13-EVPN命令参考
01-EVPN命令
本章节下载 01-EVPN命令  (690.95 KB)
01-EVPN命令
  录
1 EVPN
1.1 EVPN配置命令
1.1.1 address-family evpn (public instance view)
1.1.2 address-family evpn (VPN instance view)
1.1.3 address-family ipv4 (public instance view)
1.1.4 address-family l2vpn evpn (BGP instance view)
1.1.5 advertise l2vpn evpn
1.1.6 arp mac-learning disable
1.1.7 arp proxy-send enable
1.1.8 bestroute ipv6-nexthop
1.1.9 display bgp l2vpn evpn
1.1.10 display bgp l2vpn evpn inlabel
1.1.11 display evpn auto-discovery
1.1.12 display evpn es
1.1.13 display evpn instance
1.1.14 display evpn ipv6 auto-discovery
1.1.15 display evpn route arp
1.1.16 display evpn route arp suppression
1.1.17 display evpn route arp-mobility
1.1.18 display evpn route mac
1.1.19 display evpn route mac-mobility
1.1.20 display evpn route nd
1.1.21 display evpn route nd suppression
1.1.22 display evpn route xconnect-group
1.1.23 display evpn routing-table
1.1.24 display l2vpn forwarding evpn
1.1.25 display l2vpn forwarding evpn split-horizon
1.1.26 evpn encapsulation
1.1.27 evpn encapsulation binding instance
1.1.28 evpn global-mac
1.1.29 evpn df-election algorithm (interface view)
1.1.30 evpn df-election algorithm (system view)
1.1.31 evpn df-election preference
1.1.32 evpn df-election preference non-revertive
1.1.33 evpn frr remote
1.1.34 evpn instance
1.1.35 evpn irb asymmetric
1.1.36 evpn mac-ip advertise distributed-gateway
1.1.37 evpn mpls routing-enable
1.1.38 evpn multihoming advertise ignore-ethernet-tag
1.1.39 evpn route arp-mobility suppression
1.1.40 evpn route mac-mobility suppression
1.1.41 evpn span-segment disable
1.1.42 evpn timer ad-delay
1.1.43 evpn timer es-delay
1.1.44 evpn track bfd
1.1.45 evpn track peer
1.1.46 export route-policy
1.1.47 ignore-ac-state
1.1.48 igp-metric inherit
1.1.49 import evpn mac-ip
1.1.50 import route-policy
1.1.51 ip public-instance
1.1.52 l2vpn ignore-ac-state
1.1.53 l3-vni
1.1.54 mac-advertising disable
1.1.55 nd mac-learning disable
1.1.56 peer advertise encap-type mpls
1.1.57 peer advertise vpn-reoriginate ibgp (BGP EVPN address family view)
1.1.58 peer default-gateway no-advertise
1.1.59 peer re-originated
1.1.60 peer re-originated mac
1.1.61 peer suppress original-route
1.1.62 ping evpn vpws
1.1.63 ping evpn vsi
1.1.64 policy vpn-target
1.1.65 reset evpn route arp-mobility suppression
1.1.66 reset evpn route mac-mobility suppression
1.1.67 route-distinguisher
1.1.68 rr-filter
1.1.69 tracert evpn vpws
1.1.70 tracert evpn vsi
1.1.71 vpn-route cross multipath
1.1.72 vpn-target
1 EVPN
设备不支持VXLAN数据中心互联组网、EVPN数据中心互联组网。
1.1  EVPN配置命令
address-family evpn命令用来进入公网实例EVPN视图。
undo address-family evpn命令用来删除公网实例EVPN视图下的所有配置。
address-family evpn
公网实例视图
在公网实例EVPN视图下可以配置EVPN的参数,如EVPN的RT属性、应用的出方向路由策略等。
# 进入公网实例EVPN视图。
[Sysname] ip public-instance
[Sysname-public-instance] address-family evpn
[Sysname-public-instance-evpn]
address-family evpn命令用来进入VPN实例EVPN视图。
undo address-family evpn命令用来删除VPN实例EVPN视图下的所有配置。
address-family evpn
VPN实例视图
在VPN实例EVPN视图下可以配置EVPN的参数,如EVPN的RT属性、应用的出方向路由策略等。
# 进入VPN实例EVPN视图。
[Sysname] ip vpn-instance tenant
[Sysname-vpn-instance-tenant] address-family evpn
[Sysname-vpn-evpn-tenant]
address-family ipv4命令用来进入公网实例IPv4地址族视图。
undo address-family ipv4命令用来删除公网实例IPv4地址族视图下的所有配置。
address-family ipv4
公网实例视图
# 进入公网实例IPv4地址族视图。
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4]
address-family l2vpn evpn命令用来创建BGP EVPN地址族,并进入BGP EVPN地址族视图。如果BGP EVPN地址族已经存在,直接进入BGP EVPN地址族视图。
undo address-family l2vpn evpn命令用来删除BGP EVPN地址族,及相应地址族视图下的所有配置。
不存在BGP EVPN地址族。
BGP实例视图
BGP EVPN地址族视图下的配置,只对公网BGP EVPN地址族的路由和对等体生效。
# 创建BGP EVPN地址族,并进入BGP EVPN地址族视图。
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn]
advertise l2vpn evpn命令用来配置允许对外发布 BGP EVPN路由。
undo advertise l2vpn evpn命令用来禁止对外发布 BGP EVPN路由。
允许对外发布BGP EVPN路由。
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
配置允许对外发布 BGP EVPN路由后,设备接收到BGP EVPN路由,并将其添加到某个VPN实例路由表后,会将该路由(私网路由)发布到本地站点。
# 配置允许BGP VPN实例vpn1对外发布BGP EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] advertise l2vpn evpn
arp mac-learning disable命令用来配置禁止EVPN从ARP信息中学习MAC地址表项。
undo arp mac-learning disable命令用来恢复缺省情况。
EVPN可以从ARP信息中学习MAC地址表项。
EVPN实例视图
VSI实例下的EVPN实例视图
本端VTEP或PE可能会同时接收到远端设备通告的MAC地址信息和ARP信息。其中,ARP信息中包含MAC地址信息。为了避免重复,可以在本端设备上执行本命令禁止EVPN从ARP信息中学习MAC地址表项,EVPN仅通过MAC地址信息学习远端MAC地址表项。
# 配置禁止EVPN从ARP信息中学习MAC地址表项。
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan] arp mac-learning disable
arp proxy-send enable命令用来开启ARP请求代理发送功能。
undo arp proxy-send enable命令用来关闭ARP请求代理发送功能。
ARP请求代理发送功能处于关闭状态。
VSI虚接口视图
EVPN VXLAN组网中,VM 1连接VTEP 1,VM 2连接VTEP 2,VM 1和VM 2属于同一网段。VTEP 1和VTEP 2分别配置VSI虚接口作为VM 1和VM 2的网关,VTEP 1和VTEP 2均配置如下功能:
·     VTEP 1和VTEP 2建立BGP EVPN邻居
·     禁止EVPN从ARP信息中学习MAC地址表项
·     禁止通告MAC地址信息,并撤销已经通告的MAC地址信息
·     关闭远端MAC地址自动学习功能
·     VSI虚接口开启本地代理ARP功能
·     VTEP 1和VTEP 2的VSI虚接口的IP地址、MAC地址均不同
在该组网中,VM 1希望访问VM 2时,VM 1发送ARP请求报文,VTEP 1学习VM 1的MAC地址并代理应答VM 1的ARP请求报文。同时VTEP 1发送ARP请求报文请求VM 2的MAC地址。VM 2单播应答VTEP 1的ARP请求。VTEP 2不会从VM 2的ARP应答报文中学习VM 2的MAC地址,由于VTEP 1关闭了远端MAC地址自动学习功能,也不会学习VM 2的MAC地址,无法形成表项,导致VM 1无法访问VM 2。
为解决上述问题,可在VTEP 2上配置本命令,使VTEP 2收到VTEP 1的ARP请求报文时,生成以VSI虚接口IP地址为源的ARP请求,并同时广播两个ARP请求。VM 2分别应答VTEP 1和VTEP 2的ARP请求。VTEP 2从VM 2发给自己的ARP应答报文中学习VM 2的MAC地址,并通过EVPN路由发布给VTEP 1。VTEP 1和VTEP 2均获得VM 1和VM 2的MAC地址信息后,VM 1和VM 2可以互相访问。
# 在VSI虚接口100上开启ARP代理发送请求功能。
[Sysname] interface vsi-interface 100
[Sysname-vsi-interface100] arp proxy-send enable
·     local-proxy-arp enable(三层技术-IP业务命令参考/代理ARP)
bestroute ipv6-nexthop命令用来配置BGP选择最优路由时,优选下一跳地址为IPv6地址的路由。
undo bestroute ipv6-nexthop命令用来恢复缺省情况。
BGP选择最优路由时,优选下一跳地址为IPv4地址的路由。
BGP EVPN地址族视图
在EVPN组网中,Underlay网络可能由IPv4网络和IPv6网络共同组成。当网络中同时存在下一跳为IPv4地址和IPv6地址的多条路由时,BGP会优先选择下一跳地址为IPv4地址的路由,使得VXLAN报文优先通过IPv4 Underlay网络转发。若想优先通过IPv6 Underlay网络转发VXLAN报文,则可以执行本命令,配置BGP优选下一跳地址为IPv6地址的路由。
# 在BGP EVPN地址族视图下,配置路由优选时优先选择下一跳地址为IPv6地址的路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] bestroute ipv6-nexthop
display bgp l2vpn evpn命令用来显示BGP EVPN路由信息。
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ statistics ] | [ route-distinguisher route-distinguisher | route-type { auto-discovery | es | igmp-js | igmp-ls | imet | ip-prefix | mac-ip | smet } ] * [ { evpn-route route-length | evpn-prefix } [ advertise-info | as-path | cluster-list | community | ext-community ] | ipv4-address | ipv6-address | mac-address ] | statistics ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] community-list { basic-community-list-number | comm-list-name | adv-community-list-number } [ whole-match ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] ext-community [ bandwidth link-bandwidth-value | rt route-target | soo site-of-origin | color color ]&<1-32> [ whole-match ]
peer { ipv4-address | ipv6-address }:显示向指定对等体发布或者从指定对等体收到的BGP EVPN路由。ipv4-address表示对等体的IPv4地址;ipv6-address为对等体的IPv6地址。
advertised-routes:显示向指定对等体发布的BGP EVPN路由信息。
received-routes:显示从指定对等体接收到的BGP EVPN路由信息。
statistics:显示BGP EVPN路由的统计信息。
route-distinguisher route-distinguisher:显示指定路由标识符的BGP EVPN路由信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
route-type:显示指定类型的BGP EVPN路由。
auto-discovery:显示以太网自动发现路由(Ethernet auto-discovery route)。
es:显示以太网段路由(Ethernet segment route)。
igmp-js:显示IGMP加入同步路由(IGMP join synch route)。
igmp-ls:显示IGMP离开同步路由(IGMP leave synch route)。
imet:显示包含性组播以太网标签路由(Inclusive multicast Ethernet tag route),
ip-prefix:显示IP前缀路由(IP prefix advertisement route)。
mac-ip:显示MAC/IP发布路由(MAC/IP advertisement route)。
smet:显示选择性组播以太网标签路由(Selective multicast Ethernet tag route)。
evpn-route:显示指定BGP EVPN路由的详细信息。evpn-route表示EVPN路由信息,为1~512个字符的字符串。
route-length:BGP EVPN路由信息的长度,取值范围为0~65535,单位为比特。
evpn-prefix:显示指定BGP EVPN路由的详细信息。evpn-prefix包含EVPN路由信息和路由信息长度,组成格式为evpn-route/route-length,为1~512个字符的字符串,不区分大小写。
advertise-info:显示BGP EVPN路由的通告信息。
as-path:显示指定BGP EVPN路由的AS_PATH属性信息。
cluster-list:显示指定BGP EVPN路由的集群ID列表属性信息。
community:显示指定BGP EVPN路由的团体属性信息,或显示匹配指定团体号的BGP EVPN路由信息。
ext-community:显示BGP EVPN路由的扩展团体属性信息,或显示匹配指定扩展团体属性的BGP EVPN路由信息。
ipv4-address:显示包含指定IPv4地址的EVPN路由信息。
ipv6-address:显示包含指定IPv6地址的EVPN路由信息。
mac-address:显示包含指定MAC地址的MAC/IP发布路由信息。执行本命令时,如果指定了route-type参数,则只有指定路由类型为mac-ip时,才可以指定本参数。
aa:nn&<1-32>:团体号,aann的取值范围为0~65535。&<1-32>表示前面的参数可以输入1~32次。
internet:表示预定义的团体属性。缺省情况下,所有的路由都具有internet团体属性,可以被通告给所有的BGP对等体。
no-advertise:表示NO_ADVERTISE团体属性。具有此属性的路由在收到后,不能被通告给任何其他的BGP对等体。
no-export:表示NO_EXPORT团体属性。具有此属性的路由在收到后,不能被发布到本地AS之外。如果使用了联盟,则不能被发布到联盟之外,但可以发布给联盟中的其他子AS。
no-export-subconfed:表示NO_EXPORT_SUBCONFED团体属性。具有此属性的路由在收到后,不能被发布到本地AS之外,也不能发布到联盟中的其他子AS。
whole-match:精确匹配。如果指定了本参数,则只有路由的团体属性列表/团体号/扩展团体属性与指定的团体属性列表/团体号/扩展团体属性完全相同时,才显示该路由的信息;如果未指定本参数,则只要路由的团体属性列表/团体号/扩展团体属性中包含指定的团体属性列表/团体号/扩展团体属性,就显示该路由的信息。
communit-list:显示匹配指定BGP团体列表的BGP EVPN单播路由信息。
basic-community-list-number:基本团体列表号,取值范围为1~99。
comm-list-name:团体属性列表名,为1~63个字符的字符串,区分大小写。
adv-community-list-number:高级团体列表号,取值范围为100~199。
bandwidth link-bandwidth-value:链路带宽扩展团体属性,link-bandwidth-value为3~16个字符的字符串,形式为16位自治系统号:32位用户自定义数,例如:100:3。其中,自治系统号的取值范围为0~65535,用户自定义数的取值范围为0~4294967295。
color color:Color扩展团体属性,color为4~13个字符的字符串,形式为CO(Color-Only)标记位:color-value,例如:10:3。其中,CO标记位取值为二进制数00~11,color-value取值范围为0~4294967295。
rt route-target:RT(Route Target,路由目标)扩展团体属性,route-target为3~24个字符的字符串。
soo site-of-origin:SoO(Site of Origin,源站点)扩展团体属性,site-of-origin为3~24个字符的字符串。site-of-origin有五种形式:
·     16位自治系统号:32位用户自定义数,例如:101:3。其中,自治系统号取值范围为0~65535,用户自定义数取值范围为0~4294967295。
·     32位IP地址:16位用户自定义数,例如:192.168.122.15:1。其中,用户自定义数取值范围为0~65535。
·     32位自治系统号:16位用户自定义数,例如:70000:3。其中,自治系统号取值范围为65536~4294967295,用户自定义数取值范围为0~65535。
·     32位IP地址/IPv4地址掩码:16位用户自定义数。例如:192.168.122.15/24:1。
·     32位自治系统号的点分方式:16位用户自定义数。例如:65535.65535:1。
&<1-32>:表示前面的参数可以输入1~32次。
如果未指定任何参数,则显示所有BGP EVPN路由的简要信息。
不指定community-numberaa:nninternetno-advertiseno-exportno-export-subconfed参数时,显示携带任意团体属性的BGP路由信息,且此时指定的whole-match参数不生效。
不指定bandwidthcolorrtsoo参数时,显示携带任意扩展团体属性的BGP路由信息,且此时指定的whole-match参数不生效。
# 显示所有BGP EVPN路由的简要信息。
<Sysname> display bgp l2vpn evpn
 BGP local router ID is 1.1.1.9
               a – additional-path
 Total number of routes from all PEs: 6
 Route distinguisher: 100:1
 Total number of routes: 3
* >  [2][0][48][00aa.00bb.00cc][4][0.0.0.0]/136
                       10.1.1.2        0                   32768   ?
*  e                   10.1.1.1        0                   0       65410?
* >  [3][300][16][::ffff:1.1.1.1]/176
                       127.0.0.1       0                   32768   ?
 Route distinguisher: 200:1
 Total number of routes: 2
* >i [2][0][48][00aa.00cc.00dd][4][1.1.1.1]/136
                       3.3.3.9         0         100       0       ?
* >i [3][300][16][::ffff:2.2.2.2]/176
                       3.3.3.9         0         100       0       65420?
