07-Layer 3 - IP Routing
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10007-Layer 3 - IP Routing
03-HH3C-ISIS-MIB
03-HH3C-ISIS-MIB 37.19 KB
HH3C-ISIS-MIB
About this MIB
Use this MIB to obtain all IS-IS process IDs by using the hh3cIsisSysInstance node.
MIB file name
hh3c-isis.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2)
Tabular objects
hh3cIsisSysTable
About this table
This table contains information about all IS-IS process IDs.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIsisSysInstance.
Object (OID)
Access
Value range
Implementation
hh3cIsisSysInstance (1.3.6.1.4.1.25506.2.59.1.1.1.1.1)
read-only
Integer32
Integer32 (1..65535)
Process node.
As per the MIB.
