19-EPON命令参考
01-EPON基本命令
本章节下载: 01-EPON基本命令  (1023.88 KB)
01-EPON基本命令
1 EPON基础
1.1 OLT配置命令
1.1.1 agmp enable
1.1.2 alarm device-fatal-error enable
1.1.3 alarm oam critical-event enable
1.1.4 alarm oam dying-gasp enable
1.1.5 alarm oam local-link-fault enable
1.1.6 alarm onu-laser always-on enable
1.1.7 alarm onu-over-limit enable
1.1.8 alarm registration-error enable
1.1.9 authentication-mode
1.1.10 display epon alarm history
1.1.11 display epon alarm statistics
1.1.12 display epon authentication-mode
1.1.13 display epon fiber-backup group
1.1.14 display epon oam
1.1.15 display epon onu-event
1.1.16 display epon optics-parameters
1.1.17 display epon parameter
1.1.18 display epon statistics
1.1.19 display epon version
1.1.20 display epon workmode
1.1.21 display interface
1.1.22 display olt statistics
1.1.23 display rolt interface
1.1.24 encryption update-time
1.1.25 fiber-backup group
1.1.26 fiber-backup tcp
1.1.27 ftth
1.1.28 grant-filtering enable
1.1.29 interface
1.1.30 interface rolt
1.1.31 interface ronu
1.1.32 max-rtt
1.1.33 member
1.1.34 member interface
1.1.35 monitor enable
1.1.36 oam-discovery-timeout
1.1.37 olt-mode
1.1.38 onu flow
1.1.39 onu invalid-address mode
1.1.40 onu snmp port-limit
1.1.41 port fiber-backup group
1.1.42 port switch-over
1.1.43 port-type
1.1.44 timer monitor
1.1.45 uplink interface
1.1.46 vendor-compatible
1.2 ONU远程配置命令
1.2.1 alarm enable
1.2.2 anti-dhcp-server enable
1.2.3 apply onu template
1.2.4 bind onu-id
1.2.5 blacklist onu-id
1.2.6 deregister onu
1.2.7 display dhcp-client
1.2.8 display epon mac-address
1.2.9 display epon onu-loop-status
1.2.10 display epon onu-template apply-process
1.2.11 display epon onu-update
1.2.12 display onu
1.2.13 display onu loid
1.2.14 display onu mac-address
1.2.15 display onu neighbor
1.2.16 display onu protocol
1.2.17 display onu protocol smart-link uni-bind information
1.2.18 display serial-information
1.2.19 display uni
1.2.20 display vendor-specific information
1.2.21 encryption enable
1.2.22 forward-error-correction
1.2.23 ip address
1.2.24 ipv6 address
1.2.25 management-vlan
1.2.26 onu authentication-domain
1.2.27 onu authentication-format
1.2.28 onu bind auto
1.2.29 onu bind batch
1.2.30 onu bind one-to-one
1.2.31 onu event
1.2.32 onu mac-address timer
1.2.33 onu port-isolate enable
1.2.34 onu protocol enable
1.2.35 onu protocol loopback-detection action
1.2.36 onu protocol smart-link flush enable
1.2.37 onu protocol smart-link uni-bind enable
1.2.38 onu replace enable
1.2.39 onu statistics enable
1.2.40 onu suspicious-loopback-detection enable
1.2.41 onu template
1.2.42 reboot onu
1.2.43 remove offline-onu
1.2.44 reset counters serial
1.2.45 reset counters uni
1.2.46 serial databit
1.2.47 serial parity
1.2.48 serial session protocol-type
1.2.49 serial speed
1.2.50 serial stopbit
1.2.51 shutdown management-vlan-interface
1.2.52 transceiver-txpower
1.2.53 uni auto-negotiation
1.2.54 uni description
1.2.55 uni duplex
1.2.56 uni flow-control
1.2.57 uni mac-address
1.2.58 uni mac-address max-mac-count
1.2.59 uni mdix-mode
1.2.60 uni mirroring-port
1.2.61 uni monitor-port
1.2.62 uni port-isolate
1.2.63 uni qinq
1.2.64 uni restart auto-negotiation
1.2.65 uni shutdown
1.2.66 uni speed
1.2.67 uni statistics enable
1.2.68 uni virtual-cable-test
1.2.69 uni vlan-mode (interface view)
1.2.70 uni vlan-mode (ONU template view)
1.2.71 update onu filename
1.2.72 update onu type
1.2.73 using onu
1 EPON基础
设备支持10G-EPON单板和1G-EPON单板。如无特殊说明,本文一般使用1G-EPON单板上的接口进行举例。
1.1  OLT配置命令
1.1.1  agmp enable
agmp enable命令用来开启AGMP功能。
undo agmp enable命令用来关闭AGMP功能。
agmp enable
undo agmp enable
AGMP功能处于关闭状态。
FTTH视图
在OLT设备开启AGMP功能后,可以通过OLT设备的Web页面来远程管理局域网内的Aolynk S1500E系列交换机。
# 开启AGMP功能。
[Sysname] ftth
[Sysname-ftth] agmp enable
alarm device-fatal-error enable命令用来开启Device Fatal Error告警功能。
undo alarm device-fatal-error enable命令用来关闭Device Fatal Error告警功能。
Device Fatal Error告警功能处于开启状态。
FTTH视图
OLT端口视图
当遇到内存泄露、内存使用率过高或者其他导致系统不可用的错误时,就会产生Device Fatal Error告警。
本命令在OLT端口视图下配置时只对该OLT端口起作用,在FTTH视图下配置时对所有OLT端口生效。针对单个OLT端口,当OLT端口视图下的配置和FTTH视图下的配置不同时,新配置会覆盖旧配置。
# 开启Olt1/0/1端口的Device Fatal Error告警功能。
[Sysname] interface olt 1/0/1
[Sysname-Olt1/0/1] alarm device-fatal-error enable
alarm oam critical-event enable命令用来开启Critical Event告警功能。
undo alarm oam critical-event enable命令用来关闭Critical Event告警功能。
Critical Event告警功能处于开启状态。
FTTH视图
OLT端口视图
Critical Event包含Local Link Fault与Dying Gasp两种事件,当其中一个事件发生时,就会产生Critical Event告警。
# 开启Olt1/0/1端口的Critical Event告警功能。
[Sysname-Olt1/0/1] alarm oam critical-event enable
alarm oam dying-gasp enable命令用来开启Dying Gasp告警功能。
undo alarm oam dying-gasp enable命令用来关闭Dying Gasp告警功能。
Dying Gasp告警功能处于开启状态。
FTTH视图
OLT端口视图
当遇到系统出错、数据加载错误或者其他无法恢复的错误时,就会产生Dying Gasp告警。
# 开启Olt1/0/1端口的Dying Gasp告警功能。
[Sysname-Olt1/0/1] alarm oam dying-gasp enable
alarm oam local-link-fault enable命令用来开启Local Link Fault告警功能。
undo alarm oam local-link-fault enable命令用来关闭Local Link Fault告警功能。
Local Link Fault告警功能处于开启状态。
FTTH视图
OLT端口视图
当OLT的接收方向出现故障时,就会产生Local Link Fault告警。
# 开启Olt1/0/1端口的Local Link Fault告警功能开启。
[Sysname-Olt1/0/1] alarm oam local-link-fault enable
alarm onu-laser always-on enable命令用来开启ONU长发光告警功能。
undo alarm onu-laser always-on enable命令用来关闭ONU长发光告警功能。
alarm onu-laser always-on enable [ action power-off ]
ONU长发光告警功能处于关闭状态。
FTTH视图
OLT端口视图
action power-off:当OLT检测到ONU出现长发光现象时,产生长发光告警并关闭该ONU的Tx电源(PON口的光模块发送电源)。如果不指定该参数,当OLT检测到ONU出现长发光现象时,仅产生长发光告警。
开启ONU长发光告警功能后,当OLT检测到ONU长时间持续发送光信号时,就会产生该告警。
# 开启Olt1/0/1的ONU长发光告警功能。
[Sysname-Olt1/0/1] alarm onu-laser always-on enable
alarm onu-over-limit enable命令用来开启ONU Over Limit告警功能。
undo alarm onu-over-limit enable命令用来关闭ONU Over Limit告警功能。
ONU Over Limit告警功能处于开启状态。
FTTH视图
OLT端口视图
当OLT连接的ONU总数超过系统所支持的规格,就会产生ONU Over Limit告警。
# 开启Olt1/0/1的ONU Over Limit告警功能。
[Sysname-Olt1/0/1] alarm onu-over-limit enable
alarm registration-error enable命令用来开启Registration Error告警功能。
undo alarm registration-error enable命令用来关闭Registration Error告警功能。
Registration Error告警功能处于开启功能。
FTTH视图
OLT端口视图
当ONU在注册过程中发生错误时,就会产生Registration Error告警。
# 开启Olt1/0/1的Registration Error告警功能。
[Sysname] interface olt1/0/1
[Sysname-Olt1/0/1] alarm registration-error enable
authentication-mode命令用来配置OLT认证模式。
undo authentication-mode命令用来删除指定的认证模式配置。
authentication-mode { mac | loid | loid-password }*
undo authentication-mode [ mac | loid | loid-password ]*
OLT基于ONU的MAC地址进行认证。
FTTH视图
OLT端口视图
OLT冗余接口视图
mac:配置OLT基于ONU的MAC地址进行认证。
loid:配置OLT基于ONU的LOID(Logical ONU Identifier,逻辑ONU标识符)进行认证。
loid-password:配置OLT基于ONU的LOID和LOID密码进行认证。
LOID模式和LOID-password模式互斥,不能同时配置。
本命令在接口视图下配置时只对该接口起作用,在FTTH视图下配置时对所有OLT冗余接口和未加入OLT冗余接口的OLT端口生效。对一个OLT端口/OLT冗余接口来说,优先采用该接口的配置,只有该接口未进行配置时,才采用FTTH的配置。
多次执行本命令时,最终生效的认证模式是多次配置的集合。
undo命令不指定参数时,表示恢复为缺省情况。undo命令指定参数时,表示删除指定的认证模式配置。
# 配置端口Olt1/0/1基于ONU的MAC地址或LOID进行认证。
[Sysname-Olt1/0/1] authentication-mode mac loid
display epon alarm history命令用来显示EPON告警信息。
display epon alarm history [ interface interface-type interface-number ] [ count number ] [ from start-time ] [ to end-time ]
interface:显示指定接口的EPON告警信息。如果不指定该参数,将显示所有OLT端口、ONU接口和ONU冗余接口的EPON告警信息。
interface-type:指定接口类型,取值为Olt、Onu或Ronu。
interface-number:指定接口编号。
count number:指定最近发生的EPON告警的显示数量上限,取值范围为1~2000,缺省值为100。如果不指定本参数,则显示最近记录的所有EPON告警。
from start-time:指定显示的EPON告警的起始时间。start-time的格式为yyyy/mm/dd-hh:mm:ss,取值范围为1970/01/01-00:00:00~2035/12/31-23:59:59。如果不指定该参数,则EPON告警的起始时间为取值范围下限。
to end-time:指定显示的EPON告警的结束时间。end-time的格式为yyyy/mm/dd-hh:mm:ss,取值范围为1970/01/01-00:00:00~2035/12/31-23:59:59。结束时间必须大于等于起始时间。如果不指定该参数,则EPON告警的结束时间为取值范围上限。
设备会将最近发生的EPON告警记录在内存中供用户查看,最多可记录2000条,新生成的EPON告警信息优先显示。
显示指定OLT端口的EPON告警信息时,也会显示该OLT端口对应ONU接口的EPON告警信息。
# 显示所有EPON告警信息。
<Sysname> disp epon alarm history
2018/09/28-16:03:30:203 Olt1/0/1 OnuSilence Onu silence which mac is 0011-00ff-00dd.
# 显示指定时间范围发生的最近2条EPON告警信息。
<Sysname> display epon alarm history count 2 from 2018/02/02-10:01:30 to 2018/02/02-13:10:10
2018/02/02-10:15:39:866 Onu1/0/1:1 Uni 20 change to up.
2018/02/02-10:01:30:166 Onu1/0/1:1 Uni 20 change to down.
display epon alarm statistics命令用来显示EPON告警统计信息。
display epon alarm statistics [ interface interface-type interface-number ] [ from start-time ] [ to end-time ]
interface:显示指定接口的EPON告警统计信息。如果不指定该参数,将显示所有OLT端口、ONU接口和ONU冗余接口的EPON告警统计信息。
显示指定OLT端口的EPON告警统计信息时,也会显示该OLT端口对应ONU接口的EPON告警统计信息。
# 显示所有EPON告警统计信息。
<Sysname> display epon alarm statistics
Type                     Count
PortAlarmBer             0
PortAlarmFer             0
表1-1 display epon alarm statistics命令显示信息描述表
告警类型
Count
告警数量
display epon authentication-mode命令用来显示OLT的认证模式。
display epon authentication-mode [ interface interface-type interface-number ]
interface:显示指定接口的认证模式。如果不指定该参数,将显示FTTH认证模式和所有OLT端口、OLT冗余接口的认证模式。
interface-type:指定接口类型,取值为Olt或Rolt。
# 显示FTTH认证模式和所有OLT的认证模式。
<Sysname> display epon authentication-mode
Ftth authentication mode:-
Interface              Authentication-mode
Olt1/0/1               mac and loid
表1-2 display epon authentication-mode命令显示信息描述表
FTTH认证模式
·     未在FTTH视图下配置认证模式时,显示为“-”,此时采用缺省情况的FTTH认证模式
·     在FTTH视图下配置认证模式后,取值可能为:
¡     mac:表示所有OLT缺省基于ONU的MAC地址进行认证。
¡     loid:表示所有OLT缺省基于ONU的LOID进行认证。
¡     loid-password:表示所有OLT缺省基于ONU的LOID和LOID密码进行认证。
¡     mac and loid:表示所有OLT缺省基于ONU的MAC地址或者LOID进行认证
¡     mac and loid-password:表示所有OLT缺省基于ONU的MAC地址或者LOID和LOID密码进行认证
接口名称
Authentication mode
OLT认证模式
·     未在OLT端口/OLT冗余接口视图下配置认证模式时,不显示该OLT端口/OLT冗余接口,此时该OLT采用FTTH的认证模式
·     在OLT端口/OLT冗余接口视图下配置认证模式后,取值可能为:
¡     mac:表示OLT基于ONU的MAC地址进行认证
¡     loid:表示OLT基于ONU的LOID进行认证
¡     loid-password:表示OLT基于ONU的LOID和LOID密码进行认证
¡     mac and loid:表示OLT基于ONU的MAC地址或者LOID进行认证
¡     mac and loid-password:表示OLT基于ONU的MAC地址或者LOID和LOID密码进行认证
display epon fiber-backup group命令用来显示光纤备份组中的端口信息及其主备关系。
display epon fiber-backup group { group-number | all }
group-number:光纤备份组的编号,取值范围为1~120。
all:显示所有光纤备份组的信息。
# 显示所有光纤备份组的信息。其中含有Uplink interface字段的为跨设备光纤备份组。
<Sysname> display epon fiber-backup group all
Fiber backup group 1 information:
 Member         Role        State
 OLT1/0/1       Master      Active
 OLT1/0/2       Standby     Ready
Fiber backup group 2 information:
 Member         Role        State
 OLT1/0/3       Master      Other
 Uplink interface: GigabitEthernet1/0/20
表1-3 display epon fiber-backup group命令显示信息描述表
光纤备份组1的信息
Member
光纤备份组的成员端口(只能为OLT端口)
Role
OLT端口在备份组中的角色:
·     Master:主用端口。对于跨设备光纤备份组,表示命令行指定的主用端口
·     Standby:备用端口。对于跨设备光纤备份组,表示命令行指定的备用端口
OLT端口的状态:
·     Active:端口处于转发状态,为实际主用端口
·     Ready:端口处于备份状态
·     Other:其他情况,例如端口down
Uplink interface
跨设备光纤备份组的上行接口
·     对于跨设备光纤备份组,未配置该接口时,本字段显示为“-”
·     对于普通光纤备份组,本字段不显示
display epon oam命令用来显示ONU的OAM(Operations、Administration and Maintenance,操作、管理与维护)信息。
display epon oam interface interface-type interface-number
interface-type:指定接口类型,取值为Onu或Ronu。
# 显示接口Onu1/0/1:1连接的ONU的OAM信息。
<Sysname> display epon oam interface onu 1/0/1:1
OAM information:
 OAM version: 1
 Multiplexer action: Discard non-OAM PDUs
 Parser action     : Forward non-OAM PDUs to higher layer
 Sending variable-length OAM response PDUs: Not supported
 Interpreting link events                 : Not supported
 OAM mode              : Active
 Unidirectional support: Disabled
 Loopback support      : Disabled
 Maximal PDU size      : 494 bytes
 Identifier            : 433348
表1-4 display epon oam命令显示信息描述表
OAM information
OAM信息
OAM version
OAM版本号
Multiplexer action
设备复用器对于非oam协议数据单元处理方式,取值为:
·     Discard non-OAM PDUs:丢弃非OAM PDU
·     Forward non-OAM PDUs to the lower sublayer:向底层发送非OAM PDU
Parser action
解析器的动作:
·     Forward non-OAM PDUs to the higher layer:向高层发送非OAM PDU
·     Loop back non-OAM PDUs to the lower layer:将非OAM PDU环回给底层
是否支持发送可变长度的响应OAM PDU,取值为:
·     Not supported:不支持
·     Supported:支持
是否支持解释连接事件
·     Not supported:不支持
·     Supported:支持
OAM mode
OAM的工作模式,取值为:
·     Active:主动模式
·     Passive:被动模式
当接收路径不可用时,是否能够发送OAM协议数据单元,取值为:
·     Disabled:不允许发送
·     Enabled:允许发送
Loopback support
是否具有OAM协议远端环回能力,取值为:
·     Disabled:不具有OAM协议远端环回能力
·     Enabled:具有OAM协议远端环回能力
Maximal PDU size
PDU的最大长度,单位为字节
Identifier
产品标识
display epon onu-event命令用来显示ONU的注册和注销记录。
display epon onu-event interface interface-type interface-number
# 显示接口Onu1/0/1:1连接的ONU的注册和注销记录。
<Sysname> display epon onu-event interface onu 1/0/1:1
Date         Time       ONU Event          ONU Status
