02-WLAN命令参考
05-WLAN RRM命令
本章节下载: 05-WLAN RRM命令  (352.17 KB)
05-WLAN RRM命令
1 WLAN RRM
1.1 WLAN RRM配置命令
1.1.1 adjacent-channel interference trap
1.1.2 ap radio
1.1.3 autochannel-set avoid-dot11h
1.1.4 channel holddown-time
1.1.5 channel-utilization threshold
1.1.6 co-channel interference trap
1.1.7 description
1.1.8 display wlan ap rrm-history
1.1.9 display wlan ap rrm-status
1.1.10 display wlan mesh calibrate-channel history
1.1.11 display wlan rrm
1.1.12 display wlan rrm-calibration-group
1.1.13 dot11a
1.1.14 dot11a adjacency-factor
1.1.15 dot11a calibrate-channel
1.1.16 dot11a calibrate-channel persistent
1.1.17 dot11a calibrate-channel pronto
1.1.18 dot11a calibrate-channel self-decisive
1.1.19 dot11a calibrate-power
1.1.20 dot11a calibrate-power min
1.1.21 dot11a calibrate-power persistent
1.1.22 dot11a calibrate-power pronto
1.1.23 dot11a calibrate-power self-decisive
1.1.24 dot11a calibrate-power threshold
1.1.25 dot11a calibration-interval
1.1.26 dot11a crc-error-threshold
1.1.27 dot11a exclude-channel
1.1.28 dot11a interference-threshold
1.1.29 dot11a max-bandwidth
1.1.30 dot11a tolerance-level
1.1.31 dot11ac mandatory maximum-nss
1.1.32 dot11ac support maximum-nss
1.1.33 dot11ac multicast-rate nss
1.1.34 dot11b
1.1.35 dot11b max-bandwidth
1.1.36 dot11bg adjacency-factor
1.1.37 dot11bg calibrate-channel
1.1.38 dot11bg calibrate-channel persistent
1.1.39 dot11bg calibrate-channel pronto
1.1.40 dot11bg calibrate-channel self-decisive
1.1.41 dot11bg calibrate-power min
1.1.42 dot11bg calibrate-power
1.1.43 dot11bg calibrate-power persistent
1.1.44 dot11bg calibrate-power pronto
1.1.45 dot11bg calibrate-power self-decisive
1.1.46 dot11bg calibrate-power threshold
1.1.47 dot11bg calibration-interval
1.1.48 dot11bg crc-error-threshold
1.1.49 dot11bg exclude-channel
1.1.50 dot11bg interference-threshold
1.1.51 dot11bg tolerance-level
1.1.52 dot11g
1.1.53 dot11g max-bandwidth
1.1.54 dot11g protection enable
1.1.55 dot11g protection-mode
1.1.56 dot11n mandatory maximum-mcs
1.1.57 dot11n max-bandwidth
1.1.58 dot11n multicast-rate
1.1.59 dot11n protection enable
1.1.60 dot11n protection-mode
1.1.61 dot11n support maximum-mcs
1.1.62 mesh calibrate-channel
1.1.63 mesh calibrate-channel pronto
1.1.64 mesh calibrate-channel self-decisive
1.1.65 power-constraint
1.1.66 power holddown-time
1.1.67 scan channel
1.1.68 scan type
1.1.69 scan report-interval
1.1.70 spectrum-management enable
1.1.71 wlan rrm
1.1.72 wlan rrm-calibration-group
1.2 负载均衡配置命令
1.2.1 ap radio
1.2.2 description
1.2.3 display wlan load-balance-group
1.2.4 display wlan load-balance neighbor-list ap
1.2.5 display wlan load-balance neighbor-list client
1.2.6 display wlan load-balance reject-client ap
1.2.7 display wlan load-balance reject-client client
1.2.8 load-balance access-denial
1.2.9 load-balance rssi-threshold
1.2.10 load-balance session
1.2.11 load-balance traffic
1.2.12 wlan load-balance-group
1.3 频谱导航配置命令
1.3.1 band-navigation aging-time
1.3.2 band-navigation balance access-denial
1.3.3 band-navigation balance session
1.3.4 band-navigation enable (WLAN RRM View)
1.3.5 band-navigation enable (AP Template View)
1.3.6 band-navigation rssi-threshold
1 WLAN RRM
1.1  WLAN RRM配置命令
adjacent-channel interference trap threshold value
undo adjacent-channel interference trap threshold
RRM视图
【缺省级别】
2:系统级
threshold value:邻频干扰告警门限值,取值范围为10~90,单位为dBm,代表功率范围为-10~-90。如果设备检测到的邻频干扰达到指定值,则向网络管理系统发送Trap消息。
【描述】
adjacent-channel interference trap threshold命令用来配置邻频干扰告警门限值。undo adjacent-channel interference trap threshold命令用来恢复缺省情况。
缺省情况下,邻频干扰告警门限值为60。
# 配置邻频干扰告警门限值为80。
[Sysname] wlan rrm
[Sysname-wlan-rrm] adjacent-channel interference trap threshold 80
1.1.2  ap radio
ap ap-name radio radio-number
undo ap { ap-name [ radio radio-number ] | all }
RRM保持调整组视图
【缺省级别】
2:系统级
ap-name:加入RRM保持调整组的AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”,不区分大小写,可以包含空格。加入RRM保持调整组的AP必须已经存在。
radio-number:将AP的第几个Radio加入RRM保持调整组。不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
all:删除RRM保持调整组中的所有Radio。
【描述】
ap radio命令用来将AP的Radio加入到RRM保持调整组中。undo ap ap-name用来删除RRM保持调整组中的Radio。
缺省情况下,RRM保持调整组中不存在任何AP的Radio。
·     删除RRM保持调整组中的Raido时,如果使用undo ap ap-name命令(即不指定radio radio-number参数时)表示删除RRM保持调整组中指定AP的所有Radio。
·     RRM保持调整组中的成员单位为Radio。
·     一个Radio只能加入一个RRM保持调整组。
# 将ap1的第2个Radio加入到ID为10的RRM保持调整组中。
[Sysname] wlan rrm-calibration-group 10
[Sysname-wlan-rc-group-10] ap ap1 radio 2
# 删除ID为10的RRM保持调整组中的所有Radio。
[Sysname-wlan-rc-group-10] undo ap all
# 删除RRM保持调整组10中ap1的所有Radio。
[Sysname-wlan-rc-group-10] undo ap ap1
# 删除RRM保持调整组10中ap1的第2个Radio。
[Sysname-wlan-rc-group-10] undo ap ap1 radio 2
undo autochannel-set
RRM视图
【缺省级别】
2:系统级
无
【描述】
autochannel-set avoid-dot11h命令用来配置扫描非dot11h信道。配置此功能后,设备在初始信道选择时和信道调整过程中,只扫描属于配置国家代码的非dot11h信道。undo autochannel-set命令用来恢复缺省情况。
缺省情况下,该功能是关闭的。
802.11h信道即雷达信道,使用了部分和802.11a重叠的频段,一旦设备选择了和802.11h相同的信道作为工作信道,可能会干扰雷达信号。开启autochannel-set avoid-dot11h命令后,设备在选择信道时,只扫描属于配置区域码的非802.11h信道,避免和802.11h信道产生冲突。
相关命令可参考scan channel。
# 配置扫描非dot11h信道。
[Sysname] wlan rrm
[Sysname-wlan-rrm] autochannel-set avoid-dot11h
channel holddown-time minutes
undo channel holddown-time
RRM保持调整组视图
【缺省级别】
2:系统级
minutes:信道保持时长,表示在配置自动信道调整后,信道在每次调整后(包括自动调整和初始信道选择)的指定时间内将保持不变,取值范围为10~1440,单位为分钟。
【描述】
channel holddown-time命令用来配置RRM保持调整组的自动调整信道保持时长。undo channel holddown-time命令用来恢复缺省情况。
缺省情况下,信道保持时长为720分钟。
需要注意的是,如果AC在信道保持时长内检测到信道内存在雷达信号,AC会立即重新选择信道,选定新的信道后,信道保持时长会重新开始计时。
# 为RRM保持调整组10配置自动调整信道保持时长为600分钟。
[Sysname-wlan-rc-group-10] channel holddown-time 600
channel-utilization threshold threshold
undo channel-utilization threshold
RRM视图
【缺省级别】
2:系统级
threshold:信道利用率告警门限值,以百分比表示,取值范围为5~100,默认值为90。
【描述】
channel-utilization threshold命令用来配置信道利用率告警门限值。当AP的信道利用率达到配置的门限值时,设备打印信道利用率告警syslog。undo channel-utilization threshold命令用来恢复缺省值。
缺省情况下,信道利用率告警门限值为90。
