07-Layer 3 - IP Routing
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10007-Layer 3 - IP Routing
08-OSPFV3-MIB
08-OSPFV3-MIB 269.86 KB
OSPFV3-MIB
About this MIB
Use this MIB to obtain OSPFv3 information.
MIB file name
rfc5643-ospfv3.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ospfv3MIB(191)
Scalar objects
ospfv3RouterId
Object (OID)
Access
Value range
Implementation
ospfv3RouterId (1.3.6.1.2.1.191.1.1.1)
read-write
Ospfv3RouterIdTC
Unsigned32(1..'FFFFFFFF'h)
Unique identifier of a router in an AS.
Supports only the read operation.
ospfv3AdminStatus
Object (OID)
Access
Value range
Implementation
ospfv3AdminStatus (1.3.6.1.2.1.191.1.1.2)
read-write
Status
INTEGER{
enabled (1),
disabled (2)
Enabled indicates that a minimum of one interface is in up state. Disabled indicates that no interface is in up state.
ospfv3VersionNumber
Object (OID)
Access
Value range
Implementation
ospfv3VersionNumber (1.3.6.1.2.1.191.1.1.3)
read-only
INTEGER
version3 (3)
Version number (3).
As per the MIB.
ospfv3AreaBdrRtrStatus
Object (OID)
Access
Value range
Implementation
ospfv3AreaBdrRtrStatus (1.3.6.1.2.1.191.1.1.4)
read-only
TruthValue
true(1),
false(2)
Whether the device is an ABR.
As per the MIB.
ospfv3ASBdrRtrStatus
Object (OID)
Access
Value range
Implementation
ospfv3ASBdrRtrStatus (1.3.6.1.2.1.191.1.1.5)
read-write
TruthValue
true(1),
false(2)
Whether the device is an ASBR.
ospfv3AsScopeLsaCount
Object (OID)
Access
Value range
Implementation
ospfv3AsScopeLsaCount (1.3.6.1.2.1.191.1.1.6)
read-only
Gauge32
INTEGER(0..4294967295)
Number of AS external LSAs.
As per the MIB.
ospfv3AsScopeLsaCksumSum
Object (OID)
Access
Value range
Implementation
ospfv3AsScopeLsaCksumSum (1.3.6.1.2.1.191.1.1.7)
read-only
Unsigned32
Standard MIB values.
Sum of checksums in external LSAs.
As per the MIB.
ospfv3OriginateNewLsas
Object (OID)
Access
Value range
Implementation
ospfv3OriginateNewLsas (1.3.6.1.2.1.191.1.1.8)
read-only
Counter32
Number of new LSAs that have been originated. This number is incremented each time the device originates a new LSA.
As per the MIB.
ospfv3RxNewLsas
Object (OID)
Access
Value range
Implementation
ospfv3RxNewLsas (1.3.6.1.2.1.191.1.1.9)
read-only
Counter32
Number of newly received LSAs, excluding self-originated LSAs.
As per the MIB.
ospfv3ExtLsaCount
Object (OID)
Access
Value range
Implementation
ospfv3ExtLsaCount (1.3.6.1.2.1.191.1.1.10)
read-only
Gauge32
Number of Type-5 LSAs.
As per the MIB.
ospfv3ExtAreaLsdbLimit
Object (OID)
Access
Value range
Implementation
ospfv3ExtAreaLsdbLimit (1.3.6.1.2.1.191.1.1.11)
read-write
Integer32
Integer32(-1..'7FFFFFFF'h)
Maximum number of non-default ASEs in the LSDB. A value of -1 indicates no limit.
ospfv3ExitOverflowInterval
Object (OID)
Access
Value range
Implementation
ospfv3ExitOverflowInterval (1.3.6.1.2.1.191.1.1.12)
read-write
Unsigned32
Time that the router takes to leave the OverflowState. 0 indicates the router does not leave the OverflowState until it is restarted.
ospfv3DemandExtensions
Object (OID)
Access
Value range
Implementation
ospfv3DemandExtensions (1.3.6.1.2.1.191.1.1.13)
read-write
TruthValue
true(1),
false(2)
Support for demand routing.
ospfv3ReferenceBandwidth
Object (OID)
Access
Value range
Implementation
ospfv3ReferenceBandwidth (1.3.6.1.2.1.191.1.1.14)
read-write
Unsigned32
Reference bandwidth in Kbps for calculating the interface cost.
When the value is divided by 1000, the decimal number will be ignored.
ospfv3RestartSupport
Object (OID)
Access
Value range
Implementation
ospfv3RestartSupport (1.3.6.1.2.1.191.1.1.15)
read-write
INTEGER
none(1), plannedOnly(2), plannedAndUnplanned(3)
Support for GR.
If the value changes from 1 to 2 or 3, IETF GR is supported.
If the value changes between 2 and 3, the original GR type remains unchanged.
ospfv3RestartInterval
Object (OID)
Access
Value range
Implementation
ospfv3RestartInterval (1.3.6.1.2.1.191.1.1.16)
read-write
Ospfv3UpToRefreshIntervalTC
Unsigned32 (40..1800)
GR timeout timer.
Value range: 40 to 1800.
ospfv3RestartStrictLsaChecking
Object (OID)
Access
Value range
Implementation
ospfv3RestartStrictLsaChecking (1.3.6.1.2.1.191.1.1.17)
read-write
TruthValue
true(1),
false(2)
Whether the strict LSA checking capability is enabled for GR.
Default: false(2).
ospfv3RestartStatus
Object (OID)
Access
Value range
Implementation
ospfv3RestartStatus (1.3.6.1.2.1.191.1.1.18)
read-only
INTEGER
notRestarting(1), plannedRestart(2), unplannedRestart(3)
Graceful restart state.
