05-DHCP命令
本章节下载: 05-DHCP命令 (1.35 MB)
1.1.2 dhcp conflict-ip-address offline
1.1.5 dhcp flood-protection aging-time
1.1.6 dhcp flood-protection enable
1.1.7 dhcp flood-protection global enable
1.1.8 dhcp flood-protection threshold
1.1.9 dhcp interface-rate-suppression aging-time
1.1.10 dhcp interface-rate-suppression enable
1.1.11 dhcp interface-rate-suppression global enable
1.1.12 dhcp interface-rate-suppression threshold
1.1.16 dhcp session-mismatch action
1.1.18 display dhcp flood-protection
1.1.19 display dhcp interface-rate-suppression
1.1.20 display dhcp rate-limit
1.1.22 reset dhcp flood-protection
1.1.23 reset dhcp interface-rate-suppression
1.2.14 dhcp server allocated-ip threshold
1.2.15 dhcp server always-broadcast
1.2.16 dhcp server apply ip-pool
1.2.17 dhcp server bootp ignore
1.2.18 dhcp server bootp reply-rfc-1048
1.2.19 dhcp server check mac-address
1.2.20 dhcp server database filename
1.2.21 dhcp server database update interval
1.2.22 dhcp server database update now
1.2.23 dhcp server database update stop
1.2.24 dhcp server forbidden-ip
1.2.25 dhcp server multi-ip per-mac enable
1.2.26 dhcp server ping packets
1.2.27 dhcp server ping timeout
1.2.28 dhcp server policy-first enable
1.2.29 dhcp server relay information enable
1.2.30 dhcp server reply-exclude-option60
1.2.31 dhcp server request-ip-address check
1.2.32 display dhcp pool-group-usage
1.2.33 display dhcp pool-usage
1.2.34 display dhcp server conflict
1.2.35 display dhcp server database
1.2.36 display dhcp server expired
1.2.37 display dhcp server free-ip
1.2.38 display dhcp server ip-in-use
1.2.39 display dhcp server packet statistics
1.2.40 display dhcp server statistics
1.2.41 display dhcp-access count
1.2.42 display dhcp-access packet statistics
1.2.43 display dhcp-access user-table
1.2.59 ip-pool algorithm round-robin
1.2.69 reserve expired-ip enable
1.2.70 reserve expired-ip mode
1.2.71 reset dhcp pool-usage peak
1.2.72 reset dhcp server conflict
1.2.73 reset dhcp server expired
1.2.74 reset dhcp server ip-in-use
1.2.75 reset dhcp server packet statistics
1.2.76 reset dhcp-access packet statistics
1.2.78 snmp-agent trap enable dhcp server
1.2.80 tftp-server domain-name
1.2.87 vpn-instance (dhcp pool view)
1.2.88 vpn-instance (ip pool-group view)
1.3.1 dhcp relay always-unicast
1.3.2 dhcp relay check mac-address
1.3.3 dhcp relay client-information record
1.3.4 dhcp relay client-information refresh
1.3.5 dhcp relay client-information refresh enable
1.3.6 dhcp relay dhcp-server timeout
1.3.7 dhcp relay forward reply by-option82
1.3.9 dhcp relay information circuit-id
1.3.10 dhcp relay information enable
1.3.11 dhcp relay information remote-id
1.3.12 dhcp relay information strategy
1.3.13 dhcp relay master-server switch-delay
1.3.14 dhcp relay non-first-hop enable
1.3.16 dhcp relay release-agent
1.3.17 dhcp relay server-address
1.3.18 dhcp relay server-address algorithm
1.3.19 dhcp relay source-address
1.3.21 dhcp smart-relay enable
1.3.24 dhcp-server source-address
1.3.27 display dhcp relay client-information
1.3.28 display dhcp relay information
1.3.29 display dhcp relay packet statistics
1.3.30 display dhcp relay remote-server-info
1.3.31 display dhcp relay server-address
1.3.33 master-server switch-delay
1.3.34 remote-server algorithm
1.3.35 reset dhcp relay client-information
1.3.36 reset dhcp relay packet statistics
1.5.1 dhcp snooping binding database filename
1.5.2 dhcp snooping binding database update interval
1.5.3 dhcp snooping binding database update now
1.5.4 dhcp snooping binding record
1.5.5 dhcp snooping check mac-address
1.5.6 dhcp snooping check request-message
1.5.9 dhcp snooping information circuit-id
1.5.10 dhcp snooping information enable
1.5.11 dhcp snooping information remote-id
1.5.12 dhcp snooping information strategy
1.5.13 dhcp snooping log enable
1.5.14 dhcp snooping max-learning-num
1.5.16 display dhcp snooping binding
1.5.17 display dhcp snooping binding database
1.5.18 display dhcp snooping information
1.5.19 display dhcp snooping packet statistics
1.5.20 display dhcp snooping trust
1.5.21 reset dhcp snooping binding
1.5.22 reset dhcp snooping packet statistics
dhcp client-detect命令用来开启DHCP服务器或DHCP中继的用户下线探测功能。
undo dhcp client-detect命令用来关闭DHCP服务器或DHCP中继的用户下线探测功能。
dhcp client-detect
DHCP服务器或DHCP中继的用户下线探测功能处于关闭状态。
DHCP服务器开启该功能后,当设备上的ARP表项老化时,DHCP服务器认为该表项对应的DHCP客户端已经下线,DHCP服务器会删除对应的IP地址租约。
DHCP中继开启该功能后,当设备上的ARP表项老化时,DHCP中继认为该表项对应的DHCP客户端已经下线,DHCP中继会删除对应的用户地址表项,并通过发Release报文通知DHCP服务器删除下线用户的IP地址租约。
本功能不支持在BRAS场景下应用。
# 开启用户下线探测功能。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] dhcp client-detect
dhcp conflict-ip-address offline命令用来配置当为新DHCP客户端分配的地址和已在线DHCP客户端的IP地址发生冲突时,释放已在线DHCP客户端的IP地址。
undo dhcp conflict-ip-address offline命令用来恢复缺省情况。
当为新DHCP客户端分配的地址和已在线DHCP客户端的IP地址发生冲突时,已在线DHCP客户端不受影响。
当DHCP服务器为DHCP客户端分配的IP地址和中继记录的用户地址表项冲突,或者接入设备(DHCP服务器或DHCP中继)上配置的认证授权模块分配的地址和已在线DHCP客户端的地址发生冲突时,已在线的客户端不受影响,新客户端或认证授权用户上线失败。配置本功能后,DHCP设备会有以下处理方式:
· 在DHCP服务器上配置本功能,当DHCP服务器上配置的认证授权模块分配的地址和已在线DHCP客户端的地址发生冲突时,DHCP服务器会释放已在线DHCP客户端的IP地址,并通知接入模块此地址冲突不可用。
· 在DHCP中继上配置本功能,处理方式如下:
¡ 如果是认证授权模块分配的地址和DHCP中继记录的用户地址表项冲突,则中继向DHCP服务器发送DHCP-RELEASE报文释放冲突地址,并通知接入模块此地址冲突不可用;
¡ 如果DHCP服务器发送的应答报文中记录的地址和DHCP中继记录的用户表项冲突,则中继向DHCP服务器发送DHCP-RELEASE报文释放冲突地址,丢弃该应答报文,新DHCP客户端无法获取到IP地址。
当新客户端或认证授权用户再次发起地址申请时,可以正常申请到该地址,不会再发生地址冲突问题。
只有开启了DHCP中继用户地址表项记录功能后,DHCP中继上配置本功能才能生效。
# 配置当DHCP服务器或授权地址池为新用户分配的地址和已在线DHCP客户端的IP地址发生冲突时,释放已在线DHCP客户端的IP地址。
[Sysname] dhcp conflict-ip-address offline
· dhcp relay client-information record
dhcp dscp命令用来配置DHCP服务器或DHCP中继发送DHCP报文的DSCP优先级。
undo dhcp dscp命令用来恢复缺省情况。
dhcp dscp dscp-value
undo dhcp dscp
DHCP服务器或DHCP中继发送DHCP报文的DSCP优先级为56。
dscp-value:DHCP报文的DSCP优先级,取值范围为0~63。
# 配置DHCP服务器或DHCP中继发送的DHCP报文的DSCP优先级为30。
[Sysname] dhcp dscp 30
dhcp enable命令用来开启DHCP服务。
undo dhcp enable命令用来关闭DHCP服务。
dhcp enable
undo dhcp enable
DHCP服务处于关闭状态。
只有开启DHCP服务后,其它相关的DHCP配置才能生效。
配置DHCP服务器和DHCP中继时,都需要先开启DHCP服务。
# 开启DHCP服务。
[Sysname] dhcp enable
dhcp flood-protection aging-time命令用来配置DHCP Flood攻击表项老化时间。
undo dhcp flood-protection aging-time命令用来恢复缺省情况。
dhcp flood-protection aging-time time
DHCP Flood攻击表项老化时间为300秒。
time:DHCP Flood攻击表项老化时间,取值范围为30~600,单位为秒。
当某个MAC地址对应的DHCP Flood攻击表项老化时间到达后,设备会检查接口表项报文抑制速率,如果速率小于DHCP Flood攻击报文速率阈值,设备会删除此表项,设备再次收到源MAC地址为此MAC地址的DHCP请求报文时,会重新统计接收到的报文数目;如果速率大于等于DHCP Flood攻击报文速率阈值,设备不会删除此表项,老化时间重新刷新。
只有配置dhcp flood-protection enable命令开启了DHCP Flood攻击防范功能,本功能才生效。
多次执行本命令,最后一次执行的命令生效。
# 配置DHCP Flood攻击表项老化时间为90秒。
[Sysname] dhcp flood-protection aging-time 90
· dhcp flood-protection enable
· dhcp flood-protection threshold
· display dhcp flood-protection
dhcp flood-protection enable命令用来在接口上开启DHCP Flood攻击防范功能。
undo dhcp flood-protection enable命令用来关闭接口上的DHCP Flood攻击防范功能。
接口的DHCP Flood攻击防范功能状态与全局DHCP Flood攻击防范功能的状态保持一致。
配置DHCP Flood攻击防范功能后,设备会根据DHCP报文中的源MAC地址统计收到的DHCP报文数,并创建一个check状态的DHCP防Flood攻击表项。当收到某个MAC地址对应DHCP客户端发送的报文数在指定的时间内达到配置的最大报文数时,设备认为受到了该DHCP客户端的攻击,DHCP防Flood攻击表项状态从check状态变成restrain状态,且设备丢弃该DHCP客户端发送的DHCP报文。
# 在接口Ten-GigabitEthernet3/0/1上开启DHCP Flood攻击防范功能。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp flood-protection enable
· dhcp flood-protection aging-time
dhcp flood-protection global enable命令用来全局开启DHCP Flood攻击防范功能。
undo dhcp flood-protection global enable命令用来全局关闭DHCP Flood攻击防范功能。
全局DHCP Flood攻击防范功能处于关闭状态。
全局开启DHCP Flood攻击防范功能后,设备上所有接口都会开启DHCP Flood攻击防范功能。
全局开启DHCP Flood攻击防范功能后,设备会根据每个DHCP报文中的源MAC地址分别统计接口收到的DHCP报文数,并为每个MAC地址创建一个check状态的DHCP防Flood攻击表项。当接口收到某个MAC地址对应DHCP客户端发送的报文数在指定的时间内达到配置的最大报文数时,设备认为自身受到了该DHCP客户端的攻击,将该DHCP客户端的DHCP防Flood攻击表项状态从check状态变成restrain状态,且丢弃该DHCP客户端发送的DHCP报文。
用户可以使用dhcp flood-protection global enable命令或dhcp flood-protection enable命令开启DHCP Flood攻击防范功能。两者的配置关系如下:
· 只要全局或接口任一视图下开启了DHCP Flood攻击防范功能,则该接口的DHCP Flood攻击防范功能就处于开启状态。
· 如果只想在某个接口上开启DHCP Flood攻击防范功能,需要在全局DHCP Flood攻击防范功能处于关闭状态的情况下,在该接口下配置dhcp flood-protection enable命令。
# 全局开启DHCP Flood攻击防范功能。
[Sysname] dhcp flood protection global enable
dhcp flood-protection threshold命令用来配置DHCP Flood攻击报文速率阈值。
undo dhcp flood-protection threshold命令用来恢复缺省情况。
dhcp flood-protection threshold packet-number milliseconds
DHCP Flood攻击检测的最大报文数为10,检测时间为5000毫秒。
packet-number:DHCP Flood攻击检测最大报文数,取值范围为2~200,单位为个。
milliseconds:DHCP Flood攻击检测时间,取值范围为1000~30000,单位为毫秒。
用户配置本命令来检测设备是否受到DHCP Flood攻击。当收到某个MAC地址对应DHCP客户端发送的报文数在配置的指定的时间内超过配置的最大报文数时,设备认为收到了该DHCP客户端的攻击。
# 配置DHCP Flood攻击检测最大报文数为2,检测时间为9000毫秒。
[Sysname] dhcp flood-protection threshold 2 9000
dhcp interface-rate-suppression aging-time命令用来配置DHCP接口攻击抑制表项的老化时间。
undo dhcp interface-rate-suppression aging-time命令用来恢复缺省情况。
dhcp interface-rate-suppression aging-time time
DHCP接口攻击抑制表项的老化时间为300秒。
time:DHCP接口攻击抑制表项的老化时间,取值范围为30~600,单位为秒。
当某个接口对应的DHCP接口攻击抑制表项老化时间到达后,接口会查询当前接口收到报文的速率,如果速率达不到攻击标准,设备会删除此表项,接口再次收到DHCP报文时,会重新统计接收到的报文数目;如果速率超过攻击标准,则DHCP接口攻击抑制表项老化时间重新刷新。
只有配置dhcp interface-rate-suppression enable命令开启了DHCP接口攻击抑制功能,本功能才生效。
# 配置DHCP接口攻击抑制表项的老化时间为90秒。
[Sysname] dhcp interface-rate-suppression aging-time 90
· dhcp interface-rate-suppression enable
· dhcp interface-rate-suppression threshold
· display dhcp interface-rate-suppression
dhcp interface-rate-suppression enable命令用来开启DHCP接口攻击抑制功能。
undo dhcp interface-rate-suppression enable命令用来关闭DHCP接口攻击抑制功能。
接口的DHCP接口攻击抑制功能状态与全局DHCP接口攻击抑制功能的状态保持一致。
某接口开启DHCP接口攻击抑制功能后,该接口收到DHCP报文后,会统计收到的DHCP报文数,同时创建一个check状态的DHCP接口攻击抑制表项。当接口收到的DHCP报文数在指定的时间内达到配置的最大报文数时,则认为该接口受到了DHCP报文攻击,DHCP接口攻击抑制表项状态从check状态变成restrain状态,在DHCP接口攻击抑制表项的老化时间到期之前设备会限制被攻击的接口每秒钟接收DHCP报文的速率,防止DHCP攻击报文持续冲击CPU。
# 在接口Ten-GigabitEthernet3/0/1上开启DHCP接口攻击抑制功能。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp interface-rate-suppression enable
· dhcp interface-rate-suppression aging-time
dhcp interface-rate-suppression global enable命令用来全局开启DHCP接口攻击抑制功能。
undo dhcp interface-rate-suppression global enable命令用来全局关闭DHCP接口攻击抑制功能。
全局DHCP接口攻击抑制功能处于关闭状态。
全局开启DHCP接口攻击抑制功能后,设备上所有接口都会开启DHCP接口攻击抑制功能。
全局开启DHCP接口攻击抑制功能后,每个接口会各自统计本接口收到的DHCP报文数,同时创建一个check状态的DHCP接口攻击抑制表项。当接口收到的DHCP报文数在指定的时间内达到配置的最大报文数时,则认为该接口受到了DHCP报文攻击,DHCP接口攻击抑制表项状态从check状态变成restrain状态,在DHCP接口攻击抑制表项的老化时间到期之前设备会限制被攻击的接口每秒钟接收DHCP报文的速率,防止DHCP攻击报文持续冲击CPU。
用户可以使用dhcp interface-rate-suppression global enable命令或dhcp interface-rate-suppression enable命令开启DHCP接口攻击抑制功能。两者的配置关系如下:
· 只要全局或接口任一视图下开启了DHCP接口攻击抑制功能,则该接口的DHCP接口攻击抑制功能就处于开启状态。
· 如果只想在某个接口上开启DHCP接口攻击抑制功能,需要在全局DHCP 接口攻击抑制功能处于关闭状态的情况下,在该接口下配置dhcp interface-rate-suppression enable命令。
# 全局开启DHCP接口攻击抑制功能。
[Sysname] dhcp interface-rate-suppression global enable
dhcp interface-rate-suppression threshold命令用来配置DHCP接口攻击抑制阈值。
undo dhcp interface-rate-suppression threshold命令用来恢复缺省情况。
dhcp interface-rate-suppression threshold packet-number milliseconds
当在5000毫秒内某个接口收到的DHCP报文个数超过3000,则认为该接口受到DHCP报文攻击。
packet-number:DHCP接口攻击抑制检测最大报文数,取值范围为2~6000,单位为个。
milliseconds:DHCP接口攻击抑制检测时间,取值范围为1000~10000,单位为毫秒。
用户配置本命令来检测接口是否受到DHCP报文攻击。当某个接口收到的DHCP报文数在配置的指定的时间内达到配置的最大报文数时,则认为该接口受到了DHCP报文攻击。
# 配置DHCP接口攻击抑制检测最大报文数为2000,检测时间为9000毫秒。
[Sysname] dhcp interface-rate-suppression threshold 2000 9000
dhcp log enable命令用来开启DHCP服务器日志信息功能。
undo dhcp log enable命令用来关闭DHCP服务器日志信息功能。
dhcp log enable
DHCP服务器日志信息功能处于关闭状态。
DHCP服务器日志是为了满足管理员审计需求。设备生成DHCP日志信息会交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启DHCP服务器日志信息功能。
[Sysname] dhcp log enable
dhcp rate-limit命令用来开启DHCP报文限速功能,即限制接口接收DHCP报文的速率。
undo dhcp rate-limit命令用来关闭DHCP报文限速功能。
dhcp rate-limit rate
DHCP报文限速功能处于关闭状态。
rate:接口接收DHCP报文的最高速率,单位为Kbps。取值范围为1~10240。
开启DHCP报文限速功能后,当接口上收到的DHCP报文速率超过用户设定的限速值时,丢弃超过速率限制的DHCP报文。
# 开启DHCP报文限速功能,即限制接口Ten-GigabitEthernet3/0/1接收DHCP报文的速率为64Kbps。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp rate-limit 64
dhcp select命令用来配置接口工作在DHCP服务器或DHCP中继模式。
undo dhcp select命令用来取消接口工作在DHCP服务器或DHCP中继模式,即接口将丢弃DHCP客户端发来的DHCP报文。
dhcp select { relay | server }
undo dhcp select { relay | server }
接口工作在DHCP服务器模式,即当接口收到DHCP客户端发来的DHCP报文时,将从DHCP服务器的IP地址池中分配地址等参数。
relay:配置接口工作在DHCP中继模式。
server:配置接口工作在DHCP服务器模式。
接口从DHCP服务器模式切换到DHCP中继模式后,设备不会删除IP地址绑定信息,也不会删除相应的授权ARP表项。这些表项可能会与DHCP中继新生成的ARP表项冲突。因此,建议接口从DHCP服务器模式切换到DHCP中继模式之前,通过reset dhcp server ip-in-use命令清除已有的IP地址绑定信息。
# 配置接口Ten-GigabitEthernet3/0/1工作在DHCP中继模式。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp select relay
· dhcp relay always-unicast
· dhcp server request-ip-address check
· dhcp smart-relay enable
· reset dhcp server ip-in-use
dhcp session-mismatch action命令用来配置DHCP设备收到物理位置发生变化、MAC地址不变的上线用户发送的DHCP请求的处理方式。
undo dhcp session-mismatch action命令用来恢复缺省情况。
dhcp session-mismatch action { fast-renew | roam }
DHCP设备收到物理位置发生变化、MAC地址不变的上线用户发送的DHCP请求报文时,直接丢弃该DHCP请求报文。
fast-renew:首先释放对应MAC地址的地址租约,然后重新为其分配IP地址。
roam:使用对应MAC地址的地址租约应答DHCP请求,并刷新该地址租约的老化时间。本参数仅适用于IPoE组网中用户在属于同一漫游组的接口上漫游的场景。
本功能仅适用于IPoE组网。
当用户的物理接入位置发生变化时,例如无线终端用户漫游时,若需要该用户下线后重新上线,则DHCP设备可能会因为未及时收到用户的下线请求,而导致DHCP设备认为该终端用户还在线。因为终端用户所在的无线网络发生变化,但MAC地址不变,则DHCP设备会认为收到的终端用户重新发送的DHCP请求报文是攻击报文,直接丢弃该DHCP请求报文。
为了解决这个问题,需要在DHCP设备上配置本功能:
· 指定fast-renew参数后,当DHCP服务器收到物理位置发生变化,MAC地址不变的上线用户发送的DHCP请求报文,先释放对应MAC地址的已在线租约,再为该用户分配IP地址。当DHCP中继收到物理位置发生变化,MAC地址不变的上线用户发送的DHCP请求报文,先向服务器发报文释放对应MAC地址的已在线租约,再将请求报文转发给DHCP服务器。
· 指定roam参数后,当DHCP服务器收到物理位置发生变化,MAC地址不变的上线用户发送的DHCP请求报文,使用对应MAC地址的地址租约应答DHCP请求,并刷新该地址租约的老化时间。这样,可以保证用户继续使用相同的IP地址上线,避免了重新进行接入认证。当DHCP中继收到物理位置发生变化,MAC地址不变的上线用户发送的DHCP请求报文,直接将该请求报文转发给DHCP服务器。
配置本功能后,可能会导致正常在线的用户掉线。因此,仅在网络中不存在DHCP攻击,又需要解决漫游用户的上线问题时,才建议开启本功能。
本命令与dhcp server multi-ip per-mac enable命令互斥。
# 在接口Ten-GigabitEthernet3/0/1上配置DHCP设备收到物理位置发生变化、MAC地址不变的上线用户发送的DHCP请求报文后,先释放将对应MAC地址的已在线租约,再为该用户分配IP地址。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp session-mismatch action fast-renew
· ip subscriber roaming enable(BRAS业务命令参考/IPoE)
dhcp user offline命令用来配置当DHCP服务器收到客户端的请求后,如果发现之前为该客户端分配过租约,则直接释放已分配的租约。
undo dhcp user offline命令用来恢复缺省情况。
dhcp { discover | reboot-request } * user offline
undo dhcp { discover | reboot-request } * user offline
当DHCP服务器收到客户端的请求后,如果发现之前为该客户端分配过租约,则使用已分配租约中的地址应答请求。
discover:DHCP客户端发送的DHCP-DISCOVER报文。
reboot-request:DHCP客户端重启后发送的DHCP-REQUEST报文。
当用户下线时,如果DHCP服务器感知不到用户下线的动作,则DHCP服务器不会删除该用户的地址租约。当该用户重新上线后,如果用户上线的认证域发生变化,则用户发送DHCP报文中的Option选项信息会发生变化。DHCP服务器收到请求报文后,发现存在相同MAC地址的地址租约,则DHCP服务器不会再解析请求报文中的Option选项信息(涉及的选项包括Option 16、Option 17和Option 60),直接使用已存在租约的地址应答该请求报文。这就造成用户一直获取之前认证域的地址,导致用户无法正常访问网络。
当DHCP服务器收到用户发送的本命令配置类型的请求报文时,会删除相同MAC地址的地址租约,且不应答该请求。当用户等待超时后,会重新发送DHCP请求。DHCP服务器收到请求报文后,会按照Option选项选择正确认证域对应的地址池,并从该地址池中选择地址分配给用户,保证用户可以在新的认证域中正常上线。对于非本命令配置类型的请求报文,如果发现之前为该客户端分配过租约,则使用已分配租约中的地址应答请求。
# 配置当DHCP服务器收到客户端发送的DHCP-DISCOVER报文后,如果发现之前为该客户端分配过租约,则直接释放已分配的租约。
[Sysname] dhcp discover user offline
# 配置当DHCP服务器收到客户端重启后发送的DHCP-REQUEST报文后,如果发现之前为该客户端分配过租约,则直接释放已分配的租约。
[Sysname] dhcp reboot-request user offline
display dhcp flood-protection命令用来显示DHCP防Flood攻击表项信息。
display dhcp flood-protection slot slot-number [ mac-address mac-address [ interface interface-type interface-number ] | state { check | restrain } [ verbose ] | statistics | verbose ]
mac-address mac-address:显示指定MAC地址的DHCP防Flood攻击表项信息。mac-address的格式为H-H-H。指定mac-address mac-address参数时,显示的是DHCP防Flood攻击表项的详细信息,如果未指定本参数,显示的是DHCP防Flood攻击表项的简要信息。
interface interface-type interface-number:显示指定接口上指定MAC地址的DHCP防Flood攻击表项信息。
state { check | restrain }:显示指定状态的DHCP防Flood攻击表项信息。check表示显示的是检查状态的DHCP防Flood攻击表项信息。restrain表示显示的是抑制状态的DHCP防Flood攻击表项信息。
slot slot-number:指定单板。slot-number为单板所在的槽位号。
statistics:显示DHCP防Flood攻击表项统计信息。
verbose:显示DHCP防Flood攻击表项的详细信息。
如果未指定任何参数,则显示设备上所有的DHCP防Flood攻击表项简要信息。
# 显示指定slot上的DHCP防Flood攻击表项的简要信息。
<Sysname> display dhcp flood-protection slot 1
Global DHCP flood protection: Enabled
DHCP flood protection threshold: 100 packets/ 2000 milliseconds
Index MAC address UDP port SVLAN/CVLAN State
0 4211-cc00-0116 67 4091/4094 Restrain
1 60d0-d50a-0231 68 4091/4094 Check
2 4211-cc00-0117 67 4091/4094 Restrain
3 000f-3d81-7faf 67 4091/4094 Check
4 4211-cc00-0118 67 4091/4094 Restrain
Total entries: 5
# 显示指定slot上的DHCP防Flood攻击表项的详细信息。
<Sysname> display dhcp flood-protection slot 1 verbose
Interface: Ten-GigabitEthernet3/0/1
MAC address: 78a8-3e93-0216
Hardware status: Succeeded
SVLAN/CVLAN: -/-
State: Restrain
Entry created at: 2021/06/24 11:23:45
Total passed packets: 1
Total restrain packets: 2
Interface: Ten-GigabitEthernet3/0/2
MAC address: 78a8-3e93-0217
SVLAN/CVLAN: -/-
State: Restrain
Entry created at: 2021/06/24 11:23:43
Interface: Ten-GigabitEthernet3/0/3
MAC address: 78a8-3e93-0218
SVLAN/CVLAN: -/-
State: Restrain
Entry created at: 2021/06/24 11:23:41
Total entries: 3
# 显示指定slot上的MAC地址为4211-cc00-0116的DHCP防Flood攻击表项的详细信息。
<Sysname> display dhcp flood-protection slot 1 mac-address 4211-cc00-0116
MAC address: 4211-cc00-0116
SVLAN/CVLAN: 4091/4094
State: Restrain
Entry created at: 2018/01/08 15:51:50
Total passed packets: 2
Total restrain packets: 3
Total entries: 1
# 显示DHCP防Flood攻击表项统计信息。
<Sysname> display dhcp flood-protection slot 1 statistics
Total entries: 5
Entries in check state: 2
Entries in restrain state: 3
表1-1 display dhcp flood-protection命令显示信息描述表
Global DHCP flood protection |
全局DHCP Flood攻击防范功能的状态: · Enabled:全局DHCP Flood攻击防范功能处于开启状态 · Disabled:全局DHCP Flood攻击防范功能处于关闭状态 |
DHCP flood protection threshold: xxx packets/ yyy milliseconds |
DHCP Flood攻击检测最大报文数为xxx,检测时间为yyy毫秒 |
Index |
DHCP防Flood攻击表项的序号 |
MAC address |
DHCP报文中的源MAC地址 |
UDP port |
DHCP报文的目的UDP端口号 |
SVLAN/CVLAN |
DHCP报文的外层VLAN和内层VLAN,如果报文不属于任何VLAN,则显示为“-” |
State |
DHCP防Flood攻击表项的状态,取值包括: · Check:检查状态 · Restrain:抑制状态 |
收到DHCP报文的接口名称 |
Hardware status |
生成攻击表项后,下发硬件资源的状态,取值包括: · Succeeded:成功下发硬件表项资源 · Failed:设备故障或硬件攻击表项资源已被占满,硬件资源下发失败 · N/A:当前表项对应的报文为非攻击报文,未下发硬件攻击表项资源 · Not support:硬件不支持DHCP攻击检测与防范功能 |
Entry created at |
设备建立CHECK类型DHCP防Flood攻击表项的时间 |
Total passed packets |
DHCP防Flood攻击表项处于check状态时检测通过的报文总数 |
Total restrain packets |
DHCP防Flood攻击表项处于restrain状态时抑制的报文总数 |
Total entries |
DHCP防Flood攻击表项总数 |
Entries in check state |
Check状态的DHCP防Flood攻击表项总数 |
Entries in restrain state |
Restrain状态的DHCP防Flood攻击表项总数 |
· reset dhcp flood-protection
display dhcp interface-rate-suppression命令用来显示DHCP接口攻击抑制表项信息。
display dhcp interface-rate-suppression slot slot-number [ interface interface-type interface-number | state { check | restrain } [ verbose ] | statistics | verbose ]
interface interface-type interface-number:显示指定接口上DHCP接口攻击抑制表项详细信息。
state { check | restrain }:显示指定状态的DHCP接口攻击抑制表项信息。check表示显示的是检查状态的DHCP接口攻击抑制表项信息。restrain表示显示的是抑制状态的DHCP接口攻击抑制表项信息。