# 配置信道利用率告警门限值为60%。
[Sysname] wlan rrm
[Sysname-rrm] channel-utilization threshold 60
co-channel interference trap threshold value
undo co-channel interference trap threshold
RRM视图
【缺省级别】
2:系统级
threshold value:同频干扰告警门限值,取值范围为10~90,单位为dBm,代表功率范围为-10~-90。如果设备检测到的同频干扰达到指定值,则向网络管理系统发送Trap消息。
【描述】
co-channel interference trap命令用来配置同频干扰告警门限值。undo co-channel interference trap命令用来恢复缺省情况。
缺省情况下,同频干扰告警门限值为60。
# 配置同频干扰告警门限值为80。
[Sysname] wlan rrm
[Sysname-wlan-rrm] co-channel interference trap threshold 80
1.1.7  description
RRM保持调整组
【缺省级别】
2:系统级
text:RRM保持调整组的描述信息,为1~64个字符的字符串,区分大小写。
【描述】
description命令用来配置RRM保持调整组的描述信息。undo description命令用来恢复缺省情况。
缺省情况下,RRM保持调整组没有描述信息。
# 配置RRM保持调整组10的描述信息为office。
[Sysname-wlan-rc-group-10] description office
display wlan ap { all | name ap-name } rrm-history [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all:所有AP。
name ap-name:AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”,不区分大小写,可以包含空格。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display wlan ap rrm-history命令用来显示所有AP或指定AP的RRM历史信息。具体显示所有或指定名称的AP上最近3个改变的信道或功率的详细信息。命令输出包括改变时间、触发原因、功率、冲突等参数。
# 显示ap1的RRM详细信息。
<Sysname> display wlan ap name ap1 rrm-history
                         AP RRM History
 Flags : I - Interference,   P - Packets discarded,    F - Retransmission,
         R - Radar,          C - Coverage,             O - Others
                         AP RRM History : ap1
 Radio : 2                                Basic BSSID : 000f-e2ff-7700
        Chl Power Load Util Intf PER Retry Reason  Date         Time
            (dBm) (%)  (%)  (%)  (%) (%)           (yyyy-mm-dd) (hh:mm:ss)
 Before 6   20    24   2    21   11  18    -P----  2008-01-07   17:31:50
 After  1   20    9    0    8    0   27    -       -            -
 Before 1   20    54   1    53   11  15    IP----  2008-01-08   12:19:50
 After  6   20    10   0    10   3   29    -       -            -
 Before 6   20    29   1    28   21  20    -P----  2008-01-08   12:59:50
 After  1   20    30   0    29   2   24    -       -            -
表1-1 display wlan ap rrm-history命令显示信息描述表
Radio
AP的射频
Basic BSSID
基本服务集标识,AP的Radio接口的MAC地址
Chl
信道,channel number的缩写形式。射频或功率改变时,射频运行的信道
Power
射频或功率改变时,射频运行的功率
Load
射频或功率改变时,射频上观测到的负载,以百分比表示
Util
射频利用率,utilization的缩写形式。射频或功率改变时,射频利用率,以百分比表示
Intf
干扰,interference的缩写形式。射频或功率改变时,射频上观测到的冲突,以百分比表示
PER
包错误率,packet error rate的缩写形式。信道中观测到的包错误率,以百分比显示。
Retry
重传率,retransmission rate的缩写形式。射频或功率改变时,射频上发生的重传,以百分比表示
Reason
射频或功率改变的原因,如冲突、包丢弃、重传、雷达和覆盖
Date
射频或功率改变发生的日期
Time
射频或功率改变发生的时间
display wlan ap { all | name ap-name } rrm-status [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all:所有AP。
name ap-name:AP名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”不区分大小写,可以包含空格。
【描述】
display wlan ap rrm-status命令用来显示所有AP或指定AP的每个射频的RRM详细信息,如:AP运行的信道、AP功率级别、观测到的冲突以及邻居的数量。
在AC设备上,如果RRM处于未使能状态,则执行此命令时,只会显示AP相应射频的运行信道和功率级别,其它信息如冲突、邻居的数量等不会显示。这里的RRM使能是指动态功率选择或信道自动优化功能处于开启状态。
# 显示ap1的RRM详细信息。
<Sysname> display wlan ap name ap1 rrm-status
                         AP RRM Profile : ap1
 Channel : 6 (Good)                       Tx Power (dBm) : 20
   Chl   NbrCnt   Load   Util   Intf   PER   Retry   Radar
   1     6        33     -      33     1     -       -
   6     6        25     0      25     8     0       -
   11    4        48     -      48     5     -       -
   Nbr-BasicBSSID   Chl   Intf   SignalStrength   Type
                          (%)    (dBm)
   000f-e20c-4080   6     8      -69              Unmanaged
   000f-e211-2220   6     0      -63              Unmanaged
   000f-e232-5500   6     1      -79              Unmanaged
   000f-e23e-e740   1     1      -71              Unmanaged
   000f-e23e-e760   1     1      -63              Unmanaged
   000f-e25d-f3c0   11    0      -59              Unmanaged
   000f-e25d-f420   1     2      -89              Unmanaged
   000f-e267-9990   1     8      -80              Unmanaged
   000f-e267-9b10   11    0      -65              Unmanaged
   000f-e26c-2980   6     0      -85              Unmanaged
   000f-e26e-5f00   11    0      -63              Unmanaged
   000f-e274-1020   6     5      -60              Unmanaged
   000f-e299-5510   1     2      -78              Unmanaged
   000f-e2c0-0120   1     4      -76              Unmanaged
   000f-e2ff-ee10   6     1      -74              Unmanaged
   5055-5555-5500   11    41     -67              Unmanaged
表1-2 display wlan ap name rrm-status命令显示信息描述表
Radio
AP的射频id
Basic BSSID
Channel
射频运行的信道
Tx Power
当前射频运行的Tx功率
Chl
NbrCnt
信道中找到的邻居数量,neighbor count的缩写形式
Load
信道中观测到的负载,以百分比显示
Util
信道利用率,utilization的缩写形式,以百分比显示
Intf
信道中观测到的冲突,interference的缩写形式,以百分比显示
PER
信道中观测到的包错误率,packet error rate的缩写形式,以百分比显示
Load
信道中观测到的负载,以百分比显示
Retry
重传率,retransmission rate的缩写形式,信道中发生重传的百分比
Radar
雷达检测状态,radar detection status的缩写形式
Nbr-BasicBSSID
邻居AP的Radio接口的MAC地址
SignalStrengt
AP信号强度,以dBm为单位
AP类型,如已管理的或未管理的
display wlan mesh calibrate-channel history [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display wlan mesh calibrate-channel history命令用来查看Mesh动态信道调整的历史信息。
# 查看Mesh动态信道调整的历史信息。
<Sysname> display wlan mesh calibrate-channel history
                            Mesh RRM History
    Mesh-ID: outdoor                                    Number of Radios: 2
 AP                                Radio  Chl(After/Before)  Date/Time
 mpp                               1      149/auto           2009-10-10/13:16:19
 mpp                               1      153/149            2009-10-10/13:19:22
 map                               1      149/auto           2009-10-10/13:17:1
 map                               1      153/149            2009-10-10/13:19:24
表1-3 display wlan mesh calibrate-channel history命令显示信息描述表
Mesh-ID
Mesh名称
Number of Radios
Radio个数
AP
AP名称
Radio
射频ID
Chl(After/Before)
信道(调整后/调整前)
Date/Time
日期/时间
display wlan rrm [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display wlan rrm命令用来显示基本RRM配置参数。
