05-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10005-Layer 2 - LAN Switching
24-Q-BRIDGE-MIB
24-Q-BRIDGE-MIB 144.56 KB
Q-BRIDGE-MIB
About this MIB
Use this MIB to manage Virtual Bridged Local Area Networks, as defined by IEEE 802.1Q-2003.
MIB file name
rfc4363-qbridge.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).dot1dBridge(17).qBridgeMIB(7)
Scalar objects
dot1qVlanNumDeletes
Object (OID)
Access
Value range
Implementation
dot1qVlanNumDeletes (1.3.6.1.2.1.17.7.1.4.1)
read-only
Counter32
Standard MIB values.
The number of times a VLAN entry has been deleted from the dot1qVlanCurrentTable (for any reason).
Not supported
dot1qNextFreeLocalVlanIndex
Object (OID)
Access
Value range
Implementation
dot1qNextFreeLocalVlanIndex (1.3.6.1.2.1.17.7.1.4.4)
read-only
Integer32
Integer32 (0|4096..2147483647)
The next available value for dot1qVlanIndex of a local VLAN entry in dot1qVlanStaticTable.
Not supported
dot1qConstraintSetDefault
Object (OID)
Access
Value range
Implementation
dot1qConstraintSetDefault (1.3.6.1.2.1.17.7.1.4.9)
read-write
Integer32
Integer32 (0..65535)
The identity of the constraint set to which a VLAN belongs, if there is not an explicit entry for that VLAN in dot1qLearningConstraintsTable.
Not supported
dot1qConstraintTypeDefault
Object (OID)
Access
Value range
Implementation
dot1qConstraintTypeDefault (1.3.6.1.2.1.17.7.1.4.10)
read-write
INTEGER
independent(1)
shared(2)
The type of constraint set to which a VLAN belongs.
Supports only the read operation.
dot1qVlanVersionNumber
Object (OID)
Access
Value range
Implementation
dot1qVlanVersionNumber (1.3.6.1.2.1.17.7.1.1.1)
read-only
INTEGER
version1(1)
The version number of IEEE 802.1Q that this device supports.
As per the MIB.
dot1qMaxVlanId
Object (OID)
Access
Value range
Implementation
dot1qMaxVlanId (1.3.6.1.2.1.17.7.1.1.2)
read-only
VlanId
The maximum IEEE 802.1Q VLAN ID that this device supports.
As per the MIB.
dot1qMaxSupportedVlans
Object (OID)
Access
Value range
Implementation
dot1qMaxSupportedVlans (1.3.6.1.2.1.17.7.1.1.3)
read-only
Unsigned32
The maximum number of IEEE 802.1Q VLANs that this device supports.
As per the MIB.
dot1qNumVlans
Object (OID)
Access
Value range
Implementation
dot1qNumVlans (1.3.6.1.2.1.17.7.1.1.4)
read-only
Unsigned32
The current number of IEEE 802.1Q VLANs that are configured in this device.
As per the MIB.
dot1qGvrpStatus
Object (OID)
Access
Value range
Implementation
dot1qGvrpStatus (1.3.6.1.2.1.17.7.1.1.5)
read-write
EnabledStatus
enabled(1)
disabled(2)
The administrative status requested by management for GVRP:
·     enable(1)—GVRP should be enabled on this device, on all ports for which it has not been specifically disabled.
·     disable(2)—GVRP is disabled on all ports.
Not supported
Tabular objects
dot1qFdbTable
About this table
Use this table to display configuration and control information for each filtering database currently operating on this device.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is dot1qFdbId.
Object (OID)
Access
Value range
Implementation
dot1qFdbId
(1.3.6.1.2.1.17.7.1.2.1.1.1)
not-accessible
Unsigned32
The identity of this filtering database.
As per the MIB.
dot1qFdbDynamicCount
(1.3.6.1.2.1.17.7.1.2.1.1.2)
read-only
Counter32
The current number of dynamic entries in this filtering database.
As per the MIB.
dot1qTpFdbTable
About this table
Use this table to display information about unicast entries for which the device has forwarding and/or filtering information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are dot1qFdbId and dot1qTpFdbAddress.
