09-三层技术-IP路由命令参考
01-IP路由基础命令
本章节下载 01-IP路由基础命令  (539.52 KB)
01-IP路由基础命令
  录
1 IP路由基础
1.1 IP路由基础配置命令
1.1.1 address-family ipv4
1.1.2 address-family ipv6
1.1.3 bandwidth-based-sharing
1.1.4 display ecmp mode
1.1.5 display ip routing-table
1.1.6 display ip routing-table acl
1.1.7 display ip routing-table ip-address
1.1.8 display ip routing-table prefix-list
1.1.9 display ip routing-table protocol
1.1.10 display ip routing-table statistics
1.1.11 display ip routing-table summary
1.1.12 display ipv6 max-ecmp-num
1.1.13 display ipv6 rib attribute
1.1.14 display ipv6 rib graceful-restart
1.1.15 display ipv6 rib nib
1.1.16 display ipv6 route-direct nib
1.1.17 display ipv6 routing-table
1.1.18 display ipv6 routing-table acl
1.1.19 display ipv6 routing-table ipv6-address
1.1.20 display ipv6 routing-table prefix-list
1.1.21 display ipv6 routing-table protocol
1.1.22 display ipv6 routing-table statistics
1.1.23 display ipv6 routing-table summary
1.1.24 display max-ecmp-num
1.1.25 display rib attribute
1.1.26 display rib graceful-restart
1.1.27 display rib nib
1.1.28 display route-direct nib
1.1.29 ecmp mode enchanced
1.1.30 fib lifetime
1.1.31 flush route-attribute
1.1.32 inter-protocol fast-reroute
1.1.33 ip load-sharing mode
1.1.34 ip load-sharing symmetric enable
1.1.35 ipv6 max-ecmp-num
1.1.36 ipv6 route fast-switchover enable
1.1.37 ipv6 route-direct track
1.1.38 max-ecmp-num
1.1.39 maintenance-probe enable
1.1.40 nexthop recursive-lookup restrain clear-interval
1.1.41 nexthop recursive-lookup restrain disable
1.1.42 non-stop-routing
1.1.43 primary-path-detect bfd
1.1.44 protocol lifetime
1.1.45 protocol nexthop recursive-lookup
1.1.46 reset ip routing-table statistics protocol
1.1.47 reset ipv6 routing-table statistics protocol
1.1.48 route-direct track
1.1.49 rib
1.1.50 routing-table limit
1 IP路由基础
1.1  IP路由基础配置命令
address-family ipv4命令用来创建RIB IPv4地址族,并进入RIB IPv4地址族视图。
undo address-family ipv4命令用来删除RIB IPv4地址族和RIB IPv4地址族视图下的所有配置。
address-family ipv4
不存在RIB IPv4地址族。
RIB视图
# 创建RIB IPv4地址族,并进入RIB IPv4地址族视图。
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4]
address-family ipv6命令用来创建RIB IPv6地址族,并进入RIB IPv6地址族视图。
undo address-family命令用来删除RIB IPv6地址族和RIB IPv6地址族视图下的所有配置。
address-family ipv6
undo address-family ipv6
不存在RIB IPv6地址族。
RIB视图
# 创建RIB IPv6地址族,并进入RIB IPv6地址族视图。
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6]
bandwidth-based-sharing命令用来开启IPv4基于带宽的负载分担功能。
undo bandwidth-based-sharing命令用来关闭IPv4基于带宽的负载分担功能。
IPv4基于带宽的负载分担功能处于关闭状态。
开启IPv4基于带宽的负载分担功能情况下,如果转发时查到多个出接口/下一跳,则按照接口的带宽值计算出各个接口应该分配的报文比例,然后按照带宽比例对报文进行转发。
支持负载分担的协议的设备,无论是否配置bandwidth-based-sharing,负载分担比例以协议定义的负载分担比例为准。
# 开启IPv4基于带宽的负载分担功能。
[Sysname] bandwidth-based-sharing
display ecmp mode命令用来显示IPv4/IPv6等价路由模式信息。
display ecmp mode
# 显示IPv4/IPv6等价路由模式信息。
<Sysname> display ecmp mode
  ECMP-Mode in use: Default
  ECMP-Mode at the next reboot: Enhanced
表1-1 display ecmp mode命令显示信息描述表
ECMP-Mode in use
当前ECMP模式:
·     Default:等价路由普通模式
·     Enhanced:等价路由增强模式
下次启动后ECMP模式:
·     Default:等价路由普通模式
·     Enhanced:等价路由增强模式
·     ecmp mode enhanced
display ip routing-table命令用来显示路由表的信息。
display ip routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ip routing-table all-routes
all-vpn-instance:显示所有VPN实例的路由表信息。
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
all-routes:显示公网和所有VPN实例的路由表信息。
verbose:显示全部路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
# 显示路由表中当前激活路由的概要信息。
<Sysname> display ip routing-table
Destinations : 10        Routes : 10
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
1.1.1.0/24          Static 60   0            192.168.47.4    XGE0/0/6
                    Static 60   0            192.168.47.4    XGE0/0/7
192.168.1.40/32     Direct 0    0            127.0.0.1       InLoop0
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
# 显示公网和所有VPN实例中当前激活路由的概要信息。
<Sysname> display ip routing-table all-routes
VPN instance: public instance
VPN instance: vpn1
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
1.1.2.0/24          Static 60   0            2.2.1.1         XGE0/0/6
3.3.1.0/24          BGP    255  0            55.1.1.2        XGE0/0/7
# 显示所有VPN实例下的IPv4路由信息。
<Sysname> display ip routing-table all-vpn-instance
VPN instance: vpn1
VPN instance: vpn2
Destinations : 9        Routes : 9
1.1.3.0/24          Static 60   0            3.3.1.1         XGE0/0/6
表1-2 display ip routing-table命令显示信息描述表
Destinations
目的地址个数
Routes
路由条数
Destination/Mask
目的地址/掩码长度
Proto
发现该路由的路由协议类型:
·     Direct:直连路由
·     Static:静态路由
·     RIP:RIP路由协议
·     OSPF:OSPF路由协议
·     ISIS:IS-IS路由协议
·     EIGRP:EIGRP路由协议
·     BGP:BGP路由协议
·     OpenR:OpenR(Open Routing)路由
·     LDP:LDP标签分发协议
·     SLSP:静态LSP
·     PIM:PIM协议
·     MSTATIC:组播静态路由
·     O_INTRA:OSPF区域内路由
·     O_INTER:OSPF区域间路由
·     O_ASE1:OSPF第一类外部路由
·     O_ASE2:OSPF第二类外部路由
·     O_SUM:OSPF聚合路由
·     IS_L1:IS-IS Level-1路由
·     IS_L2:IS-IS Level-2路由
·     IS_SUM:IS-IS聚合路由
Pre
路由的优先级
Cost
路由的度量值
NextHop
此路由的下一跳地址
出接口,即到该目的网段的数据包将从此接口发出
Summary count
路由数目
# 显示路由表的全部详细信息。
<Sysname> display ip routing-table verbose
Destinations : 13        Routes : 13
Destination: 0.0.0.0/32
   Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                        Age: 08h34m37s
         Cost: 0                  Preference: 0
      IpPre: N/A                  QosLocalID: N/A
         Tag: 0                        State: Active NoAdv
   OrigTblID: 0x0                    OrigVrf: default-vrf
     TableID: 0x2                     OrigAs: 0
       NibID: 0x10000000              LastAs: 0
      AttrID: 0xffffffff            Neighbor: 0.0.0.0
       Flags: 0x1000c            OrigNextHop: 127.0.0.1
       Label: NULL               RealNextHop: 127.0.0.1
     BkLabel: NULL                 BkNextHop: N/A
     SRLabel: NULL                 Interface: InLoopBack0
   BkSRLabel: NULL               BkInterface: N/A
   Tunnel ID: Invalid            IPInterface: InLoopBack0
 BkTunnel ID: Invalid          BKIPInterface: N/A
     InLabel: NULL            ColorInterface: N/A
    SIDIndex: NULL          BKColorInterface: N/A
    FtnIndex: 0x0            TunnelInterface: N/A
TrafficIndex: N/A          BKTunnelInterface: N/A
   Connector: N/A                     PathID: 0x0
  SRTunnelID: Invalid
    SID Type: N/A                        NID: Invalid
    FlushNID: Invalid                  BkNID: Invalid
  BkFlushNID: Invalid              StatFlags: 0x0
         Exp: N/A
   VpnPeerId: N/A                       Dscp: N/A
         SID: N/A                 OrigLinkID: 0x0
       BkSID: N/A                 RealLinkID: 0x0
CommBlockLen: 0
Destination: 1.1.1.0/24
   Protocol: Static
  Process ID: 0
   SubProtID: 0x0                        Age: 04h20m37s
        Cost: 0                   Preference: 60
         Tag: 0                        State: Active Adv
       NibID: 0x10000003              LastAs: 0
       Flags: 0x1008c            OrigNextHop: 192.168.47.4
       Label: NULL               RealNextHop: 192.168.47.4
     SRLabel: NULL                 Interface: Ten-GigabitEthernet0/0/6
   Tunnel ID: Invalid            IPInterface: Ten-GigabitEthernet0/0/6
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: 1.2.3.4/32
   Protocol: BGP instance default
  Process ID: 0
   SubProtID: 0x1                        Age: 02h38m34s
        Cost: 0                   Preference: 255
     TableID: 0x2                     OrigAs: 200
       NibID: 0x16000000              LastAs: 200
      AttrID: 0x2                   Neighbor: 2.2.3.4
       Flags: 0x10060            OrigNextHop: 2.2.3.4
       Label: NULL               RealNextHop: 2.2.3.4
     SRLabel: NULL                 Interface: Ten-GigabitEthernet0/0/8
   Tunnel ID: Invalid            IPInterface: Ten-GigabitEthernet0/0/8
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
# 显示所有VPN实例内所有路由的详细信息。
<Sysname> display ip routing-table all-vpn-instance verbose
VPN instance: vpn1
Destinations : 1        Routes : 1
   Protocol: Direct
  Process ID: 0
   OrigTblID: 0x0                    OrigVrf: vpn1
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
VPN instance: vpn2
   Protocol: Static
  Process ID: 0
   OrigTblID: 0x0                    OrigVrf: vpn2
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
表1-3 display ip routing-table verbose命令显示信息描述表
Destinations
目的地址个数
Routes
路由条数
Destination
目的地址/掩码
Protocol
发现该路由的路由协议类型:
·     Direct:直连路由
·     Static:静态路由