Route distinguisher of public instance: 1:15
Total number of routes: 1
* >e [2][0][48][0011.0022.0033][32][11.22.33.55]/136
                        30.30.1.2       0                     0       100i
# 显示所有具有团体属性的BGP EVPN路由信息。
<Sysname> display bgp l2vpn evpn community
               a – additional-path
     Network         NextHop         MED      LocPrf   PrefVal  Path/Ogn  Community
                     10.1.1.2        0                 32768   ?         <1:2>
*  e                 10.1.1.1        0                 0       65410?    <2:3>
                     127.0.0.1       0                 32768   ?         <3:4>
# 显示所有具有扩展团体属性的BGP EVPN路由信息。
<Sysname> display bgp l2vpn evpn ext-community
               a – additional-path
     Network         NextHop        MED      LocPrf   PrefVal  Path/Ogn  Ext-Community
                     10.1.1.2       0                 32768    ?        <RT 1:2>
*  e                 10.1.1.1       0                 0        65410?   <RT 2:3>
                     127.0.0.1      0                 32768    ?        <RT 3:4>
表1-1 display bgp l2vpn evpn命令简要显示信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     s - suppressed:聚合抑制路由
·     S - stale:过期路由
·     a - additional-path:Add-Path优选路由
Origin
路由信息的来源,取值包括:
·     i – IGP:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
·     e – EGP:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
·     ? - incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
来自所有PE设备的BGP EVPN路由总数
Route distinguisher
路由标识符
公网实例的路由标识符
路由标识符为指定值的BGP EVPN路由总数
Network
BGP EVPN路由/路由长度,例如,Network取值为[2][0][48][1485-247c-0506][32][10.1.2.20]/136时,[2][0][48][1485-247c-0506][32][10.1.2.20]为BGP EVPN路由,136表示该路由的长度为136比特
BGP EVPN路由取值包括:
·     [1][ESI][EthernetTagID]:
¡     1:表示以太网自动发现路由(Ethernet auto-discovery route)
¡     ESI:以太网段标识
¡     EthernetTagID:以太网标签
·     [2][EthernetTagID][MACLength][MAC][IPAddressLength][IPAddress]
¡     2:表示MAC/IP发布路由(MAC/IP advertisement route)
¡     MACLength:MAC地址长度
¡     MAC:MAC地址
¡     IPAddressLength:IP地址长度
¡     IPAddress:IP地址
·     [3][EthernetTagID][IPAddressLength][IPAddress]
¡     3:表示包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)
¡     IPAddress:始发路由器的IP地址
·     [4][ESI][IPAddressLength][IPAddress]
¡     4:表示以太网段路由(Ethernet segment route)
¡     ESI:以太网段标识
·     [5][EthernetTagID][IPAddressLength][IPAddress]
¡     5:表示IP前缀路由(IP prefix advertisement route)
·     [6][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP]
¡     6:表示选择性组播以太网标签路由(Selective multicast Ethernet tag route)
¡     Source Len:组播源IP地址长度,(*,G)情况下设置为0
¡     Source IP:IGMP成员报告的源IP地址,(*,G)情况下该字段不存在
¡     Group Len:组播组IP地址长度
¡     Group IP:IGMP成员报告的组IP地址
¡     Originator Len:始发路由器IP地址长度
¡     Originator IP:始发路由器IP地址
·     [7][ESI][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP]
¡     7:表示IGMP加入同步路由(IGMP join synch route)
¡     ESI:以太网标识段
·     [8][ESI][EthernetTagID] [Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP][ [LeaveGroup Synchronization]
¡     8:表示IGMP离开同步路由(IGMP leave synch route)
¡     ESI:以太网标识段
¡     LeaveGroup Synchronization:离开组播组的同步序列号值
NextHop
下一跳IP地址
MED
MED(Multi-Exit Discriminator,多出口区分)属性值
LocPrf
本地优先级
PrefVal
路由首选值
Path/Ogn
路由的AS路径(AS_PATH)属性和路由信息的来源(ORIGIN)属性
Community
团体属性
Ext-Community
扩展团体属性
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[1][00:01:02:03:04:05:06:07:08:09][5]/120的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [1][00:01:02:03:04:05:06:07:08:09][5] 120
 BGP local router ID: 172.16.250.133
 Local AS number: 100
 Route distinguisher: 1.1.1.1:100
 Paths:   1 available, 1 best
 BGP routing table information of [1][00:01:02:03:04:05:06:07:08:09][5]/120:
 Rely nexthop    : 10.1.1.2
 Original nexthop: 10.1.1.2
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN >, <ESI Label: Flag 0,
                   Label 1>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Ethernet auto-discovery route
 ESI             : 00:01:02:03:04:05:06:07:08:09
 Ethernet tag ID : 5
 MPLS label      : 10
表1-2 display bgp l2vpn evpn命令中Ethernet auto-discovery route详细显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
Paths
路由数信息
·     available:有效路由数目
·     best:最佳路由数目
From
发布该路由的BGP对等体的IP地址
Rely nexthop
路由迭代后的下一跳IP地址,如果没有迭代出下一跳地址,则显示为“not resolved”
Original nexthop
路由的原始下一跳地址,如果是从BGP更新消息中获得的路由,则该地址为接收到的消息中的下一跳IP地址
OutLabel
路由的出标签值
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     Encapsulation Type:封装类型
·     ESI Label:ESI标签
RxPathID
接收到的路由的Add-Path ID值
BGP EVPN地址族暂不支持本字段
TxPathID
发送的路由的Add-Path ID值
BGP EVPN地址族暂不支持本字段
AS-path
路由的AS路径(AS_PATH)属性,记录了此路由经过的所有AS,可以避免路由环路的出现
Origin
路由信息的来源,取值包括:
·     igp:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
·     egp:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的。
·     incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
·     localredist:从本地其他VPN实例或公网实例引入到当前VPN实例的路由
·     reoriginated:重生成路由
IP precedence
路由的IP优先级,取值范围为0~7,N/A表示无效值
QoS local ID
路由的Qos-Local-ID属性,取值范围为1~4095,N/A表示无效值
Traffic index
流量索引值,取值范围为1~64,N/A表示无效值
EVPN route type
BGP EVPN路由类型,取值为Ethernet auto-discovery route,表示以太网自动发现路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
MPLS label
MPLS标签,目前此字段无意义
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[2][5][48][0001-0203-0405][32][4.5.5.5]/136的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [2][5][48][0001-0203-0405][32][5.5.5.5] 136
 BGP routing table information of [2][5][48][0001-0203-0405][32][5.5.5.5]/136:
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <RT: 1:3>, <RT: 1:4>, <RT: 1:5>, <RT: 1:6>, <RT: 1:7
                   >, <Encapsulation Type: VXLAN>, <Router's Mac: 0006-0708-0910
                   >, <MAC Mobility: Flag 0, SeqNum 2>, <Default GateWay>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : MAC/IP advertisement route
 Ethernet tag ID : 5
 MAC address     : 0001-0203-0405
 IP address      : 5.5.5.5/32
 MPLS label1     : 10
 MPLS label2     : 0
 Re-origination  : Enable
 Route distinguisher: 2.2.2.2:100
 OutLabel        : 0
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 State           : valid, external, best, reoriginated, remoteredist
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 ESI             : 0001.0203.0405.0607.0809
 Ethernet tag ID : 5
 MPLS label1     : 200
 MPLS label2     : 300
表1-3 display bgp l2vpn evpn命令中MAC/IP advertisement route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     Router's Mac:路由器MAC
·     MAC Mobility:MAC迁移属性。Flags表示是否为固定MAC地址,1为固定不可移动MAC,0为可以移动MAC;SeqNum用来标识最新的一次迁移
·     Default GateWay:默认网关路由
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
·     remoteredist:远端路由生成的MAC/IP发布路由
EVPN route type
BGP EVPN路由类型,取值为MAC/IP advertisement route,表示MAC/IP发布路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
MAC address
MAC地址
IP address
IP地址
MPLS label1
用于二层转发的VXLAN ID
MPLS label2
用于三层转发的VXLAN ID,即L3VNI
Re-origination
是否开启了修改路由信息的功能,取值包括:
·     Enable:开启修改路由信息功能
·     Disable:关闭修改路由信息功能
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[3][0][32][5.5.5.5]/80的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [3][0][32][4.5.5.5] 80
 BGP routing table information of [3][0][32][4.5.5.5]/80:
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 Attribute value : MED 0,pref-val 0
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Inclusive multicast Ethernet tag route
 Ethernet tag ID : 0
 Origin address  : 5.5.5.5/32
表1-4 display bgp l2vpn evpn命令中Inclusive multicast Ethernet tag route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
EVPN route type
BGP EVPN路由类型,取值为Inclusive multicast Ethernet tag route,表示包含性组播以太网标签路由
Ethernet tag ID
以太网标签
Origin address
始发路由器地址
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128的详细信息。
<Sysname>  display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128
 BGP routing table information of [4][00:00:00:00:00:00:00:00:00:0a][32] [4.5.5
.5]/128:
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, <ES-Import RT: 1:1>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Ethernet segment route
 ESI             : 00:00:00:00:00:00:00:00:00:0a
 Origin address  : 4.5.5.5/32
表1-5 display bgp l2vpn evpn命令中Ethernet segment route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     ES-Import RT:ES-Import Route Target属性
EVPN route type
BGP EVPN路由类型,取值为Ethernet segment route,表示以太网段路由
ESI
以太网段标识
Origin address
始发路由器地址
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[5][10][32][4.5.5.5]/80的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [5][10][32][4.5.5.5] 80
 BGP routing table information of [5][10][32][4.5.5.5]/80:
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, <Router's Mac:
                   0006-0708-0910>, <Priority-Color: (1:10:10)>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IP prefix advertisement route
 Ethernet tag ID : 10
 IP address      : 4.5.5.5/32
 Gateway address : 0.0.0.0
 MPLS Label      : 1
表1-6 display bgp l2vpn evpn命令中IP prefix advertisement route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     Priority-Color:Priority-Color扩展团体属性
EVPN route type
BGP EVPN路由类型,取值为IP prefix advertisement route,表示IP前缀路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
IP address
IP网络前缀
Gateway address
网关地址
MPLS Label
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/160的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1] 160
 BGP routing table information of [6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/160:
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Selective multicast Ethernet tag route
 Ethernet tag ID : 0
 Source length   : 32
 Source address  : 10.1.1.1
 Group length    : 32
 Group address   : 224.224.224.224
 Origin address  : 192.168.3.1
 IGMP flags      : v3, include
表1-7 display bgp l2vpn evpn命令中Selective multicast Ethernet tag route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
EVPN route type
BGP EVPN路由类型,取值为Selective multicast Ethernet tag route,表示SMET路由
Ethernet tag ID
以太网标签
Source length
组播源地址长度
Source address
组播源地址
Group length
组播组地址长度
Group address
组播组地址
Origin address
始发路由器地址
IGMP flags
IGMP标记位信息
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[7][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/240的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [7][0000.0000.0000.0000.0000][0][32][10.1.1.1][16][224.224.224.224][32][192.168.3.1] 240
 BGP routing table information of [7][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/240:
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, < ESI-RT: 0:0>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IGMP join synch route
 ESI             : 0000.0000.0000.0000.0000
 Ethernet tag ID : 0
 Source length   : 32
 Group length    : 32
表1-8 display bgp l2vpn evpn命令中IGMP join synch route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     EVI-RT:与EVI关联的Route Target属性
EVPN route type
BGP EVPN路由类型,取值为IGMP join synch route,表示IGMP-JS路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
Source length
组播源地址长度
Source address
组播源地址
Group length
组播组地址长度
Group address
组播组地址
Origin address
始发路由器地址
IGMP flags
IGMP 标记位信息
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[8][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0]/272的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [8][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0] 272
 BGP routing table information of [8][0000.0000.0000.0000.0000]  [0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0]/272:
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, < ESI-RT: 1:200>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IGMP leave synch route
 Ethernet tag ID : 0
 Source length   : 32
 Group length    : 32
 Leave group sync: 0
 Max ResponseTime: 2500ms
 Max ResponseCode: 25
表1-9 display bgp l2vpn evpn命令中IGMP leave synch route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     ESI-RT:与ESI关联的Route Target属性
EVPN route type
BGP EVPN路由类型,取值为IGMP leave synch route,表示IGMP-LS路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
Source length
组播源地址长度
Source address
组播源地址
Group length
组播组地址长度
Group address
组播组地址
Origin address
始发路由器地址
Leave group sync
离开组播组的同步序列号值
Max ResponseTime
最大响应时间,单位为毫秒
Max ResponseCode
接收到的报文中携带的最大响应值,单位为十分之一秒
IGMP flags
IGMP标记位信息
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128的通告信息。
<Sysname> display bgp l2vpn  evpn  route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a] [32][4.5.5.5] 128 advertise-info
 Paths:   1 best
 BGP routing table information of [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128:
    10.2.1.2
表1-10 display bgp l2vpn evpn advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
Paths
到达指定目的网络的优选路由数目
BGP routing table information of [4][00:00:00:00:00:00:00:00:00:0a] [32] [4.5.5.5]/128
BGP EVPN路由[4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128的通告信息
该路由已经向哪些BGP EVPN对等体发送,以及对等体的数目
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128的团体属性信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 community
 BGP local router ID: 1.1.1.9
 Community: no-export
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128的扩展团体属性信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 ext-community
 Ext-Community: <RT 1:1>
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128的AS_PATH属性信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 as-path
 As-path: 80
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128的集群ID列表属性信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 cluster-list
 Cluster list: 80
表1-11 display bgp l2vpn evpn命令路由属性显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
Paths
路由数信息:
·     available:有效路由数目
