07-Layer 3 - IP Routing
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10007-Layer 3 - IP Routing
07-OSPF-TRAP-MIB
07-OSPF-TRAP-MIB 189.84 KB
OSPF-TRAP-MIB
About this MIB
Use this MIB to set, edit, and view OSPF protocol and notification information about network devices.
MIB file name
rfc4750-ospf-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ospf(14)
Scalar objects
ospfSetTrap
Object (OID)
Access
Value range
Implementation
ospfSetTrap (1.3.6.1.2.1.14.16.1.1)
read-write
OCTET STRING
OCTET STRING (4)
Whether OSPF notification is enabled.
As per the MIB.
ospfConfigErrorType
Object (OID)
Access
Value range
Implementation
ospfConfigErrorType (1.3.6.1.2.1.14.16.1.2)
read-only
INTEGER
badVersion (1), areaMismatch (2), unknownNbmaNbr (3), unknownVirtualNbr (4),       authTypeMismatch(5),        authFailure (6),        netMaskMismatch (7),       helloIntervalMismatch (8), deadIntervalMismatch (9),       optionMismatch (10),        mtuMismatch (11),       duplicateRouterId (12),        noError (13)
Possible configuration error type.
As per the MIB.
ospfPacketType
Object (OID)
Access
Value range
Implementation
ospfPacketType (1.3.6.1.2.1.14.16.1.3)
read-only
INTEGER
hello (1),       dbDescript (2),        lsReq (3),        lsUpdate (4),       lsAck (5),       nullPacket (6)
OSPF packet type.
As per the MIB.
ospfPacketSrc
Object (OID)
Access
Value range
Implementation
ospfPacketSrc (1.3.6.1.2.1.14.16.1.4)
read-only
IpAddress
OCTET STRING (4)
IP address that cannot be identified by a neighbor.
As per the MIB.
Notifications
ospfVirtIfStateChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.14.16.2.1
Virtual interface state changes.
Informational
ON
A notification sent when the state of a virtual interface regresses (for example, changing from P2P to Down) or progresses to a terminal state (for example, P2P).
Status control
ON
CLI: Use the snmp-agent trap enable ospf virtif-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virtif-state-change command.
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.14.1.1 (ospfRouterId)
Unique identifier of a router in an AS.
No
RouterID
IpAddress
1.3.6.1.2.1.14.9.1.1 (ospfVirtIfAreaId)
ID of the area to which the virtual link belongs.
No
AreaID
IpAddress
1.3.6.1.2.1.14.9.1.2 (ospfVirtIfNeighbor)
Router ID of the virtual neighbor.
No
RouterID
IpAddress
1.3.6.1.2.1.14.9.1.7 (ospfVirtIfState)
Virtual interface state.
No
INTEGER
down (1)
pointToPoint (4)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
ospfNbrStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.2
Neighbor state changes.
Informational
ON
A notification sent when the state of a neighbor regresses (for example, changing from Attempt or Full to 1-Way or Down) or progresses to a terminal state (for example, 2-Way or Full). When the state of a neighbor in an NBMA or broadcast network changes from Full to another state or changes from another state to Full, the notification is generated by the DR. An ospfIfStateChange notification will be generated when the DR does down.
Status control
ON
CLI: Use the snmp-agent trap enable ospf neighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf neighbor-state-change command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
1.3.6.1.2.1.14.10.1.1 (ospfNbrIpAddr)
IP address of the neighbor.
No
IpAddress
Standard MIB values.
1.3.6.1.2.1.14.10.1.2 (ospfNbrAddressLessIndex)
Set to 0 on an interface having an IP address, and set to the value of interface index in the Internet Standard MIB on an interface having no IP address.
No
InterfaceIndexOrZero
Integer32 (0..2147483647)
1.3.6.1.2.1.14.10.1.3 (ospfNbrRtrId)
Router ID of the neighbor.
No
RouterID
IpAddress
1.3.6.1.2.1.14.10.1.6 (ospfNbrState)
Neighbor state.
No
INTEGER
down (1)
attempt (2)
init (3)
twoWay (4)
exchangeStart (5)
exchange (6)
loading (7)
full (8)
Recommended action
ospfVirtNbrStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.3
Virtual neighbor state changes.
Informational
ON
A notification sent when the state of a virtual neighbor regresses (for example, changing from Attempt or Full to 1-Way or Down) or progresses to a terminal state (for example, Full).
Status control
ON
CLI: Use the snmp-agent trap enable ospf virtneighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virtneighbor-state-change command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
1.3.6.1.2.1.14.11.1.1 (ospfVirtNbrArea)
ID of the area to which the virtual neighbor belongs.
No
AreaID
IpAddress
1.3.6.1.2.1.14.11.1.2 (ospfVirtNbrRtrId)
A 32-bit integer that uniquely identifies the neighboring router in the AS.
