05-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10005-Layer 2 - LAN Switching
07-HH3C-LswMSTP-MIB
07-HH3C-LswMSTP-MIB 144.11 KB
HH3C-LswMSTP-MIB
About this MIB
Spanning tree protocols eliminate loops by selectively blocking ports to prune the loop structure into a loop-free tree structure.
This MIB defines private MIB objects for MSTP.
MIB file name
hh3c-splat-mstp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).huawei(2011).products(2).lanSw(23).lswCommon(1).hwdotlsMstp(14)
Scalar objects
hh3cdot1sStpStatus
Object (OID)
Access
Value range
Implementation
hh3cdot1sStpStatus (1.3.6.1.4.1.25506.8.35.14.1)
read-write
EnabledStatus
enabled(1)
disabled(2)
MSTP status.
As per the MIB.
hh3cdot1sStpForceVersion
Object (OID)
Access
Value range
Implementation
hh3cdot1sStpForceVersion (1.3.6.1.4.1.25506.8.35.14.2)
read-write
INTEGER
stp(0)
rstp(2)
mstp(3)
Spanning tree mode.
Same as MIB definition. The value for PVST is 2.
hh3cdot1sStpDiameter
Object (OID)
Access
Value range
Implementation
hh3cdot1sStpDiameter (1.3.6.1.4.1.25506.8.35.14.3)
read-write
INTEGER
2..7
Network diameter.
This object is related to the dot1dStpHelloTime, dot1dStpMaxAge, and dot1dStpForwardDelay objects defined in IEEE 802.1d. Modification to the hh3cdot1sStpDiameter object will change the values of those objects.
Modification to any of the dot1dStpHelloTime, dot1dStpMaxAge, and dot1dStpForwardDelay objects will invalidate the value of the hh3cdot1sStpDiameter object.
hh3cdot1sMstBridgeMaxHops
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstBridgeMaxHops (1.3.6.1.4.1.25506.8.35.14.4)
read-write
INTEGER
1..40
Maximum hops of an MST region.
As per the MIB.
hh3cdot1sMstMasterBridgeID
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstMasterBridgeID (1.3.6.1.4.1.25506.8.35.14.5)
read-only
BridgeId
OCTET STRING (8)
Root bridge in an MSTP region.
As per the MIB.
hh3cdot1sMstMasterPathCost
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstMasterPathCost (1.3.6.1.4.1.25506.8.35.14.6)
read-only
INTEGER
Standard MIB values.
Cost of the path to the root bridge.
As per the MIB.
hh3cdot1sMstBpduGuard
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstBpduGuard (1.3.6.1.4.1.25506.8.35.14.7)
read-write
EnabledStatus
enabled(1)
disabled(2)
BPDU guard.
As per the MIB.
hh3cdot1sMstAdminFormatSelector
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstAdminFormatSelector (1.3.6.1.4.1.25506.8.35.14.8)
read-write
INTEGER
0.
Bridge selection factor.
This object is configurable, and you can set it only to 0.
hh3cdot1sMstAdminRegionName
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstAdminRegionName (1.3.6.1.4.1.25506.8.35.14.9)
read-write
OCTET STRING
SIZE (1..32)
MST region name.
As per the MIB.
hh3cdot1sMstAdminRevisionLevel
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstAdminRevisionLevel (1.3.6.1.4.1.25506.8.35.14.10)
read-write
INTEGER
0..65535
MSTP revision level.
As per the MIB.
hh3cdot1sMstOperFormatSelector
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstOperFormatSelector (1.3.6.1.4.1.25506.8.35.14.11)
read-only
INTEGER
Effective selection factor of an MSTP region.
As per the MIB.
hh3cdot1sMstOperRegionName
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstOperRegionName (1.3.6.1.4.1.25506.8.35.14.12)
read-only
OCTET STRING
SIZE (0..32)
Effective MST region name.
As per the MIB.
hh3cdot1sMstOperRevisionLevel
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstOperRevisionLevel (1.3.6.1.4.1.25506.8.35.14.13)
read-only
INTEGER
0..65535
Effective MSTP revision level.
As per the MIB.
hh3cdot1sMstOperConfigDigest
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstOperConfigDigest (1.3.6.1.4.1.25506.8.35.14.14)
read-only
OCTET STRING
SIZE (0..16)
Effective configuration digest of an MST region.
