05-H3C 融合AC Probe命令参考
01-正文
本章节下载: 01-正文  (328.16 KB)
01-正文
1 Probe命令
1.1 D
1.1.1 debug
1.1.2 debug from-device clear
1.1.3 debug from-device display
1.1.4 debug level
1.1.5 debug module
1.1.6 debugging system internal wlan forward packet
1.1.7 debugging wlan ap app
1.1.8 debugging wlan rfid-tracking
1.1.9 diag app display filename
1.1.10 diag boot-info display
1.1.11 diag dev-table display
1.1.12 diag drvflag display
1.1.13 diag environment display
1.1.14 diag fan display speed
1.1.15 diag hasa display
1.1.16 diag if display
1.1.17 diag led display
1.1.18 diag lipc display
1.1.19 diag log display
1.1.20 diag mbuf-relay display
1.1.21 diag mbus display
1.1.22 diag mem-assign display
1.1.23 diag module display content
1.1.24 diag module display content
1.1.25 diag pcie display
1.1.26 diag poe
1.1.27 diag port display  statistics
1.1.28 diag port-list display
1.1.29 diag port-table display
1.1.30 diag stm display
1.1.31 diag stm statistic display
1.1.32 diag temperature display status
1.1.33 diag tmpr-alarm display threshold
1.1.34 display debug-info
1.1.35 display system internal dot11 characteristics
1.1.36 display system internal dot11 verbose
1.1.37 display system internal wlan adapter-asyncinfo
1.1.38 display system internal wlan ap message
1.1.39 display system internal wlan ap name
1.1.40 display system internal wlan ap radio drv-info
1.1.41 display system internal wlan ap-libinfo
1.1.42 display system internal wlan band-navigation
1.1.43 display system internal wlan client ip
1.1.44 display system internal wlan command-cache
1.1.45 display system internal wlan history-error
1.1.46 display system internal wlan kernel-ap
1.1.47 display system internal wlan link-info
1.1.48 display system internal wlan load-balance neighbor-list ap
1.1.49 display system internal wlan load-balance neighbor-list client
1.1.50 display system internal wlan response-timeout event
1.1.51 display system internal wlan statistics
1.1.52 display system internal wlan virtual ap
1.1.53 display system internal wlan virtual client
1.2 F
1.2.1 fpl-diag
1.3 R
1.3.1 reset system internal wlan history-error
1.3.2 reset system internal wlan response-timeout event
1.3.3 rrm calibrate-power step
1.4 W
1.4.1 wlan ap-execute exec-console enable
1.4.2 wlan image-load model
1.4.3 wlan image-load simultaneous
1.4.4 wlan system internal offline-restrain
1.4.5 wlan system internal reboot-restrain
1.4.6 wlan virtual ap add
1.4.7 wlan virtual ap delete
1.4.8 wlan virtual client add
1.4.9 wlan virtual client delete
1 Probe命令
本手册中的命令,仅供专业技术人员进行问题定位和调试所用,不建议用户使用。
1.1  D
1.1.1  debug
debug命令用来打开debug开关,配置调试信息的输出设置。
debug {on | off | switch-save | out-to-ic | out-to-console }
Probe视图
on:表示debug打开开关。
off: 表示debug关闭开关。
switch-save: 表示保存debug开关。
out-to-ic: 表示调试信息在信息中心输出。
out-to-console: 表示调试信息在串口输出。
debug from-device clear命令用来清除debug异常调试信息。
Probe视图
debug from-device display命令用来显示设备异常信息开关。
debug from-device display { all | error }
Probe视图
all:显示设备所有异常信息。
error:显示设备异常错误信息。
# 显示设置所有的异常信息。
[H3C-probe] debug from-device display all
Kernel exec cmd ok.
 ulReplyLen = 32
 Not found saved debug entrys.
1.1.4  debug level
debug level命令用来配置驱动debug调试信息级别开关。
debug level { all | debug | error | info | print-fileline | print-modulename } { on | off }
Probe视图
all:打开或关闭所有level调试信息开关。
debug:打开或关闭debug level调试信息开关。
error:打开或关闭 level error调试信息开关。
info:打开或关闭 level info调试信息开关。
print-fileline:打开或关闭输出文件行数调试信息开关。
print-modulename:打开或关闭输出模块名调试信息开关。
on:表示开启指定的debug信息开关。
off:表示关闭指定的debug信息开关。
1.1.5  debug module
debug module命令用来打开或关闭器件调试信息。
debug module { adp | all-module | btrm | cf | cfm | conf | cpld | cpu | dev | devm | dim | drv-mod1 | drv-mod2 | drv-mod3 | ec | eeprom | fan | fe | flash| fshe | fwd | ge | ht | i2c | ibc | init | intf | led | lic | lipc | lpu | lpum | mbuf-relay | mbus | mcore | mm | mon | np | nvram | oem | optic | other | pci | per | plat | port | relinfo | rtc | sae | stm | tcam | tmpr | u2f | uart | usb | xge } {on | off }
Probe视图
debugging system internal wlan forward packet用来打开WLAN转发WLAN转发报文调试开关,并设置过滤调试信息的规则。
undo debugging system internal wlan forward packet命令用来关闭WLAN转发报文调试开关,并删除所有设置的过滤调试信息的规则。
debugging system internal wlan forward packet content content-hex [ offset bytes ]
WLAN转发报文的调试开关处于关闭状态。
Probe视图
packet:WLAN转发报文调试信息开关。
content content-hex:指定用来过滤WLAN转发报文调试信息的过滤信息。content-hex表示过滤信息,可以输入多条,信息之间使用符号“&”相隔,表示过滤信息之间是“与”的关系,当过滤信息依次全部匹配成功时,才会打印WLAN转发报文的调试信息。其中每条过滤信息表示报文十六进制内容,形式为H:H:H,H代表用十六进制表示的报文中一个字节的内容,H之间使用“:”相隔,H的个数范围1~256。
offset bytes:表示从指定的偏移位置开始匹配调试信息,bytes表示偏移量,取值范围0~127,单位为字节,缺省值为0字节。当使用“&”指定多条规则时,不可指定offset。
debugging wlan ap app命令用来开启APP调试信息开关。
undo debugging wlan ap app命令用来关闭APP调试信息开关。
debugging wlan ap app { app-id | all }
undo debugging wlan ap app { app-id | all }
APP调试信息开关处于关闭状态。
Probe视图
app-id:APP的ID,取值范围为0~277。
all:所有APP。
debugging wlan rfid-tracking命令用来开启WLAN定位调试信息开关。
undo debugging wlan rfid-tracking命令用来关闭WLAN定位调试信息开关。
debugging wlan rfid-tracking { all | error | event | packet }
undo debugging wlan rfid-tracking { all | error | event | packet }
WLAN定位调试信息开关处于关闭状态。
Probe视图
all:表示WLAN定位所有调试信息开关。
error:表示WLAN定位的错误调试信息开关。
event:表示WLAN定位的事件调试信息开关。
packet:表示WLAN定位的报文调试信息开关。
diag app display filename命令用来查看应用程序打包的文件信息。
diag app display filename string
Probe视图
string:带有路径的文件名,为1~128个字符的字符串,不区分大小写。
# 查看cfa0:/boot.bin中打包的文件信息。
[H3C-probe] diag app display filename cfa0:/boot.bin
Kernel exec cmd ok.
