07-Layer 3—IP Routing Configuration Guide
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration GuidesH3C CR16000-F Routers Configuration Guides-R838x-6W10007-Layer 3—IP Routing Configuration Guide
05-IS-IS configuration
05-IS-IS configuration 1.72 MB
Configuring IS-IS·· 1
About IS-IS· 1
Terminology· 1
IS-IS address· 1
NET· 2
IS-IS area· 3
IS-IS topology· 3
Route leaking· 4
IS-IS network types· 4
DIS and pseudonodes· 4
IS-IS PDUs· 5
IPv6 IS-IS· 7
Protocols and standards· 7
IPv4 IS-IS tasks at a glance· 8
IPv6 IS-IS tasks at a glance· 10
Configuring basic IS-IS· 12
Enabling IPv4 IS-IS· 12
Enabling IPv6 IS-IS· 13
Enabling a lightweight IS-IS process· 13
Setting the IS level and circuit level 14
Configuring P2P network type for an interface· 14
Configuring IS-IS multi-instance processes· 15
Configuring IPv6 IS-IS MTR· 16
Configuring IS-IS route control 17
Configuring IS-IS link cost 17
Changing the link cost of a Layer 3 aggregate interface when its bandwidth falls below the threshold  19
Enabling IS-IS to advertise the maximum link cost to neighbors· 20
Specifying a preference for IS-IS· 21
Configuring the maximum number of ECMP routes· 21
Configuring IS-IS route summarization· 22
Advertising a default route· 22
Configuring IS-IS route redistribution· 23
Filtering routes calculated from received LSPs· 25
Configuring IS-IS route leaking· 26
Advertising IS-IS link state information to other protocols· 27
Configuring the IPv6 IS-IS link tag feature· 28
Configuring IS-IS to advertise network performance parameters· 29
About IS-IS network performance parameters· 29
Restrictions and guidelines· 29
Enabling IS-IS to advertise link attributes in LSPs· 29
Advertising link delay information· 30
Advertising link bandwidth information· 31
Advertising link loss information· 32
Configuring IS-IS flexible algorithm·· 34
About IS-IS flexible algorithm·· 34
IS-IS flexible algorithm tasks at a glance· 35
Prerequisites· 36
Mapping an affinity attribute name to an affinity bit 36
Assigning affinity attributes to IS-IS links· 36
Configuring a flexible algorithm·· 37
Configuring the metric type of a flexible algorithm·· 38
Configuring flexible algorithm FRR· 40
Configuring flexible algorithm TI-LFA FRR· 41
Set the priority of an FRR backup path selection policy· 45
Applying a flexible algorithm to SR-MPLS· 46
Configuring color attribute-based traffic redirection· 47
Applying a flexible algorithm to SRv6· 48
Enabling trust level-based FAD advertisement 49
Configuring IS-IS timers· 50
Specifying the interval for sending IS-IS hello packets· 50
Specifying the interval for sending IS-IS CSNP packets· 50
Setting the maximum age of LSPs· 51
Setting the LSP refresh interval and generation interval 51
Setting LSP sending intervals· 52
Setting the LSP receiving interval 52
Setting the lifetime for expired LSPs in the LSDB· 53
Setting the SPF calculation interval 53
Configuring IS-IS packet-related features· 54
Configuring a DIS priority for an interface· 54
Configuring the administrative tag value for an interface· 55
Specifying the IS-IS hello multiplier 57
Disabling an interface from sending/receiving IS-IS packets· 57
Enabling an interface to send small hello packets· 57
Setting LSP lengths· 58
Enabling LSP flash flooding· 58
Enabling LSP fragment extension· 59
Controlling LSP generation, advertisement and reception· 60
Limiting LSP flooding· 60
Configuring IS-IS route update suppression· 61
Configuring advanced IS-IS features· 61
Enabling source address check for hello packets on a P2P interface· 61
Configuring convergence priorities for specific routes· 62
Setting the LSDB overload bit 63
Setting IS-IS interface cost upon LSDB overload· 64
Configuring IS-IS isolation· 65
Configuring IS-IS shutdown· 66
Configuring the ATT bit 66
Configuring system ID to host name mappings· 67
Enabling BIER for an IS-IS process· 68
Configuring IS-IS logging and SNMP notifications· 69
Enabling the logging of neighbor state changes· 69
Setting the maximum number of log entries that can be recorded· 70
Setting the maximum number of advertisement sources that trigger LSP update logging· 70
Setting the maximum number of IS-IS neighbor relationship troubleshooting entries· 70
Configuring IS-IS network management 71
Configuring IS-IS fast convergence· 71
Enabling ISPF· 71
Enabling prefix suppression· 72
Configuring IS-IS PIC· 73
Enhancing IS-IS network security· 74
Configuring neighbor relationship authentication· 74
Configuring area authentication· 74
Configuring routing domain authentication· 75
Configuring IS-IS GR· 76
Configuring BFD for IS-IS· 77
Enabling BFD for IS-IS· 77
Enabling IS-IS to adjust the interface cost according to the BFD session state· 78
Controlling adjacency establishment and maintenance based on BFD session state· 80
Configuring IS-IS FRR· 82
About IS-IS FRR· 82
IS-IS FRR tasks at a glance· 83
Configuring IS-IS LFA FRR· 83
Configuring IS-IS remote LFA FRR· 87
Setting the priority for FRR backup path selection policies· 89
Enabling IS-IS to adjust the interface cost according to the link quality· 90
Configuring IS-IS neighbor flapping suppression· 91
Configuring IS-IS member port flapping suppression· 93
Display and maintenance commands for IS-IS· 95
Displaying and maintaining IPv4 IS-IS· 95
Displaying and maintaining IPv6 IS-IS· 98
IS-IS configuration examples· 100
Example: Configuring basic IS-IS· 100
Example: Configuring DIS election· 105
Example: Configuring IS-IS route redistribution· 109
Example: Configuring IS-IS authentication· 112
Example: Configuring IS-IS GR· 115
Example: Configuring BFD for IS-IS· 116
Example: Configuring IS-IS LFA FRR· 120
Example: Configuring IS-IS remote LFA FRR· 123
Example: Configuring IS-IS multi-instance processes· 127
IPv6 IS-IS configuration examples· 131
Example: Configuring IPv6 IS-IS basics· 131
Example: Configuring BFD for IPv6 IS-IS· 135
Example: Configuring IPv6 IS-IS FRR· 138
Applying a flexible algorithm to IS-IS SRv6· 141
Configuring IS-IS
About IS-IS
IS-IS is an IGP used within an AS. It uses the SPF algorithm for route calculation.
Terminology
·     Intermediate system—Similar to a router in TCP/IP, IS is the basic unit used in an IS-IS routing domain to generate and propagate routing information. Throughout this chapter, an IS refers to a router.
·     End system—Similar to a host in TCP/IP, an ES does not run IS-IS. ISO defines the ES-IS protocol for communication between an ES and an IS.
·     Routing domain—An RD comprises a group of ISs that exchange routing information with each other by using the same routing protocol.
·     Area—An IS-IS routing domain can be split into multiple areas.
·     Link State Database—All link states in the network form the LSDB. Each IS has a minimum of one LSDB. An IS uses the SPF algorithm and LSDB to generate IS-IS routes.
·     Link State Protocol Data Unit or Link State Packet—An IS advertises link state information in an LSP.
·     Network Protocol Data Unit—An NPDU is a network layer protocol packet in OSI, similar to an IP packet in TCP/IP.
·     Designated IS—A DIS is elected on a broadcast network.
·     Network service access point—An NSAP is an OSI network layer address. The NSAP identifies an abstract network service access point and describes the network address format in the OSI reference model.
IS-IS address
As shown in Figure 1, an NSAP address comprises the Initial Domain Part (IDP) and the Domain Specific Part (DSP). The IDP is analogous to the network ID of an IP address, and the DSP is analogous to the subnet and host ID.
The IDP includes the Authority and Format Identifier (AFI) and the Initial Domain Identifier (IDI).
The DSP includes:
·     High Order Part of DSP (HO-DSP)—Identifies the area.
·     System ID—Identifies the host.
·     SEL—Also known as the N-SEL or the NSAP selector (SEL). It is similar to the protocol identifier in IP and is used to identify the type of service. Different transport layer protocols correspond to different SELs.
The IDP and DSP are variable in length. The length of an NSAP address is in the range of 8 to 20 bytes.
Figure 1 NSAP address format
An IS-IS address contains the following components:
·     Area address
The area address comprises the IDP and the HO-DSP of the DSP, which identify the area and the routing domain. Different routing domains cannot have the same area address.
Typically, a router only needs one area address, and all nodes in the same area must have the same area address. To support smooth area merging, partitioning, and switching, a router can have a maximum of three area addresses.
·     System ID
A system ID uniquely identifies a host or router. It has a fixed length of 48 bits (6 bytes).
The system ID of a device can be generated from the router ID. For example, suppose a router uses the IP address 168.10.1.1 of Loopback 0 as the router ID. The system ID can be obtained in the following steps:
a.     Extend each decimal number of the IP address to three digits by adding 0s from the left, such as 168.010.001.001.
b.     Divide the extended IP address into three sections that each has four digits to get the system ID 1680.1000.1001.
If you use other methods to define a system ID, make sure that it can uniquely identify the host or router.
·     SEL
An SEL is used to identify the type of service. Different transport layer protocols correspond to different SELs. It has a fixed length of 8 bits. All SELs in IP are 00.
NET
A network entity title (NET) identifies the network layer information of an IS. It does not include transport layer information. A NET is a special NSAP address with the SEL being 0. The length of a NET is in the range of 8 to 20 bytes, same as a NSAP address.
A NET includes the following parts:
·     Area ID—Has a length of 1 to 13 bytes.
·     System ID—A system ID uniquely identifies a host or router in the area and has a fixed length of 6 bytes.
·     SEL—Has a value of 0 and a fixed length of 1 byte.
For example, for a NET ab.cdef.1234.5678.9abc.00, the area ID is ab.cdef, the system ID is 1234.5678.9abc, and the SEL is 00.
Typically, a router only needs one NET, but it can have a maximum of three NETs for smooth area merging and partitioning. When you configure multiple NETs, make sure the system IDs are the same.
IS-IS area
IS-IS has a 2-level hierarchy to support large-scale networks. A large-scale routing domain is divided into multiple areas. Typically, a Level-1 router is deployed within an area. A Level-2 router is deployed between areas. A Level-1-2 router is deployed between Level-1 and Level-2 routers.
Level-1 router
A Level-1 router establishes neighbor relationships with Level-1 and Level-1-2 routers in the same area. It maintains an LSDB comprising intra-area routing information. A Level-1 router forwards packets destined for external areas to the nearest Level-1-2 router. Level-1 routers in different areas cannot establish neighbor relationships.
Level-2 router
A Level-2 router establishes neighbor relationships with Level-2 and Level-1-2 routers in the same area or in different areas. It maintains a Level-2 LSDB containing inter-area routing information. All the Level-2 and Level-1-2 routers must be contiguous to form the backbone of the IS-IS routing domain. Level-2 routers can establish neighbor relationships even if they are in different areas.
Level-1-2 router
A router with both Level-1 and Level-2 router functions is a Level-1-2 router. It can establish Level-1 neighbor relationships with Level-1 and Level-1-2 routers in the same area. It can establish Level-2 neighbor relationships with Level-2 and Level-1-2 routers in different areas. A Level-1 router can reach other areas only through a Level-1-2 router. The Level-1-2 router maintains two LSDBs, a Level-1 LSDB for intra-area routing and a Level-2 LSDB for inter-area routing.
IS-IS topology
Figure 2 shows one IS-IS network topology. Area 1 is the backbone that comprises a set of Level-2 routers. The other four areas are non-backbone areas connected to the backbone through Level-1-2 routers.
Figure 2 IS-IS topology 1
Figure 3 shows another IS-IS topology. No area is defined as the backbone in this topology. The backbone comprises all contiguous Level-2 and Level-1-2 routers in different areas. The IS-IS backbone does not need to be a specific area.
Figure 3 IS-IS topology 2
Both the Level-1 and Level-2 routers use the SPF algorithm to generate the shortest path tree.
Route leaking
Level-2 and Level-1-2 routers form a Level-2 area. An IS-IS routing domain comprises only one Level-2 area and multiple Level-1 areas. A Level-1 area must connect to the Level-1-2 area rather than another Level-1 area.
Level-1-2 routers send the routing information of Level-1 areas to the Level-2 area. Level-2 routers know the routing information of the entire IS-IS routing domain. By default, a Level-2 router does not advertise the routing information of other areas to a Level-1 area. A Level-1 router simply sends packets destined for other areas to the nearest Level-1-2 router. The path passing through the Level-1-2 router might not be the best. To resolve this issue, IS-IS provides the route leaking feature.
Route leaking enables a Level-1-2 router to advertise the routes of other areas to the connected Level-1 area so that the Level-1 routers can select the optimal routes.
IS-IS network types
IS-IS supports broadcast networks (for example, Ethernet and Token Ring) and point-to-point networks (for example, PPP and HDLC).
For an NBMA interface, such as an ATM interface, you must configure point-to-point or broadcast subinterfaces. IS-IS cannot run on P2MP links.
DIS and pseudonodes
IS-IS routers on a broadcast network must elect a DIS.
The Level-1 and Level-2 DISs are elected separately. You can assign different priorities to a router for different level DIS elections. The higher the router priority, the more likely the router becomes the DIS. If multiple routers with the same highest DIS priority exist, the one with the highest Subnetwork Point of Attachment (SNPA) address will be elected. On a broadcast network, the SNPA address is the MAC address. A router can be the DIS for different levels.
IS-IS DIS election differs from OSPF DIS election in the following ways:
·     A router with priority 0 can also participate in the DIS election.
·     When a router with a higher priority is added to the network, an LSP flooding process is performed to elect the router as the new DIS.
As shown in Figure 4, the same level routers on a network, including non-DIS routers, establish adjacency with each other.
Figure 4 DIS in the IS-IS broadcast network
The DIS creates and updates pseudonodes, and generates LSPs for the pseudonodes, to describe all routers on the network.
A pseudonode represents a virtual node on the broadcast network. It is not a real router. In IS-IS, it is identified by the system ID of the DIS and a 1-byte Circuit ID (a non-zero value).
Using pseudonodes simplifies network topology and can reduce the amount of resources consumed by SPF.
On an IS-IS broadcast network, all routers establish adjacency relationships, but they synchronize their LSDBs through the DIS.
IS-IS PDUs
PDU
IS-IS PDUs are encapsulated into link layer frames. An IS-IS PDU has two parts, the headers and the variable length fields. The headers comprise the PDU common header and the PDU specific header. All PDUs have the same PDU common header. The specific headers vary by PDU type.
Figure 5 PDU format
Table 1 PDU types
PDU Type
Acronym
15
Level-1 LAN IS-IS hello PDU
L1 LAN IIH
16
Level-2 LAN IS-IS hello PDU
L2 LAN IIH
17
Point-to-Point IS-IS hello PDU
P2P IIH
18
Level-1 Link State PDU
L1 LSP
20
Level-2 Link State PDU
L2 LSP
24
Level-1 Complete Sequence Numbers PDU
L1 CSNP
25
Level-2 Complete Sequence Numbers PDU
L2 CSNP
26
Level-1 Partial Sequence Numbers PDU
L1 PSNP
27
Level-2 Partial Sequence Numbers PDU
L2 PSNP
Hello PDU
IS-to-IS hello (IIH) PDUs are used by routers to establish and maintain neighbor relationships. On broadcast networks, Level-1 routers use Level-1 LAN IIHs, and Level-2 routers use Level-2 LAN IIHs. The P2P IIHs are used on point-to-point networks.
LSP
The LSPs carry link state information. LSPs include Level-1 LSPs and Level-2 LSPs. The Level-2 LSPs are sent by the Level-2 routers, and the Level-1 LSPs are sent by the Level-1 routers. The Level-1-2 router can send both types of LSPs.
SNP
A sequence number PDU (SNP) describes the complete or partial LSPs for LSDB synchronization.
SNPs include CSNP and PSNP, which are further divided into Level-1 CSNP, Level-2 CSNP, Level-1 PSNP, and Level-2 PSNP.
A CSNP describes the summary of all LSPs for LSDB synchronization between neighboring routers. On broadcast networks, CSNPs are sent by the DIS periodically (every 10 seconds by default). On point-to-point networks, CSNPs are sent only during the first adjacency establishment.
A PSNP only contains the sequence numbers of one or multiple latest received LSPs. It can acknowledge multiple LSPs at one time. When LSDBs are not synchronized, a PSNP is used to request missing LSPs from a neighbor.
CLV
The variable fields of PDU comprise multiple Code-Length-Value (CLV) triplets.
Figure 6 CLV format
Table 2 shows that different PDUs contain different CLVs. Codes 1 through 10 are defined in ISO 10589 (code 3 and 5 are not shown in the table). Codes 128 through 132 are defined in RFC 1195. Codes 222 through 237 are defined in RFC 5120.
Table 2 CLV codes and PDU types
CLV Code
Name
PDU Type
1
Area Addresses
IIH, LSP
2
IS Neighbors (LSP)
LSP
4
Partition Designated Level 2 IS
L2 LSP
6
IS Neighbors (MAC Address)
LAN IIH
7
IS Neighbors (SNPA Address)
LAN IIH
8
Padding
IIH
9
LSP Entries
SNP
10
Authentication Information
IIH, LSP, SNP
128
IP Internal Reachability Information
LSP
129
Protocols Supported
IIH, LSP
130
IP External Reachability Information
L2 LSP
131
Inter-Domain Routing Protocol Information
L2 LSP
132
IP Interface Address
IIH, LSP
222
MT-ISN
LSP
229
M-Topologies
IIH, LSP
235
MT IP. Reach
LSP
237
MT IPv6 IP. Reach
LSP
IPv6 IS-IS
IS-IS supports multiple network protocols, including IPv6. To support IPv6, the IETF added two type-length-values (TLVs) and a new network layer protocol identifier (NLPID).
The TLVs are as follows:
·     IPv6 Reachability—Contains routing prefix and metric information to describe network reachability and has a type value of 236 (0xEC).
·     IPv6 Interface Address—Same as the "IP Interface Address" TLV in IPv4 ISIS, except that the 32-bit IPv4 address is translated to the 128-bit IPv6 address.
The new NLPID is an 8-bit field that identifies which network layer protocol is supported. For IPv6, the NLPID is 142 (0x8E).
·     ISO 8348, Ad2 Network Services Access Points
·     ISO 9542, ES-IS Routing Protocol
·     ISO 10589, ISO IS-IS Routing Protocol
·     RFC 1195, Use of OSI IS-IS for Routing in TCP/IP and Dual Environments
·     RFC 2973, IS-IS Mesh Groups
·     RFC 3277, IS-IS Transient Blackhole Avoidance
·     RFC 3358, Optional Checksums in ISIS
·     RFC 3359, Reserved Type, Length and Value (TLV) Codepoints in Intermediate System to Intermediate System
·     RFC 3563, Cooperative Agreement Between the ISOC/IETF and ISO/IEC Joint Technical Committee 1/Sub Committee 6 (JTC1/SC6) on IS-IS Routing Protocol Development
·     RFC 3719, Recommendations for Interoperable Networks using Intermediate System to Intermediate System (IS-IS)
·     RFC 3787, Recommendations for Interoperable IP Networks using Intermediate System to Intermediate System (IS-IS)
·     RFC 4444, Management Information Base for Intermediate System to Intermediate System (IS-IS)
·     RFC 4972, Routing Extensions for Discovery of Multiprotocol (MPLS) Label Switch Router (LSR) Traffic Engineering (TE) Mesh Membership
·     RFC 5029, Definition of an IS-IS Link Attribute Sub-TLV
·     RFC 5089, IS-IS Protocol Extensions for Path Computation Element (PCE) Discovery
·     RFC 5130, A Policy Control Mechanism in IS-IS Using Administrative Tags
·     RFC 5301, Dynamic Hostname Exchange Mechanism for IS-IS
·     RFC 5302, Domain-Wide Prefix Distribution with Two-Level IS-IS
·     RFC 5303, Three-Way Handshake for IS-IS Point-to-Point Adjacencies
·     RFC 5304, IS-IS Cryptographic Authentication
·     RFC 5305, IS-IS Extensions for Traffic Engineering
·     RFC 5306, Restart Signaling for IS-IS
·     RFC 5308, Routing IPv6 with IS-IS
·     RFC 5310, IS-IS Generic Cryptographic Authentication
·     RFC 5311, Simplified Extension of Link State PDU (LSP) Space for IS-IS
·     RFC 6165, Extensions to IS-IS for Layer-2 Systems
·     RFC 6213, IS-IS BFD-Enabled TLV
·     RFC 6232, Purge Originator Identification TLV for IS-IS
·     RFC 6233, IS-IS Registry Extension for Purges
·     RFC 6329, IS-IS Extensions Supporting IEEE 802.1aq Shortest Path Bridging
·     RFC 6571, Loop-Free Alternate (LFA) Applicability in Service Provider (SP) Networks
·     RFC 6823, Advertising Generic Information in IS-IS
·     RFC 7142, OSI IS-IS Intra-domain Routing Protocol
·     RFC 7356, IS-IS Flooding Scope Link State PDUs (LSPs)
·     RFC 7370, Updates to the IS-IS TLV Codepoints Registry
·     RFC 7602, IS-IS Extended Sequence Number TLV
·     RFC 7645, The Keying and Authentication for Routing Protocol (KARP) IS-IS Security Analysis
·     RFC 7775, IS-IS Route Preference for Extended IP and IPv6 Reachability
·     RFC 7794, IS-IS Prefix Attributes for Extended IPv4 and IPv6 Reachability
·     RFC 7810, IS-IS Traffic Engineering (TE) Metric Extensions
·     RFC 7813, IS-IS Path Control and Reservation
·     RFC 7917, Advertising Node Administrative Tags in IS-IS
·     RFC 7981, IS-IS Extensions for Advertising Router Information
·     RFC 7987, IS-IS Minimum Remaining Lifetime
To configure IPv4 IS-IS, perform the following tasks:
1.     Configuring basic IS-IS
a.     Enabling IPv4 IS-IS
b.     (Optional.) Enabling a lightweight IS-IS process
c.     (Optional.) Setting the IS level and circuit level
d.     (Optional.) Configuring P2P network type for an interface
e.     (Optional.) Configuring IS-IS multi-instance processes
2.     (Optional.) Configuring IS-IS route control
¡     Configuring IS-IS link cost
¡     Changing the link cost of a Layer 3 aggregate interface when its bandwidth falls below the threshold
¡     Enabling IS-IS to advertise the maximum link cost to neighbors
¡     Specifying a preference for IS-IS
¡     Configuring the maximum number of ECMP routes
¡     Configuring IS-IS route summarization
¡     Advertising a default route
¡     Configuring IS-IS route redistribution
¡     Filtering routes calculated from received LSPs
¡     Configuring IS-IS route leaking
¡     Advertising IS-IS link state information to other protocols
3.     (Optional.) Configuring IS-IS to advertise network performance parameters
¡     Enabling IS-IS to advertise link attributes in LSPs
¡     Advertising link delay information
¡     Advertising link bandwidth information
¡     Advertising link loss information
4.     (Optional.) Configuring IS-IS flexible algorithm
5.     (Optional.) Configuring IS-IS timers
¡     Specifying the interval for sending IS-IS hello packets
¡     Specifying the interval for sending IS-IS CSNP packets
¡     Setting the maximum age of LSPs
¡     Setting the LSP refresh interval and generation interval
¡     Setting LSP sending intervals
¡     Setting the LSP receiving interval
¡     Setting the lifetime for expired LSPs in the LSDB
¡     Setting the SPF calculation interval
6.     (Optional.) Configuring IS-IS packet-related features
¡     Configuring a DIS priority for an interface
¡     Configuring the administrative tag value for an interface
¡     Specifying the IS-IS hello multiplier
¡     Disabling an interface from sending/receiving IS-IS packets
¡     Enabling an interface to send small hello packets
¡     Setting LSP lengths
¡     Enabling LSP flash flooding
¡     Enabling LSP fragment extension
7.     (Optional.) Controlling LSP generation, advertisement and reception
¡     Limiting LSP flooding
¡     Configuring IS-IS route update suppression
8.     (Optional.) Configuring advanced IS-IS features
¡     Enabling source address check for hello packets on a P2P interface
¡     Configuring convergence priorities for specific routes
¡     Setting the LSDB overload bit
¡     Setting IS-IS interface cost upon LSDB overload
¡     Configuring IS-IS isolation
¡     Configuring IS-IS shutdown
¡     Configuring the ATT bit
¡     Configuring system ID to host name mappings
9.     (Optional.) Configuring IS-IS logging and SNMP notifications
¡     Enabling the logging of neighbor state changes
¡     Setting the maximum number of log entries that can be recorded
¡     Setting the maximum number of advertisement sources that trigger LSP update logging
¡     Setting the maximum number of IS-IS neighbor relationship troubleshooting entries
¡     Configuring IS-IS network management
10.     (Optional.) Configuring IS-IS fast convergence
¡     Enabling ISPF
¡     Enabling prefix suppression
¡     Configuring IS-IS PIC
11.     (Optional.) Enhancing IS-IS network security
¡     Configuring neighbor relationship authentication
¡     Configuring area authentication
¡     Configuring routing domain authentication
12.     (Optional.) Enhancing IS-IS network reliability:
¡     Configuring IS-IS GR
¡     Configuring BFD for IS-IS
¡     Configuring IS-IS FRR
¡     Enabling IS-IS to adjust the interface cost according to the link quality
¡     Configuring IS-IS neighbor flapping suppression
¡     Configuring IS-IS member port flapping suppression
To configure IPv6 IS-IS, perform the following tasks:
a.     Enabling IPv6 IS-IS
2.     (Optional.) Configuring IPv6 IS-IS MTR
3.     (Optional.) Configuring IS-IS route control
¡     Configuring the IPv6 IS-IS link tag feature
4.     (Optional.) Configuring IS-IS to advertise network performance parameters
5.     (Optional.) Configuring IS-IS flexible algorithm
6.     (Optional.) Configuring IS-IS timers
7.     (Optional.) Configuring IS-IS packet-related features
8.     (Optional.) Controlling LSP generation, advertisement and reception
9.     (Optional.) Configuring advanced IS-IS features
10.     (Optional.) Enabling BIER for an IS-IS process
11.     (Optional.) Configuring IS-IS logging and SNMP notifications
12.     (Optional.) Configuring IS-IS fast convergence
¡     Enabling ISPF
13.     (Optional.) Enhancing IS-IS network security
14.     (Optional.) Enhancing IS-IS network reliability:
Enabling IPv4 IS-IS
2.     Enable IS-IS and enter IS-IS view.
By default, IS-IS is disabled.
3.     Assign a NET.
network-entity net
By default, NET is not assigned.
CAUTION
CAUTION:
When you execute the network-entity command together with the cost-style and is-level commands for the same IS-IS process, execute the network-entity command at last. Incorrect configuration order might cause data loss because the IS-IS process will restart.
