05-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10005-Layer 2 - LAN Switching
13-IEEE8023-LAG-MIB
13-IEEE8023-LAG-MIB 93.95 KB
IEEE8023-LAG-MIB
About this MIB
This MIB defines MIB objects for the following information:
·     Aggregate interface configuration.
·     Aggregation member port list.
·     Aggregation member port configuration.
·     Traffic statistics.
·     State machine information about aggregation member ports.
MIB file name
ieee8023-lag.mib
Root object
iso(1).member-body(2).us(840).802dot3(10006).snmpmibs(300).lagMIB(43)
Scalar objects
dot3adTablesLastChanged
Object (OID)
Access
Value range
Implementation
dot3adTablesLastChanged (1.2.840.10006.300.43.1.3)
Read-only
TimeTicks
Standard MIB values.
The time of the most recent change to the dot3adAggTable, dot3adAggPortListTable, or dot3adAggPortTable.
Not supported
Tabular objects
dot3adAggTable
About this table
Use this table to configure aggregate interfaces.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is dot3adAggIndex.
Object (OID)
Access
Value range
Implementation
dot3adAggIndex (1.2.840.10006.300.43.1.1.1.1.1)
not-accessible
InterfaceIndex
Integer32 (1..2147483647)
Unique identifier allocated to an aggregate interface by the local system, table index.
N/A
dot3adAggMACAddress (1.2.840.10006.300.43.1.1.1.1.2)
read-only
MacAddress
OCTET STRING (6)
MAC address of the aggregate interface.
Default: 0.
dot3adAggActorSystemPriority (1.2.840.10006.300.43.1.1.1.1.3)
read-write
INTEGER
INTEGER (0..65535)
Local system priority.
N/A
dot3adAggActorSystemID (1.2.840.10006.300.43.1.1.1.1.4)
read-only
MacAddress
OCTET STRING (6)
Local system ID.
Default: 0.
dot3adAggAggregateOrIndividual (1.2.840.10006.300.43.1.1.1.1.5)
read-only
TruthValue
true(1)
false(2)
Aggregation flag.
The value is fixed at true.
dot3adAggActorAdminKey (1.2.840.10006.300.43.1.1.1.1.6)
read-write
LacpKey
INTEGER (0..65535)
Administrative key.
Only the read operation is supported.
dot3adAggActorOperKey (1.2.840.10006.300.43.1.1.1.1.7)
read-only
LacpKey
INTEGER (0..65535)
Operational key.
N/A
dot3adAggPartnerSystemID (1.2.840.10006.300.43.1.1.1.1.8)
read-only
MacAddress
OCTET STRING (6)
Peer system ID.
Default: 0.
dot3adAggPartnerSystemPriority (1.2.840.10006.300.43.1.1.1.1.9)
read-only
INTEGER
INTEGER (0..65535)
Peer system priority.
N/A
dot3adAggPartnerOperKey (1.2.840.10006.300.43.1.1.1.1.10)
read-only
LacpKey
INTEGER (0..65535)
Peer operational key.
N/A
dot3adAggCollectorMaxDelay (1.2.840.10006.300.43.1.1.1.1.11)
read-write
INTEGER (
INTEGER (0..65535)
Maximum delay.
A value of 0 is returned for read operations. Only the read operation is supported.
About this table
Use this table to obtain the member port list for an aggregate interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
dot3adAggPortListPorts (1.2.840.10006.300.43.1.1.2.1.1)
read-only
PortList
OCTET STRING (0..255)
Member port list.
Each bit set in this list represents a member port.
dot3adAggPortTable
About this table
Use this table to configure an aggregation member port.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is dot3adAggPortIndex.
Object (OID)
Access
Value range
Implementation
dot3adAggPortIndex (1.2.840.10006.300.43.1.2.1.1.1)
not-accessible
InterfaceIndex
Member port index.
As per the MIB.
dot3adAggPortActorSystemPriority (1.2.840.10006.300.43.1.2.1.1.2)
read-write
INTEGER
INTEGER (0..65535)
As per the MIB.
dot3adAggPortActorSystemID (1.2.840.10006.300.43.1.2.1.1.3)
read-only
MacAddress
OCTET STRING (6)
Local system ID.
As per the MIB.
dot3adAggPortActorAdminKey (1.2.840.10006.300.43.1.2.1.1.4)
read-write
LacpKey
INTEGER (0..65535)
Administrative key.