FileName : cfa0:/boot.bin
FileLen   ProductId   DeviceId    FileNum HeadCrc
217736192 0x3c030105  0x5         19      0x389c
No  IdType                    Offset    Length    FileCrc Version   FileId
0   BasBtm                    6180      232764    0x3174  5.06      0x5000001
1   ExtBtm                    238944    160500    0x9d52  5.06      0x5000000
2   MainApp/mpu.cpio          399444    5187620   0xde01  1400.1400 0x4000000
3   script.cpio               5587064   612       0xdbe2  1400.1400 0x4fefefe
4   package                   5587676   756       0x1edc  1400.1400 0x40000f0
5   Unknown                   5588432   740644    0x5a9c  1.03      0x3000002
6   wa2600a_update.bin        6329076   12993876  0x2cdb  1.00      0xff0000a0
7   wa2600a.ipe               19322952  12903764  0xc486  1.00      0xff0000a1
8   wa4300_update.bin         32226716  13725012  0x347a  1.00      0xff0000b0
9   wa4300.ipe                45951728  14229844  0x6388  1.00      0xff0000b1
10  wa4300s_update.bin        60181572  12265812  0x9e8e  1.00      0xff0000b3
11  wa4300s.ipe               72447384  12163412  0x3864  1.00      0xff0000b4
12  wa4600_update.bin         84610796  13722964  0xa319  1.00      0xff0000c2
13  wa4600.ipe                98333760  14088532  0x186b  1.00      0xff0000c3
14  wt1020.ipe                112422292 33398100  0x74ba  1.00      0xff0000d0
15  wt1010.ipe                145820392 30302548  0x1e21  1.00      0xff0000e0
16  wa3600_update.bin         176122940 13434196  0x8dd8  1.00      0xff000005
17  wa3600.ipe                189557136 14039380  0xb160  1.00      0xff000006
18  wa5600.ipe                203596516 14138708  0x9b27  1.00      0xff000090
表1-1 diag app display filename显示信息描述表
No
序号
IdType
文件名称
Offset
偏移量
Length
文件长度
FileCrc
文件校验值
Version
文件版本
FileId
文件ID
diag boot-info display命令用来显示设备启动信息。
Probe视图
# 显示设备启动信息。
[H3C-probe] diag boot-info display
Kernel exec cmd ok.
 ulReplyLen = 341
PowerOn BootTimes   : 125
Watchdog BootTimes  : 16
Software BootTimes  : 1174
Hardware BootTimes  : 0
MotherBoard BootTimes: 0
Backup BootTimes    : 2
Current Boot Type   : Software-boot
Current Running Time: 142200(s)
Running Time        : 165(d)7(h)
表1-2 diag boot-info display显示信息描述表
PowerOn BootTimes
上电启动次数
Watchdog BootTimes
看门狗启动次数
Software BootTimes
软件启动次数
Hardware BootTimes
硬件启动次数
主板启动次数
Backup BootTimes
备份文件启动次数
Current Boot Type
当前启动类型
当前系统运行时间
Running Time
设备总运行时间
diag dev-table display命令用来显示设备管理信息。
Probe视图
# 显示设备管理信息。
[H3C-probe] diag dev-table display
TopID    NodeID   Row Col Slot  SSlot CType PIndex EIndex Class MState
0        bfe1b180 0   0   1     65535 2     65535  1      3     2
bfe1b180 bfd10000 1   0   1     65535 3     1      2      5     2
0        bfd106c8 1   1   0     0     0     0      0      0     0
0        bfd10d90 1   2   0     0     0     0      0      0     0
0        bfd11458 1   3   0     0     0     0      0      0     0
0        bfd11b20 1   4   0     0     0     0      0      0     0
0        bfd121e8 1   5   0     0     0     0      0      0     0
0        bfd128b0 1   6   0     0     0     0      0      0     0
0        bfd12f78 1   7   0     0     0     0      0      0     0
0        bfd13640 1   8   0     0     0     0      0      0     0
0        bfd13d08 1   9   0     0     0     0      0      0     0
表1-3 diag dev-table display显示信息描述表
TopID
顶点ID
NodeID
节点ID
Row
行
Col
列
Slot
槽位
Sslot
子槽位
CType
内容类型
PIndex
物理索引
EIndex
实体索引
Class
类
MState
状态
diag drvflag display命令用来显示各个存储模块的存储区信息。
diag drvflag { apmode | art | bf | bm | capwap | debug | dm | fanmi | lic | log | mac | mi | mon | netcfg | powmi | rel | stm | target | tr } display
Probe视图
【参数】】
apmode:显示AP工作模式信息。
art:显示射频信息。
bf:显示驱动Bootware Flag段标志区信息。
bm:显示主、备启动文件和主、备配置文件信息。
capwap:显示capwap隧道统计信息。
debug:显示目前系统中存储debug信息数量和存储debug起始位置信息。
dm:显示驱动dm段标志区信息,包括flash擦除次数,启动次数,重启类型,调试开关标志。
fanmi:显示风扇制造标志区信息,具体支持情况和设备型号有关。
lic:显示驱动license标志区信息,具体支持情况和设备型号有关。
log:显示驱动存储日志起始位置,日志存储的最大数量等信息。
mac:显示驱动MAC标志区信息。
mi:显示驱动电子标签字段信息。
mon:显示驱动监控信息类型,日志存放起始位置等信息。
netcfg:显示bootware的网络参数。
powmi:显示电源制造信息,具体支持情况和设备型号有关。
rel:显示可靠性,进风口,出风口, cpu,温感等信息。
stm:显示驱动stm标志区信息。
target:显示射频驱动监控信息类型,日志存放起始位置等信息。
tr:显示存储器件测试结果。
# 显示驱动MAC标志区信息。
[H3C-probe] diag drvflag mac display
Kernel exec cmd ok.
THE MAIN:
InfoName                 Info
uiCrc                    4557
uiMacNum                 1
MacAdr1                  00:0f:12:12:11:01
THE BACKUP:
InfoName                 Info
uiCrc                    4557
uiMacNum                 1
表1-4 diag drvflag mac display显示信息描述表
InfoName
信息名称
Info
信息值
uiCrc
校验值
uiMacNum
Mac地址数量
MacAdr1
Mac地址
diag environment display命令用来显示设备当前各个温感数据。
Probe视图
# 显示设备当前各个温感数据。
[H3C-probe] diag environment display
Kernel exec cmd ok.
power1: normal
power2: not present
fan1: normal(speed 1)
fan2: normal(speed 1)
fan3: normal(speed 1)
tmpr(VENT-IN): 34 threshold <3, 58, 70>
tmpr(CPU): 72 threshold <20, 85, 100>
tmpr(VENT-OUT): NOT SUPPORT
tmpr(HOT-SET2): NOT SUPPORT
tmpr(HOT-SET3): NOT SUPPORT
tmpr(HOT-SET4): NOT SUPPORT
表1-5 diag environment display显示信息描述表
power1
电源1的工作状态:
·     normal:电源正常工作
·     abnormal:电源工作异常
·     not present:电源不在位
power2
电源2的工作状态:
·     normal:电源正常工作
·     abnormal:电源工作异常
·     not present:电源不在位
fan1
风扇1的工作状态:
·     normal(speed n):风扇正常工作,speed表示风扇转速
·     abnormal:风扇工作异常
·     not present:风扇不在位
fan2
风扇2的工作状态:
·     abnormal:风扇工作异常
·     not present:风扇不在位
fan3
风扇3的工作状态:
·     abnormal:风扇工作异常
·     not present:风扇不在位
tmpr(VENT-IN)
入风口的温度信息:
当前温度 threshold <低温, 高温, 高温>
tmpr(CPU)
CPU的温度信息:
tmpr(VENT-OUT)
出风口的温度信息:
tmpr(HOT-SET2)
热点
tmpr(HOT-SET3)
热点
tmpr(HOT-SET4)
热点
diag fan display speed命令用来显示风扇速度。本命令的支持情况与设备型号有关,请以设备的实际情况为准。
Probe视图
# 显示风扇速度。
[H3C-probe] diag fan display speed
Kernel exec cmd ok.
The current speed is 1.
diag hasa display命令用来显示hasa标志位信息。本命令的支持情况与设备型号有关,请以设备的实际情况为准。
diag hasa display
Probe视图
# 显示hasa标志位信息。
[H3C-probe] diag hasa display
Kernel exec cmd ok.
