- 06-Layer 3 - IP Services
- 01-HH3C-ARP-RATELIMIT-MIB
- 02-HH3C-ARP-TRAP-MIB
- 03-HH3C-DHCP-SNOOP2-MIB
- 04-HH3C-DHCP4-CLIENT-MIB
- 05-HH3C-DHCP4-MIB
- 06-HH3C-DHCP6-MIB
- 07-HH3C-FIB-MIB
- 08-HH3C-IP-ADDRESS-MIB
- 09-HH3C-IPFW-MIB
- 10-HH3C-IPV6-ADDRESS-MIB
- 11-HH3C-NAT-MIB
- 12-HH3C-ND-TRAP-MIB
- 13-HH3C-SESSION-MIB
- 14-HH3C-TCP-MIB
- 15-HH3C-TUNNEL-TRAP-MIB
- 16-IPV6-MIB
02-HH3C-ARP-TRAP-MIB | 233.79 KB |
hh3cARPTrapSlotThresholdResume
hh3cARPTrapSuppThresholdResume
hh3cARPTrapMACIPConflictResume
hh3cARPTrapUserIpConflictAlarm
hh3cARPTrapAckStrictCheckAlarm
hh3cARPTrapPacketValidCheckAlarm
hh3cARPTrapDtcDropVlanPktAlarm
HH3C-ARP-TRAP-MIB
About this MIB
Use this MIB to output notifications for the ARP module.
MIB file name
hh3c-arp-trap.mib
Notifications
hh3cARPTrapThresholdAlarm
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.217.1.0.1 |
The number of global ARP entries exceeded the alarm threshold. |
Error |
Minor |
1.3.6.1.4.1.25506.2.217.1.0.2 (hh3cARPTrapThresholdResume) |
OFF |
Notification triggers
This notification is generated when the number of ARP entries learned by the device exceeds the alarm threshold (80% of the upper entry limit).
System impact
If the number of ARP entries continues to increase, the device might not learn new ARP entries because of insufficient resources, which causes service interruption.
Status control
ON
CLI: Use the snmp-agent trap enable arp entry-limit command.
OFF
CLI: Use the undo snmp-agent trap enable arp entry-limit command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.1.1.4 (hh3cARPTrapEntryThreshold) |
Alarm threshold. |
N/A |
INTEGER |
Integer32 (1..2147483647) |
1.3.6.1.4.1.25506.2.217.1.1.5 (hh3cARPTrapDynamicEntryNum) |
Number of dynamic ARP entries. |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.217.1.1.6 (hh3cARPTrapStaticEntryNum) |
Number of static ARP entries. |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.217.1.1.7 (hh3cARPTrapOtherEntryNum) |
Number of other ARP entries. |
N/A |
INTEGER |
Recommended action
1.Execute the display arp all command to compare the numbers of static and dynamic ARP entries.
- If the number of static ARP entries is larger, go to step 2.
- If the number of dynamic ARP entries is larger, go to step 3.
2.Based on the network planning and service deployment, check whether the static ARP entries are necessary.
- If the static ARP entries are necessary, go to step 3.
- If the static ARP entries are not necessary, execute the undo arp command to delete specified ARP entries or execute the reset arp static command to clear all static ARP entries. Make sure the operation does not affect services.
3.Execute the arp max-learning-number command to set a larger dynamic ARP learning limit for the device. Execute the arp max-learning-num command to set larger dynamic ARP learning limits for interfaces.
4.If the issue persists, collect configuration files and alarm information, and then contact Technical Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.1.0.2 |
The number of ARP entries dropped below the alarm threshold. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the number of ARP entries learned by the device drops below the alarm threshold (60% of the upper entry limit).
System impact
The device can learn ARP entries normally. No negative impact on services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Alarm threshold. |
N/A |
INTEGER |
N/A |
INTEGER |
N/A |
INTEGER |
N/A |
INTEGER |
Recommended action
No action is required.
hh3cARPTrapSlotThresholdAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.1.0.3 |
The number of ARP entries on the card exceeded the alarm threshold. |
Error |
Minor |
1.3.6.1.4.1.25506.2.217.1.0.4 (hh3cARPTrapSlotThresholdResume) |
OFF |
This notification is generated when the number of ARP entries learned by a card exceeds the alarm threshold (80% of the upper entry limit).
