05-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10005-Layer 2 - LAN Switching
04-HH3C-LLDP-EXT-MIB
04-HH3C-LLDP-EXT-MIB 51.73 KB
HH3C-LLDP-EXT-MIB
About this MIB
The Link Layer Discovery Protocol (LLDP) is a Layer 2 industry-standard protocol (IEEE 802.1AB) that allows network devices from different vendors to discover neighbors and exchange system and configuration information.
This MIB defines private MIB objects for the following extended LLDP management features:
·     Global LLDP configuration:
¡     Global status of LLDP.
¡     Global status of CDP compatibility.
·     LLDP port configuration:
¡     Port-specific packet transmission settings of CDP-compatible LLDP.
¡     Protection action taken on ports whose neighbors fail validation.
¡     Protection action taken on ports whose neighbors age out.
·     LLDP neighbor validation criteria:
¡     Chassis ID subtype.
¡     Chassis ID.
¡     Port ID subtype.
¡     Port ID.
·     Feature status on LLDP-enabled ports:
¡     Neighbor validation status.
¡     Neighbor aging status.
·     Trapping configuration on LLDP-enabled ports:
¡     Trapping for neighbor validation status changes.
¡     Trapping for neighbor aging status changes.
MIB file name
hh3c-lldp-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).huawei.h3c(10).h3cCommon(2).h3clldp(100)
Scalar objects
hh3clldpAdminStatus
Object (OID)
Access
Value range
Implementation
hh3clldpAdminStatus
(1.3.6.1.4.1.25506.2.100.1.1.1)
read-write
TruthValue
true(1)
false(2)
As per the MIB.
Tabular objects
hh3clldpPortConfigTable
About this table
Use this table to configure LLDP on ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3clldpPortConfigPortNum.
The table OID is 1.3.6.1.4.1.25506.2.100.1.1.3.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.100.1.1.3.1.1)
not-accessible
LldpPortNumber
Standard MIB values.
Port index.
As per the MIB.
hh3clldpPortConfigCDPComplianceStatus
(1.3.6.1.4.1.25506.2.100.1.1.3.1.2)
read-write
INTEGER
txAndRx(1)
disabled(2)
Packet transmission capabilities of CDP-compatible LLDP.
As per the MIB.
hh3clldpPortConfigValidationAction
(1.3.6.1.4.1.25506.2.100.1.1.3.1.3)
read-write
Integer32
As per the MIB.
h3clldpPortConfigAgingAction
(1.3.6.1.4.1.25506.2.100.1.1.3.1.4)
read-write
Integer32
As per the MIB.