No
RouterID
IpAddress
1.3.6.1.2.1.14.11.1.5 (ospfVirtNbrState)
Neighbor state.
No
INTEGER
down (1)
attempt (2)
init (3)
twoWay (4)
exchangeStart (5)
exchange (6)
loading (7)
full (8)
Recommended action
ospfIfConfigError
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.4
Interface configuration error.
Error
Warning
ON
A notification sent when an interface on a router receives a packet from another router with mismatched configuration. The optionMismatch event causes a notification only if it prevents an adjacency from establishing.
Status control
ON
CLI: Use the snmp-agent trap enable ospf config-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospf config-error command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
1.3.6.1.2.1.14.7.1.1 (ospfIfIpAddress)
IP address of the interface.
No
IpAddress
1.3.6.1.2.1.14.7.1.2 (ospfAddressLessIf)
Used to distinguish interface instances with addresses configured and those without addresses configured.
No
1.3.6.1.2.1.14.16.1.4 (ospfPacketSrc)
No
IpAddress
1.3.6.1.2.1.14.16.1.2 (ospfConfigErrorType)
Configuration error type.
No
INTEGER
badVersion (1)
areaMismatch (2)
unknownNbmaNbr (3)
authTypeMismatch(5)
authFailure (6)
netMaskMismatch (7)
optionMismatch (10)
mtuMismatch (11)
noError (13)
1.3.6.1.2.1.14.16.1.3 (ospfPacketType)
OSPF packet type.
No
INTEGER
hello (1)
dbDescript (2)
lsReq (3)
lsUpdate (4)
lsAck (5)
nullPacket (6)
Recommended action
To resolve this issue:
1.     Verify that the interface configuration is correct.
2.     If the issue persists, contact H3C Support.
ospfVirtIfConfigError
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.5
Virtual interface configuration error.
Error
Warning
ON
A notification sent when an OSPF virtual interface on a router receives a packet from another router with mismatched configuration. The optionMismatch event causes a notification only if it prevents establishment of an adjacency.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virt-config-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virt-config-error command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
No
AreaID
IpAddress
No
RouterID
IpAddress
No
INTEGER
badVersion (1)
areaMismatch (2)
unknownNbmaNbr (3)
authTypeMismatch(5)
authFailure (6)
netMaskMismatch (7)
optionMismatch (10)
mtuMismatch (11)
noError (13)
OSPF packet type.
No
INTEGER
hello (1)
dbDescript (2)
lsReq (3)
lsUpdate (4)
lsAck (5)
nullPacket (6)
Recommended action
1.     Verify that the virtual interface configuration is correct.
ospfIfAuthFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.6
Interface authentication failure.
Error
Warning
ON
A notification sent when an interface on a router receives a packet from another router with mismatched authentication key or authentication type.
Status control
ON
CLI: Use the snmp-agent trap enable ospf authentication-failure command.
OFF
CLI: Use the undo snmp-agent trap enable ospf authentication-failure command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
No
IpAddress
No
IP address that cannot be identified by a neighbor instance.
No
IpAddress
No
INTEGER
badVersion (1)
areaMismatch (2)
unknownNbmaNbr (3)
authTypeMismatch(5)
authFailure (6)
netMaskMismatch (7)
optionMismatch (10)
mtuMismatch (11)
noError (13)
OSPF packet type.
No
INTEGER
hello (1)
dbDescript (2)
lsReq (3)
lsUpdate (4)
lsAck (5)
nullPacket (6)
Recommended action
1.     Verify that the interface authentication settings are correct.
ospfVirtIfAuthFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.7
Virtual interface authentication failure.
Error
Warning
ON
A notification sent when an OSPF virtual interface on a router receives a packet from another router with mismatched authentication key or authentication type.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virt-authentication-failure command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virt-authentication-failure command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
No
AreaID
IpAddress
No
RouterID
IpAddress
No
INTEGER
badVersion (1)
areaMismatch (2)
unknownNbmaNbr (3)
authTypeMismatch(5)
authFailure (6)
netMaskMismatch (7)
optionMismatch (10)
mtuMismatch (11)
noError (13)
OSPF packet type.
No
INTEGER
hello (1)
dbDescript (2)
lsReq (3)
lsUpdate (4)
lsAck (5)
nullPacket (6)
Recommended action
1.     Verify that the virtual interface authentication settings are correct.
ospfIfRxBadPacket
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.8
An interface receives an error packet.
Informational
ON
A notification sent when an interface receives an OSPF packet that cannot be parsed.
Status control
ON
CLI: Use the snmp-agent trap enable ospf bad-packet command.
OFF
CLI: Use the undo snmp-agent trap enable ospf bad-packet command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
No
IpAddress
No
No
IpAddress
OSPF packet type.