# 显示RRM配置参数。
 <Sysname>display wlan rrm
                                 RRM Configuration
 11a Configured Rates (Mbps)
   Mandatory                   : 6, 12, 24
   Supported                   : 9, 18, 36, 48, 54
   Disabled                    : -NA-
   Multicast                   : Auto
 11b Configured Rates (Mbps)
   Mandatory                   : 1, 2
   Supported                   : 5.5, 11
   Disabled                    : -NA-
   Multicast                   : Auto
 11g Configured Rates (Mbps)
   Mandatory                   : 1, 2, 5.5, 11
   Supported                   : 6, 9, 12, 18, 24, 36, 48, 54
   Disabled                    : -NA-
   Multicast                   : Auto
 Scan Configuration
   Scan Type                   : Passive
   Channel Mode                : Auto
   Report-Interval (s)         : 10
 11a Configuration
   Automatic Channel Selection : Disabled
   Automatic Power Selection   : Disabled
   Calibration Mode-Channel    : -NA-
   Mesh Calibration Mode-Channel: -NA-
   Calibration Mode-Power      : -NA-
   exclude-channel             : -NA-
   Calibration Interval (min)  : 8
   Interference Threshold (%)  : 50
   Tolerance Level (%)         : 20
   Adjacency Factor            : 3
   CRC-Error Threshold (%)     : 20
   Power Threshold (dBm)       : -65
   Minimum Power (dBm)         : 1
   max-bandwidth (kbps)        : 30000
 11bg Configuration
 11b Configuration
   max-bandwidth (kbps)        : 7000
 11g Configuration
   11g Protection              : Disabled
   11g Protection Mode         : RTS/CTS
 11n Configuration
   Mandatory Maximum MCS       : -NA-
   Supported Maximum MCS       : 76
   Multicast MCS               : -NA-
   11n Protection              : Disabled
   11n Protection Mode         : RTS/CTS
   max-bandwidth (kbps)        : 180000
 11h Configuration
   Spectrum Management         : Disabled
   Power Constraint (dBm)      : 0
   Channel Set                 : All
 11ac Configuration
   Mandatory Maximum NSS       : -NA-
   Support Maximum NSS         : 8
   Multicast NSS               : -NA-
   Multicast VHT-MCS           : -NA-
 Band Navigation Configuration
   Band Navigation             : Disabled
 Load Balance Configuration
   Load Balancing Mode         : Disabled
<Sysname>
表1-4 display wlan rrm命令显示信息描述表
802.11a模式下的射频速率。802.11b和802.11g具有的相同字段表示相同的意思
Mandatory
强制速率,AP必须支持的速率
Supported
支持速率,AP或客户端支持的扩展速率
Disabled
禁用速率,禁止AP使用的传输速率
Multicast
组播速率
Scan Type
扫描类型
Channel Mode
射频的工作信道。如果信道模式设置为auto模式时,只扫描规定的信道;模式设置为all,会在所有信道进行扫描
Report-Interval (s)
报告间隔
11a Configuration
802.11a的配置信息
802.11b、802.11g和802.11n具有的相同字段表示相同的意思
自动信道调整功能:
·     Enabled:开启
·     Disabled:关闭
自动功率调整功能
·     Enabled:开启
·     Disabled:关闭
自动信道调整触发方式:
·     Self-decisive:定时触发
·     Pronto:手动触发
·     -NA-:未配置
Mesh自动信道调整触发方式:
·     Pronto:手动触发
·     -NA-:未配置
自动功率调整触发方式:
·     Pronto:手动触发
·     -NA-:未配置
exclude-channel
信道排除列表
校准间隔
信道冲突门限值
Tolerance Level (%)
容限系数
Adjacency Factor
邻居系数
CRC错误门限值
功率调整门限值
Minimum Power (dBm)
最小发射功率
max-bandwidth
最大带宽参考值
11g Protection
802.11g保护功能
·     Enabled:开启802.11g保护功能
·     Disabled:关闭802.11g保护功能
11g Protection mode
802.11g保护方式
·     CTS-to-Self方式
·     RTS/CTS方式
11n Configuration
802.11n的配置信息
802.11n基本MCS集的最大MCS索引
802.11n支持MCS集的最大MCS索引
Multicast MCS
802.11n的组播MCS索引
11n Protection
802.11n保护功能
·     Enabled:开启802.11n保护功能
·     Disabled:关闭802.11n保护功能
11n Protection Mode
802.11n保护方式
·     CTS-to-Self方式
·     RTS/CTS方式
11h Configuration
802.11h的配置情况
Spectrum Management
802.11a频段的频谱管理功能:
·     Enabled:开启
·     Disabled:关闭
802.11a射频的功率限制值
Channel Set
Non-dot11h:信道组设置为非dot11h信道。配置此功能后,设备在初始信道选择时,只扫描属于配置国家代码的非dot11h信道
All:不限制选择的信道
11ac Configuration
802.11ac的配置情况
强制的最大流数
Support Maximum NSS
支持的最大流数
Multicast NSS
组播空间流数
Multicast VHT-MCS
组播VHT-MCS索引
频谱导航的配置情况
Band Navigation
频谱导航功能
·     Enabled:开启
·     Disabled:关闭
负载均衡的配置情况
Load Balancing Mode
负载均衡模式
如果没有使能负载均衡,此字段将显示Disabled,并不会显示下面两个字段
Session Threshold (users)
会话门限。当配置负载均衡模式为流量模式(traffic)时,此字段将显示:Traffic Threshold (%),表示流量门限
Session Gap (users)
会话差值门限。当配置负载均衡模式为流量模式(traffic)时,此字段将显示:Traffic Gap (%),表示流量差值门限
display wlan rrm-calibration-group { group-id | all } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
group-id:RRM保持调整组的ID。不同型号的设备支持的取值范围不同,请参见“命令参考导读”中的“命令行及参数差异情况”部分的介绍。
all:所有RRM保持调整组。
【描述】
display wlan rrm-calibration-group命令用来显示RRM保持调整组的相关配置。
# 显示RRM保持调整组10的相关配置。
<Sysname> display wlan rrm-calibration-group 10
                  RRM Calibration Group Information
Group ID                : 10
Description             : office
Channel holddown time   : 720  (in minutes)
Power holddown time     : 60   (in minutes)
Group members           : ap4-radio2,
                          ap3-radio2,
表1-5 display wlan rrm-calibration-group命令显示信息描述表
Group ID
RRM保持调整组的ID
RRM保持调整组的描述信息
信道保持时长
Power holddown time
功率保持时长
Group members
加入RRM保持调整组的Radio
1.1.13  dot11a
dot11a { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11a { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
RRM视图
【缺省级别】
2:系统级
disabled-rate:禁用速率。
mandatory-rate:强制速率。
multicast-rate:组播速率,即AP向客户端发送组播报文的速率。组播速率必须在强制速率中选取。
supported-rate:支持速率。
rate-value:可设置的射频速率如下:
·     6 Mbps
·     9 Mbps
·     12 Mbps
·     18 Mbps
·     24 Mbps
·     36 Mbps
·     48 Mbps
·     54 Mbps
【描述】
dot11a命令用来配置“802.11a”模式下的射频速率。undo dot11a用来恢复缺省情况。
缺省情况下,
·     禁用速率:无。
·     强制速率:6,12,24。
·     组播速率:自动从强制速率集中选取,即在所有客户端都支持的强制速率中选取发送速率,作为组播报文的发送速率。
·     支持速率:9,18,36,48,54。
# 配置802.11a模式的射频速率(组播速率:6;支持速率:12)。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a multicast-rate 6
[Sysname-wlan-rrm] dot11a supported-rate 12
dot11a adjacency-factor neighbor
undo dot11a adjacency-factor
RRM视图
【缺省级别】
2:系统级
neighbor:最大邻居数,并指定需要和功率调整门限值进行比较的邻居AP,取值范围为1~16。
【描述】
dot11a adjacency-factor用来配置工作在802.11a频段上的最大邻居数,并指定需要和功率调整门限值进行比较的邻居AP。undo dot11a adjacency-factor命令用来恢复缺省情况。