4.     Return to system view.
5.     Enter interface view.
6.     Enable IS-IS on the interface.
isis enable [ process-id ]
Enabling IPv6 IS-IS
2.     Enable an IS-IS process and enter IS-IS view.
By default, no IS-IS process is enabled.
3.     Configure the NET for the IS-IS process.
network-entity net
By default, the NET is not configured.
CAUTION
CAUTION:
4.     Create the IPv6 address family and enter its view.
5.     Return to IS-IS view.
6.     Return to system view.
7.     Enter interface view.
8.     Enable IPv6 for IS-IS on the interface.
isis ipv6 enable [ process-id ]
By default, IPv6 is disabled for IS-IS on an interface.
Enabling multiple IS-IS processes on a device might cause memory insufficiency. To resolve this issue, perform this task to enable lightweight IS-IS processes.
Although lightweight processes use less memory resources than traditional processes, device performance might degrade when a large number of neighbors and routes exist. As a best practice, plan the number of lightweight IS-IS processes to be enabled on the basis of the device resource condition.
2.     Enable a lightweight OSPF process and enter its view.
isis [ process-id ] lite [ vpn-instance vpn-instance-name ]
Follow these guidelines when you configure the IS level for routers in only one area:
·     Set the IS level of all routers to Level-1 or Level-2 rather than different levels because the routers do not need to maintain two identical LSDBs.
·     Set the IS level to Level-2 on all routers in an IP network for good scalability.
For an interface of a Level-1 or Level-2 router, the circuit level can only be Level-1 or Level-2. For an interface of a Level-1-2 router, the default circuit level is Level-1-2. If the router only needs to form Level-1 or Level-2 neighbor relationships, set the circuit level for its interfaces to Level-1 or Level-2. This will limit neighbor relationship establishment.
2.     Enter IS-IS view.
3.     Specify the IS level.
is-level { level-1 | level-1-2 | level-2 }
By default, the IS level is Level-1-2.
6.     Specify the circuit level.
isis circuit-level [ level-1 | level-1-2 | level-2 ]
By default, an interface can establish either the Level-1 or Level-2 adjacency.
Interfaces with different network types operate differently. For example, broadcast interfaces on a network must elect the DIS and flood CSNP packets to synchronize the LSDBs. However, P2P interfaces on a network do not need to elect the DIS, and have a different LSDB synchronization mechanism.
If only two routers exist on a broadcast network, set the network type of attached interfaces to P2P. This avoids DIS election and CSNP flooding, saving network bandwidth and speeding up network convergence.
The local device and the remote device might fail to establish a neighbor relationship when their hello packets use different destination MAC addresses. To avoid this issue, use the isis circuit-type p2p mac-by-level command on both the local device and the remote device to ensure that their hello packets use the same destination MAC address.
2.     Enter interface view.
3.     Configure P2P network type for an interface.
isis [ process-id process-id ] circuit-type p2p
By default, the network type of an interface varies by physical interface.
Perform this task only for a broadcast network that has up to two attached routers.
4.     (Optional.) Enable the P2P interface to determine the destination MAC address of hello packets by IS-IS level.
By default, the destination MAC address is 0900-2b00-0005 for the Level-1 hello packets and the Level-2 hello packets sent from a P2P interface.
After you configure this command, the destination MAC address is 0180-c200-0014 for Level-1 hello packets and is 0180-c200-0015 for Level-2 hello packets.
IS-IS processes not enabled with the multi-instance process feature are called traditional IS-IS processes. IS-IS processes enabled with the multi-instance process feature are called IS-IS multi-instance processes.
By default, an interface supports only one IS-IS process. To configure multiple IS-IS processes on a device, you must add more interfaces to the device and configure the interfaces manually. To simplify configuration, use the IS-IS multi-instance process feature to configure multiple IS-IS multi-instance processes as well as a traditional IS-IS process on an interface.
3.     Enable the IS-IS multi-instance process and specify an instance ID for the process.
multi-instance enable iid iid-value
By default, IS-IS multi-instance process is disabled.
4.     Configure IS-IS multi-instance processes on an interface:
a.     Return to system view.
b.     Enter interface view.
c.     Enable an IS-IS multi-instance process on the interface:
IPv4:
By default, IPv4 IS-IS is disabled on an interface, and the interface is not enabled with any IS-IS processes.
IPv6:
By default, IPv6 IS-IS is disabled on an interface, and the interface is not enabled with any IS-IS processes.
On a network, IPv4 and IPv6 topologies must be consistent so that both IPv6 IS-IS and IPv4 IS-IS can use the SPF algorithm to perform route calculation. If they are different, routers supporting both IPv4 and IPv6 might send IPv6 packets to routers that do not support IPv6, resulting in packet loss.
To resolve this issue, configure IPv6 IS-IS MTR to perform route calculation separately in IPv4 and IPv6 topologies.
Figure 7 Network diagram
As shown in Figure 7, the numbers refer to the link costs. Router A, Router B, and Router D support both IPv4 and IPv6. Router C supports only IPv4 and cannot forward IPv6 packets.
Enable IPv6 IS-IS MTR on Router A, Router B, Router C, and Router D to make them perform route calculation separately in IPv4 and IPv6 topologies. With this configuration, Router A does not forward IPv6 packets destined to Router D through Router B, avoiding packet loss.
As a best practice to avoid route calculation failures, configure this feature when both IPv4 and IPv6 topologies exist in the network.
3.     Specify an IS-IS cost style.
cost-style { compatible | wide | wide-compatible }
By default, IS-IS only transmits and receives packets using the narrow cost style.
4.     Enter IPv6 address family view.
5.     Enable IPv6 IS-IS MTR.
multi-topology [ compatible ]
By default, IPv6 IS-IS MTR is disabled.
The IS-IS cost of an interface is determined in the following order:
1.     IS-IS cost specified in interface view.
2.     IS-IS cost specified in system view.
The cost is applied to the interfaces associated with the IS-IS process.
3.     Automatically calculated cost.
If the cost style is wide or wide-compatible, IS-IS automatically calculates the cost using the formula: Interface cost = (Bandwidth reference value / Expected interface bandwidth) × 10, in the range of 1 to 16777214. For other cost styles, Table 3 applies.
Configure the expected bandwidth of an interface with the bandwidth command.
Table 3 Automatic cost calculation scheme for cost styles other than wide and wide-compatible
Interface bandwidth
Interface cost
≤ 10 Mbps
60
≤ 100 Mbps
50
≤ 155 Mbps
40
≤ 622 Mbps
30
≤ 2500 Mbps
20
> 2500 Mbps
10
4.     If none of the above costs is used, a default cost of 10 applies.
Configuring an IPv4 IS-IS cost for an interface
3.     (Optional.) Specify an IS-IS cost style.
By default, the IS-IS cost type is narrow.
6.     Specify a cost for the IS-IS interface.
isis [ process-id process-id ] cost cost-value [ level-1 | level-2 ]
By default, no cost for the interface is specified.
Configuring a global IPv4 IS-IS cost
3.     Specify a global IS-IS cost.
circuit-cost cost-value [ level-1 | level-2 ]
By default, no global cost is specified.
Enabling automatic IPv4 IS-IS cost calculation
3.     Enable automatic IS-IS cost calculation.
auto-cost enable
By default, automatic IS-IS cost calculation is disabled.
4.     (Optional.) Configure a bandwidth reference value for automatic IS-IS cost calculation.
bandwidth-reference value
The default setting is 100 Mbps.
Configuring an IPv6 IS-IS cost for an interface
9.     Specify an IPv6 cost for the IS-IS interface.
isis [ process-id process-id ] ipv6 cost cost-value [ level-1 | level-2 ]
By default, no IPv6 cost is specified for the interface.
Configuring a global IPv6 IS-IS cost
3.     Enter IPv6 address family view.
4.     Specify a global IPv6 IS-IS cost.
By default, no global IPv6 cost is specified.
Enabling automatic IPv6 IS-IS cost calculation
5.     Enable automatic IPv6 IS-IS cost calculation.
auto-cost enable
By default, automatic IPv6 IS-IS cost calculation is disabled.
6.     (Optional.) Configure a bandwidth reference value for automatic IPv6 IS-IS cost calculation.
By default, the bandwidth reference value is 100 Mbps.
When a member port of a Layer 3 aggregate interface goes down, the bandwidth of the aggregate interface decreases and services might be interrupted. To resolve this issue, perform this task to change the link cost of a Layer 3 aggregate interface as follows:
·     When the bandwidth of the Layer 3 aggregate interface falls below the specified threshold, the aggregate interface uses the specified link cost. Make sure the link cost you specified is larger than the original link cost, so that IS-IS can select an optimal path for traffic forwarding.
·     When the bandwidth of the Layer 3 aggregate interface is equal to or larger than the bandwidth threshold, the aggregate interface uses the original link cost.
For more information about IS-IS link cost, see "Configuring IS-IS link cost."
2.     Enter Layer 3 aggregate interface view or Layer 3 aggregate subinterface view.
¡     Enter Layer 3 aggregate interface view.
interface route-aggregation interface-number [ pex ]
¡     Enter Layer 3 aggregate interface view or Layer 3 aggregate subinterface view.
interface route-aggregation interface-number.subnumber
3.     Change the link cost of the interface to the specified value when the bandwidth of the interface falls below the specified threshold.
IPv4:
isis cost-fallback cost-value threshold bandwidth-value [ level-1 | level-2 ]
IPv6:
isis ipv6 cost-fallback cost-value threshold bandwidth-value [ level-1 | level-2 ]
By default, a Layer 3 aggregate interface uses the original link cost.
On an IS-IS network, when a link recovers from failures or the state of an interface changes, IS-IS will re-establish neighbor relationships and perform route convergence. During the route convergence process, routing loops and traffic loss might occur because the convergence speeds of the nodes are different. To address this issue, enable IS-IS to advertise the maximum link cost to neighbors within the specified period of time, so the traffic forwarding path remains unchanged. After the specified period of time, IS-IS advertises the original link cost to neighbors and performs optimal route selection again.
3.     Enable IS-IS to advertise the maximum link cost to neighbors within the specified period of time.
isis peer hold-max-cost duration time
By default, IS-IS advertises the original link cost to neighbors during a route convergence.
If multiple routing protocols find routes to the same destination, the route found by the routing protocol that has the highest preference is selected as the optimal route.
Perform this task to assign a preference to IS-IS directly or by using a routing policy. For more information about the routing policy, see "Configuring routing policies."
Configuring a preference for IPv4 IS-IS
2.     Enter IS-IS IPv4 unicast address family view.
3.     Configure a preference for IPv4 IS-IS.
The default setting is 15.
Configuring a preference for IPv6 IS-IS
3.     Enter IS-IS IPv6 address family view.
4.     Configure a preference for IPv6 IS-IS.
Perform this task to implement load sharing over ECMP routes.
Configuring the maximum number of ECMP routes for IPv4 IS-IS
3.     Specify the maximum number of ECMP routes.
maximum load-balancing number
By default, the maximum number of IPv4 IS-IS ECMP routes is 64.
Configuring the maximum number of ECMP routes for IPv6 IS-IS
4.     Specify the maximum number of ECMP routes.
By default, the maximum number of IPv6 IS-IS ECMP routes equals the maximum number of ECMP routes, which is configurable by using the max-ecmp-num command.
Perform this task to summarize specific routes, including IS-IS routes and redistributed routes, into a single route. Route summarization can reduce the routing table size and the LSDB scale.
Route summarization applies only to locally generated LSPs.
Configuring IPv4 IS-IS route summarization
3.     Configure IPv4 IS-IS route summarization.
summary ip-address { mask-length | mask } [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
By default, IPv4 IS-IS route summarization is not configured.
The cost of the summary route is the lowest one among the costs of the more-specific routes.
Configuring IPv6 IS-IS route summarization
4.     Configure IPv6 IS-IS route summarization.
summary ipv6-prefix prefix-length [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
By default, IPv6 IS-IS route summarization is not configured.
IS-IS cannot redistribute a default route to its neighbors. This task enables IS-IS to advertise a default route of 0.0.0.0/0 in an LSP to the same-level neighbors. Upon receiving the default route, the neighbors add it into their routing table.
When multiple devices exist in the IS-IS network, configuring default route advertisement is more flexible than configuring default static routes. For example, if multiple border devices exist in the IS-IS routing domain, you can configure a routing policy to control the advertisement of default routes and prevent routing blackholes.
Advertising an IPv4 IS-IS default route
3.     Advertise a Level-1 or Level-2 default route.
default-route-advertise [ avoid-learning | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
By default, IPv4 IS-IS does not advertise a Level-1 or Level-2 default route.
Advertising an IPv6 IS-IS default route
4.     Advertise a Level-1 or Level-2 default route.
By default, IPv6 IS-IS does not advertise a Level-1 or Level-2 default route.
After you enable default route advertisement for a border device in the IS-IS routing domain, the border device acts as a gateway to external routing domains for other devices in the same routing domain. The service burden on the border device will be heavy when it receives a large number of packets from other devices. Besides, selecting the optimal route to an external routing domain might be an issue when multiple border devices exist in the IS-IS routing domain. To resolve these issues, you can perform this task to redistribute routes from other routing protocols into IS-IS.
You can configure the cost value for redistributed IGP routes and BGP routes. With an ACL, IP prefix list, or routing policy, IS-IS can filter redistributed routes. IS-IS adds only matching routes into its routing table, and then advertises them in LSPs.
To avoid the potential impact on the performance of some network devices, you can specify the maximum number of redistributed routes.
Configuring IPv4 IS-IS route redistribution
3.     Redistribute routes from other routing protocols or other IS-IS processes.
import-route bgp [ as-number ] [ allow-ibgp ] [ cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route bgp [ as-number ] [ allow-ibgp ] inherit-cost [ [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { direct | static | unr } [ cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { direct | static | unr } inherit-cost [ [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route eigrp [ eigrp-as | all-as ] [ allow-direct | cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route eigrp [ eigrp-as | all-as ] inherit-cost [ allow-direct | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route rip [ process-id | all-processes ] [ allow-direct | cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route rip [ process-id | all-processes ] inherit-cost [ allow-direct | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { isis | ospf } [ process-id | all-processes ] [ allow-direct | cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | no-sid | route-policy route-policy-name | tag tag ] *
import-route { isis | ospf } [ process-id | all-processes ] inherit-cost [ allow-direct | [ level-1 | level-1-2 | level-2 ] | no-sid | route-policy route-policy-name | tag tag ] *
By default, IS-IS does not redistribute routes.
This command redistributes only active routes. To display active routes, use the display ip routing-table protocol command.
4.     (Optional.) Configure the maximum number of redistributed Level 1/Level 2 IPv4 routes.
import-route limit number
By default, the maximum number of redistributed Level 1/Level 2 IPv4 routes is not configured.
5.     (Optional.) Enable IPv4 IS-IS to filter redistributed routes.
filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } export [ bgp | direct | eigrp eigrp-as | { isis | ospf | rip } process-id | static | unr ]
By default, IPv4 IS-IS does not filter redistributed routes.
6.     (Optional.) Exclude redistributed IPv4 routes from route calculation.
import-route no-route-calculate
By default, redistributed IPv4 routes can participate in route calculation.
Configuring IPv6 IS-IS route redistribution
4.     Redistribute routes from other routing protocols or other IS-IS processes.
import-route protocol [ as-number | process-id ] [ allow-ibgp ] [ allow-direct | [ cost cost-value | inherit-cost ] | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
By default, no route is redistributed.
5.     (Optional.) Configure the maximum number of redistributed Level 1/Level 2 IPv6 routes.
The default for this command varies by device model.
6.     (Optional.) Enable IPv6 IS-IS to filter redistributed routes.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } export [ bgp4+ | direct | { isisv6 | ospfv3 | ripng } process-id | static | unr ]
By default, IPv6 IS-IS does not filter redistributed routes.
7.     (Optional.) Exclude redistributed IPv6 routes from route calculation.
By default, redistributed IPv6 routes can participate in route calculation.
IS-IS saves LSPs received from neighbors in the LSDB, and uses the SPF algorithm to calculate the shortest path tree with itself as the root. IS-IS installs the calculated routes to the IS-IS routing table and the optimal routes to the IP routing table.
Perform this task to filter calculated routes. Only routes that are not filtered can be added to the IP routing table. The filtered routes retain in the IS-IS routing table and can be advertised to neighbors.
Filtering IPv4 IS-IS routes calculated from received LSPs
3.     Filter routes calculated using received LSPs.
filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } import
By default, IPv4 IS-IS route filtering is not configured.
Filtering IPv6 IS-IS routes calculated from received LSPs
4.     Filter routes calculated using received LSPs.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } import
By default, IPv6 IS-IS route filtering is not configured.
By default, the Level-2 router does not advertise the routes of the Level-2 area and other Level-1 areas to a Level-1 area. The Level-1 routers in that Level-1 area sends packets destined for other areas to the nearest Level-1-2 router. As a result, IS-IS cannot use the optimal route to forward these packets. To resolve this issue, perform this task to configure IS-IS route leaking.
After you configure route leaking on a Level-1-2 router, this feature functions as follows:
1.     Filters routes with the specified criteria.
2.     Imports the desired routes from other Level-1 areas and the Level-2 area into the Level-1 area to which the Level-1-2 router belongs.
As shown in Figure 8, the optimal path from Device A to Device F is Device A > Device B > Device D > Device E > Device F and the total cost is 40. By default, the actual path to Device F on Device A is Device A > Device C > Device E > Device F and the total cost is 70. After you configure route leaking on Device C and Device D, IS-IS will use the Device A > Device B > Device D > Device E > Device F path to forward traffic from Device A to Device F.
Figure 8 Route leaking
Perform this task to control route advertisement (route leaking) between Level-1 and Level-2.
You can configure IS-IS to advertise routes from Level-2 to Level-1, and to not advertise routes from Level-1 to Level-2.
Configuring IPv4 IS-IS route leaking
3.     Configure route leaking from Level-1 to Level-2.
import-route isis level-1 into level-2 [ filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | no-sid | tag tag ] *
By default, IS-IS advertises routes from Level-1 to Level-2.
4.     Configure route leaking from Level-2 to Level-1.
import-route isis level-2 into level-1 [ filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | no-sid | tag tag ] *
By default, IS-IS does not advertise routes from Level-2 to Level-1.
Configuring IPv6 IS-IS route leaking
import-route isisv6 level-2 into level-1 [ filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
5.     Configure route leaking from Level-1 to Level-2.
import-route isisv6 level-1 into level-2 [ filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
After the device advertises IS-IS link state information to other protocols, such as BGP and SR-MPLS TE Policy, these protocols can then advertise the information for intended applications.
3.     Advertise IS-IS link state information to BGP.
distribute { bgp-ls | link-state } [ instance-id id ] [ level-1 | level-2 ]
By default, the device does not advertise IS-IS link state information to any other protocol.
Set an IPv6 IS-IS link tag for a device (for example, Device A) and enable IPv6 IS-IS link tag inheritance on another device (for example, Device B) to filter routes as follows:
1.     Device A advertises the IPv6 IS-IS link tag in LSPs.
2.     After receiving the LSPs advertised by Device A, Device B inherits the IPv6 IS-IS link tag advertised by Device A.
If Device B receives multiple link tags from Device A, Device B selects and inherits only one tag.
3.     Device B configures the link tag as the route tag for all routes that pass the link.
Then, the route tag can be used for route filtering.
This feature is usually used in Source Address Validation Architecture (SAVA) scenarios to ensure the consistency of IPv6 SAVA entries on multiple gateway devices:
1.     Set an IPv6 IS-IS link tag for the customer-side interface on the gateway device that advertises IPv6 SAVA entries.
2.     Enable IPv6 IS-IS link tag inheritance on the gateway device that receives IPv6 SAVA entries. The device generates an IPv6 SAVA entry based on a route prefix if the following two tags are the same:
¡     The route tag configured by executing the ipv6 sava import remote-route-tag command.
¡     The IPv6 IS-IS link tag that the route inherits.
For more information about SAVA and IPv6 SAVA entries, see SAVA configuration in Security Configuration Guide.
Setting an IPv6 IS-IS link tag for an interface
3.     Set an IPv6 IS-IS link tag for the interface.
isis ipv6 link-tag tag
By default, no IPv6 IS-IS link tag is configured for the interface.
Enabling IPv6 IS-IS link tag inheritance
4.     Enable IPv6 IS-IS link tag inheritance.
link-tag inherit enable
By default, IPv6 IS-IS link tag inheritance is disabled.
A controller in a network performance-sensitive scenario uses parameters that can reflect the network performance as route calculation metrics.
Perform this task to enable IS-IS to advertise network performance parameters and report the information to the controller through BGP-LS. Then, the controller performs optimal route calculation based on the network performance parameters.
Network performance parameters include the following:
·     Delay—Unidirectional link delay performance metrics, including:
¡     Average link delay—Average unidirectional link delay.
¡     Min/Max link delay—Minimum/maximum unidirectional link delay.
¡     Average link delay variation—Average unidirectional link delay variation.
·     Bandwidth—Unidirectional link bandwidth performance metrics, including:
¡     Remaining bandwidth—Remaining unidirectional link bandwidth.
¡     Available bandwidth—Available unidirectional link bandwidth.
¡     Utilized bandwidth—Unidirectional link bandwidth usage.
·     Link loss—Unidirectional link loss performance metric.
To enable IS-IS to advertise link attributes in LSPs, perform one or more of the following tasks as needed:
·     Execute the advertise link-attributes command to enable IS-IS to advertise link attributes in LSPs.
·     Enable MPLS TE on the device that runs IPv4 IS-IS and the interface enabled with IPv4 IS-IS. For more information, see MPLS TE configuration in MPLS Configuration Guide.
·     Enable IPv6 TE on the device that runs IPv6 IS-IS. For more information, see SRv6 configuration in Segment Routing Configuration Guide.
·     Execute the te attribute enable command to enable IS-IS to advertise TE attributes.
Perform this task to enable IS-IS to advertise network performance parameters through sub-TLVs in the extended IS reachability TLV (type 22).
3.     Enter IS-IS IPv4 address family view or IS-IS IPv6 address family view.
¡     Enter IS-IS IPv4 address family view.
¡     Enter IS-IS IPv6 address family view.
4.     Enable IS-IS to advertise link attributes in LSPs.
By default, IS-IS does not advertise link attributes in LSPs.
Perform this task to enable IS-IS to advertise link delay information and report the information to the controller through BGP-LS. Then, the controller performs optimal route calculation based on the link delay information.
Perform either of the following tasks to obtain link delay information of an interface:
·     Static configuration—Execute the isis link-delay command to manually configure link delay parameters on the interface.
·     Dynamic acquisition—Execute the test-session bind interface command to bind the interface as the out interface of a TWAMP Light test session. Then, TWAMP Light will send the detected link delay information to the interface, and the interface will immediately report the link delay information to IS-IS. For more information about TWAMP Light, see NQA configuration in Network Management and Monitoring Configuration Guide.
In dynamic acquisition mode, NQA TWAMP-light advertises link delay information to the associated interface at rather short intervals. As a result, the interface reports link delay information to IS-IS frequently. As a result, IS-IS needs to frequently process the link delay information and reports the information to the controller through BGP-LS, which consumes a lot of device and network resources. To resolve this issue, you can configure IS-IS to suppress advertisement of link delay information.
Link delay advertisement suppression works as follows:
·     NQA TWAMP Light sends the detected link delay information to the associated interface at intervals, and then the interface will report the link delay information to IS-IS.
·     IS-IS advertises link delay information through BGP-LS at intervals specified by the time-value argument. IS-IS does not advertise link delay information within the suppression timer except for the following conditions:
¡     The variation ratio between two consecutive minimum delays is larger than or equivalent to the suppression threshold for the delay variation ratio.
¡     The absolute value of the difference between two consecutive minimum delays is larger than or equivalent to the suppression threshold for the absolute value of the delay variation.
For an interface, static link delay parameters take precedence over the parameters obtained through dynamic acquisition.
As a best practice, set the link delay advertisement suppression interval to be larger than or equivalent to the NQA delay measurement interval.
Configuring link delay parameters
3.     Configure link delay parameters.
isis link-delay { average average-delay-value | min min-delay-value max max-delay-value | variation variation-value } *
By default, link delay parameters are not configured.
Enabling IS-IS to advertise link delay information
3.     Enter IS-IS IPv4 address family view or IS-IS IPv4 address family view.
4.     Enable IS-IS to advertise link delay information.
metric-delay advertisement enable [ level-1 | level-2 ]
By default, IS-IS does not advertise link delay information.
Configuring IS-IS to suppress link delay information advertisement
3.     Configure IS-IS to suppress link delay information advertisement.
metric-delay suppression timer time-value percent-threshold percent-value absolute-threshold absolute-value
By default, IS-IS suppresses link delay information advertisement.
If you set an argument to 0, the corresponding suppression mechanism does not take effect. If you set all arguments to 0, IS-IS does not suppress link delay information advertisement.
Perform this task to enable IS-IS to advertise link bandwidth information and report the information to the controller through BGP-LS. Then, the controller performs optimal route calculation based on the link bandwidth information.
By default, an interface reports link bandwidth information to IS-IS at short intervals, for example, 100 milliseconds. As a result, IS-IS needs to frequently process the link bandwidth information and reports the information to the controller through BGP-LS, which consumes a lot of device and network resources. To resolve this issue, you can configure IS-IS to suppress advertisement of link bandwidth information.
Link bandwidth advertisement suppression works as follows:
·     An interface reports link bandwidth information to IS-IS at negotiated intervals.
·     IS-IS advertises link bandwidth information through BGP-LS at intervals specified by the time-value argument.
As a best practice, set the link bandwidth advertisement suppression interval to be larger than or equivalent to the Ethernet interface bandwidth measurement interval.
Enabling IS-IS to advertise link bandwidth information
4.     Enable IS-IS to advertise link bandwidth information.
metric-bandwidth advertisement enable [ level-1 | level-2 ]
By default, IS-IS does not advertise link bandwidth information.
Configuring IS-IS to suppress link bandwidth information advertisement
3.     Configure IS-IS to suppress link bandwidth information advertisement.
metric-bandwidth suppression timer time-value
By default, IS-IS suppresses link bandwidth information advertisement.
If you set the time-value argument to 0, IS-IS does not suppress link bandwidth information advertisement.
Perform this task to enable IS-IS to advertise link loss information and report the information to the controller through BGP-LS. Then, the controller performs optimal route calculation based on the link loss information.
Perform either of the following tasks to obtain link loss information of an interface:
·     Static configuration—Execute the isis link-loss command to manually configure the link loss of an interface.
·     Dynamic acquisition—Execute the test-session bind interface command to bind the interface as the out interface of a TWAMP Light test session. Then, TWAMP Light will send the detected link loss information to the interface, and the interface will immediately report the link loss information to IS-IS. For more information about TWAMP Light, see NQA configuration in Network Management and Monitoring Configuration Guide.