statistics:显示DHCP接口攻击抑制统计信息。
verbose:显示DHCP接口攻击抑制表项的详细信息。
如果未指定任何参数,则显示设备上所有的DHCP接口攻击抑制表项简要信息。
# 显示指定slot上的DHCP接口攻击抑制表项的简要信息。
<Sysname> display dhcp interface-rate-suppression slot 1
DHCP attack suppression threshold: 100 packets/ 2000 milliseconds
Index Interface State
0 XGE3/0/1 Restrain
1 XGE3/0/2 Check
2 XGE3/0/3 Restrain
Total entries: 3
# 显示指定slot上的DHCP接口攻击抑制表项详细信息。
<Sysname>display dhcp interface-rate-suppression slot 1 verbose
State: Restrain
Entry created at 2021/06/24 11:23:45
Total passed packets: 7
Total restrain packets: 0
State: Restrain
Entry created at 2021/06/24 11:23:43
State: Restrain
Entry created at 2021/06/24 11:23:41
Total passed packets: 6
Total entries: 3
# 显示指定slot上接口Ten-GigabitEthernet3/0/1的DHCP接口攻击抑制表项的详细信息。
<Sysname> display dhcp interface-rate-suppression slot 1 interface ten-gigabitethernet 3/0/1
State: Restrain
Entry created at 2018/07/08 15:51:50
# 显示指定slot上DHCP接口攻击抑制统计信息。
<Sysname> display dhcp interface-rate-suppression slot 1 statistics
Interfaces enabled with DHCP attack suppression: 3
Entries in restrain state: 1
表1-2 display dhcp interface-rate-suppression命令显示信息描述表
DHCP attack suppression threshold: xxx packets/ yyy milliseconds |
DHCP接口攻击抑制检测最大报文数为xxx,检测时间为yyy毫秒 |
Index |
DHCP接口攻击抑制表项的序号 |
State |
DHCP接口攻击抑制表项的状态,取值包括: · Check:检查状态 · Restrain:抑制状态 |
收到DHCP报文的接口名称 |
Hardware status |
Entry created at |
接口攻击抑制表项生成的时间 |
DHCP接口攻击抑制表项处于restrain状态时转发的报文总数 |
DHCP接口攻击抑制表项处于restrain状态时丢弃的报文总数 |
Total entries |
DHCP接口攻击抑制表项总数 |
Interfaces enabled with DHCP attack suppression |
开启DHCP接口攻击抑制功能的接口总数 |
Check state count |
Check状态的DHCP接口攻击抑制表项总数 |
Restrain state count |
Restrain状态的DHCP接口攻击抑制表项总数 |
· reset dhcp interface-rate-suppression
display dhcp rate-limit命令用来显示DHCP接入用户的DHCP报文限速功能的报文统计信息。
display dhcp rate-limit slot slot-number
在DHCP服务器或DHCP中继上通过ip subscriber dhcp rate-limit命令开启接入用户的DHCP报文限速功能后,设备将限制接收DHCP报文(包括Discover报文和未经认证用户的Request报文)的速率。使用本命令可以查看开启限速功能后的丢包个数、允许通过的报文个数等统计信息。
# 显示指定slot上DHCP接入用户的DHCP报文限速功能的报文统计信息。
<Sysname> display dhcp rate-limit slot 1
DHCP rate-limit packet statistics:
Dropped since last poll:12
Total dropped packets:22
Total passed packets:1000
表1-3 display dhcp rate-limit命令显示信息描述表
DHCP rate-limit packet statistics |
DHCP接入用户的DHCP报文限速功能的报文统计信息 |
Dropped since last poll |
最近一次查询时统计的DHCP报文限速功能的丢包个数 |
Total dropped packets |
DHCP报文限速功能的丢包总数 |
DHCP报文限速功能允许通过的报文总数 |
· ip subscriber dhcp rate-limit(BRAS业务命令参考/IPoE)
· reset dhcp rate-limit
remote-server命令用来指定IP地址池对应的DHCP服务器地址。
undo remote-server命令用来删除为IP地址池指定的DHCP服务器地址。
remote-server ip-address&<1-8> [ public | vpn-instance vpn-instance-name ]
undo remote-server [ ip-address&<1-8> ]
未指定IP地址池对应的DHCP服务器的地址。
IP地址池视图
ip-address:DHCP服务器的IP地址。&<1-8>表示ip-address最多支持配置8个,之间需要用空格分隔。
public:指定公网中的DHCP服务器。
vpn-instance vpn-instance-name:指定VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示指定公网。
执行undo remote-server命令时,如果未指定任何参数,则删除所有配置DHCP服务器地址。
如果未指定public或vpn-instance vpn-instance-name参数,则以当前DHCP客户端位置(公网或VPN)为准。
# 配置IP地址池0为中继配置的服务器地址为10.1.1.1。
[Sysname] ip pool 0
[Sysname-ip-pool-0] remote-server 10.1.1.1
· display dhcp relay remote-server-info
reset dhcp flood-protection命令用来清除DHCP防Flood攻击表项信息。
reset dhcp flood-protection slot slot-number [ mac-address mac-address [ interface interface-type interface-number ] ] [ packet-statistics ]
mac-address mac-address:清除指定MAC地址的DHCP防Flood攻击表项信息。mac-address的格式为H-H-H。如果未指定本参数,则清除所有MAC地址的DHCP防Flood攻击表项信息。
interface interface-type interface-number:清除指定接口上指定MAC地址的DHCP防Flood攻击表项信息。
packet-statistics:清除DHCP防Flood攻击表项中的报文统计信息,包括DHCP防Flood攻击表项处于check状态时检测通过的报文总数和DHCP防Flood攻击表项处于restrain状态时抑制的报文总数。如果未指定本参数,将删除DHCP防Flood攻击表项。
如果未指定任何参数,则清除设备上所有的DHCP防Flood攻击表项信息。
# 清除指定slot上的DHCP防Flood攻击表项信息。
<Sysname> reset dhcp flood-protection slot 1
reset dhcp interface-rate-suppression命令用来清除DHCP接口攻击抑制表项信息。
reset dhcp interface-rate-suppression slot slot-number [ interface interface-type interface-number ] [ packet-statistics ]
interface interface-type interface-number:清除指定接口上DHCP接口攻击抑制表项信息。
packet-statistics:清除接口上DHCP接口攻击抑制表项中的报文统计信息,包括DHCP接口攻击抑制表项处于restrain状态时转发的报文总数和DHCP接口攻击抑制表项处于restrain状态时丢弃的报文总数。如果未指定本参数,将删除DHCP接口攻击抑制表项。
如果未指定任何参数,则清除设备上所有的DHCP接口攻击抑制表项信息。
# 清除指定slot上的DHCP接口攻击抑制表项信息。
<Sysname> reset dhcp interface-rate-suppression slot 1
reset dhcp rate-limit命令用来清除DHCP接入用户的DHCP报文限速功能的报文统计信息。
reset dhcp rate-limit slot slot-number
在DHCP服务器或DHCP中继上通过ip subscriber dhcp rate-limit命令开启接入用户的DHCP报文限速功能后,设备将限制接收接入用户发送的DHCP报文(包括Discover报文和未经认证用户的Request报文)的速率。使用本命令可以清除开启限速功能后的丢包个数等报文统计信息。
# 清除指定slot上的DHCP报文限速功能的报文统计信息。
<Sysname> reset dhcp rate-limit slot 1
· display dhcp rate-limit
address range命令用来配置IP地址池动态分配的IP地址范围。
undo address range命令用来恢复缺省情况。
undo address range
未配置动态分配的IP地址范围。
IP地址池视图
IP地址池从网段视图
start-ip-address:动态分配范围的起始IP地址。
end-ip-address:动态分配范围的结束IP地址。
当地址池下通过network或gateway命令指定了网段地址或通过network secondary命令指定了从网段地址时:
· 如果未通过本命令配置地址池动态分配的IP地址范围,则网段地址或从网段地址都可以分配给DHCP客户端;
· 如果通过本命令配置了地址池动态分配的IP地址范围,则只有与网段或从网段重叠的IP地址范围内的地址能分配给客户端。
为了避免出现无效配置而导致没有地址可分配给客户端,address range指定的地址范围必须在network、gateway或network secondary配置的网段范围内。
# 配置IP地址池1动态分配的地址范围为192.168.8.1到192.168.8.150。
[Sysname] ip pool 1
[Sysname-ip-pool-1] network 192.168.8.1 mask 255.255.255.0
[Sysname-ip-pool-1] address range 192.168.8.1 192.168.8.150
# 配置IP地址池1中从网段动态分配的地址范围为192.168.8.1到192.168.8.150。
[Sysname] ip pool 1
[Sysname-ip-pool-1] network 192.168.8.1 secondary
[Sysname-ip-pool-1-secondary] address range 192.168.8.1 192.168.8.150
· class
· dhcp class
· display ip pool
· network
allocate-new-ip enable命令用来配置IP地址池随机分配新地址功能。
undo allocate-new-ip enable命令用来关闭IP地址池随机分配新地址功能。
IP地址池随机分配新地址功能处于关闭状态。
IP地址池视图
目前IP地址池正常的地址分配方式是尽量保证同一用户上线能够获得相同的IP地址。但是在某些通过IP地址识别身份的应用中,用户需要实现每次上线能够获得不同的IP地址的需求。针对这种需求,设备需提供IP地址池随机分配新地址的需求。本功能保证用户在断线重拨后可以获得不同的IP地址。
DHCP中继组网环境中,当DHCP中继同时作为接入设备时,DHCP服务器上配置本功能后,会导致异常下线的DHCP中继接入用户无法再次上线。
# 配置IP地址池随机分配新地址功能
[Sysname] ip pool 1
[Sysname-ip-pool-1] allocate-new-ip enable
This command will enable the random address allocation mode. Enable it? [Y/N]:
bims-server命令用来配置IP地址池为DHCP客户端分配的BIMS服务器IP地址、端口及共享密钥信息。
undo bims-server命令用来恢复缺省情况。
undo bims-server
未配置IP地址池为DHCP客户端分配的BIMS服务器信息。
IP地址池视图
ip ip-address:指定BIMS服务器的IP地址。
port port-number:指定BIMS服务器的端口号。port-number为端口号,取值范围为1~65534。
cipher:以密文形式设置密钥。
simple:以明文形式设置密钥,该密钥将以密文方式存储。
string:密钥字符串,区分大小写。明文密钥为1~16个字符的字符串,密文密钥为1~53个字符的字符串。DHCP客户端获取到BIMS服务器的信息后,与BIMS服务器通信时,采用共享密钥对传递的消息进行加密,以保证消息传递的安全性。
# 配置IP地址池0为DHCP客户端分配的BIMS服务器的IP地址为1.1.1.1,端口号为80,共享密钥为aabbcc。
[Sysname] ip pool 0
[Sysname-ip-pool-0] bims-server ip 1.1.1.1 port 80 sharekey simple aabbcc
· display ip pool
bootfile-name命令用来配置DHCP客户端使用的启动文件名或远程启动文件的HTTP形式URL。
undo bootfile-name命令用来恢复缺省情况。
bootfile-name { bootfile-name | url }
undo bootfile-name
未配置DHCP客户端使用的启动文件名或远程启动文件的HTTP形式URL。
IP地址池视图
bootfile-name:启动文件名,为1~63个字符的字符串,区分大小写。
url:远程启动文件的HTTP形式URL,为1~63个字符的字符串,区分大小写。
当启动文件在TFTP服务器上,使用bootfile-name参数指定DHCP客户端使用的启动文件名;当启动文件在HTTP服务器上,使用url参数指定远程启动文件的HTTP形式URL。
# 配置IP地址池0为DHCP客户端分配的启动文件名为boot.cfg。
[Sysname] ip pool 0
[Sysname-ip-pool-0] bootfile-name boot.cfg
# 配置IP地址池0为DHCP客户端分配的启动文件的HTTP URL为http://10.1.1.1/boot.cfg。
[Sysname] ip pool 0
[Sysname-ip-pool-0] bootfile-name http://10.1.1.1/boot.cfg
· display ip pool
· next-server
· tftp-server domain-name
· tftp-server ip-address
class ip-pool命令用来指定DHCP用户类关联的IP地址池。
undo class ip-pool命令删除为指定DHCP用户类关联的IP地址池。
undo class class-name ip-pool
未指定DHCP用户类关联的IP地址池。
DHCP策略视图
class-name:DHCP用户类名称,为1~63个字符的字符串,不区分大小写。
pool-name:IP地址池名称,为1~63个字符的字符串,不区分大小写。
对于一个DHCP用户类,在一个DHCP策略中只能关联一个IP地址池。
多次执行本命令为同一个DHCP用户类关联不同的IP地址池,最后一次执行的命令生效。
# 在DHCP策略1中,配置DHCP用户类test关联IP地址池pool1。
[Sysname] dhcp policy 1
[Sysname-dhcp-policy-1] class test ip-pool pool1
· default ip-pool
· dhcp policy
· ip pool
class option-group命令用来配置IP地址池下DHCP用户类和DHCP选项组的关联。
undo class option-group命令用来删除IP地址池下DHCP用户类和DHCP选项组的关联。
undo class class-name option-group
未配置IP地址池的DHCP用户类和DHCP选项组的关联。
IP地址池视图
option-group-number:DHCP选项组编号,取值范围为1~32768。
DHCP服务器应答DHCP客户端报文时,首先根据配置顺序逐个匹配通过class option-group命令指定的DHCP用户类。如果匹配成功,则将该用户类对应的选项组中的选项填充到应答报文中;如果同时匹配多个DHCP用户类,且各用户类对应的选项组中有相同编号的选项,以最先匹配到DHCP用户类对应的选项组中的选项为准。
需要注意的是,对于一个DHCP用户类,在一个IP地址池中只能指定一个选项组。多次执行本命令为同一个DHCP用户类指定不同的选项组,最后一次执行的命令生效。
# 在IP地址池0中,配置DHCP用户类user和DHCP选项组1的关联。
[Sysname] ip pool 0
[Sysname-ip-pool-0] class user option-group 1
· dhcp option-group
class range命令用来配置IP地址池为指定DHCP用户类动态分配的IP地址范围。
undo class range命令用来删除为指定DHCP用户类动态分配的IP地址范围。
undo class class-name range
未配置为指定DHCP用户类动态分配的IP地址范围。
IP地址池视图
class-name:DHCP用户类名称,为1~63个字符的字符串,不区分大小写。如果指定的DHCP用户类不存在,则为该用户类指定的地址范围不能分配给任何DHCP客户端。
DHCP服务器从IP地址池中选择地址分配给客户端时,首先根据配置顺序逐个匹配通过class range命令指定的DHCP用户类。如果匹配成功,则从为该用户类指定的地址范围内选择地址分配给DHCP客户端;如果该用户类中没有可供分配的地址,则继续匹配下一个用户类;如果所有匹配上的用户类地址范围都没有可供分配的地址,则从公共地址范围中选择地址分配给客户端;如果不匹配任何DHCP用户类,则会从IP地址池动态分配的IP地址范围(通过address range命令配置)中选择地址分配给DHCP客户端;如果address range命令指定的地址范围内也没有空闲地址,或者未配置address range命令,则地址分配失败,即DHCP服务器无法为DHCP客户端分配地址。
通过本配置可以实现将一个IP地址池下的地址范围划分成多个地址段,分别分配给属于不同DHCP用户类的DHCP客户端。
配置class range命令后,不能再通过network secondary命令在IP地址池中配置从网段。
配置class range命令后,只能从class range命令或address range命令指定的地址范围内选择地址分配给客户端。
一个IP地址池中只能为一个DHCP用户类指定一个地址范围。多次执行本命令为同一个DHCP用户类指定不同的地址范围,最后一次执行的命令生效。
一个IP地址池中可以为多个不同的DHCP用户类指定地址范围。
class range命令指定的地址范围应该在network命令指定的主网段范围内,主网段范围外的地址将无法被分配。
当用户配置class range命令修改已存在的为DHCP用户类动态分配的IP地址范围时,新的IP地址范围必须包含之前IP地址范围中已分配的地址租约,否则将导致已分配的地址租约续约失败,且用户必须等该续约失败的租约超期后才能申请新的租约。
# 在IP地址池1中配置为DHCP用户类user动态分配的地址范围为192.168.8.1到192.168.8.150。
[Sysname] ip pool 1
[Sysname-ip-pool-1] class user range 192.168.8.1 192.168.8.150
· address range
· dhcp class
· display ip pool
default ip-pool命令用来指定默认IP地址池。
undo default ip-pool命令用来恢复缺省情况。
default ip-pool pool-name
未指定默认IP地址池。
DHCP策略视图
pool-name:默认IP地址池名称,为1~63个字符的字符串,不区分大小写。
若匹配DHCP策略中的所有DHCP用户类失败,当配置了默认IP地址池时,则从该地址池中分配IP地址和其他参数;当未配置默认IP地址池或默认IP地址池中不存在可供分配的地址信息时,IP地址和其他参数分配失败。
在一个DHCP策略视图中,只能配置一个默认IP地址池。多次执行本命令,最后一次执行的命令生效。
# 在DHCP策略1中指定默认IP地址池pool1。
[Sysname-dhcp-policy-1] default ip-pool pool1
· class ip-pool
· dhcp policy
dhcp apply-policy命令用来指定接口引用的DHCP策略。
undo dhcp apply-policy命令用来恢复缺省情况。
dhcp apply-policy policy-name
接口未引用DHCP策略。
policy-name:DHCP策略名称,为1~63个字符的字符串,不区分大小写。
在一个接口上只能引用一条DHCP策略。在同一个接口上多次执行本命令,最后一次执行的命令生效。
# 指定接口Ten-GigabitEthernet3/0/1引用的DHCP策略test。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp apply-policy test
· dhcp policy
dhcp class命令用来创建DHCP用户类并进入DHCP用户类视图,如果指定的DHCP用户类已存在,则直接进入用户类视图。
undo dhcp class命令用来删除指定的DHCP用户类。
dhcp class class-name
undo dhcp class class-name
不存在DHCP用户类。
class-name:DHCP用户类的名称,为1~63个字符的字符串,不区分大小写。
在DHCP用户类视图下,可以通过if-match命令配置DHCP用户类的匹配规则,根据匹配规则判断DHCP客户端属于的DHCP用户类,从而实现灵活的用户分类策略。
# 创建名称为test的DHCP用户类,并进入DHCP用户类视图。
[Sysname] dhcp class test
[Sysname-dhcp-class-test]
· address range
· class ip-pool
· class option-group
· class range
· dhcp policy
· if-match
dhcp option-group命令用来创建DHCP选项组并进入DHCP选项组视图,如果指定的DHCP选项组已存在,则直接进入DHCP选项组视图。
undo dhcp option-group命令用来删除指定的DHCP选项组。
undo dhcp option-group option-group-number
不存在DHCP选项组。
# 创建DHCP选项组1并进入该选项组视图。
[Sysname] dhcp option-group 1
[Sysname-dhcp-option-group-1]
· option
dhcp policy命令用来创建DHCP策略,并进入DHCP策略视图。如果指定的DHCP策略已存在,则直接进入DHCP策略视图。
undo dhcp policy命令用来删除已创建的DHCP策略。
dhcp policy policy-name
undo dhcp policy policy-name
不存在DHCP策略。
在DHCP策略视图下,可以通过class ip-pool命令指定DHCP用户类关联的IP地址池,使匹配该DHCP用户类的客户端可以从关联的IP地址池中获取到IP地址和其他参数。
需要注意的是,需要配置dhcp apply-policy命令在接口上引用DHCP策略后,DHCP策略才能生效。
# 创建DHCP策略test,并进入该DHCP策略视图。
[Sysname] dhcp policy test
[Sysname-dhcp-policy-test]
· class ip-pool
· default ip-pool
· dhcp apply-policy
· dhcp class
dhcp route-log enable命令用来开启全局IP地址池路由日志功能。
undo dhcp route-log enable命令用来关闭全局IP地址池路由日志功能。
全局IP地址池路由日志功能处于关闭状态。
开启本功能后,当添加或删除IP地址池的网段路由等路由事件发生时,设备会打印日志信息。
用户可以使用dhcp route-log enable命令或route-log enable命令开启IP地址池路由日志功能。两者的配置关系如下:
· 配置dhcp route-log enable命令后,设备上所有类型IP地址池的路由日志功能将被开启。
· 如果只想开启某个IP地址池的路由日志功能,需要关闭全局IP地址池路由日志功能,仅在该地址池视图下配置route-log enable命令。
· 全局IP地址池路由日志功能开启时,为了避免输出大量日志信息淹没有用信息,可以在IP地址池下通过undo route-log enable命令关闭部分地址池的路由日志功能。
# 开启全局IP地址池路由日志功能。
[Sysname] dhcp route-log enable
· route-log enable
dhcp server allocated-ip threshold命令用来设置在5分钟内成功分配出去的地址租约数所占IP地址池收到的DHCP客户端请求数比率的门限阈值。
undo dhcp server allocated-ip threshold命令用来恢复缺省情况。
dhcp server allocated-ip threshold threshold-value
设备不会发送告警信息。
threshold-value:成功分配率的门限阈值,为百分比形式,取值范围为1~100。
执行本命令设置地址成功分配率告警门限阈值,在地址成功分配率低于此门限阈值时,系统会发送告警信息提醒管理员进行处理。
在同一个视图下多次执行本命令,最后一次执行的命令生效。
# 设置DHCP服务器地址成功分配率告警门限阈值为85%。
[Sysname] dhcp server allocated-ip threshold 85
· snmp-agent trap enable dhcp server
dhcp server always-broadcast命令用来开启DHCP服务器的广播回应报文功能。
undo dhcp server always-broadcast命令用来恢复缺省情况。
DHCP服务器的广播回应报文功能处于关闭状态。DHCP服务器根据请求报文中的广播标志位来决定以广播还是单播的形式发送应答报文。
开启DHCP服务器的广播回应报文功能后,DHCP服务器忽略请求报文中的广播标志位,以广播的形式发送应答报文。
# 开启DHCP服务器的广播回应报文功能。
[Sysname] dhcp server always-broadcast
dhcp server apply ip-pool命令用来指定接口引用的IP地址池。
undo dhcp server apply ip-pool命令用来恢复缺省情况。
接口未引用IP地址池。
如果接口上配置了本命令,则接口接收到DHCP请求后,将优先为客户端分配静态绑定的IP地址;如果不存在静态绑定的IP地址,则从引用的IP地址池中选择IP地址分配给客户端。引用的IP地址池中不存在可供分配的IP地址时,设备无法为客户端分配IP地址。
接口上配置了dhcp server apply ip-pool命令后,如果接口引用的IP地址池不存在,则无法为客户端动态分配IP地址。
# 配置接口Ten-GigabitEthernet3/0/1引用IP地址池0。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp server apply ip-pool 0
· ip pool
dhcp server bootp ignore命令用来配置DHCP服务器忽略BOOTP请求。
undo dhcp server bootp ignore命令用来恢复缺省情况。
DHCP服务器不会忽略BOOTP请求。
BOOTP客户端申请到的地址的租约是无限期的。在特殊的组网环境中,可能不希望出现无限期的地址租约。此时,可以通过配置DHCP服务器忽略BOOTP请求报文,避免分配无限期的地址租约。
# 配置DHCP服务器忽略BOOTP请求。
[Sysname] dhcp server bootp ignore
dhcp server bootp reply-rfc-1048命令用来开启DHCP服务器回应RFC 1048格式报文功能。
undo dhcp server bootp reply-rfc-1048命令用来关闭DHCP服务器回应RFC 1048格式报文功能。
DHCP服务器回应RFC 1048格式报文功能处于关闭状态。
本功能只在客户端通过BOOTP报文申请静态绑定地址时有效。
# 开启DHCP服务器的回应RFC 1048格式报文功能。
[Sysname] dhcp server bootp reply-rfc-1048
dhcp server check mac-address命令用来开启DHCP服务器源MAC检查功能。
undo dhcp server check mac-address命令用来关闭DHCP服务器源MAC检查功能。
DHCP服务器源MAC检查功能处于关闭状态。
开启该功能后,DHCP服务器检查接收到的DHCP请求报文中的chaddr字段和数据帧的源MAC地址字段是否一致。如果一致,则认为该报文合法,继续后续处理;如果不一致,则丢弃该报文。
# 在接口Ten-GigabitEthernet3/0/1上开启DHCP服务器的MAC地址检查功能。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp server check mac-address
dhcp server database filename命令用来指定存储DHCP服务器表项的文件名称。
undo dhcp server database filename命令用来恢复缺省情况。
未指定存储DHCP服务器表项的文件名称。
filename:目标文件名,为1~255个字符的字符串,区分大小写,该配置用于本地存储模式。文件名取值范围的详细介绍,请参见“基础配置指导”中的“文件系统管理”。
url url:配置远程目标文件URL,为1~255个字符的字符串,区分大小写,该配置用于远程文件系统模式。此参数中不能包含用户名和密码,和参数username和string配合使用。
username username:配置远程目标文件URL时的用户名,为1~32个字符的字符串,区分大小写。如果未指定本参数,则表示登录远程目标文件URL时无需使用用户名。
cipher:表示以密文方式设置用户密码。
string:密码字符串,区分大小写。明文密码为1~32个字符的字符串,密文密码为1~73个字符的字符串。如果未指定本参数,则表示登录远程目标文件URL时无需使用密码。
存储DHCP服务器表项时,如果设备中还不存在对应名称的文件,则设备会自动创建该文件。
执行本命令后,会立即触发一次表项备份。之后,如果未配置dhcp server database update interval命令,若表项发生变化,默认在300秒之后刷新存储文件;若表项未发生变化,则不再刷新存储文件。如果配置了dhcp server database update interval命令,若表项发生变化,则到达刷新时间间隔后刷新存储文件;若表项未发生变化,则不再刷新存储文件。
参数filename不支持远程目标文件URL,配置远程目标文件URL请使用url、username、string配合使用。
频繁擦写本地存储介质可能会影响存储介质寿命,建议使用远程文件系统模式存储DHCP服务器表项文件。
当进行远程存储时,支持FTP和TFTP协议:
· 当采用FTP或TFTP协议时,服务器地址支持IPv4形式或IPv6形式,并且支持DNS域名方式。服务器地址为IPv6地址形式时需使用方括号(“[”和“]”)引用。配置服务器地址为DNS域名格式时请勿使用方括号引用。
· 当采用FTP协议时,URL采用“ftp://服务器地址[:端口号]/文件路径”的形式,如有用户名和密码请分别使用参数username和参数string进行配置,用户名和密码必须和服务器上的配置一致,如果服务器只对用户名进行认证,则不用输入密码。
· 当采用TFTP协议时,URL采用“tftp://服务器地址[:端口号]/文件路径”的形式。
# 配置存储DHCP服务器表项的文件名为database.dhcp。
[Sysname] dhcp server database filename database.dhcp
# 配置远程存储DHCP服务器表项至IP地址为10.1.1.1的FTP服务器工作目录下,用户名为1,密码为1,文件名为database.dhcp。
[Sysname] dhcp server database filename url ftp://10.1.1.1/database.dhcp username 1 password simple 1
· dhcp server database update interval
· dhcp server database update now
· dhcp server database update stop
dhcp server database update interval命令用来配置刷新DHCP服务器表项存储文件的延迟时间。
undo dhcp server database update interval命令用来恢复缺省情况。
若DHCP服务器表项不变化,则不刷新表项存储文件;若DHCP服务器表项发生变化,默认在300秒后刷新表项存储文件。
执行本命令后,当服务器表项发生变化后,DHCP服务器开始计时,当本命令配置的延迟时间到达后,DHCP服务器会把这个时间段内表项所有的变化信息备份到固化文件中。
如果未通过dhcp server database filename命令指定存储表项的文件,则本命令的配置不会生效。
# 若DHCP服务器表项发生变化,在10分钟后刷新表项存储文件。
[Sysname] dhcp server database update interval 600
· dhcp server database filename
dhcp server database update now命令用来将当前DHCP服务器表项保存到用户指定的文件中。
本命令只用来触发一次DHCP服务器表项的备份。
# 将当前的DHCP服务器表项保存到文件中。
[Sysname] dhcp server database update now
dhcp server database update stop命令用来终止当前的DHCP服务器表项恢复操作。
本命令只用来触发一次终止DHCP服务器表项的恢复操作。
从固化文件恢复表项的连接超时的最长时间为60分钟,可以通过本命令立刻终止远程恢复。DHCP服务器从固化文件中恢复表项的过程中,DHCP服务器不会学习新的表项。
# 终止当前的DHCP服务器表项恢复操作。
[Sysname] dhcp server database update stop
dhcp server forbidden-ip命令用来配置全局不参与自动分配的IP地址。
undo dhcp server forbidden-ip命令用来取消全局不参与自动分配的IP地址的配置。
undo dhcp server forbidden-ip start-ip-address [ end-ip-address ] [ vpn-instance vpn-instance-name ]
未配置全局不参与自动分配的IP地址。
start-ip-address:不参与自动分配的起始IP地址。
end-ip-address:不参与自动分配的结束IP地址,不能小于start-ip-address。如果未指定本参数,则表示只有一个不参与自动分配的IP地址,即start-ip-address;否则,表示start-ip-address到end-ip-address之间的IP地址均不能参与自动分配。
某些服务器占用的IP地址(如网关地址、FTP服务器地址),不能分配给DHCP客户端。通过本命令可以避免这些地址参与自动分配。
已经通过static-bind命令静态绑定的IP地址不能通过本命令配置为不参与自动分配的IP地址。执行undo dhcp server forbidden-ip命令取消不参与自动分配IP地址的配置时,指定的地址/地址范围必须与执行dhcp server forbidden-ip命令时指定的地址/地址范围保持一致。如果配置不参与自动分配的IP地址为某一地址范围,则只能同时取消该地址范围内所有IP地址的配置,不能单独取消其中某个IP地址的配置。
# 配置10.110.1.1到10.110.1.63之间的IP地址不参与地址自动分配。
[Sysname] dhcp server forbidden-ip 10.110.1.1 10.110.1.63
· forbidden-ip
· static-bind
dhcp server multi-ip per-mac enable命令用来开启为MAC地址相同的DHCP客户端分配不同IP地址功能。
undo dhcp server multi-ip per-mac enable命令用来关闭为MAC地址相同的DHCP客户端分配不同IP地址功能。
为MAC地址相同的DHCP客户端分配不同IP地址功能处于关闭状态。
如果DHCP服务器已经为客户端分配IP地址,则不允许开启或关闭本功能,否则DHCP服务器会报错。
本命令与dhcp session-mismatch action命令互斥。
# 开启为MAC地址相同的DHCP客户端分配不同IP地址功能。
[Sysname] dhcp server multi-ip per-mac enable
dhcp server ping packets命令用来配置DHCP服务器发送ICMP回显请求报文的最大数目。
undo dhcp server ping packets命令用来恢复缺省情况。
DHCP服务器发送ICMP回显请求报文的最大数目为1。
number:发送ICMP回显请求报文的最大数目,取值范围为0~10。0表示DHCP服务器将IP地址分配给DHCP客户端之前,不会通过ping操作探测该地址是否冲突。
DHCP服务器的地址探测是通过ping功能实现的,通过检测是否能在指定时间内得到ping响应来判断是否存在地址冲突。DHCP服务器发送目的地址为待分配地址的ICMP回显请求报文。如果在指定时间内收到ICMP回显响应报文,则认为存在地址冲突。DHCP服务器从IP地址池中选择新的IP地址,并重复上述操作。如果在指定时间内未收到ICMP回显响应报文,则继续发送ICMP回显请求报文,直到发送的ICMP回显请求报文数目达到本命令配置的最大值。如果仍然未收到ICMP回显响应报文,则将地址分配给客户端,从而确保客户端获得的IP地址唯一。
# 配置DHCP服务器最多发送10个ICMP回显请求报文。
[Sysname] dhcp server ping packets 10
· dhcp server ping timeout
· display dhcp server conflict
· reset dhcp server conflict
dhcp server ping timeout命令用来配置DHCP服务器等待ICMP回显响应报文的超时时间。
