07-Layer 3—IP Routing Configuration Guide
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration GuidesH3C CR16000-F Routers Configuration Guides-R838x-6W10007-Layer 3—IP Routing Configuration Guide
03-RIP configuration
03-RIP configuration 441.10 KB
Configuring RIP·· 1
About RIP· 1
RIP routing metrics· 1
RIP route entries· 1
RIP operation· 1
Routing loop prevention· 1
RIP versions· 2
Protocols and standards· 2
RIP tasks at a glance· 2
Configuring basic RIP· 3
Restrictions and guidelines for configuring basic RIP· 3
Enabling RIP· 3
Controlling RIP reception and advertisement on interfaces· 4
Configuring a RIP version· 5
Specifying a RIP neighbor 6
Configuring RIP route control 6
Configuring an additional routing metric· 6
Configuring RIPv2 route summarization· 7
Disabling host route reception· 8
Advertising a default route· 8
Configuring received/redistributed route filtering· 9
Setting a preference for RIP· 9
Configuring RIP route redistribution· 10
Tuning and optimizing RIP networks· 11
Setting RIP timers· 11
Enabling split horizon and poison reverse· 11
Setting the maximum number of RIP ECMP routes· 12
Setting the RIP triggered update interval 12
Configuring the RIP packet sending rate· 13
Setting the maximum length of RIP packets· 13
Setting the DSCP value for outgoing RIP packets· 14
Configuring RIP network management 14
Configuring RIP GR· 14
Configuring BFD for RIP· 15
About BFD for RIP· 15
Restrictions and guidelines· 15
Configuring single-hop echo detection (for a directly connected RIP neighbor) 16
Configuring single-hop echo detection (for a specific destination) 16
Configuring bidirectional control detection for an indirectly connected neighbor 17
Configuring bidirectional control detection for a directly connected neighbor 17
Configuring RIP FRR· 17
About RIP FRR· 17
Restrictions and guidelines for RIP FRR· 18
Enabling RIP FRR· 18
Enabling BFD bidirectional control detection for RIP FRR· 18
Enabling BFD single-hop echo detection for RIP FRR· 19
Enhancing RIP security· 19
Enabling zero field check for incoming RIPv1 messages· 19
Enabling source IP address check for incoming RIP updates· 20
Configuring RIPv2 message authentication· 20
Display and maintenance commands for RIP· 21
RIP configuration examples· 21
Example: Configuring basic RIP· 21
Example: Configuring RIP route redistribution· 24
Example: Configuring an additional metric for a RIP interface· 26
Example: Configuring RIP to advertise a summary route· 28
Example: Configuring RIP GR· 30
Example: Configuring BFD for RIP (single-hop echo detection for a directly connected neighbor) 31
Example: Configuring BFD for RIP (single-hop echo detection for a specific destination) 33
Example: Configuring BFD for RIP (bidirectional control detection) 36
Example: Configuring RIP FRR· 40
Configuring RIP
About RIP
Routing Information Protocol (RIP) is a distance-vector IGP suited to small-sized networks. It employs UDP to exchange route information through port 520.
RIP routing metrics
RIP uses a hop count to measure the distance to a destination. The hop count from a router to a directly connected network is 0. The hop count from a router to a directly connected router is 1. To limit convergence time, RIP restricts the value range of the metric from 0 to 15. A destination with a metric value of 16 (or greater) is considered unreachable. For this reason, RIP is not suitable for large-sized networks.
RIP route entries
RIP stores routing entries in a database. Each routing entry contains the following elements:
·     Destination address—IP address of a destination host or a network.
·     Next hop—IP address of the next hop.
·     Egress interface—Egress interface of the route.
·     Metric—Cost from the local router to the destination.
·     Route time—Time elapsed since the last update. The time is reset to 0 when the routing entry is updated.
·     Route tag—Used for route control. For more information, see "Configuring routing policies."
RIP operation
RIP works as follows:
1.     RIP sends request messages to neighboring routers. Neighboring routers return response messages that contain their routing tables.
2.     RIP uses the received responses to update the local routing table and sends triggered update messages to its neighbors. All RIP routers on the network do this to learn latest routing information.
3.     RIP periodically sends the local routing table to its neighbors. After a RIP neighbor receives the message, it updates its routing table, selects optimal routes, and sends an update to other neighbors. RIP ages routes to keep only valid routes.
RIP uses the following mechanisms to prevent routing loops:
·     Counting to infinity—A destination with a metric value of 16 is considered unreachable. When a routing loop occurs, the metric value of a route will increment to 16 to avoid endless looping.
·     Triggered updates—RIP immediately advertises triggered updates for topology changes to reduce the possibility of routing loops and to speed up convergence.
·     Split horizon—Disables RIP from sending routes through the interface where the routes were learned to prevent routing loops and save bandwidth.
·     Poison reverse—Enables RIP to set the metric of routes received from a neighbor to 16 and sends these routes back to the neighbor. The neighbor can delete such information from its routing table to prevent routing loops.
RIP versions
There are two RIP versions, RIPv1 and RIPv2.
RIPv1 is a classful routing protocol. It advertises messages only through broadcast. RIPv1 messages do not carry mask information, so RIPv1 can only recognize natural networks such as Class A, B, and C. For this reason, RIPv1 does not support discontiguous subnets.
RIPv2 is a classless routing protocol. It has the following advantages over RIPv1:
·     Supports route tags to implement flexible route control through routing policies.
·     Supports masks, route summarization, and CIDR.
·     Supports designated next hops to select the best ones on broadcast networks.
·     Supports multicasting route updates so only RIPv2 routers can receive these updates to reduce resource consumption.
·     Supports plain text authentication and MD5 authentication to enhance security.
RIPv2 supports two transmission modes: broadcast and multicast. Multicast is the default mode using 224.0.0.9 as the multicast address. An interface operating in RIPv2 broadcast mode can also receive RIPv1 messages.
·     RFC 1058, Routing Information Protocol
·     RFC 1723, RIP Version 2 - Carrying Additional Information
·     RFC 1721, RIP Version 2 Protocol Analysis
·     RFC 1722, RIP Version 2 Protocol Applicability Statement
·     RFC 1724, RIP Version 2 MIB Extension
·     RFC 2082, RIPv2 MD5 Authentication
·     RFC 2091, Triggered Extensions to RIP to Support Demand Circuits
·     RFC 2453, RIP Version 2
To configure RIP, perform the following tasks:
1.     Configuring basic RIP
a.     Enabling RIP
b.     (Optional.) Controlling RIP reception and advertisement on interfaces
c.     (Optional.) Configuring a RIP version
d.     Specifying a RIP neighbor
To enable RIP on a link that does not support broadcast or multicast, you must manually specify a RIP neighbor.
2.     (Optional.) Configuring RIP route control
¡     Configuring an additional routing metric
¡     Configuring RIPv2 route summarization
¡     Disabling host route reception
¡     Advertising a default route
¡     Configuring received/redistributed route filtering
¡     Setting a preference for RIP
¡     Configuring RIP route redistribution
3.     (Optional.) Tuning and optimizing RIP networks
¡     Setting RIP timers
¡     Enabling split horizon and poison reverse
¡     Setting the maximum number of RIP ECMP routes
¡     Setting the RIP triggered update interval
¡     Configuring the RIP packet sending rate
¡     Setting the maximum length of RIP packets
¡     Setting the DSCP value for outgoing RIP packets
4.     (Optional.) Configuring RIP network management
5.     Enhancing RIP availability
¡     Configuring RIP GR
¡     Configuring BFD for RIP
¡     Configuring RIP FRR
6.     (Optional.) Enhancing RIP security
¡     Enabling zero field check for incoming RIPv1 messages
¡     Enabling source IP address check for incoming RIP updates
¡     Configuring RIPv2 message authentication
To enable multiple RIP processes on a router, you must specify an ID for each process. A RIP process ID has only local significance. Two RIP routers having different process IDs can also exchange RIP packets.