Object (OID)
Access
Value range
Implementation
dot1qTpFdbAddress (1.3.6.1.2.1.17.7.1.2.2.1.1)
not-accessible
MacAddress
A unicast MAC address for which the device has forwarding and/or filtering information.
As per the MIB.
dot1qTpFdbPort (1.3.6.1.2.1.17.7.1.2.2.1.2)
read-only
Integer32
The port number of the port on which a frame having a source address equal to the value of the corresponding instance of dot1qTpFdbAddress has been seen.
A value of 0 indicates that the port number has not been learned but that the device does have some forwarding/filtering information about this address.
As per the MIB.
dot1qTpFdbStatus (1.3.6.1.2.1.17.7.1.2.2.1.3)
read-only
INTEGER
other(1)
invalid(2)
learned(3)
self(4)
mgmt(5)
The status of this entry.
Manually added dynamic MAC address entries are counted as learned MAC address entries.
dot1qTpGroupTable
About this table
Use this table to obtain filtering information for VLANs configured into the bridge by (local or network) management, or learned dynamically.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are dot1qVlanIndex and dot1qTpGroupAddress.
Object (OID)
Access
Value range
Implementation
dot1qTpGroupAddress (1.3.6.1.2.1.17.7.1.2.3.1.1)
not-accessible
MacAddress
The destination group MAC address in a frame to which this entry's filtering information applies.
As per the MIB.
dot1qTpGroupEgressPorts (1.3.6.1.2.1.17.7.1.2.3.1.2)
read-only
PortList
The complete set of ports, in this VLAN, to which frames destined for this Group MAC address are currently being explicitly forwarded.
As per the MIB.
dot1qTpGroupLearnt (1.3.6.1.2.1.17.7.1.2.3.1.3)
read-only
PortList
The subset of ports in dot1qTpGroupEgressPorts that were learned by GMRP or some other dynamic mechanism, in this filtering database.
As per the MIB.
dot1qForwardAllTable
About this table
Use this table to obtain forwarding information for each VLAN, specifying the set of ports to which forwarding of all multicasts applies.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table index is dot1qVlanIndex.
Object (OID)
Access
Value range
Implementation
dot1qForwardAllPorts
(1.3.6.1.2.1.17.7.1.2.4.1.1)
read-only
PortList
The complete set of ports in this VLAN to which all multicast group-addressed frames are to be forwarded.
This includes ports for which this need has been determined dynamically by GMRP, or configured statically by management.
Not supported
dot1qForwardAllStaticPorts
(1.3.6.1.2.1.17.7.1.2.4.1.2)
read-write
PortList
The set of ports configured by management in this VLAN to which all multicast group-addressed frames are to be forwarded.
Not supported
dot1qForwardAllForbiddenPorts
(1.3.6.1.2.1.17.7.1.2.4.1.3)
read-write
PortList
The set of ports configured by management in this VLAN for which the Service Requirement attribute Forward All Multicast Groups may not be dynamically registered by GMRP.
Not supported
dot1qForwardUnregisteredTable
About this table
Use this table to obtain forwarding information for each VLAN, specifying the set of ports to which forwarding of multicast group-addressed frames for which no more specific forwarding information applies.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
Object (OID)
Access
Value range
Implementation
dot1qForwardUnregisteredPorts
(1.3.6.1.2.1.17.7.1.2.5.1.1)
read-only
PortList
The complete set of ports in this VLAN to which multicast group-addressed frames for which there is no more specific forwarding information will be forwarded.
Not supported
dot1qForwardUnregisteredStaticPorts (1.3.6.1.2.1.17.7.1.2.5.1.2)
read-write
PortList
The set of ports configured by management, in this VLAN, to which multicast group-addressed frames for which there is no more specific forwarding information.
Not supported
dot1qForwardUnregisteredForbiddenPorts (1.3.6.1.2.1.17.7.1.2.5.1.3)
read-write
PortList
The set of ports configured by management in this VLAN for which the Service Requirement attribute Forward Unregistered Multicast Groups may not be dynamically registered by GMRP.
Not supported
dot1qStaticUnicastTable
About this table
Use this table to obtain filtering information for unicast MAC addresses for each filtering database.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are dot1qFdbId, dot1qStaticUnicastAddress, and dot1qStaticUnicastReceivePort.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.17.7.1.3.1.1.1)
not-accessible
MacAddress
The destination MAC address in a frame to which this entry's filtering information applies.
