07-Layer 3 - IP Routing
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10007-Layer 3 - IP Routing
02-HH3C-IPRAN-DCN-MIB
02-HH3C-IPRAN-DCN-MIB 80.16 KB
HH3C-IPRAN-DCN-MIB (IPRAN)
About this MIB
This MIB describes how OSPF supports IPRAN DCN so that the gateway can manage and control remote devices, monitor running states of the devices, and obtain notifications when the devices come online or go offline.
MIB file name
hh3c-ipran-dcn.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpRanDcn(152)
Tabular objects
hh3cIpRanDcnInfoObject
About this table
This table contains network element information about the current device.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
hh3cIpRanDcnNeId (1.3.6.1.4.1.25506.2.152.1.1.1)
read-only
Hh3cIpRanNeId
OCTET STRING (4)
ID that uniquely identifies the local network element.
hh3cIpRanDcnNeIpType (1.3.6.1.4.1.25506.2.152.1.1.2)
read-only
InetAddressType
ipv4(1)
IP address type of the local network element.
hh3cIpRanDcnNeIp (1.3.6.1.4.1.25506.2.152.1.1.3)
read-only
InetAddress
OCTET STRING (0..255)
IP address of the local network element.
hh3cIpRanDcnMask (1.3.6.1.4.1.25506.2.152.1.1.4)
read-only
InetAddress
Subnet mask of the IP address of the local network element.
hh3cIpRanDcnMAC (1.3.6.1.4.1.25506.2.152.1.1.5)
read-only
MacAddress
OCTET STRING (6)
Bridge MAC of the local network element.
hh3cIpRanDcnVendor (1.3.6.1.4.1.25506.2.152.1.1.6)
read-only
DisplayString
SIZE (0..255)
Vendor of the local network element.
hh3cIpRanDcnNeInfoTable
About this table
This table contains information about all network elements in the network.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
hh3cIpRanDcnNeInfoNeId (1.3.6.1.4.1.25506.2.152.1.1.2.1.1)
read-only
Hh3cIpRanNeId
OCTET STRING (4)
ID that uniquely identifies the network element.
hh3cIpRanDcnNeInfoNeIpType (1.3.6.1.4.1.25506.2.152.1.1.2.1.2)
read-only
InetAddressType
ipv4(1)
IP address type of the network element.
hh3cIpRanDcnNeInfoNeIp (1.3.6.1.4.1.25506.2.152.1.1.2.1.3)
read-only
InetAddress
IP address of the network element.
hh3cIpRanDcnNeInfoMetric (1.3.6.1.4.1.25506.2.152.1.1.2.1.4)
read-only
Integer32
Standard MIB values.
Distance from the local network element to the remote node.
hh3cIpRanDcnNeInfoDeviceType (1.3.6.1.4.1.25506.2.152.1.1.2.1.5)
read-only
DisplayString
Device type of the network element.
hh3cIpRanDcnNeInfoMAC (1.3.6.1.4.1.25506.2.152.1.1.2.1.6)
read-only
MacAddress
OCTET STRING (6)
Bridge MAC of the network element.
hh3cIpRanDcnNeInfoVendor (1.3.6.1.4.1.25506.2.152.1.1.2.1.7)
read-only
DisplayString
Vendor of the network element.
hh3cIpRanDcnTrapObjects
About this table
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
hh3cIpRanDcnNeNumber (1.3.6.1.4.1.25506.2.152.1.2.1)
read-only
Integer32
Total number of online network elements.
hh3cIpRanDcnNeChangeMode (1.3.6.1.4.1.25506.2.152.1.2.2)
read-only
INTEGER
online (1), offline (2)
Network element state in the most recent notification.
hh3cIpRanDcnCompanyName (1.3.6.1.4.1.25506.2.152.1.2.3)
read-only
DisplayString
Device vendor name.
hh3cIpRanDcnDeviceType (1.3.6.1.4.1.25506.2.152.1.2.4)
read-only
DisplayString
Device type.
hh3cIpRanDcnDeviceMac (1.3.6.1.4.1.25506.2.152.1.2.5)
read-only
MacAddress
OCTET STRING(6)
Bridge MAC of the device.
Notifications
hh3cIpRanDcnNeOnline
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.152.1.3.0.1
A network element comes online.
Informational
OFF
A notification sent when a network element comes online.
Status control
ON
CLI: Use the auto-report command.
OFF
CLI: Use the undo auto-report command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.152.1.1.2.1.1 (hh3cIpRanDcnNeInfoNeId)
Network element ID.
No
Hh3cIpRanNeId
OCTET STRING (4)
1.3.6.1.4.1.25506.2.152.1.1.2.1.2 (hh3cIpRanDcnNeInfoNeIpType)
No
InetAddressType
ipv4(1)
1.3.6.1.4.1.25506.2.152.1.1.2.1.3 (hh3cIpRanDcnNeInfoNeIp)
No
InetAddress
1.3.6.1.4.1.25506.2.152.1.2.3 (hh3cIpRanDcnCompanyName)
Device vendor name.
No
DisplayString
1.3.6.1.4.1.25506.2.152.1.2.4 (hh3cIpRanDcnDeviceType)
Device type.
No
DisplayString
1.3.6.1.4.1.25506.2.152.1.2.5 (hh3cIpRanDcnDeviceMac)
No
MacAddress
OCTET STRING (6)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cIpRanDcnNeOffline
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.152.1.3.0.2
A network element goes offline.
Informational
OFF
A notification sent when a network element goes offline.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Network element ID.
No
Hh3cIpRanNeId
OCTET STRING (4)
No
InetAddressType
ipv4(1)
No
InetAddress
Recommended action