缺省情况下,最大邻居数为3,需要和功率调整门限值进行比较的AP为在所有邻居AP中信号强度排在第3位的邻居AP。
相关命令可参考dot11a calibrate-power threshold。
# 配置802.11a频段上最大邻居数为7,需要和功率调整门限值进行比较的AP为在所有邻居AP中信号强度排在第7位的邻居AP。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a adjacency-factor 7
undo dot11a calibrate-channel
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11a calibrate-channel命令用来配置信道监测,以开启自动信道调整功能。undo dot11a calibrate-channel命令用来恢复缺省情况。
缺省情况下,没有配置信道监测。
开启自动信道调整功能后,获取到的最大功率是以最终信道为准的,最终信道不同,获取到的最大功率就不同。
# 配置802.11a的信道监测。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11a calibrate-channel persistent命令用来对5GHz射频上的所有Radio执行信道固化。
执行此命令,设备会固化自动选择的工作信道或是调整后的工作信道。在AC重启后,AP能继续使用被固化的工作信道。
·     一旦在信道上检测到雷达信号,即使已经配置dot11a calibrate-channel persistent命令固化过信道,设备也会立即切换信道。
·     如果已经配置channel auto命令,但是在未选出信道前执行dot11a calibrate-channel persistent命令,那么命令不会生效。例如,在某个Radio上配置channel auto命令,在Radio未选出工作信道前就执行dot11a calibrate-channel persistent命令,那么此操作不会生效。
·     如果已经配置channel auto命令,在选出工作信道后执行dot11a calibrate-channel persistent命令,设备会自动使用channel channel-number命令保存工作信道值。在AC重启后,AP能继续使用被固化的工作信道。
·     如果先配置channel lock命令,然后再执行dot11a calibrate-channel persistent命令,信道的锁定状态会被取消,设备会自动使用channel channel-number命令保存工作信道值。在AC重启后,AP能继续使用被固化的工作信道。
# 对5GHz射频上的所有Radio执行信道固化。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel persistent
dot11a calibrate-channel pronto ap { all | name apname radio radio-num }
RRM视图
【缺省级别】
2:系统级
name apname:AP名称,为1~64个字符的字符串,不区分大小写。
radio radio-num:射频号。
【描述】
dot11a calibrate-channel pronto命令用来执行手动触发自动信道调整,即指定AP或所有AP开始信道优化。从RRM中获得的校准信道将在下一次优化间隔后应用到AP上。该命令不能取消。
缺省情况下,没有执行手动触发自动信道调整。
需要注意的是,执行手动触发自动信道调整之前需要先配置信道监测dot11a calibrate-channel。
# 配置802.11a下所有AP开始优化。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel pronto ap all
undo dot11a calibrate-channel self-decisive
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11a calibrate-channel self-decisive命令用来配置定时触发自动信道调整(同时配置了信道监测)。undo dot11a calibrate-channel self-decisive命令用来恢复缺省情况。
缺省情况下,没有配置定时触发自动信道调整。
# 配置定时触发自动信道调整。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel self-decisive
undo dot11a calibrate-power
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11a calibrate-power命令用来配置功率监测,以开启自动功率调整功能。undo dot11a calibrate-power命令用来恢复缺省情况。
缺省情况下,没有配置功率监测。
# 配置802.11a的功率监测。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power
dot11a calibrate-power min tx-power
undo dot11a calibrate-power min
RRM视图
【缺省级别】
2:系统级
tx-power:射频的最小发射功率,取值范围为1~20,单位为dBm。
【描述】
dot11a calibrate-power min用来配置射频的最小发射功率。undo dot11a calibrate-power min用来恢复缺省情况。
缺省情况下,射频的最小发射功率为1dBm。
#  配置射频的最小发射功率为10。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power min 10
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11a calibrate-power persistent命令用来对5GHz射频上的所有Radio执行功率固化。
执行此命令,设备会固化调整后的功率值。如果调整后的功率值不是max-power命令的缺省值,设备会自动使用max-power命令保存该值。在AC重启后,AP能继续使用被固化的功率值。
# 对5GHz射频上的所有Radio执行功率固化。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power persistent
dot11a calibrate-power pronto ap { all | name apname radio radio-num }
RRM视图
【缺省级别】
2:系统级
all:所有AP。
【描述】
dot11a calibrate-power pronto命令用来执行手动触发自动功率调整,即指定AP或所有AP开始功率优化。从RRM中获得的校准功率将在下一次优化间隔后应用到AP上。该命令不能取消。配置自动功率调整功能之前需要先配置功率监测功能。
缺省情况下,没有执行手动触发自动功率调整。
# 配置802.11a下AP1的射频1开始执行功率优化。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power pronto ap name ap1 radio 1
undo dot11a calibrate-power self-decisive
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11a calibrate-power self-decisive命令用来配置定时触发自动功率调整(同时配置了功率监测)。undo dot11a calibrate-power self-decisive命令用来恢复缺省情况。
缺省情况下,没有配置定时触发自动功率调整。
# 配置定时触发自动功率调整。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power self-decisive
dot11a calibrate-power threshold value
undo dot11a calibrate-power threshold
RRM视图
【缺省级别】
2:系统级
value:功率调整门限值,取值范围为50~90,单位为dBm,代表功率范围为-90~-50。
【描述】
dot11a calibrate-power threshold用来配置功率调整门限值。undo dot11a calibrate-power threshold用来恢复缺省情况。
缺省情况下,功率调整门限值为80。
相关命令可参考dot11a adjacency-factor。
# 配置功率调整门限值为70。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power threshold 70
dot11a calibration-interval minutes
undo dot11a calibration-interval
RRM视图
【缺省级别】
2:系统级
minutes:校准间隔,取值范围为3~180,单位为分钟。
【描述】
dot11a calibration-interval命令用来配置校准间隔为指定值。undo dot11a calibration-interval命令用来恢复缺省情况。
缺省情况下,校准间隔是8分钟。
需要注意的是,校准间隔对Mesh网络信道优化、无线服务的信道和功率优化都会起作用。
# 配置802.11a的校准间隔为10分钟。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibration-interval 10
dot11a crc-error-threshold percent
undo dot11a crc-error-threshold
RRM视图
【缺省级别】
2:系统级
percent:门限,以百分比表示,取值范围为1~100。
【描述】
dot11a crc-error-threshold命令用来配置CRC错误门限值。undo dot11a crc-error-threshold命令用来恢复缺省情况。
缺省情况下,CRC错误门限值为20。
# 配置802.11a的CRC错误门限为50%。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a crc-error-threshold 50
dot11a exclude-channel channel-list
undo dot11a exclude-channel { channel-list | all }
RRM视图
【缺省级别】
2:系统级
channel-list:信道列表,表示方式为channel-list = { channel }&<1-10>,channel的取值范围为设备支持的所有5GHz信道,&<1-10>表示前面的参数最多可以输入10次。
all:所有信道。
【描述】
dot11a exclude-channel命令用来配置5GHz信道排除列表。undo dot11a exclude-channel命令用来删除5GHz信道排除列表中的信道。
缺省情况下,信道排除列表中不存在任何信道。
# 将信道149和153添加到5GHz信道排除列表。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a exclude-channel 149 153
dot11a interference-threshold percent
undo dot11a interference-threshold
RRM视图
【缺省级别】
2:系统级
percent:信道冲突门限,以百分比表示,取值范围为1~100。
【描述】
dot11a interference-threshold命令用来配置信道冲突门限值。undo dot11a interference-threshold命令用来恢复缺省情况。
缺省情况下,信道冲突门限值为50。
# 配置802.11a的信道冲突门限为60%。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a interference-threshold 60
dot11a max-bandwidth 11a-bandwidth
undo dot11a max-bandwidth
RRM视图
【缺省级别】
2:系统级
11a-bandwidth:802.11a的带宽参考值,单位为kbps。取值范围为16~30000。
【描述】
dot11a max-bandwidth命令用来配置802.11a的最大带宽参考值。undo dot11a max-bandwidth命令用来恢复缺省情况。
缺省情况下,802.11a的最大带宽参考值为30000kbps。
