06-Layer 3 - IP Services
HomeSupportRoutersCR16000-M SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-M Routers Alarm Reference-R838x-6W10006-Layer 3 - IP Services
08-HH3C-IP-ADDRESS-MIB
08-HH3C-IP-ADDRESS-MIB 61.54 KB
HH3C-IP-ADDRESS-MIB
About this MIB
Use this MIB to obtain and configure IPv4 addresses.
MIB file name
hh3c-ip-address.mib
Notifications
hh3cIpAddressChangeNotify
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.67.2.2.0.1
Address change.
Informational
Warning
ON
Notification triggers
This notification is generated when the number of IPv6 FIB entries on the device drops below 60% of the threshold. The device recovers from a FIB entry capacity usage alarm.
System impact
OID
Event
Severity
Default status
Address change.
Informational
Warning
ON
This notification is generated when the IP address of an interface changes.
System impact
The IP address of an interface changes, which might cause service interruption.
Status control
The SNMP notification for IP address change cannot be disabled.
Object
OID (object name)
Index
Value range
hh3cIpAddrNotifyIfIndex (1.3.6.1.4.1.25506.2.67.2.1.1)
Interface index.
N/A
Integer32
Integer32 (1..2147483647)
hh3cIpAddrOldIpAddress (1.3.6.1.4.1.25506.2.67.2.1.2)
Previous IP address.
N/A
InetAddress
OCTET STRING (0..255)
hh3cIpAddrNewIpAddress (1.3.6.1.4.1.25506.2.67.2.1.3)
New IP address.
N/A
InetAddress
hh3cIpAddrFirstTrapTime (1.3.6.1.4.1.25506.2.67.2.1.4)
Time when the first SNMP notification was sent.
N/A
TimeTicks
TimeTicks (04294967295)
Recommended action
Use the display ip interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief ] command to view the interface IP address and verify that the IP address change is as expected. If the IP address is changed unexpectedly, correct the error in time to avoid service interruption.