System impact
If the number of ARP entries on the card continues to increase, the card might not learn new ARP entries because of insufficient resources, which causes service interruption.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.1.1.1 (hh3cARPTrapEntryChassis) |
Chassis number. |
N/A |
Unsigned32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.217.1.1.2 (hh3cARPTrapEntrySlot) |
Slot number. |
N/A |
Unsigned32 |
Alarm threshold. |
N/A |
INTEGER |
N/A |
INTEGER |
Recommended action
1.Execute the display arp command to view dynamic ARP entries on the card.
2.Based on the network planning and service deployment, check whether the dynamic ARP entries are necessary.
- If the dynamic ARP entries are necessary, go to step 3.
- If the dynamic ARP entries are not necessary, execute the undo arp command to delete specified ARP entries. Make sure the operation does not affect services.
3.Execute the arp max-learning-number command to set a larger dynamic ARP learning limit for the card.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.1.0.4 |
The number of ARP entries on the card dropped below the alarm threshold. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the number of ARP entries learned by a card drops below the alarm threshold (60% of the upper entry limit).
System impact
The card can learn ARP entries normally. No negative impact on services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Chassis number. |
N/A |
Unsigned32 |
Slot number. |
N/A |
Unsigned32 |
Alarm threshold. |
N/A |
INTEGER |
N/A |
INTEGER |
Recommended action
hh3cARPTrapIfThresholdAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.1.0.5 |
The number of ARP entries on the interface exceeded the alarm threshold. |
Error |
Minor |
1.3.6.1.4.1.25506.2.217.1.0.6 (hh3cARPTrapIfThresholdResume) |
OFF |
This notification is generated when the number of ARP entries learned by an interface exceeds the alarm threshold (80% of the upper entry limit).
System impact
If the number of ARP entries on the interface continues to increase, the interface might not learn new ARP entries because of insufficient resources, which causes service interruption.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.1.1.3 (hh3cARPTrapEntryIfName) |
Interface name. |
N/A |
DisplayString |
OCTET STRING (0..255) |
Alarm threshold. |
N/A |
INTEGER |
N/A |
INTEGER |
Recommended action
1.Execute the display arp command to view the dynamic ARP entries on the interface.
3.Execute the arp max-learning-num command to set a larger dynamic ARP learning limit for the interface.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.1.0.6 |
The number of ARP entries on the interface dropped below the alarm threshold. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the number of ARP entries learned by an interface drops below the alarm threshold (60% of the upper entry limit).
System impact
The interface can learn ARP entries normally. No negative impact on services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Interface name. |
N/A |
DisplayString |
Alarm threshold. |
N/A |
INTEGER |
N/A |
INTEGER |
Recommended action
hh3cARPTrapSuppThresholdAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.1.0.7 |
The number of ARP suppression entries on the device exceeded the alarm threshold. |
Error |
Minor |
1.3.6.1.4.1.25506.2.217.1.0.8 (hh3cARPTrapSuppThresholdResume) |
OFF |
This notification is generated when the number of ARP suppression entries learned by the device exceeds the alarm threshold (80% of the upper entry limit).
System impact
If the number of ARP suppression entries on the interface continues to increase, the device might not learn new ARP suppression entries because of insufficient resources, which causes service interruption.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Alarm threshold. |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.217.1.1.8 (hh3cARPTrapSuppEntryNum) |
Number of ARP suppression entries. |
N/A |
INTEGER |
Recommended action
1.Execute the display arp suppression xconnect-group command to view ARP suppression entries.
2.Based on the network planning and service deployment, check whether the ARP suppression entries are necessary.
- If the ARP suppression entries are necessary, go to step 3.
- If the ARP suppression entries are not necessary, execute the reset arp suppression xconnect-group command to clear ARP suppression entries.
3.If the issue persists, collect configuration files and alarm information, and then contact Technical Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.1.0.8 |
The number of ARP suppression entries on the device dropped below the alarm threshold. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the number of ARP suppression entries learned by the device drops below the alarm threshold (60% of the upper entry limit).
