02-WLAN命令参考
02-WLAN接入命令
本章节下载: 02-WLAN接入命令  (397.98 KB)
02-WLAN接入命令
1 WLAN接入
1.1 802.11 MAC配置命令
1.1.1 a-mpdu enable
1.1.2 a-msdu enable
1.1.3 ani enable
1.1.4 antenna type
1.1.5 beacon-measurement enable
1.1.6 beacon-measurement interval
1.1.7 beacon-measurement type
1.1.8 beacon ssid-hide
1.1.9 beacon-interval
1.1.10 channel
1.1.11 channel band-width
1.1.12 client
1.1.13 client max-count(服务模板视图)
1.1.14 debugging wlan mac
1.1.15 display wlan client
1.1.16 display wlan client beacon-report
1.1.17 display wlan client bridge
1.1.18 display wlan service-template
1.1.19 display wlan statistics client
1.1.20 display wlan statistics service-template
1.1.21 distance
1.1.22 dtim
1.1.23 fast-association enable
1.1.24 fragment-threshold
1.1.25 green-energy-management enable
1.1.26 long-retry threshold
1.1.27 max-power
1.1.28 max-rx-duration
1.1.29 mimo
1.1.30 power-off timeout
1.1.31 preamble
1.1.32 protection-mode
1.1.33 radio-type
1.1.34 reset wlan statistics
1.1.35 reset wlan client
1.1.36 rts-threshold
1.1.37 service-template (WLAN射频接口视图)
1.1.38 service-template (服务模板视图)
1.1.39 short-gi enable
1.1.40 short-retry threshold
1.1.41 shut-all-led enable
1.1.42 ssid
1.1.43 stbc enable
1.1.44 wlan broadcast-probe reply
1.1.45 wlan client idle-timeout
1.1.46 wlan client keep-alive
1.1.47 wlan country-code
1.1.48 wlan link-test
1.1.49 wlan service-template
1.1.50 wlan-client-isolation enable
1.1.51 wlan uplink-interface
1.2 Workgroup Bridge配置命令
1.2.1 client-mode authentication-method
1.2.2 client-mode cipher-suite
1.2.3 client-mode connect
1.2.4 client-mode disconnect
1.2.5 client-mode interface wlan-bss
1.2.6 client-mode roam
1.2.7 client-mode roam active-scan-time
1.2.8 client-mode roam rssi-threshold
1.2.9 client-mode keep-alive
1.2.10 client-mode ssid
1.2.11 client-mode state-timeout
1.2.12 display wlan client-mode radio
1.2.13 display wlan client-mode ssid
1 WLAN接入
1.1  802.11 MAC配置命令
1.1.1  a-mpdu enable
a-mpdu enable
undo a-mpdu enable
WLAN射频接口视图
【缺省级别】
2:系统级
无
【描述】
a-mpdu enable命令用来开启当前射频接口的A-MPDU功能。undo a-mpdu enable命令用来关闭A-MPDU功能。
缺省情况下,A-MPDU功能处于开启状态。
需要注意的是,该命令仅对802.11n模式的接口有效。在进行接口模式切换的时候,设备会恢复该功能在该模式下的缺省情况。
# 关闭A-MPDU功能。
<sysname> system-view
[sysname] interface WLAN-Radio 1/0/1
[sysname-WLAN-Radio1/0/1] undo a-mpdu enable
1.1.2  a-msdu enable
a-msdu enable
undo a-msdu enable
WLAN射频接口视图
【缺省级别】
2:系统级
无
【描述】
a-msdu enable命令用来开启当前射频接口的A-MSDU功能。undo a-msdu enable用来关闭A-MSDU功能。
缺省情况下,A-MSDU功能处于开启状态。
·     该命令仅对802.11n模式的接口有效。在进行接口模式切换的时候,设备会恢复该功能在该模式下的缺省情况。
·     目前,设备只支持接收A-MSDU报文,不支持发送A-MSDU。
# 关闭A-MSDU功能。
[sysname] interface wlan-radio 1/0/1
[sysname-WLAN-Radio1/0/1] undo a-msdu enable
1.1.3  ani enable
ani enable
undo ani enable
WLAN射频接口视图
【缺省级别】
2:系统级
无
【描述】
ani enable命令用来开启ANI(Adaptive Noise Immunity,自动抗干扰)功能。undo ani enable命令用来关闭该功能。
缺省情况下,自动抗干扰功能处于开启状态。
开启自动抗干扰功能后,设备会根据周边信号环境自动调整抗噪等级,来抵消周边射频干扰。
# 关闭自动抗干扰功能。
[Sysname] interface wlan-radio 1/0/1
[Sysname-WLAN-Radio 1/0/1] undo ani enable
1.1.4  antenna type
antenna type type
undo antenna type
WLAN射频接口视图
【缺省级别】
2:系统级
type:射频天线类型。
【描述】
antenna type命令用来配置射频的天线类型。undo antenna type命令用来恢复缺省情况。
设备各款型对于本节所描述的缺省支持情况有所不同,详细差异信息如下:
产品系列
型号
WA2600系列
WA2610H
缺省情况为internal
WA4600系列
WA4620i-ACN/WA4620E-ACN
WA4620i-ACN的缺省情况为internal,WA4620E-ACN的缺省情况为Ext-Def
WA4300系列
WA4320H-ACN
缺省情况为internal
WA4320i-ACN/WA4320i-X
WA4320i-ACN的缺省情况为internal,WA4320i-X的缺省情况为Ext-Def
WA4320-TS/WA4320-TQ/WA4320-TQ-V
缺省情况为Ext-Def
WA4320X
缺省情况为Ext-Def
WA4320-ACN/WA4320/WA4320-ACN-SI/WA4320-ACN-C/WA4320-ACN-D/WA4320-ACN-E/WA4320-ACN-PI
缺省情况为internal
WA4330-ACN
缺省情况为internal
LA4300系列
LA4310/LA4310V/LA4320/LA4320V/LA4320X
LA4310/LA4310V/LA4320/LA4320V的缺省情况为internal,LA4320X的缺省情况为Ext-Def
小贝系列
WAP722/WAP722E/WAP722S
缺省情况为internal
WAP712/WAP712C
缺省情况为internal
# 配置射频天线类型。
[sysname-WLAN-Radio1/0/1] antenna type internal
undo beacon-measurement enable
服务模板视图
【缺省级别】
2:系统级
无
【描述】
beacon-measurement enable命令用来开启信标测量功能。undo beacon-measurement enable 命令用来关闭信标测量功能。
缺省情况下,信标测量功能处于关闭状态。
开启信标测量功能后,AP会向支持802.11k协议的客户端发送信标测量请求。
# 开启信标测量功能。
[Sysname] wlan service-template 1 clear
[Sysname-wlan-st-1] beacon-measurement enable
beacon-measurement interval interval
undo beacon-measurement interval
服务模板视图
【缺省级别】
2:系统级
interval:信标测量请求的发送间隔,取值范围为10~200,单位为秒。
【描述】
beacon-measurement interval命令用来配置信标测量请求的发送间隔。undo beacon-measurement interval命令用来恢复缺省情况。
缺省情况下,信标测量请求的发送间隔为60秒。
# 配置信标测量请求的发送间隔为60秒。
[Sysname-wlan-st-1] beacon-measurement interval 60
beacon-measurement type { active | beacon-table | passive }
undo beacon-measurement type
服务模板视图
【缺省级别】
2:系统级
active:配置信标测量模式为主动模式。该模式下,AP向客户端发送信标测量请求,客户端收到信标测量请求后,会在其支持的所有信道上广播发送Probe Request帧,然后设置一个测量持续时长,在测量结束后,处理收到的所有Beacon帧和Probe Response帧,并编制信标测量报告回复给AP。
beacon-table:配置信标测量模式为信标表模式。该模式下,AP向客户端发送信标测量请求,客户端收到信标测量请求后,不执行额外的测量,直接向AP回复信标测量报告,该报告中包含客户端当前存储的所有信标测量信息。
passive:配置信标测量模式为被动模式。该模式下,AP向客户端发送信标测量请求,客户端收到信标测量请求后,会设置一个测量持续时长,在测量结束后,处理收到的所有Beacon帧和Probe Response帧,并编制信标测量报告回复给AP。
【描述】
beacon-measurement type命令用来配置信标测量模式。undo beacon-measurement type命令用来恢复缺省情况。
缺省情况下,信标测量模式为信标表模式。
# 配置信标测量模式为主动模式。
[Sysname-wlan-st-1] beacon-measurement type active
beacon ssid-hide
undo beacon ssid-hide
服务模板视图
【缺省级别】
2:系统级
无
【描述】
beacon ssid-hide命令用来配置在信标帧中隐藏SSID,即不通告SSID。undo beacon ssid-hide命令用来恢复缺省情况。
缺省情况下,信标帧中不隐藏SSID。
需要注意的是,信标帧中的SSID隐藏后,AP发送的信标帧里面不包含SSID信息,接入的无线客户端必须手动配置该SSID标识才能接入AP。
隐藏SSID对无线安全意义不大。允许广播SSID可以使无线客户端更容易发现AP。
# 配置在信标帧中隐藏SSID。
[Sysname-wlan-st-1] beacon ssid-hide
beacon-interval interval
undo beacon-interval
WLAN射频接口视图
【缺省级别】
2:系统级
interval:发送信标帧的时间间隔。取值范围为32~8191,单位TU(Time Unit,1TU=1024微秒)。
【描述】
beacon-interval命令用来设置AP发送Beacon帧(信标帧)的时间间隔。undo beacon-interval命令用来恢复缺省情况。
缺省情况下,发送Beacon帧的时间间隔为100TU。
# 设置发送信标帧的时间间隔为1000TU。
[Sysname-WLAN-Radio1/0/1] beacon-interval 1000
1.1.10  channel
channel { channel-number | auto }
undo channel
WLAN射频接口视图
【缺省级别】
2:系统级
channel-number:射频的工作信道。射频的工作信道由国家码和射频模式决定。当射频接口工作在802.11a、802.11ac和802.11an射频模式时,信道列表为36、40、44、48、52、56、60、64、149、153、157、161、165,当射频接口工作在802.11b、802.11g和802.11gn射频模式时,信道列表为1~13。
auto:自动选择信道模式,由设备根据实际环境自动选择最优信道。
【描述】
