.2.75.4.1.28)
read-write
Integer32
同MIB标准取值
表示触发相邻干扰告警的阈值,如果设备的信号强度超过这个值,将会发送此告警。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11AllAPMonitorMode (1.3.6.1.4.1.25506.2.75.4.1.29)
read-write
INTEGER
normal(1)
monitor(2)
hybrid(3)
表示AP工作模式。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11GlobalApFmwUpdState (1.3.6.1.4.1.25506.2.75.4.1.30)
read-write
INTEGER
enable(1)
disable(2)
表示AP是否开启版本自动升级功能。
实现与MIB文件定义一致
hh3cDot11ACNasIDCM
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11ACNasIDCM (1.3.6.1.4.1.25506.2.75.4.1.31)
read-write
OCTET STRING
同MIB标准取值
表示当前AC的NAS-ID
实现与MIB文件定义一致
hh3cDot11ACRole
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11ACRole (1.3.6.1.4.1.25506.2.75.4.1.32)
read-only
INTEGER
normal(1)
central(2)
local(3)
表示AC当前的角色。
normal:普通AC
central:集中式AC(此AC可以配置local AC并且和这些local AC建立CAPWAP隧道)
local:本地式AC(此AC为AP提供网络访问并处理客户端流量)
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11GlobalLocalACState (1.3.6.1.4.1.25506.2.75.4.1.33)
read-write
INTEGER
enable(1)
disable(2)
表示AC是否使能local AC角色。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11CentralACIPAddress (1.3.6.1.4.1.25506.2.75.4.1.34)
read-write
IpAddress
同MIB标准取值
表示local AC需要关联的central AC的IP地址。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11CentralACIPv6Address (1.3.6.1.4.1.25506.2.75.4.1.35)
read-write
OCTET STRING
同MIB标准取值
表示local AC需要关联的central AC的IPv6地址。
实现与MIB文件定义一致
hh3cDot11iMcIP
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11iMcIP (1.3.6.1.4.1.25506.2.75.4.1.36)
read-write
IpAddress
同MIB标准取值
表示iMc的IP地址。
实现与MIB文件定义一致
hh3cDot11iMcPort
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11iMcPort (1.3.6.1.4.1.25506.2.75.4.1.37)
read-write
Integer32
同MIB标准取值
表示iMc的端口号。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11APProvisionSave (1.3.6.1.4.1.25506.2.75.4.1.38)
read-write
OCTET STRING
表示下发给AP的预配置,不支持读操作。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11ApRenameCurrentName (1.3.6.1.4.1.25506.2.75.4.1.39)
read-write
OCTET STRING
表示需要重命名的AP的旧AP名称,不支持读操作。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11ApRenameNewName (1.3.6.1.4.1.25506.2.75.4.1.40)
read-write
OCTET STRING
表示需要重命名的AP的新AP名称,不支持读操作。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11ACDescription (1.3.6.1.4.1.25506.2.75.4.1.41)
read-write
OCTET STRING
同MIB标准取值
表示此属性将提供关于AC的更多信息。
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11BackupACAdrssIP (1.3.6.1.4.1.25506.2.75.4.7.1)
read-write
InetAddress
OCTET STRING (0..255)
表示备AC IP地址。如果没有配置,此值为0.0.0.0
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11BackupACAdrssIPv6 (1.3.6.1.4.1.25506.2.75.4.7.2)
read-write
InetAddress
表示备AC IPv6地址。如果没有配置,此值为0::0
实现与MIB文件定义一致
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11PreConflictTemplateNum (1.3.6.1.4.1.25506.2.75.4.9.1.1)
accessible-for-notify
Integer32
Integer32 (1..1024)
在密码配置中,当无线射频绑定服务策略和当前服务策略与以前的服务策略冲突时,表示以前的服务策略ID
不支持
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11CurrConflictTemplateNum (1.3.6.1.4.1.25506.2.75.4.9.1.2)
Integer32
Integer32 (1..1024)
在密码配置中,当无线射频绑定服务策略和当前服务策略与之前的服务策略冲突时,表示当前服务策略ID
不支持
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11ConflictCipherIdx (1.3.6.1.4.1.25506.2.75.4.9.1.3)
Integer32
Integer32 (1..4)
表示与之冲突的wep ID
不支持
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11ConfigureAPID (1.3.6.1.4.1.25506.2.75.4.9.1.4)
Hh3cDot11ObjectIDType
Hh3cDot11ObjectIDType (0..127)
表示配置的AP
不支持
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11ConfigureRadioID (1.3.6.1.4.1.25506.2.75.4.9.1.5)
Hh3cDot11RadioScopeType
同MIB标准取值
表示AP中配置的无线射频
不支持
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11ConfigureAPMacAddress (1.3.6.1.4.1.25506.2.75.4.9.1.6)
MacAddress
MacAddress(6)
表示AP的MAC地址
不支持
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11PreConflictTemplateSSID (1.3.6.1.4.1.25506.2.75.4.9.1.7)
Hh3cDot11SSIDStringType
同MIB标准取值
表示AP的前一个SSID
不支持
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11CurrConflictTemplateSSID (1.3.6.1.4.1.25506.2.75.4.9.1.8)
同MIB标准取值
表示AP的当前SSID
不支持
表节点详细描述
【功能描述】
该表根据CLI的业务策略定义ESS的参数。可以将一个服务策略分配给不同的无线射频(AP)。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11ServicePolicyID。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11ServicePolicyID (1.3.6.1.4.1.25506.2.75.4.2.2.1.1)
not-accessible
Hh3cDot11ServicePolicyIDType
同MIB标准取值
表示每个服务策略的ID
实现与MIB文件定义一致
hh3cDot11SSIDName (1.3.6.1.4.1.25506.2.75.4.2.2.1.2)
read-create
Hh3cDot11SSIDStringType(1..32)
表示ESS。根据CLI,服务策略名称的值将是SSID
实现与MIB文件定义一致
hh3cDot11SSIDHidden (1.3.6.1.4.1.25506.2.75.4.2.2.1.3)
read-create
TruthValue
true(1),
false(2)
此属性控制是否在信标帧中发布SSID。如果是真的,那么SSID将不会在信标帧中发布
实现与MIB文件定义一致
hh3cDot11AuthenMode (1.3.6.1.4.1.25506.2.75.4.2.2.1.4)
read-create
Hh3cDot11AuthenType
none(1),
opensystem(2),
sharedkey(3),
all(4)
表示802.11定义的认证模式
实现与MIB文件定义一致
hh3cDot11SSIDEncryptionMode (1.3.6.1.4.1.25506.2.75.4.2.2.1.5)
read-create
Hh3cDot11SSIDEncryptModeType
cleartxt(1),
cipher(2),
ext(3)
表示此ESS的加密模式
实现与MIB文件定义一致
hh3cDot11WlanInfBindingType (1.3.6.1.4.1.25506.2.75.4.2.2.1.6)
read-create
OCTET STRING
同MIB标准取值
表示服务策略将绑定到哪种数据转发接口
实现与MIB文件定义一致
hh3cDot11WlanInfBindingID (1.3.6.1.4.1.25506.2.75.4.2.2.1.7)
read-create
Integer32
同MIB标准取值
表示ESS将绑定到的接口的接口ID。如果该值被设置为-1,绑定将被移除
实现与MIB文件定义一致
hh3cDot11SrvPolicyRowStatus (1.3.6.1.4.1.25506.2.75.4.2.2.1.8)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
该表项的状态
实现与MIB文件定义一致
hh3cDot11ClientMaxCount (1.3.6.1.4.1.25506.2.75.4.2.2.1.9)
read-create
Integer32
Integer32 (0..2147483647)
表示此服务策略支持的最大无线客户端数
实现与MIB文件定义一致
hh3cDot11SPInCirMode (1.3.6.1.4.1.25506.2.75.4.2.2.1.10)
read-create
Hh3cDot11CirMode
static(1),
dynamic(2)
入方向承诺信息速率(CIR)模式。只有当对应的CIR不为0时,该节点才有用。如果该节点的值被改变,相应的CIR将被重置
实现与MIB文件定义一致
hh3cDot11SPInCirValue (1.3.6.1.4.1.25506.2.75.4.2.2.1.11)
read-create
Integer32
同MIB标准取值
表示此服务策略入方向的CIR。
如果该值为0,表示该服务策略不应用流控,对应的CIR模式没有意义
实现与MIB文件定义一致
hh3cDot11SPOutCirMode (1.3.6.1.4.1.25506.2.75.4.2.2.1.12)
read-create
Hh3cDot11CirMode
static(1),
dynamic(2)
CIR(承诺信息速率)出方向模式。只有当对应的CIR不为0时,该节点才有用。如果该节点的值被改变,相应的CIR将被重置
实现与MIB文件定义一致
hh3cDot11SPOutCirValue (1.3.6.1.4.1.25506.2.75.4.2.2.1.13)
read-create
Integer32
同MIB标准取值
表示该服务策略出站方向的CIR。
如果该值为0,表示不应用流控制服务策略,对应的CIR模式没有意义
实现与MIB文件定义一致
hh3cDot11WlanInfPVID (1.3.6.1.4.1.25506.2.75.4.2.2.1.14)
read-create
read-create
同MIB标准取值
SSID的VLAN ID
实现与MIB文件定义一致
hh3cDot11SPInCirStaticValue (1.3.6.1.4.1.25506.2.75.4.2.2.1.15)
read-create
Integer32
同MIB标准取值
静态CIR模式下inbound方向的CIR
实现与MIB文件定义一致
hh3cDot11SPOutCirStaticValue (1.3.6.1.4.1.25506.2.75.4.2.2.1.16)
read-create
Integer32
同MIB标准取值
静态CIR模式下出方向的CIR
实现与MIB文件定义一致
hh3cDot11SPIsolate (1.3.6.1.4.1.25506.2.75.4.2.2.1.17)
read-create
TruthValue
true(1),
false(2)
如果为true,则隔离与该服务策略相连接的无线客户端
实现与MIB文件定义一致
hh3cDot11WlanexAuthServerIP (1.3.6.1.4.1.25506.2.75.4.2.2.1.18)
read-create
IpAddress
同MIB标准取值
代表Wlanex认证服务器的IP地址
实现与MIB文件定义一致
hh3cDot11SPBeaconMeasEnable (1.3.6.1.4.1.25506.2.75.4.2.2.1.19)
read-create
TruthValue
true(1),
false(2)
如果为真,则信标测量启用
实现与MIB文件定义一致
hh3cDot11SPBeaconMeasType (1.3.6.1.4.1.25506.2.75.4.2.2.1.20)
read-create
INTEGER
passive(1),
active(2),
beaconTable(3)
表示信标测量类型的工作模式。
实现与MIB文件定义一致