As per the MIB.
ospfv3RestartAge
Object (OID)
Access
Value range
Implementation
ospfv3RestartAge (1.3.6.1.2.1.191.1.1.19)
read-only
Unsigned32 (1..1800)
Remaining time for the current graceful restart.
As per the MIB.
ospfv3RestartExitReason
Object (OID)
Access
Value range
Implementation
ospfv3RestartExitReason (1.3.6.1.2.1.191.1.1.20)
read-only
INTEGER
none(1), inProgress(2), completed(3) timedOut(4), topologyChanged(5)
GR exit reason.
As per the MIB.
ospfv3NotificationEnable
Object (OID)
Access
Value range
Implementation
ospfv3NotificationEnable (1.3.6.1.2.1.191.1.1.21)
read-write
TruthValue
true(1),
false(2)
Whether OSPFv3 notification is enabled.
If the value of this object is true(1), all OSPFv3 notifications are enabled.
ospfv3StubRouterSupport
Object (OID)
Access
Value range
Implementation
ospfv3StubRouterSupport (1.3.6.1.2.1.191.1.1.22)
read-only
TruthValue
true(1),
false(2)
Support for stub router.
As per the MIB.
ospfv3StubRouterAdvertisement
Object (OID)
Access
Value range
Implementation
ospfv3StubRouterAdvertisement (1.3.6.1.2.1.191.1.1.23)
read-write
INTEGER
doNotAdvertise(1), advertise(2)
Whether to advertise stub router LSAs.
As per the MIB.
ospfv3DiscontinuityTime
Object (OID)
Access
Value range
Implementation
ospfv3DiscontinuityTime (1.3.6.1.2.1.191.1.1.24)
read-only
TimeStamp
TimeTicks
Most recent system startup time.
As per the MIB.
ospfv3RestartTime
Object (OID)
Access
Value range
Implementation
ospfv3RestartTime (1.3.6.1.2.1.191.1.1.25)
read-only
TimeStamp
TimeTicks
Time when the most recent GR occurred.
As per the MIB.
Tabular objects
ospfv3AreaTable
About this table
This table contains parameter and statistics information about each area on the device.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ospfv3AreaId.
Object (OID)
Access
Value range
Implementation
ospfv3AreaId (1.3.6.1.2.1.191.1.2.1.1)
not-accessible
Ospfv3AreaIdTC
Unsigned32 (0..'FFFFFFFF'h)
Area ID, a 32-bit integer that uniquely identifies an area.
As per the MIB.
ospfv3AreaImportAsExtern (1.3.6.1.2.1.191.1.2.1.2)
read-create
INTEGER
importExternal(1),   importNoExternal(2),   importNssa(3)
Area type, stub, NSSA, or common area.
ospfv3AreaSpfRuns (1.3.6.1.2.1.191.1.2.1.3)
read-only
Counter32
Time of route calculations in the area.
As per the MIB.
ospfv3AreaBdrRtrCount (1.3.6.1.2.1.191.1.2.1.4)
read-only
Gauge32
Number of reachable ABRs in the area.
As per the MIB.
ospfv3AreaAsBdrRtrCount (1.3.6.1.2.1.191.1.2.1.5)
read-only
Gauge32
Number of reachable ASBRs in the area.
As per the MIB.
ospfv3AreaScopeLsaCount (1.3.6.1.2.1.191.1.2.1.6)
read-only
Gauge32
Number of LSAs in the LSDB of the area.
As per the MIB.
ospfv3AreaScopeLsaCksumSum (1.3.6.1.2.1.191.1.2.1.7)
read-only
Unsigned32
Sum of the checksums of the LSAs in the area.
As per the MIB.
ospfv3AreaSummary (1.3.6.1.2.1.191.1.2.1.8)
read-create
INTEGER
noAreaSummary(1),
sendAreaSummary(2)
Whether to send summary LSAs to stub and NSSA areas.
Supports read and write operations.
ospfv3AreaRowStatus (1.3.6.1.2.1.191.1.2.1.9)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Area state.
ospfv3AreaStubMetric (1.3.6.1.2.1.191.1.2.1.10)
read-create
BigMetric
Integer32(0..16777215)
Cost of the default route advertised to a stub or NSSA area.
Default: 1.
Value range: 0 to 16777214.
ospfv3AreaNssaTranslatorRole (1.3.6.1.2.1.191.1.2.1.11)
read-create
INTEGER
always(1), candidate(2)
Ability of the NSSA ABR to translate Type-7 LSAs into Type-5 LSAs.
ospfv3AreaNssaTranslatorState (1.3.6.1.2.1.191.1.2.1.12)
read-only
INTEGER
enabled(1),
elected(2),
disabled(3)
State for the NSSA ABR to become capable of translating Type-7 LSAs into Type-5 LSAs.
As per the MIB.
ospfv3AreaNssaTranslatorStabInterval (1.3.6.1.2.1.191.1.2.1.13)
read-create
Unsigned32
Time period during which the elected translator continues to perform translation after determining that its services are no longer required.
Default: 0.
Value range: 0 to 900.
ospfv3AreaNssaTranslatorEvents (1.3.6.1.2.1.191.1.2.1.14)
read-only
Counter32
Number of role changes.
As per the MIB.
ospfv3AreaStubMetricType (1.3.6.1.2.1.191.1.2.1.15)
read-create
INTEGER
ospfv3Metric(1),   ableCost(2), mparable(3)
Cost type of the default route advertised to a stub or NSSA area.
ospfv3AreaTEEnabled
(1.3.6.1.2.1.191.1.2.1.16)
read-create
TruthValue
true(1),
false(2)
Whether TE is enabled.
ospfv3AsLsdbTable (not supported)
About this table
This table contains information about LSDB information of an AS.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfv3AsLsdbType, ospfv3AsLsdbRouterId, and ospfv3AsLsdbLsid.