Not supported
(1.3.6.1.2.1.17.7.1.3.1.1.2)
not-accessible
Integer32
The port number of the port from which a frame must be received in order for this entry's filtering information to apply.
A value of 0 indicates that this entry applies on all ports of the device for which there is no other applicable entry.
Not supported
dot1qStaticUnicastAllowedToGoTo
(1.3.6.1.2.1.17.7.1.3.1.1.3)
read-write
PortList
The set of ports for which a frame with a specific unicast address will be flooded in the event that it has not been learned.
Not supported
dot1qStaticUnicastStatus
(1.3.6.1.2.1.17.7.1.3.1.1.4)
read-write
INTEGER
other(1)
invalid(2)
permanent(3)
deleteOnReset(4)
deleteOnTimeout(5)
Status of this entry.
Not supported
dot1qStaticMulticastTable
About this table
Use this table to obtain filtering information for multicast and broadcast MAC addresses for each VLAN.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are dot1qVlanIndex, dot1qStaticMulticastAddress, and dot1qStaticMulticastReceivePort.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.17.7.1.3.2.1.1)
not-accessible
MacAddress
Not supported
(1.3.6.1.2.1.17.7.1.3.2.1.2)
not-accessible
Integer32
Not supported
dot1qStaticMulticastStaticEgressPorts
(1.3.6.1.2.1.17.7.1.3.2.1.3)
read-write
PortList
The set of ports to which frames received from a specific port and destined for a specific multicast or broadcast MAC address must be forwarded.
Not supported
dot1qStaticMulticastForbiddenEgressPorts
(1.3.6.1.2.1.17.7.1.3.2.1.4)
read-write
PortList
The set of ports to which frames received from a specific port and destined for a specific multicast or broadcast MAC address must not be forwarded.
Not supported
dot1qStaticMulticastStatus
(1.3.6.1.2.1.17.7.1.3.2.1.5)
read-write
INTEGER
other(1)
invalid(2)
permanent(3)
deleteOnReset(4)
deleteOnTimeout(5)
Not supported
About this table
Use this table to obtain current configuration information for each VLAN currently configured into the device.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are dot1qVlanTimeMark and dot1qVlanIndex.
Object (OID)
Access
Value range
Implementation
dot1qVlanTimeMark
(1.3.6.1.2.1.17.7.1.4.2.1.1)
not-accessible
TimeFilter
A time filter for this entry.
As per the MIB.
dot1qVlanIndex
(1.3.6.1.2.1.17.7.1.4.2.1.2)
not-accessible
VlanIndex
The VLAN-ID or other identifier referring to this VLAN.
As per the MIB.
dot1qVlanFdbId
(1.3.6.1.2.1.17.7.1.4.2.1.3)
read-only
Unsigned32
The filtering database used by this VLAN.
As per the MIB.
dot1qVlanCurrentEgressPorts
(1.3.6.1.2.1.17.7.1.4.2.1.4)
read-only
PortList
The set of ports that are transmitting traffic for this VLAN as either tagged or untagged frames.
As per the MIB.
dot1qVlanCurrentUntaggedPorts
(1.3.6.1.2.1.17.7.1.4.2.1.5)
read-only
PortList
The set of ports that are transmitting traffic for this VLAN as untagged frames.
As per the MIB.
dot1qVlanStatus
(1.3.6.1.2.1.17.7.1.4.2.1.6)
read-only
INTEGER
other(1)
permanent(2)
dynamicGvrp(3)
Status of this VLAN.
As per the MIB.
dot1qVlanCreationTime
(1.3.6.1.2.1.17.7.1.4.2.1.7)
read-only
TimeTicks
Time when this VLAN was created.
As per the MIB.
About this table
Use this table to obtain static configuration information for each VLAN configured into the device.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
dot1qVlanStaticName (1.3.6.1.2.1.17.7.1.4.3.1.1)
read-create
SnmpAdminString
OCTET STRING (0..32)
VLAN name.
If the name string is too long or empty, a default name in the vlan VLAN ID format applies.
dot1qVlanStaticEgressPorts (1.3.6.1.2.1.17.7.1.4.3.1.2)
read-create
PortList
The set of ports that are permanently assigned to the egress list for this VLAN by management.
