03-Monitor
HomeSupportSecurityH3C SecPath F5000 FirewallConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide(E1196 E8371)-6W70003-Monitor
Table of Contents
Related Documents
40-TopN file filtering trends
40-TopN file filtering trends 12.49 KB
Introduction
The File Type Trend page allows you to generate a trend report for the types of files transferred over a specific time range. You can use the information to customize file filtering profiles to reduce the information leakage and virus infection risks on the company network.