 ulReplyLen = 0
diag if display命令用来显示系统接口规格。
diag if display
Probe视图
# 显示系统接口规格。
[H3C-probe] diag if display
MaxSubSlotPerSlot : 2
MaxIfPerSubSlot   : 11
MaxSlotNumber     : 2
MaxIfPerSlot      : 11
IfDimension       : 2
表1-6 diag if display显示信息描述表
MaxSubSlotPerSlot
每槽位最大子卡数量
MaxIfPerSubSlot
每子卡最大接口数量
MaxSlotNumber
系统最大槽位数量
MaxIfPerSlot
每板最大物理口数量
IfDimension
接口维度
diag led display命令用于显示设备LED指示灯灯状态。
diag led display
Probe视图
# 显示设备LED指示灯灯状态。
[H3C-probe] diag led display
********* sysslot led info *********
num        1(0)
firstno    1(0)
CtrlMode   0(0)
capability 0x0023(0)
run   state colour 0x0021 interval 1000(0)
alarm state colour 0x0002 interval 0(0)
slot     subslot  type     index    CtrlMode Mono     ColBit CurStat   SaveStat
SetStat  Mono     DMono    DUMo     Invalid  Inactive SetErr CurErr    Total
ffffffffffffffffffffffffffffffff0        1        0        0        0x1    0x21 1000 0x0  0
1    0 0 0        0        0        0        0        0      0         172721
********* power led info *********
num        2(0)
firstno    1(0)
CtrlMode   0(0)
run   state colour 0x0001 interval 0(0)
ffffffffffffffffffffffffffffffff2        1        0        0        0x0    0x1  0    0x0  0
1    0 0 0        0        0        0        0        0      0         0
ffffffffffffffffffffffffffffffff2        2        0        0        0x0    0x20 0    0x0  0
********* EC Event info *********
FanPst   FanEc    PwrPst   PwrEc    TmrEc    InitEc   SelfTestEx
0        0        0        0        0        0        0
0        0        0        0        0        0        0
0        0        1        0        0        0        0
0        0        0        0        0        0        0
0        0        0        0        0        0        0
0        0        0        0        0        0        0
********* Global Count *********
invalid parameter 0
get info error    0
表1-7 diag led display显示信息描述表
num
序号
firstno
起始序号
CtrlMode
控制模式:
·     硬件控制
·     软件控制
capability
能力:
·     0x01 绿
·     0x02 黄
·     0x04 橙
·     0x08 红
·     0x10 蓝
·     0x20 关闭
·     0x40 恢复保存状态
run   state colour
运行时LED灯颜色
interval
LED灯闪烁间隔
alarm state colour
告警时LED灯颜色
slot
槽位号
subslot
子槽位号
type
类型:
·     0 槽位灯
·     1 风扇灯
·     2 电源灯
·     3 Poe灯
index
索引
Mono
独占次数
ColBit
颜色位图
CurStat
当前状态
SaveStat
保存状态
SetStat
设置状态
DMono
多次独占次数
DUMo
多次取消独占次数
Invalid
无效次数
Inactive
未激活次数
SetErr
设置状态错误次数
CurErr
当前状态错误次数
Total
总次数
FanPst
风扇不在位次数
FanEc
风扇异常次数
PwrPst
电源不在位次数
PwrEc
电源异常次数
TmrEc
温度次数
InitEc
初始化异常次数
SelfTestEx
自检异常次数
invalid parameter
无效参数次数
get info error
获取信息错误次数
diag lipc display命令用来显示产品IPC信息。FEL层IPC报文用户注册的EINTF信息、多播组信息、IPC收发报文信息。
diag lipc display
Probe视图
# 显示产品IPC信息。
[H3C-probe] diag lipc display
********************** FEL LIPC Info ************************
Product Reg Info:
Mtu     = 1400
Drv Head Len    = 128
Multi Cast Group Info:
        Group Num = 0
Lipc Statistic Info:
         Rx From U2f =110236
         Rx Ucast From U2f =109163
         Rx Bcast From U2f =1073
         Rx Success Count =110236 Failed Count =0
         Rx Failed Info
                 Pdt not sup = 0
                 mod not init = 0
                 Pkt type err = 0
                 Domain err = 0
                 Ver/SubPro err = 0
                 Stm port err = 0
                 Not in Group = 0
                 Self Slot err = 0
                 Out Irf err = 0
                 Cmw failed = 0
         Tx From Plat =216297
         Tx Ucast From Plat =120514
         Tx Bcast From Plat =95783
         Tx Success Count =203520 Failed Count =12777
         Tx Failed Info
                 Pdt not sup = 0
                 mod not init = 0
                 Param err = 0
                 Stm port err = 12777
                 Get mac err = 0
                 No Mgroup = 0
                 U2f failed = 0
         TxDone Success Count = 203520 Failed Count = 0
         TxDone Failed Info
                 Pdt not sup = 0
                 mod not init = 0
                 Pkt type err = 0
                 Cmw failed = 0
                    Relay BroadCast Pkt Ok  = 0
                    Relay BroadCast Pkt Err  = 0
                    Relay UniCast Pkt Ok  = 0
                    Relay UniCast Pkt Err  = 0
表1-8 diag lipc display显示信息描述表
Product Reg Info
产品注册信息
Mtu
MTU值
Drv Head Len
驱动头长度
组播组信息
Group Num
组播组数量
Lipc Statistic Info
Lipc统计信息
Rx From U2f
从U2F收到的报文
Rx Ucast From U2f
从U2F收到的组播报文
Rx Bcast From U2f
从U2F收到的广播报文
Rx Success Count/ Failed Count
收包成功/失败计数
Pdt not sup
产品不支持
mod not init
模块未初始化
Pkt type err
包类型错误
Domain err
域错误
Ver/SubPro err
版本错误
Stm port err
堆叠端口错误
Not in Group
不在组错误
Self Slot err
本槽位错误
Out Irf err
非本堆叠错误
Cmw failed
上报平台错误
Tx From Plat
从平台发送的报文
Tx Ucast From Plat
从平台发送的组播报文
Tx Bcast From Plat
从平台发送的广播报文
Tx Success Count / Failed Count
发包成功/失败计数
Param err
参数错误
Get mac err
取mac地址错误
No Mgroup
控制平面错误
U2f failed
U2f错误
TxDone Success/Failed Count
发包完成成功/失败计数
中继广播成功报文
中继广播失败报文
中继组播成功报文
中继组播失败报文
diag log display命令用来显示设备的日志信息。
diag log display { all | last }
Probe视图
all:显示所有的日志信息。
last:显示最新的日志信息。
# 显示最新的日志信息。
[H3C-probe] diag log display last
60: (PwrNotPresent)2016-03-14 01:09:55 Power 2 not present in 1/0
diag mbuf-relay display命令用来显示产品mbuf-relay信息。mbuf-relay用户注册的EINTF信息,Mbuf-Relay报文收方向信息,Mbuf-Relay报文发送方向信息。
Probe视图
# 显示产品mbuf-relay模块信息。
[H3C-probe] diag mbuf-relay display
********************** FEL Mbuf-Relay Info ************************
Product Reg Info:
Mtu     = 1800
Drv Head Reserved       = 48
Rcv Buf Len     = 2560
Max Vcpu Num    = 32
Channel Type    = STM
Mbuf-Relay Statistic Info:
         Rx From U2f Count =0
         Rx From U2f Unicast Count =0
         Rx From U2f Broadcast Count =0
         Rx Success Count =0 Failed Count =0
         Rx Failed Info
                 Pdt not sup = 0
                 mod not init = 0
                 Pkt type err = 0
                 Pkt domain err = 0
                 Ver/SubPro err = 0
                 Stm port err = 0
                 Self Slot err = 0
                 Out Irf = 0
                 Malloc failed = 0
                 Cmw failed = 0
         Tx From Platform Count =0 NoFSBuf Count =0
         Tx Success Count =0 Failed Count =0
         Tx Failed Info
                 Pdt not sup = 0
                 mod not init = 0
                 Param err = 0