2015/06/24   14:41:18   Registration       Up
2015/06/24   14:41:59   Deregistration     Down
2015/06/24   14:42:02   Registration       Up
2015/06/24   14:42:49   Deregistration     Down
表1-5 display epon onu-event命令显示信息描述表
Date
ONU事件发生的日期
Time
ONU事件发生的时间
ONU Event
ONU事件:
·     Registration:注册
·     Deregistration:取消注册
ONU Status
发生ONU事件时,ONU的状态:
·     Up:ONU状态为up
·     Down:ONU状态为down
display epon optics-parameters命令用来显示OLT端口的光参数信息。
display epon optics-parameters interface interface-type interface-number
interface-type:指定接口类型,取值为Olt。
interface-number:OLT端口号。
# 显示Olt1/0/1端口的光参数信息。
<Sysname> display epon optics-parameters interface olt 1/0/1
Optical parameters:
 Temperature       :37.50 ℃
 Voltage           :3.27 V
 Bias              :1.74 mA
 Transmitter power :4.36 dBm
表1-6 display epon optics-parameters命令显示信息描述表
Optical parameters
光参数信息
Temperature
温度
Voltage
电压
Bias
偏置电流
对于10G-EPON单板上的OLT端口,该字段变为Bias(1G/10G),并同时显示1G-EPON接口和10G-EPON接口的偏置电流,例如24.36 mA/80.72 mA
Transmitter power
发射功率
对于10G-EPON单板上的OLT端口,该字段变为Transmitter power(1G/10G),并同时显示1G-EPON接口和10G-EPON接口的发射功率,例如4.48 dBm/3.44 dBm
display epon parameter命令用来显示EPON系统参数信息。
(独立运行模式)
display epon parameter slot slot-number
display epon parameter chassis chassis-number slot slot-number
slot slot-number:显示指定单板上的EPON系统参数信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的EPON系统参数信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 显示指定slot上EPON参数的相关信息。
<Sysname> display epon parameter slot 1
Parameters:
     OUI: 111111     OAM version:3.0
     OUI: 111111     OAM version:2.1
     OUI: 111111     OAM version:2.0
     OUI: 111111     OAM version:1.3
     OUI: 111111     OAM version:1(default)
     Key update timer            : 10 seconds
     OAM discovery timeout timer : 3.0 seconds
表1-7 display epon parameter命令显示信息描述表
EPON系统参数
OUI
设备允许通信的ONU的OUI(Organizationally Unique Identifier,机构唯一性标识)
OAM version
通信时使用的扩展OAM版本号
Key update timer
LLID密钥的更新周期,单位为秒
扩展OAM连接过程中消息超时时间,单位为秒
display epon statistics命令用来显示ONU的统计信息。
display epon statistics interface interface-type interface-number
仅当接口处于up状态时,才能显示对应ONU的统计信息。
该命令统计的是最近一个采样周期内的错误率,当统计值小于1e-9时显示为0。
# 显示接口Onu1/0/1:1连接的ONU的统计信息。
<Sysname> display epon statistics interface onu 1/0/1:1
ONU statistics:
 Bit error rate(in 1e-9 unit)  : 0
 Frame error rate(in 1e-9 unit): 0
表1-8 display epon statistics命令显示信息描述表
ONU statistics
ONU的统计信息
平均数据位错误率
平均数据帧错误率
display epon version命令用来显示OLT或ONU的版本信息。
display epon version interface interface-type interface-number
仅当接口的状态为up时,才能显示版本信息。
# 显示OLT的版本信息。
<Sysname> display epon version interface olt 1/0/1
OLT version information:
 Firmware major version: 0
 Firmware minor version: 3
 Hardware major version: 1
 Hardware minor version: 1
 Supported LLIDs       : 63
# 显示ONU的版本信息。
<Sysname> display epon version interface onu 1/0/1:1
ONU version information:
 Hardware major version: A
 Hardware minor version: 0
 Supported LLIDs       : 1
 MAC type of UNI port  : MII
 CTC version           : 2.1
表1-9 display epon version命令显示信息描述表
OLT设备的版本信息
ONU设备的版本信息
固件主版本
固件小版本
硬件主版本
硬件小版本
Supported LLIDs
支持的LLID数目,LLID(Logical Link Identifier,逻辑链路标识)是OLT动态分配给ONU的身份标识码
UNI(User Network Interface,用户网络接口)MAC类型:
·     GMII(Gigabit Media Independent Interface):千兆媒质无关接口
·     MII:百兆媒质无关接口
CTC version
OLT与指定ONU建立扩展OAM连接时使用的CTC标准版本
display epon workmode命令用来显示OLT或ONU的工作模式。
display epon workmode interface interface-type interface-number
如果端口类型是OLT,那么还可以显示其MAC地址和DBA(Dynamic Bandwidth Allocation,动态带宽分配)算法模式。
仅当ONU已绑定到ONU接口/ONU冗余接口,才能显示该ONU的工作模式。
# 显示OLT的工作模式。
<Sysname> display epon workmode interface olt 1/0/1
Port status: Open
MAC address: 000f-e2a1-1027
DBA mode   : Internal
# 显示接口Onu1/0/1:1连接的ONU的工作模式。
<Sysname> display epon workmode interface onu 1/0/1:1
Port status: Open
FEC mode   : Disabled
表1-10 display epon-workmode命令显示信息描述表
Port status
接口的内部状态:
·     Open表示接口已经开启
·     Closed表示接口己经关闭
·     (仅OLT)Resetting表示芯片处于重启过程中
·     (仅ONU)Pending表示ONU已注册但未通过鉴权
·     Unknown表示未知状态
MAC address
OLT端口的MAC地址
同一设备下所有的OLT端口共用一个MAC地址
DBA mode
OLT采用的DBA算法:
·     Internal表示内部DBA算法
·     External表示外部DBA算法
FEC mode
FEC(Forward Error Correction,前向纠错)功能模式,取值为:
·     Disabled表示该功能处于关闭状态
·     Enabled表示该功能处于开启状态
display interface命令用来显示OLT端口、ONU接口、OLT冗余接口或ONU冗余接口的相关信息。
display interface [ interface-type [ interface-number ] ] [ brief [ description | down ] ]
interface-type:指定接口类型,取值为Olt、Onu、Rolt或Ronu。如果不指定接口类型,将显示设备支持的所有接口的相关信息。
interface-number:表示接口的编号。如果指定接口类型,不指定interface-number参数,将显示所有该类型接口的相关信息。
description:用来显示用户配置的接口的全部描述信息。如果某接口的描述信息超过25个字符,不指定该参数时,只显示描述信息中的前25个字符,超出部分不显示。
OLT冗余接口不支持统计接收和发送的报文。
显示10G-EPON单板上OLT端口的详细信息时,Input/Output系列字段和10G-EPON Input/Output系列字段分别用于显示该OLT端口内部1G-EPON接口和10G-EPON接口的报文统计信息。
# 显示Olt1/0/1端口的详细信息。
<Sysname> display interface Olt 1/0/1
Olt1/0/1
Current state: UP
IP packet frame type: Ethernet II, hardware address: 00e0-fc00-511e
Description: Olt1/0/1 Interface
Maximum frame length: 1500
Port hardware type is 1000_BASE_PX_SFP
Flow-control is not enabled
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
Port link-type: Hybrid
 Tagged VLANs:   None
 Untagged VLANs: 1(default vlan)
Current system time:2019-01-05 05:12:35
Last time when physical state changed to up:-
Last time when physical state changed to down:2019-01-04 00:54:04
 Last 300 seconds input: 0 packets/sec 0 bytes/sec 0%
 Last 300 seconds output: 0 packets/sec 0 bytes/sec 0%
 Input (total):  0 packets, 0 bytes
          - unicasts, - broadcasts, - multicasts, 0 pauses
 Input (normal):  0 packets, 0 bytes
 Input:  0 input errors, 0 runts, 0 giants, - throttles
          0 CRC, - frame, - overruns, - aborts
          - ignored, - parity errors
 Output (total): 100000 packets, 12800000 bytes
 Output (normal): 100000 packets, 12800000 bytes
          - aborts, - deferred, - collisions, - late collisions
          - lost carrier, - no carrier
 10G-EPON input (normal): 100000 packets, 12893588 bytes
 10G-EPON input: 0 input errors, 0 runts, 0 giants, 0 CRC
 10G-EPON output (normal): 100000 packets, 12845974 bytes
 10G-EPON output: 0 output errors
# 显示接口Rolt1的详细信息。
<Sysname> display interface rolt 1
Rolt1
Current state: DOWN
Description: Rolt1 Interface
PVID: 1
 Tagged VLANs:   None
 Peak input rate: 0 bytes/sec, at 00-00-00 00:00:00
 Peak output rate: 0 bytes/sec, at 00-00-00 00:00:00
# 显示Onu1/0/1:1接口的详细信息。
<Sysname> display interface Onu 1/0/1:1
Onu1/0/1:1
Current state: DOWN
Description: Onu1/0/1:1 Interface
Loopback is not set
Port hardware type is 1000M_SFF_NO_CONNECTOR
PVID: 1
Port link-type: Access
 Tagged VLANs:   None
 Untagged VLANs: 1
 Last 300 seconds input: - packets/sec - bytes/sec -%
 Last 300 seconds output: - packets/sec - bytes/sec -%
          - unicasts, 0 broadcasts, - multicasts, - pauses
 Input (normal):  - packets, - bytes
          - unicasts, - broadcasts, - multicasts, - pauses
 Input:  0 input errors, - runts, 0 giants, - throttles
          0 CRC, 0 frame, - overruns, - aborts
 Output (normal): - packets, - bytes
 Output: - output errors, - underruns, 0 buffer failures
# 显示所有OLT端口的概要信息。
<Sysname> display interface Olt brief
Speed: (a) - auto
Olt1/0/1             UP   --      --     H    1
Olt1/0/2             DOWN --      --     H    1
表1-11 display interface命令显示信息描述表
Current state
接口的物理状态,状态可能为:
·     DOWN:表示该接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障)
·     UP:该端口的管理状态和物理状态均为开启
IPv4报文发送帧格式
hardware address
接口的MAC地址
接口的描述信息
接口允许通过的最大以太网帧长度
接口的硬件类型
未配置流量控制功能,该显示信息与用户的配置以及链路参数的协商结果有关
Broadcast max-
广播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
Multicast max-
组播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
Unicast max-
未知单播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关
PVID
接口所在的缺省VLAN ID
Port link-type
链路类型,取值为Access、Trunk或Hybrid,与用户的配置有关
Tagged VLANs
通过该接口后携带Tag的VLAN
UnTagged VLANs
通过该接口后不再携带Tag的VLAN
最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never)
Current system time
当前系统时间,时间显示格式为YYYY/MM/DD HH:MM:SS
如果配置了时区,当前系统时间后面会追加显示时区的配置,格式为YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS,其中zone-name为本地时区名称
最近一次接口物理状态变为UP的时刻
如果配置了时区,该时间后面会追加显示时区的配置,格式为YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS,其中zone-name为本地时区名称
“-”表示接口物理状态没有发生过变化
最近一次接口物理状态变为DOWN的时刻
“-”表示接口物理状态没有发生过变化
端口在最近300秒接收和发送报文的平均速率,单位分别为数据包/秒和字节/秒,以及实际速率和接口带宽的百分比
如果值显示为“-”,则表示不支持该统计项
 Input (total)
端口接收报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数
端口接收的单播报文、广播报文、组播报文和PAUSE帧的数量
Input (normal)
端口接收的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
端口接收的正常单播报文、广播报文、组播报文和PAUSE帧的数量
Input
端口接收的异常报文统计值,包括:
·     input errors:接收错误的报文数量
·     runts:超小帧的数量
·     giants:超大帧的数量
·     throttles:长度为非整数字节的帧的数量
·     CRC:CRC校验错误且长度正常的帧的数量
·     frame:CRC校验错误且长度不是整字节数的帧的数量
·     overruns:因端口的接收速率超过接收队列的处理能力而丢弃的报文数量
·     aborts:非法报文总数,非法报文包括报文碎片(长度小于64字节且CRC校验错误的帧)、jabber帧(有效长度大于端口允许通过的最大报文长度,且CRC校验错误的帧)、符号错误帧等
·     ignored:因端口接收缓冲区不足等原因而丢弃的报文数量
·     parity errors:奇偶校验错误的帧的数量
Output (total)
端口发送报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数
端口发送的单播报文、广播报文、组播报文和PAUSE帧的数量
Output (normal)
端口发送的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
端口发送的正常单播报文、广播报文、组播报文和PAUSE帧的数量
Output
端口发送的异常报文统计值,包括:
·     output errors:发送错误的报文数量
·     underruns:因端口的发送速率超过了发送队列的处理能力而丢弃的报文数量
·     buffer failures:因端口发送缓冲区不足而丢弃的报文数量
·     aborts:由于各种原因(如冲突)而发送失败的报文数量
·     deferred:延迟报文的数量,延迟报文是指发送前检测到冲突而被延迟发送的报文
·     collisions:冲突帧的数量,冲突帧是指在发送过程中检测到冲突的而停止发送的报文
·     late collisions:延迟冲突帧的数量,延迟冲突帧是指帧的前512 bits已经被发送,由于检测到冲突,该帧被延迟发送
·     lost carrier:载波丢失,一般适用于串行WAN接口,发送过程中,每丢失一个载波,此计数器加一
·     no carrier:无载波,一般适用于串行WAN接口,当试图发送帧时,如果没有载波出现,此计数器加一
10G-EPON接口发送的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数
10G-EPON接口发送的正常单播报文、广播报文、组播报文和PAUSE帧的数量
10G-EPON input
10G-EPON接口接收的异常报文统计值,包括:
·     runts:超小帧的数量
·     giants:超大帧的数量
10G-EPON接口发送错误的报文数量
二层接口的概要信息
接口名称
Link
接口物理连接状态,取值为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上是不通的
·     ADM:表示接口被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态
·     Stby:表示该接口是一个处于Standby状态的备份接口
Speed
接口的速率(单位为bps)
Duplex
接口的双工模式
接口的链路类型
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
PVID
接口所在的缺省VLAN ID
接口的描述信息
display olt statistics命令用来显示OLT端口的报文统计信息。
(独立运行模式)
display olt statistics { inbound | outbound } { olt interface-number | slot slot-number }
display olt statistics { inbound | outbound } { olt interface-number | chassis chassis-number slot slot-number }
inbound:显示端口入方向的统计信息。
outbound:显示端口出方向的统计信息。
olt interface-number:显示指定OLT端口的报文统计信息。interface-number表示OLT端口的编号。
slot slot-number:显示指定单板上的所有OLT端口的报文统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的所有OLT端口的报文统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 显示指定slot上所有OLT端口的出方向报文统计信息。
<Sysname> display olt statistics outbound slot 1
Output Statistics:
Olt1/0/1: 1711 broadcasts, 30461 multicasts, 0 errors
Olt1/0/2: 15 broadcasts, 150 multicasts, 10 errors
Olt1/0/3: 0 broadcasts, 0 multicasts, 0 errors
表1-12 display epon olt interface命令显示信息描述表
Input Statistics
端口入方向的统计信息
Output Statistics
端口出方向的统计信息
Olt1/0/1
端口Olt1/0/1的报文统计信息,包括:
·     broadcasts:广播报文数
·     multicasts:组播报文数
·     errors:错误报文数
display rolt interface命令用来显示OLT冗余接口的成员端口信息。
display rolt interface rolt interface-number
rolt interface-number:已创建的OLT冗余接口的编号。
# 显示OLT冗余接口1的信息。
<Sysname> display rolt interface rolt 1
Rolt1:
  Member           Priority       Forwarding status      Presence status
  Olt1/0/1         100            Inactive               Normal
  Olt1/0/2         50             Active                 Normal
表1-13 display rolt interface命令显示信息描述表
Rolt1
OLT冗余接口1的信息
Member
成员端口的名称
Priority
成员端口优先级
Forwarding status
成员端口的转发状态:
·     Active:成员端口可以正常收发报文
·     Inactive:成员端口不能收发报文
Presence status
成员端口的状态:
·     Normal:表示存在该接口
·     Absent:表示该接口不存在
encryption update-time命令用来配置LLID密钥的更新周期。
undo encryption update-time命令用来恢复缺省情况。
(独立运行模式)
encryption slot slot-number update-time update-time
undo encryption slot slot-number update-time
encryption chassis chassis-number slot slot-number update-time update-time
undo encryption chassis chassis-number slot slot-number update-time
LLID密钥的更新周期为10秒。
FTTH视图
slot slot-number:配置指定单板上LLID密钥的更新周期,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备指定单板上LLID密钥的更新周期,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
