04-Layer 2—LAN Switching Configuration Guide
HomeSupportSwitchesS7500X-G SeriesConfigure & DeployConfiguration GuidesH3C S7500X-G Switch Series Configuration Guides-R7748Pxx-6W10004-Layer 2—LAN Switching Configuration Guide
12-Layer 2 forwarding configuration
12-Layer 2 forwarding configuration 32.75 KB
Configuring cut-through Layer 2 forwarding
About cut-through Layer 2 forwarding
A cut-through forwarding-enabled device forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame and enhances forwarding performance.
Restrictions and guidelines for cut-through Layer 2 forwarding configuration
With cut-through forwarding, the device forwards CRC-error frames because it starts forwarding frames before their CRC field is received.
For cut-through Layer 2 forwarding configuration to take effect, save the configuration and reboot the device after you configure cut-through Layer 2 forwarding.
2.     Enable cut-through forwarding.
cut-through enable
By default, cut-through forwarding is disabled.
