05-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10005-Layer 2 - LAN Switching
19-LLDP-EXT-MED-MIB
19-LLDP-EXT-MED-MIB 108.68 KB
LLDP-EXT-MED-MIB
About this MIB
Use this MIB to obtain TIA-TR41.4 Media Endpoint Discovery (MED) information.
MIB file name
lldp-ext-med.mib
Root object
iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).lldpMIB(2).lldpObjects(1).lldpExtnesions(5).lldpXMedMIB(4795)
Scalar objects
lldpXMedLocDeviceClass
Object (OID)
Access
Value range
Implementation
lldpXMedLocDeviceClass (1.0.8802.1.1.2.1.5.4795.1.1.1)
read-only
LldpXMedDeviceClass
Standard MIB values.
MED device class.
As per the MIB.
lldpXMedFastStartRepeatCount
Object (OID)
Access
Value range
Implementation
lldpXMedFastStartRepeatCount (1.0.8802.1.1.2.1.5.4795.1.1.3)
read-write
Unsigned32
Unsigned32 (1..8)
Number of times the fast start LLDPDU are being sent.
As per the MIB.
lldpXMedLocHardwareRev
Object (OID)
Access
Value range
Implementation
lldpXMedLocHardwareRev (1.0.8802.1.1.2.1.5.4795.1.2.2)
read-only
SnmpAdminString
OCTET STRING (0..32)
Local hardware revision.
As per the MIB.
lldpXMedLocFirmwareRev
Object (OID)
Access
Value range
Implementation
lldpXMedLocFirmwareRev (1.0.8802.1.1.2.1.5.4795.1.2.3)
read-only
SnmpAdminString
Local firmware revision.
As per the MIB.
lldpXMedLocSoftwareRev
Object (OID)
Access
Value range
Implementation
lldpXMedLocSoftwareRev (1.0.8802.1.1.2.1.5.4795.1.2.4)
read-only
SnmpAdminString
Local software revision.
As per the MIB.
lldpXMedLocSerialNum
Object (OID)
Access
Value range
Implementation
lldpXMedLocSerialNum (1.0.8802.1.1.2.1.5.4795.1.2.5)
read-only
SnmpAdminString
Local serial number.
As per the MIB.
lldpXMedLocMfgName
Object (OID)
Access
Value range
Implementation
lldpXMedLocMfgName (1.0.8802.1.1.2.1.5.4795.1.2.6)
read-only
SnmpAdminString
Local manufacturer name.
As per the MIB.
lldpXMedLocModelName
Object (OID)
Access
Value range
Implementation
lldpXMedLocModelName (1.0.8802.1.1.2.1.5.4795.1.2.7)
read-only
SnmpAdminString
Local model name.
As per the MIB.
lldpXMedLocAssetID
Object (OID)
Access
Value range
Implementation
lldpXMedLocAssetID (1.0.8802.1.1.2.1.5.4795.1.2.8)
read-only
SnmpAdminString
Local asset tracking identifier.
As per the MIB.
lldpXMedLocXPoEDeviceType
Object (OID)
Access
Value range
Implementation
lldpxMedLocXPoEDeviceType (1.0.8802.1.1.2.1.5.4795.1.2.10)
read-only
INTEGER
unknown(1)
pseDevice(2)
pdDevice(3)
none(4)
Local PoE type.
As per the MIB.
lldpXMedLocXPoEPSEPowerSource
Object (OID)
Access
Value range
Implementation
lldpXMedLocXPoEPSEPowerSource (1.0.8802.1.1.2.1.5.4795.1.2.12)
read-only
INTEGER
unknown(1)
primary(2)
backup(3)
Local PSE power supply type.
As per the MIB.
lldpXMedLocXPoEPDPowerReq
Object (OID)
Access
Value range
Implementation
lldpXMedLocXPoEPDPowerReq (1.0.8802.1.1.2.1.5.4795.1.2.13)
read-only
Gauge32
Power required by a PD.
As per the MIB.
lldpXMedLocXPoEPDPowerSource
Object (OID)
Access
Value range
Implementation
lldpXMedLocXPoEPDPowerSource (1.0.8802.1.1.2.1.5.4795.1.2.14)
read-only
INTEGER
unknown(1)
fromPSE(2)
local(3)
localAndPSE(4)
Local PD power supply type.
