03-Monitor
HomeSupportSecurityH3C SecPath F5000 FirewallConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide(E1196 E8371)-6W70003-Monitor
Table of Contents
Related Documents
60-Terminal status
60-Terminal status 28.64 KB
Terminal status
This help contains the following topics:
·     Introduction
¡     Terminal heat map
¡     Terminal information
·     Restrictions and guidelines
Introduction
Terminal heat map
The terminal heat map offers a visual representation of the state of each terminal in each network segment. The terminal state can be normal, abnormal, or unreachable. You can search terminals by terminal state or block state. You can click the IP address of a terminal to take the following actions on the terminal:
·     Approve—Approves the terminal as legal so the traffic from and to the terminal is permitted after the terminal information changes. After the information of a terminal changes, the traffic from and to the terminal will be denied if the terminal identification function is in whitelist mode and the action is block. If you trust the new terminal information, you can approve the terminal as legal after the terminal information changes.
·     Reidentify—Clears all terminal information for an IP address and re-identifies the terminal.
·     Block—Drops traffic from and to the terminal until the block duration expires or you unblock terminal.
The terminal heat map uses different colors to represent different states.
·     Unused (Gray)—The device does not detect the traffic from the terminal that uses the IP address or the terminal remains unreachable for more than seven days..
·     Normal (Green)—The device has detected the traffic from the terminal, and the traffic is between the bandwidth lower limit and the bandwidth upper limit.
·     Abnormal (Orange)—The terminal is in abnormal state, which includes the following situations:
¡     Poorly connected—The traffic from the terminal is below the bandwidth lower limit or above the bandwidth upper limit.
¡     Illegally used—The IP address of the terminal is used by another illegal terminal. The device detects this situation when terminal information changes.
·     Unreachable (Red)—The device detected the traffic from the terminal and then cannot detect the traffic. This state transitions to the Unused state after being kept for seven days.
·     Blocked (Purple)—The IP address of the terminal is administratively blocked.
·     Unknown (Brown)—The state of the terminal cannot be determined (whether the terminal is connected to the device cannot be determined).
This section displays information about and states of all terminals for monitoring purposes. By monitoring the MAC address, manufacturer, model information and approving information of a terminal, you can prevent its IP address from being illegally used or prevent it from being illegally replaced. You can block, unblock, approve, or re-identify a terminal as needed.
The block function can be used only after you click Enable globally on the Policies > Attack Defense > Blacklist page.
