08-MPLS
HomeSupportSwitchesS12500R SeriesDiagnose & MaintainAlarms ReferencesH3C S12500R Switch Router Series Alarms References(R52xx)-6W10008-MPLS
04-MPLS-LSR-STD-MIB
04-MPLS-LSR-STD-MIB 76.85 KB
MPLS-LSR-STD-MIB
About this MIB
A label switching router (LSR) is a router that performs MPLS forwarding. Based on the traditional routing table, LSRs establish label switching paths through a label distribution protocol to perform fast label switching.
MPLS-LSR-STD-MIB is a standard MIB based on RFC 3813.
MIB file name
rfc3813-mpls-lsr-std.mib
Notifications
mplsXCUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.10.166.2.0.1
mplsXCup
Recovery
Warning
ON
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
mplsXCup
Recovery
Warning
ON
A notification sent when the cross-connect for a tunnel enters up state. The cross-connect state is indicated by the mplsXCOperStatus object.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.10.166.2.1.10.1.9 (mplsXCAdminStatus)
Operational status of the label.
No
INTEGER
up(1) , down(2) , testing(3)
1.3.6.1.2.1.10.166.2.1.10.1.10 (mplsXCOperStatus)
Actual operational status of the cross-connect.
No
INTEGER
up(1) , down(2) ,  testing(3) , unknown(4) , dormant(5) , notPresent(6) , lowerLayerDown(7)
Recommended action
No action is required.
mplsXCDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.2.0.2
A cross-connect enters down state.
Recovery
Major
ON
System impact
OID
Event
Severity
Default status
Recovery
Major
ON
A notification sent when the cross-connect for a tunnel enters down state. The cross-connect state is indicated by the mplsXCOperStatus object.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
No
INTEGER
No
INTEGER
Recommended action