channel命令用来配置射频的工作信道。undo channel命令用来恢复缺省情况。
缺省情况下,使用自动选择信道模式,即auto模式。
配置channel channel-number命令表示一直使用固定信道,这种情况下,不需要配置channel lock命令。如果先配置了channel lock命令,再配置channel channel-number命令,后者的配置会覆盖前者。
相关配置可参考命令channel lock。
# 配置射频的工作信道为6。
[Sysname] interface wlan-radio 1/0/2
[Sysname-WLAN-Radio1/0/2] radio-type dot11b
[Sysname-WLAN-Radio1/0/2] channel 6
channel band-width { 20 | 40 | 80 }
undo channel band-width
WLAN射频接口视图
【缺省级别】
2:系统级
20:表示802.11n的工作带宽是20MHz。
40:表示802.11n的工作带宽是40MHz。
80:表示802.11ac的工作带宽是80MHz。
设备各款型对于本节所描述的参数的支持情况有所不同,详细差异信息如下:
产品系列
型号
参数
WA2600系列
WA2610H
80
不支持
WA4600系列
支持
WA4300系列
WA4320H-ACN
支持
支持
支持
WA4320X
支持
支持
WA4330-ACN
支持
LA4300系列
LA4320X
LA4310/LA4310V不支持,LA4320/LA4320V/LA4320X支持
小贝系列
支持
WAP712/WAP712C
支持
【描述】
channel band-width命令用来指定当前射频接口的带宽模式。undo channel band-width命令用来恢复缺省情况。
缺省情况下,802.11an类型的射频接口的带宽为40MHz,802.11gn类型的射频接口的带宽为20MHz,802.11ac类型的射频接口的带宽为80MHz。
·     该命令仅对802.11n和802.11ac类型的接口有效。在进行接口模式切换的时候,设备恢复在该模式下的缺省值。
·     在指定带宽为40MHz情况下,如果找到两条可以绑定到一起的信道,那么使用40MHz带宽;如果找不到可以绑定的信道,那么实际只能使用20MHz带宽。关于此部分的协议规范可参见“IEEE 802.11n-2009”。
# 配置当前射频接口的带宽模式为40MHz。
[sysname-WLAN-Radio1/0/1] radio-type dot11ac
[sysname-WLAN-Radio1/0/1] channel band-width 40
1.1.12  client
client { dot11n-only | dot11ac-only }
undo client { dot11n-only | dot11ac-only }
WLAN射频接口视图
【缺省级别】
2:系统级
dot11n-only:在5GHz射频接口下配置该参数表示射频允许802.11n或者802.11ac用户接入,在2.4GHz射频接口下配置该参数表示射频只允许802.11n用户接入。
dot11ac-only:表示射频只允许802.11ac用户接入。
产品系列
型号
参数
WA2600系列
WA2610H
dot11ac-only
不支持
WA4600系列
支持
WA4300系列
WA4320H-ACN
支持
支持
支持
WA4320X
支持
支持
WA4330-ACN
支持
LA4300系列
LA4320X
小贝系列
支持
WAP712/WAP712C
支持
【描述】
client命令用来配置仅允许802.11n或者802.11ac用户接入功能。undo client 命令用来恢复缺省情况。
缺省情况下,802.11an/ac类型的射频接口同时允许802.11a、802.11an和802.11ac用户接入;802.11gn类型的接口同时允许802.11b/g和802.11gn用户接入。
·     当执行client dot11n-only命令后,5G射频只有802.11n或者802.11ac的无线客户端才能接入AP,2.4G射频只有802.11n的无线客户端才能接入AP。如果用户需要兼容802.11a/b/g的无线客户端,同时还要接入802.11n或者802.11ac的无线客户端,则必须关闭client dot11n-only命令。
·     当执行client dot11ac-only命令后,只有802.11ac的无线客户端才能接入AP。如果用户需要兼容802.11a/n的无线客户端,同时还要接入802.11ac的无线客户端,则必须关闭client dot11ac-only命令。
相关配置可参考命令“WLAN命令参考/WLAN RRM”中的命令dot11n mandatory maximum-mcs和dot11ac mandatory maximum-nss。
# 配置仅允许802.11n或者802.11ac用户接入功能。
[sysname-WLAN-Radio1/0/1] radio-type dot11an
[sysname-WLAN-Radio1/0/1] client dot11n-only
# 配置仅允许802.11ac用户接入功能。
<Sysname>system-view
[sysname-WLAN-Radio1/0/1] radio 1 type dot11ac
[sysname-WLAN-Radio1/0/1] client dot11ac-only
client max-count max-number
undo client max-count
服务模板视图
【缺省级别】
2:系统级
max-number:在一个射频下,某个SSID下的关联无线客户端的最大个数,取值范围为1~124。
【描述】
client max-count命令用来指定在一个射频下,某个SSID下的关联无线客户端的最大个数。undo client max-count命令用来恢复缺省情况。
缺省情况下,最多可以关联64个无线客户端。
需要注意的是,当某个SSID下关联的无线客户端达到最大个数时,该SSID会自动隐藏。
# 配置名为“service”的SSID下可以关联的最大无线客户端的个数为10。
[Sysname-wlan-st-1] ssid service
[Sysname-wlan-st-1] client max-count 10
debugging wlan mac { all | error | event | frame [ acl acl-number | verbose ] | fsm [ acl acl-number ] | timer }
undo debugging wlan mac { all | error | event | frame | fsm | timer }
【缺省级别】
2:系统级
all:调试所有的wlan MAC信息。
error:调试所有的wlan MAC错误信息。
event:调试所有的wlan MAC事件信息。
frame:调试接受和发送的wlan MAC信息。
acl acl-number :指定帧的访问控制列表,取值范围4000~4999。
verbose:显示详细的wlan MAC调试信息。
fsm:调试协议FSM相关信息。
timer:调试时间信息。
【描述】
debugging wlan mac命令用于打开WLAN MAC的输出调试信息。undo debugging wlan mac命令用于取消指定的调试信息。
缺省情况下,WLAN MAC的调试信息关闭。
# 打开调试AC的错误信息开关。
<Sysname> debugging wlan mac error
display wlan client { interface wlan-radio [ radio-number ] | mac-address mac-address | service-template service-template-number } [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
wlan-radio radio-number:显示连接到指定射频接口的无线客户端信息。
mac-address mac-address:无线客户端的MAC地址。
service-template service-template-number:显示基于指定服务模板的无线客户端信息,取值范围为1~1024。
verbose:显示无线客户端的详细信息。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display wlan client命令用来查看指定无线客户端或者所有无线客户端的信息。
# 显示所有无线客户端的信息。
<Sysname> display wlan client
Total Number of Clients           : 3
                               Client Information
 SSID: office
 MAC Address   User Name            APID/RID IP Address                     VLAN
000f-e265-6400 -NA-                    1/1   1.1.1.1                        1
000f-e265-6401 user                 1024/1   3.0.0.3                        3
000f-e265-6402 [email protected]       103 /1   FE:11:12:03::11:25:13          1
表1-1 display wlan client命令显示信息描述表
SSID
无线客户端关联的SSID
MAC Address
无线客户端的MAC地址
User Name
无线客户端的认证用户名
如果无线客户端采用明文方式或无用户名的加密方式接入,该字段显示为-NA-
需要注意的是,该字段的显示情况和无线客户端是否采用Portal认证无关。也就是说,如果无线客户端采用Portal认证方式,User Name字段不会显示无线客户端的Portal用户名
APID/RID
无线客户端的关联AP的ID以及Radio的ID
IP Address
无线客户端的IP地址
VLAN
无线客户端所在的VLAN
# 显示所有无线客户端的详细信息。
<Sysname> display wlan client verbose
 Total Number of Clients           : 1
                              Client Information
 MAC Address                       : 60a4-4c82-c1ee
 User Name                         : -NA-
 IP Address                        : 50.30.1.3
 AID                               : 1
 Radio Interface                   : WLAN-Radio1/0/1
 Service Template Number           : 1
 SSID                              : office
 BSSID                             : 0023-8900-4320
 Port                              : WLAN-BSS32
 VLAN                              : 30
 State                             : Running
 Power Save Mode                   : Active
 Wireless Mode                     : 11ac
 Channel Band-width                : 20/40/80MHz
 SM Power Save Enable              : Disabled
 Short GI for 20MHz                : Supported
 Short GI for 40MHz                : Supported
 Short GI for 80MHz                : Supported
 Short GI for 160/80+80MHz         : Not Supported
 LDPC RX capability                : Not Supported
 STBC TX capability                : Supported
 STBC RX capability                : Supported For 1 Nss
 Support VHT-MCS and Nss Set       : 2,2,2,3,3,3,3,3
 BLOCK ACK-TID 0                   : IN
 QoS Mode                          : WMM
 Listen Interval (Beacon Interval) : 10
 RSSI                              : 54
 Rx/Tx Rate                        : 6/1300