Enabling RIP
You can enable RIP on a network and specify a wildcard mask for the network. After that, only the interface attached to the network runs RIP.
If you configure RIP settings in interface view before enabling RIP, the settings do not take effect until RIP is enabled.
If a physical interface is attached to multiple networks, you cannot advertise these networks in different RIP processes.
You cannot enable multiple RIP processes on a physical interface.
The rip enable command takes precedence over the network command.
Enabling RIP on a network
2.     Enable RIP and enter RIP view.
rip [ process-id ] [ vpn-instance vpn-instance-name ]
By default, RIP is disabled.
3.     Enable RIP on a network.
By default, RIP is disabled on a network.
The network 0.0.0.0 command can enable RIP on all interfaces in a single process, but does not apply to multiple RIP processes.
Enabling RIP on an interface
3.     Return to system view.
4.     Enter interface view.
5.     Enable RIP on the interface.
rip process-id enable [ exclude-subip ]
By default, RIP is disabled on an interface.
You can perform this task to configure the following features:
·     Suppressing an interface. The suppressed interface can receive RIP messages but cannot send RIP messages.
·     Disabling an interface from sending RIP messages.
·     Disabling an interface from receiving RIP messages.
Restrictions and guidelines for RIP reception and advertisement control on interfaces
An interface suppressed by using the silent-interface command can only receive RIP messages. It cannot send RIP messages. You can use the silent-interface all command to suppress all interfaces. The silent-interface command takes precedence over the rip input and rip output commands.
2.     Enter RIP view.
3.     Suppress an interface.
By default, all RIP-enabled interfaces can send RIP messages.
The suppressed interface can still receive RIP messages and respond to unicast requests containing unknown ports.
2.     Enter interface view.
3.     Disable an interface from receiving RIP messages.
undo rip input
By default, a RIP-enabled interface can receive RIP messages.
3.     Disable an interface from sending RIP messages.
undo rip output
By default, a RIP-enabled interface can send RIP messages.
You can configure a global RIP version in RIP view or an interface-specific RIP version in interface view.
An interface preferentially uses the interface-specific RIP version. If no interface-specific version is specified, the interface uses the global RIP version. If neither a global nor interface-specific RIP version is configured, the interface sends RIPv1 broadcasts and can receive the following:
·     RIPv1 broadcasts and unicasts.
·     RIPv2 broadcasts, multicasts, and unicasts.
2.     Specify a RIP version.
¡     Execute the following commands in sequence to specify a global RIP version:
version { 1 | 2 }
By default, no global version is specified. An interface sends RIPv1 broadcasts, and can receive RIPv1 broadcasts and unicasts, and RIPv2 broadcasts, multicasts, and unicasts.
¡     Execute the following commands in sequence to specify a RIP version on an interface:
rip version { 1 | 2 [ broadcast | multicast ] }
By default, no interface-specific RIP version is specified. The interface sends RIPv1 broadcasts, and can receive RIPv1 broadcasts and unicasts, and RIPv2 broadcasts, multicasts, and unicasts.
Typically RIP messages are sent in broadcast or multicast. To enable RIP on a link that does not support broadcast or multicast, you must manually specify a RIP neighbor.
As a best practice, do not use the peer ip-address command to specify a directly connected neighbor. The neighbor might receive a route update in both unicast and multicast (or broadcast) messages from the device.
2.     Enter RIP view.
3.     Specify a RIP neighbor.
peer ip-address
By default, RIP does not unicast updates to any peer.
4.     Disable source IP address check on inbound RIP updates.
undo validate-source-address
By default, source IP address check is enabled on inbound RIP updates.
If the specified neighbor is not directly connected, disable source address check on incoming updates.
An additional routing metric (hop count) can be added to the metric of an inbound or outbound RIP route.
·     An outbound additional metric is added to the metric of a sent route, and it does not change the route's metric in the routing table.
·     An inbound additional metric is added to the metric of a received route before the route is added into the routing table, and the route's metric is changed. If the sum of the additional metric and the original metric is greater than 16, the metric of the route is 16.
3.     Specify an inbound additional routing metric.
rip metricin [ route-policy route-policy-name ] value
By default, the additional metric of an inbound route is 0.
4.     Specify an outbound additional routing metric.
rip metricout [ route-policy route-policy-name ] value
By default, the additional metric of an outbound route is 1.
Perform this task to summarize contiguous subnets into a summary network and sends the network to neighbors. The smallest metric among all summarized routes is used as the metric of the summary route.
You can use the following methods to summarize routes in RIPv2:
·     Automatic summarization—Configure RIPv2 to generate a natural network for contiguous subnets. For example, suppose there are three subnet routes 10.1.1.0/24, 10.1.2.0/24, and 10.1.3.0/24. Automatic summarization automatically creates and advertises a summary route 10.0.0.0/8 instead of the more specific routes.
·     Manual summarization—Manually configure a summary route. RIPv2 advertises the summary route rather than more specific routes. For example, suppose contiguous subnets routes 10.1.1.0/24, 10.1.2.0/24, and 10.1.3.0/24 exist in the routing table. You can create a summary route 10.1.0.0/16 on Ten-GigabitEthernet 3/1/1 to advertise the summary route instead of the more specific routes. By default, natural masks are used to advertise summary routes. To manually configure a summary route on an interface, you must first disable RIPv2 automatic route summarization.
In certain cases, route summarization might result in incorrect route calculation because it disables subnet route advertisement. If the routing table contains non-contiguous subnets, disable automatic route summarization so that RIPv2 can advertise subnet routes and host routes for correct route calculation.
As shown in Figure 1, RIPv2 is enabled on all interfaces on Device A, Device B, and Device C. If automatic route summarization is enabled (default setting), both Device A and Device C will send 10.1.0.0/8 to Device B. To ensure correct route calculation on Device B based on subnets 10.1.0.0/16 and 10.2.0.0/16, disable RIPv2 automatic route summarization.
Figure 1 Disabling RIPv2 automatic route summarization
To prevent loops caused by route summarization, create a black hole route by specifying interface NULL 0 as the output interface of the summary route. Packets that match the black hole route are dropped.
Enabling RIPv2 automatic route summarization
2.     Enter RIP view.
3.     Enable RIPv2 automatic route summarization.
summary
By default, RIPv2 automatic route summarization is enabled.
If subnets in the routing table are not contiguous, disable automatic route summarization to advertise more specific routes.
Advertising a summary route
2.     Enter RIP view.
3.     Disable RIPv2 automatic route summarization.
undo summary
4.     Return to system view.
5.     Enter interface view.
6.     Configure a summary route.
rip summary-address ip-address { mask-length | mask }
By default, no summary route is configured.
This task disables RIPv2 from receiving host routes from the same network to save network resources. This feature does not apply to RIPv1.
2.     Enter RIP view.
3.     Disable RIP from receiving host routes.
undo host-route
By default, RIP receives host routes.
