- 03-Security Configuration Guide
- 01-Security zone configuration
- 02-Security policy configuration
- 03-ASPF configuration
- 04-Session management
- 05-Object group configuration
- 06-IP source guard configuration
- 07-AAA configuration
- 08-802.1X configuration
- 09-User identification configuration
- 10-Password control configuration
- 11-Portal configuration
- 12-MAC authentication configuration
- 13-IPoE configuration
- 14-Public key management
- 15-PKI configuration
- 16-SSH configuration
- 17-SSL configuration
- 18-Connection limit configuration
- 19-Attack detection and prevention configuration
- 20-Server connection detection configuration
- 21-ARP attack protection configuration
- 22-ND attack defense configuration
- 23-uRPF configuration
- 24-IP-MAC binding configuration
- 25-APR configuration
- 26-Keychain configuration
- 27-Crypto engine configuration
- 28-MAC learning through a Layer 3 device configuration
- 29-SMS configuration
25-APR configuration | 110.79 KB |
APR signature library management
Restrictions: Licensing requirements for APR
Configuring a user-defined NBAR rule
Configuring a risk type for a user-defined application
Configuring application groups
Enabling application statistics on an interface
Configuring detection thresholds for categorizing an application as type other
Managing the APR signature library
Restrictions and guidelines for APR signature library management
Scheduling an automatic update for the APR signature library
Triggering an automatic update for the APR signature library
Performing a manual update for the APR signature library
Rolling back the APR signature library
Display and maintenance commands for APR
Configuring APR
About APR
The application recognition (APR) feature recognizes application protocols of packets for features such as QoS, ASPF, and bandwidth management.
APR uses the following methods to recognize an application protocol:
· Port-based application recognition (PBAR).
· Network-based application recognition (NBAR).
PBAR
PBAR maps a port to an application protocol and recognizes packets of the application protocol according to the port-protocol mapping.
PBAR supports the following port-protocol mappings:
· Predefined—An application protocol uses the port defined by the system. You can modify the predefined mappings as needed.
· User-defined—An application protocol uses the port defined by the user.
PBAR offers the following mappings to maintain and apply user-defined port configuration:
· General port mapping—Maps a user-defined port to an application protocol. All packets destined for that port are regarded as packets of the application protocol. For example, if port 2121 is mapped to FTP, all packets destined for that port are regarded as FTP packets.
· Host-port mapping—Maps a user-defined port to an application protocol for packets to or from some specific hosts. For example, you can establish a host-port mapping so that all packets destined for the network segment 10.110.0.0/16 on port 2121 are regarded as FTP packets. To define the range of the hosts, you can specify the ACL, the host IP address range, or the subnet.
Host-port mapping can be further divided into the following categories:
¡ ACL-based host-port mapping—Maps a port to an application protocol for the packets matching the specified ACL.
¡ Subnet-based host-port mapping—Maps a port to an application protocol for the packets sent to the specified subnet.
¡ IP address-based host-port mapping—Maps a port to an application protocol for the packets destined for the specified IP addresses.
APR selects a port mapping to recognize the application protocol of a packet in the following order:
· IP address-based port mapping.
· Subnet-based port mapping.
· ACL-based host-port mapping.
· General port mapping.
For the same type of mappings, the port mapping with a transport layer protocol has higher priority than the mapping without a transport layer protocol.
NBAR
NBAR uses predefined or user-defined NBAR rules to match packet contents to recognize the application protocols of packets that match the applied object policy.
NBAR can recognize the following application types:
· Predefined—Defined by NBAR rules in the APR signature library.
· User-defined—Defined by user-configured NBAR rules.
Application group
You can add application protocols that have similar signatures or restrictions to an application group. APR recognizes packets of the application protocols by matching the packet contents with the signatures or restrictions. If a packet is recognized as the packet of an application protocol in the application group, the packet is considered to be the packet of the application group. Features such as ASPF and bandwidth management can handle packets belonging to the same group in batch.
You can add application protocols to an application group by using the following methods:
· Add application protocols one by one to the application group.
· Copy application protocols from another application group to the application group.
APR signature library is a resource library of character string signatures for application recognition. It includes PBAR and NBAR signatures. To meet the changing requirements for application recognition, you must update the APR signature library in a timely manner and roll back the APR signature library as needed.
APR signature library update
You can update the APR signature library by using one of the following methods:
· Automatic update.
The device automatically downloads the most up-to-date APR signature file to update its local signature library periodically.
· Triggered update.
The device downloads the most up-to-date APR signature file to update its local signature library immediately after you trigger the update operation.