As per the MIB.
hh3cdot1sMstRegionConfActive
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstRegionConfActive (1.3.6.1.4.1.25506.8.35.14.15)
read-write
INTEGER
enable(1)
disable(2)
Activate MST region configuration.
Default: Enabled.
If you set the value to disable, MST region configuration is read-only and does not take effect.
hh3cdot1sMstDefaultVlanAllo
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstDefaultVlanAllo (1.3.6.1.4.1.25506.8.35.14.16)
read-write
INTEGER
enable(1)
unused(65535)
Default VLAN-to-instance mappings in an MST region.
As per the MIB.
hh3cdot1sMstDefaultRegionName
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstDefaultRegionName (1.3.6.1.4.1.25506.8.35.14.17)
read-write
INTEGER
enable(1)
unused(65535)
Default MST region name.
As per the MIB.
hh3cdot1sStpPathCostStandard
Object (OID)
Access
Value range
Implementation
hh3cdot1sStpPathCostStandard (1.3.6.1.4.1.25506.8.35.14.21)
read-write
INTEGER
legacy(0)
dot1d-1998(1)
dot1t(2)
Standard for calculating the default path costs.
·     legacy—Private standard.
·     dot1d-1998—IEEE 802.1d-1998.
·     dot1t—IEEE 802.1t.
Tabular objects
hh3cdot1sVIDAllocationTable
About this table
Use this table to configure MSTP VLAN settings.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cdot1sMstVID.
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstVID (1.3.6.1.4.1.25506.8.35.14.18.1.1)
read-only
INTEGER
1..4094
VLAN ID
As per the MIB.
hh3cdot1sAdminMstID (1.3.6.1.4.1.25506.8.35.14.18.1.2)
read-write
INTEGER
0..4094
Configured MST region mapping.
As per the MIB.
hh3cdot1sOperMstID (1.3.6.1.4.1.25506.8.35.14.18.1.3)
read-only
INTEGER
0..4094
Effective MST region mapping.
As per the MIB.
hh3cdot1sInstanceTable
About this table
Use this table to configure MST region settings.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cdot1sInstanceID.
Object (OID)
Access
Value range
Implementation
hh3cdot1sInstanceID (1.3.6.1.4.1.25506.8.35.14.19.1.1)
read-only
INTEGER
0..4094
Instance ID.
As per the MIB.
hh3cdot1sMstiBridgeID (1.3.6.1.4.1.25506.8.35.14.19.1.2)
read-only
BridgeId
OCTET STRING (8)
Bridge ID.
As per the MIB.
hh3cdot1sMstiBridgePriority (1.3.6.1.4.1.25506.8.35.14.19.1.3)
read-write
INTEGER
0..61440
Bridge priority.
As per the MIB.
hh3cdot1sMstiDesignedRoot (1.3.6.1.4.1.25506.8.35.14.19.1.4)
read-only
BridgeId
OCTET STRING (8)
Root bridge.
As per the MIB.
hh3cdot1sMstiRootPathCost (1.3.6.1.4.1.25506.8.35.14.19.1.5)
read-only
INTEGER
Path cost from the MSTI to the root bridge.
As per the MIB.
hh3cdot1sMstiRootPort (1.3.6.1.4.1.25506.8.35.14.19.1.6)
read-only
INTEGER
Root port.
As per the MIB.
hh3cdot1sMstiRootType (1.3.6.1.4.1.25506.8.35.14.19.1.7)
read-write
INTEGER
normal(0)
secondary(1)
primary(2)
Root bridge type.
As per the MIB.
hh3cdot1sMstiRemainingHops (1.3.6.1.4.1.25506.8.35.14.19.1.8)
read-only
INTEGER
Remaining hops.
As per the MIB.
hh3cdot1sMstiAdminMappedVlanListLow (1.3.6.1.4.1.25506.8.35.14.19.1.9)
read-only
OCTET STRING
SIZE (0..256)
Lower part of the VLAN ID list mapped to the instance.
As per the MIB.
hh3cdot1sMstiAdminMappedVlanListHigh (1.3.6.1.4.1.25506.8.35.14.19.1.10)
read-only
OCTET STRING
SIZE (0..256)
Higher part of the VLAN ID list mapped to the instance.
As per the MIB.
hh3cdot1sMstiOperMappedVlanListLow (1.3.6.1.4.1.25506.8.35.14.19.1.11)
read-only
OCTET STRING
SIZE (0..256)
Lower part of the effective VLAN ID list.
