07-Layer 3 - IP Routing
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10007-Layer 3 - IP Routing
05-ISIS-MIB
05-ISIS-MIB 316.39 KB
ISIS-MIB
About this MIB
ISIS-MIB is a standard MIB implemented based on RFC4444. Use this MIB to define MIB variables on managed devices according to associated IS-IS configuration at the CLI.
MIB file name
rfc4444-isis.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).isisMIB(138)
Scalar objects
isisSysVersion
Object (OID)
Access
Value range
Implementation
isisSysVersion (1.3.6.1.2.1.138.1.1.1.1)
read-only
INTEGER
unknown(0),           one(1)
IS-IS version number.
The value is fixed at one(1).
isisSysLevelType
Object (OID)
Access
Value range
Implementation
isisSysLevelType
(1.3.6.1.2.1.138.1.1.1.2)
read-write
IsisLevel
level1(1),
level2(2),
level1and2(3)
IS level.
Supports only the read operation.
isisSysID
Object (OID)
Access
Value range
Implementation
isisSysID (1.3.6.1.2.1.138.1.1.1.3)
read-write
IsisSystemID
OCTET STRING (6)
System ID
isisSysMaxPathSplits
Object (OID)
Access
Value range
Implementation
isisSysMaxPathSplits (1.3.6.1.2.1.138.1.1.1.4)
read-write
Unsigned32
Unsigned32(1..32)
Maximum number of ECMP routes supported by IS-IS.
The value range and default value vary by device model. The object can be modified whether the value of isisSysAdminState is on(1).
isisSysMaxLSPGenInt
Object (OID)
Access
Value range
Implementation
isisSysMaxLSPGenInt (1.3.6.1.2.1.138.1.1.1.5)
read-write
Unsigned32
Unsigned32(1..65235)
Maximum LSP generation interval supported by IS-IS.
This value must be smaller than isisSysMaxAge.
This value must be greater than any isisSysLevelMinLSPGenInt value (not implemented yet).
This value must be at least 300 seconds shorter than isisSysMaxAge (not implemented yet).
isisSysPollESHelloRate
Object (OID)
Access
Value range
Implementation
isisSysPollESHelloRate (1.3.6.1.2.1.138.1.1.1.6)
read-write
IsisUnsigned16TC
Unsigned32(1..65535)
Maximum ES solicitation interval in ISH PDUs.
The value is fixed at 50.
isisSysWaitTime
Object (OID)
Access
Value range
Implementation
isisSysWaitTime (1.3.6.1.2.1.138.1.1.1.7)
read-write
IsisUnsigned16TC
Maximum time to wait for the IS to come up.
The value is fixed at 60.
isisSysAdminState
Object (OID)
Access
Value range
Implementation
isisSysAdminState (1.3.6.1.2.1.138.1.1.1.8)
read-write
IsisAdminState
INTEGER {
on(1),
off(2)
Administrative state of the IS.
isisSysL2toL1Leaking
Object (OID)
Access
Value range
Implementation
isisSysL2toL1Leaking (1.3.6.1.2.1.138.1.1.1.9)
read-write
TruthValue
true(1),
false(2)
Whether route leaking from Level-2 to Level-1 is allowed.
As per the MIB.
isisSysMaxAge
Object (OID)
Access
Value range
Implementation
isisSysMaxAge (1.3.6.1.2.1.138.1.1.1.10)
read-write
IsisUnsigned16TC
Unsigned32(350..65535)
LSP maximum age. The value must be 300 seconds longer than the maximum LSP generation interval.
The value must be larger than isisSysMaxLSPGenInt, and at least 300 seconds longer than isisSysMaxLSPGenInt.
isisSysReceiveLSPBufferSize
Object (OID)
Access
Value range
Implementation
isisSysReceiveLSPBufferSize(1.3.6.1.2.1.138.1.1.1.11)
read-write
IsisUnsigned16TC
Unsigned32(1492..16000)
LSP receiving buffer size.
Default: 1497.
isisSysProtSupported
Object (OID)
Access
Value range
Implementation
isisSysProtSupported (1.3.6.1.2.1.138.1.1.1.12)
read-only
BITS
iso8473 (0),        ipv4 (1),       ipv6 (2)
Supported protocol type.
Supports only ipv4(1) and ipv6(2).
The return value is ipv6(2) when both IPv4 and IPv6 are supported.
isisSysNotificationEnable
Object (OID)
Access
Value range
Implementation
isisSysNotificationEnable (1.3.6.1.2.1.138.1.1.1.13)
read-write
TruthValue
true(1),
false(2)
Whether IS-IS SNMP notifications is enabled.
As per the MIB.
Tabular objects
isisManAreaAddrTable
About this table
This table contains information about manually configured area addresses.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is isisManAreaAddr.
Object (OID)
Access
Value range
Implementation
isisManAreaAddr (1.3.6.1.2.1.138.1.1.2.1.1)
not-accessible
IsisOSINSAddress
OCTET STRING (0..20)
Manually configured area address.
As per the MIB.
isisManAreaAddrExistState (1.3.6.1.2.1.138.1.1.2.1.2)
read-create
RowStatus
active(1)
State of the manually configured area address.
Supports only active(1).
isisAreaAddrTable
About this table
This table contains information about reachable Level-1 area addresses.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is isisAreaAddr.
Object (OID)
Access
Value range
Implementation
isisAreaAddr
(1.3.6.1.2.1.138.1.1.3.1.1)
read-only
IsisOSINSAddress
Reachable Level-1 area address
A value is returned only when the value of isisSysLevelType is level1and2(3).
isisSummAddrTable
About this table
This table contains information about summarized addresses.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are isisSummAddressType, isisSummAddress, and isisSummAddrPrefixLen.
Object (OID)
Access
Value range
Implementation
isisSummAddressType (1.3.6.1.2.1.138.1.1.4.1.1)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Summary address type.
As per the MIB.
isisSummAddress (1.3.6.1.2.1.138.1.1.4.1.2)
not-accessible
InetAddress
OCTET STRING(0..255)
Summary address.
As per the MIB.
isisSummAddrPrefixLen (1.3.6.1.2.1.138.1.1.4.1.3)
not-accessible
InetAddressPrefixLength
Unsigned32(0..2040)
Prefix length of the summary address.
As per the MIB.
isisSummAddrExistState (1.3.6.1.2.1.138.1.1.4.1.4)
read-create
RowStatus
active(1)
State of the summary address.
Support only active(1).
isisSummAddrMetric (1.3.6.1.2.1.138.1.1.4.1.5)
read-create
IsisDefaultMetric
Unsigned32(0..63)
Metric of the summary address.
Default: 20.
isisSummAddrFullMetric (1.3.6.1.2.1.138.1.1.4.1.6)
read-create
IsisFullMetric
Unsigned32
Total metric (internal metric plus external metric) of the summary address.