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Alarm threshold. |
N/A |
INTEGER |
N/A |
INTEGER |
Recommended action
hh3cARPTrapMACConflictAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.1.0.1 |
The sender MAC address in the received ARP packet and the MAC address of the local device conflicted. |
Error |
Major |
1.3.6.1.4.1.25506.2.217.2.1.0.2 (hh3cARPTrapMACConflictResume) |
OFF |
This notification is generated when the sender MAC address in the received ARP packet is the same as the MAC address of the local device.
This notification might be generated when the following events occur:
An endpoint on the network has the same MAC address as that of the local device.
The network has a loop.
System impact
The conflict might cause service interruption.
Status control
ON
CLI: Use the snmp-agent trap enable arp local-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable arp local-conflict command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.2.1.1.1 (hh3cARPTrapLocalConflictIf) |
Interface that receives the conflicting ARP packet. |
N/A |
OCTET STRING |
OCTET STRING (1..47) |
1.3.6.1.4.1.25506.2.217.2.1.1.2 (hh3cARPTrapLocalConflictMac) |
Sender MAC address in the conflicting ARP packet. |
N/A |
OCTET STRING |
OCTET STRING (1..15) |
1.3.6.1.4.1.25506.2.217.2.1.1.5 (hh3cARPTrapLocalSrcIp) |
Sender IP address in the conflicting ARP packet. |
N/A |
IpAddress |
1.3.6.1.4.1.25506.2.217.2.1.1.8 (hh3cARPTrapLocalPeVlan) |
Outer VLAN of the conflicting ARP packet. |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.217.2.1.1.9 (hh3cARPTrapLocalCeVlan) |
Inner VLAN of the conflicting ARP packet. |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.217.2.1.1.10 (hh3cARPTrapLocalInboundIf) |
Physical interface corresponding to the VLAN interface that receives the conflicting ARP packet. |
N/A |
OCTET STRING |
Recommended action
1.Configure STP to check whether the network has a loop.
2.Check whether another device on the network has the same MAC address as that of the local device.
- If you can identify the device that has the same MAC address, change the MAC address of the device.
- If you cannot identify the device that has the same MAC address, change the MAC address of the corresponding interface.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.1.0.2 |
The condition that the sender MAC address in the received ARP packet and the MAC address of the local device conflicted was cleared. |
Recovery |
Major |
N/A (N/A) |
OFF |
This notification is generated when the interface does not receive any ARP packet in which the sender MAC address is the same as the interface MAC address within 3 minutes.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
IpAddress |
N/A |
INTEGER |
N/A |
INTEGER |
N/A |
OCTET STRING |
Recommended action
hh3cARPTrapMACIPConflictAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.1.0.3 |
The sender MAC and IP addresses in the received ARP packet and the MAC and IP addresses of the local device conflicted. |
Error |
Major |
1.3.6.1.4.1.25506.2.217.2.1.0.4 (hh3cARPTrapMACIPConflictResume) |
OFF |
This notification is generated when the sender MAC and IP addresses in the received ARP packet are the same as the MAC and IP addresses of the local device.
The network has an ARP packet attack.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.1.1.3 (hh3cARPTrapLocalConflictIP) |
N/A |
IpAddress |
1.3.6.1.4.1.25506.2.217.2.1.1.6 (hh3cARPTrapLocalDstMac) |
Target MAC address in the conflicting ARP packet. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.1.1.7 (hh3cARPTrapLocalDstIP) |
Target IP address in the conflicting ARP packet. |
N/A |
IpAddress |
N/A |
INTEGER |
N/A |
INTEGER |
N/A |
OCTET STRING |
Recommended action
2.If the network does not have any loop, identify the source through capturing packets, and then edit the IP and MAC addresses of the device that sends the ARP packet.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.1.0.4 |
The condition that the sender MAC and IP addresses in the received ARP packet and the MAC and IP addresses of the local device conflicted was cleared. |
Recovery |
Major |
N/A (N/A) |
OFF |
This notification is generated when the interface does not receive any ARP packet in which the sender IP and MAC addresses are the same as the interface IP and MAC addresses within 3 minutes.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
IpAddress |
N/A |
OCTET STRING |
N/A |
IpAddress |
N/A |
INTEGER |
N/A |
INTEGER |
N/A |
OCTET STRING |
Recommended action
hh3cARPTrapIPConflictAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.1.0.5 |
The sender IP address in the received ARP packet and the IP address of the local device conflicted. |
Error |
Major |
1.3.6.1.4.1.25506.2.217.2.1.0.6 (hh3cARPTrapIPConflictResume) |
OFF |
This notification is generated when the sender IP address in the ARP packet is the same as that of the local device.