In dynamic acquisition mode, NQA TWAMP-ligh advertises link loss information to the associated interface at rather short intervals. As a result, the interface reports link loss information to IS-IS frequently. As a result, IS-IS needs to frequently process the link loss information and reports the information to the controller through BGP-LS, which consumes a lot of device and network resources. To resolve this issue, you can configure IS-IS to suppress advertisement of link loss information.
Link loss advertisement suppression works as follows:
·     NQA TWAMP Light sends the detected link loss information to the associated interface at intervals, and then the interface will report the link loss information to IS-IS.
·     IS-IS advertises link loss information through BGP-LS at intervals specified by the time-value argument. IS-IS does not advertise link loss information within the suppression timer except for the following conditions:
¡     The variation ratio between two consecutive link loss values is larger than or equivalent to the suppression threshold for the link loss variation ratio.
¡     The absolute value of the difference between two consecutive link loss values is larger than or equivalent to the suppression threshold for the absolute link loss variation.
For the same interface, the isis link-loss command takes precedence over the test-session bind interface command.
As a best practice, the suppression timer you specified should not be less than the NQA measurement interval. For more information about NQA, see NQA configuration in Network Management and Monitoring Configuration Guide.
Configuring link loss parameters
3.     Configure link loss parameters.
isis link-loss loss-value
By default, link loss parameters are not configured.
Enabling IS-IS to advertise link loss information
4.     Enable IS-IS to advertise link loss information.
metric-link-loss advertisement enable [ level-1 | level-2 ]
By default, IS-IS does not advertise link loss information.
Configuring IS-IS to suppress link loss information advertisement
3.     Configure IS-IS to suppress link loss information advertisement.
metric-link-loss suppression timer timer-value percent-threshold percent-value absolute-threshold absolute-value
By default, IS-IS suppresses link loss information advertisement.
If you set an argument to 0, the corresponding suppression mechanism does not take effect. If you set all arguments to 0, IS-IS does not suppress link loss information advertisement.
IS-IS traditionally calculates optimal paths based on the IGP metric values of all links. This might not meet the traffic requirements. Flexible algorithm allows users to control path selection flexibly by customizing path calculation methods.
Flexible algorithm concepts
·     FAD—Flexible algorithm definition, a composite of calculation type, metric type, and constraints.
·     Calculation type—Algorithm used for path calculation. In the current software version, only the SPF algorithm is supported.
·     Metric type—Metric type used for optimal path calculation. Available metric types include IS-IS link cost, link delay, and TE cost. For more information about TE cost, see MPLS TE configuration in MPLS TE Configuration Guide.
·     Constraint—Link filter criteria for topology generation. You can use a set of constraints to exclude links with specific affinities from or include them in the flexible algorithm topology. Flexible algorithms use the following link attributes:
¡     Affinity attribute—A link attribute, also known as link color. IS-IS uses LSPs that contain extended administrative group sub-TLVs to advertise FAD constraints, including flexible algorithm exclude admin group sub-TLV, flexible algorithm include-any admin group sub-TLV, and flexible algorithm include-all admin group sub-TLV, which are corresponding to the exclude-any, include-any, and include-all rules, respectively.
¡     SRLG—A Shared Risk Link Group (SRLG) is a set of links that share a resource. If one link in the group fails, the other links might also fail. IS-IS uses LSPs that contain flexible algorithm exclude SRLG sub-TLVs to advertise SRLGs that FAD excludes. For more information about SRLG, see MPLS TE configuration in MPLS Configuration Guide.
·     Flexible algorithm ID—Unique identifier of a flexible algorithm. The ID range is 128 to 255.
Flexible algorithm topology
The flexible algorithm topology is the scope of path calculation. It consists of links selected by the flexible algorithm based on the link constraints. The flexible algorithm excludes a node or a link from the topology in one of the following scenarios:
·     The node is not configured with the flexible algorithm.
·     The link meets one of the following requirements:
¡     An exclude-any constraint exists in the FAD and the link has an affinity that is included in the constraint.
¡     An exclude SRLG constraint exists in the FAD and the link in an SRLG defined by the constraint.
¡     An include-any constraint exists in the FAD and the link does not have any affinity that is included in the constraint.
¡     An include-all constraint exists in the FAD and the link does not have all the affinities that are included in the constraint.
¡     The metric type in the FAD is not IS-IS link cost and the link does not advertise the cost of the metric type.
As shown in Figure 9, when no flexible algorithm is configured, all nodes calculate optimal paths by IS-IS link cost.
Figure 9 Topology without flexible algorithm 130
For comparison, you can configure flexible algorithm 130 for all nodes except Router F. The FAD of flexible algorithm 130 is as follows:
·     Calculation type—SPF algorithm.
·     Metric type—IS-IS link cost.
·     Constraint—Exclude affinity attribute red.
In the new topology shown in Figure 10, all nodes calculate optimal paths based on the calculation type and metric type in the FAD.
Figure 10 Topology with flexible algorithm 130
IS-IS flexible algorithm tasks at a glance
To configure IS-IS flexible algorithm, perform the following tasks:
·     Configuring the definition of a flexible algorithm
a.     Mapping an affinity attribute name to an affinity bit
b.     Assigning affinity attributes to IS-IS links
c.     Configuring a flexible algorithm
d.     (Optional.) Configuring the metric type of a flexible algorithm
·     (Optional.) Improving the reliability of a flexible algorithm
¡     Configuring flexible algorithm FRR
¡     Configuring flexible algorithm TI-LFA FRR
¡     Set the priority of an FRR backup path selection policy
·     Configuring SR-MPLS flexible algorithm:
¡     Applying a flexible algorithm to SR-MPLS
¡     Configuring color attribute-based traffic redirection
·     (Optional.) Applying a flexible algorithm to SRv6
·     (Optional.) Enabling trust level-based FAD advertisement
Configure segment routing before configuring IS-IS flexible algorithms. For more information about SR-MPLS, see SR-MPLS configuration in Segment Routing Configuration Guide. For more information about SRv6, see SRv6 configuration in Segment Routing Configuration Guide.
IS-IS supports a maximum of 256 affinity bits. They are numbered from 0 to 255. You can perform this task to map different affinity attribute names to these bits. As shown in Figure 11, affinity attribute name blue is mapped to bit 1, and red to bit 5.
This feature enables you to configure affinity attributes for links or define the flexible algorithm topology by specifying only the affinity attribute names.
Figure 11 Mapping an affinity attribute to an affinity bit
3.     Map an affinity attribute name to an affinity bit.
affinity-map affinity-name bit-position bit
By default, no affinity attribute name is mapped to an affinity bit.
If you perform this task on an IS-IS interface, the links between the interface and its neighbors will carry specific affinity attributes. In a flexible algorithm scenario, these links will be filtered for path calculation based on the link constraints in the FAD.
3.     Assign affinity attributes to IS-IS links.
isis process-id affinity flex-algo { affinity-name }&<1-32>
By default, an IS-IS link has no affinity attributes.
An IS-IS node cannot participate in the path calculation for a flexible algorithm unless you configure the flexible algorithm for the node. To use a flexible algorithm for path calculation, you must make sure a minimum of one node can advertises the FAD of that flexible algorithm in LSPs.
Each node that participates in the path calculation for a flexible algorithm can have a different FAD. To avoid routing loops in an FAD advertisement scope (IS-IS area), these nodes must use the same FAD. By convention, a node selects an FAD as follows:
·     The FAD with the highest priority will be selected from the FADs advertised within the IS-IS routing domain. If the node does not advertise an FAD, it selects the FAD with the highest priority from the received FADs.
·     The FAD with the greatest system ID will be selected from the FADs that have the highest priority.
3.     Create a flexible algorithm and enter its view.
flex-algo flex-algo-id
4.     Configure a priority for the flexible algorithm.
priority priority-value
By default, the priority of a flexible algorithm is 128.
5.     Configure the link constraints for a flexible algorithm.
¡     Exclude links that have a minimum of one specified affinity attribute.
affinity exclude-any affinity-name&<1-32>
¡     Include links that have a minimum of one specified affinity attribute.
affinity include-any affinity-name&<1-32>
¡     Include links that have all specified affinity attribute.
affinity include-all affinity-name&<1-32>
¡     Specify the SRLG links to be excluded.
exclude-srlg srlg-value&<1-32>
By default, all nodes configured to participate in the path calculation for a flexible algorithm are not excluded from the topology.
6.     Enable FAD advertisement on a node.
advertise-definition enable
By default, a node does not advertise the FAD.
About metric type configuration for flexible algorithm
By default, the flexible algorithm uses IS-IS link cost for optimal path calculation. In some scenarios, the paths calculated by the flexible algorithm might not be optimal. To resolve this issue, configure the flexible algorithm to use another metric type for optimal path calculation.
The flexible algorithm supports the following metric types:
·     IS-IS link cost.
·     Link delay. The flexible algorithm uses the minimum link delay for optimal path calculation.
·     TE cost. The flexible algorithm can use the TE cost reported by MPLS TE or the TE cost specified for the flexible algorithm on the interface. The TE cost specified for the flexible algorithm on the interface takes precedence over the TE cost reported by MPLS TE.
To enable a flexible algorithm to use link delay for optimal path calculation, enable IS-IS link delay advertisement on all interfaces that participate in path calculation.
To enable a flexible algorithm to use the TE cost reported by MPLS TE for optimal path calculation, make sure the following requirements are met:
·     MPLS TE is enabled for each node that participates in path calculation for that flexible algorithm.
·     MPLS and MPLS TE are enabled on each interface that participates in path calculation for that flexible algorithm.
·     TE attribute advertisement has been enabled or IPv6 TE has been enabled for the IS-IS process. To enable TE attribute advertisement, execute the te attribute enable command. To enable IPv6 TE, execute the router-id command.
·     Application-specific link attribute advertisement has been enabled for IS-IS. To enable application-specific link attribute advertisement, execute the advertise application link-attributes command.
Configuring the metric type as link delay
4.     Enable IS-IS link delay advertisement.
By default, IS-IS link delay advertisement is disabled.
5.     Enable IS-IS to advertise application-specific link attributes.
advertise application link-attributes { bandwidth | delay | link-loss | unidirectional-bandwidth | srlg | te } [ asla-only ]
advertise application link-attributes { te [ suppression ] | srlg [ suppression ] } *
By default, IS-IS does not advertise any application-specific link attributes.
6.     Return to IS-IS view.
7.     Enter flexible algorithm view.
8.     Configure the metric type as link delay.
metric-type delay
By default, the metric type is IS-IS link cost.
Configuring the metric type as TE cost reported by MPLS TE
3.     Enable IS-IS to advertise TE attributes.
te attribute enable [ level-1 | level-2 ]
By default, IS-IS does not advertise TE attributes.
4.     Enter IS-IS IPv4 address family view or IS-IS IPv6 address family view.
8.     Configure the metric type as TE cost.
metric-type te-cost
Configuring the metric type as TE cost specified on the IS-IS interface
3.     Enter flexible algorithm view.
4.     Configure the metric type as TE cost.
metric-type te-cost
8.     Specify the TE cost for flexible algorithm.
isis te-metric flex-algo metric-value
By default, the TE cost for flexible algorithm is not specified on an interface.
The flexible algorithm FRR is similar to IS-IS LFA FRR, because it uses LFA to calculate a loop-free backup path with the lowest cost based on the topology.
For illustration, flexible algorithm 130 is configured for all nodes in Figure 12. The FAD of flexible algorithm 130 is as follows:
Figure 12 Topology without flexible algorithm 130
In Figure 13, after you enable FRR, flexible algorithm 130 uses LFA to calculate a primary path and a backup path from Router A to Router D.
Figure 13 Topology with flexible algorithm 130
4.     Enable flexible algorithm FRR.
fast-reroute enable
By default, flexible algorithm FRR is enabled.
If no backup paths exist in the topology, execute the undo fast-reroute enable command to disable flexible algorithm FRR to save device resources.
About TI-LFA FRR
Topology-Independent Loop-free Alternate Fast Reroute (TI-LFA FRR) is an enhanced version of LFA FRR. TI-LFA FRR uses the same algorithms to calculate P space and Q space as Remote LFA FRR. This feature can protect a topology without PQ nodes.
For more information about P space and Q space, see "Configuring IS-IS remote LFA FRR."
For more information about TI-LFA FRR path calculation, see SRv6 configuration in Segment Routing Configuration Guide.
TI-LFA FRR protection types
The following TI-LFA traffic protection types are available:
·     Link protection—Protects traffic that traverses a specific link.
·     Node protection—Protects traffic that traverses a specific node.
Node protection takes precedence over link protection.
TI-LFA FRR uses the common algorithm to calculate backup paths for a flexible algorithm. The only difference is that TI-LFA FRR calculates backup paths for a flexible algorithm according to the FAD and topology of that flexible algorithm.
As shown in Figure 14, Router B is the source node and Router A is the destination node.
The number on each link represents the link cost. A data flow traverses from Router B to Router A. To avoid traffic loss against Router B failure, TI-LFA FRR calculates the backup path: Router B > Router C > Router E > Router F > Router A.
Figure 14 TI-LFA FRR backup path calculation without a flexible algorithm
As shown in Figure 15, flexible algorithm 130 is configured for each node. The FAD of flexible algorithm 130 is as follows:
In this case, the backup path calculated by TI-LFA FRR is Router B > Router C > Router D > Router E > Router F > Router A.
Figure 15 TI-LFA FRR backup path calculation with a flexible algorithm
FRR microloop avoidance for a flexible algorithm
When a link or node fails, TI-LFA FRR switches the traffic to the backup path to ensure continuous data forwarding. During the route convergence process, microloops might occur and cause packet loss and disorder if the route convergence on each device is not simultaneous.
As shown in Figure 16, flexible algorithm 128 is configured for all nodes on the network and TI-LFA is enabled for that flexible algorithm. The FAD of flexible algorithm 128 is as follows:
·     Metric type—IS-IS link cost. The link cost of each link in Figure 16 is 10.
If no node failures occur, Device A forwards traffic to Device C along the path: Device A > Device B > Device C. If Device B fails, traffic to Device C will be switched to the backup path calculated by TI-LFA. After Device A finishes route convergence, traffic to Device C will be forwarded along the post-convergence path. If Device D has not finished route convergence and still forward traffic along the pre-convergence path, a loop is formed between Device A and Device D. The loop exists until Device D finishes route convergence.
Figure 16 TI-LFA FRR microloop avoidance after a node failed
FRR microloop avoidance can resolve this issue. After you enable this feature for Device A, Device A first switches traffic to the backup path calculated by TI-LFA when Device B fails. Device A does not start route convergence unless Device D and Device F finish route convergence. After Device A also finishes route convergence, Device A switches the traffic to the post-convergence route.
SR microloop avoidance for a flexible algorithm
FRR microloop avoidance for a flexible algorithm provides microloop avoidance after a network failure. SR microloop avoidance for a flexible algorithm provides microloop avoidance both after a network failure and after a failure recovery.
After a network failure occurs or recovers in a scenario where flexible algorithm is used for path calculation, route convergence occurs on relevant network devices. Because of non-simultaneous convergence on network devices, microloops might be formed. After you configure SR microloop avoidance for a flexible algorithm, the devices will forward traffic along the specified path before route convergence is finished on all the relevant network devices. Because the forwarding path is independent of route convergence, microloops are avoided. To leave sufficient time for IS-IS to finish route convergence, set the SR microloop avoidance delay timer. Before the timer expires, failure relevant devices will forward traffic along the specified path. After the timer expires, IS-IS route convergence should have finished and traffic will traverse along the IS-IS-calculated path.
This section introduces only SR microloop avoidance after a failure recovery.
As shown in Figure 17, flexible algorithm TI-LFA is deployed on all network nodes. The FAD is as follows:
·     Use the SPF algorithm.
·     Calculate the smallest cost path based on IS-IS link cost. Assume that the cost is 10 for all links.
·     Exclude links with affinity attribute red.
Before the link between Device B and Device C recovers, traffic traverses along the backup path. After the link recovers, Device A will forward the traffic to Device B if Device A finishes route convergence before Device B. Before Device B also finishes route convergence, Device B still forwards the traffic along the backup path. A loop is formed between Device A and Device B.
SR microloop avoidance can resolve this issue. After the link recovers, SR microloop avoidance automatically calculates the optimal path from Device A to Device C and forwards traffic along the path. To forward a packet along the newly calculated path, Device A adds end-to-end path information, for example, the adjacency SID from Device B to Device C to the packet and then sends the packet to Device B. Then, Device B forwards the packet to Device C based on the path information.
When the SR microloop avoidance delay timer expires, Device B should have finished route convergence. Device A does not add path information to packets anymore, and it forwards packets to Device C as usual.
Figure 17 Network diagram
If you configure both FRR microloop avoidance and SR microloop avoidance for a flexible algorithm, SR microloop avoidance takes effect.
Enabling TI-LFA FRR
4.     Enable TI-LFA FRR.
fast-reroute ti-lfa enable
By default, TI-LFA FRR is enabled.
5.     (Optional.) Enable Level-1 TI-LFA to use a Level-2 path as the backup path.
a.     Return to IS-IS view.
b.     Enter IS-IS IPv4 address family view or IS-IS IPv6 address family view.
address-family { ipv4 | ipv6 } [ unicast ]
c.     Enable Level-1 TI-LFA to use a Level-2 path as the backup path.
inter-level-tilfa level-1 enable [ prefer ]
By default, Level-1 TI-LFA cannot use a Level-2 path as the backup path.
If you execute this command together with the fast-reroute lfa ecmp-shared command in IS-IS IPv4 unicast address family view, this command does not take effect.
If you execute this command together with the fast-reroute lfa ecmp-shared command in IS-IS IPv6 unicast address family view, this command does not take effect.
Configuring FRR microloop avoidance
4.     Enable FRR microloop avoidance.
fast-reroute microloop-avoidance enable
By default, FRR microloop avoidance is enabled.
5.     Set the RIB update delay timer for FRR microloop avoidance.
fast-reroute microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
By default, the RIB update delay timer is 5000 milliseconds.
Configuring SR microloop avoidance
4.     Enable SR microloop avoidance for the flexible algorithm.
segment-routing microloop-avoidance enable
By default, SR microloop avoidance is enabled for the flexible algorithm.
5.     Set the SR microloop avoidance delay timer.
segment-routing microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
By default, the SR microloop avoidance delay timer is 5000 milliseconds.
6.     (Optional.) Configure SR microloop avoidance to encapsulate only strict SIDs in the SID list.
segment-routing microloop-avoidance strict-sid-only
By default, the strict-SI-only feature is not configured for SR microloop avoidance.
IS-IS flexible algorithm FRR selects a backup path based on the following policies:
·     Node-protection policy—Selects the path that involves a specific node.
·     Lowest-cost policy—Selects the path that has the lowest cost.
As shown in Figure 18, flexible algorithm 128 is configured for all nodes on the network. The FAD of flexible algorithm 128 is as follows:
·     Constraint—Exclude affinity attribute blue.
Traffic forwarding path Device A->Device E->Device F->Device G->Device H has three backup paths. You can set the priority of each backup path selection policy as follows to control backup path selection:
·     To select path Device A->Device E->Device F->Device C->Device D ->Device H that involves Device E, set a higher priority for the node-protection policy than the lowest-cost policy.
·     To select path Device A->Device B->Device C->Device F->Device G ->Device H that has the lowest cost, set a higher priority for the lowest-cost policy than the node-protection policy.
Figure 18 IS-IS FRR backup path selection
If the node-protection policy has a higher priority but the backup path calculation fails, IS-IS uses the lowest-cost policy for further calculation. If the backup path calculation still fails, IS-IS does not perform further backup path calculation.
If the lowest-cost policy has a higher priority but the backup path calculation fails, IS-IS does not perform further backup path calculation.
4.     Set the priority for a backup path selection policy.
fast-reroute tiebreaker { lowest-cost | node-protecting } preference preference [ level-1 | level-2 ]
By default, the priority values of the node-protection and lowest-cost backup path selection policies are 40 and 20, respectively.
IS-IS advertises a prefix SID together with the algorithm ID associated to that prefix SID. By default, the algorithm ID associated to a prefix SID is 0. In this case, IS-IS uses the SPF algorithm and IS-IS link cost to calculate the optimal path to the prefix of that prefix SID.
After you associate a prefix SID to a flexible algorithm, IS-IS uses the flexible algorithm to calculate the optimal path to the prefix of that prefix SID. For example, you can associate the prefix SID configure on the loopback interface of Router F to flexible algorithm 130. The FAD of flexible algorithm 130 is as follows:
SID index value 201 is assigned to loopback address 1.1.1.1/32 on Router F. The incoming label calculated by Router F is 16201. After using flexible algorithm 130 to calculate the optimal path to 1.1.1.1/32, Router A creates a label forwarding entry. The incoming label is 16201, the outgoing label is 16201, and the next hop is Router C. Figure 19 shows the established SRLSP from Router A to Router F.
Figure 19 SRLSP from Router A to Router F with flexible algorithm 130
2.     Enter loopback interface view.
interface loopback interface-number
3.     Associate an IS-IS prefix SID to a flexible algorithm.
isis [ process-id process-id ] prefix-sid algorithm algorithm-id { absolute absolute-value | index index-value } [ n-flag-clear | { explicit-null | no-php } ] *
By default, an IS-IS prefix SID is not associated to any flexible algorithm.
For more information about this command, see SR-MPLS commands in Segment Routing Command Reference.
Configure this feature to forward packets through the path calculated by the specified flexible algorithm in an SR MPLS network where multiple paths exist between the source and destination nodes.
After you configure this feature, an SR node processes a received BGP route that carries the color attribute as follows:
1.     Finds the flexible algorithm mapped to the color attribute.
2.     Finds the path calculated by the flexible algorithm based on the destination address of the BGP route.
3.     Recurses the BGP route to the path.
Then, the SR node will forward packets that match the BGP route through the path.
If a BGP route received by the SR node does not carry the extended community attribute, you can perform either of the following tasks to specify a color attribute for the route:
·     Add a color value to the route by using a routing policy.
·     Execute the default-color command to specify a default color value for the route. For more information about the default-color command, see SR-MPLS TE policy commands in Segment Routing Command Reference.
The color value specified through the routing policy takes precedence.
2.     Enter segment routing view.
segment-routing
3.     Create and enter SR flexible algorithm view.
flex-algo
4.     Map a color attribute to a flexible algorithm.
color-mapping color-value flex-algo flex-algo-id
By default, a color attribute is not mapped to any flexible algorithm.
With SRv6 enabled, IS-IS advertises SRv6 locator TLVs in LSPs. You can identify the algorithm associated to the locator by checking the algorithm field in an SRv6 locator TLV. By default, IS-IS uses the SPF algorithm to calculate the shortest path to an SRv6 locator, and the value for the algorithm field is 0.
If you associate an SRv6 locator to a flexible algorithm, IS-IS uses the flexible algorithm to calculate the shortest path to the locator. For example, you can associate the SRv6 locators in Figure 20 to flexible algorithm 130. The FAD of flexible algorithm 130 is as follows:
As shown in Figure 20, Router A uses the SPF algorithm to calculate the optimal path to locator 2001:0:8:6::/64 based on the topology of flexible algorithm 130.
Figure 20 Optimal path calculated by flexible algorithm 130
You must associate an SRv6 locator to a flexible algorithm that already exists, or IS-IS will not advertise the locator.
2.     Enable SRv6 and enter SRv6 view.
segment-routing ipv6
By default, SRv6 is disabled.
For more information about this command, see SRv6 configuration in Segment Routing Configuration Guide.
3.     Configure a locator and enter SRv6 locator view.
locator locator-name [ ipv6-prefix ipv6-address prefix-length [ args args-length | static static-length ] * ]
4.     Associate the locator to a flexible algorithm.
flex-algo algorithm algo-id
By default, a locator is not associated to any flexible algorithm.
This feature can control FAD advertisement accroding to the trust level and flexible algorithm mappings. For more information about trust level configuration, see trust level configuration in Security Configuration Guide.
Provided that the trust level of the device is X and the security level of flexible algorithm N is M, the device advertises flexible algorithm N as follows:
·     If M is not higher than X, the device advertises flexible algorithm N and generates a network topology based on the flexible algorithm.
·     If M is higher than X, the device does not advertise flexible algorithm N.
4.     Enable trust level-based FAD advertisement for the flexible algorithm.
trust-level-mapping enable
By default, trust level-based FAD advertisement is disabled. If you create a flexible algorithm on a trust level client or server, the device advertises the flexible algorithm.
Configuring IS-IS timers
Specifying the interval for sending IS-IS hello packets
IS-IS uses hello packets to maintain neighbor relationships. If a neighbor does not receive any hello packets from the router within the advertised hold time, it considers the router down and recalculates the routes. The hold time is the hello multiplier multiplied by the hello interval.
The interval between hello packets sent by the DIS is 1/3 the hello interval set with the isis timer hello command.
3.     Specify the interval for sending hello packets.
isis timer hello seconds [ level-1 | level-2 ]
The default setting is 10 seconds.
Specifying the interval for sending IS-IS CSNP packets
On a broadcast network, perform this task on the DIS that uses CSNP packets to synchronize LSDBs.
3.     Specify the interval for sending CSNP packets on the DIS of a broadcast network.
isis timer csnp seconds [ level-1 | level-2 ]
Setting the maximum age of LSPs
Each LSP has an age that decreases in the LSDB. Any LSP with an age of 0 is deleted from the LSDB. You can adjust the age value based on the scale of a network.
2.     Enter IS-IS view.
3.     Set the maximum LSP age.
timer lsp-max-age seconds
The default setting is 1200 seconds.
Setting the LSP refresh interval and generation interval
Each router needs to refresh its LSPs at a configurable interval and send them to other routers to prevent valid routes from aging out. A smaller refresh interval speeds up network convergence but consumes more bandwidth.
When network topology changes such as neighbor state, interface metric, system ID, or area ID changes occur, the router generates an LSP after a configurable interval. If such a change occurs frequently, excessive LSPs are generated, consuming a large amount of router resources and bandwidth. To solve the problem, you can adjust the LSP generation interval.
Follow these restrictions and guidelines when you configure the timer lsp-generation command:
·     If you specify only the maximum-interval argument, the LSP generation interval is maximum-interval.
·     If you do not specify the incremental-interval argument, the LSP generation interval is in the range of minimum-interval to maximum-interval.
·     If you specify the incremental-interval argument, the LSP generation interval is as follows:
¡     When network changes are not frequent, the minimum-interval is adopted.
¡     When network changes are frequent, the LSP generation interval increases by incremental-interval × 2n-2 (n is the number of calculation times) each time a generation occurs until the maximum-interval is reached.
3.     Set the LSP refresh interval.
timer lsp-refresh seconds
By default, the LSP refresh interval is 900 seconds.
4.     Set the LSP generation interval.
timer lsp-generation maximum-interval [ minimum-interval [ incremental-interval ] ] [ level-1 | level-2 ]
By default:
¡     The maximum interval is 5 seconds.
¡     The minimum interval is 50 milliseconds.
¡     The incremental interval is 200 milliseconds.
Setting LSP sending intervals
If a change occurs in the LSDB, IS-IS advertises the changed LSP to neighbors. You can specify the minimum interval for sending these LSPs to control the amount of LSPs on the network.