undo dhcp server ping timeout命令用来恢复缺省情况。
DHCP服务器等待ICMP回显响应报文的超时时间为500毫秒。
milliseconds:等待ICMP回显响应报文的超时时间,取值范围是0~10000,单位为毫秒。0表示DHCP服务器将IP地址分配给DHCP客户端之前,不会通过ping操作探测该地址是否冲突。
DHCP服务器的地址探测是通过ping功能实现的,通过检测是否能在指定时间内得到ping响应来判断是否存在地址冲突。DHCP服务器发送目的地址为待分配地址的ICMP回显请求报文。如果在本命令指定的时间内收到ICMP回显响应报文,则认为存在地址冲突。DHCP服务器从IP地址池中选择新的IP地址,并重复上述操作。如果在指定时间内未收到ICMP回显响应报文,则继续发送ICMP回显请求报文,直到发送的回显请求报文数目达到最大值。如果仍然未收到ICMP回显响应报文,则将地址分配给客户端,从而确保客户端获取的IP地址唯一。
# 配置DHCP服务器等待ICMP回显响应报文的超时时间为1000毫秒。
[Sysname] dhcp server ping timeout 1000
· dhcp server ping packets
dhcp server policy-first enable命令用来为IPoE用户优先选择DHCP策略关联的IP地址池。
undo dhcp server policy-first enable命令用来恢复缺省情况。
设备为IPoE用户选择授权地址池。
三层以太网接口视图
三层以太网子接口视图
三层聚合接口视图
三层聚合子接口视图
管理员需要在IPoE用户上线前就确定好地址分配方式,当IPoE用户上线后再修改IP地址池选择方式,已经分配的地址租约无法正常续约。当IPoE用户的IP地址租约到期后,IPoE用户会下线,IPoE会删除该用户会话。
# 在接口Ten-GigabitEthernet3/0/1配置为IPoE用户优先选择DHCP策略关联的IP地址池。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp server policy-first enable
· authorization-attribute(BRAS业务命令参考/AAA)
dhcp server relay information enable命令用来配置DHCP服务器处理Option 82。
undo dhcp server relay information enable命令用来配置DHCP服务器忽略Option 82。
DHCP服务器处理Option 82。
当DHCP服务器收到含有Option 82的报文时,如果DHCP服务器处理Option 82,则将请求报文中的Option 82原样复制到应答报文中;如果DHCP服务器忽略Option 82,则不会在应答报文中携带Option 82。
# 配置DHCP服务器忽略Option 82。
[Sysname] undo dhcp server relay information enable
dhcp server reply-exclude-option60命令用来配置DHCP服务器发送DHCP应答报文时不携带Option 60选项。
undo dhcp server reply-exclude-option60命令用来恢复缺省情况。
DHCP服务器发送DHCP应答报文时可以携带Option 60选项。
如果开启不携带Option 60选项功能,则无论收到的DHCP报文中是否携带Option 60选项,也无论IP地址池中是否配置Option 60选项,DHCP应答报文都不携带Option 60选项。
如果关闭不携带功能,当收到的DHCP报文携带Option 60选项或IP地址池中已配置Option 60选项,则DHCP应答报文携带Option 60选项,否则DHCP应答报文不携带Option 60选项。
# 配置DHCP服务器发送DHCP应答报文时不携带Option 60选项。
[Sysname] dhcp server reply-exclude-option60
dhcp server request-ip-address check命令用来配置当DHCP客户端请求的新地址与之前DHCP服务器分配的地址不同或该地址对应的租约不存在时,DHCP服务器回复NAK报文。
undo dhcp server request-ip-address check命令用来恢复缺省情况。
当DHCP客户端请求的新地址与之前使用的地址不同或该地址对应的租约不存在时,DHCP服务器不回复NAK报文。
未开启本功能时,如果DHCP客户端请求的新地址与之前使用的地址不同或该地址对应的租约不存在时,DHCP服务器不回复应答报文。当DHCP服务器上保存的地址租约到期后,DHCP服务器才会应答DHCP客户端的请求并分配新的IP地址。
开启本功能时,如果DHCP客户端请求的新地址与之前使用的地址不同或该地址对应的租约不存在时,DHCP服务器直接回复NAK报文拒绝DHCP客户端的地址请求,DHCP客户端收到NAK报文后,重新申请IP地址。
# 配置当DHCP客户端请求的新地址与之前使用的地址不同或该地址对应的租约不存在时,DHCP服务器直接回复NAK报文的功能。
[Sysname] dhcp server request-ip-address check
· dhcp select server
display dhcp pool-group-usage命令用来显示IP地址池组的使用率。
display dhcp pool-group-usage [ pool-group pool-group-name ]
pool-group pool-group-name:显示指定IP地址池组的使用率。pool-group-name表示IP地址池组名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有IP地址池组的使用率。
# 显示所有IP地址池组的使用率。
<Sysname> display dhcp pool-group-usage
Pool group name Total Used Utilization(%)
poolgroup1 91 1 1.10%
poolgroup2 245 1 0.41%
# 显示IP地址池组poolgroup1的使用率。
<Sysname> display dhcp pool-group-usage pool-group poolgroup1
表1-4 display dhcp pool-group-usage命令显示信息描述表
Pool group name |
地址池组名称 |
Total |
地址池组中的地址总数 |
Used |
已分配的地址总数 |
Utilizaiton(%) |
地址池组的使用率,单位为百分比 |
display dhcp pool-usage命令用来显示IP地址池的使用率。
display dhcp pool-usage [ peak ] [ pool pool-name ]
peak:显示IP地址池使用率的历史峰值。历史峰值指的是从创建地址池到执行本命令期间,IP地址池使用率的最大值。如果不指定本参数,则显示执行本命令时IP地址池的使用率。
pool pool-name:显示指定IP地址池的使用率。pool-name表示IP地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有IP地址池的使用率。
IP地址池地址使用率=(总地址数—未分配地址数)/总地址数,未分配地址数可通过display dhcp server statistics命令中的“Free IP addresses”字段查看。
如果IP地址池使用率的历史峰值在多个时间点出现,则执行display dhcp pool-usage peak命令后显示为最早出现的时间。
# 显示所有IP地址池的使用率。
<Sysname> display dhcp pool-usage
Pool name Total Used Utilization(%)
pool1 91 1 1.10%
pool2 245 1 0.41%
# 显示IP地址池pool1的使用率。
<Sysname> display dhcp pool-usage pool pool1
pool1 91 1 1.10%
# 显示所有IP地址池使用率的历史峰值。
<Sysname> display dhcp pool-usage peak
Pool name Peak utilization(%) Time
pool1 1.10% Mar 11 07:22:43 2021
pool2 0.41% Mar 11 07:22:43 2021
# 显示IP地址池pool1使用率的历史峰值。
<Sysname> display dhcp pool-usage peak pool pool1
pool1 1.10% Mar 11 07:23:02 2021
表1-5 display dhcp pool-usage命令显示信息描述表
Pool name |
IP地址池名称 |
Total |
IP地址池中的地址总数 |
Used |
已分配的地址总数 |
Utilization(%) |
IP地址池的使用率,单位为百分比 |
Peak utilization(%) |
IP地址池使用率历史峰值,单位为百分比 |
Time |
IP地址池使用率达到历史峰值的时间,单位为MM-DD hh:mm:ss YYYY,其中MM为月,DD为日,hh为小时,mm为分钟,ss为秒,YYYY为年 |
· reset dhcp pool-usage peak
display dhcp server conflict命令用来显示DHCP的地址冲突信息。
display dhcp server conflict [ interface interface-type interface-number | ip ip-address | vxlan vxlan-id ] [ vpn-instance vpn-instance-name ]
interface:显示指定接口的地址冲突信息。
ip ip-address:显示指定IP地址的地址冲突信息。
vxlan vxlan-id:显示指定VXLAN内的地址冲突信息,vxlan-id的取值范围为0~16777215。
DHCP服务器在下列几种情况下会生成地址冲突信息:
· DHCP服务器在为客户端分配IP地址前,通过ping操作检测到网络中已有主机使用该地址。
· DHCP客户端向DHCP服务器发送Decline报文,报告DHCP服务器为其分配的地址存在冲突。
· DHCP服务器检测到IP地址池内的可供分配的地址是设备自身的地址。
如果未指定任何参数,则显示所有的DHCP地址冲突信息。
# 显示所有的地址冲突信息。
<Sysname> display dhcp server conflict
IP address Detect time
4.4.4.1 Apr 25 16:57:20 2019
4.4.4.2 Apr 25 17:00:10 2019
表1-6 display dhcp server conflict命令显示信息描述表
IP address |
发生冲突的IP地址。(*)表示该地址为可重用的冲突IP地址 |
Detect time |
检测到冲突的时间 |
display dhcp server database命令用来显示DHCP服务器的表项备份信息。
# 显示DHCP服务器的表项备份信息。
<Sysname> display dhcp server database
File name : database.dhcp
Username :
Password :
Update interval : 600 seconds
Latest write time : Feb 8 16:09:53 2014
Status : Last write succeeded.
表1-7 display dhcp server database命令显示信息描述表
File name |
存储DHCP服务器表项的文件名称 |
Username |
配置远程目标文件时的用户名 |
Password |
配置远程目标文件时的密码,有配置时显示为”******” |
Update interval |
定期刷新表项存储文件的刷新时间间隔,单位为秒 |
Latest write time |
最近一次写文件的时间 |
Status |
写文件的状态,即写文件是否成功 · Writing:正在写文件 · Last write succeeded.:上一次写文件成功 · Last write failed.:上一次写文件失败 |
display dhcp server expired命令用来显示租约过期的地址绑定信息。
display dhcp server expired [ [ interface interface-type interface-number | ip ip-address | mac mac-address | vxlan vxlan-id ] [ vpn-instance vpn-instance-name ] | pool pool-name ] [ verbose ]
interface interface-type interface-number:显示指定接口的租约过期地址绑定信息。
ip ip-address:显示指定IP地址的租约过期地址绑定信息。
mac mac-address:显示指定MAC地址的租约过期绑定信息。
vxlan vxlan-id:显示指定VXLAN内的租约过期地址绑定信息,vxlan-id的取值范围为0~16777215。
pool pool-name:显示指定IP地址池中租约过期的地址绑定信息。pool-name表示IP地址池名称,为1~63个字符的字符串,不区分大小写。
verbose:显示租约过期地址绑定详细信息。如果未指定本参数,则显示所有IP地址的租约过期地址绑定信息。
在IP地址池的可用地址分配完后,租约过期的地址将被分配给DHCP客户端。
如果未指定任何参数,则显示所有的租约过期的地址绑定信息。
# 显示所有租约过期的地址绑定信息。
<Sysname> display dhcp server expired
IP address Client-identifier/Hardware address Lease expiration
4.4.4.6 3030-3066-2e65-3230-302e-3130-3234 Apr 25 17:10:47 2019
-2d45-7468-6572-6e65-7430-2f31
表1-8 display dhcp server expired命令显示信息描述表
IP address |
租约过期的IP地址 |
Client-identifier/Hardware address |
租约过期的客户端ID或MAC地址 |
Lease expiration |
租约过期的时间 |
# 显示所有租约过期的地址的详细绑定信息。
<Sysname> display dhcp server expired verbose
IP address: 192.168.56.3
Pool name: 1
Client-identifier: N/A
Hardware address type: Ethernet
Hardware address: 0000-0000-0002
Lease expiration: Mar 16 16:00:22 2017
Remaining reservation time: 136 years 2 months 6 hours 28 minutes 11 seconds
IP address reservation mode: Based on client MAC
IP address: 5.5.5.5
Pool name: 2
Client-identifier: 0061-6161-612e-6161-6161-2e61-6161-612d-4745-302f-302f-33
Hardware address: 0000-0000-0003
Lease expiration: Mar 16 16:00:33 2017
Remaining reservation time: 136 years 2 months 6 hours 28 minutes 22 seconds
IP address reservation mode: Based on client ID
IP address: 3.3.3.5
Pool name: abc
Client-identifier: 0100-0000-0000-05
Hardware address: 0000-0000-0005
Lease expiration: Mar 16 16:10:33 2017
Remaining reservation time: 2 months 6 hours 27 minutes 22 seconds
表1-9 display dhcp server expired verbose命令显示信息描述表
IP address |
租约过期的IP地址 |
Pool name |
租约所在的IP地址池 |
Client-identifier |
租约过期的客户端ID,取值为N/A时表示DHCP请求报文未携带Option61信息 |
Hardware address type |
硬件地址类型,取值包括: · Ethernet:以太网 · Token ring:令牌环网 · Unknown:未知组网 |
Hardware address |
硬件地址 |
Lease expiration |
租约过期的时间 |
Remaining reservation time |
租约保留剩余时间,取值为0该时表示IP地址池内保留老化租约正在删除 |
IP address reservation mode |
保留IP地址的类型,取值包括: · Based on client ID:按客户端ID保留 · Based on client MAC:按MAC地址保留 |
· reserve expired-ip enable
· reset dhcp server expired
display dhcp server free-ip命令用来显示IP地址池的空闲地址信息,即尚未分配给DHCP客户端的IP地址信息。
pool pool-name:显示指定IP地址池的空闲地址信息。pool-name表示IP地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有IP地址池的空闲地址信息。
# 显示所有IP地址池的空闲地址信息。
<Sysname> display dhcp server free-ip
Pool name: 1
Network: 10.0.0.0 mask 255.0.0.0
IP ranges from 10.0.0.10 to 10.0.0.100
IP ranges from 10.0.0.105 to 10.0.0.255
Secondary networks:
10.1.0.0 mask 255.255.0.0
IP ranges from 10.1.0.0 to 10.1.0.255
10.2.0.0 mask 255.255.0.0
IP Ranges from 10.2.0.0 to 10.2.0.255
Pool name: 2
Network: 20.1.1.0 mask 255.255.255.0
IP ranges from 20.1.1.0 to 20.1.1.255
表1-10 display dhcp server free-ip命令显示信息描述表
Pool name |
IP地址池的名称 |
Network |
可分配的地址网段 |
IP ranges |
可分配的地址范围 |
Secondary networks |
可分配的从地址网段 |
· address range
· ip pool
· network
display dhcp server ip-in-use命令用来显示DHCP地址绑定信息。
display dhcp server ip-in-use [ [ interface interface-type interface-number | ip ip-address | subnet network-address mask-length | vxlan vxlan-id ] [ vpn-instance vpn-instance-name ] | pool pool-name | pool-group pool-group-name ]
interface:显示指定接口的地址绑定信息。
ip ip-address:显示指定IP地址的地址绑定信息。
subnet network-address mask-length:显示指定子网段内的地址绑定信息。
vxlan vxlan-id:显示指定VXLAN内的地址绑定信息,vxlan-id的取值范围为0~16777215。
pool pool-name:显示指定IP地址池的地址绑定信息。pool-name表示IP地址池名称,为1~63个字符的字符串,不区分大小写。
pool-group pool-group-name:显示指定IP地址池组的地址绑定信息。pool-group-name表示IP地址池组名称,为1~63个字符的字符串,不区分大小写。
如果未指定任何参数,则显示所有IP地址的地址绑定信息。
当DHCP服务器作为DHCP客户端的网关设备时,DHCP服务器上记录的该DHCP客户端的地址绑定信息才会提供给其他安全特性使用。
需要注意的是,如果租约的截止时间超过2100年,则显示为After 2100。
# 显示所有DHCP地址绑定信息。
<Sysname> display dhcp server ip-in-use
IP address Client-identifier/ Lease expiration Type
Hardware address
10.1.1.1 4444-4444-4444 Not used Static(F)
10.1.1.2 0030-3030-2e30-3030- May 1 14:02:49 2015 Auto(C)
662e-3030-3033-2d45-
7468-6572-6e65-74
10.1.1.3 0133-3037-392e-3933- May 1 14:18:22 2016 Auto(C)
3037-2e39-3030-32
10.1.1.4 1111-1111-1111 After 2100 Static(C)
# 显示指定地址10.1.1.2的地址绑定信息。
<Sysname> display dhcp server ip-in-use ip 10.1.1.2
IP address: 10.1.1.2/24
Giaddr: 10.1.1.10
Gateway: 10.1.1.1
Client identifier/Hardware address: 3030-3030-2e30-3030-662e-3030-3033-2d45-7468
-6572-6e65-74
Lease expiration: May 1 14:02:49 2015
Type: Auto(C)
Client access interface: XGE3/0/1
Outer VLAN: N/A
Inner VLAN: N/A
User ID: 0x3fffff
表1-11 display dhcp server ip-in-use命令显示信息描述表
IP address |
分配给DHCP客户端的IP地址及掩码长度 |
Giaddr |
DHCP客户端发出请求报文后经过的第一跳DHCP中继的IP地址 |
Gateway |
默认网关 |
客户端ID或客户端的硬件地址。客户端ID使用指定十六进制字符串,通常前两位代表硬件类型,如00表示无类型使用ASCII字符串;01为以太网;06为令牌环网 当DHCP服务器作为接入设备时,用户租约信息下记录的客户端ID固定为用户类型与客户端MAC地址生成的值,而非客户端真实的ID |
Lease expiration |
租约到期时间,取值包括: · 具体的时间值(如May 1 14:02:49 2015):表示租约在该时间到期 · Not used:表示静态绑定的地址尚未分配给特定客户端 · Unlimited:表示租约为无限长 · After 2100:表示租约过期时间超过2100年 |
Type |
地址绑定的类型,取值包括: · Static(F):表示尚未分配给客户端的静态绑定,即静态无效绑定 · Static(O):服务器从IP地址池选择静态绑定的IP地址,并发送DHCP-OFFER报文为客户端提供该IP地址后产生该类型的地址绑定信息,即静态临时绑定 · Static(C):表示已经分配给客户端的静态绑定,即静态正式绑定 · Auto(O):表示动态绑定的临时租约,即从IP地址池中动态选择IP地址,并发送DHCP-OFFER报文为客户端提供该IP地址后,产生的租约 · Auto(C):表示动态绑定的正式租约,即从IP地址池中动态选择IP地址,并发送DHCP-ACK报文成功将该IP地址分配给客户端后,产生的租约 |
Client access interface |
连接DHCP客户端的接口信息 |
Outer VLAN |
DHCP请求报文的外层VLAN。如果不存在外层VLAN,则显示为N/A |
Inner VLAN |
DHCP请求报文的内层VLAN。如果不存在内层VLAN,则显示为N/A |
User ID |
DHCP接入用户标识值,如果不存在用户标识值,则显示N/A |
display dhcp server packet statistics命令用来显示DHCP服务器的报文统计信息。
display dhcp server packet statistics [ vpn-instance vpn-instance-name ]
# 显示DHCP服务器的报文统计信息。
<Sysname> display dhcp server packet statistics
Messages received: 0
DHCPDISCOVER: 0
DHCPREQUEST: 0
DHCPDECLINE: 0
DHCPRELEASE: 0
DHCPINFORM: 0
BOOTPREQUEST: 0
ODAP DHCPOFFER: 0
ODAP DHCPACK: 0
ODAP DHCPNAK: 0
ODAP DHCPDISCOVER: 0
ODAP DHCPREQUEST: 0
ODAP DHCPRELEASE: 0
ODAP DHCPDECLINE: 0
ODAP DHCPFORCERENEW: 0
ODAP CPADDRESS: 0
Messages sent: 0
DHCPOFFER: 0
DHCPACK: 0
DHCPNAK: 0
BOOTPREPLY: 0
ODAP DHCPOFFER: 0
ODAP DHCPACK: 0
ODAP DHCPNAK: 0
ODAP DHCPREQUEST: 0
ODAP DHCPRELEASE: 0
ODAP DHCPDECLINE: 0
Bad Messages: 0
表1-12 display dhcp server packet statistics命令显示信息描述表
Messages received |
DHCP服务器接收到DHCP客户端发送的报文数。DHCP报文类型如下: · DHCPDISCOVER · DHCPREQUEST · DHCPDECLINE · DHCPRELEASE · DHCPINFORM · BOOTPREQUEST · ODAP DHCPOFFER · ODAP DHCPACK · ODAP DHCPNAK · ODAP DHCPDISCOVER · ODAP DHCPREQUEST · ODAP DHCPRELEASE · ODAP DHCPDECLINE · ODAP DHCPFORCERENEW |
Messages sent |
DHCP服务器发给DHCP客户端的报文数。DHCP报文类型如下: · DHCPOFFER · DHCPACK · DHCPNAK · BOOTPREPLY · ODAP DHCPOFFER · ODAP DHCPACK · ODAP DHCPNAK · ODAP DHCPDISCOVER · ODAP DHCPREQUEST · ODAP DHCPRELEASE · ODAP DHCPDECLINE · ODAP DHCPFORCERENEW |
Bad Messages |
错误报文数 |
display dhcp server statistics命令用来显示DHCP服务器的统计信息。
pool pool-name:显示指定IP地址池的统计信息。pool-name表示IP地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有IP地址池的统计信息。
# 显示DHCP服务器的统计信息。
<Sysname> display dhcp server statistics
Pool number: 10
Pool utilization: 0.08%
Bindings:
Automatic: 300
Manual: 1
Expired: 0
Reserve: 0
Conflicts: 0
# 显示IP地址池pool1的统计信息。
<Sysname> display dhcp server statistics pool pool1
Total IP addresses: 256
Free IP addresses: 100
Used: 155
Pool utilization: 60.78%
Bindings:
Automatic: 155
Manual: 1
Expired: 0
Reserve: 0
Conflicts: 0
表1-13 display dhcp server statistics命令显示信息描述表
Pool number |
IP地址池的数目,显示指定IP地址池的统计信息时无此字段 |
Total IP addresses |
IP地址池中的地址总数 |
Free IP addresses |
空闲地址总数 |
Used |
已分配的地址总数 |
Pool utilization |
IP地址池的利用率 |
Bindings |
各种状态的地址绑定数,包括: · Automatic:动态分配的IP地址数 · Manual:手工绑定的IP地址数 · Expired:租约过期的IP地址数 · Reserve:预留的IP地址数 |
Conflicts |
冲突地址数 |
· reset dhcp server statistics
display dhcp-access count命令用来显示DHCP接入用户的数量。
可以通过display dhcp-access user-table命令查看DHCP接入用户的表项信息。
# 显示设备上DHCP接入用户的数量。
<Sysname> display dhcp-access count
Total access-user count: 20
表1-14 display dhcp-access count命令显示信息描述表
Total access-user count |
DHCP接入用户数 |
· display dhcp-access user-table
display dhcp-access packet statistics命令用来显示DHCP接入模块的报文统计信息。
# 显示DHCP接入模块的报文统计信息。
<Sysname> display dhcp-access packet statistics
Received packets
Received from clients : 0
DHCPDISCOVER : 0
DHCPREQUEST : 0
DHCPDECLINE : 0
DHCPRELEASE : 0
DHCPINFORM : 0
Received from servers : 0
DHCPOFFER : 0
DHCPACK : 0
DHCPNAK : 0
Sent packets
Send to clients : 0
DHCPOFFER : 0
DHCPACK : 0
DHCPNAK : 0
Send to servers : 0
DHCPDISCOVER : 0
DHCPREQUEST : 0
DHCPDECLINE : 0
DHCPRELEASE : 0
表1-15 display dhcp-access packet statistics命令显示信息描述表
Received packets |
收到的报文统计信息 |
Received from clients |
收到DHCP客户端发送的报文数 |
DHCPDISCOVER |
收到的DHCP-DISCOVER报文数 |
DHCPREQUEST |
收到的DHCP-REQUEST报文数 |
DHCPDECLINE |
收到的DHCP-DECLINE报文数 |
DHCPRELEASE |
收到的DHCP-RELEASE报文数 |
DHCPINFORM |
收到的DHCP-INFORM报文数 |
Received from servers |
收到DHCP服务器发送的报文数 |
DHCPOFFER |
收到的DHCP-OFFER报文数 |
DHCPACK |
收到的DHCP-ACK报文数 |
DHCPNAK |
收到的DHCP-NAK报文数 |
Sent packets |
发送的报文统计信息 |
Send to clients |
发送给DHCP客户端的报文数 |
DHCPOFFER |
发送的DHCP-OFFER报文数 |
DHCPACK |
发送的DHCP-ACK报文数 |
DHCPNAK |
发送的DHCP-NAK报文数 |
Send to servers |
发送给DHCP服务器的报文数 |
DHCPDISCOVER |
发送的DHCP-DISCOVER报文数 |
DHCPREQUEST |
发送的DHCP-REQUEST报文数 |
DHCPDECLINE |
发送的DHCP-DECLINE报文数 |
DHCPRELEASE |
发送给DHCP-RELEASE报文数 |
· reset dhcp-access packet statistics
display dhcp-access user-table命令用来显示DHCP接入用户的信息。
display dhcp-access user-table [ index index-value | mac-address mac-address | user-id user-id ]
index index-value:显示指定索引的DHCP接入用户的信息。index-value为接入用户索引,取值范围是1~4294967294。
mac-address mac-address:显示指定MAC地址的DHCP接入用户的信息。mac-address为MAC地址,格式为H-H-H。
user-id user-id:显示指定用户标识值的DHCP接入用户的信息。user-id为用户标识值,取值范围是1~fffffffe,不区分大小写。
如果未指定任何参数,则显示的是设备上所有DHCP接入用户的信息。
# 显示所有DHCP接入用户信息。
<Sysname> display dhcp-access user-table
DHCP-ACCESS-USER-INFO-BRIEF(Total:3)
User ID : 0x40000001
User index : 1
Interface : Ten-GigabitEthernet3/0/1
SVLAN : N/A
CVLAN : N/A
User MAC address : 0000-0000-0007
User state : ONLINE
VPN instance : N/A
User IP address : 10.1.1.254/24
Renew time : 43200 seconds
Rebind time : 75600 seconds
Gateway : 10.1.1.1
Primary DNS server : 10.1.1.2
Second DNS server : N/A
Address pool name : test_dhcp
Option60 string : N/A
Client ID : 0032387
User ID : 0x40000002
User index : 2
SVLAN : N/A
CVLAN : N/A
User MAC address : 0000-0000-0008
User state : ONLINE
VPN instance : N/A
User IP address : 10.1.1.200/24
Gateway : 10.1.1.1
Client ID : 003238671
User ID : 0x13
User index : 13
SVLAN : N/A
CVLAN : N/A
User MAC address : 0010-9400-0005
User state : WAIT-SERVER-OFFER
VPN instance : N/A
User IP address : 0.0.0.0
Gateway : N/A
Primary DNS server : N/A
Address pool name : ipoe
Client ID : 003238612
User entry aging time : Mar 4 15:38:14 2021
# 显示MAC地址为0050-ba50-7349的DHCP接入用户信息。
<Sysname> display dhcp-access user-table mac-address 0050-ba50-7349
User index : 2
SVLAN : N/A
CVLAN : N/A
User MAC address : 0050-ba50-7349
User state : ONLINE
VPN instance : N/A
Gateway : N/A
Address pool name : 1
Option60 String : N/A
Client ID : 010050ba507349
表1-16 display dhcp-access user-table命令显示信息描述表
DHCP-ACCESS-USER-INFO-BRIEF |
DHCP接入用户信息表项数 |
User ID |
DHCP接入用户标识值,为十六进制数 |
User index |
DHCP接入用户索引值,为十进制数 |
DHCP用户上线的接口 |
SVLAN |
DHCP接入用户所在的外层VLAN,如果用户不属于某个VLAN,则显示为“N/A” |
CVLAN |
DHCP接入用户所在的内层VLAN,如果用户不属于某个VLAN,则显示为“N/A” |
User MAC address |
DHCP接入用户的MAC地址 |
User state |
DHCP接入用户的状态,取值包括: · INIT:初始化 · WAIT_UCM_REQ_ACK:等待UCM回应确认 · WAIT_SERVER_OFFER:等待DHCP服务器应答DHCP-OFFER报文 · WAIT_CLIENT_REQ:等待DHCP客户端发送DHCP-REQUEST报文 · WAIT_UCM_UP_ACK:DHCP通知UCM接入用户的租约信息,等待UCM回应确认 · ONLINE:在线状态 · WAIT_UCM_DOWN_ACK:DHCP通知UCM释放接入用户的租约,等待UCM回应确认 · RENEW_WAIT_SERVER_REPLY:收到续约报文等待DHCP服务器回应DHCP-ACK报文 · WAIT_SERVER_ACK:等待DHCP服务器回应DHCP-ACK报文 |
VPN instance |
DHCP接入用户所在的VPN信息,如果处于公网,则显示为“N/A” |
User IP address |
DHCP接入用户获取的IP地址及掩码长度 |
Renew time |
续约时间 |
Rebind time |
重绑定时间 |
Gateway |
默认网关 |
Primary DNS server |
主DNS服务器 |
Second DNS server |
备DNS服务器 |
Address pool name |
为DHCP接入用户分配地址的IP地址池的名称 |
User entry aging time |
用户信息表项的老化时间。格式为MM DD hh:mm:ss:xxx YYYY,其中MM为月,DD为日,hh为小时,mm为分钟,ss为秒,YYYY为年。老化时间超时后,DHCP服务器将删除该用户信息表项。User state为ONLINE时,不会显示该字段 |
Option60 String |
厂商信息字符串,如果不存在Option60,则显示为N/A |
Client ID |
客户端标识 |
display ip pool命令用来显示查看IP地址池信息。
display ip pool [ all | name pool-name | pool-group pool-group-name | [ vpn-instance vpn-instance-name ] [ bas { local | remote } ] ] [ verbose ]
所有视图
all:显示所有的IP地址池的信息。包括公网和所有VPN实例中的IP地址池信息。
name pool-name:显示指定IP地址池的信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。
