05-IP地址配置-IP性能配置命令
本章节下载 (229.92 KB)
display ip interface [ brief [ interface-type [ interface-number ] ] | [ interface-type interface-number ] ]
interface-type interface-number:interface-type为接口类型,interface-number为接口编号。参数具体取值请参见“端口基本配置”中interface命令介绍。
brief:显示接口基本配置信息。
【描述】
display ip interface命令用来显示接口的相关信息。
# 显示VLAN接口1的相关信息。
<H3C> display ip interface Vlan-interface 1
Vlan-interface1 current state :UP
Line protocol current state :UP
Internet Address is 192.168.0.39/24 Primary
Broadcast address : 192.168.0.255
The Maximum Transmit Unit : 1500 bytes
IP packets input number: 9678, bytes: 475001, multicasts: 7
IP packets output number: 8622, bytes: 391084, multicasts: 0
TTL invalid packet number: 0
ICMP packet input number: 0
Echo reply: 0
Unreachable: 0
Source quench: 0
Routing redirect: 0
Echo request: 0
Router advert: 0
Router solicit: 0
Time exceed: 0
IP header bad: 0
Timestamp request: 0
Timestamp reply: 0
Information request: 0
Information reply: 0
Netmask request: 0
Netmask reply: 0
表1-1 display ip interface显示信息描述表
Vlan-interface1 current state |
VLAN接口1当前状态 |
Line protocol current state |
Line协议当前状态 |
Internet Address |
IP地址 |
Broadcast address |
广播地址 |
The Maximum Transmit Unit |
最大传输单元 |
IP packets input number: 9678, bytes: 475001, multicasts: 7 IP packets output number: 8622, bytes: 391084, multicasts: 0 |
输入/输出单播包数、字节数,组播包数 |
TTL invalid packet number |
收到的TTL非法的报文个数 |
ICMP packet input number: 0 Echo reply: 0 Unreachable: 0 Source quench: 0 Routing redirect: 0 Echo request: 0 Router advert: 0 Router solicit: 0 Time exceed: 0 IP header bad: 0 Timestamp request: 0 Timestamp reply: 0 Information request: 0 Information reply: 0 Netmask request: 0 Netmask reply: 0 Unknown type: 0 |
收到的ICMP报文总数,包括如下报文: Echo应答报文、不可达报文、源地址抑制报文、路由重定向报文、Echo请求报文、路由广播报文、路由请求报文、时间超期报文、IP头错报文、时间戳请求报文、时间戳响应报文、信息请求报文、信息响应报文、掩码请求报文、掩码响应报文、未知类型报文 |
undo ip address [ ip-address { mask | mask-length } [ sub ] ]
VLAN接口视图、LoopBack接口视图
ip-address:IP地址,为点分十进制格式。
mask:IP地址的子网掩码,为点分十进制格式。
mask-length:子网掩码长度。
sub:表示设置该地址为VLAN接口/LoopBack接口的从IP地址。
【描述】
ip address命令用来给VLAN接口/LoopBack接口指定IP地址和掩码。undo ip address命令用来删除VLAN接口/LoopBack接口的IP地址和掩码。
缺省情况下,所有VLAN接口/LoopBack接口的IP地址为空。
在一般情况下,一个VLAN接口/LoopBack接口配置一个IP地址即可,但为了使交换机的一个VLAN接口/LoopBack接口可以与多个子网相连,一个VLAN接口/LoopBack接口最多可以配置5个IP地址,其中一个为主IP地址,其余为从IP地址。主从地址的配置关系为:
l 当配置主IP地址时,如果接口上已经有主IP地址,则原主IP地址被删除,新配置的地址成为主IP地址。