As per the MIB.
hh3cdot1sMstiOperMappedVlanListHigh (1.3.6.1.4.1.25506.8.35.14.19.1.12)
read-only
OCTET STRING
SIZE (0..256)
Higher part of the effective VLAN ID list.
As per the MIB.
hh3cdot1sPortTable
About this table
Use this table to configure MSTP on ports.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are hh3cdot1sInstanceID and hh3cdot1sMstiPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstiPortIndex (1.3.6.1.4.1.25506.8.35.14.20.1.1)
read-only
INTEGER
(0..65535)
Port index.
As per the MIB.
hh3cdot1sMstiState (1.3.6.1.4.1.25506.8.35.14.20.1.2)
read-only
INTEGER
disabled(1)
discarding(2)
learning(4)
forwarding(5)
Port status.
Does not support disabled.
hh3cdot1sMstiPortPriority (1.3.6.1.4.1.25506.8.35.14.20.1.3)
read-write
INTEGER
0..240
Port priority.
As per the MIB.
hh3cdot1sMstiPathCost (1.3.6.1.4.1.25506.8.35.14.20.1.4)
read-write
INTEGER
1..200000000
Port path cost.
As per the MIB.
hh3cdot1sMstiDesignatedRoot (1.3.6.1.4.1.25506.8.35.14.20.1.5)
read-only
BridgeId
OCTET STRING (8)
Root bridge.
As per the MIB.
hh3cdot1sMstiDesignatedCost (1.3.6.1.4.1.25506.8.35.14.20.1.6)
read-only
INTEGER
Path cost of the designated port.
As per the MIB.
hh3cdot1sMstiDesignatedBridge (1.3.6.1.4.1.25506.8.35.14.20.1.7)
read-only
BridgeId
OCTET STRING (8)
Designated bridge.
As per the MIB.
hh3cdot1sMstiDesignatedPort (1.3.6.1.4.1.25506.8.35.14.20.1.8)
read-only
OCTET STRING
SIZE (2)
Designated port.
As per the MIB.
hh3cdot1sMstiMasterBridgeID (1.3.6.1.4.1.25506.8.35.14.20.1.9)
read-only
BridgeId
OCTET STRING (8)
Master bridge.
As per the MIB.
hh3cdot1sMstiMasterPortCost (1.3.6.1.4.1.25506.8.35.14.20.1.10)
read-only
INTEGER
Path cost to the master bridge.
As per the MIB.
hh3cdot1sMstiStpPortEdgeport (1.3.6.1.4.1.25506.8.35.14.20.1.11)
read-write
EnabledStatus
enabled(1)
disabled(2)
Whether the port is an edge port.
As per the MIB.
hh3cdot1sMstiStpPortPointToPoint (1.3.6.1.4.1.25506.8.35.14.20.1.12)
read-write
INTEGER
forceTrue(1)
forceFalse(2)
auto(3)
Whether to set the port link type to point-to-point.
As per the MIB.
hh3cdot1sMstiStpMcheck (1.3.6.1.4.1.25506.8.35.14.20.1.13)
read-write
INTEGER
enable(1)
unused(65535)
Perform mCheck.
As per the MIB.
hh3cdot1sMstiStpTransLimit (1.3.6.1.4.1.25506.8.35.14.20.1.14)
read-write
INTEGER
1..255
BPDU transmission rate.
Default: 10.
hh3cdot1sMstiStpRXStpBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.15)
read-only
Counter32
Incoming BPDU count.
As per the MIB.
hh3cdot1sMstiStpTXStpBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.16)
read-only
Counter32
Outgoing BPDU count.
As per the MIB.
hh3cdot1sMstiStpRXTCNBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.17)
read-only
Counter32
Incoming TCN BPDU count.
As per the MIB.
hh3cdot1sMstiStpTXTCNBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.18)
read-only
Counter32
Outgoing TCN BPDU count.
As per the MIB.
hh3cdot1sMstiStpRXRSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.19)
read-only
Counter32
Incoming RSTP BPDU count.
As per the MIB.
hh3cdot1sMstiStpTXRSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.20)
read-only
Counter32
Outgoing RSTP BPDU count.
As per the MIB.
hh3cdot1sMstiStpRXMSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.21)
read-only
Counter32
Incoming MSTP BPDU count.
As per the MIB.
hh3cdot1sMstiStpTXMSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.22)
read-only
Counter32
Outgoing MSTP BPDU count.