As per the MIB.
lldpXMedLocXPoEPDPowerPriority
Object (OID)
Access
Value range
Implementation
lldpXMedLocXPoEPDPowerPriority (1.0.8802.1.1.2.1.5.4795.1.2.15)
read-only
INTEGER
unknown(1)
critical(2)
high(3)
low(4)
Local PD power priority.
As per the MIB.
Tabular objects
lldpXMedPortConfigEntry
About this table
Use this table to configure MED on ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is lldpPortConfigPortNum.
The table OID is 1.0.8802.1.1.2.1.5.4795.1.1.2.1.
Object (OID)
Access
Value range
Implementation
lldpXMedPortCapSupported (1.0.8802.1.1.2.1.5.4795.1.1.2.1.1)
read-only
LldpXMedCapabilities
Supported MED TLVs.
As per the MIB.
lldpXMedPortConfigTLVsTxEnable (1.0.8802.1.1.2.1.5.4795.1.1.2.1.2)
read-write
Enabled MED TLVs.
By default, the  networkPolicy bit  is set to 0. On a port operating in bridging mode, the networkPolicy bit is set to 1.
By default, the location and extendedPD bits are set to 0, and the other bits are set to 1. If the extendedPSE bit is set to 1 but a port does not support a capability, the bridge agents on the port does not send the related TLVs, and this bit is read-only.
lldpXMedPortConfigNotifEnable (1.0.8802.1.1.2.1.5.4795.1.1.2.1.3)
read-write
TruthValue
true(1)
false(2)
LLDP-MED trapping status.
As per the MIB.
lldpXMedLocMediaPolicyTable
About this table
Use this table to obtain local media policy configuration.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpLocPortNum and lldpXMedLocMediaPolicyAppType.
The table OID is 1.0.8802.1.1.2.1.5.4795.1.2.1.
Object (OID)
Access
Value range
Implementation
lldpXMedLocMediaPolicyAppType (1.0.8802.1.1.2.1.5.4795.1.2.1.1.1)
not-accessible
PolicyAppType
Media policy type.
As per the MIB.
lldpXMedLocMediaPolicyVlanID (1.0.8802.1.1.2.1.5.4795.1.2.1.1.2)
read-only
Integer32
Integer32 (0|1..4094|4095)
Media VLAN ID.
As per the MIB.
lldpXMedLocMediaPolicyPriority(1.0.8802.1.1.2.1.5.4795.1.2.1.1.3)
read-only
Integer32
Integer32 (0..7)
Media policy priority.
As per the MIB.
lldpXMedLocMediaPolicyDscp (1.0.8802.1.1.2.1.5.4795.1.2.1.1.4)
read-only
Dscp
DSCP value.
As per the MIB.
lldpXMedLocMediaPolicyUnknown (1.0.8802.1.1.2.1.5.4795.1.2.1.1.5)
read-only
TruthValue
true(1)
false(2)
Whether the media policy type is unknown.
As per the MIB.
lldpXMedLocMediaPolicyTagged (1.0.8802.1.1.2.1.5.4795.1.2.1.1.6)
read-only
TruthValue
true(1)
false(2)
Whether packets of the media VLAN are tagged.
As per the MIB.
lldpXMedLocLocationTable
About this table
Use this table to configure the local location information.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are lldpLocPortNum and lldpXMedLocLocationSubtype.
The table OID is 1.0.8802.1.1.2.1.5.4795.1.2.9.
Object (OID)
Access
Value range
Implementation
lldpXMedLocLocationSubtype (1.0.8802.1.1.2.1.5.4795.1.2.9.1.1)
not-accessible
LocationSubtype
Local MED location type.
Supports only civicAddress(3) and elin(4).
lldpXMedLocLocationInfo (1.0.8802.1.1.2.1.5.4795.1.2.9.1.2)
read-write
OCTET STRING
OCTET STRING (0..256)
Local MED location information.
As per the MIB.
lldpXMedLocXPoEPSEPortTable
About this table
Use this table to obtain PSE information on ports.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is lldpLocPortNUm.
The table OID is 1.0.8802.1.1.2.1.5.4795.1.2.11.
