05-TE-MIB | 84.68 KB |
TE-MIB
About this MIB
Use this MIB to manage TE tunnel interface and explicit path settings.
MIB file name
rfc3970-te.mib
Notifications
teTunnelUp
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.122.0.1 |
TE tunnel up |
Recovery |
Warning |
ON |
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.122.0.1
TE tunnel up
Recovery
Warning
ON
This notification is generated when the tunnel specified by teTunnelName transitions to the up state.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.122.1.2.1.2 (teTunnelName) |
TE tunnel name |
No |
SnmpAdminString |
OCTET STRING (SIZE (1..32)) |
1.3.6.1.2.1.122.1.3.1.2 (tePathName) |
Name of the TE tunnel's path |
No |
SnmpAdminString |
OCTET STRING (SIZE (0..32)) |
Recommended action
No action is required.
teTunnelDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.122.0.2 |
TE tunnel down |
Error |
Major |
ON |
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.122.0.2
TE tunnel down
Error
Major
ON
This notification is generated when the tunnel specified by teTunnelName transitions to the down state.
【System impact】
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
TE tunnel name |
No |
SnmpAdminString |
No |
SnmpAdminString |
Recommended action
teTunnelChanged
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.122.0.3 |
TE tunnel path change |
Informational |
Warning |
ON |
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.122.0.3
Informational
Warning
ON
This notification is generated when the active path on the tunnel specified by teTunnelName changes or a new path becomes active. The value of tePathName is the new active path.
【System impact】
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
TE tunnel name |
No |
SnmpAdminString |
No |
SnmpAdminString |
Recommended action