hh3cDot11SPBeaconMeasInterval (1.3.6.1.4.1.25506.2.75.4.2.2.1.21)
read-create
Integer32
Integer32 (10..200)
表示信标测量间隔
实现与MIB文件定义一致
hh3cDot11AuthenModeCM (1.3.6.1.4.1.25506.2.75.4.2.2.1.22)
read-create
INTEGER
opensystem(0),
sharedkey(1)
表示802.11定义的认证模式
实现与MIB文件定义一致
hh3cDot11SecIEStatusCM (1.3.6.1.4.1.25506.2.75.4.2.2.1.23)
read-create
INTEGER
none(0),
wpa(1),
wpa2(2),
wlanex(3)
启用AP发送的信标和探测响应帧中的安全信息元素
实现与MIB文件定义一致
hh3cDot11SecurityCiphersCM (1.3.6.1.4.1.25506.2.75.4.2.2.1.24)
read-create
INTEGER
none(0),
wep40(1),
wep104(2),
tkip(3),
aesccmp(4),
wpisms4(5)
WLAN系统支持以下加密方式对数据帧进行加密。
实现与MIB文件定义一致
hh3cDot11SrvPolicyStatusCM (1.3.6.1.4.1.25506.2.75.4.2.2.1.25)
read-create
INTEGER
off(0),
on(1)
服务策略的状态
实现与MIB文件定义一致
hh3cDot11SSIDHiddenCM (1.3.6.1.4.1.25506.2.75.4.2.2.1.26)
read-create
Hh3cDot11TruthValueCM
dot11false(0),
dot11true(1)
此属性控制是否在信标帧中发布SSID。如果它是dot11true, SSID将不会在信标帧中发布
实现与MIB文件定义一致
hh3cDot11SPIsolateCM (1.3.6.1.4.1.25506.2.75.4.2.2.1.27)
read-create
dot11false(0),
dot11true(1)
如果为dot11true,表示与该服务策略连接的客户端是相互隔离的
实现与MIB文件定义一致
hh3cDot11FwdVlanBitMapLow (1.3.6.1.4.1.25506.2.75.4.2.2.1.28)
read-create
OCTET STRING
OCTET STRING (0..256)
该值的每一个八位代表一个8个VLAN的集合,第一个八位代表VLAN 1 ~ 8,第二个八位代表VLAN 9 ~ 16,以此类推。在每个八位中,最高位代表编号最高的VLAN,最低位代表编号最低的VLAN。因此,hybrid端口的每个untagged VLAN都用该节点值内的一个位表示。如果该位的值为“1”,则该VLAN在VLAN集中是无标记的;如果VLAN的位值为“0”,则该VLAN不是未标记的
实现与MIB文件定义一致
hh3cDot11FwdVlanBitMapHigh (1.3.6.1.4.1.25506.2.75.4.2.2.1.29)
read-create
OCTET STRING
该值中的每一个字节都指定了一组8个vlan,第一个字节指定vlan 1到8,第二个字节指定vlan 9到16,以此类推。
在每个八位中,最高位表示编号最高的VLAN,最低位表示编号最低的VLAN。因此,hybrid端口的每个untagged VLAN都用该节点值内的一个位表示。如果该位的值为“1”,则该VLAN在VLAN集中是无标记的;如果VLAN的位值为“0”,则该VLAN不是未标记的
实现与MIB文件定义一致
hh3cDot11ServicePolicyName (1.3.6.1.4.1.25506.2.75.4.2.2.1.30)
read-create
OCTET STRING
同MIB标准取值
表示每个服务策略的名称
实现与MIB文件定义一致
hh3cDot11SecurityModeCM (1.3.6.1.4.1.25506.2.75.4.2.2.1.31)
read-write
INTEGER
none(0),
psk(1),
radius(2),
wlanex(3)
确定WLAN端口的安全模式。
实现与MIB文件定义一致
hh3cDot11SPInCbsValue (1.3.6.1.4.1.25506.2.75.4.2.2.1.32)
read-create
Integer32
同MIB标准取值
表示此服务策略入站方向的CBS。当该值为0时,表示根据CIR自动计算CBS
实现与MIB文件定义一致
hh3cDot11SPOutCbsValue (1.3.6.1.4.1.25506.2.75.4.2.2.1.33)
read-create
Integer32
同MIB标准取值
表示该服务策略出站方向的CBS。当该值为0时,表示根据CIR自动计算CBS
实现与MIB文件定义一致
hh3cDot11WlanInfCustomerPVID (1.3.6.1.4.1.25506.2.75.4.2.2.1.34)
read-create
Integer32
同MIB标准取值
代表客户PVID
实现与MIB文件定义一致
【功能描述】
该表根据CLI的业务策略定义ESS的参数。当hh3cDot11SSIDEncryptionMode的值等于cipher(2)时,会将ESS的更多配置放入表中的功能。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
不支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11ServicePolicyExtID。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11ServicePolicyExtID (1.3.6.1.4.1.25506.2.75.4.2.3.1.1)
not-accessible
同MIB标准取值
表示每个服务策略的ID
实现与MIB文件定义一致
hh3cDot11SecIEStatus (1.3.6.1.4.1.25506.2.75.4.2.3.1.2)
read-create
Hh3cDot11SecIEStatusType
none(1),
rsn(2),
wpa(3),
all(4),
ext(5)
实现与MIB文件定义一致
hh3cDot11SecurityCiphers (1.3.6.1.4.1.25506.2.75.4.2.3.1.3)
read-create
Integer32
同MIB标准取值
实现与MIB文件定义一致
hh3cDot11CipherKeyIndex (1.3.6.1.4.1.25506.2.75.4.2.3.1.4)
read-create
Integer32
同MIB标准取值
表示数据包的密码密钥的密钥索引。当hh3cDot11SecurityCiphers的值为wep40或wep104时,配置生效
实现与MIB文件定义一致
hh3cDot11CipherKey (1.3.6.1.4.1.25506.2.75.4.2.3.1.5)
read-create
OCTET STRING
同MIB标准取值
表示数据包的加密密钥。当hh3cDot11SecurityCiphers的值为wep40或wep104时,配置生效
实现与MIB文件定义一致
hh3cDot11SrvPolicyExtRowStatus (1.3.6.1.4.1.25506.2.75.4.2.3.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
该表项的状态
实现与MIB文件定义一致
hh3cDot11CipherKeyType (1.3.6.1.4.1.25506.2.75.4.2.3.1.7)
read-create
INTEGER
char(1),
hex(2)
表示hh3cDot11CipherKey的密码密钥类型
实现与MIB文件定义一致
hh3cDot11AkmMode (1.3.6.1.4.1.25506.2.75.4.2.3.1.8)
read-create
INTEGER
none(0),
dot1x(1),
psk(2)
认证和密钥管理方式
实现与MIB文件定义一致
hh3cDot11PskKey (1.3.6.1.4.1.25506.2.75.4.2.3.1.9)
read-create
OCTET STRING
同MIB标准取值
表示预共享键。当“hh3cDot11AkmMode”的值为“psk”时生效
实现与MIB文件定义一致
【功能描述】
该表定义了每个无线射频的无线射频策略。如果无线射频策略为默认无线射频策略,则不能修改。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11RPAPSerialID,hh3cDot11RPRadioID。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11RPAPSerialID (1.3.6.1.4.1.25506.2.75.4.2.4.1.1)
not-accessible
OCTET STRING
此AP的序列号
实现与MIB文件定义一致
hh3cDot11RPRadioID (1.3.6.1.4.1.25506.2.75.4.2.4.1.2)
not-accessible
Integer32同MIB标准取值
此AP射频的ID
实现与MIB文件定义一致
hh3cDot11RPBeaconInterval (1.3.6.1.4.1.25506.2.75.4.2.4.1.3)
read-write
Integer32
同MIB标准取值
此AP射频beacon管理帧的间隔
实现与MIB文件定义一致
hh3cDot11RPDtimInterval (1.3.6.1.4.1.25506.2.75.4.2.4.1.4)
read-write
Integer32
同MIB标准取值
此AP射频的beacon传输在包含DTIM计数字段为0的业务指示图(TIM)中应经过的信标间隔数,该值在beacon帧传送TIM(DTIM)周期字段中传输
实现与MIB文件定义一致
hh3cDot11RPRtsThreshold (1.3.6.1.4.1.25506.2.75.4.2.4.1.5)
read-write
Integer32
同MIB标准取值
此AP射频MAC协议数据单元(MPDU)当前的最小大小(以八位字节为单位), 低于该最小大小,将不执行发送请求/清除发送(RTS/CTS)握手
实现与MIB文件定义一致
hh3cDot11RPFragThreshold (1.3.6.1.4.1.25506.2.75.4.2.4.1.6)
read-write
Integer32
同MIB标准取值
此AP射频当前可以传送到PHY的MPDU的最小大小(以八位字节为单位)。如果在添加MAC报头和尾部后MSDU的大小超过此属性的值,则MSDU应被拆分为片段
实现与MIB文件定义一致
hh3cDot11RPShortRetryThreshold (1.3.6.1.4.1.25506.2.75.4.2.4.1.7)
read-write
Integer32
同MIB标准取值
此AP射频传输长度小于或等于hh3cDot11RTSThreshold的帧的最大尝试次数,在指示故障条件之前应进行此操作
实现与MIB文件定义一致
hh3cDot11RPLongRetryThreshold (1.3.6.1.4.1.25506.2.75.4.2.4.1.8)
read-write
Integer32
同MIB标准取值
此AP射频传输长度大于hh3cDot11RTSThreshold的帧的最大尝试次数,在指示故障条件之前应进行此操作
实现与MIB文件定义一致
hh3cDot11RPClientMaxCount (1.3.6.1.4.1.25506.2.75.4.2.4.1.9)
read-write
Integer32
Integer32(0..2147483647)
此AP射频射频策略支持的最大射频数
实现与MIB文件定义一致
hh3cDot11RPBeaconIntervalCM (1.3.6.1.4.1.25506.2.75.4.2.4.1.10)
read-write
Integer32
同MIB标准取值
此AP射频beacon的间隔
实现与MIB文件定义一致
【功能描述】
该表定义了绑定加密服务模板的ESS、BSS和WLAN- ethernet接口的WLAN安全状态。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11SecurityServicePolicyID。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11SrvPortSecurityMode (1.3.6.1.4.1.25506.2.75.4.2.5.1.2)
read-write
INTEGER
noRestrictions(1),
userLoginSecureExt(2),
psk(3),
macAddressAndPsk(4),
userLoginSecureExtOrPsk(5),
ext(6)
确定WLAN端口的安全模式。
不支持
hh3cDot11SrvSecurityKeyType (1.3.6.1.4.1.25506.2.75.4.2.5.1.3)
read-write
INTEGER
userLoginTxKeyTypeNone(1),
userLoginTxKeyTypeDot11Key(2),
userLoginTxKeyTypeRsaRC4Key(3)
802.1X EAPOL_Key报文中的密钥类型。
不支持
hh3cDot11SrvSecurityPskKeyMode (1.3.6.1.4.1.25506.2.75.4.2.5.1.4)
read-write
INTEGER
pskKeyModeNone(1),
pskKeyModePassPhrase(2),
pskKeyModeRawKey(3)
密码输入方式。
不支持
hh3cDot11SrvSecurityPskKeyString (1.3.6.1.4.1.25506.2.75.4.2.5.1.5)
read-write
DisplayString
DisplayString (0..64)
psk认证的密码字符串
不支持
hh3cDot11SrvPortSecurityModeCM (1.3.6.1.4.1.25506.2.75.4.2.5.1.6)
read-write
INTEGER
none(0),
psk(1),
radius(2),
wlanex(3)
确定WLAN端口的安全模式。
不支持
【功能描述】
该表定义了每个服务策略的参数。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11SPEnable。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11SPEnable (1.3.6.1.4.1.25506.2.75.4.2.6.1.1)
read-write
INTEGER
enable(1),
disable(2)
表示服务策略是否已启用
实现与MIB文件定义一致
【功能描述】
该表定义了业务模板的二层鉴权状态。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11SrvL2AuthenID。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11SrvL2AuthenID (1.3.6.1.4.1.25506.2.75.4.2.7.1.1)
not-accessible
同MIB标准取值
表示服务模板的ID
实现与MIB文件定义一致
hh3cDot11L2AuthenMode (1.3.6.1.4.1.25506.2.75.4.2.7.1.2)
read-write
INTEGER
bypass(1),
macAuthentication(2),