Object (OID)
Access
Value range
Implementation
ospfv3AsLsdbType (1.3.6.1.2.1.191.1.3.1.1)
not-accessible
Unsigned32
Unsigned32(0..'FFFFFFFF'h)
LSA type.
As per the MIB.
ospfv3AsLsdbRouterId (1.3.6.1.2.1.191.1.3.1.2)
not-accessible
Ospfv3RouterIdTC
Router ID of the device that generates the LSA.
As per the MIB.
ospfv3AsLsdbLsid (1.3.6.1.2.1.191.1.3.1.3)
not-accessible
Ospfv3LsIdTC
Unsigned32 (1..'FFFFFFFF'h)
LS ID.
As per the MIB.
ospfv3AsLsdbSequence (1.3.6.1.2.1.191.1.3.1.4)
read-only
Ospfv3LsaSequenceTC
Integer32
LSA sequence number.
As per the MIB.
ospfv3AsLsdbAge (1.3.6.1.2.1.191.1.3.1.5)
read-only
Ospfv3LsaAgeTC
Unsigned32 (0..3600)
LSA age.
As per the MIB.
ospfv3AsLsdbChecksum (1.3.6.1.2.1.191.1.3.1.6)
read-only
Integer32
Checksum.
As per the MIB.
ospfv3AsLsdbAdvertisement (1.3.6.1.2.1.191.1.3.1.7)
read-only
OCTET STRING
OCTET STRING(1..65535)
LSA information, including the header.
As per the MIB.
ospfv3AsLsdbTypeKnown (1.3.6.1.2.1.191.1.3.1.8)
read-only
TruthValue
true(1),
false(2)
Whether the LSA type is unknown.
As per the MIB.
ospfv3AreaLsdbTable
About this table
This table contains information about LSDB information of an area.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfv3AreaLsdbAreaId, ospfv3AreaLsdbType, ospfv3AreaLsdbRouterId, and ospfv3AreaLsdbLsid.
Object (OID)
Access
Value range
Implementation
ospfv3AreaLsdbAreaId (1.3.6.1.2.1.191.1.4.1.1)
not-accessible
Ospfv3AreaIdTC
Area from which the LSA was received.
As per the MIB.
ospfv3AreaLsdbType (1.3.6.1.2.1.191.1.4.1.2)
not-accessible
Unsigned32
LSA type.
As per the MIB.
ospfv3AreaLsdbRouterId (1.3.6.1.2.1.191.1.4.1.3)
not-accessible
Ospfv3RouterIdTC
As per the MIB.
ospfv3AreaLsdbLsid (1.3.6.1.2.1.191.1.4.1.4)
not-accessible
Ospfv3LsIdTC
LS ID.
As per the MIB.
ospfv3AreaLsdbSequence (1.3.6.1.2.1.191.1.4.1.5)
read-only
Ospfv3LsaSequenceTC
Integer32
As per the MIB.
ospfv3AreaLsdbAge (1.3.6.1.2.1.191.1.4.1.6)
read-only
Ospfv3LsaAgeTC
LSA age.
As per the MIB.
ospfv3AreaLsdbChecksum (1.3.6.1.2.1.191.1.4.1.7)
read-only
Integer32
Checksum.
As per the MIB.
ospfv3AreaLsdbAdvertisement (1.3.6.1.2.1.191.1.4.1.8)
read-only
OCTET STRING
As per the MIB.
ospfv3AreaLsdbTypeKnown (1.3.6.1.2.1.191.1.4.1.9)
read-only
TruthValue
true(1),
false(2)
As per the MIB.
ospfv3LinkLsdbTable
About this table
This table contains link-scope LSDB information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfv3LinkLsdbIfIndex, ospfv3LinkLsdbIfInstId, ospfv3LinkLsdbType, ospfv3LinkLsdbRouterId, and ospfv3LinkLsdbLsid.
Object (OID)
Access
Value range
Implementation
ospfv3LinkLsdbIfIndex (1.3.6.1.2.1.191.1.5.1.1)
not-accessible
InterfaceIndex
Integer32(1..2147483647)
Interface index.
As per the MIB.
ospfv3LinkLsdbIfInstId (1.3.6.1.2.1.191.1.5.1.2)
not-accessible
Ospfv3IfInstIdTC
Unsigned32(0..255)
Instance ID.
As per the MIB.
ospfv3LinkLsdbType (1.3.6.1.2.1.191.1.5.1.3)
not-accessible
Unsigned32
LSA type.
As per the MIB.
ospfv3LinkLsdbRouterId (1.3.6.1.2.1.191.1.5.1.4)
not-accessible
Ospfv3RouterIdTC
As per the MIB.
ospfv3LinkLsdbLsid (1.3.6.1.2.1.191.1.5.1.5)
not-accessible
Ospfv3LsIdTC
LS ID.
As per the MIB.
ospfv3LinkLsdbSequence (1.3.6.1.2.1.191.1.5.1.6)
read-only
Ospfv3LsaSequenceTC
Integer32
As per the MIB.
ospfv3LinkLsdbAge (1.3.6.1.2.1.191.1.5.1.7)
read-only
Ospfv3LsaAgeTC
LSA age.
As per the MIB.
ospfv3LinkLsdbChecksum (1.3.6.1.2.1.191.1.5.1.8)
read-only
Integer32
Checksum.
As per the MIB.
ospfv3LinkLsdbAdvertisement (1.3.6.1.2.1.191.1.5.1.9)
read-only
OCTET STRING
As per the MIB.
ospfv3LinkLsdbTypeKnown (1.3.6.1.2.1.191.1.5.1.10)
read-only
TruthValue
true(1),
false(2)
As per the MIB.
ospfv3HostTable
About this table
This table contains host route information (not supported in the current software version).
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are ospfv3HostAddressType and ospfv3HostAddress.
Object (OID)
Access
Value range
Implementation
ospfv3HostAddressType (1.3.6.1.2.1.191.1.6.1.)
not-accessible
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Host route address type.
