- 05-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-LswMSTP-MIB
- 08-HH3C-LswVLAN-MIB
- 09-HH3C-MAC-INFORMATION-MIB
- 10-HH3C-PROTOCOL-VLAN-MIB
- 11-IEEE8021-CFM-MIB
- 12-IEEE8021-CFM-V2-MIB
- 13-IEEE8023-LAG-MIB
- 14-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 15-LLDP-EXT-DOT1-MIB
- 16-LLDP-EXT-DOT1-V2-MIB
- 17-LLDP-EXT-DOT3-MIB
- 18-LLDP-EXT-DOT3-V2-MIB
- 19-LLDP-EXT-MED-MIB
- 20-LLDP-MIB
- 21-LLDP-V2-MIB
- 22-MAU-MIB
- 23-P-BRIDGE-MIB
- 24-Q-BRIDGE-MIB
| 15-LLDP-EXT-DOT1-MIB | 77.19 KB |
LLDP-EXT-DOT1-MIB
About this MIB
For network managers to discover inconsistent or incorrect VLAN configurations and different supported protocols on interconnected ports, LLDP must implement the IEEE 802.1 organizationally specific extended features.
LLDP-EXT-DOT1-MIB is one of the four MIBs available for LLDP, which also include LLDP-MIB, LLDP-EXT-DOT3-MIB, and LLDP-MED-MIB. This MIB is a standard public MIB, which contains LDDP configuration, local and neighboring LLDP information.
MIB file name
lldp-ext-dot1.mib
Root object
iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).lldpMIB(2).lldpObjects(1).lldpExtnesions(5).lldpXdot1MIB(32962)
This MIB is the LLDP Management Information Base extension module for IEEE 802.1 organizationally defined discovery information.
Tabular objects
lldpXdot1ConfigPortVlanTable
About this table
This table controls selection of LLDP Port VLAN-ID TLVs to be transmitted on individual ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is lldpPortConfigPortNum.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.1.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1ConfigPortVlanTxEnable (1.0.8802.1.1.2.1.5.32962.1.1.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Selects whether to enable port VLAN TLV transmission on a given LLDP transmission capable port. |
Default: true. |
lldpXdot1ConfigVlanNameTable
About this table
This table controls selection of LLDP VLAN name TLV instances to be transmitted on individual ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Not supported |
Columns
The table indexes are lldpLocPortNum and lldpXdot1LocVlanId.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.1.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1ConfigVlanNameTxEnable (1.0.8802.1.1.2.1.5.32962.1.1.2.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Selects whether to enable VLAN name TLV transmission on a given LLDP transmission capable port. |
Default: false. As a best practice, do not perform the walk operation from the MIB browser, because it takes a long time to walk through all ports and VLANs. |
lldpXdot1ConfigProtoVlanTable
About this table
This table controls selection of LLDP port and protocol VLAN ID TLV instances to be transmitted on individual ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are lldpLocPortNum and lldpXdot1LocProtoVlanId.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.1.3.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1ConfigProtoVlanTxEnable (1.0.8802.1.1.2.1.5.32962.1.1.3.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Selects whether to enable Port and Protocol VLAN ID TLV transmission on a given LLDP transmission capable port. |
lldpXdot1ConfigProtocolTable
About this table
This table controls selection of LLDP Protocol TLV instances to be transmitted on individual ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table indexes are lldpLocPortNum and lldpXdot1LocProtocolIndex.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.1.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1ConfigProtocolTxEnable (1.0.8802.1.1.2.1.5.32962.1.1.4.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Selects whether to enable Protocol Identity TLV transmission on a given LLDP transmission capable port. |
Not supported. The default is false if the port is operating in bridge mode. |
lldpXdot1LocTable
About this table
This table contains one row per port for IEEE 802.1 organizationally defined LLDP extension on the local system.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is lldpLocPortNum.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.2.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1LocPortVlanId (1.0.8802.1.1.2.1.5.32962.1.2.1.1.1) |
read-only |
Integer32 |
Integer32(0|1..4094) |
PPVID. |
As per the MIB. |
lldpXdot1LocProtoVlanTable
About this table
This table contains one or more rows per Port and Protocol VLAN information about the local system.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.0.8802.1.1.2.1.5.32962.1.2.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1LocProtoVlanId (1.0.8802.1.1.2.1.5.32962.1.2.2.1.1) |