pool-group pool-group-name:显示IP地址池所属的IP地址池组的信息。pool-group-name表示地址池组名称,为1~63个字符的字符串,不区分大小写。
bas{ local | remote }:显示BAS IP地址池信息。local表示显示本地BAS IP地址池信息,remote表示显示远端BAS IP地址池信息。
verbose:显示IP地址池的详细信息。如果未指定本参数,则显示IP地址池的简要信息。
如果未指定bas参数,则只显示普通IP地址池信息。
# 显示所有DHCP普通IP地址池的简要信息。
<Sysname> display ip pool
Pool name: 0 (lock strict)
Pool index: 1
network 20.1.1.0 mask 255.255.255.0
undo exhaustion log enable
exhaustion trap enable
route-log enable
dhcp-server nak-count 10
class a range 20.1.1.50 20.1.1.60
bootfile-name abc.cfg
dns-list 20.1.1.66 20.1.1.67 20.1.1.68
domain-name www.aabbcc.com
bims-server ip 192.168.0.51 sharekey cipher $c$3$K13OmQPi791YvQoF2Gs1E+65LOU=
option 2 ip-address 1.1.1.1
expired day 1 hour 2 minute 3 second 0
reserve expired-ip mode client-id time 4294967295 limit 256000
ip-in-use threshold 100
Pool name: 1
Pool index: 2
route-log enable
secondary networks:
20.1.2.0 mask 255.255.255.0
20.1.3.0 mask 255.255.255.0
bims-server ip 192.168.0.51 port 50 sharekey cipher $c$3$K13OmQPi791YvQoF2Gs1E+65LOU=
forbidden-ip 20.1.1.22 20.1.1.36 20.1.1.37
forbidden-ip 20.1.1.22 20.1.1.23 20.1.1.24
forbidden-ip-range 20.1.1.50 20.1.2.55
gateway-list 1.1.1.1 2.2.2.2 4.4.4.4
nbns-list 5.5.5.5 6.6.6.6 7.7.7.7
netbios-type m-node
expired day 1 hour 0 minute 0 second 0 allow-hint
reserve expired-ip disable
Pool name: 2
Pool index: 3
undo exhaustion trap enable
route-log enable
address range 20.1.1.1 to 20.1.1.15
class departmentA range 20.1.1.20 to 20.1.1.29
class departmentB range 20.1.1.30 to 20.1.1.40
next-server 20.1.1.33
tftp-server domain-name www.example.org.cn
tftp-server ip-address 192.168.0.120
voice-config ncp-ip 10.1.1.2
voice-config as-ip 10.1.1.5
voice-config voice-vlan 3 enable
voice-config fail-over 10.1.1.1 123*
option 2 ip-address 1.1.1.3
reserve expired-ip mode mac time 100 limit 100
Pool name: 3
Pool index: 4
route-log enable
expired unlimited
static bindings:
ip-address 10.10.1.2 mask 255.0.0.0
hardware-address 00e0-00fc-0001 ethernet
ip-address 10.10.1.3 mask 255.0.0.0
client-identifier aaaa-bbbb
# 显示本地BAS IP地址池的简要信息。
<Sysname> display ip pool bas local
Pool name: 10
Pool index: 5
route-log enable
gateway 11.1.1.0 mask 255.255.255.0
class a range 11.1.1.50 20.1.1.60
dns-list 11.1.1.66 20.1.1.67 11.1.1.68
unr tag 100
表1-17 display ip pool命令显示信息描述表
Pool name (lock strict) |
IP地址池的名称,锁定状态取值包括: · lock:该IP地址池被锁定,不会为新的DHCP客户端分配地址,但会应答已在线客户端的地址续约需求 · lock strict:该IP地址池被锁定,既不会为新的DHCP客户端分配地址,也不会应答已在线客户端的地址续约需求 若IP地址池未锁定,则无锁定状态信息 |
Pool index |
IP地址池索引 |
gateway |
BAS地址池网关的IP地址和网络掩码 |
network |
可分配的地址网段 |
exhaustion log enable |
地址池地址资源耗尽或资源恢复时生成日志信息的功能处于开启状态。地址池地址资源耗尽或资源恢复时生成日志信息的功能关闭时,本字段显示为“undo exhaustion log enable” |
undo exhaustion trap enable |
地址池资源耗尽告警功能处于关闭状态。地址池资源耗尽告警功能处于开启时,本字段显示为“exhaustion trap enable” |
route-log enable |
IP地址池路由日志功能处于开启状态。地址池路由日志功能关闭时,本字段显示为“undo route-log enable” |
dhcp-server nak-count |
DHCP中继允许接收DHCP-NAK报文的最大个数 |
secondary networks |
可分配的从地址网段 |
ip-address mask mask |
从网段的地址段、掩码 |
address range |
可分配的地址范围 |
class class-name range |
为指定DHCP用户类分配的地址范围 |
static bindings |
静态绑定的IP地址、硬件地址或客户端ID |
unr tag |
网段路由标记值 |
option |
自定义的DHCP选项 |
expired |
租约期限,其后数值的单位分别为天、小时、分钟和秒。例如,expired day 1 hour 2 minute 3 second 4表示租约期限为1天2小时3分钟4秒;unlimited表示租约期限为无限长;allow-hint表示允许与客户端协商决定租约期限 |
remote server |
远端BAS IP地址池对应的DHCP服务器地址,当在DHCP中继创建远端BAS IP地址池并执行remote-server命令后,会显示本字段 |
active remote server |
当前活跃的DHCP服务器地址,当在DHCP中继创建远端BAS IP地址池并执行remote-server命令后,会显示本字段。取值包括: · 如果显示为all,表示当前配置的DHCP服务器选择方式为polling,即DHCP中继同时向所有DHCP服务器转发DHCP请求报文 · 如果显示为IP地址,则表示当前配置的DHCP服务器选择方式为master-backup,该地址为当前活跃的DHCP服务器地址,即DHCP中继向该地址对应的DHCP服务器转发DHCP请求报文 |
remote server pool status |
远端BAS IP地址池状态,取值包括: · Available:存在可分配的IP地址 · Unavailable:不存在可分配的IP地址 |
bootfile-name |
为DHCP客户端分配的启动文件名 |
dns-list |
为DHCP客户端分配的DNS服务器地址 |
domain-name |
为DHCP客户端分配的域名后缀 |
bims-server |
为DHCP客户端分配的BIMS服务器信息 |
forbidden-ip |
IP地址池中不参与自动分配的IP地址 |
forbidden-ip-range |
IP地址池中不参与自动分配的IP地址段 |
gateway mask |
IP地址池的网关IP地址和网络掩码 |
ip-in-use threshold |
IP地址池地址使用率告警门限阈值,单位为百分比 |
reserve expired-ip |
预留老化地址 |
reserve expired-ip mode client-id time 4294967295 limit 256000 |
预留老化地址租约类型,预留时间和预留地址上限 |
sub-networks |
子网网段 |
export-route |
网段路由下发给路由管理 |
preference |
下发给路由管理的网段路由的优先级 |
tag |
下发给路由管理的网段路由的标记值 |
# 显示所有DHCP普通IP地址池的详细信息。
<Sysname> display ip pool verbose
Pool name: pool1 (lock strict)
Pool index: 1
Pool-group-name:
group1
Network: 10.1.1.0 mask 255.255.255.0
route-log enable
IP address statistics
Total IP addresses: 254
Free IP addresses: 254
Used: 0
Pool utilization: 0.00%
Bindings:
Automatic: 0
Manual: 0
Expired: 0
Reserve: 0
Conflicts: 0
Total sub-networks: 0
Pool name: pool2
Pool-group-name:
group1
Network: 10.2.1.0 mask 255.255.255.0
route-log enable
Used: 0
Bindings:
Automatic: 0
Manual: 0
Expired: 0
Reserve: 0
Conflicts: 0
表1-18 display ip pool verbose命令显示信息描述表
IP地址池的名称,IP地址池锁定状态取值包括: · lock:该IP地址池被锁定,不会为新的DHCP客户端分配地址,但会应答已在线客户端的地址续约需求 · lock strict:该IP地址池被锁定,既不会为新的DHCP客户端分配地址,也不会应答已在线客户端的地址续约需求 若IP地址池未锁定,则无锁定状态信息 |
Pool index |
IP地址池索引 |
Pool-group-name |
IP地址池组的名称 |
Network |
可分配的地址网段 |
expired |
reserve expired-ip enable |
预留老化地址 |
route-log enable |
IP地址池使用率告警门限阈值 |
IP address statistics |
IP地址池中地址的统计信息 |
IP地址池中的地址总数 |
Free IP addresses |
空闲地址总数 |
Used |
已分配的地址总数 |
Pool utilization |
IP地址池利用率 |
Bindings |
Conflicts |
冲突地址数 |
· gateway
· ip pool
display ip pool-group命令用来显示IP地址池组的信息。
display ip pool-group [ all | [ name pool-group-name ] [ vpn-instance vpn-instance-name ] ] [ verbose ]
all:显示所有的IP地址池组信息。包括公网和所有VPN实例内的IP地址池组信息。
name pool-group-name:显示指定IP地址池组的信息。pool-group-name表示IP地址池组名称,为1~63个字符的地址串,不区分大小写。如果未指定本参数,则显示的是所有IP地址池组的信息。
verbose:显示IP地址池组以及地址池的详细信息。如果未指定本参数,则显示IP地址池组以及地址池的简要信息。
# 显示IP地址池组group1的信息。
<Sysname> display ip pool-group name group1
Pool-group: group1
VPN instance name: abc
IP-in-use threshold: 100
Exhaustion trap enable
Undo exhaustion log enable
Discover-nak-count: 3 10(sec)
Total IP addresses: 100
Used IP addresses: 0
Conflicting IP addresses: 0
Free IP addresses: 0
Static bindings: 0
Excluded IP addresses: 0
Current pool: pool1
Pool group usage: 0.00%
Bound pools: 2
pool1 priority 1
pool2 priority 2
# 显示设备上公网上所有IP地址池组的简要信息。
Pool-group: group1
VPN instance name: N/A
Total IP addresses: 200
Static bindings: 0
Excluded IP addresses : 0
Current pool: pool2
Bound pools: 2
Pool2 priority 1
Pool3 priority 3
Pool-group: group2
VPN-instance name: N/A
Total IP addresses: 300
Static bindings: 0
Current pool: pool3
Bound pools: 3
pool3 priority 2
pool4 priority 3
pool5 priority 4
表1-19 display ip pool-group命令显示信息描述表
Pool-group |
IP地址池组名称 |
VPN instance name |
IP地址池组绑定的VPN实例名称。如果是公网中的IP地址池组,则显示为N/A |
IP-in-use threshold |
IP地址池组地址使用率告警门限阈值,单位为百分比 |
Exhaustion trap enable |
IP地址池组资源耗尽告警功能处于开启状态。IP地址池组资源耗尽告警功能关闭时,本字段显示为“Undo exhaustion trap enable” |
Undo exhaustion log enable |
IP地址池组地址资源耗尽或资源恢复时生成日志信息的功能处于关闭状态。IP地址池组地址资源耗尽或资源恢复时生成日志信息的功能开启时,本字段显示为“Exhaustion log enable” |
Discover-nak-count: xx yy(sec) |
DHCP中继收到应答DHCP-DISCOVER报文的DHCP-NAK报文后,切换到向下一个远端BAS IP地址池对应的服务器转发报文的条件为:yy秒内收到的应答DHCP-DISCOVER报文的DHCP-NAK报文超过xx个 |
IP地址池组中总地址个数 |
Used IP addresses |
IP地址池组中已分配的地址个数 |
Conflicting IP addresses |
IP地址池组中冲突的地址个数 |
Free IP addresses |
IP地址池组中空闲的地址个数 |
Static bindings |
IP地址池组中静态绑定的地址个数 |
Excluded IP addresses |
IP地址池组中不参与自动分配的地址个数 |
Current pool |
IP地址池组中当前所用的地址池,如果没有IP地址池,则显示N/A |
Pool group usage |
IP地址池组的地址利用率 |
Bound pools |
IP地址池组中绑定的IP地址池个数和所有IP地址池的名称,每行只支持显示一个IP地址池名称和地址池的优先级 |
# 显示IP地址池组以及地址池的详细信息。
<Sysname> display ip pool-group verbose
Pool-group: group1
Total IP addresses: 508
Free IP addresses: 508
Static bindings: 0
Current pool: pool1
Bound pools: 2
pool1
Pool name: pool1
Pool index: 1
Pool-group-name:
group1
Used: 0
Bindings:
Automatic: 0
Manual: 0
Expired: 0
Reserve: 0
Conflicts: 0
pool2
Pool name: pool2
Pool index: 2
Pool-group-name:
group1
Used: 0
Bindings:
Automatic: 0
Manual: 0
Expired: 0
Reserve: 0
Conflicts: 0
表1-20 display ip pool-group verbose命令显示信息描述表
Pool-group |
IP地址池组名称 |
VPN instance name |
IP地址池组中总地址个数 |
Used IP addresses |
IP地址池组中已分配的地址个数 |
IP地址池组中冲突的地址个数 |
Free IP addresses |
IP地址池组中空闲的地址个数 |
Static bindings |
IP地址池组中静态绑定的地址个数 |
Current pool |
Pool group usage |
IP地址池组的地址利用率 |
Bound pools |
Pool name |
IP地址池组中地址池的信息,请参见表1-18 |
· ip pool-group
dns-list命令用来配置IP地址池为DHCP客户端分配的DNS服务器地址。
undo dns-list命令用来删除IP地址池为DHCP客户端分配的DNS服务器地址。
dns-list ip-address&<1-8>
undo dns-list [ ip-address&<1-8> ]
未配置IP地址池为DHCP客户端分配的DNS服务器地址。
IP地址池视图
ip-address&<1-8>:DNS服务器的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
多次执行该命令,最后一次执行的命令生效。
执行undo dns-list命令时,如果未指定任何参数,则删除IP地址池中的所有DNS服务器地址。
# 配置IP地址池0为DHCP客户端分配的DNS服务器地址为10.1.1.254。
[Sysname] ip pool 0
[Sysname-ip-pool-0] dns-list 10.1.1.254
· display ip pool
domain-name命令用来配置IP地址池为DHCP客户端分配的域名。
undo domain-name命令用来恢复缺省情况。
domain-name domain-name
undo domain-name
未配置IP地址池为DHCP客户端分配的域名。
IP地址池视图
domain-name:DHCP客户端的域名,为1~50个字符的字符串,区分大小写。
# 配置IP地址池0为DHCP客户端分配的域名为example.com。
[Sysname] ip pool 0
[Sysname-ip-pool-0] domain-name example.com
· display ip pool
exhaustion log enable命令用来配置当IP地址池或地址池组的可分配地址资源耗尽或资源恢复时,系统生成日志信息。
undo exhaustion log enable命令用来恢复缺省情况。
当IP地址池或地址池组的可分配地址资源耗尽或资源恢复时,系统不会生成日志信息。
IP地址池视图
IP地址池组视图
开启本功能后,当IP地址池或地址池组中可分配的地址资源耗尽时,系统将生成DHCP日志信息,并交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
非转发与控制分离场景中,IP地址池或地址池组中地址使用率的计算方式为:地址使用率=(总地址数—未分配地址数)/总地址数。当IP地址池或地址池组中地址使用率重新下降到低于90%时,系统也会生成日志信息通知管理员。
# 在IP地址池pool1中,配置当地址池的可分配地址资源耗尽或资源恢复时,系统生成日志信息。
[Sysname] ip pool pool1
[Sysname-ip-pool-pool1] exhaustion log enable
# 在IP地址池组group1中,配置当地址池组的可分配地址资源耗尽或资源恢复时,系统生成日志信息。
[Sysname] ip pool-group group1
[Sysname-ip-group-group1] exhaustion log enable
exhaustion trap enable命令用来开启IP地址池或地址池组的资源耗尽告警功能。
undo exhaustion trap enable命令关闭IP地址池或地址池组的资源耗尽告警功能。
IP地址池资源耗尽告警功能处于开启状态,IP地址池组资源耗尽告警功能处于关闭状态。
普通类型的IP地址池视图
BAS类型的IP地址池视图
IP地址池组视图
非转发与控制分离场景中,IP地址或地址池组中地址使用率的计算方式为:地址使用率=(总地址数-未分配地址数)/总地址数,开启地址池或地址池组资源耗尽告警功能后,当地址池或地址池组中地址使用率达到100%,即资源耗尽时,设备会生成告警信息提示管理员地址已耗尽。
只有开启DHCP服务器地址池或地址池组资源耗尽的告警功能(通过snmp-agent trap enable dhcp server address-exhaust或snmp-agent trap enable dhcp server pool-group-exhaust命令)后,本命令才能生效。
snmp-agent trap enable dhcp server address-exhaust命令会开启所有IP地址池的资源耗尽告警功能,如果希望减少告警信息的生成,可以使用undo exhaustion trap enable命令关闭部分地址池的资源耗尽告警功能。
# 关闭地址池pool1的资源耗尽告警功能。
[Sysname-ip-pool-pool1] undo exhaustion trap enable
# 开启地址池组group1的资源耗尽告警功能。
[Sysname] ip pool-pool group1
[Sysname-pool-group-group1] exhaustion trap enable
· display ip pool
expired命令用来配置IP地址池中分配的IP地址的租约有效期限。
undo expired命令用来恢复缺省情况。
expired { allow-hint | { day day [ hour hour [ minute minute [ second second ] ] ] | unlimited } [ allow-hint ] }
undo expired
IP地址池中IP地址的租约有效期限为1天。
IP地址池视图
allow-hint:表示允许DHCP客户端与DHCP服务器协商决定租约有效期限(取IP地址池中配置的租约期限和客户端期望的租约期限中的较小值)。如果未指定本参数,则忽略客户端的期望租约期限,以IP地址池中配置的租约期限为准。
day day:指定租约过期的天数,day取值范围为0~365。
hour hour:指定租约过期的小时数,hour取值范围为0~23。如果未指定本参数,则指定过期的小时数为0。
minute minute:指定租约过期的分钟数,minute取值范围为0~59。如果未指定本参数,则指定过期的分钟数为0。
second second:指定租约过期的秒数,second取值范围为0~59。如果未指定本参数,则指定过期的秒数为0。
unlimited:有效期限为无限长(实际上系统限定约为136年)。
DHCP服务器从IP地址池中选择IP地址分配给DHCP客户端时,会同时将该地址池中IP地址的租约有效期限通知给DHCP客户端。在租约有效期限到达之前,DHCP客户端需要进行续约申请。如果续约成功,则DHCP客户端可以继续使用该IP地址。否则,租约有效期限到达后,DHCP客户端不能再继续使用该IP地址,并且DHCP服务器会将该地址添加到过期租约信息中。
# 配置IP地址池0的IP地址租约有效期为1天2小时3分4秒。
[Sysname] ip pool 0
[Sysname-ip-pool-0] expired day 1 hour 2 minute 3 second 4
# 配置IP地址池0的IP地址租约有效期为1天2小时3分4秒,且允许DHCP客户端与DHCP服务器协商决定租约有效期限。
[Sysname] ip pool 0
[Sysname-ip-pool-0] expired day 1 hour 2 minute 3 second 4 allow-hint
· display dhcp server expired
· display ip pool
export host-route命令用来开启用户主机路由发布功能。
undo export host-route命令用来关闭用户主机路由发布功能。
export host-route
用户主机路由发布功能处于关闭状态。
IP地址池视图
IP地址池分配IP地址时,通过执行network export-route命令可以配置发布IP地址对应的网段路由。由于多个IP地址池的地址空间网段相同,则这些IP地址池分配地址时,发布的网段路由相同,导致外部设备根据路由无法访问到终端设备。为了解决这个问题,需要开启用户主机路由发布功能。
主机路由的生成不受本命令控制。缺省情况下,地址池已分配地址的主机路由生成后,不允许该主机路由通过路由协议(例如BGP)发布到其它设备上。开启本功能后,对于当前IP地址池:
· 执行network export-route或gateway命令后本设备上生成的UNR路由被删除;
· 本设备上地址池已分配地址的主机路由生成后,允许该主机路由通过路由协议发布到其它设备上。
只有当IP地址池未分配任何地址时,才能配置本功能。
# 在IP地址池1中开启用户主机路由发布功能。
[Sysname] ip pool 1
[Sysname-ip-pool-1] export host-route
· ip pool
forbidden-ip命令用来配置IP地址池中不参与自动分配的IP地址。
undo forbidden-ip命令用来取消IP地址池中不参与自动分配的IP地址的配置。
forbidden-ip ip-address&<1-8>
undo forbidden-ip [ ip-address&<1-8> ]
除DHCP服务器接口的IP地址外,IP地址池中的所有IP地址都参与自动分配。
IP地址池视图
ip-address&<1-8>:IP地址池中不参与自动分配的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
在IP地址池视图下通过forbidden-ip命令配置不参与自动分配的IP地址后,只有当前的IP地址池不能分配这些IP地址,其他IP地址池仍然可以分配这些IP地址。
多次执行forbidden-ip命令,可以配置多个不参与自动分配的IP地址。
执行undo forbidden-ip命令时,如果未指定任何参数,则删除所有不参与自动分配的IP地址。
# 配置IP地址池0中不参与自动分配的IP地址为192.168.1.3和192.168.1.10。
[Sysname] ip pool 0
[Sysname-ip-pool-0] forbidden-ip 192.168.1.3 192.168.1.10
· dhcp server forbidden-ip
· display ip pool
forbidden-ip-range命令用来配置IP地址池中不参与自动分配的IP地址段。
undo forbidden-ip-range命令用来取消配置的IP地址池中不参与自动分配的IP地址段。
forbidden-ip-range start-ip-address [ end-ip-address ]
undo forbidden-ip-range [ start-ip-address [ end-ip-address ] ]
未配置IP地址池中不参与自动分配的IP地址段。
IP地址池视图
start-ip-address:表示不参与自动分配的起始IP地址。
end-ip-address:表示不参与自动分配的终止IP地址,不能小于start-ip-address。如果未指定本参数,则表示只有一个不参与自动分配的IP地址,即start-ip-address。否则,表示start-ip-address到end-ip-address之间的IP地址段均不参与自动分配。
在IP地址池视图下通过forbidden-ip-range命令配置不参与自动分配的IP地址段后,只有当前的地址池不能分配这些IP地址段,其他地址池仍然可以分配这些IP地址段。
多次执行forbidden-ip-range命令,可以配置多个不参与自动分配的IP地址段,多次配置的地址空间可以互相重复。
执行undo forbidden-ip-range命令时,如果未指定任何参数,则删除所有不参与自动分配的IP地址段。
如果执行undo forbidden-ip-range命令指定的地址段范围比forbidden-ip-range现有的地址段范围小,则只取消undo forbidden-ip-range指定的地址段范围的配置。如果执行undo forbidden-ip-range命令指定的地址段范围比forbidden-ip-range指定的地址段范围大,则只取消forbidden-ip-range命令指定的地址段范围。
# 配置IP地址池pool1中不参与自动分配的IP地址段为192.168.1.3到192.168.1.10。
[Sysname-ip-pool-pool1] forbidden-ip-range 192.168.1.3 192.168.1.10
· display ip pool
gateway命令用来配置IP地址池的网关IP地址和网络掩码。
undo gateway命令用来恢复缺省情况。
gateway ip-address { mask | mask-len }
undo gateway
未配置IP地址池的网关的IP地址和网络掩码。
本地BAS IP地址池视图
远端BAS IP地址池视图
ip-address:网关的IP地址。
mask:网关IP地址的网络掩码,为点分十进制形式。
mask-len:网关IP地址的网络掩码长度,取值范围为1~30。
在BAS接入组网中,为了给通过认证的接入用户分配IP地址,需要在DHCP服务器的IP地址池中配置网关的IP地址和网络掩码。配置完成后,当DHCP服务器收到接入用户的DHCP请求报文后,就从网关地址所在的网段中选择一个可用的IP地址,并将该地址分配给接入用户。
一个BAS地址池中只支持配置一个网关的IP地址和网络掩码,多次执行本命令,最后一次执行的命令生效。
当IP地址池中已分配的地址租约时,则无法执行本命令修改或删除gateway配置。
# 在本地BAS IP地址池p1中,配置网关的IP地址为1.1.1.1,网关IP地址的网络掩码长度为24。
[Sysname] ip pool p1 bas local
[Sysname-ip-pool-p1] gateway 1.1.1.1 24
· display ip pool
· network
gateway-list命令用来配置DHCP服务器为DHCP客户端分配的网关地址。
undo gateway-list命令用来删除DHCP服务器为DHCP客户端分配的网关地址。
gateway-list ip-address&<1-64> [ export-route ]
undo gateway-list [ ip-address&<1-64> ] [ export-route ]
IP地址池、DHCP从网段下均未配置为DHCP客户端分配的网关地址。
IP普通地址池视图
DHCP从网段视图
ip-address&<1-64>:网关的IP地址。&<1-64>表示最多可以输入64个IP地址,每个IP地址之间用空格分隔。网关地址需要和DHCP客户端在同一个网段中。
export-route:将网关列表信息下发给地址管理,通过应答客户端的ARP请求,即可实现对不同类型的业务流量的引导。如果未指定本参数,则不将网关列表信息下发给地址管理。
当用户通过本命令配置的网关地址上线后,请勿删除已在线用户正在使用的网关地址,否则将影响用户后续的报文转发。
IP地址池视图下执行gateway-list命令,配置的是为IP地址池中所有DHCP客户端分配的网关地址。如果用户需要为IP地址池下某个从网段的DHCP客户端分配其它的网关地址,可以在IP地址池的从网段视图下执行gateway-list命令。如果在IP地址池视图和从网段视图下都配置了网关地址,则优先将从网段视图下配置的网关地址分配给从网段的DHCP客户端。
执行undo gateway-list命令时,如果未指定任何参数,则删除所有配置的网关地址。
# 配置IP地址池0为DHCP客户端分配的网关地址为10.1.1.1。
[Sysname] ip pool 0
[Sysname-ip-pool-0] gateway-list 10.1.1.1
· display ip pool
if-match命令用来配置DHCP用户类的匹配规则。
undo if-match命令用来删除DHCP用户类的匹配规则。
未配置DHCP用户类的匹配规则。
DHCP用户类视图
hardware-address hardware-address:指定匹配规则的硬件地址。hardware-address表示客户端的硬件地址,为4~39个字符的字符串,字符串只能包含十六进制数和“-”,且形式为H-H-H,除最后一个H表示2位或4位十六进制数外,其他均表示4位十六进制数。例如:aabb-ccdd-ee为有效的硬件地址,aabb-c-dddd和aabb-cc-dddd为无效的客户端硬件地址。
mask hardware-address-mask:指定匹配规则的硬件地址掩码。长度需要与hardware-address保持一致。
option option-code:DHCP选项的数值,取值范围为1~254。option-code用于指定匹配DHCP客户端时从DHCP报文中获取哪个选项。
ascii ascii-string:指定用来匹配报文中指定选项的内容。ascii-string为1~128个字符的ACSII字符串。
offset offset:指定匹配DHCP客户端时获取选项内容的起始位置。offset为选项内容偏移量,取值范围为0~254,单位为字节。如果未指定本参数,则表示从选项值第一字节开始匹配整个选项的内容。
partial:指定部分匹配,即只要报文中的选项内容中包含指定的hex-string或ascii-string,即认为匹配通过。
length length:指定匹配DHCP客户端时获取选项内容的长度。length为选项内容的长度,取值范围为1~128,单位为字节。指定的选项内容长度必须和hex-string长度相同。
relay-agent gateway-address:指定匹配报文中的giaddr字段的内容。gateway-address为IP地址,为点分十进制形式。
DHCP服务器通过将DHCP客户端发送的报文与本命令配置的规则匹配,来判断DHCP客户端属于的DHCP用户类。DHCP用户类视图下通过多次执行if-match命令,可以配置多条匹配规则。只要任意一条规则匹配成功,就认为该DHCP客户端属于该用户类。
在同一用户类视图下配置匹配规则时:
· 多次执行相同rule-number的命令,如果规则类型(包括匹配option、relay-agent或hardware address)相同,最后一次执行的命令生效;如果规则类型不同,则新的配置和已有配置会共存。建议不同类型的规则不要使用同一个rule-number。
· 不同rule-number的匹配规则内容不能完全相同。
将报文与某一条if-match hardware-address命令配置的规则匹配的方式为:
· 匹配硬件地址类型,目前只支持以太类型的硬件地址(即MAC地址)匹配,非以太类型的硬件地址均会匹配失败。
· 如果报文中的客户端硬件地址与配置的客户端硬件地址及硬件地址掩码匹配,则认为匹配成功。否则,匹配失败。
· 匹配时报文中的客户端硬件地址长度与配置规则中的硬件地址长度一致时才进行匹配,否则直接认为不匹配。如匹配规则为if-match rule 1 hardware-address 0094-0000 mask ffff-0000,需匹配硬件地址长度为4字节的用户;若报文中客户端硬件地址长度为6字节(比如0094-0000-0010),则认为匹配失败。
· 匹配硬件地址时,可以配置不连续匹配的硬件地址,如匹配规则为if-match rule 1 hardware-address 0094-0000-1100 mask ffff-0000-ff00,则匹配硬件地址为0094-xxxx-11xx(x代表变量)的报文。
· 如果规则中只指定了option-code参数,则只要报文中包括该选项,就认为匹配成功。否则,匹配失败。
· 如果规则中只指定了option-code和hex-string/ascii-string参数,则报文中指定选项的值从第1位到最后一位的长度和内容都与hex-string/ascii-string相同时,认为匹配成功。否则,匹配失败。
· 如果规则中指定了option-code、ascii-string和offset参数,则将指定选项的值的第offset+1位到最后一位的长度和内容分别与acsii-string比较,二者相同时,认为匹配成功。否则,匹配失败。
· 如果规则中指定了option-code、hex-string、offset和length参数,则将指定选项值的第offset+1位到offset+length位的内容与hex-string比较,二者相同时,认为匹配成功。否则,匹配失败。
· 如果规则中指定了option-code、hex-string和mask参数,则将指定选项值的第1位到mask长度位的内容与mask进行与运算,将结果与hex-string与mask与运算的结果比较,二者相同时,认为匹配成功。否则,匹配失败。
· 如果规则中指定了option-code、hex-string/ascii-string和partial参数,则选项内容内包含了指定的hex-string/ascii-string,就认为匹配成功。否则,匹配失败。例如匹配字段为abc,那xabc、xyzabca、xabcyz和abcxyz均认为匹配通过。
将报文与某一条if-match relay-agent命令配置的规则匹配的方式是只要报文中的giaddr字段和指定的gateway-address一致时,认为匹配成功。否则,匹配失败。
# 配置DHCP用户类exam的匹配规则,匹配规则编号1,匹配硬件地址0094-0000-0101,硬件掩码长度为ffff-0000-0000。
<Sysname> syatem-view
[Sysname] dhcp class exam
[Sysname-dhcp-class-exam] if-match rule 1 hardware-address 0094-0000-0101 mask ffff-0000-0000
# 配置DHCP用户类exam的匹配规则,匹配规则编号2,报文中包含Option 82。
[Sysname-dhcp-class-exam] if-match rule 2 option 82
# 配置DHCP用户类exam的匹配规则,匹配规则编号3,报文中包含Option 82,并且该选项的十六进制数第四个字节的最高位为1。
[Sysname-dhcp-class-exam] if-match rule 3 option 82 hex 00000080 mask 00000080
# 配置DHCP用户类exam的匹配规则,匹配规则编号4,报文中包含Option 82,并且该选项的前三个字节为十六进制数13ae92。
[Sysname-dhcp-class-exam] if-match rule 4 option 82 hex 13ae92 offset 0 length 3
