06-Layer 3 - IP Services
HomeSupportRoutersCR16000-M SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-M Routers Alarm Reference-R838x-6W10006-Layer 3 - IP Services
12-HH3C-ND-TRAP-MIB
12-HH3C-ND-TRAP-MIB 115.91 KB
HH3C-ND-TRAP-MIB
About this MIB
Use this MIB to obtain information about ND entry learning threshold and packet conflict related alarms.
MIB file name
hh3c-nd-trap.mib
Notifications
hh3cNDTrapAllThresholdExceed
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.218.1.0.1
The number of global ND entries exceeded the alarm threshold.
Error
Warning
1.3.6.1.4.1.25506.2.218.1.0.2 (hh3cNDTrapAllThresholdResume)
OFF
Notification triggers
This notification is generated when the number of ND entries learned by the device exceeds the alarm threshold (80% of the upper entry limit).
System impact
The device might not learn new ND entries, which causes service interruption.
Status control
ON
CLI: Use the ipv6 nd entry-limit record enable command.
OFF
CLI: Use the undo ipv6 nd entry-limit record enable command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.218.1.1.4 (hh3cNDTrapEntryThreshold)
Alarm threshold for the number of global ND entries.
N/A
Unsigned32
Unsigned32
1.3.6.1.4.1.25506.2.218.1.1.5 (hh3cNDTrapEntryDynamicNum)
Number of dynamic ND entries.
N/A
Unsigned32
Unsigned32
1.3.6.1.4.1.25506.2.218.1.1.6 (hh3cNDTrapEntryStaticNum)
Number of static ND entries.
N/A
Unsigned32
Unsigned32
1.3.6.1.4.1.25506.2.218.1.1.7 (hh3cNDTrapEntryOtherNum)
Number of other ND entries.
N/A
Unsigned32
Unsigned32
Recommended action
1.Execute the display ipv6 neighbors all command to compare the numbers of static and dynamic ND entries.
  - If the number of static ND entries is larger, go to step 2.
  - If the number of dynamic ND entries is larger, go to step 3.
2.Based on the network planning and service deployment, check whether the static ND entries are necessary.
  - If the static ND entries are necessary, go to step 4.
  - If the static ND entries are not necessary, execute the undo ipv6 neighbor command to delete specified ND entries or execute the reset ipv6 neighbors static command to clear all static ND entries. Make sure the operation does not affect services.
3.Execute the ipv6 neighbors max-learning-number command to set a larger dynamic ND learning limit for the device. Execute the ipv6 neighbors max-learning-num command to set larger dynamic ND learning limits for interfaces.
4.If the issue persists, collect configuration files and alarm information, and then contact Technical Support for help.
Basic information
OID
Event
Severity
Default status
The number of global ND entries dropped below the alarm threshold.
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the number of ND entries learned by the device drops below the alarm threshold (60% of the upper entry limit).
This notification might be generated when the following events occur:
Dynamic ND entries age out.
The user manually clears ND entries.
The device receives ND entry deleting messages.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
Unsigned32
Unsigned32
N/A
Unsigned32
Unsigned32
N/A
Unsigned32
Unsigned32
N/A
Unsigned32
Unsigned32
Recommended action
No action is required.
hh3cNDTrapSlotThresholdExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.218.1.0.3
The number of dynamic ND entries on the card exceeded the alarm threshold.
Error
Warning
1.3.6.1.4.1.25506.2.218.1.0.4 (hh3cNDTrapSlotThresholdResume)
OFF
This notification is generated when the number of the dynamic ND entries learned by a card exceeds the alarm threshold (80% of the upper entry limit).
System impact
The card might not learn new ND entries, which causes service interruption.
Status control
ON
OFF
Status control
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.218.1.1.1 (hh3cNDTrapEntryChassis)
Chassis number of the IRF member.
N/A
Unsigned32
Unsigned32
1.3.6.1.4.1.25506.2.218.1.1.2 (hh3cNDTrapEntrySlot)
Slot number.
N/A
Unsigned32
Unsigned32
Alarm threshold for the number of dynamic ND entries on the card.
N/A
Unsigned32
Unsigned32
Number of dynamic ND entries on the card.
N/A
Unsigned32
Unsigned32
Recommended action
Execute the display ipv6 neighbors command to view the number of dynamic ND entries on the card.