As per the MIB.
hh3cdot1sMstiStpClearStatistics (1.3.6.1.4.1.25506.8.35.14.20.1.23)
read-write
INTEGER
clear(1)
unused(65535)
Clear packet statistics.
As per the MIB.
hh3cdot1sMstiStpDefaultPortCost (1.3.6.1.4.1.25506.8.35.14.20.1.24)
read-write
INTEGER
enable(1)
unused(65535)
Default port path cost.
As per the MIB.
hh3cdot1sMstiStpStatus (1.3.6.1.4.1.25506.8.35.14.20.1.25)
read-write
EnabledStatus
enabled(1)
disabled(2)
Spanning tree feature status.
As per the MIB.
hh3cdot1sMstiPortRootGuard (1.3.6.1.4.1.25506.8.35.14.20.1.26)
read-write
EnabledStatus
enabled(1)
disabled(2)
Root guard status.
As per the MIB.
hh3cdot1sMstiPortLoopGuard (1.3.6.1.4.1.25506.8.35.14.20.1.27)
read-write
EnabledStatus
enabled(1)
disabled(2)
Loop guard status.
As per the MIB.
hh3cdot1sMstiStpPortSendingBPDUType (1.3.6.1.4.1.25506.8.35.14.20.1.28)
read-only
INTEGER
stp(1)
rstp(2)
mstp(3)
BPDU type.
As per the MIB.
hh3cdot1sMstiStpOperPortPointToPoint (1.3.6.1.4.1.25506.8.35.14.20.1.29)
read-only
TruthValue
true(1)
false(2)
Whether the port link type is point-to-point.
As per the MIB.
hh3cdot1sMstiStpPortAdminBPDUFmt (1.3.6.1.4.1.25506.8.35.14.20.1.30)
read-write
Hh3cdot1sFormatStatus
legacy(1)
dot1s(2)
auto(3)
Set the mode used by the port to recognize and send MSTP BPDUs.
·     legacy—The port receives and sends only compatible-format MSTP BPDUs.
·     dot1s—The port receives and sends only standard-format (802.1s-compliant) MSTP BPDUs.
·     auto—The port recognizes the MSTP BPDU format automatically and determines the format of MSTP BPDUs to send accordingly.
This mode takes effect only on the CIST.
hh3cdot1sMstiStpPortOperBPDUFmt (1.3.6.1.4.1.25506.8.35.14.20.1.31)
read-only
legacy(1)
dot1s(2)
auto(3)
Read the mode used by the port to send MSTP BPDUs.
·     legacy—The port sends only compatible-format MSTP BPDUs.
·     dot1s—The port sends only standard-format (802.1s-compliant) MSTP BPDUs.
hh3cdot1sMstiStpPortRoleRestriction(1.3.6.1.4.1.25506.8.35.14.20.1.32)
read-write
EnabledStatus
enabled(1)
disabled(2)
Port role restriction status.
As per the MIB.
hh3cdot1sMstiStpPortTcRestriction(1.3.6.1.4.1.25506.8.35.14.20.1.33)
read-write
EnabledStatus
enabled(1)
disabled(2)
TC-BPDU transmission restriction status.
As per the MIB.
hh3cdot1sMstiStpPortDisputed(1.3.6.1.4.1.25506.8.35.14.20.1.34)
read-only
TruthValue
true(1)
false(2)
Dispute guard status.
As per the MIB.
Notifications
hh3cPortMstiStateForwarding
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.8.35.14.0.1
A port transits to the forwarding state.
Informational
OFF
This notification is generated when a port transits to the forwarding state.
Status control
ON
CLI: Use the stp port-log command.
OFF
CLI: Use the undo stp port-log command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.14.19.1.1 (hh3cdot1sInstanceID)
Instance ID.
Yes
INTEGER
0..4094
1.3.6.1.4.1.25506.8.35.14.20.1.1 (hh3cdot1sMstiPortIndex)
Port index.
Yes
INTEGER
1..65535
Recommended action
Check for link failures after the network topology becomes stable.
hh3cPortMstiStateDiscarding
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.2
A port transits to the discarding state.
Informational
OFF
This notification is generated when a port transits to the discarding state.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Instance ID.
Yes
INTEGER
0..4094
Port index.
Yes
INTEGER
1..65535
Recommended action
hh3cBridgeLostRootPrimary
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.3
The device loses its root bridge role after another device is elected as root bridge.
Informational
ON
This table does not contain indexes. For information about the index or indexes of a MIB object instance, see the section for that MIB object.