# 配置DHCP用户类exam的匹配规则,匹配规则编号5,报文中包含Option 82,并且该选项内容中包含指定的十六进制数13ae。
[Sysname-dhcp-class-exam] if-match rule 5 option 82 hex 13ae partial
# 配置DHCP用户类exam的匹配规则,匹配规则编号6,报文中包含Option 61,并且该选项的内容为abcd。
[Sysname-dhcp-class-exam] if-match rule 6 option 61 ascii abcd
# 配置DHCP用户类exam的匹配规则,匹配规则编号7,报文中包含的giaddr字段值为10.1.1.1。
[Sysname-dhcp-class-exam] if-match rule 7 relay-agent 10.1.1.1
· dhcp class
ip pool命令用来创建IP地址池并进入IP地址池视图。如果已经创建了IP地址池,则直接进入该地址池视图。
undo ip pool命令用来删除指定的IP地址池。
ip pool pool-name [ bas { local | remote } ]
undo ip pool pool-name
不存在IP地址池。
bas { local | remote }:表示创建为BAS接入用户分配地址的IP地址池。local表示创建的是本地BAS IP地址池。remote表示创建的是远端BAS IP地址池。
根据不同的组网环境,管理员可以通过本命令创建普通IP地址池和特定组网使用的地址池。
在某些组网(如IPoE)中,接入用户首先通过认证服务器(如RADIUS服务器)进行认证,认证通过后再向DHCP服务器申请IP地址。如果BAS接入设备直接为接入用户分配地址,则需要配置本地BAS IP地址池;如果BAS接入设备不能直接为接入用户分配地址,而是将用户的地址请求转发给DHCP服务器统一处理,则BAS接入设备需要配置远端BAS IP地址池,并通过remote-server命令指定DHCP服务器的IP地址。远端DHCP服务器上需要配置的本地BAS IP地址池,为用户分配IP地址。
如果未指定bas参数,则表示创建的是普通的IP地址池。
在同一台设备上,无法创建IP地址池名称相同,但地址池类型不同的IP地址池,否则会报错。
在同一台设备上,可以创建多个相同类型的IP地址池。
# 创建为BAS接入用户分配地址的本地IP地址池,并进入本地BAS IP地址池视图。
· display ip pool
ip pool-group命令用来创建IP地址池组,并进入IP地址池组视图。如果指定的IP地址池组已存在,则直接进入IP地址池组视图。
undo ip pool-group命令用来删除指定的IP地址池组。
ip pool-group pool-group-name
undo ip pool-group pool-group-name
不存在IP地址池组。
pool-group-name:IP地址池组名称,为1~63个字符的字符串,不区分大小写。
将IP地址池加入IP地址池组后,DHCP在分配地址时,如果DHCP客户端匹配到指定IP地址池组,DHCP将选择此IP地址池组中的一个可用IP地址池进行地址分配。
如果设置AAA的用户授权属性中同时存在IP地址池和IP地址池组,则经过AAA认证后的用户只能从IP地址池中获取IP地址。当IP地址池中不存在可分配的地址时,也无法从IP地址池组中获取IP地址。
如果DHCP中继上配置的IP地址池组关联了远端BAS IP地址池,IP地址池组匹配到远端BAS IP地址池时,无法判断远端BAS IP地址池关联的服务器是否存在可分配的地址资源。为了解决这个问题,管理员需要在远端BAS IP地址池内通过gateway命令配置和远端BAS IP地址池关联的服务器相同的网段信息,且通过dhcp server forbidden-ip、forbidden-ip或forbidden-ip-range配置和远端BAS IP地址池关联的服务器相同的IP地址池中不参与自动分配的IP地址。当远端BAS IP地址池关联的服务器为客户端分配一个IP地址后,中继收到应答报文时,也会在对应的远端BAS IP地址池配置的可分配地址资源中去掉这个地址。这就保证了远端BAS IP地址池上的空闲地址信息和远端服务器的空闲地址信息相同,地址池组只要检查远端BAS IP地址池的空闲地址情况,就能确定关联的远端服务器是否存在空闲地址。
# 创建名称为poolgroup1的IP地址池组,并进入IP地址池组视图。
[Sysname] ip pool-group poolgroup1
[Sysname-ip-pool-group-poolgroup1]
· display ip pool-group
· pool
ip-pool algorithm round-robin命令用来配置IP地址池组采用轮询方式选择IP地址池。
undo ip-pool algorithm round-robin命令用来恢复缺省情况。
ip-pool algorithm round-robin { local | remote } *
undo ip-pool algorithm round-robin { local | remote } *
IP地址池组使用某个地址池为用户分配地址,当该地址池没有可用地址空间后,再选择下一个IP地址池。
IP地址池组视图
local:采用轮询方式选择本地IP地址池。
remote:采用轮询方式选择远端BAS IP地址池。
缺省情况下,IP地址池组会选择某个地址池为用户分配地址,当该地址池没有可用地址后,再顺序选择下一个可用的IP地址池。这种分配方式会造成IP地址池地址资源分配不均匀。为了解决此问题,可以配置IP地址池组采用轮询方式选择IP地址池。配置本功能后,当IP地址池组收到第一个DHCP请求报文后,会选择一个可用的IP地址池为其分配IP地址;收到第二个DHCP请求报文后,会顺序选择下一个可用的IP地址池为其分配IP地址;以此类推,当选择完最后一个可用的IP地址池后,再从第一个地址池开始继续分配。
本命令参数的匹配规则为:
· 指定local参数时,IP地址池组只会轮询本地IP地址池,本地IP地址池资源耗尽后,远端BAS IP地址池的分配方式仍按照缺省情况处理。
· 指定remote参数时,IP地址池组会先按照缺省情况选择本地IP地址池为用户分配地址,本地IP地址池资源耗尽后,才会去轮询远端BAS IP地址池。
· 同时指定local参数和remote参数时,IP地址池组会先轮询本地IP地址池,本地IP地址池资源耗尽后,再轮询远端BAS IP地址池。
# 在IP地址池组1中,配置IP地址池组采用轮询方式选择本地IP地址池。
[Sysname] ip pool-group 1
[Sysname-ip-pool-group-1] ip-pool algorithm round-robin local
ip unr命令用来配置IPv4用户网段路由标记值。
undo ip unr命令用来恢复缺省情况。
ip unr { framed-ip-address-tag tag-value | framed-ip-netmask-tag tag-value | framed-route-tag tag-value | local-pool-tag tag-value | remote-pool-tag tag-value } *
undo ip unr { framed-ip-address-tag | framed-ip-netmask-tag | framed-route-tag | local-pool-tag | remote-pool-tag } *
未配置IPv4用户网段路由标记值。
framed-ip-address-tag tag-value:RADIUS服务器下发Framed-IP-Address属性生成的主机路由的路由标记值。tag-value为地址池的路由标记值,取值范围为1~4294967295。
framed-ip-netmask-tag tag-value:RADIUS服务器下发Framed-IP-Netmask属性生成的网段路由的路由标记值。tag-value为地址池的路由标记值,取值范围为1~4294967295。
framed-route-tag tag-value:RADIUS服务器下发Framed-Routing属性生成的网段路由的路由标记值。tag-value为地址池的路由标记值,取值范围为1~4294967295。
local-pool-tag tag-value:普通IP地址池和本地BAS IP地址池生成的网段路由标记值。tag-value为地址池的路由标记值,取值范围为1~4294967295。
remote-pool-tag tag-value:远端BAS IP地址池生成的网段路由标记值。tag-value为地址池的路由标记值,取值范围为1~4294967295。
使用IP地址池为用户分配IP地址后,设备会将地址段对应的路由添加到路由管理中。BAS接入组网环境中,可能需要将不同BAS地址池下的用户分类,发布到不同的网络。通过配置动态路由协议引用对应标记值的地址段路由,可以实现将该地址段路由通告到对应的网络中的目的。
本命令支持为RADIUS服务器下发的网段路由、普通IP地址池生成的网段路由、本地BAS IP地址池生成的网段路由和远端BAS IP地址池生成的网段路由设置路由标记值。
执行本命令修改路由标记值后,修改的结果只对新上线的用户生效。
IP地址池视图和系统视图下均可以配置用户网段路由标记值,对于BAS接入用户,IP地址池视图下的配置优先级高。
# 配置本地BAS IP地址池生成的网段路由标记值为1。
[Sysname] ip unr local-pool-tag 1
· unr tag
ip-in-use threshold命令用来设置IP地址池或地址池组使用率告警门限阈值。
undo ip-in-use threshold命令用来恢复缺省情况。
IP地址池或地址池组使用率告警门限阈值为100%。
IP地址池视图
IP地址池组视图
threshold-value:IP地址池或地址池组使用率告警阈值,为百分比形式,取值范围为0~100。例如,设置threshold-value为80,表示地址池或地址池组使用率高于等于80%时,系统会生成告警信息和日志信息。如果threshold-value为100,当IP地址池或地址池组中地址使用率等于阈值,或IP地址池中的地址使用率重新下降到低于90%时,只会生成告警信息,不会生成日志信息。
执行本命令后,如果IP地址池或地址池组中地址使用率高于等于阈值,则DHCP模块会生成日志信息和告警信息提醒管理员进行IP地址池规划,避免因为IP地址池或地址池组中地址资源耗尽,导致后续用户不能上线。当IP地址池或地址池组中的地址使用率重新下降到低于(threshold-value×0.9)%时,DHCP模块会同时生成告警信息和日志信息。
DHCP模块将告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性,并将日志信息交给信息中心模块处理,通过设置信息中心的参数,最终决定这两种信息的输出规则(即是否允许输出以及输出方向)。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。有关信息中心参数配置请参见“网络管理和监控配置指导”中的“信息中心”。
# 在IP地址池pool1,设置地址池使用率门限阈值为75%。
[Sysname-ip-pool-pool1] ip-in-use threshold 75
# 设置IP地址池组group1的地址使用率门限阈值为75%。
[Sysname-ip-pool-group-group1] ip-in-use threshold 75
lock命令用来锁定IP地址池。
undo lock命令用来恢复缺省情况。
lock [ strict ]
undo lock
IP地址池未锁定。
IP地址池视图
strict:配置IP地址池收到DHCP客户端的续约报文后,直接丢弃该报文,DHCP客户端无法续约。如果未指定本参数,则IP地址池会应答地址续约请求,DHCP客户端可以正常续约。
在管理IP地址池时,可能会有如下需求:
· 当前IP地址池地址空间被规划为维护使用,即只用于维护已在线DHCP客户端的需求,不为新的DHCP客户端分配地址。
· 管理员对地址池中的地址空间进行更新或删除时,如果IP地址池已经分配了IP地址,会提示当前有用户在线,无法执行删除或更新操作。
为了解决上述问题,管理员需要配置锁定IP地址池:
· 如果未指定strict参数,则IP地址池不会为新的DHCP客户端分配地址,但会应答已在线客户端的地址续约需求。这种情况下,IP地址池的地址仅用于维护,仅处理在线用户的续租请求。
· 如果指定strict参数,则IP地址池既不会为新的DHCP客户端分配地址,也不会应答已在线客户端的地址续约需求。这种情况下,待IP地址池中的地址全部回收后,管理员可以对地址空间进行更新或删除操作。
# 锁定IP地址池1,不会再为新用户分配地址,只会应答已在线用户的续约请求。
[Sysname] ip pool 1
[Sysname-ip-pool-1] lock
The IP pool will answer only renewal requests of online users but will not assign addresses to new users. Continue? [Y/N]:
# 锁定IP地址池1,既不会再为新用户分配地址,也不会应答已在线用户的续约请求。
[Sysname] ip pool 1
[Sysname-ip-pool-1] lock strict
The IP pool will not answer renewal requests of online users or assign addresses to new users. Continue? [Y/N]:
· display ip pool
nbns-list命令用来配置IP地址池为DHCP客户端分配的WINS服务器地址。
undo nbns-list命令用来删除IP地址池为DHCP客户端分配的WINS服务器地址。
nbns-list ip-address&<1-8>
undo nbns-list [ ip-address&<1-8> ]
未配置IP地址池为DHCP客户端分配的WINS服务器地址。
IP地址池视图
ip-address&<1-8>:WINS服务器的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
执行undo nbns-list命令时,如果未指定任何参数,则删除IP地址池中的所有WINS服务器地址。
# 配置IP地址池0为DHCP客户端分配WINS服务器地址为10.1.1.1。
[Sysname] ip pool 0
[Sysname-ip-pool-0] nbns-list 10.1.1.1
· display ip pool
· netbios-type
netbios-type命令用来配置IP地址池为DHCP客户端分配的NetBIOS节点类型。
undo netbios-type命令用来恢复缺省情况。
undo netbios-type
未配置IP地址池为DHCP客户端分配的NetBIOS节点类型。
IP地址池视图
b-node:b类节点,“b”代表广播(broadcast),此类节点采用广播方式获取主机名和IP地址之间的映射。源节点通过发送带有目的节点主机名的广播报文来获取目的节点的IP地址,目的节点收到广播报文后,就将自己的IP地址返回给源节点。
h-node:h类节点,“h”代表混合(hybrid),是具备“端到端”通信机制的b类节点。此类节点首先发送单播报文与WINS服务器通信来获取映射关系,如果未获取到,再发送广播报文来获取映射关系。
m-node:m类节点,“m”代表混合(mixed),是具有部分广播特性的p类节点。此类节点首先发送广播报文来获取映射关系,如果未获取到,则再发送单播报文与WINS服务器通信来获取映射关系。
p-node:p类节点,“p”代表端到端(peer-to-peer),即此类节点采用发送单播报文与WINS服务器通信的方式获取映射关系。源节点给WINS服务器发送单播报文,WINS服务器收到单播报文后,返回源节点请求的目的节点名所对应的IP地址。
# 配置IP地址池0为DHCP客户端分配的NetBIOS节点类型为p类节点。
[Sysname] ip pool 0
[Sysname-ip-pool-0] netbios-type p-node
· display ip pool
· nbns-list
network命令用来配置IP地址池动态分配的IP地址网段。
undo network命令用来删除已经创建的用于动态分配的IP地址网段。
network network-address [ mask-length | mask mask ] [ secondary ] [ export-route [ preference preference | tag tag ] * ]
undo network network-address [ mask-length | mask mask ] [ secondary ]
未配置动态分配的IP地址网段,即没有可供分配的IP地址。
普通IP地址池视图
network-address:用于动态分配的网段地址。未指定掩码长度和掩码时,表示采用自然掩码。
mask-length:IP地址的网络掩码长度,取值范围为1~30。
mask mask:IP地址的网络掩码,mask为点分十进制形式。
secondary:指定配置的网段为从网段。如果未指定本参数,则表示配置的网段为主网段。主网段中的地址分配完之后,DHCP服务器可以在从网段中选择地址分配给DHCP客户端。
export-route:将网段信息下发给路由管理,由路由管理发布指定网段信息的路由。引导指定网段的下行数据流量。如果未指定本参数,则不会将网段信息下发给路由管理。
preference preference:下发给路由管理的网段路由的优先级,preference的取值范围为1~255,缺省值为70。
tag tag:下发给路由管理的网段路由的标记值,tag的取值范围为0~4294967295,缺省值为0。tag字段用于标识该网段路由,路由策略可根据tag字段对路由条目进行过滤。路由策略的详细介绍请参见“三层技术-IP路由配置指导”中的“路由策略”。
执行本命令时如果指定了secondary参数,则会进入从网段视图。用户可以在该视图下通过gateway-list命令配置为从网段的DHCP客户端分配的网关地址。
每个IP地址池中只能配置一个主网段,多次执行network命令配置主网段,最后一次执行的命令生效。
对于普通IP地址池,每个IP地址池中最多可以配置96个从网段。
一个IP地址池中各个主、从网段的网络号和掩码不能完全相同。
在IP地址池下配置了address range或class命令后,不能再在该IP地址池下配置从网段。
如果IP地址池下有已分配的地址,则无法执行本命令修改或删除network配置。
配置network export-route命令可以用来发布网段路由,指定preference或tag参数可以修改网段路由的优先级或标记值,多次执行本命令,最后一次执行的命令生效。
# 配置IP地址池0动态分配的主地址网段为192.168.8.0/24,从地址网段为192.168.10.0/24。
[Sysname] ip pool 0
[Sysname-ip-pool-0] network 192.168.8.0 mask 255.255.255.0
[Sysname-ip-pool-0] network 192.168.10.0 mask 255.255.255.0 secondary
[Sysname-ip-pool-0-secondary]
· display ip pool
· gateway-list
next-server命令用来配置IP地址池为DHCP客户端分配的下一个提供服务的服务器IP地址。
undo next-server命令用来恢复缺省情况。
next-server ip-address
undo next-server
未配置IP地址池为DHCP客户端分配的下一个提供服务的服务器IP地址。
IP地址池视图
ip-address:下一个提供服务的服务器IP地址。
为DHCP客户端分配的下一个提供服务的服务器IP地址,是在DHCP客户端启动过程中,在获取到IP地址后,用于获取其他启动数据的服务器地址。例如,TFTP服务器地址。
# 配置IP地址池0为DHCP客户端分配的下一个提供服务的服务器IP地址为10.1.1.254。
[Sysname] ip pool 0
[Sysname-ip-pool-0] next-server 10.1.1.254
· display ip pool
option命令用来自定义DHCP选项。
undo option命令用来删除自定义的DHCP选项。
undo option code
未自定义DHCP选项。
IP地址池视图
DHCP选项组视图
code:选项的数值,取值范围为2~254,不包括50~54、56、58、59、61和82。
ascii ascii-string:指定选项内容为配置的ASCII字符串。ascii-string为1~255个字符的ASCII字符串,区分大小写。
hex hex-string:指定选项内容为配置的十六进制数。hex-string为十六进制数,位数的取值范围为2~256之间的偶数。
ip-address ip-address&<1-8>:指定选项内容为配置的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
通过执行本命令,可以配置编号为code的DHCP选项内容为指定的ASCII字符串、十六进制数或IP地址,即采用指定的内容来填充DHCP应答报文中编号为code的选项,以便将指定的选项内容分配给客户端。
本命令为DHCP服务器提供了灵活的选项配置方式,使得DHCP服务器可以为DHCP客户端提供更加丰富的选项内容。在以下情况下,可以使用本命令自定义DHCP选项:
· 随着DHCP的不断发展,新的DHCP选项会陆续出现。通过自定义DHCP选项,可以方便地添加新的DHCP选项。
· 有些选项的内容,RFC中没有统一规定。厂商可以根据需要定义选项的内容,如Option 43。通过自定义DHCP选项,可以为DHCP客户端提供厂商指定的信息。
· 设备上只提供了有限的选项配置命令(如gateway-list、dns-list命令),对于没有专门命令来配置的DHCP选项,可以通过option命令配置选项内容。例如,可以通过option 4 ip-address 1.1.1.1命令指定为DHCP客户端分配的时间服务器地址为1.1.1.1。
· 扩展已有的DHCP选项。当前已提供的方式无法满足用户需求时(比如通过dns-list命令最多只能配置8个DNS服务器地址,如果用户需要配置的DNS服务器地址数目大于8,则该命令无法满足需求),可以通过自定义DHCP选项的方式进行扩展。
有些DHCP选项既可以通过专门的命令来配置,也可以通过option命令来配置。例如,Option 6(DNS服务器地址选项)既可以通过dns-list命令配置,也可以通过option 6命令配置。如果同时通过上述两种方式配置了这些选项,则在填充DHCP应答报文的选项时,优先选择专门命令的配置。如果未通过专门命令来配置,则采用option命令配置的内容填充选项。
DHCP服务器在应答DHCP客户端报文时,如果DHCP选项组的选项编号和IP地址池选项编号相同且匹配用户类时,以DHCP选项组的选项为准。
DHCP服务器在应答客户端报文时,如果多个DHCP选项组的选项编号相同时,以最先匹配的DHCP用户类对应的DHCP选项组的选项为准。
# 日志服务器选项的编号为7。在IP地址池0中配置为DHCP客户端分配的日志服务器地址为2.2.2.2。
[Sysname] ip pool 0
[Sysname-ip-pool-0] option 7 ip-address 2.2.2.2
· display ip pool
pool命令用来将一个IP地址池加入到IP地址池组中。
undo pool命令用来将IP地址池从IP地址池组中删除。
pool pool-name [ priority priority-value ]
undo pool [ pool-name ]
IP地址池组中不存在任何IP地址池。
IP地址池组视图
pool-name:IP地址池名称,为1~63个字符的字符串,不区分大小写。执行undo pool命令,如果未指定本参数,则删除IP地址池组中添加的所有IP地址池。
priority priority-value:IP地址池的优先级,priority-value的取值范围为0~65535,缺省值为0。优先级值越小,IP地址池的优先级越高。
本命令用来将一个IP地址池加入到一个IP地址池组。当DHCP客户端匹配到某一个IP地址池组时,DHCP按照优先级从小到大选择一个可用的IP地址池进行地址分配。当优先级值相同时,按照display ip pool-group命令的显示顺序匹配IP地址池。
同一个IP地址池组可以添加多个IP地址池,同一个IP地址池也可以加入到多个IP地址池组中。一个IP地址池组最多支持添加1024个IP地址池。
将某个IP地址池加入到IP地址池组前,需要保证该IP地址池所在的公网或VPN与IP地址池组所在的公网或VPN一致。
将某个IP地址池从IP地址池组中删除前,需要保证该IP地址池未分配任何IP地址。
# 创建名称为poolgroup1的IP地址池组,将IP地址池pool1加入到IP地址池组中。
[Sysname-ip-pool-group-poolgroup1] pool pool1
· ip pool-group
reserve expired-ip enable命令用来开启IP地址池下老化地址保留功能。
undo reserve expired-ip enable命令用来关闭IP地址池下老化地址保留功能。
IP地址池下老化地址保留功能处于开启状态。
IP地址池视图
当DHCP客户端下线后,DHCP服务器会将该客户端对应的地址保存在老化租约中。当DHCP客户端再次上线时,DHCP服务器会从老化租约中选择该地址分配给DHCP客户端。
如果管理员希望IP地址池不保留IP地址老化租约,DHCP客户端下线后释放的IP地址可以直接用来分配给其他的DHCP客户端,则需要关闭IP地址池下老化地址保留功能。
# 在IP地址池0内关闭IP地址池下老化地址保留功能。
[Sysname] ip pool 0
[Sysname-ip-pool-0] undo reserve expired-ip enable
· reserve expired-ip mode
reserve expired-ip mode命令用来配置IP地址池下老化地址保留模式。
undo reserve expired-ip mode命令用来恢复缺省情况。
reserve expired-ip mode { client-id | mac } [ limit limit-number | time time ] *
当开启了IP地址池老化地址保留功能,则设备按照客户端ID保留IP地址。
IP地址池视图
client-id:按照客户端ID保留IP地址。
mac:按照DHCP客户端MAC地址信息保留IP地址。
limit limit-number:指定该IP地址池下保留IP地址的最大数目,取值范围为1~2560000。如果未指定本参数,则保留IP地址的最大个数为256000。
time time:指定保留IP地址的时间,取值范围为60~4294967295,单位为秒。如果未指定本参数,则保留IP地址的时间为无限长(实际上系统限定约为136年)。
当用户下线后希望再次上线的时候还是使用第一次申请的IP地址,即保留IP地址,可以开启保留DHCP老化租约的功能并配置用户IP地址的保留类型。
· 如果用户第一次上线时,DHCP服务器记录用户的客户端ID信息和分配给用户的IP地址,当用户下线并再次上线时,仍然可以获取到之前使用的IP地址,这种保留模式为按客户端ID保留。
· 如果用户第一次上线时,DHCP服务器记录用户的MAC地址和分配给用户的IP地址,当用户下线并再次上线时,仍然可以获取到之前使用的IP地址,这种保留模式为按MAC地址保留。
执行本命令切换IP地址池下老化地址保留模式后,会删除设备上所有的按之前保留模式保存的老化租约。
# 在IP地址池0配置按照客户端ID保留IP地址的模式为按照客户端ID保留IP地址。
[Sysname] ip pool 0
[Sysname-ip-pool-0] reserve expired-ip enable
[Sysname-ip-pool-0] reserve expired-ip mode client-id
reset dhcp pool-usage peak命令用来清除IP地址池使用率峰值记录。
reset dhcp pool-usage peak [ pool pool-name ]
pool pool-name:清除指定IP地址池的使用率峰值记录。pool-name表示IP地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则清除所有IP地址池的使用率峰值记录。
执行reset dhcp pool-usage peak命令后,设备将清除所有的或指定IP地址池使用率峰值记录,释放记录表项所占用的设备资源。再次执行display dhcp pool-usage peak命令时,显示的是从执行reset dhcp pool-usage peak命令到执行display dhcp pool-usage peak命令期间,IP地址池使用率的最大值。
# 清除所有IP地址池的使用率峰值记录。
<Sysname> reset dhcp pool-usage peak
· display dhcp pool-usage
reset dhcp server conflict命令用来清除DHCP的地址冲突信息。
reset dhcp server conflict [ ip start-ip-address [ end-ip-address ] ] [ vpn-instance vpn-instance-name ]
ip start-ip-address [ end-ip-address ]:清除指定IP地址范围内的地址冲突信息。如果未指定ip参数,则表示清除所有IP地址的地址冲突信息。
· start-ip-address:起始IP地址。
· end-ip-address:结束IP地址。end-ip-address取值不能小于start-ip-address。如果仅指定start-ip-address,而未指定end-ip-address,则表示清除指定IP地址的冲突信息。
vpn-instance vpn-instance-name:指定VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示指定公网。
如果未指定任何参数,则清除公网中所有DHCP地址冲突信息。
出现冲突地址,一般是由于网络配置不合理,动态分配的地址和网络中静态配置的地址冲突而产生的。在合理调整网络配置,不再存在冲突的情况后,原来的冲突地址可能不再冲突,可以被重新分配。此时,通过本命令,清除检测到的冲突地址,则该地址可以被重新分配。
# 清除公网中全部地址冲突信息。
<Sysname> reset dhcp server conflict
reset dhcp server expired命令用来清除租约过期的地址绑定信息。
reset dhcp server expired [ [ ip start-ip-address [ end-ip-address ] ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
ip start-ip-address [ end-ip-address ]:清除指定IP地址范围内租约过期的地址绑定信息。如果未指定ip参数,则清除所有租约过期的IP地址绑定信息。
· end-ip-address:结束IP地址。end-ip-address取值不能小于start-ip-address。如果仅指定了start-ip-address,而未指定end-ip-address,则表示清除指定IP地址的租约过期地址绑定信息。
pool pool-name:清除指定IP地址池中租约过期的地址绑定信息。pool-name表示IP地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则清除所有IP地址池的租约过期地址绑定信息。
如果未指定任何参数,则清除公网中所有租约过期的地址绑定信息。
# 清除公网中所有租约过期的地址绑定信息。
<Sysname> reset dhcp server expired
reset dhcp server ip-in-use命令用来清除DHCP的正式绑定和临时绑定信息。
reset dhcp server ip-in-use [ [ ip start-ip-address [ end-ip-address ] | relay-address ip-address ] [ vpn-instance vpn-instance-name ] | pool pool-name [ relay-address ip-address ] ]
ip start-ip-address [ end-ip-address ]:清除指定IP地址范围内的正式绑定和临时绑定信息。如果未指定ip参数,则表示清除所有IP地址的正式绑定和临时绑定信息。
· end-ip-address:结束IP地址。end-ip-address取值不能小于start-ip-address。如果仅指定了start-ip-address,而未指定end-ip-address,则表示清除指定IP地址的正式绑定和临时绑定信息。
relay-address ip-address:清除指定中继下的正式绑定和临时绑定信息。ip-address表示连接DHCP客户端的中继接口的IP地址。
pool pool-name:清除指定IP地址池的正式绑定和临时绑定信息。pool-name表示IP地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则清除所有IP地址池的正式绑定和临时绑定信息。
relay-address ip-address:清除IP地址池中指定中继下的正式绑定和临时绑定信息。ip-address表示连接DHCP客户端的中继接口的IP地址。
如果未指定任何参数,则清除设备上公网中所有的正式绑定和临时绑定信息。
清除静态正式绑定信息时,将使该绑定信息变为静态无效绑定。
# 清除地址10.110.1.1的正式绑定和临时绑定信息。
<Sysname> reset dhcp server ip-in-use ip 10.110.1.1
· display dhcp server ip-in-use
reset dhcp server packet statistics命令用来清除DHCP服务器的报文统计信息。
reset dhcp server packet statistics [ vpn-instance vpn-instance-name ]
# 清除公网中所有的DHCP服务器的报文统计信息。
<Sysname> reset dhcp server packet statistics
reset dhcp-access packet statistics命令用来清除DHCP接入模块的报文统计信息。
# 清除DHCP接入模块的报文统计信息。
<Sysname> reset dhcp-access packet statistics
· display dhcp-access packet statistics
route-log enable命令用来开启单个IP地址池路由日志功能。
undo route-log enable命令用来关闭单个IP地址池路由日志功能。
route-log enable
IP地址池路由日志功能处于关闭状态。
IP地址池视图
开启本功能后,当添加或删除单个IP地址池的网段路由等路由事件发生时,设备会打印日志信息。
用户可以使用dhcp route-log enable命令或route-log enable命令开启IP地址池路由日志功能。两者的配置关系如下:
· 配置dhcp route-log enable命令后,设备上所有类型IP地址池的路由日志功能将被开启。
· 如果只想开启某个IP地址池的路由日志功能,需要关闭全局IP地址池路由日志功能,仅在该地址池视图下配置route-log enable命令。
· 全局IP地址池路由日志功能开启时,为了避免输出大量日志信息淹没有用信息,可以在IP地址池下通过undo route-log enable命令关闭部分地址池的路由日志功能。
# 开启IP地址池1的路由日志功能。
[Sysname] ip pool 1
[Sysname-ip-pool-1] route-log enable
· dhcp route-log enable
snmp-agent trap enable dhcp server命令用来开启DHCP服务器的告警功能。
undo snmp-agent trap enable dhcp server命令用来关闭DHCP服务器的告警功能。
snmp-agent trap enable dhcp server [ address-exhaust | allocated-ip | ip-alloc-failed | ip-in-use | pool-group-exhaust | pool-group-threshold ] *
undo snmp-agent trap enable dhcp server [ address-exhaust | allocated-ip | ip-alloc-failed | ip-in-use | pool-group-exhaust | pool-group-threshold ] *
DHCP服务器的告警功能均处于开启状态。
address-exhaust:表示单个IP地址池的地址资源耗尽/恢复的告警信息。
allocated-ip:表示DHCP服务器上所有地址池过去5分钟内地址成功分配率低于阈值的告警信息。使用命令dhcp server allocated-ip threshold可配置门限阈值。
ip-alloc-failed:表示DHCP服务器分配地址失败的告警信息。
ip-in-use:表示单个IP地址池在采样时刻的地址使用率高于等于阈值或恢复到低于阈值的告警信息。使用命令ip-in-use threshold可配置门限阈值。
pool-group-exhaust:表示IP地址池组中的地址资源耗尽/恢复的告警信息。
pool-group-threshold:表示单个IP地址池组中的地址使用率高于等于阈值或恢复到低于阈值的告警信息。使用命令ip-in-use threshold可配置地址池组中地址资源使用率门限阈值。
如果未指定任何参数,将开启DHCP服务器所有类型的告警功能。
开启DHCP服务器模块的告警功能后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
# 关闭DHCP服务器的所有告警功能。
[Sysname] undo snmp-agent trap enable dhcp server
# 关闭DHCP服务器地址池的地址资源耗尽/恢复的告警功能。
[Sysname] undo snmp-agent trap enable dhcp server address-exhaust
# 关闭DHCP服务器的地址成功分配率低于门限阈值告警功能。
[Sysname] undo snmp-agent trap enable dhcp server allocated-ip
# 关闭DHCP服务器地址池使用率高于等于门限阈值/恢复到低于阈值的告警功能。
[Sysname] undo snmp-agent trap enable dhcp server ip-in-use
# 关闭DHCP服务器的IP地址池组中的地址资源耗尽/恢复的告警功能。
[Sysname] undo snmp-agent trap enable dhcp server pool-group-exhaust
· dhcp server allocated-ip threshold
· ip-in-use threshold
· snmp-agent target-host(网络管理和监控命令参考/SNMP)
static-bind命令用来在IP地址池中配置静态地址绑定,以便实现DHCP服务器为客户端ID或硬件地址为指定值的客户端分配固定的IP地址。
undo static-bind命令用来删除IP地址池中的静态地址绑定。
undo static-bind ip-address ip-address
未在IP地址池中配置静态地址绑定。
IP地址池视图
ip-address ip-address:指定静态绑定的IP地址。未指定掩码长度和掩码时,表示采用自然掩码。
mask-length:静态绑定IP地址的掩码长度,即掩码中连续“1”的个数,取值范围为1~30。
mask mask:指定静态绑定IP地址的掩码,mask为点分十进制形式。