# 配置802.11a的最大带宽参考值为15000。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a max-bandwidth 15000
dot11a tolerance-level percentage
undo dot11a tolerance-level
RRM视图
【缺省级别】
2:系统级
percentage:容限系数,以百分比表示,取值范围为1~45。
【描述】
dot11a tolerance-level命令用来配置频段的容限系数。undo dot11a tolerance-level命令用来恢复缺省情况。
当冲突门限超过门限值时,系统会选择新的信道,但只有在新的信道和旧信道的信道质量差超过容限系数时,新的信道才会真正被应用。
缺省情况下,频段的容限系数的值为20。
# 配置802.11a的容限系数为25%。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a tolerance-level 25
dot11ac mandatory maximum-nss number
undo dot11ac mandatory maximum-nss
RRM视图
【缺省级别】
2:系统级
number:指定802.11ac的最大基本空间流数,取值范围为1~8。
【描述】
dot11ac mandatory maximum-nss命令用来配置802.11ac的最大基本空间流数。undo dot11ac mandatory maximum-nss命令用来取消已有配置。
缺省情况下,没有配置任何最大基本空间流数。
# 配置802.11ac的最大基本空间流数为4。
<sysname> system-view
[sysname] wlan rrm
[sysname-wlan-rrm] dot11ac mandatory maximum-nss 4
dot11ac support maximum-nss number
undo dot11ac support maximum-nss
RRM视图
【缺省级别】
2:系统级
number:指定802.11ac的支持的最大空间流数,取值范围为1~8。
【描述】
dot11ac support maximum-nss命令用来配置802.11ac的最大空间流数。undo dot11ac support maximum-nss取消已有配置。
需要注意的是,用该命令指定的最大空间流数不能小于用dot11ac mandatory maximum-nss命令配置的最大基本空间流数。
缺省情况下,支持最大空间流数为8。
# 配置802.11ac的最大支持空间流数为5。
[sysname] wlan rrm
[sysname-wlan-rrm] dot11ac support maximum-nss 5
dot11ac multicast-rate nss number vht-mcs index
undo dot11ac multicast-rate
RRM视图
【缺省级别】
2:系统级
number:指定组播空间流数,取值范围为1~8。
index:指定组播VHT-MCS索引,取值范围为0~9。
【描述】
dot11ac multicast-rate命令用来配置802.11ac的组播空间流数与VHT-MCS索引。undo dot11ac  multicast-rate用来取消已配置的组播空间流数与VHT-MCS索引。
缺省情况下,没有指定802.11ac的组播空间流数与VHT-MCS索引。
# 配置802.11ac的组播空间流数为2,VHT-MCS索引为7。
[sysname] wlan rrm
[sysname-wlan-rrm] dot11ac multicast-rate nss 2 VHT-MCS 7
1.1.34  dot11b
dot11b { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11b { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
RRM视图
【缺省级别】
2:系统级
disabled-rate:禁用速率。
·     1 Mbps
·     2 Mbps
·     5.5 Mbps
·     11 Mbps
【描述】
dot11b命令用来配置“802.11b”模式下的射频速率。undo dot11b用来恢复缺省情况。
缺省情况下,
·     禁用速率:无。
·     强制速率:1,2。
·     支持速率:5.5,11。
# 配置802.11b模式的射频速率(禁用速率:1;组播速率:2;支持速率:11)。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11b disabled-rate 1
[Sysname-wlan-rrm] dot11b multicast-rate 2
[Sysname-wlan-rrm] dot11b supported-rate 11
dot11b max-bandwidth 11b-bandwidth
undo dot11b max-bandwidth
RRM视图
【缺省级别】
2:系统级
11b-bandwidth:802.11b的带宽参考值,单位为kbps。取值范围为16~7000。
【描述】
dot11b max-bandwidth命令用来配置802.11b的最大带宽参考值。undo dot11b max-bandwidth命令用来恢复缺省情况。
缺省情况下,802.11b的最大带宽参考值为7000kbps。
# 配置802.11b的最大带宽参考值为6000。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11b max-bandwidth 6000
dot11bg adjacency-factor neighbor
undo dot11bg adjacency-factor
RRM视图
【缺省级别】
2:系统级
【描述】
dot11bg adjacency-factor用来配置工作在802.11b/g频段上的最大邻居数,并指定需要和功率调整门限值进行比较的邻居AP。undo dot11bg adjacency-factor命令用来恢复缺省情况。
相关命令可参考dot11bg calibrate-power threshold。
# 配置802.11g频段上最大邻居数为7,需要和功率调整门限值进行比较的AP为在所有邻居AP中信号强度排在第7位的邻居AP。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg adjacency-factor 7
undo dot11bg calibrate-channel
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11bg calibrate-channel命令用来配置信道监测,以开启自动信道调整功能。undo dot11bg calibrate-channel命令用来恢复缺省情况。
缺省情况下,没有配置信道监测。
# 配置802.11bg的信道监测。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11bg calibrate-channel persistent命令用来对2.4GHz射频上的所有Radio执行信道固化。
·     如果已经配置channel auto命令,但是在未选出信道前执行dot11bg calibrate-channel persistent命令,那么命令不会生效。例如,在某个Radio上配置channel auto命令,在Radio未选出工作信道前就执行dot11bg calibrate-channel persistent命令,那么此操作不会生效。
·     如果已经配置channel auto命令,在选出工作信道后执行dot11bg calibrate-channel persistent命令,设备会自动使用channel channel-number命令保存工作信道值。在AC重启后,AP能继续使用被固化的工作信道。
·     如果先配置channel lock命令,然后再执行dot11bg calibrate-channel persistent命令,信道的锁定状态会被取消,设备会自动使用channel channel-number命令保存工作信道值。在AC重启后,AP能继续使用被固化的工作信道。
# 对2.4GHz射频上的所有Radio执行信道固化。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel persistent
dot11bg calibrate-channel pronto ap { all | name apname radio radio-num }
RRM视图
【缺省级别】
2:系统级
all :所有AP。
【描述】
dot11bg calibrate-channel pronto ap命令用来配置手动触发自动信道调整,即指定AP或所有AP开始信道优化。从RRM中获得的校准信道将在下一次优化间隔后应用到AP上。
缺省情况下,没有配置手动触发自动信道调整。
需要注意的是,执行手动触发自动信道调整之前需要先配置信道监测dot11bg calibrate-channel。
# 配置AP1的射频1开始信道优化。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel pronto ap name ap1 radio 2
undo dot11bg calibrate-channel self-decisive
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11bg calibrate-channel self-decisive命令用来配置定时触发自动信道调整(同时配置了信道监测)。undo dot11bg calibrate-channel self-decisive命令用来恢复缺省情况。
# 配置定时触发自动信道调整。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel self-decisive
dot11bg calibrate-power min tx-power
undo dot11bg calibrate-power min
RRM视图
【缺省级别】
2:系统级
【描述】
dot11bg calibrate-power min命令用来配置射频的最小发射功率。undo dot11bg calibrate-power min命令用来恢复缺省情况。
# 配置射频的最小发射功率为10。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power min 10
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11bg calibrate-power命令用来配置功率监测,以开启自动功率调整功能。undo dot11bg calibrate-power命令用来恢复缺省情况。
缺省情况下,没有配置功率监测。
# 配置802.11bg的功率监测。
[Sysname] wlan rrm
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11bg calibrate-power persistent命令用来对2.4GHz射频上的所有Radio执行功率固化。
# 对2.4GHz射频上的所有Radio执行功率固化。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power persistent
dot11bg calibrate-power pronto ap { all | name apname radio radio-num }
RRM视图
【缺省级别】
2:系统级
all:所有AP。
【描述】
dot11bg calibrate-power pronto ap命令用来配置手动触发自动功率调整,即指定AP或所有AP开始功率优化。从RRM中获得的校准功率将在下一次优化间隔后应用到AP上。在配置自动功率调整之前需要先配置功率监测功能。
缺省情况下,没有配置手动触发自动功率调整。
# 配置802.11bg下所有AP开始功率优化。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power pronto all
undo dot11bg calibrate-power self-decisive
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11bg calibrate-power self-decisive命令用来配置定时触发自动功率调整(同时配置了功率监测)。undo dot11bg calibrate-power self-decisive命令用来恢复缺省情况。
# 配置定时触发自动功率调整。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power self-decisive
dot11bg calibrate-power threshold value
