03-MPLS-LDP-STD-MIB | 89.13 KB |
MPLS-LDP-STD-MIB
About this MIB
LDP is the core of MPLS and defines the messages and processing procedures involved in the label distribution process.
The Label Distribution Protocol (LDP) dynamically distributes FEC-label mapping information between LSRs to establish LSPs. LSPs can be established between two adjacent LSRs or terminate at the egress node of the network, so that all intermediate nodes in the network use label switching.
MPLS-LDP-STD-MIB is a public MIB defined by RFC 3815.
MIB file name
rfc3815-mpls-ldp-std.mib
Notifications
mplsLdpInitSessionThresholdExceeded
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.10.166.4.0.1 |
The number of session initialization messages exceeds the limit. |
Error |
Major |
1.3.6.1.2.1.10.166.4.1.2.3.1.11 (mplsLdpEntityInitSessionThreshold) |
ON |
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
Error
Major
ON
A notification sent when the value of the mplsLdpEntityInitSessionThreshold object is not zero and the number of session initialization messages exceeds the value of the mplsLdpEntityInitSessionThreshold object.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable ldp command.
OFF
CLI: Use the undo snmp-agent trap enable ldp command.
Object
OID (object name) |
Index |
Type |
Value range |
During the session establishment with an LDP peer, if the number of session initialization messages sent by the LDP entity exceeds the maximum value defined by the mplsLdpInitSessionThresholdExceeded object, the LDP entity will send notifications. |
No |
Integer32 |
0..100 |
Recommended action
To resolve this issue:
1.Check LDP session initialization message parameters.
2.If the issue persists, contact H3C Support.
mplsLdpSessionUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.4.0.3 |
The session state changes to operational. |
Recovery |
Warning |
ON |
System impact
OID
Event
Severity
Default status
Recovery
Warning
ON
A notification sent when the value of the mplsLdpSessionState object changes to operational(5).
【System impact】
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.10.166.4.1.3.3.1.2 (mplsLdpSessionState) |
LDP session state. |
No |
INTEGER |
nonexistent(1) , initialized(2) , openrec(3) , opensent(4) , operational(5)) |
1.3.6.1.2.1.10.166.4.1.3.3.1.8 (mplsLdpSessionDiscontinuityTime) |
Time when the LDP session is up. |
No |
Timeticks |
Standard MIB values. |
1.3.6.1.2.1.10.166.4.1.3.4.1.1 (mplsLdpSessionStatsUnknownMesTypeErrors) |
Number of unknown messages detected by the LSR during the session. |
No |
Counter32 |
1.3.6.1.2.1.10.166.4.1.3.4.1.2 (mplsLdpSessionStatsUnknownTlvErrors) |
Number of unknown TLVs detected by the LSR during the session. |
No |
Counter32 |
Recommended action
No action is required.
mplsLdpSessionDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.4.0.4 |
The session state is not operational. |
Error |
Major |
ON |
System impact
OID
Event
Severity
Default status
Error
Major
ON
A notification sent when the value of the mplsLdpSessionState object is not operational.
【System impact】
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Session state. |
No |
INTEGER |
System time when a counter of the LDP session suffered a discontinuity. |
No |
Timeticks |
No |
Counter32 |
No |
Counter32 |
Recommended action