As per the MIB.
dot3adAggPortActorOperKey (1.2.840.10006.300.43.1.2.1.1.5)
read-write
LacpKey
INTEGER (0..65535)
Operational key.
dot3adAggPortPartnerAdminSystemPriority (1.2.840.10006.300.43.1.2.1.1.6)
read-write
INTEGER
INTEGER (0..65535)
Administrative priority of the peer port.
dot3adAggPortPartnerOperSystemPriority (1.2.840.10006.300.43.1.2.1.1.7)
read-only
INTEGER
INTEGER (0..65535)
Peer operational priority.
As per the MIB.
dot3adAggPortPartnerAdminSystemID (1.2.840.10006.300.43.1.2.1.1.8)
read-write
MacAddress
OCTET STRING (6)
Peer administrative system ID.
dot3adAggPortPartnerOperSystemID (1.2.840.10006.300.43.1.2.1.1.9)
read-only
MacAddress
OCTET STRING (6)
Peer operational system ID.
Default: 0.
dot3adAggPortPartnerAdminKey (1.2.840.10006.300.43.1.2.1.1.10)
read-write
LacpKey
INTEGER (0..65535)
Peer administrative key.
dot3adAggPortPartnerOperKey (1.2.840.10006.300.43.1.2.1.1.11)
read-only
LacpKey
INTEGER (0..65535)
As per the MIB.
dot3adAggPortSelectedAggID (1.2.840.10006.300.43.1.2.1.1.12)
read-only
InterfaceIndexOrZero
Integer32 (0..2147483647)
Selected aggregate interface index.
As per the MIB.
dot3adAggPortAttachedAggID (1.2.840.10006.300.43.1.2.1.1.13)
read-only
Joined aggregate interface index.
As per the MIB.
dot3adAggPortActorPort (1.2.840.10006.300.43.1.2.1.1.14)
read-only
INTEGER
INTEGER (0..65535)
Local port index.
As per the MIB.
dot3adAggPortActorPortPriority (1.2.840.10006.300.43.1.2.1.1.15)
read-write
INTEGER
INTEGER (0..65535)
Local port priority.
As per the MIB.
dot3adAggPortPartnerAdminPort (1.2.840.10006.300.43.1.2.1.1.16)
read-write
INTEGER
INTEGER (0..65535)
Peer administrative port number.
dot3adAggPortPartnerOperPort (1.2.840.10006.300.43.1.2.1.1.17)
read-only
INTEGER
INTEGER (0..65535)
Peer operational port number.
As per the MIB.
dot3adAggPortPartnerAdminPortPriority (1.2.840.10006.300.43.1.2.1.1.18)
read-write
INTEGER
INTEGER (0..65535)
Peer administrative port priority.
dot3adAggPortPartnerOperPortPriority (1.2.840.10006.300.43.1.2.1.1.19)
read-only
INTEGER
INTEGER (0..65535)
Peer operational port priority.
As per the MIB.
dot3adAggPortActorAdminState (1.2.840.10006.300.43.1.2.1.1.20)
read-write
LacpState
BITS {
lacpActivity(0)
lacpTimeout(1)
aggregation(2)
synchronization(3)
collecting(4)
distributing(5)
defaulted(6)
expired(7)
Local administrative status.
The write operation processes only bit 1.
dot3adAggPortActorOperState (1.2.840.10006.300.43.1.2.1.1.21)
read-only
LacpState
BITS {
lacpActivity(0)
lacpTimeout(1)
aggregation(2)
synchronization(3)
collecting(4)
distributing(5)
defaulted(6)
expired(7)
Local operational status.
As per the MIB.
dot3adAggPortPartnerAdminState (1.2.840.10006.300.43.1.2.1.1.22)
read-write
LacpState
BITS {
lacpActivity(0)
lacpTimeout(1)
aggregation(2)
synchronization(3)
collecting(4)
distributing(5)
defaulted(6)
expired(7)
Peer administrative status.
dot3adAggPortPartnerOperState (1.2.840.10006.300.43.1.2.1.1.23)
read-only
LacpState
BITS {
lacpActivity(0)
lacpTimeout(1)
aggregation(2)
synchronization(3)
collecting(4)
distributing(5)
defaulted(6)
expired(7)
Peer operational status.
As per the MIB.
dot3adAggPortAggregateOrIndividual (1.2.840.10006.300.43.1.2.1.1.24)
read-only
TruthValue
true(1)
false(2)
Aggregation status.