                 Get global slot err = 0
                 Stm port err = 0
                 Get mac err = 0
                 Mbuf_Prepend failed = 0
                 U2f failed = 0
                 Drv failed = 0
                 No MBuf = 0
表1-9 diag mbuf-relay display显示信息描述表
Product Reg Info
产品注册信息
Mtu
MTU值
Drv Head Reserved
驱动头保留长度
Rcv Buf Len
接收缓冲区长度
Max Vcpu Num
最大vcpu数量
Channel Type
通道类型:
堆叠
普通
Mbuf-Relay统计信息
Rx From U2f
从U2F收到的报文
Rx Ucast From U2f
从U2F收到的组播报文
Rx Bcast From U2f
从U2F收到的广播报文
收包成功/失败计数
Pdt not sup
产品不支持
mod not init
模块未初始化
Pkt type err
包类型错误
Pkt domain err
包域错误
Ver/SubPro err
版本错误
Stm port err
堆叠端口错误
Malloc failed
分配内存错误
Self Slot err
本槽位错误
Out Irf err
非本堆叠错误
Cmw failed
上报平台错误
Tx From Plat Count
从平台发送的报文
NoFSBuf Count
无快转缓冲区计数
Param err
参数错误
Get mac err
取mac地址错误
Get global slot err
取全局槽位号错误
Mbuf_Prepend failed
Mbuf准备失败
U2f failed
U2f失败
Drv failed
驱动失败
No MBuf
无Mbuf
中继广播成功报文
中继广播失败报文
中继组播成功报文
中继组播失败报文
diag mbus display命令用来显示mbus的调试信息,显示用户注册的EINTF信息,mbus报文信息。
diag mbus display
Probe视图
# 显示mbus的调试信息。
[H3C-probe] diag mbus display
********************** FEL MBUS Info ************************
 Product Reg Info:
   Mtu = 1400
   Drv Head Len = 64
   Data Rate Limit = 1000 (pps)
 Mbus Statistic Info:
   Rx From U2f = 360
   Rx Ucast From U2f = 0
   Rx Bcast From U2f = 360
   Rx Success Count = 359 Failed Count = 1
   Rx SubPro Info
         Test = 0
         Load = 0
         HeartBeat = 359
         Issu = 0
         Vcheck = 0
         Reserved = 0
   Rx Failed Info
         Pdt not sup = 0
         mod not init = 0
         Not Mbus Pkt = 0
         Domain err = 0
         Ver/SubPro invalid = 0
         Stm port err = 0
         Self Slot err = 0
         Out Irf  = 1
         Cmw failed = 0
   Tx From Plat = 192434
   Tx Success Count = 166989 Failed Count = 25445
   Tx SubPro Info
         Test = From Plat 0     0
         Load = From Plat 0     0
         HeartBeat = From Plat 192434   166989
         Issu = From Plat 0     0
         Vcheck = From Plat 0   0
         Reserved = From Plat 0 0
   Tx Failed Info
         Pdt not sup = 0
         mod not init = 0
         Param err = 0
         Stm port err = 25445
         Get mac err = 0
         MCast Du failed = 0
         U2f failed = 0
表1-10 diag mbus display显示信息描述表
Product Reg Info
产品注册信息
Mtu
MTU值
Drv Head Len
驱动头长度
Data Rate Limit
数据速率限制
Mbus  Statistic Info
Mbus统计信息
Rx From U2f
从U2F收到的报文
Rx Ucast From U2f
从U2F收到的组播报文
Rx Bcast From U2f
从U2F收到的广播报文
收包成功/失败计数
Rx SubPro Info
接收子协议信息
Test
测试报文
Load
加载报文
HeartBeat
心跳报文
Issu
Issu报文
Vcheck
检查报文
Reserved
保留报文
Rx Failed Info
收包失败信息
Pdt not sup
产品不支持
mod not init
模块未初始化
Pkt type err
包类型错误
domain err
包域错误
Ver/SubPro err
版本错误
Stm port err
堆叠端口错误
Malloc failed
分配内存错误
Self Slot err
本机报文错误
Out Irf err
非本机报文错误
Cmw failed
上报平台错误
Tx From Plat Count
从平台发送的报文
Tx Success Count/Failed Count
发送成功/失败计数
Tx SubPro Info
发送子协议信息
Test = From Plat
从平台发送的test报文 发送成功计数
Load = From Plat
从平台发送的Load报文 发送成功计数
从平台发送的HeartBeat报文 发送成功计数
Issu = From Plat
从平台发送的Issu报文 发送成功计数
Vcheck = From Plat
从平台发送的Vcheck报文 发送成功计数
从平台发送的Reserved报文 发送成功计数
Tx Failed Info
发包失败信息
Param err
参数错误
Get mac err
取mac地址错误
MCast Du failed
组播拷贝失败
U2f failed
U2f失败
中继广播成功报文
中继广播失败报文
中继组播成功报文
中继组播失败报文
diag mem-assign display命令用来显示存储器件的空间分配情况。
Probe视图
# 显示存储器件的空间分配情况。
[H3C-probe] diag mem-assign display
SlotNo SubSlotNo MemType           Index OrgMemStart    OrgMemSize
-----   -------- SRC_TYPE_power    1     0x0            0x400
-----   -------- SRC_TYPE_fan      1     0x0            0x0
1      0         SRC_TYPE_NorF     1     0x17000000     0x1000000
1      0         SRC_TYPE_cf       1     0x0            0x0
1      0         SRC_TYPE_HgMem    1     0xec00000      0x100000
*************************System  MemoryType*********************************
MemType          Id  MemContent          M/B  StartAddr      NeedSize
SRC_TYPE_power   1   DST_TYPE_powmi      M    0x0            0x400
SRC_TYPE_power   2   DST_TYPE_powmi      M    0x0            0x400
*************************SlotNo:1  SubSlotNo:0******************************
SRC_TYPE_NorF    1   DST_TYPE_lic        B    0x17aa0000     0x380000
SRC_TYPE_NorF    1   DST_TYPE_stm        B    0x17a80000     0x1000
表1-11 diag mem-assign display显示信息描述表
SlotNo
槽位号
SubSlotNo
子槽位号
MemType
存储类型:
·     电源
·     风扇
Index
索引
OrgMemStar
起始地址
OrgMemSize
存储区大小
Id
存储区域ID
MemContent
存储内容
M/B
主/备
StartAddr
起始地址
NeedSize
存储区大小
diag module display content命令用来显示各个器件模块指定地址存储信息。
diag module slot/subslot { btrm | cf | cpld | cpu | dimm | eeprom | fan | nandflash | norflash | | nvram | pci | power | rtc | tmpr | usb } chip-no display content offset-value len-value
Probe视图
slot/subslot:指定槽位号或者子槽位号。
chip-no:指定芯片编号。
offset-value:指定起始地址。
len-value:指定偏移长度值。
btrm:显示bootrom的信息。
cf:显示cf卡的信息。
cpld:显示cpld的信息。
cpu:显示cpu的信息。
dimm:显示内存的信息。
eeprom:显示eeprom的信息。
fan:显示风扇的信息。
nandflash:显示nandflash的信息。
norflash:显示norflash的信息。
nvram:显示nvram的信息。
pci:显示pci的信息。
power:显示电源的信息。
rtc:显示硬件时钟的信息。
tmpr:显示温感的信息。
usb:显示usb的信息。
# 显示1/0槽位0 cpu无偏移第一个地址信息。
[H3C-probe] diag module 1/0 cpu 0 display content 0 1
Kernel exec cmd ok.
 ulReplyLen = 95
00000000: 00
diag module display content命令用来显示mac或phy模块各个端口信息。
diag module slot/subslot { mac | phy } { aux | console | ethernet | gigabitethernet | i-gigabitethernet | inasync | inner-ethernet | m-ethernet | m-gigabitethernet | ten-gigabitethernet | wlan-radio } chip-no display content offset-value len-value
Probe视图
设备接口类型的支持情况请以设备实际情况为准。
mac:显示mac模块各个端口信息。
phy:显示phy模块各个端口信息。
aux:aux接口,本参数的支持情况与设备型号有关。
console:console接口,本参数的支持情况与设备型号有关。
ethernet:以太网接口,本参数的支持情况与设备型号有关。
gigabitethernet:GE接口,本参数的支持情况与设备型号有关。
i-gigabitethernet:内部GE接口,本参数的支持情况与设备型号有关。
inasync:内部异步接口,本参数的支持情况与设备型号有关。
inner-ethernet:内部以太网接口,本参数的支持情况与设备型号有关。
m-ethernet:百兆管理以太网接口,本参数的支持情况与设备型号有关。
m-gigabitethernet:千兆管理以太网接口,本参数的支持情况与设备型号有关。
ten-gigabitethernet:10GE(万兆以太网接口),本参数的支持情况与设备型号有关。
wlan-radio:无线射频接口,本参数的支持情况与设备型号有关。
chip-no:指定芯片编号。
len-value:指定偏移长度值。
# 显示mac模块console口的信息。
[H3C-probe] diag module 1/0 mac console 1 display content 0 3
diag pcie display命令用于显示PCIE状态。
diag pcie slot/subslot display chip-no bus-id device-id function-id offset width
Probe视图
chip-no:指定芯片号。
bus-id:指定总线号。
device-id:指定设备ID。
function-id:指定功能ID。
offset:指定偏移量。
width:指定长度。
# 显示指定PCIE的状态。
[H3C-probe] diag pcie 1/0 display 1 0 1 0 0 3
Kernel exec cmd ok.
