05-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10005-Layer 2 - LAN Switching
10-HH3C-PROTOCOL-VLAN-MIB
10-HH3C-PROTOCOL-VLAN-MIB 147.60 KB
About this MIB
Use this MIB to configure protocol-based VLANs, for example, assign packets from a protocol to a VLAN, bind ports to protocol templates, and query protocol-based VLAN data. This MIB is available only on devices that support the protocol-based VLAN feature.
MIB file name
hh3c-protocol-vlan.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cProtocolVlan(16)
Scalar objects
hh3cProtocolNumAllVlan
Object (OID)
Access
Value range
Implementation
hh3cProtocolNumAllVlan (1.3.6.1.4.1.25506.2.16.1.1)
read-only
Integer32
Standard MIB values.
Maximum number of protocols that can be configured for all VLANs.
Implementation varies by product.
hh3cProtocolNumPerVlan
Object (OID)
Access
Value range
Implementation
hh3cProtocolNumPerVlan (1.3.6.1.4.1.25506.2.16.1.2)
read-only
Integer32
Maximum number of protocols that can be configured for a single VLAN.
Tabular objects
hh3cProtocolVlanTable
About this table
Use this table to configure the protocol-based VLAN feature, associate a VLAN with a protocol, and isolate packets from different protocols at Layer 2 through assigning them to different VLANs.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cProtocolVlanVlanId and hh3cProtocolVlanProtocolIndex.
When creating a protocol-based VLAN, the index objects hh3cProtocolVlanVlanId and hh3cProtocolVlanProtocolIndex must be specified together with the following objects: hh3cProtocolVlanProtocolType, hh3cProtocolVlanProtocolSubType, hh3cProtocolVlanProtocolTypeValue, and hh3cProtocolVlanRowStatus. The relationship among them is as follows:
ip
notused
notused (creation)
ipv6
notused
notused (creation)
at
notused
notused (creation)
ipx
ethernetii
notused (creation)
llc
raw
snap
mode-snap
etype
Hexadecimal string, for example, 600 (0x0600).
Value range:  [0x600..0xffff].
mode-ethernetii
etype
mode-llc
notused
Different parts are in the following order:
[dsap value][;ssap value][dsap value;ssap value]
The value ranges are both [0x00..0xff]. For example, the dsap is 0x09, and the ssap is 0x0a. If neither dsap nor ssap is specified, the string length is 0.
If the dsap is specified, the string is 09; or 09.
If the ssap is specified, the string is ;0a.
If both dsap and ssap are specified and, the string is 09;0a.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.16.1.5.1.1)
not-accessible
Integer32
ID of a protocol-based VLAN.
As per the MIB.
(1.3.6.1.4.1.25506.2.16.1.5.1.2)
not-accessible
Integer32
Integer32 (0..hh3cProtocolNumPerVlan-1)
Protocol template of a protocol-based VLAN.
As per the MIB.
(1.3.6.1.4.1.25506.2.16.1.5.1.3)
read-create
Hh3cvProtocolVlanProtocolType
Layer 3 protocols: ip(1), ipx(2), at(3), ipv6(4),
Layer 2 protocols: mode-llc(101), mode-snap(102), mode-ethernetii(103),
Protocol no configure: notConfigure(201)
Protocol types specified in the protocol template.
This object cannot be separately modified after the VLAN-to-protocol mapping is configured.
(1.3.6.1.4.1.25506.2.16.1.5.1.4)
read-create
Hh3cvProtocolVlanProtocolSubType
notused(1),
ethernetii(2), llc(3), raw(4), snap(5),
etype(6)
Protocol subtypes specified in the protocol template.
(1.3.6.1.4.1.25506.2.16.1.5.1.5)
read-create
OCTET STRING
OCTET STRING (0..255)
Protocol type values specified in the protocol template.
(1.3.6.1.4.1.25506.2.16.1.5.1.6)
read-create
RowStatus
Whether a protocol-based VLAN takes effect on a port.
Available values are active(1), createAndGo(4), and destroy(6).
hh3cProtocolVlanPortTable
About this table
Use this table to bind a port to a protocol-based VLAN template.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are hh3cProtocolVlanPortIndex, hh3cProtocolVlanPortVlanId, and hh3cProtocolVlanPortProtocolId.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.16.1.6.1.1)
not-accessible
Integer32
Index of a port configured with a protocol-based VLAN.
As per the MIB.
(1.3.6.1.4.1.25506.2.16.1.6.1.2)
not-accessible
Integer32
ID of a protocol-based VLAN configured on a port.
As per the MIB.
(1.3.6.1.4.1.25506.2.16.1.6.1.3)
not-accessible
Integer32
Index of a protocol template on a port.
As per the MIB.
hh3cProtocolVlanPortProtocolType
(1.3.6.1.4.1.25506.2.16.1.6.1.4)
read-only
Protocol types specified on a port.
As per the MIB.
hh3cProtocolVlanPortProtocolSubType
(1.3.6.1.4.1.25506.2.16.1.6.1.5)
read-only
notused(1),
ethernetii(2),
llc(3),
raw(4),
snap(5),
etype(6)
Protocol subtypes specified on a port.
As per the MIB.
hh3cProtocolVlanPortTypeValue
(1.3.6.1.4.1.25506.2.16.1.6.1.6)
read-only
OCTET STRING
Protocol type values specified on a port.
As per the MIB.
hh3cProtocolVlanPortRowStatus (1.3.6.1.4.1.25506.2.16.1.6.1.7)
read-create
RowStatus
Operating state of a protocol-based VLAN associated with a port.
hh3cProtocolVlanPortStatus (1.3.6.1.4.1.25506.2.16.1.6.1.8)
read-only
Integer
active (1),
inactive (2)
State of a protocol-based VLAN configured on a port.
active(1):
The protocol template on the port is associated with a protocol-based VLAN (the hh3cProtocolVlanPortProtocolId object has the corresponding data in the hh3cProtocolVlanTable table), and the port is configured as hybrid port and assigned to the protocol-based VLAN.
