08-MPLS
HomeSupportSwitchesS12500R SeriesDiagnose & MaintainAlarms ReferencesH3C S12500R Switch Router Series Alarms References(R52xx)-6W10008-MPLS
01-MPLS-FRR-FACILITY-STD-MIB
01-MPLS-FRR-FACILITY-STD-MIB 82.10 KB
About this MIB
Use this MIB to manage tunnels on the MPLS interfaces configured for FRR protection.
MIB file name
rfc6445-mpls-frr-facility-std.mib
Notifications
mplsFrrFacilityInitialBackupTunnelInvoked
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.204.0.1
Interface failed and bypass tunnel took over.
Error
Major
1.3.6.1.2.1.204.1.7.1.7 (mplsFrrFacilityDBNumProtectingTunnelOnIf)
ON
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.204.0.1
Error
Major
ON
This notification is generated when a bypass tunnel specified in mplsFrrConstraintsTable takes over the primary tunnel running over an interface also specified in the mplsFrrConstraintsTable.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Object
OID (object name)
Index
Value range
Number of bypass tunnels on an interface for protection.
No
Gauge32
Standard MIB values.
1.3.6.1.2.1.204.1.7.1.8
 (mplsFrrFacilityDBNumProtectedLspOnIf)
Number of CRLSPs protected on the interface.
No
Gauge32
1.3.6.1.2.1.204.1.7.1.9
 (mplsFrrFacilityDBNumProtectedTunnels)
Number of tunnels protected on the interface.
No
Gauge32
1.3.6.1.2.1.204.1.7.1.10
 (mplsFrrFacilityDBProtectingTunnelStatus)
State of a bypass tunnel on the interface.
No
INTEGER
active(1), ready(2)
1.3.6.1.2.1.204.1.7.1.11 (mplsFrrFacilityDBProtectingTunnelResvBw)
Amount of bandwidth reserved by a bypass tunnel on the interface.
No
Unsigned32
Recommended action
No action is required.
mplsFrrFacilityFinalTunnelRestored
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.204.0.2
Interface recovered and primary tunnel recovered.
Recovery
Warning
ON
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.204.0.2
Recovery
Warning
ON
This notification is generated when the primary tunnel that is being protected by a bypass tunnel as specified in the mplsFrrConstraintsTable restores normal operation.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Number of bypass tunnels for FRR facility backup.
No
Unsigned32
Number of LSPs protected by FRR facility backup.
No
Unsigned32
Number of tunnels protected by FRR facility backup.
No
Unsigned32
State of a bypass tunnel for FRR facility backup.
No
Integer32
active(1), ready(2)
Amount of bandwidth reserved by the bypass tunnel for FRR facility backup.
No
Unsigned32
Recommended action
