06-Layer 3 - IP Services
HomeSupportRoutersCR16000-M SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-M Routers Alarm Reference-R838x-6W10006-Layer 3 - IP Services
16-IPV6-MIB
16-IPV6-MIB 60.25 KB
IPV6-MIB
About this MIB
Use this MIB to implement IPv6.
MIB file name
rfc2465-ipv6.mib
Notifications
ipv6IfStateChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.55.2.0.1
IPv6 interface state change
Informational
Warning
ON
Notification triggers
This notification is generated when the state of an interface link changed or the IPv6 address of an interface changed.
System impact
If the notification is generated and the link state is not UP, errors might be present on IPv6 services on the interface.
Status control
ON
CLI: snmp-agent trap enable ipv6 address [ interface-state-change ]
OFF
CLI : undo snmp-agent trap enable ipv6 address [ interface-state-change ]
Object
OID (object name)
Index
Value range
ipv6IfDescr (1.3.6.1.2.1.55.1.5.1.2)
Interface information.
ipv6IfIndex
DisplayString
DisplayString , (0255)
ipv6IfOperStatus (1.3.6.1.2.1.55.1.5.1.10)
Interface state.
ipv6IfIndex
INTEGER
up(1), down(2), noIfIdentifier(3), unknown(4), notPresent(5)
Recommended action
Check the interface connection and the interface address.