update-time update-time:LLID密钥的更新周期,取值范围为1~255,单位为秒。
# 配置指定slot上LLID密钥的更新周期为8秒。
[Sysname] ftth
[Sysname-ftth] encryption slot 1 update-time 8
fiber-backup group命令用来创建光纤备份组,并进入光纤备份组视图。如果指定的光纤备份组已经存在,则直接进入光纤备份组视图。
undo fiber-backup group命令用来删除光纤备份组。
fiber-backup group group-number [ multidevice ]
undo fiber-backup group group-number
不存在光纤备份组。
FTTH视图
multidevice:创建跨设备光纤备份组。不指定本参数时,创建的是普通光纤备份组。
光纤备份组有以下两种形式:
·     普通光纤备份组:互为备份的两个OLT端口属于同一OLT设备。
·     跨设备光纤备份组:互为备份的两个OLT端口分别属于两台OLT设备。两台OLT设备之间通过TCP连接来同步数据。
# 创建普通光纤备份组1,并进入光纤备份组视图。
[Sysname] ftth
[Sysname-ftth] fiber-backup group 1
·     member
·     port fiber-backup group
fiber-backup tcp命令用来配置跨设备光纤备份组的TCP连接参数。
undo fiber-backup tcp命令用来恢复缺省情况。
fiber-backup tcp local-ip local-ip-address peer-ip peer-ip-address
未配置跨设备光纤备份组的TCP连接参数。
FTTH视图
local-ip local-ip-address:本端设备的IP地址。
peer-ip peer-ip-address:对端设备的IP地址。
跨设备光纤备份组所在的两台设备通过TCP连接来同步数据。
# 配置跨设备光纤备份组的TCP连接参数。
[Sysname] ftth
[Sysname-ftth] fiber-backup tcp local-ip 192.168.56.1 peer-ip 192.168.56.2
·     fiber-backup group
1.1.27  ftth
ftth命令用来进入FTTH视图。
ftth
# 进入FTTH视图。
[Sysname] ftth
[Sysname-ftth]
grant-filtering enable命令用来开启OLT端口的授权过滤功能。
undo grant-filtering enable命令用来关闭OLT端口的授权过滤功能。
OLT端口授权过滤功能处于开启状态。
OLT端口视图
# 开启Olt1/0/1端口的授权过滤功能。
[Sysname-Olt1/0/1] grant-filtering enable
1.1.29  interface
interface命令用来进入OLT或ONU接口视图。
interface-type:接口类型,取值为Olt或Onu。
interface-number:接口编号。
# 进入Olt1/0/1端口视图。
[Sysname-Olt1/0/1]
# 进入Onu1/0/1:1接口视图。
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1]
interface rolt命令用来创建OLT冗余接口,并进入该接口视图。如果指定的OLT冗余接口已经存在,则直接进入该接口视图。
undo interface rolt命令用来删除OLT冗余接口。
undo interface rolt interface-number
不存在OLT冗余接口。
interface-number:OLT冗余接口编号,取值范围为1~120。
OLT冗余接口是一种二层虚拟接口。一个OLT冗余接口中包含两个成员端口,使用OLT冗余接口可以实现这两个接口之间的冗余备份。
删除OLT冗余接口时,如果该接口下存在成员端口,则不允许删除。
# 创建OLT冗余接口1。
[Sysname] interface rolt 1
·     member interface
interface ronu命令用来进入ONU冗余接口视图。
interface ronu interface-number
interface-number:已创建的ONU冗余接口的编号。
ONU冗余接口可以在OLT冗余接口下通过using onu命令创建。
ONU冗余接口的编号方式为“OLT冗余接口编号:ONU冗余接口编号”,例如Ronu1:1。
# 创建ONU冗余接口1,并进入该接口视图。
[Sysname] interface Rolt 1
[Sysname-Rolt1] using onu 1
[Sysname-Rolt1] quit
[Sysname] interface ronu 1:1
[Sysname-Ronu1:1]
·     interface rolt
·     using onu
1.1.32  max-rtt
max-rtt命令用来配置ONU到OLT的最大RTT(Round Trip Time,往返时间)值。
undo max-rtt命令用来将RTT值恢复为缺省情况。
max-rtt max-rtt-value
undo max-rtt
最大RTT值为15000TQ。
OLT端口视图
max-rtt-value:最大RTT值,取值范围为2000~32000,单位为TQ。1TQ=16ns。
通常情况下,不建议调整最大RTT值。
# 配置Olt1/0/1端口下接入的ONU最大RTT值为25000TQ。
[Sysname-Olt1/0/1] max-rtt 25000
1.1.33  member
member命令用来向光纤备份组中添加OLT端口。
undo member命令用来将OLT端口从光纤备份组中删除。
member olt interface-number [ master | standby ]
undo member olt interface-number
光纤备份组中未添加OLT端口。
光纤备份组视图
olt interface-number:OLT端口的编号。
master:指定添加的OLT端口为跨设备光纤备份组的主用端口。
standby:指定添加的OLT端口为跨设备光纤备份组的备用端口。
一个光纤备份组只能包含两个OLT端口。需要注意的是:
·     普通光纤备份组不支持指定master或standby参数。先加入普通光纤备份组的OLT端口为主用端口,后加入的为备用端口。
·     跨设备光纤备份组必须指定master或standby参数。请确保两台设备的跨设备光纤备份组ID相同,且其中一台设备上的该备份组包含一个主用端口,另一台设备的该备份组包含一个备用端口。
本命令和port fiber-backup group命令视图不同,执行效果相同。
# 将Olt1/0/1端口加入到普通光纤备份组1。
[Sysname] ftth
[Sysname-fiber-group1] member olt 1/0/1
member interface命令用来向OLT冗余接口添加成员端口。
undo member interface命令用来将成员端口从OLT冗余接口中删除。
member interface olt interface-number priority priority
undo member interface olt interface-number
OLT冗余接口下不存在成员端口。
OLT冗余接口视图
interface-number:OLT端口编号。
priority:成员端口优先级,取值范围为1~255。数值越大,优先级越高。
OLT端口加入光纤备份组或配置OLT认证模式后,将不能加入OLT冗余接口。反之,已加入OLT冗余接口的OLT端口也不能加入光纤备份组或配置OLT认证模式。
向OLT冗余接口添加成员端口时,需要注意:
·     每个OLT冗余接口下最多可添加两个成员端口,且它们的优先级不能相同。
·     一个OLT端口只能加入一个OLT冗余接口。
·     OLT端口的属性类配置必须和OLT冗余接口相同,才能加入该冗余接口;OLT端口加入OLT冗余接口后,不能修改属性类配置。
属性配置包括端口隔离、VLAN映射、QinQ和基于端口的VLAN配置。
# 向OLT冗余接口1添加成员端口Olt1/0/1并指定优先级为100,然后添加成员端口Olt1/0/2并指定优先级为50。
[Sysname-Rolt1] member interface olt 1/0/1 priority 100
[Sysname-Rolt1] member interface olt 1/0/2 priority 50
·     authentication-mode
·     interface rolt
monitor enable命令用来开启告警监视功能。
undo monitor enable命令用来关闭告警监视功能。
monitor enable
undo monitor enable
告警监视功能处于开启状态。
FTTH视图
# 开启系统告警监视功能。
[Sysname] ftth
[Sysname-ftth] monitor enable
·     timer monitor
oam-discovery-timeout命令用来配置扩展OAM发现超时时间。
undo oam-discovery-timeout命令用来恢复缺省情况。
(独立运行模式)
oam-discovery-timeout slot slot-number value value
undo oam-discovery-timeout slot slot-number value
oam-discovery-timeout chassis chassis-number slot slot-number value value
undo oam-discovery-timeout chassis chassis-number slot slot-number value
扩展OAM发现超时时间为3秒。
FTTH视图
slot slot-number:配置指定单板上的扩展OAM发现超时时间,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备指定单板上的扩展OAM发现超时时间,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
value value:扩展OAM发现超时时间,取值范围为30~2550,单位为100毫秒。
扩展OAM发现超时时间是指扩展OAM发现过程中OLT与ONU之间交互的扩展OAM消息的超时时间,一般情况下建议保持缺省情况。
如果ONU已经连接到OLT且绑定到ONU接口后还一直处于down状态,可以尝试将OLT所在slot的扩展OAM发现超时时间改为更大一点的数值。
# 配置指定slot上的扩展OAM发现超时时间为10秒。
[Sysname] ftth
[Sysname-ftth] oam-discovery-timeout slot 1 value 100
1.1.37  olt-mode
olt-mode命令用来配置OLT工作模式。
undo olt-mode命令用来恢复缺省情况。
(独立运行模式)
olt-mode slot slot-number { 64-onu | 128-onu }
undo olt-mode slot slot-number
olt-mode chassis chassis-number slot slot-number { 64-onu | 128-onu }
undo olt-mode chassis chassis-number slot slot-number
OLT工作模式为64-ONU。
FTTH视图
slot slot-number:配置指定单板的OLT工作模式,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备指定单板的OLT工作模式,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
64-onu:64-ONU模式。该模式下指定slot的每个OLT端口支持创建的ONU接口数量上限为64。
128-onu:128-ONU模式。该模式下指定slot的每个OLT端口支持创建的ONU接口数量上限为128。
仅10G-EPON单板支持本命令。
切换slot的OLT工作模式后,需要重启该slot或者重启设备才能使OLT工作模式生效。
·     如果重启slot,则该slot上的OLT端口都恢复为缺省配置,这些OLT端口上创建的ONU接口也会被删除。
·     如果重启整个设备且保存配置,则OLT端口以及编号为1~64的ONU接口的配置不受影响。从128-ONU模式切换到64-ONU模式时,编号大于64的ONU接口会被删除。
# 配置指定slot的OLT工作模式为128-ONU。
[Sysname] ftth
[Sysname-ftth] olt-mode slot 1 128-onu
·     using onu
1.1.38  onu flow
onu flow命令用来配置ONU组播/广播报文的多VLAN转发。
undo onu flow命令用来取消ONU组播/广播报文的多VLAN转发配置。
onu flow flow-id vlan vlan-id { destination-ip ipv4-address { mask-length | mask } | destination-mac mac-address } [ udp-port port-number ] forward-vlan vlan-list
undo onu flow flow-id
未配置ONU组播/广播报文的多VLAN转发。
flow-id:流匹配规则的ID号,取值范围为1~48。ID越小,流匹配的优先级越高。
vlan vlan-id:组播或广播报文所属的VLAN。vlan-id表示VLAN的编号,取值范围为1~4094。
destination-ip ipv4-address:组播或广播报文的目的IPv4地址,为点分十进制格式。其中组播IP地址取值范围为224.0.0.0~239.255.255.255,广播IP地址为255.255.255.255。
mask-length:子网掩码长度,即掩码中连续“1”的个数,取值范围为1~31。
mask:IPv4地址的掩码,为点分十进制格式。
destination-mac mac-address:组播或广播报文的目的MAC地址,格式为H-H-H。其中组播MAC地址取值范围为0100-5E00-0000~0100-5EFF-FFFF,广播MAC地址为FFFF-FFFF-FFFF。
udp-port port-number:组播或广播报文的UDP端口号,取值范围为1~65535。如果未指定本参数,则匹配组播或广播报文时不关注UDP端口号。
forward-vlan vlan-list:转发VLAN的列表。vlan-list表示多个VLAN的编号,表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>。其中,vlan-id为VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
应用场景
使用本命令可以实现灵活的二层跨VLAN转发。当OLT设备从指定VLAN中收到来自ONU的、目的MAC地址/目的IP地址为指定地址、目的端口为指定端口号的报文时,设备会将这样的报文直接在指定目标VLAN中转发。
注意事项
多次执行本命令,且指定的flow-id相同时,最后一次执行的命令生效。
# 配置ID为1的流匹配规则:将VLAN 1、目的IP地址为255.1.1.1/16网段的组播报文转发至VLAN 10~20。
[Sysname] onu flow 1 vlan 1 destination-ip 255.1.1.1 16 forward-vlan 10 to 20
onu invalid-address mode命令用来配置非标准MAC地址报文的处理模式。
undo onu invalid-address mode命令用来恢复缺省情况。
onu invalid-address mode { abandon | broadcast | unicast }
非标准MAC地址报文的处理模式为丢弃模式。
FTTH视图
abandon:表示丢弃模式,即当源MAC地址为非标准MAC地址的报文发送到OLT时,OLT直接丢弃这些报文。
broadcast:表示广播模式,即当源MAC地址为非标准MAC地址的报文发送到OLT时,OLT转发该报文但不学习它的源MAC地址,对目的是该MAC地址的报文将采取广播方式通过对应VLAN内的所有接口(除接收接口外)转发该报文。
unicast:表示单播模式,即当源MAC地址为非标准MAC地址的报文发送到OLT时,OLT通过学习该报文的源MAC地址生成单播MAC地址表项并转发该报文,对目的是该MAC地址的报文从对应接口转发出去。
非标准MAC地址指的是第一字节的第7比特位为1的MAC地址。例如地址02-10-94-00-00-02(16进制)对应00000010-...(二进制),该地址为非标准MAC地址。
以下接口能正常转发非标准MAC地址报文,配置非标准MAC地址报文的处理模式对这些接口没有影响:
·     10G-EPON单板上的OLT端口。
·     切换到GE接口类型的EPON光接口。关于接口类型的切换,请参见port-type命令。
# 配置非标准MAC地址报文的处理模式为广播模式。
[Sysname] ftth
[Sysname-ftth] onu invalid-address mode broadcast
onu snmp port-limit命令用来配置SNMP和NETCONF模块对离线ONU的E1/UNI/VoIP端口的查询数量上限。
undo onu snmp port-limit命令用来恢复缺省情况。
onu snmp port-limit { e1 e1-count | uni uni-count | voip voip-count }*
SNMP和NETCONF模块查询的UNI端口数上限为4,E1端口数上限和VoIP端口数上限都为0。
FTTH视图
e1 e1-count:ONU的E1端口查询数量上限,取值范围为0~16。
uni uni-count:ONU的UNI端口查询数量上限,取值范围为1~79。
voip voip-count:ONU的VoIP端口查询数量上限,取值范围为0~64。
设备支持通过SNMP和NETCONF协议查询ONU设备上各端口的信息,并通过SNMP和NETCONF协议将查询结果上报给网管软件。当ONU数量众多,或者ONU上接口数量众多时,查询和上报操作会占用较多资源。使用本命令,可以配置SNMP和NETCONF模块对离线ONU的E1/UNI/VoIP端口的查询数量上限,通过减少需要查询的接口的数量甚至不查询,来降低设备资源的消耗。
本命令仅供管理员使用,建议一般用户不要配置。
本命令作用于所有OLT端口下的所有ONU接口,且仅对ONU未上线的ONU接口生效。
# 配置SNMP和NETCONF模块对离线ONU的UNI端口的查询数量上限为63。
[Sysname] ftth
[Sysname-ftth] onu snmp port-limit uni 63
port fiber-backup group命令用来将OLT端口加入光纤备份组。
undo port fiber-backup group命令用来恢复缺省情况。
port fiber-backup group group-number [ master | standby ]
OLT端口未加入任何光纤备份组。
OLT端口视图
group-number:光纤备份组的编号,取值范围为1~120。必须是已创建的光纤备份组。
本命令和member命令视图不同,执行效果相同。
# 将Olt1/0/1端口加入普通光纤备份组1。
[Sysname] ftth
[Sysname-fiber-group1] quit
[Sysname-Olt1/0/1] port fiber-backup group 1
·     member
port switch-over命令用来手动切换光纤备份组内主备端口。
port switch-over
光纤备份组视图
仅当备用OLT端口处于Ready状态时,本命令才能成功执行。
执行该命令后,原主用OLT端口切换成备用端口,原备用OLT端口则切换成主用端口。
# 将光纤备份组1中的两个OLT端口手动进行主备切换。
[Sysname] ftth
[Sysname-fiber-group1] port switch-over
1.1.43  port-type
port-type命令用来在OLT端口和GE接口间进行类型切换。
undo port-type命令用来取消接口的类型切换。
在OLT端口视图下:
port-type gigabitethernet
undo port-type gigabitethernet
在二层GE接口视图/三层GE接口视图下:
port-type olt
undo port-type olt
接口为OLT端口类型。
OLT端口视图
二层GE接口视图/三层GE接口视图
gigabitethernet:将接口切换到GE接口类型。切换后的GE接口缺省情况下工作在二层模式。
olt:将接口切换到OLT端口类型。
仅LSQM1PT24TSSC0接口板支持本命令。
本命令需要同一组的4个接口同时配置(第一组接口编号为1~4,第二组接口编号为5~8,以此类推),并重启接口所在的接口板,才能成功切换接口类型。
接口类型切换后,原接口自动删除并创建新的接口,切换后的接口编号与切换前保持一致。
# 将GE接口GigabitEthernet1/0/1~GigabitEthernet1/0/4切换到OLT端口Olt1/0/1~Olt1/0/4。
[Sysname] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/4
[Sysname-if-range] port-type olt
timer monitor命令用来配置告警监视周期。
undo timer monitor命令用来恢复缺省情况。
timer monitor seconds
undo timer monitor
告警监视周期为80秒。
FTTH视图
seconds:告警监视周期,取值范围为1~3600,单位为秒。
# 配置告警监视周期为100秒。
[Sysname] ftth
[Sysname-ftth] timer monitor 100
·     monitor enable
uplink interface命令用来配置跨设备光纤备份组的上行接口。
undo uplink interface命令用来恢复缺省情况。
uplink interface interface-type interface-number
未配置跨设备光纤备份组的上行接口。
光纤备份组视图
interface-type:指定接口类型,只能为二层以太网接口/二层聚合接口。
仅跨设备光纤备份组支持配置本命令。
一个跨设备光纤备份组只能配置一个上行接口。同一接口可以作为不同跨设备光纤备份组的上行接口。
# 配置跨设备光纤备份组的上行接口为GigabitEthernet 1/0/20。
[Sysname] ftth
[Sysname-ftth] fiber-backup group 1 multidevice
[Sysname-fiber-group1] uplink interface gigabitethernet 1/0/20
vendor-compatible命令用来开启OLT的厂商兼容功能。
undo vendor-compatible命令用来关闭OLT的厂商兼容功能。
(独立运行模式)
vendor-compatible slot slot-number
undo vendor-compatible slot slot-number
vendor-compatible chassis chassis-number slot slot-number
undo vendor-compatible chassis chassis-number slot slot-number
OLT的厂商兼容功能均处于开启状态。
FTTH视图
slot slot-number:开启指定单板上的厂商兼容功能,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:开启指定成员设备指定单板上的厂商兼容功能,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
厂商兼容功能开启时,OLT允许所有厂商的ONU注册。厂商兼容功能关闭后,OLT只允许H3C的ONU注册。
关闭厂商兼容功能后,如果使用bind onu-id命令在ONU接口上绑定了非H3C的ONU设备,那么再开启厂商兼容功能时,需要注销该ONU接口(执行deregister onu命令)或关闭再打开该ONU接口(执行shutdown、undo shutdown命令),才能使该ONU注册到OLT。
# 关闭指定slot上的厂商兼容功能。
[Sysname] ftth
[Sysname-ftth] undo vendor-compatible slot 1
1.2  ONU远程配置命令
OLT端口下ONU对各特性的支持情况以ONU实际型号和版本支持情况为准。
1.2.1  alarm enable
alarm enable命令用来开启ONU的告警功能。
undo alarm enable命令用来关闭ONU的告警功能。
alarm enable { onu onu-alarm | pon pon-alarm | uni uni-alarm } [ protocol { auto | ctc2.1 | ctc3.0 } ] [ threshold trigger-value clear-value ]
undo alarm enable { onu onu-alarm | pon pon-alarm | uni uni-alarm }
ONU设备上UNI口的eth-port-loopback(以太网端口环路检测)告警功能处于开启状态,其他CTC告警功能处于关闭状态。
ONU接口视图
ONU冗余接口视图
onu-alarm:表示ONU设备告警,取值见表1-14。
pon-alarm:表示ONU设备上PON口的告警,取值见表1-15。
uni-alarm:表示UNI口的告警,取值见表1-16。
protocol:表示配置CTC标准协议。如果不指定该参数,将使用自动协商的CTC标准协议。
auto:使用自动协商的CTC标准协议。
ctc2.1:使用CTC2.1标准协议。
ctc3.0:使用CTC3.0或更新标准协议。
threshold trigger-value clear-value:设置告警的门限值。trigger-value表示告警触发门限值,clear-value表示告警取消门限值。trigger-value和clear-value的取值范围见表1-14、表1-15和表1-16,需要注意的是:
·     “门限值取值范围”一列为“-”时表示对应的告警不支持设置门限值,不为“-”时表示必须设置门限值。
·     输入的门限值如果超过了取值范围支持的小数位数,则自动忽略超出的小数部分。例如取值只能为整数时,输入5.9,实际生效值为5。
一个ONU只能设置一种CTC标准协议。
如图1-1所示,告警触发门限值trigger-value和取消门限值clear-value有如下关系:
·     下限类告警(例如temp-low-alarm)的取消门限值必须大于或等于它的触发门限值。上限类告警(例如temp-high-alarm)的触发门限值必须大于或等于它的取消门限值。