The return value is fixed at true.
dot3adAggPortStatsTable
About this table
Use this table to obtain traffic statistics about aggregate interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
dot3adAggPortStatsLACPDUsRx (1.2.840.10006.300.43.1.2.2.1.1)
read-only
Counter32
Valid incoming LACPDU count.
As per the MIB.
dot3adAggPortStatsMarkerPDUsRx (1.2.840.10006.300.43.1.2.2.1.2)
read-only
Counter32
Valid incoming Maker PDU count.
As per the MIB.
dot3adAggPortStatsMarkerResponsePDUsRx (1.2.840.10006.300.43.1.2.2.1.3)
read-only
Counter32
Valid incoming Maker response PDU count.
As per the MIB.
dot3adAggPortStatsUnknownRx (1.2.840.10006.300.43.1.2.2.1.4)
read-only
Counter32
Unknown incoming packet count.
As per the MIB.
dot3adAggPortStatsIllegalRx (1.2.840.10006.300.43.1.2.2.1.5)
read-only
Counter32
Invalid incoming packet count.
As per the MIB.
dot3adAggPortStatsLACPDUsTx (1.2.840.10006.300.43.1.2.2.1.6)
read-only
Counter32
Outgoing LACPDU count.
As per the MIB.
dot3adAggPortStatsMarkerPDUsTx (1.2.840.10006.300.43.1.2.2.1.7)
read-only
Counter32
Outgoing Maker PDU count.
As per the MIB.
dot3adAggPortStatsMarkerResponsePDUsTx (1.2.840.10006.300.43.1.2.2.1.8)
read-only
Counter32
Outgoing Maker response PDU count.
As per the MIB.
dot3adAggPortDebugTable
About this table
Use this table to obtain state machine information about aggregation member ports.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is dot3adAggPortDebugRxState.
Object (OID)
Access
Value range
Implementation
dot3adAggPortDebugRxState (1.2.840.10006.300.43.1.2.3.1.1)
read-only
INTEGER
currentRx(1)
expired(2)
defaulted(3)
initialize(4)
lacpDisabled(5)
portDisabled(6)
Receive state machine.
As per the MIB.
dot3adAggPortDebugLastRxTime (1.2.840.10006.300.43.1.2.3.1.2)
read-only
TimeTicks
Time when the last LACPDU was received.
As per the MIB.
dot3adAggPortDebugMuxState (1.2.840.10006.300.43.1.2.3.1.3)
read-only
INTEGER
detached(1)
waiting(2)
attached(3)
collecting(4)
distributing(5)
collectingDistributing(6)
Mux state machine.
As per the MIB.
dot3adAggPortDebugMuxReason (1.2.840.10006.300.43.1.2.3.1.4)
read-only
DisplayString
Cause for the last Mux state machine change.
As per the MIB.
dot3adAggPortDebugActorChurnState (1.2.840.10006.300.43.1.2.3.1.5)
read-only
ChurnState
INTEGER {
noChurn(1)
churn(2)
churnMonitor(3)
Actor Churn state machine.
As per the MIB.
dot3adAggPortDebugPartnerChurnState (1.2.840.10006.300.43.1.2.3.1.6)
read-only
ChurnState
INTEGER {
noChurn(1)
churn(2)
churnMonitor(3)
Partner Churn state machine.
As per the MIB.
dot3adAggPortDebugActorChurnCount (1.2.840.10006.300.43.1.2.3.1.7)
read-only
Counter32
Number of times the Actor Churn state machine has entered the ACTOR_CHURN state.
As per the MIB.
dot3adAggPortDebugPartnerChurnCount (1.2.840.10006.300.43.1.2.3.1.8)
read-only
Counter32
Number of times the Partner Churn state machine has entered the PARTNER_CHURN state.
As per the MIB.
dot3adAggPortDebugActorSyncTransitionCount (1.2.840.10006.300.43.1.2.3.1.9)
read-only
Counter32
Number of times the Mux state machine has entered the IN_SYNC state on the local port.
Not supported
dot3adAggPortDebugPartnerSyncTransitionCount (1.2.840.10006.300.43.1.2.3.1.10)
read-only
Counter32
Number of times the Mux state machine has entered the IN_SYNC state on the peer port.
Not supported
dot3adAggPortDebugActorChangeCount (1.2.840.10006.300.43.1.2.3.1.11)
read-only
Counter32
Number of times the Actor Churn state machine has changed status.
As per the MIB.
dot3adAggPortDebugPartnerChangeCount (1.2.840.10006.300.43.1.2.3.1.12)
read-only
Counter32
Number of times the Partner Churn state machine has changed status.
As per the MIB.