No
INTEGER
hello (1)
dbDescript (2)
lsReq (3)
lsUpdate (4)
lsAck (5)
nullPacket (6)
Recommended action
ospfVirtIfRxBadPacket
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.9
A virtual interface receives an error packet.
Informational
ON
A notification sent when a virtual interface receives an OSPF packet that cannot be parsed.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virt-bad-packet command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virt-bad-packet command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
No
AreaID
IpAddress
No
RouterID
IpAddress
OSPF packet type.
No
INTEGER
hello (1)
dbDescript (2)
lsReq (3)
lsUpdate (4)
lsAck (5)
nullPacket (6)
Recommended action
ospfTxRetransmit
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.10
An interface retransmits an OSPF packet.
Informational
ON
A notification sent when an interface retransmits an OSPF packet. All packets that might be retransmitted are associated with an LSDB entry, which is identified by the LS type, LS ID, and Router ID.
Status control
ON
CLI: Use the snmp-agent trap enable ospf retransmit command.
OFF
CLI: Use the undo snmp-agent trap enable ospf retransmit command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
No
IpAddress
No
No
RouterID
IpAddress
OSPF packet type.
No
INTEGER
hello (1)
dbDescript (2)
lsReq (3)
lsUpdate (4)
lsAck (5)
nullPacket (6)
1.3.6.1.2.1.14.4.1.2 (ospfLsdbType)
LSA type.
Type-5 LSAs are not displayed.
No
INTEGER
routerLink (1)
networkLink (2)
summaryLink (3)
asSummaryLink (4)
asExternalLink (5)
multicastLink (6)
nssaExternalLink (7)
areaOpaqueLink (10)
1.3.6.1.2.1.14.4.1.3 (ospfLsdbLsid)
LS ID.
No
IpAddress
1.3.6.1.2.1.14.4.1.4 (ospfLsdbRouterId)
Router ID of the device that generates the LSA.
No
RouterID
IpAddress
Recommended action
ospfVirtIfTxRetransmit
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.11
A virtual interface retransmits an OSPF packet.
Informational
ON
A notification sent when a virtual interface retransmits an OSPF packet. All packets that might be retransmitted are associated with an LSDB entry, which is identified by the LS type, LS ID, and Router ID.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virt-retransmit command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virt-retransmit command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
No
AreaID
IpAddress
No
RouterID
IpAddress
OSPF packet type.
No
INTEGER
hello (1)
dbDescript (2)
lsReq (3)
lsUpdate (4)
lsAck (5)
nullPacket (6)
LSA type.
No
INTEGER
routerLink (1)
networkLink (2)
summaryLink (3)
asSummaryLink (4)
asExternalLink (5)
multicastLink (6)
areaOpaqueLink (10)
LS ID
No
IpAddress
No
RouterID
IpAddress
Recommended action
ospfOriginateLsa
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.12
The local device generates a new LSA.
Informational
ON
A notification sent when the local device generates a new LSA. This notification is generated only when an LSA is originated because of a topology change. Flushing of aged LSAs and refreshes of LSAs will not trigger this notification.
Status control
ON
CLI: Use the snmp-agent trap enable ospf lsa-originate command.
OFF
CLI: Use the undo snmp-agent trap enable ospf lsa-originate command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
1.3.6.1.2.1.14.4.1.1 (ospfLsdbAreaId)
ID of the area from which the LSA was received.
No
AreaID
IpAddress
LSA type.
No
INTEGER
routerLink (1)
networkLink (2)
summaryLink (3)
asSummaryLink (4)
asExternalLink (5)
multicastLink (6)
areaOpaqueLink (10)
LS ID.
No
IpAddress
No
RouterID
IpAddress
Recommended action
ospfMaxAgeLsa
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.13
An LSA in the LSDB ages.
Informational
ON
A notification sent when an LSA in the LSDB ages.
Status control
ON
CLI: Use the snmp-agent trap enable ospf lsa-maxage command.
OFF
CLI: Use the undo snmp-agent trap enable ospf lsa-maxage command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
No
AreaID
IpAddress
LSA type.
No
INTEGER
routerLink (1)
networkLink (2)
summaryLink (3)
asSummaryLink (4)
asExternalLink (5)
multicastLink (6)
areaOpaqueLink (10)
LS ID.
No
IpAddress
No
RouterID
IpAddress
Recommended action
ospfLsdbOverflow
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.14
The number of LSAs in the LSDB of a device exceeds the upper limit.
Error
Warning
ON
A notification sent when the number of LSAs in the LSDB of a device exceeds the upper limit.
Status control
ON
CLI: Use the snmp-agent trap enable ospf lsdb-overflow command.
OFF
CLI: Use the undo snmp-agent trap enable ospf lsdb-overflow command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
1.3.6.1.2.1.14.1.11 (ospfExtLsdbLimit)
Maximum number of non-default ASEs in the LSDB. A value of -1 indicates no limit.