You can advertise a default route on all RIP interfaces in RIP view or on a specific RIP interface in interface view. The interface view setting takes precedence over the RIP view settings.
To disable an interface from advertising a default route, use the rip default-route no-originate command on the interface.
The router enabled to advertise a default route does not accept default routes from RIP neighbors.
2.     Advertise a default route.
¡     Execute the following commands in sequence to configure RIP to advertise a default route:
default-route { only | originate } [ cost cost-value | route-policy route-policy-name ] *
By default, RIP does not advertise a default route.
¡     Execute the following commands in sequence to configure a RIP interface to advertise a default route:
rip default-route { { only | originate } [ cost cost-value | route-policy route-policy-name ] * | no-originate }
By default, a RIP interface can advertise a default route if the RIP process is enabled to advertise a default route.
This task allows you to create a policy to filter received or redistributed routes that match specific criteria such as an ACL or IP prefix list.
2.     Enter RIP view.
3.     Configure the filtering of received routes.
filter-policy { ipv4-acl-number | gateway prefix-list-name | prefix-list prefix-list-name [ gateway prefix-list-name ] } import [ interface-type interface-number ]
By default, the filtering of received routes is not configured.
This command filters received routes. Filtered routes are not installed into the routing table or advertised to neighbors.
4.     Configure the filtering of redistributed routes.
filter-policy { ipv4-acl-number | prefix-list prefix-list-name } export [ interface-type interface-number | bgp | direct | eigrp [ eigrp-as ] | [ isis | ospf | rip ] [ process-id ] | static | unr ]
By default, the filtering of redistributed routes is not configured.
This command filters redistributed routes, including routes redistributed with the import-route command.
If multiple IGPs find routes to the same destination, the route found by the IGP that has the highest priority is selected as the optimal route. Perform this task to assign a preference to RIP. The smaller the preference value, the higher the priority.
2.     Enter RIP view.
3.     Set a preference for RIP.
The default preference for RIP is 100.
Perform this task to configure RIP to redistribute routes from other routing protocols, including OSPF, IS-IS, BGP, static, and direct.
In addition, you can enable RIP to redistribute user network routes, which are generated by access devices for online users.
2.     Enter RIP view.
3.     Configure route redistribution.
¡     Redistribute BGP routes.
import-route bgp [ as-number ] [ allow-ibgp ] [ cost cost-value | route-policy route-policy-name | tag tag ] *
¡     Redistribute direct routes, static routes, or user network routes.
import-route { direct | static | unr } [ cost cost-value | route-policy route-policy-name | tag tag ] *
¡     Redistribute EIGRP routes.
import-route eigrp [ eigrp-as | all-as ] [ allow-direct | cost cost-value | route-policy route-policy-name | tag tag ] *
¡     Redistribute IS-IS routes, OSPF routes, or routes from other RIP processes.
import-route { isis | ospf | rip } [ process-id | all-processes ] [ allow-direct | cost cost-value | route-policy route-policy-name | tag tag ] *
By default, RIP does not redistribute routes.
This command can redistribute only active routes. To view active routes, use the display ip routing-table protocol command.
4.     (Optional.) Set a default cost for redistributed routes.
default cost cost-value
The default cost for redistributed routes is 0.
Setting RIP timers
You can change the RIP network convergence speed by adjusting the following RIP timers:
·     Update timer—Specifies the interval between route updates.
·     Timeout timer—Specifies the route aging time. If no update for a route is received within the aging time, the metric of the route is set to 16.
·     Suppress timer—Specifies how long a RIP route stays in suppressed state. When the metric of a route is 16, the route enters the suppressed state. A suppressed route can be replaced by an updated route that is received from the same neighbor before the suppress timer expires and has a metric less than 16.
·     Garbage-collect timer—Specifies the interval from when the metric of a route becomes 16 to when it is deleted from the routing table. RIP advertises the route with a metric of 16. If no update is announced for that route before the garbage-collect timer expires, the route is deleted from the routing table.
To avoid unnecessary traffic or route flapping, configure identical RIP timer settings on RIP routers.
2.     Enter RIP view.
3.     Set RIP timers.
The default settings are as follows:
¡     The garbage-collect timer is 120 seconds.
¡     The suppress timer is 120 seconds.
¡     The timeout timer is 180 seconds.
¡     The update timer is 30 seconds.
The split horizon and poison reverse features can prevent routing loops.
·     Split horizon disables RIP from sending routes through the interface where the routes were learned to prevent routing loops between adjacent routers.
·     Poison reverse allows RIP to send routes through the interface where the routes were learned. The metric of these routes is always set to 16 (unreachable) to avoid routing loops between neighbors.
If both split horizon and poison reverse are configured, only the poison reverse feature takes effect.
3.     Enable split horizon.
rip split-horizon
By default, split horizon is enabled.
Enabling poison reverse
3.     Enable poison reverse.
rip poison-reverse
By default, poison reverse is disabled.
Perform this task to use ECMP routes to share the load of the RIP network.
2.     Enter RIP view.
3.     Set the maximum number of RIP ECMP routes.
maximum load-balancing number
By default, the maximum number of RIP ECMP routes is 64.
Perform this task to avoid network overhead and reduce system resource consumption caused by frequent RIP triggered updates.
You can use the timer triggered command to set the maximum interval, minimum interval, and incremental interval for sending RIP triggered updates.
·     For a stable network, the minimum-interval is used.
·     If network changes become frequent, the incremental interval incremental-interval is used to extend the triggered update sending interval until the maximum-interval is reached.
2.     Enter RIP view.
3.     Set the RIP triggered update interval.
¡     The maximum interval is 5 seconds.
¡     The minimum interval is 50 milliseconds.
¡     The incremental interval is 200 milliseconds.
Perform this task to set the interval for sending RIP packets and the maximum number of RIP packets that can be sent at each interval. This feature can avoid excessive RIP packets from affecting system performance and consuming too much bandwidth.
2.     Configure the RIP packet sending rate.
¡     Execute the following commands in sequence to configure the RIP packet sending rate for all interfaces:
output-delay time count count
By default, an interface sends up to three RIP packets every 20 milliseconds.
¡     Execute the following commands in sequence to configure the RIP packet sending rate for an interface:
rip output-delay time count count
By default, the interface uses the RIP packet sending rate configured for the RIP process that the interface runs.
CAUTION
CAUTION:
The supported maximum length of RIP packets varies by vendor. Use this feature with caution to avoid compatibility issues.
The packet length of RIP packets determines how many routes can be carried in a RIP packet. Set the maximum length of RIP packets to make good use of link bandwidth.
When authentication is enabled, follow these guidelines to ensure packet forwarding:
·     For simple authentication, the maximum length of RIP packets must be no less than 52 bytes.
·     For MD5 authentication (with packet format defined in RFC 2453), the maximum length of RIP packets must be no less than 56 bytes.
·     For MD5 authentication (with packet format defined in RFC 2082), the maximum length of RIP packets must be no less than 72 bytes.
3.     Set the maximum length of RIP packets.
rip max-packet-length value
By default, the maximum length of RIP packets is 512 bytes.
The DSCP value specifies the precedence of outgoing packets.
2.     Enter RIP view.
3.     Set the DSCP value for outgoing RIP packets.
dscp dscp-value
By default, the DSCP value for outgoing RIP packets is 48.
You can use network management software to manage the RIP process to which MIB is bound.
2.     Bind MIB to a RIP process.
rip mib-binding process-id
By default, MIB is bound to the RIP process with the smallest process ID.
