- 03-Monitor
- 01-Application analysis center
- 02-Blacklist logs
- 03-Single-packet attack logs
- 04-Scanning attack logs
- 05-Flood attack logs
- 06-Threat logs
- 07-Reputation logs
- 08-URL filtering logs
- 09-File filtering logs
- 10-Data filtering logs
- 11-Security policy logs
- 12-IPCAR logs
- 13-Sandbox logs
- 14-NAT logs
- 15-SSL VPN user access logs
- 16-SSL VPN access resource logs
- 17-Terminal status
- 18-DLP logs
- 19-Zero trust policy logs
- 20-Application audit logs
- 21-System logs
- 22-Configuration logs
- 23-Traffic logs
- 24-Load balancing logs
- 25-TopN traffic
- 26-Security policy hit analysis
- 27-TopN threats
- 28-TopN URL filtering statistics
- 29-TopN file filtering statistics
- 30-Attack defense statistics
- 31-Server load balancing statistics
- 32-Outbound link load balancing statistics
- 33-Transparent DNS proxy statistics
- 34-Connection rate ranking
- 35-DLP statistics
- 36-TopN traffic trends
- 37-Security policy hit trend analysis
- 38-TopN threat trends
- 39-TopN URL filtering trends
- 40-TopN file filtering trends
- 41-Link trend
- 42-Routing policy trends
- 43-Virtual server trend
- 44-Server farm trends
- 45-Real server trend
- 46-Domain Requested Times Trend
- 47-TopN file filtering trends
- 48-Online SSL VPN users trend
- 49-Botnet analysis
- 50-Asset security
- 51-Threat case management
- 52-Report settings
- 53-Session list
- 54-LB session information
- 55-DNS cache information
- 56-User information center
- 57-IPv4 online users
- 58-IPv6 online users
- 59-MAC authentication online users
- 60-Terminal status
- 61-Asset scan
- 62-Ping
- 63-Tracert
- 64-Packet capture
- 65-Webpage Diagnosis
- 66-Diagnostic Info
- 67-Packet trace
- 68-Load balancing test
- 69-IPsec diagnosis
- 70-Risk analysis
- 71-Content moderation logs
- 72-Content security top
| 68-Load balancing test | 31.08 KB |
Load balancing test
Introduction
The administrator can test the load balancing result by specifying the protocol, source IPv4/IPv6 address, source port number, destination IPv4/IPv6 address, and destination port number.
Performing a load balancing test
1. Select Monitor > Diagnosis Center > Load Balancing Test.
2. Configure test parameters.
Table 1 Test parameter configuration items
Item |
Slot number |
Specify the slot number to be tested. |
IP type |
IP address type: · IPv4 · IPv6 |
VPN instance |
Specify the VPN instance to be tested. |
Destination IPv4/IPv6 address |
Specify the destination IPv4/IPv6 address to be tested. Typically, specify the IP address of the virtual server. |
Source IPv4/IPv6 address |
Specify the source IPv4/IPv6 address to be tested. |
Protocol layer |
Specify the layer of the information that can be identified by load balancing. · Layer 4: Identifies network layer and transport layer information. · Layer 7: Identifies network layer, transport layer, and application layer information. |
Layer 4 protocol |
Select a way to identify a protocol: · Protocol name · Protocol number |
Protocol name |
Specify the protocol to be tested: · ICMP · TCP · UDP |
Protocol number |
Enter the number of the protocol to be tested. |
Layer 7 protocol |
Specify a way to identify an HTTP packet: · Import HTTP packet · Construct HTTP packet |
Import HTTP packet |
Import the HTTP packet to be tested. The file containing the HTTP packet content must be suffixed with .txt, and cannot be larger than 5000 bytes. |
HTTP request method |
Specify an HTTP request method: · GET · POST |
URL |
Specify a URL for the HTTP packet, case sensitive. A URL can contain letters, digits, hyphens (-), underscores (_), and periods (.). The URL cannot contain consecutive periods and question marks (?). |
HTTP packet header |
Specify a space-separated list of up to 10 HTTP packet headers. A header cannot contain question marks (?). |
HTTP packet content |
Specify the content of the HTTP packet body. The HTTP packet content cannot contain question marks (?). |
Destination port number |
Enter the destination port number to be tested. Support for this parameter depends on the protocol. |
Source port number |
Enter the source port number to be tested. Support for this parameter depends on the protocol. |
3. Click Start testing. For more information about the test result, see Table 2.
Slot number |
Slot number of the device. The displayed value for this field depends on your configuration. |
Matched virtual server name |
Name of the matching virtual server. The displayed value for this field depends on your configuration. |
No virtual server is matched |
N/A |
Matched class name |
Name of the matching class. The displayed value for this field depends on your configuration. |
Default action is matched |
N/A |
Matched server farm name |
Name of the matching default server farm. The displayed value for this field depends on your configuration. |
Matched link group name |
Name of the matching default link group. The displayed value for this field depends on your configuration. |
Forwarding mode |
Forwarding mode: · Load balancing is not performed because the destination address is the address of the local device. · Load balancing is not supported because an HTTP virtual server is matched. · Forwards packets. · Forwards packets to the real server. · Forwards packets to the link. · Drops packets. · Redirects packets. |
Selected real server name |
Name of the matching real server. The displayed value for this field depends on your configuration. |
Selected link name |
Name of the matching link. The displayed value for this field depends on your configuration. |
Scheduling algorithm used to select a real server |
Scheduling algorithm used to select the real server: · Predictor · Sticky method |
Scheduling algorithm used to select a link |
Scheduling algorithm used to select the link: · Predictor · Sticky method · Proximity |
Packet drop reason |
Packet drop reason: · Number of connections or bandwidth for the virtual server exceeded the limit. · No class is matched and no available server farm is configured. · No class is matched and no available link group is configured. · No available real server in the server farm. · No available link in the link group. · Action is drop. · A sticky entry was matched but the number of connections or bandwidth for the real server exceeded the limit. · A sticky entry was matched but the number of connections or bandwidth for the link exceeded the limit. · A class was matched but no available server farm exists in the action of the class. · A class was matched but no available link group exists in the action of the class. · The HTTP packet is invalid. · The HTTP request line is invalid. · The HTTP header is invalid. · The chunk HTTP content is invalid. |