l undo ip address命令不带任何参数表示删除该接口的所有IP地址。undo ip address ip-address { mask | mask-length }表示删除主IP地址。undo ip address ip-address { mask | mask-length } sub表示删除从IP地址。
需要注意的是,当VLAN接口被配置为通过BOOTP或DHCP分配IP地址后,则不能再给该VLAN接口配置从IP地址。
相关配置可参考命令display ip interface。
# 指定VLAN接口1的IP地址为129.12.0.1,子网掩码为255.255.255.0。
<H3C> system-view
[H3C] interface Vlan-interface 1
[H3C-Vlan-interface1] ip address 129.12.0.1 255.255.255.0
display fib
无
【描述】
display fib命令用来查看转发信息表表项。输出信息的每一行代表一条FIB表项,内容包括:目的地址/掩码长度、下一跳、当前标志、时间戳和输出接口。
# 查看FIB转发信息表项。
<H3C> display fib
Flag:
U:Usable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Reject E:Equal cost multi-path L:Generated by ARP or ESIS Destination/Mask Nexthop Flag TimeStamp Interface
10.153.17.0/24 10.153.17.99 U t[0] Vlan-interface1
10.153.18.88/32 127.0.0.1 GHU t[0] InLoopBack0
10.153.18.0/24 10.153.18.88 U t[0] LoopBack0
10.153.17.99/32 127.0.0.1 GHU t[0] InLoopBack0
127.0.0.0/8 127.0.0.1 U t[0] InLoopBack0
表2-1 display fib命令显示信息表
Destination/Mask |
目的地址/掩码长度 |
Nexthop |
转发的下一跳地址 |
Flag |
标志: "U"——代表是路由UP,可用 "G"——代表是网关路由 "H"——代表是本机路由 "B"——代表是黑洞路由 "D"——代表是动态路由 "S"——代表是静态路由 "R"——代表是被拒绝的路由,不可用 “E”——代表是多路径等价路由 "L"——代表是由ARP或ESIS生成的路由 |
TimeStamp |
时间戳 |
转发接口 |
display fib ip-address1 [ { mask1 | mask-length1 } [ ip-address2 { mask2 | mask-length2 } | longer ] | longer ]
ip-address1、ip-address2:目的IP地址,点分十进制格式。ip-address1和ip-address2共同确定一个地址范围,显示该地址范围内的FIB表项。
mask1、mask2:IP地址掩码,以点分十进制格式表示。
mask-length1、mask-length2:以整数形式表示IP地址掩码长度,取值范围为0~32。
longer:显示与特定网络/掩码对匹配的FIB表项。
【描述】
display fib ip-address命令用来查看与指定目的IP地址匹配的转发信息表表项。输出信息的每一行代表一条FIB表项,内容包括:目的地址/掩码长度、下一跳、当前标志、时间戳和输出接口。
# 查看目的地址与12.158.10.0在自然掩码范围内匹配的FIB项。
<H3C> display fib 12.158.10.0
Route Entry Count: 1
Flag:
12.158.10.0/24 12.158.10.1 U t[85391] Vlan-interface10
# 查看目的地址在12.158.10.0/24和12.158.10.6/24范围内的FIB项。
<H3C> display fib 12.158.10.0 255.255.255.0 12.158.10.6 255.255.255.0
Flag:
以上显示信息的解释请参见表2-1。
display fib acl number
number:数字表示的ACL规则,取值范围为2000~2999。
【描述】
display fib acl命令用来查看通过指定访问控制列表过滤的FIB转发信息表项。关于访问控制列表请参见“ACL”模块。
# 查看全部FIB转发信息表项。
<H3C> display fib
Flag:
211.71.75.0/24 1.1.1.2 GSU t[250763] Vlan-interface2
1.1.2.1/32 127.0.0.1 GHU t[37] InLoopBack0
127.0.0.1/32 127.0.0.1 GHU t[37] InLoopBack0
127.0.0.0/8 127.0.0.1 U t[37] InLoopBack0
1.1.1.1/32 127.0.0.1 GHU t[37] InLoopBack0
1.1.1.0/24 1.1.1.1 U t[37] Vlan-interface2
# 查看访问控制列表2001。
<H3C> display acl 2001
Basic ACL 2001, 1 rule
Acl's step is 1
rule 0 permit source 211.71.75.0 0.0.0.255
# 查看通过访问控制列表2001过滤的FIB转发信息表项。
<H3C> display fib acl 2001