On a P2P link, IS-IS requires an advertised LSP be acknowledged. If no acknowledgment is received within a configurable interval, IS-IS will retransmit the LSP.
2.     Enter interface view.
3.     Specify the minimum interval for sending LSPs and the maximum LSP number that can be sent at a time.
isis timer lsp time [ count count ]
By default, the minimum interval is 33 milliseconds, and the maximum LSP number that can be sent at a time is 5.
4.     Specify the LSP retransmission interval on a P2P link.
isis timer retransmit seconds
By default, the LSP retransmission interval on a P2P link is 5 seconds.
Setting the LSP receiving interval
When the network is stable, IS-IS uses the minimum receiving interval. When the network changes frequently, the receiving interval increases by the incremental interval each time the same LSP is received until the maximum receiving interval is reached.
3.     Set the LSP receiving interval.
timer lsp-arrival maximum-interval [ minimum-interval [ incremental-interval ] ] [ level-1 | level-2 ]
By default, the LSP receiving interval is not set.
Setting the lifetime for expired LSPs in the LSDB
Each IS-IS LSP has a maximum lifetime. After a device receives an LSP, the lifetime of this LSP decreases. The LSP will expire if the following conditions exist:
·     The device does not receive any update for the LSP.
·     The lifetime of the LSP has decreased to 0.
If the device still does not receive any update for the expired LSP within a specific period of time, it will delete the LSP from its LSDB.
Some LSPs might expire before flooding and are deleted from the LSDB, especially when IS-IS has multiple neighbors and the LSDB contains a large number of LSPs. As a result, IS-IS might take a long time to complete route learning, if the LSP advertisement sources cannot update LSPs in time.
To resolve this issue, perform this task to increase the lifetime for expired LSPs. Then, IS-IS can flood out the expired LSPs before they are deleted, which ensures the LSP advertisement sources can update LSPs in time.
3.     Setting the lifetime for expired LSPs in the LSDB.
timer aging-lsp-lifetime { non-self-originate | self-originate } lifetime
By default, the lifetime for an expired LSP varies by the source of this LSP as follows:
¡     If this LSP is generated by the local device, the lifetime is 1200 seconds.
¡     If this LSP is received from another device, the lifetime is 60 seconds.
Setting the SPF calculation interval
Based on the LSDB, an IS-IS router uses the SPF algorithm to calculate the shortest path tree with itself being the root, and uses the shortest path tree to determine the next hop to a destination network. By adjusting the SPF calculation interval, you can prevent bandwidth and router resources from being over consumed due to frequent topology changes.
When network changes are not frequent, the minimum-interval is adopted. If network changes become frequent, the SPF calculation interval increases by incremental-interval × 2n-2 (n is the number of calculation times) each time a calculation occurs until the maximum-interval is reached.
Setting the IPv4 SPF calculation interval
3.     Set the SPF calculation interval.
timer spf { maximum-interval [ minimum-interval [ incremental-interval [ conservative ] ] ] | millisecond millisecond-interval } [ exclude-prc ]
By default:
Setting the IPv6 SPF calculation interval
4.     Set the SPF calculation interval.
By default:
Configuring IS-IS packet-related features
Configuring a DIS priority for an interface
On a broadcast network, IS-IS must elect a router as the DIS at a routing level. You can specify a DIS priority at a level for an interface. The greater the interface's priority, the more likely it becomes the DIS. If multiple routers in the broadcast network have the same highest DIS priority, the router with the highest MAC address becomes the DIS.
3.     Configure a DIS priority for the interface.
isis dis-priority priority [ level-1 | level-2 ]
The default setting is 64.
Configuring the administrative tag value for an interface
This task simplifies route management by allowing IS-IS to control IP address prefixes with the administrative tag.
As shown in Figure 21, Device A needs to communicate with Device B, Device C, and Device D. For security purposes, other devices in areas 2, 3, and 5 cannot receive the packets sent by Device A. To resolve this issue, perform the following task:
1.     Configure the same administrative tag value for the IS-IS interfaces on Device B, Device C, and Device D.
2.     Configure route leaking from Level-2 to Level-1 on the Level-1-2 device in Area 4 and specify the same tag value as the route filter.
As shown in Figure 22, the IS-IS network topology on Device A is updated after you perform the above task.
Figure 21 IS-IS network diagram without the administrative tag
Figure 22 IS-IS network diagram with the administrative tag
Configuring the IPv4 IS-IS administrative tag value for an interface
3.     Configure the IPv4 IS-IS administrative tag value for the interface.
isis tag tag
By default, the IPv4 IS-IS administrative tag value of the interface is not configured.
IS-IS adds the administrative tag to the network address information in LSPs only if the following conditions exist:
¡     An administrative tag value is specified.
¡     The link cost style is wide, wide-compatible, or compatible.
Configuring the IPv6 IS-IS administrative tag value for an interface
3.     Configure the IPv6 IS-IS administrative tag value for the interface.
isis ipv6 tag tag
By default, the IPv6 IS-IS administrative tag value of the interface is not configured.
After you specify an administrative tag value, IS-IS always adds the specified tag value to the IPv6 prefix information in LSPs, regardless of the link cost style.
Specifying the IS-IS hello multiplier
The hello multiplier is the number of hello packets a neighbor must miss before it declares that the router is down.
If a neighbor receives no hello packets from the router within the advertised hold time, it considers the router down and recalculates the routes. The hold time is the hello multiplier multiplied by the hello interval.
On a broadcast link, Level-1 and Level-2 hello packets are advertised separately. You must set a hello multiplier for each level.
On a P2P link, Level-1 and Level-2 hello packets are advertised in P2P hello packets. You do not need to specify Level-1 or Level-2.
3.     Specify the hello multiplier.
isis timer holding-multiplier value [ level-1 | level-2 ]
The default setting is 3.
Disabling an interface from sending/receiving IS-IS packets
After being disabled from sending and receiving hello packets, an interface cannot form any neighbor relationship, but can advertise directly connected networks in LSPs through other interfaces. This can save bandwidth and CPU resources, and ensures that other routers know networks directly connected to the interface.
3.     Disable the interface from sending and receiving IS-IS packets.
isis silent
By default, the interface can send and receive IS-IS packets.
Enabling an interface to send small hello packets
IS-IS messages cannot be fragmented at the IP layer because they are directly encapsulated in frames. Any two IS-IS neighboring routers must negotiate a common MTU. To avoid sending big hellos to save bandwidth, enable the interface to send small hello packets without CLVs.
3.     Enable the interface to send small hello packets without CLVs.
isis small-hello
By default, the interface sends standard hello packets.
Setting LSP lengths
IS-IS messages cannot be fragmented at the IP layer because they are directly encapsulated in frames. IS-IS routers in an area must send LSPs smaller than the smallest interface MTU in the area.
If the IS-IS routers have different interface MTUs, configure the maximum size of generated LSP packets to be smaller than the smallest interface MTU in the area. Without the configuration, the routers must dynamically adjust the LSP packet size to fit the smallest interface MTU, which takes time and affects other services.
3.     Specify the maximum length of generated Level-1 LSPs or Level-2 LSPs.
lsp-length originate size [ level-1 | level-2 ]
By default, the maximum length of generated Level-1 LSPs or Level-2 LSPs is 1497 bytes.
4.     Specify the maximum length of received LSPs.
lsp-length receive size
By default, the maximum length of received LSPs is 1497 bytes.
Enabling LSP flash flooding
Changed LSPs can trigger SPF recalculation. To advertise the changed LSPs before the router recalculates routes for faster network convergence, enable LSP flash flooding.
3.     Enable LSP flash flooding.
flash-flood [ flood-count flooding-count | max-timer-interval flooding-interval | [ level-1 | level-2 ] ] *
By default, LSP flash flooding is disabled.
Enabling LSP fragment extension
When the LSP capacity of a device is insufficient, enable LSP fragment extension to expand the LSP capacity. These LSPs can then carry more IS-IS information, including redistributed routes and TLVs. If IS-IS fails to add some redistributed routes or TLVs into an LSP, it will automatically try to re-add those redistributed routes and TLVs into the LSP after LSP fragment extension.
The LSP fragment extension feature involves the following concepts:
·     Originating System—IS-IS process.
·     Normal System ID—System ID of the originating system.
·     Additional System ID—Unique identifier assigned to a virtual system.
·     Virtual System—System used to generate extended LSP fragments. Each extended LSP fragment carries the additional system ID of the virtual system in its LSP ID.
·     IS Alias ID TLV—TLV that describes the relationship between the originating system and the virtual system.
By default, an IS-IS process can generate a maximum of 256 LSP fragments. The number of routes that these LSP fragments can carry is limited. To resolve this issue, the LSP fragment extension feature introduces the concept of additional system ID. Each additional system ID can generate 256 extended LSP fragments. When the LSP capacity of the originating system is insufficient, IS-IS adds the overflowing route information together with the IS Alias ID TLV into the extended LSPs of a virtual system.
As shown in Figure 23, both Device A and Device B support LSP fragment extension. With LSP fragment extension enabled, Device A advertises some route information in the LSPs generated by Device A1 and Device A2. On receipt of these LSPs, Device B reads the IS Alias ID TLVs and determines that Device A is the originating system. The route information received from Device A1 and Device A2 is actually generated by Device A. In this situation, virtual systems do not participate in route calculation.
Figure 23 IS-IS LSP fragment extension
3.     Enable LSP fragment extension.
lsp-fragments-extend [ level-1 | level-1-2 | level-2 ]
By default, LSP fragment extension is disabled.
The MTUs of all interfaces running the IS-IS process must not be less than 512. Otherwise, LSP fragment extension does not take effect.
4.     Configure a virtual system ID.
virtual-system virtual-system-id
By default, no virtual system ID is configured.
Configure a minimum of one virtual system to generate extended LSP fragments.
Controlling LSP generation, advertisement and reception
Limiting LSP flooding
Multiple P2P links might exist on an NBMA network such as ATM and FR. As shown in Figure 24, Routers A, B, C and D run IS-IS. When Router A generates an LSP, it floods the LSP out of Serial3/1/1:0, Serial3/1/2:0, and Serial3/1/3:0. After Router D receives the LSP from Serial3/1/3:0, it floods it out of Serial3/1/1:0 and Serial3/1/2:0 to Router B and Router C. However, Router B and Router C have already received the LSP from Router A. Repeated LSP flooding consumes extra bandwidth.
Figure 24 Network diagram of a fully meshed network
To avoid this issue, you can add interfaces to a mesh group or block some interfaces.
·     An interface in a mesh group floods a received LSP only to interfaces not in the mesh group.
·     A blocked interface sends LSPs only after receiving LSP requests.
Before you configure this task, you must consider redundancy for interfaces in case LSP packets cannot be flooded because of link failures.
3.     Limit LSP flooding.
¡     Add the interface to a mesh group.
isis mesh-group mesh-group-number
¡     Block the interface.
isis mesh-group mesh-blocked
By default, the interface does not belong to any mesh group and is not blocked.
The commands take effect only on P2P interfaces.
Configuring IS-IS route update suppression
Perform this task to protect network resources and routers from being overwhelmed by LSPs when route flapping occurs.
3.     Configure IS-IS route update suppression.
¡     Suppress LSP generation.
timer lsp-generation suppress-flapping delay-interval [ threshold threshold-value] [ level-1 | level-2 ]
By default, IS-IS does not suppress LSP generation.
¡     Suppress LSP flooding.
timer lsp-flood suppress-flapping delay-interval [ threshold threshold-value ] [ level-1 | level-2 ]
By default, IS-IS does not suppress LSP flooding.
¡     Suppress route calculation.
timer route-calculate suppress-flapping delay-interval [ threshold threshold-value ] [ level-1 | level-2 ]
By default, IS-IS does not suppress route calculation.
¡     Suppress route calculation after fragment 0 of a purge LSP is received.
timer purge-zero-lsp route-calculate-delay delay-interval [ level-1 | level-2 ]
By default, IS-IS suppresses route calculation for 10 seconds after fragment 0 of a purge LSP is received.
Configuring advanced IS-IS features
Enabling source address check for hello packets on a P2P interface
An IS-IS P2P interface can have a peer on a different network. Perform this task to configure an IS-IS P2P interface to establish neighbor relationship only with a peer on the same network.
3.     Enable source address check for hello packets on a P2P interface.
isis peer-ip-check
By default, an IS-IS P2P interface can have a peer on a different network.
Configuring convergence priorities for specific routes
A topology change causes IS-IS routing convergence. To improve convergence speed, you can assign convergence priorities to IS-IS routes. Convergence priority levels are critical, high, medium, and low. The higher the convergence priority, the faster the convergence speed.
After you use the prefix-priority command, IS-IS sets the convergence priorities for IS-IS routes as follows:
·     IS-IS sets the convergence priorities for routes that already exist according to the configuration of the prefix-priority command.
·     IS-IS sets the convergence priorities for subsequent routes according to the filter result of the prefix-priority command.
·     When a route matches the rules of multiple convergence priorities, it uses the highest priority.
Configuring convergence priorities for specific IPv4 IS-IS routes
2.     Enter IS-IS IPv4 unicast address family view.
3.     Assign convergence priorities to specific IPv4 IS-IS routes.
¡     Assign a convergence priority to IPv4 IS-IS routes matching the specified prefix list.
prefix-priority { critical | high | medium } { prefix-list prefix-list-name | tag tag-value }
¡     Assign a convergence priority to IPv4 IS-IS routes by using a route policy.
By default, IPv4 IS-IS routes, except IS-IS host routes, have the low convergence priority.
Configuring convergence priorities for specific IPv6 IS-IS routes
3.     Enter IPv6 address family view.
4.     Assign convergence priorities to specific IPv6 IS-IS routes.
By default, IPv6 IS-IS routes, except IS-IS host routes, have the low convergence priority.
Setting the LSDB overload bit
By setting the overload bit in sent LSPs, an IS-IS device informs other devices of failures that make it unable to select routes and forward packets. The device is then excluded from the SPF calculation by other devices except its direct routes.
When an IS-IS device cannot record the complete LSDB, for example, because of memory insufficiency, it will calculate routes incorrectly. To make troubleshooting easier, temporarily isolate the device from the IS-IS network by setting the overload bit. To locate the faulty device, you can temporarily isolate the suspects from the IS-IS network by setting the overload bit.
As shown in Figure 25, the path from Device A to the IP network should be Device A > Device D > Device E > IP network. After you set the overload bit in the LSPs sent by Device D, the path from Device A to the IP network becomes Device A > Device B > Device C > Device E > IP network. If the packets from Device A are destined for Device D's directly-connected networks, the forwarding path does not change.
Figure 25 Overload bit
Setting the LSDB overload bit for IPv4 IS-IS
3.     Set the overload bit.
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 | wait-for-bgp [ timeout3 ] ] [ route-delay-distribute delay-time ] [ send-sa-bit [ duration ] ] [ route-max-metric ] ] [ allow { external | interlevel } * ]
By default, the overload bit is not set.
Setting the LSDB overload bit for IPv6 IS-IS
4.     Set the overload bit.
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 | wait-for-bgp4+ [ timeout3 ] ] [ route-delay-distribute delay-time ] [ send-sa-bit [ duration ] ] [ route-max-metric ] ] [ allow { external | interlevel } * ]
Setting IS-IS interface cost upon LSDB overload
Perform this task to prevent neighbor devices from sending traffic to an overloaded device in an anycast scenario.
Upon entering the overload state, the device sends an LSP with the OL bit set to its neighbors. The neighbor that receives the LSP performs path calculation and forwards packets as follows:
·     For packets destined to a network not directly connected to the overloaded device, the neighbor device does not forward the packets to the overloaded device.
·     For packets destined to the network directly connected to the overloaded device, the neighbor device forwards the packets to the overloaded device.
These processing methods might cause problems in an anycast scenario where the destination address of packets is an anycast address. The neighbor device will send such packets to the anycast node with the smallest cost, and that node might have already entered the overload state. To avoid such problems, perform this task to enable an overloaded device to increase its cost. Neighbors will not select the device during path calculation.
The command takes effect when the device enters the overload state as follows:
·     When the device is in overload state, the system increases the cost of all IS-IS interfaces on the device. Neighbors will not select the device during path calculation.
·     When the device exits the overload state or you execute the undo overload adjust-cost command, the IS-IS interfaces resume their original costs.
Follow these guidelines when you set IS-IS interface cost upon LSDB overload:
·     If route calculation is not performed separately for IPv4 and IPv6 topologies, the configuration takes effect as follows:
¡     The configuration in IS-IS view applies to both IPv4 and IPv6 IS-IS interfaces.
¡     The configuration in IPv6 address family view does not take effect.
·     If route calculation is performed separately for IPv4 and IPv6 topologies, the configuration takes effect as follows:
¡     The configuration in IS-IS view applies only to IPv4 IS-IS interfaces.
¡     The configuration in IPv6 address family view applies only to IPv6 IS-IS interfaces.
2.     Enter IS-IS view or IPv6 address family view.
¡     Enter IS-IS view:
¡     Execute the following commands in sequence to enter IPv6 address family view.
3.     Set the cost for all IS-IS interfaces when the device enters the overload state.
overload adjust-cost { cost-offset | max }
By default, the device does not change the cost for any IS-IS interfaces when it enters the overload state.
Configuring IS-IS isolation
Isolation is a method used for network device maintenance. It gracefully removes a device from the packet forwarding path for maintenance and gracefully adds the device to the network after maintenance.
To reduce impact on traffic forwarding, you can isolate a device before upgrading it. IS-IS isolation works as follows:
1.     After IS-IS isolation is enabled for a device, IS-IS sets the overload bit in the LSPs advertised by the device and sets the link cost to the maximum value.
2.     Each neighbor of the device reselects an optimal route based on the LSPs and stops forwarding traffic to the device. The device is fully isolated from the network and you can upgrade the device.
3.     After the maintenance, disable IS-IS isolation on the device by using the undo isolate enable command. The device can return to the network gracefully after the overload bit is cleared and the link cost restores to the original value.
3.     Configure IS-IS isolation.
a.     Enable IS-IS isolation to gracefully remove the device from the network.
isolate enable
b.     Disable IS-IS isolation to gracefully add the device to the network.
undo isolate enable
By default, IS-IS isolation is disabled.
Configuring IS-IS shutdown
For maintenance purposes, you can use this feature to shut down IS-IS processes on the device with small impact on the network. If you shut down an IS-IS process, it will perform the following operations:
·     Change the state of all neighbors to down.
·     Stop receiving and sending IS-IS packets.
·     Clear its neighbor, LSDB, and IS-IS route information.
If the neighbors do not receive any hello packets from the IS-IS process within the hold time, they consider the process down and recalculate the routes.
After maintenance, you can use the undo shutdown process command to restart the IS-IS process for neighbor relationship re-establishment.
This feature shuts down an IS-IS process while retaining the process-associated settings to facilitate your maintenance.
3.     Configure IS-IS shutdown.
a.     Shut down an IS-IS process to isolate it from the network.
shutdown process
b.     Restart the IS-IS process to add it back to the network.
By default, the IS-IS process is not shut down.
Configuring the ATT bit
The ATT bit is used to identify the connection status between a Level-1 area and other areas. By default, a Level-1-2 router sets the ATT bit for Level-1 LSPs as follows:
·     The Level-1-2 router sets the ATT bit in Level-1 LSPs to inform the Level-1 routers that it can reach other areas. After a Level-1 router receives a Level-1 LSP with the ATT bit set, it generates a default route destined for the Level-1-2 router.
·     The Level-1-2 router does not set the ATT bit in Level-1 LSPs if it can reach only one area.
To edit the default ATT bit setting rule for a Level-1-2 router, perform the following tasks as needed:
·     To enable ATT bit setting for all Level-1 LSPs, execute the set-att always command on the Level-1-2 router.
·     To disable a Level-1 router from generating a default route upon receiving an ATT-bit-set Level-1 LSP from the Level-1-2 router, you can perform one of the following tasks:
¡     Execute the ignore-att command on the Level-1 router.
¡     Execute the set-att never command on the Level-1-2 router.
Configuring IS-IS not to calculate the default route through the ATT bit
3.     Configure IS-IS not to calculate the default route through the ATT bit.
ignore-att
By default, IS-IS uses the ATT bit to calculate the default route.
Setting the IPv4 ATT bit of Level-1 LSPs
3.     Set the ATT bit of Level-1 LSPs.
set-att { always | never }
By default, the Level-1-2 router sets the ATT bit for IPv4 Level-1 LSPs in accordance with the default ATT bit setting rule.
Setting the IPv6 ATT bit of Level-1 LSPs
4.     Set the IPv6 ATT bit of Level-1 LSPs.
By default, the Level-1-2 router sets the ATT bit for IPv6 Level-1 LSPs in accordance with the default ATT bit setting rule.
Configuring system ID to host name mappings
A 6-byte system ID in hexadecimal notation uniquely identifies a router or host in an IS-IS network. To make a system ID easy to read, the system allows you to use host names to identify devices. It also provides mappings between system IDs and host names.
The mappings can be configured manually or dynamically.
·     Static system ID to host name mapping—You must manually configure a mapping for each router in the network. When a new router is added to the network or a mapping must be modified, you must configure all routers manually.
·     Dynamic system ID to host name mapping—You only need to configure a host name for each router in the network. Each router advertises the host name in a dynamic host name CLV to other routers so all routers in the network can have all mappings. To help check the origin of LSPs in the LSDB, you can configure a name for the DIS in a broadcast network.
Follow these guidelines when you configure the mappings:
·     To view host names rather than system IDs by using the display isis lsdb command, you must enable dynamic system ID to host name mapping.
·     If you configure both dynamic mapping and static mapping on a router, the host name specified for dynamic mapping applies.
Configuring a static system ID to host name mapping
3.     Configure a system ID to host name mapping for a remote IS.
is-name map sys-id map-sys-name
By default, no system ID to host name mapping is configured for a remote IS.
A system ID can correspond to only one host name.
Configuring dynamic system ID to host name mapping
3.     Specify a host name for the IS and enable dynamic system ID to host name mapping.
is-name sys-name
By default, dynamic system ID to host name mapping is disabled and no host name is specified for the router.
4.     Return to system view.
5.     Enter interface view.
6.     Configure a DIS name.
isis dis-name symbolic-name
By default, no DIS name is configured.
This command takes effect only on a router enabled with dynamic system ID to host name mapping.
This command is not available on P2P interfaces.
Enabling BIER for an IS-IS process
A node cannot generate a BFR ID-based forwarding table for multicast packet forwarding unless you enable IS-IS Bit Index Explicit Replication (BIER) on the node. For more information about BIER, see BIER configuration in BIER Configuration Guide.
With BIER enabled, IS-IS floods the BFR IDs of BIER edge devices and other information (for example, IP address of the node) in LSPs. After receiving the LSP, each node generates a bit index forwarding table to forward BIER packets by their bit strings.
You can enable BIER only for IS-IS instances running on the public network.
You can enable BIER only for one IS-IS instance on the same device.
The bier enable command takes effect only after you enable BIER by using the bier command.
2.     Enable BIER and enter its view.
bier
By default, BIER is disabled.
For more information about this command, see BIER commands in BIER Command Reference.
3.     Return to system view
4.     Enter IS-IS view.
5.     Specify an IS-IS cost style.
cost-style { compatible | wide | wide-compatible }
6.     Enable BIER for the IS-IS process.
bier enable
By default, BIER is disabled for the IS-IS process.
7.     (Optional.) Enable IS-IS to redistribute BIER information from other protocols.
a.     Enter IS-IS IPv6 address family view.
b.     Enable IS-IS to redistribute BIER information from other protocols.
import-bier bgp4+ [ as-number ]
By default, IS-IS does not redistribute BIER information from other protocols.
This command is applicable to inter-AS BIER traffic forwarding.
Configuring IS-IS logging and SNMP notifications
Enabling the logging of neighbor state changes
Neighbor flappings cause a series of issues, such as network instability, unnecessary resource consumption, and even data loss. You can enable the logging of neighbor state changes for fast issue location and troubleshooting.
With this feature enabled, the device delivers logs about neighbor state changes to its information center. The information center processes the logs according to user-defined output rules (whether to output logs and where to output). For more information about the information center, see Network Management and Monitoring Configuration Guide.
3.     Enable the logging of neighbor state changes.
log-peer-change
By default, the logging of neighbor state changes is enabled.
Setting the maximum number of log entries that can be recorded
Perform this task to set the maximum number of log entries that IS-IS can record for each log type.
3.     Set the maximum number of log entries that IS-IS can record.
event-log { hello { peer-change | received-abnormal | received-dropped | sent-abnormal | sent-failed } | lsp | peer | spf } size count
By default, IS-IS can record 100 log entries for each log type.
Setting the maximum number of advertisement sources that trigger LSP update logging
About task
After the device starts running, it records LSP-update log information every 15 minutes. By default, it can record LSP-update log information for up to 200 advertisement sources. LSP update logging consumes memory resources. To control the memory usage by LSP update logging, you can perform this task.
3.     Set the maximum number of advertisement sources that trigger LSP update logging.
event-log updated-lsp size count
By default, a maximum of 200 advertisement sources can trigger LSP update logging.
Setting the maximum number of IS-IS neighbor relationship troubleshooting entries
2.     Set the maximum number of IS-IS neighbor relationship troubleshooting entries.
isis troubleshooting max-number number
By default, IS-IS can record a maximum of 100 neighbor relationship troubleshooting entries.
Configuring IS-IS network management
This task includes the following configurations:
·     Bind an IS-IS process to MIB so that you can use network management software to manage the specified IS-IS process.
·     Enable IS-IS notifications to report important events.
To report critical IS-IS events to an NMS, enable SNMP notifications for IS-IS. For SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
2.     Bind MIB to an IS-IS process.
isis mib-binding process-id
By default, MIB is bound to the IS-IS process with the smallest process ID.
3.     Enable IS-IS notification sending.
snmp-agent trap enable isis [ adjacency-state-change | area-mismatch | authentication | authentication-type | buffsize-mismatch | id-length-mismatch | lsdboverload-state-change | lsp-corrupt | lsp-parse-error | lsp-size-exceeded | manual-address-drop | max-seq-exceeded | maxarea-mismatch | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | system-id-conflict | version-skew ] *
By default, IS-IS notification sending is enabled.
4.     (Optional.) Extend the format of SNMP notifications for neighbor state changes.
snmp-agent trap isis adjacency-state-change extended
By default, IS-IS does not extend the format of SNMP notifications for neighbor state changes.
5.     Enter IS-IS view.
6.     Configure the context name for the SNMP object for managing IS-IS.
By default, no context name is set for the SNMP object for managing IS-IS.
Configuring IS-IS fast convergence
Enabling ISPF
When the network topology changes, Incremental Shortest Path First (ISPF) computes only the affected part of the SPT, instead of the entire SPT.
Enabling IPv4 IS-IS ISPF
3.     Enable IPv4 IS-IS ISPF.
ispf enable
By default, IPv4 IS-IS ISPF is enabled.