macThenDot1xAuthentication(3),
dot1xAuthentication(4),
dot1xThenMacAuthentication(5),
ouiThenDot1x(6),
macAndDot1x(7)
服务模板鉴权方式。
实现与MIB文件定义一致
hh3cDot11L2IntrusProtectEnable (1.3.6.1.4.1.25506.2.75.4.2.7.1.3)
read-write
TruthValue
true(1),
false(2)
启用服务模板的入侵防御功能
实现与MIB文件定义一致
hh3cDot11L2IntrusProtectOpt (1.3.6.1.4.1.25506.2.75.4.2.7.1.4)
read-write
INTEGER
blockMACTemporarily(1),
stopServiceTemporarily(2),
stopService(3)
检测到入侵时的运行模式
实现与MIB文件定义一致
hh3cDot11TempServiceStopTimer (1.3.6.1.4.1.25506.2.75.4.2.7.1.5)
read-write
Integer32
Integer32 (10..300)
暂停服务的时间
实现与MIB文件定义一致
hh3cDot11TempBlockMACTimer (1.3.6.1.4.1.25506.2.75.4.2.7.1.6)
read-write
Integer32
Integer32 (60..300)
用户mac被临时阻断的时间段
实现与MIB文件定义一致
hh3cDot11L2IgnoreAuthorization (1.3.6.1.4.1.25506.2.75.4.2.7.1.7)
read-write
TruthValue
true(1),
false(2)
忽略服务器设置的所有授权信息
实现与MIB文件定义一致
hh3cDot11L2FailVLAN (1.3.6.1.4.1.25506.2.75.4.2.7.1.8)
read-write
Integer32
Integer32(0..4094)
VLAN认证失败。0表示未配置
实现与MIB文件定义一致
hh3cDot11L2CriticalVLAN (1.3.6.1.4.1.25506.2.75.4.2.7.1.9)
read-write
Integer32
Integer32(0..4094)
用于服务器不可用情况的VLAN。0表示未配置
实现与MIB文件定义一致
hh3cDot11L2AuthorFailOffline (1.3.6.1.4.1.25506.2.75.4.2.7.1.10)
read-write
TruthValue
true(1),
false(2)
如果授权失败,用户将被注销
实现与MIB文件定义一致
hh3cDot11L2AccountFailOffline (1.3.6.1.4.1.25506.2.75.4.2.7.1.11)
read-write
TruthValue
true(1),
false(2)
如果计费失败,用户将被注销
实现与MIB文件定义一致
hh3cDot11Dot1xHSEnable (1.3.6.1.4.1.25506.2.75.4.2.7.1.12)
read-write
TruthValue
true(1),
false(2)
启用802.1X握手功能
实现与MIB文件定义一致
hh3cDot11Dot1xSecureHSEnable (1.3.6.1.4.1.25506.2.75.4.2.7.1.13)
read-write
TruthValue
true(1),
false(2)
启用安全802.1X握手
实现与MIB文件定义一致
hh3cDot11Dot1xReauthenEnable (1.3.6.1.4.1.25506.2.75.4.2.7.1.14)
read-write
TruthValue
true(1),
false(2)
启用802.1X重认证
实现与MIB文件定义一致
hh3cDot11Dot1xMandatoryDomain (1.3.6.1.4.1.25506.2.75.4.2.7.1.15)
read-write
OCTET STRING
同MIB标准取值
用户的802.1X认证域
实现与MIB文件定义一致
hh3cDot11Dot1xMaxUserCount ()
read-write
Integer32
同MIB标准取值
业务模板绑定的BSS支持的最大802.1X用户数
实现与MIB文件定义一致
hh3cDot11MACAuthenDomain (1.3.6.1.4.1.25506.2.75.4.2.7.1.17)
read-write
OCTET STRING
同MIB标准取值
服务模板中用户的MAC认证域
实现与MIB文件定义一致
hh3cDot11MACAuthenMaxUserCount (1.3.6.1.4.1.25506.2.75.4.2.7.1.18)
read-write
Integer32
同MIB标准取值
该服务模板绑定的BSS支持的最大MAC认证用户数
实现与MIB文件定义一致
【功能描述】
该表用于显示服务模板的IP学习类型和状态。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
只限Comware V7 D029分支(H系列及WX5500X、WX5800X)产品支持,其他不支持。
该表的索引节点是hh3cDot11IPLearningServiceName,hh3cDot11IPLearningType。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11IPLearningServiceName (1.3.6.1.4.1.25506.2.75.4.2.8.1.1)
not-accessible
OCTET STRING
OCTET STRING (1..255)
表示服务名称
实现与MIB文件定义一致
hh3cDot11IPLearningType (1.3.6.1.4.1.25506.2.75.4.2.8.1.2)
not-accessible
INTEGER
invalid(1),
arp(2),
dhcp(3),
dhcp6(4),
nd(5)
表示IP学习类型
实现与MIB文件定义一致
hh3cDot11IPLearningStatus (1.3.6.1.4.1.25506.2.75.4.2.8.1.3)
read-write
TruthValue
true(1),
false(2)
表示接口的ip学习状态。将该属性设置为true,可以在接口上进行IP学习
实现与MIB文件定义一致
hh3cDot11IPLearningVlanBitMapL (1.3.6.1.4.1.25506.2.75.4.2.8.1.4)
read-write
OCTET STRING
OCTET STRING (1..256)
实现与MIB文件定义一致
hh3cDot11IPLearningVlanBitMapH (1.3.6.1.4.1.25506.2.75.4.2.8.1.5)
read-write
OCTET STRING
该值中的每一个字节都指定了一个8个vlan的集合,第一个字节指定vlan 1到8,第二个字节指定vlan 9到16,以此类推。在每个八位中,最高位表示编号最高的VLAN,最低位表示编号最低的VLAN。因此,hybrid端口的每个untagged VLAN都用该节点值内的一个位表示。如果该位的值为“1”,则该VLAN在VLAN集中是无标记的;如果VLAN的位值为“0”,则该VLAN不是未标记的
实现与MIB文件定义一致
【功能描述】
该表用来实现管理员便捷地配置AP参数的功能。在AP启动并通过CAPWAP隧道连接到AC之前,管理员将给每个AP创建一个AP模板。当AP连接到AC时,AC将通过AP模板中的AP序列号将配置信息下发到AP。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
支持
【表节点信息】
该表的索引节点是hh3cDot11APTemplateName。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11APTemplateName (1.3.6.1.4.1.25506.2.75.4.3.1.1.1)
not-accessible
OCTET STRING
OCTET STRING (0..127)
表示AP模板名称
实现与MIB文件定义一致
hh3cDot11APSerialID (1.3.6.1.4.1.25506.2.75.4.3.1.1.2)
read-create
OCTET STRING
同MIB标准取值
表示AP序列号
实现与MIB文件定义一致
hh3cDot11TemplateAPModelAlias (1.3.6.1.4.1.25506.2.75.4.3.1.1.3)
read-create
OCTET STRING
同MIB标准取值
表示AP型号名称
实现与MIB文件定义一致
hh3cDot11Description (1.3.6.1.4.1.25506.2.75.4.3.1.1.4)
read-create
OCTET STRING
同MIB标准取值
表示AP详细信息,管理员可以记录AP的位置,拥有者或者其他信息。如果此值被设置为空,则表示描述信息将会被移除。
实现与MIB文件定义一致
hh3cDot11APWorkMode (1.3.6.1.4.1.25506.2.75.4.3.1.1.5)
read-create
INTEGER
normal(1)
monitor(2)
hybrid(3)
表示AP的工作模式。
normal:提供无线服务
monitor:监测探测攻击
hybrid:既能提供无线服务,又能探测攻击
实现与MIB文件定义一致
hh3cDot11APTemplateRowStatus (1.3.6.1.4.1.25506.2.75.4.3.1.1.6)
read-create
RowStatus
INTEGER {
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
表示AP模板行状态
实现与MIB文件定义一致
hh3cDot11APName
(1.3.6.1.4.1.25506.2.75.4.3.1.1.7)
read-create
OCTET STRING
同MIB标准取值
表示AP名称
实现与MIB文件定义一致
hh3cDot11StatisInterv
(1.3.6.1.4.1.25506.2.75.4.3.1.1.8)
read-create
Integer32
同MIB标准取值
表示射频统计时间间隔
实现与MIB文件定义一致
hh3cDot11APBroadcastProbeReply
(1.3.6.1.4.1.25506.2.75.4.3.1.1.9)
read-create
TruthValue
true(1),
false(2)
表示AP是否使能回复广播探测报文
实现与MIB文件定义一致
hh3cDot11StaIdleTimerInterv (1.3.6.1.4.1.25506.2.75.4.3.1.1.10)
read-create
Integer32
同MIB标准取值
表示AP和STA(省电或唤醒)之间链路空闲的时间间隔
实现与MIB文件定义一致
hh3cDot11StaKeepAliveTimerInterv (1.3.6.1.4.1.25506.2.75.4.3.1.1.11)
read-create
Integer32
同MIB标准取值
表示AP和STA之间链路保活的时间间隔,单位为秒
实现与MIB文件定义一致
hh3cDot11APCir (1.3.6.1.4.1.25506.2.75.4.3.1.1.12)
read-create
Integer32
同MIB标准取值
表示AP和AC间的确认速率
实现与MIB文件定义一致
hh3cDot11APCbs (1.3.6.1.4.1.25506.2.75.4.3.1.1.13)
read-create
Integer32
同MIB标准取值
表示AP和AC间的拥塞大小
实现与MIB文件定义一致
hh3cDot11APPriorityLevel (1.3.6.1.4.1.25506.2.75.4.3.1.1.14)
read-create
Integer32
Integer32(0..7)
表示AP连接的优先级,默认值为4
实现与MIB文件定义一致
hh3cDot11APElementID (1.3.6.1.4.1.25506.2.75.4.3.1.1.15)
read-only
Integer32
同MIB标准取值
表示APID
实现与MIB文件定义一致
hh3cDot11APDevDetectEnable (1.3.6.1.4.1.25506.2.75.4.3.1.1.16)
read-create
TruthValue
true(1),
false(2)
表示是否开启设备探测功能,如果开启,AP将会同时提供无线服务和设备探测功能。
实现与MIB文件定义一致
hh3cDot11APGetIPMethod (1.3.6.1.4.1.25506.2.75.4.3.1.1.17)
read-create
INTEGER
dhcpAlloc(1)
static(2)
表示AP获取IP地址的方式。
实现与MIB文件定义一致
hh3cDot11StatisIntervMode (1.3.6.1.4.1.25506.2.75.4.3.1.1.18)
read-create
INTEGER
normal(1)
realtime(2)
表示统计间隔方式。
 normal:统计间隔在10s – 240s
realtime:统计间隔在0s – 5s
实现与MIB文件定义一致
hh3cDot11ApTrapEnabled
(1.3.6.1.4.1.25506.2.75.4.3.1.1.19)
read-create
TruthValue
true(1),
false(2)
表示告警状态是否开启
实现与MIB文件定义一致
hh3cDot11ApFmwUpdState (1.3.6.1.4.1.25506.2.75.4.3.1.1.20)
read-create
INTEGER
enable(1)
disable(2)
inherit(3)
表示AP版本自动升级开关状态。
enable:自动升级使能
disable:自动升级未使能
inherit:继承组配置
实现与MIB文件定义一致
hh3cDot11StatisIntervModeCM (1.3.6.1.4.1.25506.2.75.4.3.1.1.21)
read-create
INTEGER
off(0)
on(1)
表示统计信息间隔状态
off:统计间隔在10s – 240s
on:统计间隔在0s – 5s
实现与MIB文件定义一致
hh3cDot11ApNasIDCM (1.3.6.1.4.1.25506.2.75.4.3.1.1.22)
read-create
OCTET STRING
同MIB标准取值
表示AP每个指定射频当前服务策略的NAS-ID
实现与MIB文件定义一致
hh3cDot11ApCoveragetype (1.3.6.1.4.1.25506.2.75.4.3.1.1.23)
read-create
INTEGER
school(1)
traffic(2)
shopping(3)
company(4)
表示AP覆盖类型。
school:学校
traffic:交通
shopping:商场
company:办公场所
实现与MIB文件定义一致
hh3cDot11APControlAddressState (1.3.6.1.4.1.25506.2.75.4.3.1.1.24)
read-create
INTEGER
enable(1)
disable(2)
表示AP二次发现功能使能状态。
enable:二次发现功能使能
disable:二次发现功能未使能
实现与MIB文件定义一致
hh3cDot11APControlAddressIPv4 (1.3.6.1.4.1.25506.2.75.4.3.1.1.25)
read-write
IpAddress
同MIB标准取值
表示二次发现的AC IP地址。