· Manual update.
Use this method when the device cannot obtain the APR signature file automatically.
You must first download the most up-to-date APR signature file manually. The device then obtains the downloaded file to update its local signature library.
APR signature library rollback
You can perform the rollback operation if high error rate or abnormality occurs when the device uses the current APR signature library for application recognition.
You can roll back the current APR signature library to the last version or to the factory version.
To update the APR signature library, you must purchase and install the appropriate license. After the license expires, APR can still use the existing signature library but cannot update the signature library. For information about licenses, see license management in Fundamentals Configuration Guide.
APR tasks at a glance
To configure APR, perform the following tasks:
2. Configuring a user-defined NBAR rule
3. Configuring a risk type for a user-defined application
4. Configuring application groups
5. Enabling application statistics on an interface
6. Configuring detection thresholds for categorizing an application as type other
7. Managing the APR signature library
Configuring PBAR
1. Enter system view.
2. Configure a port mapping.
Choose the options to configure as needed:
¡ Configure a general port mapping:
port-mapping application application-name port port-number [ protocol protocol-name ]
¡ Configure an ACL-based host-port mapping:
port-mapping application application-name port port-number [ protocol protocol-name ] acl [ ipv6 ] acl-number
¡ Configure a subnet-based host-port mapping:
port-mapping application application-name port port-number [ protocol protocol-name ] subnet { ip ipv4-address { mask-length | mask } | ipv6 ipv6-address prefix-length } [ vpn-instance vpn-instance-name ]
¡ Configure an IP address-based host-port mapping:
port-mapping application application-name port port-number [ protocol protocol-name ] host { ip | ipv6 } start-ip-address [ end-ip-address ] [ vpn-instance vpn-instance-name ]
By default, all application protocols are mapped to well-known ports.
If the specified application protocol does not exist, the system first creates the protocol.
You can configure user-defined NBAR rules if predefined NBAR rules cannot meet user needs. The predefined NBAR rules cannot be deleted or modified.
A user-defined NBAR rule can contain the following match criteria:
· Signatures.
· Destination IP subnet.
· Source IP subnet.
· Direction at which the application is recognized.
· Port number.
You can configure more than one match criterion for the NBAR rule. To match the NBAR rule, packets must match all the configured match criteria in the rule. If multiple signatures are configured, packets must match a minimum of one signature.
2. Create a user-defined NBAR rule and enter its view.
nbar application application-name protocol { http | tcp | udp }
3. (Optional.) Configure the description of the NBAR rule.
By default, the user-defined NBAR rule is described as User defined application.
4. Configure a signature and enter NBAR rule signature view.
signature [ signature-id ] [ field field-name ] [ offset offset-value ] { hex hex-vector | regex regex-pattern | string string }
By default, no signatures are configured for an NBAR rule.
5. (Optional.) Configure a detection item for the signature.
detection detection-id field field-name match-type { exclude | include } { hex hex-vector | regex regex-pattern | text text-string } [ offset offset-value [ depth depth-value ] | relative-offset relative-offset-value [ relative-depth relative-depth-value ] ]
By default, no detection items are configured for a signature.
6. Return to user-defined NBAR rule view.
7. (Optional.) Specify a destination IP subnet.
destination ip ipv4-address [ mask-length ]
By default, an NBAR rule matches packets with any destination IP address.
8. (Optional.) Specify a source IP subnet.
source ip ipv4-address [ mask-length ]
By default, an NBAR rule matches packets with any source IP address.
9. (Optional.) Specify a direction.
direction { to-client | to-server }
By default, an NBAR rule matches packets in both directions.
10. (Optional.) Specify a port number or port range.
service-port { port-num | range start-port end-port }
By default, an NBAR rule matches packets of all port numbers.
11. (Optional.) Set the maximum detected length.
apr set detectlen bytes
By default, the maximum detected length is not set for an NBAR rule.
12. (Optional.) Disable the user-defined NBAR rule.
disable
By default, a user-defined NBAR rule is enabled.
13. Activate the user-defined NBAR rule.
inspect activate
For information about this command, see DPI engine commands in DPI Command Reference.
A user-defined application can have multiple or no risk types.
The more risk types a user-defined application has, the higher risk level the application has. You can configure security policies according to the risk level.
The risk types for predefined applications are automatically generated by the APR signature library.
Before configuring risk types, you must update the APR signature library to the latest version.
The user-defined application must already exist.
2. Enter user-defined application view.
user-defined-application application-name
3. Configure a risk type for the user-defined application.
risk type risk-type
By default, a user-defined application does not have any risk type.