 ulReplyLen = 6
65535
1.1.26  diag poe
diag poe命令用于设置超瘦本体PoE功能状态,以及获取端口PoE工作状态。
diag poe slot/subslot { port-no | all } { disable | enable | status }
Probe视图
slot/subslot:指定槽位号或子槽位号。
port-no:指定端口号。
all:配置所有端口的PoE功能。
disable:关闭端口PoE功能。
enable:开启端口PoE功能。
status:显示端口PoE功能的状态,关闭或开启。
diag port display statistics命令用来显示各端口统计信息。
diag port { aux | console | Ethernet | gigabitethernet | i-gigabitethernet | inasync | inner-ethernet | m-ethernet | m-gigabitethernet | wlan-radio } display statistics
Probe视图
all:显示所有端口的统计信息。
aux:显示aux接口的统计信息,本参数的支持情况与设备型号有关。
console:显示console接口的统计信息。
ethernet:显示以太网接口的统计信息,本参数的支持情况与设备型号有关。
gigabitethernet:显示GE接口的统计信息,本参数的支持情况与设备型号有关。
i-gigabitethernet:显示内部GE接口的统计信息,本参数的支持情况与设备型号有关。
inasync:显示内部异步接口的统计信息,本参数的支持情况与设备型号有关。
inner-ethernet:显示内部以太网接口的统计信息,本参数的支持情况与设备型号有关。
m-ethernet:显示以以太管理接口的统计信息,本参数的支持情况与设备型号有关。
m-gigabitethernet:显示管理以太网接口的统计信息,本参数的支持情况与设备型号有关。
ten-gigabitethernet:显示10GE接口的统计信息,本参数的支持情况与设备型号有关。
wlan-radio:显示无线射频接口的统计信息,本参数的支持情况与设备型号有关。
smartrate-ethernet:显示smartrate-ethernet以太网接口的统计信息,本参数的支持情况与设备型号有关。
fortygige:显示fortygige接口的统计信息,本参数的支持情况与设备型号有关。
# 显示管理以太网接口统计信息。
[H3C-probe] diag port m-gigabitethernet 0/0/0 display statistics
Kernel exec cmd ok.
****************SlotNo 1,SubSlotNo 0,M-GigabitEthernet0/0/0***************
InfoName                 Info
ui64InBytes              14702943
ui64InPkts               107093
ui64InUcastPkts          0
ui64InMcastPkts          17900
ui64InBcastPkts          89193
ui64InDiscards           0
ui64InGiant              0
ui64InCrcErrs            0
ui64InSysFailDrop        0
ui64InLastPkts           107091
ui64InLastDiscards       0
ui64InBuffers            0
ui64OutBytes             0
ui64OutPkts              0
ui64OutUcastPkts         0
ui64OutMcastPkts         0
ui64OutBcastPkts         0
ui64OutDiscards          0
ui64OutBuffers           0
ui64InputErrs            0
ui64OutputErrs           0
ui64CrcErrs              0
ui64RxPause              0
ui64AlignErrs            0
ui64CarrierSenseErr      0
ui64RxUndersize          0
ui64RxOversize           0
ui64RuntFrameErrs        0
ui64TooLongErrs          0
ui64InUnknownProtos      0
ui64OverrunErrs          0
ui64Pkts64Octets            0
ui64Pkts65to127Octets       0
ui64Pkts128to255Octets      0
ui64Pkts256to511Octets      0
ui64Pkts512to1023Octets     0
ui64Pkts1024to1518Octets    0
ui64TxPause              0
ui64DeferedErrs          0
ui64SingleCollision      0
ui64TxLateCollison       0
ui64TxExcesiveCollison   0
ui64TxCollison           0
ui64TxJabber             0
ui64TxFCSErr             0
ui64TxOversize           0
ui64UnderrunErrs         0
ui64CollisionErrs        0
ui64ShutDownCnt          0
ui64NoShutCnt            1
ui64LinkupCnt            1
ui64LinkdownCnt          0
ulRxEnableCnt            2
ulRxDisableCnt           2
ulDataTxDoneInt          0
ulDataRxDoneInt          0
ulTxCalledCnt            0
ulTxCalledOkCnt          0
表1-12 diag port displaystatistics显示信息描述表
InfoName
参数名称
Info
参数值
ui64InBytes
接口接收字节数
ui64InPkts
接口接收报文数
ui64InUcastPkts
接口接收单播报文数
ui64InMcastPkts
接口接收多播报文数
ui64InBcastPkts
接口接收广播报文数
ui64InDiscards
接收丢弃报文数
ui64InGiant
超长报文数
ui64InCrcErrs
Crc错误数
ui64InSysFailDrop
失败丢包数
ui64InLastPkts
上次收包数
ui64InLastDiscards
上次丢包数
ui64InBuffers
实际收到有效buffer数
ui64OutBytes
接口发送字节数
ui64OutPkts
接口发送报文数
ui64OutUcastPkts
接口发送单播报文数
ui64OutMcastPkts
接口发送多播报文数
ui64OutBcastPkts
接口发送广播报文数
ui64OutDiscards
发送丢弃报文数
ui64OutBuffers
实际发送有效buffer数
ui64InputErrs
接收错误数
ui64OutputErrs
发送错误数
ui64CrcErrs
Crc错误数
ui64RxPause
接收流控帧数
ui64AlignErrs
帧对齐错误
ui64CarrierSenseErr
CarrierSense错误数
ui64RxUndersize
小于64且FCS正确
ui64RxOversize
长度超 1518活1522且FCS正确
ui64RuntFrameErrs
小于64且FCS错误
ui64TooLongErrs
长度超 1518活1522且FCS错误
ui64InUnknownProtos
接收的未知协议报文
ui64OverrunErrs
收包速度超队列处理速度丢弃
ui64Pkts64Octets
接收64字节报文数
接收65-127字节报文数
接收128-255字节报文数
接收256-511字节报文数
接收512-1023字节报文数
接收1024-1518字节报文数
ui64TxPause
发送流控帧数
ui64DeferedErrs
延迟错误报文数
ui64SingleCollision
发送单次冲突报文
ui64SingleCollision
发送多次冲突报文
ui64TxLateCollison
最近冲突
冲突丢包
ui64TxCollison
发送冲突计数
ui64TxJabber
发送模糊报文计数
ui64TxFCSErr
发送错误报文计数
ui64TxOversize
发送大于jumb帧长度报文
ui64UnderrunErrs
错误统计
ui64CollisionErrs
冲突错误统计
ui64ShutDownCnt
接口shutdown次数
ui64NoShutCnt
接口undo shutdown次数
ui64LinkupCnt
接口linkup次数
ui64LinkdownCnt
接口linkdown次数
ulRxEnableCnt
使能接口接收次数
ulRxDisableCnt
禁止接口接收次数
ulDataTxDoneInt
数据发送完成中断调用次数
ulDataRxDoneInt
数据接收完成中断调用次数
ulTxCalledCnt
发送函数被调用次数
ulTxCalledOkCnt
发送函数被调用成功次数
diag port-list display命令用来显示所有端口列表。
Probe视图
# 显示所有端口列表。
[H3C-probe] diag port-list display
SlotNo      SubSlotNo   PortType                 PortNum     FirstPortNo
1           0           InAsync                  0           0
1           0           Inner-Ethernet           0           0
1           0           I-GigabitEthernet        0           0
1           0           Console                  0           0
1           0           Aux                      0           0
1           0           M-Ethernet               0           0
1           0           M-GigabitEthernet        1           0
1           0           Ethernet                 0           0
1           0           GigabitEthernet          8           1
1           0           Smartrate-Ethernet       0           0
1           0           Ten-GigabitEthernet      2           9
1           0           FortyGigE                0           0
1           0           WLAN-Radio               0           0
表1-13 diag port-list display显示信息描述表
SlotNo
槽位号
SubSlotNo
子槽位号
PortType
端口类型
PortNum
端口数量
FirstPortNo
起始端口号
diag port-table display命令用来显示上报平台端口列表。
Probe视图
# 显示上报平台端口列表。
1           0           InAsync                  0           0
1           0           Console                  0           0
1           0           Aux                      0           0
1           0           M-Ethernet               0           0
1           0           Ethernet                 0           0
1           0           FortyGigE                0           0
1           0           WLAN-Radio               0           0
表1-14 diag port-list display显示信息描述表
SlotNo
槽位号
SubSlotNo
子槽位号
