03-Typical Configuration Example
HomeSupportRoutersSR8800-X SeriesConfigure & DeployConfiguration ExamplesH3C SR8800-X Routers Configuration Examples All-In-One-R838x-6W10203-Typical Configuration Example
Table of Contents
Related Documents
53-CE1 Interface Connection Configuration Examples
Example: Configuring CE1 interfaces in unchannelized E1 mode for connectivity
This configuration example is applicable to high-end routers running Release 838x or later.
As shown in Figure 1, Router A and Router B are connected through CE1 interfaces, and the links run the PPP protocol. Bind the links into an MP link through binding the links to an MP-group interface.
Figure 1 Network diagram
Analysis
·     Configure the CE1 interfaces to operate in unchannelized E1 mode. Then, the system will automatically create synchronous serial interfaces.
·     Create an MP-group interface, and assign the synchronous serial interfaces to the MP-group interface for MP bundling.
Procedures
Configuring Router A
1.     Configure CE1 interfaces:
# Configure the clock mode as master for CE1 interface E1 3/1/1. Configure it to operate in unchannelized E1 mode. Then, the system will automatically create synchronous serial interface Serial 3/1/1:0.
[RouterA] controller e1 3/1/1
[RouterA-E1 3/1/1] clock master
[RouterA-E1 3/1/1] using e1
[RouterA-E1 3/1/1] quit
# Configure the clock mode as master for CE1 interface E1 3/1/2. Configure it to operate in unchannelized E1 mode. Then, the system will automatically create a synchronous serial interface Serial 3/1/2:0.
[RouterA] controller e1 3/1/2
[RouterA-E1 3/1/2] clock master
[RouterA-E1 3/1/2] using e1
[RouterA-E1 3/1/2] quit
2.     Configure MP bundling:
# Create an MP-group interface, and assign IP address 10.1.1.1/24 to it.
[RouterA] interface mp-group 3/1/1
[RouterA-MP-group3/1/1] ip address 10.1.1.1 24
[RouterA-MP-group3/1/1] quit
# Assign Serial 3/1/1:0 to interface MP-group 3/1/1.
[RouterA] interface serial 3/1/1:0
[RouterA-Serial3/1/1:0] link-protocol ppp
[RouterA-Serial3/1/1:0] ppp mp mp-group 3/1/1
[RouterA-Serial3/1/1:0] undo shutdown
[RouterA-Serial3/1/1:0] quit
# Assign Serial 3/1/2:0 to interface MP-group 3/1/1.
[RouterA] interface serial 3/1/2:0
[RouterA-Serial3/1/2:0] link-protocol ppp
[RouterA-Serial3/1/2:0] ppp mp mp-group 3/1/1
[RouterA-Serial3/1/2:0] undo shutdown
[RouterA-Serial3/1/2:0] quit
Configuring Router B
# Configure CE1 interface E1 3/1/1 to operate in unchannelized E1 mode. Then, the system will automatically create synchronous serial interface Serial 3/1/1:0.
<RouterB> system-view
[RouterB] controller e1 3/1/1
[RouterB-E1 3/1/1] using e1
[RouterB-E1 3/1/1] quit
# Configure CE1 interface E1 3/1/2 to operate in unchannelized E1 mode. Then, the system will automatically create synchronous serial interface Serial 3/1/2:0.
[RouterB] controller e1 3/1/2
[RouterB-E1 3/1/2] using e1
[RouterB-E1 3/1/2] quit
[RouterB] interface mp-group 3/1/1
[RouterB-MP-group3/1/1] ip address 10.1.1.2 24
[RouterB-MP-group3/1/1] quit
[RouterB] interface serial 3/1/1:0
[RouterB-Serial3/1/1:0] link-protocol ppp
[RouterB-Serial3/1/1:0] ppp mp mp-group 3/1/1
[RouterB-Serial3/1/1:0] undo shutdown
[RouterB-Serial3/1/1:0] quit
[RouterB] interface serial 3/1/2:0
[RouterB-Serial3/1/2:0] link-protocol ppp
[RouterB-Serial3/1/2:0] ppp mp mp-group 3/1/1
[RouterB-Serial3/1/2:0] undo shutdown
[RouterB-Serial3/1/2:0] quit
1.     Display MP information on Router A.
[RouterA] display ppp mp
Template: MP-group3/1/1
max-bind: 31, fragment: enabled, min-fragment: 128
Master link: MP-group3/1/1, Active members: 1, Bundle Multilink
Peer's endPoint descriptor: MP-group3/1/1
Sequence format: short (rcv)/long (sent)
Bundle Up Time: 2023/05/15  09:03:16:612
0 lost fragments, 0 reordered, 0 unassigned, 0 interleaved
Sequence: 9 (rcv)/10 (sent)
Active member channels: 1 members
      Serial3/1/1:0               Up-Time:2023/05/15  09:03:16:613
      Serial3/1/2:0               Up-Time:2023/05/15  09:03:16:614
2.     Ping the peer IP address from Router A.
[RouterA] ping 10.1.1.2
Ping 10.1.1.2 (10.1.1.2): 56 data bytes, press CTRL+C to break
56 bytes from 10.1.1.2: icmp_seq=0 ttl=255 time=4.000 ms
56 bytes from 10.1.1.2: icmp_seq=1 ttl=255 time=1.000 ms
56 bytes from 10.1.1.2: icmp_seq=2 ttl=255 time=0.000 ms
56 bytes from 10.1.1.2: icmp_seq=3 ttl=255 time=7.000 ms
56 bytes from 10.1.1.2: icmp_seq=4 ttl=255 time=1.000 ms
--- Ping statistics for 10.1.1.2 ---
round-trip min/avg/max/std-dev = 0.000/2.600/7.000/2.577 ms
The output indicates that Router A and Router B have successfully connected through the CE1 interfaces in unchannelized E1 mode.