实现与MIB文件定义一致
hh3cDot11APControlAddressIPv6 (1.3.6.1.4.1.25506.2.75.4.3.1.1.26)
read-create
OCTET STRING
同MIB标准取值
表示二次发现的AC IPv6地址
实现与MIB文件定义一致
hh3cDot11APLocalACName (1.3.6.1.4.1.25506.2.75.4.3.1.1.27)
read-only
OCTET STRING
同MIB标准取值
表示AP所属的local AC名称
实现与MIB文件定义一致
hh3cDot11APEchoInterval (1.3.6.1.4.1.25506.2.75.4.3.1.1.28)
read-create
Integer32
同MIB标准取值
表示AP保活时间间隔
实现与MIB文件定义一致
hh3cDot11APProvisionAPIPv4 (1.3.6.1.4.1.25506.2.75.4.3.1.1.29)
read-write
IpAddress
同MIB标准取值
表示预配置AP IPv4地址。
实现与MIB文件定义一致
hh3cDot11APProvisionIPv4Mask
(1.3.6.1.4.1.25506.2.75.4.3.1.1.30)
read-create
Integer32
Integer32(1..31)
表示预配置AP IPv4地址掩码
实现与MIB文件定义一致
hh3cDot11APProvisionAPIPv6 (1.3.6.1.4.1.25506.2.75.4.3.1.1.31)
read-create
OCTET STRING
同MIB标准取值
表示预配置AP IPv6地址
实现与MIB文件定义一致
hh3cDot11APProvisionIPv6PrefixLen (1.3.6.1.4.1.25506.2.75.4.3.1.1.32)
read-create
Integer32
Integer32(1..128)
表示预配置AP IPv6地址前缀长度
实现与MIB文件定义一致
hh3cDot11APProvisionACIPv4 (1.3.6.1.4.1.25506.2.75.4.3.1.1.33)
read-write
IpAddress
同MIB标准取值
表示预配置AC IPv4地址。
实现与MIB文件定义一致
hh3cDot11APProvisionACIpv6 (1.3.6.1.4.1.25506.2.75.4.3.1.1.34)
read-create
OCTET STRING
同MIB标准取值
表示预配置AC IPv6地址
实现与MIB文件定义一致
hh3cDot11APProvisionGateWayIPV4 (1.3.6.1.4.1.25506.2.75.4.3.1.1.35)
read-write
IpAddress
同MIB标准取值
表示预配置网关IPv4地址。
实现与MIB文件定义一致
hh3cDot11APProvisionGateWayIPV6 (1.3.6.1.4.1.25506.2.75.4.3.1.1.36)
read-create
OCTET STRING
同MIB标准取值
表示预配置网关IPv6地址
实现与MIB文件定义一致
hh3cDot11APMapConfigFileName (1.3.6.1.4.1.25506.2.75.4.3.1.1.37)
read-create
OCTET STRING
同MIB标准取值
表示MapConfig配置文件名称
实现与MIB文件定义一致
【功能描述】
该表用来实现Radio下配置的功能。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点说明,如果为多级索引,以顿号“、”分隔。
该表的索引节点是hh3cDot11APTemplateNameCfg、hh3cDot11CfgRadioID。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11APTemplateNameCfg (1.3.6.1.4.1.25506.2.75.4.3.2.1.1)
not-accessible
OCTET STRING
此AP模板的名称
实现与MIB文件定义一致
hh3cDot11CfgRadioID (1.3.6.1.4.1.25506.2.75.4.3.2.1.2)
not-accessible
Integer32同MIB标准取值
此AP射频的ID
实现与MIB文件定义一致
hh3cDot11CfgRadioPolicyName (1.3.6.1.4.1.25506.2.75.4.3.2.1.3)
read-write
OCTET STRING
同MIB标准取值
此AP射频策略的名称
实现与MIB文件定义一致
hh3cDot11CfgRadioType (1.3.6.1.4.1.25506.2.75.4.3.2.1.4)
read-write
Hh3cDot11RadioType
dot11a(1),
dot11b(2),
dot11g(4),
dot11n(8),
dot11gn(16),
dot11an(32),
dot11ac(64),
dot11gac(128),
dot11ax(256),
dot11gax(512)
此AP射频使用的802.11射频类型
实现与MIB文件定义一致
hh3cDot11CfgChannel (1.3.6.1.4.1.25506.2.75.4.3.2.1.5)
read-write
Hh3cDot11ChannelScopeType
Integer32同MIB标准取值
此AP射频分配的信道
实现与MIB文件定义一致
hh3cDot11CfgMaxTxPowerLevel (1.3.6.1.4.1.25506.2.75.4.3.2.1.6)
read-write
Hh3cDot11TxPwrLevelScopeType
Integer32同MIB标准取值
此AP射频的最大发射功率范围
实现与MIB文件定义一致
hh3cDot11PreambleLen (1.3.6.1.4.1.25506.2.75.4.3.2.1.7)
read-write
Hh3cDot11PreambleType
long (1),
short (2)
此AP射频对802.11 MAC帧使用的短导类型(长/短)。当hh3cDot11CfgRadioType为dot11b、dot11g或dot11gn时,hh3cDot11PreambleLen的值将有效。否则,其值将无效
实现与MIB文件定义一致
hh3cDot11CfgRadioStatus (1.3.6.1.4.1.25506.2.75.4.3.2.1.8)
read-write
TruthValue
true(1),
false(2)
此AP射频管理状态(启用/关闭)
实现与MIB文件定义一致
hh3cDot11CfgRdElementID (1.3.6.1.4.1.25506.2.75.4.3.2.1.9)
read-only
Unsigned32
同MIB标准取值
此AP射频的元素ID,该ID包括两部分,最高的24位是APID,最低的8位是射频ID
实现与MIB文件定义一致
hh3cDot11CfgWorkMode (1.3.6.1.4.1.25506.2.75.4.3.2.1.10)
read-write
Hh3cDot11WorkMode
normal (1),
monitor (2),
hybrid (3)
此AP射频的工作模式
实现与MIB文件定义一致
hh3cDot11CfgPwrAttValue (1.3.6.1.4.1.25506.2.75.4.3.2.1.11)
read-write
Integer32
同MIB标准取值
此AP射频的功率衰减值
实现与MIB文件定义一致
hh3cDot11RadioTxArithmetic (1.3.6.1.4.1.25506.2.75.4.3.2.1.12)
read-write
INTEGER
quality(1),
bandwidth(2)
此AP射频的传输算法,支持如下值:
quality-在传输过程中首先考虑质量
bandwidth-带宽-在传输过程中首先考虑带宽
实现与MIB文件定义一致
hh3cDot11CfgChannelLockStat (1.3.6.1.4.1.25506.2.75.4.3.2.1.13)
read-write
INTEGER
unlocked (1),
locked (2)
此AP射频信道的锁定状态
实现与MIB文件定义一致
hh3cDot11CfgPowerLockStat (1.3.6.1.4.1.25506.2.75.4.3.2.1.14)
read-write
INTEGER
unlocked (1),
locked (2)
此AP射频功耗的锁定状态
实现与MIB文件定义一致
hh3cDot11CfgLBRdGroupId (1.3.6.1.4.1.25506.2.75.4.3.2.1.15)
read- write
Unsigned32
同MIB标准取值
为此AP射频分配的负载平衡组ID
实现与MIB文件定义一致
hh3cDot11CfgRRMSDRdGroupId (1.3.6.1.4.1.25506.2.75.4.3.2.1.16)
read- write
Unsigned32
同MIB标准取值
为此AP射频分配的RRN自主组ID
实现与MIB文件定义一致
hh3cDot11CfgRadioType2 (1.3.6.1.4.1.25506.2.75.4.3.2.1.17)
read-write
Hh3cDot11RadioType2
dot11a(1),
dot11b(2),
dot11g(4),
dot11an(8),
dot11gn(16),
dot11ac(32),
dot11gac(64),
dot11ax(128),
dot11gax(256)
此AP射频使用的802.11射频类型
实现与MIB文件定义一致
hh3cDot11CfgIDSEnable (1.3.6.1.4.1.25506.2.75.4.3.2.1.18)
read-write
TruthValue
true(1),
false(2)
此AP射频是否启用入侵检测
实现与MIB文件定义一致
hh3cDot11CfgSaEnable
(1.3.6.1.4.1.25506.2.75.4.3.2.1.19)
read-write
TruthValue
true(1),
false(2)
是否启用频谱分析
实现与MIB文件定义一致
hh3cDot11CfgSaCltRtFFTData
(1.3.6.1.4.1.25506.2.75.4.3.2.1.20)
read-write
TruthValue
true(1),
false(2)
是否收集实时FFT数据
实现与MIB文件定义一致
hh3cDot11CfgSaBand
(1.3.6.1.4.1.25506.2.75.4.3.2.1.21)
read-write
INTEGER
dot11g(1), dot11aLower(2), dot11aMiddle(3), dot11aUpper(4)
实时收集FFT数据所用的信道
实现与MIB文件定义一致
hh3cDot11CfgSaRptDevType
(1.3.6.1.4.1.25506.2.75.4.3.2.1.22)
read-write
BITS
microwave(0), microwaveInverter(1),
 bluetooth(2), fixedFreqOthers(3), fixedFreqCordlessPhone(4), fixedFreqVideo(5),
fixedFreqAudio(6),
freqHopperOthers(7), freqHopperCordlessBase(8), freqHopperCordlessNetwork(9), freqHopperXbox(10), genericInterferer(11),
freqHopperCordlessNetwork5g(12)
上报的设备类型
实现与MIB文件定义一致
hh3cDot11CfgSaTrapDevEnable
(1.3.6.1.4.1.25506.2.75.4.3.2.1.23)
read-write
TruthValue
true(1),
false(2)
是否开启trap
实现与MIB文件定义一致
hh3cDot11CfgSaTrapDevType
(1.3.6.1.4.1.25506.2.75.4.3.2.1.24)
read-write
BITS
fixedFreqAudio(6),
开启trap的设备类型
实现与MIB文件定义一致
hh3cDot11CfgSaTrapAQEnable
(1.3.6.1.4.1.25506.2.75.4.3.2.1.25)
read-write
TruthValue
true(1),
false(2)
是否开启信道质量trap
实现与MIB文件定义一致
hh3cDot11CfgSaTrapAQThreshold
(1.3.6.1.4.1.25506.2.75.4.3.2.1.26)
read-write
Integer32
Integer32(1..100)
信道质量阈值
实现与MIB文件定义一致
hh3cDot11CfgSaDrivenRRMEnable
(1.3.6.1.4.1.25506.2.75.4.3.2.1.27)
read-write
TruthValue
true(1),
false(2)
当AP检测到一定程度的干扰时是否运行RRM
实现与MIB文件定义一致
hh3cDot11CfgSaDrivenRRMSnt
(1.3.6.1.4.1.25506.2.75.4.3.2.1.28)
read-write
INTEGER
low(1),
medium(2),
high(3)
触发RRM的阈值
实现与MIB文件定义一致
hh3cDot11CfgSPInCirMode (1.3.6.1.4.1.25506.2.75.4.3.2.1.29)
read-create
Hh3cDot11CirMode
static(1),
dynamic(2)
此AP射频指定入站方向的提交信息速率 (CIR)模式,只有当相应的CIR具有非零值时,此对象才有用。如果更改此对象的值,则将重置相应的CIL
实现与MIB文件定义一致
hh3cDot11CfgSPInCirValue (1.3.6.1.4.1.25506.2.75.4.3.2.1.30)
read- create
Integer32
同MIB标准取值
此AP射频服务策略的入站方向的CIR。如果值为0,则表示没有对服务策略应用流控制,相应的CIR模式没有意义
实现与MIB文件定义一致
hh3cDot11CfgSPOutCirMode (1.3.6.1.4.1.25506.2.75.4.3.2.1.31)
read-create
Hh3cDot11CirMode
static(1),
dynamic(2)
此AP射频指定出站方向的提交信息速率 (CIR)模式,只有当相应的CIR具有非零值时,此对象才有用。如果更改此对象的值,则将重置相应的CIL
实现与MIB文件定义一致
hh3cDot11CfgSPOutCirValue (1.3.6.1.4.1.25506.2.75.4.3.2.1.32)
read- create
Integer32
同MIB标准取值
此AP射频服务策略的出站方向的CIR。如果值为0,则表示没有对服务策略应用流控制,相应的CIR模式没有意义
实现与MIB文件定义一致
【功能描述】
对于每个无线射频,它可以配置多个服务策略。该表用于描述无线射频策略和业务策略之间的关系的功能。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
不支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11CfgServicePolicyID。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11CfgServicePolicyID (1.3.6.1.4.1.25506.2.75.4.3.3.1.1)
not-accessible
同MIB标准取值
表示AP使用的每个服务策略的ID