Another device on the network has the same IP address as that of the local device.
The network has an ARP packet attack that forges the sender IP address.
System impact
The gateway information of the user might be edited by the attacker, which causes an ARP packet attack. As a result, user services might be interrupted.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING |
N/A |
IpAddress |
1.3.6.1.4.1.25506.2.217.2.1.1.4 (hh3cARPTrapLocalSrcMac) |
N/A |
OCTET STRING |
N/A |
INTEGER |
N/A |
INTEGER |
Recommended action
1.Check whether another device on the network has the same IP address as that of the local device.
- If you can identify the device that has the same IP address, change the IP address of the device.
- If you cannot identify the device that has the same IP address, change the IP address of the corresponding interface. Make sure the operation does not affect services.
2.Check whether an ARP packet attack exists on the network and identify the attack source through capturing packets.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.1.0.6 |
The condition that the sender IP address in the received ARP packet and the IP address of the local device conflicted was cleared. |
Recovery |
Major |
N/A (N/A) |
OFF |
This notification is generated when the interface does not receive any ARP packet in which the sender IP address is the same as the interface IP address within 3 minutes.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING |
N/A |
IpAddress |
N/A |
OCTET STRING |
N/A |
INTEGER |
N/A |
INTEGER |
Recommended action
hh3cARPTrapHostMoveAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.2.0.1 |
The access port for a host changed. |
Error |
Warning |
1.3.6.1.4.1.25506.2.217.2.2.0.1 (hh3cARPTrapHostMoveResume) |
OFF |
This notification is generated when the user port migrates after you enable recording user port migrations.
System impact
The user port migration might cause service interruption. Too many user port migrations might degrade the device performance.
Status control
ON
CLI: Use the snmp-agent trap enable arp user-move command.
OFF
CLI: Use the undo snmp-agent trap enable arp user-move command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.2.2.1.1 (hh3cARPTrapMoveUserIP) |
Sender IP address in the ARP packet whose port changes. |
N/A |
IpAddress |
1.3.6.1.4.1.25506.2.217.2.2.1.2 (hh3cARPTrapMoveUserMAC) |
Sender MAC address in the ARP packet whose port changes. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.2.1.3 (hh3cARPTrapMoveLocalIf) |
Name of the port before migration. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.2.1.4 (hh3cARPTrapMoveLocalPeVlan) |
Outer VLAN of the ARP packet before port migration. |
N/A |
INTEGER |
Interger32(1..2147483647) |
1.3.6.1.4.1.25506.2.217.2.2.1.5 (hh3cARPTrapMoveLocalCeVlan) |
Inner VLAN of the ARP packet before port migration. |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.217.2.2.1.6 (hh3cARPTrapMoveRemoteIF) |
Name of the port after migration. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.2.1.7 (hh3cARPTrapMoveRemotePeVlan) |
Outer VLAN of the ARP packet after port migration. |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.217.2.2.1.8 (hh3cARPTrapMoveRemoteCeVlan) |
Inner VLAN of the ARP packet after port migration. |
N/A |
INTEGER |
Recommended action
1.Check whether the user port migration is reasonable.
2.If the issue persists, collect configuration files and alarm information, and then contact Technical Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.2.0.2 |
The condition that the access port for a host changed was cleared. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the access port for the user does not change within 3 minutes.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
IpAddress |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
N/A |
INTEGER |
N/A |
INTEGER |
N/A |
OCTET STRING |
N/A |
INTEGER |
N/A |
INTEGER |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.3.0.1 |
User IP address conflicted. |
Error |
Warning |
N/A (N/A) |
OFF |
This notification is generated when a user IP address conflict occurs. The conflict occurs if an incoming ARP packet has the same sender IP address as an existing ARP entry but a different sender MAC address.
System impact
The network might have conflicting IP addresses, which causes route oscillation, service interruption, or traffic interruption.