Not supported
ospfv3HostAddress (1.3.6.1.2.1.191.1.6.2.)
not-accessible
InetAddress
OCTET STRING(0..255)
Host route address.
Not supported
ospfv3HostMetric (1.3.6.1.2.1.191.1.6.3.)
read-create
Metric
Integer32(0..'FFFF'h)
Host route cost.
Not supported
ospfv3HostRowStatus( 1.3.6.1.2.1.191.1.6.4.)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Not supported
ospfv3HostAreaID (1.3.6.1.2.1.191.1.6.5.)
read-create
Ospfv3AreaIdTC
ID of the area to which the host route belongs.
Not supported
ospfv3IfTable
About this table
This table contains OSPFv3 interface information.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfv3IfIndex and ospfv3IfInstId.
Object (OID)
Access
Value range
Implementation
ospfv3IfIndex (1.3.6.1.2.1.191.1.7.1.1)
not-accessible
InterfaceIndex
Interface index.
As per the MIB.
ospfv3IfInstId (1.3.6.1.2.1.191.1.7.1.2)
not-accessible
Ospfv3IfInstIdTC
Unsigned32(0..255)
Interface instance ID.
As per the MIB.
ospfv3IfAreaId (1.3.6.1.2.1.191.1.7.1.3)
read-create
Ospfv3AreaIdTC
Area ID.
ospfv3IfType (1.3.6.1.2.1.191.1.7.1.4)
read-create
INTEGER
broadcast(1),
nbma(2),
pointToPoint(3),
pointToMultipoint(5)
Interface type.
Loopback interfaces do not support the write operation.
ospfv3IfAdminStatus (1.3.6.1.2.1.191.1.7.1.5)
read-create
Status
INTEGER{
enabled (1),
disabled (2)
Administrative state of the interface.
ospfv3IfRtrPriority (1.3.6.1.2.1.191.1.7.1.6)
read-create
DesignatedRouterPriority
Integer32(0..'FF'h)
DR priority of the interface.
ospfv3IfTransitDelay (1.3.6.1.2.1.191.1.7.1.7)
read-create
LSA transmission delay.
Value range: 1 to 1800.
ospfv3IfRetransInterval (1.3.6.1.2.1.191.1.7.1.8)
read-create
Retransmission interval of the interface.
ospfv3IfHelloInterval (1.3.6.1.2.1.191.1.7.1.9)
read-create
HelloRange
Integer32(1..'FFFF'h)
Hello interval of the interface.
ospfv3IfRtrDeadInterval (1.3.6.1.2.1.191.1.7.1.10)
read-create
Ospfv3DeadIntervalRangeTC
Dead interval.
When the value of ospfv3IfRtrDeadInterval is larger than 65535, this object returns 65535.
ospfv3IfPollInterval (1.3.6.1.2.1.191.1.7.1.11)
read-create
Unsigned32
Poll interval.
Value range: 1 to 65535.
ospfv3IfState (1.3.6.1.2.1.191.1.7.1.12)
read-only
INTEGER
down(1), loopback(2),
waiting(3),
pointToPoint(4),
designatedRouter(5),
backupDesignatedRouter(6),
otherDesignatedRouter(7),
standby(8)
Interface state.
As per the MIB.
ospfv3IfDesignatedRouter (1.3.6.1.2.1.191.1.7.1.13)
read-only
Ospfv3RouterIdTC
DR address.
As per the MIB.
ospfv3IfBackupDesignatedRouter (1.3.6.1.2.1.191.1.7.1.14)
read-only
Ospfv3RouterIdTC
BDR address.
As per the MIB.
ospfv3IfEvents(1.3.6.1.2.1.191.1.7.1.15)
read-only
Counter32
Number of interface state changes.
As per the MIB.
ospfv3IfRowStatus (1.3.6.1.2.1.191.1.7.1.16)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
ospfv3IfDemand (1.3.6.1.2.1.191.1.7.1.17)
read-create
TruthValue
true(1),
false(2)
Whether the interface performs demand routing.
ospfv3IfMetricValue (1.3.6.1.2.1.191.1.7.1.18)
read-create
Metric
Interface cost.
Value range for loopback interfaces: 0 to 65535.
Value range for other interfaces: 1 to 65535.
ospfv3IfLinkScopeLsaCount (1.3.6.1.2.1.191.1.7.1.19)
read-only
Gauge32
Number of link-scope LSAs.
As per the MIB.
ospfv3IfLinkLsaCksumSum (1.3.6.1.2.1.191.1.7.1.20)
read-only
Unsigned32
LSA checksum.
As per the MIB.
ospfv3IfDemandNbrProbe (1.3.6.1.2.1.191.1.7.1.21)
read-create
TruthValue
true(1),
false(2)
Whether neighbor probing is enabled.
ospfv3IfDemandNbrProbeRetransLimit (1.3.6.1.2.1.191.1.7.1.22)
read-create
Unsigned32
Number of neighbor probing times.
ospfv3IfDemandNbrProbeInterval (1.3.6.1.2.1.191.1.7.1.23)
read-create
Unsigned32
Neighbor probing interval.
ospfv3IfTEDisabled (1.3.6.1.2.1.191.1.7.1.24)
read-create
TruthValue
true(1),
false(2)
Whether TE is enabled on the interface.
ospfv3IfLinkLSASuppression (1.3.6.1.2.1.191.1.7.1.25)
read-create
TruthValue
true(1),
false(2)
Whether LSA suppression is enabled.
ospfv3VirtIfTable
About this table
This table contains OSPFv3 virtual interface information.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfv3VirtIfAreaId and ospfv3VirtIfNeighbor.
Object (OID)
Access
Value range
Implementation
ospfv3VirtIfAreaId (1.3.6.1.2.1.191.1.8.1.1)
not-accessible
Ospfv3AreaIdTC
ID of the area to which the virtual interface belongs.