实现与MIB文件定义一致
hh3cDot11SrvSetRowStatus (1.3.6.1.4.1.25506.2.75.4.3.3.1.2)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
该表项的状态
实现与MIB文件定义一致
hh3cDot11ServiceSetVlanId (1.3.6.1.4.1.25506.2.75.4.3.3.1.3)
read-create
Integer32
Integer32(0..4094)
表示业务策略与Radio绑定时生成的BSS的Vlan ID
实现与MIB文件定义一致
hh3cDot11ServiceSetVlanGroup (1.3.6.1.4.1.25506.2.75.4.3.3.1.4)
read-create
OCTET STRING
OCTET STRING (0..31)
表示业务策略与射频绑定时生成的BSS的VLAN组
实现与MIB文件定义一致
【功能描述】
该表用来提供指定AP的系统信息配置。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11SIDAPSerialID。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11APSysNetID (1.3.6.1.4.1.25506.2.75.4.3.4.1.1)
read-write
OCTET STRING
此AP的系统网络ID
实现与MIB文件定义一致
hh3cDot11APCpuUsageThreshold (1.3.6.1.4.1.25506.2.75.4.3.4.1.2)
read-write
Integer32
Integer32(0..100)
此AP的CPU使用阈值
实现与MIB文件定义一致
hh3cDot11APMemUsageThreshold (1.3.6.1.4.1.25506.2.75.4.3.4.1.3)
read-write
Integer32
Integer32(0..100)
此AP的内存使用阈值
实现与MIB文件定义一致
【功能描述】
对于每个连接的ap,管理员可以配置一系列限制。该表描述AP的限制信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11APElementIndex。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11APSsidNumLimit (1.3.6.1.4.1.25506.2.75.4.3.5.1.1)
read-write
Integer32
Integer32(0..65535)
表示该AP绑定的服务模板的上限,所有AP的射频共享此上限。默认值0:表示该AP绑定的服务模板没有上限
实现与MIB文件定义一致
hh3cDot11APUserCntLimit (1.3.6.1.4.1.25506.2.75.4.3.5.1.2)
read-write
Integer32
Integer32(0..65535)
表示访问该AP的用户的上限,所有与AP绑定的bss共享此上限。缺省值0:表示没有访问该AP的用户上限
实现与MIB文件定义一致
hh3cDot11APUserThreshold (1.3.6.1.4.1.25506.2.75.4.3.5.1.3)
read-write
Integer32
Integer32(0..65535)
表示能够访问该AP的用户阈值,所有与AP绑定的bss共享此阈值。如果用户计数器溢出,则发送该告警。缺省值0:表示不存在访问该AP的用户阈值
实现与MIB文件定义一致
【功能描述】
该表用来实现AP接口配置。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11APElementIndex、hh3cDot11APSetIfIndex。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11APSetIfIndex (1.3.6.1.4.1.25506.2.75.4.3.6.1.1)
not-accessible
Integer32
同MIB标准取值
此AP接口的索引
实现与MIB文件定义一致
hh3cDot11APIfAlias (1.3.6.1.4.1.25506.2.75.4.3.6.1.2)
read-write
DisplayString
OCTET STRING同MIB标准取值
此AP指定的接口的别名
实现与MIB文件定义一致
【功能描述】
该表用来实现AP各射频的配置信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11RCAPSerialID、hh3cDot11RCRadioID。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11RCAPSerialID (1.3.6.1.4.1.25506.2.75.4.3.8.1.1)
not-accessible
OCTET STRING
此AP的序列号
实现与MIB文件定义一致
hh3cDot11RCRadioID (1.3.6.1.4.1.25506.2.75.4.3.8.1.2)
not-accessible
Integer32同MIB标准取值
此AP射频的ID
实现与MIB文件定义一致
hh3cDot11RCRadioType (1.3.6.1.4.1.25506.2.75.4.3.8.1.3)
read-write
Hh3cDot11RadioType
dot11a(1),
dot11b(2),
dot11g(4),
dot11n(8),
dot11gn(16),
dot11an(32),
dot11ac(64),
dot11gac(128),
dot11ax(256),
dot11gax(512)
此AP射频的使用的802.11射频类型
实现与MIB文件定义一致
hh3cDot11RCChannel (1.3.6.1.4.1.25506.2.75.4.3.8.1.4)
read-write
Integer32同MIB标准取值
此AP射频分配的信道
实现与MIB文件定义一致
hh3cDot11RCPreambleLen (1.3.6.1.4.1.25506.2.75.4.3.8.1.5)
read-write
long (1),
short (2)
此AP射频对802.11 MAC帧使用的短导类型(长/短)。当hh3cDot11CfgRadioType为dot11b、dot11g或dot11gn时,hh3cDot11PreambleLen的值将有效。否则,其值将无效。
实现与MIB文件定义一致
hh3cDot11RCPwrAttValue (1.3.6.1.4.1.25506.2.75.4.3.8.1.6)
read-write
Integer32
同MIB标准取值
此AP射频的功率衰减值
实现与MIB文件定义一致
hh3cDot11RCApPowerLevel (1.3.6.1.4.1.25506.2.75.4.3.8.1.7)
read-write
Integer32同MIB标准取值
此AP射频的最大发射功率范围
实现与MIB文件定义一致
hh3cDot11RCDynamicChlState (1.3.6.1.4.1.25506.2.75.4.3.8.1.8)
read-write
TruthValue
true(1),
false(2)
此AP射频启用/禁用动态频道选择
实现与MIB文件定义一致
hh3cDot11RCDynamicPowerState (1.3.6.1.4.1.25506.2.75.4.3.8.1.9)
read-write
TruthValue
true(1),
false(2)
此AP射频启用/禁用动态功耗选择
实现与MIB文件定义一致
hh3cDot11RCRadioStatus (1.3.6.1.4.1.25506.2.75.4.3.8.1.10)
read-write
TruthValue
true(1),
false(2)
此AP射频启用/禁用射频管理状态
实现与MIB文件定义一致
hh3cDot11RCRadioRate (1.3.6.1.4.1.25506.2.75.4.3.8.1.11)
read-write
OCTET STRING
OCTET STRING(0..255)
此AP射频可设置的射频数据传输速率,格式为1,2,5.5…对于802.11n无线电,格式可以是MCS X。AP和STA之间的数据传输率必须符合配置的速率。(注意:对于802.11n无线电,第一个值将被视为强制速率,第二个值将视为支持速率。如果配置了两个以上的速率,则配置无法生效。如果仅配置了一个速率,则默认情况下将其视为强制率。)
实现与MIB文件定义一致
hh3cDot11RCPwrAdjustStepLength (1.3.6.1.4.1.25506.2.75.4.3.8.1.12)
read-only
Integer32
同MIB标准取值
此AP射频功率调整的步长
实现与MIB文件定义一致
hh3cDot11RCRadioType2 (1.3.6.1.4.1.25506.2.75.4.3.8.1.13)
read-write
Hh3cDot11RadioType2
dot11a(1),
dot11b(2),
dot11g(4),
dot11an(8),
dot11gn(16),
dot11ac(32),
dot11gac(64),
dot11ax(128),
dot11gax(256)
此AP射频使用的802.11射频类型
实现与MIB文件定义一致
hh3cDot11RCPreambleLenCM (1.3.6.1.4.1.25506.2.75.4.3.8.1.14)
read-write
INTEGER
long (1),
short (2)
实现与MIB文件定义一致
hh3cDot11RCDynamicChlStateCM (1.3.6.1.4.1.25506.2.75.4.3.8.1.15)
read-write
INTEGER
off (0),
on (1)
此AP射频启用/禁用动态频道选择
实现与MIB文件定义一致
hh3cDot11RCRadioStatusCM (1.3.6.1.4.1.25506.2.75.4.3.8.1.16)
read-write
INTEGER
up (1),
down (2),
testing (3)
此AP射频的射频管理状态(启用/禁用)
实现与MIB文件定义一致
hh3cDot11RCRadioRateCM (1.3.6.1.4.1.25506.2.75.4.3.8.1.17)
read-write
OCTET STRING
实现与MIB文件定义一致
hh3cDot11RCDynamicPowerStateCM (1.3.6.1.4.1.25506.2.75.4.3.8.1.18)
read-write
dot11false (0),
dot11true (1)
此AP射频启用/禁用频带动态功耗选择
实现与MIB文件定义一致
hh3cDot11RCRssiThresholdCM (1.3.6.1.4.1.25506.2.75.4.3.8.1.19)
read-write
Integer32
同MIB标准取值
此AP射频RSSI的最小值,RSSI低于此值的客户端将被拒绝关联。
实现与MIB文件定义一致
hh3cDot11RCDynamicChlStateSelfDecisiveCM (1.3.6.1.4.1.25506.2.75.4.3.8.1.20)
read-write
dot11false (0),
dot11true (1)
此AP射频启用/禁用频带的自动动态频道选择
实现与MIB文件定义一致
hh3cDot11RCDynamicPowerStateSelfDecisiveCM (1.3.6.1.4.1.25506.2.75.4.3.8.1.21)
read-write
dot11false (0),
dot11true (1)
此AP射频启用/禁用频带的自动动态功耗选择
实现与MIB文件定义一致
【功能描述】
对于AP上的所有无线射频,它可以配置多个服务策略。该表描述了AP与业务策略的对应关系的功能。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
不支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11APServiceVlanSerialID,hh3cDot11APServiceVlanSPID。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11APServiceVlanSerialID (1.3.6.1.4.1.25506.2.75.4.3.7.1.1)
not-accessible
OCTET STRING
同MIB标准取值
该节点表示AP的序列号
实现与MIB文件定义一致
hh3cDot11APServiceVlanSPID (1.3.6.1.4.1.25506.2.75.4.3.7.1.2)
not-accessible
同MIB标准取值
该节点表示AP使用的每个服务策略的ID
实现与MIB文件定义一致
hh3cDot11APServiceVlanId (1.3.6.1.4.1.25506.2.75.4.3.7.1.3)
read-create
Integer32
Integer32(0..4094)
该节点表示业务策略与射频绑定时产生的BSS的VLAN ID
实现与MIB文件定义一致
hh3cDot11APServiceVlanRowStatus (1.3.6.1.4.1.25506.2.75.4.3.7.1.4)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
该节点表示该表项的状态
实现与MIB文件定义一致
【功能描述】
对于每个无线射频,它可以配置多个服务策略。该表用于描述无线射频策略和业务策略之间的关系。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
不支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11RadioSSIDSerialID,hh3cDot11RadioSSIDRadioID,hh3cDot11RadioSSIDWLANID。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11RadioSSIDSerialID (1.3.6.1.4.1.25506.2.75.4.3.9.1.1)
not-accessible
Hh3cDot11ObjectIDType(0..127)
该节点表示AP的序列号
实现与MIB文件定义一致
hh3cDot11RadioSSIDRadioID (1.3.6.1.4.1.25506.2.75.4.3.9.1.2)
not-accessible
同MIB标准取值
这个对象代表每个无线射频
实现与MIB文件定义一致
hh3cDot11RadioSSIDWLANID (1.3.6.1.4.1.25506.2.75.4.3.9.1.3)
not-accessible
Integer32
同MIB标准取值
BSSID的WLAN ID
实现与MIB文件定义一致
hh3cDot11RadioSSIDIndex (1.3.6.1.4.1.25506.2.75.4.3.9.1.4)
read-create
同MIB标准取值
该对象表示电台使用的每个服务策略的ID
实现与MIB文件定义一致
hh3cDot11RadioBSSID (1.3.6.1.4.1.25506.2.75.4.3.9.1.5)
read-only
MacAddress
MacAddress(6)
作为MAC地址格式,用于标识BSS
实现与MIB文件定义一致
hh3cDot11RadioSSIDRowStatus (1.3.6.1.4.1.25506.2.75.4.3.9.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
RowStatus.