·     RIP:RIP路由协议
·     OSPF:OSPF路由协议
·     ISIS:IS-IS路由协议
·     EIGRP:EIGRP路由协议
·     BGP:BGP路由协议
·     LDP:LDP标签分发协议
·     SLSP:静态LSP
·     PIM:PIM
·     MSTATIC:组播静态路由
·     O_INTRA:OSPF区域内路由
·     O_INTER:OSPF区域间路由
·     O_SUM:OSPF聚合路由
·     IS_SUM:IS-IS聚合路由
Process ID
进程号
SubProtID
路由子协议ID
Age
此路由在路由表中存在的时间
Cost
路由的度量值
Preference
路由的优先级
IpPre
IP优先级值
QosLocalID
QoS本地ID,N/A表示无效值
Tag
路由标记
路由状态描述:
·     Active:有效的单播路由
·     Adv:允许对外发送的路由
·     Inactive:非激活路由标志
·     NoAdv:不允许发布的路由
·     Vrrp:VRRP产生的路由
·     Nat:NAT产生的路由
·     TunE:Tunnel隧道的标志
·     Derive:派生路由,即路由迭代的出接口不唯一时,第一条迭代路由外的其他迭代路由。携带此标记的路由不计入路由条数
OrigTblID
原始路由表ID
OrigVrf
‌路由所属的原始VPN,显示为default-vrf表示公网
TableID
路由所在路由表的ID
OrigAs
初始AS号
NibID
下一跳ID
LastAs
最后AS号
AttrID
路由属性ID号
Neighbor
路由协议的邻居地址
Flags
路由标志位
OrigNextHop
此路由的下一跳地址
Label
标签
RealNextHop
路由真实下一跳
BkLabel
备份标签
BkNexthop
备份下一跳地址
SRLabel
SR(Segment Routing,分段路由)标签
BkSRLabel
SR备份标签
SIDIndex
SID的索引值
InLabel
路由入标签
Tunnel ID
隧道ID
BkTunnel ID
备份隧道ID,如果显示信息中存在“...”,则表示有多个备份隧道,此时仅第一个备份隧道生效
BkInterface
备份出接口,如果显示信息中存在“...”,则表示有多个备份出接口,此时仅第一个备份出接口生效
IPInterface
IP出接口
BkIPInterface
备份IP出接口
ColorInterface
(暂不支持)Color出接口,即通过SR-MPLS TE Policy或SRv6 TE Policy迭代的出接口
BkColorInterface
备份Color出接口
FtnIndex
FTN表项索引
TunnelInterface
Tunnel出接口
TrafficIndex
流量统计索引值,取值范围为1~64,N/A表示无效值
BkTunnelInterface
备份Tunnel出接口
Connector
‌表示BGP为MD VPN特性所携带的Connector属性,具体取值为BGP对等体在交换VPN-IPv4路由时携带源PE的地址,N/A表示没有该属性
Summary count
路由数目
PathID
路径ID
SRTunnelID
SR隧道ID
SID Type
SID类型,N/A表示没有该属性
NID
路由协议下刷的NHLFE(Next Hop Label Forwarding Entry,下一跳标签转发项)表项索引
FlushNID
实际向FIB下刷的NHLFE表项索引
BkNID
路由协议下刷的备份NHLFE表项索引
BkFlushNID
实际向FIB下刷的备份NHLFE表项索引
StatFlags
SRv6流量统计标记
VpnPeerId
路由所属的VPN peer ID值,取值范围为1~134217727,N/A表示无效值
Dscp
路由的DSCP优先级,取值范围为0~63,N/A表示无效值
Exp
路由的EXP优先级(仅BGP支持),N/A表示无效值
SID
主用SID(Segment Identifier,段标识),N/A表示没有该属性
BkSID
备用SID,N/A表示没有该属性
CommBlockLen
Locator中的公共前缀长度
OrigLinkID
SDWAN TTE连接的原始Link ID
RealLinkID
SDWAN TTE连接的真实Link ID
display ip routing-table acl命令用来显示通过指定ACL过滤的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ]
ipv4-acl-number:基本ACL的编号,取值范围为2000~2999。
verbose:显示通过指定ACL过滤的所有路由的详细信息。如果未指定本参数,将只显示通过指定ACL过滤的激活路由的概要信息。
引用ACL时,需要注意的是:
·     若引用的ACL不存在,或者引用的ACL中没有配置规则,则显示所有的路由信息。
·     在引用的ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
# 配置ACL 2000,并设置路由过滤规则。
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
# 显示通过ACL 2000过滤的激活路由的概要信息。
[Sysname-acl-ipv4-basic-2000] display ip routing-table acl 2000
Summary count : 4
192.168.1.0/24      Direct 0    0            192.168.1.111   XGE0/0/6
192.168.1.0/32      Direct 0    0            192.168.1.111   XGE0/0/6
192.168.1.111/32    Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.111   XGE0/0/6
以上显示信息解释请参见表1-2
# 显示通过ACL 2000过滤的所有路由的详细信息。
<Sysname> display ip routing-table acl 2000 verbose
Summary count : 4
Destination: 192.168.1.0/24
   Protocol: Direct
  Process ID: 0
   SubProtID: 0x1                        Age: 04h20m37s
       Flags: 0x10080            OrigNextHop: 192.168.1.111
       Label: NULL               RealNextHop: 192.168.1.111
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: 192.168.1.111/32
   Protocol: Direct
  Process ID: 0
       Flags: 0x10004            OrigNextHop: 127.0.0.1
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: 192.168.1.255/32
   Protocol: Direct
  Process ID: 0
       Flags: 0x1008c            OrigNextHop: 192.168.1.111
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
以上显示信息解释请参见表1-3
display ip routing-table ip-address命令用来显示指定目的地址的路由信息。
display ip routing-table ip-address1 to ip-address2命令用来显示指定目的地址范围内的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ]
ip-address:目的IP地址,点分十进制格式。
mask-length:网络掩码长度,取值范围为0~32。
mask:网络掩码,点分十进制格式。
longer-match:显示与指定目的网络匹配的所有路由信息。关于匹配条件的详细说明,请查看使用指导。
ip-address1 to ip-address2:IP地址范围。ip-address1ip-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
使用不同的可选参数,命令的输出也不相同,以下是对该命令不同形式的输出说明:
(1)     display ip routing-table ip-address
显示满足如下条件的所有激活路由:
·     用户输入的目的IP地址同路由表中各条路由的子网掩码值进行与运算;
·     路由表中各条路由的目的IP地址同其自身子网掩码值进行与运算;
·     两次运算结果相同的路由条目将被显示出来。
(2)     display ip routing-table ip-address mask
显示满足如下条件的所有激活路由:
·     用户输入的目的IP地址同用户输入的子网掩码值进行与运算;
·     路由表中各条路由的目的IP地址同用户输入的子网掩码值进行与运算;
·     两次运算结果相同,并且掩码小于等于用户输入的子网掩码的路由条目将被显示出来。
(3)     display ip routing-table ip-address longer-match
显示满足如下条件的所有激活路由:
·     用户输入的目的IP地址同子网掩码值进行与运算,有以下三种情况:
¡     用户输入的目的IP地址得出其所对应的自然网段,取该自然网段对应的子网掩码默认值(A、B、C类IP地址对应的子网掩码默认值分别为255.0.0.0、255.255.0.0和255.255.255.0),再将用户输入的目的IP地址与对应的子网掩码默认值进行与运算。
¡     如果用户输入的目的IP地址是0.0.0.0,将使用掩码0.0.0.0与其进行与运算。
¡     除上述两种情况外(如组播地址、环回地址),将使用掩码255.255.255.255与用户输入的目的IP地址进行与运算。
·     路由表中各条路由的目的IP地址同上一步得到的子网掩码值进行与运算;
·     两次运算结果相同的所有路由条目将被显示出来。
(4)     display ip routing-table ip-address mask longer-match
显示满足如下条件的所有激活路由:
(5)     display ip routing-table ip-address1 to ip-address2
显示ip-address1/32到ip-address2/32之间的激活路由,目的地址与掩码(32位)同时在指定范围内才会显示。
# 显示目的地址为11.0.0.1的路由信息。
<Sysname> display ip routing-table 11.0.0.1
Summary count : 3
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.0.0.0/16         Static 60   0            0.0.0.0         NULL0
11.0.0.0/24         Static 60   0            0.0.0.0         NULL0
# 显示目的地址/掩码为11.0.0.1/20的路由信息。
<Sysname> display ip routing-table 11.0.0.1 20
Summary count : 2
# 显示目的地址为11.0.0.1并且满足匹配条件的路由信息。
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary count : 3
# 显示目的地址/掩码为11.0.0.1/20并且满足匹配条件的路由信息。
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary count : 3
# 显示目的地址从1.1.1.0到5.5.5.0范围内的路由信息。
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary count : 5
1.1.1.1/32          Direct 0    0            127.0.0.1       InLoop0
3.3.3.0/24          Direct 0    0            3.3.3.1         XGE0/0/7
3.3.3.1/32          Direct 0    0            127.0.0.1       InLoop0
4.4.4.0/24          Direct 0    0            4.4.4.1         XGE0/0/6
4.4.4.1/32          Direct 0    0            127.0.0.1       InLoop0
# 显示目的地址为1.2.3.4的路由的详细信息。
<Sysname> display ip routing-table 1.2.3.4 verbose
Summary count : 1
   Protocol: Static
  Process ID: 0
   SubProtID: 0x1                        Age: 00h00m37s
       NibID: 0x15000000              LastAs: 0
      AttrID: 0x0                   Neighbor: 0.0.0.0
       Flags: 0x10060            OrigNextHop: 192.168.47.2
       Label: NULL               RealNextHop: 192.168.47.2
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
以上显示信息的解释请参见表1-2
display ip routing-table prefix-list命令用来显示通过指定前缀列表过滤的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name:前缀列表名称,为1~63个字符的字符串,区分大小写。
verbose:当使用该参数时,显示通过过滤规则的所有路由的详细信息。如果未指定本参数,将只显示通过过滤规则的激活路由的概要信息。
如果指定的前缀列表不存在,将显示所有的路由信息。
# 配置地址前缀列表test允许前缀为1.1.1.0,掩码长度为24的路由通过。
[Sysname] ip prefix-list test permit 1.1.1.0 24
# 显示通过前缀列表test过滤的激活路由的概要信息。
[Sysname] display ip routing-table prefix-list test
Summary count : 1
1.1.1.0/24          Direct 0    0            1.1.1.2         XGE0/0/7
以上显示信息的解释请参见表1-2
# 显示通过前缀列表test过滤的所有路由的详细信息。
[Sysname] display ip routing-table prefix-list test verbose
Summary count : 1
   Protocol: Direct
  Process ID: 0
       Flags: 0x1008c            OrigNextHop: 1.1.1.2
       Label: NULL               RealNextHop: 1.1.1.2
     SRLabel: NULL                 Interface: Ten-GigabitEthernet0/0/7
   Tunnel ID: Invalid            IPInterface: Ten-GigabitEthernet0/0/7
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
以上显示信息的解释请参见表1-3
display ip routing-table protocol命令用来显示指定协议生成或发现的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
protocol:显示指定路由协议的信息。
inactive:显示未激活路由的信息。如果未指定本参数,则显示激活路由和未激活路由的信息。
verbose:当使用该参数时,显示路由的详细信息。如果未指定本参数,将显示路由的概要信息。
# 显示所有直连路由的概要信息。
<Sysname> display ip routing-table protocol direct
Summary count : 9
Direct Routing table status : <Active>
Summary count : 9
192.168.80.0/24     Direct 0    0            192.168.80.10   XGE0/0/6
192.168.80.0/32     Direct 0    0            192.168.80.10   XGE0/0/6
192.168.80.10/32    Direct 0    0            127.0.0.1       InLoop0
192.168.80.255/32   Direct 0    0            192.168.80.10   XGE0/0/6
Direct Routing table status : <Inactive>
Summary count : 0
# 显示静态路由表。
<Sysname> display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 0
Static Routing table status : <Inactive>
Summary count : 1
3.0.0.0/8           Static 60   0            2.2.2.2        XGE0/0/6
# 显示OpenR路由表。
<Sysname> display ip routing-table protocol openr
Summary count : 1