No
Integer32
-1..'7FFFFFFF'h
Recommended action
1.     Reduce the number of LSAs.
ospfLsdbApproachingOverflow
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.15
The number of LSAs in the LSDB of a device reaches 90% the upper limit.
Error
Warning
ON
A notification sent when the number of LSAs in the LSDB of a device reaches 90% the upper limit.
Status control
ON
CLI: Use the snmp-agent trap enable ospf lsdb-approaching-overflow command.
OFF
CLI: Use the undo snmp-agent trap enable ospf lsdb-approaching-overflow command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
No
Integer32
-1..'7FFFFFFF'h
Recommended action
ospfIfStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.16
Interface state changes.
Informational
ON
A notification sent when the state of an OSPF interface regresses (for example, changing from Dr to Down) or progresses to a terminal state (for example, Point-to-Point, DR Other, Dr, or Backup).
Status control
ON
CLI: Use the snmp-agent trap enable ospf if-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf if-state-change command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
No
IpAddress
No
1.3.6.1.2.1.14.7.1.12 (ospfIfState)
Interface state.
No
INTEGER
down (1)
loopback (2)
waiting (3)
pointToPoint (4)
designatedRouter (5)
backupDesignatedRouter (6)
otherDesignatedRouter (7)
Recommended action
ospfNssaTranslatorStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.17
A router's ability to translate OSPF type-7 LSAs into OSPF type-5 LSAs changes.
Informational
ON
A notification sent when a router's ability to translate OSPF type-7 LSAs into OSPF type-5 LSAs changes.
Status control
ON
CLI: Use the snmp-agent trap enable ospf nssatranslator-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf nssatranslator-status-change command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
1.3.6.1.2.1.14.2.1.1 (ospfAreaId)
Area ID, a 32-bit integer that uniquely identifies an area.
No
AreaID
IpAddress
1.3.6.1.2.1.14.2.1.12 (ospfAreaNssaTranslatorState)
Method for the NSSA ABR to become capable of translating Type-7 LSAs into Type-5 LSAs.
No
INTEGER
enabled (1)
elected (2)
disabled (3)
Recommended action
ospfRestartStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.18
GR restarter state changes.
Informational
ON
A notification sent when the state of the GR restarter changes.
Status control
ON
CLI: Use the snmp-agent trap enable ospf grrestarter-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf grrestarter-status-change command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
1.3.6.1.2.1.14.1.21 (ospfRestartStatus)
GR restarter state.
No
INTEGER
notRestarting (1)
plannedRestart (2)
unplannedRestart (3)
1.3.6.1.2.1.14.1.19 (ospfRestartInterval)
Graceful restart timeout interval.
No
Integer32
1..1800
1.3.6.1.2.1.14.1.23 (ospfRestartExitReason)
Reason why the GR restarter exited.
No
INTEGER
none (1)
inProgress (2)
completed (3)
timedOut (4)
topologyChanged (5)
Recommended action
ospfNbrRestartHelperStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.19
GR helper state changes.
Informational
ON
A notification sent when the GR helper state of a neighbor changes.
Status control
ON
CLI: Use the snmp-agent trap enable ospf grhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf grhelper-status-change command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
No
IpAddress
No
No
RouterID
IpAddress
1.3.6.1.2.1.14.10.1.12 (ospfNbrRestartHelperStatus)
GR helper state.
No
INTEGER
notHelping (1)
helping (2)
1.3.6.1.2.1.14.10.1.13 (ospfNbrRestartHelperAge)
Remaining time of the GR interval when the router is acting as a GR helper for the neighbor.
No
Unsigned32
1.3.6.1.2.1.14.10.1.14 (ospfNbrRestartHelperExitReason)
Reason why the GR helper exited.
No
INTEGER
none (1)
inProgress (2)
completed (3)
timedOut (4)
topologyChanged (5)
Recommended action
ospfVirtNbrRestartHelperStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.20
The GR helper state of a virtual neighbor changes.
Informational
ON
A notification sent when the GR helper state of a virtual neighbor changes.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virtgrhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virtgrhelper-status-change command.
Objects
OID (object name)
Index
Value range
No
RouterID
IpAddress
No
AreaID
IpAddress
No
RouterID
IpAddress
1.3.6.1.2.1.14.11.1.9 (ospfVirtNbrRestartHelperStatus)
Whether the router is acting as a GR helper for the virtual neighbor.
No
INTEGER
notHelping (1)
helping (2)
1.3.6.1.2.1.14.11.1.10 (ospfVirtNbrRestartHelperAge)
No
Unsigned32
1.3.6.1.2.1.14.11.1.11 (ospfVirtNbrRestartHelperExitReason)
No
INTEGER
none (1)
inProgress (2)
completed (3)
timedOu t 4)
topologyChanged (5)
Recommended action