实现与MIB文件定义一致
【功能描述】
该表用来实现给AP下发基础信息配置的功能。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
支持
支持
支持
【表节点信息】
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11SIDAPSerialID (1.3.6.1.4.1.25506.2.75.4.3.10.1.1)
not-accessible
OCTET STRING
同MIB标准取值
表示AP序列号
实现与MIB文件定义一致
hh3cDot11SIDAPWorkMode (1.3.6.1.4.1.25506.2.75.4.3.10.1.2)
read-create
INTEGER
normal(1)
monitor(2)
hybrid(3)
表示AP的工作模式。
normal:提供无线服务
monitor:监测探测攻击
实现与MIB文件定义一致
hh3cDot11SIDAPGetIPMethod (1.3.6.1.4.1.25506.2.75.4.3.10.1.3)
read-create
INTEGER
dhcpAlloc(1)
static(2)
表示AP获取IP地址的方式。
实现与MIB文件定义一致
hh3cDot11SIDAPTemplateName (1.3.6.1.4.1.25506.2.75.4.3.10.1.4)
read-create
OCTET STRING
同MIB标准取值
表示AP模板名称
实现与MIB文件定义一致
hh3cDot11SIDModelAlias (1.3.6.1.4.1.25506.2.75.4.3.10.1.5)
read-create
OCTET STRING
同MIB标准取值
表示AP型号名称
实现与MIB文件定义一致
hh3cDot11SIDAPDescription (1.3.6.1.4.1.25506.2.75.4.3.10.1.6)
read-create
OCTET STRING
同MIB标准取值
实现与MIB文件定义一致
hh3cDot11SIDRowStatus (1.3.6.1.4.1.25506.2.75.4.3.10.1.7)
read-create
RowStatus
INTEGER {
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
表示AP序列号表行状态
实现与MIB文件定义一致
hh3cDot11SIDAPName (1.3.6.1.4.1.25506.2.75.4.3.10.1.8)
read-create
OCTET STRING
同MIB标准取值
表示AP名称
实现与MIB文件定义一致
hh3cDot11SIDStatisInterv (1.3.6.1.4.1.25506.2.75.4.3.10.1.9)
read-create
Integer32
同MIB标准取值
表示射频统计时间间隔
实现与MIB文件定义一致
hh3cDot11SIDAPBroadcastProbeReply (1.3.6.1.4.1.25506.2.75.4.3.10.1.10)
read-create
TruthValue
true(1),
false(2)
表示AP是否使能回复广播探测报文
实现与MIB文件定义一致
hh3cDot11SIDAPStaIdleTimerInterv (1.3.6.1.4.1.25506.2.75.4.3.10.1.11)
read-create
Integer32
同MIB标准取值
实现与MIB文件定义一致
hh3cDot11SIDStaKeepAliveTimerInterv (1.3.6.1.4.1.25506.2.75.4.3.10.1.12)
read-create
Integer32
同MIB标准取值
实现与MIB文件定义一致
hh3cDot11SIDAPCir (1.3.6.1.4.1.25506.2.75.4.3.10.1.13)
read-create
Integer32
同MIB标准取值
表示AP和AC间的传输速率
实现与MIB文件定义一致
hh3cDot11SIDAPCbs (1.3.6.1.4.1.25506.2.75.4.3.10.1.14)
read-create
Integer32
同MIB标准取值
表示AP和AC间的拥塞字节数
实现与MIB文件定义一致
hh3cDot11SIDAPPriorityLevel (1.3.6.1.4.1.25506.2.75.4.3.10.1.15)
read-create
Integer32
Integer32(0..7)
表示AP连接的优先级,默认值为4
实现与MIB文件定义一致
hh3cDot11SIDAPElementID (1.3.6.1.4.1.25506.2.75.4.3.10.1.16)
read-only
Integer32
同MIB标准取值
表示APID
实现与MIB文件定义一致
hh3cDot11SIDAPDevDetectEnable (1.3.6.1.4.1.25506.2.75.4.3.10.1.17)
read-create
TruthValue
true(1),
false(2)
实现与MIB文件定义一致
hh3cDot11SIDAPStatisIntervMode (1.3.6.1.4.1.25506.2.75.4.3.10.1.18)
read-create
INTEGER
normal(1)
realtime(2)
表示统计间隔方式。
实现与MIB文件定义一致
hh3cDot11SIDAPWorkModeCM
(1.3.6.1.4.1.25506.2.75.4.3.10.1.19)
read-create
INTEGER
normal(0),
monitor(1), semimonitor(2)
Ap的工作模式,默认是normal
实现与MIB文件定义一致
hh3cDot11SIDEchoInterval (1.3.6.1.4.1.25506.2.75.4.3.10.1.20)
read-create
Integer32
同MIB标准取值
表示心跳保活报文间隔
实现与MIB文件定义一致
【功能描述】
对于每个服务策略,它可以绑定到多个vlan。该表描述了VLAN与业务策略的对应关系。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
不支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11SIDAPSerialID,hh3cDot11CfgRadioID,hh3cDot11CfgServicePolicyID,hh3cDot11CfgServiceSetRowStatus。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11CfgSTVLANID (1.3.6.1.4.1.25506.2.75.4.3.11.1.1)
read-create
Integer32
Integer32(0..4094)
表示当前服务策略绑定到的VLAN
实现与MIB文件定义一致
hh3cDot11CfgSTNASPortID (1.3.6.1.4.1.25506.2.75.4.3.11.1.2)
read-only
OCTET STRING
表示AP的每个特定无线射频的当前服务策略的NAS端口ID
实现与MIB文件定义一致
hh3cDot11CfgServiceSetRowStatus (1.3.6.1.4.1.25506.2.75.4.3.11.1.3)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
该表项的状态
实现与MIB文件定义一致
hh3cDot11CfgSTNASID (1.3.6.1.4.1.25506.2.75.4.3.11.1.4)
read-only
OCTET STRING
表示AP的每个特定无线射频的当前服务策略的NAS ID
实现与MIB文件定义一致
【功能描述】
该表用来提供AP各射频的信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11RadioIfIdx。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11RadioIfIdx (1.3.6.1.4.1.25506.2.75.4.4.1.1.1)
not-accessible
Integer32
同MIB标准取值
此AP射频的索引
实现与MIB文件定义一致
hh3cDot11RadioCfgBeaconIntvl (1.3.6.1.4.1.25506.2.75.4.4.1.1.2)
read-write
Integer32
同MIB标准取值
此AP射频的beacon管理帧的间隔
实现与MIB文件定义一致
hh3cDot11RadioCfgDtimIntvl (1.3.6.1.4.1.25506.2.75.4.4.1.1.3)
read-write
Integer32
同MIB标准取值
实现与MIB文件定义一致
hh3cDot11RadioCfgRtsThreshold (1.3.6.1.4.1.25506.2.75.4.4.1.1.4)
read-write
Integer32
同MIB标准取值
此AP射频MAC协议数据单元(MPDU)的当前最小大小(以八位字节为单位),低于该最小大小将不执行请求发送/清除发送(RTS/CTS)握手
实现与MIB文件定义一致
hh3cDot11RadioCfgFragThreshold (1.3.6.1.4.1.25506.2.75.4.4.1.1.5)
read-write
Integer32
同MIB标准取值
此AP射频当前可传递到PHY的MPDU的最大大小(以八位字节为单位)。如果在添加MAC报头和尾部后MSDU的大小超过此属性的值,则MSDU应被拆分为片段
实现与MIB文件定义一致
hh3cDot11RadioCfgShtRetryThld (1.3.6.1.4.1.25506.2.75.4.4.1.1.6)
read-write
Integer32
同MIB标准取值
此AP射频帧得最大传输次数,该帧的长度小于或等于hh3cDot11RadioRTSThreshold,在指示故障条件之前应进行传输尝试
实现与MIB文件定义一致
hh3cDot11RadioCfglongRtrThld (1.3.6.1.4.1.25506.2.75.4.4.1.1.7)
read-write
Integer32
同MIB标准取值
此AP射频帧得最大传输次数,该帧的长度大于hh3cDot11RadioRTSThreshold,在指示故障条件之前应进行传输尝试
实现与MIB文件定义一致
hh3cDot11RadioCfgMaxRxLifetime (1.3.6.1.4.1.25506.2.75.4.4.1.1.8)
read-write
Unsigned32
同MIB标准取值
此AP射频的接收经过的时间,在hh3cDot11RadioCfgMaxRxLifetime指定的时间之后,应终止重新组装MSDU的进一步尝试
实现与MIB文件定义一致
hh3cDot11RadioCfgType (1.3.6.1.4.1.25506.2.75.4.4.1.1.9)
read-write
Hh3cDot11RadioType
dot11a(1),
dot11b(2),
dot11g(4),
dot11n(8),
dot11gn(16),
dot11an(32),
dot11ac(64),
dot11gac(128),
dot11ax(256),
dot11gax(512)
此AP射频使用的802.11射频类型
实现与MIB文件定义一致
hh3cDot11RadioCfgChannel (1.3.6.1.4.1.25506.2.75.4.4.1.1.10)
read-write
Integer32同MIB标准取值
此AP射频的信道分配
实现与MIB文件定义一致
hh3cDot11RadioCfgMaxTxPwrLvl (1.3.6.1.4.1.25506.2.75.4.4.1.1.11)
read-write
Integer32同MIB标准取值
此AP射频的最大发射功率范围
实现与MIB文件定义一致
hh3cDot11RadioCfgPreambleLen (1.3.6.1.4.1.25506.2.75.4.4.1.1.12)
read-write
long (1),
short (2)
此AP射频的802.11MAC帧使用的前导码类型(长/短)
实现与MIB文件定义一致
hh3cDot11RadioCfgWorkMode (1.3.6.1.4.1.25506.2.75.4.4.1.1.13)
read-write
Hh3cDot11WorkMode
normal (1),
monitor (2),
hybrid (3)
此AP射频的工作模式
实现与MIB文件定义一致
hh3cDot11RadioCfgOnly11gEnable (1.3.6.1.4.1.25506.2.75.4.4.1.1.14)
read-write
TruthValue
true(1),
false(2)
此AP射频的是否仅启用802.11g无线模式:
“true”:仅启用802.11g无线电模式
“false”:仅禁用802.11g无线模式
实现与MIB文件定义一致
hh3cDot11RadioCfgType2 (1.3.6.1.4.1.25506.2.75.4.3.8.1.2)
read-write
Hh3cDot11RadioType2
dot11a(1),
dot11b(2),
dot11g(4),
dot11an(8),
dot11gn(16),
dot11ac(32),
dot11gac(64),
dot11ax(128),
dot11gax(256)
此AP射频使用的802.11射频类型
实现与MIB文件定义一致
hh3cDot11RadioCfgRssithresholdCM (1.3.6.1.4.1.25506.2.75.4.3.8.1.2)
read-write
Integer32