·     上限类告警(例如rx-power-high-alarm)的取消门限值必须大于或等于对应的下限类告警(rx-power-low-alarm)的触发门限值。上限类告警的触发门限值必须大于或等于对应的下限类告警的取消门限值。
图1-1 告警触发门限值和取消门限值的关系示意图
设备支持的CTC告警列表如表1-14、表1-15和表1-16所示。
表1-14 ONU设备CTC告警
告警名称
门限值取值范围
battery-failure
电池不能充电时上报
battery-missing
电池未找到时上报
battery-volt-low
电池电压过低时上报
0~6.55V
equipment-alarm
内部接口故障时上报
iad-connection-failure
内部IAD和SS平台连接失败时上报
onu-self-test-failure
ONU未通过自我测试时上报
onu-temp-high-alarm
ONU内部温度超过设置的高温告警门限时上报
-127~127°C
onu-temp-low-alarm
ONU内部温度低于设置的低温告警门限时上报
-127~127°C
physical-intrusion-alarm
ONU检测到机盒被打开时上报
ponif-switch
ONU检测到链路故障后,向主用的OLT PON口上报链路故障
power-alarm
电源异常时上报
sleep-status-update
ONU主动离开节能状态进入正常工作状态时上报
表1-15 PON口CTC告警
告警名称
门限值取值范围
downstream-crc-error-frames-alarm
下行CRC错误报文数超过设置的告警门限时上报
0~4294967295
downstream-crc-error-frames-warning
下行CRC错误报文数超过设置的警示门限时上报
0~4294967295
downstream-discards-alarm
下行丢弃报文数超过设置的告警门限时上报
0~4294967295
downstream-discards-warning
下行丢弃报文数超过设置的警示门限时上报
0~4294967295
downstream-drop-events-alarm
下行丢包事件数超过设置的告警门限时上报
0~4294967295
downstream-drop-events-warning
下行丢包事件数超过设置的警示门限时上报
0~4294967295
downstream-errors-alarm
下行错误报文数超过设置的告警门限时上报
0~4294967295
downstream-errors-warning
下行错误报文数超过设置的警示门限时上报
0~4294967295
downstream-fragments-alarm
下行碎片报文数超过设置的告警门限时上报
0~4294967295
downstream-fragments-warning
下行碎片报文数超过设置的警示门限时上报
0~4294967295
downstream-jabbers-alarm
下行Jabber帧数超过设置的告警门限时上报
0~4294967295
downstream-jabbers-warning
下行Jabber帧数超过设置的警示门限时上报
0~4294967295
downstream-oversize-frames-alarm
下行超长报文数超过设置的告警门限时上报
0~4294967295
downstream-oversize-frames-warning
下行超长报文数超过设置的警示门限时上报
0~4294967295
downstream-undersize-frames-alarm
下行超短报文数超过设置的告警门限时上报
0~4294967295
downstream-undersize-frames-warning
下行超短报文数超过设置的警示门限时上报
0~4294967295
rx-power-high-alarm
接收光功率超过设置的告警门限时上报
-40.00~8.10dBm
rx-power-high-warning
接收光功率超过设置的警示门限时上报
-40.00~8.10dBm
rx-power-low-alarm
接收光功率低于设置的告警门限时上报
-40.00~8.10dBm
rx-power-low-warning
接收光功率低于设置的警示门限时上报
-40.00~8.10dBm
temp-high-alarm
内部温度超过设置的告警门限时上报
-127~127°C
temp-high-warning
内部温度超过设置的警示门限时上报
-127~127°C
temp-low-alarm
内部温度低于设置的告警门限时上报
-127~127°C
temp-low-warning
内部温度低于设置的警示门限时上报
-127~127°C
tx-bias-high-alarm
偏置电流超过设置的告警门限时上报
0~131mA
tx-bias-high-warnig
偏置电流超过设置的警示门限时上报
0~131mA
tx-bias-low-alarm
偏置电流低于设置的告警门限时上报
0~131mA
tx-bias-low-warning
偏置电流低于设置的警示门限时上报
0~131mA
tx-power-high-alarm
发送光功率超过设置的告警门限时上报
-40.00~8.10dBm
tx-power-high-warning
发送光功率超过设置的警示门限时上报
-40.00~8.10dBm
tx-power-low-alarm
发送光功率低于设置的告警门限时上报
-40.00~8.10dBm
tx-power-low-warning
发送光功率低于设置的警示门限时上报
-40.00~8.10dBm
upstream-crc-error-frames-alarm
上行CRC错误报文数超过设置的告警门限时上报
0~4294967295
upstream-crc-error-frames-warning
上行CRC错误报文数超过设置的警示门限时上报
0~4294967295
upstream-discards-alarm
上行丢弃报文数超过设置的告警门限时上报
0~4294967295
upstream-discards-warning
上行丢弃报文数超过设置的警示门限时上报
0~4294967295
upstream-drop-events-alarm
上行丢包事件数超过设置的告警门限时上报
0~4294967295
upstream-drop-events-warning
上行丢包事件数超过设置的警示门限时上报
0~4294967295
upstream-errors-alarm
上行错误报文数超过设置的告警门限时上报
0~4294967295
upstream-errors-warning
上行错误报文数超过设置的警示门限时上报
0~4294967295
upstream-fragments-alarm
上行报文碎片数超过设置的告警门限时上报
0~4294967295
upstream-fragments-warning
上行报文碎片数超过设置的警示门限时上报
0~4294967295
upstream-jabbers-alarm
上行Jabber帧数超过设置的告警门限时上报
0~4294967295
upstream-jabbers-warning
上行Jabber帧数超过设置的警示门限时上报
0~4294967295
upstream-oversize-frames-alarm
上行超长报文数超过设置的告警门限时上报
0~4294967295
upstream-oversize-frames-warning
上行超长报文数超过设置的警示门限时上报
0~4294967295
upstream-undersize-frames-alarm
上行超短报文数超过设置的告警门限时上报
0~4294967295
upstream-undersize-frames-warning
上行超短报文数超过设置的警示门限时上报
0~4294967295
vcc-high-alarm
内部电压超过设置的告警门限时上报
0~6.55V
vcc-high-warning
内部电压超过设置的警示门限时上报
0~6.55V
vcc-low-alarm
内部电压低于设置的告警门限时上报
0~6.55V
vcc-low-warning
内部电压低于设置的警示门限时上报
0~6.55V
表1-16 UNI口CTC告警
告警名称
门限值取值范围
0~4294967295
0~4294967295
下行丢弃报文数超过设置的告警门限时上报
0~4294967295
下行丢弃报文数超过设置的警示门限时上报
0~4294967295
下行丢包事件数超过设置的告警门限时上报
0~4294967295
下行丢包事件数超过设置的警示门限时上报
0~4294967295
下行错误报文数超过设置的告警门限时上报
0~4294967295
下行错误报文数超过设置的警示门限时上报
0~4294967295
下行报文碎片数超过设置的告警门限时上报
0~4294967295
下行报文碎片数超过设置的警示门限时上报
0~4294967295
0~4294967295
0~4294967295
下行超长报文数超过设置的告警门限时上报
0~4294967295
下行超长报文数超过设置的警示门限时上报
0~4294967295
下行超短报文数超过设置的告警门限时上报
0~4294967295
下行超短报文数超过设置的警示门限时上报
0~4294967295
e1-los
E1端口LOS(Loss of Signal,信号丢失)告警
e1-port-failure
E1端口故障时上报
e1-timing-unlock
eth-port-auto-neg-failure
以太网端口自动协商失败时上报
eth-port-congestion
以太网端口检测到拥塞时上报
eth-port-failure
以太网端口故障时上报
eth-port-loopback
以太网端口检测到环路时上报
eth-port-los
以太网端口LOS(Loss of Signal,信号丢失)告警
pots-port-failure
POTS端口故障
status-change-times-alarm
端口状态变化次数超过设置的告警门限时上报
0~4294967295
status-change-times-warning
端口状态变化次数超过设置的警示门限时上报
0~4294967295
0~4294967295
0~4294967295
上行丢弃报文数超过设置的告警门限时上报
0~4294967295
上行丢弃报文数超过设置的警示门限时上报
0~4294967295
上行丢包事件数超过设置的告警门限时上报
0~4294967295
下行丢包事件数超过设置的警示门限时上报
0~4294967295
上行错误报文数超过设置的告警门限时上报
0~4294967295
上行错误报文数超过设置的警示门限时上报
0~4294967295
上行报文碎片数超过设置的告警门限时上报
0~4294967295
上行报文碎片数超过设置的警示门限时上报
0~4294967295
0~4294967295
0~4294967295
上行超长报文数超过设置的告警门限时上报
0~4294967295
上行超长报文数超过设置的警示门限时上报
0~4294967295
上行超短报文数超过设置的告警门限时上报
0~4294967295
上行超短报文数超过设置的警示门限时上报
0~4294967295
# 开启ONU的equipment-alarm告警功能,并使用CTC3.0标准协议。
[Sysname-Onu1/0/1:1] alarm enable onu equipment-alarm protocol ctc3.0
anti-dhcp-server enable命令用来禁止ONU的UNI口接收DHCP服务器的报文。
undo anti-dhcp-server enable命令用来恢复缺省情况。
允许ONU的UNI口接收DHCP服务器的报文。
ONU接口视图
ONU冗余接口视图
应用场景
本命令可以用来阻止非法的DHCP服务器连接ONU设备。
工作机制
配置本命令后,当ONU的UNI口收到DHCP服务器的报文时,会自动丢弃该报文。
# 禁止ONU的UNI口接收DHCP服务器的报文。
[Sysname-Onu1/0/1:1] anti-dhcp-server enable
apply onu template命令用来应用ONU配置模板。
undo apply onu template命令用来取消应用ONU配置模板。
apply onu template template-id
未应用ONU配置模板。
FTTH视图
OLT端口视图
template-id:ONU配置模板的ID,取值范围为1~32。
在批量绑定ONU或自动绑定ONU的场景中,通过应用ONU配置模板,可以自动配置在线和新上线的ONU设备。
ONU配置模板的应用方式包括以下两种:
·     全局应用方式:在FTTH视图下应用ONU配置模板,将模板中的命令下发到所有OLT端口下的ONU在线的ONU接口;新创建ONU接口时,模板中的命令也会自动下发到该接口。
·     端口应用方式:在OLT端口上应用ONU配置模板,将模板中的命令下发到该OLT端口下的ONU在线的ONU接口;该OLT端口下新创建ONU接口时,模板中的命令也会自动下发到该接口。
应用或取消应用ONU配置模板时,需要注意:
·     ONU配置模板的全局应用和端口应用方式只能选择一种,二者配置互斥。
·     应用ONU配置模板后,该ONU配置模板视图下不能配置命令,直到取消应用该模板。
·     取消应用ONU配置模板后,已下发给ONU接口的命令不会撤回。
各视图下多次执行本命令,最后一次执行的命令生效。
# 开启ONU自动绑定功能,并全局应用ONU配置模板1。
[Sysname] ftth
[Sysname-ftth] onu bind auto
[Sysname-ftth] apply onu template 1
·     onu template
1.2.4  bind onu-id
bind onu-id命令用来将ONU设备绑定到ONU接口/ONU冗余接口。
undo bind onu-id命令用来解除ONU接口/ONU冗余接口和ONU设备的绑定。
bind onu-id { mac-address | loid loid | loid-password loid { cipher | simple } password }
undo bind onu-id
ONU接口/ONU冗余接口未绑定任何ONU设备。
ONU接口视图
ONU冗余接口视图
mac-address:ONU设备的MAC地址。指定本参数时,表示ONU使用其MAC地址进行绑定。
loid:表示ONU使用其LOID进行绑定。
loid-password:表示ONU使用其LOID和LOID密码进行绑定。
loid:ONU的LOID,为1~24个字符的字符串,区分大小写,不能包含字符“?”,且不能以字符“DEL”、“@”、“.”、“,”、“!”、“;”、“: ”、“`”、“"”或十六进制数字0x0~0x20开头或结尾。
cipher:以密文方式设置密码。
simple:以明文方式设置密码。
password:ONU的LOID密码,区分大小写。明文密码为1~12个字符的字符串,不能包含字符“?”,且不能以字符“DEL”、“@”、“.”、“,”、“!”、“;”、“: ”、“`”、“"”或十六进制数字0x0~0x20开头或结尾。密文密码由明文密码加密后生成。
使用bind onu-id命令绑定ONU时使用的媒介(MAC地址 / LOID / LOID+LOID密码)不受OLT认证模式(authentication-mode)的限制。
使用undo bind onu-id命令解除ONU接口/ONU冗余接口和ONU设备的绑定后,将导致该ONU设备下线。
每个ONU接口/ONU冗余接口只能绑定一台ONU。
# 将ONU设备(MAC地址为11-22-33)绑定到Onu1/0/2:1接口。
[Sysname] interface onu 1/0/2:1
[Sysname-Onu1/0/2:1] bind onu-id 11-22-33
blacklist onu-id命令用来添加ONU黑名单表项。
undo blacklist onu-id命令用来删除指定ONU的黑名单表项。
blacklist onu-id { mac-address | loid loid }
undo blacklist onu-id { mac-address | loid loid }
不存在ONU黑名单表项。
FTTH视图
loid loid:ONU设备的LOID。
通过配置ONU黑名单功能可以禁止指定MAC地址或LOID的ONU设备注册到OLT。
本功能仅对设备开启自动绑定ONU功能后新接入的ONU生效。
最多可以添加256台ONU设备到黑名单。
# 将LOID为abc的ONU设备加入黑名单。
[Sysname] ftth
[Sysname-ftth] blacklist onu-id loid abc
deregister onu命令用来注销ONU。
deregister onu
ONU接口视图
ONU冗余接口视图
注销ONU后,ONU将重新进行注册。
# 注销Onu1/0/1:1接口连接的ONU。
[Sysname] interface Onu 1/0/1:1
[Sysname-Onu1/0/1:1] deregister onu
display dhcp-client命令用来显示ONU作为DHCP客户端时的地址分配信息。
display [ ipv6 ] dhcp-client
ONU接口视图
ONU冗余接口视图
ipv6:显示ONU作为DHCPv6客户端时的地址分配信息。如果未指定本参数,则显示ONU作为DHCPv4客户端时的地址分配信息。
# 显示Onu1/0/1:1接口所连接的ONU作为DHCPv4客户端时的地址分配信息。(本命令的显示信息与ONU设备的型号有关,请以设备的实际情况为准。)
[Sysname-Onu1/0/1:1] display dhcp-client
DHCP client statistic information :
  Current machine state : HALT
表1-17 display dhcp-client命令显示信息描述表
DHCP客户端统计信息
DHCP客户端状态机所处的状态
display epon mac-address命令用来显示ONU的MAC地址表项信息。
display epon mac-address interface onu interface-number [ mac mac-address ] [ vlan vlan-id ] [ pon | uni uni-number ]
display epon mac-address interface onu interface-number [ count ]
interface-number:指定ONU接口编号。
mac mac-address:显示ONU上指定MAC地址的MAC地址表项。mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
vlan vlan-id:显示ONU上指定VLAN的MAC地址表项。vlan-id的取值范围为1~4094。
pon:显示ONU的上联PON口的MAC地址表项。
uni:显示ONU的UNI端口的MAC地址表项。
uni-number:UNI端口的编号,取值范围为1~当前ONU的UNI端口数,且支持最大的UNI端口数为79。
count:显示ONU上MAC地址表项的数量。如果配置本参数,将仅显示PON口和各UNI端口的MAC地址表项的数量。如果不指定本参数,则显示MAC地址表的具体内容。
如果不指定任何参数,将显示ONU上所有的MAC地址表项信息。
# 显示接口Onu1/0/1:1对应ONU设备上所有的MAC地址表项信息。
<Sysname> display epon mac-address interface onu 1/0/1:1
MAC Address      VLAN ID      State        Port        Aging
000f-e291-6101   -            Static       PON         N
000f-e291-6100   -            Static       PON         N
表1-18 display epon mac-address命令显示信息描述表
MAC Address
ONU上的MAC地址
VLAN ID
接口所属的VLAN ID
“-”表示不支持获取该字段信息
MAC地址表项的状态,包括:
·     Static:表示该表项是静态MAC地址表项
·     Learned:动态MAC地址表项。可以手工配置也可以由设备学习获得
Port
MAC地址对应的接口名称,表示发往该MAC地址的报文将从此接口发出
Aging
MAC地址的老化时间,单位为秒
取值为N时,表示该表项不会被老化
# 显示ONU设备上MAC地址表项的数量。
<Sysname> display epon mac-address interface onu 1/0/1:1 count
PON    : 2
UNI 1  : 0
UNI 2  : 0
display epon onu-loop-status命令用来显示ONU的UNI端口环路信息。
(独立运行模式)
display epon onu-loop-status { interface interface-type interface-number | slot slot-number }
display epon onu-loop-status { interface interface-type interface-number | chassis chassis-number slot slot-number }
interface interface-type interface-number:显示指定OLT端口或ONU接口连接的ONU的UNI端口环路信息。interface-type表示接口类型,取值为olt或onu;interface-number表示接口编号。接口类型为olt时,表示查看该OLT端口连接的所有ONU的UNI端口环路信息。
slot slot-number:显示指定单板上的所有OLT端口下的ONU的UNI端口环路信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的所有OLT端口下的ONU的UNI端口环路信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
通过本命令可以查看ONU的UNI端口最近上报的环路信息。
ONU设备上UNI口的eth-port-loopback告警功能处于开启状态时,才会上报环路信息。关于该告警功能的介绍,请参见alarm enable命令。
# 显示指定OLT端口下的所有ONU的UNI端口环路信息。
<Sysname> display epon onu-loop-status interface olt 1/0/1
ONU Interface  UNI      Date      Time
Onu1/0/1:1
               1        2022/9/27 18:3:55
               2        2022/9/27 18:3:55
               3        2022/9/27 18:3:55
表1-19 display epon onu-loop-status命令显示信息描述表
ONU Interface
ONU接口名称
UNI
UNI端口号
Date
UNI端口上报环路的日期
Time
UNI端口上报环路的时间
display epon onu-template apply-process命令用来显示ONU配置模板的应用进度。
network-operation
通过apply onu template命令应用ONU配置模板会消耗一定时间。在ONU配置模板应用到所有ONU接口之前,系统不支持以下操作:
·     取消应用该ONU配置模板。
·     修改该ONU配置模板。
需要注意的是,应用ONU配置模板完成后,执行本命令不会打印显示信息。
# 显示ONU配置模板的应用进度。
<Sysname> display epon onu-template apply-process
There are 2 OLT port(s) left to be applied
Current applied interface: Olt1/0/1(Onu1/0/1:3)
表1-20 display epon onu-template apply-process命令显示信息描述表
剩余2个OLT端口还没有完成ONU配置模板的应用
当前正在应用ONU配置模板的OLT端口下的ONU接口
·     apply onu template
display epon onu-update命令用来显示ONU升级信息。
(独立运行模式)
display epon onu-update { interface interface-type interface-number | slot slot-number }
display epon onu-update { interface interface-type interface-number | chassis chassis-number slot slot-number }
interface interface-type interface-number:显示指定OLT端口或ONU接口连接的ONU的升级信息。interface-type表示接口类型,取值为olt或onu;interface-number表示接口编号。接口类型为olt时,表示查看该OLT端口连接的所有ONU的升级信息。
slot slot-number:显示指定单板上的所有OLT端口下的ONU升级信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的所有OLT端口下的ONU升级信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 显示指定slot上的ONU升级信息。
<Sysname> display epon onu-update slot 1
---------------------------------- Olt1/0/1 ---------------------------------
Port           Model            Version          Protocol   State
Onu1/0/1:3     ET924-H-POE      105              H3C        Not Configured
Onu1/0/1:4     ET924-H-POE      105              H3C        Not Configured
Onu1/0/1:5     ET916-H-A        107              H3C        Not Configured
Onu1/0/1:6     ET908-H-P        106              H3C        Not Configured
Onu1/0/1:7     ET904-H          203              H3C        Not Configured
ONUs found: 5
---------------------------------- Olt1/0/2 ---------------------------------
The port is down.