·     best:最佳路由数目
指定BGP EVPN路由的属性信息
Community
路由的团体属性
Ext-Community
路由的扩展团体属性
As-path
路由的AS_PATH属性
Cluster-list
路由的集群ID列表属性
# 显示具有团体属性的BGP EVPN路由统计信息。
<Sysname> display bgp l2vpn evpn statistics community
 Total number of routes from all PEs: 1
 Route distinguisher: 100:1(vpn1)
 Total number of routes: 4
表1-12 display bgp l2vpn evpn statistics命令显示信息描述表
来自所有PE设备的EVPN路由总数
Route distinguisher
路由标识符
路由标识符为指定值的EVPN路由总数
display bgp l2vpn evpn inlabel命令用来显示BGP EVPN的IP前缀路由的入标签信息。
display bgp [ instance instance-name ] l2vpn evpn inlabel
可通过本命令显示本地PE为EVPN的IP前缀路由分配的私网标签。
# 显示BGP EVPN IP前缀路由的入标签信息。
<Sysname> display bgp l2vpn evpn inlabel
               a - additional-path
       Origin: i - IGP, e - EGP, ? – incomplete
 Route distinguisher: 100:2
     Network            NextHop         OutLabel        InLabel
* >e [5][0][24][192.168.1.0]/80
                        192.168.1.10    NULL            1151
表1-13 display bgp l2vpn evpn inlabel命令显示信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
·     e – EGP:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
Route distinguisher
路由标识符
公网实例的路由标识符
Network
BGP EVPN路由/路由长度,BGP EVPN路由取值为[5][EthernetTagID][IPAddressLength][IPAddress]
·     5:表示IP前缀路由(IP prefix advertisement route)
·     EthernetTagID:以太网标签
·     IPAddressLength:IP地址长度
·     IPAddress:始发路由器的IP地址
NextHop
下一跳IP地址
OutLabel
出标签值,即对端PE为EVPN路由分配的私网标签,取值为NULL表示空标签
InLabel
入标签值,即本地PE为EVPN路由分配的私网标签
·     evpn mpls routing-enable
·     peer advertise encap-type mpls
display evpn auto-discovery命令用来显示EVPN通过BGP自动发现的邻居信息。
display evpn auto-discovery { { imet [ mpls | vxlan ] | mac-ip [ mpls | srv6 | vxlan ] } [ peer peer-address] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
imet:显示通过包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)发现的邻居信息。
mac-ip:显示通过MAC/IP发布路由发现的邻居。
mpls:显示EVPN VPLS组网中通过BGP自动发现的邻居信息。
srv6:显示EVPN VPLS over SRv6组网中通过BGP自动发现的邻居信息。EVPN VPLS over SRv6的详细介绍,请参见“Segment Routing配置指导”中的“EVPN VPLS over SRv6”。
vxlan:显示EVPN VXLAN组网中通过BGP自动发现的邻居信息。
peer peer-address:显示指定邻居的自动发现相关信息。peer-address为邻居的IPv4地址或IPv6地址。如果未指定本参数,则显示自动发现的所有邻居的信息。
vsi vsi-name:显示指定VSI内自动发现的邻居信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI内自动发现的邻居信息。
macip-prefix:显示通过MAC/IP发布路由和IP前缀路由发现的邻居信息。
nexthop next-hop:显示从指定路由下一跳学习到的邻居信息。next-hop next-hop为路由下一跳的IPv4地址或IPv6地址。如果未指定本参数,则显示从所有路由下一跳学习到的邻居信息。
count:显示自动发现的邻居数目。如果未指定本参数,则显示邻居的具体信息。
如果执行本命令时,没有指定mplsvxlansrv6参数,则同时显示所有类型组网中EVPN通过BGP自动发现的邻居信息。
# EVPN VXLAN组网下显示通过包含性组播以太网标签路由发现的邻居信息。
<Sysname> display evpn auto-discovery imet vxlan
Total number of automatically discovered peers: 2
VSI name: vpna
EVPN instance: -
RD                    PE_address      Tunnel_address  Tunnel mode VXLAN ID
1:10                  2.2.2.2         2.2.2.2         VXLAN       10
2:100                 3.3.3.3         3.3.3.3         VXLAN       10
# EVPN VPLS组网下显示通过包含性组播以太网标签路由发现的邻居信息。
<Sysname> display evpn auto-discovery imet mpls
Total number of automatically discovered peers: 1
VSI name: vpna
EVPN instance: -
RD                    PE_address      In/Out label    Tunnel mode
1:1                   1.1.1.1         1151/1151       PW
# EVPN VPLS over SRv6组网下显示通过包含性组播以太网标签路由发现的邻居信息。
<Sysname> display evpn auto-discovery imet srv6
VSI name: vpnc
EVPN instance: -
RD         : 1:1                 Tunnel mode      :  SRv6
PE_address : 1::1
In SID     : 100::10::0
Out SID    : 200::20::0
表1-14 display evpn auto-discovery imet命令显示信息描述表
自动发现的邻居数目
VSI name
VSI名称
EVPN instance
EVPN实例名称。显示为“-”时,表示VSI实例下创建的EVPN实例
RD
路由标识符
PE_address
远端VTEP在VSI内的标识
Tunnel_address
隧道的目的端地址
Tunnel mode
隧道的模式,取值包括:
·     VXLAN:表示VXLAN隧道
·     VXLAN-DCI:表示VXLAN数据中心互联隧道
·     PW:表示PW
·     SRv6:表示SRv6隧道
In/Out label
PW的入标签和出标签,当标签无效时显示为“-”
VXLAN ID
VXLAN编号
In SID
入SID
Out SID
出SID
# EVPN VXLAN组网下显示通过MAC/IP发布路由发现的IPv4邻居信息。
<Sysname> display evpn auto-discovery mac-ip vxlan
VSI name: vpna
EVPN instance: -
Destination IP  Source IP       VXLAN ID    Tunnel mode     Tunnel name
6.6.6.6         1.1.1.9         100         VXLAN           Tunnel1
# EVPN VPLS组网下显示通过MAC/IP发布路由发现的IPv4邻居信息。
<Sysname> display evpn auto-discovery mac-ip mpls
VSI name: vpnb
EVPN instance: -
Destination IP  In/Out label    Tunnel Mode
7.7.7.7         1420/1419       PW
# EVPN VPLS over SRv6组网下显示通过MAC/IP发布路由发现的IPv4邻居信息。
<Sysname> display evpn auto-discovery mac-ip srv6
VSI name: vpnb
EVPN instance: -
Destination IP : 1::1
In SID         : 100::10::0
表1-15 display evpn auto-discovery mac-ip命令显示信息描述表
自动发现的邻居数目
VSI name
VSI名称
EVPN instance
Destination IP
隧道的目的端地址
Source IP
隧道的源端地址
VXLAN ID
VXLAN编号
Tunnel mode
VXLAN隧道的模式,取值包括:
·     VXLAN:表示VXLAN隧道
·     PW:表示PW
·     SRv6:表示SRv6隧道
Tunnel name
隧道名称
In/Out label
In SID
入SID
Out SID
出SID
# 显示通过MAC/IP发布路由和IP前缀路由发现的邻居信息。
<Sysname> display evpn auto-discovery macip-prefix
Destination IP  Source IP       L3VNI           Tunnel mode Outgoing interface
1.1.1.1         3.3.3.3         200             VXLAN       Vsi-interface3
2.2.2.2         3.3.3.3         200             VXLAN       Vsi-interface3
# 显示通过MAC/IP发布路由和IP前缀路由发现的邻居总数。
<Sysname> display evpn auto-discovery macip-prefix count
Total number of entries: 2
表1-16 display evpn auto-discovery macip-prefix命令显示信息描述表
Destination IP
隧道的目的端地址
Source IP
隧道的源端地址
L3VNI
用于三层转发的VXLAN ID
Tunnel mode
隧道的模式,取值包括
·     VXLAN:表示VXLAN隧道
Outgoing interface
出接口,即与L3VNI关联的VSI虚接口
邻接表项的总数
display evpn es命令用来显示EVPN的ES信息。
display evpn es { local [ count | [ vsi vsi-name  | xconnect-group group-name ] [ esi esi-id ] [ verbose ] ] | remote [ vsi vsi-name | xconnect-group group-name ] [ esi esi-id ] [ nexthop next-hop ] [ verbose ] }
local:显示本地多归属成员ES信息。
count:显示本地多归属成员ES的数目。
vsi vsi-name:显示指定VSI的ES信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的ES信息。
xconnect-group group-name:显示指定交叉连接组内EVPN的本地ES信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有交叉连接组内EVPN的本地ES信息。
esi esi-id:显示指定ESI的ES信息。esi-id表示以太网链路网段标识符的值,格式为xxxx.xxxx.xxxx.xxxx.xxxx,必须以00开头,其中x为十六进制数,不支持全0。如果未指定本参数,则显示VSI的所有ES信息。
verbose:显示ES的详细信息。如果不指定本参数,则显示ES的简要信息。
remote:显示远端多归属成员ES信息。
nexthop next-hop:显示从指定路由下一跳接收到的ES信息。next-hop为路由下一跳的IPv4地址或IPv6地址。如果不指定本参数,则显示从所有路由下一跳收到的ES信息。
# 显示本地ES的数目。
<Sysname> display evpn es local count
 Total number of ES entries: 1
# EVPN VPLS组网中显示VSI实例vpna的本地ES简要信息。
<Sysname> display evpn es local vsi vpna
Redundacy mode: A – All-active, S – Single-active
VSI name : vpna
EVPN instance: -
VSI ESI                     Tag ID      DF address      Mode  State ESI label
0001.0002.0002.0002.0002    0           1.1.1.1         A     Up    1000
0001.0002.0003.0004.0005    0           1.1.1.1         A     Up    1001
0003.0003.0003.0003.0003    2           2.2.2.2         A     Up    1002
# EVPN VPLS over SRv6组网中显示VSI实例vpna的本地ES简要信息。
VSI name : vpna
EVPN instance: -
 ESI        : 0001.0001.0001.0001.0001
 Tag ID     : -
 DF address : 1.1.1.1
 Mode       : A
 State      : Down
 Argument   : ::1
# EVPN VPWS组网中显示交叉连接组vpna的本地ES简要信息。
<Sysname> display evpn es local xconnect-group vpna
Redundancy mode: A – All-active, S – Single-active
Xconnect group name: vpna
0001.0002.0002.0002.0002    -           1.1.1.1         A     Up    -
0001.0002.0003.0004.0005    -           1.1.1.1         A     Up    -
0003.0003.0003.0003.0003    2           2.2.2.2         A     Up    -
# EVPN VPWS over SRv6组网中显示交叉连接组vpna的本地ES简要信息。
Xconnect-group name : vpna
 Tag ID     : -
 Mode       : A
 State      : Up
 Argument   : -
表1-17 display evpn es local命令显示信息描述表
VSI name
VSI名称
EVPN instance
Xconnect group name
交叉连接组名称
ESI
ES标识符
Tag ID
以太网标签ID
DF address
被选为DF的VTEP或PE的Router ID
Mode
ES的冗余备份模式,取值包括:
·     A:表示ES的冗余备份模式为all-active模式
·     S:表示ES的冗余备份模式为single-active模式
当前ES的状态,取值包括Up和Down
ESI label
ESI标签;在EVPN VPWS和EVPN VXLAN组网中ESI label无效,显示为“-”
Argument
标识Leaf AC的Argument值,在EVPN VPLS over SRv6的E-Tree组网中用于实现Leaf AC间的流量隔离
当无Argument时显示为“-”
# 显示所有VSI内本地ES的详细信息。
<Sysname> display evpn es local verbose
VSI name : v1
EVPN instance: -
  VSI ESI                  : 0001.0001.0001.0001.0003
  Redundancy mode          : All-active
  ES state                 : Up
  AD-delay remaining time  : 10
  ESI                      : 0003.0003.0003.0003.0003
  Interface                : Ten-GigabitEthernet0/0/6
  State                    : Up
  ACs                      :
    Link ID     Service instance ID   Tag ID      DF address        ESI label
    0           1                     1           1.1.1.1           1001
    1           3                     3           3.3.3.3           1002
    2           10                    10          2.2.2.2           1003
VSI name : v2
EVPN instance: -
  ESI                      : 0004.0004.0004.0004.0004
  Interface                : -
  State                    : Up
  UPWs                     :
    Link ID     Tag ID      DF address        ESI label
    0           1           1.1.1.1           1004
VSI name : vpna
EVPN instance: -
  ESI                      : 0001.0002.0002.0002.0002
  Interface                : Ten-GigabitEthernet0/0/7
  State                    : Up
  ACs                      :
    1           -                     0           1.1.1.1           -
VSI name : vpnb
EVPN instance: -
  Interface                : XGE0/0/8
  State                    : Down
  ACs                      :
    Link ID                : 0
    Service instance ID    : -
    Tag ID                 : 0
    Argument               : ::1
Xconnect group name : vpna
 Connection name           : aa
  AC                       : XGE0/0/10 srv1
  State                    : Up
  Link ID                  : 0
  Tag ID                   : 10
Xconnect group name : vpnd
 Connection name           : dd
  ESI                      : 0006.0006.0006.0006.0006
  State                    : Up
  UPW Link ID              : 0
  Tag ID                   : 10
表1-18 display evpn es local verbose命令显示信息描述表
VSI name
VSI名称
EVPN instance
VSI ESI
VSI实例的ES标识符
Xconnect group name
交叉连接组名称
Connection name
交叉连接名称
ESI
ES标识符
接口名称
AC
与交叉连接关联的接入电路,取值为:
·     三层接口名称:表示交叉连接关联三层接口
·     二层接口名称和以太网服务实例:表示交叉连接关联以太网服务实例
Redundancy mode
ES的冗余备份模式,取值包括:
ES state
当前VSI对应ES的状态,取值包括Up、Down和“-”。其中,“-”表示未手动配置ESI
当前接口或UPW对应ES的状态,取值包括Up、Down和“-”。其中,“-”表示未手动配置ESI
以太网自动发现路由延迟发布定时器的剩余时间,单位为秒
ACs
VSI在当前ES下的AC列表
UPWs
VSI在当前ES下的UPW列表
Link ID
AC在VSI内的链路ID
Service instance ID
以太网服务实例ID
Tag ID
以太网标签ID
DF address
被选为DF的VTEP或PE的Router ID,取值为“-”表示当前设备未被选举为该AC的DF
ESI label
Argument
当无Argument时显示为“-”
UPW link ID
UPW在VSI内的链路标识符
# 显示远端ES的简要信息。
<Sysname> display evpn es remote
Control Flags: P - Primary, B - Backup, C - Control word
VSI name : vpna
EVPN instance: -
  ESI                     : 0001.0000.0000.0000.0001
  Ethernet segment routes :
    1.1.1.1
    3.3.3.3
  A-D per ES routes       :
    Peer IP             Remote Redundancy mode
    1.1.1.1             All-active
    3.3.3.3             All-active
  A-D per EVI routes      :
    Tag ID      Peer IP
    -           1.1.1.1
    -           3.3.3.3
  ESI                     : 0001.0002.0003.0004.0005
    1.1.1.1
  A-D per ES routes       :
    1.1.1.1             All-active
    Tag ID      Peer IP
    -           1.1.1.1
Xconnect group name : a
    123.123.123.123
    3.3.3.3
  A-D per ES routes       :
    123.123.123.123     All-active
    3.3.3.3             All-active
    Tag ID      Peer IP          Control Flags
    2           3.3.3.3          P
    4           123.123.123.123  PC
# 显示远端ES的详细信息。
VSI name : vpna
EVPN instance: -
  A-D per ES routes       :
    Peer IP               : 2::2
    Remote Redundancy mode: All-active
    Argument              : ::1
    Tag ID                : 1
    Peer IP               : 2::2
    2::2
  A-D per ES routes       :
    Peer IP               : 2::2
    Tag ID                : 1
    Control Flags         : P
    Peer IP               : 2::2
# 显示VSI实例vpna内,从下一跳3.3.3.3接收到的远端ES的信息。
<Sysname> display evpn es remote vsi vpna nexthop 3.3.3.3
VSI name : vpna
EVPN instance: -
    3.3.3.3
  A-D per ES routes       :
    3.3.3.3
    Tag ID      Peer IP
    -           3.3.3.3
表1-19 display evpn es remote命令显示信息描述表
VSI name
VSI名称
EVPN instance
Xconnect group name
交叉连接组名称
ESI
ES标识符
Redundancy mode
ES的冗余备份模式,取值包括:
·     All-active:表示ES的冗余备份模式为多活模式
·     Single-active:表示ES的冗余备份模式为单活模式
Argument
当无Argument时显示为“-”
与该ES关联的以太网段路由
A-D per Ethernet segment routes
与该ES关联的A-D per ES路由
A-D per EVI routes
与该ES关联的A-D per EVI路由
Tag ID
以太网标签ID
Peer IP
远端设备的IP地址
远端ES的冗余备份模式,取值包括:
Control Flags
远端路由二层属性控制标识,取值包括:
·     P:接收到的路由携带了Primary标识
·     B:接收到的路由携带了Backup标识
·     C:接收到的路由携带了Control word标识
display evpn instance命令用来显示EVPN实例的相关信息。
display evpn instance [ name instance-name | vsi vsi-name | xconnect-group group-name ]
name instance-name:显示指定EVPN实例的信息。instance-name表示EVPN实例名称,为1~31个字符的字符串,区分大小写。
vsi vsi-name:显示指定VSI对应EVPN实例的信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
xconnect-group group-name:显示指定交叉连接组对应EVPN实例的信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。
执行本命令时,如果没有指定name instance-namevsi vsi-namexconnect-group group-name参数,则显示所有EVPN实例的信息。
# 显示所有EVPN实例的信息。
<Sysname> display evpn instance
Total number of EVPN instances: 3
EVPN instance : abc
  Route distinguisher    : -
  Export VPN targets     : -
  Import VPN targets     : -
  MAC advertisement      : Enabled
  ARP advertisement      : Enabled
  ARP-based MAC learning : Enabled
  ND-based MAC learning  : Enabled
  Local fast-reroute     : Inherit
  Tunnel policy          : -
  PW class               : -
  Dt2uLocatorName        : -
  Dt2ulLocatorName       : -
  Dt2mLocatorName        : -
  E-Tree                 : Disabled
  Best-Effort            : Disabled