client-identifier client-identifier:指定静态绑定的客户端ID。client-identifier表示客户端ID,为4~254个字符的字符串,字符串中只能包括十六进制数和“-”,且形式为H-H-H…,除最后一个H表示2位或4位十六进制数外,其他均表示4位十六进制数。例如:aabb-cccc-dd为有效的ID,aabb-c-dddd和aabb-cc-dddd为无效客户端ID。IPoE用户不支持绑定本参数。
hardware-address hardware-address:指定静态绑定的客户端硬件地址。hardware-address表示客户端硬件地址,为4~39个字符的字符串,字符串中只能包括十六进制数和“-”,且形式为H-H-H…,除最后一个H表示2位或4位十六进制数外,其他均表示4位十六进制数。例如:aabb-cccc-dd为有效的客户端硬件地址,aabb-c-dddd和aabb-cc-dddd为无效的客户端硬件地址。PPPoE用户不支持绑定本参数。
ethernet:指定客户端硬件地址类型为以太网,缺省为以太网类型。
token-ring:指定客户端硬件地址类型为令牌环网。
静态绑定的IP地址不能是DHCP服务器的接口IP地址,否则会导致IP地址冲突,被绑定的客户端将无法正常获取到IP地址。
通过dhcp server forbidden-ip配置的不参与自动分配的IP地址,不能配置为静态绑定的IP地址。
同一IP地址池下多次执行本命令,可以配置多个静态地址绑定。
同一地址只能绑定给一个客户端。不能通过重复执行本命令修改IP地址与客户端的绑定关系。如需修改IP地址与客户端的绑定关系,请先通过undo static-bind命令删除静态地址绑定,再执行static-bind命令。
远端BAS IP地址池下不支持配置本命令。
# 在IP地址池0中配置:为客户端ID为00aa-aabb的客户端,固定分配IP地址10.1.1.1/24。
[Sysname] ip pool 0
[Sysname-ip-pool-0] static-bind ip-address 10.1.1.1 mask 255.255.255.0 client-identifier 00aa-aabb
· display ip pool
tftp-server domain-name命令用来配置IP地址池为DHCP客户端分配的TFTP服务器域名。
undo tftp-server domain-name命令用来恢复缺省情况。
未配置IP地址池为DHCP客户端分配的TFTP服务器域名。
IP地址池视图
domain-name:TFTP服务器域名,为1~63个字符的字符串,区分大小写。
# 配置IP地址池0为DHCP客户端分配的TFTP服务器域名为aaa。
[Sysname] ip pool 0
[Sysname-ip-pool-0] tftp-server domain-name aaa
· display ip pool
· tftp-server ip-address
tftp-server ip-address命令用来配置IP地址池为DHCP客户端分配的TFTP服务器地址。undo tftp-server ip-address命令用来恢复缺省情况。
未配置IP地址池为DHCP客户端分配的TFTP服务器地址。
IP地址池视图
ip-address:TFTP服务器的IP地址。
# 配置IP地址池0为DHCP客户端分配的TFTP服务器地址为10.1.1.1。
[Sysname] ip pool 0
[Sysname-ip-pool-0] tftp-server ip-address 10.1.1.1
· display ip pool
· tftp-server domain-name
unr preference命令用来配置BAS IP地址池下发给路由管理的网段路由的优先级。
undo unr preference命令用来恢复缺省情况。
unr preference preference-value
undo unr preference
BAS IP地址池下发给路由管理的网段路由的优先级为65。
本地BAS IP地址池视图/远端BAS IP地址池视图
preference-value:路由管理的网段路由的优先级,取值范围为1~255。
使用IP地址池为用户分配IP地址后,设备会将地址段对应的路由添加到路由管理中。通过本命令可以修改BAS IP地址池下发给路由管理的网段路由的优先级。优先级的值越小,相应的网段路由的优先级越高。
修改网段路由的优先级,之前分配的IP地址的优先级不受影响。
# 配置本地BAS IP地址池p1下发给路由管理的网段路由的优先级为1。
[Sysname-ip-pool-p1] unr preference 1
unr tag命令用来配置BAS IP地址池的用户网络路由标记值。
undo unr tag命令用来恢复缺省情况。
unr tag tag-value
undo unr tag
未配置BAS IP地址池的用户网络路由标记值。
tag-value:用户网络路由的标记值,取值范围为0~4294967294。
修改网段路由标记值,之前分配的IP地址的标记值不受影响。
本功能仅在BAS IP地址池才能生效。
# 配置本地BAS IP地址池p1的用户网络路由标记值为1。
[Sysname-ip-pool-p1] unr tag 1
· ip unr
valid class命令用来配置DHCP白名单包括的用户类名。
undo valid class命令用来删除DHCP白名单中包括的用户类名。
valid class class-name&<1-8>
undo valid class class-name&<1-8>
未配置DHCP白名单包括的用户类。
IP地址池视图
class-name&<1-8>:DHCP白名单包括的用户类名列表。其中class-name为DHCP用户类名,为1~63个字符的字符串,不区分大小写。&<1-8>代表最多可以输入8个用户类名,每个用户类名之间用空格分隔。
在配置了IP地址池用户白名单功能后,DHCP服务器才会检查用户是否属于白名单包括的用户类。
# 在IP地址池0中配置DHCP白名单包括的用户类名为test1和test2。
[Sysname] ip pool 0
[Sysname-ip-pool-0] valid class test1 test2
· dhcp class
· verify class
verify class命令用来开启DHCP用户类白名单功能。
undo verify class命令用来关闭DHCP用户类白名单功能。
verify class
undo verify class
DHCP用户类白名单功能处于关闭状态。
IP地址池视图
在开启了DHCP用户类白名单功能后,DHCP服务器才会检查用户是否属于白名单包括的用户类。
需要注意的是,DHCP用户类白名单功能对获取静态绑定租约的客户端不生效。
# 在IP地址池0中开启DHCP用户类白名单功能。
[Sysname] syatem-view
[Sysname] ip pool 0
[Sysname-ip-pool-0] verify class
· valid class
voice-config命令用来配置IP地址池为DHCP客户端分配的Option 184内容。
undo voice-config命令用来删除IP地址池为DHCP客户端分配的Option 184内容。
voice-config { as-ip ip-address | fail-over ip-address dialer-string | ncp-ip ip-address | voice-vlan vlan-id { disable | enable } }
undo voice-config [ as-ip | fail-over | ncp-ip | voice-vlan ]
未配置IP地址池为DHCP客户端分配的Option 184内容。
IP地址池视图
as-ip ip-address:指定备用服务器的IP地址。
fail-over ip-address dialer-string:指定自动故障转移IP地址及呼叫字符串。dialer-string为1~39个字符的字符串,字符只能是数字0~9及“*”。
ncp-ip ip-address:指定网络呼叫处理器的IP地址。
voice-vlan vlan-id:指定语音VLAN的ID。vlan-id取值范围为2~4094。
· disable:指定VLAN处于禁止状态,即DHCP客户端不会将所指定的VLAN ID作为语音VLAN。
· enable:指定VLAN处于开启状态,即DHCP客户端会将所指定的VLAN ID作为语音VLAN。
# 为IP地址池0指定Option 184的内容:网络呼叫处理器的IP地址为10.1.1.1,备用服务器的IP地址为10.2.2.2,语音VLAN的ID为3,为开启状态,自动故障转移IP地址为10.3.3.3,呼叫字符串为99*。
[Sysname] ip pool 0
[Sysname-ip-pool-0] voice-config ncp-ip 10.1.1.1
[Sysname-ip-pool-0] voice-config as-ip 10.2.2.2
[Sysname-ip-pool-0] voice-config voice-vlan 3 enable
[Sysname-ip-pool-0] voice-config fail-over 10.3.3.3 99*
· display ip pool
vpn-instance命令用来为DHCP服务器上的地址池绑定VPN实例。
undo vpn-instance命令用来恢复缺省情况。
undo vpn-instance
DHCP服务器上的地址池未绑定VPN实例。
IP地址池视图
当地址池绑定了VPN实例后,DHCP服务器可以将网络划分成公网和VPN私网。未配置VPN属性的地址池被划分到公网,配置了VPN属性的地址池被划分到相应的VPN私网,这样,对于处于公网或VPN私网中的客户端,服务器都能够选择合适的地址池来为客户端分配租约并且记录该客户端的状态信息。
DHCP客户端的VPN信息可以从认证模块获取,也可以从DHCP服务器接收报文的接口配置的VPN信息获取。如果以上两种方式都可获取VPN信息,以从认证模块获取的VPN信息为准。
# 为IP地址池0绑定的VPN实例编号为abc。
[Sysname] ip pool 0
[Sysname-ip-pool-0] vpn-instance abc
vpn-instance命令用来为地址池组绑定VPN实例。
undo vpn-instance
地址池组未绑定VPN实例。
IP地址池组视图
未配置VPN属性的地址池组被划分到公网,配置了VPN属性的地址池组被划分到相应的VPN私网。在公网中的地址池组只能为公网中的DHCP客户端分配地址和其他参数;在某个VPN中地址池组只能为该VPN内的DHCP客户端分配地址和其他参数。
# 为IP地址池组g1绑定的VPN实例编号为abc。
[Sysname] ip pool-group g1
[Sysname-ip-pool-group-g1] vpn-instance abc
dhcp relay always-unicast命令用来开启DHCP中继单播转发DHCP应答报文功能。
undo dhcp relay always-unicast命令用来恢复缺省情况。
DHCP中继根据应答报文中的广播标志位选择广播还是单播转发DHCP应答报文。
开启DHCP中继单播转发应答报文功能后,DHCP中继会忽略DHCP应答报文中的广播标志位,统一以单播形式向DHCP客户端转发DHCP应答报文。
# 开启DHCP中继单播转发DHCP应答报文功能。
[Sysname] dhcp relay always-unicast
· dhcp select relay
dhcp relay check mac-address命令用来开启DHCP中继的MAC地址检查功能。
undo dhcp relay check mac-address命令用来关闭DHCP中继的MAC地址检查功能。
DHCP中继的MAC地址检查功能处于关闭状态。
开启该功能后,DHCP中继检查接收到的DHCP请求报文中的chaddr字段和数据帧的源MAC地址字段是否一致。如果一致,则认为该报文合法,将其转发给DHCP服务器;如果不一致,则丢弃该报文。
只有在接口上配置dhcp select relay后,DHCP中继的MAC地址检查功能才会生效。
由于DHCP中继转发DHCP报文时会修改报文的源MAC地址,所以只能在靠近DHCP客户端的第一跳DHCP中继设备上开启MAC地址检查功能。
# 开启DHCP中继的MAC地址检查功能。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] dhcp relay check mac-address
· dhcp select relay
dhcp relay client-information record命令用来开启DHCP中继用户地址表项记录功能。
undo dhcp relay client-information record命令用来关闭DHCP中继用户地址表项记录功能。
DHCP中继用户地址表项记录功能处于关闭状态。
当DHCP中继作为DHCP客户端的网关设备时,才会记录此DHCP客户端的地址表项。DHCP中继用户地址表项记录了DHCP客户端的IP地址、MAC地址和用户地址表项类型等信息。
关闭DHCP中继用户地址表项记录功能时,会删除DHCP中继上记录的全部地址表项。
对于广域网接入类型(如IPoE和PPPoE)的用户,本命令不生效:
· 当接入用户通过配置了授权地址池的DHCP中继上线时,DHCP中继无法记录用户地址表项。
· 当接入用户通过未配置授权地址池的DHCP中继上线时,DHCP中继用户地址表项记录功能自动开启且无法关闭,DHCP中继会一直记录此类接入用户的地址表项。
# 开启DHCP中继用户地址表项记录功能。
[Sysname] dhcp relay client-information record
· dhcp conflict-ip-address offline
· dhcp relay client-information refresh
· dhcp relay client-information refresh enable
dhcp relay client-information refresh命令用来配置DHCP中继动态用户地址表项的定时刷新周期。
undo dhcp relay client-information refresh命令用来恢复缺省情况。
dhcp relay client-information refresh { auto | interval interval }
定时刷新周期为auto,即根据表项的数目自动计算刷新时间间隔。
auto:指定根据表项的数目自动计算刷新时间间隔。表项越多,刷新时间间隔越短,但最短时间间隔不会小于50毫秒。
interval interval:刷新时间间隔,取值范围为1~120,单位为秒。
对于广域网接入类型(如IPoE和PPPoE)的用户,本命令不生效。
# 配置DHCP中继动态用户地址表项的刷新时间间隔为100秒。
[Sysname] dhcp relay client-information refresh interval 100
· dhcp relay client-information record
dhcp relay client-information refresh enable命令用来开启DHCP中继动态用户地址表项定时刷新功能。
undo dhcp relay client-information refresh enable命令用来关闭DHCP中继动态用户地址表项定时刷新功能。
DHCP中继动态用户地址表项定时刷新功能处于开启状态。
DHCP中继动态用户地址表项定时刷新功能开启时,DHCP中继每隔指定时间采用客户端获取到的IP地址和DHCP中继接口的MAC地址向DHCP服务器发送DHCP-REQUEST报文:
· 如果DHCP中继接收到DHCP服务器响应的DHCP-ACK报文或在指定时间内未接收到DHCP服务器的响应报文,则表明这个IP地址已经可以进行分配,DHCP中继会删除动态用户地址表中对应的表项,为了避免地址浪费,DHCP中继收到DHCP-ACK报文后,会发送DHCP-RELEASE报文释放申请到的IP地址。
· 如果DHCP中继接收到DHCP服务器响应的DHCP-NAK报文,则表示该IP地址的绑定信息仍然存在,DHCP中继不会删除该IP地址对应的表项。
需要注意的是,关闭DHCP中继动态用户地址表项定时刷新功能时,DHCP中继上记录的用户地址表项不会自动老化。DHCP客户端释放申请到的IP地址后,需要用户执行reset dhcp relay client-information命令删除DHCP中继上对应的用户地址表项。
对于广域网接入类型(如IPoE和PPPoE)的用户,本命令不生效。此类接入用户通过未配置授权地址池的DHCP中继上线时,DHCP中继记录的用户地址表项会根据租约自动老化,当租约到期后会同步删除DHCP中继上对应的用户地址表项。
# 关闭DHCP中继动态用户地址表项定时刷新功能。
[Sysname] undo dhcp relay client-information refresh enable
· reset dhcp relay client-information
dhcp relay dhcp-server timeout命令用来配置DHCP服务器应答超时切换时间。
undo dhcp relay dhcp-server timeout命令用来恢复缺省情况。
dhcp relay dhcp-server timeout time
DHCP服务器应答超时切换时间为30秒。
time:超时切换时间,取值范围为1~65535,单位为秒。
# 在接口Ten-GigabitEthernet3/0/1上配置DHCP服务器应答超时切换时间为60秒。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp relay dhcp-server timeout 60
· dhcp relay server-address algorithm
dhcp relay forward reply by-option82命令用来配置DHCP中继通过Option 82信息转发DHCP应答报文。
undo dhcp relay forward reply by-option82命令用来恢复缺省情况。
DHCP中继不通过Option 82信息转发DHCP应答报文。
本功能需要同时配置dhcp relay information enable和dhcp relay information circuit-id命令才能生效。
# 在接口Ten-GigabitEthernet3/0/1上配置DHCP中继通过Option 82信息转发DHCP应答报文。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp relay forward reply by-option82
· dhcp relay information circuit-id
· dhcp relay information enable
dhcp relay gateway命令用来配置DHCP中继在DHCP报文中填充的中继地址。
undo dhcp relay gateway命令用来恢复缺省情况。
dhcp relay gateway ip-address
DHCP中继在DHCP报文中填充的中继地址是接口下的主IP地址。
ip-address:中继地址。该地址必须属于命令行所在的接口。
在接口视图下配置此命令后,中继会使用此命令配置的地址作为中继地址。
# 在接口Ten-GigabitEthernet3/0/1上配置在DHCP报文中填充的中继地址为10.1.1.1。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp relay gateway 10.1.1.1
· gateway-list
dhcp relay information circuit-id命令用来配置Option 82的Circuit ID子选项的填充模式和填充格式。
undo dhcp relay information circuit-id命令用来恢复缺省情况。
dhcp relay information circuit-id { bas [ sub-interface-vlan ] [ with-vxlan ] | string circuit-id | { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] [ interface [ vlan-in-vlan ] ] } [ sub-interface-vlan ] [ format { ascii | hex } ] }
Option 82的Circuit ID子选项的填充模式为Normal,填充格式为hex。
bas:表示支持使用工信部规范的格式填充Circuit ID子选项。填充内容包括接口信息、VLAN信息,封装格式为:interface-type slot/subslot/port vxlan_id.vlan_id.subvlan_id。
sub-interface-vlan:以L2VE子接口所在的VLAN的VLAN编号来填充Circuit ID子选项。本参数只用于L3VE接口。如果未指定本参数,则表示填充的是配置本命令所在接口的VLAN ID。本设备暂不支持该参数。
with-vxlan:表示支持使用带有VXLAN ID的电信格式内容填充Circuit子选项。如果未指定本参数,则表示支持使用不带有VXLAN ID的电信格式内容来填充Circuit子选项。
string circuit-id:指定以用户配置的字符串填充Circuit ID子选项。circuit-id表示用户配置的用来填充Circuit ID子选项的内容,为3~63个字符的字符串,区分大小写。
normal:指定以Normal模式填充Circuit ID子选项,填充内容为VLAN ID和端口号。
verbose:指定以Verbose模式填充Circuit ID子选项。填充的内容为节点标识、接口信息和接口所在的VLAN编号。节点标识缺省以节点的MAC地址构成;接口信息缺省由以太网类型(取值固定为“eth”)、框号、槽号、子槽号和接口编号组成。
node-identifier { mac | sysname | user-defined node-identifier }:指定接入节点标识。
· mac:表示以节点的MAC地址作为节点标识。
· sysname:表示以节点的设备名称作为节点标识。设备的系统名称可以通过系统视图下的sysname命令配置。不管配置了哪种填充格式,设备的系统名称始终采用ASCII码格式填充。
系统名称中不能包含空格,否则DHCP中继添加或替换Option 82失败。
· user-defined node-identifier:表示以指定的字符串作为节点标识,node-identifier为1~50个字符的字符串,区分大小写。不管配置了哪种填充格式,指定的字符串始终采用ASCII码格式填充。
interface:表示以接口名构成接口信息,始终采用ASCII码格式填充。配置本参数后,VLAN ID也采用ASCII码格式填充。
vlan-in-vlan:表示填充的是请求报文所在的两层VLAN信息,始终采用ASCII码格式填充。只有配置sysname类型的接入节点标识,才支持本参数。
format:指定Circuit ID子选项的填充格式。
ascii:指定以ASCII码格式填充Circuit ID子选项,即将数值转换为对应的ASCII码填充到Circuit ID子选项。
hex:指定以十六进制数值的格式填充Circuit ID子选项。
以不同模式填充Circuit ID子选项时,填充格式有所不同:
· 以用户配置的字符串填充Circuit ID子选项时,填充格式固定为ASCII码格式;
· 以Normal和Verbose模式填充Circuit ID子选项时,填充格式由本命令的配置决定。
如果本命令中未指定填充格式,则对于Normal模式,VLAN ID和端口号均以hex格式填充;对于Verbose模式,节点标识(MAC地址、设备的系统名称或指定的字符串)、以太网类型、框号、槽号、子槽号、接口编号均以ASCII码格式填充,VLAN ID以hex格式填充。
· 如果本命令中指定填充格式为ascii,则所有内容均以ASCII码格式填充。
· 如果本命令中指定填充格式为hex,则对于Normal模式,VLAN ID和端口号均以hex格式填充;对于Verbose模式,设备的节点标识、以太网类型以ASCII码格式填充,其余内容均以hex格式填充。
Option 82的Circuit ID子选项信息中无法携带接口拆分信息或子接口信息,关于“接口拆分”和“子接口”的详细介绍,请参见“接口管理配置指导”中的“以太网接口”。
# 配置以Verbose模式填充Option 82的Circuit ID子选项,节点标识为设备的系统名称,填充格式为ASCII码格式。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp relay information enable
[Sysname-Ten-GigabitEthernet3/0/1] dhcp relay information strategy replace
[Sysname-Ten-GigabitEthernet3/0/1] dhcp relay information circuit-id verbose node-identifier sysname format ascii
· dhcp relay forward reply by-option82
· dhcp relay information strategy
· display dhcp relay information
dhcp relay information enable命令用来开启DHCP中继支持Option 82功能。
undo dhcp relay information enable命令用来关闭DHCP中继支持Option 82功能。
DHCP中继支持Option 82功能处于关闭状态。
开启DHCP中继支持Option 82功能后,DHCP中继将向转发给DHCP服务器的请求报文中增加Option 82选项。选项内容由dhcp relay information circuit-id命令和dhcp relay information remote-id命令决定。如果DHCP中继收到的请求报文中已经包含Option 82选项,则按照dhcp relay information strategy命令配置的策略处理请求报文。
关闭DHCP中继支持Option 82功能后,DHCP中继不会向转发给DHCP服务器的请求报文中增加Option 82选项,也不检查收到的请求报文中是否包含Option 82选项。
# 开启DHCP中继支持Option 82功能。
· dhcp relay information remote-id
dhcp relay information remote-id命令用来配置Option 82的Remote ID子选项的填充模式和填充格式。
undo dhcp relay information remote-id命令用来恢复缺省情况。
Option 82的Remote ID子选项的填充模式为Normal、填充格式为hex。
normal:指定以Normal模式填充Remote ID子选项,填充内容为接收报文接口的MAC地址。
format:指定Remote ID子选项的填充格式。如果未配置本参数,则以hex格式填充。
ascii:指定以ASCII码格式填充Remote ID子选项,即将数值转换为对应的ASCII码填充到Remote ID子选项。
hex:指定以十六进制数值的格式填充Remote ID子选项。
string remote-id:指定以用户配置的字符串填充Remote ID子选项。remote-id表示用户配置的用来填充Remote ID子选项的内容,为1~63个字符的字符串,区分大小写。
sysname:指定以设备的系统名称填充Remote ID子选项。设备的系统名称可以通过系统视图下的sysname命令配置。
以用户配置的字符串(string)和设备的系统名称(sysname)填充Remote ID子选项时,填充内容固定为ASCII格式;以Normal模式填充Remote ID子选项时,填充内容的格式由本命令配置的填充格式决定。
# 配置采用字符串device001填充Option 82的Remote ID子选项。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp relay information remote-id string device001
dhcp relay information strategy命令用来配置DHCP中继对包含Option 82的请求报文的处理策略。
undo dhcp relay information strategy命令用来恢复缺省情况。
DHCP中继对带有Option 82的请求报文的处理策略为replace。
drop:如果报文中带有Option 82,则丢弃该报文。
keep:如果报文中带有Option 82,则保持该报文中的Option 82不变并进行转发。
replace:如果报文中带有Option 82,则按照配置的填充内容和填充格式填充Option 82,用该选项替换报文中原有的Option 82,并进行转发。
本命令仅对包含Option 82的请求报文有效。
如果开启了DHCP中继支持Option 82功能,则对于接收到的不包含Option 82的请求报文,DHCP中继的处理方式始终为在请求报文中添加Option 82,并转发给DHCP服务器。
DHCP中继对包含Option 82请求报文的处理策略为replace时,需要配置Option 82的填充模式和填充格式;处理策略为keep或drop时,不需要配置Option 82选项的填充模式和填充格式。
# 配置接收到的请求报文中带有Option 82时,DHCP中继保持该报文中的Option 82不变并进行转发。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp relay information strategy keep
dhcp relay master-server switch-delay命令用来配置回切主用DHCP服务器并指定回切延迟时间。
undo dhcp relay master-server switch-delay命令用来恢复缺省情况。
dhcp relay master-server switch-delay delay-time
DHCP中继不回切到主用DHCP服务器。
delay-time:延迟时间,取值范围为1~65535,单位为分钟。
# 在接口Ten-GigabitEthernet3/0/1上配置回切主用DHCP服务器并指定回切延迟时间为3分钟。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp relay master-server switch-delay 3
dhcp relay non-first-hop enable命令用来开启非首跳DHCP中继功能。
undo dhcp relay non-first-hop enable命令用来关闭非首跳DHCP中继功能。
非首跳DHCP中继功能处于关闭状态。
在某些网络环境中,在DHCP客户端和DHCP服务器之间可能存在多跳DHCP中继。缺省情况下,只有连接DHCP客户端的第一跳DHCP中继处理DHCP请求报文,后续的DHCP中继只会转发该报文。若需要在非第一跳DHCP中继设备上开启接入认证功能,则需要在该DHCP中继设备开启本功能,DHCP中继收到DHCP请求报文后,会将报文发送接入认证模块进行用户的认证、授权等操作。
本命令只适用于接入认证组网环境,普通组网不需要配置本功能。只需要在开启接入认证功能的DHCP中继开启本功能,其他中继不需要配置本功能。
需要在DHCP中继的上行口和下行口同时配置本命令,本功能才正常生效。
只有开启了DHCP中继功能后,本功能才生效。
对于开启本功能的非首跳中继设备,不能配置如下命令修改报文的giaddr字段,否则将导致报文转发异常:
· dhcp relay gateway
· dhcp relay source-address
# 在接口Ten-GigabitEthernet3/0/1上开启非首跳DHCP中继功能。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp relay non-first-hop enable
· dhcp select relay
dhcp relay release ip命令用来配置向DHCP服务器请求释放客户端申请到的IP地址。
ip-address:请求释放的DHCP客户端IP地址。
如果DHCP中继上存在客户端IP地址对应的动态用户地址表项,则配置通过DHCP中继释放该客户端IP地址后,DHCP中继会主动向DHCP服务器发送DHCP-RELEASE报文。DHCP服务器收到该报文后,将会释放指定IP地址的绑定信息。DHCP中继也会删除该动态用户地址表项。
# 向DHCP服务器请求释放客户端申请到的IP地址1.1.1.1。
[Sysname] dhcp relay release ip 1.1.1.1
dhcp relay release-agent命令用来配置清除用户表项时通知DHCP服务器释放租约。
undo dhcp relay release-agent命令用来配置清除用户表项时不通知DHCP服务器释放租约。
清除用户表项时会通知DHCP服务器释放租约。
对于普通非接入用户,本功能不生效,DHCP中继清除用户表项时不会通知服务器释放租约。
对于PPPoE用户,当通过cut access-user命令强制用户下线时,本功能不生效,DHCP中继始终会通知服务器释放租约。cut access-user命令的详细介绍请参见“BRAS业务命令参考”中的“UCM”。
# 在接口Ten-GigabitEthernet3/0/1上配置清除用户表项时不通知DHCP服务器释放租约。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp select relay
[Sysname-Ten-GigabitEthernet3/0/1] undo dhcp relay release-agent
· cut access-user(BRAS业务命令参考/UCM)
· dhcp select relay
dhcp relay server-address命令用来在DHCP中继上指定DHCP服务器的地址。
undo dhcp relay server-address命令用来在DHCP中继上删除指定DHCP服务器的地址。
dhcp relay server-address ip-address [ public | vpn-instance vpn-instance-name ]
undo dhcp relay server-address [ ip-address [ public | vpn-instance vpn-instance-name ] ]
在DHCP中继上未指定DHCP服务器的地址。
ip-address:DHCP服务器的IP地址。DHCP中继将DHCP客户端发送的报文转发到该地址。
public:为DHCP中继配置的DHCP服务器地址属于公网。
vpn-instance vpn-instance-name:为DHCP中继配置的DHCP服务器地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~32个字符的字符串,区分大小写。
指定的DHCP服务器IP地址不能与DHCP中继的接口IP地址在同一网段。否则,可能导致客户端无法获得IP地址。
如果指定了vpn-instance参数,则DHCP中继根据配置的DHCP服务器地址对应的VPN信息,向该VPN内的DHCP服务器转发报文。如果未指定public和vpn-instance vpn-instance-name参数,则以当前DHCP客户端位置(公网或VPN)为准。
通过多次执行dhcp relay server-address命令可以指定多个DHCP服务器地址。一个接口上最多可以指定8个DHCP服务器地址。DHCP中继接收到DHCP客户端发送的报文后,将其转发给所有的DHCP服务器。
执行undo dhcp relay server-address命令时,如果未指定ip-address参数,则删除接口上的所有DHCP服务器地址。
# 在接口Ten-GigabitEthernet3/0/1上为DHCP中继指定DHCP服务器的地址为1.1.1.1。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp relay server-address 1.1.1.1
· dhcp select relay
· display dhcp relay interface
· display dhcp relay remote-server-info
dhcp relay server-address algorithm命令用来配置DHCP中继选择DHCP服务器方式。
undo dhcp relay server-address algorithm命令用来恢复缺省情况。
dhcp relay server-address algorithm { master-backup | polling }
DHCP中继同时向所有DHCP服务器转发DHCP请求报文(polling方式)。
master-backup:主备方式,即DHCP中继向主用DHCP服务器转发DHCP请求报文,当主用DHCP服务器不可用或没有空闲地址时,再按照服务器地址配置顺序依次向其他备用DHCP服务器发送DHCP请求报文。
polling:全部方式,即DHCP中继同时向所有DHCP服务器转发DHCP请求报文。
# 在接口Ten-GigabitEthernet3/0/1上配置DHCP中继使用主备方式选择DHCP服务器。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp relay server-address algorithm master-backup
· dhcp relay dhcp-server timeout
· dhcp relay master-server switch-delay
· remote-server algorithm
dhcp relay source-address命令用来指定DHCP中继向DHCP服务器转发报文的源地址。
undo dhcp relay source-address命令用来恢复缺省情况。
dhcp relay source-address { ip-address [ option code [ option-text ] ] | gateway | relay-interface }
undo dhcp relay source-address { ip-address [ option code [ option-text ] ] | gateway | relay-interface }
当DHCP中继连接服务器的接口和DHCP服务器属于同一个VPN时,将DHCP中继向DHCP服务器转发报文出接口的地址作为报文源地址;当DHCP中继连接服务器的接口和DHCP服务器不属于同一个VPN时,DHCP中继会选择一个中继上和DHCP服务器同VPN的最小地址作为报文源地址。
ip-address:指定该IP地址为发送到DHCP服务器的报文源地址和giaddr字段。
option code [ option-text ]:表示如果DHCP请求报文中携带指定的Option选项,则发送给DHCP服务器的报文源地址和giaddr字段值为指定的IP地址。如果未指定本参数,则接口接收到的所有DHCP请求报文均采用指定的IP地址作为发送给DHCP服务器的报文源地址和giaddr字段值。其中:
· code表示Option选项编号,取值范围为1~254。
· 只有当code取值为60时,才能配置option-text。option-text表示Option 60选项信息,为1~128位的字符串,区分大小写。本参数用来匹配DHCP请求报文中Option 60选项的内容,只有指定Option 60时才可以配置本字段。
gateway:DHCP中继向DHCP服务器转发报文的源地址为报文中giaddr字段地址,如果giaddr字段为空,则继续按照缺省情况填充。
relay-interface:DHCP中继向DHCP服务器转发报文的源地址为DHCP中继连接DHCP客户端的接口主IP地址,如果该接口不存在IP地址,则按照缺省情况继续填充。
当使用dhcp relay source-address命令中的ip-address时,会同时修改报文中的源地址和giaddr字段,导致giaddr字段地址和DHCP中继接口地址不在同一网段。因此,指定这个参数时需要先开启DHCP中继支持Option 82功能,DHCP中继收到DHCP请求报文时在Option 82选项填充中继接口的主IP地址,DHCP服务器可以根据该地址来给DHCP客户端分配IP地址。DHCP中继收到DHCP应答报文后,通过查找MAC地址表中的接口信息向DHCP客户端转发。