 Client Type                       : PRE-RSNA
 Authentication Method             : Open System
 Authentication Mode               : Central
 AKM Method                        : None
 Key Derivation                    : -NA-
 4-Way Handshake State             : -NA-
 Group Key State                   : -NA-
 Encryption Cipher                 : Clear
 PMF Status                        : -NA-
 Roam Status                       : Normal
 Roam Count                        : 0
 Up Time (hh:mm:ss)                : 00:05:25
表1-2 display wlan client verbose命令显示信息描述表
MAC Address
无线客户端的MAC地址
User Name
无线客户端的认证用户名
AID
无线客户端的关联ID
Radio Interface
WLAN射频接口
SSID
无线客户端关联的SSID
BSSID
基本服务集标识
Port
与无线客户端关联的WLAN-BSS接口
VLAN
无线客户端所在的VLAN
无线客户端的状态,例如:Running
Power Save Mode
无线客户端节电模式的状态:
·     Active模式(激活)
·     Sleep模式(睡眠)
Wireless Mode
无线模式:802.11a、802.11b、802.11g、802.11gn、802.11an和802.11ac
Channel Band-width
带宽模式:
·     20MHz:工作带宽为20MHz
·     40MHz:工作带宽为40MHz
·     80MHz:工作带宽为80MHz
SM Power Save可以使无线客户端上只有一个天线处于工作状态,其余天线均处于休眠状态,从而达到节省电源的目的
·     Enabled:支持SM Power Save
·     Disabled:不支持SM Power Save
Short GI for 20MHz
无线客户端工作带宽为20MHz时,对于Short GI的支持情况:
·     Not Supported:无线客户端不支持Short GI
·     Supported:无线客户端支持Short GI
Short GI for 40MHz
无线客户端工作带宽为40MHz时,对于Short GI的支持情况:
Short GI for 80MHz
客户端工作带宽为80MHz时,对于Short GI的支持情况:
·     Not Supported:客户端不支持Short GI
·     Supported:客户端支持Short GI
客户端工作带宽为160/80+80MHz时,对于Short GI的支持情况:
LDPC
·     Not Supported:无线客户端不支持LDPC
·     Supported:无线客户端支持LDPC
STBC Tx Capability
·     Not Supported:不支持STBC发送能力
·     Supported:支持STBC发送能力
对于STBC发送能力的支持情况,AP和Client会进行协商。只有客户端和AP都支持STBC发送能力,才能协商成功
STBC Rx Capability
·     Not Supported:不支持STBC接收能力
·     Supported: 支持STBC接收能力
对于STBC接收能力的支持情况,AP和Client会进行协商。只有客户端和AP都支持STBC接收能力,才能协商成功
Support MCS Set
无线客户端支持MCS集
客户端支持的VHT-MCS和NSS集
BLOCK ACK-TID 0
按照QoS优先级ID 0协商BLOCK ACK:
·     OUT:下行方向
·     IN:上行方向
·     BOTH:上行方向和下行方向
QoS Mode
QoS模式:
·     None:不支持WMM协议
·     WMM:支持WMM协议
对于WMM的支持情况,AP和Client会进行协商。只有AP和无线客户端同时支持WMM时,才能协商成功
Listen Interval(Beacon Interval)
处于Sleep模式的无线客户端定期醒来接收缓存在AP中的数据帧的时间间隔,单位为Beacon interval(信标发送时间间隔)
RSSI
接收信号强度值,该值表明了AP检测到Client的信号强度
Rx/Tx Rate
无线客户端发送/接收报文的速率(包括数据、管理和控制报文)
Client Type
无线客户端类型,例如:RSN、WPA或PRE-RSN
认证方法,例如:开放系统或共享密钥
AKM Method
AKM套件,如Dot1X,PSK
Key Derivation
密钥衍生类型:
·     SHA1:采用HMAC-SHA1散列算法
·     SHA256:采用HMAC-SHA256散列算法
·     -NA-:表示客户端使用的认证类型不涉及密钥衍生算法
四次握手状态中的一种:
·     IDLE:初始化状态
·     PTKSTART:四次握手初始化完毕
·     PTKNEGOTIATING:发送第三个有效消息
·     PTKINITDONE:四次握手成功
Group Key State
组密钥状态,包括以下几种:
·     IDLE:初始化状态
·     REKEYNEGOTIATE:无线控制器向用户发送初始化消息
·     REKEYESTABLISHE:密钥更新成功
Encryption Cipher
加密密码:明文或者密文加密的类型
PMF Status
保护管理帧功能状态:
·     Active:支持保护管理帧功能
·     Inactive:不支持保护管理帧功能
·     -NA-:表示客户端使用的认证类型不涉及保护管理帧功能
Roam Status
漫游状态:正常或者快速漫游,FAT AP的漫游状态只能显示正常
Roam Count
无线客户端的漫游次数(FAT AP不支持)
Up Time
无线客户端和AP关联的时间
display wlan client [ mac-address mac-address ] beacon-report [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
mac-address mac-address:客户端的MAC地址。不指定该参数时,显示从所有客户端接收到的信标测量报告。
【描述】
display wlan client beacon-report命令用来显示从客户端接收到的信标测量报告。
# 显示从指定的客户端接收到的信标测量报告。
<Sysname>  display wlan client mac-address 000f-e265-6400 beacon-report
Report Information
MAC Address              : 000f-e265-6400
Total Number of Reports  : 4
----------------------------------------------------------------------------------------Channel         BSSID       Regulatory Class  Antenna ID      SSID
1           0026-3e08-1150        12             1            eagle
1           0026-3e08-1151        12             1            eagle
6           0026-3e08-1152        12             1            eagle
6           0026-3e08-1153        12             1            eagle
表1-3 display wlan client beacon-report命令显示信息描述表
MAC Address
回复信标测量报告的客户端MAC地址
信标测量报告的数量
Channel
信道号
BSSID
基本服务集标识
Regulatory Class
调整集,取值为12或5。关于该值的详细含义请参见802.11k协议
Antenna ID
天线ID
SSID
服务集标识符
display wlan client bridge [ interface wlan-radio [ radio-number ] ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface wlan-radio radio-number:显示连接到指定射频接口的无线客户端信息。
verbose:显示客户端的详细信息。
【描述】
display wlan client bridge命令用来查看无线网桥设备作为客户端连接AP的信息。
为了便于描述,此命令描述中提到的客户端指的是无线网桥设备作为客户端,目前只支持显示H3C的无线网桥设备作为客户端。
# 显示所有无线客户端的信息。
<Sysname> display wlan client bridge
                               Client Information
 SSID: dragon
5866-baf2-d7cd -NA-                 2   /2   192.168.1.48                   1
表1-4 display wlan client bridge命令显示信息描述表
SSID
无线客户端关联的SSID
MAC Address
无线客户端的MAC地址
User Name
无线客户端的认证用户名
APID/RID
IP Address
无线客户端的IP地址
VLAN
无线客户端所在的VLAN
# 显示所有无线客户端的详细信息。
<Sysname> display wlan client bridge verbose
                              Client Information
 MAC Address                       : 5866-baf2-d7cd
 User Name                         : -NA-
 IP Address                        : 192.168.1.48
 AID                               : 1
 AP Name                           : floor11
 Radio Id                          : 2
 SSID                              : dragon
 BSSID                             : 5866-ba21-2770
 Port                              : WLAN-DBSS1:0
 VLAN                              : 1
 State                             : Running
 Wireless Mode                     : 11gn
 Channel Band-width                : 20MHz
 Short GI for 40MHz                : Not Supported
 Support MCS Set                   : 0,1,2,3,4,5,6,7
 QoS Mode                          : WMM
 RSSI                              : 80
 Rx/Tx Rate                        : 52/0
 AKM Method                        : None
 Roam Count                        : 0
 Up Time (hh:mm:ss)                : 00:13:56
 Serial Number                     : 219801A0BHM125002207
 Device Information                : WB524
 Software Version                  : WB524V100R004
 Associated AP RSSI                : -NA-
 Associated AP SNR                 : -NA-
 Tx Power (dBm)                    : -NA-
 Rx Packets                        : 0
 Rx Bytes                          : 0
 Tx Packets                        : 0
 Tx Bytes                          : 0
