08-MPLS
HomeSupportSwitchesS12500R SeriesDiagnose & MaintainAlarms ReferencesH3C S12500R Switch Router Series Alarms References(R52xx)-6W10008-MPLS
02-MPLS-L3VPN-STD-MIB
02-MPLS-L3VPN-STD-MIB 108.53 KB
MPLS-L3VPN-STD-MIB
About this MIB
Use this MIB to obtain MPLS VPN information.
MIB file name
rfc4382-mpls-l3vpn-std.mib
Notifications
mplsL3VpnVrfUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.10.166.11.0.1
An interface associated with a VRF comes up.
Recovery
Warning
ON
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
A notification sent when the following conditions exist:
No interface is associated with this VRF. The value of the ifOperStatus object for the first (and only the first) interface associated with it changes to up(1).
One interface is associated with this VRF. The value of the ifOperStatus object for the interface changes to up(1).
Multiple interfaces are associated with this VRF. The value of the ifOperStatus object for all interfaces except for the first one is down(2), and the value of the ifOperStatus object for the first interface changes to up(1).
System impact
Status control
ON
CLI: Use the snmp-agent trap enable l3vpn command.
OFF
CLI: Use the undo snmp-agent trap enable l3vpn command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.10.166.11.1.2.1.1.5 (mplsL3VpnIfConfRowStatus)
Row status used to create, modify, and delete a row in this table.
No
INTEGER
active(1)
1.3.6.1.2.1.10.166.11.1.2.2.1.6 (mplsL3VpnVrfOperStatus)
Operational state of the VPN.
No
INTEGER
up(1), down(2)
Recommended action
No action is required.
mplsL3VpnVrfDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.11.0.2
An interface associated with a VRF goes down.
Error
Major
ON
System impact
OID
Event
Severity
Default status
Error
Major
ON
One interface is associated with this VRF. The value of the ifOperStatus object for the interface changes from up to down.
Multiple interfaces are associated with this VRF. The value of the ifOperStatus object for all interfaces except for the first one is up, and the value of the ifOperStatus object for the first interface changes from up to down.
The last interface whose ifOperStatus value is up disassociates from this VRF.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
No
INTEGER
active(1)
No
INTEGER
up(1), down(2)
Recommended action
mplsL3VpnVrfRouteMidThreshExceeded
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.11.0.3
The number of routes in a VRF exceeds the value indicated by mplsL3VpnVrfMidRouteThreshold.
Error
Warning
ON
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when the number of routes in a VRF exceeds the value indicated by mplsL3VpnVrfMidRouteThreshold. Only one notification is generated when this threshold is exceeded. No more notifications of this type will be generated until the value of mplsL3VpnVrfPerfCurrNumRoutes falls below that of mplsL3VpnVrfConfMidRteThresh.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.10.166.11.1.3.1.1.3 (mplsL3VpnVrfPerfCurrNumRoutes)
Total number of active IPv4 and IPv6 routes.
No
Gauge32
INTEGER(0..4294967295)
1.3.6.1.2.1.10.166.11.1.2.2.1.9 (mplsL3VpnVrfConfMidRteThresh)
Mid-level water marker for the number of routes that this VRF supports.
No
Unsigned32
Standard MIB values.
Recommended action
mplsL3VpnVrfNumVrfRouteMaxThreshExceeded
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.11.0.4
The number of routes in a VRF exceeds or about to exceed the maximum allowed value as indicated by mplsL3VpnVrfMaxRouteThreshold.
Error
Warning
1.3.6.1.2.1.10.166.11.0.6 (1.3.6.1.2.1.10.166.11.0.6)
ON
System impact
OID
Event
Severity
Default status
Error
Warning
ON
A notification sent when the number of routes in a VRF exceeds or about to exceed the maximum allowed value as indicated by mplsL3VpnVrfMaxRouteThreshold. If mplsL3VpnVrfConfHighRteThresh is set to the same value as mplsL3VpnVrfConfMaxRoutes, this notification is generated when mplsL3VpnVrfConfHighRteThresh is reached.
mplsL3VpnVrfConfRteMxThrshTime defines the interval at which this notification is regenerated after the maximum value has been exceeded (or reached if mplsL3VpnVrfConfMaxRoutes and mplsL3VpnVrfConfHighRteThresh are equivalent) and the initial notification has been sent. This interval prevents continuous generation of notifications by an agent when routes are continually added to a VRF after it has reached its maximum value. The default value is 0. If this value is set to 0, the agent generates a single notification when the maximum threshold has been reached and does not generate any more notifications until the number of routes falls below the configured threshold.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
No
Gauge32
1.3.6.1.2.1.10.166.11.1.2.2.1.10 (mplsL3VpnVrfConfHighRteThresh)
High-level water marker for the number of routes that the VRF supports.
No
Unsigned32
Recommended action
mplsL3VpnNumVrfRouteMaxThreshCleared
Basic information
OID
Event
Severity
Default status
The number of routes in a VRF falls below the value of the mplsVrfMaxRouteThreshold object.
Informational
Warning
ON
System impact
OID
Event
Severity
Default status
Informational
Warning
ON
This notification is generated only after the number of routes in a VRF exceeds or about to exceed the maximum allowed value as indicated by the mplsVrfMaxRouteThreshold object and then falls below this value. The notification informs the operator that the error has been cleared and the operator does not need to check the device.
mplsL3VpnVrfConfRteMxThrshTime defines the interval at which the mplsNumVrfRouteMaxThreshExceeded notification will be regenerated after the maximum value has been exceeded (or reached if mplsL3VpnVrfConfMaxRoutes and mplsL3VpnVrfConfHighRteThresh are equivalent) and the initial notification has been sent. The generation of this notification will be triggered with the same frequency (assuming that the error condition is cleared). If the error condition is reached and cleared several times during the period of time specified in mplsL3VpnVrfConfRteMxThrshTime, only a single notification will be generated to indicate the first instance of the error condition as well as the first time the error condition is cleared.
This prevents continuous generation of notifications by an agent in the event that routes are continually added to or removed from a VRF after it has reached its maximum value. The default value is 0. If this value is set to 0, the agent sends a notification whenever the maximum threshold has been cleared.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
No
Gauge32
No
Unsigned32
Recommended action