执行undo dhcp relay source-address命令时,如果未指定任何参数,则删除接口上的所有配置的源地址。
如果在同一个接口视图下重复执行如下命令,则后执行的配置覆盖之前的配置:
· dhcp relay source-address ip-address(未指定option参数)
· dhcp relay source-address gateway
· dhcp relay source-address relay-interface
dhcp relay source-address ip-address option code [ option-text ]命令不会和dhcp relay source-address { gateway | relay-interface }命令相互覆盖。
接口下配置了多个源地址时,源地址选择顺序为:
(1) 按照Option选项值从大到小的顺序依次匹配dhcp relay source-address ip-address 命令,选择匹配的第一条命令指定的源IP地址。当匹配的是Option 60时,优先选择指定了option-text参数的源IP地址,再选择未指定option-text参数的源IP地址。
(2) 选择dhcp relay source-address relay-interface命令指定的源IP地址。
(3) 选择dhcp relay source-address gateway命令指定的源IP地址。
(4) 选择dhcp relay source-address ip-address(未指定option参数)命令指定的源IP地址。
本命令与dhcp smart-relay enable命令不能同时配置。
# 在接口Ten-GigabitEthernet3/0/1上指定DHCP中继向DHCP服务器转发报文的源地址为1.1.1.1
[Sysname-Ten-GigabitEthernet3/0/1] dhcp relay source-address 1.1.1.1
dhcp server命令用来配置DHCP服务器可用性探测功能。
undo dhcp server命令用来恢复缺省情况。
dhcp server [ ip-address [ vpn-instance vpn-instance-name ] ] { dead-count dead-count-value | dead-time dead-time | nak-count nak-count-value | timeout timeout } *
undo dhcp server [ ip-address [ vpn-instance vpn-instance-name ] ] { dead-count | dead-time | nak-count | timeout } *
DHCP中继在25秒后还未收到DHCP服务器的应答,则DHCP中继认为该DHCP服务器不可用或没有空闲地址。
ip-address:配置DHCP中继判断指定DHCP服务器是否可用的条件。如果未指定本参数,则表示配置的是所有DHCP服务器不可用的共用判断条件。
dead-count dead-count-value:指定DHCP服务器连续未回复DHCP应答报文的最大次数。dead-count-value的取值范围为1~64,缺省值为0。
dead-time dead-time:指定DHCP中继认为DHCP服务器不可用的时长。到时后,则DHCP中继重新认为DHCP服务器可用。dead-time的取值范围为1~65536,单位为分钟,缺省值为3。
nak-count nak-count-value:指定DHCP中继允许接收DHCP-NAK报文的最大个数。nak-count-value的取值范围为0~255,缺省值为10。
timeout timeout:指定DHCP中继检查是否收到DHCP服务器回复DHCP应答报文的时间间隔。timeout的取值范围为1~60,单位为秒,缺省值为25。
本功能只适用于IP地址池组中的远端BAS IP地址池选择DHCP服务器的组网环境。
对于同一台DHCP服务器来说,DHCP中继优先使用指定判断条件;如果指定判断条件不存在,则使用共用判断条件。
配置本功能后,DHCP中继根据如下原则判断DHCP服务器是否可用:
· 当DHCP中继向DHCP服务器转发第一个DHCP请求报文时,开始对请求报文进行计数,并开始计时。DHCP中继会在每次转发请求报文时重新开始timeout计时,每经过一个timeout时长后,DHCP中继都会检查向DHCP服务器转发的报文数。
¡ 如果中继发送请求报文后在timeout内收到应答报文,则中继认为该服务器可用,并将请求报文计数清零,同时关闭timeout计时器。再次发送请求报文时,中继会重新进行报文计数,并重新开始timeout计时。
¡ 如果中继向服务器转发的请求报文数不多于dead-count-value且未收到一个应答报文,则请求报文数持续累计。当请求报文数多于dead-count-value却仍未收到一个应答报文时,中继认为该DHCP服务器不可用或没有空闲地址。
· 当DHCP中继在转发了用户续约报文后连续收到DHCP服务器应答的nak-count个DHCP-NAK报文后,也会认为该DHCP服务器不可用或没有空闲地址。
当DHCP中继认为DHCP服务器不可用后:
· 在dead-time时长内,该DHCP服务器处于不可用状态。如果在dead-time时长内匹配到该DHCP服务器时,则不会向其转发DHCP请求报文。经过dead-time时长后,DHCP中继会重新认为该DHCP服务器可用。当再次匹配到该DHCP服务器时,会向其转发DHCP请求报文。
· 当DHCP中继认为所有DHCP服务器都不可用后,如果DHCP中继收到一个请求报文,则远端BAS IP地址池会重新认为所有的DHCP服务器可用,并重新开始向第一个DHCP服务器转发报文。
对于将DHCP中继选择DHCP服务器方式配置成polling方式的远端BAS IP地址池:
· 如果远端BAS IP地址池下各个DHCP服务器配置的可用判断条件不同,则中继会选择timeout值最大的配置,且仅通过该条配置指定的DHCP服务器判断可用性。如果该DHCP服务器不可用,则该远端BAS IP地址池下的所有DHCP服务器均置为不可用。
· 如果存在不同DHCP服务器配置了相同的最大timeout,则选择最先下发的那条配置。
多次配置dhcp server命令时,如果ip-address参数取值不同,则可以配置多条。如果ip-address参数取值相同,或者不带ip-address参数时,则配置相同参数时,最后一次配置生效,配置不同参数时,所有配置均可以生效。
# 配置DHCP中继判断IP地址为1.1.1.1的DHCP服务器是否可用的条件:指定DHCP服务器连续未回复DHCP应答报文的最大次数为10,DHCP中继等待DHCP服务器回复DHCP应答报文的超时时长为20秒,DHCP中继认为DHCP服务器不可用的时长为3分钟。
[Sysname] dhcp server 1.1.1.1 dead-count 10 timeout 20 dead-time 3
dhcp smart-relay enable命令用来开启DHCP中继支持smart-relay功能。
undo dhcp smart-relay enable命令用来关闭DHCP中继支持smart-relay功能。
DHCP中继支持smart-relay功能处于关闭状态。
未开启smart-relay功能时,DHCP中继只能使用中继接口的主IP地址填充请求报文的giaddr字段。开启smart-relay功能后,当DHCP中继转发3次DHCP-DISCOVER报文后,若还未收到DHCP服务器的应答报文,则DHCP中继可以使用除中继接口主地址外的其他IP地址来填充giaddr字段。
本命令与dhcp relay source-address命令不能同时配置。
# 开启DHCP中继支持smart-relay功能。
[Sysname] dhcp smart-relay enable
· dhcp select
· gateway-list
dhcp-proxy enable命令用来开启DHCP代理功能。
undo dhcp-proxy enable命令用于关闭DHCP代理功能。
dhcp-proxy enable
DHCP代理功能处于开启状态。
当设备工作在DHCP代理模式时,如果收到DHCP客户端发来的DHCP请求报文,将报文转发给DHCP服务器,由DHCP服务器为DHCP客户端分配地址等参数;如果收到DHCP服务器发来的应答报文,首先将报文中的DHCP服务器地址修改为报文出接口或giaddr字段的地址,然后发送给DHCP客户端。
# 在接口Ten-GigabitEthernet3/0/1上开启DHCP代理功能
[Sysname-Ten-GigabitEthernet3/0/1] dhcp-proxy enable
dhcp-server nak-count命令用来配置DHCP中继允许从同一个DHCP服务器接收DHCP-NAK报文的最大个数。
undo dhcp-server nak-count命令用来恢复缺省情况。
dhcp-server nak-count nak-count-value [ gateway-only ]
DHCP中继允许从同一个DHCP服务器接收DHCP-NAK报文的最大个数为10。
远端BAS IP地址池视图
普通IP地址池视图
nak-count-value:DHCP-NAK报文的最大个数,取值范围为0~255。
gateway-only:当DHCP中继收到DHCP-NAK报文的最大个数达到配置的最大值时,中继不会向下一个DHCP服务器发送续约报文。如果未指定本参数,则DHCP中继会向下一个DHCP服务器发送续约报文。
本功能只适用于DHCP中继使用主备方式选择DHCP服务器的组网环境中。
当DHCP中继使用远端BAS IP地址池指定DHCP服务器地址时,可以通过配置gateway-list命令指定多个类型用户所在网段地址。当收到DHCP客户端的续约请求报文后,DHCP中继会向主备方式当前选择到的DHCP服务器地址转发DHCP续约请求报文。当DHCP中继收到该DHCP服务器应答的DHCP-NAK报文达到配置的最大值时,DHCP中继会执行以下操作:
· 如果未配置gateway-only参数,则DHCP中继会继续向下一个DHCP服务器发送续约报文;
· 如果配置了gateway-only参数并开启了DHCP中继的smart-relay功能,则DHCP中继使用gateway-list命令配置的下一个地址修改DHCP请求报文中的giaddr字段;
· 如果未配置gateway-only参数并开启DHCP中继的smart-relay功能,则DHCP中继既会向下一个DHCP服务器发送续约报文,也会使用gateway-list命令配置的下一个地址修改DHCP请求报文中的giaddr字段。
如果nak-count-value参数设置为0,DHCP中继使用主备方式选择DHCP服务器的功能不生效;如果同时还开启smart-relay功能,则smart relay功能也不生效。
# 配置DHCP中继允许从同一个DHCP服务器接收DHCP-NAK报文的最大个数为20。
[Sysname] ip poo1 1 bas remote
[Sysname-pool-1] dhcp-server nak-count 20
· dhcp smart-relay enable
· remote-server algorithm master-backup
dhcp-server source-address命令用来指定DHCP中继向DHCP服务器转发报文的源地址。
undo dhcp-server source-address命令用来恢复缺省情况。
dhcp-server source-address { ip-address | gateway | interface interface-type interface-number }
远端BAS IP地址池视图
普通IP地址池视图
ip-address:使用指定的地址作为向服务器转发报文的源地址。
gateway:使用报文的giaddr字段地址作为向服务器转发报文的源地址。如果giaddr字段为空,则按照缺省情况填充。
interface interface-type interface-number:指定该接口IP地址为发送到DHCP服务器的报文源地址。interface-type interface-number表示接口类型和接口编号。
在某些组网中,多个DHCP中继接口IP地址相同或者中继接口IP到服务器没有可达路由,用户需要配置本命令选择中继设备上的另一个接口(一般选择的是Loopback口)的IP地址填充到发送到DHCP服务器的DHCP请求报文中的源地址字段。
当多个DHCP中继接口IP地址相同时,导致DHCP中继转发DHCP应答报文时候无法根据目的IP地址找到唯一的出接口。配置本功能时需要先开启DHCP中继支持Option 82功能,DHCP中继收到DHCP请求报文时在Option 82中的子选项sub-option5填充正确的子网网段,服务器可以根据中继填充的sub-option5 来分配地址,之后DHCP中继处理DHCP应答报文时通过MAC地址表中的接口信息转发DHCP应答报文。
多次执行命令,最后一次执行的命令生效。
# 在远端BAS IP地址池0中,配置DHCPv4服务器发送报文的源地址1.1.1.1。
[Sysname] ip pool 0 bas remote
[Sysname-ip-pool-0] dhcp-server source-address 1.1.1.1
undo dhcp-server timeout命令用来恢复缺省情况。
配置DHCP服务器应答超时切换时间为30秒。
远端BAS IP地址池视图
普通IP地址池视图
# 在远端BAS IP地址池0中配置DHCP服务器应答超时切换时间为60秒。
[Sysname-ip-pool-0] dhcp-server timeout 60
discover-nak-count命令用来配置DHCP中继收到应答DHCP-DISCOVER报文的DHCP-NAK报文后,切换到向下一个远端BAS IP地址池对应的服务器转发报文的条件。
undo discover-nak-count命令用来恢复缺省情况。
discover-nak-count nak-count seconds
DHCP中继无论收到多少应答DHCP-DISCOVER报文的DHCP-NAK报文,都无法切换到向下一个远端BAS IP地址池对应的服务器转发报文。
IP地址池组视图
nak-count:收到应答DHCP-DISCOVER报文的DHCP-NAK报文的数目,取值范围为1~255,单位为个。当配置为1时,则无论seconds取值多少,DHCP中继收到1个DHCP-NAK报文后,立刻切换到向下一个远端BAS IP地址池对应的服务器转发报文。
seconds:检测时长,取值范围为1~180,单位为秒。
某些DHCP服务器上的地址池中不存在可分配的DHCP地址时,收到DHCP客户端发送的DHCP-DISCOVER报文后,会应答DHCP-NAK报文。DHCP中继收到DHCP-NAK报文后,会将该报文直接转发给DHCP客户端。如果DHCP中继上创建了IP地址池组,且在IP地址池组中添加了多个远端BAS IP地址池。DHCP中继无论收到多少应答DHCP-DISCOVER报文的DHCP-NAK报文,也不会切换到下一个远端BAS IP地址池。这就导致DHCP中继将收到的DHCP请求报文全部转发给不存在可分配的DHCP地址的DHCP服务器,DHCP客户端无法获取到DHCP地址。配置本功能后,当DHCP中继在seconds时间内收到应答DHCP-DISCOVER报文的DHCP-NAK报文数超过nak-count时,将切换到下一个远端BAS IP地址池对应的服务器转发报文,保证DHCP客户端可以获取到DHCP地址。
# 在IP地址池组poolgroup1上,配置当DHCP中继在10秒内收到的应答DHCP-DISCOVER报文的DHCP-NAK报文超过3个时,则切换到向下一个远端BAS IP地址池对应的服务器转发报文。
[Sysname-ip-pool-group-poolgroup1] discover-nak-count 3 10
display dhcp relay client-information命令用来显示DHCP中继的用户地址表项信息。
interface interface-type interface-number:显示指定接口上的用户地址表项信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上的用户地址表项信息。
ip ip-address:显示指定IP地址的用户地址表项信息。如果未指定本参数,则显示所有IP地址的用户地址表项信息。
不同类型用户对DHCP中继用户地址表项记录功能的支持情况不同:
· 对于非广域网接入类型(如IPoE和PPPoE)的用户,只有执行dhcp relay client-information record命令后,DHCP中继才会记录用户地址表项信息。
· 对于通过未配置授权地址池的DHCP中继上线的广域网接入类型(如IPoE和PPPoE)的用户,DHCP中继用户地址表项记录功能自动开启且无法关闭,DHCP中继会一直记录此类接入用户的地址表项信息。
· 对于通过配置了授权地址池的DHCP中继上线的广域网接入类型(如IPoE和PPPoE)的用户,DHCP中继无法记录用户地址表项。如果管理员需要查询表项信息,需要在DHCP服务器执行display dhcp server ip-in-use命令进行查询。
# 显示所有DHCP中继的用户地址表项信息。
<Sysname> display dhcp relay client-information
Total number of client-information items: 2
Total number of dynamic items: 1
Total number of temporary items: 1
IP address MAC address Type Interface VPN name
10.1.1.1 00e0-0000-0001 Dynamic XGE3/0/1 N/A
10.1.1.5 00e0-0000-0000 Temporary XGE3/0/1 N/A
# 显示DHCP中继的指定地址的用户地址表项信息。
<Sysname> display dhcp relay client-information ip 10.1.1.1
Total number of client-information items: 1
Total number of temporary items: 0
IP address : 10.1.1.1
MAC address : 00e0-0000-0000
Type : Dynamic
Port index : N/A
Interface : Vlan2
VPN name : N/A
Server address : 12.1.1.2
Access type : CommonV4
Outer VLAN : N/A
Inner VLAN : N/A
PPP index : 0
User ID : 0x40000001
表1-21 display dhcp relay client-information命令显示信息描述表
Total number of client-information items |
用户地址信息条目总数 |
Total number of dynamic items |
动态用户地址条目总数 |
Total number of temporary items |
临时用户地址条目总数 |
IP address |
DHCP客户端的IP地址 |
MAC address |
DHCP客户端的MAC地址 |
Type |
用户地址表项类型的取值包括: · Dynamic:动态用户地址表项,接收到DHCP服务器对DHCP客户端REQUEST请求的ACK应答后,创建的用户表项 · Temporary:临时用户地址表项,接收DHCP客户端的REQUEST请求,但未收到DHCP服务器ACK应答时,创建的用户表项 |
与DHCP客户端相连的三层接口。如果用户地址表项中未记录接口,则显示为”N/A” |
VPN name |
VPN实例名称,如果表项不属于任何VPN,则显示为”N/A” |
Port index |
DHCP中继收到DHCP客户端请求报文的二层端口信息。如果报文不从二层端口进入DHCP中继,则显示为"N/A" |
Server address |
DHCP服务器地址 |
Access type |
接入类型,取值包括: · CommonV4:DHCP地址申请方式 · IPoEv4:IPoE接入方式 · PPPv4:PPP接入方式 |
Outer VLAN |
DHCP中继用户地址表项的外层VLAN Tag,若不存在,则显示为N/A |
Inner VLAN |
DHCP中继用户地址表项的内层VLAN Tag,若不存在,则显示为N/A |
PPP index |
用户地址表项对应的PPP索引,如果不存在PPP索引,则显示为N/A |
User ID |
DHCP接入用户标识值,为十六进制数 |
display dhcp relay information命令用来显示DHCP中继上的Option 82配置信息。
interface interface-type interface-number:显示指定接口上的Option 82配置信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上的Option 82配置信息。
# 显示所有接口上的Option 82配置信息。
<Sysname> display dhcp relay information
Interface: Ten-GigabitEthernet3/0/1
Status: Enable
Strategy: Replace
Circuit ID Pattern: Verbose
Remote ID Pattern: Sysname
Circuit ID format: Undefined
Remote ID format: ASCII
Node identifier: aabbcc
Interface: Ten-GigabitEthernet3/0/2
Status: Enable
Strategy: Replace
Circuit ID Pattern: User Defined
Remote ID Pattern: User Defined
Circuit ID format: ASCII
User defined:
Circuit ID: vlan100
Remote ID: device001
表1-22 display dhcp relay information命令显示信息描述表
接口名 |
Status |
Option 82的状态,取值包括: · Enable:开启了DHCP中继支持Option 82功能 · Disable:未开启DHCP中继支持Option 82功能 |
Strategy |
对包含Option 82的请求报文的处理策略,取值为Drop、Keep或Replace |
Circuit ID Pattern |
Circuit ID子选项的填充方式,取值为Verbose、Normal或User Defined |
Remote ID Pattern |
Remote ID子选项的填充方式,取值为Sysname、Normal或User Defined |
Circuit ID format |
Circuit ID子选项的填充格式,取值为ASCII、Hex或Undefined |
Remote ID format |
Remote ID子选项的填充格式,取值为ASCII、Hex或Undefined |
Node identifier |
接入节点的标识 |
User defined |
用户自定义的子选项内容 |
Circuit ID |
用户自定义的Circuit ID子选项的内容 |
Remote ID |
用户自定义的Remote ID子选项的内容 |
display dhcp relay packet statistics命令用来显示DHCP中继的相关报文统计信息。
display dhcp relay packet statistics [ interface interface-type interface-number ]
interface interface-type interface-number:指定接口,interface-type interface-number为接口类型和接口编号。如果不指定本参数,则显示所有的DHCP中继相关报文统计信息。
# 显示所有的DHCP中继相关报文统计信息。
<Sysname> display dhcp relay packet statistics
DHCP packets dropped: 0
DHCP packets received from clients: 0
DHCPDISCOVER: 0
DHCPREQUEST: 0
DHCPINFORM: 0
DHCPRELEASE: 0
DHCPDECLINE: 0
BOOTPREQUEST: 0
DHCP packets received from servers: 0
DHCPOFFER: 0
DHCPACK: 0
DHCPNAK: 0
BOOTPREPLY: 0
DHCP packets relayed to servers: 0
DHCPDISCOVER: 0
DHCPREQUEST: 0
DHCPINFORM: 0
DHCPRELEASE: 0
DHCPDECLINE: 0
BOOTPREQUEST: 0
DHCP packets relayed to clients: 0
DHCPOFFER: 0
DHCPACK: 0
DHCPNAK: 0
BOOTPREPLY: 0
DHCP packets sent to servers: 0
DHCPDISCOVER: 0
DHCPREQUEST: 0
DHCPINFORM: 0
DHCPRELEASE: 0
DHCPDECLINE: 0
BOOTPREQUEST: 0
DHCP packets sent to clients: 0
DHCPOFFER: 0
DHCPACK: 0
DHCPNAK: 0
BOOTPREPLY: 0
表1-23 display dhcp relay packet statistics命令显示信息描述表
DHCP packets dropped |
DHCP中继丢掉的报文数 |
DHCP packets received from clients |
DHCP中继从客户端接收的DHCP报文数 |
DHCP packets received from servers |
DHCP中继从服务器接收的DHCP报文数 |
DHCP packets relayed to servers |
DHCP中继转发给服务器的报文数 |
DHCP packets relayed to clients |
DHCP中继转发给客户端的报文数 |
DHCP packets sent to servers |
DHCP中继主动发送给服务器的DHCP报文数,用于实现动态用户地址表项的定时刷新 |
DHCP packets sent to clients |
DHCP中继主动发送给客户端的DHCP报文数(目前设备作为DHCP中继时,不会主动发送DHCP报文给客户端) |
· reset dhcp relay packet statistics
display dhcp relay remote-server-info命令用来显示DHCP中继的DHCP地址池对应的远端DHCP服务器配置和状态信息。
display dhcp relay remote-server-info [ vpn-instance vpn-name ] [ slot slot-number ]
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。
# 显示DHCP中继的DHCP地址池对应的远端DHCP服务器配置和状态信息。
<Sysname> display dhcp relay remote-server-info
Remote server count: 2
Remote server: 1.1.1.1 *
RemoteSrvRefCnt: 2 State: Up
CfgNakCount: 10 CfgTimeOut: 25(s) CfgDeadCount: 0 CfgDeadTime: 3(m)
RunDeadCnt: 0 RunNakCnt: 0 RunDeadTime: 1622(s)
Remote server: 1.1.1.2
RemoteSrvRefCnt: 3 State: Up
表1-24 display dhcp relay remote-server-info命令显示信息描述表
Remote server count |
远端DHCP服务器的个数 |
Remote server |
远端DHCP服务器的IP地址,*表示指定了对该IP地址对应的DHCP服务器判断是否可用的条件;否则,则显示为空 |
RemoteSrvRefCnt |
DHCP服务器被中继地址池引用的次数 |
State |
远端DHCP服务器的状态,取值包括: · Up:可用 · Down:不可用 · UnKnown:未知 |
CfgNakCount |
配置的DHCP中继允许接收DHCP-NAK报文的最大个数 |
CfgTimeOut |
配置的DHCP中继检查是否收到DHCP服务器回复的DHCP应答报文的时间间隔,单位为秒 |
CfgDeadCount |
配置的DHCP服务器连续未回复DHCP应答报文的最大次数 |
CfgDeadTime |
配置的DHCP中继认为DHCP服务器不可用的时长,单位为分钟 |
RunDeadCnt |
DHCP服务器连续未回复DHCP应答报文的次数 |
RunNakCnt |
DHCP中继接收DHCP-NAK报文的个数 |
RunDeadTime |
DHCPv6中继认为DHCPv6服务器不可用的时长,单位为秒 |
· dhcp server
· remote-server
display dhcp relay server-address命令用来显示接口上指定的DHCP服务器地址信息。
interface interface-type interface-number:显示指定接口上的DHCP服务器地址信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上的DHCP服务器地址信息。
# 显示所有接口上指定的DHCP服务器地址信息。
<Sysname> display dhcp relay server-address
Interface name Server IP address Public/VRF name
XGE3/0/1 2.2.2.2 Y/--
# 显示三层以太网接口Ten-GigabitEthernet3/0/1上指定的DHCP服务器地址信息。
<Sysname> display dhcp relay server-address interface ten-gigabitethernet 3/0/1
Active server address: 2.2.2.2
表1-25 display dhcp relay server-address命令显示信息描述表
Active server address: |
当前活跃的DHCP服务器地址,取值包括: · 如果显示为All,表示当前配置的DHCP服务器选择方式为全部方式,即DHCP中继同时向所有DHCP服务器转发DHCP请求报文 · 如果显示为IP地址,则表示当前配置的DHCP服务器选择方式为主备模式,该地址为当前活跃的DHCP服务器地址,即DHCP中继向该地址对应的DHCP服务器转发DHCP请求报文 |
Interface name |
接口名 |
Server IP address |
指定的DHCP服务器地址 |
Public/VRF name |
DHCP服务器所在位置,取值包括: · 当配置了dhcp relay server-address命令时,显示为--/-- · 当配置了dhcp relay server-address public命令时,显示为Y/-- · 当配置了dhcp relay server-address vpn-instancevpn-instance-name命令时,显示为--/VPN实例名称 |
gateway-list命令用来指定匹配该地址池的DHCP客户端所在的网段的地址。
undo gateway-list命令用来删除指定的匹配该地址池的DHCP客户端所在的网段的地址。
未指定匹配该地址池的DHCP客户端所在的网段地址。
普通IP地址池视图
ip-address&<1-64>:该地址池的DHCP客户端所在的网段的地址。&<1-64>表示最多可以输入64个IP地址,每个IP地址之间用空格分隔。
# 指定匹配该地址池0的DHCP客户端所在的网段的地址为10.1.1.1。
[Sysname] ip pool 0
undo master-server switch-delay命令用来恢复缺省情况。
远端BAS IP地址池视图
普通IP地址池视图
# 在IP地址池0上,配置回切主用DHCP服务器并指定回切延迟时间为3分钟。
[Sysname-ip-pool-0] master-server switch-delay 3
remote-server algorithm命令用来配置DHCP中继选择DHCP服务器方式。
undo remote-server algorithm命令用来恢复缺省情况。
remote-server algorithm { master-backup | polling }
远端BAS IP地址池视图
普通IP地址池视图
# 在远端BAS IP地址池0内,配置DHCP中继使用主备方式选择DHCP服务器。
[Sysname-ip-pool-0] remote-server algorithm master-backup
· dhcp server
· dhcp-server timeout
· master-server switch-delay
· remote-server
reset dhcp relay client-information命令用来清除DHCP中继的用户地址表项信息。
interface interface-type interface-number:清除指定接口上的DHCP中继的用户地址表项信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则清除所有接口的DHCP中继的用户地址表项信息。
ip ip-address:清除指定IP地址的用户地址表项信息。如果未指定本参数,则清除所有IP地址的DHCP中继的用户地址表项信息。
# 清除公网中所有的DHCP中继用户地址表项信息。
<Sysname> reset dhcp relay client-information
· display dhcp relay client-information
reset dhcp relay packet statistics命令用来清除DHCP中继的报文统计信息。
reset dhcp relay packet statistics [ interface interface-type interface-number ]
interface interface-type interface-number:指定接口,interface-type interface-number为接口类型和接口编号。如果不指定本参数,则清除所有的DHCP中继相关报文统计信息。
# 清除DHCP中继的报文统计信息。
<Sysname> reset dhcp relay packet statistics
· display dhcp relay packet statistics
dhcp client dad enable命令用来开启地址冲突检查功能。
undo dhcp client dad enable命令用来关闭地址冲突检查功能。
地址冲突检查功能处于关闭状态。
DHCP客户端通过发送和接收ARP报文,对DHCP服务器分配的IP地址进行地址冲突检测,如果攻击者仿冒地址拥有者进行ARP应答,就可以欺骗DHCP客户端,导致DHCP客户端无法正常使用分配到的IP地址。在网络中存在上述攻击者时,建议在客户端上关闭地址冲突检查功能。
# 开启地址冲突检查功能。
[Sysname] dhcp client dad enable
dhcp client dscp命令用来配置DHCP客户端发送DHCP报文的DSCP优先级。
undo dhcp client dscp命令用来恢复缺省情况。
dhcp client dscp dscp-value
DHCP客户端发送DHCP报文的DSCP优先级为56。
dscp-value:DHCP请求报文的DSCP优先级,取值范围为0~63。
# 配置DHCP客户端发送的DHCP报文的DSCP优先级为30。
[Sysname] dhcp client dscp 30
dhcp client identifier命令用来配置接口使用指定的DHCP客户端ID。
undo dhcp client identifier命令用来恢复缺省情况。
根据本接口的MAC地址生成DHCP客户端ID。如果本接口没有MAC地址,则获取设备第一个以太接口的MAC地址生成DHCP客户端ID。
ascii ascii-string:使用指定的ASCII字符串作为该接口的客户端ID,为1~63个字符的字符串,区分大小写。
hex hex-string:使用指定的十六进制数作为该接口的客户端ID,为4~64个字符的字符串。
mac interface-type interface-number:使用指定接口的MAC地址作为客户端ID。interface-type interface-number表示接口类型和接口编号。
DHCP客户端ID用来填充DHCP报文Option 61,作为识别DHCP客户端的唯一标识。DHCP服务器可以根据客户端ID为特定的客户端分配特定的IP地址。用户可以通过以下三种方法指定DHCP客户端ID:ASCII字符串、十六进制数或使用指定接口的MAC地址作为DHCP客户端ID,以上三种方式都需要由用户保证不同客户端的客户端ID不会相同。
# 配置接口Ten-GigabitEthernet3/0/1使用的客户端ID为接口Ten-GigabitEthernet3/0/2的MAC地址。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp client identifier mac ten-gigabitethernet 3/0/2
display dhcp client命令用来显示DHCP客户端的相关信息。
verbose:显示DHCP客户端的详细信息。如果未指定本参数,则显示DHCP客户端简要信息。
interface interface-type interface-number:显示指定接口的DHCP客户端相关信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口的DHCP客户端信息。
# 显示所有接口的DHCP客户端简要信息。
<Sysname> display dhcp client
Ten-GigabitEthernet3/0/1 DHCP client information:
Current state: BOUND
Allocated IP: 40.1.1.20 255.255.255.0
Allocated lease: 259200 seconds, T1: 129600 seconds, T2: 226800 seconds
DHCP server: 40.1.1.2
# 显示所有接口的DHCP客户端详细信息。
<Sysname> display dhcp client verbose
Lease from May 21 19:00:29 2012 to May 31 19:00:29 2012
Transaction ID: 0x1c09322d
Default router: 40.1.1.2
Classless static routes:
Destination: 1.1.0.1, Mask: 255.0.0.0, NextHop: 192.168.40.16
Destination: 10.198.122.63, Mask: 255.255.255.255, NextHop: 192.168.40.16
DNS servers: 44.1.1.11 44.1.1.12
Domain name: example.com
Boot servers: 200.200.200.200 1.1.1.1
ACS parameter:
URL: https://192.168.1.1:7547/acs
Username: bims
Password: ******
Client ID value: 000c.29d3.8659-XGE3/0/1
6433-2e38-3635-392d-
4574-6830-2f30-2f32
T1 will timeout in 1 day 11 hours 58 minutes 52 seconds.