Route Entry matched by access-list 2001
Summary Counts :1
Flag:
以上显示信息的解释请参见表2-1。
display fib | { begin | exclude | include } text
begin:从第一个包含指定字符串text的FIB表项开始显示。
exclude:只显示那些不包含指定字符串text的FIB表项。
include:只显示那些包含指定字符串text的FIB表项。
text:字符串。
【描述】
display fib | 命令用来根据正则表达式输出缓冲区中与指定字符串相关的FIB表项。正则表达式格式可以参见“配置文件管理”模块。
# 查看从包含字符串“169.254.0.0”那一行开始的所有行。
<H3C> display fib | begin 169.254.0.0
169.254.0.0/16 2.1.1.1 U t[0] Vlan-interface1
2.0.0.0/16 2.1.1.1 U t[0] Vlan-interface1
以上显示信息的解释请参见表2-1。
display fib ip-prefix listname
listname:前缀列表名,为字符串,其长度取值范围为1~19个字符。
【描述】
display fib ip-prefix命令用来查看通过指定前缀列表过滤的FIB转发信息表项。关于前缀列表请参见“路由协议”中的IP路由策略配置部分。
# 查看abc前缀列表。
<H3C> display ip ip-prefix abc
name index conditions ip-prefix / mask GE LE
abc 10 permit 211.71.75.0/24 -- --
# 查看全部FIB表项。
<H3C> display fib
Flag:
# 查看通过abc前缀列表过滤的FIB表项。
<H3C> display fib ip-prefix abc
Route Entry matched by prefix-list abc
Summary Counts :1
Flag:
以上显示信息的解释请参见表2-1。
display fib statistics
无
【描述】
display fib statistics命令用来查看FIB表项的总数目。
# 查看FIB表项总数。
Route Entry Count : 30
display icmp statistics
无
【描述】
display icmp statistics命令用来显示ICMP流量统计信息。
相关配置可参考命令display ip interface,reset ip statistics。
# 显示ICMP流量统计信息。
<H3C> display icmp statistics
Input: bad formats 0 bad checksum 0
echo 5 destination unreachable 0
source quench 0 redirects 0
echo reply 10 parameter problem 0
timestamp 0 information request 0
mask requests 0 mask replies 0
time exceeded 0
Output:echo 10 destination unreachable 0
echo reply 5 parameter problem 0
timestamp 0 information reply 0
time exceeded 0
表2-2 display icmp statistics 命令显示信息描述表
bad formats |
输入的格式错误报文数 |
bad checksum |
输入的校验和错误报文数 |
echo |
输入/输出的echo请求类型报文数 |
destination unreachable |
输入/输出的目的不可达报文数 |
source quench |
输入/输出的源站抑制报文数 |
redirects |
输入/输出的重定向报文数 |
echo reply |
输入/输出的echo应答报文数 |
parameter problem |
输入/输出的参数错误报文数 |
timestamp |
输入/输出的时间戳报文数 |
information request |
输入的信息请求报文数 |
mask requests |
输入/输出的掩码请求报文数 |
mask replies |
输入/输出的掩码应答报文数 |
information reply |
输出的信息应答报文数 |
time exceeded |
超时的报文数 |
display ip socket [ socktype sock-type ] [ task-id socket-id ]
sock-type:套接口类型,取值范围为1~3,分别对应于SOCK_STREAM(TCP socket)、SOCK_DGRAM(UDP socket或支持链路层访问的socket)、SOCK_RAW (RAW IP socket)。
task-id:任务号,取值范围为1~100。
socket-id:套接口号,取值范围为0~3072。
【描述】
display ip socket命令用来显示系统当前套接口信息。
# 显示套接口类型为TCP的信息。
<H3C> display ip socket socktype 1
SOCK_STREAM:
Task = VTYD(18), socketid = 1, Proto = 6,