表1-21 display epon onu-update命令显示信息描述表
Port
绑定ONU设备的ONU接口
Model
ONU设备型号。若ONU未上电,则显示为N/A
Version
PCB版本号。若ONU未注册成功,则显示为N/A
Protocol
升级协议类型,取值包括:
·     H3C:H3C私有升级协议
·     CTC:CTC升级协议
ONU升级状态,取值包括:
·     Not configured:未配置升级ONU
·     Configured:已配置升级ONU,升级命令等待下发到对应的ONU
·     Updating(xx%):正在升级ONU,xx为当前进度的百分比
·     Active:升级文件的版本校验成功,正在重启ONU。如果ONU重启失败,则升级失败、版本回退
·     Update canceled:向ONU发送升级文件过程中,取消升级配置
·     Reconfigured:向ONU发送升级文件过程中,使用其他升级文件重新下发升级命令
·     Successful:ONU升级成功
·     Failed:ONU升级失败
·     Unsupported protocol:ONU不支持指定的升级协议
ONUs found
找到的ONU总数
The port is down.
OLT端口处于down状态
1.2.12  display onu
display onu命令用来显示ONU信息。
(独立运行模式)
display onu [ silent [ mac | loid ] | status [ keep-time keep-time ] ] { interface interface-type interface-number | slot slot-number }
display onu [ silent [ mac | loid ] | status [ keep-time keep-time ] ] { interface interface-type interface-number | chassis chassis-number slot slot-number }
silent:显示处于静默状态(未注册)的ONU的信息。指定本参数且不指定[ mac | loid ] 参数时,显示的ONU均是以MAC地址进行绑定的。
mac:显示处于静默状态的以MAC地址进行绑定的ONU的信息。
loid:显示处于静默状态的以LOID进行绑定的ONU的信息。
status:显示ONU的状态信息。
keep-time keep-time:显示状态持续时间大于等于指定值的ONU。keep-time为Offline或者Up状态的持续时间,单位为分钟,取值范围为1~4294967295。如果未指定本参数,则显示所有ONU的状态信息。
interface interface-type interface-number:显示指定接口上的ONU信息。interface-type表示接口类型,取值为Olt、Onu、Rolt或Ronu;interface-number表示接口编号。
slot slot-number:显示指定单板上的ONU信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的ONU信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
OLT端口作为OLT冗余接口的成员端口时,只能显示其OLT冗余接口上的ONU信息,而不会显示该成员端口上的ONU信息。
# 显示指定slot上的ONU状态信息。
<Sysname> display onu status slot 1
MAC            Port            Model          State    KeepTime   Description
3c8c-40cf-0f9e Onu1/0/1:1      ET254-G-S      Up       2625       Onu1/0/1:1 Interface
3c8c-40cf-0bf0 Onu1/0/1:2      ET254-G-S      Up       2625       Onu1/0/1:2 Interface
3c8c-40cf-04fd Onu1/0/1:3      ET254-G-S      Offline  239        Onu1/0/1:3 Interface
ONUs found: 128
  Up ONUs: 109
  Down ONUs: 8
  Offline ONUs: 11
表1-22 display onu status命令显示信息描述表
MAC
ONU的MAC地址。仅显示绑定了ONU接口的ONU设备
Port
被绑定的ONU接口
Model
ONU设备型号。若ONU为Offline状态,则显示为N/A
ONU状态,取值包括:
·     若ONU未上电,但已和ONU接口绑定,则显示为Offline。此时Time表示ONU的离线时间
·     若ONU已上电,且已经和ONU接口绑定,则显示为Up。此时Time表示ONU的在线时间
·     若ONU已经绑定,但ONU接口的数据链路层协议状态为关闭,则显示为Down。此时KeepTime显示为N/A,但ONU仍视为在线,在线时间会继续累积
KeepTime
ONU Offline或者Up状态的持续时间,单位为分钟
ONU接口的描述信息
如果未使用description命令配置ONU接口描述信息,则该字段显示为“接口名 Interface”,例如:Onu1/0/1:1 Interface
ONUs found
找到的ONU总数,具体包括:
·     Up ONUs:在线ONU数量
·     Down ONUs:Down状态的ONU数量
·     Offline ONUs:离线ONU数量
# 显示Olt1/0/1端口上的ONU信息。
<Sysname> display onu interface olt 1/0/1
MAC             LOID                      LLID    Dist(M)  Port             Mode
l/Version   Sft/Epm    State     Aging
3c8c-40cf-07f2                            N/A     N/A      Onu1/0/1:2       N/A
            N/A        Offline   N/A
# 显示指定slot上的ONU信息。
<Sysname> display onu slot 1
            N/A        Offline   N/A
The port is down.
表1-23 display onu命令显示信息描述表
MAC
ONU的MAC地址
LOID
ONU的LOID
LLID
OLT为注册成功的ONU自动分配的链路标识。若ONU未注册成功,则显示为N/A
Dist(M)
OLT与ONU之间的光纤长度,单位为米。如果光纤长度远小于1km,显示为<1000;如果ONU未注册成功,则显示为N/A
Port
被绑定的ONU接口或ONU冗余接口。若未绑定,则显示为N/A
Model/Version
ONU的型号和PCB版本号。若ONU未注册成功,则显示为N/A
Sft/Epm
ONU的软件版本号和EEPROM的版本号。若ONU未注册成功,则显示为N/A
ONU状态:
·     若ONU已上电,但未和ONU接口绑定,则显示为Silent;
·     若ONU未上电,但已和ONU接口绑定,则显示为Offline;
·     若ONU已上电,且已经和ONU接口绑定,则显示为Up;
·     若ONU已经绑定,但ONU接口被手工SHUTDOWN,则显示为Down
Aging
显示处于静默(Silent)状态的ONU的MAC地址老化时间。对于非静默状态的ONU,则显示为N/A
The port is down.
OLT端口/OLT冗余接口处于down状态
ONUs found
找到的ONU总数
display onu loid命令用来显示指定LOID的合法ONU信息。
display onu loid loid
# 显示指定LOID的合法ONU信息。
<Sysname> display onu loid test
3c8c-40cf-07f2  test                      10      1200     Onu1/0/1:2       BT/BV
            S/E        Up        N/A
关于各显示字段的详细解释请参见表1-23。
display onu mac-address命令用来显示指定MAC地址的合法ONU信息。
display onu mac-address mac-address
mac-address:ONU的MAC地址。
# 显示指定MAC地址的合法ONU信息。
<Sysname> display onu mac-address 000f-e200-0031
000f-e200-0031                            N/A     N/A      Onu1/0/1:2       N/A
            N/A        Offline   N/A
 ---  1 entry found  ---
display onu neighbor命令用来显示ONU的邻居设备信息。
display onu neighbor [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上的ONU的邻居设备信息。interface-type表示接口类型,取值为Onu或Ronu;interface-number为已创建的接口的编号。不指定该参数时,将显示所有ONU的邻居设备信息。
ONU的邻居设备指ONU的UNI端口连接的无线AP(Access Point,接入点)等设备。
# 显示所有ONU的邻居设备信息。
<Sysname> display onu neighbor
Interface: Onu1/0/1:1
  UNI number     Neighbor MAC       Neighbor type
  1              3c8c-40cf-07f2     AP
表1-24 display onu neighbor命令显示信息描述表
ONU接口或ONU冗余接口的名称
UNI number
UNI端口的编号
Neighbor MAC
ONU邻居设备的MAC地址
Neighbor type
ONU邻居设备类型:
·     AP:无线AP设备
display onu protocol命令用来显示ONU所支持的协议信息。
display onu protocol { dhcp-snooping information | igmp-snooping | loopback-detection | pppoe | smart-link | stp }
ONU接口视图
ONU冗余接口视图
dhcp-snooping information:DHCP-Snooping Option 82协议。
igmp-snooping: IGMP Snooping协议。
loopback-detection:环路检测协议。
pppoe:PPPoE+协议。
smart-link:Smart Link协议。
stp:RSTP(Rapid Spanning Tree Protocol,快速生成树协议)。
# 显示Onu1/0/1:1接口连接的ONU所支持的IGMP Snooping协议信息。
[Sysname-Onu1/0/1:1] display onu protocol igmp-snooping
 Protocol name: IGMP snooping
 Protocol status: Enabled
 Total 4 Multicast groups.
 Group: 0100-5e01-0140
 Port : 9
 Group: 0100-5e01-013f
 Port : 9
 Group: 0100-5e01-013e
 Port : 9
 Group: 0100-5e01-013d
 Port : 9
# 显示Onu1/0/1:1接口连接的ONU的环路检测协议信息。
[Sysname-Onu1/0/1:1] display onu protocol loopback-detection
 Protocol name: Loopback detection
 Loopback action: Semi-block
 Loopback is detected on following interfaces:UNI 1  UNI 4
表1-25 display onu protocol命令显示信息描述表
Protocol name
协议名
Protocol status
协议状态:
·     Enabled:协议处于使能状态
·     Disabled:协议处于关闭状态
·     Failed to get:没有获取到ONU上的协议状态
Total x Multicast groups
ONU上记录的组播MAC地址总数
Group
组播MAC地址
Port
UNI端口的编号
Loopback action
ONU检测到UNI端口出现环路时的处理方式:
·     Semi-block:禁止UNI端口学习MAC地址并将该端口的入方向阻塞
·     No-learning:禁止UNI端口学习MAC地址
·     Shutdown:自动关闭UNI端口
·     No-shutdown:不会自动关闭UNI端口
·     Failed to get:没有获取到ONU上的环路检测处理模式
下列UNI端口被检测到存在环路
display onu protocol smart-link uni-bind information命令用来显示ONU设备PON口与UNI端口联动功能的配置信息。
ONU接口视图
ONU冗余接口视图
# 显示ONU设备PON口与UNI端口联动功能的配置信息。
[Sysname-Onu1/0/1:1] display onu protocol smart-link uni-bind information
 Protocol name: smart-link uni-bind
表1-26 display onu protocol smart-link uni-bind information命令显示信息描述表
Protocol name
协议名
Protocol status
协议状态:Enabled或者Disabled
·     onu protocol smart-link uni-bind enable
display serial-information命令用来显示ONU上指定串口的信息。
display serial-information interface-number
ONU接口视图
ONU冗余接口视图
interface-number:ONU上串口的编号,取值范围为1~10。
# 显示ONU上串口1的信息。
[Sysname-Onu1/0/1:1] display serial-information 1
Description: Serial 1 interface
Parameters:
  Baud:9600
  Databits:8
  Parity:none
  Stopbits:1
Statistics:
  Input total: 0 bytes, Error 0 bytes
  Output total: 0 bytes, Error 0 bytes
表1-27 display serial-information命令显示信息描述表
串口描述
串口信息参数:
·     Baud: 波特率
·     Databits: 数据位
·     Parity :校验类型
·     Stopbits:停止位
Statistics
统计数据:
·     Input total:接收报文字节数和其中的错误(Error)报文字节数
·     Output total:发送报文字节数和其中的错误(Error)报文字节数
1.2.19  display uni
display uni命令用来显示ONU上指定UNI端口的信息。
display uni uni-number
ONU接口视图
ONU冗余接口视图
# 显示ONU的UNI端口1的信息。
[Sysname-Onu1/0/1:1] display uni 1
 UNI 1
 Configuration        :
 Port status          : Undo shutdown
 Flow control         : Closed
 Autonegotiation state: Enable
 Port isolation       : Disable
 MDI type             : Automdix
 Port policy :
   Inbound :
     CIR : 0
     Bucket depth : 0
     Extra burst size : 0
   Outbound :
     CIR : 0
     PIR : 0
 Vlan configuration :
   VLAN mode : Transparent
 Classification & marking :
 Multicast VLAN : None
 Multicast groups : 64
 Multicast VLAN untagging : Disable
 Multicast VLAN forwarding info:
  Multicast VLAN forwarding index:0
  VLAN ID:100
  Multicast MAC address:0100-5e00-0002
 Current Status :
 Link state : DOWN
 Local autonegotiation ability :
     1000BASE-T UTP PHY
     Full duplex 1000BASE-T UTP PHY
     100BASE-TX
     Full duplex 100BASE-TX
     Full duplex 10BASE-T
     10BASE-T
     Symmetric PAUSE operation for full duplex links
     Asymmetric PAUSE operation for full duplex links
 Autonegotiation advertisement ability :
     1000BASE-T UTP PHY
     100BASE-TX
     10BASE-T
 100Mbps-speed mode, Full-duplex mode
 Link speed type is autonegotiation, Link duplex type is autonegotiation
 Input(total):  0 packets, 0 bytes
          0 broadcasts, 0 multicasts, 0 unicasts, 0 pauses
 Input:  0 input errors, 0 runts, 0 giants, 0 InRxErr, 0 CRC
         0 buffer failures
 Output(total): 0 packets, 0 bytes
 Output: 0 output errors, 0 deferred, 0 collisions, 0 InTxErr
表1-28 display uni命令显示信息描述表
UNI
UNI端口号
Configuration
显示UNI端口配置情况
Port status
端口的管理状态:
·     Shutdown:表示该端口已经通过uni shutdown命令被关闭,即管理状态为关闭
·     Undo shutdown:表示该接口的管理状态为开启
Flow control
流量控制情况:
·     Open:表示流量控制功能开启
·     Closed:表示流量控制功能关闭
自协商功能状态:
·     Enable:表示自协商功能开启
·     Disable:表示自协商功能关闭
Port isolation
端口是否加入端口隔离组:
·     Enable:表示端口加入端口隔离组
·     Disable:表示端口不加入端口隔离组
MDI type
网线类型,取值为Automdix、Mdi或Mdix,与用户的配置有关
Port policy
UNI端口的上/下行流量监管参数:
·     Inbound:表示上行流量监管参数,包括CIR、Bucket depth和Extra burst size。相关配置命令为uni port-policy inbound
·     Outbound:表示下行流量监管参数,包括CIR和PIR。相关配置命令为uni port-policy outbound
Vlan configration
UNI端口的VLAN操作模式,包括:
·     Transparent:表示VLAN透传模式
·     Add-vlan-tag:表示VLAN标记模式
·     Translation:表示VLAN Translation模式
·     802.1q-in-802.1q:表示VLAN QinQ模式
·     Trunk:表示VLAN Trunk模式
·     Aggregation:表示VLAN N:1聚合模式
VLAN操作模式中可能出现的字段包括:
·     PVID:表示端口缺省VLAN ID
·     Priority:表示报文的802.1p优先级
·     Old VLAN:表示原始VLAN ID
·     New VLAN:表示转换后的VLAN ID
·     Trunk VLAN:表示端口允许通过的VLAN范围
相关配置命令为uni vlan-mode
流分类配置
Multicast VLAN
UNI端口加入的组播VLAN
Multicast groups
UNI端口支持的组播频道数目
是否开启了删除UNI端口下行组播流的VLAN Tag功能
UNI端口的未知组播报文透传功能的配置信息
未知组播报文透传功能的配置索引号
VLAN ID
组播MAC地址对应的VLAN ID
透传的组播MAC地址
Current Status
显示当前状态
Link state
端口的链路层状态:
·     UP:表示数据链路层状态为开启
·     DOWN:表示数据链路层状态为关闭
本地自协商能力
本地自协商通告能力
百兆全双工模式
端口速率处于双方自协商状态,端口双工状态为自协商状态
Input(total)
端口接收报文的统计值,包括:
·     报文和PAUSE帧的报文数、字节数
·     端口接收的广播报文、组播报文、单播报文和PAUSE帧的数量
Input
端口接收的错误帧、超小帧(runts)、超大帧(giants)、接收过程出现错误的报文(InRxErr)、CRC校验错误的帧、因端口发送缓冲区不足而丢弃的帧(buffer failures)的数量
Output(total)
端口发送报文的统计值,包括报文和PAUSE帧的报文数、字节数
端口发送的广播报文、组播报文、单播报文和PAUSE帧的数量
Output
端口发送的错误帧、延迟报文(deferred)、冲突帧(collisions)、发送过程出现错误的报文(InTxErr)的数量
display vendor-specific information命令用来显示ONU的详细信息。
ONU接口视图
ONU冗余接口视图
# 显示Onu1/0/1:1接口对应ONU的详细信息。
[Sysname-Onu1/0/1:1] display vendor-specific information
 Serial number
     Vendor ID : H3C
     ONU MAC address : 3c8c-40cf-0f12
     ONU model : 254
     ONU hardware version : A0
     ONU software version : 110
     ONU extend model :
 Firmware version : 0x1
 Chipset information :
     Vendor ID : 0x4530
     Chip model : 6750
     Revision version : 0xa0
     Design date : 08/03/27
 ONU capability :
     Gigabit ethernet interface :  Support
     Fast ethernet interface :  Not support
     VoIP service :  Not support
     TDM ces service :  Not support
     Gigabit ethernet ports number :  4
     Gigabit ethernet ports :
       0x1
       0x2
       0x3
       0x4
     Fast ethernet ports number :  0
     POTS ports number :  0
     E1 ports number :  0
     Upstream queues number :  8
     Maximum queues per port upstream :  8
     Downstream queues number :  8
     Maximum queues per port downstream :  8
     Battery backup :  Not support
 ONU capability(CTC2.1) :
     ONU type :  SFU
     LLID number :  1
     Protection type :  Not support
     Slot number :  0
     PON number :  1
     Interface type number :  1
     VoIP ports number :  0
     GE ports number :  4
     FE ports number :  0
     WLAN ports number :  0
     CATV RF ports number :  0
     USB ports number :  0
 Forward error correction ability : Support