Based on the network planning and service deployment, check whether the dynamic ND entries are necessary.
If the dynamic ND entries are necessary, go to step 3.
If the dynamic ND entries are not necessary, execute the undo ipv6 neighbor command to delete specified ND entries. Make sure the operation does not affect services.
Execute the ipv6 neighbors max-learning-number command to set a larger dynamic ND learning limit for the card.
Basic information
OID
Event
Severity
Default status
The number of dynamic ND entries on the card dropped below the alarm threshold.
Recovery
Warning
N/A
ON
This notification is generated when the number of dynamic ND entries learned by a card drops below the alarm threshold (60% of the upper entry limit).
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
Unsigned32
Unsigned32
Slot number.
N/A
Unsigned32
Unsigned32
N/A
Unsigned32
Unsigned32
N/A
Unsigned32
Unsigned32
Recommended action
hh3cNDTrapIfThresholdExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.218.1.0.5
The number of dynamic ND entries on the interface exceeded the alarm threshold.
Error
Warning
1.3.6.1.4.1.25506.2.218.1.0.6 (hh3cNDTrapIfThresholdResume)
OFF
This notification is generated when the number of dynamic ND entries learned by an interface exceeds the alarm threshold (80% of the upper entry limit).
The interface learns a large number of dynamic ND entries trigger by normal services.
The user configures a large number of static ND entries.
The device receives a large number of remote ND entries.
System impact
The interface might not learn new ND entries, which causes service interruption.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.218.1.1.3 (hh3cNDTrapEntryIfName)
Interface name.
N/A
DisplayString
OCTET STRING (1:0..255)
Alarm threshold for the number of dynamic ND entries on the interface.
N/A
Unsigned32
Unsigned32
Number of dynamic ND entries on the interface.
N/A
Unsigned32
Unsigned32
Recommended action
1.Execute the display ipv6 neighbors command to view the number of dynamic ND entries on the interface.
2.Based on the network planning and service deployment, check whether the dynamic ND entries are necessary.
  - If the dynamic ND entries are necessary, go to step 3.
  - If the dynamic ND entries are not necessary, execute the undo ipv6 neighbor command to delete specified ND entries. Make sure the operation does not affect services.
3.Execute the ipv6 neighbors max-learning-num command to set a larger dynamic ND learning limit for the interface.
Basic information
OID
Event
Severity
Default status
The number of dynamic ND entries on the interface dropped below the alarm threshold.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the number of dynamic ND entries learned by an interface drops below the alarm threshold (60% of the upper entry limit).
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface name.
N/A
DisplayString
N/A
Unsigned32
Unsigned32
N/A
Unsigned32
Unsigned32
Recommended action
hh3cNDTrapSuppThresholdExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.218.1.0.7
The number of ND suppression entries learned by the device exceeded the alarm threshold.
Error
Warning
1.3.6.1.4.1.25506.2.218.1.0.8 (hh3cNDTrapSuppThresholdResume)
ON
This notification is generated when the number of ND suppression entries learned by the device exceeds the alarm threshold (80% of the upper entry limit).
The device dynamically learns ND suppression entries triggered by normal services.
The remote end issues ND suppression entries.
System impact
The device might not learn new ND suppression entries, which causes service interruption.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Alarm threshold for the number of ND suppression entries on the device.
N/A
Unsigned32
Unsigned32
1.3.6.1.4.1.25506.2.218.1.1.8 (hh3cNDTrapEntrySuppNum)
Number of ND suppression entries on the device.
N/A
Unsigned32
Unsigned32
Recommended action
1.Execute the display ipv6 nd suppression xconnect-group command to view ND suppression entries.
2.Based on the network planning and service deployment, check whether the ND suppression entries are necessary.
  - If the ND suppression entries are necessary, go to step 3.
  - If the ND suppression entries are not necessary, execute the reset ipv6 nd suppression xconnect-group command to clear ND suppression entries.
3.If the issue persists, collect configuration files and alarm information, and then contact Technical Support for help.
Basic information
OID
Event
Severity
Default status
The number of ND suppression entries on the device dropped below the alarm threshold.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the number of ND suppression entries learned by the device drops below the alarm threshold (60% of the upper entry limit).
Dynamic ND suppression entries age out.
The user manually clears ND suppression entries.