LA = 0.0.0.0:23, FA = 0.0.0.0:0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_KEEPALIVE SO_SENDVPNID SO_SETKEEPALIVE,
socket state = SS_PRIV SS_ASYNC
Task = VTYD(18), socketid = 2, Proto = 6,
LA = 10.153.17.99:23, FA = 10.153.17.56:1161,
socket option = SO_KEEPALIVE SO_OOBINLINE SO_SENDVPNID SO_SETKEEPALIVE,
socket state = SS_ISCONNECTED SS_PRIV SS_ASYNC
Task = VTYD(18), socketid = 3, Proto = 6,
LA = 10.153.17.99:23, FA = 10.153.17.82:1121,
表2-3 display ip socket命令显示信息描述表
SOCK_STREAM |
套接口类型,共有3种套接口类型:SOCK_STREAM (TCP socket)、SOCK_DGRAM (UDP socket或支持链路层访问的socket)、SOCK_RAW (RAW IP socket) |
Task |
任务号 |
socketid |
套接口号 |
Proto |
该套接口使用的协议号 |
sndbuf |
套接口的发送缓冲区大小 |
rcvbuf |
套接口的接收缓冲区大小 |
sb_cc |
发送缓存中现有的数据大小(只有TCP会缓存数据,该值才有用) |
rb_cc |
接收缓存中现有的数据大小 |
socket option |
套接口选项 |
socket state |
套接口状态 |
display ip statistics
无
【描述】
display ip statistics命令用来显示IP流量统计信息。
# 显示IP流量统计信息。
<H3C> display ip statistics
Input: sum 7120 local 112
bad protocol 0 bad format 0
bad checksum 0 bad options 0
Output: forwarding 0 local 27
dropped 0 no route 2
compress fails 0
Fragment:input 0 output 0
dropped 0
fragmented 0 couldn't fragment 0
Reassembling:sum 0 timeouts 0
表2-4 display ip statistics命令显示信息描述表
Input: |
sum |
输入报文总数 |
Local |
输入的目的地址是本地的报文 |
bad protocol |
协议号错的报文数 |
bad format |
格式错误的报文数 |
bad checksum |
校验和错误的报文数 |
bad options |
选项错误的报文数 |
Output: |
forwarding |
转发的报文数 |
local |
本地发送报文数 |
dropped |
发送时丢弃的报文数 |
no route |
查不到路由的报文数 |
compress fails |
压缩失败的报文数 |
Fragment: |
input |
输入的分片数 |
output |
输出的分片数 |
dropped |
丢弃的分片数 |
fragmented |
成功分片的报文数 |
couldn't fragment |
不能分片的报文数 |
Reassembling: |
sum |
重组报文总数 |
timeouts |
超时的分片报文数 |
display tcp statistics
无
【描述】
display tcp statistics命令用来显示TCP连接的流量统计信息。
相关配置可参考命令display tcp status,reset tcp statistics。
# 显示TCP流量统计信息。
<H3C> display tcp statistics
Received packets:
Total: 753
packets in sequence: 412 (11032 bytes)
window probe packets: 0, window update packets: 0
checksum error: 0, offset error: 0, short error: 0
duplicate packets: 4 (88 bytes), partially duplicate packets: 5 (7 bytes)
out-of-order packets: 0 (0 bytes)
packets of data after window: 0 (0 bytes)
packets received after close: 0
ACK packets: 481 (8776 bytes)
duplicate ACK packets: 7, too much ACK packets: 0
Sent packets:
Total: 665
urgent packets: 0
control packets: 5 (including 1 RST)
window probe packets: 0, window update packets: 2
data packets: 618 (8770 bytes) data packets retransmitted: 0 (0 bytes)