Enabling IPv6 IS-IS ISPF
4.     Enable IPv6 IS-IS ISPF.
ispf enable
By default, IPv6 IS-IS ISPF is enabled.
Enabling prefix suppression
Perform this task to disable an interface from advertising its prefix in LSPs. This enhances network security by preventing IP routing to the interval nodes and speeds up network convergence.
Enabling IPv4 IS-IS prefix suppression
3.     Enable IPv4 IS-IS prefix suppression on the interface.
isis prefix-suppression
By default, IPv4 IS-IS prefix suppression is disabled on the interface.
This command is also applicable to the secondary IP address of the interface.
Enabling IPv6 IS-IS prefix suppression
3.     Enable IPv6 IS-IS prefix suppression on the interface.
isis ipv6 prefix-suppression
By default, IPv6 IS-IS prefix suppression is disabled on the interface.
Configuring IS-IS PIC
Prefix Independent Convergence (PIC) enables the device to speed up network convergence by ignoring the number of prefixes.
Restrictions and guidelines for IS-IS PIC
Follow these restrictions and guidelines when you configure IS-IS PIC:
·     When both IS-IS PIC and IS-IS FRR are configured, IS-IS FRR takes effect.
·     IS-IS PIC applies only to LSPs sent by neighbors.
Enabling IS-IS PIC
3.     Enable PIC for IS-IS.
By default, IS-IS PIC is disabled.
Enabling BFD control packet mode for IS-IS PIC
3.     Enable BFD control packet mode for IS-IS PIC.
isis primary-path-detect bfd ctrl
By default, BFD control packet mode is disabled for IS-IS PIC.
To use BFD (control packet mode) to detect primary link failures, you must enable BFD control packet mode on both ends of the link.
Enabling BFD echo packet mode for IS-IS PIC
2.     (Optional) Configure the source IP address of BFD echo packets.
bfd echo-source-ip ip-address
By default, the source IP address of BFD echo packets is not configured.
As a best practice to avoid network congestion caused by massive ICMP redirect packets from the remote end, execute this command and specify a source IP address that is not on the same network segment as any local interface's IP address.
For more information, see High Availability Command Reference.
3.     Enter interface view.
4.     Enable BFD echo packet mode for IS-IS PIC.
isis primary-path-detect bfd echo
By default, BFD echo packet mode is disabled for IS-IS PIC.
To use BFD (echo packet mode) to detect primary link failures, you only need to enable BFD echo packet mode on one end of the link.
Enhancing IS-IS network security
To enhance the security of an IS-IS network, you can configure IS-IS authentication. IS-IS authentication involves neighbor relationship authentication, area authentication, and routing domain authentication.
Configuring neighbor relationship authentication
With neighbor relationship authentication configured, an interface adds the key in the specified mode into hello packets to the peer and checks the key in the received hello packets. If the authentication succeeds, it forms the neighbor relationship with the peer.
The authentication mode and key at both ends must be identical.
To prevent packet exchange failure in case of an authentication key change, configure the interface not to check the authentication information in the received packets.
3.     Specify the authentication mode and key.
isis [ process-id process-id ] authentication-mode { { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } [ nonstandard ] | md5 | simple } { cipher | plain } string | keychain keychain-name } [ level-1 | level-2 ] [ ip | osi ]
By default, the authentication mode and key are not configured.
4.     (Optional.) Configure the interface not to check the authentication information in the received hello packets.
isis authentication send-only [ level-1 | level-2 ]
When the authentication mode and key are configured, the interface checks the authentication information in the received packets by default.
Configuring area authentication
Area authentication prevents the router from installing routing information from untrusted routers into the Level-1 LSDB. The router encapsulates the authentication key in the specified mode in Level-1 packets (LSP, CSNP, and PSNP). It also checks the key in received Level-1 packets.
Routers in a common area must have the same authentication mode and key.
To prevent packet exchange failure in case of an authentication key change, configure IS-IS not to check the authentication information in the received packets.
3.     Specify the area authentication mode and key.
area-authentication-mode { { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } [ nonstandard ] | md5 | simple } { cipher | plain } string | keychain keychain-name } [ ip | osi ]
By default, the area authentication mode and key are not configured.
4.     (Optional.) Configure the interface not to check the authentication information in the received Level-1 packets, including LSPs, CSNPs, and PSNPs.
area-authentication send-only
Configuring routing domain authentication
Routing domain authentication prevents untrusted routing information from entering into a routing domain. A router with the authentication configured encapsulates the key in the specified mode into Level-2 packets (LSP, CSNP, and PSNP) and check the key in received Level-2 packets.
A router configured with routing domain authentication can establish neighbor relationships with routers not configured with routing domain authentication, but it will discard LSPs not carrying the authentication information. In this situation, IS-IS might fail to learn the expected routes. To resolve this issue, configure the same authentication mode and key on all routers in the backbone area.
3.     Specify the routing domain authentication mode and key.
domain-authentication-mode { { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } [ nonstandard ] | md5 | simple } { cipher | plain } string | keychain keychain-name } [ ip | osi ]
By default, the routing domain authentication mode and key are not configured.
4.     (Optional.) Configure the interface not to check the authentication information in the received Level-2 packets, including LSPs, CSNPs, and PSNPs.
domain-authentication send-only
Configuring IS-IS GR
GR ensures forwarding continuity when a routing protocol restarts or an active/standby switchover occurs.
Two routers are required to complete a GR process. The following are router roles in a GR process.
·     GR restarter—Graceful restarting router. It must have GR capability.
·     GR helper—A neighbor of the GR restarter. It assists the GR restarter to complete the GR process. By default, the device acts as the GR helper.
Configure IS-IS GR on the GR restarter.
GR restarter uses the following timers:
·     T1 timer—Specifies the times that GR restarter can send a Restart TLV with the RR bit set. When rebooted, the GR restarter sends a Restart TLV with the RR bit set to its neighbor. If the GR restarter receives a Restart TLV with the RA set from its neighbor before the T1 timer expires, the GR process starts. Otherwise, the GR process fails.
·     T2 timer—Specifies the LSDB synchronization interval. Each LSDB has a T2 timer. The Level-1-2 router has a Level-1 timer and a Level-2 timer. If the LSDBs have not synchronized before the two timers expire, the GR process fails.
·     T3 timer—Specifies the GR interval. The GR interval is set as the holdtime in hello PDUs. Within the interval, the neighbors maintain their adjacency with the GR restarter. If the GR process has not completed within the holdtime, the neighbors tear down the neighbor relationship and the GR process fails.
Follow these restrictions and guidelines when you configure IS-IS GR:
·     The product of the T1 timer and the number of times that the T1 timer can expire must be smaller than the T2 timer.
·     The T2 timer must be smaller than the T3 timer.
2.     Enable IS-IS and enter IS-IS view.
3.     Enable IS-IS GR.
graceful-restart
By default, the GR capability for IS-IS is disabled.
4.     (Optional.) Suppress the SA bit during restart.
graceful-restart suppress-sa
By default, the SA bit is not suppressed.
By enabling the GR restarter to suppress the Suppress-Advertisement (SA) bit in the hello PDUs, the neighbors will still advertise their adjacency with the GR restarter.
5.     (Optional.) Configure the T1 timer.
graceful-restart t1 seconds count count
By default, the T1 timer is 3 seconds and can expire 10 times.
6.     (Optional.) Configure the T2 timer.
graceful-restart t2 seconds
By default, the T2 timer is 60 seconds.
7.     (Optional.) Configure the T3 timer.
graceful-restart t3 seconds
By default, the T2 timer is 300 seconds.
Configuring BFD for IS-IS
Enabling BFD for IS-IS
IS-IS exchanges hello packets at specific intervals with its neighbors to detect neighbor state changes. If IS-IS does not receive any hello packets from a neighbor within the advertised neighbor relationship hold time, it considers the neighbor down and recalculates the routes. The hold time is the hello multiplier multiplied by the hello interval and the default hold time is 30 seconds. This mechanism is not efficient at neighbor state change detection. Serious packet loss might occur when a neighbor goes down.
To resolve this issue, perform this task to enable BFD for IS-IS. BFD provides a single mechanism to quickly detect and monitor the connectivity of links between IS-IS neighbors, reducing network convergence time. For more information about BFD, see High Availability Configuration Guide.
You can use the bfd all-interfaces enable, isis bfd enable, or isis ipv6 bfd enable command to enable IS-IS BFD. These commands are different as follows:
·     The bfd all-interfaces enable command takes effect on all interfaces in an IPv4 or IPv6 IS-IS process. To disable BFD on an interface in the IS-IS process, use the isis bfd exclude or isis ipv6 bfd exclude command on the interface.
·     The isis bfd enable and isis ipv6 bfd enable commands take effect only on one IS-IS interface. To enable BFD on an IS-IS interface, perform the following tasks:
a.     Make sure the IS-IS process to which the interface belongs is not enabled with BFD session state-based interface cost adjustment.
You can use the undo bfd all-interfaces enable command to disable BFD for an IS-IS process.
b.     Use the isis bfd enable or isis ipv6 bfd enable command to enable BFD on the IS-IS interface.
Configuring BFD for an IS-IS process
3.     Enter IPv4 address family view or IPv6 address family view.
¡     Enter IPv4 address family view.
¡     Enter IPv6 address family view.
4.     Enable BFD for the IS-IS process.
By default, BFD is disabled for an IS-IS process.
5.     (Optional.) Suppress the BFD capacity of an IPv4 IS-IS interface.
b.     Return to system view.
c.     Enter interface view.
d.     Suppress the BFD capacity of the IS-IS interface.
IPv4:
isis bfd exclude
IPv6:
By default, the BFD capacity of an IS-IS interface is not suppressed.
Configuring BFD on an IS-IS interface
3.     Enable BFD on an IPv4 IS-IS interface.
IPv4:
isis bfd enable
By default, the IPv4 IS-IS interface inherits the configuration of the bfd all-interfaces enable command in IS-IS IPv4 unicast address family view.
IPv6:
By default, the IPv6 IS-IS interface inherits the configuration of the bfd all-interfaces enable command in IS-IS IPv6 unicast address family view.
Enabling IS-IS to adjust the interface cost according to the BFD session state
After you enable BFD for IS-IS link failure detection, IS-IS neighbor relationship flapping will occur upon frequent BFD session state changes. The running of services (such as BGP) that rely on IPv4 IS-IS might be interrupted. To resolve this issue, enable IS-IS to adjust the interface cost according to the BFD session state. IS-IS will adjust the cost value for an interface as follows to ensure fast route convergence against link state changes:
·     When the BFD session on the interface goes down, IS-IS increases the cost value for the interface.
·     When the BFD session on the interface comes up again, IS-IS restores the cost value for the interface to the original value.
This task can take effect on an IS-IS interface only when BFD is enabled on the interface.
You can use one of the following commands to enable IS-IS to adjust the interface cost according to the BFD session state:
·     bfd all-interfaces adjust-cost
·     isis bfd adjust-cost
·     isis ipv6 bfd adjust-cost
·     The bfd all-interfaces adjust-cost command takes effect on all interfaces in an IPv4 or IPv6 IS-IS process. To disable this feature on an interface in that IS-IS process, use the isis bfd adjust-cost exclude or isis ipv6 bfd adjust-cost exclude command on the interface.
·     The isis bfd adjust-cost and isis ipv6 bfd adjust-cost commands take effect only on one IS-IS interface. For IS-IS to adjust the cost value for a single interface according to the BFD session state, perform the following tasks:
You can use the undo bfd all-interfaces adjust-cost command to disable this feature for an IS-IS process.
b.     Use the isis bfd adjust-cost or isis ipv6 bfd adjust-cost command to enable this feature on the interface.
·     For an IS-IS interface, the isis bfd adjust-cost or isis ipv6 bfd adjust-cost command takes precedence over the bfd all-interfaces adjust-cost command. The interface uses the configuration of the bfd all-interfaces adjust-cost command only when you do not execute the isis bfd adjust-cost or isis ipv6 bfd adjust-cost command on that interface.
Enabling BFD session state-based interface cost adjustment for an IS-IS process
4.     Enable BFD session state-based interface cost adjustment for the IS-IS process and set the interface cost adjustment value.
bfd all-interfaces adjust-cost { cost-offset | max }
By default, BFD session state-based interface cost adjustment is disabled for an IS-IS process.
5.     (Optional.) Suppress BFD session state-based interface cost adjustment on an IS-IS interface.
d.     Suppress BFD session state-based interface cost adjustment on the IS-IS interface.
IPv4:
By default, IPv4 IS-IS can adjust the cost value for an interface according to the BFD session state.
IPv6:
By default, IPv6 IS-IS can adjust the cost value for an interface according to the BFD session state.
Enabling BFD session state-based interface cost adjustment on an IS-IS interface
3.     Enable BFD session state-based interface cost adjustment on the IS-IS interface and set the interface cost adjustment value.
¡     IPv4:
isis bfd adjust-cost { cost-offset | max }
By default, the IPv4 IS-IS interface inherits the configuration of the bfd all-interfaces adjust-cost command in IS-IS IPv4 unicast address family view.
¡     IPv6:
isis ipv6 bfd adjust-cost { cost-offset | max }
By default, the IPv6 IS-IS interface inherits the configuration of the bfd all-interfaces adjust-cost command in IS-IS IPv6 unicast address family view.
Controlling adjacency establishment and maintenance based on BFD session state
When BFD detects a Layer 3 forwarding failure between two routers, the BFD session goes down, which causes the IS-IS adjacency to go down. If Layer 2 forwarding is still available, the routers can exchange IS-IS packets and re-establish the adjacency, which might cause traffic loss.
To avoid the issue, enable this feature on the BFD-enabled interfaces of the local and remote routers, enabling the interfaces to carry BFD-enabled TLVs in hello packets. After the BFD session goes down, the routers do not establish an adjacency if the exchanged BFD-enabled TLVs are identical.
If two IS-IS routers establish both IPv4 and IPv6 adjacency relationships, the following rules apply:
·     If route calculation is not performed separately for the IPv4 and IPv6 topologies, the IPv4 or IPv6 adjacency relationship is up only when both the IPv4 and IPv6 BFD sessions are up.
·     If route calculation is performed separately for the IPv4 and IPv6 topologies, the IPv4 or IPv6 adjacency relationship is up when the corresponding IPv4 or IPv6 BFD session is up.
If two IS-IS routers establish only an IPv4 or IPv6 adjacency relationship, the adjacency relationship is up when the corresponding IPv4 or IPv6 BFD session is up.
For more information about BFD, see BFD configuration in High Availability Configuration Guide.
You can use one of the following commands to enable BFD session state-based control of IS-IS adjacency establishment and maintenance:
·     bfd all-interfaces session-restrict-adj
·     isis bfd session-restrict-adj
·     isis ipv6 bfd session-restrict-adj
·     The bfd all-interfaces session-restrict-adj command takes effect on all interfaces in an IPv4 or IPv6 IS-IS process. To disable this feature on an interface in that IS-IS process, use the isis bfd session-restrict-adj exclude or isis ipv6 bfd session-restrict-adj exclude command on the interface.
·     The isis bfd session-restrict-adj and isis ipv6 bfd session-restrict-adj commands take effect only on one IS-IS interface. To enable BFD session state-based control of IS-IS adjacency establishment and maintenance on a single IS-IS interface, perform the following tasks:
a.     Make sure the IS-IS process to which the IS-IS interface belongs is not enabled with BFD session state-based control of adjacency establishment and maintenance.
You can use the undo bfd all-interfaces session-restrict-adj command to disable this feature for an IS-IS process.
b.     Use the isis bfd session-restrict-adj or isis ipv6 bfd session-restrict-adj command to enable this feature on the IS-IS interface.
Enabling BFD session state-based control of IS-IS adjacency establishment and maintenance for an IS-IS process
4.     Enable BFD session state-based control of IS-IS adjacency establishment and maintenance for the IS-IS process.
By default, BFD session state-based control of IS-IS adjacency establishment and maintenance is disabled for an IS-IS process.
5.     (Optional.) Suppress BFD session state-based control of IS-IS adjacency establishment and maintenance on an IS-IS interface.
a.     Return to IS-IS view.
d.     Suppress BFD session state-based control of IS-IS adjacency establishment and maintenance on the IS-IS interface.
IPv4:
By default, BFD session state-based control of IS-IS adjacency establishment and maintenance is not suppressed on an IPv4 IS-IS interface.
IPv6:
By default, BFD session state-based control of IS-IS adjacency establishment and maintenance is not suppressed on an IPv6 IS-IS interface.
Enabling BFD session state-based control of IS-IS adjacency establishment and maintenance on an IS-IS interface
3.     (Optional.) Enable IS-IS BFD on the interface.
¡     IPv4:
isis bfd enable
¡     IPv6:
4.     Enable BFD session state-based control of IS-IS adjacency establishment and maintenance on the IS-IS interface.
¡     IPv4:
By default, the IPv4 IS-IS interface inherits the configuration of the bfd all-interfaces session-restrict-adj command in IS-IS IPv4 unicast address family view.
¡     IPv6:
By default, the IPv6 IS-IS interface inherits the configuration of the bfd all-interfaces session-restrict-adj command in IS-IS IPv6 unicast address family view.
Configuring IS-IS FRR
About IS-IS FRR
IS-IS Fast Reroute (FRR) calculates a backup path based on the LSDB and saves the backup path information to the FIB. When the primary path fails, the system immediately switches traffic to the backup path to prevent traffic loss and reduce the route convergence time.
IS-IS supports Loop Free Alternate (LFA) FRR and remote LFA FRR.
The following IS-IS FRR traffic protection types are available:
·     Link protection—Protects traffic that traverses a specific link.
·     Node protection—Protects traffic that traverses a specific node.
Node protection takes precedence over link protection.
IS-IS FRR tasks at a glance
1.     Configuring IS-IS LFA FRR
¡     Configuring IPv4 IS-IS LFA FRR to calculate a backup next hop through LFA calculation
¡     Configuring IPv4 IS-IS LFA FRR using a routing policy
¡     Configuring IPv6 IS-IS LFA FRR to calculate a backup next hop through LFA calculation
¡     Configuring IPv6 IS-IS LFA FRR using a routing policy
¡     Enabling BFD-powered primary link failure detection for an IS-IS process
¡     Enabling BFD-powered primary link failure detection on an IS-IS interface
2.     Configuring IS-IS remote LFA FRR
3.     (Optional.) Setting the priority for FRR backup path selection policies
A link or router failure on a path can cause packet loss. IS-IS LFA FRR enables fast rerouting to minimize the failover time.
Figure 26 Network diagram for IS-IS LFA FRR
In Figure 26, after you enable LFA FRR on Router B, IS-IS automatically calculates or designates a backup next hop when a link failure is detected. In this way, packets are directed to the backup next hop to reduce traffic recovery time. Meanwhile, IS-IS calculates the shortest path based on the new network topology, and forwards packets over the path after network convergence.
When a primary link failure occurs, BFD can detect and report the link failure to IS-IS for a primary-backup path switchover. This can shorten the duration of service interruption.
You can assign a backup next hop for IS-IS FRR through the following ways:
·     Enable IS-IS LFA FRR to calculate a backup next hop through LFA calculation.
·     Designate a backup next hop with a routing policy for routes matching specific criteria.
The LFA calculation of FRR and that of TE are mutually exclusive.
To enable BFD-powered primary link failure detection for IS-IS FRR, you can use the fast-reroute primary-path-detect bfd , isis primary-path-detect bfd, or isis ipv6 primary-path-detect bfd command.
·     The fast-reroute primary-path-detect bfd command takes effect on all interfaces in an IPv4 or IPv6 IS-IS process. To disable this feature on an interface in that IS-IS process, use the isis primary-path-detect bfd exclude or isis ipv6 primary-path-detect bfd exclude command on the interface.
·     The isis primary-path-detect bfd and isis ipv6 primary-path-detect bfd commands take effect only on one IS-IS interface. To enable BFD-powered primary link failure detection on a single IS-IS interface, perform the following tasks:
a.     Make sure the IS-IS process to which the IS-IS interface belongs is not enabled with BFD-powered primary link failure detection.
You can use the undo fast-reroute primary-path-detect bfd command to disable this feature for an IS-IS process.
b.     Use the isis primary-path-detect bfd or isis ipv6 primary-path-detect bfd command to enable this feature on the IS-IS interface.
3.     (Optional.) Disable LFA calculation on the interface.
isis fast-reroute lfa-backup exclude [ level-1 | level-2 ]
By default, the interface participates in LFA calculation, and can be elected as a backup interface.
5.     Enter IS-IS IPv4 unicast address family view.
6.     Enable IS-IS LFA FRR to calculate a backup next hop through LFA calculation.
fast-reroute lfa [ level-1 | level-2 ]
By default, IS-IS FRR is disabled.
6.     Enable IPv4 IS-IS LFA FRR using a routing policy.
¡     Create a routing policy and specify a backup next hop.
apply fast-reroute backup-interface
For more information about the apply fast-reroute backup-interface command and routing policy, see Layer 3—IP Routing Configuration Guide.
¡     Configure IPv4 IS-IS LFA FRR.
By default, IPv4 IS-IS LFA FRR is disabled.
isis ipv6 fast-reroute lfa-backup exclude
6.     Enter IS-IS IPv6 address family view.
7.     Enable IPv6 IS-IS LFA FRR to calculate a backup next hop through LFA calculation.
fast-reroute lfa [ ecmp-shared | level-1 | level-2 ]
By default, IPv6 IS-IS LFA FRR is disabled.
isis ipv6 fast-reroute lfa-backup exclude [ level-1 | level-2 ]
7.     Enable IPv6 IS-IS LFA FRR using a routing policy.
apply ipv6 fast-reroute backup-interface
For more information about the apply ipv6 fast-reroute backup-interface command and routing policy, see Layer 3—IP Routing Configuration Guide.
¡     Configure IPv6 IS-IS LFA FRR.
4.     Enable BFD-powered primary link failure detection for the IS-IS process.
fast-reroute primary-path-detect bfd { ctrl | echo }
By default, BFD-powered primary link failure detection is disabled for an IS-IS process.
To use BFD (echo packet mode) to detect primary link failures, configure the source IP address of BFD echo packets by using the bfd echo-source-ip or bfd echo-source-ipv6 command.
5.     (Optional.) Suppress BFD-powered primary link failure detection on an IS-IS interface.
d.     Suppress BFD-powered primary link failure detection on the IS-IS interface.
IPv4:
By default, BFD-powered primary link failure detection is not suppressed on an IPv4 IS-IS interface.
IPv6:
By default, BFD-powered primary link failure detection is not suppressed on an IPv6 IS-IS interface.
3.     Enable BFD-powered primary link failure detection on the IS-IS interface.
¡     IPv4:
isis primary-path-detect bfd { ctrl | echo }
By default, the IPv4 IS-IS interface inherits the configuration of the fast-reroute primary-path-detect bfd command in IS-IS IPv4 unicast address family view.
¡     IPv6:
isis ipv6 primary-path-detect bfd { ctrl | echo }
By default, the IPv6 IS-IS interface inherits the configuration of the fast-reroute primary-path-detect bfd command in IS-IS IPv6 unicast address family view.
In a ring topology where IS-IS LFA FRR cannot calculate the backup path, configure remote LFA FRR to ensure network reliability.
Remote LFA uses the following concepts:
·     P space—Use the source node of the protected link as the root to establish a shortest path tree. All nodes that are reachable from the source node without passing the protected link form the P space. Nodes in the P space are called P nodes.
·     Extended P space—Use the source node of the protected link and its neighbors as the roots to establish shortest path trees. All nodes that are reachable from the source node or one of its neighbors without passing the protected link form the extended P space. The P space is a subset of the extended P space.
·     Q space—Use the destination node of the protected link as the root to establish a reverse shortest path tree. All nodes that are reachable from the root node without passing the protected link form the Q space. Nodes in the Q space are called Q nodes.
·     PQ node—A PQ node refers to a node that resides in both the extended P space and the Q space. Remote LFA uses a PQ node as the destination node of a protected link.
As shown in Figure 27, the traffic forwarding path is PE 1—P 1—P 2—PE 2. To avoid traffic loss caused by link failures between P 1 and P 2, the system establishes an LDP tunnel between P 1 and P 4, which is the PQ node. When the link between P 1 and P 2 fails, P 1 encapsulates IP packets in MPLS packets and sends the MPLS packets to P 4 through the LDP tunnel. After receiving the MPLS packets, P 4 removes the MPLS labels of the packets and then forwards the packets to the next hop based on the IP routing table.
The system determines P 4 as the PQ node as follows:
1.     Uses P 1 (source node of the protected link) and its neighbors except P 2 (which passes the protected link) as the roots to establish shortest path trees.
2.     Finds out all nodes that are reachable from P 1 or one of its neighbors without passing the protected link, which are PE 1, P 1, P 3, and P 4.
These nodes form the extended P space.
3.     Uses P 2 (destination node of the protected link) as the root to establish a reverse shortest path tree.
4.     Finds out all nodes that are reachable from P 2 without passing the protected link, which are PE 2 and P 4.
These nodes form the Q space.
5.     Finds out all nodes that reside in both the extended P space and the Q space.
Only P 4 resides in both the extended P space and the Q space, so P 4 is the PQ node of the protected link.
Figure 27 Network diagram for IS-IS remote LFA FRR
To implement remote LFA FRR at a specific IS-IS level, you must enable LFA FRR for that IS-IS level.
Enable MPLS and MPLS LDP on all nodes and interfaces participating in MPLS forwarding. For more information, see basic MPLS configuration and LDP configuration in MPLS Configuration Guide.
2.     Enter IS-IS view.
3.     Enter IS-IS IPv4 unicast address family view.
4.     Enable IS-IS remote LFA FRR.
fast-reroute remote-lfa tunnel ldp [ level-1 | level-2 ]
By default, IS-IS remote LFA FRR is disabled.
5.     (Optional.) Set the maximum cost from the source node of a protected link to a PQ node.
fast-reroute remote-lfa maximum-cost cost [ level-1 | level-2 ]
By default, the maximum cost from the source node of a protected link to a PQ node is 16777215.
6.     (Optional.) Specify a prefix list to filter PQ nodes.
fast-reroute remote-lfa prefix-list prefix-list-name [ level-1 | level-2 ]
By default, no prefix list is specified to filter PQ nodes. Any PQ node can be selected as the backup next hop.
Multiple PQ nodes might reach the source node of a specific protected link. You can use this command to specify a prefix list to filter PQ nodes.
7.     (Optional.) Disable remote LFA calculation on an interface.
a.     Return to system view.
b.     Enter interface view.
c.     Disable remote LFA calculation on the interface.
isis fast-reroute remote-lfa disable [ level-1 | level-2 ]
By default, remote LFA calculation is enabled on the interface.
IS-IS FRR uses specific policies for backup path calculation. The fast-reroute tiebreaker command defines the priority for the backup path selection policy. The higher the value, the higher the priority of the associated backup path selection policy. Changing the backup path selection policy priority can affect the backup path calculation result for IS-IS FRR. The backup paths can provide node protection or link protection for traffic, or provide both node protection and link protection.