Object (OID)
Access
Value range
Implementation
lldpXMedLocXPoEPSEPortPowerAv (1.0.8802.1.1.2.1.5.4795.1.2.11.1.1)
read-only
Gauge32
Available PoE power on PSE ports.
As per the MIB.
lldpXMedLocXPoEPSEPortPDPriority (1.0.8802.1.1.2.1.5.4795.1.2.11.1.2)
read-only
INTEGER
Unknown(1)
Critical(2)
High(3)
Low(4)
PSE port power priority.
As per the MIB.
lldpXMedRemCapabilitiesTable
About this table
Use this table to obtain the LLDP-MED capabilities of a neighbor.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, and lldpRemIndex.
The table OID is 1.0.8802.1.1.2.1.5.4795.1.3.1.
Object (OID)
Access
Value range
Implementation
lldpXMedRemCapSupported (1.0.8802.1.1.2.1.5.4795.1.3.1.1.1)
read-only
Supported MED TLVs.
As per the MIB.
lldpXMedRemCapCurrent (1.0.8802.1.1.2.1.5.4795.1.3.1.1.2)
read-only
Sent MED TLVs.
As per the MIB.
lldpXMedRemDeviceClass (1.0.8802.1.1.2.1.5.4795.1.3.1.1.3)
read-only
LldpXMedDeviceClass
MED device type.
As per the MIB.
lldpXMedRemMediaPolicyTable
About this table
Use this table to obtain the media policy configuration of a neighbor.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, and lldpXMedRemMediaPolicyAppType.
The table OID is 1.0.8802.1.1.2.1.5.4795.1.3.2.
Object (OID)
Access
Value range
Implementation
lldpXMedRemMediaPolicyAppType (1.0.8802.1.1.2.1.5.4795.1.3.2.1.1)
not-accessible
PolicyAppType
Media policy type.
As per the MIB.
lldpXMedRemMediaPolicyVlanID (1.0.8802.1.1.2.1.5.4795.1.3.2.1.2)
read-only
Integer32
Media VLAN ID.
As per the MIB.
lldpXMedRemMediaPolicyPriority (1.0.8802.1.1.2.1.5.4795.1.3.2.1.3)
read-only
Integer32
Integer32 (0..7)
As per the MIB.
lldpXMedRemMediaPolicyDscp (1.0.8802.1.1.2.1.5.4795.1.3.2.1.4)
read-only
Dscp
DSCP value.
As per the MIB.
lldpXMedRemMediaPolicyUnknown (1.0.8802.1.1.2.1.5.4795.1.3.2.1.5)
read-only
TruthValue
true(1)
false(2)
As per the MIB.
lldpXMedRemMediaPolicyTagged (1.0.8802.1.1.2.1.5.4795.1.3.2.1.6)
read-only
TruthValue
true(1)
false(2)
As per the MIB.
lldpXMedRemInventoryTable
About this table
Use this table to obtain the inventory information about a neighbor.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.0.8802.1.1.2.1.5.4795.1.3.3.
Object (OID)
Access
Value range
Implementation
lldpXMedRemHardwareRev (1.0.8802.1.1.2.1.5.4795.1.3.3.1.1)
read-only
SnmpAdminString
Hardware revision.
As per the MIB.
lldpXMedRemFirmwareRev (1.0.8802.1.1.2.1.5.4795.1.3.3.1.2)
read-only
SnmpAdminString
Firmware revision.
As per the MIB.
lldpXMedRemSoftwareRev (1.0.8802.1.1.2.1.5.4795.1.3.3.1.3)
read-only
SnmpAdminString
Software revision.
As per the MIB.
lldpXMedRemSerialNum (1.0.8802.1.1.2.1.5.4795.1.3.3.1.4)
read-only
SnmpAdminString
Serial number.
As per the MIB.
lldpXMedRemMfgName (1.0.8802.1.1.2.1.5.4795.1.3.3.1.5)
read-only
SnmpAdminString
Manufacturer name.
As per the MIB.
lldpXMedRemModelName (1.0.8802.1.1.2.1.5.4795.1.3.3.1.6)
read-only
SnmpAdminString
Model name.
As per the MIB.
lldpXMedRemAssetID (1.0.8802.1.1.2.1.5.4795.1.3.3.1.7)
read-only
SnmpAdminString
Asset tracking identifier.