  Traffic-Engineering    : Disabled
  Import routing policy  : -
  Export routing policy  : -
  VSI binding list:
    VSI name                                Tag ID
    vpna                                    3
    vpnb                                    5
EVPN instance : - (created on vsi abc)
  Encapsulation          : VXLAN
  VXLAN ID               : -
EVPN instance : - (created on Xconnect-group xcga)
  Encapsulation          : MPLS
  Import Route Policy    : -
  Export Route Policy    : -
表1-20 display evpn instance命令显示信息描述表
EVPN实例总数
EVPN instances
EVPN实例名称,显示方式如下:
·     instance-name:表示系统视图下创建的EVPN实例
·     - (created on VSI vsi-name):表示VSI实例vsi-name下创建的EVPN实例
·     -(created on Xconnect-group xconnect-group-name):表示交叉连接组xconnect-group-name下创建的EVPN实例
Encapsulation
EVPN的封装类型,取值包括:
·     VXLAN:表示EVPN的封装类型为VXLAN
·     MPLS:表示EVPN的封装类型为MPLS
·     SRv6:表示EVPN的封装类型为SRv6
Route distinguisher
EVPN实例的RD
Export VPN targets
EVPN实例的Export Target
Import VPN targets
EVPN实例的Import Target
MAC advertisement
是否允许通告MAC地址信息,取值包括:
·     Enabled:允许通告MAC地址信息
·     Disabled:禁止通告MAC地址信息
ARP advertisement
是否允许通告ARP信息,取值包括:
·     Enabled:允许通告ARP信息
·     Disabled:禁止通告ARP信息
是否允许EVPN从ARP信息中学习MAC地址表项,取值包括:
·     Enabled:允许EVPN从ARP信息中学习MAC地址表项
·     Disabled:禁止EVPN从ARP信息中学习MAC地址表项
是允许EVPN从ND信息中学习MAC地址表项功能,取值包括:
·     Enabled:允许EVPN从ND信息中学习MAC地址表项
·     Disabled:禁止EVPN从ND信息中学习MAC地址表项
Local fast-reroute
EVPN实例FRR功能的状态,取值包括:
·     Enabled:在EVPN实例视图下开启EVPN实例的FRR功能
·     Disabled:在EVPN实例视图下关闭EVPN实例的FRR功能
·     Inherit:在EVPN实例视图下未配置EVPN实例FRR功能,继承系统视图下的配置
Tunnel policy
EVPN实例引用的隧道策略
PW class
EVPN实例引用的PW模板
Control word
是否开启控制字功能,取值包括:
·     Enabled:PW开启控制字功能
·     Disabled:PW关闭控制字功能
E-Tree
是否开启EVPN E-Tree功能,取值包括:
·     Enabled:开启EVPN E-Tree功能
·     Disabled:关闭EVPN E-Tree功能
PW type
PW类型,取值包括:
·     Ethernet:以太网类型
·     VLAN:VLAN类型
Sequencing
PW的排序处理,取值包括:
·     Both:表示对PW收发两个方向的报文均进行排序处理
·     -:表示未配置PW的排序处理,即不对PW上传输的报文进行排序
VXLAN ID
VXLAN编号
Flow label
流标签能力,取值包括:
·     Both:具有发送和接收能力
·     Send:具有发送能力
·     Recv:具有接收能力
·     -:未开启流标签能力
Dt2u SID
EVPN VPLS over SRv6组网中,用于转发单播报文的SRv6 SID,括号中为SID各组成部分长度,依次为Locator段长度、动态Opcode长度、静态Opcode长度和Argument长度,各组成部分长度之和为128
Dt2ul SID
EVPN VPLS over SRv6多归属站点组网中,用于在冗余备份组成员设备间的Bypass隧道上转发单播报文的SRv6 SID,括号中为SID各组成部分长度,依次为Locator段长度、动态Opcode长度、静态Opcode长度和Argument长度,各组成部分长度之和为128
Dt2m SID
EVPN VPLS over SRv6组网中,用于转发组播报文的SRv6 SID,括号中为SID各组成部分长度,依次为Locator段长度、动态Opcode长度、静态Opcode长度和Argument长度,各组成部分长度之和为128
Dt2uLocatorName
用于申请DT2U SID的Locator段名称
若禁止动态分配SID,则显示auto-sid-disable;否则,不显示
Dt2ulLocatorName
用于申请DT2UL SID的Locator段名称
Dt2mLocatorName
用于申请DT2M SID的Locator段名称
Best-Effort
是否根据SRv6 SID进行SR-BE路由迭代,取值包括:
·     Enabled:根据SRv6 SID进行SR-BE路由迭代
·     Disabled:不会根据SRv6 SID进行SR-BE路由迭代
Traffic-Engineering
是否根据下一跳地址进行SR-TE路由迭代,取值包括:
·     Enabled:根据下一跳地址进行SR-TE路由迭代
·     Disabled:不会根据下一跳地址进行SR-TE路由迭代
EVPN实例引用的入方向路由策略,如果未引用入方向路由策略,则显示为“-”。只有报文封装类型为MPLS或SRv6时才显示本字段
EVPN实例引用的出方向路由策略,如果未引用出方向路由策略,则显示为“-”。只有报文封装类型为MPLS或SRv6时才显示本字段
VSI binding list
绑定EVPN实例的VSI列表
VSI name
VSI名称
Tag ID
VSI的Tag ID
·     evpn encapsulation
·     vsi
display evpn ipv6 auto-discovery命令用来显示EVPN通过BGP自动发现的IPv6邻居信息。
display evpn ipv6 auto-discovery { { imet | mac-ip } [ srv6 | vxlan ] [ peer ipv6-address ] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
imet:显示通过包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)发现的IPv6邻居信息。
mac-ip:显示通过MAC/IP发布路由(MAC/IP Advertisement route)发现的IPv6邻居信息。
srv6:显示EVPN VPLS over SRv6组网中通过BGP自动发现的邻居信息。EVPN VPLS over SRv6组网的详细介绍,请参见“Segment Routing配置指导”中的“EVPN VPLS over SRv6”。
peer ipv6-address:显示指定IPv6邻居的自动发现相关信息。ipv6-address为邻居的IPv6地址。如果未指定本参数,则显示所有IPv6邻居的自动发现相关信息。
vsi vsi-name:显示指定VSI内自动发现的IPv6邻居信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI内自动发现的IPv6邻居信息。
macip-prefix:显示通过携带L3VNI的MAC/IP发布路由或IP前缀路由发现的IPv6邻居信息。
nexthop next-hop:显示从指定路由下一跳学习到的邻居信息。如果未指定本参数,则显示从所有路由下一跳学习到的IPv6邻居信息。
count:显示自动发现的IPv6邻居数目。如果未指定本参数,则显示IPv6邻居的具体信息。
# EVPN VXLAN组网中显示通过包含性组播以太网标签路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery imet
VSI name: vpna
EVPN instance  : -
RD             : 1:10
PE address     : 11::8
Tunnel address : 11::8
Tunnel mode    : VXLAN
VXLAN ID       : 10
RD             : 2:100
PE address     : 12::8
Tunnel address : 12::8
Tunnel mode    : VXLAN
VXLAN ID       : 10
# EVPN VPLS over SRv6组网中显示通过包含性组播以太网标签路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery imet srv6
VSI name: vpnc
 PE_address  : 3::3
 In SID      : 111::1
 Out SID     : 333::1
表1-21 display evpn ipv6 auto-discovery imet命令显示信息描述表
自动发现的邻居数目
VSI name
VSI名称
EVPN instance
EVPN实例名称,如果未创建则显示“-”
RD
路由标识符
PE address
远端VTEP在VSI内的标识
Tunnel address
隧道的目的端地址
Tunnel mode
隧道的模式,取值包括:
·     VXLAN:表示VXLAN隧道
·     SRv6:表示SRv6隧道
VXLAN ID
VXLAN编号
In SID
SRv6隧道的入SID
Out SID
SRv6隧道的出SID
# EVPN VXLAN组网中显示通过MAC/IP发布路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery mac-ip
VSI name: vpna
Destination IP : 6:6::6:8
Source IP      : 1:1::1:7
VXLAN ID       : 100
Tunnel mode    : VXLAN
Tunnel name    : Tunnel1
# EVPN VPLS over SRv6组网中显示通过MAC/IP发布路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery mac-ip srv6
VSI name: vpnc
Tunnel mode    :  SRv6
In SID         : 100::10::0
表1-22 display evpn ipv6 auto-discovery mac-ip命令显示信息描述表
自动发现的邻居数目
VSI name
VSI名称
Destination IP
隧道的目的端地址
Source IP
隧道的源端地址
VXLAN ID
VXLAN编号
Tunnel mode
隧道模式,取值包括:
·     VXLAN,表示VXLAN隧道
·     SRv6:表示SRv6隧道
Tunnel name
隧道名称
In SID
SRv6隧道的入SID
Out SID
SRv6隧道的出SID
# 显示通过MAC/IP发布路由和IP前缀路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery macip-prefix
L3VNI              : 100
Tunnel mode        : VXLAN
OutInterface       : Vsi-interface3
# 显示通过MAC/IP发布路由和IP前缀路由发现的IPv6邻居总数。
<Sysname> display evpn ipv6 auto-discovery macip-prefix count
Total number of entries: 1
表1-23 display evpn ipv6 auto-discovery macip-prefix命令显示信息描述表
Destination IP
隧道的目的端地址
Source IP
隧道的源端地址
L3VNI
用于三层转发的VXLAN ID
Tunnel mode
隧道的模式,取值包括
·     VXLAN:表示VXLAN隧道
OutInterface
邻接表项的总数
display evpn route arp命令用来显示EVPN的ARP信息。
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ ip ipv4-address ] [ count ]
local:显示本地ARP信息。
remote:显示远端ARP信息。
public-instance:显示公网实例的ARP信息。
vpn-instance vpn-instance-name:显示指定VPN实例的ARP信息。vpn-instance-name表示 MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
ip ipv4-address:显示指定IPv4地址的ARP信息。ipv4-address表示IPv4地址,为点分十进制格式。如果不指定本参数,则显示公网或VPN实例的所有ARP信息。
count:显示ARP表项的数目。如果不指定本参数,则显示ARP表项的具体信息。
执行本命令时,如果没有指定localremote参数,则显示EVPN的本地和远端ARP信息。
执行本命令时,如果没有指定public-instancevpn-instance vpn-instance-name参数,则显示公网实例和所有VPN实例的ARP信息。
# 显示所有EVPN的ARP信息。
<Sysname> display evpn route arp
Flags: D - Dynamic   B - BGP      L - Local active
       G - Gateway   S - Static   M - Mapping        I - Invalid
       E - Multihoming ES sync    F - Leaf
VPN instance: vpn1                            Interface: Vsi-interface1
IP address      MAC address     Router MAC      VSI index   Flags
10.1.1.1        0003-0003-0003  a0ce-7e40-0400  0           GL
10.1.1.11       0001-0001-0001  a0ce-7e40-0400  0           DL
10.1.1.12       0001-0001-0011  a0ce-7e41-0401  0           B
10.1.1.13       0001-0001-0021  a0ce-7e42-0402  0           B
Public instance                               Interface: Vsi-interface2
11.1.1.1        0033-0033-0033  a0ce-7e40-0400  0           GL
11.1.1.11       0011-0011-0011  a0ce-7e40-0400  0           DL
# 显示EVPN的ARP表项总数。
<Sysname> display evpn route arp count
Total number of entries: 6
表1-24 display evpn route arp命令显示信息描述表
VPN instance name
VPN实例名称
Public instance
公网实例
VSI虚接口
IP address
IP地址
MAC address
MAC地址
Router MAC
设备的Router MAC
在SRv6分布式网关组网中,本字段显示为“-”
VSI index
VSI索引
Flags
ARP表项类型,取值包括:
·     D:表示存在动态学习的ARP表项
·     B:表示存在通过BGP EVPN路由学习的ARP表项
·     L:表示本地ARP表项生效,未设置该标志表示通过BGP EVPN路由学习的ARP表项生效
·     G:表示生效的ARP表项是网关的ARP表项
·     S:表示生效的ARP表项是静态配置的ARP表项
·     M:表示生效的ARP表项是来自映射的远端VXLAN的ARP表项
·     I:表示该ARP表项无效,原因如下:
¡     通过shutdown命令手工关闭VSI
¡     出方向Tunnel接口不存在
·     E:表示多归属成员同步的ARP表项
·     F:表示EVPN E-tree组网中从Leaf上学习到的ARP表项
ARP表项的总数
display evpn route arp suppression命令用来显示EVPN的ARP泛洪抑制信息。
display evpn route arp suppression [ mpls | srv6 | vxlan ] [ local | remote ] [ vsi vsi-name ] [ ip ipv4-address ] [ count ]
mpls显示EVPN VPLS组网中的ARP泛洪抑制信息。
srv6显示EVPN VPLS over SRv6组网中的ARP泛洪抑制信息。EVPN VPLS over SRv6的详细介绍,请参见“Segment Routing配置指导”中的“EVPN VPLS over SRv6”。
vxlan:显示EVPN VXLAN组网中的ARP泛洪抑制信息。
local:显示本地ARP泛洪抑制信息。
remote:显示远端ARP泛洪抑制信息。
vsi vsi-name:显示指定VSI的ARP泛洪抑制信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的ARP泛洪抑制信息。
ip ipv4-address:显示指定IP地址的ARP泛洪抑制信息。ipv4-address表示IPv4地址,为点分十进制格式。如果不指定本参数,则显示所有ARP泛洪抑制信息。
count:显示ARP泛洪抑制表项的数目。如果不指定本参数,则显示ARP泛洪抑制表项的具体信息。
执行本命令时,如果没有指定localremote参数,则显示EVPN的本地和远端的ARP泛洪抑制信息;如果没有指定mplssrv6vxlan参数,则显示所有组网环境下的ARP泛洪抑制信息。
# 显示所有EVPN的ARP泛洪抑制信息。
<Sysname> display evpn route arp suppression
VSI name: vpna
EVPN instance: -
IP address      MAC address       Flags           Encap
10.1.1.12       0002-0002-0002    B               VXLAN
10.1.1.13       0002-0002-0002    BI              VXLAN
10.1.1.101      0001-0011-0101    BS              VXLAN
10.1.1.102      0001-0011-0102    DL              VXLAN
# 显示EVPN的ARP泛洪抑制表项总数。
<Sysname> display evpn route arp suppression count
表1-25 display evpn route arp suppression命令显示信息描述表
VSI name
VSI名称
EVPN instance
IP address
IP地址
MAC address
MAC地址
Flags
ARP泛洪抑制表项类型,取值包括:
·     D:表示存在动态学习的ARP泛洪抑制表项
·     B:表示存在通过BGP EVPN路由学习的ARP泛洪抑制表项
·     L:表示本地ARP泛洪抑制表项生效,未设置该标志表示通过BGP EVPN路由学习的ARP泛洪抑制表项生效
·     G:表示生效的ARP泛洪抑制表项是网关的ARP表项
·     S:表示生效的ARP泛洪抑制表项是静态配置的ARP表项
·     M:表示生效的ARP泛洪抑制表项是来自映射的远端VXLAN的ARP表项
·     I:表示该ARP泛洪抑制表项无效,原因如下:
¡     出方向Tunnel接口不存在
·     E:表示多归属成员同步的ARP泛洪抑制表项
·     F:表示EVPN E-tree组网中从Leaf上学习到的ARP泛洪抑制表项
Encap
报文封装类型,取值包括:
·     MPLS:报文封装类型为MPLS
·     VXLAN:报文封装类型为VXLAN
ARP泛洪抑制表项的总数
display evpn route arp-mobility命令用来显示EVPN的ARP迁移信息。
display evpn route arp-mobility [ public-instance | vpn-instance vpn-instance-name ] [ ip ip-address ]
public-instance:显示公网实例的ARP迁移信息。
vpn-instance vpn-instance-name:显示指定VPN实例的ARP迁移信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
ip ip-address:显示指定IP地址的ARP迁移信息。ip-address表示IPv4地址,为点分十进制格式。如果不指定本参数,则显示公网或VPN实例的所有ARP迁移信息。
配置本命令时,如果不指定public-instancevpn-instance vpn-instance-name参数,则显示公网和所有VPN实例的ARP迁移信息。
# 显示所有EVPN的ARP迁移信息。
<Sysname> display evpn route arp-mobility
Flags: S - Suppressed, N - Not suppressed
  Suppression threshold: 5
  Detection cycle      : 180s
  Suppression time     : Permanent
VPN instance : vpn1
Interface    : Vsi-interface1
  IP address      Move count Moved from                Flags Suppressed at
  192.168.156.120 5          XGE0/0/6                  S     17:24:33 2018/04/01
  192.168.56.20   -          -                         N     -
Public instance
Interface    : Vsi-interface2
  192.168.156.120 5          XGE0/0/7                  S     17:24:33 2018/04/01
  192.168.56.20   5          2.2.2.2                   S     17:24:33 2018/04/01
表1-26 display evpn route arp-mobility命令显示信息描述表
从本地迁移到远端站点的次数阈值
Detection cycle
检测周期,单位为秒
Suppression time
抑制恢复时间,单位为秒
取值为Permanent时,表示永远抑制
VPN instance
VPN实例
Public instance
公网实例
IP address
IP地址
Move count
迁出次数
Moved from
表示ARP上一次迁移到的AC接口名称或所在VTEP/PE的IP地址
Flags
ARP是否被抑制迁移,取值包括:
·     S:表示抑制迁移
·     N:表示未抑制迁移
Suppressed at
迁移抑制发生的时间
·     evpn route arp-mobility suppression
display evpn route mac命令用来显示EVPN的MAC地址信息。
display evpn route mac [ mpls | srv6 | vxlan ] [ local | remote ] [ vsi vsi-name ] [ mac-address mac-address ] [ count ]
mpls显示EVPN VPLS组网中的MAC地址信息。
srv6显示EVPN VPLS over SRv6组网中的MAC地址信息。EVPN VPLS over SRv6的详细介绍,请参见“Segment Routing配置指导”中的“EVPN VPLS over SRv6”。
vxlan:显示EVPN VXLAN组网中的MAC地址信息。
local:显示本地MAC地址信息。
remote:显示远端MAC地址信息。
vsi vsi-name:显示指定VSI的MAC地址信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的MAC地址信息。
mac-address mac-address:显示指定MAC地址表项信息。mac-address表示MAC地址,格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。如果未指定本参数,则显示所有MAC地址表项信息。
count:显示MAC地址表项的数目。如果不指定本参数,则显示MAC地址的具体信息。
执行本命令时,如果没有指定localremote参数,则显示EVPN的本地和远端MAC地址信息;如果没有指定mplssrv6vxlan参数,则显示所有组网环境下的MAC地址信息。
# EVPN VXLAN组网中显示所有EVPN的本地和远端MAC地址信息。
<Sysname> display evpn route mac
VSI name: bbb
EVPN instance: -
MAC address     Link ID/Name   Flags   Encap           Next hop
0000-0000-000a  1              DL      VXLAN           -
0000-0000-0009  Tunnel1        B       VXLAN           2.2.2.2
0001-2000-4000  -              BI      VXLAN           3.3.3.3
# EVPN VPLS over SRv6组网中显示所有EVPN的本地和远端MAC地址信息。
<Sysname> display evpn route mac srv6
VSI name: vpnb
EVPN instance: -
 MAC address    : 68ba-0573-0606
  Link ID/Name  : 0x0
  Flags         : DL
  Encap         : SRv6
  Next hop      : -
  Type          : TE
  Color         : -
  Delete delay  : 110s
  SID           : 1::2
 MAC address    : 68ba-0b4f-0706
  Link ID/Name  : 0x9000000
  Flags         : B
  Encap         : SRv6
  Next hop      : 2::2
  Type          : TE
  Color         : -
  Delete delay  : 110s
  SID           : 1::3
# 显示EVPN的MAC地址表项数目。
<Sysname> display evpn route mac count
表1-27 display evpn route mac命令显示信息描述表
VSI name
VSI名称
EVPN instance
MAC address
MAC地址
Link ID/Name
Link ID表示路由表项的出链路标识符,即AC在VSI内的链路标识符
Name表示Tunnel接口名称
Flags
表项类型,取值包括:
·     D:表示存在动态学习的MAC地址表项
·     B:表示存在通过BGP EVPN路由学习的MAC地址表项
·     L:表示本地MAC地址表项生效,未设置该标志表示通过BGP EVPN路由学习的MAC地址表项生效
·     G:表示生效的MAC地址表项是网关的MAC地址表项
·     S:表示生效的MAC地址表项是静态配置的MAC地址表项
·     M:表示生效的MAC地址表项是来自映射的远端VXLAN的MAC地址表项
·     I:表示该MAC地址表项无效,原因如下:
¡     出方向Tunnel接口不存在
·     E:表示多归属成员同步的MAC地址表项
·     F:表示EVPN E-tree组网中从Leaf上学习到的MAC地址表项
Encap
报文封装类型,取值包括:
·     MPLS:报文封装类型为MPLS
·     SRv6:报文封装类型为SRv6
Nexthop
远端VTEP的地址,取值为“-”表示本地MAC
出接口类型,取值包括:
·     BE:表示SRv6 Best-Effort隧道
·     TE:表示SRv6 TE Policy隧道