 Tx Dropped Packets                : 0
 Command Execution Result          : -NA-
表1-5 display wlan client bridge verbose命令显示信息描述表
MAC Address
无线客户端的MAC地址
User Name
无线客户端的认证用户名
IP address
无线客户端的IP地址
AID
无线客户端的关联ID
AP Name
接入点名称
Radio Id
无线客户端关联的Radio口的编号
服务模板的序号
SSID
无线客户端关联的SSID
BSSID
基本服务集识别码
Port
与无线客户端关联的WLAN-DBSS接口
VLAN
无线客户端所在的VLAN
无线客户端的状态:
·     Running:表示该客户端通过主链路与AC相连
·     Running(Backup):表示该客户端通过备份链路与AC相连
Power Save Mode
无线客户端节电模式的状态:
·     Active模式(激活)
·     Sleep模式(睡眠)
Wireless Mode
无线模式:802.11a、802.11b、802.11g、802.11gn和802.11an
Channel Band-width
带宽模式:
·     20MHz:工作带宽为20MHz
·     40MHz:工作带宽为40MHz
Short GI for 20MHz
Short GI for 40MHz
STBC Tx Capability
STBC Rx Capability
Support MCS Set
无线客户端支持MCS集
BLOCK ACK-TID
按照QoS优先级ID值协商BLOCK ACK:
·     OUT:下行方向
·     IN:上行方向
·     BOTH:上行方向和下行方向
QoS Mode
QoS模式:
·     None:不支持WMM协议
·     WMM:支持WMM协议
RSSI
接收信号强度指示,该值表明了AP检测到Client的信号强度
Rx/Tx Rate
无线客户端发送/接收报文的速率(包括数据、管理和控制报文)。对于AC+Fit AP模式,由于接收/传输速率信息是按照一定的时间间隔周期性的从AP传送到AC,因此会有延时
Client Type
无线客户端类型,如:RSN、WPA或PRE-RSN
认证方法,如:开放系统或共享密钥
Authentication Mode
认证模式:
·     Central:AC集中式认证,表示由AC对客户端进行认证
·     Local:AP本地认证,表示由AP作为认证实体对客户端进行认证
AKM Method
AKM套件,如Dot1X,PSK
四次握手状态中的一种:
·     IDLE:初始化状态
Group Key State
组密钥状态,包括以下几种:
·     IDLE:初始化状态
Encryption Cipher
加密密码:明文或者密文加密的类型
Roam Status
漫游状态:目前支持Normal、Intra-AC roam association、Inter-AC roam association
Roam Count
无线客户端的漫游次数(包括AC内漫游、AC间漫游)
·     对于AC内漫游:无线客户端离开该AC后,字段计数会清零
·     对于AC间漫游:无线客户端离开该AC所在的漫游组后,字段计数会清零
Up Time
无线客户端和AP关联的时间
Serial Number
客户端的序列号
Device Information
客户端的设备型号
Software Version
客户端的软件版本
Associated AP RSSI
接收信号强度指示,该值表明了客户端检测到所关联的AP的信号强度
Associated AP SNR
客户端检测到所关联的AP的SNR
Tx Power (dBm)
客户端射频的发送功率
Rx Packets
客户端收到的总包数
Rx Bytes
客户端收到的总字节数
Tx Packets
客户端发送的总包数
Tx Byets
客户端发送的总字节数
Tx Dropped Packets
客户端发送的丢包数
客户端上报的命令执行结果
-NA-表示设备未收到客户端上报的命令执行结果。具体显示情况请参见无线网桥手册
display wlan service-template [ service-template-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
service-template-number:服务模板号,取值范围为1~1024。
【描述】
display wlan service-template命令用来查看指定的服务模板的信息。
如果未指定服务模板号,则显示所有服务模板的信息。
# 显示服务模板1的配置信息。
<Sysname> display wlan service-template 1
                           Service Template Parameters
 SSID                         : nsw-nsw
 Description                  : Not Configured
 Service Template Type        : Crypto
 Security IE                  : WPA2(RSN) WPA
 Beacon-measurement           : Enable
 Beacon-measurement Interval  : 30
 Beacon-measurement Type      : Passive
SSID-hide                    : Disabled
 Cipher Suite                 : TKIP AES-CCMP
 WEP Key Index  1             : WEP40
 WEP Key Mode                 : ASCII
 WEP Key                      : ******
 TKIP Countermeasure Time(s)  : 60
 PTK Life Time(s)             : 180
 GTK Rekey                    : Enabled
 GTK Rekey Method             : Packet-based
 GTK Rekey Packets            : 5000
PMF Status                   : Optional
 Service Template Status      : Enabled
 Maximum clients per BSS      : 35
表1-6  display wlan service-template命令各字段的含义描述
当前服务模板号
SSID
无线客户端关联的SSID
服务模板类型:Crypto、Clear
Security IE
安全IE:WPA或WPA2(RSN)
使用的认证类型:开放系统认证或者共享密钥认证
Authentication Mode
服务模板使用的认证模式:
·     Central:AC集中式认证
·     Local:AP本地认证
·     Backup:备份认证
Beacon-measurement
Enable:信标测量功能处于开启状态
信标测量请求的发送间隔,单位为秒
信标测量模式:
·     Passive:被动模式
·     Active:主动模式
·     Beacon-table:信标表模式
SSID-hide
·     Disable:启用SSID通告
·     Enable:禁用SSID通告
Cipher Suite
加密套件:AES-CCMP,TKIP,WEP40、WEP104或WEP128
WEP Key Index
加密或解密帧的密钥索引
WEP Key Mode
WEP密钥模式:
·     ASCII:WEP密钥为字符串的形式
·     HEX:WEP密钥为16进制数的形式
WEP Key
WEP密钥
TKIP反制策略中,MIC失败的计时器,单位为秒
PTK Life Time(s)
PTK生存时间,单位为秒
GTK Rekey
GTK密钥更新配置:
·     Disable:GTK密钥功能处于关闭状态
·     Enable:GTK密钥功能处于开启状态
GTK Rekey Method
已配置的GTK密钥更新方法:
·     Packet-based:采用基于数据包的方法更新GTK密钥
·     Time-based:采用基于时间的方法更新GTK密钥
GTK Rekey Time(s)
GTK密钥更新时间,单位为秒
PMF Status
保护管理帧功能的状态:
·     Disable:保护管理帧功能处于关闭状态
·     Optional:保护管理帧功能处于开启状态,支持或不支持保护管理帧功能的客户端均可接入
·     Mandatory:保护管理帧功能处于开启状态,且强制要求只有支持保护管理帧功能的客户端可以接入
服务模板状态:
·     Disable:服务模板处于关闭状态
·     Enable:服务模板处于开启状态
一个BSS中能够连接的最大无线客户端数
display wlan statistics client { all | mac-address mac-address } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
client:显示无线客户端的统计信息。
all:显示所有无线客户端的统计信息。
mac-address mac-address:指定无线客户端的MAC地址。
【描述】
display wlan statistics client命令用来查看指定无线客户端或所有无线客户端的统计信息。
# 显示所有无线客户端统计信息。
<Sysname> display wlan statistics client all
                                Client Statistics
 AP Name                           : sysname
 Radio Id                          : 1
 SSID                              : office
 BSSID                             : 000f-e2ff-7700
 MAC Address                       : 0014-6c8a-43ff
 RSSI                              : 31
 Transmitted Frames:
 Back Ground (Frames/Bytes)        : 0/0
 Best Effort (Frames/Bytes)        : 9/1230
 Video (Frames/Bytes)              : 0/0
 Voice (Frames/Bytes)              : 2/76
 Received Frames:
 Best Effort (Frames/Bytes)        : 18/2437
 Voice (Frames/Bytes)              : 7/468
 Discarded Frames:
 Best Effort (Frames/Bytes)        : 0/0
 Voice (Frames/Bytes)              : 5/389
表1-7 display wlan statistics client命令各字段的含义描述
AP Name
接入点名称
Radio Id
射频ID号
SSID
无线客户端关联的SSID
BSSID
基本服务集识别码
MAC Address
无线客户端的MAC地址
RSSI
接收信号强度指示,该值表明AP检测到Client的信号强度
Transmitted Frames
发送的帧的数目
Back Ground
以帧或字节为单位对背景流优先级队列进行统计
Best Effort
以帧或字节为单位对尽力而为流优先级队列进行统计
Video
以帧或字节为单位对视频流优先级队列进行统计
Voice
以帧或字节为单位对语音流优先级队列进行统计
Received Frames
收到的帧的数目
Discarded Frames
丢弃的帧的数目
Back Ground、Best Effort、Video及Voice优先级的统计仅针对QoS客户端。对于非QoS客户端的收发流量,统一统计为Best Effort类型,包括SVP报文,可能与实际物理发送队列不一致。上述优先级统计只能针对Dot11E或者WMM报文携带的用户优先级进行区分,否则会造成接收方向无法统计。
display wlan statistics service-template service-template-number [ connect-history ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
connect-history:显示配置了指定服务模板的AP的客户端连接历史信息。
【描述】
display wlan statistics service-template命令用来显示指定服务模板的统计信息。
display wlan statistics service-template service-template-number connect-history命令用来显示指定服务模板的所有AP的连接历史信息。
