- 03-Security Configuration Guide
- 01-Security zone configuration
- 02-Security policy configuration
- 03-ASPF configuration
- 04-Session management
- 05-Object group configuration
- 06-IP source guard configuration
- 07-AAA configuration
- 08-User identification configuration
- 10-Portal configuration
- 11-MAC authentication configuration
- 12-SMS configuration
- 13-802.1X configuration
- 14-Public key management
- 15-PKI configuration
- 16-SSH configuration
- 17-SSL configuration
- 18-Connection limit configuration
- 19-Attack detection and prevention configuration
- 20-Server connection detection configuration
- 21-ARP attack protection configuration
- 22-ND attack defense configuration
- 23-uRPF configuration
- 24-IP-MAC binding configuration
- 25-Keychain configuration
- 26-MAC learning through a Layer 3 device configuration
- 27-APR configuration
- 28-IPoE configuration
- 29-Crypto engine configuration
- 30-Location identification configuration
- 31-Terminal identification configuration
| 30-Location identification configuration | 182.14 KB |
Configuring location identification
Location identification tasks at a glance
Updating the location signature library
Display and maintenance commands for location identification
Example: Configuring location identification
About location identification
This feature identifies the locations of the source and destination IP addresses of packets and works with a security policy to implement location-based packet control.
A location in this feature refers to a set of IP addresses in the location. You can add locations and their IP addresses to the location identification module by loading a location signature file or manually configuring locations. The device determines the source and destination locations of packets by examining the source and destination IP addresses of the packets. Then, the device works with a security policy to implement location-based packet control.
Figure 1 Location identification
To configure location identification, perform the following tasks:
2. Configuring a location group
3. Updating the location signature library
Locations include the following types:
· Predefined locations—Locations defined in the location signature library, including countries, provinces, and cities.
· User-defined locations—Locations created by the user. This type of location can be used to define a smaller geographical area, such as a district or a street in a city.
· Unknown location—A particular location in the location signature library, which is used to store IP addresses that do not have a location.
The name of a user-defined location cannot be the same as that of a predefined location.
The IPv4 addresses in different locations cannot be overlapping.
When manually added IPv4 addresses overlap with predefined IPv4 addresses, the predefined IPv4 addresses do not take effect.
Only user-defined locations can be configured with the longitude and latitude.
1. Enter system view.
2. Enter location view.
geo-location { unknown | { pre-defined | user-defined } geo-location-name }
3. Add IPv4 addresses to the location.
ip address { ip-address { mask-length | mask } | range ip-address1 ip-address2 }
By default, only a predefined location or the unknown location contains IPv4 addresses.
The undo ip address command can only remove manually added IPv4 addresses.
4. (Optional.) Specify the longitude and latitude of the location.
coordinate longitude longitude-value latitude latitude-value
By default, the longitude and latitude are not specified.
5. (Optional.) Configure a description for the location.
By default, no description is configured.
You can add multiple locations to a location group to process the packets of the locations in the same way. You can also add a location group to another location group.
Two location groups cannot contain each other at the same time.
The system supports a maximum of three location group hierarchy layers. For example, if groups 1 and 2 are members of groups 2 and 3, respectively, group 3 cannot have members and group 1 cannot be members of another group.
2. Enter location group view.
geo-location-group geo-location-group-name
3. Add a location to the location group.
add geo-location geo-location-name
By default, a location group does not contain any locations.
4. Add a location group to the location group.
add geo-location-group geo-location-group-name
By default, a location group does not contain any location groups.
5. (Optional.) Configure a description for the location group.
The location signature library contains predefined countries, provinces, and cities as locations and contains public IP addresses of each location. The device is loaded with a location signature file by default. To update the location signature library, copy the latest signature file from the official website to the local root directory and load it.
2. Load a location signature file to update the location signature library.
geo-load file-name
Task |
Command |
Display information about locations. |
display geo-location { all | type { pre-defined | unknown | user-defined } | name geo-location-name } |
Display the location of an IP address. |
display geo-location ip ip-address |
Display information about location groups. |
display geo-location-group [ name geo-location-group-name ] |
See "Configuring security policies."