As per the MIB.
ospfv3VirtIfNeighbor (1.3.6.1.2.1.191.1.8.1.2)
not-accessible
Ospfv3RouterIdTC
Router ID of the virtual neighbor.
As per the MIB.
ospfv3VirtIfIndex (1.3.6.1.2.1.191.1.8.1.3)
read-only
InterfaceIndex
Virtual interface index.
As per the MIB.
ospfv3VirtIfInstId (1.3.6.1.2.1.191.1.8.1.4)
read-only
Ospfv3IfInstIdTC
Unsigned32(0..255)
Virtual interface instance ID.
As per the MIB.
ospfv3VirtIfTransitDelay (1.3.6.1.2.1.191.1.8.1.5)
read-create
Transmission delay of the virtual interface.
ospfv3VirtIfRetransInterval (1.3.6.1.2.1.191.1.8.1.6)
read-create
Retransmission interval of the virtual interface.
ospfv3VirtIfHelloInterval (1.3.6.1.2.1.191.1.8.1.7)
read-create
HelloRange
Hello interval of the virtual interface.
Value range: 1 to 8192.
ospfv3VirtIfRtrDeadInterval (1.3.6.1.2.1.191.1.8.1.8)
read-create
Dead interval of the virtual interface.
Default: 40.
Value range: 1 to 32768.
ospfv3VirtIfState (1.3.6.1.2.1.191.1.8.1.9)
read-only
INTEGER
down(1),
pointToPoint(4)
Virtual interface state.
As per the MIB.
ospfv3VirtIfEvents (1.3.6.1.2.1.191.1.8.1.10)
read-only
Counter32
Number of virtual interface state changes.
As per the MIB.
ospfv3VirtIfRowStatus (1.3.6.1.2.1.191.1.8.1.11)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
ospfv3VirtIfLinkScopeLsaCount (1.3.6.1.2.1.191.1.8.1.12)
read-only
Gauge32
Number of link LSAs on the virtual interface.
As per the MIB.
ospfv3VirtIfLinkLsaCksumSum (1.3.6.1.2.1.191.1.8.1.13)
read-only
Unsigned32
Sum of checksums in link-scope LSAs.
As per the MIB.
ospfv3NbrTable
About this table
This table contains OSPFv3 neighbor information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfv3NbrIfIndex, ospfv3NbrIfInstId, and ospfv3NbrRtrId.
Object (OID)
Access
Value range
Implementation
ospfv3NbrIfIndex (1.3.6.1.2.1.191.1.9.1.1)
not-accessible
InterfaceIndex
Egress interface index.
As per the MIB.
ospfv3NbrIfInstId (1.3.6.1.2.1.191.1.9.1.2)
not-accessible
Ospfv3IfInstIdTC
Unsigned32(0..255)
Egress interface instance ID.
As per the MIB.
ospfv3NbrRtrId (1.3.6.1.2.1.191.1.9.1.3)
not-accessible
Ospfv3RouterIdTC
Router ID of the neighbor.
As per the MIB.
ospfv3NbrAddressType (1.3.6.1.2.1.191.1.9.1.4)
read-only
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Neighbor address type.
As per the MIB.
ospfv3NbrAddress (1.3.6.1.2.1.191.1.9.1.5)
read-only
InetAddress
Neighbor address.
As per the MIB.
ospfv3NbrOptions (1.3.6.1.2.1.191.1.9.1.6)
read-only
Integer32
Priority of the neighbor.
As per the MIB.
ospfv3NbrPriority (1.3.6.1.2.1.191.1.9.1.7)
read-only
Integer32(0..'FF'h)
Option field of the neighbor.
As per the MIB.
ospfv3NbrState (1.3.6.1.2.1.191.1.9.1.8)
read-only
INTEGER
down(1),
attempt(2),
init(3), twoWay(4),
exchangeStart(5),
exchange(6), loading(7),
full(8)
Neighbor state.
As per the MIB.
ospfv3NbrEvents (1.3.6.1.2.1.191.1.9.1.9)
read-only
Counter32
Number of neighbor state changes.
As per the MIB.
ospfv3NbrLsRetransQLen (1.3.6.1.2.1.191.1.9.1.10)
read-only
Gauge32
Retransmission queue length.
As per the MIB.
ospfv3NbrHelloSuppressed (1.3.6.1.2.1.191.1.9.1.11)
read-only
TruthValue
true(1),
false(2)
Whether hello packets are being suppressed to the neighbor.
As per the MIB.
ospfv3NbrIfId (1.3.6.1.2.1.191.1.9.1.12)
read-only
InterfaceIndex
Neighbor interface ID.
As per the MIB.
ospfv3NbrRestartHelperStatus (1.3.6.1.2.1.191.1.9.1.13)
read-only
INTEGER
notHelping(1),      helping(2)
Whether the router is acting as a GR helper for the neighbor.
As per the MIB.
ospfv3NbrRestartHelperAge (1.3.6.1.2.1.191.1.9.1.14)
read-only
Remaining time of the GR interval when the router is acting as a GR helper for the neighbor.
As per the MIB.
ospfv3NbrRestartHelperExitReason (1.3.6.1.2.1.191.1.9.1.15)
read-only
INTEGER
none(1),       inProgress(2),      completed(3),      timedOut(4),      topologyChanged(5)
GR helper exit reason.
As per the MIB.
ospfv3CfgNbrTable
About this table
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfv3CfgNbrIfIndex, ospfv3CfgNbrIfInstId, ospfv3CfgNbrAddressType, and ospfv3CfgNbrAddress.
Object (OID)
Access
Value range
Implementation
ospfv3CfgNbrIfIndex (1.3.6.1.2.1.191.1.10.1.1)
not-accessible
InterfaceIndex
Configured neighbor interface index.