undo dot11bg calibrate-power threshold
RRM视图
【缺省级别】
2:系统级
【描述】
dot11bg calibrate-power threshold命令用来配置功率调整门限值。undo dot11bg calibrate-power threshold命令用来恢复缺省情况。
缺省情况下,功率调整门限值为80。
相关命令可参考dot11bg adjacency-factor。
# 配置功率调整门限值为70。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power threshold 70
dot11bg calibration-interval minutes
undo dot11bg calibration-interval
RRM视图
【缺省级别】
2:系统级
【描述】
dot11bg calibration-interval命令用来配置校准间隔。undo dot11bg calibration-interval命令用来恢复缺省情况。
缺省情况下,校准间隔是8分钟。RRM机制会在校准间隔后周期运行。
# 配置802.11bg的校准间隔为10分钟。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibration-interval 10
dot11bg crc-error-threshold percent
undo dot11bg crc-error-threshold
RRM视图
【缺省级别】
2:系统级
【描述】
dot11bg crc-error-threshold命令用来配置CRC错误门限值。undo dot11bg crc-error-threshold命令用来恢复缺省情况。
缺省情况下,CRC错误门限值为20。
# 配置802.11bg的CRC错误门限为50%。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg crc-error-threshold 50
dot11bg exclude-channel channel-list
undo dot11bg exclude-channel { channel-list | all }
RRM视图
【缺省级别】
2:系统级
channel-list:信道列表,表示方式为channel-list = { channel }&<1-10>,channel的取值范围为设备支持的所有2.4GHz信道,&<1-10>表示前面的参数最多可以输入10次。
all:所有信道。
【描述】
dot11bg exclude-channel命令用来配置2.4GHz信道排除列表。undo dot11bg exclude-channel命令用来删除2.4GHz信道排除列表中的信道。
# 将信道1和2添加到2.4GHz信道排除列表。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg exclude-channel 1 2
dot11bg interference-threshold percent
undo dot11bg interference-threshold
RRM视图
【缺省级别】
2:系统级
【描述】
dot11bg interference-threshold命令用来配置信道冲突门限值。undo dot11bg interference-threshold命令用来恢复缺省情况。
缺省情况下,信道冲突门限值为50。
开启信道调整功能后,如果工作信道中的信道冲突高于设置的冲突门限值且新的信道和旧信道的信道质量差超过容限系数时,设备会执行信道切换。
# 配置802.11g的信道冲突门限为60%。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg interference-threshold 60
dot11bg tolerance-level percentage
undo dot11bg tolerance-level
RRM视图
【缺省级别】
2:系统级
【描述】
dot11bg tolerance-level命令用来设置频段的容限系数。undo dot11bg tolerance-level命令用来恢复缺省情况。
缺省情况下,容限系数的值为20。
# 设置802.11g的容限系数设为25%。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg tolerance-level 25
1.1.52  dot11g
dot11g { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11g { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
RRM视图
【缺省级别】
2:系统级
disabled-rate:禁用速率。
·     1 Mbps
·     2 Mbps
·     5.5 Mbps
·     6 Mbps
·     9 Mbps
·     11 Mbps
·     12 Mbps
·     18 Mbps
·     24 Mbps
·     36 Mbps
·     48 Mbps
·     54 Mbps
【描述】
dot11g命令用来配置“802.11g”模式下的射频速率。undo dot11g用来恢复缺省情况。
缺省情况下,
·     禁用速率:无。
·     强制速率:1,2,5.5,11。
·     支持速率:6,9,12,18,24,36,48,54。
# 配置802.11g模式的射频速率(禁用速率:2,36;组播速率:11;支持速率:54)。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g disabled-rate 2 36
[Sysname-wlan-rrm] dot11g multicast-rate 11
[Sysname-wlan-rrm] dot11g supported-rate 54
dot11g max-bandwidth 11g-bandwidth
undo dot11g max-bandwidth
RRM视图
【缺省级别】
2:系统级
11g-bandwidth:802.11g的带宽参考值,单位为kbps。取值范围为16~30000。
【描述】
dot11g max-bandwidth命令用来配置802.11g的最大带宽参考值。undo dot11g max-bandwidth命令用来恢复缺省情况。
缺省情况下,802.11g的最大带宽参考值为30000kbps。
# 配置802.11g的最大带宽参考值为6000。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g max-bandwidth 6000
undo dot11g protection enable
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11g protection enable命令用来开启802.11g保护功能。undo dot11g protection enable命令用来恢复缺省情况。
缺省情况下,802.11g保护功能处于关闭状态。
# 开启802.11g保护功能。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g protection enable
dot11g protection-mode { cts-to-self | rts-cts }
undo dot11g protection-mode
RRM视图
【缺省级别】
2:系统级
cts-to-self:CTS-to-Self方式。
rts-cts:RTS/CTS方式。
【描述】
dot11g protection-mode命令用来配置802.11g保护方式。undo dot11g protection-mode命令用来恢复缺省情况。
缺省情况下,802.11g保护方式为CTS-to-Self。
# 配置802.11g保护方式为RTS/CTS。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g protection-mode rts-cts
dot11n mandatory maximum-mcs index
undo dot11n mandatory maximum-mcs
RRM视图
【缺省级别】
2:系统级
index:指定802.11n基本MCS集的最大MCS索引,取值范围为0~最大MCS索引,目前MCS最大索引值为76。
【描述】
dot11n mandatory maximum-mcs命令用来配置802.11n基本MCS集的最大MCS索引。undo dot11n mandatory maximum-mcs命令用来取消已有配置。
缺省情况下,没有配置任何基本MCS集。
需要注意的是:如果用户在指定Radio接口下配置使能了client dot11n-only命令,则必须配置基本MCS集。
# 配置802.11n的基本MCS集的最大MCS索引为7。
[sysname] wlan rrm
[sysname-wlan-rrm] dot11n mandatory maximum-mcs 7
dot11n max-bandwidth 11n-bandwidth
undo dot11n max-bandwidth
RRM视图
【缺省级别】
2:系统级
11n-bandwidth:802.11n的带宽参考值,单位为kbps。取值范围为16~250000。
【描述】
dot11n max-bandwidth命令用来配置802.11n的最大带宽参考值。undo dot11n max-bandwidth命令用来恢复缺省情况。
缺省情况下,802.11n的最大带宽参考值为250000kbps。
# 配置802.11n的最大带宽参考值为6000。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n max-bandwidth 6000
dot11n multicast-rate index
undo dot11n multicast-rate
RRM视图
【缺省级别】
2:系统级
index:组播MCS索引,取值范围为0~76。
【描述】
dot11n multicast-rate命令用来配置802.11n的组播MCS索引。undo dot11n multicast-rate用来取消已配置的组播MCS索引。
缺省情况下,没有配置802.11n的组播MCS索引。
·     当接入的客户端都是802.11n客户端时,才能选用组播MCS索引。
·     当存在非802.11n客户端时,只能选用基础模式的组播速率,即802.11a/b/g的组播速率。
·     组播MCS起作用时,无论带宽模式设置的是20MHz模式还是40MHz模式,统一采用20MHz模式对应的速率。
·     在设置组播MCS索引时,如果设置的值超过了射频支持的最大值,则实际采用的组播MCS索引值为射频支持的最大值。
·     在设置组播MCS索引之前,需要先配置802.11n基本MCS集的最大MCS索引,并且设置的组播MCS索引不能超过配置的802.11n基本MCS集的最大MCS索引值。
# 配置802.11n模式的组播MCS索引为70。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n mandatory maximum-mcs 70
[Sysname-wlan-rrm] dot11n multicast-rate 70
undo dot11n protection enable
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11n protection enable命令用来开启802.11n保护功能。undo dot11n protection enable 命令用来恢复缺省情况。
缺省情况下,802.11n保护功能处于关闭状态。
# 开启802.11n保护功能。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n protection enable
dot11n protection-mode { cts-to-self | rts-cts }
undo dot11n protection-mode
RRM视图
【缺省级别】
2:系统级
rts-cts:RTS/CTS方式。
【描述】
dot11n protection-mode命令用来配置802.11n保护方式。undo dot11n protection-mode命令用来恢复缺省情况。
缺省情况下,802.11n保护方式为CTS-to-Self。
# 配置802.11n保护方式为RTS/CTS。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n protection-mode rts-cts
dot11n support maximum-mcs index