Configuring RIP GR
GR ensures forwarding continuity when a routing protocol restarts or an active/standby switchover occurs.
Two routers are required to complete a GR process. The following are router roles in a GR process:
·     GR restarter—Graceful restarting router. It must have GR capability.
·     GR helper—A neighbor of the GR restarter. It helps the GR restarter to complete the GR process.
After RIP restarts on a router, the router must learn RIP routes again and update its FIB table, which causes network disconnections and route reconvergence.
With the GR feature, the restarting router (known as the GR restarter) can notify the event to its GR capable neighbors. GR capable neighbors (known as GR helpers) maintain their adjacencies with the router within a GR interval. During this process, the FIB table of the router does not change. After the restart, the router contacts its neighbors to retrieve its FIB.
By default, a RIP-enabled device acts as the GR helper. Perform this task on the GR restarter.
2.     Enter RIP view.
3.     Enable GR for RIP.
graceful-restart
By default, RIP GR is disabled.
4.     (Optional.) Set the GR interval.
By default, the GR interval is 60 seconds.
About BFD for RIP
RIP detects route failures by periodically sending requests. If it receives no response for a route within a certain time, RIP considers the route unreachable. To speed up convergence, perform this task to enable BFD for RIP. For more information about BFD, see High Availability Configuration Guide.
RIP supports the following BFD detection modes:
·     Single-hop echo detection—Detection mode for a directly connected neighbor. In this mode, a BFD session is established only when the directly connected neighbor has route information to send.
·     Single-hop echo detection for a specific destination—Detection mode for a directly connected neighbor. In this mode, a BFD session is established to the specified RIP neighbor when RIP is enabled on the local interface. When BFD detects a unidirectional link, the local device will not receive or send any RIP packets through the interface to improve convergence speed. When the link recovers, the interface can send RIP packets again.
·     Bidirectional control detection—Detection mode for both directly and indirectly connected neighbors. In this mode, a BFD session is established only when both ends have routes to send and BFD is enabled on the receiving interface.
The bfd all-interfaces enable command enables BFD for RIP on all interfaces of a RIP process. If the link to one of the interfaces becomes unstable, the BFD session might flap on the interface. This will affect the stability of the network. To resolve this problem, use the rip bfd disable command to disable BFD on that interface.
2.     (Optional.) Configure the source IP address of BFD echo packets.
bfd echo-source-ip ip-address
By default, the source IP address of BFD echo packets is not configured.
As a best practice, configure this command and do not specify a source IP address on the same network segment as any local interfaces. This can avoid network congestion caused by a large number of ICMP redirect packets sent from the peer.
For more information about this command, see High Availability Command Reference.
3.     Enable BFD for RIP.
¡     Execute the following commands in sequence to enable BFD on all interfaces of a RIP process:
¡     Execute the following commands in sequence to enable BFD on an interface:
rip bfd enable
By default, BFD for RIP is disabled.
This feature applies only to RIP neighbors that are directly connected.
By default, no source IP address is configured for BFD echo packets.
3.     Enter interface view.
4.     Enable BFD for RIP.
rip bfd enable destination ip-address
2.     Enter RIP view.
peer ip-address
Because the undo peer command does not remove the neighbor relationship immediately, executing the command cannot bring down the BFD session immediately.
rip bfd enable
2.     Enable BFD for RIP.
bfd all-interfaces enable ctrl
rip bfd enable ctrl
Configuring RIP FRR
About RIP FRR
A link or router failure on a path can cause packet loss and even routing loop until RIP completes routing convergence based on the new network topology. FRR enables fast rerouting to minimize the impact of link or node failures.
Figure 2 Network diagram for RIP FRR
As shown in Figure 2, configure FRR on Router B by using a routing policy to specify a backup next hop. When the primary link fails, RIP directs packets to the backup next hop. At the same time, RIP calculates the shortest path based on the new network topology, and forwards packets over that path after network convergence.
RIP FRR takes effect only for RIP routes learned from directly connected neighbors.
RIP FRR is available only when the state of primary link (with Layer 3 interfaces staying up) changes from bidirectional to unidirectional or down.
Equal-cost routes do not support RIP FRR.
Enabling RIP FRR
2.     Configure a routing policy for FRR.
You must specify a next hop by using the apply fast-reroute backup-interface command in the routing policy.
For more information about routing policy configuration, see "Configuring routing policies."
3.     Enter RIP view.
4.     Enable RIP FRR.
By default, RIP FRR is disabled.
By default, RIP FRR does not use BFD to detect primary link failures. For quicker RIP FRR, use BFD bidirectional control detection on the primary link of redundant links to detect link failure. BFD bidirectional control detection must be configured on both ends of the link to take effect.
3.     Enable BFD bidirectional control detection for RIP FRR.
rip primary-path-detect bfd ctrl
By default, BFD bidirectional control detection for RIP FRR is disabled.
By default, RIP FRR does not use BFD to detect primary link failures. For quicker RIP FRR, use BFD single-hop echo detection on the primary link of redundant links to detect link failure.
4.     Enable BFD for RIP FRR.
rip primary-path-detect bfd echo
By default, BFD for RIP FRR is disabled.
Some fields in the RIPv1 message must be set to zero. These fields are called "zero fields." You can enable zero field check for incoming RIPv1 messages. If a zero field of a message contains a non-zero value, RIP does not process the message. If you are certain that all messages are trustworthy, disable zero field check to save CPU resources.
This feature does not apply to RIPv2 packets, because they have no zero fields.
2.     Enter RIP view.
3.     Enable zero field check for incoming RIPv1 messages.
checkzero
By default, zero field check is disabled for incoming RIPv1 messages.
Perform this task to enable source IP address check for incoming RIP updates.
·     Upon receiving a message on an Ethernet interface, RIP compares the source IP address of the message with the IP address of the interface. If they are not in the same network segment, RIP discards the message.
·     Upon receiving a message on a PPP interface, RIP checks whether the source address of the message is the IP address of the peer interface. If not, RIP discards the message.
2.     Enter RIP view.
3.     Enable source IP address check for incoming RIP messages.
By default, source IP address check is disabled for incoming RIP updates.
Perform this task to enable authentication on RIPv2 messages.
RIPv2 supports simple authentication, MD5 authentication, and keychain authentication.
·     Simple authentication—As a best practice, do not configure the simple authentication mode in network requirements with high security requirements, because the passwords are sent with authentication packets.
·     MD5 authentication—Uses MD5 passwords to perform packet encryption and decryption. This authentication method is securer than the simple authentication mode.
·     Keychain authentication—Uses keychains to perform dynamic authentication. For more information about keychains, see keychain configuration in Security Configuration Guide.
3.     Configure RIPv2 authentication.
rip authentication-mode { keychain keychain-name { rfc2453 | rfc4822 } | md5 { rfc2082 { cipher | plain } string key-id | rfc2453 { cipher | plain } string } | simple { cipher | plain } string }
By default, RIPv2 authentication is not configured.
RIPv1 does not support authentication. Although you can specify an authentication mode for RIPv1 in interface view, the configuration does not take effect.
For information about the keychain feature, see Security Configuration Guide.
Execute display commands in any view and execute reset commands in user view.