 IGMP-snooping fast-leave : Support
 Multicast control fast-leave : Support
 Forward error correction mode : Disable
 DBA-Report parameters :
   Queue sets number : 2
     Queue set : 1
       Queue 1 : State:1 , Value:0
       Queue 2 : State:1 , Value:0
       Queue 3 : State:1 , Value:0
       Queue 4 : State:1 , Value:65535
       Queue 5 : State:1 , Value:65535
       Queue 6 : State:0 , Value:0
       Queue 7 : State:0 , Value:0
       Queue 8 : State:0 , Value:0
     Queue set : 2
 Multicast-fast-leave : Disable
 ONU-Isolate state : Disable
 Multicast-mode : IGSP
表1-29 display vendor-specific information命令显示信息描述表
Serial number
序列号
Vendor ID
ONU厂商ID
ONU MAC address
ONU 的MAC 地址
ONU model
ONU 类型
ONU 硬件版本
ONU 软件版本
ONU extend model
完整的ONU型号,CTC3.0标准时需要此字段
Firmware version
固件版本
Chipset information
芯片信息
·     Vendor ID:厂商ID
·     Chip model:芯片类型
·     Revision version:修订版本
·     Design date:设计日期
ONU capability
ONU能力信息
·     Gigabit ethernet interface:是否具有千兆以太网接口
·     Fast ethernet interface:是否具有百兆以太网接口
·     VoIP service:是否支持Voice over IP业务
·     TDM ces service:是否支持时分复用电路仿真(Circuit Emulation Service)业务
·     Gigabit ethernet ports number:千兆以太网端口数目
·     Fast ethernet ports number:百兆以太网端口数目
·     POTS ports number:POTS(Plain Old Telephone Service,传统电话业务)端口数量
·     E1 ports number:E1 端口数目
·     Upstream queues number:上行队列数目
·     Maximum queues per port upstream:每端口上行支持的最大队列数目
·     Downstream queues number:下行队列数目
·     Maximum queues per port downstream:每端口下行支持的最大队列数目
·     Battery backup:是否支持电池备份
ONU能力信息(CTC2.1标准)
·     ONU type:ONU设备形态,包括SFU(Single Family Unit,单个家庭用户单元)、HGU(Home Gateway Unit,家庭网关单元)、SBU(Single Business Unit,单个商业用户单元)、盒式MDU(Multi-Dwelling Unit,多住户单元)、插卡式MDU和MTU(Multi-Tenant Unit,多租户单元)
·     LLID number:ONU支持的LLID数量
·     Protection type:ONU支持的光链路保护类型,包括类型c和类型d
·     Slot number:插卡式ONU的业务槽位数量
·     PON number:ONU支持的上联PON口数量
·     Interface type number:ONU的接口类型数量
·     VoIP ports number:ONU的VoIP接口数量
·     GE ports number:ONU的千兆以太网接口数量
·     FE ports number:ONU的百兆以太网接口数量
·     WLAN ports number:ONU的WLAN接口数量
·     CATV RF ports number:ONU的CATV RF接口数量
·     USB ports number:ONU的USB接口数量
ONU capability(CTC3.0)
ONU能力信息(CTC3.0标准)
·     IPV6 supported:是否支持IPv6感知
·     Power supply control:是否支持ONU电源控制,包括ONU Tx电源控制和ONU Rx电源控制
·     Service SLA:是否支持SLA(Service Level Agreement,服务等级协定)功能
是否支持FEC 功能
是否支持指定UNI端口快速离开功能
是否支持所有UNI端口快速离开功能
是否开启FEC 功能
DBA Report 消息参数
·     Queue sets number:表示支持的队列集数量
·     Queue set:队列集编号
·     Queue x: State:x , Value:x:队列x的状态(State)及阈值(Value),当State为0 表示该队列关闭,为1 表示该队列开启
是否开启了ONU下所有UNI端口快速离开功能
ONU-Isolate state
是否开启了ONU下所有UNI端口隔离功能
Multicast-mode
组播模式:IGSP(IGMP Snooping)或者multicast control
1.2.21  encryption enable
encryption enable命令用来开启ONU接口/ONU冗余接口的下行流量加密功能。
undo encryption enable命令用来关闭ONU接口/ONU冗余接口的下行流量加密功能。
encryption enable
ONU接口/ONU冗余接口的下行流量加密功能处于开启状态。
ONU接口视图
ONU冗余接口视图
# 打开ONU接口的下行流量加密功能。
[Sysname-Onu1/0/1:1] encryption enable
1.2.22  forward-error-correction
forward-error-correction enable命令用来开启ONU的FEC(Forward Error Correction,前向错误纠错)功能。
undo forward-error-correction enable命令用来关闭ONU的FEC功能。
ONU的FEC功能处于关闭状态。
ONU接口视图
ONU冗余接口视图
当10G-EPON单板的ONU接口/ONU冗余接口连接的10G/10G ONU上线后,该ONU缺省支持FEC功能,无需配置;如果在该接口上使用undo命令关闭FEC功能,命令不生效。
# 开启ONU的FEC功能。
[Sysname-Onu1/0/1:1] forward-error-correction enable
1.2.23  ip address
ip address命令用来配置ONU的管理VLAN的IPV4地址。
undo ip address命令用来将ONU的管理VLAN的IPv4地址恢复为缺省情况。
ip address { dhcp-alloc | ip-address { mask-length | mask } gateway gateway }
undo ip address
H3C ONU的管理VLAN接口的IPv4地址为192.168.0.240,子网掩码为255.255.255.0。
ONU接口视图
ONU冗余接口视图
dhcp-alloc:通过DHCP功能自动获取IPv4地址。
ip-address:手工配置的接口IPv4地址,为点分十进制格式。
mask:接口IPv4地址相应的子网掩码,为点分十进制格式。
gateway gateway:网关IPv4地址。
如果用management-vlan命令改变ONU的管理VLAN,原管理VLAN接口的IP地址将被清除。
使用rule命令为用户角色创建基于特性的规则时,本命令所属特性为ipstack而不是epon。例如,当规则“rule 1 deny write feature ipstack”生效时,本命令会被禁止执行。有关rule命令的详细介绍,请参见“基础配置命令参考”中的“RBAC”。
# 配置ONU的IPv4地址为192.168.0.1/24,网关为192.168.0.99。
[Sysname-Onu1/0/1:1] ip address 192.168.0.1 24 gateway 192.168.0.99
·     management-vlan
1.2.24  ipv6 address
ipv6 address命令用来配置ONU的管理VLAN接口的IPv6地址。
undo ipv6 address命令用来删除ONU的管理VLAN接口的IPv6地址。
ipv6 address { dhcp-alloc | { ipv6-address prefix-length | ipv6-address/prefix-length } gateway gateway }
undo ipv6 address
未配置ONU的管理VLAN接口的IPv6地址。
ONU接口视图
ONU冗余接口视图
dhcp-alloc:通过DHCP功能自动获取IPv6地址。
ipv6-address:ONU的管理VLAN接口的IPv6地址。
prefix-length:前缀长度,取值范围为1~128。
gateway gateway:网关的IPv6地址。
# 开启ONU的管理VLAN接口,配置该接口的IPv6地址为2001::1,前缀长度为64,网关的IPv6地址为2001::99。
[Sysname-Onu1/0/1:1] undo shutdown management-vlan-interface
[Sysname-Onu1/0/1:1] ipv6 address 2001::1/64 gateway 2001::99
·     management-vlan
1.2.25  management-vlan
management-vlan命令用来配置ONU的管理VLAN。
undo management-vlan命令用来将ONU的管理VLAN恢复为缺省情况。
management-vlan vlan-id
管理VLAN为VLAN 1。
ONU接口视图
ONU冗余接口视图
vlan-id :管理VLAN ID,取值范围为1~4094。
如果改变ONU的管理VLAN,原管理VLAN接口的IP地址将被清除。
# 设置ONU的管理VLAN为VLAN 10。
[Sysname-Onu1/0/1:1] management-vlan 10
·     shutdown management-vlan-interface
1.2.26  onu authentication-domain
onu authentication-domain命令用来开启OLT的ONU认证功能,并指定该OLT下ONU用户使用的ISP域。
undo onu authentication-domain命令用来关闭OLT的ONU认证功能,并删除该OLT下ONU用户使用的ISP域。
onu authentication-domain domain-name
OLT的ONU认证功能处于关闭状态。
OLT端口视图
OLT冗余接口视图
domain-name:ISP认证域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符。
指定的ISP域中定义了对ONU用户进行认证的方案。有关ISP域的介绍及相关认证配置,请参见“安全配置指导”中的“AAA”。
仅当ONU自动绑定功能开启后,ONU认证功能才能生效。
# 开启Olt1/0/1端口的ONU认证功能,并指定该OLT下ONU用户使用的ISP域为test。
[Sysname] interface Olt 1/0/1
[Sysname-Olt1/0/1] onu authentication-domain test
[Sysname-Olt1/0/1] quit
# 开启指定slot上的ONU自动绑定功能。
[Sysname] ftth
[Sysname-ftth] onu bind auto slot 1
[Sysname-ftth] quit
·     authentication onu(安全命令参考/AAA)
·     onu bind auto
1.2.27  onu authentication-format
onu authentication-format命令用来配置ONU认证用户的账号格式。
undo onu authentication-format命令用来恢复缺省情况。
onu authentication-format mac-address { { with-hyphen | without-hyphen } | { lowercase | uppercase } }*
OLT使用ONU的MAC地址作为ONU身份认证的用户名和密码,MAC地址使用带两个连字符“-”的格式,字母全大写。
FTTH视图
mac-address:使用ONU的MAC地址作为ONU认证的用户名和密码。
with-hyphen:表示认证使用的MAC地址为带两个连字符“-”的格式,例如3C8C-40CF-0523。
without-hyphen:表示认证使用的MAC地址为不带连字符“-”的格式,例如3C8C40CF0523。
lowercase:表示认证使用的MAC地址为全小写的格式。
uppercase:表示认证使用的MAC地址为全大写的格式。
多次执行本命令,最后一次执行的命令生效。未指定with-hyphen和without-hyphen参数时,缺省值为with-hyphen;未指定lowercase和uppercase参数时,缺省值为uppercase。
# 配置所有OLT使用ONU的MAC地址作为ONU身份认证的用户名和密码,MAC地址使用不带连字符“-”的格式,字母全小写。
[Sysname] ftth
[Sysname-ftth] onu authentication-format mac-address without-hyphen lowercase
·     onu authentication-domain
1.2.28  onu bind auto
onu bind auto命令用来开启ONU自动绑定功能。
undo onu bind auto命令用来关闭ONU自动绑定功能。
(独立运行模式)
onu bind auto [ slot slot-number ] [ bind-type { mac | loid | loid-password }* ]
undo onu bind auto [ slot slot-number ] [ bind-type { mac | loid | loid-password }* ]
onu bind auto [ chassis chassis-number slot slot-number ] [ bind-type { mac | loid | loid-password }* ]
undo onu bind auto [ chassis chassis-number slot slot-number ] [ bind-type { mac | loid | loid-password }* ]
ONU自动绑定功能处于关闭状态。
FTTH视图
slot slot-number:开启指定单板上的ONU自动绑定功能,slot-number表示单板所在的槽位号。如果不指定该参数,将开启所有单板上的ONU自动绑定功能。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备指定单板上的ONU自动绑定功能,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,将开启所有单板上的ONU自动绑定功能。(IRF模式)
bind-type:指定ONU绑定时使用的媒介。不指定本参数时,ONU使用其MAC地址进行绑定。
mac:表示ONU使用其MAC地址进行绑定。
配置ONU自动绑定后,设备不仅会自动将未注册的ONU设备MAC地址绑定到ONU接口/ONU冗余接口上,而且对于后加入的ONU 设备也会进行自动绑定。
这种绑定方式适用于对OLT下面连接的ONU设备完全信任的情况。如果要解除某个ONU的绑定,需要先使用undo onu bind auto命令关闭ONU自动绑定功能。
多次执行带有bind-type参数的本命令时,ONU绑定时使用的媒介是多次配置的集合。
undo onu bind auto命令不指定bind-type参数时,表示关闭ONU的自动绑定功能。undo onu bind auto命令指定bind-type参数时,表示取消ONU使用指定媒介进行自动绑定。
当使用onu bind auto命令配置ONU使用LOID或LOID+LOID密码进行自动绑定,且ONU设备自动绑定到ONU接口/ONU冗余接口并注册上线后,如果ONU设备修改LOID或LOID密码,那么只有解除对应接口和ONU设备的绑定(可使用undo bind onu-id命令),该ONU才能重新注册上线。
[Sysname] ftth
1.2.29  onu bind batch
onu bind batch命令用来开启ONU批量绑定功能。
(独立运行模式)
onu bind batch [ slot slot-number ] [ bind-type { mac | loid | loid-password }]
onu bind batch [ chassis chassis-number slot slot-number ] [ bind-type { mac | loid | loid-password } ]
ONU批量绑定功能处于关闭状态。
FTTH视图
slot slot-number:开启指定单板上的ONU批量绑定功能,slot-number表示单板所在的槽位号。如果不指定该参数,将开启所有单板上的ONU批量绑定功能。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备指定单板上的ONU批量绑定功能,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,将开启所有单板上的ONU批量绑定功能。(IRF模式)
开启ONU批量绑定后,设备会自动将未注册的ONU设备MAC地址绑定到ONU接口上,对于后加入的ONU不再进行绑定处理。
这种绑定方式适用于网络环境最初建立时,确定ONU 都是合法的,可以省去大量繁琐的绑定操作。而之后为了防止非法ONU 自动注册,对于新加入的ONU,可以再使用bind onu-id命令单独绑定。
# 开启指定slot上的ONU批量绑定功能。
[Sysname] ftth
[Sysname-ftth] onu bind batch slot 1
·     bind onu-id
1.2.30  onu bind one-to-one
onu bind one-to-one命令用来开启OLT的ONU绑定控制功能。
undo onu bind one-to-one命令用来关闭OLT的ONU绑定控制功能。
onu bind one-to-one
OLT的ONU绑定控制功能处于关闭状态。
FTTH视图
OLT端口视图
OLT冗余接口视图
本功能用于将ONU绑定到唯一OLT端口或OLT冗余接口下的一个ONU接口或ONU冗余接口。开启本功能后,如果该OLT端口或OLT冗余接口上注册了一台ONU,那么本设备的其他OLT端口或OLT冗余接口都不能再注册该ONU。
本功能在接口视图下配置时只对该接口起作用,在FTTH视图下配置时对所有OLT端口和OLT冗余接口生效,但是不能同时在接口视图下和FTTH视图下配置。
·     开启本功能时,已经在不同OLT下注册的ONU不受影响。
·     请不要将开启ONU绑定控制功能的OLT端口加入光纤备份组,否则光纤备份特性不能正常运行。(光纤备份特性要求一台ONU同时绑定到互为备份的两个OLT端口下的两个ONU接口上。)
·     进行配置回滚时,如果回滚配置文件中存在onu bind one-to-one命令且不同OLT端口下的ONU接口通过bind onu-id命令绑定了同一个ONU,则配置回滚后可能只有其中一个OLT端口下的ONU接口保留bind onu-id命令配置。
# 开启Olt1/0/1端口的ONU绑定控制功能。
[Sysname] interface olt 1/0/1
[Sysname-Olt1/0/1] onu bind one-to-one
1.2.31  onu event
onu event命令用来开启ONU向OLT上报事件信息功能。
undo onu event命令用来关闭ONU向OLT上报事件信息功能。
onu event { debug | log | trap } enable level severity
undo onu event { debug | log | trap } enable
未开启ONU向OLT上报事件信息功能。
ONU接口视图
ONU冗余接口视图
debug:Debug信息。
log:Log信息。
trap:Trap信息。
level severity:ONU向OLT上报信息的级别,根据上报信息的优先级由高到低分别为以下8类:
·     emergencies (severity=0)
·     alerts (severity=1)
·     critical (severity=2)
·     errors (severity=3)
·     warnings (severity=4)
·     notifications (severity=5)
·     information (severity=6)
·     debugging (severity=7)
设定ONU向OLT上报信息的等级时,所有信息等级高于或等于设置等级的信息都会被上报。例如,输出规则中指定允许上报等级为6(information)的信息,则等级0~6的信息均会被上报。
# 设置Onu1/0/2:1接口向OLT上报优先级为1的Debug信息。
[Sysname-Onu1/0/2:1] onu event debug enable level alerts
1.2.32  onu mac-address timer
onu mac-address timer命令用来配置ONU的动态MAC地址表项的老化时间。
undo onu mac-address timer命令用来恢复缺省情况。
onu mac-address timer { aging seconds | no-aging }
ONU的动态MAC地址表项的老化时间为300秒。
ONU接口视图
ONU冗余接口视图
aging seconds:动态MAC地址表项的老化时间,取值范围为1~4294967295,单位为秒。
no-aging:不老化。
# 配置ONU的动态MAC地址表项的老化时间为500秒。
[Sysname-Onu1/0/1:1] onu mac-address timer aging 500
1.2.33  onu port-isolate enable
onu port-isolate enable命令用来将ONU下的所有UNI端口加入隔离组。
undo onu port-isolate enable命令用来将ONU下的所有UNI端口从隔离组中删除。
ONU下的UNI端口未加入隔离组。
ONU接口视图
ONU冗余接口视图
本命令和uni port-isolate命令互斥,不能同时配置。
# 隔离Onu1/0/1:1接口连接的ONU下所有UNI端口。
[Sysname-Onu1/0/1:1] onu port-isolate enable
·     uni port-isolate
1.2.34  onu protocol enable
onu protocol enable命令用来开启ONU的业务特性。
undo onu protocol enable命令用来关闭指定的业务特性。
onu protocol { dhcp-snooping | dhcp-snooping information | loopback-detection | pppoe | stp } enable
undo onu protocol { dhcp-snooping | dhcp-snooping information | loopback-detection | pppoe | stp } enable
环路检测处于开启状态,DHCP-Snooping、DHCP-Snooping Option 82(dhcp-snooping information)、PPPoE+(pppoe)和RSTP(stp)均处于关闭状态。
ONU接口视图
ONU冗余接口视图
dhcp-snooping:DHCP-Snooping协议。
pppoe:PPPoE+协议。
stp:RSTP协议。
建议不要同时开启ONU的RSTP功能和环路检测功能,否则可能导致功能异常。
# 开启ONU的DHCP-Snooping功能。
[Sysname-Onu1/0/1:1] onu protocol dhcp-snooping enable
1.2.35  onu protocol loopback-detection action
onu protocol loopback-detection action命令用来配置ONU的环路检测处理模式。
undo onu protocol loopback-detection action命令用来恢复缺省情况。
onu protocol loopback-detection action { no-learning | semi-block | shutdown }
ONU的环路检测处理模式为semi-block。
ONU接口视图
ONU冗余接口视图
no-learning:当ONU检测到UNI端口出现环路时,禁止该端口学习MAC地址。
semi-block:当ONU检测到UNI端口出现环路时,禁止该端口学习MAC地址并将该端口的入方向阻塞。
shutdown:当ONU检测到UNI端口出现环路时,自动关闭该端口。
# 开启ONU的环路检测处理模式为semi-block。
[Sysname-Onu1/0/1:1] onu protocol loopback-detection action semi-block