Status control
ON
CLI: Use the snmp-agent trap enable arp user-ip-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable arp user-ip-conflict command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.2.3.1.1 (hh3cARPTrapUIPCPRcvMac) |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.3.1.2 (hh3cARPTrapUIPCPRcvPVid) |
Outer VLAN of the local interface on which the conflict occurs. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.3.1.3 (hh3cARPTrapUIPCPRcvCVid) |
Inner VLAN of the local interface on which the conflict occurs. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.3.1.4 (hh3cARPTrapUIPCPRcvIf) |
Local interface on which the conflict occurs. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.3.1.5 (hh3cARPTrapUIPCPLocalMac) |
MAC address in the local ARP entry. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.3.1.6 (hh3cARPTrapUIPCPLocalPVid) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.3.1.7 (hh3cARPTrapUIPCPLocalCVid) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.3.1.8 (hh3cARPTrapUIPCPLocalIf) |
Name of the interface that receives the ARP packet. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.3.1.9 (hh3cARPTrapUIPCPIpAddr) |
IP address in the local ARP entry. |
N/A |
IpAddress |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.4.0.1 |
The received ARP packet was not the ARP reply to the ARP request sent by the device. |
Error |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the following conditions are met:
You enable ARP active acknowledgement in strict mode on the device.
When the device receives an ARP reply, it does not send any ARP request to the sender IP address in the reply within the probe interval.
System impact
Some normal ARP replies and ARP requests might be dropped, which affects normal services.
Status control
ON
CLI: Use the snmp-agent trap enable arp active-ack command.
OFF
CLI: Use the undo snmp-agent trap enable arp active-ack command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.2.4.1.1 (hh3cARPTrapAckIfName) |
Interface that receives the ARP packet. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.4.1.2 (hh3cARPTrapAckSourceIP) |
Sender IP address in the received ARP packet. |
N/A |
IpAddress |
Recommended action
1.Check whether an ARP packet attack exists on the network and identify the attack source through capturing packets.
hh3cARPTrapSpeedLimitAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.5.0.1 |
The sending rate of ARP packets or ARP Miss messages exceeded the alarm threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.217.2.5.0.2 (hh3cARPTrapSpeedLimitResume) |
OFF |
This notification is generated when the sending rate of ARP packets or ARP Miss messages exceeds the alarm threshold.
System impact
Some normal ARP packets might be dropped, which causes traffic interruption.
Status control
ON
CLI: Use the snmp-agent trap enable arp rate-limit command.
OFF
CLI: Use the undo snmp-agent trap enable arp rate-limit command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.2.5.1.1 (hh3cARPTrapSpeedLimitChassis) |
Chassis number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.5.1.2 (hh3cARPTrapSpeedLimitSlot) |
Slot number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.5.1.3 (hh3cARPTrapSpeedLimitSupValue) |
Sending rate limit (in pps) for ARP packets or ARP Miss messages. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.5.1.4 (hh3cARPTrapSpeedLimitCurValue) |
Current sending rate (in pps) of ARP packets or ARP Miss messages. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.5.1.5 (hh3cARPTrapSpeedLimitSupType) |
Rate limit type. |
N/A |
INTEGER |
packet(1), miss(2) |
Recommended action
1.Check whether an ARP packet attack exists on the network. Identify the source for the IP packets with unresolvable destination IP addresses through capturing packets and check whether the source is reasonable.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.5.0.2 |
The sending rate of ARP packets or ARP Miss messages dropped below 60% of the alarm threshold. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the sending rate of ARP packets or ARP Miss messages drops below 60% of the alarm threshold.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Chassis number. |
N/A |
Unsigned32 |
Slot number. |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
N/A |
Unsigned32 |
Rate limit type. |
N/A |
INTEGER |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.6.0.1 |
The device received an invalid ARP packet. |
Error |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the device receives an invalid ARP packet.
System impact
An ARP packet attack might exists on the network, which affects device operation.
Status control
ON
CLI: Use the snmp-agent trap enable arp packet-check command.
OFF
CLI: Use the undo snmp-agent trap enable arp packet-check command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.2.6.1.1 (hh3cARPTrapPktValidCheckIf) |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.6.1.2 (hh3cARPTrapPktValidCheckMac) |
Sender MAC address in the ARP packet. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.6.1.3 (hh3cARPTrapPktValidCheckIp) |
Sender IP address in the ARP packet. |
N/A |
IpAddress |
1.3.6.1.4.1.25506.2.217.2.6.1.4 (hh3cARPTrapPktValidCheckVlan) |
VLAN ID of the ARP packet. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.6.1.5 (hh3cARPTrapPktValidtCheckSvlan) |
Service VLAN ID of the ARP packet. |
N/A |
Unsigned32 |
Recommended action
- If the notification is generated continuously, identify the attack source through capturing packets.