# 显示服务模板1的统计信息。
<Sysname> display wlan statistics service-template office
                        Service Template Statistics
Service Template           : office
AP Name                    : ap1
 Radio                      : 1
 Receive                    :
    Frame Count             : 1713
    Frame Bytes             : 487061
    Data Frame Count        : 1683
    Data Frame Bytes        : 485761
    Associate Frame Count   : 2
 Send                       :
    Frame Count             : 62113
    Frame Bytes             : 25142076
    Data Frame Count        : 55978
    Data Frame Bytes        : 22626600
表1-8 display wlan statistics service-template命令显示信息描述表
Service Template
服务模板编号
AP Name
AP名称
Receive
接收统计:
·     Frame Count:接收帧数
·     Frame Bytes:接收帧字节数
·     Data Frame Count:接收数据帧数
·     Data Frame Bytes:接收数据帧字节数
·     Associate Frame Count:接收连接请求帧数
Send
发送统计:
·     Frame Count:发送帧数
·     Frame Bytes:发送帧字节数
·     Data Frame Count:发送数据帧数
·     Data Frame Bytes:发送数据帧字节数
·     Associate Frame Count:发送连接请求帧数
# 显示绑定服务模板名为“office”的AP的客户端连接历史信息。
<Sysname> display wlan statistics service-template office connect-history
                            Connect History
 AP Name                    : ap1
 Radio                      : 1
 Associations               : 132
 Failures                   : 3
 Reassociations             : 30
 Rejections                 : 12
 Exceptional Deassociations : 2
 Current Associations       : 57
 AP Name                    : ap1
 Radio                      : 2
 Associations               : 1004
 Failures                   : 35
 Reassociations             : 59
 Rejections                 : 4
 Exceptional Deassociations : 22
 Current Associations       : 300
表1-9 display wlan statistics service-template connect-history命令显示信息描述表
Service Template
服务模板编号
AP Name
AP名称
Radio
射频编号
Associations
累计关联次数
Failures
累计关联失败次数
Reassociations
累计重关联次数
Rejections
累计拒绝客户端连接次数
累计异常重关联次数
当前关联次数
1.1.21  distance
distance distance
undo distance
WLAN射频接口视图
【缺省级别】
2:系统级
distance:射频可覆盖的最远距离,单位为公里。取值范围为1~40。
【描述】
distance命令用来配置射频可覆盖的最远距离。undo distance命令用来恢复缺省情况。
缺省情况下,射频可覆盖的最远距离为1公里。
# 配置射频可覆盖的最远距离为5公里。
[Sysname-WLAN-Radio1/0/1] distance 5
1.1.22  dtim
dtim counter
undo dtim
WLAN射频接口视图
【缺省级别】
2:系统级
counter:DTIM(Delivery Traffic Indication Message,数据待传指示信息)帧间的信标数,取值范围为1~31。例如,配置counter值为1,则每个信标帧中都会携带DTIM信息。
【描述】
dtim命令用来在AP发送缓存的多播帧或广播帧之前,为其设置信标帧的DTIM计数器。undo dtim命令用来恢复缺省情况。
缺省情况下,DTIM计数器为1。
当DTIM计数达到0时,AP才会发送缓存中的多播帧或广播帧。
# 配置DTIM计数器为10。
[Sysname-WLAN-Radio1/0/1] dtim 10
undo fast-association enable
服务模板视图
【缺省级别】
2:系统级
无。
【描述】
fast-association enable命令用来开启快速关联功能。undo fast-association enable命令用来关闭快速关联功能。
缺省情况下,快速关联功能处于关闭状态。
开启此功能后,设备不会对关联到此SSID的客户端进行频谱导航和负载均衡计算。
# 开启快速关联功能。
[Sysname-wlan-st-1] fast-association enable
fragment-threshold size
undo fragment-threshold
WLAN射频接口视图
【缺省级别】
2:系统级
【描述】
fragment-threshold命令用来配置帧的分片门限值,即数据包无分片传输的最大包长。undo fragment-threshold命令用来恢复缺省情况。
缺省情况下,帧的分片门限值为2346字节,即小于2346字节的帧在传输时不分片。
当数据包的实际大小超过指定的分片门限值时,该数据包被分片传输。
# 配置帧的分片门限值为2048字节。
[Sysname-WLAN-Radio1/0/1] fragment-threshold 2048
undo green-energy-management enable
WLAN射频接口视图
【缺省级别】
2:系统级
无
【描述】
green-energy-management enable命令用来开启绿色自动节能功能(在没有用户与radio关联时,设置radio工作在1x1模式,以减少辐射,节省电量)。undo green-energy-management enable命令用来关闭绿色自动节能功能。
缺省情况下,绿色自动节能功能处于关闭状态。
# 开启绿色自动节能功能。
[sysname-WLAN-Radio1/0/1] green-energy-management enable
long-retry threshold count
undo long-retry threshold
WLAN射频接口视图
【缺省级别】
2:系统级
count:帧长超过RTS(Request to Send,发送请求)门限值的帧的最大重传次数,取值范围为1~15。
【描述】
long-retry threshold命令用来设置帧长超过RTS门限值的帧的最大重传次数。undo long-retry threshold命令用来恢复缺省情况。
缺省情况下,帧长超过RTS门限值的帧的最大重传次数为4。
# 配置帧长超过RTS门限值的帧的最大重传次数为10。
[Sysname-WLAN-Radio1/0/1] long-retry threshold 10
1.1.27  max-power
max-power radio-power
undo max-power
WLAN射频接口视图
【缺省级别】
2:系统级
radio-power:射频的最大传输功率,其取值范围由国家码和射频模式决定。
【描述】
max-power命令用来配置射频的最大传输功率。undo max-power命令用来恢复缺省情况。
缺省情况下,射频的最大功率和国家码、信道、AP型号、射频模式和天线类型相关,如果采用802.11n或者802.11ac射频模式,那么射频的最大功率和带宽模式也相关。实际部署应用中,请根据法规要求、选择天线的增益值配置AP射频的最大传输功率。
相关配置可参考命令wlan country-code和radio type。
# 配置射频的最大传输功率为5。
[Sysname-WLAN-Radio1/0/1] radio-type dot11a
[Sysname-WLAN-Radio1/0/1] max-power 5
max-rx-duration interval
undo max-rx-duration
WLAN射频接口视图
【缺省级别】
2:系统级
interval:AP接收到的帧可以在缓存区保存的最大时间,取值范围为500~250000,单位为毫秒。
【描述】
max-rx-duration命令用来配置AP接收的帧可以在缓存中保存的最长时间。undo max-rx-duration命令用来恢复缺省情况。
缺省情况下,AP接收的帧可以在缓存中保存的最长时间为2000毫秒。
# 配置AP接收的帧可以在缓存中保存的最长时间为5000毫秒。
[Sysname-WLAN-Radio1/0/1] max-rx-duration 5000
1.1.29  mimo
mimo { 1x1 | 2x2 | 3x3 }
undo mimo
WLAN射频接口视图
【缺省级别】
2:系统级
无
【描述】
mimo命令用来配置射频的MIMO模式。undo mimo 命令用来恢复缺省情况。
缺省情况下,不配置射频的MIMO模式。
需要注意的是,AP支持配置的NxN MIMO模式与设备支持的流数相关,如果AP只支持1x1模式,则MIMO模式只能配置成1x1的,如果AP支持2x2的,则对应的MIMO模式可以配置成1x1和2x2的。
设备各款型对于本节所描述的特性支持情况有所不同,详细差异信息如下:
产品系列
型号
WA2600系列
WA2610H
不支持3x3参数
WA4600系列
支持
WA4300系列
WA4320H-ACN
不支持3x3参数
不支持3x3参数
不支持3x3参数
WA4320X
不支持3x3参数
不支持3x3参数
WA4330-ACN
不支持3x3参数
LA4300系列
LA4320X
不支持3x3参数
小贝系列
不支持3x3参数
WAP712/WAP712C
不支持3x3参数
# 配置radio的MIMO模式为1x1。
[sysname-WLAN-Radio1/0/1] mimo 1x1
power-off timeout minutes
undo power-off timeout
【缺省级别】
2:系统级
minutes:指定超时时间,取值范围为1~255,单位为分钟。
【描述】
power-off timeout minutes命令用来设置设备关机的超时时间,达到超时时间后,设备就会关机。undo power-off timeout命令用来恢复缺省情况。
缺省情况下,设备关机的超时时间为10分钟。
通过此命令配置设备关机的超时时间,当设备断电后,在超时时间内,确保设备能够正常工作。
产品系列
型号
WA2600系列
WA2610H
不支持
WA4600系列
不支持
WA4300系列
WA4320H-ACN
不支持
不支持
不支持
WA4320X
不支持
不支持
WA4330-ACN
不支持
LA4300系列
LA4320X
LA4310/LA4320/
LA4320X不支持
LA4310V/LA4320V支持
小贝系列
不支持
WAP712/WAP712C
不支持
# 设置设备关机的超时时间为1分钟。
[Sysname] power-off timeout 1
1.1.31  preamble
preamble { long | short }
undo preamble
WLAN射频接口视图
【缺省级别】
2:系统级
long:指定只传输有long前导码的帧。
short:指定传输有short或long前导码的帧。
【描述】
preamble命令用来配置AP支持的前导码类型。undo preamble命令用来恢复缺省情况。
缺省情况下,支持short前导码。
前导码是位于数据包起始处的一组bit位,接收者可以据此同步并准备接收实际的数据。前导码有两种:long和short。
802.11a、802.11an和802.11ac不支持此项配置。
# 配置AP支持long前导码。
[Sysname-WLAN-Radio1/0/1] radio-type dot11b
[Sysname-WLAN-Radio1/0/1] preamble long
protection-mode { cts-to-self | rts-cts }
undo protection-mode
WLAN射频接口视图
【缺省级别】
2:系统级
cts-to-self:CTS-to-Self方式。
rts-cts:RTS/CTS方式。
【描述】
