06-HH3C-MPLSEXT-MIB | 96.24 KB |
HH3C-MPLSEXT-MIB
About this MIB
Use this MIB to manage MPLS and LDP capabilities and MPLS BFD sessions.
MIB file name
rfc3812-mpls-te-std.mib
Notifications
mplsTunnelUp
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.10.166.3.0.1 |
A tunnel comes up. |
Recovery |
Warning |
1.3.6.1.2.1.10.166.3.2.2.1.34 (mplsTunnelAdminStatus) |
ON |
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
A tunnel comes up.
Recovery
Warning
ON
A notification sent when the operational state (indicated by the mplsTunnelOperStatus object) of a tunnel changes from down to another value (except for notPresent).
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Object
OID (object name) |
Index |
Type |
Value range |
Administrative state of the tunnel. |
No |
INTEGER |
up(1) , down(2) , testing(3) |
1.3.6.1.2.1.10.166.3.2.2.1.35 (mplsTunnelOperStatus) |
Actual state of the tunnel. |
No |
INTEGER |
up(1) , down(2) , testing(3) , unknown(4) , dormant(5) , notPresent(6) , lowerLayerDown(7) |
Recommended action
No action is required.
mplsTunnelDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.3.0.2 |
The operation state of a tunnel becomes down. |
Error |
Major |
ON |
System impact
OID
Event
Severity
Default status
Error
Major
ON
A notification sent when the operational state (indicated by the mplsTunnelOperStatus object) of a tunnel changes to down from another value (except for notPresent).
【System impact】
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
No |
INTEGER |
Operational state of the tunnel. |
No |
INTEGER |
Recommended action
To resolve this issue:
1.Verify that the tunnel settings are correct.
2.If the issue persists, contact H3C Support.
mplsTunnelRerouted
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.3.0.3 |
A tunnel is rerouted. |
Informational |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Informational
Warning
ON
A notification sent when a tunnel is rerouted. If the mplsTunnelARHopTable is used, the tunnel entry in the mplsTunnelARHopTable might contain the new path of the tunnel for a time period after the agent sends this notification.
【System impact】
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
No |
INTEGER |
No |
INTEGER |
Recommended action
mplsTunnelReoptimized
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.3.0.4 |
A tunnel is reoptimized. |
Informational |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Informational
Warning
ON
A notification sent when a tunnel is reoptimized. If the mplsTunnelARHopTable is used, the tunnel entry in the mplsTunnelARHopTable might contain the new path of the tunnel for a time period after the agent sends this notification.
【System impact】
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
No |
INTEGER |
No |
INTEGER |
Recommended action
1.Check the new path of the tunnel.
