- 06-WLAN access
- 01-WEP Encryption Configuration Examples
- 02-PSK Encryption Configuration Examples
- 03-WPA3-SAE PSK Encryption Configuration Examples
- 04-WLAN Access (IPv6) Configuration Examples
- 05-Policy-Based Forwarding with Dual Gateways Configuration Examples
- 06-Scheduled Configuration Deployment by AP Group Configuration Examples
- 07-Inter-AC Roaming with Static Client VLAN Allocation Configuration Examples
- 08-Service Template and Radio Binding Configuration Examples
- 09-Scheduled WLAN Access Services Configuration Examples
| 02-PSK Encryption Configuration Examples | 74.23 KB |
H3C Access Controllers |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring PSK encryption.
This document applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of WLAN access and WLAN security.
Example: Configuring PSK encryption
As shown in Figure 1, the switch acts as a DHCP server to assign IP addresses to the AP and the client. Perform the following tasks:
· Configure PSK on the AC to enable the client to use PSK for encryption.
· Configure open system authentication and bypass authentication so that the client can access the WLAN without being authenticated.
· Configure PSK as the authentication and key management (AKM) mode.
· Set the cipher suite to CCMP.
· Set the security IE to RSN.
When you configure PSK encryption, follow these restrictions and guidelines:
· Use the serial ID labeled on the AP's rear panel to specify an AP.
· Configure a pre-shared key if the AKM mode is PSK.
Procedures
Configuring the AC
1. Configure AC interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.1.1 16
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The client will use this VLAN to access the WLAN.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.1.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100 and 200.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2. Configure wireless services:
# Create service template 1 and enter its view.
[AC] wlan service-template 1
# Configure the SSID as service.
[AC-wlan-st-1] ssid service
# Specify VLAN 200 for clients to access the WLAN defined by the service template.
[AC-wlan-st-1] vlan 200
# Set the AKM mode to PSK, and configure simple character string of 12345678 as the PSK.
[AC-wlan-st-1] akm mode psk
[AC-wlan-st-1] preshared-key pass-phrase simple 12345678
# Set the cipher suite to CCMP and set the security IE to RSN.
[AC-wlan-st-1] cipher-suite ccmp
[AC-wlan-st-1] security-ie rsn
# Configure the AC to forward client data traffic. You can skip this step if the AC is the client traffic forwarder by default.
[AC-wlan-st-1] client forwarding-location ac
# Enable the service template.
[AC-wlan-st-1] quit
3. Configure the AP:
NOTE: In a large-scale network, configure AP groups instead of single APs as a best practice. |
# Create manual AP officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA6320
[AC-wlan-ap-officeap] serial-id 219801A28N819CE0002T
[AC-wlan-ap-officeap] quit
# Create AP group group1, and add the AP to the AP group.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap officeap
# Bind service template 1 to radio 2.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template 1
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] quit
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
Configuring the switch
1. Configure switch interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The switch will use VLAN 100 to forward packets between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.1.2 16
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The switch will use VLAN 200 to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.1.2 24
[Switch-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100 and 200.
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 that connects the switch to the AP as a trunk port, remove the port from VLAN 1, set the PVID to VLAN 100, and assign the port to VLAN 100.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 100
[Switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
# Enable PoE on GigabitEthernet 1/0/2.
2. Configure DHCP:
# Enable DHCP.
[Switch] dhcp enable
# Create DHCP address pool vlan100 to assign an IP address to the AP, and specify subnet 192.1.0.0/16 in the DHCP address pool.
[Switch] dhcp server ip-pool vlan100
[Switch-dhcp-pool-vlan100] network 192.1.0.0 mask 255.255.0.0
# Exclude IP address 192.1.1.1 from dynamic allocation in the address pool.
[Switch-dhcp-pool-vlan100] forbidden-ip 192.1.1.1
# Specify the gateway address as 192.1.1.2 in the DHCP address pool.
[Switch-dhcp-pool-vlan100] gateway-list 192.1.1.2
[Switch-dhcp-pool-vlan100] quit
# Create DHCP address pool vlan200 to assign an IP address to the client, and specify subnet 192.2.1.0/24 in the DHCP address pool.
[Switch] dhcp server ip-pool vlan200
[Switch-dhcp-pool-vlan200] network 192.2.1.0 mask 255.255.255.0
# Exclude IP address 192.2.1.1 from dynamic allocation in the address pool.
[Switch-dhcp-pool-vlan200] forbidden-ip 192.2.1.1
# Specify the gateway address as 192.2.1.2 and specify the DNS server address in the DHCP address pool. In this example, the gateway also acts as a DNS server.
[Switch-dhcp-pool-vlan200] gateway-list 192.2.1.2
[Switch-dhcp-pool-vlan200] dns-list 192.2.1.2
[Switch-dhcp-pool-vlan200] quit
# Verify that the client has been associated with the WLAN and the AKM mode is PSK.
[AC] display wlan client verbose
Total number of clients: 1
MAC address : 0024-d705-c608
IPv4 address : 192.2.1.3
IPv6 address : N/A
Username : N/A
AID : 1
AP ID : 2
AP name : officeap
Radio ID : 2
SSID : service
BSSID : 80f6-2eaf-5190
VLAN ID : 200
Sleep count : 137
Wireless mode : 802.11g
Supported rates : 1, 2, 5.5, 6, 9, 11,
12, 18, 24, 36, 48, 54 Mbps
QoS mode : WMM
Listen interval : 100
RSSI : 20
Rx/Tx rate : 2/1
Authentication method : Open system
Security mode : PRE-RSNA
AKM mode : N/A
Security mode : RSN
AKM mode : PSK
Cipher suite : CCMP
User authentication mode : Bypass
Authorization ACL ID : N/A
Authorization user profile : N/A
Roam status : N/A
Key derivation : N/A
PMF status : N/A
Forwarding policy name : N/A
Online time : 0days 0hours 21minutes 55seconds
FT status : Inactive
Configuration files
· AC:
vlan 100
vlan 200
ssid service
vlan 200
akm mode psk
preshared-key pass-phrase cipher $c$3$N//5BVbsOqdBTxi+7MJZKT6Zqh5MAmYs2ZzM
cipher-suite ccmp
security-ie rsn
interface Vlan-interface100
ip address 192.1.1.1 255.255.0.0
interface Vlan-interface200
ip address 192.2.1.1 255.255.255.0
ap officeap
ap-model WA6320
radio 2
radio enable
service-template 1
· Switch:
dhcp enable
vlan 100
vlan 200
dns-list 192.2.1.2
poe enable
Related documentation
· WLAN Access Command Reference in H3C Access Controllers Command References
· WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