同MIB标准取值
实现与MIB文件定义一致
【功能描述】
该表定义了AP中每个无线射频的绑定信息。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
不支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11RadioIfIdx,hh3cDot11RadioIntfBindSvcPlcyID。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11RadioIntfBindSvcPlcyID (1.3.6.1.4.1.25506.2.75.4.4.2.1.1)
not-accessible
同MIB标准取值
表示每个服务策略的ID
实现与MIB文件定义一致
hh3cDot11RadioIntfBindIfIdx (1.3.6.1.4.1.25506.2.75.4.4.2.1.2)
read-create
Unsigned32
同MIB标准取值
表示绑定到无线射频的接口的Ifindex
实现与MIB文件定义一致
hh3cDot11RadioIntfBindRowStatus (1.3.6.1.4.1.25506.2.75.4.4.2.1.3)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWati(5),
destroy(6)
该表项的状态
实现与MIB文件定义一致
【功能描述】
该表用于配置WLAN ESS接口。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
不支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11WlanEssIfNumber。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11WlanEssIfNumber (1.3.6.1.4.1.25506.2.75.4.6.1.1.1)
not-accessible
Integer32
同MIB标准取值
表示WLAN ESS接口号
不支持
hh3cDot11WlanEssIfIndex (1.3.6.1.4.1.25506.2.75.4.6.1.1.2)
read-only
Integer32
同MIB标准取值
该节点表示WLAN-ESS接口的ifIndex
不支持
【功能描述】
该表用于配置WLAN BSS接口。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
不支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11WlanBssIfNumber。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11WlanBssIfIndex (1.3.6.1.4.1.25506.2.75.4.6.2.1.2)
read-only
Integer32
同MIB标准取值
表示WLAN-BSS接口的ifIndex
不支持
hh3cDot11WlanBssRowStatus (1.3.6.1.4.1.25506.2.75.4.6.2.1.3)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4)
表示WLAN BSS接口行状态
不支持
【功能描述】
该表用来实现WLAN以太网接口配置。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
不支持
支持
支持
【表节点信息】
该表的索引节点是hh3cDot11WlanEthernetIfNumber。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11WlanEthernetIfNumber (1.3.6.1.4.1.25506.2.75.4.6.3.1.1)
not-accessible
Integer32
同MIB标准取值
此WLAN以太网接口的编号
实现与MIB文件定义一致
hh3cDot11WlanEthernetIfNumber (1.3.6.1.4.1.25506.2.75.4.6.3.1.2)
read-only
Integer32
同MIB标准取值
此WLAN以太网接口的索引
实现与MIB文件定义一致
hh3cDot11WlanEthernetRowStatus (1.3.6.1.4.1.25506.2.75.4.6.3.1.3)
read- create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
此WLAN以太网接口的行状态
实现与MIB文件定义一致
【功能描述】
该表定义了绑定加密服务模板的ESS、BSS、mesh和WLAN- ethernet接口的WLAN安全状态。否则,在绑定clear service-template时,应该使用hh3cPortSecurityTables配置端口安全。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
不支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11PortSecurityMode。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11SecurityUserLoginTxKeyType (1.3.6.1.4.1.25506.2.75.4.6.4.1.2)
read-write
INTEGER
802.1X EAPOL_Key报文中的密钥类型。userLoginTxKeyTypeNone -这意味着密钥类型尚未设置。userLoginTxKeyTypeDot11Key -选择802.11密钥类型。userLoginTxKeyTypeRsaRC4Key -为RSA RC4会话加密选择RC4密钥
不支持
hh3cDot11SecurityPskKeyMode (1.3.6.1.4.1.25506.2.75.4.6.4.1.3)
read-write
INTEGER
pskKeyModeNone(1),
pskKeyModeRawKey(3)
这是密码输入方式。
不支持
hh3cDot11SecurityPskKeyString (1.3.6.1.4.1.25506.2.75.4.6.4.1.4)
read-write
DisplayString
DisplayString(0..64)
psk认证的密码字符串
不支持
【功能描述】
该表用来实现射频上dot11n的配置。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11nRadioCfgIndex。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11nRadioCfgIndex (1.3.6.1.4.1.25506.2.75.4.8.1.1.1)
not-accessible
Hh3cDot11RadioElementIndex
Unsigned32同MIB标准取值
此AP射频索引。其包含两部分:最低8位表示射频ID,中间8表示APID,最高8位保留
实现与MIB文件定义一致
hh3cDot11nAMpduEnable (1.3.6.1.4.1.25506.2.75.4.8.1.1.2)
read-write
TruthValue
true(1),
false(2)
此AP射频是否启用A-MPDU功能
实现与MIB文件定义一致
hh3cDot11nAMsduEnable (1.3.6.1.4.1.25506.2.75.4.8.1.1.3)
read-write
TruthValue
true(1),
false(2)
此AP射频是否启用A-MSDU功能
实现与MIB文件定义一致
hh3cDot11nClientDot11nOnly (1.3.6.1.4.1.25506.2.75.4.8.1.1.4)
read-write
TruthValue
true(1),
false(2)
此AP射频射频类型为802.11an或802.11gn,则仅允许终端协商为11n模式;如果射频类型为802.11ac,则允许终端协商为11n和11ac模式
实现与MIB文件定义一致
hh3cDot11nChanelBand (1.3.6.1.4.1.25506.2.75.4.8.1.1.5)
read- write
INTEGER
mode20 (1),
mode40 (2),
mode80 (3),
mode160 (4),
mode80and80 (5)
此AP射频的指定带宽模式
实现与MIB文件定义一致
hh3cDot11nShortGiEnable (1.3.6.1.4.1.25506.2.75.4.8.1.1.6)
read-write
TruthValue
true(1),
false(2)
此AP射频是否开启缩短两数据的传输间隔
实现与MIB文件定义一致
hh3cDot11nClientDot11acOnly (1.3.6.1.4.1.25506.2.75.4.8.1.1.7)
read-write
TruthValue
true(1),
false(2)
此AP射频是否开启仅允许协商11ac模式的终端
实现与MIB文件定义一致
hh3cDot11nSupportMaxMcs (1.3.6.1.4.1.25506.2.75.4.8.1.1.8)
read-write
Integer32
Integer32 (0..76)
此AP射频指定的802.11n支持速率的最大调制和编码方案(MCS)索引。802.11n支持速率的指定最大MCS索引必须不小于802.11n强制速率的指定的最大MCS索引
不支持
hh3cDot11nMandatoryMaxMcs (1.3.6.1.4.1.25506.2.75.4.8.1.1.9)
read-write
Integer32
Integer32 (0..76 | 255)
此AP射频指定的802.11n强制速率的最大调制和编码方案(MCS)索引。该值为255表示未指定最大MCS索引。默认情况下,没有为802.11n强制速率指定最大MCS索引。除了255之外,为802.11n支持的速率指定的最大MCS索引必须不小于为802.11n强制性速率指定的最小MCS索引
不支持
【功能描述】
该表用来实现射频上dot11n的配置。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11nRadioCfg2APIDIndex, hh3cDot11nRadioCfg2APIDIndex。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11nRadioCfg2APIDIndex (1.3.6.1.4.1.25506.2.75.4.8.3.1.1)
not-accessible
此AP的索引
实现与MIB文件定义一致
hh3cDot11nRadioCfg2RadioIDIndex (1.3.6.1.4.1.25506.2.75.4.8.3.1.2)
not-accessible
Integer32同MIB标准取值
此AP射频的索引
实现与MIB文件定义一致
hh3cDot11nRadioCfg2AMpduEnable (1.3.6.1.4.1.25506.2.75.4.8.3.1.3)
read-write
TruthValue
true(1),
false(2)
此AP射频是否启用A-MPDU功能
实现与MIB文件定义一致
hh3cDot11nRadioCfg2AMsduEnable (1.3.6.1.4.1.25506.2.75.4.8.3.1.4)
read-write
TruthValue
true(1),
false(2)
此AP射频是否启用A-MSDU功能
实现与MIB文件定义一致
hh3cDot11nRadioCfg2ClientDot11nOnly (1.3.6.1.4.1.25506.2.75.4.8.3.1.5)
read-write
TruthValue
true(1),
false(2)
实现与MIB文件定义一致
hh3cDot11nRadioCfg2ChannelBand (1.3.6.1.4.1.25506.2.75.4.8.3.1.6)
read- write
INTEGER
mode20 (1),
mode40 (2),
mode80 (3),
mode160 (4),
mode80and80 (5)
此AP射频的指定带宽模式
实现与MIB文件定义一致
hh3cDot11nRadioCfg2ShortGiEnable (1.3.6.1.4.1.25506.2.75.4.8.3.1.7)
read-write
TruthValue
true(1),
false(2)
此AP射频是否开启缩短两数据的传输间隔
实现与MIB文件定义一致
hh3cDot11nRadioCfg2AMpduEnableCM (1.3.6.1.4.1.25506.2.75.4.8.3.1.8)
read-write
INTEGER
off (0),
on (1)
此AP射频是否启用A-MPDU功能
实现与MIB文件定义一致
hh3cDot11nRadioCfg2ChannelBandCM (1.3.6.1.4.1.25506.2.75.4.8.3.1.9)
read- write
INTEGER
mode20 (1),
mode40 (2),
mode80 (3),
mode160 (4),
mode80and80 (5)
此AP射频的指定带宽模式
实现与MIB文件定义一致
hh3cDot11nRadioCfg2ShortGiEnableCM (1.3.6.1.4.1.25506.2.75.4.8.3.1.10)
read-write
INTEGER
off (0),
on (1)
此AP射频是否开启缩短两数据的传输间隔
实现与MIB文件定义一致