2. Create an application group and enter its view.
app-group group-name
3. (Optional.) Configure the description of the application group.
By default, the description is "User-defined application group".
4. Add application protocols to the group.
¡ Copy all application protocols from another group to the group.
copy app-group group-name
Execute this command multiple times to copy application protocols from multiple groups to the current group.
¡ Add an application protocol to the group.
include application application-name
By default, an application group does not contain any application protocols.
When the application statistics feature is enabled on an interface, the device separately counts the number of packets or bytes that the interface has received or sent for each application protocol. It also calculates the transmission rates of the interface for these protocols.
To display application statistics, use the display application statistics command.
The application statistics feature consumes a large amount of system memory. When the system generates an alarm for lack of memory, disable the application statistics feature on all interfaces.
2. Enter Layer 3 interface view.
3. Enable application statistics on the interface.
application statistics enable [ inbound | outbound ]
If you do not specify the inbound or outbound keyword, this command enables the application statistics feature in both the inbound and outbound directions of the interface.
If the device cannot identify the application to which the packets of a protocol belongs after detection thresholds are reached, it categorizes the packets as belonging to type other.
You can configure both the packet count threshold and the payload length threshold for the same protocol.
2. Configure detection thresholds for categorizing an application as type other.
apr protocol protocol-name detect-threshold { packet-count count | payload-length length } application-other
By default, the device uses predefined detection thresholds in the signature library for categorizing an application as type other.
For a successful APR signature library update or rollback, do not delete the /dpi/ folder in the root directory on the device storage media.
Do not update or roll back the APR signature library when the remaining system memory reaches any alarm threshold. Insufficient memory causes update or rollback failure and affects the operation of NBAR. For information about memory alarm thresholds, see device management in Fundamentals Configuration Guide.
You can update only one APR signature library at a time. If an APR signature library is being updated, please wait for the update to complete before updating another APR signature library.
If the device can access the signature library services on the official website, you can schedule an automatic update. The automatic update enables the device to automatically update the local APR signature library at the scheduled update time.
For a successful automatic update, make sure the following requirements are met:
· The device can obtain the IP address of the official website through static or dynamic domain name resolution.
· The device can access the signature library services on the official website.
For information about DNS, see Layer 3—IP Services Configuration Guide.
2. Enable the automatic update feature and enter auto-update configuration view.
apr signature auto-update
By default, the automatic update feature is disabled.
3. Configure the update schedule.
By default, the device automatically updates the APR signature library between 02:01:00 to 04:01:00 every day.
4. (Optional.) Overwrite the current signature file.
override-current
By default, the current APR signature file is not overwritten for an update operation. Instead, the device will back up the current APR signature file.
Anytime you find a release of new signature version on the official website, you can trigger the device to immediately update the local APR signature library.
For a successful triggered update, make sure the following requirements are met:
2. Trigger an automatic update for the APR signature library.
apr signature auto-update-now
If the device cannot access the signature library services on the official website, use one of the following methods to manually update the APR signature library on the device:
· Local update—By using the locally stored APR signature file.
The APR signature file must be stored on the mater device for a successful update.
· FTP/TFTP update—By using the APR signature file stored on the FTP or TFTP server.
2. Manually update the APR signature library.
apr signature update [ override-current ] file-path
Each time a rollback operation is performed, the device backs up the APR signature library of the current version. If you repeat the rollback to the last version operation multiple times, the APR signature library will repeatedly switch between the current version and the last version.
To ensure that the APR signature library can be successfully rolled back to the last version, back up the current APR signature library each time you update the library.
2. Roll back the APR signature library.
apr signature rollback { factory | last }
Task |
Command |
Display information about application groups. |
display app-group [ name group-name ] |
Display information about application protocols. |
display application [ name application-name | pre-defined | user-defined ] |
Display statistics for application protocols. |
display application statistics [ direction { inbound | outbound } | interface interface-type interface-number [ slot slot-number ] | name application-name ] * |
Display statistics for application protocols on an interface in descending order based on the specified criteria. |
display application statistics top number { bps | bytes | packets | pps } interface interface-type interface-number [ slot slot-number ] |
Display detection threshold settings for applications categorized as type other. |
display apr protocol [ protocol-name ] detection-threshold-other |
Display APR signature library information. |
display apr signature library |
Display information about predefined port mappings. |
display port-mapping pre-defined |
Display information about user-defined port mappings. |
display port-mapping user-defined [ application application-name | port port-number ] |
Clear application statistics for interfaces. |
reset application statistics [ interface interface-type interface-number ] |
