06-Layer 3 - IP Services
HomeSupportRoutersCR16000-M SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-M Routers Alarm Reference-R838x-6W10006-Layer 3 - IP Services
10-HH3C-IPV6-ADDRESS-MIB
10-HH3C-IPV6-ADDRESS-MIB 37.92 KB
About this MIB
Use this MIB to obtain and configure IPv6 addresses.
MIB file name
hh3c-ipv6-address.mib
Notifications
hh3cIpv6AddrSetProEnableFailed
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.71.1.2.0.1
IPv6 enabling failed.
Informational
Major
N/A (N/A)
ON
Notification triggers
This notification is generated when IPv6 fails to be enabled on an interface due to insufficient system resources.
System impact
IPv6 services are unavailable on the interface.
Status control
ON
CLI: snmp-agent trap enable ipv6 address [ protocol-enable-failure ]
OFF
CLI: undo snmp-agent trap enable ipv6 address [ protocol-enable-failure ]
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.71.1.2.1.1 (hh3cIpv6AddrSetProEnableIfName)
Interface name.
N/A
OCTET STRING
OCTET STRING (0..255)
1.3.6.1.4.1.25506.2.71.1.2.1.2 (hh3cIpv6AddrSetProEnableChassis)
Chassis number.
N/A
Unsigned32
Unsigned32(0..65535)
1.3.6.1.4.1.25506.2.71.1.2.1.3 (hh3cIpv6AddrSetProEnableSlot)
Slot number.
N/A
Unsigned32
Recommended action
To resolve the issue:
1.Use the display ipv6 interface command to view IPv6 information on all interfaces.
2.Based on network planning and service deployment, examine whether IPv6 is not required on some interfaces enabled with IPv6.
  - If such interfaces do not exist, proceed to step 3.
  - If such interfaces exist, use the undo ipv6 address command to delete all IPv6 addresses of the interfaces. Then, try to configure an IPv6 address for the target interface for which the notification is generated.
3.Collect alarm information and configuration data, and then contact H3C Support for help.
