- 03-Monitor
- 01-Application analysis center
- 02-Blacklist logs
- 03-Single-packet attack logs
- 04-Scanning attack logs
- 05-Flood attack logs
- 06-Threat logs
- 07-Reputation logs
- 08-URL filtering logs
- 09-File filtering logs
- 10-Data filtering logs
- 11-Security policy logs
- 12-IPCAR logs
- 13-Sandbox logs
- 14-NAT logs
- 15-SSL VPN user access logs
- 16-SSL VPN access resource logs
- 17-Terminal status
- 18-DLP logs
- 19-Zero trust policy logs
- 20-Application audit logs
- 21-System logs
- 22-Configuration logs
- 23-Traffic logs
- 24-Load balancing logs
- 25-TopN traffic
- 26-Security policy hit analysis
- 27-TopN threats
- 28-TopN URL filtering statistics
- 29-TopN file filtering statistics
- 30-Attack defense statistics
- 31-Server load balancing statistics
- 32-Outbound link load balancing statistics
- 33-Transparent DNS proxy statistics
- 34-Connection rate ranking
- 35-DLP statistics
- 36-TopN traffic trends
- 37-Security policy hit trend analysis
- 38-TopN threat trends
- 39-TopN URL filtering trends
- 40-TopN file filtering trends
- 41-Link trend
- 42-Routing policy trends
- 43-Virtual server trend
- 44-Server farm trends
- 45-Real server trend
- 46-Domain Requested Times Trend
- 47-TopN file filtering trends
- 48-Online SSL VPN users trend
- 49-Botnet analysis
- 50-Asset security
- 51-Threat case management
- 52-Report settings
- 53-Session list
- 54-LB session information
- 55-DNS cache information
- 56-User information center
- 57-IPv4 online users
- 58-IPv6 online users
- 59-MAC authentication online users
- 60-Terminal status
- 61-Asset scan
- 62-Ping
- 63-Tracert
- 64-Packet capture
- 65-Webpage Diagnosis
- 66-Diagnostic Info
- 67-Packet trace
- 68-Load balancing test
- 69-IPsec diagnosis
- 70-Risk analysis
- 71-Content moderation logs
- 72-Content security top
| 47-TopN file filtering trends | 23.72 KB |
URL visit trends
Introduction
The administrator can set statistics conditions to view URL visit trends for virtual servers, statistics nodes, and visit sources.
Table 1 Common filter option
Item |
Statistics object |
Select a statistics object: · Virtual server · Statistics node · Visit source |
Table 2 Filter options for virtual server statistics object
Item |
Query scope |
Select the query scope for the virtual server statistics object: · Top 5 virtual servers: Collects URL visit trend statistics for the top 5 virtual servers by URL visit count. · Specify virtual servers: Collects URL visit trend statistics for the specified virtual servers. |
Virtual server name |
Specify the names of the virtual servers for which the URL visit trend statistics are collected. This parameter is available only when you select Specify virtual servers for Query scope. |
Table 3 Filter options for statistics node statistics object
Item |
Specify a virtual server. The URL visit trend statistics are collected for the HTTP statistics nodes that belong to the virtual server. |
Query scope |
Select the query scope for the statistics node statistics object: · Top 5 statistics nodes: Collects URL visit trend statistics for the top 5 statistics nodes of the specified virtual server by URL visit count. · Specify statistics nodes: Collects URL visit trend statistics for the specified statistics nodes of specified virtual server. |
Statistics node name |
Specify the names of the statistics nodes for which the URL visit trend statistics are collected. This parameter is available only when you select Specify statistics nodes for Query scope. |
Table 4 Filter options for visit source statistics object
Item |
Specify a virtual server. The URL visit trend statistics are collected for the visit sources that belong to the virtual server. |
Specify the name of the statistics node accessed by the visit source. |
Query scope |
Select the query scope for the visit source statistics object: · Top 5 visit sources: Collects URL visit trend statistics for the top 5 visit sources by URL visit count. · Specify visit sources: Collects URL visit trend statistics for the specified visit sources. |
Visit source name |
Specify the source address object group names or source IP addresses for which the URL visit trend statistics are collected. This parameter is available only when you select Specify visit sources for Query scope. |
Click Start to enable the device to collect URL access statistics based on the specified statistics conditions.