表1-26 display dhcp client命令显示信息描述表
XXXX DHCP client information |
作为DHCP客户端的接口信息 |
Current state |
DHCP客户端状态机的当前状态,取值包括: · HALT:停止申请IP地址状态; · INIT:初始化状态; · SELECTING:发送DHCP-DISCOVER报文寻找DHCP服务器后,进入该状态,等待DHCP服务器的响应报文; · REQUESTING:发送DHCP-REQUEST报文请求IP地址后,进入该状态,等待DHCP服务器的响应报文; · BOUND:接收到DHCP服务器发送的DHCP-ACK报文,成功获取IP地址后,进入该状态; · RENEWING:T1定时器超时后,进入该状态; · REBOUNDING:T2定时器超时后,进入该状态。 |
Allocated IP |
DHCP服务器为接口分配的IP地址 |
Allocated lease |
租约时长 |
T1 |
DHCP客户端的一半左右租约时间(以秒为单位) |
T2 |
DHCP客户端的7/8租约时间(以秒为单位) |
Lease from….to…. |
租约起止时间 |
DHCP server |
选择的DHCP服务器的地址 |
Transaction ID |
DHCP客户端发起申请时生成的一个随机数,用来唯一标识一次申请过程 |
Default router |
为DHCP客户端指定的网关地址 |
Classless static routes |
为DHCP客户端指定的无分类静态路由 |
Static routes |
为DHCP客户端指定的有分类静态路由 |
DNS servers |
为DHCP客户端指定的DNS服务器地址 |
Domain name |
为DHCP客户端指定的域名后缀 |
Boot servers |
为DHCP客户端指定的PXE引导服务器地址,通过Option 43获取,最多可以获取16个地址 |
ACS parameter |
ACS参数 |
URL |
ACS的URL地址 |
Username |
登录ACS设备使用的用户名 |
Password |
登录ACS设备使用的密码,若存在密码,则显示为“******”;若不存在密码,则不显示此项; |
Client ID type |
DHCP客户端ID的类型,type value表示类型值。类型为ASCII时,type value为00;为MAC address时,type value为01;为Hex时,type value为配置的十六进制数的前两位 |
Client ID value |
DHCP客户端ID的取值 |
Client ID (with type) hex |
DHCP客户端ID的十六进制形式(带类型值字段) |
T1 will timeout in 1 day 11 hours 58 minutes 52 seconds. |
在多少时间后T1定时器(即一半左右租约时间)将到期 |
· dhcp client identifier
ip address dhcp-alloc命令用来配置接口通过DHCP协议获取IP地址。
undo ip address dhcp-alloc命令用来取消接口通过DHCP协议获取的IP地址。
接口不通过DHCP协议获取IP地址。
取消接口通过DHCP协议获取IP地址时,DHCP客户端会发送DHCP-RELEASE报文通知DHCP服务器释放租约。如果此时该接口处于down状态,则无法保证报文成功发送。
如果配置子接口通过DHCP协议获取IP地址,在其主接口上执行shutdown命令时,DHCP客户端不会发送请求释放子接口IP地址租约的DHCP-RELEASE报文。
# 在Ten-GigabitEthernet3/0/1接口上配置接口通过DHCP协议获取IP地址。
[Sysname-Ten-GigabitEthernet3/0/1] ip address dhcp-alloc
· display dhcp client
设备只有位于DHCP客户端与DHCP服务器之间,或DHCP客户端与DHCP中继之间时,DHCP Snooping功能配置后才能正常工作;设备位于DHCP服务器与DHCP中继之间时,DHCP Snooping功能配置后不能正常工作。
dhcp snooping binding database filename命令用来指定存储DHCP Snooping表项的文件名称。
undo dhcp snooping binding database filename命令用来恢复缺省情况。
dhcp snooping binding database filename { filename | url url [ username username [ password { cipher | simple } string ] ] }
未指定存储文件名称。
url url:配置远程目标文件URL,为1~255个字符的字符串,区分大小写,该配置用于远程文件系统模式。此参数中不能包含用户名和密码,和参数username和string配合使用。远程目标文件URL是否支持路径格式遵循远程服务器端规格。
username username:配置登录远程目标文件URL时的用户名,为1~32个字符的字符串,区分大小写。如果未指定本参数,则表示登录远程目标文件URL时无需使用用户名。
cipher:表示以密文方式设置用户密码。
string:密码字符串,区分大小写。明文密码为1~32个字符的字符串,密文密码为1~73个字符的字符串。如果未指定本参数,则表示登录远程目标文件URL时无需使用密码。
存储DHCP Snooping表项时,如果设备中还不存在对应名称的文件,则设备会自动创建该文件。
执行本命令后,会立即触发一次表项备份。之后,如果未配置dhcp snooping binding database update interval命令,若表项发生变化,默认在300秒之后刷新存储文件;若表项未发生变化,则不再刷新存储文件。如果配置了dhcp snooping binding database update interval命令,若表项发生变化,则到达刷新时间间隔后刷新存储文件;若表项未发生变化,则不再刷新存储文件。
参数filename不支持远程目标文件URL,配置远程目标文件URL请使用url、username、string配合使用。
频繁擦写本地存储介质可能会影响存储介质寿命,建议使用远程文件系统模式存储DHCP Snooping表项文件。
当进行远程存储时,支持FTP和TFTP协议:
· 当采用FTP或TFTP协议时,服务器地址支持IPv4形式或IPv6形式,并且支持DNS域名方式。服务器地址为IPv6地址形式时需使用方括号(“[”和“]”)引用。配置服务器地址为DNS域名格式时请勿使用方括号引用。
· 当采用FTP协议时,URL采用“ftp://服务器地址[:端口号]/文件路径”的形式,如有用户名和密码请分别使用参数username和参数string进行配置,用户名和密码必须和服务器上的配置一致,如果服务器只对用户名进行认证,则不用输入密码。
· 当采用TFTP协议时,URL采用“tftp://服务器地址[:端口号]/文件路径”的形式。
# 配置存储DHCP Snooping表项的文件名为database.dhcp。
[Sysname] dhcp snooping binding database filename database.dhcp
# 配置远程存储DHCP Snooping表项至IP地址为1.1.1.1的ftp服务器工作目录下,用户名为1,密码为1,文件名为database.dhcp。
[Sysname] dhcp snooping binding database filename url ftp://10.1.1.1/database.dhcp username 1 password simple 1
# 配置远程存储DHCP Snooping表项至IP地址为10.1.1.1的tftp服务器工作目录下,文件名为database.dhcp。
[Sysname] dhcp snooping binding database filename url tftp://10.1.1.1/database.dhcp
· dhcp snooping binding database update interval
dhcp snooping binding database update interval命令用来配置刷新DHCP Snooping表项存储文件的延迟时间。
undo dhcp snooping binding database update interval命令用来恢复缺省情况。
dhcp snooping binding database update interval interval
若DHCP Snooping表项不变化,则不刷新存储文件;若DHCP Snooping表项发生变化,默认在300秒之后刷新存储文件。
执行本命令后,当DHCP Snooping表项发生变化后,DHCP Snooping设备开始计时,当本命令配置的延迟时间到达后,DHCP Snooping会把这个时间段内表项所有的变化信息备份到固化文件中。
如果未通过dhcp snooping binding database filename命令指定存储表项的文件,则本命令不会生效。
# 若DHCP Snooping表项发生变化,在600秒后刷新表项存储文件。
[Sysname] dhcp snooping binding database update interval 600
· dhcp snooping binding database filename
dhcp snooping binding database update now命令用来将当前的DHCP Snooping表项保存到用户指定的文件中。
本命令只用来触发一次DHCP Snooping表项的备份。
# 将当前的DHCP Snooping表项保存到文件中。
[Sysname] dhcp snooping binding database update now
dhcp snooping binding record命令用来开启端口的DHCP Snooping表项记录功能。
undo dhcp snooping binding record命令用来关闭端口的DHCP Snooping表项记录功能。
端口DHCP Snooping表项记录功能处于关闭状态。
二层以太网接口视图/二层聚合接口视图
用户可在DHCP Snooping设备直接与客户端连接的端口上开启DHCP Snooping表项记录功能。
在端口上开启DHCP Snooping表项记录功能后,设备将监听该端口上接收的报文,生成DHCP Snooping表项。
# 开启端口Ten-GigabitEthernet3/0/1的DHCP Snooping表项记录功能。
[Sysname]interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping binding record
dhcp snooping check mac-address命令用来开启DHCP Snooping的MAC地址检查功能。
undo dhcp snooping check mac-address命令用来关闭DHCP Snooping的MAC地址检查功能。
DHCP Snooping的MAC地址检查功能处于关闭状态。
二层以太网接口视图/二层聚合接口视图
三层以太网接口视图/三层聚合接口视图
开启该功能后,DHCP Snooping检查接收到的DHCP请求报文中的chaddr字段和数据帧的源MAC地址字段是否一致。如果一致,则认为该报文合法,将其转发给DHCP服务器;如果不一致,则丢弃该报文。
# 开启DHCP Snooping的MAC地址检查功能。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping check mac-address
dhcp snooping check request-message命令用来开启DHCP Snooping的DHCP请求方向报文检查功能。
undo dhcp snooping check request-message命令用来关闭DHCP Snooping的DHCP请求方向报文检查功能。
DHCP Snooping的DHCP请求方向报文检查功能处于关闭状态。
二层以太网接口视图/二层聚合接口视图
如果开启了该功能,则DHCP Snooping设备接收到上述报文后,检查本地是否存在与接收报文匹配的DHCP Snooping表项。若存在,则接收报文信息与DHCP Snooping表项信息一致时,认为该报文为合法的请求方向报文,将其转发给DHCP服务器;不一致时,认为该报文为伪造的请求方向报文,将其丢弃。若不存在,则认为该报文合法,将其转发给DHCP服务器。
# 开启DHCP Snooping的DHCP请求方向报文检查功能。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping check request-message
dhcp snooping deny命令用来在端口上开启DHCP Snooping报文阻断功能。
undo dhcp snooping deny命令用来在端口上关闭DHCP Snooping报文阻断功能。
dhcp snooping deny
端口上的DHCP Snooping报文阻断功能处于关闭状态。
二层以太网接口视图/二层聚合接口视图
在端口上开启本功能后,DHCP Snooping设备会丢弃该端口收到的所有DHCP请求方向报文,这将导致该端口上的DHCP客户端无法申请到IP地址。因此,本功能只能在未连接DHCP客户端的端口上开启。
在某些组网环境下,用户需要在DHCP Snooping设备的某一端口上丢弃该端口收到的所有DHCP请求方向报文,而又不影响其他端口正常接收DHCP报文。这时,用户可以在该端口上开启DHCP Snooping报文阻断功能。
# 在端口Ten-GigabitEthernet3/0/1上开启DHCP Snooping报文阻断功能。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping deny
dhcp snooping enable命令用来开启DHCP Snooping功能。
undo dhcp snooping enable命令用来关闭DHCP Snooping功能。
DHCP Snooping功能处于关闭状态。
开启DHCP Snooping功能后,如果不信任端口接收到DHCP服务器发送的报文,将丢弃该报文,以保证客户端从合法的DHCP服务器获取IP地址。
在DHCP Snooping功能关闭后,所有端口都可转发DHCP服务器的响应报文。
# 开启DHCP Snooping功能。
[Sysname] dhcp snooping enable
dhcp snooping information circuit-id命令用来配置Option 82的Circuit ID子选项的填充模式和填充格式。
undo dhcp snooping information circuit-id命令用来恢复缺省情况。
dhcp snooping information circuit-id { [ vlan vlan-id ] string circuit-id | { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] } [ format { ascii | hex } ] }
undo dhcp snooping information circuit-id [ vlan vlan-id ]
二层以太网接口视图/二层聚合接口视图
vlan vlan-id:为从指定VLAN内收到的DHCP报文填充Circuit ID子选项。如果未指定本参数,则表示为缺省VLAN内收到的DHCP报文填充Circuit ID子选项。
node-identifier { mac | sysname | user-defined node-identifier }:指定接入节点的标识。
· sysname:表示以节点的设备名称作为节点标识。设备的系统名称可以通过系统视图下的sysname命令配置。不管配置了哪种填充格式,设备的系统名称始终采用ASCII码格式填充。系统名称中不能包含空格,否则,DHCP Snooping添加或替换Option 82失败。
以用户配置的字符串填充Circuit ID子选项时,填充格式固定为ASCII码格式。
· 如果本命令中未指定填充格式,则对于Normal模式,VLAN ID和端口号均以hex格式填充;对于Verbose模式,节点标识(MAC地址、设备的系统名称或指定的字符串)、以太网类型、框号、槽号、子槽号、接口编号均以ASCII码格式填充,VLAN ID以hex格式填充。
Option 82的Circuit ID子选项信息中无法携带接口拆分信息或子接口信息,关于“接口拆分”和“子接口”的详细介绍,请参见“以太网接口配置指导”中的“以太网接口通用配置”。
多次执行该命令,最后一次执行的命令生效。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping information enable
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping information strategy replace
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping information circuit-id verbose node-identifier sysname format ascii
· dhcp snooping information enable
· dhcp snooping information strategy
· display dhcp snooping information
dhcp snooping information enable命令用来开启DHCP Snooping支持Option 82功能。
undo dhcp snooping information enable命令用来关闭DHCP Snooping支持Option 82功能。
DHCP Snooping支持Option 82功能处于关闭状态。
二层以太网接口视图/二层聚合接口视图
开启DHCP Snooping支持Option 82功能后,DHCP Snooping将向转发给DHCP服务器的请求报文中增加Option 82选项。选项内容由dhcp snooping information circuit-id和dhcp snooping information remote-id决定。如果DHCP Snooping收到的请求报文中已经包含Option 82选项,则按照dhcp snooping information strategy配置的策略处理请求报文。
# 开启DHCP Snooping支持Option 82功能。
· dhcp snooping information circuit-id
· dhcp snooping information remote-id
dhcp snooping information remote-id命令用来配置Option 82的Remote ID子选项的填充模式和填充格式。
undo dhcp snooping information remote-id命令用来恢复缺省情况。
dhcp snooping information remote-id { normal [ format { ascii | hex } ] | [ vlan vlan-id ] { string remote-id | sysname } }
undo dhcp snooping information remote-id [ vlan vlan-id ]
二层以太网接口视图/二层聚合接口视图
vlan vlan-id:为从指定VLAN内收到的DHCP报文填充Remote ID子选项。如果未指定本参数,则表示为缺省VLAN内收到的DHCP报文填充Remote ID子选项。
normal:指定以Normal模式填充Remote ID子选项,填充内容为设备的桥MAC地址。
format:指定Remote ID子选项的填充格式。如果未指定本参数,则以hex模式填充。
多次执行本命令,最后一次执行的命令生效。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping information remote-id string device001
dhcp snooping information strategy命令用来配置DHCP Snooping对包含Option 82的请求报文的处理策略。
undo dhcp snooping information strategy命令用来恢复缺省情况。
dhcp snooping information strategy { drop | keep | replace }
二层以太网接口视图/二层聚合接口视图
replace:如果报文中带有Option 82,则按照配置的填充格式填充Option 82,用该选项替换报文中原有的Option 82,并进行转发。
如果开启了DHCP Snooping支持Option 82功能,则对于接收到的不包含Option 82的请求报文,DHCP Snooping的处理方式始终为在请求报文中添加Option 82,并将报文转发给DHCP服务器。
DHCP Snooping对包含Option 82请求报文的处理策略为replace时,需要配置Option 82的填充模式和填充格式;处理策略为keep或drop时,不需要配置Option 82选项的填充模式和填充格式。
# 配置DHCP Snooping对带有Option 82的请求报文使用keep策略。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping information strategy keep
dhcp snooping log enable命令用来开启DHCP Snooping日志信息功能。
undo dhcp snooping log enable命令关闭DHCP Snooping日志信息功能。
DHCP Snooping日志信息功能处于关闭状态。
DHCP Snooping日志是为了满足管理员的审计需求。DHCP Snooping设备生成DHCP Snooping日志信息会交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
当DHCP Snooping设备输出大量日志信息时,可能会降低设备性能。为了避免该情况的发生,用户可以关闭DHCP Snooping日志信息功能,使得DHCP Snooping设备不再输出日志信息。
# 开启DHCP Snooping日志信息功能。
[Sysname] dhcp snooping log enable
dhcp snooping max-learning-num命令用来配置接口动态学习DHCP Snooping表项的最大数目。
undo dhcp snooping max-learning-num命令用来恢复缺省情况。
dhcp snooping max-learning-num max-number
不限制接口动态学习DHCP Snooping表项的最大数目。
二层以太网接口视图/二层聚合接口视图
三层以太网接口视图/三层聚合接口视图
max-number:接口动态学习DHCP Snooping表项的最大数目。取值范围为1~4294967295。
接口动态学习的DHCP Snooping表项数达到最大数目后,不影响DHCP Snooping功能正常运行,但是接口不会继续学习新的DHCP Snooping表项。
# 配置二层以太网接口Ten-GigabitEthernet3/0/1动态学习DHCP Snooping表项的最大数目为10。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping max-learning-num 10
dhcp snooping trust命令用来配置端口为信任端口。
undo dhcp snooping trust命令用来恢复端口为不信任端口。
dhcp snooping trust
在开启DHCP Snooping功能后,设备上所有支持DHCP Snooping功能的端口均为不信任端口。
二层以太网接口视图/二层聚合接口视图
三层以太网接口视图/三层聚合接口视图
指向DHCP服务器方向的端口需要设置为信任端口,其他端口设置为不信任端口,从而保证DHCP客户端只能从合法的DHCP服务器获取IP地址,私自架设的伪DHCP服务器无法为DHCP客户端分配IP地址。
# 配置二层以太网接口Ten-GigabitEthernet3/0/1为信任端口。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping trust
· display dhcp snooping trust
display dhcp snooping binding命令用来显示DHCP Snooping表项信息。
display dhcp snooping binding [ ip ip-address [ vlan vlan-id ] ] [ verbose ]
ip ip-address:显示指定IP地址对应的DHCP Snooping表项。如果未指定本参数,则显示所有IP地址对应的DHCP Snooping表项。
vlan vlan-id:显示指定VLAN内的DHCP Snooping表项。如果未指定本参数,则显示所有VLAN内的DHCP Snooping表项。
verbose:显示DHCP Snooping表项的详细信息。如果未指定本参数,则显示DHCP Snooping表项的概要信息。
# 显示DHCP Snooping表项的概要信息。
<Sysname> display dhcp snooping binding
2 DHCP snooping entries found
IP address MAC address Lease VLAN SVLAN Interface
1.1.1.7 0000-0101-0107 16907533 2 3 XGE3/0/1
1.1.1.11 0000-0101-010b 16907537 2 3 XGE3/0/3
# 显示DHCP Snooping表项的详细信息。
<Sysname> display dhcp snooping binding verbose
IP address: 1.1.1.7
MAC address: 0000-0101-0107
Lease: 16907553 seconds
VLAN: 2
SVLAN: 3
Parameter request list: 03 06 21
IP address: 1.1.1.104
MAC address: 0000-0101-010b
Lease: 16907537 seconds
VLAN: 2
SVLAN: 3
Interface: Ten-GigabitEthernet3/0/3
Parameter request list: 37 0B 01 0F 03 06 2C 2E 2F 1F 21 F9 2B
表1-27 display dhcp snooping binding命令显示信息描述表
DHCP snooping entries found |
表项统计计数 |
IP address |
DHCP服务器为DHCP客户端分配的IP地址 |
MAC address |
DHCP客户端的MAC地址 |
Lease |
绑定的租约剩余时间,单位为秒 |
VLAN |
如果DHCP Snooping功能与QinQ功能同时使用,或接收到的DHCP报文带有两层VLAN Tag,则表示外层VLAN Tag;否则,表示与DHCP客户端连接的设备端口所属的VLAN |
SVLAN |
如果DHCP Snooping功能与QinQ功能同时使用,或接收到的DHCP报文带有两层VLAN Tag,则表示内层VLAN Tag;否则,显示为“N/A” |
与DHCP客户端连接的设备端口 |
Parameter request list |
DHCP客户端的请求参数 |
· dhcp snooping enable
· reset dhcp snooping binding
display dhcp snooping binding database命令用来显示DHCP Snooping表项备份信息。
# 显示DHCP Snooping表项备份信息。
<Sysname> display dhcp snooping binding database
File name : database.dhcp
Username :
Password :
Update interval : 600 seconds
Latest write time : Feb 27 18:48:04 2012
Status : Last write succeeded.
表1-28 display dhcp snooping binding database命令显示信息描述表
File name |
存储DHCP Snooping表项的文件名称 |
Username |
配置远程目标文件时的用户名 |
Password |
配置远程目标文件时的密码,有配置时显示为”******” |
Update interval |
定期刷新表项存储文件的刷新时间间隔,单位为秒 |
Latest write time |
最近一次写文件的时间 |
Status |
写文件的状态,即写文件是否成功 · Writing:正在写文件 · Last write succeeded.:写文件成功 · Last write failed.:写文件失败 |
display dhcp snooping information命令用来显示DHCP Snooping上Option 82的配置信息。
display dhcp snooping information { all | interface interface-type interface-number }
all:显示所有二层以太网接口对应的Option 82配置信息。
interface interface-type interface-number:显示指定接口对应的Option 82配置信息。interface-type interface-number为接口类型和接口编号。
# 显示所有接口对应的Option 82配置信息。
<Sysname> display dhcp snooping information all
Interface: Bridge-Aggregation1
Status: Disable
Strategy: Drop
Circuit ID:
Padding format: User Defined
User defined: abcd
Format: ASCII
Remote ID:
Padding format: Normal
Format: ASCII
VLAN 10:
Circuit ID: abcd
Remote ID: company
表1-29 display dhcp snooping information命令显示信息描述表
接口名 |
Status |
Option 82的状态,取值为Enable或Disable |
Strategy |
Circuit ID |
Circuit ID子选项的内容 |
Padding format |
Option 82的填充模式: · 在填充Circuit ID子选项时,取值为Normal、User Defined、Verbose(sysname)、Verbose(MAC)或Verbose(user defined) · 在填充Remote ID子选项时,取值为Normal、Sysname或User Defined |
Node identifier |
接入节点的标识 |
User defined |
用户自定义的子选项内容 |
Format |
Option 82子选项的填充格式 · 在填充Circuit ID子选项时,取值为ASCII、Default或Hex · 在填充Remote ID子选项时,取值为ASCII或Hex |
Remote ID |
Remote ID子选项的内容 |
VLAN |
为指定VLAN内收到的DHCP报文填充的Circuit ID子选项和Remote ID子选项内容 |
display dhcp snooping packet statistics命令用来显示DHCP Snooping设备上的DHCP报文统计信息。
display dhcp snooping packet statistics [ slot slot-number ]
# 显示DHCP Snooping设备上的DHCP报文统计信息。
<Sysname> display dhcp snooping packet statistics
DHCP packets received : 100
DHCP packets sent : 200
Invalid DHCP packets dropped : 0
表1-30 display dhcp snooping packet statistics命令显示信息描述表
DHCP packets received |
接收的DHCP报文数 |
DHCP packets sent |
发送的DHCP报文数 |
Invalid DHCP packets dropped |
丢弃的无效DHCP报文数 |
· reset dhcp snooping packet statistics
display dhcp snooping trust命令用来显示信任端口信息。
# 显示信任端口信息。
<Sysname> display dhcp snooping trust
DHCP snooping is enabled.
Interface Trusted
Ten-GigabitEthernet3/0/1 Trusted
表1-31 display dhcp snooping trust命令显示信息描述表
DHCP snooping is |
DHCP Snooping功能的开启状态,取值包括: · enable:开启DHCP Snooping功能 · disable:未开启DHCP Snooping功能 |
接口名称 |
Trusted |
接口为信任接口 |
· dhcp snooping trust
reset dhcp snooping binding命令用来清除DHCP Snooping表项。
reset dhcp snooping binding { all | ip ip-address [ vlan vlan-id ] }
all:清除所有的DHCP Snooping表项。
ip ip-address:清除指定IP地址对应的DHCP Snooping表项。
vlan vlan-id:清除指定VLAN内的DHCP Snooping表项。如果未指定本参数,则清除缺省VLAN内的DHCP Snooping表项。
对于分布式设备,执行该命令后,将清除所有槽位上对应的DHCP Snooping表项。
# 清除所有的DHCP Snooping表项。
<Sysname> reset dhcp snooping binding all
· display dhcp snooping binding
reset dhcp snooping packet statistics命令用来清除DHCP Snooping设备上的DHCP报文统计信息。
reset dhcp snooping packet statistics [ slot slot-number ]
# 清除DHCP Snooping设备上的DHCP报文统计信息。
<Sysname> reset dhcp snooping packet statistics
· display dhcp snooping packet statistics
display bootp client命令用来显示BOOTP客户端的相关信息。
interface interface-type interface-number:显示指定接口的BOOTP客户端相关信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上的BOOTP客户端的相关信息。
# 显示接口Ten-GigabitEthernet3/0/1的BOOTP客户端相关信息。
<Sysname> display bootp client interface ten-gigabitethernet 3/0/1
Ten-GigabitEthernet3/0/1 BOOTP client information:
Allocated IP: 169.254.0.2 255.255.0.0
Transaction ID: 0x3d8a7431
MAC Address: 00e0-fc0a-c3ef
表1-32 display bootp client命令显示信息描述表
XXXX BOOTP client information |
作为BOOTP客户端的接口信息 |
Allocated IP |
BOOTP服务器为BOOTP客户端分配的IP地址 |
Transaction ID |
BOOTP报文中XID字段值,即BOOTP客户端发送BOOTP请求报文时选择的随机数,用来与BOOTP服务器的响应报文相匹配。如果响应报文的XID字段值与请求报文的XID字段值不相同,则BOOTP客户端丢弃该响应报文 |
MAC Address |
BOOTP客户端的MAC地址 |
· ip address bootp-alloc
ip address bootp-alloc命令用来配置接口通过BOOTP协议获取IP地址。
undo ip address bootp-alloc命令用来取消接口通过BOOTP协议获取的IP地址。
接口不通过BOOTP协议获取IP地址。
# 在Ten-GigabitEthernet3/0/1接口上配置接口通过BOOTP协议获取IP地址。
[Sysname-Ten-GigabitEthernet3/0/1] ip address bootp-alloc
· display bootp client