ACK-only packets: 40 (28 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections: 0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Packets dropped with MD5 authentication: 0
Packets permitted with MD5 authentication: 0
表2-5 display tcp statistics显示信息描述表
Received packets |
Total |
接收报文总数 |
packets in sequence |
队列中的报文数 |
window probe packets/ window update packets |
窗口探测报文数/窗口更新报文数 |
checksum error/ offset error/ short error |
报文校验和错误数/报文长度错误数/报文太短错误数 |
duplicate packets/ partially duplicate packets |
完全重复报文数/部分重复报文数 |
out-of-order packets |
乱序报文数 |
packets of data after window |
落在接收窗口外的报文数 |
packets received after close |
在连接关闭后到达的报文数 |
ACK packets |
ACK确认报文数 |
duplicate ACK packets/ too much ACK packets |
重复的ACK确认报文数/确认了未发送数据的ACK报文数 |
Sent packets |
Total |
总计发送报文数 |
urgent packets |
紧急数据报文数 |
control packets (including 1 RST) |
控制报文数(包含1个重传数据报文) |
窗口探测报文数/窗口更新报文数 |
data packets/ data packets retransmitted |
数据报文数/报文重发数 |
ACK-only packets |
ACK报文数(28个延迟ACK报文) |
Retransmitted timeout/ connections dropped in retransmitted timeout |
重传定时器超时次数/重传次数超过限制而丢弃的连接数 |
Keepalive timeout/ keepalive probe/ Keepalive timeout, so connections disconnected |
保活定时器超时次数/发送保活探测报文数/保活探测失败丢弃连接数 |
Initiated connections/ accepted connections/ established connections |
发起连接次数/接受连接/已建立连接 |
Closed connections (dropped:\ initiated dropped: ) |
已关闭连接数目 (意外丢弃连接数\主动连接失败到对端SYN之前的次数) |
Packets dropped with MD5 authentication |
MD5验证丢弃报文数 |
Packets permitted with MD5 authentication |
MD5验证通过报文数 |
display tcp status
无
【描述】
display tcp status命令用来显示全部TCP连接的状态,使用户随时监控TCP连接。
# 显示全部TCP连接状态。
<H3C> display tcp status
*: TCP MD5 Connection
TCPCB Local Add:port Foreign Add:port State
03e37dc4 0.0.0.0:4001 0.0.0.0:0 Listening
04217174 100.0.0.204:23 100.0.0.253:65508 Established
表2-6 display tcp status命令显示信息描述表
如果某个连接前有此标识,则表示该TCP连接是采用MD5加密算法认证的连接 |
TCPCB |
TCP控制块结构的地址 |
Local Add:port |
本地IP地址:端口号 |
Foreign Add:port |
远端IP地址:端口号 |
State |
TCP连接状态 |
display udp statistics
无
【描述】
display udp statistics命令用来显示UDP流量统计信息。
相关配置可参考命令reset udp statistics。
# 显示UDP流量统计信息。
<H3C> display udp statistics
Received packets:
Total: 26320
checksum error: 0
shorter than header: 0, data length larger than packet: 0
no socket on port: 0
total broadcast or multicast packets : 25006
no socket broadcast or multicast packets: 24989
not delivered, input socket full: 0
input packets missing pcb cache: 1314
Sent packets:
Total: 7187
表2-7 display udp statistics命令显示信息描述表
Received packets: |
Total |
总计收到的UDP报文数 |