undo dot11n support maximum-mcs
RRM视图
【缺省级别】
2:系统级
index:指定802.11n支持MCS集的最大MCS索引,取值范围为0~最大MCS索引,目前MCS最大索引为76。
【描述】
dot11n support maximum-mcs命令用来配置802.11n支持MCS集的最大MCS索引。undo dot11n support maximum-mcs命令用来恢复缺省情况。
缺省情况下,支持MCS集的索引为76。
需要注意的是,用该命令指定的最大MCS索引不能小于dot11n mandatory maximum-mcs命令配置的基本MCS集最大索引。
# 配置802.11n的支持MCS集最大索引为25。
[sysname] wlan rrm
[sysname-wlan-rrm] dot11n support maximum-mcs 25
undo mesh calibrate-channel
RRM视图
【缺省级别】
2:系统级
无
【描述】
mesh calibrate-channel命令用来配置Mesh信道检测。undo mesh calibrate-channel命令用来恢复缺省情况。
缺省情况下,没有配置Mesh信道检测。
# 配置Mesh信道检测。
[Sysname] wlan rrm
[Sysname-wlan-rrm] mesh calibrate-channel
mesh calibrate-channel pronto mesh-profile { mesh-profile-number | all }
RRM视图
【缺省级别】
2:系统级
mesh-profile-number:Mesh Profile号,取值范围为1~32。
all:所有Mesh Profile。
【描述】
mesh calibrate-channel pronto命令用来配置手动触发Mesh自动信道调整。从RRM中获得的校准信道将在下一次优化间隔后应用到Mesh Profile上。在执行手动触发Mesh自动信道调整之前需要先配置Mesh信道检测。
缺省情况下,没有配置手动触发Mesh自动信道调整。
# 配置手动触发Mesh自动信道调整。
[Sysname] wlan rrm
[Sysname-wlan-rrm] mesh calibrate-channel pronto mesh-profile all
undo mesh calibrate-channel self-decisive
RRM视图
【缺省级别】
2:系统级
无
【描述】
mesh calibrate-channel self-decisive命令用来配置定时触发Mesh自动信道调整(同时配置了Mesh信道监测)。undo mesh calibrate-channel self-decisive命令用来恢复缺省情况。
缺省情况下,没有配置定时触发Mesh自动信道调整。
# 配置定时触发Mesh自动信道调整。
[Sysname] wlan rrm
[Sysname-wlan-rrm] mesh calibrate-channel self-decisive
power-constraint power-constraint
undo power-constraint
RRM视图
【缺省级别】
2:系统级
power-constraint:限制功率值,取值范围为0~30,单位为dBm。
【描述】
power-constraint命令用于将设置的限制功率值通知给802.11a客户端。undo power-constraint命令用来恢复缺省情况。
缺省情况下,不对802.11a客户端发送功率进行限制。
只有开启spectrum-management enable命令后,限制功率功能才能生效。配置了功率限制值后,设备会通知802.11a客户端将其最大发送功率降低power-constraint dBm。
相关配置可参考命令spectrum-management enable。
# 开启频谱管理功能,并通知802.11a客户端将其最大发送功率降低5dBm。
[Sysname] wlan rrm
[Sysname-wlan-rrm] spectrum-management enable
[Sysname-wlan-rrm] power-constraint 5
power holddown-time minutes
undo power holddown-time
RRM保持调整组视图
【缺省级别】
2:系统级
minutes:功率保持时长,表示配置自动功率调整后,功率在每次调整后的指定时间内将保持不变,取值范围为10~1440,单位为分钟。
【描述】
power holddown-time命令用来配置RRM保持调整组的自动调整功率保持时长。undo power holddown-time命令用来恢复缺省情况。
缺省情况下,功率保持时长为60分钟。
# 为RRM保持调整组10配置自动调整功率保持时长为600分钟。
[Sysname-wlan-rc-group-10] power holddown-time 600
1.1.67  scan channel
scan channel { all | auto }
undo scan channel
RRM视图
【缺省级别】
2:系统级
all:全部扫描模式,表示扫描所有信道。
auto:自动扫描模式,表示扫描国家码下设备支持的所有信道。
【描述】
scan channel命令用来配置扫描模式。undo scan channel命令用来恢复缺省情况。
缺省情况下,扫描模式为自动扫描。
# 配置扫描模式为全部扫描。
[Sysname] wlan rrm
[Sysname-wlan-rrm] scan channel all
1.1.68  scan type
scan type { active | passive }
undo scan type
RRM视图
【缺省级别】
2:系统级
active:配置为主动扫描类型。
passive:配置为被动扫描类型。
【描述】
scan type命令用来配置扫描类型。undo scan type命令用来恢复缺省情况。
缺省情况下,扫描类型为被动扫描。
# 配置扫描类型为主动扫描。
[Sysname] wlan rrm
[Sysname-wlan-rrm] scan type active
scan report-interval seconds
undo scan report-interval
RRM视图
【缺省级别】
2:系统级
seconds:报告间隔,取值范围为5~120,单位为秒。
【描述】
scan report-interval命令用来配置扫描报告间隔为指定值。undo scan report-interval命令用来恢复缺省情况。
缺省情况下,扫描报告间隔为10秒。
# 配置扫描报告间隔为20秒。
[Sysname] wlan rrm
[Sysname-wlan-rrm] scan report-interval 20
undo spectrum-management enable
RRM视图
【缺省级别】
2:系统级
无
【描述】
spectrum-management enable命令用于开启802.11a频段的频谱管理功能。undo spectrum-management enable命令用来恢复缺省情况。
缺省情况下,频谱管理功能处于关闭状态。
开启频谱管理功能后,AP会通告其功率能力和对客户端的功率限制。
相关配置可参考命令power-constraint。
# 开启频谱管理功能。
[Sysname] wlan rrm
1.1.71  wlan rrm
wlan rrm
【缺省级别】
2:系统级
无
【描述】
wlan rrm命令用来进入RRM(射频资源管理)视图。
在该视图下,用户可以进行WLAN射频资源管理的相关配置。
# 进入RRM视图。
[Sysname] wlan rrm
[Sysname-wlan-rrm]
wlan rrm-calibration-group group-id
undo wlan rrm-calibration-group { group-id | all }
【缺省级别】
2:系统级
all:所有的RRM保持调整组。
【描述】
wlan rrm-calibration-group命令用来创建RRM保持调整组,并进入RRM保持调整组视图。undo wlan rrm-calibration-group命令用来删除已创建的RRM保持调整组。
缺省情况下,不存在RRM保持调整组。
# 创建ID为10的RRM保持调整组。
1.2  负载均衡配置命令
1.2.1  ap radio
负载均衡组视图
【缺省级别】
2:系统级
ap-name:加入负载均衡组的AP名称。为1~64个字符的字符串,不区分大小写。加入负载均衡组的AP必须已经存在。
radio-number:将AP的第几个Radio加入负载均衡组。不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
all:删除负载均衡组中所有的Radio。
【描述】
ap radio命令用来将AP的Radio加入到负载均衡组中。undo ap ap-name命令用来删除负载均衡组中的Radio。
缺省情况下,负载均衡组中不存在任何AP的Radio。
删除负载均衡组中的Raido时,如果使用undo ap ap-name命令(即不指定radio radio-number参数时),表示删除负载均衡组中指定AP的所有Radio。
# 将ap1的第2个Radio加入到ID为10的负载均衡组中。
[Sysname] wlan load-balance-group 10
[Sysname-wlan-lb-group-10] ap ap1 radio 2
# 删除ID为10的负载均衡组中的所有Radio。
[Sysname-wlan-lb-group-10] undo ap all
# 删除负载均衡组10中ap1的所有Radio。
[Sysname-wlan-lb-group-10] undo ap ap1
# 删除负载均衡组10中ap1的第2个Radio。
[Sysname-wlan-lb-group-10] undo ap ap1 radio 2
1.2.2  description
负载均衡组视图
【缺省级别】
2:系统级
text:负载均衡组的描述信息,为1~64个字符的字符串,区分大小写。
【描述】
description命令用来配置负载均衡组的描述信息。undo description命令用来删除描述信息。
缺省情况下,负载均衡组没有描述信息。
# 配置负载均衡组10的描述信息为marketing。
[Sysname-wlan-lb-group10] description marketing
display wlan load-balance-group { group-id | all } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
group-id:负载均衡组的ID。不同型号的设备支持的取值范围不同,请参见“命令参考导读”中的“命令行及参数差异情况”部分的介绍。
all:显示所有负载均衡组的配置。
【描述】
display wlan load-balance-group命令用来显示负载均衡组的相关配置。
# 显示负载均衡组10的相关配置。
<Sysname> display wlan load-balance-group 10
                  Load Balance Group Information
Group ID                : 10
Description             : AA
Group members           : ap5-radio2,
                          ap4-radio2,
                          ap3-radio2,
                          ap2-radio2,
表1-6 display wlan load-balance-group命令显示信息描述表
Group ID
负载均衡组的ID
负载均衡组的描述信息
Group members
加入负载均衡组的Radio
display wlan load-balance neighbor-list ap ap-name
【缺省级别】
1:监控级
ap ap-name:指定AP的名字,为1~64个字符的字符串,不区分大小写。
【描述】
display wlan load-balance neighbor-list ap命令用来显示指定AP的所有邻居的MAC地址。
# 显示ap1的邻居的MAC地址。
<Sysname> display wlan load-balance neighbor-list ap ap1
Total entry(ies): 6
AP Neighbor List
Neighbor MAC-Address of Radio 1
0014-6c8a-43ff
0016-6F9D-61F3
0019-5B79-F04A
Neighbor MAC-Address of Radio 2
0012-e235-dc71
0011-6c2a-abcd
0013-e201-0101
表1-7 display wlan load-balance neighbor-list ap命令显示信息描述表