MAC地址表项的总数
Color
MAC地址的Color属性值,如果MAC地址无Color属性,则显示为“-”。只有报文封装类型为SRv6时才显示该字段
Delete delay
收到撤销MAC/IP路由后,MAC地址表项的延迟删除时间,单位为秒;取值为“-”表示不延迟删除该MAC表项
SID
为MAC地址分配的SRv6 SID
display evpn route mac-mobility命令用来显示EVPN的MAC地址迁移信息。
display evpn route mac-mobility [ vsi vsi-name ] [ mac-address mac-address ]
vsi vsi-name:显示指定VSI的MAC地址迁移信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的MAC地址迁移信息。
mac-address mac-address:显示指定MAC地址的迁移信息。mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。如果不指定本参数,则显示VSI的所有MAC地址的迁移信息。
# 显示所有IPv4 EVPN的MAC地址迁移信息。
<Sysname> display evpn route mac-mobility
VSI name      : vsia
EVPN instance : -
  MAC address     Move count Moved from               Flags Suppressed at
  1000-0000-0000  10         XGE0/0/6                 S     15:30:30 2018/03/30
  1000-0000-0001  -          -                        N     -
VSI name      : vsib
EVPN instance : -
  1000-0000-0003  2          XGE0/0/7                 N     -
  1000-0000-0005  10         5.5.5.5                  S     17:24:33 2018/04/01
表1-28 display evpn route mac-mobility命令显示信息描述表
从本地迁移到远端站点的次数阈值
Detection cycle
检测周期,单位为秒
Suppression time
抑制恢复时间,单位为秒
VSI name
VSI名称
EVPN instance
MAC address
MAC地址
Move count
迁出次数
Moved from
表示MAC地址上一次迁移到的AC接口名称或所在VTEP/PE的IP地址
Flags
MAC地址是否被抑制迁移,取值包括:
·     S:表示抑制迁移
·     N:表示未抑制迁移
Suppressed at
迁移抑制发生的时间
·     evpn route mac-mobility suppression
display evpn route nd命令用来显示EVPN的ND表项信息。
display evpn route nd [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ ipv6 ipv6-address ] [ count ]
local:显示本地ND表项信息。
remote:显示远端ND表项信息。
public-instance:显示公网实例的ND表项信息。
vpn-instance vpn-instance-name:显示指定VPN实例的ND表项信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
ipv6 ipv6-address:显示指定IPv6地址的ND信息。ipv6-address表示IPv6地址。如果不指定本参数,则显示公网或VPN实例的所有ND信息。
count:显示ND表项的数目。如果不指定本参数,则显示ND表项的具体信息。
执行本命令时,如果没有指定localremote参数,则显示EVPN的本地和远端的ND表项信息。
执行本命令时,如果没有指定public-instancevpn-instance vpn-instance-name参数,则显示公网实例和所有VPN实例的ND表项信息。
# 显示所有EVPN的ND表项信息。
<Sysname> display evpn route nd
IPv6 address :   AD80:0300:1000:0050:0200:0300:0100:0012
MAC address  :   0001-0001-0001       Router MAC   :   a0ce-7e40-0400
VSI index    :   0                    Flags        :   GL
IPv6 address :   AD10:0300:1000:0020:0200:0300:0100:0022
MAC address  :   0001-0001-0002       Router MAC   :   a0ce-7e40-0411
Public instance                               Interface: Vsi-interface1
IPv6 address :   BC80:0300:1000:0050:0200:0300:0100:0033
MAC address  :   0002-0002-0001       Router MAC   :   a0ce-7e40-0422
IPv6 address :   BC10:0300:1000:0020:0200:0300:0100:0034
MAC address  :   0002-0002-0002       Router MAC   :   a0ce-7e40-0433
#显示EVPN的ND表项总数。
<Sysname>display evpn route nd count
表1-29 display evpn route nd命令显示信息描述表
VPN instance
VPN实例名称
Public instance
公网实例
VSI虚接口名称
IPv6 address
IPv6地址
MAC address
MAC地址
Router MAC
设备的Router MAC
VSI index
ND表项所属VSI的索引
Flags
ND表项类型,取值包括:
·     D:表示动态学习的ND表项
·     B:表示通过BGP EVPN路由学习的ND表项
·     L:表示本地ND表项生效,未设置该标志表示通过BGP EVPN路由学习的ND表项生效
·     G:表示生效的ND表项是网关的ND表项
·     S:表示生效的ND表项是静态配置的ND表项(暂不支持)
·     M:表示生效的ND表项是来自映射的远端VXLAN的ND表项
·     I:表示该ND表项无效,原因如下:
¡     出方向Tunnel接口不存在
ND表项的总数
display evpn route nd suppression命令用来显示EVPN的ND泛洪抑制信息。
display evpn route nd suppression [ local | remote ] [ vsi vsi-name ] [ ipv6 ipv6-address ] [ count ]
local:显示本地ND泛洪抑制信息。
remote:显示远端ND泛洪抑制信息。
vsi vsi-name:显示指定VSI的ND泛洪抑制信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的ND泛洪抑制信息。
ipv6 ipv6-address:显示指定IPv6地址的ND泛洪抑制信息。ipv6-address表示IPv6地址。如果不指定本参数,则显示公网或VPN实例的所有ND泛洪抑制信息。
count:显示ND泛洪抑制表项的数目。如果不指定本参数,则显示ND泛洪抑制表项的具体信息。
执行本命令时,如果没有指定localremote参数,则显示EVPN的本地和远端的ND泛洪抑制信息。
# 显示EVPN的所有ND泛洪抑制信息。
<Sysname> display evpn route nd suppression
VSI name: vpna
IPv6 address                            MAC address    Flags Encap
11::8                                   72cb-ce9b-0a06 DL    VXLAN
11::9                                   0001-0001-0001 B     VXLAN
# 显示EVPN的ND泛洪抑制表项总数。
<Sysname> display evpn route nd suppression count
表1-30 display evpn route nd suppression命令显示信息描述表
VSI name
VSI名称
IPv6 address
IPv6地址
MAC address
MAC地址
Flags
ND泛洪抑制表项类型,取值包括:
·     D:表示存在动态学习的ND泛洪抑制表项
·     B:表示存在通过BGP EVPN路由学习的ND泛洪抑制表项
·     L:表示本地ND泛洪抑制表项生效,未设置该标志表示通过BGP EVPN路由学习的ND泛洪抑制表项生效
·     G:表示生效的ND泛洪抑制表项是网关的ND表项
·     S:表示生效的ND泛洪抑制表项是静态配置的ND表项
·     M:表示生效的ND泛洪抑制表项是来自映射的远端VXLAN的ND表项
·     I:表示该ND表项无效,原因可能是:
¡     出方向Tunnel接口不存在
Encap
报文封装类型,取值包括:
·     MPLS:报文封装类型为MPLS
ND泛洪抑制表项的总数
display evpn route xconnect-group命令用来显示交叉连接的EVPN相关信息。
display evpn route xconnect-group [ name group-name [ connection connection-name ] ] [ count ]
name group-name:显示指定交叉连接组的EVPN相关信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有交叉连接组的EVPN相关信息。
connection connection-name:显示交叉连接组内指定交叉连接的EVPN相关信息。交叉连接的名称,为1~20个字符的字符串,不能包含字符“-”,区分大小写。如果未指定本参数,则显示指定交叉连接组内所有交叉连接的EVPN相关信息。
count:显示EVPN交叉连接的总数。如果不指定本参数,则显示交叉连接的EVPN的具体信息。
# 显示所有交叉连接的EVPN相关信息。
<Sysname> display evpn route xconnect-group
Ctrl Flags: P - Primary, B - Backup, C - Control word
Xconnect group name: aa
 Connection name: aaa
  Local service ID    : 16777215
  Remote service ID   : 16777214
  Control word        : Enabled
  In label            : 502
  Local MTU           : 1500
  AC state            : Up
  PW type             : VLAN
    Nexthop          ESI                       Out label  Flags  MTU    State
    192.123.123.123  0001.0002.0002.0002.0001  1299       PC     1500   Up
    192.1.1.1        0001.0002.0002.0002.0001  1026       B      1500   Down
 Connection name: aab
  Remote service ID   : 2
  Control word        : Disabled
  In label            : 323
  Local MTU           : 1500
  AC state            : Up
  PW type             : VLAN
    192.1.1.1        0002.0002.0002.0002.0001  1234       P      1500   Up
    192.2.1.2        0002.0002.0002.0002.0001  603        P      1500   Up
 Connection name: aac
  Local service ID    : 3
  Remote service ID   : 4
  In label            : -
  Local MTU           : 1500
  AC state            : Up
  PW type             : Ethernet
    192.1.1.3        0000.0000.0000.0000.0000  555        P      1500   Idle
 Connection name: pw1
  Encapsulation       : SRv6
  In SID[DX2]         : 100::1
  In SID[DX2L]        : -
  Local MTU           : 1500
  AC State            : Up
  SRv6 Tunnel:
    Next Hop          : 2::2
    Out SID           : 200::1
    Flags             : P
    MTU               : 1500
    State             : Up
# 显示EVPN交叉连接的总数。
<Sysname> display evpn route xconnect-group count
表1-31 display evpn route xconnect-group命令显示信息描述表
Xconnect group name
交叉连接组名称
Connection name
交叉连接名称
Encapsulation
EVPN的封装类型,取值包括:
ESI
ES标识符
Local service ID
本地服务ID
Remote service ID
远端服务ID
Control word
是否开启控制字功能取值包括:
·     Enabled:PW开启控制字功能
In label
PW的入标签
Local MTU
本地配置的最大传输单元,单位为字节
AC state
当前AC的状态,取值包括Up、Down和“-”。其中,“-”表示未配置AC
PW type
PW的数据封装类型,取值包括Ethernet和VLAN
Nexthop
远端PE的地址
Out label
PW的出标签
Flags
PW属性标记,取值包括:
·     P:接收到的路由携带了Primary标识,需要建立主PW
·     B:接收到的路由携带了Backup标识,需要建立备份PW
·     C:接收到的路由中携带控制字标识,表示对端开启控制字功能,若本地使能控制字功能,则使EVPN PW处于UP状态,否则EVPN PW无法UP
MTU
接收到的路由中携带的最大传输单元,单位为字节
EVPN PW的状态,取值包括:
·     Up:表示协议状态Up
·     Down:表示协议状态Down
·     Idle:表示入或出标签不可用
In SID[DX2]
End.DX2类型的入SID
In SID[DX2L]
End.DX2L类型的入SID
SRv6 Tunnel
SRv6隧道信息
Out SID
出SID
EVPN PW和SRv6隧道的总数
display evpn routing-table命令用来显示EVPN的路由表信息。
display evpn routing-table [ ipv6 ] { public-instance | vpn-instance vpn-instance-name } [ count ]
ipv6:显示EVPN的IPv6路由表信息。如果不指定本参数,则显示EVPN的IPv4路由表信息。
public-instance:显示公网实例的路由信息。
vpn-instance vpn-instance-name:显示指定VPN实例的路由信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
count:显示路由表项的数目。如果不指定本参数,则显示路由表项的具体信息。
# EVPN分布式网关组网中,显示VPN实例vpn1对应EVPN的IPv4路由信息。
<Sysname> display evpn routing-table vpn-instance vpn1
Flags: E - with valid ESI   A – A-D ready   L - Local ES exists
VPN instance name: vpn1                             Local L3VNI: 7
IP address         Nexthop            Outgoing interface       NibID       Flags
10.1.1.11          1.1.1.1            Vsi-interface3           0x18000000  -
10.1.1.12          2.2.2.2            Vsi-interface3           0x18000001  -
# SRv6分布式网关组网中,显示VPN实例vpnb对应EVPN的IPv4路由信息。
<Sysname> display evpn routing-table vpn-instance vpnb
VPN instance: vpnb
Local SID   : BC10:0300:1000:0020:0200:0300:0100:0034
IP address          :      10.0.0.2
Nexthop             :      BC10:0300:1000:0020:0200:0300:0100:0035
NibID               :      0x18000000
Flags               :      EA
Remote SID          :      BC10:0300:1000:0020:0200:0300:0100:0034
# EVPN分布式网关组网中,显示公网实例的EVPN IPv4路由信息。
<Sysname> display evpn routing-table public-instance
Public instance                                     Local L3VNI: 3900
# 显示VPN实例vpn1对应的EVPN的IPv4路由表项总数。
<Sysname> display evpn routing-table vpn-instance vpn1 count
# EVPN分布式网关组网中,显示VPN实例vpna对应的EVPN的IPv6路由信息。
<Sysname> display evpn routing-table ipv6 vpn-instance vpna
VPN instance: vpna                              Local L3VNI: 7
Outgoing interface  :      Vsi-interface3
Next hop            :      1.1.1.1
NibID               :      0x18000000
Flags               :      E
IPv6 address        :      BC10:0300:1000:0020:0200:0300:0100:0035
Next hop            :      2.2.2.2
NibID               :      0x18000001
Flags               :      E
表1-32 display evpn routing-table命令显示信息描述表
VPN instance name
VPN实例名称
Public instance
公网实例
Local L3VNI
与VPN实例或公网实例关联的L3VNI
IP address
目的IPv4地址
IPv6 address
目的IPv6地址
Nexthop
下一跳地址
Outgoing interface
出接口
NibID
下一跳ID
Local SID
本地SRv6分布式网关的SID
Remote SID
远端SRv6分布式网关的SID
Flags
路由表项等价属性,取值包括:
·     E:即with valid ESI,表示路由携带了有效的ESI字段
·     A:即A-D ready,表示1类路由接收完全,可以下发该下一跳对应的等价路径
·     L:即Local ES exists,表示本地有激活的ESI,不下发远端路由表项
路由表项的总数
display l2vpn forwarding evpn命令用来显示EVPN VPLS/VPWS和EVPN VPLS/VPWS over SRv6的转发信息。
display l2vpn forwarding evpn [ vsi [ name vsi-name ] [ verbose ] ] slot slot-number
vsi显示VSI下的EVPN的转发信息。不指定本参数时,显示所有关联EVPN的VSI和交叉连接的转发信息。
name vsi-name:显示指定VSI下的EVPN的转发信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI下的EVPN的信息。
verbose:显示指定VSI下的EVPN的详细信息。如果不指定本参数,则显示VSI下的EVPN的简要信息。
slot slot-number:指定单板。slot-number为单板所在的槽位号。
# 显示EVPN VPLS组网中slot 1上所有EVPN的简要转发信息。
<Sysname> display l2vpn forwarding evpn vsi slot 1
Total number of VSIs: 2
VSI name                       VSI index
vpls1                          0
表1-33 display l2vpn forwarding evpn命令显示信息描述表
VSI的总数
VSI name
VSI名称
VSI index
VSI索引
# 显示EVPN VPLS组网中slot 1上所有EVPN的详细转发信息。
<Sysname> display l2vpn forwarding evpn vsi verbose slot 1
VSI name: vpls1
  VSI index                         : 0
  MPLS label                        : 1150
  IMET MPLS label                   : 1149
  Control word                      : enabled
  PW type                           : Ethernet
  Sequencing                        : Both
  Flow label                        : Both
表1-34 display l2vpn forwarding evpn verbose命令显示信息描述表
VSI name
VSI名称
VSI index
VSI索引
Encapsulation
封装类型,取值包括:
·     MPLS:表示MPLS封装
·     SRv6:表示SRv6封装
MPLS label
MAC/IP发布路由携带的MPLS标签
IMET MPLS label
IMET路由携带的MPLS标签
Control word
是否开启控制字功能,取值包括:
·     enabled:PW开启控制字功能
·     disabled:PW关闭控制字功能
PW type
PW类型,取值包括:
·     Ethernet:以太网类型
·     VLAN:VLAN类型
Sequencing
PW的排序处理,取值包括:
Flow label
流标签能力,取值包括:
·     Both:具有发送和接收能力
·     Send:具有发送能力
·     Recv:具有接收能力
·     -:未开启流标签能力
Dt2u SID
用于转发单播报文的SRv6 SID
Dt2ul SID
Dt2m SID
用于转发组播报文的SRv6 SID
·     vsi
display l2vpn forwarding evpn split-horizon命令用来显示EVPN多归属组网中满足水平分割原则的接口信息。
display l2vpn forwarding evpn split-horizon { ac interface interface-type interface-number | ac interface interface-type interface-number service-instance instance-id | tunnel tunnel-number } [ slot slot-number ]
ac interface interface-type interface-number:显示EVPN VPLS多归属组网中AC接口的水平分割信息,即从指定AC收到的泛洪流量不会转发到哪些AC。interface-type interface-number为三层接口的接口类型和接口编号。
ac interface interface-type interface-number service-instance instance-id:显示EVPN VPLS多归属组网中AC接口的水平分割信息,即从指定AC收到的泛洪流量不会转发到哪些AC。interface-type interface-number为二层接口的接口类型和接口编号;service-instance instance-id为二层接口下配置的以太网服务实例,instance-id为以太网服务实例的编号,取值范围为1~4096。
tunnel tunnel-number:显示EVPN VXLAN组网中VXLAN隧道的水平分割信息,即从指定VXLAN隧道接收到的泛洪流量不会转发到哪些AC。tunnel-number为VXLAN隧道接口的编号,取值范围为0~20479。如果未指定本参数,则显示EVPN多归属组网中所有满足水平分割原则的接口信息。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。
# 显示从Tunnel 0上收到的泛洪流量中满足水平分割原则的接口信息。
<Sysname> display l2vpn forwarding evpn split-horizon tunnel 0
Tunnel name: 0
  Total number of filtered interfaces: 2
  Filtered interfaces:
    XGE0/0/6
    XGE0/0/7
# EVPN VPLS组网中显示AC接口Ten-GigabitEthernet0/0/6的水平分割信息。
<Sysname> display l2vpn forwarding evpn split-horizon ac interface ten-gigabitethernet 0/0/6
Interface name  : Ten-GigabitEthernet0/0/6
AC link ID              : 0
Service instance ID     : 100
PW count                : 2
VSI name        PW link ID         ESI label
vpna            8                  775128
vpna            9                  775128
# EVPN VPLS over SRv6组网中显示AC接口Ten-GigabitEthernet0/0/6的水平分割信息。
AC link ID              : 0
SRv6 tunnel count       : 2
VSI name        SRv6 link ID       Argument
vpna            0x8                ::1
vpna            0x9                ::1
表1-35 display l2vpn forwarding evpn split-horizon命令显示信息描述表
Tunnel name
VXLAN隧道接口名称
Filtered interfaces
从指定VXLAN隧道接收到的泛洪流量在该设备上不能转发的接口
Interface name
接口名称
AC link ID
AC的链路标识符
Service instance ID
以太网服务实例编号
PW count
PW的数量
SRv6 tunnel count
SRv6隧道的数量
VSI name
VSI名称
PW link ID
PW的链路标识符
SRv6 link ID
SRv6隧道的链路标识符
ESI label
ESI标签
Argument
当无Argument时显示为“-”
1.1.26  evpn encapsulation
evpn encapsulation命令用来创建EVPN实例,并进入EVPN实例视图。如果EVPN实例已经存在,则直接进入EVPN实例视图。
undo evpn encapsulation命令用来恢复缺省情况。