hh3cDot11nRadioCfg2ClientDot11acOnly (1.3.6.1.4.1.25506.2.75.4.8.3.1.11)
read-write
TruthValue
true(1),
false(2)
实现与MIB文件定义一致
hh3cDot11nRadioCfg2ClientDot11nOnlyCM (1.3.6.1.4.1.25506.2.75.4.8.3.1.12)
read-write
dot11false (0),
dot11true (1)
实现与MIB文件定义一致
hh3cDot11nRadioCfg2SupportMaxMcs (1.3.6.1.4.1.25506.2.75.4.8.3.1.13)
read-write
Integer32
Integer32 (0..76)
不支持
hh3cDot11nRadioCfg2MandatoryMaxMcs (1.3.6.1.4.1.25506.2.75.4.8.3.1.14)
read-write
Integer32
不支持
【功能描述】
该表用来实现管理员便捷地配置local AC参数的功能。在local AC启动并通过CAPWAP隧道连接到central AC之前,管理员将给每个local AC创建一个local AC模板。当local AC连接到central AC时,AC将通过local AC模板中的local AC序列号将配置信息下发到local AC。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
支持
不支持
支持
支持
【表节点信息】
该表的索引节点是hh3cDot11LocalACTemplateName。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11LocalACTemplateName (1.3.6.1.4.1.25506.2.75.4.10.1.1.1)
not-accessible
OCTET STRING
表示local AC模板名称
实现与MIB文件定义一致
hh3cDot11LocalACName (1.3.6.1.4.1.25506.2.75.4.10.1.1.2)
read-create
OCTET STRING
同MIB标准取值
表示local AC名称
实现与MIB文件定义一致
hh3cDot11LocalACSerialID (1.3.6.1.4.1.25506.2.75.4.10.1.1.3)
read-create
OCTET STRING
同MIB标准取值
表示local AC序列号
实现与MIB文件定义一致
hh3cDot11TemLocalACModelAlias (1.3.6.1.4.1.25506.2.75.4.10.1.1.4)
read-create
OCTET STRING
同MIB标准取值
表示local AC型号名称
实现与MIB文件定义一致
hh3cDot11LocalACTempRowStatus (1.3.6.1.4.1.25506.2.75.4.10.1.1.5)
read-create
RowStatus
INTEGER {
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
表示local AC模板表行状态
实现与MIB文件定义一致
hh3cDot11LocalACStatus
(1.3.6.1.4.1.25506.2.75.4.10.1.1.6)
read-only
INTEGER
join(1)
joinConfirm(2)
download(3)
config(4)
run(5)
idle(6)
表示local AC的CAPWAP状态。
join:local AC正在加入central AC;
joinConfirm:central AC确认是否允许local AC加入;
download:local AC正在下载版本;
run:local AC上线;
idle:local AC不在线。
实现与MIB文件定义一致
hh3cDot11LocalACIPAddress (1.3.6.1.4.1.25506.2.75.4.10.1.1.7)
read-only
IpAddress
同MIB标准取值
表示local AC的IP地址
实现与MIB文件定义一致
hh3cDot11LocalACIPv6Address (1.3.6.1.4.1.25506.2.75.4.10.1.1.8)
read-only
OCTET STRING
同MIB标准取值
表示local AC的IPv6地址
实现与MIB文件定义一致
hh3cDot11EchoInterval (1.3.6.1.4.1.25506.2.75.4.10.1.1.9)
read-create
Integer32
Integer32(0 | 5..255)
表示心跳保活报文间隔,默认是10
实现与MIB文件定义一致
hh3cDot11EchoInterval (1.3.6.1.4.1.25506.2.75.4.10.1.1.10)
read-create
Integer32
Integer32(3..8)
表示重传间隔,默认是5
实现与MIB文件定义一致
hh3cDot11RetransCount (1.3.6.1.4.1.25506.2.75.4.10.1.1.11)
read-create
Integer32
Integer32(2..5)
表示最大重传次数,默认是3
实现与MIB文件定义一致
hh3cDot11FirmwareUpgrade (1.3.6.1.4.1.25506.2.75.4.10.1.1.12)
read-create
INTEGER
enable(1)
disable(2)
表示local AC版本升级开关状态
实现与MIB文件定义一致
【功能描述】
该表用来实现AP上各接口的配置。
【操作支持情况】
创建约束
修改约束
删除约束
读取约束
不支持
支持
不支持
支持
【表节点信息】
该表的索引节点是hh3cDot11RmtIfApName, hh3cDot11RmtIfType, hh3cDot11RmtIfNum。
节点名称及OID
最大访问权限
数据类型
有效范围
含义
实现规格
hh3cDot11RmtIfApName (1.3.6.1.4.1.25506.2.75.4.11.2.1.1)
not-accessible
OCTET STRING
OCTET STRING(1..127)
此AP的名称
实现与MIB文件定义一致
hh3cDot11RmtIfType (1.3.6.1.4.1.25506.2.75.4.11.2.1.2)
not-accessible
Integer32
ethernet (1),
gigabitethernet (2),
ten-gigabitethernet (3),
smartrate-ethernet (4)
此AP接口的类型
实现与MIB文件定义一致
hh3cDot11RmtIfNum (1.3.6.1.4.1.25506.2.75.4.11.2.1.3)
not-accessible
Integer32
同MIB标准取值
此AP接口的ID
实现与MIB文件定义一致
hh3cDot11RmtIfName (1.3.6.1.4.1.25506.2.75.4.11.2.1.4)
read-only
OCTET STRING
同MIB标准取值
此AP接口的名称
实现与MIB文件定义一致
hh3cDot11RmtIfLinkType (1.3.6.1.4.1.25506.2.75.4.11.2.1.5)
read-write
INTEGER
access (1),
trunk (2),
hybrid (3)
此AP接口链接类型设置为访问、混合或中继。设置建议使用一个或多个相关节点。
实现与MIB文件定义一致
hh3cDot11RmtIfAccessVlan (1.3.6.1.4.1.25506.2.75.4.11.2.1.6)
read-write
Integer32
同MIB标准取值
此AP接口指定访问VLAN的端口
实现与MIB文件定义一致
hh3cDot11RmtIfTrunkPvidVlan (1.3.6.1.4.1.25506.2.75.4.11.2.1.7)
read-write
Integer32
同MIB标准取值
此AP接口指定访问VLAN的默认端口
实现与MIB文件定义一致
hh3cDot11RmtIfTrunkVlanlist (1.3.6.1.4.1.25506.2.75.4.11.2.1.8)
read- write
OCTET STRING
同MIB标准取值
此AP接口允许访问的指定VLAN列表
实现与MIB文件定义一致
hh3cDot11RmtIfHybridPvidVlan (1.3.6.1.4.1.25506.2.75.4.11.2.1.9)
read-write
Integer32
同MIB标准取值
为AP混合接口指定的默认VLAN
实现与MIB文件定义一致
hh3cDot11RmtIfHybVlanListTag (1.3.6.1.4.1.25506.2.75.4.11.2.1.10)
read- write
OCTET STRING
同MIB标准取值
为混合端口分配已标记的VLAN
实现与MIB文件定义一致
hh3cDot11RmtIfHybVlanListUnTag (1.3.6.1.4.1.25506.2.75.4.11.2.1.11)
read- write
OCTET STRING
同MIB标准取值
为混合端口分配未标记的VLAN
实现与MIB文件定义一致
hh3cDot11RmtIfIsolate (1.3.6.1.4.1.25506.2.75.4.11.2.1.12)
read-write
TruthValue
true(1),
false(2)
此AP接口启用/禁用端口隔离
实现与MIB文件定义一致
hh3cDot11RmtIfLinkAggGroupId (1.3.6.1.4.1.25506.2.75.4.11.2.1.13)
read-write
Integer32
同MIB标准取值
此AP接口的链接聚合组号
实现与MIB文件定义一致
hh3cDot11RmtIfManagement (1.3.6.1.4.1.25506.2.75.4.11.2.1.14)
read-write
TruthValue
true(1),
false(2)
此AP接口是否启用接口管理
实现与MIB文件定义一致
告警信息
本节介绍HH3C-DOT11-CFG-MIB模块输出的告警信息。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.75.4.9.0.1
无线服务加密类型变化告警
事件告警
警告
关闭
【触发原因】
当系统的无线服务下面设置的加密算法发生变化时,系统发送该告警
【系统影响】
对系统无影响
【状态控制】
开启
命令行:snmp-agent trap enable  wlan usersec
关闭
命令行:undo snmp-agent trap enable  wlan usersec
【绑定变量】
OID (变量名)
含义
索引节点
类型
取值范围
1.3.6.1.4.1.25506.2.75.4.2.2.1.2 (hh3cDot11SSIDName)
SSID
1.3.6.1.4.1.25506.2.75.4.2.3.1.3 (hh3cDot11SecurityCiphers)
加密套件
Integer32
同MIB标准取值
【处理建议】
无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.75.4.9.0.2
无线服务PSK密钥变化告警
事件告警
警告
关闭
【触发原因】
当系统的无线服务使用PSK加密和认证方式时,如果下面设置的PSK密钥发生变化,系统发送该告警
【系统影响】
对系统无影响
【状态控制】
开启
关闭
【绑定变量】
OID (变量名)
含义
索引节点
类型
取值范围
SSID
【处理建议】
无需处理。
【属性】
OID
告警标题
类型
级别
清除告警
缺省状态
1.3.6.1.4.1.25506.2.75.4.9.0.3
AP的WEP密钥配置冲突告警
事件告警
警告
关闭
【触发原因】
当一个AP的两个服务配置了相同ID的WEP密钥造成冲突时,会触发该告警。
【系统影响】
对系统无影响
【状态控制】
开启
关闭
【绑定变量】
OID (变量名)
含义
索引节点
类型
取值范围
1.3.6.1.4.1.25506.2.75.4.9.1.1 (hh3cDot11PreConflictTemplateNum)
Integer32
Integer32 (1..1024)
1.3.6.1.4.1.25506.2.75.4.9.1.2 (hh3cDot11CurrConflictTemplateNum)
Integer32
Integer32 (1..1024)
1.3.6.1.4.1.25506.2.75.4.9.1.3 (hh3cDot11ConflictCipherIdx)
表示与之冲突的wep ID
Integer32
Integer32 (1..4)
1.3.6.1.4.1.25506.2.75.4.9.1.4 (hh3cDot11ConfigureAPID)
表示配置的AP
1.3.6.1.4.1.25506.2.75.4.9.1.5 (hh3cDot11ConfigureRadioID)
表示AP中配置的无线射频
同MIB标准取值
1.3.6.1.4.1.25506.2.75.4.9.1.6 (hh3cDot11ConfigureAPMacAddress)
表示AP的MAC地址
MacAddress
MacAddress(6)
1.3.6.1.4.1.25506.2.75.4.9.1.7 (hh3cDot11PreConflictTemplateSSID)
表示AP的前一个SSID
同MIB标准取值
1.3.6.1.4.1.25506.2.75.4.9.1.8 (hh3cDot11CurrConflictTemplateSSID)
表示AP的当前SSID
同MIB标准取值
【处理建议】
无需处理。