As per the MIB.
lldpXMedRemLocationTable
About this table
Use this table to obtain the location information about a neighbor.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex ,and lldpXMedRemLocationSubtype.
The table OID is 1.0.8802.1.1.2.1.5.4795.1.3.4.
Object (OID)
Access
Value range
Implementation
lldpXMedRemLocationSubtype(1.0.8802.1.1.2.1.5.4795.1.3.4.1.1)
not-accessible
LocationSubtype
MED location type.
As per the MIB.
lldpXMedRemLocationInfo (1.0.8802.1.1.2.1.5.4795.1.3.4.1.2)
read-only
OCTET STRING
As per the MIB.
lldpXMedRemXPoETable
About this table
Use this table to obtain the PoE type of a neighbor.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.0.8802.1.1.2.1.5.4795.1.3.5.
Object (OID)
Access
Value range
Implementation
lldpXMedRemXPoEDeviceType (1.0.8802.1.1.2.1.5.4795.1.3.5.1.1)
read-only
INTEGER
unknown(1)
pseDevice(2)
pdDevice(3)
none(4)
PoE type.
As per the MIB.
lldpXMedRemXPoEPSETable
About this table
Use this table to obtain the PSE information about a neighbor.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.0.8802.1.1.2.1.5.4795.1.3.6.
Object (OID)
Access
Value range
Implementation
lldpXMedRemXPoEPSEPowerAv (1.0.8802.1.1.2.1.5.4795.1.3.6.1.1)
read-only
Gauge32
As per the MIB.
lldpXMedRemXPoEPSEPowerSource (1.0.8802.1.1.2.1.5.4795.1.3.6.1.2)
read-only
INTEGER
unknown(1)
primary(2)
backup(3)
As per the MIB.
lldpXMedRemXPoEPSEPowerPriority (1.0.8802.1.1.2.1.5.4795.1.3.6.1.3)
read-only
INTEGER
unknown(1)
critical(2)
high(3)
low(4)
As per the MIB.
lldpXMedRemXPoEPDTable
About this table
Use this table to obtain the PD information about a neighbor.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.0.8802.1.1.2.1.5.4795.1.3.7.
Object (OID)
Access
Value range
Implementation
lldpXMedRemXPoEPDPowerReq (1.0.8802.1.1.2.1.5.4795.1.3.7.1.1)
read-only
Gauge32
As per the MIB.
lldpXMedRemXPoEPDPowerSource (1.0.8802.1.1.2.1.5.4795.1.3.7.1.2)
read-only
INTEGER
unknown(1)
fromPSE(2)
local(3)
localAndPSE(4)
As per the MIB.
lldpXMedRemXPoEPDPowerPriority (1.0.8802.1.1.2.1.5.4795.1.3.7.1.3)
read-only
INTEGER
unknown(1)
critical(2)
high(3)
low(4)
PD power priority.
As per the MIB.
Notifications
lldpXMedTopologyChangeDetected
Basic information
OID
Event
Severity
Recovery notification
Default status
1.0.8802.1.1.2.1.5.4795.0.1
MED neighbor topology changes.
Informational
OFF
This notification is set when the device detects topology changes, such as attaching a peer device to the local device, disconnecting a peer device, or moving a peer device from one port to another port.
Status control
ON
CLI: Use the lldp notification med-topology-change enable command.
MIB: Set the lldpXMedPortConfigNotifEnable object to true (1).
OFF
CLI: Use the undo lldp notification med-topology-change enable command.
MIB: Set the lldpXMedPortConfigNotifEnable object to false (2).
Objects
OID (object name)
Index
Value range
1.0.8802.1.1.2.1.4.1.1.4 (lldpRemChassisIdSubtype)
Neighbor chassis ID type.
No
LldpChassisIdSubtype
1.0.8802.1.1.2.1.4.1.1.5 (lldpRemChassisId)
Neighbor chassis ID.
No
LldpChassisId
1.0.8802.1.1.2.1.5.4795.1.3.1.1.3 (lldpXMedRemDeviceClass)
Neighbor MED device class.
No
LldpXMedDeviceClass
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
Verify that the topology changes are as expected.
If you cannot resolve the issue, contact H3C Support.