Default: 20.
isisRedistributeAddrTable (not supported)
About this table
This table contains information about route leaking from Level-2 to Level-1.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are isisRedistributeAddrType, isisRedistributeAddrAddress, and isisRedistributeAddrPrefixLen.
Object (OID)
Access
Value range
Implementation
isisRedistributeAddrType (1.3.6.1.2.1.138.1.1.5.1.1)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Redistributed address type.
As per the MIB.
isisRedistributeAddrAddress (1.3.6.1.2.1.138.1.1.5.1.2)
not-accessible
InetAddress
Redistributed address.
As per the MIB.
isisRedistributeAddrPrefixLen (1.3.6.1.2.1.138.1.1.5.1.3)
not-accessible
Unsigned32(0..2040)
Prefix length of the redistributed address.
As per the MIB.
isisRedistributeAddrExistState (1.3.6.1.2.1.138.1.1.5.1.4)
read-create
RowStatus
active(1)
State of the redistributed address.
isisRouterTable
About this table
This table contains information about mappings between host names and system IDs.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are isisRouterSysID and isisRouterLevel.
Object (OID)
Access
Value range
Implementation
isisRouterSysID (1.3.6.1.2.1.138.1.1.6.1.1)
not-accessible
IsisSystemID
OCTET STRING (6)
System ID.
As per the MIB.
isisRouterLevel (1.3.6.1.2.1.138.1.1.6.1.2)
not-accessible
IsisISLevel
level1(1),
level2(2),
level1and2(3)
IS level.
As per the MIB.
isisRouterHostName (1.3.6.1.2.1.138.1.1.6.1.3)
read-only
SnmpAdminString
OCTET STRING (0..255)
Host name of the IS.
As per the MIB.
isisRouterID (1.3.6.1.2.1.138.1.1.6.1.4)
read-only
Unsigned32
Standard MIB values.
Router ID of the IS.
As per the MIB.
isisSysLevelTable
About this table
This table contains information about the specified IS level.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is isisSysLevelIndex.
Object (OID)
Access
Value range
Implementation
isisSysLevelIndex (1.3.6.1.2.1.138.1.2.1.1.1)
not-accessible
IsisISLevel
INTEGER{
area(1),
domain(2)
IS level.
As per the MIB.
isisSysLevelOrigLSPBuffSize (1.3.6.1.2.1.138.1.2.1.1.2)
read-write
IsisLSPBuffSize
Unsigned32(512..16000)
Maximum LSP size that can be generated by the specified IS level.
Default: 1497.
The value must be smaller than isisSysReceiveLSPBufferSize.
The object is modifiable whether the value of isisSysAdminState is on(1).
isisSysLevelMinLSPGenInt (1.3.6.1.2.1.138.1.2.1.1.3)
read-write
IsisUnsigned16TC
Minimum LSP generation interval of the specified IS level.
Value range: 1 to 120.
Default: 1.
The return value is an integer. When the intelligent timer is configured, if the value is smaller than 1, the return value is 1.
isisSysLevelState (1.3.6.1.2.1.138.1.2.1.1.4)
read-only
IsisLevelState
off (1)
on (2)
waiting (3)
overloaded(4)
Overload status of the specified IS level.
Supports only off(1), on(2), and overloaded(4).
isisSysLevelSetOverload (1.3.6.1.2.1.138.1.2.1.1.5)
read-write
TruthValue
true(1),
false(2)
Whether the overload status is set for the specified IS level.
As per the MIB.
isisSysLevelSetOverloadUntil (1.3.6.1.2.1.138.1.2.1.1.6)
read-write
Unsigned32
Most recent time when the specified IS level exits the overload status.
If the object is a non-zero value, the overload bit is set for this level when the isisSysAdminState variable enters "on" state (when the IS is not implemented yet).
isisSysLevelMetricStyle (1.3.6.1.2.1.138.1.2.1.1.7)
read-write
IsisMetricStyle
INTEGER{
narrow(1),
wide(2),
both(3)
Cost style of the specified IS level.
As per the MIB.
isisSysLevelSPFConsiders (1.3.6.1.2.1.138.1.2.1.1.8)
read-write
IsisMetricStyle
INTEGER{
narrow(1),
wide(2),
both(3)
Cost style used by the specified IS level during SPF calculation.
isisSysLevelTEEnabled (1.3.6.1.2.1.138.1.2.1.1.9)
read-write
TruthValue
true(1),
false(2)
Whether TE is enabled for the specified IS level.
As per the MIB.
isisCirc
About this table
This table contains interface index information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
This table has no indexes.
Object (OID)
Access
Value range
Implementation
isisNextCircIndex (1.3.6.1.2.1.138.1.3.1)
read-only
IndexIntegerNextFree
Unsigned32(0..4294967295)
Available interface index of the system.
As per the MIB.
isisCircTable
About this table
This table contains IS-IS interface information.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is isisCircIndex.
Object (OID)
Access
Value range
Implementation
isisCircIndex (1.3.6.1.2.1.138.1.3.2.1.1)
not-accessible
IndexInteger
Unsigned32(1..4294967295)
Interface index.
As per the MIB.
isisCircIfIndex (1.3.6.1.2.1.138.1.3.2.1.2)
read-create
InterfaceIndex
Integer32(1..2147483647)
Ifnet index of the interface.
isisCircAdminState (1.3.6.1.2.1.138.1.3.2.1.3)
read-create
IsisAdminState
INTEGER {
on(1),
off(2)
Administrative state of the interface.
isisCircExistState (1.3.6.1.2.1.138.1.3.2.1.4)
read-create
RowStatus
active(1)
State of the interface.
isisCircType (1.3.6.1.2.1.138.1.3.2.1.5)
read-create
INTEGER
broadcast(1),                ptToPt(2),                staticIn(3),               staticOut(4),             dA(5)
Type of the interface.
Supports only broadcast(1) and ptToPt(2).
This value is broadcast(1) on a broadcast link, and is ptToPt (2) on other types of links.
isisCircExtDomain (1.3.6.1.2.1.138.1.3.2.1.6)
read-create
TruthValue
true(1),
false(2)
Domain attribute of the interface.
The value is fixed at false(2).
isisCircLevelType (1.3.6.1.2.1.138.1.3.2.1.7)
read-create
IsisLevel
level1(1),
level2(2),
level1and2(3)
Level of the interface.