VSI视图:
evpn encapsulation { mpls | vxlan }
交叉连接组视图:
evpn encapsulation mpls
不存在EVPN实例。
VSI视图
交叉连接组视图
mpls:表示EVPN采用MPLS封装方式。
vxlan:表示EVPN采用VXLAN封装方式。
只有创建EVPN实例后,才能进行EVPN相关配置。
本命令与evpn encapsulation binding instance命令互斥,即通过本命令在VSI下创建EVPN实例后,不能在该VSI下通过evpn encapsulation binding instance命令将该VSI与其它EVPN实例关联;反之亦然。
# 创建EVPN实例,并进入VSI实例下的EVPN实例视图。
[Sysname] vsi aaa
1.1.27  evpn encapsulation binding instance
evpn encapsulation binding instance命令用来配置VSI与指定EVPN实例关联。
undo evpn encapsulation binding instance命令用来恢复缺省情况。
evpn encapsulation mpls binding instance instance-name [ vsi-tag tag-id ]
undo evpn encapsulation mpls binding instance instance-name
evpn encapsulation vxlan binding instance instance-name [ vsi-tag { tag-id | auto-vxlan } ]
undo evpn encapsulation vxlan binding instance instance-name
VSI实例视图
VSI未关联EVPN实例。
instance-name:VSI关联的EVPN实例名称,为1~31个字符的字符串,区分大小写。
vsi-tag:指定VSI实例的Tag ID。多个VSI关联同一个EVPN实例时,可以通过Tag ID来区分不同的VSI。如果未指定本参数,则表示VSI实例的Tag ID为0。
tag-id:手动指定VSI实例的Tag ID值。采用VXLAN封装时,取值范围为1~16777215;采用MPLS封装时,取值范围为1~4094。
auto-vxlan:表示VSI实例的Tag ID根据VXLAN ID自动生成。
本命令仅用于EVPN VXLAN和EVPN VPLS组网。
一个VSI实例可以关联一个或者两个EVPN实例。关联两个EVPN实例时,其中一个EVPN实例的封装类型必须为MPLS,另一个EVPN实例的封装类型必须为VXLAN。
本命令与evpn encapsulation命令互斥,即通过本命令将VSI与指定EVPN实例关联后,不能在该VSI下通过evpn encapsulation命令创建EVPN实例;反之亦然。
# 配置VSI实例vpna与EVPN实例evpna关联。
[Sysname] vsi vpna
[Sysname-vsi-vpna] evpn encapsulation vxlan binding instance evpna vsi-tag auto-vxlan
·     evpn instance
1.1.28  evpn global-mac
evpn global-mac命令用来配置EVPN的全局MAC地址。
undo evpn global-mac命令用来恢复缺省情况。
evpn global-mac mac-address
未配置EVPN的全局MAC地址。
mac-address:MAC地址,形式为H-H-H,不能配置为全0、广播MAC地址和组播MAC地址。
本命令配置的全局MAC地址仅用于承载L3VNI的VSI虚接口。
如果承载L3VNI的VSI虚接口上通过mac-address命令配置了MAC地址,则VSI虚接口的MAC地址为该地址;否则,VSI虚接口的MAC地址为evpn global-mac命令配置的全局MAC地址。
本命令配置的全局MAC地址不能与设备的预留MAC地址相同。预留MAC地址的取值与设备型号有关,请以设备的实际情况为准。
# 配置EVPN的全局MAC地址为0001-0001-0001。
[Sysname] evpn global-mac 1-1-1
1.1.29  evpn df-election algorithm (interface view)
evpn df-election algorithm命令用来配置DF选举算法。
undo evpn df-election algorithm命令用来恢复缺省情况。
evpn df-election algorithm algorithm
以系统视图下配置的DF选举算法为准。
algorithm:指定DF选举算法。当前仅支持取值preference,表示基于优先级的DF选举算法。
在EVPN多归属组网中,如果用户希望通过更加灵活地方式控制DF选举,则可以配置本命令修改DF选举算法。
接口视图和系统视图下均可以配置DF选举算法。系统视图的配置对所有ES都有效,而接口视图下的配置只对当前接口下的ES有效。对于一个ES来说,优先采用该接口视图下的配置,只有该接口下未进行配置时,才采用系统视图的配置。
# 在接口Ten-GigabitEthernet0/0/6上配置基于优先级的DF选举算法。
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] evpn df-election algorithm preference
·     evpn df-election algorithm (system view)
·     evpn df-election preference
1.1.30  evpn df-election algorithm (system view)
evpn df-election algorithm命令用来全局配置DF选举算法。
采用基于VLAN Tag的DF选举算法。
系统视图和接口视图下均可以配置DF选举算法。系统视图的配置对所有ES都有效,而接口视图下的配置只对当前接口下的ES有效。对于一个ES来说,优先采用该接口视图下的配置,只有该接口下未进行配置时,才采用系统视图的配置。
# 全局配置基于优先级的DF选举算法。
[Sysname] evpn df-election algorithm preference
·     evpn df-election algorithm (interface view)
1.1.31  evpn df-election preference
evpn df-election preference命令用来配置DF选举优先级。
undo evpn df-election preference命令用来恢复缺省情况。
evpn df-election preference preference
DF选举优先级为32767。
preference:指定DF选举优先级,取值范围为0~65535。优先级数值越大则优先级越高。
在EVPN多归属组网中,若采用了基于优先级的DF选举算法,则可以通过本命令配置DF选举优先级来控制DF的选举。DF优先级最高的设备将选举为DF。
只有在接口视图或系统视图下执行evpn df-election algorithm preference命令后,本命令配置的优先级才会生效。
# 配置DF选举优先级为100。
[Sysname-Ten-GigabitEthernet0/0/6] evpn df-election preference 100
1.1.32  evpn df-election preference non-revertive
evpn df-election preference non-revertive命令用来开启基于优先级DF选举算法的不回切功能。
undo evpn df-election preference non-revertive命令用来关闭基于优先级DF选举算法的不回切功能。
基于优先级算法的DF选举不回切功能处于关闭状态。
配置基于优先级的DF选举算法后,优先级最高的设备被选举为DF进行流量转发。
如用户通过多归属接入VTEP 1和VTEP 2,VTEP 1的DF选举优先级为200,VTEP 2的DF选举优先级为100,则VTEP 1被选举为DF。若出现如下情况则会重新选举VTEP 2作为DF:
·     VTEP 1设备故障。
·     用户接入VTEP 1的链路故障。
·     在VTEP 2上配置了比VTEP 1更高的DF选举优先级。
若在VTEP 2被选举为DF后,VTEP 1故障恢复、用户接入VTEP 1的链路故障恢复或者VTEP 1上配置了高于VTEP 2上的DF选举优先级,则又会重新选举VTEP 1作为DF。如果此时将DF切换为VTEP 1,则会造成一些不必要的丢包。在VTEP 2上配置本功能,可以避免DF回切为VTEP 1,减少丢包。
只有在接口视图或系统视图下执行evpn df-election algorithm preference命令后,本命令才会生效。
# 开启基于优先级DF选举算法的不回切功能。
[Sysname-Ten-GigabitEthernet0/0/6] evpn df-election preference non-revertive
1.1.33  evpn frr remote
evpn frr remote enable命令用来开启指定EVPN实例的主备PW功能。
evpn frr remote disable命令用来关闭指定EVPN实例的主备PW功能,同时删除已经建立的备PW。
undo evpn frr remote命令用来恢复缺省情况。
evpn frr remote [ disable | enable ]
EVPN实例的主备PW功能状态与EVPN VPWS全局主备PW功能状态保持一致。
交叉连接组EVPN实例视图
EVPN VPWS和EVPN VPWS over SRv6组网中,通过本命令开启主备PW功能后,PE间将建立主备两条PW,实现当主PW出现故障后,将流量立即切换到备份PW,使得流量转发得以继续。
MPLS封装和SRv6封装的交叉连接组EVPN实例均支持本命令。
如果同时执行了本命令和evpn vpws-frr remote命令,则当前EVPN实例的主备PW功能状态以本命令的配置为准。
# 开启交叉连接组xcga的EVPN实例的主备PW功能。
[Sysname] xconnect-group xcga
[Sysname-xcg-xcga] evpn encapsulation mpls
[Sysname-xcg-xcga-evpn-mpls] evpn frr remote enable
·     evpn vpws-frr remote
1.1.34  evpn instance
evpn instance命令用来创建EVPN实例,并进入EVPN实例视图。如果指定的EVPN实例已经存在,则直接进入EVPN实例视图。
undo evpn instance命令用来删除指定的EVPN实例。
evpn instance instance-name
undo evpn instance instance-name
不存在EVPN实例。
instance-name:EVPN实例名称,为1~31个字符的字符串,区分大小写。
系统视图下创建EVPN实例后,不同的VSI均可以关联该EVPN实例,无需在各个VSI下重复配置相同的EVPN实例,以简化配置。
# 系统视图下创建一个名为evpn1的EVPN实例,并进入EVPN实例视图。
[Sysname] evpn instance evpn1
[Sysname-evpn-instance-evpn1]
1.1.35  evpn irb asymmetric
evpn irb asymmetric命令用来配置EVPN VXLAN采用非对称IRB方式转发流量。
undo evpn irb asymmetric命令用来恢复缺省情况。
evpn irb asymmetric [ route-policy route-policy-name ]
EVPN VXLAN采用对称IRB方式转发流量。
route-policy route-policy-name:指定通过路由策略过滤的流量采用非对称IRB方式转发。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。不指定本参数或指定的路由策略不存在时,所有流量均通过非对称IRB方式转发。
EVPN VXLAN支持对称IRB和非对称IRB两种流量转发方式,通过本命令可以修改流量转发方式。
# 配置EVPN VXLAN采用非对称IRB方式转发流量。
[Sysname] evpn irb asymmetric
1.1.36  evpn mac-ip advertise distributed-gateway
evpn mac-ip advertise distributed-gateway命令用来开启通过MAC/IP发布路由通告分布式网关ARP信息的功能。
undo evpn mac-ip advertise distributed-gateway命令用来关闭通过MAC/IP发布路由通告分布式网关ARP信息的功能。
通过MAC/IP发布路由通告分布式网关ARP信息的功能处于关闭状态。
在EVPN分布式网关下行连接VTEP的组网中,分布式网关通过IP前缀路由通告网关的ARP信息。VTEP设备上由于不存在网关配置而无法学习到网关的ARP信息,导致其不能将流量转发到网关设备。此时,可以在分布式网关设备上开启本功能,使得该网关通过MAC/IP发布路由通告分布式网关的ARP信息(即作为分布式网关的VSI虚接口的IP地址和MAC地址),使VTEP学习到网关的ARP信息。
# 开启通过MAC/IP发布路由通告分布式网关ARP信息的功能。
[Sysname] evpn mac-ip advertise distributed-gateway
1.1.37  evpn mpls routing-enable
evpn mpls routing-enable命令用来开启EVPN通告VPN路由功能。
undo evpn mpls routing-enable命令用来关闭EVPN通告VPN路由功能。
EVPN通告VPN路由功能处于关闭状态。
VPN实例IPv4地址族视图
VPN实例IPv6地址族视图
开启本功能后,VPN路由表中的VPN路由会作为EVPN的IP前缀路由发布给邻居;当收到邻居发送的MPLS封装的IP前缀路由时,会将其插入到相应的VPN路由表中。
本功能需要与向对等体/对等体组发布MPLS封装的IP前缀路由功能配合使用,即在配置本功能后还需要在BGP EVPN地址族视图下执行命令peer advertise encap-type mpls配置向对等体/对等体组发布MPLS封装的IP前缀路由功能。
# 在VPN实例vpna的IPv4地址族视图下使能EVPN通告VPN路由功能。
[Sysname-vpn-instance-vpna] address-family ipv4
[Sysname-vpn-ipv4-vpna] evpn mpls routing-enable
1.1.38  evpn multihoming advertise ignore-ethernet-tag
evpn multihoming advertise ignore-ethernet-tag命令用来配置发布以太网自动发现路由和MAC/IP发布路由时忽略以太网标签。
undo evpn multihoming advertise ignore-ethernet-tag命令用来恢复缺省情况。
EVPN多归属组网中,PE发送以太网自动发现路由和MAC/IP发布路由时携带以太网标签。
本命令需要配置在冗余备份组成员PE上。
多归属站点组网中,为冗余备份组成员上的AC配置ESI后,冗余备份组成员发送以太网自动发现路由和MAC/IP发布路由时会携带AC的以太网标签。如果对端设备无法识别以太网标签,为了与该对端设备互通,需要在本端设备上配置本命令,使得本端设备将发送的以太网自动发现路由和MAC/IP发布路由中的以太网标签字段填为0。
执行本命令后,设备会撤销已经发布的以太网自动发现路由和MAC/IP发布路由,并重新发布以太网标签字段为0的以太网自动发现路由和MAC/IP发布路由。
执行本命令时,需要注意的是:
·     为二层以太网接口或二层聚合接口配置ESI后,同一个接口上创建的不同以太网服务实例不能关联相同的VSI,具有相同ESI的接口上的以太网服务实例也不能关联相同的VSI。
·     为三层主接口配置ESI后,如果该接口上的子接口未配置ESI,则子接口会继承主接口的ESI。此时,具有相同ESI的子接口不能关联相同的VSI。
# 配置发布以太网自动发现路由和MAC/IP发布路由时忽略以太网标签。
[Sysname] evpn multihoming advertise ignore-ethernet-tag
·     esi
1.1.39  evpn route arp-mobility suppression
evpn route arp-mobility suppression命令用来开启ARP反复迁移抑制功能。
undo evpn route arp-mobility suppression命令用来关闭ARP反复迁移抑制功能。
evpn route arp-mobility suppression [ detect-cycle detect-time | detect-threshold move-times | suppression-time [ suppression-time | permanent ] ] *
ARP反复迁移抑制功能处于关闭状态。
detect-cycle detect-time:指定ARP迁移的检测周期。detect-time取值范围为60~900,单位为秒,缺省值为180。
detect-threshold move-times:指定从本地迁移到远端站点的次数阈值。move-times取值范围为3~10,缺省值为5。
suppression-time:指定ARP迁移抑制功能的抑制恢复时间。被抑制的ARP表项在抑制恢复时间超时后,会从抑制状态恢复为正常状态,可以正常迁移。缺省取值为permanent,即不会恢复被抑制的ARP表项,永远抑制。
suppression-time:抑制恢复时间,取值范围为120~3600,单位为秒。
permanent:不会恢复被抑制的ARP表项,永远抑制。
EVPN VXLAN组网中,不同VTEP下的设备如果错误地配置了相同的IP地址,会造成VTEP间不断同步ARP信息,并更新本地EVPN的ARP表项信息,此时VTEP认为该设备在不断迁移。这种情况可能会使VTEP间形成环路,占用大量的链路带宽。开启本功能后,若检测周期内某ARP信息从本地迁移到远端的次数超过阈值,则抑制最后一次由远端向本地迁移,即仅本地学习但不对外通告该ARP信息,避免VTEP间形成环路。
执行undo evpn route arp-mobility suppression命令或ARP表项的抑制时间超过抑制恢复时间时,如果VTEP上被抑制迁移的ARP表项未老化,则立即向远端通告该ARP信息;如果VTEP上被抑制迁移的ARP表项已经老化,则VTEP重新从本地学习该ARP信息后再对外通告。
ARP反复迁移抑制功能仅在EVPN VXLAN分布式网关组网中生效。
# 开启ARP反复迁移抑制功能。
[Sysname] evpn route arp-mobility suppression
·     display evpn route arp-mobility
1.1.40  evpn route mac-mobility suppression
evpn route mac-mobility suppression命令用来开启MAC地址反复迁移抑制功能。
undo evpn route mac-mobility suppression命令用来关闭MAC地址反复迁移抑制功能。
evpn route mac-mobility suppression [ detect-cycle detect-time | detect-threshold  move-times | suppression-time [ suppression-time | permanent ] ] *
MAC地址反复迁移抑制功能处于关闭状态。
detect-cycle detect-time:指定MAC地址迁移的检测周期。detect-time取值范围为60~900,单位为秒,缺省值为180。
suppression-time:指定MAC迁移抑制功能的抑制恢复时间。被抑制的MAC地址在抑制恢复时间超时后,会从抑制状态恢复为正常状态,可以正常迁移。缺省取值为permanent,即不会恢复被抑制的MAC地址,永远抑制。
permanent:不会恢复被抑制的MAC地址,永远抑制。
EVPN VXLAN或EVPN VPLS组网中,不同VTEP或PE下的设备如果错误地配置了相同的MAC地址,会造成VTEP或PE间不断同步MAC地址信息,并更新本地EVPN的MAC地址表项。此时VTEP或PE认为该设备在不断迁移。这种情况可能会使VTEP或PE间形成环路,占用大量的链路带宽。开启本功能后,若在检测周期内某MAC地址从本地迁移到远端的次数超过阈值,则抑制最后一次由远端向本地迁移,即仅本地学习但不对外通告该MAC地址,避免VTEP或PE间形成环路。
执行undo evpn route mac-mobility suppression命令或MAC地址的抑制时间超过抑制恢复时间时,如果VTEP或PE上被抑制迁移的MAC地址未老化,则立即向远端通告该MAC地址;如果VTEP或PE上被抑制迁移的MAC地址已经老化,则VTEP或PE重新从本地学习该MAC地址后再对外通告。
# 开启MAC地址反复迁移抑制功能。
[Sysname] evpn route mac-mobility suppression
·     display evpn route mac-mobility
1.1.41  evpn span-segment disable
evpn span-segment disable命令用来禁止集中式EVPN网关跨网段学习MAC/IP发布路由中的ARP或ND信息。
undo evpn span-segment disable命令用来恢复缺省情况。
evpn span-segment { arp-learning | nd-learning } disable
undo evpn span-segment { arp-learning | nd-learning } disable
集中式EVPN网关可以跨网段学习MAC/IP发布路由中的ARP和ND信息。
VSI虚接口视图
arp-learning:禁止集中式EVPN网关跨网段学习MAC/IP发布路由中的ARP信息。
nd-learning:禁止集中式EVPN网关跨网段学习MAC/IP发布路由中的ND信息。
集中式EVPN网关组网中,虚拟机VM 1和VM 2属于同一VXLAN,所属网段为10.1.1.0/24,VSI虚接口1为该VXLAN的网关接口,网关连接的外部三层网络为10.1.2.0/24。若连接VM 2的VTEP上配置了ARP/ND泛洪抑制功能,则VM 2的地址错误地配置为10.1.2.0/24网段的地址(如10.1.2.2)时,连接VM 2的VTEP会向网关发送携带ARP/ND信息(IP为10.1.2.2,MAC为VM 2的MAC)的MAC/IP发布路由,网关会学习该ARP/ND并下发到转发表。这种情况下,若VM 1访问外部网络中的10.1.2.2,则网关会将流量转发至VM 2,造成VM 1无法访问10.1.2.2。
为解决上述问题,可在网关虚接口上配置本命令,禁止网关跨网段学习MAC/IP发布路由中的ARP/ND信息。
# 禁止集中式EVPN网关跨网段学习MAC/IP发布路由中的ARP信息。
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] evpn span-segment arp-learning disable
1.1.42  evpn timer ad-delay
evpn timer ad-delay命令用来开启以太网自动发现路由延迟发布功能,并指定延迟发布时间。
undo evpn timer ad-delay命令用来关闭以太网自动发现路由延迟发布功能。
evpn timer ad-delay delay-time
以太网自动发现路由延迟发布功能处于关闭状态,即不延迟发布以太网自动发现路由。
delay-time:以太网自动发现路由延迟发布时间,取值范围3~1200,单位为秒。
EVPN VPLS组网中,CE 1通过聚合口或S-trunk双归属多活接入PE 1和PE 2,PE 3为远端PE连接CE 2。CE 1选择PE 1侧发送流量至CE 2,CE 2通过PE 1和PE 2两侧均可将流量转发至CE 1。PE 1重启后,在PE 2发送MAC/IP发布路由同步CE 1的MAC地址之前,PE 1先发送携带下一跳信息的以太网自动发现路由至PE 3,导致PE 3查找CE 1的MAC地址转发流量时会将流量转发给PE 1和PE 2,此时PE 1未学习到CE 1的MAC地址,报文会被丢弃。
为解决上述问题,可在PE 1的AC接口上配置本功能,延迟发布以太网自动发现路由,使PE 1先学习到CE 1的MAC地址,再发布以太网自动发现路由,减少丢包。
# 接口Ten-GigabitEthernet0/0/6下配置以太网自动发现路由发布的延迟时间为300秒。
[Sysname-Ten-GigabitEthernet0/0/6] evpn timer ad-delay 300
1.1.43  evpn timer es-delay
evpn timer es-delay命令用来开启以太网段路由延迟发布功能,并指定延迟发布时间。
undo evpn timer es-delay命令用来关闭以太网段路由延迟发布功能。
evpn timer es-delay delay-time
以太网段路由延迟发布功能处于关闭状态,即不延迟发布以太网段路由。
delay-time:以太网段路由延迟发布时间,取值范围3~1200,单位为秒。
本命令通常与evpn track peer命令配合使用。
在多归属组网中,冗余备份组的一台成员设备因故障等原因重启后,站点间的广播流量转发可能会失败。为了解决这个问题,可以在成员设备连接CE的接口上配置evpn track peer命令。如果通过本命令开启了以太网段路由延迟发布功能,则当成员设备从故障中恢复且连接CE的接口状态变为Up时,成员设备会启动以太网段路由的延迟发送定时器,并对指定BGP邻居状态进行监控。如果在定时器超时前,所有设备的BGP邻居状态均Up,则本地成员设备正常发送以太网段路由;否则,定时器超时后,本地成员设备向所有BGP邻居状态为Up的设备发送以太网段路由。定时器超时或所有监控的BGP邻居均Up后,本地成员设备根据收到的所有以太网段路由进行DF选举。
# 接口Ten-GigabitEthernet0/0/6下配置以太网段路由发布的延迟时间为300秒。
[Sysname-Ten-GigabitEthernet0/0/6] evpn timer es-delay 300
·     evpn track peer
1.1.44  evpn track bfd
evpn track bfd命令用来配置BDF监测静态BFD会话状态。当DF侧AC故障导致静态BFD会话状态为down时,BDF快速切换为DF。
undo evpn track bfd命令用来恢复缺省情况。
evpn track bfd session-name
undo evpn track bfd
BDF未监测静态BFD会话状态。
三层以太网接口视图
三层聚合接口视图
FlexE业务接口视图
session-name:静态BFD会话的名称,为1~15个字符的字符串,区分大小写。
EVPN VPWS多归属组网中,当DF侧的AC故障时,BDF无法快速切换为DF并转发流量,导致DF切换过程中丢包。为解决上述问题,可在DF与BDF间创建静态BFD会话,在DF上配置静态BFD会话监测本地AC接口的状态,并在BDF上配置本命令监测静态BFD会话状态,从而实现当DF侧AC故障时,DF上的静态BFD会话状态变为down,并将静态BFD会话状态通告给BDF,BDF快速切换为DF,从而缩短DF的切换时间,减少丢包。
不能通过重复执行evpn track bfd命令修改BDF监测的静态BFD会话。如需修改,请先通过undo evpn track bfd命令取消BDF监测静态BFD会话,再执行evpn track bfd命令配置BDF监测其它的静态BFD会话。
# 配置BDF上的接口Ten-GigabitEthernet0/0/6监测静态BFD会话abc。
[Sysname-Ten-GigabitEthernet0/0/6] evpn track bfd abc
·     bfd static(可靠性命令参考/BFD)
1.1.45  evpn track peer
evpn track peer命令用来在多归属组网中,配置冗余备份组中的成员设备监视其它VTEP/PE设备的BGP邻居状态。
undo evpn track peer命令用来取消监视其它VTEP/PE设备的BGP邻居状态。
evpn track peer { peer-ipv4-address | peer-ipv6-address }
undo evpn track peer peer-address
在多归属组网中,冗余备份组中的成员设备不会监视其它设备的BGP邻居状态。
peer-ipv4-address:VTEP/PE的IPv4地址。
peer-ipv6-address:VTEP/PE的IPv6地址。
在多归属组网中,冗余备份组的一台成员设备因故障等原因重启后,站点间的广播流量转发可能会失败。为了解决这个问题,可以在成员设备连接CE的接口上配置evpn track peer命令。这样,当成员设备从故障中恢复且连接CE的接口状态变为Up时,成员设备会启动以太网段路由的延迟发送定时器,并对本命令指定的BGP邻居状态进行监控。如果在定时器超时前,所有设备的BGP邻居状态均Up,则本地成员设备正常发送以太网段路由;否则,定时器超时后,本地成员设备向所有BGP邻居状态为Up的设备发送以太网段路由。定时器超时或所有监控的BGP邻居均Up后,本地成员设备根据收到的所有以太网段路由进行DF选举。
# 在接口Ten-GigabitEthernet0/0/6上配置本地成员设备监视设备1.1.1.1的BGP邻居状态。
[Sysname-Ten-GigabitEthernet0/0/6] evpn track peer 1.1.1.1
·     evpn timer es-delay
1.1.46  export route-policy
export route-policy命令用来配置EVPN的出方向路由策略。
undo export route-policy命令用来恢复缺省情况。