As per the MIB.
dot1qVlanForbiddenEgressPorts (1.3.6.1.2.1.17.7.1.4.3.1.3)
read-create
PortList
The set of ports that are prohibited by management from being included in the egress list for this VLAN.
Not supported
dot1qVlanStaticUntaggedPorts (1.3.6.1.2.1.17.7.1.4.3.1.4)
read-create
PortList
The set of ports that should transmit egress packets for this VLAN as untagged.
As per the MIB.
dot1qVlanStaticRowStatus (1.3.6.1.2.1.17.7.1.4.3.1.5)
read-create
RowStatus
Supports only active(1), createAndgo(4) and destroy(6). You cannot delete the default VLAN.
dot1qPortVlanTable
About this table
Use this table to obtain per-port control and status information for VLAN configuration in the device.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
dot1qPvid (1.3.6.1.2.1.17.7.1.4.5.1.1)
read-write
VlanIndex
The PVID, the VLAN ID assigned to untagged frames received on this port.
Does not support the write operation on an access port.
dot1qPortAcceptableFrameTypes (1.3.6.1.2.1.17.7.1.4.5.1.2)
read-write
INTEGER
admitAll(1)
admitOnlyVlanTagged(2)
Packet types that this port can receive:
·     admitOnlyVlanTagged(2)—Drop untagged packets.
·     admitAll(1)—Accept untagged packets and assign them the PVID.
dot1qPortIngressFiltering (1.3.6.1.2.1.17.7.1.4.5.1.3)
read-write
TruthValue
true(1),
false(2)
When this is true(1), the device will discard incoming frames for VLANs that do not include this port in its member set. When false(2), the port will accept all incoming frames.
dot1qPortGvrpStatus (1.3.6.1.2.1.17.7.1.4.5.1.4)
read-write
EnabledStatus
enabled(1),
disabled(2)
The state of GVRP operation on this port:
·     enabled(1)—GVRP is enabled.
·     disabled(2)—GVRP is disabled. This port drops any incoming GVRP frames.
Not supported
dot1qPortGvrpFailedRegistrations (1.3.6.1.2.1.17.7.1.4.5.1.5)
read-only
Counter32
The total number of failed GVRP registrations, for any reason, on this port.
Not supported
dot1qPortGvrpLastPduOrigin (1.3.6.1.2.1.17.7.1.4.5.1.6)
read-only
MacAddress
The source MAC address of the last GVRP message received on this port.
Not supported
dot1qPortRestrictedVlanRegistration
(1.3.6.1.2.1.17.7.1.4.5.1.7)
read-write
TruthValue
true(1),
false(2)
The state of restricted vlan registration on this port. If the value of this object is true(1), then creation of a new dynamic VLAN entry is permitted only if there is a static vlan registration entry for the VLAN concerned, in which the registrar administrative control value for this port is normal registration.
Not supported
dot1qPortVlanStatisticsTable
About this table
Use this table to obtain per-port, per-VLAN statistics for traffic received. Separate objects are provided for both the most-significant and least-significant bits of statistics counters for ports that are associated with this transparent bridge. The most-significant bit objects are only required on high-capacity interfaces, as defined in the conformance clauses for these objects. This mechanism is provided as a way to read 64-bit counters for agents that support only SNMPv1.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are dot1dBasePort and dot1qVlanIndex.
Object (OID)
Access
Value range
Implementation
dot1qTpVlanPortInFrames
(1.3.6.1.2.1.17.7.1.4.6.1.1)
read-only
Counter32
The number of valid frames received by this port from its segment that were classified as belonging to this VLAN.
Not supported
dot1qTpVlanPortOutFrames
(1.3.6.1.2.1.17.7.1.4.6.1.2)
read-only
Counter32
The number of valid frames transmitted by this port to its segment from the local forwarding process for this VLAN.
Not supported
dot1qTpVlanPortInDiscards
(1.3.6.1.2.1.17.7.1.4.6.1.3)
read-only
Counter32
The number of valid frames received by this port from its segment that were classified as belonging to this VLAN and that were discarded due to VLAN-related reasons.
Not supported
dot1qTpVlanPortInOverflowFrames
(1.3.6.1.2.1.17.7.1.4.6.1.4)
read-only
Counter32
The number of times the associated dot1qTpVlanPortInFrames counter has overflowed.