Supports only the read and write operations.
isisCircPassiveCircuit (1.3.6.1.2.1.138.1.3.2.1.8)
read-create
TruthValue
true(1),
false(2)
Whether the interface is disabled from advertising routes.
isisCircMeshGroupEnabled (1.3.6.1.2.1.138.1.3.2.1.9)
read-create
INTEGER
inactive(1),               blocked(2),               set(3)
Mesh group setting for the interface.
isisCircMeshGroup (1.3.6.1.2.1.138.1.3.2.1.10)
read-create
Unsigned32
Mesh group number.
isisCircSmallHellos (1.3.6.1.2.1.138.1.3.2.1.11)
read-create
TruthValue
true(1),
false(2)
Whether sending small hello packets is enabled.
isisCircLastUpTime (1.3.6.1.2.1.138.1.3.2.1.12)
read-only
TimeStamp
TimeTicks
Most recent up time of the interface.
As per the MIB.
isisCirc3WayEnabled (1.3.6.1.2.1.138.1.3.2.1.13)
read-create
TruthValue
true(1),
false(2)
Whether three-way handshake is enabled.
isisCircExtendedCircID (1.3.6.1.2.1.138.1.3.2.1.14)
read-create
Unsigned32
Unique interface ID during the three-way handshake process.
isisCircLevelTable
About this table
This table contains information about an interface of the specified circuit level.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are isisCircIndex and isisCircLevelIndex.
Object (OID)
Access
Value range
Implementation
isisCircLevelIndex (1.3.6.1.2.1.138.1.4.1.1.1)
not-accessible
IsisISLevel
INTEGER{
area(1),
domain(2)
Circuit level of the interface.
As per the MIB.
isisCircLevelMetric (1.3.6.1.2.1.138.1.4.1.1.2)
read-write
IsisDefaultMetric
Unsigned32(0..63)
Internal cost of the interface of the specified circuit level.
Value range: 1 to 63.
isisCircLevelWideMetric (1.3.6.1.2.1.138.1.4.1.1.3)
read-write
IsisWideMetric
Unsigned32(0..16777215)
Total cost of the interface of the specified circuit level.
Value range: 1 to 16777215.
isisCircLevelISPriority (1.3.6.1.2.1.138.1.4.1.1.4)
read-write
IsisISPriority
Unsigned32(0..127)
DIS priority for the interface of the specified circuit level.
As per the MIB.
isisCircLevelIDOctet (1.3.6.1.2.1.138.1.4.1.1.5)
read-only
Unsigned32
Unsigned32(0..255)
Circuit ID of the interface (DIS).
As per the MIB.
isisCircLevelID (1.3.6.1.2.1.138.1.4.1.1.6)
read-only
IsisCircuitID
OCTET STRING(0|7)
Unique circuit ID assigned to the interface.
The value is the isisSysID.
For a P2P circuit, the value is isisCircLevelIDOctet that is one byte long.
For a broadcast circuit, the value is a zero-length eight-byte string.
isisCircLevelDesIS (1.3.6.1.2.1.138.1.4.1.1.7)
read-only
IsisCircuitID
OCTET STRING(0|7)
LAN ID for the DIS on the interface of the specified circuit level.
As per the MIB.
isisCircLevelHelloMultiplier (1.3.6.1.2.1.138.1.4.1.1.8)
read-write
Unsigned32
Unsigned32(2..100)
IS-IS hello multiplier.
Value range: 3 to 100.
Default: 3.
isisCircLevelHelloTimer (1.3.6.1.2.1.138.1.4.1.1.9)
read-write
Unsigned32
Unsigned32(10..600000)
Hello packet sending interval.
Value range: 1000 to 255000.
Default: 10000.
When the value is divided by 1000, the decimal number will be ignored.
isisCircLevelDRHelloTimer (1.3.6.1.2.1.138.1.4.1.1.10)
read-write
Unsigned32
Unsigned32(10..120000)
Hello packet sending interval on the DIS.
Value range: 1000 to 85000.
Default: 3000.
isisCircLevelLSPThrottle (1.3.6.1.2.1.138.1.4.1.1.11)
read-write
IsisUnsigned16TC
Minimum LSP sending interval.
Value range: 1 to 1000.
Default: 33.
isisCircLevelMinLSPRetransInt (1.3.6.1.2.1.138.1.4.1.1.12)
read-write
Unsigned32
Unsigned32(1..300)
Minimum LSP retransmission interval
As per the MIB.
isisCircLevelCSNPInterval (1.3.6.1.2.1.138.1.4.1.1.13)
read-write
Unsigned32
Unsigned32(1..600)
Minimum CSNP sending interval
As per the MIB.
isisCircLevelPartSNPInterval (1.3.6.1.2.1.138.1.4.1.1.14)
read-write
Unsigned32
Unsigned32(1..120)
Minimum PSNP sending interval
The value is fixed at 2.
isisSystemCounterTable
About this table
This table contains statistics information about the specified IS level.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is isisSysStatLevel.
Object (OID)
Access
Value range
Implementation
isisSysStatLevel (1.3.6.1.2.1.138.1.5.1.1.1)
not-accessible
IsisISLevel
INTEGER{
area(1),
domain(2)
IS level.
As per the MIB.
isisSysStatCorrLSPs (1.3.6.1.2.1.138.1.5.1.1.2)
read-only
Counter32
INTEGER(0..4294967295)
Number of error LSPs.
The value is fixed at 0.
isisSysStatAuthTypeFails (1.3.6.1.2.1.138.1.5.1.1.3)
read-only
Counter32
Number of authentication type errors.
As per the MIB.
isisSysStatAuthFails (1.3.6.1.2.1.138.1.5.1.1.4)
read-only
Counter32
Number of authentication failures.
As per the MIB.
isisSysStatLSPDbaseOloads (1.3.6.1.2.1.138.1.5.1.1.5)
read-only
Counter32
Number of LSDB overload times.
As per the MIB.
isisSysStatManAddrDropFromAreas (1.3.6.1.2.1.138.1.5.1.1.6)
read-only
Counter32
Number of times the manually configured area address is deleted from the local area.
As per the MIB.
isisSysStatAttmptToExMaxSeqNums (1.3.6.1.2.1.138.1.5.1.1.7)
read-only
Counter32
Number of times the LSP sequence number exceeds the maximum sequence number.
As per the MIB.
isisSysStatSeqNumSkips (1.3.6.1.2.1.138.1.5.1.1.8)
read-only
Counter32
Number of times the LSP sequence number is not continuous.
As per the MIB.
isisSysStatOwnLSPPurges (1.3.6.1.2.1.138.1.5.1.1.9)
read-only
Counter32
Number of times the system generates LSPs with a lifetime of 0.
As per the MIB.
isisSysStatIDFieldLenMismatches (1.3.6.1.2.1.138.1.5.1.1.10)
read-only
Counter32
Number of times the system receives LSPs with ID length changes.
As per the MIB.
isisSysStatPartChanges (1.3.6.1.2.1.138.1.5.1.1.11)
read-only
Counter32
Number of area address mismatches.