OpenR Routing table status : <Active>
Summary count : 1
192.11.3.0/24       OpenR  30   0            12.13.3.12     XGE0/0/6
Summary count : 0
# 显示所有BGP路由的详细信息。
<Sysname> display ip routing-table protocol bgp verbose
Summary count : 1
Destination: 1.1.1.2/32
  Process ID: 0
   SubProtID: 0x6                        Age: 00h03m54s
      AttrID: 0x0                   Neighbor: 192.168.47.2
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
以上显示信息的解释请参见表1-2
# 显示所有OpenR路由的详细信息。
<Sysname> display ip routing-table protocol openr verbose
Summary count : 1
Destination: 192.11.3.0/24
   Protocol: OpenR
  Process ID: 0
   SubProtID: 0xfe                       Age: 01h13m48s
        Cost: 0                   Preference: 30
       NibID: 0x19000000              LastAs: 0
       Flags: 0x10040            OrigNextHop: 12.13.3.12
       Label: NULL               RealNextHop: 12.13.3.12
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
以上显示信息的解释请参见表1-2
display ip routing-table statistics命令用来显示路由表中路由或前缀的统计信息。
display ip routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] [ prefix ] statistics
all-routes:显示公网和所有VPN实例的信息。
all-vpn-instance:显示所有VPN实例的信息。
prefix:显示前缀的统计信息。如果不指定本参数,则显示路由的统计信息。
如果不指定任何参数,将显示公网的信息。
# 显示路由表中的综合路由统计信息。
<Sysname> display ip routing-table statistics
Total prefixes: 15        Active prefixes: 15
Proto      Routes      Active      Added       Deleted
DIRECT     12          12          30          18
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
OpenR      0           0           0           0
Total      15          15          35          20
# 显示公网和所有VPN实例路由表中的路由统计信息。
<Sysname> display ip routing-table all-routes statistics
Total prefixes: 11        Active prefixes: 11
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
OpenR      0           0           0           0
Total      11          11          13          2
# 显示指定VPN实例路由表中的综合路由统计信息。
<Sysname> display ip routing-table vpn-instance vpn1 statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
OpenR      0           0           0           0
Total      11          11          13          2
# 显示所有VPN实例路由表中的路由统计信息。
<Sysname> display ip routing-table all-vpn-instance statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
OpenR      0           0           0           0
Total      11          11          13          2
# 显示公网的前缀统计信息。
<Sysname> display ip routing-table prefix statistics
Proto      Prefixes    Active      Added       Deleted
DIRECT     7           7           7           0
STATIC     0           0           0           0
UNR        0           0           0           0
RIP        1           0           1           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
OpenR      0           0           0           0
Total      8           7           8           0
表1-4 display ip routing-table statistics命令显示信息描述表
Total prefixes
总的前缀数目
Active prefixes
总的激活前缀数目
Proto
路由协议
Route
总的路由数目
Prefixes
前缀数目
Active
活跃的、正在使用的路由数目
Added
路由器启动后或在上一次清除路由表后,路由表中添加的路由数目
Deleted
标记为删除的路由数目(此类路由在等待一段时间后会被释放)
Total
各种类型路由数目的总和
display ip routing-table summary命令用来显示路由表的概要信息,包括最大等价路由数、最大可激活路由前缀数、剩余可激活路由前缀数等。
display ip routing-table [ vpn-instance vpn-instance-name ] summary
# 显示公网的路由表概要信息。
<Sysname> display ip routing-table summary
Max ECMP: 32
Max Active Route: 262144
Remain Active Route: 262126
# 显示实例vpn1的路由表概要信息。
<Sysname> display ip routing-table vpn-instance vpn1 summary
Max ECMP: 32
Remain Active Route: 262134
Threshold value percentage of max active routes: 100%
表1-5 display ip routing-table summary命令显示信息描述表
Max ECMP
最大等价路由数
Max Active Route
最多支持激活路由前缀数
Remain Active Route
剩余可激活路由前缀数
Threshold value of active routes alert
显示最多支持激活路由前缀数的告警门限:
·     如果在VPN实例中配置了routing-table limit number simply-alert命令,则显示信息字段为Threshold value of active routes alert,取值表示产生告警的门限值。当VPN实例的激活路由前缀数超过该取值时,可以继续激活新的路由前缀,但会产生Trap告警和日志信息
·     若在VPN实例中为配置routing-table limit命令或配置了routing-table limit number warn-threshold命令,则显示信息字段为Threshold value percentage of max active routes,取值表示当(VPN实例中的激活路由前缀数/最多支持激活路由前缀数×100)达到warn-threshold时,产生Trap告警和日志信息,但仍然允许增加激活路由前缀。当VPN实例中的激活路由前缀由数达到最多支持激活路由前缀数目时,不再激活新的路由前缀
display ipv6 max-ecmp-num命令用来显示系统支持IPv6最大等价路由的条数。
# 显示系统支持IPv6最大等价路由的条数。
<Sysname> display ipv6 max-ecmp-num
  Max-ECMP-Num in use: 6
  Max-ECMP-Num at the next reboot: 10
表1-6 display ipv6 max-ecmp-num命令显示信息描述表
Max-ECMP-Num in use
当前使用的最大等价路由的条数
下次启动后的最大等价路由的条数
display ipv6 rib attribute命令用来显示IPv6 RIB的路由属性信息。
attribute-id:路由属性ID值,取值范围为十六进制数0~ffffffff。
# 显示IPv6 RIB的路由属性信息。
<Sysname> display ipv6 rib attribute
Total number of attribute(s): 1
Detailed information of attribute 0x9:
                  Flag: 0x0
              Protocol: BGP4+ instance default
        Address family: IPv6
       Reference count: 0
      Local preference: 0
Ext-communities number: 0
 Ext-communities value: N/A
    Communities number: 0
     Communities value: N/A
        AS-path number: 0
         AS-path value: N/A
以上显示信息的解释请参见表1-11
display ipv6 rib graceful-restart命令用来显示IPv6 RIB的GR状态信息。
# 显示IPv6 RIB的GR状态信息。
<Sysname> display ipv6 rib graceful-restart
RIB GR state     : Phase2-calculation end
RCOM GR state    : Flush end
Protocol GR state:
 No.  Protocol   Lifetime FD   State    Start/End
 1    DIRECT6    480      29   End      No/No
 2    STATIC6    480      32   End      No/No
 3    ISISV6     480      30   End      No/No
 4    BGP4+ instance default
                 480      31   End      No/No
 5    BGP4+ instance ebcdefg
                 480      32   End      No/No
 6    OpenR6     480      83   End      No/No
以上显示信息的解释请参见表1-12
display ipv6 rib nib命令用来显示IPv6 RIB的下一跳信息。
display ipv6 rib nib [ sub-nib nib-id ] [ verbose ]
self-originated:路由管理自己生成的下一跳。
sub-nib:根据子下一跳查找组合下一跳信息。
nib-id:路由下一跳ID值,取值范围为十六进制数1~ffffffff。
verbose:显示详细信息。如果未指定本参数,则显示概要信息。
protocol protocol:显示指定路由协议的下一跳信息。
# 显示IPv6 RIB的下一跳信息。
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
      NibID: 0x20000000           Sequence: 0
       Type: 0x1                   Flushed: Yes
        Age: 00h01m50s
   UserKey0: 0x0                   VrfNthp: 0
   UserKey1: 0x0                   Nexthop: ::
   UserKey2: 0x0                   IFIndex: 0x111
   UserKey3: 0x0                 LocalAddr: ::
   TopoNthp: Invalid               ExtType: 0x0
      Color: 0                      COFlag: 0x0
     LinkID: 0x0
   SIDIndex: 0x0                   SRPName:
 OriNexthop: ::
      NibID: 0x20000001           Sequence: 1
        Age: 00h01m50s
   UserKey1: 0x0                   Nexthop: ::1
   UserKey2: 0x0                   IFIndex: 0x112
   UserKey3: 0x0                 LocalAddr: ::1
     LinkID: 0x0
 OriNexthop: ::
# 显示IPv6 RIB下一跳的详细信息。
<Sysname> display ipv6 rib nib verbose
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: ::
     RefCnt: 4                 FlushRefCnt: 1
       Flag: 0x84                  Version: 1
 1 nexthop(s):
PrefixIndex: 0                 OrigNexthop: ::
  RelyDepth: 0                 RealNexthop: ::
  Interface: NULL0               LocalAddr: ::
  TunnelCnt: 0                         Vrf: default-vrf
   TunnelID: N/A                  Topology:
     Weight: 0                       Flags: 0x0
SRPolicyNID: 4294967295        SRInterface:
ColorWeight: 0                     Locator: N/A
 OrigLinkID: 0x0                RealLinkID: 0x0
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: ::
 1 nexthop(s):
PrefixIndex: 0                 OrigNexthop: ::1
  RelyDepth: 0                 RealNexthop: ::1
  Interface: InLoop0             LocalAddr: ::1
      NibID: 0x26000002           Sequence: 1
        Age: 00h01m50s
   UserKey1: 0x0                   Nexthop: 122::2
   UserKey3: 0x0                 LocalAddr: 122::2
     LinkID: 0x0
 OriNexthop: ::
   Instance: abc
 1 nexthop(s):
PrefixIndex: 0                 OrigNexthop: 122::2
  RelyDepth: 0                 RealNexthop: 122::2
以上显示信息的解释请参见表1-13表1-14
display ipv6 route-direct nib命令用来显示IPv6直连路由下一跳信息。
nib-id:路由邻居ID值,取值范围为十六进制数1~ffffffff。
# 显示IPv6直连路由下一跳信息。
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: ::
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: ::
# 显示IPv6直连路由下一跳详细信息。
<Sysname> display ipv6 route-direct nib verbose
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: ::
     RefCnt: 1                 FlushRefCnt: 0
       Flag: 0x2                   Version: 1
 1 nexthop(s):
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: ::