未配置EVPN的出方向路由策略,即不对发布的路由进行过滤。
EVPN实例视图
VSI实例下的EVPN实例视图
交叉连接组EVPN实例视图
VPN实例EVPN视图
route-policy:出方向路由策略名称,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了EVPN的出方向路由策略,则EVPN实例/VPN实例向BGP EVPN协议发布路由时,将利用指定的路由策略对发布的路由进行过滤、改变发布路由的属性等。使用本命令可以更加精确、灵活地控制路由的发布。
在同一视图下,多次执行本命令,最后一次执行的命令生效。
EVPN实例视图、VSI实例下的EVPN实例视图、交叉连接组EVPN实例视图、VPN实例视图和VPN实例EVPN视图下配置的出方向路由策略均能用来过滤EVPN路由。其中:
·     EVPN实例视图、VSI实例下的EVPN实例视图、交叉连接组EVPN实例视图下的配置用于EVPN二层转发场景。
·     VPN实例视图和VPN实例EVPN视图下的配置用于EVPN三层转发场景。如果同时配置二者,则EVPN采用VPN实例EVPN视图下的配置。
# 在VPN实例vpn1下配置EVPN的出方向路由策略为poly-1。
[Sysname-vpn-instance-vpn1] address-family evpn
[Sysname-vpn-evpn-vpn1] export route-policy poly-1
·     route-policy(三层技术-IP路由命令参考/路由策略)
1.1.47  ignore-ac-state
ignore-ac-state enable命令用来开启当前VSI或交叉连接忽略AC状态的功能。
ignore-ac-state disable命令用来关闭当前VSI或交叉连接忽略AC状态的功能。
undo ignore-ac-state命令用来恢复缺省情况。
ignore-ac-state { enable | disable }
与全局忽略AC功能状态的开关情况保持一致。
VSI视图
交叉连接视图
EVPN VPLS、EVPN VPWS、EVPN VPLS over SRv6或EVPN VPWS over SRv6多归属单活组网中,CE 1采用S-Trunk方式双归属接入PE 1和PE 2,PE 1为主用设备,PE 2为备份设备,PE 2上AC状态为Down。当PE 1上AC故障时,PE 1会撤销以太网自动发现路由,同时PE 2上的AC状态为Up,并向远端PE发送以太网自动发现路由,远端PE需要收到PE 2发送的以太网自动发现路由,才能切换至备份路径,路径切换过程速度较慢,会导致报文丢失。为解决上述问题,可在PE 2上配置本命令,使PE 2忽略AC状态并向远端PE发送以太网自动发现路由,远端PE保存该路由。当PE 1的AC故障时,远端PE将流量快速切换至备份路径,减少丢包。
如果执行本命令的同时在全局执行了l2vpn ignore-ac-state命令,则该VSI或交叉连接的配置以ignore-ac-state命令为准。
本功能可以与本地重生成MAC/IP发布路由中的MAC地址功能配合使用。
# 开启VSI实例vpna忽略AC状态的功能。
[Sysname] vsi vpna
[Sysname-vsi-vpna] ignore-ac-state enable
# 开启交叉连接组aaa下交叉连接ac2pw忽略AC状态的功能。
[Sysname] xconnect-group aaa
[Sysname-xcg-aaa] connection ac2pw
[Sysname-xcg-aaa-ac2pw] ignore-ac-state enable
·     l2vpn ignore-ac-state
1.1.48  igp-metric inherit
igp-metric inherit命令用来配置将BGP EVPN路由添加到VPN实例路由表时,路由的Metric值为到达原EVPN路由下一跳的IGP路由的Metric值。
undo igp-metric inherit命令用来恢复缺省情况。
igp-metric inherit
将BGP EVPN路由添加到VPN实例路由表时,路由的Metric值变为0。
BGP EVPN地址族视图
配置本命令后,设备将BGP EVPN路由添加到VPN实例的路由表时,VPN实例中的该路由将会继承到达原EVPN路由下一跳的IGP路由的Metric值,即该路由在VPN实例路由表中的IGP Metric值为到达原EVPN路由下一跳的IGP路由的Metric值。
# 在BGP EVPN地址族视图下,配置将BGP EVPN路由添加到VPN实例路由表时,路由的Metric值为到达原EVPN路由下一跳的IGP路由的Metric值。
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn] igp-metric inherit
1.1.49  import evpn mac-ip
import evpn mac-ip命令用来配置允许将从对等体/对等体组收到的包含ARP/ND信息的MAC/IP发布路由引入BGP单播路由表,并允许对外发布。
undo import evpn mac-ip命令用来恢复缺省情况。
import evpn mac-ip
在EVPN VXLAN组网(MAC/IP发布路由中携带VXLAN ID)中,禁止将从对等体/对等体组收到的包含ARP/ND信息的MAC/IP发布路由引入BGP单播路由表。
在SRv6组网(MAC/IP发布路由中携带SID)中,允许将从对等体/对等体组收到的包含ARP/ND信息的MAC/IP发布路由引入BGP单播路由表,但不允许对外发布。
BGP IPv4单播地址族视图
BGP IPv6 单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
在BGP IPv4或BGP IPv6单播地址族视图下执行本命令后,设备从对等体/对等体组收到包含ARP/ND信息的MAC/IP发布路由后,会将其添加到公网实例路由表,并发布到本地站点。
在BGP-VPN IPv4或BGP-VPN IPv6单播地址族视图下执行本命令后,设备从对等体/对等体组收到包含ARP/ND信息的MAC/IP发布路由后,会将其添加到VPN实例对应的BGP IPv4或BGP IPv6单播路由表,是否发布到本地站点取决于是否执行命令advertise l2vpn evpn配置允许向本地站点发布BGP EVPN路由。
# 配置将从对等体/对等体组收到的MAC/IP路由引入VPN实例vpna对应的BGP IPv4单播路由表,并允许对外发布。
[Sysname] bgp 100
[Sysname-bgp-default] ip vpn-instance vpna
[Sysname-bgp-default-vpna] address-family ipv4
[Sysname-bgp-default-ipv4-vpna] import evpn mac-ip
1.1.50  import route-policy
import route-policy命令用来配置EVPN的入方向路由策略。
undo import route-policy命令用来恢复缺省情况。
未配置EVPN的入方向路由策略,即如果接收到的路由携带的Route Target属性中存在与本地配置的Import Target相同的值,则接收该路由。
EVPN实例视图
VSI实例下的EVPN实例视图
交叉连接组EVPN实例视图
VPN实例EVPN视图
route-policy:入方向路由策略名称,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了EVPN的入方向路由策略,则将BGP EVPN协议的路由引入到EVPN实例或VPN实例时,会利用指定的路由策略对引入的路由进行过滤、改变引入路由的属性等。使用本命令可以更加精确、灵活地控制路由的引入。
EVPN实例视图、VSI实例下的EVPN实例视图、交叉连接组EVPN实例视图、VPN实例视图和VPN实例EVPN视图下配置的入方向路由策略均能用来过滤EVPN路由。其中:
# 在VPN实例vpn1下配置EVPN的入方向路由策略为poly-1。
[Sysname-vpn-evpn-vpn1] import route-policy poly-1
1.1.51  ip public-instance
ip public-instance命令用来创建公网实例,并进入公网实例视图。如果公网实例已经存在,则直接进入公网实例视图。
undo ip public-instance命令用来删除公网实例。
ip public-instance
不存在公网实例。
公网实例用来实现分布式EVPN网关转发公网的三层流量及公私网互通。公网实例可以看作是特殊的VPN实例,分布式EVPN网关对公网实例的处理与VPN实例完全相同。
# 创建公网实例,并进入公网实例视图。
[Sysname] ip public-instance
[Sysname-public-instance]
1.1.52  l2vpn ignore-ac-state
l2vpn ignore-ac-state命令用来全局开启忽略AC状态的功能。
undo l2vpn ignore-ac-state命令用来全局关闭忽略AC状态的功能。
l2vpn ignore-ac-state [ evpn-vpls | evpn-vpws ]
忽略AC状态的功能处于关闭状态。
evpn-vpls:配置VSI忽略AC状态功能。
evpn-vpws:配置交叉连接忽略AC状态功能。
EVPN VPLS、EVPN VPWS、EVPN VPLS over SRv6或EVPN VPWS over SRv6多归属单活组网中,CE 1采用S-Trunk方式双归属接入PE 1和PE 2,PE 1为主用设备,PE 2为备份设备,PE 2上AC状态为Down。当PE 1上AC故障时,PE 1会撤销以太网自动发现路由,同时PE 2上的AC状态为Up,并向远端PE发送以太网自动发现路由,远端PE收到PE 2发送的以太网自动发现路由后,才能切换至备份路径,路径切换过程速度较慢,会导致报文丢失。为解决上述问题,可在PE 2上配置本命令,使PE 2忽略AC状态并向远端PE发送以太网自动发现路由,远端PE保存该路由。当PE 1的AC故障时,远端PE将流量快速切换至备份路径,减少丢包。
如果执行本命令的同时在VSI视图或交叉连接视图下执行了ignore-ac-state命令,则该VSI或交叉连接的配置以ignore-ac-state命令为准。
执行本命令时,如果没有指定evpn-vplsevpn-vpws参数,则表示同时开启VSI忽略AC状态功能和交叉连接忽略AC状态功能。执行本命令时,如果指定了evpn-vpls(或evpn-vpws)参数开启VSI(或交叉连接)的忽略AC状态功能,则不能通过重复执行本命令开启交叉连接(或VSI)的忽略AC状态功能。如需开启交叉连接(或VSI)的忽略AC状态功能,请先通过undo l2vpn ignore-ac-state命令全局关闭忽略AC状态功能,再执行l2vpn ignore-ac-state命令开启VSI和交叉连接的忽略AC状态功能。
# 全局开启忽略AC状态的功能。
[Sysname] l2vpn ignore-ac-state
·     ignore-ac-state
1.1.53  l3-vni
l3-vni命令用来配置L3VNI。
undo l3-vni用来取消配置的L3VNI。
l3-vni vxlan-id
undo l3-vni
未配置L3VNI。
VSI虚接口视图
公网实例视图
vxlan-id:L3VNI,取值范围为0~16777215。
分布式网关组网中,需要在网关上配置L3VNI。在网关之间通过VXLAN隧道转发流量时,属于同一路由域、能够进行三层互通的流量通过L3VNI来标识。
转发某个VPN的三层流量时,需要在与该VPN实例关联的VSI虚接口视图下执行本命令;转发公网的三层流量时,不仅需要在属于公网的VSI虚接口视图下执行本命令,还需要在公网实例视图下执行本命令配置与VSI虚接口相同的L3VNI。
在公网实例视图下,不能通过重复执行本命令修改公网实例的L3VNI。如需修改公网实例的L3VNI,请先通过undo l3-vni命令删除L3VNI,再执行l3-vni命令。
本命令中指定的L3VNI不能与mapping vni命令配置的映射远端VXLAN ID相同。
# 在VSI虚接口100上配置L3VNI为1000。
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] l3-vni 1000
1.1.54  mac-advertising disable
mac-advertising disable命令用来配置禁止通告MAC地址信息,并撤销已经通告的MAC地址信息。
undo mac-advertising disable命令用来恢复缺省情况。
允许通告MAC地址信息。
EVPN实例视图
VSI实例下的EVPN实例视图
本端VTEP或PE可能会同时向远端设备通告MAC地址信息和ARP信息。其中,ARP信息中已经包含MAC地址信息。为了避免重复,可以执行本命令来禁止本端设备向远端设备通告MAC地址信息。执行本命令后,本端设备还会撤销已经发布的MAC地址信息。
# 配置EVPN实例禁止通告MAC地址信息,并撤销已经通告的MAC地址信息。
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan] mac-advertising disable
1.1.55  nd mac-learning disable
nd mac-learning disable命令用来配置禁止EVPN从ND信息中学习MAC地址表项。
undo nd mac-learning disable命令用来恢复缺省情况。
EVPN可以从ND信息中学习MAC地址表项。
EVPN实例视图
VSI实例下的EVPN实例视图
本端VTEP或PE可能会同时接收到远端设备通告的MAC地址信息和ND信息。其中,ND信息中包含MAC地址信息。为了避免重复,可以在本端设备上执行本命令禁止EVPN从ND信息中学习MAC地址表项,EVPN仅通过MAC地址信息学习远端MAC地址表项。
# 配置禁止EVPN从ND信息中学习MAC地址表项。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] nd mac-learning disable
1.1.56  peer advertise encap-type mpls
peer advertise encap-type mpls命令用来配置向对等体/对等体组发布MPLS封装的EVPN路由。
undo peer advertise encap-type mpls命令用来删除向对等体/对等体组发布MPLS封装的EVPN路由的配置。
peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type mpls
undo peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type mpls
向对等体/对等体组发布VXLAN封装的EVPN路由。
BGP EVPN地址族视图
ipv4-address:对等体的IPv4地址。指定的对等体必须已经创建。
ipv6-address:对等体的IPv6地址。指定的对等体必须已经创建。
prefix-length:前缀长度,取值范围为0~128。如果指定本参数,则表示指定网段内的动态对等体。
在EVPN VPLS、EVPN VPWS和EVPN L3VPN网络中,需要执行本命令配置向邻居发布MPLS封装的EVPN路由。
EVPN L3VPN组网中,本功能通常配置在EVPN承载的L3VPN网络的边缘节点和RR(Route Reflector,路由反射器)设备上。在边缘节点上,本功能需要与EVPN通告VPN路由功能配合使用,即在VPN实例IPv4地址族视图/VPN实例IPv6地址族视图下执行命令evpn mpls routing-enable开启EVPN通告VPN路由功能。
# 配置向对等体1.1.1.1发布MPLS封装的EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise encap-type mpls
1.1.57  peer advertise vpn-reoriginate ibgp (BGP EVPN address family view)
peer advertise vpn-reoriginate ibgp命令用来配置以IP前缀路由形式向指定IBGP对等体/对等体组发布VPN实例下重生成的BGP路由。
undo peer advertise vpn-reoriginate ibgp命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise vpn-reoriginate ibgp
undo { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } peer advertise vpn-reoriginate ibgp
不会向IBGP对等体/对等体组发布VPN实例下重生成的BGP路由。
BGP EVPN地址族视图
ipv4-address:对等体的IP地址。指定的对等体组必须已经创建。
本命令必须配合advertise route-reoriginate命令使用。单独配置本命令时,本命令不生效。
配置本命令后,设备将会以IP前缀路由的形式向指定IBGP对等体发布配置了advertise route-reoriginate命令后VPN实例下重生成的路由。
# 在BGP EVPN地址族视图下,配置以IP前缀路由的形式向IBGP对等体1.1.1.1发布VPN实例下重生成的BGP路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise vpn-reoriginate ibgp
·     advertise route-reoriginate(MPLS命令参考/MPLS L3VPN)
1.1.58  peer default-gateway no-advertise
peer default-gateway no-advertise命令用来配置向对等体/对等体组发布EVPN网关路由时不携带Default-gateway扩展团体属性。
undo peer default-gateway no-advertise命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-gateway no-advertise
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-gateway no-advertise
向对等体/对等体组发布EVPN网关路由时会携带Default-gateway扩展团体属性。
BGP EVPN地址族视图
EVPN网关路由是指EVPN网关上VSI虚接口的IP地址对应的路由。缺省情况下,EVPN网关在发布该路由时,会携带Default-gateway扩展团体属性。携带Default-gateway扩展团体属性的多条路由间无法形成等价路由。执行本命令配置EVPN网关在发布网关路由时不携带Default-gateway扩展团体属性,可使多条EVPN网关路由间形成等价路由。
# 在BGP EVPN地址族视图下,配置向对等体1.1.1.1发布EVPN网关路由时不携带Default-gateway扩展团体属性。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 default-gateway no-advertise
1.1.59  peer re-originated
peer re-originated命令用来配置从对等体/对等体组接收到BGP EVPN路由后,修改路由中的信息。
undo peer re-originated命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ ip-prefix | mac-ip ] [ replace-rt ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ ip-prefix | mac-ip ]
不修改从对等体/对等体组接收到的EVPN路由的信息。
BGP EVPN地址族视图
ip-prefix:指定修改IP前缀路由的信息。
mac-ip:指定修改MAC/IP发布路由的信息。
replace-rt:指定将IP前缀路由或MAC/IP发布路由的L3VNI、RD和RT修改为本地VPN实例的L3VNI、RD和RT。如果不指定本参数,则仅修改L3VNI、RD,不修改RT。
EVPN数据中心互联组网中,在ED上执行本命令后,ED从VTEP或远端ED接收到EVPN路由后,如果路由中的Route Target属性与本地VPN实例的Import Route Target属性匹配,则将路由中的信息修改为本地VPN实例的信息,并将修改后的路由发布给远端ED或VTEP。
通常在以下情况下,可以执行本命令:
·     不同数据中心使用的L3VNI不同,通过本配置修改L3VNI,以实现数据中心之间的互通。
·     不同数据中心互通,需要RT值匹配。当数据中心组网规模较大时,数据中心之间的RT配置比较复杂。配置本命令后,ED可直接修改EVPN路由的RT值,数据中心之间发布EVPN路由使用统一的RT值即可,无需进行复杂的RT配置。
·     用户不希望泄露本地数据中心使用的L3VNI时,可以执行本配置将本地所有L3VNI均替换为ED上的L3VNI,对外仅体现ED上的L3VNI。
执行本命令后,ED仅向对等体/对等体组发布修改路由信息后的路由,不会向对等体/对等体组发布源EVPN路由。
如果ED上本地VPN实例的RD与接收到的EVPN路由的RD相同,则不会修改该路由的L3VNI和RT,也不会重生成路由,导致该BGP EVPN路由无法向对等体/对等体组发布。因此,执行本命令时,建议在不同设备上为VPN实例配置不同的RD。
执行本命令时,如果未指定ip-prefixmac-ip参数,则表示修改IP前缀路由的信息。
# 在BGP EVPN地址族视图下,配置修改从BGP对等体1.1.1.1收到的IP前缀路由的L3VNI和RD。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 re-originated ip-prefix
·     peer advertise original-route
·     peer suppress re-originated
1.1.60  peer re-originated mac
peer re-originated mac命令用来配置从对等体/对等体组接收到MAC/IP发布路由后,修改路由中的信息。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated mac [ replace-rt ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated mac
不修改从对等体/对等体组接收到的MAC/IP发布路由的信息。
BGP EVPN地址族视图
replace-rt:指定将MAC/IP发布路由的封装类型、VXLAN ID/MPLS Label、RD和RT修改为接收到该路由的VSI(即VSI的RT与路由携带的RT匹配)关联的另一个EVPN实例的封装类型、MPLS Label/VXLAN ID、RD和RT。如果不指定本参数,则仅修改封装类型、VXLAN ID/MPLS Label、RD,不修改RT。
在EVPN VXLAN网络与EVPN VPLS网络互通的组网中,需要在网络的边界设备上配置本命令,修改MAC/IP发布路由的信息,实现MAC/IP发布路由在EVPN VXLAN网络和EVPN VPLS网络之间重生成。
使用本功能前必须先配置evpn mac re-originated enable命令,否则本功能不生效。
# 在BGP EVPN地址族视图下,配置修改从BGP对等体1.1.1.1收到的MAC/IP发布路由的封装类型、VXLAN ID/MPLS Label和RD。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 re-originated mac
·     evpn mac re-originated enable
1.1.61  peer suppress original-route
peer suppress original-route命令用来抑制向对等体/对等体组发布源EVPN路由,并撤销已经通告的源路由。
undo suppress original-route命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress original-route { auto-discovery | es | imet }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress original-route { auto-discovery | es | imet }
不抑制向对等体/对等体组发布源EVPN路由。
BGP EVPN地址族视图
auto-discovery:抑制向对等体/对等体组发送源以太网自动发现路由。
es:抑制向对等体/对等体组发送源以太网段路由。
imet:抑制向对等体/对等体组发送源包含性组播以太网标签路由。
在EVPN VXLAN网络与EVPN VPLS网络互通的组网中,GW会将从远端GW收到的以太网自动发现路由、以太网段路由和包含性组播以太网标签路由的源路由及重生成路由发送给本端网络的VTEP。此时可以在GW上执行本命令,抑制向对等体/对等体组发布源EVPN路由,并撤销已经通告的源路由,以减少源路由对于带宽资源的占用。
# 在BGP EVPN地址族视图下,配置抑制向对等体1.1.1.1发送源以太网自动发现路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 suppress original-route auto-discovery
1.1.62  ping evpn vpws
ping evpn vpws命令用来检测EVPN VPWS组网中PW连通性。
ping evpn vpws xconnect-group group-name local-service-id  remote-service-id [ -a source-ip | -c count | -exp exp-value | -m interval | -r reply-mode | -s packet-size | -t time-out ] *
xconnect-group group-name:交叉连接组的名称,为1~31个字符的字符串,不能包含字符“-”,区分大小写。
local-service-id:本端的Service ID,取值范围为1~16777215。
remote-service-id:远端的Service ID,取值范围为1~16777215。
-a source-ip:指定发送的MPLS echo request报文的源地址。source-ip为源IP地址。如果未指定本参数,则MPLS echo request报文的源地址为该节点的MPLS LSR ID。
-c count:指定发送MPLS echo request报文的次数。count为MPLS echo request报文发送次数,取值范围为1~4294967295,缺省值为5。当网络状况较差情况时,建议增加发送报文次数,通过丢包率来检测网络质量。
-exp exp-value:指定MPLS echo request报文中标签的EXP值。exp-value为EXP值,取值范围为0~7,缺省值为0。
-m interval:指定连续发送MPLS echo request报文的时间间隔。interval为发送报文的时间间隔,取值范围为1~10000,单位为毫秒,缺省值为2000。当网络状况较差情况时,建议配置此参数取值≥2000。
-r reply-mode:指定接收者对MPLS echo request报文的应答模式。reply-mode为应答模式,取值为2或4,2表示使用UDP报文回应,4表示使用VCCV报文回应。缺省值为2。
-s packet-size:指定MPLS echo request报文长度。packet-size为MPLS echo request报文长度(不包括IP头和UDP头),取值范围为80~8100,单位为字节,缺省值为100。
-t time-out:指定发送MPLS echo request报文后等待响应的超时时间。time-out为超时时间,取值范围为0~65535,单位为毫秒,缺省值为2000。
EVPN VPWS组网中,本端PE设备与远端PE设备间通过PW传输数据报文。当PE间出现丢包或断流现象时,可通过本命令检测PE设备间的PW连通性。
通过本命令检测的PW必须引用PW模板,且该PW模板下必须通过vccv cc命令配置VCCV控制通道类型。
# 检测交叉连接组xcga内本端service ID为2、远端service ID为1的PW的连通性。
<Sysname> ping evpn vpws xconnect-group xcga 2 1
EVPN VPWS PING FEC: Local Evpn Vpws Id = 1, Remote Evpn Vpws Id = 2 : 100 data bytes。
Press CTRL+C to break
Reply from 100.1.1.1: bytes=100 Sequence=1 time=11 ms
Reply from 100.1.1.1: bytes=100 Sequence=2 time=15 ms
Reply from 100.1.1.1: bytes=100 Sequence=3 time=11 ms
Reply from 100.1.1.1: bytes=100 Sequence=4 time=15 ms
Reply from 100.1.1.1: bytes=100 Sequence=5 time=11 ms
-- FEC: Local CeId = 1, Remote CeId = 5 ping statistics ---
5 packet(s) transmitted
5 packet(s) received
0.00% packet loss
round-trip min/avg/max = 11/13/15 ms
表1-36 ping evpn vpws命令显示信息描述表
EVPN VPWS PING FEC: Local Evpn Vpws Id = 1, Remote Evpn Vpws Id = 2 : 100 data bytes.