PortType
端口类型
PortNum
端口数量
FirstPortNo
起始端口号
diag stm display命令用来显示堆叠调试信息,包括是否支持堆叠、支持盒式堆叠还是分布式堆叠,获取堆叠的能力等信息。
diag stm display
Probe视图
# 显示堆叠调试信息。
[H3C-probe] diag stm display
********************** FEL STM Info ************************
 Product Reg Info:
  ulStmBoxOrChassMode   = 1
  ulStackCapability     = 1
  entmib IsSameAsLocalDev       = 1
  szPdtName     = WX5510E
  Pdt Max Device Num    = 2
  pfun-GetSupportStmPort        = 0xffffffffe01eafb0
  pfHAL_STM_WaitRemotePortLink  = 0xffffffffe01eb860
 Stack Info:
  work mode     = 1
  member id     = 1
 g_ulUpdownDelayTime    = 0
  Local self member info:
  ulCapability  = 1
  ucMemberID            = 1
  ucLocalSlotID         = 0
  ucPriority            = 1
  ucMaxMemberNum        = 2
  ucMaxMemberPort       = 4
  ucAutoMerge           = 1
  ucDefaultPortMode     = 0
  bridge mac     =[000f-1212-1101]
  cpu mac        =[000f-1212-1101]
  szStackContext        = WX5510E
  szDeviceInfo          = WX5510E
 shutdow:1-shutdown 0-undoshut forward:1-BLOCK 2-forward 3-silent)
  g_astStackPort[0] shutdown = 0, forward status = 4
  g_astStackPort[1] shutdown = 0, forward status = 4
  g_astStackPort[2] shutdown = 0, forward status = 4
  g_astStackPort[3] shutdown = 0, forward status = 2
  memberid:[1]-----CpuMac:[000f-1212-1101]
 Cluster Fwd Table Info:
      stCpuMac[000f-1212-1101] memberid:1
 CLUSTER Fwd Port Table Info:
     Ctrl Port Table Info[1]:
         PortPhyID:1
     Data Port Table Info[1]:
         PortPhyID:1
表1-15 diag stm display 显示信息描述表
Product Reg Info:
产品注册信息
ulStmBoxOrChassMode
堆叠属性:
·     盒式堆叠
·     分布式堆叠
ulStackCapability
堆叠台数
是否是同一类型设备堆叠
szPdtName
设备名称
Pdt Max Device Num
最大堆叠数量
注册的堆叠函数检查函数地址
注册的等待堆叠口函数地址
Stack Info:
堆叠信息
work mode
工作状态:
·     堆叠模式
·     非堆叠模式
member id
身份ID:1-32
g_ulUpdownDelayTime
端口linkdelay时间
本机信息
ulCapability
堆叠能力 1-4
ucMemberID
身份ID:1-32
ucLocalSlotID
框内偏移槽位号
ucPriority
Member优先级 :1-32
ucMaxMemberNum
最大堆叠成员数 1-4
ucMaxMemberPort
每个堆叠口最大成员个数 1-4
ucAutoMerge
是否默认使能merge自动重启
ucDefaultPortMode
堆叠物理接口缺省工作模式:
·     普通模式
·     增强模式
·     扩展模式
bridge mac
桥mac
cpu mac
Cpu mac
szStackContext
堆叠上下文信息
szDeviceInfo
设备说明信息
状态说明
g_astStackPort
堆叠口
memberid
身份ID:1-32
CpuMac
Cpu Mac
星型堆叠转发表信息
stCpuMac
Cpu Mac
memberid
身份ID:1-32
星型堆叠转发端口表信息
控制端口信息
PortPhyID
端口物理ID
数据端口信息
diag stm statistic display命令用来显示堆叠收发统计信息。
Probe视图
# 显示堆叠收发统计信息。
[H3C-probe] diag stm statistic display
   Plat Out Count       = 296439
   Plat Bcast Out Count = 296438
   Out Success Count    = 258225
   Out Failed           = 38214
   U2f In Count         = 550
   U2f Ucast In Count   = 2
   U2f Bcast In Count   = 548
   In Success Count     = 550
   In u2f to stm Count  = 550
--------STM driver statistics----------
   stPktsNotInitErr     = 0
   stPktsDomainErr      = 0
   stParamErr           = 0
   stChannelErr         = 0
   stNeighErr           = 0
   stMbufRawCopyErr     = 0
   stMbufCopyDataErr    = 0
   stMbufPrependErr     = 0
   stMbufCutHeadErr     = 0
   stOutDevErr          = 0
   stOutDevBusy         = 0
   stPktsNotVaildPort   = 0
   stHardXmitErr        = 0
   stPktsOutUcast       = 1
   stPktsOutMcast       = 258224
   stPktsOutBcast       = 0
   stPktsHardXmit       = 38214
   stU2fPktsIn          = 550
   stPktsIn             = 550
   stPktsUpUcast        = 0
   stPktsUpMcast        = 0
   stPktsUpBcast        = 0
   stPktsInUpStm        = 550
   stPktsRcvSelfErr     = 0
   stPktsRelayBCastErr  = 0
   stPktsRelayBCastOk   = 0
   stPktsRelayUCastErr  = 0
   stPktsRelayUCastOk   = 0
表1-16 diag stm statistics display显示信息描述表
Plat Out Count
平台发送报文
平台发送广播报文
Out Success Count
发送成功报文
Out Failed
发送失败报文
U2f In Count
U2f接收报文
U2f Ucast In Count
U2f接收单播报文
U2f Bcast In Count
U2f接收广播报文
In Success Count
接收成功报文
In u2f to stm Count
U2f接收堆叠报文
堆叠驱动统计信息
stPktsNotInitErr
接收本机报文错误
stPktsDomainErr
接收本域报文错误
stParamErr
参数错误
stChannelErr
通道错误
stNeighErr
邻居错误
stMbufRawCopyErr
Mbuf拷贝raw错误
stMbufCopyDataErr
Mbuf拷贝数据错误
stMbufPrependErr
Mbuf向前扩展失败
stMbufCutHeadErr
Mbuf去头错误
stOutDevErr
发送错误
stOutDevBusy
发送忙
stPktsNotVaildPort
报文非法端口错误
stHardXmitErr
硬件转发错误
stPktsOutUcast
发送单播报文
stPktsOutMcast
发送多播报文
stPktsOutBcast
发送广播报文
stPktsHardXmit
报文分发错误
stU2fPktsIn
U2f接收报文
stPktsIn
接收报文
stPktsUpUcast
单播向上分发报文
stPktsUpMcast
多播向上分发报文
stPktsUpBcast
广播向上分发报文
stPktsInUpStm
上送平台stm报文
stPktsRcvSelfErr
接收本机报文错误
stPktsRelayBCastErr
中继广播报文错误
stPktsRelayBCastOk
中继广播报文成功
stPktsRelayUCastErr
中继单播报文错误
stPktsRelayUCastOk
中继单播报文成功
diag temperature display status命令用来显示温感信息。
Probe视图
# 显示温度统计信息。
[H3C-probe]diag temperature display status
Kernel exec cmd ok.
TmprType        : VENT-IN
[-20, -10]      : 0
[-10,   0]      : 0
[  0,  10]      : 0
[ 10,  20]      : 3
[ 20,  30]      : 29785
[ 30,  40]      : 194082
[ 40,  50]      : 21
[ 50,  60]      : 0
[ 60,  70]      : 0
[ 70,  80]      : 0
TmprType        : CPU
[-20, -10]      : 0
[-10,   0]      : 0
[  0,  10]      : 0
[ 10,  20]      : 0
[ 20,  30]      : 0
[ 30,  40]      : 0
[ 40,  50]      : 837
[ 50,  60]      : 56376
[ 60,  70]      : 63796
[ 70,  80]      : 102882
TmprType        : VENT-OUT
[-20, -10]      : 0
[-10,   0]      : 0
[  0,  10]      : 0
[ 10,  20]      : 0
[ 20,  30]      : 0
[ 30,  40]      : 0
[ 40,  50]      : 0
[ 50,  60]      : 0
[ 60,  70]      : 0
[ 70,  80]      : 0
TmprType        : HOT-SET2
[-20, -10]      : 0
[-10,   0]      : 0
[  0,  10]      : 0
[ 10,  20]      : 0
[ 20,  30]      : 0
[ 30,  40]      : 0
[ 40,  50]      : 0
[ 50,  60]      : 0
[ 60,  70]      : 0
[ 70,  80]      : 0
TmprType        : HOT-SET3
[-20, -10]      : 0
[-10,   0]      : 0
[  0,  10]      : 0
[ 10,  20]      : 0
[ 20,  30]      : 0
[ 30,  40]      : 0
[ 40,  50]      : 0
[ 50,  60]      : 0
[ 60,  70]      : 0
[ 70,  80]      : 0
TmprType        : HOT-SET4
[-20, -10]      : 0
[-10,   0]      : 0
[  0,  10]      : 0
[ 10,  20]      : 0
[ 20,  30]      : 0
[ 30,  40]      : 0
[ 40,  50]      : 0
[ 50,  60]      : 0
[ 60,  70]      : 0
[ 70,  80]      : 0
diag tmpr-alarm display threshold命令用来显示进风口最低温度和最高温度。
Probe视图
# 显示进风口最低温度和最高温度。
[H3C-probe] diag tmpr-alarm display threshold
Kernel exec cmd ok.