checksum error |
校验和出错的报文数 |
shorter than header, |
报文长度比报文头短的报文数 |
data length larger than packet |
报文数据长度超过了报文长的报文数 |
no socket on port |
没有SOCKET使用这个端口号的报文数 |
total broadcast or multicast packets |
总计发送的广播或多播报文数 |
no socket broadcast or multicast packets |
没有SOCKET的广播或多播报文数 |
not delivered, input socket full |
因为SOCKET缓冲已经满而没有上送的报文数 |
input packets missing pcb cache |
没有送往pcb缓冲的输入报文数 |
Sent packets: |
Total |
总计发送UDP报文数 |
ip forward-broadcast
undo ip forward-broadcast
无
【描述】
ip forward-broadcast命令用来使能接收直连网段广播报文。undo ip forward-broadcast用来禁止接收直连网段广播报文。
缺省情况下,禁止接收直连网段广播报文。
# 允许接收直连网段广播报文。
<H3C> system-view
[H3C] ip forward-broadcast
ip forward-broadcast [ acl-number ]
acl-number:访问控制列表的序号,取值范围2000~3999。
【描述】
ip forward-broadcast [ acl-number ] 命令在接口视图下配置用来使能接口转发直连网段广播报文。不带任何参数表示对所有的直连广播报文都进行转发,带参数 acl-number 表示对符合特定ACL规则的直连广播报文进行转发。undo ip forward-broadcast用来禁止接口转发直连网段广播报文。
缺省情况下,禁止接口转发直连网段广播报文。
# 允许VLAN接口1对所有直连广播报文都进行转发。
<H3C> system-view
[H3C-Vlan-interface1] ip forward-broadcast
reset ip statistics
无
【描述】
reset ip statistics命令用来清除IP统计信息。
相关配置可参考命令display ip interface,display ip statistics。
# 清除IP统计信息。
<H3C> reset ip statistics
无
【描述】
reset tcp statistics命令用来清除TCP流量统计信息。
相关配置可参考命令display tcp statistics。
# 清除TCP流量统计信息。
<H3C> reset tcp statistics
无
【描述】
reset udp statistics命令用来清除UDP流量统计信息。
# 清除UDP流量统计信息。
<H3C> reset udp statistics
undo tcp timer fin-timeout
time-value:TCP finwait定时器值,单位秒,取值范围为76~3600。
【描述】
tcp timer fin-timeout命令用来设置TCP finwait定时器。undo tcp timer fin-timeout命令用来恢复TCP finwait定时器的缺省值。
缺省情况下,TCP finwait定时器的值为675秒。
当TCP的连接状态由FIN_WAIT_1变为FIN_WAIT_2时启动finwait定时器。若finwait定时器超时前仍未收到FIN报文,则TCP连接被终止。
相关配置可参考命令tcp timer syn-timeout,tcp window。
# 配置TCP finwait定时器的值为800秒。
<H3C> system-view
[H3C] tcp timer fin-timeout 800
undo tcp timer syn-timeout
time-value:TCP synwait定时器值,单位秒,取值范围为2~600。
【描述】
tcp timer syn-timeout命令用来设置TCP synwait定时器。undo tcp timer syn-timeout命令用来恢复TCP synwait定时器的缺省值。
缺省情况下,TCP synwait定时器的值为75秒。
当发送SYN报文时,TCP启动synwait定时器,若synwait超时前未收到回应报文,则TCP连接将被终止。
相关配置可参考命令tcp timer fin-timeout,tcp window。
# 设置TCP synwait定时器为80秒。
<H3C> system-view
[H3C] tcp timer syn-timeout 80
tcp window window-size
undo tcp window
window-size:面向连接的Socket的收发缓冲区大小,单位K字节,取值范围为1~32。
【描述】
tcp window命令用来设置面向连接的Socket的收发缓冲区大小。undo tcp window命令用来恢复面向连接的Socket的收发缓冲区大小的缺省值。
缺省情况下,收发缓冲区大小为8K字节。
相关配置可参考命令tcp timer fin-timeout,tcp timer syn-timeout。
# 设置面向连接的Socket的收发缓冲区大小为3K字节。
<H3C> system-view
[H3C] tcp window 3