Configuration files
·     Router A:
controller E1 3/1/1
 clock master
 using e1
controller E1 3/1/2
 clock master
 using e1
interface Serial3/1/1:0
 ppp mp MP-group3/1/1
 link-protocol ppp
interface Serial3/1/2:0
 link-protocol ppp
interface MP-group3/1/1
·     Router B:
controller E1 3/1/1
 using e1
controller E1 3/1/2
 using e1
 link-protocol ppp
 link-protocol ppp
Example: Configuring CE1 interfaces in channelized CE1 mode for connectivity
As shown in Figure 2, Router A and Router B are connected through CE1 interfaces, and the links run the PPP protocol. Bind the links into an MP link through binding the links to an MP-group interface.
Figure 2 Network diagram
Analysis
·     Configure the CE1 interfaces to operate in channelized CE1 mode, and bind the timeslots of each CE1 interface into a channel set. Then, the system will automatically create synchronous serial interfaces.
When binding the timeslots of the CE1 interfaces on Router A and Router B, make sure the bound timeslots are consistent on both ends.
Procedures
# Configure the clock mode as master for CE1 interface E1 3/1/1. Configure it to operate in channelized CE1 mode, and bind timeslots 1 through 15 of interface E1 3/1/1 into channel set 1. Then, the system will automatically create synchronous serial interface Serial 3/1/1:1.
[RouterA-E1 3/1/1] using ce1
[RouterA-E1 3/1/1] channel-set 1 timeslot-list 1-15
# Configure the clock mode as master for CE1 interface E1 3/1/2. Configure it to operate in channelized CE1 mode, and bind timeslots 1 through 15 of interface E1 3/1/2 into channel set 1. Then, the system will automatically create synchronous serial interface Serial 3/1/2:1.
[RouterA-E1 3/1/2] using ce1
[RouterA-E1 3/1/2] channel-set 1 timeslot-list 1-15
# Assign Serial 3/1/1:1 to interface MP-group 3/1/1.
[RouterA] interface serial 3/1/1:1
[RouterA-Serial3/1/1:1] link-protocol ppp
[RouterA-Serial3/1/1:1] ppp mp mp-group 3/1/1
[RouterA-Serial3/1/1:1] undo shutdown
[RouterA-Serial3/1/1:1] quit
# Assign Serial 3/1/2:1 to interface MP-group 3/1/1.
[RouterA] interface serial 3/1/2:1
[RouterA-Serial3/1/2:1] link-protocol ppp
[RouterA-Serial3/1/2:1] ppp mp mp-group 3/1/1
[RouterA-Serial3/1/2:1] undo shutdown
[RouterA-Serial3/1/2:1] quit
# Configure CE1 interface E1 3/1/1 to operate in channelized CE1 mode, and bind timeslots 1 through 15 of interface E1 3/1/1 into channel set 1. Then, the system will automatically create synchronous serial interface Serial 3/1/1:1.
[RouterB-E1 3/1/1] using ce1
[RouterB-E1 3/1/1] channel-set 1 timeslot-list 1-15
# Configure CE1 interface E1 3/1/2 to operate in channelized CE1 mode, and bind timeslots 1 through 15 of interface E1 3/1/2 into channel set 1. Then, the system will automatically create synchronous serial interface Serial 3/1/2:1.
[RouterB-E1 3/1/2] using ce1
[RouterB-E1 3/1/2] channel-set 1 timeslot-list 1-15
[RouterB] interface serial 3/1/1:1
[RouterB-Serial3/1/1:1] link-protocol ppp
[RouterB-Serial3/1/1:1] ppp mp mp-group 3/1/1
[RouterB-Serial3/1/1:1] undo shutdown
[RouterB-Serial3/1/1:1] quit
[RouterB] interface serial 3/1/2:1
[RouterB-Serial3/1/2:1] link-protocol ppp
[RouterB-Serial3/1/2:1] ppp mp mp-group 3/1/1
[RouterB-Serial3/1/2:1] undo shutdown
[RouterB-Serial3/1/2:1] quit
  Sequence format: long (rcv)/long (sent)
  Bundle Up Time: 2023/05/16  10:23:08:696
  0 lost fragments, 5 reordered, 0 unassigned, 0 interleaved
  Sequence: 4 (rcv)/5 (sent)
        Serial3/1/1:1            Up-Time:2023/05/16  10:23:08:697
        Serial3/1/2:1            Up-Time:2023/05/16  10:23:08:700
[RouterA] ping 20.1.1.2
Ping 20.1.1.2 (20.1.1.2): 56 data bytes, press CTRL+C to break
56 bytes from 20.1.1.2: icmp_seq=0 ttl=255 time=4.000 ms
56 bytes from 20.1.1.2: icmp_seq=1 ttl=255 time=1.000 ms
56 bytes from 20.1.1.2: icmp_seq=2 ttl=255 time=0.000 ms
56 bytes from 20.1.1.2: icmp_seq=3 ttl=255 time=7.000 ms
56 bytes from 20.1.1.2: icmp_seq=4 ttl=255 time=1.000 ms
--- Ping statistics for 20.1.1.2 ---
The output indicates that Router A and Router B have successfully connected through the CE1 interfaces in channelized CE1 mode.
Configuration files
·     Router A:
controller E1 3/1/1
 clock master
controller E1 3/1/2
 clock master
interface Serial3/1/1:1
 link-protocol ppp
 link-protocol ppp
 ip address 20.1.1.1 255.255.255.0
·     Router B:
controller E1 3/1/1
controller E1 3/1/2
 link-protocol ppp
interface Serial3/1/2:1
 link-protocol ppp
 ip address 20.1.1.2 255.255.255.0