Total entry(ies):
AP的邻居数量
Radio 1上检测到的邻居的MAC地址
display wlan load-balance neighbor-list client mac-address
【缺省级别】
1:监控级
mac-address:指定客户端的MAC地址。
【描述】
display wlan load-balance neighbor-list client 命令用来显示指定无线客户端能扫描到的当前ac管理的射频列表。
# 显示MAC地为0014-6c8a-4322的无线客户端能扫描到的当前ac管理的射频列表。
<Sysname> display wlan load-balance neighbor-list client 0014-6c8a-4322
Total entry(ies): 3
Client Neighbor List
AP ID         RadioID
APID : 1    Radio ID : 1
APID : 1    Radio ID : 2
APID : 2    Radio ID : 1
表1-8 display wlan load-balance neighbor-list client命令显示信息描述表
Total entry(ies):
客户端邻居数量
AP ID
客户端邻居的AP ID
Radio ID
客户端邻居的Radio ID
display wlan load-balance reject-client ap ap-name
【缺省级别】
1:监控级
【描述】
display wlan load-balance reject-client ap命令用来显示指定AP的所有因负载均衡而拒绝的终端的MAC地址。
# 显示ap1的因负载均衡而拒绝的终端的MAC地址。
<Sysname> display wlan load-balance reject-client ap ap1
                    WLAN load balance rejected client
 Radio 1: 3
 BSSID          MAC            Aging time(ms) Rejections
 CC3E-5F1D-5EE0 8C70-5A7B-2B38 89900          9
 CC3E-5F1D-57C0 8C70-5A7B-2B38 80100          5
 CC3E-5F1D-57C0 0027-10BD-0338 38300          7
 Radio 2: 0
display wlan load-balance reject-client client mac-address
【缺省级别】
1:监控级
【描述】
display wlan load-balance reject-client client 命令用来显示指定无线客户端被哪些AP因负载均衡而拒绝关联。
# 显示MAC地为8C70-5A7B-2B38的无线客户端当前被哪些AP因负载均衡而拒绝接入。
<Sysname> display wlan load-balance reject-client client 8C70-5A7B-2B38
 MAC: 8C70-5A7B-2B38
AP                             BSSID          Aging time(ms) Rejections
ap1                            CC3E-5F1D-57C0 43200          3
ap2                            CC3E-5F1D-5EE0 87600          9
load-balance access-denial access-denial
undo load-balance access-denial
RRM视图
【缺省级别】
2:系统级
access-denial:拒绝客户端关联请求的最大次数,取值范围为2~10。
【描述】
load-balance access-denial命令用来配置设备拒绝客户端关联请求的最大次数。undo load-balance access-denial命令用来恢复缺省情况。
缺省情况下,设备拒绝客户端关联请求的最大次数为10。
# 配置设备拒绝客户端关联请求的最大次数为4。
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance access-denial 4
load-balance rssi-threshold rssi-threshold
undo load-balance rssi-threshold
RRM视图
【缺省级别】
2:系统级
rssi-threshold:负载均衡RSSI门限值,取值范围为5~100。
【描述】
load-balance rssi-threshold命令用来配置负载均衡RSSI门限。undo load-balance rssi-threshold命令用来恢复缺省情况。
缺省情况下,负载均衡RSSI门限值为25。
# 配置负载均衡RSSI门限值为40。
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance rssi-threshold 40
load-balance session value [ gap gap-value ]
undo load-balance
RRM视图
【缺省级别】
2:系统级
value:会话门限,取值范围为1~40。
gap gap-value:会话差值门限,取值范围为1~8,缺省值为4。
【描述】
load-balance session命令用来配置负载均衡模式为会话模式,并配置会话门限值和会话差值门限。如果当前连接的用户数量同时达到会话门限和会话差值门限,则AP会启动负载均衡。undo load-balance命令用来禁用配置的负载均衡模式。
缺省情况下,没有开启负载均衡功能。
# 配置会话门限值为7,会话差值门限为5。
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance session 7 gap 5
load-balance traffic value [ gap gap-value ]
undo load-balance
RRM视图
【缺省级别】
2:系统级
value:流量门限,以百分比表示,取值范围为1~80。
gap gap-value:流量差值门限,以百分比表示,取值范围为10~40,缺省值为20。
【描述】
load-balance traffic命令用来配置负载均衡模式为流量模式,并配置流量门限值和流量差值门限。如果当前的流量同时达到流量门限和流量差值门限,则AP会启动负载均衡。undo load-balance命令用来禁用配置的负载均衡模式。
缺省情况下,没有开启负载均衡功能。
需要注意的是:开启802.11g保护功能后会占用一定的设备带宽,这在一定程度上降低了转发性能。若用户已开启了802.11g保护功能,那么再配置负载均衡时,应该考虑802.11g保护功能的影响,适当调低负载均衡设定的流量门限(带宽)值。
相关配置可参考命令dot11g protection enable。
# 配置流量门限值为20%,流量差值门限为25%。
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance traffic 20 gap 25
wlan load-balance-group group-id
undo load-balance-group { group-id | all }
【缺省级别】
2:系统级
all:删除所有的负载均衡组。
【描述】
wlan load-balance-group命令用来创建负载均衡组,并进入负载均衡组视图。undo wlan load-balance-group命令用来删除已创建的负载均衡组。
缺省情况下,不存在负载均衡组。
# 创建ID为10的负载均衡组。
1.3  频谱导航配置命令
band-navigation aging-time aging-time
undo band-navigation aging-time
RRM视图
【缺省级别】
2:系统级
aging-time:客户端信息的老化时间,取值范围为10~600,单位为秒。
【描述】
band-navigation aging-time命令用来配置客户端信息的老化时间。undo band-navigation aging-time命令用来恢复缺省情况。
缺省情况下,客户端信息的老化时间为180秒。
# 配置客户端信息的老化时间为50秒。
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation aging-time 50
band-navigation balance access-denial access-denial
undo band-navigation balance access-denial
RRM视图
【缺省级别】
2:系统级
access-denial:设备拒绝5GHz客户端关联请求的最大次数,取值范围为1~10。
【描述】
band-navigation balance access-denial命令用来配置设备拒绝5GHz客户端关联请求的最大次数。undo band-navigation balance access-denial命令用来恢复缺省情况。
缺省情况下,不进行拒绝。
AP的5GHz射频已经处于过载状态时,如果客户端反复向AP的5GHz射频发起关联请求,且AP拒绝客户端关联请求次数达到设定的最大拒绝关联请求次数,那么该AP会认为此时该客户端不能连接到其它任何的AP,在这种情况下,AP上的5GHz射频也会接受该客户端的关联请求。
# 配置设备拒绝5GHz客户端关联请求的最大次数为5。
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation balance access-denial 5
band-navigation balance session session [ gap gap ]
undo band-navigation balance session
RRM视图
【缺省级别】
2:系统级
session:5GHz射频上客户端连接数门限,取值范围为2~40。
gap:客户端连接数差值门限,即gap = 5GHz射频上客户端的数量-2.4GHz射频上客户端的数量,取值范围为1~8。
【描述】
band-navigation balance session命令用来配置频谱导航负载均衡门限。undo band-navigation balance session命令用来恢复缺省情况。
缺省情况下,频谱导航负载均衡功能关闭。
# 配置客户端连接数门限为10,差值门限为5。
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation balance session 10 gap 5
undo band-navigation enable
RRM视图
【缺省级别】
2:系统级
无
【描述】
band-navigation enable命令用来开启全局频谱导航功能。undo band-navigation enable用来关闭全局频谱导航功能。
缺省情况下,全局频谱导航功能处于关闭状态。
只有同时开启全局和AP频谱导航功能,频谱导航功能才能在指定AP上生效。
# 开启全局频谱导航功能。
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation enable
AP模板视图
【缺省级别】
2:系统级
无
【描述】
band-navigation enable命令用来开启指定AP的频谱导航功能。undo band-navigation enable用来关闭指定AP的频谱导航功能。
缺省情况下,AP频谱导航功能处于开启状态。
# 开启AP 1的频谱导航功能。
[Sysname] wlan ap ap1 model WA3628i-AGN
[Sysname-wlan-ap-ap1] band-navigation enable
band-navigation rssi-threshold rssi-threshold
undo band-navigation rssi-threshold
RRM视图
【缺省级别】
2:系统级
rssi-threshold:频谱导航RSSI门限值,取值范围为5~100。
【描述】
band-navigation rssi-threshold命令用来配置频谱导航RSSI门限值。undo band-navigation rssi-threshold命令用来恢复缺省情况。
缺省情况下,频谱导航RSSI门限值为15。
只有当AP的5GHz射频上检测到客户端的RSSI值达到/超过配置的门限值,AP才会引导其优先接入AP的5GHz射频。若检测到客户端的RSSI值低于配置的门限值,则不会将此客户端导航至5GHz射频。
# 配置频谱导航RSSI门限值为40。
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation rssi-threshold 40