Tmpr[VENT-IN] : [3, 58]
display debug-info命令用来打印debug设置信息。
display debug-info
Probe视图
# 显示debug设置信息。
[H3C-probe] display debug-info
Kernel exec cmd ok.
 ulReplyLen = 358
                          DRV DEBUG Setting
DRV Debug Status    : Off
Out To              : Info center
Output Num          : no-limit
Out File/Line       : On
Out Mid/Level       : On
Open Levels         :
Open Modules        :
表1-17 display debug-info显示信息描述表
DRV Debug Status
Debug状态:
·     on:表示开启
·     off:表示关闭
Out To
输出终端信息目的地址:
·     Info center:表示信息中心
·     console:表示串口
Output Num
输出行数的限制:
·     no-limit:不限制
·     其它:按设置条数输出
Out File/Line
是否携带文件名、行号
·     On:携带
·     Off:不携带
Out Mid/Level
是否携带模块ID和级别
·     On:携带
·     Off:不携带
Open Levels
开启的级别:
·     DEB_ERROR
·     DEB_INFO
·     DEB_DEBUG
Open Modules
开启的模块
display system internal dot11 characteristics命令用来显示802.11侦听特征的统计信息和详细信息。
display system internal dot11 characteristics bss bssid
Probe视图
bss bssid:显示BSS实体的特征统计信息和详细信息,包括BSS接收报文方向和发送报文方向。
display system internal dot11 verbose命令用来显示802.11协议socket的详细信息。
Probe视图
display system internal wlan adapter-asyncinfo命令用来显示适配层异步信息。
display system internal wlan adapter-asyncinfo { all | thread thread-number }
Probe视图
all:显示所有线程的适配层异步信息。
thread thread-number:显示指定线程上的适配层异步信息。
display system internal wlan ap message命令用来显示APMGR发送和接收消息的统计信息。
display system internal wlan ap message statistics
Probe视图
display system internal wlan ap name ap-name apcb命令用来打印APCB的信息。
display system internal wlan ap name ap-name radio raido-id命令用来打印指定的Radio接口信息。
display system internal wlan ap name ap-name capwap-context命令用来打印CAPWAP的信息。
display system internal wlan ap name ap-name { apcb | radio radio-id | capwap-context }
Probe视图
apcb:显示APCB的信息。
radio radio-id:显示指定的radio-id的Radio信息。
capwap-context:显示CAPWAP上下文的对话信息。
display system internal wlan ap ap-name radio drv-info命令用来显示指定AP下所有射频的驱动信息。
Probe视图
ap-name:指定AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
display system internal wlan ap-libinfo命令用来显示lib端的AP信息或射频基础配置信息。
display system internal wlan ap-libinfo app-id app-id { ap-id ap-id | ap-name ap-name } [ radio-id radio-id ]
Probe视图
app-id app-id:显示指定APP上的AP信息或射频基础配置信息,app-id表示APP的ID,取值范围与设备的当前配置有关,请以实际情况为准。
ap-id ap-id:显示指定AP的AP信息或射频基础配置信息,ap-id表示AP的ID,取值范围为1~65535。
ap-name ap-name:显示指定AP的AP信息或射频基础配置信息,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
radio-id radio-id:显示指定射频的基础配置信息,radio-id表示射频的ID,取值范围与AP设备的型号有关,请以设备的实际情况为准。如果不指定该参数,则显示lib端的AP信息。
某些情况下,APMGR与其他APP间的AP数据或射频基础配置数据同步失败,会出现局部不同步的AP数据或射频基础配置数据。这时请使用该命令查看指定APP上的AP数据或射频基础配置信息。
display system internal wlan band-navigation命令用来显示AP扫描到的客户端的频谱导航信息。
display system internal wlan band-navigation ap ap-id [ client mac-address ]
Probe视图
ap-id:AP ID,取值范围为1~65535。
client mac-address:显示AP扫描到的指定客户端的频谱导航信息。mac-address为客户端MAC地址,格式为H-H-H。如果不指定该参数,将显示AP扫描到的所有客户端的频谱导航信息。
display system internal wlan client ip [ mac-address mac-address ]命令用来显示客户端的IP地址信息。
Probe视图
mac-address mac-address:显示指定MAC地址的客户端IP地址信息。如果未指定本参数,则显示所有客户端的IP地址信息。
display system internal wlan command-cache命令用来查看缓存队列中的命令行消息。
Probe视图
display system internal wlan history-error命令用来显示APMGR消息处理失败的历史记录。
display system internal wlan history-error { ap-id ap-id | ap-name ap-name } [ radio-id radio-id ]
Probe视图
ap-id ap-id:显示指定AP的APMGR消息处理失败的历史记录。ap-id表示AP的ID,取值范围为1~65535。
ap-name ap-name:显示指定AP的APMGR消息处理失败的历史记录。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
radio-id radio-id:显示指定射频的APMGR消息处理失败的历史记录。radio-id表示射频的ID,取值范围与AP设备的型号有关,请以设备的实际情况为准。如果不指定本参数,则显示所有射频的APMGR消息处理失败的历史记录。
display system internal wlan kernel-ap命令用来显示AP内核信息。
display system internal wlan kernel-ap { name ap-name | all }
Probe视图
name ap-name:显示指定名称的AP内核信息,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线和横线。
all:显示所有内核中的AP信息。
display system internal wlan link-info用来显示连接信息。
Probe视图
display system internal wlan load-balance neighbor-list ap命令用来显示Radio的负载信息和扫描到的客户端列表。
display system internal wlan load-balance neighbor-list ap ap-id radio radio-id
Probe视图
radio-id:Radio ID,取值范围与AP设备的型号有关,请以设备的实际情况为准。
本命令仅在负载均衡类型为基于Radio的负载均衡时使用。
display system internal wlan load-balance neighbor-list client命令用来显示扫描到指定客户端的Radio的信息。
display system internal wlan load-balance neighbor-list client mac-address
Probe视图
mac-address:客户端MAC地址,格式为H-H-H。
display system internal wlan response-timeout event命令用来显示应用进程响应时间超时的事件信息。
Probe视图
通过查看应用进程响应时间超时的事件可以查找应用进程响应缓慢的原因。系统定义的响应超时时间为1秒。
display system internal wlan statistics命令用来显示AP的统计信息。
display system internal wlan statistics { ap-interface name ap-name | ap-radio name ap-name radio radio-id }
Probe视图
ap-interface:显示AP上的接口统计信息。
ap-radio:显示AP上的WLAN射频统计信息。
name ap-name:AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“ /”及“-”,不区分大小写。
radio radio-id:射频ID,取值范围与AP设备的型号有关,请以设备的实际情况为准。
display system internal wlan virtual ap命令用来查看虚拟AP的信息。
display system internal wlan virtual ap { all | bssid bssid }
Probe视图
all:显示所有虚拟AP的信息。
bssid bssid:显示指定的虚拟AP的信息。
display system internal wlan virtual client命令用来显示虚拟客户端的信息。
display system internal wlan virtual client { all | bssid bssid [ offset offset-value ] }
Probe视图
all:显示所有虚拟客户端信息。
bssid bssid:显示指定BSSID标识的无线服务下的所有虚拟客户端信息。
offset offset-value:指定BSSID偏移量,显示偏移后的BSSID关联的虚拟客户端信息,取值范围为0~511。若不指定本参数,则表示不进行偏移。
1.2  F
1.2.1  fpl-diag
fpl-diag命令用来执行指定调试命令。
fpl-diag { cmd-string | slot slot-number cmd-string }
Probe视图
slot slot-number: 表示指定槽位号的调试信息。