IS-IS FRR supports the following backup path selection policies that are used to generate different topologies for backup path calculation:
·     Node protection—IS-IS FRR performs backup path calculation after excluding the primary next hop node.
·     Lowest cost—IS-IS FRR performs backup path calculation after excluding the direct primary link.
·     SRLG disjoint—When one link in the SRLG fails, the other links in the SRLG might also fail. If you use a link in this SRLG as the backup link for the failed link, protection does not take effect. To avoid this issue, IS-IS FRR excludes the local links in the same SRLG as the direct primary link and then performs backup path calculation.
For IS-IS FRR, the SRLG disjoint policy depends on the node protection and lowest cost policies.
If multiple backup path selection policies exist in an IS-IS process, the policy with the highest priority is used to calculate the backup path. If the policy fails to calculate the backup path, another policy with higher priority is used. IS-IS performs backup path calculation by using the node protection and lowest cost policies as follows:
·     If the node protection policy has higher priority and fails to calculate the backup path, IS-IS uses the lowest cost policy to calculate the backup path. If the lowest cost policy still fails to calculate the backup path, reliability cannot be ensured upon primary link failure.
·     If the lowest cost policy has higher priority and fails to calculate the backup path, IS-IS does not perform further backup path calculation with the node protection policy. Reliability cannot be ensured upon primary link failure.
Table 4 shows the backup path selection mechanism for IS-IS FRR based on priorities of backup path selection policies.
Table 4 Backup path selection mechanism for IS-IS FRR
Priorities of link selection policies
Node protection > lowest cost > SRLG-disjoint
IS-IS FRR performs calculations based on the node protection and lowest cost policies in descending order of priority.
IS-IS FRR performs a maximum of two calculations. If IS-IS FRR obtains a backup path with a link selection policy, it does not perform further calculation.
Node protection > SRLG-disjoint > lowest cost
IS-IS FRR performs calculations based on the node protection, node protection + SRLG-disjoint, lowest cost + SRLG-disjoint, and lowest cost policies in descending order of priority.
IS-IS FRR performs a maximum of four calculations. If IS-IS FRR obtains a backup path with a link selection policy, it does not perform further calculation.
SRLG-disjoint > node protection > lowest cost
IS-IS FRR performs calculations based on the node protection + SRLG-disjoint, lowest cost + SRLG-disjoint, node protection, and lowest cost policies in descending order of priority.
Lowest cost > node protection > SRLG-disjoint
IS-IS FRR performs calculations based on the lowest cost policy.
IS-IS FRR performs only one calculation.
Lowest cost > SRLG-disjoint > node protection
SRLG-disjoint > lowest cost > node protection
IS-IS FRR performs calculations based on the node protection + SRLG-disjoint, lowest cost + SRLG-disjoint, and lowest cost policies in descending order of priority.
IS-IS FRR performs a maximum of three calculations. If IS-IS FRR obtains a backup path with a link selection policy, it does not perform further calculation.
3.     Enter IS-IS IPv4 address family view or IS-IS IPv6 address family view.
¡     Enter IS-IS IPv4 address family view.
¡     Enter IS-IS IPv6 address family view.
4.     Set the priority value for a backup path selection policy.
fast-reroute tiebreaker { lowest-cost | node-protecting | srlg-disjoint } preference preference [ level-1 | level-2 ]
By default, the priority values of the node-protection, lowest-cost, and shared risk link group (SRLG)-disjoint backup path selection policies are 40, 20, and 10, respectively.
Enabling IS-IS to adjust the interface cost according to the link quality
Error codes, which refer to bit differences between the received and source signals, cannot be avoided because of inevitable link aging and optical path jitter problems. A high error code ratio might cause service degradation or interruption.
To reduce the impact of error codes on an IS-IS network, you can enable IS-IS to adjust the interface cost according to the link quality.
After you configure this feature on an interface, IS-IS adjusts the interface cost as follows:
·     When the link quality of the interface becomes LOW, IS-IS increases the cost value for the interface.
·     When the link quality of the interface restores to GOOD, IS-IS restores the cost value for the interface to the original value.
For more information about error code detection, see error code detection configuration in High Availability Configuration Guide.
2.     Enter interface view.
3.     Enable IS-IS to adjust the link cost according to the link quality.
isis link-quality adjust-cost { cost-offset | max }
By default, IS-IS does not adjust the link cost according to the link quality.
Configuring IS-IS neighbor flapping suppression
When the state of an IS-IS neighbor flaps frequently, IS-IS performs neighbor relationship re-establishment, LSDB synchronization, and route calculation. Such tasks interrupt IS-IS services and other services that depend on IS-IS, because performing these tasks requires a large number of packet exchanges. To resolve this issue, configure IS-IS neighbor flapping suppression. This feature enables IS-IS to suppress neighbor flapping on an interface by increasing the cost value for the interface. Traffic then does not pass through the interface during neighbor flapping suppression. When the resume timer for neighbor flapping suppression expires, IS-IS restores the cost value to the original for the interface.
IS-IS supports the conservative and non-conservative modes for neighbor flapping suppression.
The conservative mode functions as follows:
1.     After you enable neighbor flapping suppression on an interface, the interface starts a flapping event counter to collect statistics about neighbor flapping events. When the time gap between two neighbor down events in a row is shorter than the detection timer, IS-IS increases the number of neighbor flapping events by one.
IS-IS resets and restarts the flapping event counter when the following conditions exist:
¡     The number of neighbor flapping events is lower than the threshold that triggers neighbor flapping suppression.
¡     The time gap between two neighbor down events in a row is longer than the resume timer.
2.     IS-IS compares the number of neighbor flapping events with the threshold that triggers neighbor flapping suppression:
¡     If the number of neighbor flapping events is lower than the threshold, IS-IS does not suppress neighbor flapping.
¡     If the number of neighbor flapping events is not lower than the threshold, IS-IS starts neighbor flapping suppression. It increases the cost value for the interface and resets the flapping event counter.
3.     The resume timer starts as IS-IS starts neighbor flapping suppression. The suppression duration equals the resume timer.
If a neighbor down event occurs on the interface during neighbor flapping suppression, the resume timer is reset and restarts.
4.     After the resume timer expires, IS-IS restores the cost value to the original for the interface if no neighbor flapping events occur on the interface before the resume timer expires.
The non-conservative mode functions as follows:
1.     After you enable neighbor flapping suppression on an interface, the interface starts a flapping event counter to collect statistics about neighbor flapping events. IS-IS increases the number of neighbor flapping events by one each time a neighbor down event occurs on the interface.
When a neighbor down event occurs on the interface, IS-IS performs the following tasks:
a.     Record the timestamp of the neighbor down event.
For brief description, the following arguments are introduced:
·     The T argument represents the timestamp that equals the neighbor down event timestamp minus the detection timer.
·     The flapping-count argument represents the number of neighbor flapping events that occur later than T and not later than the neighbor down event timestamp.
b.     Compare flapping-count with the threshold that triggers neighbor flapping suppression:
-     If flapping-count is lower than the threshold, IS-IS does not suppress neighbor flapping or reset the flapping event counter.
-     If flapping-count is not lower than the threshold, IS-IS starts neighbor flapping suppression. It increases the cost value for the interface and resets the flapping event counter.
2.     The resume timer starts as IS-IS starts neighbor flapping suppression. The suppression duration equals the resume timer.
3.     After the resume timer expires, IS-IS restores the cost value to the original for the interface if no neighbor flapping events occur on the interface before the resume timer expires.
3.     Configure the detection parameters for IS-IS neighbor flapping suppression.
¡     IPv4 IS-IS:
isis peer suppress-flapping { [ detect-interval detect-interval | threshold threshold | resume-interval resume-interval ] * | non-conservative }
By default, the detection timer is 60 seconds, the threshold is 10, and the resume timer is 120 seconds.
¡     IPv6 IS-IS:
isis ipv6 peer suppress-flapping { [ detect-interval detect-interval | threshold threshold | resume-interval resume-interval ] * | non-conservative }
4.     Enable neighbor flapping suppression on the interface and specify the cost adjustment value for the interface.
¡     IPv4 IS-IS:
isis peer suppress-flapping adjust-cost { cost-offset | max }
By default, neighbor flapping suppression is disabled on an IPv4 IS-IS interface.
¡     IPv6 IS-IS:
isis ipv6 peer suppress-flapping adjust-cost { cost-offset | max }
By default, neighbor flapping suppression is disabled on an IPv6 IS-IS interface.
Configuring IS-IS member port flapping suppression
When two IS-IS neighbors are connected by Layer 3 aggregate links and the links between member ports flap frequently, the neighbors perform link switchover frequently for traffic forwarding. To resolve this issue, enable member port flapping suppression on the aggregate interfaces.
This feature enables IS-IS to suppress member port flapping on an aggregate interface by increasing the cost value for the aggregate interface. Traffic then does not pass through the aggregate interface during member port flapping suppression. When the resume timer for member port flapping suppression expires, IS-IS restores the cost value to the original for the aggregate interface.
IS-IS supports the conservative and non-conservative modes for member port flapping suppression.
1.     After you enable member port flapping suppression on an aggregate interface, the aggregate interface starts a flapping event counter to collect statistics about the flapping events that occur on its member ports. When the time gap between two link failures in a row is shorter than the detection timer, IS-IS increases the number of member port flapping events by one.
¡     The number of member port flapping events is lower than the threshold that triggers member port flapping suppression.
¡     The time gap between two link failures in a row is longer than the resume timer.
2.     IS-IS compares the number of member port flapping events with the threshold that triggers member port flapping suppression:
¡     If the number of member port flapping events is lower than the threshold, IS-IS does not suppress member port flapping.
¡     If the number of member port flapping events is not lower than the threshold, IS-IS starts member port flapping suppression. It increases the cost value for the aggregate interface and resets the flapping event counter.
3.     The resume timer starts as IS-IS starts member port flapping suppression. The suppression duration equals the resume timer.
If a link failure occurs on a member port during member port flapping suppression, the resume timer is reset and restarts.
4.     After the resume timer expires, IS-IS restores the cost value to the original for the aggregate interface if no link failures occur on member ports before the resume timer expires.
1.     After you enable member port flapping suppression on an aggregate interface, the aggregate interface starts a flapping event counter to collect statistics about the flapping events that occur on its member ports. IS-IS increases the number of member port flapping events by one each time a link failure occurs on a member port.
When a link failure occurs on a member port, IS-IS performs the following tasks:
a.     Record the timestamp of the link failure.
·     The T argument represents the timestamp that equals the link failure timestamp minus the detection timer.
·     The flapping-count argument represents the number of member port flapping events that occur later than T and not later than the link failure timestamp.
-     If flapping-count is lower than the threshold, IS-IS does not suppress member port flapping or reset the flapping event counter.
-     If flapping-count is not lower than the threshold, IS-IS starts member port flapping suppression. It increases the cost value for the aggregate interface and resets the flapping event counter.
2.     The resume timer starts as IS-IS starts member port flapping suppression. The suppression duration equals the resume timer.
3.     After the resume timer expires, IS-IS restores the cost value to the original for the aggregate interface if no link failures occur on member ports before the resume timer expires.
¡     Enter Layer 3 aggregate interface view.
interface route-aggregation interface-number [ pex ]
¡     Enter Layer 3 aggregate subinterface view.
interface route-aggregation interface-number.subnumber
3.     Configure the detection parameters for IS-IS member port flapping suppression.
¡     IPv4 IS-IS:
isis member-port suppress-flapping { [ detect-interval detect-interval | threshold threshold | resume-interval resume-interval ] * | non-conservative }
¡     IPv6 IS-IS:
isis ipv6 member-port suppress-flapping { [ detect-interval detect-interval | threshold threshold | resume-interval resume-interval ] * | non-conservative }
4.     Enable member port flapping suppression on the interface and specify the cost adjustment value for the interface.
¡     IPv4 IS-IS:
isis member-port suppress-flapping adjust-cost { cost-offset | max }
By default, member port flapping suppression is disabled on an IPv4 IS-IS aggregate interface.
¡     IPv6 IS-IS:
isis ipv6 member-port suppress-flapping adjust-cost { cost-offset | max }
By default, member port flapping suppression is disabled on an IPv6 IS-IS aggregate interface.
Display and maintenance commands for IS-IS
Displaying and maintaining IPv4 IS-IS
Display IS-IS process information.
display isis [ process-id ]
Display IS-IS GR log information.
In standalone mode:
display isis event-log graceful-restart  slot slot-number [ cpu cpu-number ]
In IRF mode:
display isis event-log graceful-restart chassis chassis-number slot slot-number [ cpu cpu-number ]
Display IS-IS log information about received or sent hello packets.
display isis event-log hello { peer-change | received-abnormal | received-dropped | sent-abnormal | sent-failed } [ process-id ]
Display neighbor state change log information.
display isis event-log peer [ process-id ]
Display information about hello packets sent by an interface.
display isis interface [ interface-type interface-number ] hello-sent [ process-id ]
Display the IS-IS GR status.
display isis graceful-restart status [ level-1 | level-2 ] [ process-id ]
Display IS-IS interface information.
display isis interface [ [ interface-type interface-number ] [ verbose ] | statistics ] [ process-id ]
Display IS-IS LSDB information.
display isis lsdb [ [ level-1 | level-2 ] | local | lsp-id lspid | [ lsp-name lspname ] | verbose ] * [ process-id ]
Display IS-IS LSDB statistics.
display isis lsdb statistics [ level-1 | level-2 ] [ process-id ]
Display IS-IS mesh group information.
display isis mesh-group [ process-id ]
Display the host name to system ID mapping table.
display isis name-table [ process-id ]
Display IS-IS NSR log information.
In standalone mode:
display isis event-log slot non-stop-routing slot-number [ cpu cpu-number ]
In IRF mode:
display isis event-log non-stop-routing chassis chassis-number slot slot-number [ cpu cpu-number ]
Display the IS-IS NSR status.
display isis non-stop-routing status
Display IS-IS packet statistics.
display isis packet { csnp | hello | lsp | psnp } by-interface [ verbose ] [ interface-type interface-number ] [ process-id ]
display isis packet { csnp | hello | lsp | psnp } [ verbose ] [ process-id ]
Display IS-IS neighbor information.
display isis peer [ statistics | verbose ] [ process-id ]
Display information about hello packets received from neighbors.
display isis peer hello-received [ process-id ]
Display IS-IS redistributed IPv4 route information.
display isis redistribute [ ipv4 [ ip-address mask-length ] ] [ level-1 | level-2 ] [ process-id ]
Display IS-IS IPv4 routing information.
display isis route [ ipv4 [ ip-address mask-length | priority { critical | high | low | medium } ] ] [ [ level-1 | level-2 ] | [ source-id source-id | verbose ] ] * [ process-id ]
Display IS-IS IPv4 topology information.
display isis spf-tree [ ipv4 [ topology topo-name ] ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IS-IS statistics.
display isis statistics [ ipv4 ] [ level-1 | level-1-2 | level-2 ] [ process-id ]
Display IS-IS neighbor relationship troubleshooting information.
display isis troubleshooting
Display IS-IS IPv4 route calculation log information.
display isis event-log spf [ ipv4 ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IS-IS LSP update log information.
display isis event-log updated-lsp [ history [ hour-range hour-range1 to hour-range2 ] ] [ system-id system-id ] [ level-1 | level-2 ] [ process-id ]
Display IS-IS LSP log information.
display isis event-log lsp { purged [ generated | received ] | refreshed } [ level-1 | level-2 ] [ process-id ]
Display information about routes calculated by a flexible algorithm.
display isis flex-algo flex-algo-id route [ level-1 | level-2 ] [ process-id ] [ verbose ]
Display SPF tree information calculated by a flexible algorithm.
display isis flex-algo flex-algo-id spf-tree ipv4 [ level-1 | level-2 ] [ source-id source-id ] [ verbose ]
Display information about the FADs received and advertised by a node.
display isis global-flex-algo [ algorithm-id flex-algo-id ] [ level-1 | level-2 ] [ process-id ] [ system-id system-id ]
Display the configuration for a flexible algorithm on a node.
display isis local-flex-algo [ algorithm-id flex-algo-id ] [ process-id ]
Display OSI connection information.
In standalone mode:
display osi [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display osi [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display OSI connection statistics.
In standalone mode:
display osi statistics [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display osi statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display global IS-IS statistics.
display isis global-statistics [ public | vpn-instance vpn-instance-name ]
Clear IS-IS process data structure information.
reset isis all [ process-id ] [ graceful-restart ]
Clear IS-IS log information.
reset isis event-log { hello { peer-change | received-abnormal | received-dropped | sent-abnormal | sent-failed } | peer } [ process-id ]
Clear IS-IS GR log information.
In standalone mode:
reset isis event-log graceful-restart slot slot-number [ cpu cpu-number ]
In IRF mode:
reset isis event-log graceful-restart chassis chassis-number slot slot-number [ cpu cpu-number ]
Clear IS-IS NSR log information.
In standalone mode:
reset isis event-log non-stop-routing slot slot-number [ cpu cpu-number ]
In IRF mode:
reset isis event-log non-stop-routing chassis chassis-number slot slot-number [ cpu cpu-number ]
Clear IS-IS route calculation log information.
reset isis event-log spf [ process-id ]
Clear IS-IS LSP update log information.
reset isis event-log updated-lsp
Clear IS-IS LSP log information.
reset isis event-log lsp { purged [ generated | received ] | refreshed } [ process-id ]
Clear IS-IS packet statistics.
reset isis packet [ csnp | hello | lsp | psnp ] by-interface [ interface-type interface-number ] [ process-id ]
Clear the data structure information of an IS-IS neighbor.
reset isis peer system-id [ process-id ]
Clear OSI connection statistics.
reset osi statistics
Clear IS-IS neighbor relationship troubleshooting information.
reset isis troubleshooting
Displaying and maintaining IPv6 IS-IS
display isis flex-algo flex-algo-id spf-tree ipv6 [ level-1 | level-2 ] [ source-id source-id ] [ verbose ]
display isis packet { csnp | hello | lsp | psnp } [ verbose ] [ interface-type interface-number ] [ process-id ]
Display IPv6 IS-IS redistributed route information.
display isis redistribute ipv6 [ ipv6-address mask-length ] [ level-1 | level-2 ] [ process-id ]
Display IPv6 IS-IS routing information.
display isis route ipv6 [ ipv6-address | priority { critical | high | low | medium } ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IS-IS BIER route information.
display isis route bier sub-domain sub-domain-id ipv6 [ ipv6-address prefix-length ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IPv6 IS-IS topology information.
display isis spf-tree ipv6 [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IS-IS BIER SPF tree information.
display isis spf-tree bier sub-domain sub-domain-id ipv6 [ [ level-1 | level-2 ] | [ source-id source-id | verbose ] ] * [ process-id ]
Display IPv6 IS-IS statistics.
display isis statistics ipv6 [ level-1 | level-1-2 | level-2 ] [ process-id ]
Display trust level mapping information.
display isis trust-level-mapping
Display IPv6 IS-IS route calculation log information.
display isis event-log spf ipv6 [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IPv6 IS-IS LSP update log information.
Display IPv6 IS-IS LSP log information.
In standalone mode:
In IRF mode:
In standalone mode:
In IRF mode:
IS-IS configuration examples
Example: Configuring basic IS-IS
As shown in Figure 28, Router A, Router B, Router C, and Router D reside in an AS.
Router A and Router B are Level-1 routers, Router D is a Level-2 router, and Router C is a Level-1-2 router connecting two areas. Router A, Router B, and Router C are in area 10, and Router D is in area 20.
Figure 28 Network diagram
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Configure IS-IS:
# Configure Router A
[RouterA] isis 1
[RouterA-isis-1] is-level level-1
[RouterA-isis-1] network-entity 10.0000.0000.0001.00
[RouterA-isis-1] quit
[RouterA] interface ten-gigabitethernet 3/1/1
[RouterA-Ten-GigabitEthernet3/1/1] isis enable 1
[RouterA-Ten-GigabitEthernet3/1/1] quit
# Configure Router B.
<RouterB> system-view
[RouterB] isis 1
[RouterB-isis-1] is-level level-1
[RouterB-isis-1] network-entity 10.0000.0000.0002.00
[RouterB-isis-1] quit
[RouterB] interface ten-gigabitethernet 3/1/1
[RouterB-Ten-GigabitEthernet3/1/1] isis enable 1
[RouterB-Ten-GigabitEthernet3/1/1] quit
# Configure Router C.
<RouterC> system-view
[RouterC] isis 1
[RouterC-isis-1] network-entity 10.0000.0000.0003.00
[RouterC-isis-1] quit
[RouterC] interface ten-gigabitethernet 3/1/3
[RouterC-Ten-GigabitEthernet3/1/3] isis enable 1
[RouterC-Ten-GigabitEthernet3/1/3] quit
[RouterC] interface ten-gigabitethernet 3/1/1
[RouterC-Ten-GigabitEthernet3/1/1] isis enable 1
[RouterC-Ten-GigabitEthernet3/1/1] quit
[RouterC] interface ten-gigabitethernet 3/1/2
[RouterC-Ten-GigabitEthernet3/1/2] isis enable 1
[RouterC-Ten-GigabitEthernet3/1/2] quit
# Configure Router D
<RouterD> system-view
[RouterD] isis 1
[RouterD-isis-1] is-level level-2
[RouterD-isis-1] network-entity 20.0000.0000.0004.00
[RouterD-isis-1] quit
[RouterD] interface ten-gigabitethernet 3/1/1
[RouterD-Ten-GigabitEthernet3/1/1] isis enable 1
[RouterD-Ten-GigabitEthernet3/1/1] quit
[RouterD] interface ten-gigabitethernet 3/1/2
[RouterD-Ten-GigabitEthernet3/1/2] isis enable 1
[RouterD-Ten-GigabitEthernet3/1/2] quit
# Display the IS-IS LSDB information.
[RouterA] display isis lsdb
                        Database information for ISIS(1)
                          Level-1 Link State Database
LSPID                 Seq Num      Checksum      Holdtime      Length  ATT/P/OL
0000.0000.0001.00-00* 0x00000004   0xdf5e        1096          68      0/0/0
0000.0000.0002.00-00  0x00000004   0xee4d        1102          68      0/0/0
0000.0000.0002.01-00  0x00000001   0xdaaf        1102          55      0/0/0
0000.0000.0003.00-00  0x00000009   0xcaa3        1161          111     1/0/0
0000.0000.0003.01-00  0x00000001   0xadda        1112          55      0/0/0
[RouterB] display isis lsdb
0000.0000.0001.00-00  0x00000006   0xdb60        988           68      0/0/0
0000.0000.0002.00-00* 0x00000008   0xe651        1189          68      0/0/0
0000.0000.0002.01-00* 0x00000005   0xd2b3        1188          55      0/0/0
0000.0000.0003.00-00  0x00000014   0x194a        1190          111     1/0/0
0000.0000.0003.01-00  0x00000002   0xabdb        995           55      0/0/0
[RouterC] display isis lsdb
0000.0000.0001.00-00  0x00000006   0xdb60        847           68      0/0/0
0000.0000.0002.00-00  0x00000008   0xe651        1053          68      0/0/0
0000.0000.0002.01-00  0x00000005   0xd2b3        1052          55      0/0/0
0000.0000.0003.00-00* 0x00000014   0x194a        1051          111     1/0/0
0000.0000.0003.01-00* 0x00000002   0xabdb        854           55      0/0/0
                          Level-2 Link State Database
0000.0000.0003.00-00* 0x00000012   0xc93c        842           100     0/0/0
0000.0000.0004.00-00  0x00000026   0x331         1173          84      0/0/0
0000.0000.0004.01-00  0x00000001   0xee95        668           55      0/0/0
[RouterD] display isis lsdb
0000.0000.0003.00-00  0x00000013   0xc73d        1003          100     0/0/0
0000.0000.0004.00-00* 0x0000003c   0xd647        1194          84      0/0/0
0000.0000.0004.01-00* 0x00000002   0xec96        1007          55      0/0/0
# Display the IS-IS routing information on each router.
[RouterA] display isis route
                         Level-1 IPv4 Forwarding Table
 IPv4 Destination     IntCost    ExtCost ExitInterface   NextHop         Flags
 10.1.1.0/24          10         NULL    XGE3/1/1         Direct          D/L/-
 10.1.2.0/24          20         NULL    XGE3/1/1         10.1.1.1        R/-/-
 192.168.0.0/24       20         NULL    XGE3/1/1         10.1.1.1        R/-/-
 0.0.0.0/0            10         NULL    XGE3/1/1         10.1.1.1        R/-/-
[RouterC] display isis route
 10.1.2.0/24          10         NULL    XGE3/1/3         Direct          D/L/-
 192.168.0.0/24       10         NULL    XGE3/1/2         Direct          D/L/-
                         Level-2 IPv4 Forwarding Table
 10.1.1.0/24          10         NULL                                    D/L/-
 10.1.2.0/24          10         NULL                                    D/L/-
 192.168.0.0/24       10         NULL                                    D/L/-
 172.16.0.0/16        20         NULL    XGE3/1/2         192.168.0.2     R/-/-
[RouterD] display isis route
 10.1.1.0/24          20         NULL    XGE3/1/2         192.168.0.1     R/-/-
 10.1.2.0/24          20         NULL    XGE3/1/2         192.168.0.1     R/-/-
 172.16.0.0/16        10         NULL    XGE3/1/1         Direct          D/L/-
The output shows that the routing table of Level-1 routers contains a default route with the next hop as the Level-1-2 router. The routing table of Level-2 router contains all Level-1 and Level-2 routes.
Example: Configuring DIS election
As shown in Figure 29, on a broadcast network (Ethernet), Router A, Router B, Router C, and Router D reside in IS-IS Area 10. Router A and Router B are Level-1-2 routers, Router C is a Level-1 router, and Router D is a Level-2 router.
Change the DIS priority of Router A to make it elected as the Level-1-2 DIS router.
Figure 29 Network diagram
2.     Enable IS-IS:
# Configure Router A.
[RouterA] isis 1
[RouterB] isis 1
[RouterC] isis 1
[RouterC-isis-1] is-level level-1
# Configure Router D.
[RouterD] isis 1
[RouterD-isis-1] network-entity 10.0000.0000.0004.00
# Display information about IS-IS neighbors of Router A.
[RouterA] display isis peer
                          Peer information for IS-IS(1)
 System ID: 0000.0000.0002
 Interface: XGE3/1/1                 Circuit Id:  0000.0000.0003.01
 State: Up     HoldTime: 21s        Type: L1(L1L2)     PRI: 64
 System ID: 0000.0000.0003
 State: Up     HoldTime: 6s         Type: L1           PRI: 64
 Interface: XGE3/1/1                 Circuit Id:  0000.0000.0004.01
 State: Up     HoldTime: 23s        Type: L2(L1L2)     PRI: 64
 System ID: 0000.0000.0004
 State: Up     HoldTime: 23s        Type: L2           PRI: 64
# Display information about IS-IS interfaces of Router A.
[RouterA] display isis interface
  Interface:  Ten-GigabitEthernet3/1/1
  Index     IPv4 state      IPv6 state     Circuit ID   MTU   Type   DIS
  00001     Up              Down           1            1497  L1/L2  No/No
# Display IS-IS interfaces of Router C.
[RouterC] display isis interface
  00001     Up              Down           1            1497  L1/L2  Yes/No
# Display information about IS-IS interfaces of Router D.
[RouterD] display isis interface
  00001     Up              Down           1            1497  L1/L2  No/Yes
The output shows that when the default DIS priority is used, Router C is the DIS for Level-1, and Router D is the DIS for Level-2. The pseudonodes of Level-1 and Level-2 are 0000.0000.0003.01 and 0000.0000.0004.01.