 1 nexthop(s):
以上显示信息的解释请参见表1-15表1-16
display ipv6 routing-table命令用来显示IPv6路由表的信息。
display ipv6 routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ipv6 routing-table all-routes
all-vpn-instance:显示所有VPN实例的路由信息。
verbose:显示IPv6路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
# 显示当前路由表的概要信息。
<Sysname> display ipv6 routing-table
Destinations : 3 Routes : 3
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: 6::/64                                      Protocol  : Static
NextHop    : 5::2                                        Preference: 60
Interface  : XGE0/0/6                                     Cost      : 0
Interface  : XGE0/0/7                                     Cost      : 0
Destination: FE80::/10                                   Protocol  : Direct
NextHop    : ::                                          Preference: 0
Destination: FF00::/8                                    Protocol  : Direct
Interface  : NULL0                                       Cost      : 0
表1-7 display ipv6 routing-table命令显示信息描述表
Destinations
目的地址个数
Routes
路由条数
Destination
目的网络/主机的IPv6地址和前缀
NextHop
下一跳地址
Preference
路由优先级
出接口,即到该目的地址的数据包将从此接口发出(当Protocol为SRv6并且转发隧道是SRv6 TE Policy时,出接口显示该Policy的名称)
Protocol
发现该路由的路由协议类型:
·     Direct:直连路由
·     Static:静态路由
·     RIPng:RIPng路由协议
·     OSPFv3:OSPFv3路由协议
·     ISISv6:IS-ISv6路由协议
·     EIGRPv6:EIGRPv6路由协议
·     BGP4+:BGP4+路由协议
·     OpenR6:OpenR6(IPv6 Open Routing)路由
·     LDP:LDP标签分发协议
·     SLSP:静态LSP
·     PIM:PIM
·     MSTATIC:组播静态路由
·     O_INTRA:OSPF区域内路由
·     O_INTER:OSPF区域间路由
·     O_SUM:OSPF聚合路由
·     IS_SUM:IS-IS聚合路由
·     SRv6:SRv6 路由
Cost
路由的开销值
Summary count
路由数目
# 显示路由表的详细路由信息。
<Sysname> display ipv6 routing-table verbose
Destinations : 6 Routes : 6
   Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                        Age: 19h23m02s
     TableID: 0xa                     OrigAs: 0
       NibID: 0x20000000              LastAs: 0
      AttrID: 0xffffffff            Neighbor: ::
       Flags: 0x10004            OrigNextHop: ::1
       Label: NULL               RealNextHop: ::1
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: 6::/64
   Protocol: Static
  Process ID: 0
   SubProtID: 0x0                        Age: 00h01m47s
       NibID: 0x21000000              LastAs: 0
       Flags: 0x10080            OrigNextHop: 5::2
       Label: NULL               RealNextHop: 3::3
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: 12::/96
   Protocol: Direct
  Process ID: 0
       NibID: 0x20000003              LastAs: 0
       Flags: 0x10080            OrigNextHop: ::
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: 12::1/128
   Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                        Age: 00h01m45s
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: FF::11/128
  Process ID: 0
   SubProtID: 0x6                        Age: 00h00m33s
     TableID: 0xa                     OrigAs: 200
       NibID: 0x26000000              LastAs: 200
      AttrID: 0x1                   Neighbor: 12::2
       Flags: 0x10060            OrigNextHop: 12::2
       Label: NULL               RealNextHop: 12::2
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
表1-8 display ipv6 routing-table verbose命令显示信息描述表
Destination
目的网络/主机的IPv6地址和前缀
Protocol
发现该路由的路由协议类型:
·     Direct:直连路由
·     Static:静态路由
·     RIPng:RIPng路由协议
·     OSPFv3:OSPFv3路由协议
·     BGP4+:BGP4+路由协议
·     LDP:LDP标签分发协议
·     SLSP:静态LSP
·     PIM:PIM
·     MSTATIC:组播静态路由
·     O_INTRA:OSPF区域内路由
·     O_INTER:OSPF区域间路由
·     O_SUM:OSPF聚合路由
·     IS_SUM:IS-IS聚合路由
·     SRv6:SRv6 路由
Process ID
进程号
SubProtID
路由子协议ID
Age
此路由在路由表中存在的时间
Cost
路由的度量值
Preference
路由的优先级
IpPre
IP优先级值
QosLocalID
QoS本地ID,N/A表示无效值
Tag
路由标记
路由状态描述:
·     Active:有效的单播路由
·     Adv:允许对外发送的路由
·     Inactive:非激活路由标志
·     NoAdv:不允许发布的路由
·     Vrrp:VRRP产生的路由
·     Nat:NAT产生的路由
·     TunE:Tunnel隧道的标志
OrigTblID
原始路由表ID
OrigVrf
TableID
路由所在路由表的ID
OrigAs
初始AS号
NibID
下一跳ID
LastAs
最后AS号
AttrID
路由属性ID号
Neighbor
路由协议的邻居地址
Flags
路由标志位
OrigNextHop
此路由的下一跳地址
Label
标签
RealNextHop
路由真实下一跳
BkLabel
备份标签
BkNexthop
备份下一跳地址
SRLabel
BkSRLabel
SR备份标签
SIDIndex
SID的索引值
InLabel
路由入标签
Tunnel ID
隧道ID
出接口,即到该目的网段的数据包将从此接口发出(当Protocol为SRv6并且转发隧道是SRv6 TE Policy时,出接口显示该Policy的名称)
BkTunnel ID
BkInterface
备份出接口(当Protocol为SRv6并且转发隧道是SRv6 TE Policy时,备份出接口显示该Policy的名称),如果显示信息中存在“...”,则表示有多个备份出接口,此时仅第一个备份出接口生效
IPInterface
IP出接口
BkIPInterface
备份IP出接口
ColorInterface
BkColorInterface
备份Color出接口
TunnelInterface
Tunnel出接口
BkTunnelInterface
备份Tunnel出接口
FtnIndex
FTN表项索引
TrafficIndex
Connector
PathID
路径ID
SRTunnelID
SR隧道ID
SID Type
SID类型,N/A表示没有该属性
NID
FlushNID
实际向FIB下刷的NHLFE表项索引
BkNID
路由协议下刷的备份NHLFE表项索引
BkFlushNID
StatFlags
SRv6流量统计标记
VpnPeerId
Dscp
Exp
SID
BkSID
备用SID,N/A表示没有该属性
CommBlockLen
Locator中的公共前缀长度
OrigLinkID
RealLinkID
display ipv6 routing-table acl命令用来显示通过指定IPv6 ACL过滤的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ]
ipv6-acl-number:基本IPv6 ACL编号,取值范围为2000~2999。
verbose:显示通过指定IPv6 ACL过滤的所有路由的详细信息。如果未指定本参数,只显示通过IPv6 ACL过滤的激活路由的概要信息。
引用IPv6 ACL时,需要注意的是:
·     若引用的IPv6 ACL不存在,或者引用的IPv6 ACL中没有配置规则,则显示所有的IPv6路由信息。
·     在引用的IPv6 ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
# 显示通过IPv6 ACL 2000过滤的激活路由的概要信息。
<Sysname> display ipv6 routing-table acl 2000
Summary count : 6
Destination : ::1/128                                    Protocol  : Direct
Destination: 12::/96                                     Protocol  : Direct
Destination: 12::1/128                                   Protocol  : Direct
Destination: FF::11/128                                  Protocol  : BGP4+
NextHop    : 12::2                                       Preference: 255
以上显示信息的解释请参见表1-7
# 显示通过IPv6 ACL 2000过滤的所有路由的详细信息。
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary count : 6
   Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                        Age: 19h29m12s
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
   Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                        Age: 00h07m57s
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
以上显示信息的解释请参见表1-8
display ipv6 routing-table ipv6-address命令用来显示指定目的地址的IPv6路由信息。
display ipv6 routing-table ipv6-address1 to ipv6-address2命令用来显示指定目的地址范围内的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ]
ipv6-address:IPv6目的地址。
prefix-length:前缀长度,取值范围为0~128。
longer-match:显示满足匹配条件的所有路由信息。关于匹配条件的详细说明,请查看使用指导。
ipv6-address1 to ipv6-address2:IPv6地址范围。ipv6-address1ipv6-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示激活路由的概要信息。
(1)     display ipv6 routing-table ipv6-address
显示满足如下条件的所有激活路由:
·     用户输入的目的IPv6地址同路由表中各条路由的前缀长度值进行与运算;
·     路由表中各条路由的目的IPv6地址同其自身前缀长度值进行与运算;
(2)     display ipv6 routing-table ipv6-address prefix-length
显示满足如下条件的所有激活路由:
·     用户输入的目的IPv6地址同用户输入的前缀长度值进行与运算;
·     路由表中各条路由的目的IPv6地址同用户输入的前缀长度值进行与运算;
·     两次运算结果相同,并且路由表中前缀长度小于等于用户输入的前缀长度的路由条目将被显示出来。
(3)     display ipv6 routing-table ipv6-address longer-match
用户未指定前缀长度时,显示结果与display ipv6 routing-table命令的显示结果相同。
(4)     display ipv6 routing-table ipv6-address prefix-length longer-match
显示满足如下条件的所有激活路由:
(5)     display ipv6 routing-table ipv6-address1 to ipv6-address2
显示ipv6-address1/128到ipv6-address2/128之间的路由,目的IPv6地址与前缀长度(128位)同时在指定范围内才会显示。
# 显示目的IPv6地址/前缀为10::1/127的IPv6路由信息。
<Sysname> display ipv6 routing-table 10::1 127
Summary count: 3
Destination: 10::/64                                     Protocol  : Static
NextHop    : ::                                          Preference: 60
Destination: 10::/68                                     Protocol  : Static
Destination: 10::/120                                    Protocol  : Static
# 显示目的IPv6地址/前缀为10::1/127并且满足匹配条件的IPv6路由信息。
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary count : 3
# 显示目的IPv6地址从100::到300::范围内的IPv6路由信息。
<Sysname> display ipv6 routing-table 100:: to 300::
Summary count : 3
Destination: 100::/64                                    Protocol  : Static
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
# 显示目的IPv6地址/前缀为1:2::3:4/128的IPv6路由的详细信息。
<Sysname> display ipv6 routing-table 1:2::3:4 128 verbose
Summary count : 1
Destination: 1:2::3:4/128
   Protocol: BGP4+ instance abc
  Process ID: 0
   SubProtID: 0x1                        Age: 00h01m14s
     TableID: 0x1                     OrigAs: 200
      AttrID: 0x0                   Neighbor: 2:2::3:4
       Flags: 0x10060            OrigNextHop: 2:2::3:4