- If the notification is not generated continuously, no action is required.
hh3cARPTrapGatewayCheckAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.7.0.1 |
The device received an ARP packet in which the sender IP address is the same as the gateway IP address. |
Error |
Warning |
1.3.6.1.4.1.25506.2.217.2.7.0.1 (hh3cARPTrapGatewayCheckResume) |
OFF |
This notification is generated when the device receives an ARP packet in which the sender IP address is the same as the gateway IP address.
System impact
The network might have a device which forges the gateway. This might affect normal services.
Status control
ON
CLI: Use the snmp-agent trap enable arp gateway-check command.
OFF
CLI: Use the undo snmp-agent trap enable arp gateway-check command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.2.7.1.1 (hh3cARPTrapGateWayCheckIf) |
Interface that receives the ARP attack packet. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.7.1.2 (hh3cARPTrapGateWayCheckSlot) |
Slot number of the interface module that receives the ARP attack packet. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.7.1.3 (hh3cARPTrapGateWayCheckIp) |
Sender IP address in the ARP attack packet. |
N/A |
IpAddress |
Recommended action
1.Check whether another device on the network has the same IP address as the gateway IP address.
- If the device that has the same IP address as the gateway IP address exists, change the IP address of the device.
- If the device that has the same IP address as the gateway IP address does not exist, an attack might exist. As a best practice, identify the attack source through capturing packets.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.7.0.2 |
The condition that the device received an ARP packet in which the sender IP address is the same as the gateway IP address was cleared. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the device does not receive any ARP packets in which the sender IP address is the same as the gateway IP address within 3 minutes.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
OCTET STRING |
N/A |
Unsigned32 |
N/A |
IpAddress |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.8.0.1 |
ARP attack detection dropped a packet on a VLAN interface. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when ARP attack detection drops a packet on a VLAN interface.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable arp detection-drop command.
OFF
CLI: Use the undo snmp-agent trap enable arp detection-drop command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.2.8.1.1 (hh3cARPTrapDtcDropVlanPktChassis) |
Chassis number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.8.1.2 (hh3cARPTrapDtcDropVlanPktSlot) |
Slot number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.8.1.3 (hh3cARPTrapDtcDropVlanPktIfName) |
Interface name. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.8.1.4 (hh3cARPTrapDtcDropVlanPktVlanId) |
VLAN ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.8.1.5 (hh3cARPTrapDtcDropVlanPktServId) |
Service ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.8.1.6 (hh3cARPTrapDtcDropVlanPktType) |
Reason why ARP attack detection drops a packet. |
N/A |
INTEGER |
sourceMacInvalidDrop (1), destMacInvalidDrop (2), ipInvalidDrop (3), ipcimNobindingDrop (4) |
Recommended action
hh3cARPTrapDtcDropVsiPktAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.9.0.1 |
ARP attack detection dropped a packet on a VSI interface. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when ARP attack detection drops a packet on a VSI interface.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.2.9.1.1 (hh3cARPTrapDtcDropVsiPktChassis) |
Chassis number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.9.1.2 (hh3cARPTrapDtcDropVsiPktSlot) |
Slot number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.9.1.3 (hh3cARPTrapDtcDropVsiPktIfName) |
Interface name. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.9.1.4 (hh3cARPTrapDtcDropVsiPktVlanId) |
VLAN ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.9.1.5 (hh3cARPTrapDtcDropVsiPktServId) |
Service ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.9.1.6 (hh3cARPTrapDtcDropVsiPktType) |
N/A |
INTEGER |
Recommended action
hh3cARPTrapDtcDropIfPktAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.10.0.1 |
ARP attack detection dropped a packet on a Layer 2 Ethernet interface. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when ARP attack detection drops a packet on a Layer 2 Ethernet interface.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.2.10.1.1 (hh3cARPTrapDtcDropIfPktChassis) |
Chassis number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.10.1.2 (hh3cARPTrapDtcDropIfPktSlot) |
Slot number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.10.1.3 (hh3cARPTrapDtcDropIfPktIfName) |
Interface name. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.10.1.4 (hh3cARPTrapDtcDropIfPktVlanId) |
VLAN ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.10.1.5 (hh3cARPTrapDtcDropIfPktServId) |
Service ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.10.1.6 (hh3cARPTrapDtcDropIfPktType) |
N/A |
INTEGER |
Recommended action
hh3cARPTrapMacMismatch
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.11.0.1 |
The MAC address in the static ARP entry was inconsistent with the actual MAC address. |
Error |
Warning |
1.3.6.1.4.1.25506.2.217.2.11.0.1 (hh3cARPTrapMacMismatchResume) |
OFF |
This notification is generated when the MAC address in the static ARP entry is inconsistent with the MAC address in the received ARP packet.
