07-Layer 3 - IP Routing
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10007-Layer 3 - IP Routing
09-RIPv2-MIB
09-RIPv2-MIB 52.78 KB
RIPv2-MIB
About this MIB
Use this table to obtain RIPv2 interface statistics information, interface configuration information, and neighbor information.
MIB file name
rfc1724-rip.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).rip2(23)
Scalar objects
rip2GlobalRouteChanges
Object (OID)
Access
Value range
Implementation
rip2GlobalRouteChanges (1.3.6.1.2.1.23.1.1)
read-only
Counter32
INTEGER(0..4294967295)
Number of route changes.
As per the MIB.
rip2GlobalQueries
Object (OID)
Access
Value range
Implementation
rip2GlobalQueries (1.3.6.1.2.1.23.1.2)
read-only
Counter32
Number of RIP responses.
As per the MIB.
Tabular objects
rip2IfStatTable
About this table
This table contains interface statistics information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is rip2IfStatAddress.
Object (OID)
Access
Value range
Implementation
rip2IfStatAddress (1.3.6.1.2.1.23.2.1.1)
read-only
IpAddress
OCTET STRING (4)
Interface IP address.
As per the MIB.
rip2IfStatRcvBadPackets (1.3.6.1.2.1.23.2.1.2)
read-only
Counter32
Number of received bad packets.
As per the MIB.
rip2IfStatRcvBadRoutes (1.3.6.1.2.1.23.2.1.3)
read-only
Counter32
Number of received bad routes.
As per the MIB.
rip2IfStatSentUpdates (1.3.6.1.2.1.23.2.1.4)
read-only
Counter32
Number of triggered updates sent.
As per the MIB.
rip2IfStatStatus (1.3.6.1.2.1.23.2.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Interface state.
Supports only the read operation.
rip2IfConfTable
About this table
This table contains interface configuration information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is rip2IfConfAddress.
Object (OID)
Access
Value range
Implementation
rip2IfConfAddress (1.3.6.1.2.1.23.3.1.1)
read-only
IpAddress
OCTET STRING (4)
As per the MIB.
rip2IfConfDomain (1.3.6.1.2.1.23.3.1.2)
read-create
RouteTag
OCTET STRING (2)
Route tag in the packet.
rip2IfConfAuthType (1.3.6.1.2.1.23.3.1.3)
read-create
INTEGER
noAuthentication (1),         simplePassword (2),         md5 (3)
Authentication mode.
rip2IfConfAuthKey (1.3.6.1.2.1.23.3.1.4)
read-create
OCTET STRING
OCTET STRING (0..16)
Authentication key.
rip2IfConfSend (1.3.6.1.2.1.23.3.1.5)
read-create
INTEGER
doNotSend (1),
ripVersion1 (2),
rip1Compatible (3),
ripVersion2 (4),
ripV1Demand (5),
ripV2Demand (6)
Version of sent packets.
rip2IfConfReceive (1.3.6.1.2.1.23.3.1.6)
read-create
INTEGER
rip1 (1),
rip2 (2),
rip1OrRip2 (3),
doNotRecieve (4)
Version of received packets.
rip2IfConfDefaultMetric (1.3.6.1.2.1.23.3.1.7)
read-create
INTEGER
INTEGER( 0..15 )
Default cost of redistributed routes.
rip2IfConfStatus (1.3.6.1.2.1.23.3.1.8)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Interface state.
rip2IfConfSrcAddress (1.3.6.1.2.1.23.3.1.9)
read-create
IpAddress
OCTET STRING (4)
Packet source IP address.
rip2PeerTable
About this table
This table contains neighbor information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are rip2PeerAddress and rip2PeerDomain.
Object (OID)
Access
Value range
Implementation
rip2PeerAddress (1.3.6.1.2.1.23.4.1.1)
read-only
IpAddress
OCTET STRING (4)
Neighbor IP address.
As per the MIB.
rip2PeerDomain (1.3.6.1.2.1.23.4.1.2)
read-only
RouteTag
OCTET STRING (2)
As per the MIB.
rip2PeerLastUpdate (1.3.6.1.2.1.23.4.1.3)
read-only
TimeTicks
Standard MIB values.
Time when the most recent update was received from the neighbor.
As per the MIB.
rip2PeerVersion (1.3.6.1.2.1.23.4.1.4)
read-only
INTEGER
INTEGER( 0..255 )
Version of the most recent packet received from the neighbor.
As per the MIB.
rip2PeerRcvBadPackets (1.3.6.1.2.1.23.4.1.5)
read-only
Counter32
As per the MIB.
rip2PeerRcvBadRoutes (1.3.6.1.2.1.23.4.1.6)
read-only
Counter32
As per the MIB.