protection-mode命令用来配置冲突避免的方式。undo protection-mode命令用来恢复缺省情况。
缺省情况下,使用CTS-to-Self方式。
和RTS/CTS相比,CTS-To-Self机制减少了控制报文的数量。但在某些情况下可能会出现因为隐藏节点收不到AP发送的CTS报文而仍然产生冲突的情况。因此,RTS-CTS机制比CTS-To-Self机制的保护范围要大。
关于CTS-to-Self方式和RTS/CTS方式的介绍请参见“WLAN配置指导”的“WLAN RRM”。
# 配置冲突避免方式为RTS/CTS。
[Sysname-WLAN-Radio1/0/1] protection-mode rts-cts
1.1.33  radio-type
radio-type { dot11a | dot11an | dot11ac | dot11b | dot11g | dot11gn }
undo radio-type
WLAN射频接口视图
dot11a:指定无线射频类型为802.11a。
dot11an:指定无线射频类型为802.11an。
dot11ac:指定无线射频类型为802.11ac。
dot11b:指定无线射频类型为802.11b。
dot11g:指定无线射频类型为802.11g。
dot11gn:指定无线射频类型为2.4GHz的802.11gn。
产品系列
型号
参数
WA2600系列
WA2610H
dot11a、dot11an、dot11ac
不支持
WA4600系列
支持
WA4300系列
WA4320H-ACN
支持
支持
支持
WA4320X
支持
支持
WA4330-ACN
支持
LA4300系列
LA4320X
小贝系列
支持
WAP712/WAP712C
支持
【描述】
radio-type命令用来配置射频使用的射频类型。undo radio-type命令用来恢复缺省情况。
射频类型的缺省值取决于AP连接天线的型号。根据不同类型的AP,WLAN支持自定义缺省的射频类型。
# 配置接口WLAN-Radio 1/0/1的射频类型为802.11an。
[Sysname-WLAN-Radio1/0/1] radio-type dot11an
reset wlan statistics client { all | mac-address mac-address }
【缺省级别】
2:系统级
all:重置所有无线客户端的统计信息。
ap-name:AP的名称,为1~32个字符的字符串,不区分大小写。
【描述】
reset wlan statistics命令用来清除指定AP、指定无线客户端或全部无线客户端的统计信息。
# 清除所有无线客户端的统计信息。
<Sysname> reset wlan statistics client all
reset wlan client { all | mac-address mac-address }
【缺省级别】
2:系统级
all:断开所有无线客户端同AP的连接。
mac-address mac-address:设置将要被断开连接的无线客户端的MAC地址。
【描述】
reset wlan client命令用来断开所有或指定的无线客户端同AP的连接。
执行这条命令后,AP将向无线客户端发送解除认证帧,同时停止对无线客户端提供WLAN业务。
# 断开MAC地址为 000f-e2cc-8501的无线客户端同AP的连接。
<Sysname> reset wlan client mac-address 000f-e2cc-8501
rts-threshold size
undo rts-threshold
WLAN射频接口视图
【缺省级别】
2:系统级
【描述】
rts-threshold命令用来设置启用RTS机制所要求的帧的长度门限值。undo rts-threshold命令用来恢复缺省情况。
缺省情况下,启用RTS机制所要求的帧长度门限值为2346字节。
当帧的实际长度大于设定的门限值时,则系统启用RTS机制。
RTS(Request To Send,要求发送)用于在无线局域网中避免数据发送冲突。RTS包的发送频率需要合理设置,设置RTS门限时需要进行权衡:
如果将这个参数值设得较小,则会增加RTS包的发送频率,消耗更多的带宽。但RTS包发送得越频繁,系统从中断或冲突中恢复得就越快。
# 设置启用RTS机制所要求的帧的最小长度为2046字节。
[Sysname-WLAN-Radio1/0/1] rts-threshold 2046
service-template service-template-number interface wlan-bss wlan-bss-number
undo service-template service-template-number
WLAN射频接口视图
【缺省级别】
2:系统级
service-template-number:设置服务模板号,取值范围为1~1024。
wlan-bss-number:设置WLAN BSS接口号。取值范围为0~255。
【描述】
service-template命令用来将服务模板绑定到指定射频。undo service-template命令用来解除映射。
缺省情况下,服务模板和射频没有映射关系。
# 将服务模板1映射到射频WLAN BSS 1接口。
[Sysname-WLAN-Radio1/0/1] service-template 1 interface WLAN-BSS 1
service-template { disable | enable }
服务模板视图
【缺省级别】
2:系统级
disable:关闭服务模板。
enable:开启服务模板。
【描述】
service-template enable命令用来开启服务模板。service-template disable命令用来关闭服务模板。
缺省情况下,服务模板处于关闭状态。
# 开启服务模板1。
[Sysname-wlan-st-1] ssid clear
[Sysname-wlan-st-1] authentication-method open-system
[Sysname-wlan-st-1] service-template enable
short-gi enable
undo short-gi enable
WLAN射频接口视图
【缺省级别】
2:系统级
无
【描述】
short-gi enable用来开启Short GI功能。undo short-gi enable关闭Short GI功能。
缺省情况下,Short GI功能处于开启状态。
需要注意的是,该命令仅在支持802.11n的接口上存在。在进行接口模式切换的时候,设备会恢复该模式下该功能的缺省情况。
无线信号在空间传输时会因多径等因素在接收侧形成时延,如果后面的数据块发送过快,会对前一个数据块形成干扰,Short GI(Guard Interval,保护间隔)可以用来规避这种干扰。
802.11a/g的GI时长为800ns,802.11n可以配置使用Short GI,Short GI时长为400ns。在使用Short GI的情况下,可提高10%的无线吞吐量。
# 关闭Short GI特性。
[sysname-WLAN-Radio1/0/1] undo short-gi enable
short-retry threshold count
undo short-retry threshold
WLAN射频接口视图
【缺省级别】
2:系统级
count:设置AP在未收到确认的情况下,帧长不大于RTS门限值的单播帧的最大重传次数,取值范围为1~15。
【描述】
short-retry threshold命令用来设置帧长不大于RTS门限值的单播帧的最大重传次数。undo short-retry threshold命令用来恢复为缺省情况。
缺省情况下,帧长不大于RTS门限值的单播帧的最大重传次数为7。
# 设置帧长不大于RTS门限值的单播帧的最大重传次数为10。
[Sysname-WLAN-Radio1/0/1] short-retry threshold 10
shut-all-led enable
undo shut-all-led enable
【缺省级别】
2:系统级
无
【描述】
shut-all-led enable命令用来关闭当前AP设备的所有指示灯。undo shut-all-led enable命令用来恢复缺省情况。
缺省情况下,当前AP设备的所有指示灯是按照设备正常工作状态亮灯的。
# 配置关闭当前AP设备的所有指示灯。
[Sysname] shut-all-led enable
1.1.42  ssid
ssid ssid-name
undo ssid
服务模板视图
【缺省级别】
2:系统级
ssid-name:设置SSID的名称。为1~32个字符的字符串,区分大小写。
【描述】
ssid命令用来设置当前服务模板的SSID。undo ssid命令用来删除当前服务模板的SSID。
缺省情况下,没有设置SSID。
SSID的名称应该尽量具有唯一性。从安全方面考虑不应该体现公司名称,也不推荐使用长随机数序列做为SSID,因为长随机数序列只是增加了头域负载,对无线安全没有改进。
# 设置服务模板1的SSID为firstfloor。
[Sysname-wlan-st-1] ssid firstfloor
1.1.43  stbc enable
stbc enable
undo stbc enable
WLAN射频接口视图
【缺省级别】
2:系统级
无
【描述】
stbc enable命令用来开启STBC。undo stbc enable命令用来关闭STBC。
缺省情况下,STBC处于开启状态。
开启STBC后,可以提高接收端的SNR,增强数据传输的可靠性。
当AP上存在的天线 > Radio使用速率对应的空间流时,STBC才能生效,例如设置MCS索引值为8,该索引值对应的空间流数量为2,那么AP上至少有3个天线,配置的STBC才能起作用。
# 开启STBC。
[Sysname-WLAN-Radio1/0/1] stbc enable
undo wlan broadcast-probe reply
【缺省级别】
2:系统级
无
【描述】
wlan broadcast-probe reply命令用来配置AP回复无线客户端发送的SSID为空的探测请求。undo wlan broadcast-probe reply命令用来取消已有配置,即AP只对携带指定SSID的探测请求进行回复。
缺省情况下,AP会回复无线客户端发送的SSID为空的探测请求。
# 配置AP回复无线客户端发送的SSID为空的探测请求。
[Sysname] wlan broadcast-probe reply
wlan client idle-timeout interval
undo wlan client idle-timeout
【缺省级别】
2:系统级
interval:指定AP和无线客户端(节电状态或清醒状态)之间连接允许的最大空闲时间,取值范围为60~86400,单位为秒。
【描述】
wlan client idle-timeout命令用来配置无线客户端的空闲超时时间间隔,即AP和无线客户端之间的连接允许的最大空闲时间。undo wlan client idle-timeout命令用来恢复缺省情况。
缺省情况下,无线客户端的空闲超时时间间隔为3600秒。
如果无线客户端的空闲时间超过了指定时间,即AP在指定的时间内没有收到从该无线客户端发来的数据,那么该无线客户端将被从无线网络中删除。
# 配置无线客户端空闲超时时间间隔为600秒。
[Sysname] wlan client idle-timeout 600
wlan client keep-alive interval
undo wlan client keep-alive
【缺省级别】
2:系统级
interval:保活请求的时间间隔,取值范围为3~1800,单位为秒。
【描述】
wlan client keep-alive命令用来配置无线客户端的保活时间间隔。undo wlan client keep-alive命令用来恢复缺省情况。
缺省情况下,无线客户端的保活功能处于关闭状态。
保活功能通常用来检测无线客户端是否从系统中被隔离出来,并断开无线客户端同AP的连接,导致无线客户端被隔离的原因有电源故障、系统崩溃。
# 设置无线客户端的保活时间间隔为60秒。
[Sysname] wlan client keep-alive 60
wlan country-code code
undo wlan country-code
【缺省级别】
2:系统级
code:国家码。国家码和国家名的对应关系请参见表1-10。
表1-10 国家码对应的国家名
国家名
国家码
国家名
国家码
安道尔
AD
肯尼亚
KE
阿拉伯联合酋长国
AE
科威特
KW
阿尔巴尼亚
AL
哈萨克斯坦
KZ
亚美尼亚
AM
黎巴嫩
LB
澳大利亚
AU
列支郭士登
LI
阿根廷
AR
斯里兰卡
LK
奥地利
AT
立陶宛
LT
阿塞拜疆
AZ
卢森堡
LU
波斯尼亚和黑塞哥维那
BA
拉脱维亚
LV
比利时
BE
利比亚
LY
保加利亚
BG
摩洛哥
MA
巴林
BH
摩纳哥
MC
文莱
BN
摩尔多瓦
MD
玻利维亚
BO
马其顿王国
MK
巴西
BR
中国澳门
MO
巴哈马群岛
BS
马提尼克岛
MQ
白俄罗斯
BY
马耳他
MT
伯利兹
BZ
毛里求斯
MU
加拿大
CA
墨西哥
MX
瑞士
CH
马来群岛
MY
科特迪瓦
CI
纳米比亚
NA
智利
CL
尼日利亚
NG
中国
CN
尼加拉瓜
NI
哥伦比亚
CO
荷兰
NL
哥斯达黎加
CR
挪威
NO
塞尔维亚
RS
新西兰
NZ
塞浦路斯
CY
阿曼
OM
捷克斯洛伐克
CZ
巴拿马
PA
德国
DE
秘鲁
PE
丹麦
DK
波兰
PL
多米尼亚共和国
DO
菲律宾
PH
阿尔及利亚
DZ
巴基斯坦
PK
厄瓜多尔
EC
波多黎各
PR
爱沙尼亚
EE
葡萄牙
PT
埃及
EG
巴拉圭
PY
西班牙
ES