Display RIP current status and configuration information.
display rip [ process-id ]
Display active routes in the RIP database.
display rip process-id database [ ip-address { mask-length | mask } ]
Display RIP GR information.
display rip [ process-id ] graceful-restart
Display RIP interface information.
display rip process-id interface [ interface-type interface-number ]
Display neighbor information for a RIP process.
display rip process-id neighbor [ interface-type interface-number ]
Display RIP NSR information.
display rip [ process-id ] non-stop-routing
Display routing information for a RIP process.
display rip process-id route [ ip-address { mask-length | mask } [ verbose ] | peer ip-address | statistics ]
Reset a RIP process.
reset rip process-id process
Clear the statistics for a RIP process.
reset rip process-id statistics
As shown in Figure 3, enable RIPv2 on all interfaces on Router A and Router B. Configure Router B to not advertise route 10.2.1.0/24 to Router A, and to accept only route 2.1.1.0/24 from Router A.
Figure 3 Network diagram
1.     Configure IP addresses for the interfaces. (Details not shown.)
2.     Enable RIP.
# Enable RIP on the specified networks on Router A.
[RouterA] rip
[RouterA-rip-1] network 1.0.0.0
[RouterA-rip-1] network 2.0.0.0
[RouterA-rip-1] network 3.0.0.0
[RouterA-rip-1] quit
# Enable RIP on the specified interfaces on Router B.
<RouterB> system-view
[RouterB] rip
[RouterB-rip-1] quit
[RouterB] interface ten-gigabitethernet 3/1/1
[RouterB-Ten-GigabitEthernet3/1/1] rip 1 enable
[RouterB-Ten-GigabitEthernet3/1/1] quit
[RouterB] interface ten-gigabitethernet 3/1/2
[RouterB-Ten-GigabitEthernet3/1/2] rip 1 enable
[RouterB-Ten-GigabitEthernet3/1/2] quit
[RouterB] interface ten-gigabitethernet 3/1/3
[RouterB-Ten-GigabitEthernet3/1/3] rip 1 enable
[RouterB-Ten-GigabitEthernet3/1/3] quit
# Display the RIP routing table on Router A.
[RouterA] display rip 1 route
              D - Direct, O - Optimal, F - Flush to RIB
 Peer 1.1.1.2 on Ten-GigabitEthernet3/1/1
      Destination/Mask        Nexthop           Cost    Tag     Flags   Sec
      10.0.0.0/8              1.1.1.2           1       0       RAOF    9
 Local route
      1.1.1.0/24              0.0.0.0           0       0       RDOF    -
      2.1.1.0/24              0.0.0.0           0       0       RDOF    -
      3.1.1.0/24              0.0.0.0           0       0       RDOF    -
The output shows that RIPv1 uses natural masks to advertise routing information.
3.     Configure a RIP version:
# Configure RIPv2 on Router A.
[RouterA] rip
[RouterA-rip-1] version 2
[RouterA-rip-1] undo summary
# Configure RIPv2 on Router B.
[RouterB] rip
[RouterB-rip-1] version 2
[RouterB-rip-1] undo summary
      10.0.0.0/8              1.1.1.2           1       0       RAOF    87
      10.1.1.0/24             1.1.1.2           1       0       RAOF    19
      10.2.1.0/24             1.1.1.2           1       0       RAOF    19
 Local route
The output shows that RIPv2 uses classless subnet masks.
After RIPv2 is configured, RIPv1 routes might still exist in the routing table until they are aged out.
# Display the RIP routing table on Router B.
[RouterB] display rip 1 route
 Peer 1.1.1.1 on Ten-GigabitEthernet3/1/1
      2.1.1.0/24              1.1.1.1           1       0       RAOF    19
      3.1.1.0/24              1.1.1.1           1       0       RAOF    19
 Local route
      10.1.1.0/24             0.0.0.0           0       0       RDOF    -
      10.2.1.0/24             0.0.0.0           0       0       RDOF    -
4.     Configure RIP route filtering:
# Use IP prefix lists on Router B to filter received and redistributed routes.
[RouterB] ip prefix-list aaa index 10 permit 2.1.1.0 24
[RouterB] ip prefix-list bbb index 10 deny 10.2.1.0 24
[RouterB] ip prefix-list bbb index 11 permit 0.0.0.0 0 less-equal 32
[RouterB] rip 1
[RouterB-rip-1] filter-policy prefix-list aaa import
[RouterB-rip-1] filter-policy prefix-list bbb export
 Local route
 Local route
As shown in Figure 4, Router B communicates with Router A through RIP 100 and with Router C through RIP 200.
Configure RIP 200 to redistribute direct routes and routes from RIP 100 on Router B so Router C can learn routes destined for 10.2.1.0/24 and 11.1.1.0/24. Router A cannot learn routes destined for 12.3.1.0/24 and 16.4.1.0/24.
Figure 4 Network diagram
2.     Configure basic RIP settings:
# Enable RIP 100, and configure RIPv2 on Router A.
[RouterA] rip 100
[RouterA-rip-100] network 10.0.0.0
[RouterA-rip-100] network 11.0.0.0
[RouterA-rip-100] version 2
[RouterA-rip-100] undo summary
[RouterA-rip-100] quit
# Enable RIP 100 and RIP 200, and configure RIPv2 on Router B.
[RouterB] rip 100
[RouterB-rip-100] network 11.0.0.0
[RouterB-rip-100] version 2
[RouterB-rip-100] undo summary
[RouterB-rip-100] quit
[RouterB] rip 200
[RouterB-rip-200] network 12.0.0.0
[RouterB-rip-200] version 2
[RouterB-rip-200] undo summary
[RouterB-rip-200] quit
# Enable RIP 200, and configure RIPv2 on Router C.
<RouterC> system-view
[RouterC] rip 200
[RouterC-rip-200] network 12.0.0.0
[RouterC-rip-200] network 16.0.0.0
[RouterC-rip-200] version 2
[RouterC-rip-200] undo summary
[RouterC-rip-200] quit
# Display the IP routing table on Router C.
[RouterC] display ip routing-table
Destinations : 14        Routes : 14
0.0.0.0/32         Direct  0   0           127.0.0.1       InLoop0
12.3.1.0/24        Direct  0   0           12.3.1.2        XGE3/1/1
12.3.1.0/32        Direct  0   0           12.3.1.2        XGE3/1/1
12.3.1.2/32        Direct  0   0           127.0.0.1       InLoop0
12.3.1.255/32      Direct  0   0           12.3.1.2        XGE3/1/1
16.4.1.0/24        Direct  0   0           16.4.1.1        XGE3/1/2
16.4.1.0/32        Direct  0   0           16.4.1.1        XGE3/1/2
16.4.1.1/32        Direct  0   0           127.0.0.1       InLoop0
16.4.1.255/32      Direct  0   0           16.4.1.1        XGE3/1/2
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
127.0.0.1/32       Direct  0   0           127.0.0.1       InLoop0
127.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
255.255.255.255/32 Direct 0    0           127.0.0.1       InLoop0
3.     Configure RIP route redistribution:
# Configure RIP 200 to redistribute direct routes and routes from RIP 100 on Router B.
[RouterB] rip 200
[RouterB-rip-200] import-route rip 100
[RouterB-rip-200] import-route direct
Destinations : 15        Routes : 15
10.2.1.0/24         RIP    100  1            12.3.1.1        XGE3/1/1
11.1.1.0/24         RIP    100  1            12.3.1.1        XGE3/1/1
As shown in Figure 5, run RIPv2 on all the interfaces of Router A, Router B, Router C, Router D, and Router E.