As per the MIB.
isisSysStatSPFRuns (1.3.6.1.2.1.138.1.5.1.1.12)
read-only
Counter32
Number of area split events.
As per the MIB.
isisSysStatLSPErrors (1.3.6.1.2.1.138.1.5.1.1.13)
read-only
Counter32
Number of SPF calculation events.
As per the MIB.
isisCircuitCounterTable
About this table
This table contains statistics information about interfaces of the specified circuit level.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are isisCircIndex and isisCircuitType.
Object (OID)
Access
Value range
Implementation
isisCircuitType (1.3.6.1.2.1.138.1.5.2.1.1)
not-accessible
INTEGER
lanlevel1(1),  lanlevel2(2),               p2pcircuit(3)
Interface type.
As per the MIB.
isisCircAdjChanges (1.3.6.1.2.1.138.1.5.2.1.2)
read-only
Counter32
Neighbor change information.
As per the MIB.
isisCircNumAdj (1.3.6.1.2.1.138.1.5.2.1.3)
read-only
Unsigned32
Number of neighbor changes.
As per the MIB.
isisCircInitFails (1.3.6.1.2.1.138.1.5.2.1.4)
read-only
Counter32
Number of interface initialization failures.
isisCircRejAdjs (1.3.6.1.2.1.138.1.5.2.1.5)
read-only
Counter32
Number of adjacency creation failures.
As per the MIB.
isisCircIDFieldLenMismatches (1.3.6.1.2.1.138.1.5.2.1.6)
read-only
Counter32
Number of ID length changes in received IS-IS packets.
As per the MIB.
isisCircMaxAreaAddrMismatches (1.3.6.1.2.1.138.1.5.2.1.7)
read-only
Counter32
As per the MIB.
isisCircAuthTypeFails (1.3.6.1.2.1.138.1.5.2.1.8)
read-only
Counter32
As per the MIB.
isisCircAuthFails (1.3.6.1.2.1.138.1.5.2.1.9)
read-only
Counter32
Number of authentication errors of the same authentication type.
As per the MIB.
isisCircLANDesISChanges (1.3.6.1.2.1.138.1.5.2.1.10)
read-only
Counter32
Number of DIS changes.
As per the MIB.
isisPacketCounterTable
About this table
This table contains statistics information about received and sent IS-IS packets for the specified IS level.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are isisCircIndex, isisPacketCountLevel, and isisPacketCountDirection.
Object (OID)
Access
Value range
Implementation
isisPacketCountLevel (1.3.6.1.2.1.138.1.5.3.1.1)
not-accessible
IsisISLevel
INTEGER{
area(1),
domain(2)
IS level.
As per the MIB.
isisPacketCountDirection (1.3.6.1.2.1.138.1.5.3.1.2)
not-accessible
INTEGER
sending(1),     receiving(2)
Packet direction (sending or receiving).
As per the MIB.
isisPacketCountIIHello (1.3.6.1.2.1.138.1.5.3.1.3)
read-only
Counter32
Number of IS-IS packets received or sent.
As per the MIB.
isisPacketCountISHello (1.3.6.1.2.1.138.1.5.3.1.4)
read-only
Counter32
Number of hello packets received or sent.
isisPacketCountESHello (1.3.6.1.2.1.138.1.5.3.1.5)
read-only
Counter32
Number of ES packets received or sent.
isisPacketCountLSP (1.3.6.1.2.1.138.1.5.3.1.6)
read-only
Counter32
Number of LSPs received or sent.
As per the MIB.
isisPacketCountCSNP (1.3.6.1.2.1.138.1.5.3.1.7)
read-only
Counter32
Number of CSNPs received or sent.
As per the MIB.
isisPacketCountPSNP (1.3.6.1.2.1.138.1.5.3.1.8)
read-only
Counter32
Number of PSNPs received or sent.
As per the MIB.
isisPacketCountUnknown (1.3.6.1.2.1.138.1.5.3.1.9)
read-only
Counter32
Number of unknown IS-IS packets.
As per the MIB.
isisISAdjTable
About this table
This table contains neighbor information about the specified interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are isisCircIndex and isisISAdjIndex.
Object (OID)
Access
Value range
Implementation
isisISAdjIndex (1.3.6.1.2.1.138.1.6.1.1.1)
not-accessible
Unsigned32
Neighbor index.
As per the MIB.
isisISAdjState (1.3.6.1.2.1.138.1.6.1.1.2)
read-only
INTEGER
down (1),    initializing (2),
up (3),
failed(4)
Neighbor state.
Supports only down(1), initializing(2), and up(3).
isisISAdj3WayState (1.3.6.1.2.1.138.1.6.1.1.3)
read-only
INTEGER
up (0),    initializing (1),                down (2),                failed (3)
Neighbor state.
As per the MIB.
isisISAdjNeighSNPAAddress (1.3.6.1.2.1.138.1.6.1.1.4)
read-only
IsisOSINSAddress
SNPA address of the neighbor.
As per the MIB.
isisISAdjNeighSysType (1.3.6.1.2.1.138.1.6.1.1.5)
read-only
INTEGER
l1IntermediateSystem(1),     l2IntermediateSystem(2),              l1L2IntermediateSystem(3),               unknown(4)
System type of the neighbor.
Supports only l1IntermediateSystem(1), l2IntermediateSystem(2), and l1L2IntermediateSystem(3).
isisISAdjNeighSysID (1.3.6.1.2.1.138.1.6.1.1.6)
read-only
IsisSystemID
OCTET STRING (6)
System ID of the neighbor.
As per the MIB.
isisISAdjNbrExtendedCircID (1.3.6.1.2.1.138.1.6.1.1.7)
read-only
Unsigned32
Circuit ID of the neighbor learned through three-way handshake.
As per the MIB.
isisISAdjUsage (1.3.6.1.2.1.138.1.6.1.1.8)
read-only
IsisLevel
level1(1),
level2(2),
level1and2(3)
IS level.
As per the MIB.
isisISAdjHoldTimer (1.3.6.1.2.1.138.1.6.1.1.9)
read-only
IsisUnsigned16TC
Neighbor hold timer.
As per the MIB.
isisISAdjNeighPriority (1.3.6.1.2.1.138.1.6.1.1.10)
read-only
IsisISPriority
Unsigned32(0..127)
Neighbor priority.
As per the MIB.
isisISAdjLastUpTime (1.3.6.1.2.1.138.1.6.1.1.11)
read-only
TimeStamp
TimeTicks
Most recent neighbor up time.
As per the MIB.
isisISAdjAreaAddrTable
About this table
This table contains neighbor area information about the specified interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are isisCircIndex, isisISAdjIndex, and isisISAdjAreaAddrIndex.