cmd-string: 调试命令信息,此命令只适用于产品调式使用,可能引起系统崩溃,设备不可用等情况。此命令只能由H3C的技术支持人员使用。
# 显示fel已经的定制模块信息。
[H3C-probe] fpl-diag showfelconf
fel customization for mc ibc lipc mbus mbuf-relay stm log wlan
fel customizing : mc ibc lipc mbus mbuf-relay stm log
1.3  R
reset system internal wlan history-error命令用来清除APMGR消息处理失败的历史记录。
reset system internal wlan history-error { ap-id ap-id | ap-name ap-name } [ radio-id radio-id ]
Probe视图
ap-id ap-id:清除指定AP的APMGR消息处理失败的历史记录,ap-id表示AP的ID,取值范围为1~65535。
ap-name ap-name:清除指定AP的APMGR消息处理失败的历史记录,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
radio-id radio-id:清除指定射频的APMGR消息处理失败的历史记录,radio-id表示射频的ID,取值范围与AP设备的型号有关,请以设备的实际情况为准。如果不指定该参数,则清除所有射频的APMGR消息处理失败的历史记录。
reset system internal wlan response-timeout event命令用来重置应用进程响应时间超时的事件信息。
Probe视图
通过本命令可以清除已经不需要的应用进程事件信息,从而记录新增的应用进程事件信息。
rrm calibrate-power step命令用来设置功率调整步长。
undo rrm calibrate-power step命令用来恢复缺省情况。
rrm calibrate-power step { down | up } value
undo rrm calibrate-power step { down | up }
增加功率或减小功率的调整步长为3。
Probe视图
down:减小功率的步长。
up:增加功率的步长。
value:功调调整步长,取值范围为1~8,单位为dBm。
1.4  W
wlan ap-execute exec-console enable命令用来打开上线AP的执行控制台。
wlan ap-execute exec-console disable命令用来关闭上线AP的执行控制台。
wlan ap-execute ap-name exec-console { disable | enable }
当AP上线时,自动关闭执行控制台;AP下线时,自动开启执行控制台。
Probe视图
ap-name:AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
关闭AP的执行控制台后,用户将无法通过Console口和Telnet方式登录AP,已登录的用户不受影响。
wlan image-load model命令用来配置允许下发软件版本的AP型号。
undo wlan image-load model命令用来取消对指定AP型号下发软件版本的允许。
wlan image-load model { model }&<1-8>
undo wlan image-load model { model }&<1-8>
未配置对指定的AP型号下版本,即AC可对所有的AP型号下版本。
Probe视图
{ model }&<1-8>:指定AP型号,&<1-n>表示前面的参数最多可以输入n次。
开启版本升级功能,并配置对指定的AP型号下版本后,当指定型号的AP与AC建立CAPWAP隧道时,如果AP的软件版本与APDB中保存的软件版本不一致,则AP必须从AC上下载对应的软件版本文件进行升级后才能与AC建立CAPWAP隧道连接。对于其它型号的AP,即使软件版本与APDB中保存的软件版本不一致,AC也不允许对其下发版本。
wlan image-load model命令仅在版本升级功能处于开启的情况下才会生效。关于版本升级功能的介绍和配置请参见“WLAN配置指导”中的“AP管理”。
wlan image-load model命令仅对未上线的AP生效。
wlan image-load simultaneous命令用来配置AC上每个业务线程处理AP版本下载任务的并发数。
wlan image-load simultaneous count
AC上每个业务线程处理AP版本下载任务的并发数为8。
Probe视图
count:AC上每个业务线程处理AP版本下载任务的并发数,取值范围是1~64。
wlan system internal offline-restrain命令用来开启抑制AP下线功能。
undo wlan system internal offline-restrain命令用来关闭抑制AP下线功能。
wlan system internal offline-restrain ap ap-name
undo wlan system internal offline-restrain ap ap-name
抑制AP下线功能处于关闭状态。
Probe视图
ap ap-name:指定AP的名称,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”、及“-”,不区分大小写。
为定位问题方便,使用抑制AP下线功能来控制AP在AC端和AP端的状态机是否保持为Run状态。
·     开启该功能之后,AP将一直保持在线状态。执行wlan system internal offline-restrain命令后,会提示用户是否一直重传报文,如果输入Y,AC将一直发送请求报文给AP;如果输入N,AC发送给AP的请求报文的数目为配置的重传次数。
·     关闭该功能之后,AP可以正常下线。
AC发送给AP的请求报文包括Image Data Request报文、Configuration Update Request报文、Reset Request报文、Data Transfer Request报文、IEEE 802.11 WLAN Configuration Request报文和Station Configuration Request报文。
wlan system internal reboot-restrain命令用来开启抑制AP长时间未上线时自动重启功能。
undo wlan system internal reboot-restrain命令用来关闭抑制AP长时间未上线时自动重启功能。
wlan system internal reboot-restrain ap ap-name
undo wlan system internal reboot-restrain ap ap-name
抑制AP长时间未上线时自动重启功能处于关闭状态。
Probe视图
ap ap-name:抑制指定AP长时间未上线时自动重启,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”、及“-”,不区分大小写。
AP处于不在线状态10分钟后,就会自动重启。通过配置本命令,可以抑制AP进行自动重启。
wlan virtual ap add命令用来创建虚拟AP。
wlan virtual ap add { ipv4 ac-ip-address ap-ip-start | ipv6 ac-ipv6-address ap-ipv6-start } bssid bssid-start [ count count step ap-ip-step bssid-step ] [ port port-start step port-step ]
Probe视图
ipv4:指定IP地址类型为IPv4。
ipv6:指定IP地址类型为IPv6。
ac-ip-address:指定AC的IP地址。
ap-ip-start:指定AP的起始IP地址。
bssid bssid-start:指定虚拟AP的起始BSSID。
count count:指定虚拟AP数量,取值范围为1~255。若不指定本参数,则表示创建一个虚拟AP。
step ap-ip-step bssid-step:指定虚拟AP的IP地址及BSSID递增的步长,取值范围为1~255。
port port-start:指定AP端用来建立CAPWAP数据隧道的UDP端口号,取值范围为1024~65535。若不指定本参数,则表示UDP端口号为1024。
step port-step:虚拟AP的UDP端口号递增的步长,取值范围为1~20。若不指定本参数,则表示步长为1。
wlan virtual ap delete用来删除虚拟AP。
wlan virtual ap delete { all | bssid bssid }
Probe视图
all:删除所有虚拟AP。
bssid bssid:删除指定BSSID表示的虚拟AP。
wlan virtual client add命令用来创建虚拟客户端。
wlan virtual client add mac client-mac-start { ipv4 client-ip-start | ipv6 client-ipv6-start } [ count count ] [ step client-mac-step client-ip-step ] vlan vlan-id bssid { all | bssid [ offset offset-value ] } service-template service-template-name [ non-wmm ]
Probe视图
mac client-mac-start:指定虚拟客户端的起始MAC地址;若BSSID指定的参数为all,则下一个BSSID的虚拟客户端起始MAC地址为前一个BSSID的虚拟客户端偏移之后的MAC地址。
ipv4:指定虚拟客户端的IP地址为IPv4地址。
ipv6:指定虚拟客户端的IP地址为IPv6地址。
client-ip-start:指定虚拟客户端的起始IP地址;若BSSID指定的参数为all,则下一个BSSID的虚拟客户端起始IP地址为前一个BSSID的虚拟客户端偏移之后的IP地址。
count count:指定每个AP上的关联的虚拟客户端数量,取值范围为1~124。若不指定本参数,则表示每个AP上关联的虚拟客户端的数量为1个。
step client-mac-step client-ip-step:指定虚拟客户端的MAC地址及IP地址递增的步长,取值范围为1~256。若不指定本参数,则表示MAC地址递增步长为1,IP地址递增步长为1。
vlan vlan-id:指定虚拟客户端的VLAN,取值范围为1~4094。
bssid:无线服务的BSSID。
all:指定所有BSSID。
bssid:指定虚拟客户端关联的BSSID。
offset offset-value:指定BSSID偏移量,将虚拟客户端关联到偏移后的BSSID,取值范围为0~511。若不指定本参数,则表示不进行偏移。
service-template service-template-name:虚拟client关联的服务模板名称,为1~63个字符的字符串,不区分大小写。
non-wmm:创建非WMM类型的虚拟客户端,若不指定本参数,则表示创建WMM类型的虚拟客户端。
在配置本命令之前,必须先配置wlan virtual ap add命令。
wlan virtual client delete命令用来删除虚拟客户端。
wlan virtual client delete { all | bssid bssid [ offset offset-value ] | mac mac-address }
Probe视图
all:删除所有虚拟客户端。
mac mac-address:删除指定MAC地址的虚拟客户端。
bssid bssid:删除指定BSSID标识的无线服务下的所有虚拟客户端。
offset offset-value:指定BSSID偏移量,删除偏移后的BSSID关联的虚拟客户端,取值范围为0~511。若不指定本参数,则表示不进行偏移。