# Configure the DIS priority of Router A.
[RouterA-Ten-GigabitEthernet3/1/1] isis dis-priority 100
 Interface: XGE3/1/1                 Circuit Id:  0000.0000.0001.01
 State: Up     HoldTime: 29s        Type: L1(L1L2)     PRI: 64
 State: Up     HoldTime: 22s        Type: L1           PRI: 64
 State: Up     HoldTime: 22s        Type: L2(L1L2)     PRI: 64
 State: Up     HoldTime: 22s        Type: L2           PRI: 64
  00001     Up              Down           1            1497  L1/L2  Yes/Yes
The output shows that after the DIS priority configuration, Router A becomes the DIS for Level-1-2, and the pseudonode is 0000.0000.0001.01.
# Display information about IS-IS neighbors and interfaces of Router C.
[RouterC] display isis peer
 System ID: 0000.0000.0001
 State: Up     HoldTime: 7s         Type: L1           PRI: 100
 State: Up     HoldTime: 23s        Type: L1           PRI: 64
  00  1     Up              Down           1            1497  L1/L2  No/No
# Display information about IS-IS neighbors and interfaces of Router D.
[RouterD] display isis peer
 State: Up     HoldTime: 7s         Type: L2           PRI: 100
 State: Up     HoldTime: 26s        Type: L2           PRI: 64
Example: Configuring IS-IS route redistribution
As shown in Figure 30, Router A, Router B, Router C, and Router D reside in the same AS. They use IS-IS to interconnect. Router A and Router B are Level-1 routers, Router D is a Level-2 router, and Router C is a Level-1-2 router.
Redistribute RIP routes into IS-IS on Router D.
Figure 30 Network diagram
2.     Configure basic IS-IS:
[RouterA] isis 1
[RouterB] isis 1
[RouterC] isis 1
[RouterD] isis 1
# Display IS-IS routing information on each router.
 10.1.4.0/24          10         NULL                                    D/L/-
 10.1.4.0/24          10         NULL    XGE3/1/1         Direct          D/L/-
3.     Configure RIPv2 on Router D and Router E, and configure IS-IS to redistribute RIP routes on Router D:
# Configure RIPv2 on Router D.
[RouterD] rip 1
[RouterD-rip-1] network 10.0.0.0
[RouterD-rip-1] version 2
[RouterD-rip-1] undo summary
# Configure RIPv2 on Router E.
[RouterE] rip 1
[RouterE-rip-1] network 10.0.0.0
[RouterE-rip-1] version 2
[RouterE-rip-1] undo summary
# On Router D, configure IS-IS to redistribute routes from RIP.
[RouterD-rip-1] quit
[RouterD] isis 1
[RouterD–isis-1] address-family ipv4
[RouterD–isis-1-ipv4] import-route rip level-2
# Display IS-IS routing information on Router C.
 10.1.4.0/24          20         NULL    XGE3/1/2         192.168.0.2     R/L/-
 10.1.5.0/24          10         0       XGE3/1/2         192.168.0.2     R/L/-
 10.1.6.0/24          10         0       XGE3/1/2         192.168.0.2     R/L/-
Example: Configuring IS-IS authentication
As shown in Figure 31, Router A, Router B, Router C, and Router D reside in the same IS-IS routing domain.
Router A, Router B, and Router C belong to Area 10, and Router D belongs to Area 20.
·     Configure neighbor relationship authentication between neighbors.
·     Configure area authentication in Area 10 to prevent untrusted routes from entering into the area.
·     Configure routing domain authentication on Router C and Router D to prevent untrusted routes from entering the routing domain.
Figure 31 Network diagram
[RouterA] isis 1
[RouterB] isis 1
[RouterC] isis 1
[RouterD] isis 1
[RouterD-isis-1] network-entity 20.0000.0000.0001.00
3.     Configure neighbor relationship authentication between neighbors:
# Set the authentication mode to MD5 and set the plaintext key to eRq on Ten-GigabitEthernet 3/1/1 of Router A and on Ten-GigabitEthernet 3/1/3 of Router C.
[RouterA-Ten-GigabitEthernet3/1/1] isis authentication-mode md5 plain eRg
[RouterC-Ten-GigabitEthernet3/1/3] isis authentication-mode md5 plain eRg
# Set the authentication mode to MD5 and set the plaintext key to t5Hr on Ten-GigabitEthernet 3/1/1 of Router B and on Ten-GigabitEthernet 3/1/1 of Router C.
[RouterB-Ten-GigabitEthernet3/1/1] isis authentication-mode md5 plain t5Hr
[RouterC-Ten-GigabitEthernet3/1/1] isis authentication-mode md5 plain t5Hr
# Set the authentication mode to MD5 and set the plaintext key to hSec on Ten-GigabitEthernet 3/1/1 of Router D and on Ten-GigabitEthernet 3/1/2 of Router C.
[RouterC-Ten-GigabitEthernet3/1/2] isis authentication-mode md5 plain hSec
[RouterD-Ten-GigabitEthernet3/1/1] isis authentication-mode md5 plain hSec
4.     Set the area authentication mode to MD5 and set the plaintext key to 10Sec on Router A, Router B, and Router C.
[RouterA] isis 1
[RouterA-isis-1] area-authentication-mode md5 plain 10Sec
[RouterB] isis 1
[RouterB-isis-1] area-authentication-mode md5 plain 10Sec
[RouterC] isis 1
[RouterC-isis-1] area-authentication-mode md5 plain 10Sec
5.     Set routing domain authentication mode to MD5 and set the plaintext key to 1020Sec on Router C and Router D.
[RouterC] isis 1
[RouterC-isis-1] domain-authentication-mode md5 plain 1020Sec
[RouterD] isis 1
[RouterD-isis-1] domain-authentication-mode md5 plain 1020Sec
Example: Configuring IS-IS GR
As shown in Figure 32, Router A, Router B, and Router C belong to the same IS-IS routing domain. Run IS-IS on all the routers to interconnect them with each other.
Figure 32 Network diagram
1.     Configure the IP addresses and subnet masks for interfaces on the routers. (Details not shown.)
2.     Configure IS-IS on the routers to make sure Router A, Router B, and Router C can communicate with each other at Layer 3 and dynamic route update can be implemented among them with IS-IS. (Details not shown.)
3.     Enable IS-IS GR on Router A.
[RouterA] isis 1
[RouterA-isis-1] graceful-restart
[RouterA] quit
# Restart the IS-IS process on Router A.
<RouterA> reset isis all 1 graceful-restart
Reset IS-IS process? [Y/N]:y
# Check the GR state of the IS-IS process on Router A.
<RouterA> display isis graceful-restart status
Restart status: COMPLETE
Restart phase: Finish
SA Bit: supported
                          Level-1 restart information
Total number of interfaces: 1
Number of waiting LSPs: 0
                          Level-2 restart information
Example: Configuring BFD for IS-IS
·     As shown in Figure 33, run IS-IS on Router A, Router B and Router C so that they can reach each other at the network layer.
·     After the link over which Router A and Router B communicate through the Layer 2 switch fails, BFD can quickly detect the failure and notify IS-IS of the failure. Router A and Router B then communicate through Router C.
Figure 33 Network diagram
Table 5 Interface and IP address assignment
Device
IP address
Device
IP address
Router A
XGE3/1/1
192.168.0.102/24
Router B
XGE3/1/1
192.168.0.100/24
XGE3/1/2
10.1.1.102/24
XGE3/1/2
13.1.1.1/24
Loop0
121.1.1.1/32
Loop0
120.1.1.1/32
Router C
XGE3/1/1
10.1.1.100/24
XGE3/1/2
13.1.1.2/24
[RouterA] isis
[RouterA-LoopBack0] isis enable
[RouterA-LoopBack0] quit
[RouterA] interface ten-gigabitethernet 3/1/2
[RouterA-Ten-GigabitEthernet3/1/2] isis enable
[RouterA-Ten-GigabitEthernet3/1/2] quit
[RouterB] isis
[RouterB-LoopBack0] isis enable
[RouterB-LoopBack0] quit
[RouterB] interface ten-gigabitethernet 3/1/2
[RouterB-Ten-GigabitEthernet3/1/2] isis enable
[RouterB-Ten-GigabitEthernet3/1/2] quit
[RouterC] isis
3.     Configure BFD functions:
# Enable BFD and configure BFD parameters on Router A.
[RouterA] bfd session init-mode active
[RouterA-Ten-GigabitEthernet3/1/1] isis bfd enable
[RouterA-Ten-GigabitEthernet3/1/1] bfd min-receive-interval 500
[RouterA-Ten-GigabitEthernet3/1/1] bfd min-transmit-interval 500
[RouterA-Ten-GigabitEthernet3/1/1] bfd detect-multiplier 7
# Enable BFD and configure BFD parameters on Router B.
[RouterB] bfd session init-mode active
[RouterB-Ten-GigabitEthernet3/1/1] isis bfd enable
[RouterB-Ten-GigabitEthernet3/1/1] bfd min-receive-interval 500
[RouterB-Ten-GigabitEthernet3/1/1] bfd min-transmit-interval 500
[RouterB-Ten-GigabitEthernet3/1/1] bfd detect-multiplier 8
# Display the BFD session information on Router A.
[RouterA] display bfd session
 Total sessions: 1        Up sessions: 1        Init mode: Active
 LD/RD          SourceAddr      DestAddr        State    Holdtime    Interface
 3/1            192.168.0.102   192.168.0.100   Up       1700ms      XGE3/1/1
# Display routes destined for 120.1.1.1/32 on Router A.
[RouterA] display ip routing-table 120.1.1.1 verbose
Summary count : 1
 Destination: 120.1.1.1/32
    Protocol: IS_L1
  Process ID: 1
   SubProtID: 0x1                       Age: 04h20m37s
  FlushedAge: 15h28m49s
        Cost: 10                 Preference: 10
       IpPre: N/A                QosLocalID: N/A
         Tag: 0                       State: Active Adv
   OrigTblID: 0x0                   OrigVrf: default-vrf
     TableID: 0x2                    OrigAs: 0
       NibID: 0x26000002             LastAs: 0
      AttrID: 0xffffffff
    BkAttrID: 0xffffffff           Neighbor: 0.0.0.0
       Flags: 0x1008c           OrigNextHop: 192.168.0.100
       Label: NULL              RealNextHop: 192.168.0.100
     BkLabel: NULL                BkNextHop: N/A
     SRLabel: NULL                Interface: Ten-GigabitEthernet3/1/1
   BkSRLabel: NULL              BkInterface: N/A
   Tunnel ID: Invalid           IPInterface: Ten-GigabitEthernet3/1/1
 BkTunnel ID: Invalid         BkIPInterface: N/A
     InLabel: NULL           ColorInterface: N/A
    SIDIndex: NULL         BkColorInterface: N/A
    FtnIndex: 0x0           TunnelInterface: N/A
TrafficIndex: N/A         BkTunnelInterface: N/A
   Connector: N/A                    PathID: 0x0
      UserID: 0x0                SRTunnelID: Invalid
    SID Type: N/A                       NID: Invalid
    FlushNID: Invalid                 BkNID: Invalid
  BkFlushNID: Invalid             StatFlags: 0x0
         SID: N/A
       BkSID: N/A
CommBlockLen: 0                    Priority: Critical
  MemberPort: N/A
The output shows that Router A and Router B communicate through Ethernet 1/1. Then the link over Ethernet 1/1 fails.
Summary count : 1
    Protocol: IS_L1
  Process ID: 1
        Cost: 20                 Preference: 10
      AttrID: 0xffffffff
       Flags: 0x1008c           OrigNextHop: 10.1.1.100
       Label: NULL              RealNextHop: 10.1.1.100
     SRLabel: NULL                Interface: Ten-GigabitEthernet3/1/2
   Tunnel ID: Invalid           IPInterface: Ten-GigabitEthernet3/1/2
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
The output shows that Router A and Router B communicate through Ethernet 1/2.
Example: Configuring IS-IS LFA FRR
As shown in Figure 34, Router A, Router B, and Router C reside in the same IS-IS routing domain.
·     Run IS-IS on all the routers to interconnect them with each other.
·     Configure IS-IS FRR so that when Link A fails, traffic can be switched to Link B immediately.
Figure 34 Network diagram
Device
IP address
Device
IP address
Router A
XGE3/1/1
12.12.12.1/24
Router B
XGE3/1/1
24.24.24.4/24
XGE3/1/2
13.13.13.1/24
XGE3/1/2
13.13.13.2/24
Loop0
1.1.1.1/32
Loop0
4.4.4.4/32
Router C
XGE3/1/1
12.12.12.2/24
XGE3/1/2
24.24.24.2/24
1.     Configure IP addresses and subnet masks for interfaces on the routers. (Details not shown.)
2.     Configure IS-IS on the routers to make sure Router A, Router B, and Router C can communicate with each other at the network layer. (Details not shown.)
3.     Configure IS-IS FRR:
Enable IS-IS FRR to calculate a backup next hop through LFA calculation, or designate a backup next hop by using a routing policy.
¡     (Method 1.) Enable IS-IS FRR to calculate a backup next hop through LFA calculation:
[RouterA] isis 1
[RouterA-isis-1] address-family ipv4
[RouterA-isis-1-ipv4] fast-reroute lfa
[RouterA-isis-1-ipv4] quit
[RouterB] isis 1
[RouterB-isis-1] address-family ipv4
[RouterB-isis-1-ipv4] fast-reroute lfa
[RouterB-isis-1-ipv4] quit
¡     (Method 2.) Enable IS-IS FRR to designate a backup next hop by using a routing policy:
[RouterA] ip prefix-list abc index 10 permit 4.4.4.4 32
[RouterA] route-policy frr permit node 10
[RouterA-route-policy-frr-10] if-match ip address prefix-list abc
[RouterA-route-policy-frr-10] apply fast-reroute backup-interface ten-gigabitethernet 3/1/1 backup-nexthop 12.12.12.2
[RouterA-route-policy-frr-10] quit
[RouterA] isis 1
[RouterA-isis-1-ipv4] fast-reroute route-policy frr
[RouterB] ip prefix-list abc index 10 permit 1.1.1.1 32
[RouterB] route-policy frr permit node 10
[RouterB-route-policy-frr-10] if-match ip address prefix-list abc
[RouterB-route-policy-frr-10] apply fast-reroute backup-interface ten-gigabitethernet 3/1/1 backup-nexthop 24.24.24.2
[RouterB-route-policy-frr-10] quit
[RouterB] isis 1
[RouterB-isis-1-ipv4] fast-reroute route-policy frr
# Display route 4.4.4.4/32 on Router A to view the backup next hop information.
[RouterA] display ip routing-table 4.4.4.4 verbose
Summary count : 1
 Destination: 4.4.4.4/32
    Protocol: IS_L1
  Process ID: 1
      AttrID: 0xffffffff
       Flags: 0x1008c           OrigNextHop: 13.13.13.2
       Label: NULL              RealNextHop: 13.13.13.2
     BkLabel: NULL                BkNextHop: 12.12.12.2
   BkSRLabel: NULL              BkInterface: Ten-GigabitEthernet3/1/1
 BkTunnel ID: Invalid         BkIPInterface: Ten-GigabitEthernet3/1/1
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
# Display route 1.1.1.1/32 on Router B to view the backup next hop information.
[RouterB] display ip routing-table 1.1.1.1 verbose
Summary count : 1
 Destination: 1.1.1.1/32
    Protocol: IS_L1
  Process ID: 1
      AttrID: 0xffffffff
       Flags: 0x1008c           OrigNextHop: 13.13.13.1
       Label: NULL              RealNextHop: 13.13.13.1
     BkLabel: NULL                BkNextHop: 24.24.24.2
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
Example: Configuring IS-IS remote LFA FRR
As shown in Figure 34, Router A, Router B, Router C, and Router D reside in the same IS-IS routing domain.
·     Configure MPLS LDP on all the routers.
·     Configure IS-IS remote LFA FRR so that when Link A fails, traffic can be switched to Link B immediately.
Figure 35 Network diagram
Table 7 Interface and IP address assignment
Device
IP address
Device
IP address
Router A
XGE3/1/1
12.12.12.1/24
Router B
XGE3/1/1
12.12.12.2/24
XGE3/1/2
13.13.13.1/24
XGE3/1/2
15.15.15.1/24
Loop1
1.1.1.1/32
Loop1
2.2.2.2/32
Router C
XGE3/1/1
13.13.13.2/24
Router D
XGE3/1/1
15.15.15.2/24
XGE3/1/2
14.14.14.1/24
XGE3/1/2
14.14.14.2/24
Loop1
3.3.3.3/32
Loop1
4.4.4.4/32
2.     Configure IS-IS and MPLS LDP on all the routers:
[RouterA] mpls lsr-id 1.1.1.1
[RouterA] mpls ldp
[RouterA-ldp] accept target-hello all
[RouterA-ldp] quit
[RouterA] isis 1
[RouterA-isis-1] network-entity 00.0000.0000.0001.00
[RouterA-Ten-GigabitEthernet3/1/1] isis cost 10
[RouterA-Ten-GigabitEthernet3/1/1] mpls enable
[RouterA-Ten-GigabitEthernet3/1/1] mpls ldp enable
[RouterA-Ten-GigabitEthernet3/1/2] isis enable 1
[RouterA-Ten-GigabitEthernet3/1/2] isis cost 20
[RouterA-Ten-GigabitEthernet3/1/2] mpls enable
[RouterA-Ten-GigabitEthernet3/1/2] mpls ldp enable
[RouterA] interface loopback 1
[RouterA-LoopBack1] isis enable 1
[RouterA-LoopBack1] quit
[RouterB] mpls lsr-id 2.2.2.2
[RouterB] mpls ldp
[RouterB-ldp] accept target-hello all
[RouterB-ldp] quit
[RouterB] isis 1
[RouterB-isis-1] network-entity 00.0000.0000.0002.00
[RouterB-Ten-GigabitEthernet3/1/1] isis cost 10
[RouterB-Ten-GigabitEthernet3/1/1] mpls enable
[RouterB-Ten-GigabitEthernet3/1/1] mpls ldp enable
[RouterB-Ten-GigabitEthernet3/1/2] isis enable 1
[RouterB-Ten-GigabitEthernet3/1/2] isis cost 20
[RouterB-Ten-GigabitEthernet3/1/2] mpls enable
[RouterB-Ten-GigabitEthernet3/1/2] mpls ldp enable
[RouterB] interface loopback 1
[RouterB-LoopBack1] isis enable 1
[RouterB-LoopBack1] quit
[RouterC] mpls lsr-id 3.3.3.3
[RouterC] mpls ldp
[RouterC-ldp] accept target-hello all
[RouterC-ldp] quit
[RouterC] isis 1
[RouterC-isis-1] network-entity 00.0000.0000.0003.00
[RouterC-Ten-GigabitEthernet3/1/1] isis cost 20
[RouterC-Ten-GigabitEthernet3/1/1] mpls enable
[RouterC-Ten-GigabitEthernet3/1/1] mpls ldp enable
[RouterC-Ten-GigabitEthernet3/1/2] isis cost 20
[RouterC-Ten-GigabitEthernet3/1/2] mpls enable
[RouterC-Ten-GigabitEthernet3/1/2] mpls ldp enable
[RouterC] interface loopback 1
[RouterC-LoopBack1] isis enable 1
[RouterC-LoopBack1] quit
[RouterD] mpls lsr-id 4.4.4.4
[RouterD] mpls ldp
[RouterD-ldp] accept target-hello all
[RouterD-ldp] quit
[RouterD] isis 1
[RouterD-isis-1] network-entity 00.0000.0000.0004.00
[RouterD-Ten-GigabitEthernet3/1/1] isis cost 20
[RouterD-Ten-GigabitEthernet3/1/1] mpls enable
[RouterD-Ten-GigabitEthernet3/1/1] mpls ldp enable
[RouterD-Ten-GigabitEthernet3/1/2] isis cost 20
[RouterD-Ten-GigabitEthernet3/1/2] mpls enable
[RouterD-Ten-GigabitEthernet3/1/2] mpls ldp enable
[RouterD] interface loopback 1
[RouterD-LoopBack1] isis enable 1
[RouterD-LoopBack1] quit
3.     Configure IS-IS remote LFA FRR.
[RouterA] isis 1
[RouterA-isis-1-ipv4] fast-reroute remote-lfa tunnel ldp
# Display route 2.2.2.2/32 on Router A to view the backup next hop information.
[RouterA] display isis route ipv4 2.2.2.2 32 verbose
 IPv4 Dest : 2.2.2.2/32          Int. Cost  : 10               Ext. Cost  : NULL
 Admin Tag : -                   Src Count  : 1                Flag       : R/L/-
 InLabel   : 4294967295          InLabel Flag: -/-/-/-/-/-
 NextHop   :                     Interface  :                  ExitIndex  :
    12.12.12.2                         XGE3/1/1                    0x00000002
 Nib ID    : 0x14000008          OutLabel   : 4294967295       OutLabelFlag: -
 LabelSrc  : N/A                 Delay Flag : N/A
 Remote-LFA:
  Interface : XGE3/1/2
  BkNextHop : 13.13.13.2         LsIndex    : 0x01000002
  Tunnel destination address: 4.4.4.4
  Backup label: {1149}
      InLabel flags: R-Readvertisement, N-Node SID, P-no PHP
                     E-Explicit null, V-Value, L-Local
      OutLabelFlags: E-Explicit null, I-Implicit null, N-Nomal, P-SR label prefer
 Admin Tag : -                   Src Count  : 3                Flag       : -/-/-
Example: Configuring IS-IS multi-instance processes
As shown in Figure 36, the IPv4 and IPv6 costs are different on an interface. Configure IS-IS multi-instance processes to isolate the IPv4 and IPv6 network and avoid IPv6 route calculation errors.
Figure 36 Network diagram
Table 8 Interface and IP address assignment
Device
IPv4 address
IPv6 address
Router A
XGE3/1/1
10.1.1.1/24
2001::1/64
Loop0
1.1.1.1/32
10::1/128
Router C
XGE3/1/1
10.1.1.2/24
2001::2/64
Loop0
2.2.2.2/32
20::1/128
Configure IPv4 and IPv6 addresses for the interfaces. (Details not shown.)
1.     Configure traditional IPv4 IS-IS processes:
[RouterA] isis 1
[RouterA-LoopBack0] isis ipv6 enable 2
[RouterB] isis 1
[RouterB-LoopBack0] isis ipv6 enable 2
2.     Configure IPv6 IS-IS multi-instance processes:
[RouterA] isis 2
[RouterA-isis-2] network-entity 20.0000.0000.0010.00
[RouterA-isis-2] multi-instance enable iid 1
[RouterA-isis-2] address-family ipv6
[RouterA-isis-2-ipv6] quit
[RouterA-isis-2] quit
[RouterA-Ten-GigabitEthernet3/1/1] isis ipv6 enable 2
[RouterA-Ten-GigabitEthernet3/1/1] isis process-id 2 cost 63
[RouterB] isis 2
[RouterB-isis-2] network-entity 20.0000.0000.0020.00
[RouterB-isis-2] multi-instance enable iid 1
[RouterB-isis-2] address-family ipv6
[RouterB-isis-2-ipv6] quit
[RouterB-isis-2] quit
[RouterB-Ten-GigabitEthernet3/1/1] isis ipv6 enable 2
[RouterB-Ten-GigabitEthernet3/1/1] isis process-id 2 cost 63
# View information about the IPv4 IS-IS routing table of Router A.
 1.1.1.1/32           0          NULL    Loop0           Direct          D/L/-
 10.1.1.0/24          10         NULL    GE1/0/1         Direct          D/L/-
 2.2.2.2/32           10         NULL    GE1/0/1         10.1.1.2        R/L/-
 10.1.1.0/24          10         NULL    ULL             Direct          D/L/-
 2.2.2.2/32           10         NULL
The output shows that route calculation results are correct.
# View information about the IPv4 IS-IS routing table of Router B.
[RouterB] display isis route ipv4
 1.1.1.1/32           10         NULL    GE1/0/1         10.1.1.1        R/L/-
 2.2.2.2/32           0          NULL    Loop0           Direct          D/L/-
 1.1.1.1/32           10         NULL
# View information about the IPv6 IS-IS routing table of Router A.
[RouterA] display isis route ipv6
                         Route information for IS-IS(2)
                         Level-1 IPv6 forwarding table
 Destination : 10::1                                   PrefixLen: 128
 Flag        : D/L/-                                   Cost     : 0
 Next hop    : Direct                                  Interface: Loop0
 Destination : 2001::                                  PrefixLen: 64
 Flag        : D/L/-                                   Cost     : 63
 Next hop    : Direct                                  Interface: GE1/0/1
 Destination : 20::1                                   PrefixLen: 128
 Flag        : R/L/-                                   Cost     : 63
 Next hop    : FE80::861F:31FF:FE6D:201                Interface: GE1/0/1
                         Level-2 IPv6 forwarding table
 Flag        : -/-/-                                   Cost     : 63
# View information about the IPv6 IS-IS routing table of Router B.
[RouterB] display isis route ipv6
 Next hop    : FE80::861F:29FF:FE93:101                Interface: GE1/0/1
IPv6 IS-IS configuration examples
Example: Configuring IPv6 IS-IS basics
As shown in Figure 37, Router A, Router B, Router C, and Router D, all enabled with IPv6, reside in the same AS. Configure IPv6 IS-IS on the routers so that they can reach each other.
Figure 37 Network diagram
1.     Configure IPv6 addresses for interfaces. (Details not shown.)
2.     Configure IPv6 IS-IS:
[RouterA] isis 1
[RouterA-isis-1] address-family ipv6
[RouterA-isis-1-ipv6] quit
[RouterA-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[RouterB] isis 1
[RouterB-isis-1] address-family ipv6
[RouterB-isis-1-ipv6] quit
[RouterB-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[RouterC] isis 1
[RouterC-isis-1] address-family ipv6
[RouterC-isis-1-ipv6] quit
[RouterC-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[RouterC-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[RouterC-Ten-GigabitEthernet3/1/3] isis ipv6 enable 1
[RouterD] isis 1
[RouterD-isis-1] address-family ipv6
[RouterD-isis-1-ipv6] quit
[RouterD-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[RouterD-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
# Display the IPv6 IS-IS routing table on Router A.
 Destination : ::                                      PrefixLen: 0
 Flag        : R/-/-                                   Cost     : 10
 Next hop    : FE80::200:FF:FE0F:4                     Interface: XGE3/1/1
 Destination : 2001:1::                                PrefixLen: 64
 Flag        : D/L/-                                   Cost     : 10
 Next hop    : Direct                                  Interface: XGE3/1/1
 Destination : 2001:2::                                PrefixLen: 64
 Flag        : R/-/-                                   Cost     : 20
 Destination : 2001:3::                                PrefixLen: 64
# Display the IPv6 IS-IS routing table on Router B.
# Display the IPv6 IS-IS routing table on Router C.
[RouterC] display isis route ipv6
 Next hop    : Direct                                  Interface: XGE3/1/2
 Next hop    : Direct                                  Interface: XGE3/1/3
 Destination : 2001:4::                               PrefixLen: 64
# Display the IPv6 IS-IS routing table on Router D.
[RouterD] display isis route ipv6
Example: Configuring BFD for IPv6 IS-IS
As shown in Figure 38:
·     Configure IPv6 IS-IS on Router A, Router B, and Router C so that they can reach each other.