卡塔尔
QA
法罗群岛
FO
罗马尼亚
RO
芬兰
FI
俄罗斯
RU
法国
FR
沙特阿拉伯
SA
英国
GB
瑞典
SE
格鲁吉亚
GE
新加坡
SG
直布罗陀
GI
斯洛文尼亚
SI
格陵兰
GL
斯洛伐克
SK
瓜德罗普岛
GP
圣马力诺
SM
希腊
GR
萨尔瓦多
SV
危地马拉
GT
叙利亚共和国
SY
圭亚那
GY
泰国
TH
洪都拉斯
HN
突尼斯
TN
中国香港
HK
土耳其
TR
克罗地亚
HR
特立尼达和多巴哥
TT
匈牙利
HU
中国台湾
TW
冰岛
IS
乌克兰
UA
印度
IN
美国
US
印度尼西亚
ID
乌拉圭
UY
爱尔兰
IE
乌兹别克斯坦
UZ
以色列
IL
梵蒂网
VA
伊拉克
IQ
委内瑞拉
VE
意大利
IT
处女岛
VI
伊朗
IR
越南
VN
牙买加
JM
也门
YE
约旦
JO
南非
ZA
日本
JP
津巴布韦
ZW
朝鲜
KP
韩国
KR
【描述】
wlan country-code命令用来配置全局国家码。undo wlan country-code命令用来恢复缺省情况。
缺省情况下,全局国家码为CN。
在配置WLAN设备时,必须正确地设置国家或地区码,以确保不违反当地的管制规定。
# 配置全局国家码为美国。
[Sysname] wlan country-code us
wlan link-test mac-address
【缺省级别】
1:监控级
mac-address:要进行链路测试的无线客户端的MAC地址,仅允许测试已关联的无线客户端。
【描述】
wlan link-test命令用来对无线客户端进行RFPing操作。
# 对MAC地址为000f-e201-0101的无线客户端进行RFPing操作。
<Sysname> wlan link-test 000f-e201-0101
Testing link to 000f-e201-0101, press CTRL_C to break......
                                  Link Status
 RTT: Round trip time
 MAC Address: 000f-e201-0101
 VHT-MCS Rate(Mbps)  TxCnt   RxCnt   RSSI    Retries     RTT(ms)
NSS = 1
 0      29.3        5       5       68      0           3
 1      58.5        5       5       69      0           0
 2      97.5        5       4       70      2           0
 3      117         5       4       71      2           0
 4      175.5       5       5       70      0           0
 5      234         5       5       69      0           0
 6      263.3       5       5       69      0           0
 7      292.5       5       5       69      0           0
 8      351         5       5       69      0           0
 9      390         5       5       69      0           0
 NSS = 2
 0      58.5        5       5       69      0           0
 1      117         5       4       70      2           0
 2      175.5       5       5       70      0           0
 3      234         5       5       70      0           0
 4      351         5       5       69      0           0
 5      520         5       4       70      2           0
 6      526.5       5       4       69      2           0
 7      585         5       5       69      0           0
 8      702         5       5       70      0           0
 9      780         5       5       69      0           0
 NSS = 3
 0      87.8        5       5       70      0           0
 1      175.5       5       5       70      0           0
 2      263.3       5       5       70      0           0
 3      351         5       5       70      0           0
 4      526.5       5       4       69      2           0
 5      702         5       4       69      6           0
 6      NA          5       0       0       0           0
 7      975         5       0       0       10          0
 8      1170        5       0       0       10          0
 9      1300        5       0       0       10          0
表1-11 RFPing操作结果
No./MCS
·     对802.11ac客户端进行RFPing操作后,链路测试结果中会显示VHT-MCS字段,表示802.11ac客户端的VHT-MCS索引值
·     对非802.11ac和非802.11n客户端进行RFPing操作后,链路测试结果中会显示No.字段,表示非802.11ac和非802.11n客户端的速率编号
·     对802.11n客户端进行RFPing操作后,链路测试结果中会显示MCS字段,表示802.11n客户端的MCS索引值
Rate(Mbps)
Radio接口发送无线Ping包的速率
TxCnt
Radio接口发送无线Ping包的个数
RxCnt
Radio接口收到客户端回应无线Ping包的个数
RSSI
接收信号强度指示,该值表明了AP检测到客户端的信号强度
Retries
Radio接口发送无线Ping包失败时的重传总次数
RTT(ms)
从Radio接口发出无线Ping包到收到客户端回应的平均往返时间
NSS
对802.11ac客户端进行RFPing操作后,链路测试结果中会显示NSS字段,表示802.11ac客户端支持的空间流数
wlan service-template service-template-number { clear | crypto }
undo wlan service-template service-template-number
【缺省级别】
2:系统级
service-template-number:配置服务模板号。取值范围为1~1024。
clear:配置当前服务模板类型为明文方式,即无线客户端与AP关联后使用明文方式发送数据。
crypto:配置当前服务模板类型为密文方式,即无线客户端与AP关联后使用密文方式发送数据。
【描述】
wlan service-template命令用来创建服务模板并进入服务模板视图。如果输入的服务模板已经存在,则直接进入该视图。undo wlan service-template命令用来删除一个服务模板并清除相关的配置。如果指定的服务模板映射到射频,则在解除映射之前不能删除此服务模板。
本命令的缺省情况与设备的型号有关,请以设备的实际情况为准。
需要注意的是,不能修改已创建的服务模板的类型,只能先删除该服务模板,再重新创建。
# 创建一个新的服务模板,服务模板号为1。
[Sysname] wlan service-template 1 crypto
[Sysname-wlan-st-1]
undo wlan-client-isolation enable
【缺省级别】
2:系统级
无
【描述】
wlan-client-isolation enable命令用来使能无线用户隔离功能。undo wlan-client-isolation enable命令用来关闭无线用户隔离功能功能。
# 关闭无线用户隔离功能。
[Sysname] undo wlan-client-isolation enable
wlan uplink-interface interface-type interface-number
undo wlan uplink-interface interface-type interface-number
【缺省级别】
2:系统级
interface-type interface-number:指定接口类型为上行接口。
【描述】
wlan uplink-interface命令用来指定接口类型为上行接口。undo wlan uplink-interface用来取消已有配置。
缺省情况下,没有配置上行接口。
·     如果上行链路都处于down状态,设备将不能提供WLAN服务。WLAN服务正常运行要求至少有一个上行链路处于up状态。
·     可以将以太网接口或者WLAN-Radio接口配置为上行接口。其中WLAN-Radio接口配置为上行接口时,需要和相应的Mesh Profile绑定。
·     可以同时配置多个上行接口。
# 配置以太网接口GigabitEthernet 1/0/1为上行接口。
[Sysname] wlan uplink-interface GigabitEthernet 1/0/1
设备各款型对于本特性的支持情况有所不同,详细差异信息如下:
产品系列
型号
特性
WA2600系列
WA2610H
Workgroup Bridge配置
不支持
WA4600系列
支持
WA4300系列
WA4320H-ACN
支持
支持
支持
WA4320X
支持
支持
WA4330-ACN
支持
LA4300系列
LA4320X
不支持
小贝系列
支持
WAP712/WAP712C
支持
client-mode authentication-method { open-system | shared-key | wpa2-psk }
undo client-mode authentication-method
WLAN射频接口视图
【缺省级别】
2:系统级
open-system:使用开放式认证。
shared-key:使用共享密钥认证。
wpa2-psk:使用WPA2-PSK认证。
【描述】
client-mode authentication-method命令用来配置Client模式的认证方式。undo client-mode authentication-method命令用来恢复缺省情况。
缺省情况下,Client模式的认证方式为open-system。
# 配置Client模式的认证模式为shared-key。
[Sysname-WLAN-Radio1/0/1] client-mode authentication-method shared-key
client-mode cipher-suite { ccmp | tkip | { wep40 | wep104 | wep128 } [ key-id key-id ] } key [ cipher | simple ] key
undo client-mode cipher-suite
WLAN射频接口视图
【缺省级别】
2:系统级
ccmp:使用CCMP加密套件。
tkip:使用TKIP加密套件。
wep40:使用WEP40加密套件。
wep104:使用WEP104加密套件。
wep128:使用WEP128加密套件。
key-id key-id:密钥ID。在WEP中有四个静态的密钥。其密钥索引分别是1、2、3和4。指定的密钥索引所对应的密钥将被用来进行帧的加密和解密。
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥。
key:设置明文密钥或密文密钥,区分大小写。明文密钥的长度范围是8~63或者长度为64位的十六进制数。wep40、wep104、wep128的密文密钥长度为24~88,ccmp、tkip的密文密钥为24~117。在不指定simple或cipher的情况下,表示以明文方式输入密钥。
【描述】
client-mode cipher-suite命令用来配置Client模式的加密套件和预共享密钥。undo client-mode cipher-suite命令用来恢复缺省情况。
缺省情况下,没有配置Client模式的加密套件和预共享密钥。
以明文或密文方式设置的密钥,均以密文的方式保存在配置文件中。
# 配置Client模式的加密套件和预共享密钥。
[Sysname-WLAN-Radio1/0/1] client-mode cipher-suite wep40 key simple abcas