       Label: NULL               RealNextHop: 2:2::3:4
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
以上显示信息的解释请参见表1-7
·     display ipv6 routing-table
display ipv6 routing-table prefix-list命令用来显示通过指定前缀列表过滤的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name:IPv6前缀列表的名称,为1~63个字符的字符串,区分大小写。
verbose:显示所有路由的详细信息。如果未指定本参数,只显示激活路由的概要信息。
# 配置地址前缀列表test允许前缀为::1,前缀长度为128的IPv6路由通过。
[Sysname] ipv6 prefix-list test permit ::1 128
# 显示通过前缀列表test过滤的IPv6激活路由的概要信息。
[Sysname] display ipv6 routing-table prefix-list test
Summary count : 1
以上显示信息的解释请参见表1-7
# 显示通过前缀列表test过滤的所有IPv6路由的详细信息。
[Sysname] display ipv6 routing-table prefix-list test verbose
Summary count : 1
   Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                        Age: 08h57m19s
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
以上显示信息的解释请参见表1-8
display ipv6 routing-table protocol命令用来显示指定协议生成或发现的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
inactive:如果配置了该参数,此命令只显示未激活路由信息。如果未指定本参数,将显示所有激活和未激活路由信息。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示路由的概要信息。
# 显示所有IPv6直连路由的概要信息。
<Sysname> display ipv6 routing-table protocol direct
Summary count : 3
Summary count : 3
Summary count : 0
# 显示IPv6静态路由表。
<Sysname> display ipv6 routing-table protocol static
Summary count : 3
Summary count : 3
Destination: 2::2/128                                    Protocol  : Static
NextHop    : fe80::2                                     Preference: 60
NextHop    : fe80::3                                     Preference: 60
Destination: 3::3/128                                    Protocol  : Static
NextHop    : 2::2                                        Preference: 60
Summary count : 0
# 显示IPv6 OpenR路由表。
<Sysname> display ipv6 routing-table protocol openr
Summary count : 1
OpenR6 Routing table status : <Active>
Summary count : 1
Destination: 2::2/128                                    Protocol  : OpenR6
NextHop    : fe80::2                                     Preference: 30
OpenR6 Routing table status : <Inactive>
Summary count : 0
# 显示所有BGP4+路由的详细信息。
<Sysname> display ipv6  routing-table protocol bgp4+ verbose
Summary count : 1
Destination: 22::22/128
  Process ID: 0
   SubProtID: 0x6                        Age: 00h04m15s
       NibID: 0x25000001              LastAs: 200
      AttrID: 0x3                   Neighbor: 121::2
       Flags: 0x10060            OrigNextHop: 121::2
       Label: NULL               RealNextHop: 121::2
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
以上显示信息的解释请参见表1-7
# 显示所有OpenR路由的详细信息。
<Sysname> display ipv6 routing-table protocol openr verbose
Summary count : 1
   Protocol: OpenR6
  Process ID: 0
   SubProtID: 0x1                        Age: 01h28m12s
       Flags: 0x10060            OrigNextHop: 200::6
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
以上显示信息的解释请参见表1-7
display ipv6 routing-table statistics命令用来显示IPv6路由表中路由或前缀的统计信息。
display ipv6 routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] [ prefix ] statistics
如果不指定任何参数时,则显示公网的信息。
# 显示综合路由统计信息。
<Sysname> display ipv6 routing-table statistics
Total prefixes: 8        Active prefixes: 8
DIRECT     5           5           5           0
STATIC     3           3           3           0
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
OpenR6     0           0           0           0
Total      8           8           8           0
<Sysname> display ipv6 routing-table all-routes statistics
Total prefixes: 6        Active prefixes: 6
DIRECT     3           3           3           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
OpenR6     0           0           0           0
Total      6           6           8           2
<Sysname> display ipv6 routing-table vpn-instance vpn1 statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
OpenR6     0           0           0           0
Total      11          11          13          2
<Sysname> display ipv6 routing-table all-vpn-instance statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
OpenR6     0           0           0           0
Total      11          11          13          2
# 显示公网的IPv6前缀统计信息。
<Sysname> display ipv6 routing-table prefix statistics
DIRECT     5             5           5           0
STATIC     1             1           1           0
UNR        0             0           0           0
RIPng      0             0           0           0
OSPFv3     0             0           0           0
IS-ISv6    0             0           0           0
LISP       0             0           0           0
SRv6       0             0           0           0
BGP4+      0             0           0           0
OpenR6     0             0           0           0
Total      6             6           6           0
表1-9 display ipv6 routing-table statistics命令显示信息描述表
Total prefixes
总的前缀数目
Active prefixes
总的激活前缀数目
Proto
路由协议
Routes
总的路由数目
Prefixes
前缀数目
Active
激活的、正在使用的路由数目
Added
Deleted
Total
各种类型路由数目的总和
display ipv6 routing-table summary命令用来显示IPv6路由表的概要信息,包括最大等价路由数、最大可激活路由前缀数、剩余可激活路由前缀数等。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] summary
# 显示公网的路由表概要信息。
<Sysname> display ipv6 routing-table summary
Max ECMP: 32
# 显示vpn1实例的路由表概要信息。
<Sysname> display ipv6 routing-table vpn-instance vpn1 summary
Max ECMP: 32
Threshold value of active routes alert: 65100
以上显示信息的解释请参见表1-5
display max-ecmp-num命令用来显示系统支持最大等价路由的条数。
# 显示系统支持最大等价路由的条数。
<Sysname> display max-ecmp-num
表1-10 display max-ecmp-num命令显示信息描述表
Max-ECMP-Num in use
当前使用的最大等价路由的条数
下次启动后的最大等价路由的条数
·     max-ecmp-num
display rib attribute命令用来显示RIB的路由属性信息。
# 显示RIB的路由属性信息。
<Sysname> display rib attribute
Total number of attribute(s): 10
Detailed information of attribute 0x0:
                  Flag: 0x0
        Address family: IPv4
       Reference count: 0
Act-RT reference count: 0
            Flush flag: 0
      Local preference: 0
Ext-communities number: 26
 Ext-communities value: <RT: 1:1> <RT: 2:2> <RT: 3:3> <RT: 123.123.123.123:65535
                        > <RT: 1234567890:65535> <RT: 123.123.123.123:65534> <RT
                        : 4:4> <RT: 5:5> <RT: 6:6> <RT: 7:7> <RT: 8:8> <RT: 9:9>
                         <RT: 10:10> <RT: 10:1> <RT: 10:11> <RT: 10:12> <RT: 10:
                        13> <RT: 10:14> <RT: 10:15> <RT: 10:16> ...
        AS-path number: 0
         AS-path value: N/A
  SFlow AS-path length: 0
   SFlow AS-path value: N/A
Detailed information of attribute 0x1:
                  Flag: 0x0
              Protocol: BGP
       Reference count: 0
            Flush flag: 0
       Local prefrence: 0
Ext-communities number: 1
 Ext-communities value: <RT: 1:2>
        AS-path number: 0
         AS-path value: N/A
表1-11 display rib attribute命令显示信息描述表
attribute的总个数
Flag
标志位
Protocol
产生该属性的协议
Address family
地址簇类型
Reference count
引用计数
被激活路由引用次数
Flush flag
下刷FIB标记,0表示属性没有下刷FIB,1表示属性已经下刷FIB
Local prefrence
本地优先级
扩展团体属性个数
扩展团体属性值(个数为0显示N/A,最多显示20个,超出部分用…表示)
Communities number
团体属性个数
Communities value
AS-path number
AS-path个数(AS-path个数为所有AS号之和)
AS-path value
AS-path值(AS-path值不区分AS-set、AS-sequence、联盟AS-set、联盟AS-sequence;个数为0显示N/A,最多显示20个,超出部分用…表示)
sFlow AS-path属性长度
SFlow AS-path value
sFlow AS-path值(长度为0显示N/A,最多显示80个,超出部分用…表示)
display rib graceful-restart命令用来显示RIB的GR状态信息。
# 显示RIB的GR状态信息。
<Sysname> display rib graceful-restart
Protocol GR state:
 1    DIRECT     100      30   End      No/No
 2    STATIC     480      34   End      No/No
 3    OSPF       480      36   End      No/No
 4    ISIS       480      32   End      No/No
 5    BGP instance abc
                 480      22   End      No/No
 6    BGP instance default
                 480      25   End      No/No
 7    LDP        480      35   End      No/No
 8    SLSP       480      29   End      No/No
 9    OpenR      480      85   End      No/No
表1-12 display rib graceful-restart命令显示信息描述表
RIB GR state
RIB GR状态:
·     Start:协议GR开始
·     IGP end:所有IGP协议GR结束
·     VPN-triggering end:VPN路由触发优选结束
·     VPN-calculation end:VPN路由优选结束
·     Routing protocol end:所有路由协议GR结束
·     NSR-calculation unfinished:NSR优选未完成状态
·     Triggering start:所有路由触发优选开始
·     Triggering end:所有路由触发优选结束
·     Phase1-calculation end:第一阶段优选结束
·     All end:所有协议GR结束
·     Phase2-calculation end:第二阶段优选结束
RCOM GR state
RCOM GR状态:
·     Start:协议GR开始
·     VPN-notification end:VPN路由上报结束
·     Notification end:所有路由上报结束
·     Flush start:开始下刷FIB
·     Flush end:下刷FIB结束
Protocol GR state
协议GR状态
No.
