- H3C S7500X-G Switch Series Installation Guide-6W100
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Switch
- 03-Chapter 3 Installing FRUs
- 04-Chapter 4 Connecting Your Switch to the Network
- 05-Chapter 5 Replacement Procedures
- 06-Appendix A Engineering Labels
- 07-Appendix B Cable Management
| 00-Preface | 100.65 KB |
Preface
This installation guides you through installation of your S7500X-G switch, including preparing for installation, installing the device, installing FRUs, connecting the device to the network, troubleshooting, and replacement procedures.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S7500X-G switches.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