The device receives ND suppression entry deleting messages.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
Unsigned32
Unsigned32
N/A
Unsigned32
Unsigned32
Recommended action
hh3cNDTrapPktSpeedAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.218.2.0.1
The sending rate pf ND packets or ND Miss messages exceeded the alarm threshold.
Error
Warning
1.3.6.1.4.1.25506.2.218.2.0.2 (hh3cNDTrapPktSpeedAlarmResume)
OFF
This notification is generated when the sending rate of ND packets triggered by services or ND Miss messages exceeds the alarm threshold (80% of the upper rate limit). When the device receives an IP packet with an unresolvable destination IP address, it sends a ND Miss message to the CPU.
System impact
The device might not send ND requests normally, which affects ND learning. As a result, traffic cannot be forwarded.
Status control
ON
CLI: Use the snmp-agent trap enable nd nd-miss command.
OFF
CLI: Use the undo snmp-agent trap enable nd nd-miss command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.218.2.1.1 (hh3cNDTrapPktSpeedChassis)
Chassis number.
N/A
Unsigned32
Unsigned32
1.3.6.1.4.1.25506.2.218.2.1.2 (hh3cNDTrapPktSpeedSlot)
Slot number.
N/A
Unsigned32
Unsigned32
1.3.6.1.4.1.25506.2.218.2.1.3 (hh3cNDTrapPktSpeedSupValue)
Packet sending rate that triggers the notification.
N/A
Unsigned32
Unsigned32
1.3.6.1.4.1.25506.2.218.2.1.4 (hh3cNDTrapPktSpeedCurValue)
Current packet sending rate.
N/A
OCTET STRING
Unsigned32
1.3.6.1.4.1.25506.2.218.2.1.5 (hh3cNDTrapPktSpeedSupType)
Packet type: ND packet or ND Miss message.
N/A
OCTET STRING
OCTET STRING (1:1..48)
Recommended action
1.Capture packets to identify and analyze the source of IPv6 packets that trigger ND resolution. If the source is unreasonable, limit attack packet sending for the attack source.
2.If the issue persists, collect configuration files and alarm information, and then contact Technical Support for help.
Basic information
OID
Event
Severity
Default status
The sending rate of ND packets or ND Miss messages dropped below the alarm threshold.
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the sending rate of ND packets or ND Miss messages drops below the alarm threshold (60% of the upper rate limit).
The device receives fewer IP packets with unresolvable destination IP addresses.
ND packets triggered by services reduce.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number.
N/A
Unsigned32
Unsigned32
Slot number.
N/A
Unsigned32
Unsigned32
N/A
Unsigned32
Unsigned32
N/A
OCTET STRING
Unsigned32
N/A
OCTET STRING
Recommended action
hh3cNDTrapHostIPConflict
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.218.2.0.3
The IPv6 addresses of the ND packet sender and local device conflicted.
Error
Warning
1.3.6.1.4.1.25506.2.218.2.0.4 (hh3cNDTrapHostIPConflictResume)
ON
This notification is generated when an interface receives an ND packet whose source IPv6 address is the same as the IPv6 address of the local device.
Another device is configured with the same IPv6 address as that of the local device.
The network has an ND packet attack that forges the source IPv6 address.
System impact
If you do not clear the conflict immediately, user services or traffic might be interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable nd local-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable nd local-conflict command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.218.2.2.1 (hh3cNDTrapHostIPCftLocalIPv6)
IPv6 address of the interface.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.218.2.2.2
 (hh3cNDTrapHostIPCftLocalMAC)
MAC address of the interface.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.218.2.2.3 (hh3cNDTrapHostIPCftLocalIf)
Name of the interface.
N/A
OCTET STRING
OCTETSTRING (1:1..48)
1.3.6.1.4.1.25506.2.218.2.2.4 (hh3cNDTrapHostIPCftLocalPevid)
Outer VLAN ID of the interface.
N/A
Unsigned32
Unsigned32
1.3.6.1.4.1.25506.2.218.2.2.5 (hh3cNDTrapHostIPCftLocalCevid)
Inner VLAN ID of the interface.