编号
Protocol
协议名称
Lifetime
倒换过程中协议的路由信息/标签信息在RIB中的存活时间,单位为秒
FD
协议进程与RIB连接的句柄
协议GR状态:
·     Init:协议GR初始化状态
·     Listen:协议GR监听状态
·     Idle:协议GR空闲状态
·     Active:协议GR激活状态
·     Start:协议GR开始状态
·     End:协议GR结束状态
Start/End
·     No:表示该消息未发送
·     Yes:表示该消息已发送
display rib nib命令用来显示RIB的下一跳信息。
display rib nib [ sub-nib nib-id ] [ verbose ]
self-originated:路由管理自己生成的下一跳信息。
nib-id:路由下一跳信息的ID值,取值范围为十六进制数1~ffffffff。
protocol protocol:显示指定路由协议生成的下一跳信息。
# 显示RIB的下一跳信息。
<Sysname> display rib nib
Total number of nexthop(s): 176
      NibID: 0x10000000           Sequence: 0
        Age: 00h01m50s
   UserKey1: 0x0                   Nexthop: 0.0.0.0
   UserKey3: 0x0                 LocalAddr: 0.0.0.0
   TopoNthp: 0                     ExtType: 0x0
     LinkID: 0x0
 OriNexthop: 0.0.0.0
      NibID: 0x10000001           Sequence: 1
        Age: 00h01m50s
   UserKey1: 0x0                   Nexthop: 127.0.0.1
   UserKey3: 0x0                 LocalAddr: 127.0.0.1
     LinkID: 0x0
 OriNexthop: 0.0.0.0
      NibID: 0x10000002           Sequence: 2
       Type: 0x5                   Flushed: Yes
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: 0.0.0.0
      NibID: 0x16000000           Sequence: 3
       Type: 0x21                  Flushed: No
        Age: 00h01m50s
   UserKey1: 0x0                   Nexthop: 12.1.1.2
   UserKey2: 0x0                   IFIndex: 0x0
     LinkID: 0x0
 OriNexthop: 0.0.0.0
   Instance: abc
表1-13 display rib nib命令显示信息描述表
Total number of Nexthop(s)
总的下一跳个数
NibID
下一跳ID
Sequence
下一跳序列号
下一跳类型
Flushed
是否下刷FIB
Age
下一跳信息最近一次更新的时间
UserKey0
第一个协议保留数据
UserKey1
第二个协议保留数据
UserKey2
第三个协议保留数据
UserKey3
第四个协议保留数据
VrfNthp
‌下一跳所在VPN索引,显示为0表示公网
Nexthop
下一跳地址
IFIndex
接口索引
LocalAddr
本地接口地址
TopoNthp
(暂不支持子拓扑)(暂不支持子拓扑)下一跳所在拓扑索引,对于IPv4路由,显示为0表示公网拓扑;对于IPv6路由,显示为Invalid
ExtType
NIB扩展类型
Color
Color扩展团体属性
COFlag
Color的下一跳标志位
LinkID
SDWAN TTE连接的Link ID
SIDIndex
SID的索引值
Instance
BGP实例名称
SubNibID
子下一跳的ID
SubSeq
子下一跳的序列号
NthpCnt
子下一跳的下一跳计数
Samed
子下一跳中相同下一跳计数
NthpType
子下一跳类型:
·     IP:下一跳是IP转发类型
·     MPLS:下一跳是MPLS转发类型
SRPName
(暂不支持)SR-MPLS TE Policy的名称
OriNexthop
路由的原始下一跳地址,如果是从BGP更新消息中获得的路由,则该地址为接收到的消息中的下一跳IP地址
# 显示RIB下一跳详细信息。
<Sysname> display rib nib verbose
        Age: 00h01m50s
   UserKey2: 0x0                   IFIndex: 0x10002
     LinkID: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 6                 FlushRefCnt: 2
 1 nexthop(s):
PrefixIndex: 0                 OrigNexthop: 0.0.0.0
  RelyDepth: 0                 RealNexthop: 0.0.0.0
  Interface: NULL0               LocalAddr: 0.0.0.0
   TunnelID: N/A                  Topology: base
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 13                FlushRefCnt: 5
 1 nexthop(s):
PrefixIndex: 0                 OrigNexthop: 127.0.0.1
  RelyDepth: 0                 RealNexthop: 127.0.0.1
  Interface: InLoop0             LocalAddr: 127.0.0.1
      NibID: 0x15000003           Sequence: 3
       Type: 0x43                  Flushed: Yes
        Age: 00h01m50s
   UserKey0: 0x100010000           VrfNthp: 0
   UserKey1: 0x0                   Nexthop: 22.22.22.22
     LinkID: 0x0
 OriNexthop: 0.0.0.0
   Instance: default
     RefCnt: 9                 FlushRefCnt: 3
     Policy: tnl-policy1
 1 nexthop(s):
PrefixIndex: 0                 OrigNexthop: 22.22.22.22
  RelyDepth: 1                 RealNexthop: 13.1.1.2
  Interface: GE0/1/3             LocalAddr: 13.1.1.1
  TunnelCnt: 1                         Vrf: default-vrf
   TunnelID: 1025                 Topology: base
表1-14 display rib nib verbose命令显示信息描述表
总的下一跳个数
NibID
下一跳ID
Sequence
下一跳序列号
下一跳类型
Flushed
是否下刷FIB
Age
下一跳信息最近一次更新的时间
UserKey0
第一个协议保留数据
UserKey1
第二个协议保留数据
UserKey2
第三个协议保留数据
UserKey3
第四个协议保留数据
VrfNthp
下一跳所在VPN索引,显示为0表示公网
Nexthop
下一跳地址
ExtType
NIB扩展类型
SubNibID
子下一跳的ID
SubSeq
子下一跳的序列号
NthpCnt
子下一跳的下一跳计数
Samed
子下一跳中相同下一跳计数
NthpType
子下一跳类型:
·     IP:下一跳是IP转发类型
·     MPLS:下一跳是MPLS转发类型
Policy
隧道策略名
x nexthop (s)
下一跳具体值(前面数值表示下一跳个数)
PrefixIndex
等价时下一跳序号
Vrf
‌VPN实例名,显示为default-vrf表示公网
OrigNexthop
原始下一跳
RealNexthop
真实下一跳
出接口
LocalAddr
本地接口地址
IFIndex
接口索引
TopoNthp
Color
Color扩展团体属性
COFlag
Color的下一跳标志位
LinkID
SDWAN TTE连接的Link ID
SIDIndex
SID的索引值
SRPName
OriNexthop
RelyDepth
迭代深度
TunnelCnt
迭代到隧道的个数
TunnelID
迭代到隧道的ID
Topology
(暂不支持子拓扑)(暂不支持子拓扑)拓扑名称,对于IPv4路由,显示为base表示公网拓扑;对于IPv6路由,显示为空
Weight
等价路由各路由的权重,取值为0表示不是等价路由
Instance
BGP实例名称
RefCnt
下一跳信息的引用计数
FlushRefCnt
下一跳信息的下刷引用计数
Flag
下一跳信息的标志位
Version
下一跳信息的版本号
Flags
当前下一跳的标志位
SRPolicyNID
(暂不支持)SR-MPLS TE Policy迭代路由的下一跳ID
SRInterface
(暂不支持)SR-MPLS TE Policy迭代路由的出接口
ColorWeight
(暂不支持)SR-MPLS TE Policy中Color的权重值
Locator
SID所属Locator段的IPv6前缀,N/A表示没有该属性
OrigLinkID
RealLinkID
display route-direct nib命令用来显示直连路由下一跳信息。
# 显示直连路由下一跳信息。
<Sysname> display route-direct nib
Total number of nexthop(s): 116
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: 0.0.0.0
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: 0.0.0.0
表1-15 display route-direct nib命令显示信息描述表
总的下一跳个数
NibID
NIB ID号
Sequence
NIB序列号
NIB类型
Flushed
是否下刷FIB
Age
下一跳信息最近一次更新的时间
UserKey0
NIB协议保留数据1
UserKey1
NIB协议保留数据2
UserKey2
第三个协议保留数据
UserKey3
第四个协议保留数据
Color
Color扩展团体属性
COFlag
Color的下一跳标志位
LinkID
SDWAN TTE连接的Link ID
SIDIndex
SID的索引值
VrfNthp
Nexthop
下一跳信息
IFIndex
接口索引
LocalAddr
本地接口地址
TopoNthp
ExtType
NIB扩展类型
SRPName
OriNexthop
# 显示直连路由下一跳详细信息。
<Sysname> display route-direct nib verbose
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 2                 FlushRefCnt: 0
 1 nexthop(s):
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 5                 FlushRefCnt: 0
 1 nexthop(s):
表1-16 display route-direct nib verbose命令显示信息描述表
总的下一跳个数
NibID
NIB ID号
Sequence
NIB序列号
NIB类型
Flushed
是否下刷FIB
Age
下一跳信息最近一次更新的时间
UserKey0
NIB协议保留数据1
UserKey1
NIB协议保留数据2
UserKey2
第三个协议保留数据
UserKey3
第四个协议保留数据
VrfNthp
下一跳所在VPN索引,显示为0表示公网
Nexthop
下一跳信息
x nexthop (s)
下一跳具体值(前面数值表示下一跳个数)
PrefixIndex
等价时下一跳序号
Vrf
OrigNexthop
原始下一跳
RealNexthop
真实下一跳
出接口
localAddr
本地接口地址
RelyDepth
迭代深度
TunnelCnt
迭代到隧道的个数
TunnelID
迭代到隧道的ID
Topology
Weight
RefCnt
下一跳信息的引用计数
FlushRefCnt
下一跳信息的下刷引用计数
Flag
下一跳信息的标志位
Version
下一跳信息的版本号
IFIndex
接口索引
TopoNthp
ExtType
NIB扩展类型
Color
Color扩展团体属性
COFlag
Color的下一跳标志位
LinkID
SDWAN TTE连接的Link ID
SIDIndex
SID的索引值
SRPName
OriNexthop
Flags
具体下一跳信息的标志位
SRPolicyNID
SRInterface
ColorWeight
Locator
OrigLinkID
RealLinkID
ecmp mode enchaned命令用来使能IPv4/IPv6等价路由增强模式。
undo ecmp mode命令用来关闭IPv4/IPv6等价路由增强模式。
ecmp mode enhanced
undo ecmp mode
IPv4/IPv6等价路由增强模式处于关闭状态。
当去往同一目的地址存在多条等价路由时,设备在转发去往该目的地址的报文时,会在各条路径间实现负载分担;如果其中一条或者多条路径失效,所有业务流量会在剩余的可用路径间重新进行一次分配,实现新的负载均衡。
如果为了保持业务的连续性,需要保持在可用路径上转发的业务流量不改变转发路径,仅将故障路径上的原业务流量在可用路径上进行平均分配,可以配置等价路由增强模式功能。
本配置在设备重启后才能生效,进行设备重启前请评估重启对网络造成的影响,做好相关准备工作。
# 配置IPv4/IPv6等价路由增强模式。
[Sysname] ecmp mode enhanced
The configuration will take effect at the next reboot. Continue? [Y/N]:y
Reboot device to make the configuration take effect.