System impact
The short static ARP entry cannot be resolved, which affects normal services.
Status control
ON
CLI: Use the snmp-agent trap enable arp mac-mismatch command.
OFF
CLI: Use the undo snmp-agent trap enable arp mac-mismatch command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.2.11.1.1 (hh3cARPTrapMacMismatchChassis) |
Chassis number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.11.1.2 (hh3cARPTrapMacMismatchSlot) |
Slot number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.11.1.3 (hh3cARPTrapMacMismatchIfName) |
Interface name. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.11.1.4 (hh3cARPTrapMacMismatchIP) |
IP address in the static ARP entry. |
N/A |
IpAddress |
1.3.6.1.4.1.25506.2.217.2.11.1.5 (hh3cARPTrapMacMismatchVrf) |
VPN instance for the static ARP entry. |
N/A |
N/A |
N/A |
1.3.6.1.4.1.25506.2.217.2.11.1.6 (hh3cARPTrapMacMismatchMac) |
MAC address in the static ARP entry. |
N/A |
OCTET STRING |
Recommended action
Check whether the MAC address in the ARP packet is correct.
● If the MAC address is correct, edit the static ARP entry.
● If the MAC address is incorrect, the ARP packet is invalid and no action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.11.0.2 |
The MAC address in the static ARP entry is consistent with the actual MAC address. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the MAC address in the static ARP entry is consistent with the MAC address in the received ARP packet.
System impact
The short static ARP entry is resolved and services become normal.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Chassis number. |
N/A |
Unsigned32 |
Slot number. |
N/A |
Unsigned32 |
Interface name. |
N/A |
OCTET STRING |
N/A |
IpAddress |
N/A |
N/A |
N/A |
N/A |
OCTET STRING |
Recommended action
hh3cARPTrapEntryCheck
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.217.2.12.0.2 |
The device received an ARP packet which edited an existing ARP entry. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the device receives an ARP packet in which the information is inconsistent with the existing ARP entry.
System impact
User spoofing exists on the network, which affects normal services.
Status control
ON
CLI: Use the snmp-agent trap enable arp entry-check command.
OFF
CLI: Use the undo snmp-agent trap enable arp entry-check command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.217.2.12.1.1 (hh3cARPTrapEntryCheckChassis) |
Chassis number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.12.1.2 (hh3cARPTrapEntryCheckSlot) |
Slot number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.217.2.12.1.3 (hh3cARPTrapEntryCheckIfName) |
Interface name. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.12.1.4 (hh3cARPTrapEntryCheckIP) |
IP address in the original ARP entry. |
N/A |
IpAddress |
1.3.6.1.4.1.25506.2.217.2.12.1.5 (hh3cARPTrapEntryCheckMac) |
MAC address in the modified ARP entry. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.217.2.12.1.6 (hh3cARPTrapEntryCheckPeVlan) |
Inner VLAN of the modified ARP entry. |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.217.2.12.1.7 (hh3cARPTrapEntryCheckCeVlan) |
Outer VLAN of the modified ARP entry. |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.217.2.12.1.8 (hh3cARPTrapEntryCheckPortIfName) |
Interface name in the modified ARP entry. |
N/A |
DisplayString |
Recommended action
1.Check whether the ARP entry change is reasonable.
- If the change is reasonable, no action is required.
- If the change is unreasonable, identify the ARP packet source through the MAC address. Check whether an ARP packet attack exists and take attack prevention measures.