Object (OID)
Access
Value range
Implementation
isisISAdjAreaAddrIndex (1.3.6.1.2.1.138.1.6.2.1.1)
not-accessible
Unsigned32
Neighbor area address index.
As per the MIB.
isisISAdjAreaAddress (1.3.6.1.2.1.138.1.6.2.1.2)
read-only
IsisOSINSAddress
Neighbor area address.
As per the MIB.
isisISAdjIPAddrTable
About this table
This table contains IP address information in the hello packets from the specified neighbor of an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are isisCircIndex, isisISAdjIndex, and isisISAdjIPAddrIndex.
Object (OID)
Access
Value range
Implementation
isisISAdjIPAddrIndex (1.3.6.1.2.1.138.1.6.3.1.1)
not-accessible
Unsigned32
Reachable IP address index of the neighbor.
As per the MIB.
isisISAdjIPAddrType (1.3.6.1.2.1.138.1.6.3.1.2)
read-only
InetAddressType
ipv4(1),
ipv6(2)
Reachable IP address type of the neighbor.
The local IS supports ipv6(2) only when it supports IPv6 functions.
isisISAdjIPAddrAddress (1.3.6.1.2.1.138.1.6.3.1.3)
read-only
InetAddress
Reachable IP address of the neighbor.
As per the MIB.
isisISAdjProtSuppTable
About this table
This table contains protocol information supported by the specified neighbor of an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are isisCircIndex, isisISAdjIndex, and isisISAdjProtSuppProtocol.
Object (OID)
Access
Value range
Implementation
isisISAdjProtSuppProtocol (1.3.6.1.2.1.138.1.6.4.1.1)
read-only
IsisSupportedProtocol
INTEGER{
iso8473(129),
ipV6(142),
ip(204)
Protocol type supported by the neighbor.
As per the MIB.
isisRATable (not supported)
About this table
This table contains reachable NSAP address or address prefix information.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are isisCircIndex and isisRAIndex.
Object (OID)
Access
Value range
Implementation
isisRAIndex (1.3.6.1.2.1.138.1.7.1.1.1)
not-accessible
Unsigned32
Reachable address index.
As per the MIB.
isisRAExistState (1.3.6.1.2.1.138.1.7.1.1.2)
read-create
RowStatus
active(1)
Reachable address state.
The value is fixed at active(1).
isisRAAdminState (1.3.6.1.2.1.138.1.7.1.1.3)
read-create
IsisAdminState
INTEGER {
on(1),
off(2)
Administrative state of the reachable address.
Default: on(1).
isisRAAddrPrefix (1.3.6.1.2.1.138.1.7.1.1.4)
read-create
IsisOSINSAddress
Address prefix.
As per the MIB.
isisRAMapType (1.3.6.1.2.1.138.1.7.1.1.5)
read-create
INTEGER
none (1),     explicit (2),               extractIDI (3),               extractDSP (4)
Address mapping type.
Default: none(1).
isisRAMetric (1.3.6.1.2.1.138.1.7.1.1.6)
read-create
IsisDefaultMetric
Unsigned32(0..63)
Metric value of the reachable address.
As per the MIB.
isisRAMetricType (1.3.6.1.2.1.138.1.7.1.1.7)
read-create
IsisMetricType
INTEGER{
internal(1),
external(2)
Metric type of the reachable address.
As per the MIB.
isisRASNPAAddress (1.3.6.1.2.1.138.1.7.1.1.8)
read-create
IsisOSINSAddress
Reachable SNPA address.
As per the MIB.
isisRASNPAMask (1.3.6.1.2.1.138.1.7.1.1.9)
read-create
IsisOSINSAddress
Subnet mask of the reachable SNPA address.
As per the MIB.
isisRASNPAPrefix (1.3.6.1.2.1.138.1.7.1.1.10)
read-create
IsisOSINSAddress
Prefix of the reachable SNPA address.
As per the MIB.
isisRAType (1.3.6.1.2.1.138.1.7.1.1.11)
read-create
INTEGER
manual (1), automatic (2)
Reachable address type.
As per the MIB.
isisIPRATable (not supported)
About this table
This table contains reachable IP address information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are isisSysLevelIndex, isisIPRADestType, isisIPRADest, isisIPRADestPrefixLen, and isisIPRANextHopIndex.
Object (OID)
Access
Value range
Implementation
isisIPRADestType (1.3.6.1.2.1.138.1.8.1.1.1)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Reachable IP address type (manual/automatic).
As per the MIB.
isisIPRADest (1.3.6.1.2.1.138.1.8.1.1.2)
not-accessible
InetAddress
Reachable IP address.
As per the MIB.
isisIPRADestPrefixLen (1.3.6.1.2.1.138.1.8.1.1.3)
not-accessible
Unsigned32(0..2040)
Prefix length of the reachable IP address.
As per the MIB.
isisIPRANextHopIndex (1.3.6.1.2.1.138.1.8.1.1.4)
not-accessible
Unsigned32
Next hop index of the reachable IP address.
As per the MIB.
isisIPRANextHopType (1.3.6.1.2.1.138.1.8.1.1.5)
read-create
InetAddressType
ipv4(1),
ipv6(2)
Reachable next hop IP address type.
isisIPRANextHop (1.3.6.1.2.1.138.1.8.1.1.6)
read-create
InetAddress
Reachable next hop IP address.
isisIPRAType (1.3.6.1.2.1.138.1.8.1.1.7)
read-create
INTEGER
Reachable IP address type.
The value is fixed at automatic(2).
isisIPRAExistState (1.3.6.1.2.1.138.1.8.1.1.8)
read-create
RowStatus
active(1)
Reachable IP address state.
isisIPRAAdminState (1.3.6.1.2.1.138.1.8.1.1.9)
read-create
IsisAdminState
INTEGER {
on(1),
off(2)
Administrative state of the reachable IP address.
The value is fixed at on(1).
isisIPRAMetric (1.3.6.1.2.1.138.1.8.1.1.10)
read-create
IsisDefaultMetric
Unsigned32(0..63)
Internal metric value of the reachable IP address.
Default: 0.
isisIPRAMetricType (1.3.6.1.2.1.138.1.8.1.1.11)
read-create
IsisMetricType
INTEGER{
internal(1),
external(2)
Metric type of the reachable IP address.
isisIPRAFullMetric (1.3.6.1.2.1.138.1.8.1.1.12)
read-create
IsisFullMetric
Unsigned32
Total metric value of the reachable IP address.
Default: 0.
isisIPRASNPAAddress (1.3.6.1.2.1.138.1.8.1.1.13)
read-create
IsisOSINSAddress
The value is always a zero-length string of eight bytes.
isisIPRASourceType (1.3.6.1.2.1.138.1.8.1.1.14)
read-only
INTEGER
static (1),
direct (2),
ospfv2 (3),
ospfv3 (4),
isis(5),
rip(6),
igrp(7),
eigrp(8),
bgp(9),
other(10)
Route source (protocol that discovered the route).