·     display ecmp mode
1.1.30  fib lifetime
fib lifetime命令用来配置IPv4/IPv6路由在FIB中的最大存活时间。
undo fib lifetime命令用来恢复缺省情况。
fib lifetime seconds
undo fib lifetime
IPv4/IPv6路由在FIB中的最大存活时间为600秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
seconds:路由在FIB中的最大存活时间,取值范围为0~6000,单位为秒。取值为0时表示,协议或RIB进程倒换并重新恢复后,会立即通知FIB老化表项。
配置本命令后,协议在未配置GR或NSR的情况下,协议或RIB倒换重新恢复后,会延迟配置的seconds,再通知FIB老化表项。
# 配置IPv4路由在FIB中的最大存活时间为60秒。
[Sysname] rib
[Sysname-rib-ipv4] fib lifetime 60
flush route-attribute命令用来配置RIB向FIB下发路由时会携带属性消息。
undo flush route-attribute命令用来取消该配置。
flush route-attribute protocol
undo flush route-attribute protocol
RIB向FIB下发路由时不携带属性消息。
RIB IPv4地址族视图
protocol:路由协议,目前只支持BGP。
# 配置RIB向FIB下发BGP路由时会携带属性消息。
[Sysname] rib
[Sysname-rib-ipv4] flush route-attribute bgp
inter-protocol fast-reroute命令用来开启RIB IPv4/IPv6地址族的不同协议间快速重路由功能。
undo inter-protocol fast-reroute命令用来关闭RIB IPv4/IPv6地址族的不同协议间快速重路由功能。
inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
undo inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
不同协议间快速重路由功能处于关闭状态。
RIB IPv4地址族视图
RIB IPv6地址族视图
vsys-admin
vpn-instance vpn-instance-name:开启指定VPN实例的不同协议间快速重路由功能。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则开启RIB IPv4/IPv6地址族中公网的不同协议间快速重路由功能。
通过配置不同协议间快速重路由功能,可将不同协议的下一跳作为备份下一跳。当路由器检测到网络故障时,将使用备份下一跳替换失效下一跳,通过备份下一跳来指导报文的转发,从而大大缩短了流量中断的时间。
如果RIB表中去往同一目的地的不同路由的下一跳和出接口均相同,使用该命令不会生成备份下一跳。
使用不同协议间的快速重路由功能生成备份下一跳时可能会造成环路。
# 开启RIB IPv4地址族中公网的不同协议间快速重路由功能。
[Sysname] rib
[Sysname-rib-ipv4] inter-protocol fast-reroute
ip load-sharing mode命令用来配置负载分担方式。
undo ip load-sharing mode命令用来恢复缺省情况。
ip load-sharing mode per-flow [ algorithm algorithm-number [ seed seed-number ] | [ dest-ip | dest-port | ingress-port | ip-pro | src-ip | src-port ] * | tunnel { all | inner | outer } ] { global | slot slot-number }
undo ip load-sharing mode [ per-flow [ algorithm algorithm-number [ seed seed-number ] | [ dest-ip | dest-port | ingress-port | ip-pro | src-ip | src-port ] * | tunnel { all | inner | outer } ] ] { global | slot slot-number }
设备使用基于报文的目的IP地址逐流进行报文的负载分担。
per-flow:基于报文逐流进行负载分担。
algorithm algorithm-number:基于报文逐流进行负载分担的算法切换。algorithm-number指定要进行算法切换的算法编号。取值范围为0~15。
seed seed-number:负载分担算法的起始HASH值。取值范围为0~ffff。
dest-ip:基于报文的目的IP地址逐流进行负载分担。
dest-port:基于报文的目的端口逐流进行负载分担。
flow-label:基于IPv6报文的流标签逐流进行负载分担,仅IPv6报文支持本参数。
ingress-port:基于报文的入端口逐流进行负载分担。
ip-pro:基于报文的IP协议号逐流进行负载分担。
src-ip:基于报文的源IP地址逐流进行负载分担。
src-port:基于报文的源端口逐流进行负载分担。
per-packet:基于报文逐包进行负载分担。
global:表示全局配置。
slot slot-number:在指定单板上配置负载分担方式。slot-number表示单板所在的槽位号。如果未指定本参数,则在所有单板上配置负载分担方式。
当负载分担不够均匀时,可以通过修改seed参数的值来进行调整。
# 配置指定slot基于报文逐流进行负载分担。
[Sysname] ip load-sharing mode per-flow slot 1
# 配置指定slot基于报文逐流进行负载分担,算法级别为2,编号为1。
[Sysname] ip load-sharing mode per-flow level 2 algorithm 1 slot 1
ip load-sharing symmetric enable命令用来开启对称负载分担功能。
undo ip load-sharing symmetric enable命令用来关闭对称负载分担功能。
对称负载分担功能处于关闭状态。
开启对称负载分担功能后,对于源IP为A、目的IP为B的流量,和源IP为B、目的IP为A的流量,将负载分担到同一条路径。
# 开启对称负载分担功能。
[Sysname] ip load-sharing symmetric enable
ipv6 max-ecmp-num命令用来配置系统支持IPv6最大等价路由的条数。
ipv6 max-ecmp-num number
以系统支持的最大等价路由条数为准。
number:IPv6最大等价路由的条数,取值范围为1~128。
# 配置系统支持IPv6最大等价路由的条数为10。
[Sysname] ipv6 max-ecmp-num 10
重启后,系统支持IPv6最大等价路由的条数为10。
·     display ipv6 max-ecmp-num
ipv6 route fast-switchover enable命令用来开启IPv6路由快速切换功能。
undo ipv6 route fast-switchover enable命令用来关闭IPv6路由快速切换功能。
IPv6路由快速切换功能处于关闭状态。
在未开启本功能的情况下,当某个物理接口为大量路由(包括等价路由和主备路由的主路由)连接下一跳的出接口时,如果该接口所在的链路故障时,设备需要先删除失效链路对应的所有ND表项,然后通知FIB删除失效的FIB表项,处理时间过长,流量无法快速切换到可用路径。通过开启本功能,当接口所在的链路故障时,设备直接通知FIB删除失效的FIB表项,以加快路由的切换、缩短流量中断的时间。
# 开启IPv6路由快速切换功能。
[Sysname] ipv6 route fast-switchover enable
ipv6 route-direct track命令用来配置IPv6直连路由与Track项关联。
undo ipv6 route-direct track命令用来恢复缺省情况。
ipv6 route-direct track track-entry-number degrade-cost cost-value
未配置IPv6直连路由与Track项关联。
track-entry-number:指定Track项序号,取值范围为1~1024。
degrade-cost cost-value:当Track项状态变为Negative后直连路由的开销值,取值范围为1~4294967295。
不能通过重复执行本命令修改IPv6直连路由关联的Track项。如需修改IPv6直连路由关联的Track项,请先通过undo ipv6 route-direct track命令取消IPv6直连路由关联的Track项,再执行ipv6 route-direct track命令。有关Track的详细介绍,请参见“可靠性配置指导”中的“Track”。
# 在接口Ten-GigabitEthernet0/0/6上配置IPv6直连路由与序号为1的Track项关联,并设置Track项状态变为Negative后直连路由的开销值为200。
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] ipv6 route-direct track 1 degrade-cost 200
1.1.38  max-ecmp-num
max-ecmp-num命令用来配置系统支持最大等价路由的条数。
max-ecmp-num number
以系统支持的最大等价路由条数为准。
number:最大等价路由的条数,取值范围为1~128。
# 配置系统支持最大等价路由的条数为10。
[Sysname] max-ecmp-num 10
重启后,系统支持最大等价路由的条数为10。
·     display max-ecmp-num
maintenance-probe enable命令用来开启MTP(Maintain Probe,维护探测器)功能。
undo maintenance-probe enable命令用来关闭MTP功能。
MTP功能处于关闭状态。
开启MTP功能后,当与邻居间的路由协议报文超时时,设备会向超时的邻居发起Ping操作和Tracert操作并记录结果,相关信息可以通过display bgp troubleshooting等路由协议模块的显示命令查看,也可以通过display logbuffer命令查看MTP的详细信息。
# 开启MTP功能。
[Sysname] maintenance-probe enable
·     display bgp troubleshooting(三层技术-IP路由命令参考/BGP)
·     display logbuffer(网络管理和监控命令参考/信息中心)
nexthop recursive-lookup restrain clear-interval命令用来配置清除下一跳循环迭代惩罚计数的时间间隔。
undo nexthop recursive-lookup restrain clear-interval命令用来恢复缺省情况。
nexthop recursive-lookup restrain clear-interval interval
清除下一跳循环迭代惩罚计数的时间间隔为600秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
clear-interval interval:清除下一跳循环迭代惩罚计数的时间间隔。interval表示时间间隔,取值范围1~65535,单位为秒。
下一跳循环迭代惩罚计数达到20次后,设备将启动抑制,即停止根据下一跳信息查找直连出接口的操作。interval时间后,设备将停止对下一跳循环迭代进行抑制,并将下一跳循环迭代惩罚计数清零。
# 配置清除下一跳循环迭代计数的时间间隔为100秒。
[Sysname] rib
[Sysname-rib-ipv4] nexthop recursive-lookup restrain clear-interval 100
nexthop recursive-lookup restrain disable命令用来关闭下一跳循环迭代抑制功能。
undo nexthop recursive-lookup restrain disable命令用来开启下一跳循环迭代抑制功能。
下一跳循环迭代抑制功能处于开启状态。
RIB IPv4地址族视图
RIB IPv6地址族视图
在路由迭代过程中,若迭代路径包含该路由本身,则认为发生循环迭代。循环迭代将导致本次迭代失败并触发继续查找其他依赖路由。当大量路由的下一跳相同,且该下一跳因不断进行循环迭代导致路由频繁震荡时,系统会频繁处理大量的路由变化,这样会占用大量系统资源,导致CPU占用率升高,影响设备性能。
不断进行循环迭代时,迭代失败次数(下一跳循环迭代惩罚计数)会累计一次,当惩罚计数达到一定数量时,将不再进行路由迭代,从而解决上述问题。