not-accessible |
Integer32 |
Port and protocol VLAN ID. |
As per the MIB. |
lldpXdot1LocProtoVlanSupported (1.0.8802.1.1.2.1.5.32962.1.2.2.1.2) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the given port (associated with the local system) supports port and protocol VLANs. |
As per the MIB. |
lldpXdot1LocProtoVlanEnabled (1.0.8802.1.1.2.1.5.32962.1.2.2.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the port and protocol VLANs are enabled on the given port associated with the local system. |
As per the MIB. |
lldpXdot1LocVlanNameTable
About this table
This table contains one or more rows of VLAN name information on the local system.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.0.8802.1.1.2.1.5.32962.1.2.3.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1LocVlanId (1.0.8802.1.1.2.1.5.32962.1.2.3.1.1) |
not-accessible |
VlanId |
Standard MIB values. |
ID of the VLAN to which the port belongs. |
As per the MIB. |
lldpXdot1LocVlanName (1.0.8802.1.1.2.1.5.32962.1.2.3.1.2) |
read-only |
SnmpAdminString |
OCTET STRING (1..32) |
VLAN name identified by the VLAN ID associated with the given port on the local system. |
As per the MIB. |
lldpXdot1LocProtocolTable
About this table
This table contains one or more rows per protocol identity information on the local system.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table OID is 1.0.8802.1.1.2.1.5.32962.1.2.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1LocProtocolIndex (1.0.8802.1.1.2.1.5.32962.1.2.4.1.1) |
not-accessible |
Integer32 |
Integer32(1..2147483647) |
Protocol index. |
Not supported. The value is 1 if the port is operating in bridge mode. |
lldpXdot1RemTable
About this table
This table contains one or more rows per physical network connection.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, and lldpRemIndex.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.3.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1RemPortVlanId (1.0.8802.1.1.2.1.5.32962.1.3.1.1.1) |
read-only |
Integer32 |
PVID of the given port on a neighboring device. |
As per the MIB. |
lldpXdot1RemProtoVlanTable
About this table
This table contains one or more rows per port and protocol VLAN information about the neighboring devices received on the given port.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, and lldpXdot1RemProtoVlanId.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.3.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1RemProtoVlanId (1.0.8802.1.1.2.1.5.32962.1.3.2.1.1) |
not-accessible |
Integer32 |
Port and protocol VLAN ID of the given port on a neighboring device. |
As per the MIB. |
lldpXdot1RemProtoVlanSupported (1.0.8802.1.1.2.1.5.32962.1.3.2.1.2) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the given port on the neighboring device supports port and protocol VLANs. |
As per the MIB. |
lldpXdot1RemProtoVlanEnabled (1.0.8802.1.1.2.1.5.32962.1.3.2.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the port and protocol VLANs are enabled for the given port on the neighboring device. |
As per the MIB. |
lldpXdot1RemVlanNameTable
About this table
This table contains one or more rows per IEEE 802.1Q VLAN name information about the neighboring devices, received on the given port.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, lldpXdot1RemVlanId.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.3.3.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1RemVlanId (1.0.8802.1.1.2.1.5.32962.1.3.3.1.1) |
not-accessible |
VlanId |
ID of the VLAN to which the given port on a neighboring device belongs. |
As per the MIB. |
lldpXdot1RemVlanName (1.0.8802.1.1.2.1.5.32962.1.3.3.1.2) |
read-only |
SnmpAdminString |
VLAN name identified by the VLAN ID on the neighboring device. |
As per the MIB. |
lldpXdot1RemProtocolTable
About this table
This table contains one or more rows per protocol information about the neighbor, received on the given port.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, lldpXdot1RemProtocolIndex.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.3.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1RemProtocolIndex (1.0.8802.1.1.2.1.5.32962.1.3.4.1.1) |
not-accessible |
Integer32 |
Protocol index. |
As per the MIB. |
lldpXdot1RemProtocolId (1.0.8802.1.1.2.1.5.32962.1.3.4.1.2) |
read-only |
OCTET STRING |
OCTET STRING (1..255) |
ID of the protocol associated with the given port of a neighboring device. |
As per the MIB. |