Not supported
dot1qTpVlanPortOutOverflowFrames
(1.3.6.1.2.1.17.7.1.4.6.1.5)
read-only
Counter32
The number of times the associated dot1qTpVlanPortOutFrames counter has overflowed.
Not supported
dot1qTpVlanPortInOverflowDiscards
(1.3.6.1.2.1.17.7.1.4.6.1.6)
read-only
Counter32
The number of times the associated dot1qTpVlanPortInDiscards counter has overflowed.
Not supported
dot1qPortVlanHCStatisticsTable
About this table
Use this table to obtain per-port, per-VLAN statistics for traffic on high-capacity interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
Object (OID)
Access
Value range
Implementation
dot1qTpVlanPortHCInFrames
 (1.3.6.1.2.1.17.7.1.4.7.1.1)
read-only
Counter64
Not supported
dot1qTpVlanPortHCOutFrames
(1.3.6.1.2.1.17.7.1.4.7.1.2)
read-only
Counter64
Not supported
dot1qTpVlanPortHCInDiscards
(1.3.6.1.2.1.17.7.1.4.7.1.3)
read-only
Counter64
Not supported
About this table
Use this table to obtain learning constraints for sets of shared and independent VLANs.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are dot1qConstraintVlan and dot1qConstraintSet.
Object (OID)
Access
Value range
Implementation
dot1qConstraintVlan
 (1.3.6.1.2.1.17.7.1.4.8.1.1)
not-accessible
VlanIndex
The index of the row in this table for the VLAN constrained by this entry.
Not supported
dot1qConstraintSet
(1.3.6.1.2.1.17.7.1.4.8.1.2)
not-accessible
Integer32
The identity of the constraint set to which dot1qConstraintVlan belongs.
Not supported
dot1qConstraintType
(1.3.6.1.2.1.17.7.1.4.8.1.3)
read-create
INTEGER
independent(1),
shared(2)
The type of constraint this entry defines:
·     independent(1)—The VLAN uses a filtering database independent from all other VLANs in the same set.
·     shared(2)—The VLAN shares the same filtering database as all other VLANs in the same set.
Not supported
dot1qConstraintStatus
(1.3.6.1.2.1.17.7.1.4.8.1.4)
read-create
RowStatus
Status of this row.
Not supported
dot1vProtocolGroupTable
About this table
Use this table to obtain mappings from protocol templates to protocol group identifiers used for port-and-protocol-based VLAN classification.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are dot1vProtocolTemplateFrameType and dot1vProtocolTemplateProtocolValue.
Object (OID)
Access
Value range
Implementation
 (1.3.6.1.2.1.17.7.1.5.1.1.1)
not-accessible
INTEGER
ethernet(1)
rfc1042(2)
snap8021H(3)
snapOther(4)
llcOther(5)
Data-link encapsulation format.
Not supported
(1.3.6.1.2.1.17.7.1.5.1.1.2)
not-accessible
OCTET STRING
OCTET STRING SIZE (2 | 5)
The identification of the protocol above the data-link layer in a protocol template.
Not supported
dot1vProtocolGroupId
(1.3.6.1.2.1.17.7.1.5.1.1.3)
read-create
Integer32
Integer32 (0..2147483647)
A group of protocols that are associated together when assigning a VID to a frame.
Not supported
dot1vProtocolGroupRowStatus
(1.3.6.1.2.1.17.7.1.5.1.1.4)
read-create
RowStatus
Status of this row.
Not supported
dot1vProtocolPortTable
About this table
Use this table to obtain VID sets used for port-and-protocol-based VLAN classification.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are dot1dBasePort and dot1vProtocolPortGroupId.
Object (OID)
Access
Value range
Implementation
 (1.3.6.1.2.1.17.7.1.5.2.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
A group of protocols in the protocol group database.
Not supported
dot1vProtocolPortGroupVid (1.3.6.1.2.1.17.7.1.5.2.1.2)
read-create
Integer32
Integer32 (1..4094)
The VID associated with a group of protocols for each port.
Not supported
dot1vProtocolPortRowStatus
(1.3.6.1.2.1.17.7.1.5.2.1.3)
read-create
RowStatus
Status of this row.
Not supported
