- 03-Monitor
- 01-Application analysis center
- 02-Blacklist logs
- 03-Single-packet attack logs
- 04-Scanning attack logs
- 05-Flood attack logs
- 06-Threat logs
- 07-Reputation logs
- 08-URL filtering logs
- 09-File filtering logs
- 10-Data filtering logs
- 11-Security policy logs
- 12-IPCAR logs
- 13-Sandbox logs
- 14-NAT logs
- 15-SSL VPN user access logs
- 16-SSL VPN access resource logs
- 17-Terminal status
- 18-DLP logs
- 19-Zero trust policy logs
- 20-Application audit logs
- 21-System logs
- 22-Configuration logs
- 23-Traffic logs
- 24-Load balancing logs
- 25-TopN traffic
- 26-Security policy hit analysis
- 27-TopN threats
- 28-TopN URL filtering statistics
- 29-TopN file filtering statistics
- 30-Attack defense statistics
- 31-Server load balancing statistics
- 32-Outbound link load balancing statistics
- 33-Transparent DNS proxy statistics
- 34-Connection rate ranking
- 35-DLP statistics
- 36-TopN traffic trends
- 37-Security policy hit trend analysis
- 38-TopN threat trends
- 39-TopN URL filtering trends
- 40-TopN file filtering trends
- 41-Link trend
- 42-Routing policy trends
- 43-Virtual server trend
- 44-Server farm trends
- 45-Real server trend
- 46-Domain Requested Times Trend
- 47-TopN file filtering trends
- 48-Online SSL VPN users trend
- 49-Botnet analysis
- 50-Asset security
- 51-Threat case management
- 52-Report settings
- 53-Session list
- 54-LB session information
- 55-DNS cache information
- 56-User information center
- 57-IPv4 online users
- 58-IPv6 online users
- 59-MAC authentication online users
- 60-Terminal status
- 61-Asset scan
- 62-Ping
- 63-Tracert
- 64-Packet capture
- 65-Webpage Diagnosis
- 66-Diagnostic Info
- 67-Packet trace
- 68-Load balancing test
- 69-IPsec diagnosis
- 70-Risk analysis
- 71-Content moderation logs
- 72-Content security top
| 39-TopN URL filtering trends | 69.22 KB |
This help contains the following topics:
¡ URL category URL filter trend
¡ Source address URL filter trend
¡ Destination address URL filter trend
Introduction
The device analyzes users' Web resource access behaviors and generates the following types of URL filtering trend reports:
· User URL Filter Trend.
URL Category URL Filter Trend.
Website URL Filter Trend.
Source Address URL Filter Trend.
Destination Address URL Filter Trend.
These reports help you learn the trend of users' Web resource access behaviors, the peak Web resource access periods, and the most visited websites and website categories.
On each of the preceding report configuration page, you can customize conditions such as the time range and data range for statistics collection. Then, you can generate the report and export the report as needed.
User URL filter trend
Perform this task to generate the user-based URL filtering trend report.
1. Click Stats conditions in the top left corner of the page.
2. Configure the statistics collection conditions.
Table 1 Statistics collection condition configuration items for the user-based URL filtering trend report
Item |
User |
Select Top 5 users to collect statistics only for the top 5 users. Select Specify users and specify the users for statistics collection. |
Time range |
Select a time range from the list. Options are: · Today. · Past week. · Past month. · Custom. |
3. Click Start.
4. To export the user-based URL filtering trend report, click Export report.
Perform this task to generate the URL category-based URL filtering trend report.
Table 2 Statistics collection condition configuration items for the URL category-based URL filtering trend report
Item |
URL category |
Select Top 5 URL categories to collect statistics only for the top 5 URL categories. Select Specify URL categories and specify the URL categories for statistics collection. |
Time range |
3. Click Start.
4. To export the URL category-based URL filtering trend report, click Export report.
Website URL filter trend
Perform this task to generate the website-based URL filtering trend report.
Table 3 Statistics collection condition configuration items for the website-based URL filtering trend report
Item |
Website |
Select Top 5 websites to collect statistics only for the top 5 websites. Select Specify websites and specify the websites for statistics collection. |
Time range |
3. Click Start.
4. To export the website-based URL filtering trend report, click Export report.
Perform this task to generate the source address-based URL filtering trend report.
Table 4 Statistics collection condition configuration items for the source address-based URL filtering trend report
Item |
Source address |
Select Top 5 source addresses to collect statistics only for the top 5 source IP addresses. Select Specify source addresses and specify the source IP addresses for statistics collection. |
Time range |
3. Click Start.
4. To export the source address-based URL filtering trend report, click Export report.
Perform this task to generate the destination address-based URL filtering trend report.
Table 5 Statistics collection condition configuration items for the destination address-based URL filtering trend report
Item |
Destination address |
Select Top 5 destination addresses to collect statistics only for the top 5 destination IP addresses. Select Specify destination addresses and specify the destination IP addresses for statistics collection. |
Time range |
3. Click Start.
4. To export the destination address-based URL filtering trend report, click Export report.