1.2.36  onu protocol smart-link flush enable
onu protocol smart-link flush enable命令用来开启ONU的发送Flush报文功能。
undo onu protocol smart-link flush enable命令用来关闭ONU的发送Flush报文功能。
onu protocol smart-link flush enable [ control-vlan vlan-id ]
未开启ONU的发送Flush报文功能。
ONU接口视图
ONU冗余接口视图
control-vlan vlan-id:表示接收Flush报文的控制VLAN,缺省值为1。vlan-id为VLAN编号,取值范围为1~4094。
# 开启ONU的发送Flush报文功能,指定接收Flush报文的控制VLAN为2。
[Sysname-Onu1/0/1:1] onu protocol smart-link flush enable control-vlan 2
1.2.37  onu protocol smart-link uni-bind enable
本命令仅适用于配置ONU设备ET824-E。
onu protocol smart-link uni-bind enable命令用来开启ONU设备PON口与UNI端口联动功能。
undo onu protocol smart-link uni-bind enable命令用来关闭ONU设备PON口与UNI端口联动功能。
未开启ONU设备PON口与UNI端口联动功能。
ONU接口视图
ONU冗余接口视图
配置本功能后,当ONU设备的双PON口同时在线时,使在线UNI端口数最多的PON口处于转发状态(active)。
# 开启ONU设备PON口与UNI端口联动功能。
[Sysname-Onu1/0/1:1] onu protocol smart-link uni-bind enable
·     display onu protocol smart-link uni-bind information
1.2.38  onu replace enable
onu replace enable命令用来开启ONU自动替换功能。
undo onu replace enable命令用来关闭ONU自动替换功能。
onu replace enable { keep-config | clear-config }
ONU自动替换功能处于关闭状态。
FTTH视图
keep-config:替换ONU接口连接的ONU时,保留该接口的配置信息(bind onu-id命令除外)。
clear-config:替换ONU接口连接的ONU时,清除该接口的配置信息(shutdown命令除外)。
自动绑定ONU的场景中,当OLT端口下的已注册ONU数量达到上限时,缺省情况下新的接入ONU不能注册到该OLT。开启ONU自动替换功能后,对于这种情况,设备会把该OLT下已注册的离线时间最长的ONU与其相连的ONU接口解除绑定,使新接入ONU可以自动绑定到释放出来的ONU接口。
加入光纤备份组的OLT端口下的ONU接口不支持ONU自动替换功能。
OLT冗余接口下的ONU冗余接口不支持ONU自动替换功能。
一般情况下建议选择keep-config参数;如果选择clear-config参数,需要注意:
·     ONU接口下的某些配置被清除后,会对ONU上当前运行的业务产生影响。建议您在执行该命令前,完全了解其对网络产生的影响。
·     每个ONU接口清除配置信息都需要消耗一定时间,如果有大量ONU接入并触发自动替换,请耐心等待。
# 开启ONU自动替换功能。替换ONU接口连接的ONU时,清除该接口的除shutdown命令以外的所有配置信息。
[Sysname] ftth
[Sysname-ftth] onu replace enable clear-config
·     onu bind auto
1.2.39  onu statistics enable
onu statistics enable命令用来开启ONU的统计功能。
undo onu statistics enable命令用来关闭ONU的统计功能。
onu statistics enable [ period period-value ]
ONU的统计功能处于开启状态。
ONU接口视图
ONU冗余接口视图
period period-value:表示采样周期,period-value的取值范围为0~4294967295,单位为秒,缺省值为4294967295。
# 开启ONU的统计功能,并设置采样周期为1000秒。
[Sysname-Onu1/0/1:1] onu statistics enable period 1000
·     display epon statistics
1.2.40  onu suspicious-loopback-detection enable
onu suspicious-loopback-detection enable命令用来开启所有ONU的可疑环路检测功能。
undo onu suspicious-loopback-detection enable命令用来关闭所有ONU的可疑环路检测功能。
ONU的可疑环路检测功能处于关闭状态。
FTTH视图
可疑环路不一定是真正的环路,需要结合现场组网情况进行确认。
只有环路检测功能处于开启状态的ONU支持可疑环路检测。ONU的环路检测功能可通过onu protocol loopback-detection enable命令开启。
# 开启所有ONU的可疑环路检测功能。
[Sysname] ftth
[Sysname-ftth] onu suspicious-loopback-detection enable
·     onu protocol enable
1.2.41  onu template
onu template命令用来创建ONU配置模板,并进入ONU配置模板视图。如果指定的ONU配置模板已存在,则直接进入该ONU配置模板的视图。
undo onu template命令用来删除ONU配置模板。
undo onu template template-id
不存在ONU配置模板。
ONU配置模板用于存放多条ONU远程配置命令,通过应用ONU配置模板可以将模板中存放的命令批量下发到OLT端口下的ONU接口。
ONU配置模板视图下支持的命令包括:
·     如下VLAN命令:
¡     port access vlan
¡     port link-type
¡     port trunk pvid
¡     port trunk permit vlan
关于ONU接口的VLAN相关配置,请参见“EPON基础配置指导”中的“远程配置ONU/配置ONU接口链路类型”。
·     uni vlan-mode (ONU template view)
·     如下EPON基础命令:
¡     forward-error-correction enable
¡     onu port-isolate enable
¡     onu protocol loopback-detection action
¡     onu protocol loopback-detection enable
¡     uni flow-control
¡     uni mac-address max-mac-count
¡     uni port-isolate
·     如下EPON组播命令:
¡     onu multicast fast-leave enable(EPON命令参考/EPON组播)
¡     onu protocol transparent-multicast(EPON命令参考/EPON组播)
¡     uni igmp-snooping fast-leave(EPON命令参考/EPON组播)
¡     uni multicast vlan(EPON命令参考/EPON组播)
¡     uni multicast-strip-tag enable(EPON命令参考/EPON组播)
¡     uni multicast-translate-tag(EPON命令参考/EPON组播)
¡     uni transparent-multicast(EPON命令参考/EPON组播)
·     如下EPON QoS命令:
¡     bandwidth-downstream(EPON命令参考/EPON QoS)
¡     bandwidth-downstream policy enable(EPON命令参考/EPON QoS)
¡     upstream-sla(EPON命令参考/EPON QoS)
新建ONU配置模板后,该模板中缺省不存在任何命令。
如果要删除ONU配置模板中的命令,请在ONU配置模板视图下执行对应的undo命令。
# 创建ONU配置模板1,并进入ONU配置模板视图。
[Sysname] onu template 1
[Sysname-onu-template-1]
1.2.42  reboot onu
reboot onu命令用来重启ONU设备。
reboot onu
ONU接口视图
ONU冗余接口视图
只有在线ONU设备才能通过本命令远程重启。
# 将Onu1/0/1:1接口连接的ONU重新启动。
[Sysname-Onu1/0/1:1] reboot onu
1.2.43  remove offline-onu
remove offline-onu命令用来删除OLT端口上的离线ONU。
(独立运行模式)
remove offline-onu [ offline-time time ] { interface olt interface-number | slot slot-number }
remove offline-onu [ offline-time time ] { interface olt interface-number | chassis chassis-number slot slot-number }
offline-time time:删除离线时间大于等于指定时间的ONU。time为离线时间,单位为分钟,取值范围为30~4294967295。如果未指定本参数,则表示删除离线时间大于等于30分钟的ONU。
interface olt interface-number:删除指定OLT端口上的离线ONU。interface-number表示接口编号。
slot slot-number:删除指定单板的所有OLT端口上的离线ONU,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:删除指定成员设备指定单板的所有OLT端口上的离线ONU,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
本命令通过直接删除离线ONU所在的ONU接口,将离线ONU解除绑定。
仅当ONU自动绑定功能处于关闭状态时,才能删除离线ONU。
本命令不能删除已加入光纤备份组的OLT端口上的离线ONU。
离线ONU可以通过display onu命令中的Offline字段查看。
# 删除指定slot的所有OLT端口上离线时间大于30分钟的ONU。
[Sysname] remove offline-onu offline-time 30 slot 1
·     display onu
·     onu bind auto
1.2.44  reset counters serial
reset counters serial命令用来清除ONU下串口的报文统计信息。
reset counters serial interface-number
ONU接口视图
ONU冗余接口视图
interface-number:串口编号,取值范围为1~10。
在配置该命令前,需要确保该ONU下存在串口。
# 清除ONU的串口1的报文统计信息。
[Sysname-Onu1/0/1:1] reset counters serial 1
1.2.45  reset counters uni
reset counters uni命令用来清除ONU下UNI端口的报文统计信息。
reset counters uni [ uni-number ]
ONU接口视图
ONU冗余接口视图
uni-number:UNI端口号,取值范围为1~当前ONU的UNI端口数,且支持最大的UNI端口数为79。若未指定本参数,则清除当前ONU下所有UNI端口的报文统计信息。
# 清除ONU的UNI端口1的报文统计信息。
[Sysname-Onu1/0/1:1] reset counters uni 1
1.2.46  serial databit
serial databit命令用来设置ONU串口的数据位。
undo serial databit命令用来恢复缺省情况。
serial interface-number databit { 5 | 6 | 7 | 8 }
undo serial interface-number databit
ONU串口的数据位为8bits。
ONU接口视图
ONU冗余接口视图
5:串口的数据位为5bits。
6:串口的数据位为6bits。
7:串口的数据位为7bits。
8:串口的数据位为8bits。
# 设置ONU串口的数据位为5bits。
[Sysname-Onu1/0/1:1] serial 1 databit 5
1.2.47  serial parity
serial parity命令用来设置ONU串口的校验类型。
undo serial parity命令用来恢复缺省情况。
serial interface-number parity { even | mark | none | odd | space }
undo serial interface-number parity
ONU串口的校验类型为none,即不进行校验。
ONU接口视图
ONU冗余接口视图
interface-number :串口编号,取值范围为1~10。
even:进行偶校验。
mark:进行标记校验。
none:无校验。
odd:进行奇校验。
space:进行空格校验。
# 设置ONU串口1的校验类型为odd。
[Sysname-Onu1/0/1:1] serial 1 parity odd
1.2.48  serial session protocol-type
serial session protocol-type命令用来创建ONU串口会话。
undo serial session protocol-type命令用来删除ONU串口会话。
serial interface-number session session-number protocol-type tcp-client server ip-address port port-number
serial interface-number session session-number protocol-type tcp-server listen-port port-number
serial interface-number session session-number protocol-type udp server ip-address port port-number listen-port port-number
undo serial interface-number session session-number protocol-type
未创建ONU串口会话。
ONU接口视图
ONU冗余接口视图
protocol-type tcp-client:选择ONU作为TCP连接的客户端。
protocol-type tcp-server:选择ONU作为TCP连接的服务器端。
protocol-type udp:选择ONU同时作为UDP客户端和服务端。
server:指定服务器。
port:远程端口。
listen-port:本地侦听端口。
session-number:会话号,取值范围为1~6。
ip-address:服务器端有效IP地址。
port-number:远端服务器端口号,取值范围为1024~65535。
# 在ONU上创建一条UDP类型的串口会话。
[Sysname-Onu1/0/1:1] serial 1 session 5 protocol-type udp server 3.3.2.5 port 4500 l
isten-port 75
1.2.49  serial speed
serial speed命令用来设置ONU串口的波特率。
undo serial speed命令用来恢复缺省情况。
serial interface-number speed { 300 | 600 | 1200 | 2400 | 4800 | 9600 | 19200 | 38400 | 57600 | 115200 }
undo serial interface-number speed
ONU串口的波特率为9600bps。
ONU接口视图
ONU冗余接口视图
300:串口的波特率为300bps。
600:串口的波特率为600bps。
1200:串口的波特率为1200bps。
2400:串口的波特率为2400bps。
4800:串口的波特率为4800bps。
9600:串口的波特率为9600bps。
19200:串口的波特率为19200bps。
38400:串口的波特率为38400bps。
57600:串口的波特率为57600bps。
115200:串口的波特率为115200bps。
# 设置ONU串口1的波特率为300bps。
[Sysname-Onu1/0/1:1] serial 1 speed 300
1.2.50  serial stopbit
serial stopbit命令用来设置ONU串口的停止位。
undo serial stopbit命令用来恢复缺省情况。
serial interface-number stopbit { 1 | 1.5 | 2 }
undo serial interface-number stopbit
ONU串口的停止位为1bit。
ONU接口视图
ONU冗余接口视图
1:串口的停止位为1bit。
1.5:串口的停止位为1.5bits。
2:串口的停止位为2bits。
# 设置ONU串口1的停止位为1.5bits。
[Sysname-Onu1/0/1:1] serial 1 stopbit 1.5
1.2.51  shutdown management-vlan-interface
shutdown management-vlan-interface命令用来关闭ONU的管理VLAN接口。
undo shutdown management-vlan-interface命令用来开启ONU的管理VLAN接口。
管理VLAN接口处于Shutdown状态。
ONU接口视图
ONU冗余接口视图
开启ONU的管理VLAN接口后,必须配置该接口的IP地址。
当执行undo shutdown management-vlan-interface命令后,管理VLAN接口的状态与该VLAN内以太网端口(即UNI端口)状态有关:
·     当ONU的管理VLAN接口对应VLAN下的所有以太网端口状态为down时,则管理VLAN接口为关闭状态;
·     当ONU的管理VLAN接口对应VLAN下有一个或一个以上的以太网端口处于up状态,则管理VLAN接口处于打开状态。
# 开启ONU的管理VLAN接口。
1.2.52  transceiver-txpower
transceiver-txpower命令用来设置ONU的PON口光模块发送电源开关。
transceiver-txpower { on | off | off seconds } pon { all | main | standby } onu { all | onu-number-list }
ONU上所有PON口的光模块发送电源处于开启状态。
OLT端口视图
on:表示开启光模块发送电源。
off:表示关闭光模块发送电源。
off seconds:表示临时关闭光模块发送电源,经过seconds后再开启。seconds为电源临时关闭时间,取值范围为1~65534,单位为秒。
pon { all | main | standby }:设置指定PON口的光模块发送电源开关。all表示主用PON口和备用PON口,main表示主用PON口,standby表示备用PON口。
onu:表示为指定ONU设置PON口的光模块发送电源开关。
all:指定所有ONU。
onu-number-list:指定的ONU接口编号列表。表示方式为onu-number-list = { onu-number1 [ to onu-number2 ] }&<1-10>,onu-number2必须大于或等于onu-number1。onu-number1和onu-number2的取值范围为1~64。&<1-10>表示前面的参数最多可以输入10次。
在EPON系统中某一时刻只能有一台ONU上传数据,如果某个ONU发生故障,出现长发光现象,就会占据其他ONU的上行通信时隙,使其上行数据无法传输。本命令可以关闭指定ONU的Tx电源(PON口的光模块发送电源),从而阻止该ONU发光,以协助定位长发光的ONU设备。
# 配置Olt1/0/1端口下所有ONU的主备PON口的光模块发送电源临时关闭300秒。
[Sysname-Olt1/0/1] transceiver-txpower off 300 pon all onu all
1.2.53  uni auto-negotiation
uni auto-negotiation命令用来开启UNI端口的自协商功能。
undo uni auto-negotiation命令用来关闭UNI端口的自协商功能。
uni uni-number auto-negotiation
undo uni uni-number auto-negotiation
UNI端口的自协商功能处于开启状态。
ONU接口视图
ONU冗余接口视图
uni-number :UNI端口号,取值范围为1~当前ONU的UNI端口数,且支持最大的UNI端口数为79。
本命令与双工状态(uni duplex)、MDIX模式(uni mdix-mode)和速率(uni speed)配置命令互斥,不能同时配置。
# 开启UNI 1的自协商功能。
[Sysname-Onu1/0/1:1] uni 1 auto-negotiation
1.2.54  uni description
uni description命令用来设置UNI端口的描述信息。
undo uni description命令用来恢复缺省情况。
uni uni-number description text
undo uni uni-number description
UNI端口无描述信息。
ONU接口视图
ONU冗余接口视图
text:UNI端口的描述字符串,长度为1~40个字符。
# 将UNI端口1描述为Test。
[Sysname-Onu1/0/1:1] uni 1 description Test
1.2.55  uni duplex
uni duplex命令用来设置UNI端口双工状态。
undo uni duplex命令用来将端口的双工状态恢复为缺省值。
uni uni-number duplex { auto | full | half }
undo uni uni-number duplex
UNI端口处于全双工状态。
ONU接口视图
ONU冗余接口视图
auto:端口处于自协商状态。
full:端口处于全双工状态。
half:端口处于半双工状态。
在配置该命令前,需要配置undo uni uni-number auto-negotiation命令。
# 设置UNI端口1为自协商状态。
[Sysname-Onu1/0/1:1] uni 1 duplex auto
·     uni auto-negotiation
1.2.56  uni flow-control
uni flow-control命令用来开启UNI端口的流量控制功能。
undo uni flow-control命令用来关闭UNI端口的流量控制功能。
uni uni-number flow-control
undo uni uni-number flow-control
UNI端口的流量控制功能处于关闭状态。
ONU接口视图
ONU冗余接口视图
# 开启UNI端口1的流量控制功能。
[Sysname-Onu1/0/1:1] uni 1 flow-control
1.2.57  uni mac-address
uni mac-address static命令用来配置UNI端口的静态MAC地址表项。
undo uni mac-address static命令用来删除UNI端口的静态MAC地址表项。
uni uni-number mac-address static mac-address
undo uni uni-number mac-address static { all | mac-address }
未配置UNI端口的静态MAC地址表项。
ONU接口视图
ONU冗余接口视图
mac-address:表示指定MAC地址的静态MAC地址表项,格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
all:表示所有已配置的静态MAC地址表项。
应用场景
为提高UNI端口安全性,网络管理员可手工添加UNI端口下挂终端的静态MAC地址表项,将终端与UNI端口绑定,防止非法终端通过UNI口接入网络。
工作机制
配置本命令后,只有静态MAC地址表项对应的终端可以通过UNI口接入网络,其他终端的报文将被该UNI口丢弃。
注意事项
同一UNI端口最多支持配置8个静态MAC地址表项。
# 配置UNI端口的静态MAC地址表项。
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1] uni 1 mac-address static 1-1-1
1.2.58  uni mac-address max-mac-count
uni mac-address max-mac-count命令用来配置UNI端口的MAC地址数学习上限。
undo uni mac-address max-mac-count命令用来恢复缺省情况。
uni uni-number mac-address max-mac-count count
undo uni uni-number mac-address max-mac-count
UNI端口最多可以学习到的MAC地址数目不作限制。
ONU接口视图
ONU冗余接口视图
count:UNI端口的MAC地址数学习上限,取值范围为0~65534。
# 配置UNI端口1的MAC地址数学习上限为5。
[Sysname-Onu1/0/1:1] uni 1 mac-address max-mac-count 5