As per the MIB.
ospfv3CfgNbrIfInstId (1.3.6.1.2.1.191.1.10.1.2)
not-accessible
Ospfv3IfInstIdTC
Unsigned32(0..255)
Configured neighbor interface instance ID.
As per the MIB.
ospfv3CfgNbrAddressType (1.3.6.1.2.1.191.1.10.1.3)
not-accessible
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Configured neighbor address type.
As per the MIB.
ospfv3CfgNbrAddress (1.3.6.1.2.1.191.1.10.1.4)
not-accessible
InetAddress
Configured neighbor address.
As per the MIB.
ospfv3CfgNbrPriority (1.3.6.1.2.1.191.1.10.1.5)
read-create
Integer32(0..'FF'h)
Configured neighbor priority.
Only neighbors on an NBMA network support the write operation.
ospfv3CfgNbrRowStatus (1.3.6.1.2.1.191.1.10.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
ospfv3VirtNbrTable
About this table
This table contains OSPFv3 virtual neighbor information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfv3VirtNbrArea and ospfv3VirtNbrRtrId.
Object (OID)
Access
Value range
Implementation
ospfv3VirtNbrArea (1.3.6.1.2.1.191.1.11.1.1)
not-accessible
Ospfv3AreaIdTC
Area to which the virtual neighbor belongs.
As per the MIB.
ospfv3VirtNbrRtrId (1.3.6.1.2.1.191.1.11.1.2)
not-accessible
Ospfv3RouterIdTC
As per the MIB.
ospfv3VirtNbrIfIndex (1.3.6.1.2.1.191.1.11.1.3)
read-only
InterfaceIndex
As per the MIB.
ospfv3VirtNbrIfInstId (1.3.6.1.2.1.191.1.11.1.4)
read-only
Ospfv3IfInstIdTC
Unsigned32(0..255)
As per the MIB.
ospfv3VirtNbrAddressType (1.3.6.1.2.1.191.1.11.1.5)
read-only
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Virtual neighbor address type.
As per the MIB.
ospfv3VirtNbrAddress (1.3.6.1.2.1.191.1.11.1.6)
read-only
InetAddress
Virtual neighbor address.
As per the MIB.
ospfv3VirtNbrOptions (1.3.6.1.2.1.191.1.11.1.7)
read-only
Integer32
Option field of the virtual neighbor.
As per the MIB.
ospfv3VirtNbrState (1.3.6.1.2.1.191.1.11.1.8)
read-only
INTEGER
down(1),
attempt(2),
init(3),
twoWay(4),
exchangeStart(5),
exchange(6),
loading(7),
full(8)
State of the virtual neighbor.
As per the MIB.
ospfv3VirtNbrEvents (1.3.6.1.2.1.191.1.11.1.9)
read-only
Counter32
Number of virtual neighbor state changes.
As per the MIB.
ospfv3VirtNbrLsRetransQLen(1.3.6.1.2.1.191.1.11.1.10)
read-only
Gauge32
As per the MIB.
ospfv3VirtNbrHelloSuppressed (1.3.6.1.2.1.191.1.11.1.11)
read-only
TruthValue
true(1),
false(2)
Whether hello packets are being suppressed to the virtual neighbor.
As per the MIB.
ospfv3VirtNbrIfId (1.3.6.1.2.1.191.1.11.1.12)
read-only
InterfaceIndex
As per the MIB.
ospfv3VirtNbrRestartHelperStatus (1.3.6.1.2.1.191.1.11.1.13)
read-only
INTEGER
Whether the router is acting as a GR helper for the virtual neighbor.
As per the MIB.
ospfv3VirtNbrRestartHelperAge (1.3.6.1.2.1.191.1.11.1.14)
read-only
Remaining time of the GR interval when the router is acting as a GR helper for the virtual neighbor.
As per the MIB.
ospfv3VirtNbrRestartHelperExitReason (1.3.6.1.2.1.191.1.11.1.15)
read-only
INTEGER
As per the MIB.
ospfv3AreaAggregateTable
About this table
This table contains information about configured OSPFv3 summary routes.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfv3AreaAggregateAreaID, ospfv3AreaAggregateAreaLsdbType, ospfv3AreaAggregatePrefixType, ospfv3AreaAggregatePrefix, and ospfv3AreaAggregatePrefixLength.
Object (OID)
Access
Value range
Implementation
ospfv3AreaAggregateAreaID (1.3.6.1.2.1.191.1.12.1.1)
not-accessible
Ospfv3AreaIdTC
Area where the summary route resides.
As per the MIB.
ospfv3AreaAggregateAreaLsdbType (1.3.6.1.2.1.191.1.12.1.2)
not-accessible
INTEGER
interAreaPrefixLsa(8195), nssaExternalLsa(8199)
LSA type.
As per the MIB.
ospfv3AreaAggregatePrefixType (1.3.6.1.2.1.191.1.12.1.3)
not-accessible
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Summary network address type.
As per the MIB.
ospfv3AreaAggregatePrefix (1.3.6.1.2.1.191.1.12.1.4)
not-accessible
InetAddress
OCTET STRING(0..16)
Summary network address.
As per the MIB.
ospfv3AreaAggregatePrefixLength (1.3.6.1.2.1.191.1.12.1.5)
not-accessible
InetAddressPrefixLength
Unsigned32(3..128)
Summary network address length.
As per the MIB.
ospfv3AreaAggregateRowStatus (1.3.6.1.2.1.191.1.12.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
ospfv3AreaAggregateEffect (1.3.6.1.2.1.191.1.12.1.7)
read-create
INTEGER
advertiseMatching(1),
doNotAdvertiseMatching(2)
Whether subnets are included in the summary route.
ospfv3AreaAggregateRouteTag (1.3.6.1.2.1.191.1.12.1.8)
read-create
Unsigned32
Tag information.
ospfv3VirtLinkLsdbTable (not supported)
About this table
This table contains OSPFv3 link-scope LSDB information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfv3VirtLinkLsdbIfAreaId, ospfv3VirtLinkLsdbIfNeighbor, ospfv3VirtLinkLsdbType, ospfv3VirtLinkLsdbRouterId, and ospfv3VirtLinkLsdbLsid.