client-mode connect
WLAN射频接口视图
【缺省级别】
2:系统级
无
【描述】
client-mode connect命令用来发起Client模式的AP与无线服务的连接。
# 发起Client模式的AP与无线服务的连接。
[Sysname-WLAN-Radio1/0/1] client-mode connect
WLAN射频接口视图
【缺省级别】
2:系统级
无
【描述】
client-mode disconnect命令用来断开Client模式的AP与无线服务的连接。
# 断开Client模式的AP与无线服务的连接。
[Sysname-WLAN-Radio1/0/1] client-mode disconnect
client-mode interface wlan-bss bss-id
undo client-mode interface wlan-bss
WLAN射频接口视图
【缺省级别】
2:系统级
bss-id:WLAN-BSS接口编号。
【描述】
client-mode interface wlan-bss命令用来开启Client模式(即Workgroup Bridge模式),并将WLAN-BSS绑定到指定的Radio接口。undo client-mode interface wlan-bss命令用来关闭射频接口的Client模式,并取消绑定关系。
缺省情况下,Client模式处于关闭状态。
需要注意的是,Client模式开启后,其它与Client模式有关的配置才允许下发。Client模式关闭后,所有与Client模式有关的配置都被自动删除。
# 开启Client模式,将WLAN-BSS 1绑定到指定的Radio接口。
[Sysname] interface wlan-bss 1
[Sysname-WLAN-BSS1] quit
[Sysname-WLAN-Radio1/0/1] client-mode interface wlan-bss 1
client-mode roam { quick [ scan-interval scan-interval ] [ calibration-interval calibration-interval ] | slow }
undo client-mode roam
WLAN射频接口视图
【缺省级别】
2:系统级
quick:使用快速漫游模式。
slow:使用慢速漫游模式。
scan-interval scan-interval:快速漫游模式下,进行一轮信道扫描的时间间隔,取值范围为1~10,缺省值为2,单位为秒。
calibration-interval:配置快速漫游的时间间隔,取值范围为1~10,缺省值为1,单位为秒。
【描述】
client-mode roam命令用来配置开启Client模式AP的漫游功能并配置漫游模式。undo client-mode roam命令用来恢复缺省情况。
缺省情况下,Client模式AP的漫游功能处于关闭状态。
仅在Client模式处于开启状态下,才支持配置该命令。关闭Client模式,该配置将被自动删除。
# 配置Client模式AP的漫游模式为快速漫游。
[Sysname-WLAN-Radio1/0/1] client-mode roam quick
client-mode roam active-scan-time interval
undo client-mode roam active-scan-time
WLAN射频接口视图
【缺省级别】
2:系统级
interval:Client模式AP主动扫描一个信道的时间间隔,取值范围为10~1000,单位为毫秒。
【描述】
client-mode roam active-scan-time命令用来配置Client模式AP主动扫描一个信道的时间间隔。undo client-mode roam active-scan-time命令用来恢复缺省情况。
缺省情况下,Client模式AP主动扫描一个信道的时间间隔为50毫秒。
# 配置Client模式AP主动扫描一个信道的时间间隔为20毫秒。
[Sysname-WLAN-Radio1/0/1] client-mode roam active-scan-interval 20
client-mode roam rssi-threshold rssi-value [ gap gap-value ]
undo client-mode roam rssi-threshold
WLAN射频接口视图
【缺省级别】
2:系统级
rssi-value:漫游RSSI门限值,取值范围为10~50。
gap-value:漫游RSSI差值门限值,取值范围为1~50。
【描述】
client-mode roam rssi-threshold命令用来配置Client模式AP的漫游RSSI门限和差值门限。undo client-mode roam rssi-threshold命令用来恢复缺省情况。
缺省情况下,漫游RSSI门限和差值门限为20。
快速漫游模式下,只要其他无线服务的RSSI比当前连接的无线服务RSSI高出的数值超过漫游RSSI差值门限,就会发生漫游,并且选择RSSI值最大的无线服务进行连接;慢速漫游模式下,只有当前所连接的无线服务的RSSI值小于漫游RSSI门限,并且其他无线服务的RSSI比当前连接的无线服务RSSI高出的数值超过漫游RSSI差值门限,才会发生漫游,并且选择RSSI值最大的无线服务进行连接。
# 配置AP上工作在Client模式的Radio接口的漫游RSSI门限值为10,RSSI差值门限值为2。
[Sysname-WLAN-Radio1/0/1] client-mode roam rssi-threshold 10 gap 2
client-mode keep-alive interval
undo client-mode keep-alive
WLAN射频接口视图
【缺省级别】
2:系统级
interval:配置Client模式AP发送保活报文的时间间隔,取值范围为100~10000,单位为毫秒。
【描述】
client-mode keep-alive命令用来配置Client模式AP发送保活报文的时间间隔。undo client-mode keep-alive命令用来恢复缺省情况。
缺省情况下,Client模式AP发送保活报文的时间间隔为1000毫秒。
# 配置Client模式AP发送保活报文的时间间隔为500毫秒。
[Sysname-WLAN-Radio1/0/1] client-mode keep-alive 20
client-mode ssid ssid
undo client-mode ssid
WLAN射频接口视图
【缺省级别】
2:系统级
ssid:关联SSID。为1~32个字符的字符串,区分大小写。
【描述】
client-mode ssid命令用来配置Client模式的关联SSID。undo client-mode ssid命令用来停用Client的关联SSID。
缺省情况下,没有配置 Client模式的关联SSID。
# 配置Client模式的关联SSID为ChinaNet-ABC。
[Sysname-WLAN-Radio1/0/1] client-mode ssid ChinaNet-ABC
client-mode state-timeout interval
undo client-mode state-timeout
WLAN射频接口视图
【缺省级别】
2:系统级
interval:配置Client模式AP上线的状态超时时间,取值范围为100~5000,单位为毫秒。
【描述】
client-mode state-timeout命令用来配置Client模式AP上线的状态超时时间。undo client-mode state-timeout命令用来恢复缺省情况。
缺省情况下,Client模式AP上线的状态超时时间为300毫秒。
# 配置Client模式AP上线的状态超时时间为200毫秒。
[Sysname-WLAN-Radio1/0/1] client-mode state-timeout 200
display wlan client-mode radio [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display wlan client-mode radio命令用来显示当前Client模式的AP的配置和连接情况。
# 显示Client模式的配置和连接情况。
<Sysname> display wlan client-mode radio
                            WLAN Client Mode
 Radio                 : 2
 Mode                  : 802.11g
 Authentication Method : WPA2-PSK
 Cipher Suite          : AES-CCMP
 Key (Simple)          : ******
 WEP Key ID            : N/A
 SSID                  : ChinaNet-ABC
 BSSID                 : 6CF0-49CD-30BB
 Status                : Connected
Received Packets
    Data               : 1324939
    Management         : 34876
 Sent Packets
    Data               : 46365
 Discarded Packets     : 38272
 Rate(Rx/Tx)           : 1 2 5.5 6 9 11 12 18 24 36 48 54
 Online Duration       : 0 days 0 hours 45 minutes 5 seconds
表1-12 display wlan client-mode radio命令显示信息描述表
Radio
射频ID
Mode
射频模式
认证模式:Open-System/Shared-Key/WPA2-PSK
Cipher Suite
加密套件:WEP40/WEP104/WEP128/TKIP/AES-CCMP
Key
密钥:
·     (Cipher):密文显示加密密钥
·     (Simple):明文显示加密密钥
WEP Key ID
WEP密钥ID
SSID
客户端关联的SSID
BSSID
基本服务集识别码
Status
关联状态:
·     Connected:关联到无线服务
·     Disconnected:没有关联到无线服务
Received Data Packets
接收数据报文数
Received Management Packets
接收管理报文数
Sent Data Packets
发送数据报文数
Discarded Packets
丢弃报文数
Rate(Rx/Tx)
收发速率集合
Online Duration
关联到无线服务后的在线时间
display wlan client-mode ssid [ ssid ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
ssid:SSID的名称。为1~32个字符的字符串,区分大小写。
【描述】
display wlan client-mode ssid命令用来显示当前扫描到的无线服务及信号质量。
# 显示扫描到的无线服务及信号质量。
<Sysname> display wlan client-mode ssid
                                    SSID List
 SSID Name                          BSSID            Type    RSSI    Quality
 ChinaNet-ABC                       1A76-2435-FD21   Clear   55      *****
 Temp                               2334-5431-BDA1   WPA2    9       *
 TC                                 6CF0-AAFD-12FF   WEP     22      ***
 H3C                                F7FD-FDC1-F123   WPA     40      ****
 Test                               4512-ABC4-F555   WAPI    17      **
 Lab                                4138-FAB7-8545   Clear   39      ****
 Home_123456789000000000000000000   F643-ABD4-439F   WPA2    27      ***
表1-13 display wlan client-mode ssid命令显示信息描述表
SSID Name
扫描到的SSID名称
BSSID
基本服务集识别码
无线服务安全加密类型:
·     Clear
·     WPA
·     WPA2
·     WEP
·     WAPI
RSSI
信号强度
Quality
信号质量:
·     *****            非常好
·     ****              很好
·     ***               好
·     **                 低
·     *                  非常低
·     No Signal    无信号