Router A has two links to Router D. The link from Router B to Router D is more stable than that from Router C to Router D. Configure an additional metric for RIP routes received from Ten-GigabitEthernet 3/1/2 on Router A so Router A prefers route 1.1.5.0/24 learned from Router B.
Figure 5 Network diagram
1.     Configure IP addresses for the the interfaces. (Details not shown.)
# Configure Router A.
[RouterA] rip
# Configure Router B.
[RouterB] rip
[RouterB-rip-1] network 1.0.0.0
# Configure Router C.
[RouterC] rip
[RouterC-rip-1] network 1.0.0.0
[RouterC-rip-1] version 2
[RouterC-rip-1] undo summary
# Configure Router D.
<RouterD> system-view
[RouterD] rip
[RouterD-rip-1] network 1.0.0.0
[RouterD-rip-1] version 2
[RouterD-rip-1] undo summary
# Configure Router E.
<RouterE> system-view
[RouterE] rip
[RouterE-rip-1] network 1.0.0.0
[RouterE-rip-1] version 2
[RouterE-rip-1] undo summary
# Display all active routes in the RIP database on Router A.
[RouterA] display rip 1 database
   1.0.0.0/8, auto-summary
       1.1.1.0/24, cost 0, nexthop 1.1.1.1, RIP-interface
       1.1.2.0/24, cost 0, nexthop 1.1.2.1, RIP-interface
       1.1.3.0/24, cost 1, nexthop 1.1.1.2
       1.1.4.0/24, cost 1, nexthop 1.1.2.2
       1.1.5.0/24, cost 2, nexthop 1.1.1.2
       1.1.5.0/24, cost 2, nexthop 1.1.2.2
The output shows two RIP routes destined for network 1.1.5.0/24. The next hops of the routes are Router B (1.1.1.2) and Router C (1.1.2.2). The cost of the routes is 2.
3.     Configure an additional metric for a RIP interface:
# Configure an inbound additional metric of 3 for RIP-enabled interface Ten-GigabitEthernet 3/1/2.
[RouterA] interface ten-gigabitethernet 3/1/2
[RouterA-Ten-GigabitEthernet3/1/2] rip metricin 3
[RouterA-Ten-GigabitEthernet3/1/2] quit
[RouterA-Ten-GigabitEthernet3/1/2] display rip 1 database
       1.1.4.0/24, cost 2, nexthop 1.1.1.2
The output shows that only one RIP route reaches network 1.1.5.0/24, with the next hop as Router B (1.1.1.2) and a cost of 2.
As shown in Figure 6, Router A and Router B run OSPF, Router D runs RIP, and Router C runs OSPF and RIP.
·     Configure RIP to redistribute OSPF routes on Router C so Router D can learn routes destined for networks 10.1.1.0/24, 10.2.1.0/24, 10.5.1.0/24, and 10.6.1.0/24.
·     To reduce the routing table size of Router D, configure route summarization on Router C to advertise only the summary route 10.0.0.0/8 to Router D.
Figure 6 Network diagram
2.     Configure basic OSPF settings:
[RouterA] ospf
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
[RouterA-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[RouterB] ospf
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 10.6.1.0 0.0.0.255
[RouterC] ospf
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[RouterC-ospf-1] quit
3.     Configure basic RIP settings:
[RouterC] rip 1
[RouterC-rip-1] network 11.3.1.0
[RouterD] rip 1
[RouterD-rip-1] network 11.0.0.0
[RouterD-rip-1] quit
# Configure RIP to redistribute routes from OSPF process 1 and direct routes on Router C.
[RouterC-rip-1] import-route direct
[RouterC-rip-1] import-route ospf 1
[RouterC-rip-1] quit
# Display the IP routing table on Router D.
[RouterD] display ip routing-table
10.1.1.0/24         RIP    100  1            11.3.1.1        XGE3/1/1
10.2.1.0/24         RIP    100  1            11.3.1.1        XGE3/1/1
10.5.1.0/24         RIP    100  1            11.3.1.1        XGE3/1/1
10.6.1.0/24         RIP    100  1            11.3.1.1        XGE3/1/1
11.3.1.0/24         Direct 0    0            11.3.1.2        XGE3/1/1
11.3.1.0/32         Direct 0    0            11.3.1.2        XGE3/1/1
11.3.1.2/32         Direct 0    0            127.0.0.1       InLoop0
11.4.1.0/24         Direct 0    0            11.4.1.2        XGE3/1/2
11.4.1.0/32         Direct 0    0            11.4.1.2        XGE3/1/2
11.4.1.2/32         Direct 0    0            127.0.0.1       InLoop0
4.     Configure route summarization:
# Configure route summarization on Router C to advertise only the summary route 10.0.0.0/8.
[RouterC] interface ten-gigabitethernet 3/1/2
[RouterC-Ten-GigabitEthernet3/1/2] rip summary-address 10.0.0.0 8
Destinations : 12        Routes : 12
10.0.0.0/8          RIP    100  1            11.3.1.1        XGE3/1/1
As shown in Figure 7, Router A, Router B, and Router C run RIPv2.
·     Enable GR on Router A. Router A acts as the GR restarter.
·     Router B and Router C act as GR helpers to synchronize their routing tables with Router A by using GR.
Figure 7 Network diagram
1.     Configure IP addresses and subnet masks for the interfaces on the routers. (Details not shown.)
2.     Configure RIPv2 on the routers to ensure the following: (Details not shown.)
¡     Router A, Router B, and Router C can communicate with each other at Layer 3.
¡     Dynamic route update can be implemented among them with RIPv2.
3.     Enable RIP GR on Router A.
[RouterA] rip
[RouterA-rip-1] graceful-restart
# Restart RIP or trigger an active/standby process switchover, and then display GR status on Router A.
[RouterA] display rip graceful-restart
 RIP process: 1
 Graceful Restart capability     : Enabled
 Current GR state                : Normal
 Graceful Restart period         : 60  seconds
 Graceful Restart remaining time : 0   seconds
As shown in Figure 8, Ten-GigabitEthernet 3/1/1 of Router A and Router C runs RIP process 1. Ten-GigabitEthernet 3/1/2 of Router A runs RIP process 2. Ten-GigabitEthernet 3/1/2 of Router C and Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 of Router B run RIP process 1.
·     Configure a static route destined for 100.1.1.1/24 and enable static route redistribution into RIP on Router C. This allows Router A to learn two routes destined for 100.1.1.1/24 through Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 respectively, and uses the one through Ten-GigabitEthernet 3/1/1.
·     Enable BFD for RIP on Ten-GigabitEthernet 3/1/1 of Router A. When the link over Ten-GigabitEthernet 3/1/1 fails, BFD can quickly detect the failure and notify RIP. RIP deletes the neighbor relationship and route information learned on Ten-GigabitEthernet 3/1/1, and uses the route destined for 100.1.1.1 24 through Ten-GigabitEthernet 3/1/2.