This notification is generated when the device loses its root bridge role after another device is elected as root bridge.
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index
Value range
Instance ID.
No
INTEGER
0..4094
Recommended action
·     Verify the bridge priorities of the devices.
·     Check for possible attacks from other devices.
hh3cPortMstiRootGuarded
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.4
A root guard-enabled port receives a configuration BPDU with a higher priority.
Informational
OFF
This notification is generated when a root guard-enabled port receives a configuration BPDU with a higher priority.
Status control
ON
CLI: Use the stp root-protection command.
MIB: Set hh3cdot1sMstiPortRootGuard to true(1).
OFF
MIB: Set hh3cdot1sMstiPortRootGuard to false(2).
Objects
OID (object name)
Index
Value range
Instance ID.
Yes
INTEGER
0..4094
Port index.
Yes
INTEGER
1..65535
Recommended action
hh3cPortMstiBpduGuarded
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.5
A BPDU guard-enabled edge port receives configuration BPDUs.
Informational
OFF
This notification is generated when a BPDU guard-enabled edge port receives configuration BPDUs.
Status control
ON
CLI: Use the stp bpdu-protection command.
MIB: Set hh3cdot1sMstBpduGuard to true(1).
OFF
MIB: Set hh3cdot1sMstBpduGuard to false(2).
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.17.2.15.1.1 (dot1dStpPort)
Port index.
Yes
INTEGER
1..65535
Recommended action
·     Verify that the downstream device is an endpoint device.
hh3cPortMstiLoopGuarded
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.6
An alternate port or root port does not receive a BPDU upon BPDU reception timeout.
Informational
OFF
This notification is generated when an alternate port or root port does not receive a BPDU upon BPDU reception timeout.
Status control
ON
CLI: Use the stp loop-protection command.
MIB: Set hh3cdot1sMstiPortLoopGuard to true(1).
OFF
MIB: Set hh3cdot1sMstiPortLoopGuard to false(2).
Objects
OID (object name)
Index
Value range
Instance ID.
Yes
INTEGER
0..4094
Port index.
Yes
INTEGER
1..65535
Recommended action
·     Verify that the spanning tree status of the upstream device is correct.
hh3cMstiNewRoot
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.7
A new root bridge is elected.
Informational
OFF
This notification is generated when a new root bridge is elected in the network.
Status control
ON
CLI: Use the snmp trap enable stp new-root command.
OFF
CLI: Use the undo snmp trap enable stp new-root command.
Objects
OID
Index
Value range
Instance ID.
Yes
INTEGER
0..4094
1.3.6.1.4.1.25506.8.35.14.20.1.1 (hh3cdot1sMstiDesignedRoot)
Root bridge information.
No
BridgeId
No
BridgeId
Recommended action
hh3cMstiTopologyChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.9
The network topology changes after the spanning tree state of ports changes.
Informational
ON
This notification is generated when the spanning tree state changes of ports cause network topology changes.
Status control
Objects
OID
Index
Value range
Instance ID.
No
INTEGER
0..4094
Recommended action
Check the spanning tree state of ports.
hh3cPortMstiLostEdge
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.10
An edge port receives BPDUs.
Informational
Warning
ON
This notification is generated when an edge port receives BPDUs and becomes a non-edge port.
Status control
Objects
OID
Index
Value range
Port number.
Yes
INTEGER
1..65535
1.3.6.1.2.1.2.2.1.2
(ifDescr)
Interface name.
Yes
OCTET STRING
OCTET STRING(0..255)
Recommended action
Verify that the peer network attached to the edge port has changed.
hh3cMstiTcGuarded
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.11
The number of TC-BPDUs received by the device exceeds the upper threshold.
Informational
Warning
ON
This notification is generated when the number of TC-BPDUs received by the device exceeds the upper threshold.
Status control
ON
CLI: Use the stp tc-protection command.
OFF
CLI: Use the undo stp tc-protection command.
Objects
OID
Index
Value range
Instance ID.
Yes
INTEGER
0..4094
hh3cMstiProTcGuarded
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.12
Informational
Warning
ON
Status control
ON
OFF
Objects
OID
Index
Value range
Instance ID.
No
INTEGER
0..4094
1.3.6.1.4.1.25506.8.35.14.22.1 (hh3cMstiTcGuardVal)
Upper threshold
No
Integer32
Integer32  (1..255)
Recommended action
Check the STP function of upstream devices and identify whether attacks occur on other devices in the network.