检测本端service ID为2、远端service ID为1的PW的连通性,每个MPLS echo request报文中的数据为100字节
按组合键Ctrl+C可以终止ping操作
收到IP地址为100.1.1.1的设备回复的回显应答报文,包括:
·     bytes:表示MPLS Echo Reply报文中的数据字节数
·     sequence:表示报文序号,用来判断报文是否有分组丢失、失序或重复
·     time:表示响应时间
若在等待响应的超时时间内仍没有收到回显应答报文,则显示Request time out
Ping操作中收发数据的统计结果,包括:
·     packet(s) transmitted:发送的MPLS echo request报文数目
·     packet(s) received:接收到的MPLS Echo Reply报文数目
·     % packet loss:未响应报文数占发送报文总数的百分比
·     round-trip min/avg/max:往返时延的最小值、平均值、最大值,单位为ms
1.1.63  ping evpn vsi
ping evpn vsi命令用来检测EVPN VPLS组网中本端PE到指定主机连接的远端PE的PW连通性。
ping evpn vsi vsi-name mac mac-address [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] *
vsi vsi-name:检测与指定VSI关联的PW的连通性。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
mac mac-address:检测到指定主机连接的远端PE的PW连通性。mac-address表示MAC地址,形式为H-H-H,不能配置为全0、广播MAC地址和组播MAC地址。
-a source-ip:指定发送的EVPN MAC echo request报文的源地址。source-ip为源IP地址。如果未指定本参数,则EVPN MAC echo request报文的源地址为报文出接口的主IP地址。
-c count:指定发送EVPN MAC echo request报文的次数。count为EVPN MAC echo request报文发送次数,取值范围为1~4294967295,缺省值为5。
-exp exp-value:EVPN MAC echo request报文中标签的EXP值。exp-value为EXP值,取值范围为0~7,缺省值为0。
-h ttl-value:指定EVPN MAC echo request报文中的TTL值,ttl-value为TTL值,取值范围为1~255,缺省值为255。
-m wait-time:指定连续发送EVPN MAC echo request报文的时间间隔。wait-time为发送报文的时间间隔,取值范围为1~10000,单位为毫秒,缺省值为200。
-r reply-mode:指定接收者对EVPN MAC echo request报文的应答模式。reply-mode为应答模式,取值范围为1~2,1示不回应,2表示使用UDP报文回应,缺省值为2。
-rtos tos-value:指定EVPN MAC echo reply报文IP头的ToS值。tos-value为ToS值,取值范围为0~7,缺省值为6。
-s packet-size:指定EVPN MAC echo request报文长度。packet-size为EVPN echo request报文长度(不包括IP头和UDP头),取值范围为81~1200,单位为字节,缺省值为100。
-t time-out:指定发送EVPN MAC echo request报文后等待响应的超时时间。time-out为超时时间,取值范围为0~65535,单位为毫秒,缺省值为2000。
-v:显示详细的应答信息。如果未指定本参数,则显示简要的应答信息。
EVPN VPLS组网中,本端PE设备与远端PE设备间通过PW传输数据报文,当PE间出现丢包或断流现象时,可通过本命令检测PE设备间的PW连通性。
执行本命令后,本端PE设备会发送EVPN MAC回显请求报文,请求报文的目的MAC地址是指定地址,通过在指定VSI下查表获取PW标签,封装后发送给远端PE,远端PE设备收到EVPN MAC回显请求报文后,通过查找IP路由表向该请求报文的源IP地址回复回显应答报文。本端PE设备根据是否收到EVPN MAC回显应答报文、收到EVPN MAC回显应答报文的时间,判断该PW连通性,并输出相应的统计信息。
# 检测EVPN VPLS组网中本端PE到MAC地址为2-2-2的主机连接的远端PE之间PW连通性。
<System> ping evpn vsi vpna mac 2-2-2
Ping remote PE with MAC 0002-0002-0002: 100 data bytes.
Press CTRL_C to break.
100 bytes from 50.1.1.12: Sequence=1 time=1 ms
100 bytes from 50.1.1.12: Sequence=2 time=2 ms
100 bytes from 50.1.1.12: Sequence=3 time=1 ms
100 bytes from 50.1.1.12: Sequence=4 time=2 ms
100 bytes from 50.1.1.12: Sequence=5 time=1 ms
--- Ping statistics for mac 0002-0002-0002 ---
Round-trip min/avg/max = 1/1/2 ms
1.1.64  policy vpn-target
policy vpn-target命令用来开启BGP EVPN路由的VPN-Target过滤功能。
undo policy vpn-target命令用来关闭BGP EVPN路由的VPN-Target过滤功能。
policy vpn-target
BGP EVPN路由的VPN-Target过滤功能处于开启状态。
BGP EVPN地址族视图
开启BGP EVPN路由的VPN-Target过滤功能后,设备只将Export Route Target属性与本地Import Route Target属性匹配的BGP EVPN路由加入到BGP EVPN路由表。设备上如需保存所有BGP EVPN路由,则需执行undo policy vpn-target命令,不对BGP EVPN路由进行VPN-Target过滤。
# 关闭BGP EVPN路由的VPN-Target过滤功能。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] undo policy vpn-target
1.1.65  reset evpn route arp-mobility suppression
reset evpn route arp-mobility suppression命令用来取消对ARP迁移的抑制。
reset evpn route arp-mobility suppression [ public-instance | vpn-instance vpn-instance-name [ ip ip-address ] ]
public-instance:取消对公网实例内ARP迁移的抑制。
vpn-instance vpn-instance-name:取消对指定VPN实例内ARP迁移的抑制。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
ip ip-address:取消对指定IP地址对应ARP的迁移抑制。ip-address表示IPv4地址,为点分十进制格式。如果不指定本参数,则取消对所有ARP迁移的抑制。
执行reset evpn route arp-mobility suppression命令后,设备将取消对指定公网实例或VPN实例内ARP迁移的抑制,对外通告该ARP信息。后续,仍然正常进行迁移抑制,直到关闭ARP反复迁移抑制功能。
执行本命令时,如果没有指定public-instancevpn-instance vpn-instance-name参数,则表示取消对公网实例和所有VPN实例内ARP迁移的抑制。
# 取消对VPN实例vpna内IP地址1.1.1.1对应的ARP信息的迁移抑制。
<Sysname> reset evpn route arp-mobility suppression vpn-instance vpna ip 1.1.1.1
1.1.66  reset evpn route mac-mobility suppression
reset evpn route mac-mobility suppression命令用来取消对MAC地址迁移的抑制。
reset evpn route mac-mobility suppression [ vsi vsi-name [ mac mac-address ] ]
vsi vsi-name:取消对指定VSI内MAC地址迁移的抑制。vsi-name表示VSI实例的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则取消对所有VSI内MAC地址迁移的抑制。
mac mac-address:取消对指定MAC地址的迁移抑制。mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。如果不指定本参数,则取消对所有MAC地址的迁移抑制。
执行reset evpn route mac-mobility suppression命令后,设备将取消对指定VSI内MAC地址迁移的抑制,对外通告该MAC地址。后续,仍然正常进行迁移抑制,直到关闭MAC地址反复迁移抑制功能。
# 取消对VSI实例vpna内MAC地址1-1-1的迁移抑制。
<Sysname> reset evpn route mac-mobility suppression vsi vpna mac 1-1-1
1.1.67  route-distinguisher
route-distinguisher命令用来配置公网实例/EVPN实例的RD(Route Distinguisher,路由标识符)。
undo route-distinguisher命令用来恢复缺省情况。
公网实例视图/交叉连接组EVPN实例视图/EVPN实例视图/VSI实例下的EVPN实例视图(非VXLAN封装):
VSI实例下的EVPN实例视图(VXLAN封装):
route-distinguisher { route-distinguisher | auto }
未指定公网实例/EVPN实例的RD。
EVPN实例视图
VSI实例下的EVPN实例视图
交叉连接组EVPN实例视图
公网实例视图
route-distinguisher:路由标识符,为3~21个字符的字符串(不允许为全0)。路由标识符有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1
auto:表示自动生成RD。自动生成的RD取值为“N:VXLAN ID”,N为从1开始的整数;如果“N:VXLAN索引”已被使用,则RD取值改为“(N+1):VXLAN ID”,如此反复,直到找到未被使用的RD。
EVPN采用MP-BGP协议进行邻居自动发现、MAC地址通告、主机路由通告。本命令指定的RD,携带在MP-BGP协议发布的邻居、MAC地址、主机路由信息中,以标识不同EVPN实例的邻居、MAC地址、主机路由信息。
不能通过重复执行route-distinguisher命令修改RD值。如需修改RD值,请先通过undo route-distinguisher命令删除RD值,再执行route-distinguisher命令配置新的RD值。
# 配置EVPN的RD为22:1。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] route-distinguisher 22:1
1.1.68  rr-filter
rr-filter命令用来配置路由反射器对反射的EVPN路由进行过滤。
undo rr-filter命令用来恢复缺省情况。
rr-filter { ext-comm-list-number | ext-comm-list-name }
undo rr-filter
路由反射器不会对反射的EVPN路由进行过滤。
BGP EVPN地址族视图
ext-comm-list-number:扩展团体属性列表号,取值范围为1~65535。
ext-comm-list-name:扩展团体属性列表名,为1~63个不全为数字的字符串,区分大小写。
执行本命令后,路由反射器将根据扩展团体属性列表对接收的EVPN路由进行过滤:只有接收的BGP EVPN路由通过扩展团体属性列表过滤时,路由反射器才会反射该EVPN路由。
当一个集群中存在多个路由反射器时,通过在不同的路由反射器上配置不同的反射策略,可以实现路由反射器之间的负载分担。
扩展团体属性列表的详细介绍,请参见“三层技术-IP路由配置指导”中的“路由策略”。
# 配置路由反射器只反射通过扩展团体属性列表10过滤的BGP EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] rr-filter 10
·     ip extcommunity-list(三层技术-IP路由命令参考/路由策略)
1.1.69  tracert evpn vpws
tracert evpn vpws命令用来查看EVPN VPWS组网中PW所经过的路径,并根据应答信息对错误点进行定位。
tracert evpn vpws xconnect-group group-name local-service-id  remote-service-id [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -t time-out ] * [ ddmap | full-lsp-path ] *
-h ttl-value:指定MPLS echo request报文中TTL的最大值(即检测的最大跳数)。ttl-value为TTL最大值,取值范围为1~255,缺省值为255。
ddmap:为MPLS echo reply报文和MPLS echo request报文封装Downstream Detailed Mapping TLV。如果不指定本参数,则封装Downstream Mapping TLV。Downstream Detailed Mapping TLV和Downstream Mapping TLV用来携带LSP在当前节点的下游信息,主要包括下一跳地址、出标签等。进行MPLS Tracert操作时,设备需要检验以上TLV中的下一跳地址和出标签是否正确。如果两项检查均通过,则向头节点发送标识检测成功的MPLS Echo Reply报文;如果任意一项检查未通过,则向头节点发送携带错误码的MPLS Echo Reply报文。
full-lsp-path:显示本端PE到远端PE之间完整的LSP路径。如果不配置该参数,则只显示PW尾节点回应的信息。
EVPN VPWS组网中,本端PE设备与远端PE设备间通过PW传输数据报文。当PE间出现丢包或断流现象时,可通过本命令查看本端PE到远端PE的PW所经过的路径,并根据应答信息对错误点进行定位。
# 对交叉连接组xcga内本端service ID为100、远端service ID为200的PW发起tracert检测。
<Sysname> tracert evpn vpws xconnect-group xcga 100 200
Trace route to a remote PE through a PW with local service ID 100 and remote
service ID 200 in cross-connect group 4.
  TTL   Replier            Time    Type      Downstream
  0                                Ingress   42.1.1.2/[3 1892]
  1 Request time out
  2     41.1.1.1           4 ms    Egress
表1-37 tracert evpn vpws命令显示信息描述表
Trace route to a remote PE through a PW with local service ID 100 and remote service ID 200 in cross-connect group 4
查看交叉连接组xcga内本端service ID为100、远端service ID为200的PW所经过的路径
TTL
跳数
Replier
节点的IP地址
Time
RTT(Roud-Trip Time,往返时间)值,单位为毫秒
路径经过的节点类型,取值包括:
·     Ingress:入节点
·     Transit:中间节点
·     Egress:出节点
Downstream
下一跳IP地址与压入标签值
ReturnCode
返回码,括号内为返回子码
Request time out
若在等待响应的超时时间内没有收到MPLS Echo应答报文,则显示本字段
1.1.70  tracert evpn vsi
tracert evpn vsi命令用来查看EVPN VPLS组网中本端PE到指定主机连接的远端PE间PW所经过的路径,并根据应答信息对错误点进行定位。
tracert evpn vsi vsi-name mac mac-address [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out ] *
vsi vsi-name:检测指定VSI内PW的连通性。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
-a source-ip:指定发送的MPLS echo request报文的源地址。source-ip为源IP地址。如果未指定本参数,则MPLS echo request报文的源地址为报文出接口的主IP地址。
-exp exp-value:MPLS echo request报文中标签的EXP值。exp-value为EXP值,取值范围为0~7,缺省值为0。
-h ttl-value:指定MPLS echo request报文中TTL的最大值,ttl-value为TTL值,取值范围为1~255,缺省值为255。
-r reply-mode:指定接收者对MPLS echo request报文的应答模式。reply-mode为应答模式,取值范围为1~2,1表示不回应,2表示使用UDP报文回应,缺省值为2。
-rtos tos-value:指定MPLS echo reply报文IP头的ToS值。tos-value为ToS值,取值范围为0~7,缺省值为6。
EVPN VPLS组网中,本端PE设备与远端PE设备间通过PW传输数据报文。当PE间出现丢包或断流现象时,可通过本命令查看本端PE到指定主机连接的远端PE间PW所经过的路径,并根据应答信息对错误点进行定位。具体检测过程为:
(1)     本端PE设备构造MPLS echo request报文,请求报文的目的MAC地址为本命令指定的MAC地址。本端PE设备根据目的MAC地址,在指定VSI的MAC地址表中查找匹配的表项,获取PW标签,为MPLS echo request报文封装PW标签后,通过PW将报文发送给远端PE。此时MPLS报文头部的TTL字段的取值设置为1。
(2)     下一跳节点收到报文后,将TTL值减1,变为0。该节点通过查找IP路由表向该请求报文的源IP地址(即本端PE)发送ICMP超时报文。
(3)     如果本端PE收到ICMP超时报文或未在time-out时间内收到ICMP超时报文,则会将TTL字段的取值加1(此时设置为2)继续发送MPLS echo request报文。
(4)     下游节点收到报文后,依次将TTL值减1,直到TTL值变为0。TTL值减为0的节点通过查找IP路由表向该请求报文的源IP地址(即本端PE)发送ICMP超时报文;若该节点为远端PE,则向首节点发送MPLS echo reply应答报文。
(5)     本端PE依次重复上述过程,直至MPLS echo request报文中TTL达到配置的最大值或收到远端PE的应答报文。
(6)     本端PE设备根据是否收到应答报文、收到应答报文的时间,判断该PW连通性、该PW经过的路径,并输出相应的统计信息。
# 在EVPN VPLS组网中,查看本端PE到MAC地址为1-1-1的主机连接的远端PE之间PW所经过的路径,并根据应答信息对错误点进行定位。
<Sysname> tracert evpn vsi vpna mac 1-1-1
Trace route to a remote PE in VSI vpna by reaching remote-MAC 0001-0001-0001.
Press CTRL+C to break.
  0                                Ingress
  1     11.1.1.2           1 ms    Transit
  2     12.1.1.1           1 ms    Egress
表1-38 tracert evpnvsi命令显示信息描述表
查看VSI vpna内从当前设备到MAC地址为0001-0001-0001的主机连接的远端PE间PW所经过的路径
按组合键Ctrl+C可以终止tracert操作
TTL
跳数
Replier
节点的IP地址
Time
路径经过的节点类型,取值包括:
·     Ingress:入节点
·     Transit:中间节点
·     Egress:出节点
Request time out
请求超时,若在等待响应的超时时间内没有收到应答报文,则显示本字段
1.1.71  vpn-route cross multipath
vpn-route cross multipath命令用来开启VPN引入等价路由功能。
undo vpn-route cross multipath命令用来关闭VPN引入等价路由功能。
VPN引入等价路由功能处于关闭状态,对于前缀和RD均相同的多条路由,只会将最优路由引入到BGP EVPN路由表中。
BGP EVPN地址族视图
开启VPN引入等价路由功能后,BGP将前缀和RD均相同的多条路由全部引入到BGP EVPN路由表中。
# 开启VPN引入等价路由功能。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] vpn-route cross multipath
1.1.72  vpn-target
vpn-target命令用来配置EVPN的Route Target属性。
undo vpn-target命令用来删除指定的Route Target属性。
vpn-target { vpn-target&<1-8> | auto } [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { vpn-target&<1-8> | auto | all } [ both | export-extcommunity | import-extcommunity ]
VPN实例EVPN视图/公网实例视图/公网实例IPv4地址族视图/公网实例IPv6地址族视图/公网实例EVPN视图/交叉连接组EVPN实例视图/VSI实例下的EVPN实例视图(非VXLAN封装)/EVPN实例视图:
未指定EVPN的Route Target属性。
EVPN实例视图
VSI实例下的EVPN实例视图
交叉连接组EVPN实例视图
VPN实例EVPN视图
公网实例视图
公网实例IPv4地址族视图
公网实例IPv6地址族视图
公网实例EVPN视图
vpn-target&<1-8>:Route Target属性值,vpn-target为3~21个字符的字符串。&<1-8>表示前面的参数最多可以输入8次。Route Target有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
auto:表示自动生成RT。自动生成的RT取值为“BGP AS:VXLAN ID”。
both:指定配置的Route Target值同时作为Import Target和Export Target。没有指定bothexport-extcommunityimport-extcommunity中的任何一个参数时,缺省值为both
export-extcommunity:指定配置的Route Target值为Export Target。
import-extcommunity:指定配置的Route Target值为Import Target。
all:所有Route Target值。
EVPN采用MP-BGP协议进行邻居自动发现、MAC地址通告、主机路由通告等。本地设备在通过MP-BGP的Update消息将BGP EVPN路由发送给远端设备时,将Update消息中携带的VPN target属性设置为Export target。远端设备接收到BGP EVPN路由后,将该路由中携带的Export Target属性与本地配置的Import Target进行比较,如果二者中存在相同的值,则接收该信息。
重复执行本命令,Route Target值为多次配置结果的集合。
# 配置EVPN的Import Target为10:1、100:1和1000:1。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] vpn-target 10:1 100:1 1000:1 import-extcommunity