Supports only static(1), direct(2), ospfv2(3), ospfv3(4), isis(5), rip(6), and bgp(9).
isisLSPSummaryTable
About this table
This table contains LSP summary information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are isisLSPLevel and isisLSPID.
Object (OID)
Access
Value range
Implementation
isisLSPLevel (1.3.6.1.2.1.138.1.9.1.1.1)
not-accessible
IsisISLevel
INTEGER{
area(1),
domain(2)
LSP level.
As per the MIB.
isisLSPID (1.3.6.1.2.1.138.1.9.1.1.2)
not-accessible
IsisLinkStatePDUID
OCTET STRING (8)
LSP ID.
As per the MIB.
isisLSPSeq (1.3.6.1.2.1.138.1.9.1.1.3)
read-only
Unsigned32
LSP sequence number.
As per the MIB.
isisLSPZeroLife (1.3.6.1.2.1.138.1.9.1.1.4)
read-only
TruthValue
true(1),
false(2)
Whether the LSP is to be cleared (whether the remaining lifetime is 0).
As per the MIB.
isisLSPChecksum (1.3.6.1.2.1.138.1.9.1.1.5)
read-only
IsisUnsigned16TC
LSP checksum.
As per the MIB.
isisLSPLifetimeRemain (1.3.6.1.2.1.138.1.9.1.1.6)
read-only
IsisUnsigned16TC
Remaining lifetime of the LSP.
As per the MIB.
isisLSPPDULength (1.3.6.1.2.1.138.1.9.1.1.7)
read-only
IsisUnsigned16TC
LSP packet length.
As per the MIB.
isisLSPAttributes (1.3.6.1.2.1.138.1.9.1.1.8)
read-only
IsisUnsigned8TC
Unsigned32(0..255)
ATT bit of the LSP.
As per the MIB.
isisLSPTLVTable
About this table
This table contains LSP TLV information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are isisLSPLevel, isisLSPID, and isisLSPTLVIndex.
Object (OID)
Access
Value range
Implementation
isisLSPTLVIndex (1.3.6.1.2.1.138.1.9.2.1.1)
not-accessible
Unsigned32
TLV index in the LSP.
As per the MIB.
isisLSPTLVSeq (1.3.6.1.2.1.138.1.9.2.1.2)
read-only
Unsigned32
As per the MIB.
isisLSPTLVChecksum (1.3.6.1.2.1.138.1.9.2.1.3)
read-only
IsisUnsigned16TC
LSP TLV checksum.
As per the MIB.
isisLSPTLVType (1.3.6.1.2.1.138.1.9.2.1.4)
read-only
IsisUnsigned8TC
Unsigned32(0..255)
LSP TLV type.
As per the MIB.
isisLSPTLVLen (1.3.6.1.2.1.138.1.9.2.1.5)
read-only
IsisUnsigned8TC
Unsigned32(0..255)
LSP TLV length.
As per the MIB.
isisLSPTLVValue (1.3.6.1.2.1.138.1.9.2.1.6)
read-only
OCTET STRING
LSP TLV value.
As per the MIB.
isisNotificationEntry
About this table
This table contains SNMP notifications information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
Object (OID)
Access
Value range
Implementation
isisNotificationSysLevelIndex (1.3.6.1.2.1.138.1.10.1.1)
accessible-for-notify
IsisLevel
level1(1),
level2(2),
level1and2(3)
IS level.
As per the MIB.
isisNotificationCircIfIndex (1.3.6.1.2.1.138.1.10.1.2)
Unsigned32
Unsigned32(1..2147483647)
Interface index.
As per the MIB.
isisPduLspId (1.3.6.1.2.1.138.1.10.1.3)
IsisLinkStatePDUID
OCTET STRING (8)
String that uniquely identifies a link state PDU.
As per the MIB.
isisPduFragment (1.3.6.1.2.1.138.1.10.1.4)
IsisPDUHeader
OCTET STRING(0..64)
First 64 bytes in the PDU that triggers the notification.
As per the MIB.
isisPduFieldLen (1.3.6.1.2.1.138.1.10.1.5)
IsisUnsigned8TC
Unsigned32(0..255)
System ID length in the received PDU.
As per the MIB.
isisPduMaxAreaAddress (1.3.6.1.2.1.138.1.10.1.6)
IsisUnsigned8TC
Unsigned32(0..255)
Maximum address in the received PDU.
As per the MIB.
isisPduProtocolVersion (1.3.6.1.2.1.138.1.10.1.7)
IsisUnsigned8TC
Unsigned32(0..255)
Protocol version in the received PDU.
As per the MIB.
isisPduLspSize (1.3.6.1.2.1.138.1.10.1.8)
Unsigned32
Unsigned32(0..2147483647)
Size of the LSP that is too large to be forwarded.
As per the MIB.
isisPduOriginatingBufferSize (1.3.6.1.2.1.138.1.10.1.9)
IsisUnsigned16TC
Unsigned32(0..16000)
Peer isisSysOrigLSPBuffSize value in the TLV.
As per the MIB.
isisPduBufferSize (1.3.6.1.2.1.138.1.10.1.10)
IsisUnsigned16TC
Maximum received LSP size.
As per the MIB.
isisPduProtocolsSupported (1.3.6.1.2.1.138.1.10.1.11)
OCTET STRING
Protocol list supported by the neighbor.
As per the MIB.
isisAdjState (1.3.6.1.2.1.138.1.10.1.12)
INTEGER
down (1),                initializing (2),                up (3),                failed(4)
Adjacency state.
As per the MIB.
isisErrorOffset (1.3.6.1.2.1.138.1.10.1.13)
Unsigned32
Offset of the error TLV.
As per the MIB.
isisErrorTLVType (1.3.6.1.2.1.138.1.10.1.14)
Unsigned32
Unsigned32(0..255)
Type of the error TLV.
As per the MIB.
isisNotificationAreaAddress (1.3.6.1.2.1.138.1.10.1.15)
IsisOSINSAddress
Area address of the notification.
As per the MIB.
Notifications
isisDatabaseOverload
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.138.0.1
LSDB overload state changes.
Informational
ON
A notification sent when the system enters or exits the overload status. The number of times for generating and clearing the notifications is recorded in isisSysStatLSPDbaseOloads.
Status control
ON
CLI: Use the snmp-agent trap enable isis lsdboverload-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable isis lsdboverload-state-change command.
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.138.1.10.1.1 (isisNotificationSysLevelIndex)
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
1.3.6.1.2.1.138.1.2.1.1.4 (isisSysLevelState)
Overload state of the IS level.