用户不关心循环迭代造成的CPU占用率升高时,可以关闭下一跳循环迭代抑制功能。
# 关闭下一跳循环迭代抑制功能。
[Sysname] rib
[Sysname-rib-ipv4] nexthop recursive-lookup restrain disable
non-stop-routing命令用来使能路由的NSR功能。
undo non-stop-routing命令用来关闭路由的NSR功能。
non-stop-routing
路由的NSR功能处于关闭状态。
RIB IPv4地址族视图
RIB IPv6地址族视图
# 使能IPv4路由的NSR功能。
[Sysname] rib
[Sysname-rib-ipv4] non-stop-routing
primary-path-detect bfd命令用来配置协议间快速重路由或等价路由通过BFD检测主路由的下一跳是否可达。
undo primary-path-detect bfd命令用来取消协议间快速重路由或等价路由通过BFD检测主路由的下一跳是否可达的配置。
primary-path-detect bfd { ctrl | echo } [ inter-protocol-frr | protocol-ecmp protocol ]
undo primary-path-detect bfd [ inter-protocol-frr | protocol-ecmp protocol ]
未配置协议间快速重路由或等价路由通过BFD检测主路由的下一跳是否可达。
RIB IPv4地址族视图
RIB IPv6地址族视图
ctrl:配置通过控制报文方式的BFD会话检测主路由的下一跳是否可达。
echo:配置通过echo报文方式的BFD会话检测主路由的下一跳是否可达。
inter-protocol-frr:配置不同协议间快速重路由通过BFD会话检测主路由的下一跳是否可达。
protocol-ecmp protocol:配置指定路由协议的等价路由通过BFD会话检测主路由的下一跳是否可达。在RIB IPv4地址族视图中,该参数的取值包括bgpisisospfstatic。在RIB IPv6地址族视图中,对于控制报文方式的BFD会话,该参数的取值包括bgp4+isisv6ospfv3static;对于echo报文方式的BFD会话,该参数的取值包括bgp4+static
配置本命令后,设备会自动创建一个协议类型为IPFRR的BFD会话,通过该BFD会话对主路由的下一跳进行检测,以提高主路由下一跳失效时流量切换到备路由下一跳上的收敛速度:
·     对于不同协议间的快速重路由,主路由指的是去往同一目的地的多条路由中优先级最高的路由。
·     对于指定路由协议的等价路由,主路由指的是形成等价路由的每一条路由。如果在配置路由协议的快速重路由功能时指定了ecmp-shared参数,设备会为包含等价路由的所有路由通过LFA算法选取备份下一跳信息。自动计算的备份下一跳也作为等价路由添加到路由表中,状态为backup,该路由不是主路由,BFD不会检测这种等价路由。
只有存在已经生成了备份下一跳的主路由时,本命令才会生效并自动创建BFD会话。
通过重复执行本命令,可以修改BFD会话的工作方式(echo报文方式或控制报文方式)。
执行本命令时,如果没有指定inter-protocol-frrprotocol-ecmp参数,表示同时配置或取消配置不同协议间快速重路由和指定路由协议的所有等价路由通过BFD会话检测主路由的下一跳是否可达的功能。以此种方式进行的配置,优先级高于通过指定inter-protocol-frrprotocol-ecmp参数进行的配置。例如,当执行了primary-path-detect bfd ctrl命令后,仅可通过primary-path-detect bfd echo 命令修改配置,或通过undo primary-path-detect bfd命令取消配置。
通过控制报文方式的BFD会话检测主路由的下一跳是否可达时,由于控制报文方式的BFD会话需要两端进行协商才能成功建立,用户需要在下一跳设备上手工创建一个静态BFD会话。该BFD会话为控制报文方式的单跳BFD会话,并且会话源IP地址为本端自动创建的BFD会话的目的IP地址、会话目的IP地址为本端自动创建的BFD会话的源IP地址、远端标识符为本端自动创建的BFD会话的本地标识符。主路由下一跳设备上创建满足上述要求的静态BFD会话后,本端设备才能使用控制报文方式的BFD会话来检测主路由的下一跳。有关创建静态BFD会话的详细介绍,请参见“可靠性配置指导”中的“BFD”。
其他业务模块在通过BFD会话检测主路由的下一跳是否可达时,也会自动创建BFD会话(如BGP、OSPF、IS-IS等)。如果其他协议创建的自动BFD会话检测的路由下一跳与RIB主路由的下一跳相同,则设备不会重复自动创建同类型的BFD会话,而是复用其他协议的BFD会话。
# 配置通过控制报文方式的BFD会话检测IS-IS协议所有等价路由的下一跳是否可达。
[Sysname] rib
[Sysname-rib-ipv4] primary-path-detect bfd ctrl protocol-ecmp isis
·     display ip routing-table
·     fast-reroute(三层技术-IP路由命令参考/IS-IS)
·     inter-protocol fast-reroute
protocol lifetime命令用来配置IPv4/IPv6路由和标签在RIB中的最大存活时间。
undo protocol lifetime命令用来恢复缺省情况。
undo protocol protocol [ instance instance-name ] lifetime
IPv4/IPv6路由和标签在RIB中的最大存活时间为900秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
protocol:路由协议。
instance instance-name:BGP实例名称,instance-name为1~31个字符的字符串,区分大小写。如果未指定本参数,将配置所有BGP实例的最大存活时间。只有当protocolbgp时该参数可选。
seconds:最大存活时间,取值范围为1~6000,单位为秒。
如果配置了该命令,且协议配置GR的情况下,需要注意该时间不要与GR时间冲突,即必须要保证协议能够在该时间内完成GR并将全部表项下发RIB,否则会导致GR失败并断流。
# 配置RIB中静态路由和标签的最大存活时间为60秒。
[Sysname] rib
[Sysname-rib-ipv4] protocol static lifetime 60
protocol nexthop recursive-lookup命令用来配置按照路由策略进行迭代下一跳查找。
undo protocol nexthop recursive-lookup命令用来取消该配置。
protocol protocol nexthop recursive-lookup route-policy route-policy-name
undo protocol protocol nexthop recursive-lookup route-policy
没有配置按路由策略进行下一跳迭代查找。
RIB IPv4地址族视图
RIB IPv6地址族视图
protocol:路由协议,RIB IPv4地址族视图下支持bgpstatic,RIB IPv6地址族视图下支持bgp4+
route-policy-name:指定路由策略名,为1~63个字符的字符串,区分大小写。
通过配置按路由策略迭代下一跳,可以对路由迭代的结果进行控制。例如:当路由发生变化时,路由管理需要对非直连的下一跳重新进行迭代。如果不对迭代的结果路由进行任何限制,则路由管理可能会将下一跳迭代到一个错误的转发路径上,从而造成流量丢失。此时,可以通过配置本功能,将错误的依赖路由过滤掉,使路由迭代到通过路由策略过滤的指定依赖路由上。
配置路由策略时,如果配置了apply子句,apply子句不会生效。
配置路由策略时,请确保至少有一个正确的依赖路由能够通过该策略的过滤,否则可能导致相关路由不可达,无法正确指导转发。
# 配置静态路由按照路由策略policy1进行下一跳迭代查找。
[Sysname] rib
[Sysname-rib-ipv4] protocol static nexthop recursive-lookup route-policy policy1
reset ip routing-table statistics protocol命令用来清除路由表中的路由统计信息。
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ip routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
vpn-instance vpn-instance-name:清除指定VPN的路由统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则清除公网的路由统计信息。
all-routes:清除公网和所有VPN实例的路由统计信息。
all-vpn-instance:清除所有VPN实例的路由统计信息。
protocol:清除IPv4路由表中指定路由协议的统计信息。
all:清除IPv4路由表中所有路由协议的统计信息。
如果没有指定all-routesvpn-instanceall-vpn-instance参数,则清除公网的路由统计信息。
# 清除路由表中的路由统计信息。
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 routing-table statistics protocol命令用来清除IPv6路由表中的综合路由统计信息。
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ipv6 routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
protocol:清除IPv6路由表中指定路由协议的统计信息。
all:清除IPv6路由表中所有路由协议的统计信息。
# 清除IPv6路由表中所有路由协议的综合路由统计信息。
<Sysname> reset ipv6 routing-table statistics protocol all
route-direct track命令用来配置直连路由与Track项关联。
undo route-direct track命令用来恢复缺省情况。
未配置直连路由与Track项关联。
不能通过重复执行本命令修改直连路由关联的Track项。如需修改直连路由关联的Track项,请先通过undo route-direct track命令取消直连路由关联的Track项,再执行route-direct track命令。有关Track的详细介绍,请参见“可靠性配置指导”中的“Track”。
# 在接口Ten-GigabitEthernet0/0/6上配置直连路由与序号为1的Track项关联,并设置Track项状态变为Negative后直连路由的开销值为200。
[Sysname-Ten-GigabitEthernet0/0/6] route-direct track 1 degrade-cost 200
1.1.49  rib
rib命令用来进入RIB视图。
undo rib命令用来删除RIB视图下的所有配置。
rib
undo rib
# 进入RIB视图。
[Sysname] rib
[Sysname-rib]
routing-table limit命令用来配置设备支持的最大IPv4/IPv6激活路由前缀数。
undo routing-table limit命令用来恢复缺省情况。
不限制设备支持的最大IPv4/IPv6激活路由前缀数。
RIB IPv4地址族视图
RIB IPv6地址族视图
number:设备支持的最大IPv4/IPv6激活路由前缀数目,取值范围为1~4294967295。
warn-threshold:以百分比形式指定激活路由前缀数目告警阈值,取值范围为1~100。当设备中激活路由前缀数占最大支持激活路由前缀数的百分比达到告警阈值时,可以继续激活新的路由前缀,但会产生一条日志信息。当设备中的激活路由前缀数达到最大激活路由前缀数目时,将不再激活新的路由前缀,新增的路由前缀将被丢弃。
simply-alert:当设备的IPv4/IPv6激活路由前缀数超过最大支持的激活路由前缀数目时,可以继续激活新的路由前缀,但会产生一条日志信息。
RIB IPv4地址族视图下的配置用于控制公网和所有VPN实例内IPv4激活路由的总数。
RIB IPv6地址族视图下的配置用于控制公网和所有VPN实例内IPv6激活路由的总数。
多次执行本命令,最后一次执行的命令生效。
# 配置当前设备上的RIB IPv4地址族视图下公网和所有VPN实例内IPv4激活路由的总数超过1000时,可以继续激活新的路由前缀,但是会产生一条日志信息。
[Sysname] rib
[Sysname-rib-ipv4] routing-table limit 1000 simply-alert