Figure 8 Network diagram
1.     Configure basic RIP settings and enable BFD on the interfaces:
[RouterA] rip 1
[RouterA-rip-1] network 192.168.1.0
[RouterA] interface ten-gigabitethernet 3/1/1
[RouterA-Ten-GigabitEthernet3/1/1] rip bfd enable
[RouterA-Ten-GigabitEthernet3/1/1] quit
[RouterA] rip 2
[RouterA-rip-2] network 192.168.2.0
[RouterA-rip-2] quit
[RouterB] rip 1
[RouterB-rip-1] network 192.168.2.0
[RouterB-rip-1] network 192.168.3.0
[RouterC] rip 1
[RouterC-rip-1] network 192.168.1.0
[RouterC-rip-1] network 192.168.3.0
[RouterC-rip-1] import-route static
2.     Configure the BFD parameters on Ten-GigabitEthernet 3/1/1 of Router A.
[RouterA] bfd echo-source-ip 11.11.11.11
[RouterA-Ten-GigabitEthernet3/1/1] bfd min-echo-receive-interval 500
[RouterA-Ten-GigabitEthernet3/1/1] bfd detect-multiplier 7
3.     Configure a static route on Router C.
[RouterC] ip route-static 120.1.1.1 24 null 0
# Display the BFD session information on Router A.
[RouterA] display bfd session
 Total sessions: 1        Up sessions: 1        Init mode: Active
 IPv4 session working in echo mode:
 LD          SourceAddr      DestAddr        State    Holdtime    Interface
 4            192.168.1.1     192.168.1.2     Up       2000ms      XGE3/1/1
# Display RIP routes destined for 120.1.1.0/24 on Router A.
[RouterA] display ip routing-table 120.1.1.0 24
Summary count : 1
120.1.1.0/24       RIP     100 1           192.168.1.2     XGE3/1/1
The output shows that Router A communicates with Router C through Ten-GigabitEthernet 3/1/1. Then the link over Ten-GigabitEthernet 3/1/1 fails.
Summary count : 1
120.1.1.0/24       RIP     100 2           192.168.2.2     XGE3/1/2
The output shows that Router A communicates with Router C through Ten-GigabitEthernet 3/1/2.
As shown in Figure 9, Ten-GigabitEthernet 3/1/2 of Router A and Ten-GigabitEthernet 3/1/1 of Router B run RIP process 1. Ten-GigabitEthernet 3/1/2 of Router B and Router C runs RIP process 1.
·     Configure a static route destined for 100.1.1.0/24 and enable static route redistribution into RIP on both Router A and Router C. This allows Router B to learn two routes destined for 100.1.1.0/24 through Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2. The route redistributed from Router A has a smaller cost than that redistributed from Router C, so Router B uses the route through Ten-GigabitEthernet 3/1/1.
·     Enable BFD for RIP on Ten-GigabitEthernet 3/1/2 of Router A, and specify Ten-GigabitEthernet 3/1/1 of Router B as the destination. When a unidirectional link occurs between Router A and Router B, BFD can quickly detect the link failure and notify RIP. RIP then deletes the neighbor relationship and the route information learned on Ten-GigabitEthernet 3/1/2. It does not receive or send any packets on Ten-GigabitEthernet 3/1/2. When the route learned from Router A ages out, Router B uses the route destined for 100.1.1.1/24 through Ten-GigabitEthernet 3/1/2.
Figure 9 Network diagram
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Configure basic RIP settings and enable BFD on the interfaces:
[RouterA] rip 1
[RouterA-rip-1] network 192.168.2.0
[RouterA-rip-1] import-route static
[RouterA-Ten-GigabitEthernet3/1/2] rip bfd enable destination 192.168.2.2
[RouterB] rip 1
[RouterC] rip 1
[RouterC-rip-1] import-route static cost 3
3.     Configure BFD parameters on Ten-GigabitEthernet 3/1/2 of Router A.
[RouterA-Ten-GigabitEthernet3/1/2] bfd min-echo-receive-interval 500
4.     Configure static routes:
# Configure a static route on Router A.
[RouterA] ip route-static 100.1.1.0 24 null 0
# Configure a static route on Router C.
[RouterC] ip route-static 100.1.1.0 24 null 0
 3              192.168.2.1     192.168.2.2     Up       2000ms      XGE3/1/2
# Display routes destined for 100.1.1.0/24 on Router B.
[RouterB] display ip routing-table 100.1.1.0 24 verbose
Summary Count : 1
 Destination: 100.1.1.0/24
    Protocol: RIP
  Process ID: 1
   SubProtID: 0x1                       Age: 00h02m47s
  FlushedAge: 15h28m49s
        Cost: 1                  Preference: 100
       IpPre: N/A                QosLocalID: N/A
         Tag: 0                       State: Active Adv
   OrigTblID: 0x0                   OrigVrf: default-vrf
     TableID: 0x2                    OrigAs: 0
       NibID: 0x12000002             LastAs: 0
      AttrID: 0xffffffff
    BkAttrID: 0xffffffff           Neighbor: 192.168.2.1
       Flags: 0x1008c           OrigNextHop: 192.168.2.1
       Label: NULL              RealNextHop: 192.168.2.1
     BkLabel: NULL                BkNextHop: N/A
     SRLabel: NULL                Interface: Ten-GigabitEthernet3/1/1
   BkSRLabel: NULL              BkInterface: N/A
   Tunnel ID: Invalid           IPInterface: Ten-GigabitEthernet3/1/1
 BkTunnel ID: Invalid         BkIPInterface: N/A
     InLabel: NULL           ColorInterface: N/A
    SIDIndex: NULL         BkColorInterface: N/A
    FtnIndex: 0x0           TunnelInterface: N/A
TrafficIndex: N/A         BkTunnelInterface: N/A
   Connector: N/A                    PathID: 0x0
      UserID: 0x0                SRTunnelID: Invalid
    SID Type: N/A                       NID: Invalid
    FlushNID: Invalid                 BkNID: Invalid
  BkFlushNID: Invalid             StatFlags: 0x0
         SID: N/A
       BkSID: N/A
CommBlockLen: 0                    Priority: Critical
  MemberPort: N/A
# Display routes destined for 100.1.1.0/24 on Router B when the link between Router A and Router B fails.
Summary Count : 1
    Protocol: RIP
  Process ID: 1
   SubProtID: 0x1                       Age: 00h21m23s
        Cost: 4                  Preference: 100
       NibID: 0x12000003             LastAs: 0
      AttrID: 0xffffffff
    BkAttrID: 0xffffffff           Neighbor: 192.168.3.2
       Flags: 0x1008c           OrigNextHop: 192.168.3.2
       Label: NULL              RealNextHop: 192.168.3.2
     SRLabel: NULL                Interface: Ten-GigabitEthernet3/1/2
   Tunnel ID: Invalid           IPInterface: Ten-GigabitEthernet3/1/2
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
As shown in Figure 10, Ten-GigabitEthernet 3/1/2 of Router A and Ten-GigabitEthernet 3/1/1 of Router C run RIP process 1. Ten-GigabitEthernet 3/1/1 on Router A runs RIP process 2. Ten-GigabitEthernet 3/1/2 on Router C, and Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 on Router D run RIP process 1.
·     Configure a static route destined for 100.1.1.0/24 on Router A.
·     Configure a static route destined for 101.1.1.0/24 on Router C.
·     Enable static route redistribution into RIP on Router A and Router C. This allows Router A to learn two routes destined for 100.1.1.0/24 through Ten-GigabitEthernet 3/1/2 and Ten-GigabitEthernet 3/1/1. It uses the route through Ten-GigabitEthernet 3/1/2.
·     Enable BFD for RIP on Ten-GigabitEthernet 3/1/2 of Router A and Ten-GigabitEthernet 3/1/1 of Router C.
When the link over Ten-GigabitEthernet 3/1/2 fails, BFD can quickly detect the link failure and notify RIP. RIP deletes the neighbor relationship and the route information learned on Ten-GigabitEthernet 3/1/2, and uses the route destined for 100.1.1.0/24 through Ten-GigabitEthernet 3/1/1.