No
IsisLevelState
off (1)
on (2)
waiting (3)
overloaded(4)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
isisManualAddressDrops
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.2
This notification is generated for invalid area addresses.
Error
Warning
ON
A notification sent when an assigned address is ignored during route calculation. The value of the isisNotificationAreaAddress variable represents the ignored area address.
The number of times for generating the notifications is recorded in isisSysStatManAddrDropFromAreas.
The agent must throttle the generation of consecutive isisManualAddressDrops notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
Status control
ON
CLI: Use the snmp-agent trap enable isis manual-address-drop command.
OFF
CLI: Use the undo snmp-agent trap enable isis manual-address-drop command.
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.138.1.10.1.15 (isisNotificationAreaAddress)
Manually configured area addresses that have been dropped.
No
IsisOSINSAddress
Recommended action
To resolve the issue:
1.     Reduce the number of invalid or unused area addresses.
2.     If the issue persists, contact H3C Support.
isisCorruptedLSPDetected
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.3
LSP errors.
Informational
ON
A notification sent when an LSP stored in the memory is damaged. The number of times for generating the notifications is recorded in isisSysCorrLSPs.
The system forwards the LSP ID. Although the ID is defined by the system, an error might error on the ID.
Status control
ON
CLI: Use the snmp-agent trap enable isis lsp-corrupt command.
OFF
CLI: Use the undo snmp-agent trap enable isis lsp-corrupt command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
1.3.6.1.2.1.138.1.10.1.3 (isisPduLspId)
No
IsisLinkStatePDUID
OCTET STRING (8)
Recommended action
isisAttemptToExceedMaxSequence
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.4
Attempts to exceed the maximum LSP sequence number
Informational
ON
When an LSP sequence number flip occurs, the system clears and then waits for regeneration of this notification. This notification provides a description on the event. The event does not frequently occur, and the system sends a notification every time the event occurs.
The first six bytes of the LSP ID contain the system ID, and the remaining two bytes contain valid information.
Status control
ON
CLI: Use the snmp-agent trap enable isis max-seq-exceeded command.
OFF
CLI: Use the undo snmp-agent trap enable isis max-seq-exceeded command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
No
IsisLinkStatePDUID
OCTET STRING (8)
Recommended action
isisIDLenMismatch
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.5
System ID length mismatches.
Error
Warning
ON
A notification sent when we receive a PDU with a different value for the system ID length. This notification includes the index of the link that received the PDU and the header of the packet, which may help a network manager identify the source of the confusion.
The agent must throttle the generation of consecutive isisIDLenMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
Status control
ON
CLI: Use the snmp-agent trap enable isis id-length-mismatch command.
OFF
CLI: Use the undo snmp-agent trap enable isis id-length-mismatch command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
1.3.6.1.2.1.138.1.10.1.5 (isisPduFieldLen)
No
IsisUnsigned8TC
Unsigned32 (0..255)
1.3.6.1.2.1.138.1.10.1.2 (isisNotificationCircIfIndex)
Interface index.
No
Unsigned32
1.3.6.1.2.1.138.1.10.1.4 (isisPduFragment)
No
IsisPDUHeader
OCTET STRING (0..64)
Recommended action
isisMaxAreaAddressesMismatch
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.6
Maximum area address mismatches.
Error
Warning
ON
A notification sent when we receive a PDU with a different value for the isisMaxAreaAddressesMismatch. This notification includes the header of the packet, which may help a network manager identify the source of the confusion.
The agent must throttle the generation of consecutive isisMaxAreaAddressesMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
Status control
ON
CLI: Use the snmp-agent trap enable isis maxarea-mismatch command.
OFF
CLI: Use the undo snmp-agent trap enable isis maxarea-mismatch command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
1.3.6.1.2.1.138.1.10.1.6 (isisPduMaxAreaAddress)
No
IsisUnsigned8TC
Unsigned32 (0..255)
Interface index.
No
Unsigned32
No
IsisPDUHeader
Recommended action
isisOwnLSPPurge
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.7
Attempts to remove the local LSP.
Informational
ON
A notification sent when we receive a PDU with the local system ID and a lifetime value of 0. This notification includes the link index and router ID, which may help a network manager identify the source of the confusion.
Status control
ON
CLI: Use the snmp-agent trap enable isis own-lsp-purge command.
OFF
CLI: Use the undo snmp-agent trap enable isis own-lsp-purge command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
Interface index.
No
Unsigned32
No
IsisLinkStatePDUID
OCTET STRING (8)
Recommended action
isisSequenceNumberSkip
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.8
LSP sequence number duplications.
Informational
ON
When we receive a PDU with the local system ID and different content, the system might redeploy the LSP by using a greater sequence number. A notification is sent when the sequence number increases by a value greater than 1. When two ISs has the same system ID, a large number of such notifications will be generated.
Status control
ON
CLI: Use the snmp-agent trap enable isis skip-sequence-number command.
OFF
CLI: Use the undo snmp-agent trap enable isis skip-sequence-number command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
Interface index.
No
Unsigned32
No
IsisLinkStatePDUID
OCTET STRING (8)
Recommended action
isisAuthenticationTypeFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.9
Authentication type errors.
Error
Warning
ON
A notification sent when we receive a PDU with an error authentication type field. This notification includes the header of the packet, which may help a network manager identify the source of the confusion.
The agent must throttle the generation of consecutive isisAuthenticationTypeFailure notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
Status control
ON
CLI: Use the snmp-agent trap enable isis authentication-type command.
OFF
CLI: Use the undo snmp-agent trap enable isis authentication-type command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
Interface index.
No
Unsigned32
No
IsisPDUHeader
Recommended action
1.     Modify configuration on the two ends so that they have matching authentication type.
isisAuthenticationFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.10
Authentication failures.
Error
Warning
ON
A notification sent when we receive a PDU with incorrect authentication information field. This notification includes the header of the packet, which may help a network manager identify the source of the confusion.
The agent must throttle the generation of consecutive isisAuthenticationFailure notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
Status control
ON
CLI: Use the snmp-agent trap enable isis authentication command.
OFF
CLI: Use the undo snmp-agent trap enable isis authentication command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
Interface index.
No
Unsigned32
No
IsisPDUHeader
Recommended action
1.     Modify configuration on the two ends so that they have matching authentication information.
isisVersionSkew
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.11
Hello packet version mismatches.
Error
Warning
ON
A notification sent when we receive a hello packet from an IS running a different protocol version. This notification includes the header of the packet, which may help a network manager identify the source of the confusion.
The agent must throttle the generation of consecutive isisVersionSkew notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
Status control
ON
CLI: Use the snmp-agent trap enable isis version-skew command.
OFF
CLI: Use the undo snmp-agent trap enable isis version-skew command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
Interface index.