N/A
Unsigned32
Unsigned32
1.3.6.1.4.1.25506.2.218.2.2.6 (hh3cNDTrapHostIPCftRemoteIPv6)
Remote IPv6 address.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.218.2.2.7 (hh3cNDTrapHostIPCftRemoteMAC)
Remote MAC address.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.218.2.2.8 (hh3cNDTrapHostIPCftRemotePevid)
Remote outer VLAN ID.
N/A
Unsigned32
Unsigned32
1.3.6.1.4.1.25506.2.218.2.2.9 (hh3cNDTrapHostIPCftRemoteCevid)
Remote inner VLAN ID.
N/A
Unsigned32
Unsigned32
Recommended action
1.Verify if another device on the network is configured with the same IPv6 address as that of the local device.
  - If you can identify the device configured with the same IPv6 address, change the IPv6 address of the device.
  - If you cannot identify the device configured with the same IPv6 address, change the IPv6 address of the corresponding interface. Make sure the operation does not affect services.
2.Check whether an ND packet attack exists on the network and identify the attack source.
Basic information
OID
Event
Severity
Default status
The condition that the IPv6 addresses of the ND packet sender and local device conflicted was cleared.
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the interface does not receive any ND packets whose source IPv6 address is the same as its own IPv6 address within three minutes.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
N/A
OCTET STRING
N/A
OCTET STRING
N/A
Unsigned32
Unsigned32
N/A
Unsigned32
Unsigned32
N/A
OCTET STRING
Remote MAC address.
N/A
OCTET STRING
N/A
Unsigned32
Unsigned32
N/A
Unsigned32
Unsigned32
Recommended action
hh3cNDTrapDuplicateIPv6
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.218.2.0.5
The IPv6 addresses of users conflicted.
Error
Warning
N/A (N/A)
OFF
This notification is generated when the MAC address in the received ND packet is different from that in the ND entry.
System impact
The conflict might cause card or device failure.
Status control
ON
CLI: Use the snmp-agent trap enable nd user-ip-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable nd user-ip-conflict command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.218.2.3.1
 (hh3cNDTrapDupIPv6NewMac)
MAC address of the new user.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.218.2.3.2
 (hh3cNDTrapDupIPv6NewSevid)
Outer VLAN ID of the new user.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.218.2.3.3
 (hh3cNDTrapDupIPv6NewCevid)
Inner VLAN ID of the new user.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.218.2.3.4
 (hh3cNDTrapDupIPv6NewIFName)
Interface name of the new user.
N/A
DisplayString
1.3.6.1.4.1.25506.2.218.2.3.5
 (hh3cNDTrapDupIPv6OldMac)
MAC address of the old user.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.218.2.3.6
 (hh3cNDTrapDupIPv6OldSevid)
Outer VLAN ID of the old user.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.218.2.3.7
 (hh3cNDTrapDupIPv6OldCevid)
Inner VLAN ID of the old user.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.218.2.3.8
 (hh3cNDTrapDupIPv6OldIFName)
Interface name of the old user.
N/A
DisplayString
1.3.6.1.4.1.25506.2.218.2.3.9 (hh3cNDTrapDupIPv6DupAddr)
Conflicting IPv6 address.
N/A
OCTET STRING
Recommended action
1.Verify if another user on the network is configured with the same IPv6 address. If another user is configured with the same IPv6 address, change the user's IPv6 address.
2.Identify whether an ND packet attack exists on the network and identify the attack source.
hh3cNDTrapRatelimitOverspeed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.218.2.0.6
The ND packet receiving rate exceeded 80% of the threshold.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the ND packet receiving rate exceeds 80% of the threshold.
System impact
Some normal ND packets might be dropped, which affects normal services.
Status control
ON
CLI: Use the snmp-agent trap enable nd rate-limit command.
OFF
CLI: Use the undo snmp-agent trap enable nd rate-limit command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.218.2.4.1
 (hh3cNDTrapRatelimitVer)
Notification version.
N/A
Unsigned32
1
1.3.6.1.4.1.25506.2.218.2.4.2
 (hh3cNDTrapRatelimitCount)
Rate limit.
N/A
Unsigned32
Standard MIB values.
1.3.6.1.4.1.25506.2.218.2.4.3 (hh3cNDTrapRatelimitMsg)
Rate limit message.
N/A
OCTET STRING
SIZE (1..254)
Recommended action
1.Execute the ipv6 nd rate-limit command to set a larger ND packet receiving rate limit for the specified interface.