·     Enable BFD on Ten-GigabitEthernet 3/1/1 of Router A and Router B.
When the link between Router B and the Layer 2 switch fails, BFD can quickly detect the failure and notify IPv6 IS-IS of the failure. Then Router A and Router B communicate through Router C.
Figure 38 Network diagram
Table 9 Interface and IP address assignment
Device
IPv6 address
Device
IPv6 address
Router A
XGE3/1/1
2001::1/64
Router B
XGE3/1/1
2001::2/64
XGE3/1/2
2001:2::1/64
XGE3/1/2
2001:3::2/64
Router C
XGE3/1/1
2001:2::2/64
XGE3/1/2
2001:3::1/64
[RouterA] isis 1
[RouterA-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[RouterB] isis 1
[RouterB-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[RouterC] isis 1
[RouterC-Ten-GigabitEthernet3/1/1 quit
[RouterA-Ten-GigabitEthernet3/1/1] isis ipv6 bfd enable
[RouterB-Ten-GigabitEthernet3/1/1] isis ipv6 bfd enable
[RouterB-Ten-GigabitEthernet3/1/1] bfd detect-multiplier 6
# Display BFD session information on Router A.
 IPv6 session working in control packet mode:
       Local discr: 1441                 Remote discr: 1450
         Source IP: FE80::20F:FF:FE00:1202 (link-local address of Ten-GigabitEthernet3/1/1 on Router A)
    Destination IP: FE80::20F:FF:FE00:1200 (link-local address of Ten-GigabitEthernet3/1/1 on Router B)
     Session state: Up                      Interface: XGE3/1/1
         Hold time: 2319ms
# Display routes destined for 2001:4::0/64 on Router A.
[RouterA] display ipv6 routing-table 2001:4::0 64
Summary count : 2
Destination: 2001:4::/64                                 Protocol  : IS_L1
NextHop    : FE80::20F:FF:FE00:1200                      Preference: 15
Interface  : XGE3/1/1                                     Cost      : 10
The output shows that Router A and Router B communicate through Ten-GigabitEthernet 3/1/1. Then the link over Ten-GigabitEthernet 3/1/1 fails.
Summary count : 1
NextHop    : FE80::BAAF:67FF:FE27:DCD0                   Preference: 15
Interface  : XGE3/1/2                                     Cost      : 20
The output shows that Router A and Router B communicate through Ten-GigabitEthernet 3/1/2.
Example: Configuring IPv6 IS-IS FRR
As shown in Figure 39, Router A, Router B, and Router C reside in the same IS-IS routing domain.
·     Run IPv6 IS-IS on all the routers to interconnect them with each other.
·     Configure IPv6 IS-IS FRR so that when Link A fails, traffic can be switched to Link B immediately.
Figure 39 Network diagram
Table 10 Interface and IP address assignment
Device
IPv6 address
Device
IP address
Router A
XGE3/1/1
1::1/64
Router B
XGE3/1/1
3::1/64
XGE3/1/2
2::1/64
XGE3/1/2
2::2/64
Loop0
10::1/128
Loop0
20::1/128
Router C
XGE3/1/1
1::2/64
XGE3/1/2
3::2/64
1.     Configure IPv6 addresses for interfaces on the routers and enable IPv6 IS-IS. (Details not shown.)
2.     Configure IPv6 IS-IS FRR:
Enable IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation, or designate a backup next hop by using a routing policy.
¡     (Method 1.) Enable IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation:
<RouterA>system-view
[RouterA] isis 1
[RouterA-isis-1-ipv6] fast-reroute lfa
[RouterB] isis 1
[RouterB-isis-1-ipv6] fast-reroute lfa
¡     (Method 2.) Enable IPv6 IS-IS FRR to designate a backup next hop by using a routing policy:
[RouterA] ipv6 prefix-list abc index 10 permit 20::1 128
[RouterA-route-policy-frr-10] if-match ipv6 address prefix-list abc
[RouterA-route-policy-frr-10] apply ipv6 fast-reroute backup-interface ten-gigabitethernet 3/1/1 backup-nexthop 1::2
[RouterA] isis 1
[RouterA-isis-1-ipv6] fast-reroute route-policy frr
[RouterB] ipv6 prefix-list abc index 10 permit 10::1 128
[RouterB-route-policy-frr-10] if-match ipv6 address prefix-list abc
[RouterB-route-policy-frr-10] apply ipv6 fast-reroute backup-interface ten-gigabitethernet 3/1/1 backup-nexthop 3::2
[RouterB] isis 1
[RouterB-isis-1-ipv6] fast-reroute route-policy frr
# Display route 20::1/128 on Router A to view the backup next hop information.
[RouterA] display ipv6 routing-table 20::1 128 verbose
Summary count : 1
 Destination: 20::1/128
    Protocol: IS_L1
  Process ID: 1
   SubProtID: 0x1                       Age: 00h27m45s
        Cost: 10                 Preference: 15
   OrigTblID: 0xa                   OrigVrf: default-vrf
     TableID: 0xa                    OrigAs: 0
       NibID: 0x24000005             LastAs: 0
      AttrID: 0xffffffff
    BkAttrID: 0xffffffff           Neighbor: ::
       Flags: 0x10041           OrigNextHop: FE80::34CD:9FF:FE2F:D02
       Label: NULL              RealNextHop: FE80::34CD:9FF:FE2F:D02
     BkLabel: NULL                BkNextHop: FE80::7685:45FF:FEAD:102
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
# Display route 10::1/128 on Router B to view the backup next hop information.
[RouterB] display ipv6 routing-table 10::1 128 verbose
Summary count : 1
 Destination: 10::1/128
    Protocol: IS_L1
  Process ID: 1
   SubProtID: 0x1                       Age: 00h33m23s
       NibID: 0x24000006             LastAs: 0
      AttrID: 0xffffffff
       Flags: 0x10041           OrigNextHop: FE80::34CC:E8FF:FE5B:C02
       Label: NULL              RealNextHop: FE80::34CC:E8FF:FE5B:C02
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
Applying a flexible algorithm to IS-IS SRv6
As shown in Figure 40, complete the following tasks:
·     Configure IPv6 IS-IS on Device A, Device B, Device C, Device D, Device E, and Device F to achieve network level connectivity.
·     Enable IS-IS SRv6 on Device A, Device B, Device C, Device D, Device E, and Device F.
·     Configure flexible algorithm 130 for each device. The FAD of flexible algorithm 130 is as follows:
¡     Calculation type—SPF algorithm.
¡     Metric type—Link delay. In this example, the link delay on each interface is configured manually.
¡     Constraint—Exclude affinity attribute red.
·     Configure TI-LFA FRR to avoid microloops. When Link A fails, Device B will determine Device A as the next hop to Device D before completing route convergence. As a result, a loop will occur because Device B will return the traffic from Device A to Device A.
Figure 40 IS-IS SRv6 network with a flexible algorithm
Table 11 Interface and IP address assignment
Device
IPv6 address
Device
IPv6 address
Device A
XGE3/1/1
1001::1/64
Device D
XGE3/1/1
3003::2/64
XGE3/1/2
6001::2/64
XGE3/1/2
4004::1/64
Device B
XGE3/1/1
1001::2/64
Device E
XGE3/1/1
4004::2/64
XGE3/1/2
2002::1/64
XGE3/1/2
5001::1/64
Device C
XGE3/1/1
2002::2/64
XGE3/1/3
3002::2/64
XGE3/1/2
3003::1/64
Device F
XGE3/1/1
5001::2/64
XGE3/1/3
3002::1/64
XGE3/1/2
6001::1/64
1.     Configure IPv6 addresses and prefix lengths for interfaces on each device. (Details not shown.)
2.     Configure Device A.
# Configure IPv6 IS-IS to achieve network level connectivity and set the IS-IS cost style to wide.
[DeviceA] isis 1
[DeviceA-isis-1] network-entity 00.0000.0000.0001.00
[DeviceA-isis-1] cost-style wide
[DeviceA-isis-1] address-family ipv6
[DeviceA-isis-1-ipv6] quit
[DeviceA-isis-1] quit
[DeviceA] interface ten-gigabitethernet 3/1/1
[DeviceA-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[DeviceA-Ten-GigabitEthernet3/1/1] quit
[DeviceA] interface ten-gigabitethernet 3/1/2
[DeviceA-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[DeviceA-Ten-GigabitEthernet3/1/2] quit
# Enable SRv6 and configure a locator.
[DeviceA] segment-routing ipv6
[DeviceA-segment-routing-ipv6] locator 10 ipv6-prefix 1000:: 64 static 32
[DeviceA-segment-routing-ipv6-locator-10] quit
[DeviceA-segment-routing-ipv6] quit
# Apply the locator to the IPv6 IS-IS process.
[DeviceA] isis 1
[DeviceA-isis 1] address-family ipv6 unicast
[DeviceA-isis-1-ipv6] segment-routing ipv6 locator 10
# Set the minimum link delay and the maximum link delay on Ten-GigabitEthernet 3/1/1 to 50 microseconds and 100 microseconds, respectively.
[DeviceA-Ten-GigabitEthernet3/1/1] isis link-delay min 50 max 100
# Set the minimum link delay and the maximum link delay on Ten-GigabitEthernet 3/1/2 to 10 microseconds and 100 microseconds, respectively.
[DeviceA-Ten-GigabitEthernet3/1/2] isis link-delay min 10 max 100
# Enable IS-IS link delay advertisement.
[DeviceA] isis 1
[DeviceA-isis-1-ipv6] metric-delay advertisement enable
# Enable IS-IS to advertise link attributes in LSPs.
[DeviceA-isis-1-ipv6] advertise link-attributes
# Enable IS-IS to advertise link attributes for use by flexible algorithms.
[DeviceA-isis-1-ipv6] advertise application link-attributes te
# Configure flexible algorithm 130.
[DeviceA] isis 1
[DeviceA-isis-1] affinity-map red bit-position 130
[DeviceA-isis-1] flex-algo 130
[DeviceA-isis-1-flex-algo-130] advertise-definition enable
[DeviceA-isis-1-flex-algo-130] metric-type delay
[DeviceA-isis-1-flex-algo-130] priority 255
[DeviceA-isis-1-flex-algo-130] affinity exclude-any red
# Enable TI-LFA FRR for flexible algorithm 130.
[DeviceA-isis-1-flex-algo-130] fast-reroute ti-lfa enable
[DeviceA-isis-1-flex-algo-130] quit
# Associate SRv6 locator 10 to flexible algorithm 130.
[DeviceA-segment-routing-ipv6-locator-10] flex-algo algorithm 130
3.     Configure Device B.
[DeviceB] isis 1
[DeviceB-isis-1] network-entity 00.0000.0000.0002.00
[DeviceB-isis-1] cost-style wide
[DeviceB-isis-1] address-family ipv6
[DeviceB-isis-1-ipv6] quit
[DeviceB-isis-1] quit
[DeviceB] interface ten-gigabitethernet 3/1/1
[DeviceB-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[DeviceB-Ten-GigabitEthernet3/1/1] quit
[DeviceB] interface ten-gigabitethernet 3/1/2
[DeviceB-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[DeviceB-Ten-GigabitEthernet3/1/2] quit
[DeviceB] segment-routing ipv6
[DeviceB-segment-routing-ipv6] locator 10 ipv6-prefix 2000:: 64 static 32
[DeviceB-segment-routing-ipv6-locator-10] quit
[DeviceB-segment-routing-ipv6] quit
[DeviceB] isis 1
[DeviceB-isis 1] address-family ipv6 unicast
[DeviceB-isis-1-ipv6] segment-routing ipv6 locator 10
[DeviceB-Ten-GigabitEthernet3/1/1] isis link-delay min 50 max 100
# Set the minimum link delay and the maximum link delay on Ten-GigabitEthernet 3/1/2 to 50 microseconds and 100 microseconds, respectively.
[DeviceB-Ten-GigabitEthernet3/1/2] isis link-delay min 50 max 100
[DeviceB] isis 1
[DeviceB-isis-1-ipv6] metric-delay advertisement enable
[DeviceB-isis-1-ipv6] advertise link-attributes
[DeviceB-isis-1-ipv6] advertise application link-attributes te
[DeviceB] isis 1
[DeviceB-isis-1] affinity-map red bit-position 130
[DeviceB-isis-1] flex-algo 130
[DeviceB-isis-1-flex-algo-130] advertise-definition enable
[DeviceB-isis-1-flex-algo-130] metric-type delay
[DeviceB-isis-1-flex-algo-130] priority 255
[DeviceB-isis-1-flex-algo-130] affinity exclude-any red
[DeviceB-isis-1-flex-algo-130] fast-reroute ti-lfa enable
[DeviceB-isis-1-flex-algo-130] quit
[DeviceB-segment-routing-ipv6-locator-10] flex-algo algorithm 130
4.     Configure Device C.
<DeviceC> system-view
[DeviceC] isis 1
[DeviceC-isis-1] network-entity 00.0000.0000.0003.00
[DeviceC-isis-1] cost-style wide
[DeviceC-isis-1] address-family ipv6
[DeviceC-isis-1-ipv6] quit
[DeviceC-isis-1] quit
[DeviceC] interface ten-gigabitethernet 3/1/1
[DeviceC-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[DeviceC-Ten-GigabitEthernet3/1/1] quit
[DeviceC] interface ten-gigabitethernet 3/1/2
[DeviceC-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[DeviceC-Ten-GigabitEthernet3/1/2] quit
[DeviceC] interface ten-gigabitethernet 3/1/3
[DeviceC-Ten-GigabitEthernet3/1/3] isis ipv6 enable 1
[DeviceC-Ten-GigabitEthernet3/1/3] quit
[DeviceC] segment-routing ipv6
[DeviceC-segment-routing-ipv6] locator 10 ipv6-prefix 3000:: 64 static 32
[DeviceC-segment-routing-ipv6-locator-10] quit
[DeviceC-segment-routing-ipv6] quit
[DeviceC] isis 1
[DeviceC-isis 1] address-family ipv6 unicast
[DeviceC-isis-1-ipv6] segment-routing ipv6 locator 10
[DeviceC-Ten-GigabitEthernet3/1/1] isis link-delay min 50 max 100
[DeviceC-Ten-GigabitEthernet3/1/2] isis link-delay min 50 max 100
# Set the minimum link delay and the maximum link delay on Ten-GigabitEthernet 3/1/3 to 20 microseconds and 100 microseconds, respectively.
[DeviceC-Ten-GigabitEthernet3/1/3] isis link-delay min 20 max 100
[DeviceC] isis 1
[DeviceC-isis-1-ipv6] metric-delay advertisement enable
[DeviceC-isis-1-ipv6] advertise link-attributes
[DeviceC-isis-1-ipv6] advertise application link-attributes te
[DeviceC] isis 1
[DeviceC-isis-1] affinity-map red bit-position 130
[DeviceC-isis-1] flex-algo 130
[DeviceC-isis-1-flex-algo-130] advertise-definition enable
[DeviceC-isis-1-flex-algo-130] metric-type delay
[DeviceC-isis-1-flex-algo-130] priority 255
[DeviceC-isis-1-flex-algo-130] affinity exclude-any red
[DeviceC-isis-1-flex-algo-130] fast-reroute ti-lfa enable
[DeviceC-isis-1-flex-algo-130] quit
# Assign affinity attribute red to Ten-GigabitEthernet 3/1/3.
[DeviceC-Ten-GigabitEthernet3/1/3] isis 1 affinity flex-algo red
[DeviceC-segment-routing-ipv6-locator-10] flex-algo algorithm 130
5.     Configure Device D.
<DeviceD> system-view
[DeviceD] isis 1
[DeviceD-isis-1] network-entity 00.0000.0000.0004.00
[DeviceD-isis-1] cost-style wide
[DeviceD-isis-1] address-family ipv6
[DeviceD-isis-1-ipv6] quit
[DeviceD-isis-1] quit
[DeviceD] interface ten-gigabitethernet 3/1/1
[DeviceD-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[DeviceD-Ten-GigabitEthernet3/1/1] quit
[DeviceD] interface ten-gigabitethernet 3/1/2
[DeviceD-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[DeviceD-Ten-GigabitEthernet3/1/2] quit
[DeviceD] segment-routing ipv6
[DeviceD-segment-routing-ipv6] locator 10 ipv6-prefix 4000:: 64 static 32
[DeviceD-segment-routing-ipv6-locator-10] quit
[DeviceD-segment-routing-ipv6] quit
[DeviceD] isis 1
[DeviceD-isis 1] address-family ipv6 unicast
[DeviceD-isis-1-ipv6] segment-routing ipv6 locator 10
[DeviceD-Ten-GigabitEthernet3/1/1] isis link-delay min 50 max 100
[DeviceD-Ten-GigabitEthernet3/1/2] isis link-delay min 10 max 100
[DeviceD] isis 1
[DeviceD-isis-1-ipv6] metric-delay advertisement enable
[DeviceD-isis-1-ipv6] advertise link-attributes
[DeviceD-isis-1-ipv6] advertise application link-attributes te
[DeviceD] isis 1
[DeviceD-isis-1] affinity-map red bit-position 130
[DeviceD-isis-1] flex-algo 130
[DeviceD-isis-1-flex-algo-130] advertise-definition enable
[DeviceD-isis-1-flex-algo-130] metric-type delay
[DeviceD-isis-1-flex-algo-130] priority 255
[DeviceD-isis-1-flex-algo-130] affinity exclude-any red
[DeviceD-isis-1-flex-algo-130] fast-reroute ti-lfa enable
[DeviceD-isis-1-flex-algo-130] quit
[DeviceD-segment-routing-ipv6-locator-10] flex-algo algorithm 130
6.     Configure Device E.
<DeviceE> system-view
[DeviceE] isis 1
[DeviceE-isis-1] network-entity 00.0000.0000.0005.00
[DeviceE-isis-1] cost-style wide
[DeviceE-isis-1] address-family ipv6
[DeviceE-isis-1-ipv6] quit
[DeviceE-isis-1] quit
[DeviceE] interface ten-gigabitethernet 3/1/1
[DeviceE-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[DeviceE-Ten-GigabitEthernet3/1/1] quit
[DeviceE] interface ten-gigabitethernet 3/1/2
[DeviceE-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[DeviceE-Ten-GigabitEthernet3/1/2] quit
[DeviceE] interface ten-gigabitethernet 3/1/3
[DeviceE-Ten-GigabitEthernet3/1/3] isis ipv6 enable 1
[DeviceE-Ten-GigabitEthernet3/1/3] quit
[DeviceE] segment-routing ipv6
[DeviceE-segment-routing-ipv6] locator 10 ipv6-prefix 5000:: 64 static 32
[DeviceE-segment-routing-ipv6-locator-10] quit
[DeviceE-segment-routing-ipv6] quit
[DeviceE] isis 1
[DeviceE-isis 1] address-family ipv6 unicast
[DeviceE-isis-1-ipv6] segment-routing ipv6 locator 10
# Set the minimum link delay and the maximum link delay on Ten-GigabitEthernet 3/1/1 to 10 microseconds and 100 microseconds, respectively.
[DeviceE-Ten-GigabitEthernet3/1/1] isis link-delay min 10 max 100
[DeviceE-Ten-GigabitEthernet3/1/2] isis link-delay min 10 max 100
[DeviceE-Ten-GigabitEthernet3/1/3] isis link-delay min 20 max 100
[DeviceE] isis 1
[DeviceE-isis-1-ipv6] metric-delay advertisement enable
[DeviceE-isis-1-ipv6] advertise link-attributes
[DeviceE-isis-1-ipv6] advertise application link-attributes te
[DeviceE] isis 1
[DeviceE-isis-1] affinity-map red bit-position 130
[DeviceE-isis-1] flex-algo 130
[DeviceE-isis-1-flex-algo-130] advertise-definition enable
[DeviceE-isis-1-flex-algo-130] metric-type delay
[DeviceE-isis-1-flex-algo-130] priority 255
[DeviceE-isis-1-flex-algo-130] affinity exclude-any red
[DeviceE-isis-1-flex-algo-130] fast-reroute ti-lfa enable
[DeviceE-isis-1-flex-algo-130] quit
[DeviceE-Ten-GigabitEthernet3/1/3] isis 1 affinity flex-algo red
[DeviceE-segment-routing-ipv6-locator-10] flex-algo algorithm 130
7.     Configure Device F.
<DeviceF> system-view
[DeviceF] isis 1
[DeviceF-isis-1] network-entity 00.0000.0000.0006.00
[DeviceF-isis-1] cost-style wide
[DeviceF-isis-1] address-family ipv6
[DeviceF-isis-1-ipv6] quit
[DeviceF-isis-1] quit
[DeviceF] interface ten-gigabitethernet 3/1/1
[DeviceF-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[DeviceF-Ten-GigabitEthernet3/1/1] quit
[DeviceF] interface ten-gigabitethernet 3/1/2
[DeviceF-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[DeviceF-Ten-GigabitEthernet3/1/2] quit
[DeviceF] segment-routing ipv6
[DeviceF-segment-routing-ipv6] locator 10 ipv6-prefix 6000:: 64 static 32
[DeviceF-segment-routing-ipv6-locator-10] quit
[DeviceF-segment-routing-ipv6] quit
[DeviceF] isis 1
[DeviceF-isis 1] address-family ipv6 unicast
[DeviceF-isis-1-ipv6] segment-routing ipv6 locator 10
[DeviceF-Ten-GigabitEthernet3/1/1] isis link-delay min 10 max 100
[DeviceF-Ten-GigabitEthernet3/1/2] isis link-delay min 10 max 100
[DeviceF] isis 1
[DeviceF-isis-1-ipv6] metric-delay advertisement enable
[DeviceF-isis-1-ipv6] advertise link-attributes
[DeviceF-isis-1-ipv6] advertise application link-attributes te
[DeviceF] isis 1
[DeviceF-isis-1] affinity-map red bit-position 130
[DeviceF-isis-1] flex-algo 130
[DeviceF-isis-1-flex-algo-130] advertise-definition enable
[DeviceF-isis-1-flex-algo-130] metric-type delay
[DeviceF-isis-1-flex-algo-130] priority 255
[DeviceF-isis-1-flex-algo-130] affinity exclude-any red
[DeviceF-isis-1-flex-algo-130] fast-reroute ti-lfa enable
[DeviceF-isis-1-flex-algo-130] quit
[DeviceF-segment-routing-ipv6-locator-10] flex-algo algorithm 130
# Display routes calculated by flexible algorithm 130 on Device A. Device A uses Device F as the next hop to forward traffic to Device D, and the backup next hop calculated by TI-LFA is Device B.
[DeviceA] display isis flex-algo 130 route level-1 verbose
                   Flex Algo Route Information for IS-IS(1)
                            Level-1 Flex Algo Route
 IPv6 dest   : 1000::/64
 Flag        : D/-/-                       Cost        : 0
 Admin tag   : -                           Src count   : 1
 Algorithm   : 130
 Priority    : Low
 Nexthop     : Direct
 NexthopFlag : -
 Interface   : NULL0                       Delay Flag : N/A
 Nib ID      : 0x0
 IPv6 dest   : 2000::/64
 Flag        : R/-/-                       Cost        : 50
 Algorithm   : 130
 Priority    : Low
 Nexthop     : FE80::80C5:D9FF:FE06:206
 NexthopFlag : -
 Interface   : XGE3/1/1                     Delay Flag : N/A
 TI-LFA:
  BkNextHop : FE80::80C7:7DFF:FE43:607
  LsIndex    : 0x80000003
  Backup label stack(top->bottom): {3000::1:0:0}
 Nib ID      : 0x2400000c
 IPv6 dest   : 3000::/64
 Flag        : R/-/-                       Cost        : 80
 Algorithm   : 130
 Priority    : Low
 Nexthop     : FE80::80C7:7DFF:FE43:607
 NexthopFlag : -
 Interface   : XGE3/1/2                     Delay Flag : N/A
 TI-LFA:
  BkNextHop : FE80::80C5:D9FF:FE06:206
  LsIndex    : N/A
  Backup label stack(top->bottom): N/A
 Nib ID      : 0x24000008
 IPv6 dest   : 4000::/64
 Flag        : R/-/-                       Cost        : 30
 Algorithm   : 130
 Priority    : Low
 NexthopFlag : -
 TI-LFA:
  LsIndex    : 0x80000002
 Nib ID      : 0x2400000a
 IPv6 dest   : 5000::/64
 Algorithm   : 130
 Priority    : Low
 NexthopFlag : -
 TI-LFA:
 Nib ID      : 0x2400000a
 IPv6 dest   : 6000::/64
 Algorithm   : 130
 NexthopFlag : -
 TI-LFA:
 Nib ID      : 0x2400000c
# Display routes calculated by flexible algorithm 130 on Device C. The backup path to Device D does not include the link whose affinity attribute is red.
[Device C] display isis flex-algo 130 route level-1 verbose
 Algorithm   : 130
 Priority    : Low
 Nexthop     : FE80::80C7:42FF:FEF4:406
 NexthopFlag : -
 TI-LFA:
  BkNextHop : FE80::80C5:D9FF:FE06:207
  LsIndex    : N/A
 Nib ID      : 0x2400000a
 Algorithm   : 130
 Priority    : Low
 Nexthop     : FE80::80C5:D9FF:FE06:207
 NexthopFlag : -
 TI-LFA:
  BkNextHop : FE80::80C7:42FF:FEF4:406
  Backup label stack(top->bottom): {1000::1:0:0}
 Nib ID      : 0x24000009
 Algorithm   : 130
 Priority    : Low
 Nexthop     : Direct
 NexthopFlag : -
 Nib ID      : 0x0
 Algorithm   : 130
 Priority    : Low
 NexthopFlag : -
 TI-LFA:
  LsIndex    : N/A
 Nib ID      : 0x2400000a
 Flag        : R/-/-                       Cost        : 60
 Algorithm   : 130
 Priority    : Low
 NexthopFlag : -
 TI-LFA:
  LsIndex    : N/A
 Nib ID      : 0x2400000a
 Flag        : R/-/-                       Cost        : 70
 Algorithm   : 130
 NexthopFlag : -
 TI-LFA:
  LsIndex    : N/A
 Nib ID      : 0x2400000e
  • Become a Partner
  • Partner Resources