Object (OID)
Access
Value range
Implementation
ospfv3VirtLinkLsdbIfAreaId (1.3.6.1.2.1.191.1.13.1.1)
not-accessible
Ospfv3AreaIdTC
ID of the area to which the virtual link belongs.
As per the MIB.
ospfv3VirtLinkLsdbIfNeighbor(1.3.6.1.2.1.191.1.13.1.2)
not-accessible
Ospfv3RouterIdTC
As per the MIB.
ospfv3VirtLinkLsdbType (1.3.6.1.2.1.191.1.13.1.3)
not-accessible
Unsigned32
LSA type.
As per the MIB.
ospfv3VirtLinkLsdbRouterId (1.3.6.1.2.1.191.1.13.1.4)
not-accessible
Ospfv3RouterIdTC
As per the MIB.
ospfv3VirtLinkLsdbLsid (1.3.6.1.2.1.191.1.13.1.5)
not-accessible
Ospfv3LsIdTC
LSA LS ID.
As per the MIB.
ospfv3VirtLinkLsdbSequence(1.3.6.1.2.1.191.1.13.1.6)
read-only
Ospfv3LsaSequenceTC
Integer32
As per the MIB.
ospfv3VirtLinkLsdbAge (1.3.6.1.2.1.191.1.13.1.7)
read-only
Ospfv3LsaAgeTC
LSA age.
As per the MIB.
ospfv3VirtLinkLsdbChecksum(1.3.6.1.2.1.191.1.13.1.8)
read-only
Integer32
LSA checksum information.
As per the MIB.
ospfv3VirtLinkLsdbAdvertisement (1.3.6.1.2.1.191.1.13.1.9)
read-only
OCTET STRING
LSA advertisement content.
As per the MIB.
ospfv3VirtLinkLsdbTypeKnown (1.3.6.1.2.1.191.1.13.1.10)
read-only
TruthValue
true(1),
false(2)
Whether the LSA type is known.
As per the MIB.
Notifications
ospfv3VirtIfStateChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.191.0.1
Virtual interface state changes.
Informational
ON
A notification sent when the state of a virtual interface changes to Point-to-Point or changes from Point-to-Point to another state. To reduce unnecessary notifications caused by virtual interface up events, no virtual interface state change notification will be sent within 2 times the dead interval since the virtual interface state changes to a value other than DOWN.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-state-change command.
Objects
OID (object name)
Index
Value range
(ospfv3RouterId)
No
Ospfv3RouterIdTC
 (ospfv3VirtIfState)
No
INTEGER
down(1)
pointToPoint(4)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
ospfv3NbrStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.2
Neighbor state changes.
Informational
ON
For DR and BDR, this notification is sent when the state of a neighbor changes to FULL or changes from FULL to another state. For DRother, this notification is sent when the state of a neighbor changes to 2-way or changes from 2-way to another state.
To reduce unnecessary notifications caused by interface up events, no neighbor state change notification will be sent within 2 times the dead interval since the interface state changes to a value other than DOWN.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 neighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 neighbor-state-change command.
Objects
OID (object name)
Index
Value range
 (ospfv3RouterId)
No
Ospfv3RouterIdTC
(ospfv3NbrState)
Neighbor state.
No
INTEGER
down(1)
attempt(2)
init(3)
twoWay(4)
exchangeStart(5)
exchange(6)
loading(7)
full(8)
Recommended action
Check whether the interface state has changed.
ospfv3VirtNbrStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.3
Virtual neighbor state changes.
Informational
ON
A notification sent when the state of a virtual neighbor changes to FULL or changes from FULL to another state. To reduce unnecessary notifications caused by virtual interface up events, no virtual neighbor state change notification will be sent within 2 times the dead interval since the virtual interface state changes to a value other than DOWN.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtneighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtneighbor-state-change command.
Objects
OID (object name)
Index
Value range
(ospfv3RouterId)
No
Ospfv3RouterIdTC
(ospfv3VirtNbrState)
Virtual neighbor state.
No
INTEGER
down(1)
attempt(2)
init(3)
twoWay(4)
exchangeStart(5)
exchange(6)
loading(7)
full(8)
Recommended action
ospfv3IfConfigError
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.4
Interface configuration error.
Informational
ON
A notification sent when a non-virtual interface receives a packet from another router with mismatched configuration.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-cfg-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-cfg-error command.
Objects
OID (object name)
Index
Value range
(ospfv3RouterId)
No
Ospfv3RouterIdTC
(ospfv3IfState)
Interface state.
No
INTEGER
down(1)
loopback(2)
waiting(3)
pointToPoint(4)
designatedRouter(5)
standby(8)
1.3.6.1.2.1.191.1.14.3
(ospfv3PacketSrc)
IPv6 packet that cannot be identified by a neighbor.
No
InetAddressIPv6
OCTET STRING (16)
1.3.6.1.2.1.191.1.14.1
(ospfv3ConfigErrorType)
OSPFv3 configuration error type.
No
INTEGER
badVersion(1)
areaMismatch(2)
unknownNbmaNbr(3)
unknownVirtualNbr(4)
helloIntervalMismatch(5)
deadIntervalMismatch(6)
optionMismatch(7)
mtuMismatch(8)
duplicateRouterId(9)
noError(10)
1.3.6.1.2.1.191.1.14.2
(ospfv3PacketType)
OSPFv3 data packet type.
No
INTEGER
hello(1)
dbDescript(2)
lsReq(3)
lsUpdate(4)
lsAck(5)
nullPacket(6)
Recommended action
Verify that the parameters configured on the interface are consistent with parameters in the hello packets.
ospfv3VirtIfConfigError
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.5
Virtual interface configuration error.
