HomeSupportConfigure & DeployConfiguration GuidesH3C S6805 & S6825 & S6850 & S9850 Configuration Guides-Release 6715-6W10001-Fundamentals Configuration Guide
11-Preprovisioning feature configuration
11-Preprovisioning feature configuration 51.11 KB
Configuring preprovisioning
About preprovisioning
Preprovisioning allows you to preconfigure offline modules. The modules refer to member devices in this chapter.
When a preprovisioned module comes online, the preprovisioned settings are applied. After the module goes offline, you can continue to change the existing settings or add new settings for the module. The final settings are applied when the module comes online again.
Restrictions and guidelines: Preprovisioning
For the preprovisioned settings to survive a reboot, you must use the save command to save the settings to the next-startup configuration file.
Enabling preprovisioning
2.     Select the slot to preprovision and enter slot view.
slot slot-number
3.     Enable preprovisioning on the slot.
provision model model
By default, preprovisioning is disabled.
The specified model must be the same as the model of the module you want to install. If not, the preprovisioned settings cannot be applied to the module.
4.     Enable preprovisioning on a subslot for a subcard.
provision subslot subslot-number model model
The specified model must be the same as the model of the subcard you want to install. If not, the preprovisioned settings cannot be applied to the subcard.
Only the S9850-4C and S6850-2C switches support enabling preprovisioning on a subslot.
CAUTION
CAUTION:
·     When you disable preprovisioning on a slot, the device removes all preprovisioned commands for the slot, including the preprovisioned commands on the subslots.
·     When you disable preprovisioning on a subslot, the device removes preprovisioned commands for the subslot.
Display and maintenance commands for preprovisioned settings
Execute display commands in any view. Execute the reset command in user view.
Display preprovisioned-commands application failure records.
display provision failed-config
Clear preprovisioned-commands application failure records.
reset provision failed-config