Figure 10 Network diagram
Device
IP address
Router A
192.168.3.1/24
Router A
192.168.1.1/24
Router B
192.168.2.1/24
Router B
192.168.1.2/24
Router C
192.168.2.2/24
Router C
192.168.4.2/24
Router D
192.168.3.2/24
Router D
192.168.4.1/24
2.     Configure basic RIP settings and enable static route redistribution into RIP so Router A and Router C have routes to send to each other:
[RouterA] rip 1
[RouterA-rip-1] network 101.1.1.0
[RouterA-rip-1] peer 192.168.2.2
[RouterA-rip-1] undo validate-source-address
[RouterA] rip 2
[RouterA-rip-2] version 2
[RouterA-rip-2] undo summary
[RouterA-rip-2] network 192.168.3.0
[RouterC] rip 1
[RouterC-rip-1] network 192.168.2.0
[RouterC-rip-1] network 192.168.4.0
[RouterC-rip-1] network 100.1.1.0
[RouterC-rip-1] peer 192.168.1.1
[RouterC-rip-1] undo validate-source-address
[RouterC] interface ten-gigabitethernet 3/1/1
[RouterC-Ten-GigabitEthernet3/1/1] rip bfd enable
[RouterC-Ten-GigabitEthernet3/1/1] quit
[RouterD] rip 1
[RouterD-rip-1] network 192.168.3.0
[RouterD-rip-1] network 192.168.4.0
3.     Configure BFD parameters for the interfaces:
[RouterA] bfd session init-mode active
[RouterA-Ten-GigabitEthernet3/1/1] ip address 192.168.3.1 24
[RouterA-Ten-GigabitEthernet3/1/2] ip address 192.168.1.1 24
[RouterA-Ten-GigabitEthernet3/1/2] bfd min-transmit-interval 500
[RouterA-Ten-GigabitEthernet3/1/2] bfd min-receive-interval 500
[RouterA-Ten-GigabitEthernet3/1/2] bfd detect-multiplier 7
[RouterB-Ten-GigabitEthernet3/1/2] ip address 192.168.1.2 24
[RouterB-Ten-GigabitEthernet3/1/1] ip address 192.168.2.1 24
[RouterC] bfd session init-mode active
[RouterC-Ten-GigabitEthernet3/1/1] ip address 192.168.2.2 24
[RouterC-Ten-GigabitEthernet3/1/1] bfd min-transmit-interval 500
[RouterC-Ten-GigabitEthernet3/1/1] bfd min-receive-interval 500
[RouterC-Ten-GigabitEthernet3/1/1] bfd detect-multiplier 6
[RouterC-Ten-GigabitEthernet3/1/2] ip address 192.168.4.2 24
[RouterC-Ten-GigabitEthernet3/1/2] quit
[RouterD] interface ten-gigabitethernet 3/1/2
[RouterD-Ten-GigabitEthernet3/1/2] ip address 192.168.4.1 24
[RouterD-Ten-GigabitEthernet3/1/2] quit
[RouterD] interface ten-gigabitethernet 3/1/1
[RouterD-Ten-GigabitEthernet3/1/1] ip address 192.168.3.2 24
[RouterD-Ten-GigabitEthernet3/1/1] quit
# Configure a static route to Router C on Router A.
[RouterA] ip route-static 192.168.2.0 24 ten-gigabitethernet 3/1/2 192.168.1.2
# Configure a static route to Router A on Router C.
[RouterC] ip route-static 192.168.1.0 24 ten-gigabitethernet 3/1/1 192.168.2.1
 LD/RD           SourceAddr      DestAddr        State    Holdtime    Interface
 513/513         192.168.1.1     192.168.2.2     Up       1700ms      XGE3/1/2
# Display RIP routes destined for 100.1.1.0/24 learned on Router A.
[RouterA] display ip routing-table 100.1.1.0 24
Summary count : 1
100.1.1.0/24       RIP     100 1           192.168.2.2     XGE3/1/2
The output shows that Router A communicates with Router C through Ten-GigabitEthernet 3/1/2. Then the link over Ten-GigabitEthernet 3/1/2 fails.
# Display RIP routes destined for 100.1.1.0/24 on Router A.
Summary count : 1
100.1.1.0/24       RIP     100 2           192.168.3.2     XGE3/1/1
As shown in Figure 11, Router A, Router B, and Router C run RIPv2. Configure RIP FRR so that when Link A becomes unidirectional, traffic can be switched to Link B immediately.
Figure 11 Network diagram
Device
IP address
Router A
12.12.12.1/24
Router A
13.13.13.1/24
Router A
Loopback 0
1.1.1.1/32
Router B
24.24.24.4/24
Router B
13.13.13.2/24
Router B
Loopback 0
4.4.4.4/32
Router C
12.12.12.2/24
Router C
24.24.24.2/24
2.     Configure RIPv2 on the routers to make sure Router A, Router B, and Router C can communicate with each other at the network layer. (Details not shown.)
3.     Configure RIP FRR:
[RouterA] ip prefix-list abc index 10 permit 4.4.4.4 32
[RouterA] route-policy frr permit node 10
[RouterA-route-policy-frr-10] if-match ip address prefix-list abc
[RouterA-route-policy-frr-10] apply fast-reroute backup-interface ten-gigabitethernet 3/1/1 backup-nexthop 12.12.12.2
[RouterA-route-policy-frr-10] quit
[RouterA] rip 1
[RouterA-rip-1] fast-reroute route-policy frr
[RouterB] ip prefix-list abc index 10 permit 1.1.1.1 32
[RouterB] route-policy frr permit node 10
[RouterB-route-policy-frr-10] if-match ip address prefix-list abc
[RouterB-route-policy-frr-10] apply fast-reroute backup-interface ten-gigabitethernet 3/1/1 backup-nexthop 24.24.24.2
[RouterB-route-policy-frr-10] quit
[RouterB] rip 1
[RouterB-rip-1] fast-reroute route-policy frr
# Display route 4.4.4.4/32 on Router A to view the backup next hop information.
[RouterA] display ip routing-table 4.4.4.4 verbose
Summary Count : 1
 Destination: 4.4.4.4/32
    Protocol: RIP
  Process ID: 1
   SubProtID: 0x1                       Age: 04h20m37s
       NibID: 0x26000002             LastAs: 0
      AttrID: 0xffffffff
    BkAttrID: 0xffffffff           Neighbor: 13.13.13.2
       Flags: 0x1008c           OrigNextHop: 13.13.13.2
       Label: NULL              RealNextHop: 13.13.13.2
     BkLabel: NULL                BkNextHop: 12.12.12.2
 BkTunnel ID: Invalid         BkIPInterface: Ten-GigabitEthernet3/1/1
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
# Display route 1.1.1.1/32 on Router B to view the backup next hop information.
[RouterB] display ip routing-table 1.1.1.1 verbose
Summary Count : 1
 Destination: 1.1.1.1/32
    Protocol: RIP
  Process ID: 1
      AttrID: 0xffffffff
    BkAttrID: 0xffffffff           Neighbor: 13.13.13.1
       Flags: 0x1008c           OrigNextHop: 13.13.13.1
       Label: NULL              RealNextHop: 13.13.13.1
     BkLabel: NULL                BkNextHop: 24.24.24.2
         SID: N/A
       BkSID: N/A
  MemberPort: N/A
  • Become a Partner
  • Partner Resources