Error
Warning
ON
A notification sent when a virtual interface receives a packet from another router with mismatched configuration.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-cfg-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-cfg-error command.
Objects
OID (object name)
Index
Value range
(ospfv3RouterId)
No
Ospfv3RouterIdTC
(ospfv3VirtIfState)
No
INTEGER
down(1)
pointToPoint(4)
No
INTEGER
badVersion(1)
areaMismatch(2)
unknownNbmaNbr(3)
optionMismatch(7)
mtuMismatch(8)
noError(10)
(ospfv3PacketType)
No
INTEGER
hello(1)
dbDescript(2)
lsReq(3)
lsUpdate(4)
lsAck(5)
nullPacket(6)
Recommended action
ospfv3IfRxBadPacket
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.6
A non-virtual interface receives an error packet.
Error
Warning
ON
A notification sent when a non-virtual interface receives an OSPFv3 packet that cannot be parsed.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-bad-pkt command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-bad-pkt command.
Objects
OID (object name)
Index
Value range
(ospfv3RouterId)
No
Ospfv3RouterIdTC
(ospfv3IfState)
Interface state.
No
INTEGER
down(1)
loopback(2)
waiting(3)
pointToPoint(4)
designatedRouter(5)
standby(8)
(ospfv3PacketSrc)
IPv6 packet that cannot be identified by the neighbor.
No
InetAddressIPv6
OCTET STRING (16)
(ospfv3PacketType)
No
INTEGER
hello(1)
dbDescript(2)
lsReq(3)
lsUpdate(4)
lsAck(5)
nullPacket(6)
Recommended action
ospfv3VirtIfRxBadPacket
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.7
A virtual interface receives an error packet.
Informational
ON
A notification sent when a virtual interface receives an OSPFv3 packet that cannot be parsed.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-bad-pkt command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-bad-pkt command.
Objects
OID (object name)
Index
Value range
(ospfv3RouterId)
No
Ospfv3RouterIdTC
(ospfv3VirtIfState)
No
INTEGER
down(1)
pointToPoint(4)
(ospfv3PacketType)
No
INTEGER
hello(1)
dbDescript(2)
lsReq(3)
lsUpdate(4)
lsAck(5)
nullPacket(6)
Recommended action
ospfv3IfStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.10
Interface state changes.
Error
Warning
ON
A notification sent when the state of a non-virtual interface changes from DR to Down or changes to the Point-to-Point, DR, BDR, or Drother state.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-state-change command.
Objects
OID (object name)
Index
Value range
(ospfv3RouterId)
No
Ospfv3RouterIdTC
(ospfv3IfState)
Interface state.
No
INTEGER
down(1)
loopback(2)
waiting(3)
pointToPoint(4)
designatedRouter(5)
standby(8)
Recommended action
ospfv3NssaTranslatorStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.11
A router's ability to translate type-7 LSAs into type-5 LSAs changes.
Error
Warning
ON
A notification sent when a router's ability to translate type-7 LSAs into type-5 LSAs changes.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 nssatranslator-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 nssatranslator-status-change command.
Objects
OID (object name)
Index
Value range
(ospfv3RouterId)
No
Ospfv3RouterIdTC
(ospfv3AreaNssaTranslatorState)
Method for the NSSA ABR to become capable of translating Type-7 LSAs into Type-5 LSAs.
No
INTEGER
enabled(1)
elected(2)
disabled(3)
Recommended action
ospfv3RestartStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.12
GR restarter state changes.
Error
Warning
ON
A notification sent when the GR restarter state changes.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 grrestarter-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 grrestarter-status-change command.
Objects
OID (object name)
Index
Value range
(ospfv3RouterId)
No
Ospfv3RouterIdTC
(ospfv3RestartStatus)
GR restarter state.
No
INTEGER
notRestarting(1)
plannedRestart(2)
unplannedRestart(3)
(ospfv3RestartInterval)
GR timeout interval.
No
(ospfv3RestartExitReason)
Reason why the device exited GR restarter state.
No
INTEGER
none(1)
inProgress(2)
completed(3)
timedOut(4)
topologyChanged(5)
Recommended action
ospfv3NbrRestartHelperStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.13
The GR helper state of a neighbor changes.
Error
Warning
ON
A notification sent when a neighbor enters or exits GR helper state.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 grhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 grhelper-status-change command.
Objects
OID (object name)
Index
Value range
(ospfv3RouterId)
No
Ospfv3RouterIdTC
(ospfv3NbrRestartHelperStatus)
GR helper state of the neighbor.
No
INTEGER
notHelping(1)
helping(2)
(ospfv3NbrRestartHelperAge)
GR helper aging timer.
No
(ospfv3NbrRestartHelperExitReason)
Reason why the neighbor exited GR helper state.
No
INTEGER
none(1)
inProgress(2)
completed(3)
timedOut(4)
topologyChanged(5)
Recommended action
ospfv3VirtNbrRestartHelperStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.14
The GR helper state of a virtual neighbor changes.
Error
Warning
ON
A notification sent when a virtual neighbor enters or exits GR helper state.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 rejected-adjacency command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 rejected-adjacency command.
Objects
OID (object name)
Index
Value range
(ospfv3RouterId)
No
Ospfv3RouterIdTC
(ospfv3VirtNbrRestartHelperStatus)
GR helper state of the virtual neighbor.
No
INTEGER
notHelping(1)
helping(2)
(ospfv3VirtNbrRestartHelperAge)
No
(ospfv3VirtNbrRestartHelperExitReason)
Reason why the virtual neighbor exited GR helper state.
No
INTEGER
none(1)
inProgress(2)
completed(3)
timedOut(4)
topologyChanged(5)
Recommended action