1.2.59  uni mdix-mode
ET254类型的ONU不支持本命令。
uni mdix-mode命令用来设置UNI端口的MDIX(Media-dependent Interface-crossover)模式。
undo uni mdix-mode命令用来恢复缺省情况。
uni uni-number mdix-mode { automdix | mdi | mdix }
undo uni uni-number mdix-mode
UNI端口的MDIX模式为automdix。
ONU接口视图
ONU冗余接口视图
automdix:两端设备通过协商来决定引脚1和2是发送还是接收信号,引脚3和6是接收还是发送信号。
mdi:使用引脚1和2发送信号,使用引脚3和6接收信号。
mdix:使用引脚1和2接收信号,使用引脚3和6发送信号。
# 设置UNI端口1的MDIX模式为automdix。
[Sysname-Onu1/0/1:1] uni 1 mdix-mode automdix
1.2.60  uni mirroring-port
uni mirroring-port命令用来配置UNI端口为镜像源端口。
undo uni mirroring-port命令用来取消配置UNI端口为镜像源端口。
uni uni-number mirroring-port { both | inbound | outbound }
undo uni uni-number mirroring-port
UNI端口不是镜像源端口。
ONU接口视图
ONU冗余接口视图
both:设置对端口收发的报文进行镜像。
inbound:设置对端口收到的报文进行镜像。
outbound:设置对端口发出的报文进行镜像。
同一个UNI端口不支持同时配置为镜像源端口和镜像目的端口。
# 设置对UNI端口1收发的报文进行镜像。
[Sysname-Onu1/0/1:1] uni 1 mirroring-port both
·     uni monitor-port
1.2.61  uni monitor-port
uni monitor-port命令用来配置UNI端口为镜像目的端口。
undo uni monitor-port命令用来恢复缺省情况。
uni uni-number monitor-port
undo uni uni-number monitor-port
UNI端口不是镜像目的端口。
ONU接口视图
ONU冗余接口视图
同一个ONU下只能有一个镜像组目的端口。如果修改镜像组目的端口,则会先删除之前配置,然后添加新配置。
# 设置UNI端口1为镜像组目的端口。
[Sysname-Onu1/0/1:1] uni 1 monitor-port
·     uni mirroring-port
1.2.62  uni port-isolate
uni port-isolate命令用来将UNI端口加入隔离组。
undo uni port-isolate命令用来将UNI端口从隔离组中删除。
uni uni-number port-isolate
undo uni uni-number port-isolate
ONU下的UNI端口未加入隔离组。
ONU接口视图
ONU冗余接口视图
一台ONU只支持一个隔离组。隔离组内端口数不受限制。
本命令和onu port-isolate enable命令互斥,不能同时配置。
# 将ONU下的UNI端口1和UNI端口2加入隔离组。
[Sysname-Onu1/0/1:1] uni 1 port-isolate
[Sysname-Onu1/0/1:1] uni 2 port-isolate
·     onu port-isolate enable
1.2.63  uni qinq
uni qinq命令用来配置UNI端口QinQ信息,包括对指定内层VLAN Tag 的报文封装外层VLAN Tag或者透传。
undo uni qinq命令用来取消UNI端口QinQ配置。
uni uni-number qinq svlan svlan-id cvlan { cvlan-id-list | all }
undo uni uni-number qinq svlan svlan-id
uni uni-number qinq transparent-vlan { cvlan-id-list | all }
undo uni uni-number qinq transparent-vlan { cvlan-id-list | all }
未配置UNI端口QinQ信息。
ONU接口视图
ONU冗余接口视图
svlan svlan-id:外层VLAN的VLAN ID,取值范围为1~4094。
cvlan-id-list:指定的内层VLAN ID列表。表示方式为vlan-id-list = { vlan-id [ to vlan-id ] }&<1-10>,关键字to 之后的编号要大于或等于to 之前的编号。vlan-id的取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
all:指定所有内层VLAN ID。
只有VLAN操作模式为QinQ时(相关配置命令为uni vlan-mode),才能配置UNI端口QinQ信息。
VLAN透传功能可使端口在收到带有指定VLAN Tag的报文后,不为其添加外层VLAN Tag而直接在运营商网络中传输。例如,当某VLAN为企业专线VLAN或网管VLAN时,就可以使用VLAN透传功能。
# 配置UNI端口1为收到的内层VLAN Tag为VLAN 3~4的报文添加外层Tag为VLAN 20。
[Sysname-Onu1/0/1:1] uni 1 qinq svlan 20 cvlan 3 to 4
·     uni vlan-mode
1.2.64  uni restart auto-negotiation
uni restart auto-negotiation命令用来强制UNI重新自协商。
uni uni-number restart auto-negotiation
ONU接口视图
ONU冗余接口视图
uni-number :UNI 端口号,取值范围1~当前ONU的UNI端口数,且支持最大的UNI端口数为79。
只有当自协商功能(相关配置命令为uni auto-negotiation)打开时,该命令才能执行。
# 在ONU1/0/1:1下强制UNI 1重新自协商功能。
[Sysname-Onu1/0/1:1] uni 1 restart auto-negotiation
1.2.65  uni shutdown
uni shutdown命令用来关闭UNI端口。
undo uni shutdown命令用来打开UNI端口。
uni uni-number shutdown
undo uni uni-number shutdown
UNI端口处于开启状态。
ONU接口视图
ONU冗余接口视图
# 关闭UNI端口1。
[Sysname-Onu1/0/1:1] uni 1 shutdown
1.2.66  uni speed
uni speed命令用来设置UNI端口速率。
undo uni speed命令用来恢复端口的速率为缺省值。
uni uni-number speed { 10 | 100 | 1000 | auto }
undo uni uni-number speed
UNI端口速率为100Mbps。
ONU接口视图
ONU冗余接口视图
10:端口速率为10Mbps。
100:端口速率为100Mbps。
1000:端口速率为100Mbps。
auto:端口速率处于双方自协商状态。
# 设置UNI端口1速率为10Mbps。
[Sysname-Onu1/0/1:1] uni 1 speed 10
1.2.67  uni statistics enable
uni statistics enable命令用来开启ONU上指定UNI端口的统计功能。
undo uni statistics enable命令用来关闭ONU上指定UNI端口的统计功能。
uni uni-number statistics enable [ period period-value ]
undo uni uni-number statistics enable
UNI端口的统计功能处于开启状态。
ONU接口视图
ONU冗余接口视图
# 开启UNI端口1的统计功能,并设置采样周期为1000秒。
[Sysname-Onu1/0/1:1] uni 1 statistics enable period 1000
1.2.68  uni virtual-cable-test
uni virtual-cable-test命令用来对ONU设备上指定的UNI端口所连接的电缆进行一次连通性测试,并显示检测结果。
uni uni-number virtual-cable-test
ONU接口视图
ONU冗余接口视图
# 对OLT上Onu1/0/1:1接口所对应ONU设备的UNI端口1连接的电缆进行一次连通性测试,并显示检测结果。其中“-”表示测试项不支持。
[Sysname-Onu1/0/1:1] uni 1 virtual-cable-test
Cable status: abnormal(open), 0 metre(s)
Pair Impedance mismatch: -
Pair skew: - ns
Pair swap: -
Pair polarity: -
Insertion loss: - db
Return loss: - db
Near-end crosstalk: 4294967040 db
表1-30 uni virtual-cable-test命令显示信息描述表
Cable status
电缆状态,包括:
·     normal:正常
·     abnormal:异常
·     abnormal(open):异常开路
·     abnormal(short):异常短路
·     failure:检测失败
n metre(s)
当电缆状态为正常时,显示的是电缆的总长度
当电缆状态非正常时,显示的是本接口到异常位置的长度
线对阻抗是否匹配,取值为:
·     yes:阻抗匹配
·     no:阻抗不匹配
Pair skew
线对不对称
Pair swap
线对交换
Pair polarity
是否极性交换
Insertion loss
插入信号衰减
Return loss
返回信号衰减
Near-end crosstalk
近端串扰
1.2.69  uni vlan-mode (interface view)
uni vlan-mode命令用来配置UNI端口的VLAN操作模式为VLAN透传模式、VLAN标记模式、VLAN Translation模式、VLAN QinQ模式、VLAN Trunk模式或VLAN N:1聚合模式。
undo uni vlan-mode命令用来恢复缺省情况。
undo uni uni-number vlan-mode
VLAN透传模式:
uni uni-number vlan-mode transparent
VLAN标记模式:
uni uni-number vlan-mode tag pvid pvid [ priority priority ]
VLAN Translation模式:
uni uni-number vlan-mode translation pvid pvid [ priority priority ] { original-vlan-id to translated-vlan-id } &<1-15>
VLAN QinQ模式:
uni uni-number vlan-mode qinq pvid pvid [ priority priority ]
VLAN Trunk模式:
uni uni-number vlan-mode trunk pvid pvid [ priority priority ] trunk-vlan-list
VLAN N:1聚合模式:
uni uni-number vlan-mode aggregation pvid pvid [ priority priority ] { vlan-id1 to vlan-id2 aggregated-vlan aggregated-vlan }&<1-15>
UNI端口的VLAN操作模式为VLAN透传模式。
ONU接口视图
ONU冗余接口视图
pvid pvid:端口缺省VLAN ID,取值范围为1~4094。在VLAN标记模式/Translation模式/Trunk模式/N:1聚合模式下,仅当端口接收到不带VLAN Tag的报文时,才会为该报文添加本端口PVID的Tag;在VLAN QinQ模式下,不论从该端口收到的报文是否带有VLAN Tag,设备都会为该报文添加本端口PVID的Tag。
priority priority:报文的802.1p优先级,有效取值范围为0~7。在VLAN标记模式/Translation模式/Trunk模式/N:1聚合模式下,仅当端口接收到不带VLAN Tag的报文时,对添加的本端口PVID Tag的802.1p优先级进行设置;在VLAN QinQ模式下,对添加的外层VLAN Tag的802.1p优先级进行设置。
{ original-vlan-id to translated-vlan-id } &<1-15>:original-vlan-id表示原始VLAN ID,translated-vlan-id表示转换后的VLAN ID,取值范围均为1~4094。&<1-15>表示前面的参数最多可以重复输入15次。
trunk-vlan-list:表示端口允许通过的VLAN范围。具体表示方式为trunk-vlan-list = { vlan-id1 to vlan-id2 }&<1-8>,vlan-id1表示起始VLAN ID,vlan-id2表示结束VLAN ID,取值范围均为1~4094,vlan-id2的值要大于等于vlan-id1的值;&<1-8>表示前面的参数最多可以重复输入8次。不同VLAN范围之间不允许有交集。
{ vlan-id1 to vlan-id2 aggregated-vlan aggregated-vlan }&<1-15>:表示将指定范围的VLAN ID转换成指定的VLAN ID。vlan-id1 to vlan-id2表示原始VLAN范围,vlan-id2的值要大于等于vlan-id1的值;aggregated-vlan为转换后的VLAN ID;&<1-15>表示前面的参数最多可以重复输入15次。参数涉及的VLAN ID取值范围都为1~4094。不同VLAN范围之间不允许有交集。
当OLT下的所有ONU接口/ONU冗余接口的链路类型为Access时,UNI端口操作模式只能为透明传输模式,这样才能保证ONU接口/ONU冗余接口和用户PC接收的是不带Tag的报文。
配置VLAN Trunk模式时,UNI端口允许通过的VLAN总数必须在16个以内,否则该uni vlan-mode命令不能下发给ONU设备。
uni vlan-mode命令配置的VLAN仅对单播报文生效,建议该命令配置的VLAN ID范围和uni multicast vlan命令配置的组播VLAN ID范围不要有交叉。
如果开启了UNI的未知组播报文透传功能且指定的MAC地址为0100-ffff-ffff,那么uni vlan-mode命令配置的VLAN对所有未知组播报文也生效。
# 配置UNI端口1的VLAN操作模式为VLAN 透传模式。
[Sysname-Onu1/0/1:1] uni 1 vlan-mode transparent
# 配置UNI端口1的VLAN操作模式为VLAN 标记模式,给进入本端口的不带Tag报文打上VLAN 100的Tag,并设置报文802.1p优先级为3。
[Sysname-Onu1/0/1:1] uni 1 vlan-mode tag pvid 100 priority 3
# 配置UNI端口1的VLAN操作模式为VLAN Translation模式,缺省VLAN ID为100,对于进入本端口不带VLAN tag的报文,为报文添加端口缺省VLAN的Tag,并设置报文的802.1p优先级为3,对于进入本端口VLAN ID为2的报文,将其VLAN ID替换成5。
[Sysname-Onu1/0/1:1] uni 1 vlan-mode translation pvid 100 priority 3 2 to 5
# 配置UNI端口1的VLAN操作模式为VLAN QinQ模式,缺省VLAN ID为100,并设置报文802.1p优先级为3。
[Sysname-Onu1/0/1:1] uni 1 vlan-mode qinq pvid 100 priority 3
# 配置UNI端口1的VLAN操作模式为VLAN Trunk模式,PVID为1,报文的802.1p优先级为3,同时允许VLAN 2~VLAN 5的报文通过。
[Sysname-Onu1/0/1:1] uni 1 vlan-mode trunk pvid 1 priority 3 2 to 5
# 配置UNI端口1的VLAN操作模式为N:1聚合模式,PVID为1,报文的802.1p优先级为3,对于进入本端口的VLAN 2~VLAN 5的报文,将其VLAN ID替换成100。
[Sysname-Onu1/0/1:1] uni 1 vlan-mode aggregation pvid 1 priority 3 2 to 5 aggregate 100
·     onu protocol transparent-multicast(EPON命令参考/EPON组播)
·     uni multicast vlan(EPON命令参考/EPON组播)
·     uni transparent-multicast(EPON命令参考/EPON组播)
1.2.70  uni vlan-mode (ONU template view)
uni vlan-mode命令用来配置UNI端口的VLAN操作模式为VLAN透传模式或VLAN标记模式。
undo uni vlan-mode命令用来将uni vlan-mode命令从ONU配置模板中删除。
VLAN透传模式:
VLAN标记模式:
uni start-uni-number vlan-mode tag start-pvid start-pvid [ priority priority ]
ONU配置模板中不存在uni vlan-mode命令。
ONU配置模板视图
start-pvid start-pvid:起始的端口缺省VLAN ID,取值范围为1~4094。
关于VLAN操作模式的介绍,请参见“EPON配置指导”中的“远程配置ONU/配置UNI端口的VLAN操作模式”。
在ONU配置模板中配置UNI端口的VLAN标记模式时,如果指定start-pvid参数,则表示以PVID递增的方式批量配置ONU接口,具体机制为:
·     对应用该ONU配置模板的每个OLT端口,按ONU接口编号从小到大的顺序,为所有ONU在线的ONU接口配置UNI端口的VLAN标记模式;起始ONU接口对应的PVID为start-pvid,下一ONU接口对应的PVID为start-pvid + 1,以此类推。
·     PVID参数值如果达到取值上限,则不再增长。
对同一UNI端口号多次执行本命令,最后一次执行的命令生效。
关于本命令的其他使用指导和参数的详细解释,请参见uni vlan-mode (interface view)命令。
# 在ONU配置模板中以PVID递增的方式批量配置所有ONU在线的ONU接口的UNI端口1,并将该模板应用到端口Olt1/0/1。其中,起始的PVID为4092,报文802.1p优先级为3。
[Sysname-onu-template-1] uni 1 vlan-mode tag start-pvid 4092 priority 3
[Sysname-onu-template-1] quit
[Sysname-Olt1/0/1] apply onu template 1
分别进入ONU在线的多个ONU接口视图下使用display this命令显示其配置,可以看到ONU配置模板下发的命令:
interface Onu1/0/1:1
 uni 1 vlan-mode tag pvid 4092 priority 3
interface Onu1/0/1:3
 uni 1 vlan-mode tag pvid 4093 priority 3
interface Onu1/0/1:4
 uni 1 vlan-mode tag pvid 4094 priority 3
interface Onu1/0/1:5
·     uni vlan-mode (interface view)
1.2.71  update onu filename
update onu filename命令用来升级单台ONU或升级OLT端口下的所有ONU。
undo update onu命令用来取消升级配置。
update onu [ protocol-type { h3c | ctc } ] filename filename [ start-time start-time duration minutes ]
undo update onu
OLT端口视图
ONU接口视图
ONU冗余接口视图
protocol-type { h3c | ctc }:选择升级协议类型。其中h3c为H3C私有升级协议,ctc为CTC升级协议。不指定本参数时,使用H3C私有升级协议进行升级。
filename:升级文件名,由设备名与ONU升级文件的文件名组成,为1~63个字符的字符串,只能包含字母、数字、特殊字符(包括~ ! @ # $ % ^ &  ( ) - _ + = { } [ ] \ ; ' , .)。如果不指定设备名,则默认为主控板的Flash,且不能使用备用主控板中的文件进行升级。
start-time start-time:预定升级开始时间。start-time的格式为hh:mm,取值范围为00:00~23:59。如果未指定本参数,则立即下发升级命令到ONU。ONU版本升级建议在终端用户使用空闲时间内进行,例如凌晨。
duration minutes:单次升级持续时间,取值范围为1~1439,单位为分钟。如果ONU在升级持续时间内未完成升级,则暂停升级,等待下一次升级开始时间,再继续升级。单次升级持续时间建议配置为30分钟~360分钟之间。
在OLT端口视图下执行此命令,可以升级该OLT端口下所有已创建ONU接口对应的ONU;在ONU接口/ONU冗余接口视图下执行此命令,则仅升级该接口所对应的ONU。
配置protocol-type参数时,H3C的ONU设备建议选择H3C私有升级协议,其他厂商的ONU设备建议选择CTC升级协议。10G-EPON单板切换到128-ONU模式后,该单板连接的ONU不支持使用H3C私有升级协议升级。
配置升级OLT端口下的所有ONU后,如果新上线的ONU所对应的端口在升级命令配置之前已创建,则直接升级(当然,和升级文件不匹配的ONU是不能升级成功的)。反之,如果对应ONU接口在升级命令配置之后创建,则不升级。
配置本命令后,升级命令会下发到对应的ONU。
·     如果对应的ONU在线且和升级文件匹配,则直接进行升级;
·     如果对应的ONU在线但和升级文件不匹配,则不能成功升级;
·     当ONU不在线时,若使用H3C私有升级协议则待其上线后再对其进行升级操作;若使用CTC升级协议则不升级,必须用undo命令取消升级配置,待其上线后再次配置本命令才能升级。
# 升级Onu1/0/1:1接口下的单台ONU。
[Sysname-Onu1/0/1:1] update onu filename file.app
Update flash:/file.app?[Y/N] Y
1.2.72  update onu type
update onu type命令用来配置按类型升级所有ONU。
undo update onu type命令用来取消升级配置。
update onu type onu-type [ protocol-type { h3c | ctc } ] filename filename [ start-time start-time duration minutes ]
undo update onu type onu-type
FTTH视图
onu-type:ONU类型,如ET704-A和ET704-A-L等,为1~16个字符的字符串,不区分大小写。只能包含字母、数字、特殊字符(包括~ ! @ # $ % ^ &  ( ) - _ + = { } [ ] \ ; ' , .)。
配置升级交换机下指定类型的ONU后,如果新创建的ONU接口/ONU冗余接口对应的ONU符合指定类型且上线后,交换机会自动对其进行升级。
按类型升级所有ONU时,如果设备上存在OLT冗余接口,需要注意:
·     为避免ONU升级失败,升级期间请不要在OLT冗余接口中添加或删除成员端口。
·     升级期间,如果OLT冗余接口的成员端口发生倒换(例如激活端口进入down状态),可能会导致ONU升级失败。
最多可同时对64种类型的ONU进行升级,即可以通过update onu type命令为64种不同类型的ONU指定升级文件。
本命令仅对ONU接口/ONU冗余接口下未配置升级命令且匹配本命令所指定类型的ONU有效。
·     如果ONU在线且和升级文件匹配,则直接进行升级;
·     如果ONU在线但和升级文件不匹配,则不能成功升级;
# 升级交换机下挂的类型为ET704-A-L的所有ONU。
[Sysname] ftth
[Sysname-ftth] update onu type et704-a-l filename file.app
命令配置完成后,OLT即开始对ONU接口/ONU冗余接口下未配置升级命令且类型为ET704-A-L的所有ONU进行升级。
1.2.73  using onu
using onu命令用来创建ONU接口或ONU冗余接口。
undo using onu命令用来删除ONU接口或ONU冗余接口。
using onu onu-number-list
undo using onu onu-number-list
未创建ONU接口或ONU冗余接口。
OLT端口视图
OLT冗余接口视图
onu-number-list:指定的ONU接口编号列表。表示方式为onu-number-list = { onu-number1 [ to onu-number2 ] }&<1-10>,onu-number2必须大于或等于onu-number1。onu-number1、onu-number2的取值范围为1~64。&<1-10>表示前面的参数最多可以输入10次。
OLT端口下使用本命令创建的是ONU接口,接口名称为onu interface-number。
OLT冗余接口下使用本命令创建的是ONU冗余接口,接口名称为ronu interface-number。
# 在Olt1/0/2端口上创建ONU接口1。
[Sysname] interface Olt 1/0/2
[Sysname-Olt1/0/2] using onu 1
