03-Typical Configuration Example
HomeSupportRoutersSR8800-X SeriesConfigure & DeployConfiguration ExamplesH3C SR8800-X Routers Configuration Examples All-In-One-R838x-6W10203-Typical Configuration Example
Table of Contents
Related Documents
47-H3C_OSPF_Multi-Process_Configuration_Examples
Example: Configuring the OSPF multi-process feature
As shown in Figure 1, Device A and Device B establish a neighbor relationship in OSPF process 100, and Device B and Device C establish a neighbor relationship in OSPF process 200. Device A and Device C cannot learn routes from each other through OSPF.
Figure 1 Network diagram
Procedures
Configuring Device A
# Specify DeviceA as the device name.
[Sysname] sysname DeviceA
# Enable OSPF process 100 and specify the interface whose primary IP address is on network 172.10.1.0/24 to run OSPF.
[DeviceA] ospf 100 router-id 1.1.1.9
[DeviceA-ospf-100] area 0.0.0.0
[DeviceA-ospf-100-area-0.0.0.0] network 172.10.1.0 0.0.0.255
[DeviceA-ospf-100-area-0.0.0.0] quit
[DeviceA-ospf-100] quit
Configuring Device B
# Specify DeviceB as the device name.
[Sysname] sysname DeviceB
[DeviceB] ospf 100 router-id 2.2.2.9
[DeviceB-ospf-100] area 0.0.0.0
[DeviceB-ospf-100-area-0.0.0.0] network 172.10.1.0 0.0.0.255
[DeviceB-ospf-100-area-0.0.0.0] quit
[DeviceB-ospf-100] quit
# Enable OSPF process 200 and specify the interface whose primary IP address is on network 131.108.1.0/24 to run OSPF.
[DeviceB] ospf 200 router-id 2.2.2.9
[DeviceB-ospf-200] area 0.0.0.0
[DeviceB-ospf-200-area-0.0.0.0] network 131.108.1.0 0.0.0.255
[DeviceB-ospf-200-area-0.0.0.0] quit
[DeviceB-ospf-200] quit
Configuring Device C
# Specify DeviceC as the device name.
[Sysname] sysname DeviceC
[DeviceC] ospf 200 router-id 3.3.3.9
[DeviceC-ospf-200] area 0.0.0.0
[DeviceC-ospf-200-area-0.0.0.0] network 131.108.1.0 0.0.0.255
[DeviceC-ospf-200-area-0.0.0.0] quit
[DeviceC-ospf-200] quit
# Execute the display ospf peer command on Device B to verify that Device A and Device C have already established a neighbor relationship.
[DeviceB] display ospf peer
         OSPF Process 100 with Router ID 2.2.2.9
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time  State             Interface
 1.1.1.9         172.10.1.1      1   30         Full/DR           XGE3/1/1
         OSPF Process 200 with Router ID 2.2.2.9
 Area: 0.0.0.0
 3.3.3.9         131.108.1.1     1   39         Full/BDR          XGE3/1/2
# Execute the display ip routing-table command on Device A to verify that Device A does not have a route to 131.108.1.0/24.
[DeviceA] display ip routing-table
Destinations : 11       Routes : 11
1.1.1.9/32         Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
172.10.1.0/24      Direct  0   0           172.10.1.1      XGE3/1/1
172.10.1.0/32      Direct  0   0           172.10.1.1      XGE3/1/1
172.10.1.1/32      Direct  0   0           127.0.0.1       InLoop0
172.10.1.255/32    Direct  0   0           172.10.1.1      XGE3/1/1
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
# Execute the display ip routing-table command on Device C to verify that Device C does not have a route to 172.10.1.0/24.
# Execute the display ip routing-table command on Device C.
3.3.3.9/32         Direct  0   0           127.0.0.1       InLoop0
131.108.1.0/24     Direct  0   0           131.108.1.1     XGE3/1/2
131.108.1.0/32     Direct  0   0           131.108.1.1     XGE3/1/2
131.108.1.1/32     Direct  0   0           127.0.0.1       InLoop0
131.108.1.255/32   Direct  0   0           131.108.1.1     XGE3/1/2
Configuration files
·     Device A:
 sysname DeviceA
 area 0.0.0.0
interface Ten-GigabitEthernet3/1/1
 ip address 172.10.1.2 255.255.255.0
·     Device B:
 sysname DeviceB
 area 0.0.0.0
 area 0.0.0.0
 ip address 172.10.1.1 255.255.255.0
interface Ten-GigabitEthernet3/1/2
 ip address 131.108.1.3 255.255.255.0
·     Device C:
 sysname DeviceC
 area 0.0.0.0
 ip address 131.108.1.1 255.255.255.0
Related documentation
·     H3C SR8800-X Routers Layer—3 IP Routing Configuration Guide-R8380
·     H3C SR8800-X Routers Layer—3 IP Routing Command Reference-R8380
