- 06-Layer 3 - IP Services
- 01-HH3C-ARP-RATELIMIT-MIB
- 02-HH3C-ARP-TRAP-MIB
- 03-HH3C-DHCP-SNOOP2-MIB
- 04-HH3C-DHCP4-CLIENT-MIB
- 05-HH3C-DHCP4-MIB
- 06-HH3C-DHCP6-MIB
- 07-HH3C-FIB-MIB
- 08-HH3C-IP-ADDRESS-MIB
- 09-HH3C-IPFW-MIB
- 10-HH3C-IPV6-ADDRESS-MIB
- 11-HH3C-NAT-MIB
- 12-HH3C-ND-TRAP-MIB
- 13-HH3C-SESSION-MIB
- 14-HH3C-TCP-MIB
- 15-HH3C-TUNNEL-TRAP-MIB
- 16-IPV6-MIB
01-HH3C-ARP-RATELIMIT-MIB | 37.84 KB |
About this MIB
This MIB contains ARP rate limiting notifications.
MIB file name
hh3c-arp-ratelimit.mib
Notifications
hh3cARPRatelimitOverspeedTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.110.1.1.0.1 |
Rate of ARP packets delivered to the CPU on a device exceeded the threshold. |
Informational |
Warning |
N/A (N/A) |
OFF |
Notification triggers
This notification is generated when the ARP packet rate on an interface exceeds the upper limit.
System impact
The interface discards ARP packets that exceed the rate limit. This might affect ARP learning and responding, resulting in communication failure.
Status control
ON
CLI: Use the snmp-agent trap enable arp rate-limit command.
OFF
CLI: Use the undo snmp-agent trap enable arp rate-limit command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.110.1.1.1.1 (hh3cARPRatelimitTrapVer) |
Version of the trap. |
N/A |
Unsigned32 |
1 |
1.3.6.1.4.1.25506.2.110.1.1.1.2 (hh3cARPRatelimitTrapCount) |
Alarm threshold that the ARP packet rate exceeded. |
N/A |
Unsigned32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.110.1.1.1.3 (hh3cARPRatelimitTrapMsg) |
Trap messages. |
N/A |
OCTET STRING |
SIZE (1..254) |
Recommended action
To resolve this issue:
1.Execute the arp rate-limit command to set a higher ARP packet rate limit for the interface.
2.If the issue persists, collect configuration files and alarm information, and then contact H3C Support for help.