No
Unsigned32
1.3.6.1.2.1.138.1.10.1.7 (isisPduProtocolVersion)
No
IsisUnsigned8TC
Unsigned32 (0..255)
No
IsisPDUHeader
Recommended action
isisAreaMismatch
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.12
Area address mismatches.
Error
Warning
ON
A notification sent when we receive a hello packet from an IS containing no matching area addresses. This notification includes the header of the packet, which may help a network manager identify the source of the confusion.
The agent must throttle the generation of consecutive isisAreaMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
Status control
ON
CLI: Use the snmp-agent trap enable isis area-mismatch command.
OFF
CLI: Use the undo snmp-agent trap enable isis area-mismatch command.
Objects
OID (object name)
Index
Value range
Interface index.
No
Unsigned32
No
IsisPDUHeader
Recommended action
1.     Modify configuration on the two ends so that they have at least one matching area address.
isisRejectedAdjacency
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.13
Adjacency creation failures.
Error
Warning
ON
A notification sent when we receive a hello packet from an IS but no adjacency has been established with it.
The agent must throttle the generation of consecutive isisRejectedAdjacency notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
Status control
ON
CLI: Use the snmp-agent trap enable isis rejected-adjacency command.
OFF
CLI: Use the undo snmp-agent trap enable isis rejected-adjacency command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
Interface index.
No
Unsigned32
No
IsisPDUHeader
Recommended action
1.     Verify that the two ends have matching area addresses.
2.     Verify that the two ends have matching IS levels.
3.     Verify that the two ends have matching authentication types.
4.     Verify that the two ends have matching authentication information.
5.     If the issue persists, contact H3C Support.
isisLSPTooLargeToPropagate
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.14
Propagation failures caused by oversized LSPs.
Error
Warning
ON
A notification sent when an LSP larger than the dataLinkBlockSize value of the link is propagated.
The agent must throttle the generation of consecutive isisLSPTooLargeToPropagate notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
Status control
ON
CLI: Use the snmp-agent trap enable isis lsp-size-exceeded command.
OFF
CLI: Use the undo snmp-agent trap enable isis lsp-size-exceeded command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
Interface index.
No
Unsigned32
1.3.6.1.2.1.138.1.10.1.8 (isisPduLspSize)
No
Unsigned32
1.3.6.1.2.1.138.1.10.1.4 (isisPduLspId)
No
IsisLinkStatePDUID
OCTET STRING (8)
Recommended action
1.     Increase the interface MTU.
2.     Reduce the LSP size.
isisOrigLSPBuffSizeMismatch
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.15
Buffer size mismatches of IS-IS packets.
Error
Warning
ON
A notification sent when we receive an LSP (Level-1 or Level-2) that is larger than the local isisSysLevelOrigLSPBuffSize value or has a Buffer Size value not matching the local isisSysLevelOrigLSPBuffSize value. If any value of the Buffer Size or LSP size exceeds the local setting, both values are rejected.
The agent must throttle the generation of consecutive isisOrigLSPBuffSizeMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
Status control
ON
CLI: Use the snmp-agent trap enable isis buffsize-mismatch command.
OFF
CLI: Use the undo snmp-agent trap enable isis buffsize-mismatch command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
Interface index.
No
Unsigned32
No
IsisLinkStatePDUID
OCTET STRING (8)
1.3.6.1.2.1.138.1.10.1.9 (isisPduOriginatingBufferSize)
No
IsisUnsigned16TC
Unsigned32 (0..16000)
1.3.6.1.2.1.138.1.10.1.10 (isisPduBufferSize)
No
IsisUnsigned16TC
Recommended action
1.     Reduce the length of LSPs generated by the neighbor.
2.     Increase the LSP receive buffer size on the local end.
isisProtocolsSupportedMismatch
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.16
Supported-protocol mismatches.
Error
Warning
ON
A notification sent when a nonpseudonode LSP fragment 0 is received but no supported protocol is available. The reason for the notification might be that the system has not generated this field or no common elements are available. This notification includes the list of supported protocols. If the system does not support the TLV or the TLV is empty, the supported protocol list will be empty.
The agent must throttle the generation of consecutive isisProtocolsSupportedMismatch notifications so that there is at least a 5-second gap between notifications of this type. When notifications are throttled, they are dropped, not queued for sending at a future time.
Status control
ON
CLI: Use the snmp-agent trap enable isis protocol-support command.
OFF
CLI: Use the undo snmp-agent trap enable isis protocol-support command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
Interface index.
No
Unsigned32
1.3.6.1.2.1.138.1.10.1.11 (isisPduProtocolsSupported)
No
OCTET STRING
No
IsisLinkStatePDUID
OCTET STRING (8)
No
IsisPDUHeader
Recommended action
1.     Verify the protocol support.
isisAdjacencyChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.17
IS-IS adjacency status changes.
Error
Warning
ON
A notification sent when an adjacency enters or exits up state. The first six bytes of the isisPduLspId variable represents the system ID of the neighbor. The isisAdjState variable represents the most recent adjacency state.
Status control
ON
CLI: Use the snmp-agent trap enable isis adjacency-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable isis adjacency-state-change command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
Interface index.
No
Unsigned32
No
IsisLinkStatePDUID
OCTET STRING (8)
1.3.6.1.2.1.138.1.10.1.12 (isisAdjState)
Adjacency state.
No
INTEGER
down (1)
initializing (2)
up (3)
failed(4)
Recommended action
1.     Verify that the neighbor state is normal.
isisLSPErrorDetected
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.138.0.18
LSP packet parse failures.
Error
Warning
ON
A notification sent when an LSP with parse failure is received. isisCircIfIndex records the index of the link that received the PDU. isisPduFragment records the starting bytes of the PDU. isisErrorOffset indicates the problem.
If the problem was caused by malformed TLV, isisErrorOffset indicates the starting bytes of the TLV, and isisErrorTLVType records the type of the error TLV.
If the problem was caused by LSP header error, isisErrorOffset indicates the suspicious bytes.
The number of the LSPs of this type is recorded in isisSysStatLSPErrors.
Status control
ON
CLI: Use the snmp-agent trap enable isis lsp-parse-error command.
OFF
CLI: Use the undo snmp-agent trap enable isis lsp-parse-error command.
Objects
OID (object name)
Index
Value range
IS level index.
No
IsisLevel
level1(1)
level2(2)
level1and2(3)
No
IsisLinkStatePDUID
OCTET STRING (8)
Interface index.
No
Unsigned32
No
IsisPDUHeader
1.3.6.1.2.1.138.1.10.1.13 (isisErrorOffset)
No
Unsigned32
1.3.6.1.2.1.138.1.10.1.14 (isisErrorTLVType)
No
Unsigned32
Unsigned32(0..255)
Recommended action
